[geos-devel] Fw: 3.0?
S Knox roxyknox at yahoo.co.uk
Fri Oct 31 13:06:01 EDT 2008
Yes, I'll try and do that this weekend, but it will be towards the end, as am away for the weekend.
Regarding the SVN checkout - I tried this, however I noticed that the files required for configure to work are not present. [You might have to make some allowances for my inexperience here!!]. I take it this is normal, and one should use autogen.sh I tried this, however it didn't work and I got some error messages, which I can't remember off the top of my head so I had to use the tarball.
Have a good weekend
Stephen
From: Mark Cave-Ayland <mark.cave-ayland at ilande.co.uk>
To: GEOS Development List <geos-devel at lists.osgeo.org>
Sent: Friday, 31 October, 2008 14:14:59
Subject: Re: [geos-devel] Fw: 3.0?
> Sorry, forgot to mention that HCoordinate.cpp changed as well in order to
> be able to compile on Cygwin, as per last post. Here's the file I used>
> Regards
> Stephen Knox
Hi Stephen,
Okay, it's a little difficult to work out the changes from the complete
files. Would you be able post a diff between your geos-svn directory tree
that does compile, and the one you have changed? Something like:
diff -cr geos-svn.orig geos-svn.compiles
Also, can you try compiling using a proper SVN checkout from GEOS 3.0
branch? This is really just to make sure that the tarball is being updated
correctly.
Many thanks,
Mark.
geos-devel mailing list
http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20081031/0c9e9e6c/attachment.html
