[geos-devel] [Fwd: [Boost-users] [boost]
Formal Review: Boost.Polygon starts today August 24, 2009]
Martin Davis
mbdavis at refractions.net
Mon Aug 31 13:18:13 EDT 2009
Hmmm... GEOS comes off rather badly compared to GGL. Is that because of
memory access issues? Or perhaps the fact that less code is inlined?
Hartmut Kaiser wrote:
> FWIW, there will be a second Boost library review soon: GGL (Generic
> Geometry Library, here: http://trac.osgeo.org/ggl/), which is yet another
> project currently hosted by OSGEO. GGL is much larger than BP, more similar
> to GEOS (full SFS geometry, etc.). The comparing measurement I saw tend to
> show GGL being even than everything else, for instance:
> 100 points per ellipse, with area check:
> -> geos: resulting area: 69.68616316800, time: 13.641 seconds
> -> ggl: resulting area: 69.68616316800, time: 1.156 seconds
> -> gpc: resulting area: 69.68616316800, time: 9.297 seconds
> -> polygon: resulting area: 69.68616202400, time: 108.563 seconds
> -> terralib: resulting area: 69.68616316800, time: 4.672 seconds
> These results are colored by the check of the area. Checking without gives:
> 100 points per ellipse:
> -> geos time: 13.437 seconds
> -> ggl time: 1.140 seconds
> -> gpc time: 9.047 seconds
> -> polygon time: 38.688 seconds
> -> terralib time: 4.609 seconds
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
