[geos-devel] [postgis-devel] GEOS 3.4.1 is out
Greg Troxel
gdt at ir.bbn.com
Tue Aug 20 07:13:34 PDT 2013
Sandro Santilli <strk at keybit.net> writes:
> On Mon, Aug 19, 2013 at 08:45:11AM -0400, Greg Troxel wrote:
>> r3866 removed it from geos_HEADERS in include/geos/Makefile.am, as part
>> of "#601 do not incude platform.h in tar ball." It makes sense not to
>> include it in the tarball as it's a generated file, but taking it out of
>> geos_HEADERS prevents the installation as well.
>> I think we want nodist_geos_HEADERS = platform.h.
> Agreed, and committed in trunk as r3896
> Can you double-check it works fine on your end ?
> If so, it shall be backported to 3.4 and 3.3 branches.
I did 'make dist' on trunk, and (locally) update the package to that,
and got platform.h installed.
So I think the change is fine.
>> >> new empty directory /usr/pkg/lib/geos
>> The problem is in php/Makefile.am. pkglib_LTLIBRARIES is defined, and
>> it seems that required directory is created, even if "if ENABLE_PHP" is
>> false and the rest of the code isn't executed. Arguably this is an
>> automake bug. I would suggest hoisting the if ENABLE_PHP conditional up
>> a level and only having the SUBDIRS+=php if php is enabled, which will
>> prevent executing any of the php/Makefile.am.
> I actually don't get the pkg/lib/geos dir created when I configure
> here. Not with a false ENABLE_PHP, at least.
> $ ./configure --prefix=/tmp/gt && make install
> $ find /tmp/gt/ | grep pkg # no hits
With trunk and a different box, I didn't get $pkglibdir created. So I'm
not sure what's going on, but suspect an automake bug.
If I figure anything out I'll file a ticket.
Also, I ran diff from the 3.4 branch to trunk (to figure out if php
pkglibdir handling had changed, which it hadn't), and there were a
number of unexpected differences (from memory, couldn't send earlier due
to netflake):
3.4.1 NEWS entries missing from trunk
ChangeLog had far far more differences than I would expect, and looks
to be a summary in one branch, more verbose in the other
whitespace differences in the recent nodist_ fix
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130820/833b6e4d/attachment.pgp>
