[geos-devel] Weekly Report 5 - Adding Voronoi Diagram to GEOS
vishal tiwari hi.vishal123 at gmail.com
Tue Jul 23 01:35:20 PDT 2013
I tried to send a pull request for Triangle class, but seems like every
commit has been sent for the review(new to git), sorry for that. I ll send
it as subsets and i ll clean it as u mentioned before.
Thanks,
Vishal
On 23 July 2013 11:38, Sandro Santilli <strk at keybit.net> wrote:
> Vishal, I think the biggest issue so far has been making peer reviewing
> easy.
> One way to improve that would be to cleanup a subset of what you've been
> modifying and submit it for inclusion upstream. The subset should be small
> enough to be easy to read and complete with testcases. I'm thinking it
> could be changes to the Triangle class with its tests, and next one
> could maybe be changes to the CoordinateList class, with relative tests.
> Cleaning that up means removing all changes that are not directly
> related to the focus of the work. For example making sure that you
> don't have style changes for a change that's addressing adding new
> functionality. The diff must be _easy_ to read as that gives your
> code better opportunities to be commented on.
> Looking forward for your pull request as soon as possible, I'd like
> to have the time to merge it in before evaluation time.
> Thank you for the care you'll put into this :)
> --strk;
> On Sat, Jul 20, 2013 at 01:45:54AM +0530, vishal tiwari wrote:
> > Hey,
> > My week 5 report is as follows:
> > *1. Work Done:*
> >    - This week was spent mainly, in fixing the memory leaks and
> >    segmentation faults. I have tested all the methods and classes that
> have
> >    been ported. Everything seems to be working fine. Thus completion of
> the
> >    Voronoi port via C++ interface.
> > *2. Problems Faced:*
> >    - No problems other than memory leaks and seg faults.
> > *3. Work to be done in the next week:*
> >    - Check for bugs because of the coming evaluation.
> >    - I will look into, how the C-api of geos has been implemented.
> > wiki link: http://trac.osgeo.org/geos/wiki/GSoC
> > Repository link : https://github.com/vishaltiwari/libgeos
> > Thanks and kind regards,
> > Vishal Tiwari
> > Undergraduate
> > Computer Science and Engineering
> > Lab for Spatial Informatics
> > IIIT-Hyderabad
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Vishal Tiwari
Undergraduate
IIIT-Hyderabad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130723/ae7dce8d/attachment.html>
