[geos-devel] Thoughts on Backporting the emit warning message to GEOS 3.6 and GEOS 3.5
Regina Obe lr at pcorp.us
Fri Oct 6 14:05:59 PDT 2017
Slight correction I meant
"would be subjected to the warning if they are compiling source code that
uses the C++ API."
-----Original Message-----
Sent: Friday, October 06, 2017 5:04 PM
To: 'GEOS Development List' <geos-devel at lists.osgeo.org>
Subject: Thoughts on Backporting the emit warning message to GEOS 3.6 and
GEOS 3.5
I'm only softly proposing this but want to get a feel if anyone has issues
before we do.
https://git.osgeo.org/gogs/geos/geos/pulls/14
I would like to back port this pull to GEOS 3.6 and GEOS 3.5 branches.
The reason being is
1) It's just a warning that shows when compiling code that uses the C++ API
so doesn't impact existing compiles.  No one has to change their compile
scripts.
But users using libgeos-dev for example from packages would be subjected to
the warning if they are using a project that uses the C++ API.
2) It gives people notice compiling projects using GEOS C++ API, that their
use may be in jeopardy in future and they might want to consider switching
to the C API or brace for breaking changes to the C++ API.
That warning will hopefully give folks enough time to switch to C-API so
that we feel comfortable doing some spring cleaning breaking changes to the
underlying C++ API in GEOS 3.8 or 4.0 with minimal effect on existing users.
Thanks,
Regina
