[geos-devel] Correct use of setPrecision
    Daniel Baston
    dbaston at gmail.com
    Wed Sep  6 06:03:14 PDT 2017
My understanding is that precision models are considered only in the
overlay options (and not in the geometry predicates).
Dan
On Mon, Sep 4, 2017 at 5:13 AM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On 4 September 2017 at 17:29, Sandro Santilli <strk at kbt.io> wrote:
> > On Mon, Sep 04, 2017 at 04:28:32PM +1000, Nyall Dawson wrote:
> >> However, after looking into this in more depth I think the original
> >> python code is incorrectly used. It's being used by QGIS in order to
> >> set a "tolerance" on a spatial join operation - i.e. to consider that
> >> two geometries which are 100m distant actually do intersect.
> >> If this is correct, is there any other way in GEOS to handle this
> situation?
> > How about using GEOSDistance ?
> Thanks - that's a good option for intersects tests. I'm not sure
> offhand if it would be translatable to the other geometry predicates,
> but then I'd say trying to do a 'touches' or 'contains' test with a
> tolerance would be quite an edge case anyway.
> Nyall
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20170906/7fc9b027/attachment.html>
