[geos-devel] [GEOS] #894: FreeBSD and MacOSX failures on 3.7.0 - group: geos::geom::CoordinateArraySequenceFactory, test: test<1> assertion failed
    geos-trac at osgeo.org
    Mon Aug 27 19:52:33 PDT 2018
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  3.7.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by robe):
 More notes from gdt on mailing list
 https://lists.osgeo.org/pipermail/geos-devel/2018-August/008490.html
 I don't see this on NetBSD/7 amd64, which uses gcc 4.8.
 I did a build on macos 10.11, which uses clang (but a similar Intel
 processor):
   Apple LLVM version 8.0.0 (clang-800.0.42.1)
   Target: x86_64-apple-darwin15.6.0
   Thread model: posix
   InstalledDir: /Library/Developer/CommandLineTools/usr/bin
 and get the same failure as the bug.
 Specifically, if I run test 1 in that group, it fails:
   $ ./geos_unit geos::geom::CoordinateArraySequenceFactory 1
     GEOS Test Suite Application
   geos::geom::CoordinateArraySequenceFactory: [1=F]
   ---> group: geos::geom::CoordinateArraySequenceFactory, test: test<1>
        problem: assertion failed
   tests summary: failures:1 ok:0
 but tests 2,3,4,5 all pass.
 The test is in tests/unit/capi/GEOSGeomFromWKBTest.cpp in the sources, and
 is doing:
         // POINT(1.234 5.678)
         std::string wkt("POINT (1.234 5.678)");
         std::string wkb("01010000005839B4C876BEF33F83C0CAA145B61640");
         test_wkb(wkb, wkt);
 I don't know how to get it to produce the mismatching content; the
 --verbose option in --help is unrecognized, and I can't see how it would
 be reading the driver source.
 So I wonder if something in geos is sensitive to gcc/clang differences.
 (Vastly less likely, there could be a clang bug.)
Ticket URL: <https://trac.osgeo.org/geos/ticket/894#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
