[geos-devel] Death to auto_ptr?
Paul Ramsey
pramsey at cleverelephant.ca
Tue Jan 29 18:12:30 PST 2019
Because you don’t always just use the Ptr, because you’re in a crazy mixed code base and you might need to call the get() method or use std::move() or any number of things that require knowing that, yes, actually you’re using a unique_ptr<>
P
> On Jan 29, 2019, at 5:19 PM, Martin Davis <mtnclimb at gmail.com> wrote:
> Well, I raised a slightly dissenting opinion to removing the typedefs, and so did strk.
> Why not use a nice short name like GeomPtr to hide those ugly and hard-to-type <> ?
> @dbaston: there are many reasons for encapsulation. One worthy goal is to provide a simpler mental model...
> On Tue, Jan 29, 2019 at 11:56 AM Paul Ramsey <pramsey at cleverelephant.ca <mailto:pramsey at cleverelephant.ca>> wrote:
> Ah, yes, I had svn-3.5 checked out when I was running those searches. Whooops.
> Not much objection to getting rid of the typedefs [2] that I can see. Unless we really thing c++ is going to change the smart pointer implementations yet again. (an open question, I suppose)
> P
> [2] https://lists.osgeo.org/pipermail/geos-devel/2018-December/008750.html <https://lists.osgeo.org/pipermail/geos-devel/2018-December/008750.html>
>> On Jan 29, 2019, at 11:53 AM, Daniel Baston <dbaston at gmail.com <mailto:dbaston at gmail.com>> wrote:
>> I think auto_ptr has been removed from master already, no? I'd prefer to lose the typedefs as well, but last time we brought that up I recall there being some disagreement.
>> Dan
>> On Tue, Jan 29, 2019 at 2:19 PM Paul Ramsey <pramsey at cleverelephant.ca <mailto:pramsey at cleverelephant.ca>> wrote:
>> Any reason not to renovate the code base and remote the various uses
>> of auto_ptr in favour of unique_ptr and strip out the various typedefs
>> at the same time so that we uniformly just use std::unique_ptr<> right
>> in code where folks can see it?
>> P.
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org <mailto:geos-devel at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/geos-devel <https://lists.osgeo.org/mailman/listinfo/geos-devel>_______________________________________________
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190129/ec408ce6/attachment.html>
