[geos-devel] Death to auto_ptr?
Martin Davis mtnclimb at gmail.com
Tue Jan 29 18:27:09 PST 2019
Yes...  was just thinking that the most common case should be
highlighted/encouraged by making a typedef.
Whatever the most common case is...
On Tue, Jan 29, 2019 at 6:12 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Because you don’t always just use the Ptr, because you’re in a crazy mixed
> code base and you might need to call the get() method or use std::move() or
> any number of things that require knowing that, yes, actually you’re using
> a unique_ptr<>
> P
> On Jan 29, 2019, at 5:19 PM, Martin Davis <mtnclimb at gmail.com> wrote:
> Well, I raised a slightly dissenting opinion to removing the typedefs, and
> so did strk.
> Why not use a nice short name like GeomPtr to hide those ugly and
> hard-to-type <> ?
> @dbaston: there are many reasons for encapsulation.  One worthy goal is to
> provide a simpler mental model...
> On Tue, Jan 29, 2019 at 11:56 AM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> Ah, yes, I had svn-3.5 checked out when I was running those searches.
>> Whooops.
>> Not much objection to getting rid of the typedefs [2] that I can see.
>> Unless we really thing c++ is going to change the smart pointer
>> implementations yet again. (an open question, I suppose)
>> P
>> [2]
>> https://lists.osgeo.org/pipermail/geos-devel/2018-December/008750.html
>> On Jan 29, 2019, at 11:53 AM, Daniel Baston <dbaston at gmail.com> wrote:
>> I think auto_ptr has been removed from master already, no? I'd prefer to
>> lose the typedefs as well, but last time we brought that up I recall there
>> being some disagreement.
>> Dan
>> On Tue, Jan 29, 2019 at 2:19 PM Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>>> Any reason not to renovate the code base and remote the various uses
>>> of auto_ptr in favour of unique_ptr and strip out the various typedefs
>>> at the same time so that we uniformly just use std::unique_ptr<> right
>>> in code where folks can see it?
>>> P.
>>> geos-devel mailing list
>>> geos-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190129/6e6206ea/attachment-0001.html>
