[geos-devel] GEOS NG Regression Review
Paul Ramsey pramsey at cleverelephant.ca
Fri Sep 18 08:39:36 PDT 2020
> On Sep 18, 2020, at 2:39 AM, Joris Van den Bossche <jorisvandenbossche at gmail.com> wrote:
> Hi all,
> First, thanks for all the work on improving the overlay operations!
> I ran the test suites of Shapely and PyGEOS with GEOS master and DISABLE_OVERLAYNG=OFF.
> For PyGEOS there are 2 failing tests related to MakeValid. But both are just a change in coordinate order and solved by using spatial equality or normalizing the resulting and expected multipolygon first.
> And for Shapely there is 1 failing test caused by a union operation returning a GeometryCollection with the parts in a different order, so again only a normalization issue.
> So basically nothing to report. But that probably says more about the Shapely/PyGEOS test suites (which mostly test the *bindings* with simple cases, and don't include much complex geometry test cases deferring that to GEOS), than about OverlayNG not causing behaviour changes ;)
Every little bit counts! Thanks for testing!
P
> Best,
> Joris
> On Thu, 17 Sep 2020 at 17:18, Sandro Santilli <strk at kbt.io> wrote:
> On Thu, Sep 17, 2020 at 06:55:16AM -0700, Paul Ramsey wrote:
> > > On Sep 17, 2020, at 6:54 AM, Sandro Santilli <strk at kbt.io> wrote:
> > > On Wed, Sep 16, 2020 at 01:25:39PM -0700, Paul Ramsey wrote:
> > >>> https://docs.google.com/document/d/1TDm2aR4a7O41-soS-25Xog1EdQcjmvKCnKltxjbxOC0/edit#
> > >> * Despite worries, only one file in topology showed any differences. topogeo_addlinestring.sql needs to be looked at by a topology expert, Sandro do you think you could?
> > > A quick look suggests this is just a lack of normalization from
> > > the output of OverlayNG (did the old overlay normalize internally ?)
> > No, neither normalizes, it's wasted overhead except in testing. Things just come out of the graphs in different orders.
> Well the result seem to be compatible, just different order,
> so this case could be threated like the other ones of expecting
> different results based on GEOS version.
> --strk;
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
