[geos-devel] GEOS NG Regression Review
Joris Van den Bossche jorisvandenbossche at gmail.com
Fri Sep 18 02:39:53 PDT 2020
Hi all,
First, thanks for all the work on improving the overlay operations!
I ran the test suites of Shapely and PyGEOS with GEOS master and
DISABLE_OVERLAYNG=OFF.
For PyGEOS there are 2 failing tests related to MakeValid. But both are
just a change in coordinate order and solved by using spatial equality or
normalizing the resulting and expected multipolygon first.
And for Shapely there is 1 failing test caused by a union operation
returning a GeometryCollection with the parts in a different order, so
again only a normalization issue.
So basically nothing to report. But that probably says more about the
Shapely/PyGEOS test suites (which mostly test the *bindings* with simple
cases, and don't include much complex geometry test cases deferring that to
GEOS), than about OverlayNG not causing behaviour changes ;)
Best,
Joris
On Thu, 17 Sep 2020 at 17:18, Sandro Santilli <strk at kbt.io> wrote:
> On Thu, Sep 17, 2020 at 06:55:16AM -0700, Paul Ramsey wrote:
> > > On Sep 17, 2020, at 6:54 AM, Sandro Santilli <strk at kbt.io> wrote:
> > > On Wed, Sep 16, 2020 at 01:25:39PM -0700, Paul Ramsey wrote:
> https://docs.google.com/document/d/1TDm2aR4a7O41-soS-25Xog1EdQcjmvKCnKltxjbxOC0/edit#
> > >> * Despite worries, only one file in topology showed any differences.
> topogeo_addlinestring.sql needs to be looked at by a topology expert,
> Sandro do you think you could?
> > > A quick look suggests this is just a lack of normalization from
> > > the output of OverlayNG (did the old overlay normalize internally ?)
> > No, neither normalizes, it's wasted overhead except in testing. Things
> just come out of the graphs in different orders.
> Well the result seem to be compatible, just different order,
> so this case could be threated like the other ones of expecting
> different results based on GEOS version.
> --strk;
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20200918/2e74b3b3/attachment.html>
