[GRASS-SVN] r35681 - grass/trunk/locale/po
svn_grass at osgeo.org
Fri Jan 30 14:35:19 EST 2009
Author: neteler
Date: 2009-01-30 14:35:18 -0500 (Fri, 30 Jan 2009)
New Revision: 35681
grass/trunk/locale/po/grassmods_de.po
Robert Nuske: continued
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2009-01-30 19:05:22 UTC (rev 35680)
+++ grass/trunk/locale/po/grassmods_de.po 2009-01-30 19:35:18 UTC (rev 35681)
@@ -11,7 +11,7 @@
"Project-Id-Version: grassmods_de\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2009-01-09 23:29+0100\n"
-"PO-Revision-Date: 2009-01-02 22:29+0100\n"
+"PO-Revision-Date: 2009-01-30 16:56+0100\n"
"Last-Translator: Robert Nuske <rnuske at gwdg.de>\n"
"Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -94,6 +94,8 @@
"Use the same resolution as the input G3D map for the 2d output maps, "
"independent of the current region settings"
msgstr ""
+"Verwende dieselbe Auflösung wie die G3D-Eingabekarte für die 2D-"
+"Ausgabekarten. Dies ist unabhängig von der Auflösung der aktuellen Region. "
#: ../raster3d/r3.to.rast/main.c:152 ../raster3d/r3.to.rast/main.c:159
msgid "Unable to write raster row"
@@ -418,7 +420,7 @@
#: ../raster3d/r3.out.vtk/parameters.c:128 ../vector/v.out.vtk/main.c:89
#: ../raster/r.out.vtk/parameters.c:135
msgid "Correct the coordinates to fit the VTK-OpenGL precision"
-msgstr ""
+msgstr "Korrigiere die Koordinaten, um sie der VTK-OpenGL anzupassen."
#: ../raster3d/r3.out.vtk/writeVTKData.c:122
msgid "write_vtk_points: Writing point coordinates"
@@ -1032,9 +1034,8 @@
msgstr "Fehler beim Schließen der G3D-Datei."
#: ../locale/scriptstrings/r.li.setup_to_translate.c:1
-#, fuzzy
msgid "Configuration editor for r.li.'index'"
-msgstr "Konfigurationsdatei"
+msgstr "Konfigurationseditor für r.li.'index'."
#: ../locale/scriptstrings/r.li.setup_to_translate.c:2
msgid "raster, landscape structure analysis"
@@ -1042,11 +1043,11 @@
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
msgid "import GetFeature from WFS"
-msgstr ""
+msgstr "Importiert GetFeature eines WFS."
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
msgid "GetFeature URL starting with http"
-msgstr ""
+msgstr "GetFeature URL beginnend mit http"
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
msgid "Vector output map"
@@ -1055,6 +1056,8 @@
#: ../locale/scriptstrings/db.test_to_translate.c:1
msgid "Test database driver, database must exist and set by db.connect."
msgstr ""
+"Teste den Datenbank-Treiber. Die Datenbank muß existieren und mittels db."
+"connect verbunden sein."
#: ../locale/scriptstrings/db.test_to_translate.c:2
#: ../locale/scriptstrings/db.dropcol_to_translate.c:2
@@ -1072,9 +1075,8 @@
msgstr "Testname"
#: ../locale/scriptstrings/db.dropcol_to_translate.c:1
-#, fuzzy
msgid "Drops a column from selected attribute table"
-msgstr "Keine Attributtabelle erzeugen."
+msgstr "Löscht eine Spalte aus einer Attributtabelle."
#: ../locale/scriptstrings/db.dropcol_to_translate.c:3
#: ../locale/scriptstrings/db.droptable_to_translate.c:3
@@ -1083,9 +1085,8 @@
msgstr "Erzwinge das Löschen (benötigt um tatsächlich Dateien zu löschen)."
#: ../locale/scriptstrings/db.dropcol_to_translate.c:4
-#, fuzzy
msgid "Table from which to drop attribute column"
-msgstr "Skalierfaktor für die Werte der Attributspalte."
+msgstr "Tabelle von der eine Spalte gelöscht werden soll."
#: ../locale/scriptstrings/db.dropcol_to_translate.c:5
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:5
@@ -1094,7 +1095,7 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
msgid "Import Mapgen or Matlab vector maps into GRASS."
-msgstr ""
+msgstr "Importiert Mapgen oder Matlab Vektorkarten nach GRASS."
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
#: ../locale/scriptstrings/v.convert.all_to_translate.c:2
@@ -1106,33 +1107,27 @@
msgstr "Vektor, Import"
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
-#, fuzzy
msgid "Input map is in Matlab format"
-msgstr "Eingabekarte enthält keine Daten."
+msgstr "Eingabekarte liegt im Matlab-Format vor."
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
-#, fuzzy
msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr ""
-"Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die "
-"Koordinaten beinhaltet."
+msgstr "Erzeugt eine 3D Vektorpunktkarte aus 3 Spalten der Matlabdatei."
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
-#, fuzzy
msgid "Name of input file in Mapgen/Matlab format"
-msgstr "Name der Eingabe-Vektorkarte."
+msgstr "Name der Eingabedatei im Mapgen/Matlab Format."
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:10
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:11
-#, fuzzy
msgid "Name for output vector map (omit for display to stdout)"
-msgstr "Name der Vektorausgabekarte mit den angepassten Punkten im Fluss."
+msgstr ""
+"Name der Ausgabe-Vektorausgabekarte (auslassen für Ausgabe auf stdout)."
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
-#, fuzzy
msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr "von"
+msgstr "Importiert Länderdateien von geonames.org in eine Vektorpunktkarte."
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
@@ -1141,7 +1136,7 @@
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
msgid "Uncompressed geonames file from (with .txt extension)"
-msgstr ""
+msgstr "Unkomprimierte geonames-Datei (mit der Dateiendung .txt)."
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
#: ../locale/scriptstrings/v.centroids_to_translate.c:4
@@ -1152,9 +1147,8 @@
msgstr "Name für die Ausgabe-Vektorkarte"
#: ../locale/scriptstrings/v.centroids_to_translate.c:1
-#, fuzzy
msgid "Adds missing centroids to closed boundaries."
-msgstr "%d Linien zu Grenzen verwandelt"
+msgstr "Fügt fehlende Zentroide zu geschlossenen Grenzen hinzu."
#: ../locale/scriptstrings/v.centroids_to_translate.c:2
msgid "vector, centroid, area"
@@ -1165,9 +1159,8 @@
#: ../locale/scriptstrings/v.colors_to_translate.c:3
#: ../locale/scriptstrings/v.out.gps_to_translate.c:6
#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
-#, fuzzy
msgid "Name of input vector map"
-msgstr "von"
+msgstr "Name der Eingabe-Vektorkarte"
#: ../locale/scriptstrings/v.centroids_to_translate.c:5
msgid "Action to be taken"
@@ -1181,20 +1174,21 @@
msgstr "Layer-Nummer"
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
-#, fuzzy
msgid "Category number starting value"
-msgstr "Spaltenname für Kategoriewerte."
+msgstr "Startwert der Kategorienummern.goriewerte."
#: ../locale/scriptstrings/v.centroids_to_translate.c:8
#: ../vector/v.category/main.c:112
msgid "Category increment"
-msgstr ""
+msgstr "Inkrement für die Kategorienummern"
#: ../locale/scriptstrings/r.tileset_to_translate.c:1
msgid ""
"Produces tilings of the source projection for use in the destination region "
"and projection."
msgstr ""
+"Erzeugt Kacheln der der Quell-Projektion zur Verwendung in der Ziel-Region "
+"und -Projektion."
#: ../locale/scriptstrings/r.tileset_to_translate.c:2
msgid "raster, tiling"
@@ -1205,48 +1199,40 @@
msgstr "Erzeugt Ausgabe im Shell-Skript-Stil"
#: ../locale/scriptstrings/r.tileset_to_translate.c:4
-#, fuzzy
msgid "Produces web map server query string output"
-msgstr "Erzeugt Ausgabe im Shell-Skript-Stil"
+msgstr "Erzeugt ein Web Map Server Query-String."
#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-#, fuzzy
msgid ""
"Name of region to use instead of current region for bounds and resolution"
msgstr ""
-"Auflösung der Expositionsdatei unterscheidet sich von der Auflösung der "
-"aktuellen Region"
+"Name der Region die anstelle der aktuellen Region für die Ausdehnung "
+"(bounding box) und Auflösung verwendet werden soll."
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-#, fuzzy
msgid "Source projection"
-msgstr "Raster, Projektion"
+msgstr "Quell-Projektion"
#: ../locale/scriptstrings/r.tileset_to_translate.c:7
#: ../locale/scriptstrings/r.tileset_to_translate.c:9
-#, fuzzy
msgid "Conversion factor from units to meters in source projection"
-msgstr "Geben Sie den Umrechnungsfaktor von %s zu Meter ein: "
+msgstr "Umrechnungsfaktor von Einheit zu Meter in der Quell-Projektion"
#: ../locale/scriptstrings/r.tileset_to_translate.c:8
-#, fuzzy
msgid "Destination projection, defaults to this location's projection"
-msgstr "Übersteuere die Projektion (verwende Projektion der Location)."
+msgstr "Ziel-Projektion; Standard ist die Projektion dieser Location."
#: ../locale/scriptstrings/r.tileset_to_translate.c:10
-#, fuzzy
msgid "Maximum number of columns for a tile in the source projection"
-msgstr "Anzahl der Spalten in der neuen Region."
+msgstr "Maximale Anzahl der Spalten einer Kachel in der Quell-Projektion."
#: ../locale/scriptstrings/r.tileset_to_translate.c:11
-#, fuzzy
msgid "Maximum number of rows for a tile in the source projection"
-msgstr "Minimale Anzahl der im Hauptspeicher zu haltenden Zeile ist 1."
+msgstr "Maximale Anzahl der Zeilen einer Kachel in der Quell-Projektion."
#: ../locale/scriptstrings/r.tileset_to_translate.c:12
-#, fuzzy
msgid "Number of cells tiles should overlap in each direction"
-msgstr "Anzahl der Level, welche für jeden Komponent benutzt werden sollen."
+msgstr "Anzahl Zellen, die die Kacheln in alle Richtungen überlappen sollen."
#: ../locale/scriptstrings/r.tileset_to_translate.c:13
#: ../vector/v.db.select/main.c:62 ../db/db.select/select.c:199
@@ -1257,33 +1243,33 @@
#: ../locale/scriptstrings/r.tileset_to_translate.c:14
#: ../locale/scriptstrings/r.in.wms_to_translate.c:50
-#, fuzzy
msgid "Verbosity level"
-msgstr "Wasserniveau"
+msgstr "Gesprächigkeitsnievau"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
msgid "Drapes a color raster over a shaded relief map using d.his"
msgstr ""
+"Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter "
+"Verwendung von d.his."
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
-#, fuzzy
msgid "Name of shaded relief or aspect map"
-msgstr "Name der zweiten Rasterkarte."
+msgstr "Name der Schummerungs- oder Expositionskarte."
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
-#, fuzzy
msgid "Name of raster to drape over relief map"
-msgstr "Name der Rasterkarte(n) mit Höhenwerten"
+msgstr "Name der Rasterkarte die über das Relief drapiertwird."
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
-#, fuzzy
msgid "Percent to brighten"
-msgstr "Prozent Konvergenz."
+msgstr "Prozentuale Aufhellung."
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
msgid ""
"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
msgstr ""
+"Fülle Flächen ohne Daten in Rasterkarten mit Hilfe der v.surf.rst Spline-"
+"Interpolation."
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
msgid "raster, elevation, interpolation"
@@ -1310,41 +1296,37 @@
#: ../locale/scriptstrings/g.manual_to_translate.c:1
msgid "Display the HTML man pages of GRASS"
-msgstr ""
+msgstr "Zeige die HTML-Handbuchseite von GRASS."
#: ../locale/scriptstrings/g.manual_to_translate.c:2
-#, fuzzy
msgid "general, manual, help"
-msgstr "Allgemein, Kartenverwaltung"
+msgstr "Allgemein, Handbuch, Hilfe"
#: ../locale/scriptstrings/g.manual_to_translate.c:3
-#, fuzzy
msgid "Display index"
-msgstr "Darstellung"
+msgstr "Zeige den Index."
#: ../locale/scriptstrings/g.manual_to_translate.c:4
msgid "Display as MAN text page instead of HTML page in browser"
-msgstr ""
+msgstr "Zeige eine MAN-Textseite anstelle der HTML-Seite im Browser."
#: ../locale/scriptstrings/g.manual_to_translate.c:5
-#, fuzzy
msgid "Manual entry to be displayed"
-msgstr "Rasterkarte, die angezeigt werden soll."
+msgstr "Handbuchseite die gezeigt werden soll."
#: ../locale/scriptstrings/m.proj_to_translate.c:1
msgid "Convert coordinates from one projection to another (cs2cs frontend)."
msgstr ""
+"Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs "
+"Frontend)."
#: ../locale/scriptstrings/m.proj_to_translate.c:2
msgid "miscellaneous, projection"
msgstr "Verschiedenes, Projektion"
#: ../locale/scriptstrings/m.proj_to_translate.c:3
-#, fuzzy
msgid "Input coordinate file (omit to read from stdin)"
-msgstr ""
-"Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden "
-"soll)."
+msgstr "Eingabe-Koordinatendatei (auslassen für lesen von stdin)."
#: ../locale/scriptstrings/m.proj_to_translate.c:4
msgid "Output coordinate file (omit to send to stdout)"
@@ -1354,48 +1336,50 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:5
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
-#, fuzzy
msgid "Field separator"
-msgstr "Ausgabe Feld-Trennzeichen"
+msgstr "Feld-Trennzeichen"
#: ../locale/scriptstrings/m.proj_to_translate.c:6
-#, fuzzy
msgid "Input projection parameters (PROJ.4 style)"
-msgstr "* Eingabe-Projektion der GCP-Tabelle: %s"
+msgstr "Eingabe-Projektionsparameter (PROJ.4 Stil)."
#: ../locale/scriptstrings/m.proj_to_translate.c:7
-#, fuzzy
msgid "Output projection parameters (PROJ.4 style)"
-msgstr "* Ausgabe-Projektion der GCP-Tabelle: %s"
+msgstr "Ausgabe-Projektionsparameter (PROJ.4 Stil)."
#: ../locale/scriptstrings/m.proj_to_translate.c:8
msgid "Use LL WGS84 as input and current location as output projection"
msgstr ""
+"Verwende LL WGS84 als Eingabe-Projektion und aktuelle Loaction als Ausgabe-"
+"Projektion."
#: ../locale/scriptstrings/m.proj_to_translate.c:9
msgid "Use current location as input and LL WGS84 as output projection"
-msgstr ""
+msgstr "Verwende LL WGS84 als Eingabe-Projektion und Ausgabe-Projektion."
#: ../locale/scriptstrings/m.proj_to_translate.c:10
msgid ""
"Output long/lat in decimal degrees or other projections with many decimal "
"places"
msgstr ""
+"Gebe long/lat in Dezimalgrad oder einer anderen Projektion mit vielen "
+"Dezimalstellen aus."
#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
msgid ""
"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
"points map."
msgstr ""
+"Importiert LÄnderdateien vom US-NGA GEOnet Names Server (GNS) in eine "
+"Vektorpunktkarte."
#: ../locale/scriptstrings/v.in.gns_to_translate.c:3
msgid "Uncompressed GNS file from NGA (with .txt extension)"
-msgstr ""
+msgstr "Unkomprimierte GNS-Datei von NGA (mit der Dateiendung .txt)."
#: ../locale/scriptstrings/v.report_to_translate.c:1
-#, fuzzy
msgid "Reports geometry statistics for vectors."
-msgstr "Gibt statistische Werte für eine Rasterkarte aus."
+msgstr "Gibt statistische Werte für Geometrie der Vektorobjekte aus."
#: ../locale/scriptstrings/v.report_to_translate.c:2
msgid "vector, report, statistics"
@@ -1410,20 +1394,16 @@
msgstr "Sortiere die Ergebnisse."
#: ../locale/scriptstrings/v.report_to_translate.c:7
-#, fuzzy
msgid "Value to calculate"
-msgstr "Wert zum Laden in die Attributtabelle."
+msgstr "Zu berechnender Wert."
#: ../locale/scriptstrings/v.report_to_translate.c:8
msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
msgstr "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar)"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
-#, fuzzy
msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-"Überninmmt die Rasterwerte an einem angegebenen Vektor-Punkt in die "
-"Attributtabelle."
+msgstr "Schreibt den Vektorwert an der Stelle der Vektorpunkte in die Tabelle."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:2
@@ -1440,61 +1420,55 @@
msgstr "Vektor, Datenbank, Attributtabelle"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
-#, fuzzy
msgid "Points vector map to modify"
-msgstr "Mindestens 2 Layer müssen angegeben werden."
+msgstr "Zu ändernde Punktevektorkarte."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
-#, fuzzy
msgid "Layer in the vector to be modified"
+msgstr "Zu ändernder Layer der Vektorkarte."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
msgid "Column to be updated with the query result"
-msgstr ""
+msgstr "Spalte die mit den Abfrageergebnissen aktualisiert werden soll."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
msgid "Vector map to be queried"
msgstr "Vektorkarte, die abgefragt werden soll."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
-#, fuzzy
msgid "Layer of the query vector containing data"
+msgstr "Layer der Abfrage-Vektorkarte der Daten enthält."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
msgid "Column to be queried"
msgstr "Spalte, die abgefragt werden soll."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
-#, fuzzy
msgid "Maximum query distance in map units"
-msgstr "Pufferdistanz in Karteneinheiten."
+msgstr "Maximale Abfragedistanz in Karteneinheiten."
#: ../locale/scriptstrings/v.colors_to_translate.c:1
msgid ""
"Set color rules for features in a vector using a numeric attribute column."
msgstr ""
+"Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer "
+"numerischen Spalte der Attributtabelle."
#: ../locale/scriptstrings/v.colors_to_translate.c:2
-#, fuzzy
msgid "vector, color table"
-msgstr "Raster, Farbtabellen"
+msgstr "Vektor, Farbtabellen"
#: ../locale/scriptstrings/v.colors_to_translate.c:4
-#, fuzzy
msgid "Name of column containg numeric data"
-msgstr "von attribute"
+msgstr "Name der Spalte, die numerische Werte enthält."
#: ../locale/scriptstrings/v.colors_to_translate.c:5
-#, fuzzy
msgid "Layer number of data column"
-msgstr "Layer, in dem der Spaltenname geändert werden soll."
+msgstr "Layernummer der Datenspalte"
#: ../locale/scriptstrings/v.colors_to_translate.c:6
-#, fuzzy
msgid "Name of color column to populate"
-msgstr "Name der Spalte, die angezeigt werden soll."
+msgstr "Name der Farbspalte, die gefüllt werden soll."
#: ../locale/scriptstrings/v.colors_to_translate.c:7
#: ../locale/scriptstrings/v.colors_to_translate.c:10
@@ -1517,9 +1491,8 @@
msgstr "Farben"
#: ../locale/scriptstrings/v.colors_to_translate.c:8
-#, fuzzy
msgid "Manually set range (min,max)"
-msgstr "Integerspanne: min,max"
+msgstr "Manuell gesetzter Bereich (min,max)"
#: ../locale/scriptstrings/v.colors_to_translate.c:9
#: ../raster/r.colors/main.c:194
@@ -1537,7 +1510,7 @@
#: ../locale/scriptstrings/v.colors_to_translate.c:15
msgid "Save placeholder raster map for use with d.legend"
-msgstr ""
+msgstr "Speichere Platzhalter Rasterkarte für Verwendung in d.legend."
#: ../locale/scriptstrings/v.colors_to_translate.c:16
#: ../raster/r.colors/main.c:213
@@ -1550,21 +1523,21 @@
msgstr "Löscht eine Spalte der Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
-#, fuzzy
msgid "Vector map for which to drop attribute column"
msgstr ""
-"Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
+"Vektorkarte, in deren Attributtabelle eine Spalte gelsöcht werden soll."
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:4
-#, fuzzy
msgid "Layer where to drop column"
+msgstr "Layer, in dem eine Spalte gelöscht werden soll."
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
msgid ""
"Reclasses a raster map greater or less than user specified area size (in "
"hectares)."
msgstr ""
+"Reklassifiziert eine Rasterkarte mit Flächen größer oder kleiner als eine "
+"benutzerspezifizierte Fläche (in Hektar)."
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
msgid "raster, statistics, aggregation"
@@ -1594,51 +1567,46 @@
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
msgid "Lesser value option that sets the <= area size limit [hectares]"
-msgstr ""
+msgstr "Kleinerer-Wert-Option bestimmt das <= Flächengrenze [Hektar]."
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
msgid "Greater value option that sets the >= area size limit [hectares]"
-msgstr ""
+msgstr "Größerer-Wert-Option bestimmt das >= Flächengrenze [Hektar]."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:1
msgid ""
"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
msgstr ""
+"Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, das "
+"von GpsBabel unterstützt wird."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:2
-#, fuzzy
msgid "vector, export, GPS"
-msgstr "Vektor, Import, GPS"
+msgstr "Vektor, Export, GPS"
#: ../locale/scriptstrings/v.out.gps_to_translate.c:3
-#, fuzzy
msgid "Export as waypoints"
-msgstr "Importiere Wegpunkte"
+msgstr "Exportiere als Wegpunkte."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:4
-#, fuzzy
msgid "Export as routes"
-msgstr "Importiere Routen"
+msgstr "Exportiere als Routen."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:5
-#, fuzzy
msgid "Export as tracks"
-msgstr "Importiere Tracks."
+msgstr "Exportiere als Tracks."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:7
-#, fuzzy
msgid "Feature type(s)"
msgstr "Art des Vektorobjekts."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:8
-#, fuzzy
msgid "Name for output file or GPS device"
-msgstr "Name der Ausgabedatei"
+msgstr "Name der Ausgabedatei oder des GPS Gerätes."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:9
-#, fuzzy
msgid "GpsBabel supported output format"
-msgstr "Zeige unterstützte Dateiformate."
+msgstr "GpsBabel unterstütze Ausgabeformate. "
#: ../locale/scriptstrings/v.out.gps_to_translate.c:11
#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
@@ -1646,42 +1614,47 @@
"A single vector map can be connected to multiple database tables. This "
"number determines which table to use."
msgstr ""
+"Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden "
+"sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:12
#: ../locale/scriptstrings/v.out.gps_to_translate.c:15
msgid "Subset"
-msgstr ""
+msgstr "Subset"
#: ../locale/scriptstrings/v.out.gps_to_translate.c:13
#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
+msgstr "WHERE Bedingungen des SQL-Ausdrucksohne das Schlüsselwort 'where'."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:14
msgid "Example: income < 1000 and inhab >= 10000"
-msgstr ""
+msgstr "Beispiel: Einkommen < 1000 und Einwohner >= 10000"
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
+#, fuzzy
msgid "Mosaics several images and extends colormap"
msgstr ""
+"Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-"
+"Karten."
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
msgid "raster, imagery, mosaicking"
msgstr "Raster, Bilder, Mosaikieren"
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
+#, fuzzy
msgid "maps for mosaic."
-msgstr ""
+msgstr "2. Bild für das Mosaik."
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
#, fuzzy
msgid "reclass raster output map"
-msgstr "Kann Ausgabekarte nicht erzeugen."
+msgstr "Vektor-Ausgabekarte"
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
-#, fuzzy
msgid "Displays a raster map and its legend on a graphics window"
-msgstr "Zeigt einen Maßstabsbalken im Grafik-Fenster an."
+msgstr "Zeigt eine eine Rasterkarte und die Legende im Grafikfenster an."
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
#: ../display/d.title/main.c:49 ../display/d.colors/main.c:41
@@ -1707,9 +1680,8 @@
msgstr "Drehe Legende."
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
-#, fuzzy
msgid "Omit entries with missing label"
-msgstr "Überspringe Kategorien ohne Label."
+msgstr "Lasse Einträge ohne Beschriftung aus."
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
#: ../display/d.zoom/main.c:76 ../display/d.legend/main.c:90
@@ -1717,14 +1689,12 @@
msgstr "Name der Rasterkarte"
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
-#, fuzzy
msgid "Number of lines to appear in the legend"
-msgstr "Wie oft soll der Filter wiederholt werden?"
+msgstr "Anzahl Zeilen in der Legende."
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
-#, fuzzy
msgid "Name of raster map to generate legend from"
-msgstr "Name der Rasterkarte für <%s>."
+msgstr "Name der Rasterkarte von der eine Legende erzeugt werden soll."
#: ../locale/scriptstrings/r.regression.line_to_translate.c:1
msgid "Calculates linear regression from two raster maps: y = a + b*x"
@@ -1746,7 +1716,7 @@
#: ../locale/scriptstrings/r.regression.line_to_translate.c:4
msgid "Slower but accurate (applies to FP maps only)"
-msgstr ""
+msgstr "Langsamer aber genau (gilt nur für Fließkomma-Karten)."
#: ../locale/scriptstrings/r.regression.line_to_translate.c:5
msgid "Map for x coefficient"
@@ -1761,12 +1731,16 @@
"ASCII file for storing regression coefficients (output to screen if file not "
"specified)."
msgstr ""
+"ASCII-Datei n der die Regressionskoeffizienten gespeichert werden sollen "
+"(wenn keine angegeben wird erfolgt die Ausgabe auf dem Bildschirm)."
msgid ""
"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
"file into a vector map."
msgstr ""
+"Importiert Wegpunkte, Routen und Tracks von einem GPS-Gerät oder einer GPS-"
+"Download-Datei in eine Vektorkarte. "
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
@@ -1793,84 +1767,85 @@
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:7
msgid "Force vertices of track or route data as points"
-msgstr ""
+msgstr "Erzwinge den Import von Tracks oder Routen als Punkte."
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:8
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:10
msgid "Do not attempt projection transform from WGS84"
-msgstr ""
+msgstr "Versuche keine Transformation der Projektion von WGS84."
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:9
-#, fuzzy
msgid "Device or file used to import data"
-msgstr "Zu importierende Rasterdatei."
+msgstr "Gerät oder Datei, von der Daten importiert werden sollen.ei."
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:11
msgid "Format of GPS input data (use gpsbabel supported formats)"
msgstr ""
+"Format der GPS-Inputdaten (verwenden Sie von gpsbabel unterstützte Formate)."
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:12
msgid ""
"Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
msgstr ""
+"Projektion der Inputdaten (PROJ.4 Stil). Wenn nicht angegeben, wird Lat/Lon "
+"WGS84 angenommen."
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
msgid ""
"Brovey transform to merge multispectral and high-res panchromatic channels"
msgstr ""
+"Brovey-Transformation zum mischen multispektraler und hochaufgelöster "
+"panchromatischer Kanäle."
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
-#, fuzzy
msgid "imagery, fusion, Brovey"
-msgstr "Raster, Bilder, Fusion"
+msgstr "Bilder, Fusion, Brovery"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
-#, fuzzy
msgid "LANDSAT sensor"
-msgstr "LANDSAT roter Kanal"
+msgstr "LANDSAT Sensor"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:4
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
msgid "Sensor"
-msgstr ""
+msgstr "Sensor"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
msgid "QuickBird sensor"
-msgstr ""
+msgstr "QuickBird Sensor"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:7
msgid "SPOT sensor"
-msgstr ""
+msgstr "SPOT Sensor"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
-#, fuzzy
msgid "Name of input raster map (green: tm2 | qbird_green | spot1)"
-msgstr "Name der Eingabe-Rasterkarte, die umprojeziert werden soll."
+msgstr "Name der Eingabe-Rasterkarte (green: tm2 | qbird_green | spot1)."
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
#, fuzzy
msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2"
+msgstr "Name der Eingabe-Rasterkarte (NIR: tm4 | qbird_nir | spot2)."
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
#, fuzzy
msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3"
+msgstr "Name der Eingabe-Rasterkarte (MIR; tm5 | qbird_red | spot3)."
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:12
-#, fuzzy
msgid "Name of input raster map (etmpan | qbird_pan | spotpan)"
+msgstr "Name der Eingabe-Rasterkarte (etmpan | qbird_pan | spotpan)."
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:13
-#, fuzzy
msgid "Name for output raster map prefix (e.g. 'brov')"
-msgstr "Name der Ausgabe-Rasterkarte nicht angegeben."
+msgstr "Präfix für die Ausgabe-Rasterkarten (z.B. 'brov')."
#: ../locale/scriptstrings/d.polar_to_translate.c:1
msgid "Draws polar diagram of angle map such as aspect or flow directions"
msgstr ""
+"Zeichne ein Polardiagramm einer Karte mit Winkelangaben, so wie Expositionen "
+"oder Fließrichtungen."
#: ../locale/scriptstrings/d.polar_to_translate.c:2
#: ../locale/scriptstrings/d.correlate_to_translate.c:2
@@ -1878,26 +1853,26 @@
msgstr "Anzeige, Diagramm"
#: ../locale/scriptstrings/d.polar_to_translate.c:3
-#, fuzzy
msgid "Name of raster angle map"
-msgstr "Name der Rasterkarte"
+msgstr "Name der Rasterkarte mit Winkelangaben."
#: ../locale/scriptstrings/d.polar_to_translate.c:4
msgid "Pixel value to be interpreted as undefined (different from NULL)"
msgstr ""
+"Pixelwert der als undefiniert interpretiert werden soll (unterschiedlich von "
+"NULL)."
#: ../locale/scriptstrings/d.polar_to_translate.c:5
-#, fuzzy
msgid "Name of optional EPS output file"
+msgstr "Name der optionalen EPS-Ausgabedatei."
#: ../locale/scriptstrings/d.polar_to_translate.c:6
msgid "Plot using Xgraph"
-msgstr ""
+msgstr "Verwende Xgraph zum Zeichnen."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:1
msgid "Downloads and imports data from WMS servers."
-msgstr ""
+msgstr "Läd Daten von einem WMS Server herunter und importiert sie."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
msgid "wms"
@@ -1906,7 +1881,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
#: ../vector/v.in.dwg/main.c:113 ../vector/v.in.dxf/main.c:90
msgid "List available layers and exit"
-msgstr "Zeigt die vorhandenen Layer und beendet sich."
+msgstr "Listet verfügbare Layer und beendet sich."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
@@ -1926,7 +1901,7 @@
msgid "Skip to downloading (to resume downloads faster)"
-msgstr ""
+msgstr "Springe zum Download, um Downloads schneller fortzusetzten."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
@@ -1937,13 +1912,12 @@
msgstr "Download"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
-#, fuzzy
msgid "Don't request transparent data"
msgstr "Fordere keine transparenten Daten an."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
msgid "Clean existing data out of download directory"
-msgstr ""
+msgstr "Lösche existierende Daten im Download-Verzeichnis."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
#: ../raster/r.in.gdal/main.c:140
@@ -1958,101 +1932,94 @@
msgstr "Import"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
-#, fuzzy
msgid "Don't reproject the data, just patch it"
-msgstr "Die Daten nicht umprojezieren, nur Zusammenfügen."
+msgstr "Die Daten nicht umprojezieren, nur zusammenfügen."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
msgid "Use GET method instead of POST data method"
-msgstr ""
+msgstr "Verwende die GET-Methode anstelle der POST-Methode."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
msgid "This may be needed to connect to servers which lack POST capability"
-msgstr ""
+msgstr "Dies kann notwendig sein bei Servern ohne POST-Fähigkeiten."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
-#, fuzzy
msgid "Mapserver to request data from"
-msgstr "Kann Daten der Tabelle nicht selektieren."
+msgstr "Mapserver von dem Daten angefragt werden."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
msgid "Layers to request from map server"
-msgstr "Layer, die vom Mapserver angefragt werden sollen."
+msgstr "Layer, die vom Server angefragt werden."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
msgid "Styles to request from map server"
-msgstr "Stile, die vom Mapserver angefragt werden sollen."
+msgstr "Stile in denen Daten vom Server angefragt werden."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
-#, fuzzy
msgid "Source projection to request from server"
+msgstr "Projektion in der die Daten vom Server angefragt werden."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
-#, fuzzy
msgid "Image format requested from the server"
+msgstr "Bildformat das vom Server angefragt wird."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
msgid "Addition query options for server"
-msgstr ""
+msgstr "Weitere Abfrageoptionen für den Server."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
-#, fuzzy
msgid "Maximum columns to request at a time"
+msgstr "Maximale Spaltenanzahl, die jeweils angefragt wird."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
-#, fuzzy
msgid "Maximum rows to request at a time"
+msgstr "Maximale Zeilenanzahl, die jeweils angefragt wird."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
msgid "Additional options for r.tileset"
-msgstr ""
+msgstr "Weitere Optionen für r.tileset"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
msgid "Named region to request data for. Current region used if omitted"
msgstr ""
+"Benannte Region, für die Daten angefragt werden sollen. Wenn nicht angegeben "
+"wird die aktuelle Region verwendet."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
msgid "Folder to save downloaded data to"
-msgstr ""
+msgstr "Verzeichnis um heruntergeladene Daten zu speichern."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:41
msgid "Additional options for wget"
-msgstr ""
+msgstr "Weitere Optionen für wget"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:43
msgid "Additional options for curl"
-msgstr ""
+msgstr "Weitere Optionen für curl"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:45
-#, fuzzy
msgid "Reprojection method to use"
-msgstr "Zu benutzende Interpolationsmethode."
+msgstr "Methode für das Umprojezieren"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:47
msgid "Filename to save capabilities XML file to"
-msgstr ""
+msgstr "Datei in der das Capabilities-XML-Dokument gespeichert wird."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:48
-#, fuzzy
msgid "Requires list available layers flag"
+msgstr "Erfordert den Schalter 'Liste verfügbare Layer'."
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
msgid "Imports attribute tables in various formats."
msgstr "Importiert Attributtabellen aus verschiedenen Formaten."
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
-#, fuzzy
msgid "Table file to be imported or DB connection string"
-msgstr "Tabellendatei, die exportiert werden soll oder DB-Verbindung"
+msgstr "Tabellendatei, die importiert werden soll oder eine DB-Verbindung."
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
msgid "Table name of SQL DB table"
-msgstr ""
+msgstr "Tabellenname der SQL DB Tabelle."
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
@@ -2061,7 +2028,7 @@
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
msgid "Name for auto-generated unique key column"
-msgstr ""
+msgstr "Name für automatisch erzeugte Schlüsselwert-Spalte."
#: ../locale/scriptstrings/r.buffer_to_translate.c:1
#: ../raster/r.buffer/main.c:67
@@ -2093,11 +2060,12 @@
msgstr "Distanzeinheiten"
#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-#, fuzzy
msgid ""
"Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
"format"
-msgstr "Konvertiert eine Rasterkarte in eine Vektorkarte."
+msgstr ""
+"Konvertiert alle alten GRASS < Ver5.7 Vektorkarten im aktuellen Mapset in "
+"das aktuelle Format."
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
msgid "Interactively edit cell values in a raster map."
@@ -2109,33 +2077,28 @@
msgstr "Darstellung, Raster"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
-#, fuzzy
msgid "Name of aspect raster map"
-msgstr "Name der Basis-Rasterkarte."
+msgstr "Name der Expositions-Rasterkarte."
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
msgid "Width of display canvas"
msgstr "Breite des Fensters."
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
-#, fuzzy
msgid "Height of display canvas"
-msgstr "Darzustellender Text"
+msgstr "Höhe des Fensters."
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
-#, fuzzy
msgid "Minimum size of each cell"
-msgstr "Minimales Iso-Flächen-Level."
+msgstr "Kleinste Größste jeder Zelle."
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
-#, fuzzy
msgid "Maximum number of rows to load"
-msgstr "Maximale Anzahl der Spalten: %d"
+msgstr "Maximal zu ladende Anzahl Zeilen."
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
-#, fuzzy
msgid "Maximum number of columns to load"
+msgstr "Maximal zu ladende Anzahl Spalten."
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
msgid ""
@@ -2145,26 +2108,26 @@
"Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
-#, fuzzy
msgid "Vector map for which to edit attribute table"
-msgstr ""
+msgstr "Vektorkarte deren Attributtabelle editiert werden soll."
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:4
-#, fuzzy
msgid "Layer where to add column"
+msgstr "Layer, in dem eine Spalte hinzugefügt werden soll."
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
+#, fuzzy
msgid ""
"Name and type of the new column(s) ('name type [,name type, ...]' - types "
"depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION "
"and DATE)"
msgstr ""
+"Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank ab, "
+"aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
msgid "Set color rules based on stddev from a map's mean value."
-msgstr ""
+msgstr "Bestimme Farbregeln basierend auf den Standardabweichungen."
#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
#: ../raster/r.colors/main.c:164 ../raster/r.colors.out/main.c:62
@@ -2172,15 +2135,12 @@
#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
-#, fuzzy
msgid "Color using standard deviation bands"
-msgstr ""
-"Mittelwerte und Standardabweichungen für %d Band%s\n"
-"\n"
+msgstr "Farben unter Verwendung der Standardabweichung"
#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
msgid "Force center at zero"
-msgstr ""
+msgstr "Zwinge das Zentrum auf Null."
#: ../locale/scriptstrings/r.blend_to_translate.c:1
msgid "Blends color components of two raster maps by a given ratio."
@@ -2231,14 +2191,12 @@
msgstr "Raster"
#: ../locale/scriptstrings/r.blend_to_translate.c:3
-#, fuzzy
msgid "Name of first raster map for blending"
-msgstr "Name der ersten Rasterkarte."
+msgstr "Name der ersten Rasterkarte für die Mischung."
#: ../locale/scriptstrings/r.blend_to_translate.c:4
-#, fuzzy
msgid "Name of second raster map for blending"
+msgstr "Name der zweiten Rasterkarte für die Mischung."
#: ../locale/scriptstrings/r.blend_to_translate.c:5
msgid "Base name for red, green and blue output maps containing the blend"
@@ -2253,6 +2211,8 @@
msgid ""
"Displays spectral response at user specified locations in group or images."
msgstr ""
+"Zeige die Farbempfindlichkeit an Benutzerdefinierten Stellen in der Gruppe "
+"oder in Bilderen."
#: ../locale/scriptstrings/i.spectral_to_translate.c:2
msgid "imagery, raster, multispectral"
@@ -2260,17 +2220,15 @@
#: ../locale/scriptstrings/i.spectral_to_translate.c:3
msgid "Group input"
-msgstr ""
+msgstr "Eingabe-Gruppe "
#: ../locale/scriptstrings/i.spectral_to_translate.c:4
-#, fuzzy
msgid "Raster input maps"
msgstr "Eingabe-Rasterkarten"
#: ../locale/scriptstrings/i.spectral_to_translate.c:5
-#, fuzzy
msgid "Write output to PNG image"
-msgstr "Überschreibe Ausgabedatei."
+msgstr "Schreibe die Ausgabe in ein PNG-Bild."
#: ../locale/scriptstrings/i.spectral_to_translate.c:6
#, fuzzy
@@ -2278,9 +2236,8 @@
msgstr "Quelle"
#: ../locale/scriptstrings/i.spectral_to_translate.c:7
-#, fuzzy
msgid "Label with coordinates instead of numbering"
-msgstr "Benutze Kartenkoordinaten anstatt xyz-Koordniaten."
+msgstr "Beschrifte mit Koordinaten anstelle der Nummerierung."
#: ../locale/scriptstrings/i.spectral_to_translate.c:8
#, fuzzy
@@ -2289,7 +2246,7 @@
#: ../locale/scriptstrings/d.correlate_to_translate.c:1
msgid "Prints a graph of the correlation between data layers (in pairs)."
-msgstr ""
+msgstr "Gibt eine Graphik der Korrelation zweier Karten (paarweise) aus."
#: ../locale/scriptstrings/d.correlate_to_translate.c:3
msgid "raster input map"
@@ -2309,7 +2266,7 @@
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
msgid "Continue if upload column(s) already exist"
-msgstr ""
+msgstr "Fahre fort, auch wenn Zielspalte(n) bereits existiert."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
#: ../vector/v.univar/main.c:100 ../raster/r.univar/r3.univar_main.c:46
@@ -2318,36 +2275,37 @@
msgstr "Berechnet mehr statistische Kennzahlen."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
-#, fuzzy
msgid "Name of vector polygon map"
-msgstr "Name der Vektorkarte"
+msgstr "Name der Vektorkarte (Polygone)."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
#: ../locale/scriptstrings/v.db.update_to_translate.c:4
msgid "Layer to which the table to be changed is connected"
-msgstr ""
+msgstr "Layer, der die zuändernde Tabelle enthält."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
-#, fuzzy
msgid "Name of raster map to calculate statistics from"
-msgstr "Name der Rasterkarte(n), die in die Gruppe eingefügt werden sollen."
+msgstr "Name der Rasterkarte für die Statistiken berechnet werden sollen."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
-#, fuzzy
msgid "Column prefix for new attribute columns"
+msgstr "Spalten-Präfix für neue Attributspalten."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
#: ../vector/v.univar/main.c:92 ../raster/r.univar/r3.univar_main.c:37
#: ../raster/r.univar/r.univar_main.c:38
msgid "Percentile to calculate (requires extended statistics flag)"
msgstr ""
+"zu berechnende Perzentile (erfordert den Schalter 'erweiterte Statistiken')."
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
+#, fuzzy
msgid ""
"Georeference, rectify, and import Terra-ASTER imagery and relative DEM's "
"using gdalwarp."
msgstr ""
+"Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative "
+"DGMs mit Hilfe von gdalwarp."
#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
@@ -2356,17 +2314,20 @@
#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
msgid "Input ASTER image to be georeferenced & rectified"
-msgstr ""
+msgstr "Eingabe-ASTER-Bild, das georeferenziert und rektifiziert wird."
#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
-msgstr ""
+msgstr "ASTER-Bild Processing Status (Level 1A, Level 1B, oder relatives DGM)."
#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
+#, fuzzy
msgid ""
"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
"all bands"
msgstr ""
+"L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein "
+"einzelnen Kanal umrechnen."
#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
#, fuzzy
@@ -2385,18 +2346,20 @@
msgstr "Aktualisiert eine Spalte einer Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.update_to_translate.c:3
-#, fuzzy
msgid "Vector map to edit the attribute table for"
-msgstr "Vektor, Raster, Attributtabelle"
+msgstr "Vektorkarte deren Attributtabelle edtiert werden soll."
#: ../locale/scriptstrings/v.db.update_to_translate.c:5
msgid "Column to update"
msgstr "Spalte, die aktualisiert werden soll"
#: ../locale/scriptstrings/v.db.update_to_translate.c:6
+#, fuzzy
msgid ""
"Value to update the column with, can be (combination of) other column(s)"
msgstr ""
+"Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in "
+"einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
msgid "Column to query"
@@ -2407,35 +2370,34 @@
"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
"col2>1)"
msgstr ""
+"WHERE Bedingung für die Aktualisierung, ohne das Schlüsselwort 'where' (z.B. "
+"cat=1 or col1/col2>1)."
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
-#, fuzzy
msgid "Removes existing attribute table of a vector map."
-msgstr "Kann Elemente nicht von der Vektorkarte <%s> kopieren."
+msgstr "Entfernt die existierende Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
-#, fuzzy
msgid "Force removal (required for actual deletion of table)"
-msgstr "Erzwinge das Löschen (benötigt um tatsächlich Dateien zu löschen)."
+msgstr ""
+"Erzwinge das Löschen (erforderlich um tatsächlich die Tabelle zu löschen)."
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
-#, fuzzy
msgid "Vector map from which to remove attribute table"
-msgstr "Rasterkarte, von der die Farbtabelle kopiert werden soll."
+msgstr "Vektorkarte, von der die Attributtabelle gelöscht werden soll."
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
-#, fuzzy
msgid "Name of existing attribute table (default: vector map name)"
+msgstr ""
+"Name einer existierenden Attributtabelle (Standard Name der Vektorkarte)."
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
-#, fuzzy
msgid "Layer from which to drop linked attribute table"
+msgstr "Layer aus dem die Attributtabelle gelöscht werden soll."
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:1
msgid "Performs auto-balancing of colors for LANDSAT images."
-msgstr ""
+msgstr "Führt einen automatischen Farbausgleich für LANDSAT-Bilder durch."
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
msgid "raster, imagery, colors"
@@ -2455,23 +2417,23 @@
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:6
msgid "Cropping intensity (upper brightness level)"
-msgstr ""
+msgstr "Stutzstärke (obere Helligkeitslevel)."
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:7
msgid "Extend colors to full range of data on each channel"
-msgstr ""
+msgstr "Strecke die Farben über den ganzen Datenbereich in jedem Kanal."
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:8
msgid "Preserve relative colors, adjust brightness only"
-msgstr ""
+msgstr "Erhalte relative Farben, passe nur die Helligkeit an."
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:9
msgid "Reset to standard color range"
-msgstr ""
+msgstr "Setze auf den Standardfarbbereich zurück."
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
msgid "Import SRTM HGT files into GRASS"
-msgstr ""
+msgstr "Importiert SRTM HGT Dateien nach GRASS."
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
#: ../raster/r.in.gdal/main.c:79 ../raster/r.in.bin/main.c:122
@@ -2482,16 +2444,15 @@
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
msgid "SRTM input tile (file without .hgt.zip extension)"
-msgstr ""
+msgstr "SRTM Eingabe-Kachel (Dateinamen ohne die Erweiterung .hgt.zip)."
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
-#, fuzzy
msgid "Output raster map (default: input tile)"
-msgstr "Name der Ausgabe-Rasterkarte (Standard: input)."
+msgstr "Ausgabe-Rasterkarte (Standard: Eingabekachel)."
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
-msgstr ""
+msgstr "Eingabe ist eine 1-arcsec Kachel (Standard: 3-arcsec)."
#: ../locale/scriptstrings/r.grow_to_translate.c:1 ../raster/r.grow/main.c:124
msgid "Generates a raster map layer with contiguous areas grown by one cell."
@@ -2567,62 +2528,59 @@
msgstr "Eingabe-Rasterkarte (LANDSAT Kanal 7)."
#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
-#, fuzzy
msgid "raster output TC maps prefix"
+msgstr "Präfix für Ausgabe TC-Rasterkarten"
#: ../locale/scriptstrings/r.mask_to_translate.c:1
msgid "Create a MASK for limiting raster operation"
-msgstr ""
+msgstr "Erzeuge eine Maske (MASK) um Rasteroperationen zu begrenzen."
#: ../locale/scriptstrings/r.mask_to_translate.c:2
msgid "raster, mask"
msgstr "Raster, Maske"
#: ../locale/scriptstrings/r.mask_to_translate.c:3
-#, fuzzy
msgid "Raster map to use as MASK"
-msgstr "Rasterkarte, die umgeschlüsselt werden soll."
+msgstr "Rasterkarte, die als Maske (MASK) verwendet werden soll."
#: ../locale/scriptstrings/r.mask_to_translate.c:4
msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
msgstr ""
+"Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 *)."
#: ../locale/scriptstrings/r.mask_to_translate.c:5
msgid "Create inverse MASK from specified 'maskcats' list"
-msgstr ""
+msgstr "Erzeuge eine inverse Maske aus der angegebenen 'maskcats' Liste."
#: ../locale/scriptstrings/r.mask_to_translate.c:6
msgid "Remove existing MASK (overrides other options)"
msgstr "Entferne existierende Maske (MASK). Übersteuert andere Optionen."
#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-#, fuzzy
msgid ""
"Dissolves boundaries between adjacent areas sharing a common category number "
"or attribute."
msgstr ""
-"Keine Attributtabelle gefunden -> benutze nur Kategorienummern als "
-"Attributes."
+"Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder "
+"gleichem Attributwert auf."
#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
msgid "vector, area, dissolve"
msgstr "Raster, Fläche, Dissolve"
#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
-#, fuzzy
msgid "Layer number. If -1, all layers are extracted."
-msgstr "Layernummer: Wenn -1 angegeben wird, werden alle Layer dargestellt."
+msgstr "Layernummer: Wenn -1 angegeben wird, werden alle Layer ausgewählt."
#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
-#, fuzzy
msgid "Name of column used to dissolve common boundaries"
-msgstr "Name der Attribut-Spalte die für die Label benutzt werden soll."
+msgstr ""
+"Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet werden "
+"soll."
#: ../locale/scriptstrings/v.build.all_to_translate.c:1
-#, fuzzy
msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr "Nicht in der Lage Vektorkarte in anderem Mapset zu ändern."
+msgstr "Baut die Topologie aller Vektorkarten im aktuellen Mapset neu auf."
#: ../locale/scriptstrings/v.build.all_to_translate.c:2
#: ../vector/v.voronoi/vo_main.c:117 ../vector/v.voronoi/dt_main.c:44
@@ -2637,10 +2595,11 @@
msgstr "Vektor"
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-#, fuzzy
msgid ""
"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgstr ""
+"Konvertiert alle alten GRASS < Ver5.7 'Site'-karten im aktuellen Mapset zu "
+"Vektorkarten."
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
msgid "sites, vector, import"
@@ -2655,26 +2614,25 @@
"Vektorkarte."
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
-#, fuzzy
msgid "Vector map for which to add new attribute table"
msgstr ""
+"Vektorkarte, zu der eine neue Attributtabelle hinzugefügt werden soll. "
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
-#, fuzzy
msgid "Name of new attribute table (default: vector map name)"
+msgstr "Name der neuen Attributtabelle (Standard: Name der Vektorkarte)."
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
-#, fuzzy
msgid "Layer where to add new attribute table"
+msgstr "Layer in dem die neue Attributtabelle hinzugefügt werden soll."
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
msgid ""
"Name and type of the new column(s) (types depend on database backend, but "
"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
msgstr ""
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
msgid "Exports attribute tables into various formats."
@@ -2695,7 +2653,7 @@
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
msgid ""
"Export a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
+msgstr "."
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
#: ../raster/r.out.gdal/main.c:126 ../raster/r.out.ascii/main.c:58
@@ -2712,22 +2670,19 @@
"Ausgabe nach stdout)."
#: ../locale/scriptstrings/db.droptable_to_translate.c:1
-#, fuzzy
msgid "Drops an attribute table."
-msgstr "Datenbank, Attributtabelle"
+msgstr "Löscht eine Attributtabelle."
#: ../locale/scriptstrings/db.droptable_to_translate.c:4
-#, fuzzy
msgid "Table to drop"
-msgstr "Kann nicht weitermachen."
+msgstr "Tabelle die gelöscht werden soll."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-#, fuzzy
msgid ""
"Calculates univariate statistics on selected table column for a GRASS vector "
"map."
msgstr ""
-"Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
+"Berechnet univariate Statistiken von ausgewählten Spalten einer Vektorkarte."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
#: ../vector/v.random/main.c:84 ../vector/v.normal/main.c:78
@@ -2746,9 +2701,9 @@
msgstr "Name der Datentabelle"
#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-#, fuzzy
msgid "Column on which to calculate statistics (must be numeric)"
-msgstr "Spaltenname (Spaltentyp muss numerisch sein)."
+msgstr ""
+"Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
msgid "Database/directory for table"
@@ -2759,16 +2714,15 @@
msgstr "Datenbanktreiber"
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
-#, fuzzy
msgid ""
"Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+"Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten "
+"Vektorkarte um."
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
-#, fuzzy
msgid "Vector map for which to rename attribute column"
-msgstr ""
+msgstr "Vektorkarte, für die eine Spalte umbenannt werden soll."
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:4
msgid "Layer where to rename column"
@@ -2776,35 +2730,33 @@
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:5
msgid "Old and new name of the column (old,new)"
-msgstr ""
+msgstr "Alter und neuer Name der Spalte (alt,neu)."
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
-#, fuzzy
msgid "Import of SPOT VGT NDVI file into a raster map"
-msgstr "Importiert eine binäre Rasterdatei in eine GRASS Rasterkarte."
+msgstr "Importiert SPOT VGT NDVI Datei in eine Rasterkarte."
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
msgid "also import quality map (SM status map layer) and filter NDVI map"
msgstr ""
+"Importiere auch die Qualitätskarte (SM-Statuskarte) und filtere die NDVI-"
+"Karte."
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-msgstr ""
+msgstr "Existierende SPOT VGT NDVI HDF Datei (z.B. 0001_NDV.HDF)."
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-#, fuzzy
msgid "Reconnects vectors to a new database."
-msgstr "Entfernt eine Datenbank."
+msgstr "Verbindet Vektor mit einer neuen Datenbank."
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
-#, fuzzy
msgid "Name of old database"
-msgstr "Name der Datenbank-Datei."
+msgstr "Name der alten Datenbank."
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
-#, fuzzy
msgid "Name of new database"
+msgstr "Name der neuen Datenbank."
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
msgid "Old schema"
@@ -2815,11 +2767,8 @@
msgstr "Neues Schema"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
-#, fuzzy
msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr ""
-"Erstellt Karte mit topographischem Index [(ln(a/tan(beta)))] auf Basis einer "
-"Karte mit Höhenwerten."
+msgstr "Erzeugt eine Schummerungskarte aus einem Höhenmodell (DGM)."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
#: ../locale/scriptstrings/r.plane_to_translate.c:2
@@ -2832,19 +2781,16 @@
msgstr "Eingabekarte, die Höheninformationen enthält."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:4
-#, fuzzy
msgid "Output shaded relief map name"
-msgstr "Ausgabe-Treibername"
+msgstr "Name der Schummerungskarte."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:5
-#, fuzzy
msgid "Altitude of the sun in degrees above the horizon"
-msgstr "A: Höhe der Sonne über dem Horizont (in Grad)."
+msgstr "Höhe der Sonne in Grad über dem Horizont."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:6
-#, fuzzy
msgid "Azimuth of the sun in degrees to the east of north"
-msgstr "A: Winkel der Sonne, gemessen von Norden (in Grad)."
+msgstr "Winkel der Sonne in Grad östlich von der Nordrichtung."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:7
msgid "Factor for exaggerating relief"
@@ -2860,96 +2806,91 @@
msgid ""
"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
msgstr ""
+"Bestimmt den Skalierungsfaktor (nur für lat./long. Locations, kein Wert: "
+"scale=1)."
#: ../locale/scriptstrings/r.plane_to_translate.c:1
-#, fuzzy
msgid ""
"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
"point."
msgstr ""
-"Erstellt eine Rasterkarte und eine Vektorkarte, die zufällig angeordnete "
-"Punkte enthalten."
+"Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung "
+"(inclination), Ausrichtung (azimuth) und einem Punkt."
#: ../locale/scriptstrings/r.plane_to_translate.c:3
-#, fuzzy
msgid "Name of raster plane to be created"
-msgstr "Name der Rasterkarte, die angezeigt werden soll."
+msgstr "Name der zu erstellenden Ebene (Rasterkarte)."
#: ../locale/scriptstrings/r.plane_to_translate.c:4
msgid "Dip of plane. Value must be between -90 and 90 degrees"
-msgstr ""
+msgstr "Neigung der Ebene. Wert muß zwischen -90 und 90 Grad liegen."
#: ../locale/scriptstrings/r.plane_to_translate.c:5
msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
-msgstr ""
+msgstr "Ausrichtung der Ebene. Wert muß zwischen 0 und 360 Grad liegen"
#: ../locale/scriptstrings/r.plane_to_translate.c:6
-#, fuzzy
msgid "Easting coordinate of a point on the plane"
-msgstr "Ost Koordinate (ausgewählter Punkt, Standard: Kartenmittelpunkt)."
+msgstr "Ost-Koordinate eines Punktes der Ebene."
#: ../locale/scriptstrings/r.plane_to_translate.c:7
-#, fuzzy
msgid "Northing coordinate of a point on the plane"
-msgstr "Nord Koordinate (ausgewählter Punkt, Standard: Kartenmittelpunkt)."
+msgstr "Nord-Koordinate eines Punktes der Ebene."
#: ../locale/scriptstrings/r.plane_to_translate.c:8
-#, fuzzy
msgid "Elevation coordinate of a point on the plane"
-msgstr "Bitte nur ein Koordinatenpaar pro Zeile."
+msgstr "Höhe eines Punktes der Ebene."
#: ../locale/scriptstrings/r.plane_to_translate.c:9
-#, fuzzy
msgid "Type of the raster map to be created"
-msgstr "Name der Rasterkarte, die reskaliert werden soll."
+msgstr "Art der zu erstellenden Rasterkarte."
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
-#, fuzzy
msgid "Allows to join a table to a vector map table."
+msgstr ""
+"Ermöglicht es eine Tabelle an eine Attributtabelle einer Vektorkarte zu "
+"joinen."
#: ../locale/scriptstrings/v.db.join_to_translate.c:3
-#, fuzzy
msgid "Vector map to which to join other table"
+msgstr "Vektorkarte, an die eine andere Tabelle gejoined werden soll."
#: ../locale/scriptstrings/v.db.join_to_translate.c:4
msgid "Layer where to join"
msgstr "Layer, in dem 'gejoined' werden soll."
#: ../locale/scriptstrings/v.db.join_to_translate.c:5
-#, fuzzy
msgid "Join column in map table"
-msgstr "Vermisse Spalte <%s> in der Tabelle <%s>."
+msgstr ""
+"Spalte der Vektorkartentabelle, die für den Join verwendet werden soll."
#: ../locale/scriptstrings/v.db.join_to_translate.c:6
msgid "Other table name"
msgstr "Anderer Tabellenname"
#: ../locale/scriptstrings/v.db.join_to_translate.c:7
-#, fuzzy
msgid "Join column in other table"
+msgstr "Spalte in der anderen Tabelle, die für den Join verwendet werden soll."
#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
-#, fuzzy
msgid "Import E00 file into a vector map."
-msgstr "von"
+msgstr "Importiert eine E00-Datei in eine Vektorkarte."
#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
msgid "E00 file"
msgstr "E00 Datei"
#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
-#, fuzzy
msgid "Input type point, line or area"
-msgstr "Wähle Typ aus: Linie oder Fläche"
+msgstr "Eingabetyp Punkt, Linie oder Fläche."
msgid ""
"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
"vector map."
msgstr ""
+"Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Gerät in eine "
+"Vektorkarte."
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:4
msgid "Download Waypoints from GPS"
@@ -2965,23 +2906,24 @@
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:7
msgid "Force import of track or route data as points"
-msgstr ""
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:8
msgid "Use gardump instead of gpstrans as the download program"
-msgstr ""
+msgstr "Verwende gardump anstelle von gpstrans zum herunterladen."
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:9
msgid "Import track in 3D (gardump only)"
-msgstr ""
+msgstr "Importiere Track in 3D (nur gardump)."
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:12
msgid "Port Garmin receiver is connected to"
-msgstr ""
+msgstr "Das Garmin-Gerät ist verbunden mit Port "
#: ../locale/scriptstrings/i.oif_to_translate.c:1
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
msgstr ""
+"Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
#: ../locale/scriptstrings/i.oif_to_translate.c:2
msgid "raster, imagery, statistics"
@@ -3404,9 +3346,9 @@
msgstr ""
#: ../imagery/i.pca/support.c:27 ../raster/r.random.surface/save.c:217
-#, fuzzy, c-format
+#, c-format
msgid "Unable to write color table for raster map <%s>"
-msgstr "Kann die Farbtabelle der Rasterkarte <%s> nicht lesen."
+msgstr "Kann die Farbtabelle der Rasterkarte <%s> nicht schreiben."
#: ../imagery/i.pca/support.c:43
msgid "Eigen values:"
@@ -3589,7 +3531,7 @@
#: ../raster/r.resamp.rst/main.c:234 ../raster/r.resamp.rst/main.c:242
#: ../raster/r.resamp.rst/main.c:250 ../raster/r.resamp.rst/main.c:258
msgid "Settings"
-msgstr ""
+msgstr "Einstellungen"
#: ../imagery/i.cluster/main.c:106
#, fuzzy
@@ -4180,7 +4122,7 @@
#: ../imagery/i.vi/main.c:106
#, fuzzy
msgid "Name of the red channel surface reflectance map"
-msgstr "Name der Karte mit der fraktalen Oberfläche."
+msgstr "Name einer existierenden Vektorkarte."
#: ../imagery/i.vi/main.c:107 ../imagery/i.vi/main.c:114
#: ../imagery/i.vi/main.c:121 ../imagery/i.vi/main.c:128
@@ -4196,7 +4138,7 @@
#: ../imagery/i.vi/main.c:120
#, fuzzy
msgid "Name of the green channel surface reflectance map"
#: ../imagery/i.vi/main.c:127
#, fuzzy
@@ -4206,12 +4148,12 @@
#: ../imagery/i.vi/main.c:134
#, fuzzy
msgid "Name of the chan5 channel surface reflectance map"
+msgstr "Name der Rasterkarte mit Mannings n."
#: ../imagery/i.vi/main.c:141
#, fuzzy
msgid "Name of the chan7 channel surface reflectance map"
#: ../imagery/i.vi/main.c:159
msgid "sr index requires red and nir maps"
@@ -4691,9 +4633,9 @@
#: ../imagery/i.rgb.his/main.c:101 ../imagery/i.his.rgb/main.c:103
#: ../raster/r.clump/clump.c:238
-#, fuzzy, c-format
+#, c-format
msgid "Failed writing raster map row %d"
-msgstr "Schreiben der Zeile der Rasterkarte fehlgeschlagen."
+msgstr "Schreiben der Zeile %d der Rasterkarte fehlgeschlagen."
#: ../imagery/i.rgb.his/openfiles.c:28 ../imagery/i.rgb.his/openfiles.c:30
#: ../imagery/i.rgb.his/openfiles.c:32 ../imagery/i.his.rgb/openfiles.c:21
@@ -5026,7 +4968,7 @@
#: ../imagery/i.albedo/main.c:166
#, fuzzy
msgid "At least two raster maps are required"
-msgstr "Titel der Ausgabe-Rasterkarte."
+msgstr "Ausgabe-Rasterkarte erforderlich."
#: ../imagery/i.albedo/main.c:194
#, fuzzy, c-format
@@ -5088,7 +5030,7 @@
#: ../imagery/i.modis.qc/main.c:75
#, fuzzy
msgid "Name of QC type to extract"
#: ../imagery/i.modis.qc/main.c:76
#, fuzzy
@@ -5110,7 +5052,7 @@
#: ../imagery/i.modis.qc/main.c:87
#, fuzzy
msgid "Name of the surface reflectance QC layer [bit array]"
+msgstr "Name einer neuen Rasterkarte."
#: ../imagery/i.modis.qc/main.c:95
msgid "Band number of Modis product 250m=[1,2],500m=[1-7]"
@@ -5284,12 +5226,12 @@
#: ../imagery/i.latlong/main.c:63
#, fuzzy
msgid "Name of the output latitude or longitude layer"
-msgstr "Name der Eingabe-Vektorkarte."
+msgstr "Name der Ausgabe-Rasterkarte mit zufälliger Oberfläche."
#: ../imagery/i.latlong/main.c:67
#, fuzzy
msgid "Longitude output"
-msgstr "Lese r.stats Ausgabe."
+msgstr "Regionsensitive Ausgabe"
#: ../imagery/i.latlong/main.c:80
#, fuzzy, c-format
@@ -5586,18 +5528,20 @@
msgstr "Vektor, Topology"
#: ../vector/v.build/main.c:35
-#, fuzzy
msgid "Creates topology for GRASS vector map."
-msgstr "Erzeugt Paint-Label für GRASS Vektordateien und angehängte Label."
+msgstr "Erzeugt Topologie für GRASS Vektorkarten."
#: ../vector/v.build/main.c:42
-#, fuzzy
msgid "Name for vector map where erroneous vector features are written to"
-msgstr "Name der Ausgabekarte, in die die Fehler geschrieben werden sollen."
+msgstr ""
+"Name der Vektorkarte, in die fehlerhafte Vektor-Features geschrieben werden "
+"sollen."
#: ../vector/v.build/main.c:53
msgid "Build topology or dump topology or spatial index to stdout"
msgstr ""
+"Erzeuge Topologie oder schreibe die Topologie oder den räumlichen Index nach "
+"stdout."
#: ../vector/v.build/main.c:55
msgid ""
@@ -6006,9 +5950,8 @@
msgstr ""
#: ../vector/v.net.iso/main.c:106 ../vector/v.net.alloc/main.c:103
-#, fuzzy
msgid "Node cost column (number)"
-msgstr "Anzahl der Spalten"
+msgstr "Spalte mit Kosten für Knoten (Zahl)."
#: ../vector/v.net.iso/main.c:112
msgid ""
@@ -6023,9 +5966,8 @@
#: ../vector/v.net.iso/main.c:126 ../vector/v.net.salesman/main.c:135
#: ../vector/v.net.steiner/main.c:393 ../vector/v.net.alloc/main.c:116
#: ../vector/v.net.path/main.c:101 ../display/d.path/main.c:121
-#, fuzzy
msgid "Use geodesic calculation for longitude-latitude locations"
-msgstr "%s funktioniert nicht in einer Lat/Lon-Location."
+msgstr "Verwende gedätische Berechnungen für Longitude-Latitude Locations."
#: ../vector/v.net.iso/main.c:158
#, c-format
@@ -6038,9 +5980,9 @@
msgstr ""
#: ../vector/v.net.iso/main.c:163
-#, fuzzy, c-format
+#, c-format
msgid "Iso cost %d: %f"
-msgstr "Durchlauf %d (von %d)."
+msgstr "Iso Kosten %d: %f"
#: ../vector/v.net.iso/main.c:170
msgid "Not enough costs, everything reachable falls to first band"
@@ -6316,9 +6258,9 @@
msgstr "Schreibe Attribute ..."
#: ../vector/v.generalize/misc.c:174 ../vector/v.to.points/main.c:268
-#, fuzzy, c-format
+#, c-format
msgid "Unable to copy table <%s>"
-msgstr "Kann temporäre Datei nicht öffnen."
+msgstr "Kann die Tabelle <%s> nicht kopieren."
#: ../vector/v.extrude/main.c:67
msgid "vector, geometry, 3D"
@@ -6329,38 +6271,32 @@
msgstr "Presst flache Vektorobjekte in eine 3D-Form mit definierter Höhe."
#: ../vector/v.extrude/main.c:73
-#, fuzzy
msgid "Trace elevation"
-msgstr "Profildatei"
+msgstr "Zeichne die Höhen nach"
#: ../vector/v.extrude/main.c:76
-#, fuzzy
msgid "Name of input 2D vector map"
-msgstr "von"
+msgstr "Name der Eingabe 2D Vektorkarte."
#: ../vector/v.extrude/main.c:79
-#, fuzzy
msgid "Name of resulting 3D vector map"
-msgstr "von"
+msgstr "Name der resultierenden 3D Vektorkarte."
#: ../vector/v.extrude/main.c:83 ../vector/v.transform/main.c:146
-#, fuzzy
msgid "Shifting value for z coordinates"
-msgstr "für z"
+msgstr "Verschiebewert für Z-Koordinate."
#: ../vector/v.extrude/main.c:91
msgid "Elevation raster for height extraction"
msgstr "Höhenmodell zum Extrahieren der Höhen."
#: ../vector/v.extrude/main.c:98
-#, fuzzy
msgid "Fixed height for 3D vector objects"
-msgstr "für"
+msgstr "Feste Höhe für 3D Vektorobjekte."
#: ../vector/v.extrude/main.c:103
-#, fuzzy
msgid "Name of attribute column with object heights"
-msgstr "von attribute Tabelle"
+msgstr "Nam der Spalte der Attributtabelle mit Objekthöhen."
#: ../vector/v.extrude/main.c:117
#, c-format
@@ -6374,7 +6310,7 @@
#: ../vector/v.extrude/main.c:196 ../vector/v.out.svg/main.c:210
#, c-format
msgid "Skipping area %d without centroid"
-msgstr ""
+msgstr "Überspringe Fläche %d ohne Zentroid."
#: ../vector/v.extrude/main.c:211
#, fuzzy, c-format
@@ -6465,14 +6401,13 @@
msgstr "Kann Tabelle nicht erzeugen: %s"
#: ../vector/v.in.dxf/write_vect.c:221
-#, fuzzy, c-format
+#, c-format
msgid "Unable to add database link for vector map <%s>"
-msgstr "Kann die Layer-Informationen der Vektorkarte nicht auswählen."
+msgstr "Kann den Link zur Datenbank der Vektorkarte <%s> nicht hinzufügen."
#: ../vector/v.in.dxf/add_polyline.c:46
-#, fuzzy
msgid "vertices following flag missing"
-msgstr "TEXT: Vertizes"
+msgstr "Vertices folgender Schalter fehlt."
#: ../vector/v.in.dxf/add_polyline.c:70
#, c-format
@@ -6502,9 +6437,8 @@
msgstr "Erzeuge keine Topologie."
#: ../vector/v.in.dxf/main.c:86
-#, fuzzy
msgid "Import polyface meshes as 3D wire frame"
-msgstr "Import"
+msgstr "Importiert Polface-Netze als Drahtgittermodell."
#: ../vector/v.in.dxf/main.c:91 ../vector/v.in.dxf/main.c:97
#: ../vector/v.in.dxf/main.c:102 ../vector/v.in.dxf/main.c:116
@@ -6530,7 +6464,7 @@
#: ../vector/v.in.dxf/main.c:167
msgid "Building topology failed"
-msgstr ""
+msgstr "Erstellen der Topologie fehlgeschlagen."
#: ../vector/v.in.dxf/main.c:173
msgid "Failed to import DXF file!"
@@ -6622,9 +6556,8 @@
#: ../vector/v.transform/main.c:340 ../vector/v.clean/main.c:275
#: ../vector/v.kcv/main.c:156 ../vector/v.category/main.c:523
#: ../vector/v.type/main.c:229 ../vector/v.build.polylines/main.c:208
-#, fuzzy
msgid "Failed to copy attribute table to output map"
+msgstr "Kopieren der Attributtabelle in die Ausgabekarte fehlgeschlagen."
#: ../vector/v.vol.rst/user1.c:93 ../vector/v.buffer/main.c:379
#: ../vector/v.class/main.c:101 ../vector/v.to.rast3/main.c:79
@@ -6768,7 +6701,7 @@
#: ../raster/r.sun2/main.c:416 ../raster/r.horizon/main.c:271
#: ../raster/r.horizon/main.c:281 ../raster/r.horizon/main.c:289
msgid "Output_options"
-msgstr ""
+msgstr "Ausgabe Optionen"
#: ../vector/v.vol.rst/main.c:372
#, fuzzy
@@ -6887,9 +6820,8 @@
"benötigt aber den topologischen Modus."
#: ../vector/v.db.select/main.c:156
-#, fuzzy
msgid "Unable to open select cursor"
-msgstr "Kann den Select-Cursor '%s' nicht öffnen."
+msgstr "Kann den Select-Cursor nicht öffnen."
#: ../vector/v.db.select/main.c:177 ../vector/v.reclass/main.c:235
#, c-format
@@ -7100,9 +7032,8 @@
#: ../display/d.vect/main.c:341 ../display/d.thematic.area/main.c:129
#: ../display/d.thematic.area/main.c:132 ../display/d.rast/main.c:68
#: ../display/d.rast/main.c:77 ../display/d.rast/main.c:94
-#, fuzzy
msgid "Selection"
-msgstr "Auflösung"
+msgstr "Selektion"
#: ../vector/v.select/main.c:178
#, fuzzy
@@ -8384,9 +8315,8 @@
msgstr "Kann Zeile nicht einfügen: %s"
#: ../vector/v.reclass/main.c:64
-#, fuzzy
msgid "vector, reclass, attributes"
+msgstr "Vektor, Re-Klassifizierung, Attribute"
#: ../vector/v.reclass/main.c:66
msgid ""
@@ -8484,9 +8414,9 @@
msgstr "Unvollständige Regel"
#: ../vector/v.reclass/main.c:426
-#, fuzzy, c-format
+#, c-format
msgid "%d features reclassed."
-msgstr "%d Feature gelöscht"
+msgstr "%d Feature reklassifiziert."
#: ../vector/v.parallel2/main.c:45
#, fuzzy
@@ -10007,11 +9937,10 @@
msgstr "Ausgabekarte mit den Punkten wird geschrieben."
#: ../vector/v.lrs/v.lrs.segment/main.c:111 ../vector/v.segment/main.c:71
-#, fuzzy
msgid "Name of file containing segment rules. If not given, read from stdin."
msgstr ""
-"Name der Datei, die Graph>ikkommandos enthält. Falls nicht angegeben, wird "
-"von der Standardeingabe gelesen."
+"Name der Datei, die Segment-Regeln enthält. Falls nicht angegeben, wird von "
+"stdin gelesen."
#: ../vector/v.lrs/v.lrs.segment/main.c:130 ../vector/v.segment/main.c:92
#: ../vector/v.net.path/path.c:49 ../general/g.cairocomp/main.c:45
@@ -10112,9 +10041,9 @@
msgstr ""
#: ../vector/v.lrs/v.lrs.segment/main.c:330 ../vector/v.segment/main.c:219
-#, fuzzy, c-format
+#, c-format
msgid "Incorrect segment type: %s"
-msgstr "Kann die Segmentdatei %s nicht erzeugen."
+msgstr "Falscher Segmenttyp: %s"
#: ../vector/v.lrs/v.lrs.segment/main.c:346
#, fuzzy, c-format
@@ -10616,19 +10545,20 @@
#, c-format
msgid "Feature has more categories. Only first category (%d) is exported."
msgstr ""
+"Feature hat mehrere Kategorien. Nur die erste Kategorie (%d) wurde "
+"exportiert."
#: ../vector/v.out.ascii/b2a.c:197
-#, fuzzy, c-format
+#, c-format
msgid "Unable to select record from table <%s> (key %s, column %s)"
-msgstr "Kann Daten nicht aus der Tabelle selektieren."
+msgstr "Kann Daten nicht aus der Tabelle selektieren<%s> (key %s, column %s)."
#: ../vector/v.out.ascii/b2a.c:224
-#, fuzzy, c-format
+#, c-format
msgid "Column <%s>: unsupported data type"
-msgstr "Spalte <%s>: ungültiger Datentyp."
+msgstr "Spalte <%s>: nicht unterstützter Datentyp."
#: ../vector/v.out.ascii/main.c:47
-#, fuzzy
msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
msgstr ""
"Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
@@ -10653,9 +10583,9 @@
msgstr "Punkte"
#: ../vector/v.out.ascii/main.c:83
-#, fuzzy
msgid "Name of attribute column(s) to be exported (point mode)"
+msgstr ""
+"Name der Attribut-Spalte(n) die exportiert werden sollen (Punkt-Modus)."
#: ../vector/v.out.ascii/main.c:91
msgid "Create old (version 4) ASCII file"
@@ -10664,11 +10594,13 @@
#: ../vector/v.out.ascii/main.c:96
msgid "Only export points falling within current 3D region (points mode)"
msgstr ""
+"Exportiere nur Punkte, die sich in der aktuellen 3D Region befinden (Punkt-"
+"Modus)."
#: ../vector/v.out.ascii/main.c:110
#, c-format
msgid "Parameter '%s' ignored in standard mode"
-msgstr ""
+msgstr "Parameter '%s' wird im Standard-Modus ignoriert."
#: ../vector/v.out.ascii/main.c:118
msgid "Format 'point' is not supported for old version"
@@ -10683,9 +10615,9 @@
msgstr "dig_att Datei existiert bereits."
#: ../vector/v.out.ascii/main.c:179
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open dig_att file <%s>"
-msgstr "Kann die dig_att Datei <%s> nicht öffnen.\n"
+msgstr "Kann die dig_att Datei <%s> nicht öffnen."
#: ../vector/v.in.region/main.c:39
#, fuzzy
@@ -10718,7 +10650,7 @@
#: ../vector/v.in.ascii/main.c:67
msgid "point;simple x,y[,z] list;standard;GRASS's vector ASCII format"
-msgstr ""
+msgstr "Punkt; einfache x,y[,z] Liste;Standard;GRASSs Vektor-ASCII-Format"
#: ../vector/v.in.ascii/main.c:70
msgid "Input file format"
@@ -10738,38 +10670,36 @@
#: ../vector/v.in.ascii/main.c:89
msgid "Column definition in SQL style (points mode)"
-msgstr ""
+msgstr "Spaltendefinition im SQL-Stil (Punkt-Modus)."
#: ../vector/v.in.ascii/main.c:90
-#, fuzzy
msgid ""
"For example: 'x double precision, y double precision, cat int, name varchar"
"(10)'"
msgstr ""
-"Spaltendefinition für den Punkt-Modus im SQL-Stil, z.B.: 'x double "
-"precision, y double precision, cat int, name varchar(10)'"
+"Zum Beispiel: 'x double precision, y double precision, cat int, name varchar"
+"(10)'"
#: ../vector/v.in.ascii/main.c:102
msgid ""
"Number of column used as x coordinate (first column is 1) for points mode"
msgstr ""
-"Nummer der Spalte im Punkt-Modus, die als X-Koordinate genutzt werden soll "
-"(erste Spalte is 1)."
+"Nummer der Spalte, die im Punkt-Modus als X-Koordinate genutzt werden soll "
+"(erste Spalte ist 1)."
#: ../vector/v.in.ascii/main.c:112
msgid ""
"Number of column used as y coordinate (first column is 1) for points mode"
msgstr ""
-"Nummer der Spalte im Punkt-Modus, die als Y-Koordinate genutzt werden soll "
+"Nummer der Spalte, die im Punkt-Modus als Y-Koordinate genutzt werden soll "
#: ../vector/v.in.ascii/main.c:122
-#, fuzzy
msgid ""
"Number of column used as z coordinate (first column is 1) for points mode"
msgstr ""
+"Nummer der Spalte, die im Punkt-Modus als Z-Koordinate genutzt werden soll "
#: ../vector/v.in.ascii/main.c:124
msgid "If 0, z coordinate is not used"
@@ -10778,8 +10708,8 @@
#: ../vector/v.in.ascii/main.c:134
msgid "Number of column used as category (first column is 1) for points mode"
msgstr ""
+"Nummer der Spalte, die im Punkt-Modus als Kategorie genutzt werden soll "
#: ../vector/v.in.ascii/main.c:136
msgid ""
@@ -10789,10 +10719,10 @@
"Zeile geschrieben."
#: ../vector/v.in.ascii/main.c:145
-#, fuzzy
msgid "Create a new empty vector map and exit. Nothing is read from input"
msgstr ""
-"Erstellt eine neue und leere Karte und beendet sich. Nichts wird eingelesen."
+"Erstellt eine neue, leere Vektorkarte und beendet sich. Nichts wird "
+"eingelesen."
#: ../vector/v.in.ascii/main.c:150
msgid "Don't expect a header when reading in standard format"
@@ -10809,6 +10739,7 @@
#: ../vector/v.in.ascii/main.c:164
msgid "Only import points falling within current region (points mode)"
msgstr ""
+"Importiere nur Punkte die sich innerhalb der aktuellen Region befinden."
#: ../vector/v.in.ascii/main.c:178
msgid "Please specify reasonable number of lines to skip"
@@ -10825,9 +10756,8 @@
msgstr "Bitte geben Sie angemessene Z-Spalte an."
#: ../vector/v.in.ascii/main.c:197
-#, fuzzy
msgid "Column numbers must not be negative"
-msgstr "Schlüssel-Spalte (key column) muss vom Typ integer sein."
+msgstr "Spaltennummern dürfen nicht negativ sein."
#: ../vector/v.in.ascii/main.c:201 ../vector/v.edit/main.c:76
#, c-format
@@ -10835,9 +10765,9 @@
msgstr "Kann die ASCII-Datei <%s> nicht öffnen."
#: ../vector/v.in.ascii/main.c:253
-#, fuzzy, c-format
+#, c-format
msgid "Maximum input row length: %d"
-msgstr "Maximale Anzahl der Wiederholungen: %d\n"
+msgstr "Maximale Länge der Inputzeile: %d"
#: ../vector/v.in.ascii/main.c:254
#, c-format
@@ -10973,7 +10903,7 @@
#: ../vector/v.in.ascii/a2b.c:143
msgid "End of ASCII file reached before end of categories"
-msgstr ""
+msgstr "Ende der ASCII-Datei vor dem Ende der Kategorien erreicht."
#: ../vector/v.in.ascii/a2b.c:153
#, c-format
@@ -11015,22 +10945,19 @@
#: ../vector/v.in.ascii/head.c:56
#, c-format
msgid "Unknown keyword <%s> in vector head"
-msgstr "Unbekanntes Schlüsselwort <%s im Vektor-Header."
+msgstr "Unbekanntes Schlüsselwort <%s im Vektorheader."
#: ../vector/v.segment/main.c:54
-#, fuzzy
msgid "Creates points/segments from input vector lines and positions."
-msgstr "Erzeuge Punkte entlang der Eingabelinie."
+msgstr "Erzeuge Punkte/Segmente aus den Input Vektorlinien und Positionen."
#: ../vector/v.segment/main.c:57
-#, fuzzy
msgid "Name of input vector map containing lines"
-msgstr "Eingabekarte enthält Linien."
+msgstr "Namde der Eingabe-Vektorkarte mit Linien."
#: ../vector/v.segment/main.c:61
-#, fuzzy
msgid "Name for output vector map where segments will be written"
-msgstr "Ausgabekarte mit den Punkten wird geschrieben."
+msgstr "Name der Ausgabe-Vektorkarte, in die die Segmente geschrieben werden."
#: ../vector/v.segment/main.c:134 ../vector/v.segment/main.c:174
#, c-format
@@ -11038,9 +10965,9 @@
msgstr "Kann Eingabe nicht lesen: %s"
#: ../vector/v.segment/main.c:144 ../vector/v.segment/main.c:183
-#, fuzzy, c-format
+#, c-format
msgid "Unable to find line of cat %d"
-msgstr "Kann die Vektorkarte [%s] nicht finden."
+msgstr "Kann die Linie mit cat '%d' nicht finden."
#: ../vector/v.segment/main.c:154
#, c-format
@@ -11210,9 +11137,10 @@
msgstr "%d Feature verändert"
#: ../vector/v.to.points/main.c:174
-#, fuzzy
msgid "Create points along input lines in new vector with 2 layers."
+msgstr ""
+"Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei "
+"Layern."
#: ../vector/v.to.points/main.c:181
msgid "Output vector map where points will be written"
@@ -11231,9 +11159,8 @@
msgstr "Interpoliere Punkte zwischen den Vertices der Linien."
#: ../vector/v.to.points/main.c:208
-#, fuzzy
msgid "Maximum distance between points in map units"
-msgstr "Maximale Distanz zwischen den Punkten in Karteneinheiten (mapunits)."
+msgstr "Maximale Distanz zwischen den Punkten in Karteneinheiten (map units)."
#: ../vector/v.to.points/main.c:228
msgid "Use either -n or -v flag, not both"
@@ -11395,10 +11322,9 @@
#: ../vector/v.what.rast/main.c:81
-#, fuzzy
msgid "Uploads raster values at positions of vector points to the table."
msgstr ""
-"Überninmmt die Rasterwerte an einem angegebenen Vektor-Punkt in die "
+"Übernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die "
"Attributtabelle."
#: ../vector/v.what.rast/main.c:86
@@ -12110,9 +12036,8 @@
msgstr "Punkt Klassifikation."
#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:536
-#, fuzzy
msgid "<Auxiliar_edge_table> created in database."
-msgstr "in."
+msgstr "<Auxiliar_edge_table> in der Datenbank erzeugt."
#: ../vector/v.mapcalc/number.c:159
msgid "Can't call bad num-function"
@@ -12349,52 +12274,48 @@
"Finds the nearest element in vector map 'to' for elements in vector map "
"'from'."
msgstr ""
+"Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der "
+"Vektorkarte 'from'. "
#: ../vector/v.distance/main.c:120
-#, fuzzy
msgid "Name of existing vector map (from)"
-msgstr "Name einer existierenden Vektorkarte."
+msgstr "Name einer existierenden Vektorkarte (from)."
#: ../vector/v.distance/main.c:121 ../vector/v.distance/main.c:133
#: ../vector/v.distance/main.c:145
-#, fuzzy
msgid "From"
-msgstr "From_map"
+msgstr "From"
#: ../vector/v.distance/main.c:125
-#, fuzzy
msgid "Name of existing vector map (to)"
+msgstr "Name einer existierenden Vektorkarte (to)."
#: ../vector/v.distance/main.c:126 ../vector/v.distance/main.c:140
#: ../vector/v.distance/main.c:150 ../vector/v.distance/main.c:206
msgid "To"
-msgstr ""
+msgstr "To"
#: ../vector/v.distance/main.c:132
-#, fuzzy
msgid "Feature type (from)"
-msgstr "Art des Vektorobjekts."
+msgstr "Art des Vektorobjekts (from)."
#: ../vector/v.distance/main.c:139
-#, fuzzy
msgid "Feature type (to)"
+msgstr "Art des Vektorobjekts (to)."
#: ../vector/v.distance/main.c:144
-#, fuzzy
msgid "Layer number (from)"
-msgstr "Layer-Nummer"
+msgstr "Layer-Nummer (from)."
#: ../vector/v.distance/main.c:149
-#, fuzzy
msgid "Layer number (to)"
+msgstr "Layer-Nummer (to)."
#: ../vector/v.distance/main.c:155
-#, fuzzy
msgid "Name for output vector map containing lines connecting nearest elements"
-msgstr "Neu"
+msgstr ""
+"Ausgabe-Vektorkarte mit Verbindungslinien zwischen den nächstgelgenen "
+"Elementen."
#: ../vector/v.distance/main.c:163
msgid "Maximum distance or -1 for no limit"
@@ -12407,6 +12328,8 @@
#: ../vector/v.distance/main.c:179
msgid "Values describing the relation between two nearest features"
msgstr ""
+"Werte, die die Verbindung zwischen zwei nächstgelegenen Featuren "
+"beschreiben. "
#: ../vector/v.distance/main.c:181
#, fuzzy
@@ -12425,6 +12348,8 @@
msgid ""
"Column name(s) where values specified by 'upload' option will be uploaded"
msgstr ""
+"Name(n) der Spalte(n) in denen, durch die 'upload'-Option bestimmte, Werte "
+"gespeichert werden."
#: ../vector/v.distance/main.c:200
msgid "From_map"
@@ -12433,32 +12358,37 @@
#: ../vector/v.distance/main.c:205
msgid "Column name of nearest feature (used with upload=to_attr)"
msgstr ""
+"Spaltenname der nächstgelegenen Feature (verwendet mit upload=to_attr)."
#: ../vector/v.distance/main.c:211
-#, fuzzy
msgid "Name of table created for output when the distance to all flag is used"
+msgstr ""
+"Name der auszugebenden Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' "
+"gesetzt wurde."
#: ../vector/v.distance/main.c:216
-#, fuzzy
msgid "Print output to stdout, don't update attribute table"
-msgstr "Drucke"
+msgstr ""
+"Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
#: ../vector/v.distance/main.c:218
-#, fuzzy
msgid "First column is always category of 'from' feature called from_cat"
-msgstr "Drucke"
+msgstr ""
+"Die erste Spalte ist immer die Kategorie der 'from'-Feature und 'from_cat' "
+"benannt."
#: ../vector/v.distance/main.c:223
msgid "Calculate distances to all features within the threshold"
-msgstr ""
+msgstr "Berechne Distanzen zu allen Features innerhalb des Schwellwertes."
#: ../vector/v.distance/main.c:224
-#, fuzzy
msgid ""
"The output is written to stdout but may be uploaded to a new table created "
"by this module. From categories are may be multiple."
-msgstr "Berechnen Objekte"
+msgstr ""
+"Die Ausgabe wird nach stdout geschrieben und kann ebenfalls in eine neue "
+"Tabelle geschrieben werden, die von diesem Modul erzeugt wird. Es kann "
+"mehrere 'from' Kategorien geben."
#: ../vector/v.distance/main.c:275
msgid "to_column option missing"
@@ -12533,14 +12463,15 @@
msgstr "%d Kategorien existieren in der Tabelle"
#: ../vector/v.distance/main.c:1118
-#, fuzzy, c-format
+#, c-format
msgid "%d categories read from the map exist in the table"
-msgstr "von Tabelle"
+msgstr ""
+"%d aus der Karte gelesene Kategorien existieren bereits in der Tabelle."
#: ../vector/v.distance/main.c:1121
-#, fuzzy, c-format
+#, c-format
msgid "%d categories read from the map don't exist in the table"
+msgstr "%d aus der Karte gelesene Kategorien existieren nicht in der Tabelle."
#: ../vector/v.type/main.c:47
msgid "Change the type of geometry elements."
@@ -12824,11 +12755,12 @@
msgstr "Vektor, Editieren, Geometrie"
#: ../vector/v.edit/main.c:55
-#, fuzzy
msgid ""
"Edits a vector map, allows adding, deleting and modifying selected vector "
"features."
-msgstr "in."
+msgstr ""
+"Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ändern "
+"ausgewählter Vektor Feature."
#: ../vector/v.edit/main.c:64
#, c-format
@@ -12841,11 +12773,13 @@
msgstr "Vektorkarte <%s> existiert bereits."
#: ../vector/v.edit/main.c:131
-#, fuzzy, c-format
+#, c-format
msgid ""
"Unable to open vector map <%s> as the background map. It is given as vector "
"map to be edited."
-msgstr "Kann Vektorkarte <%s> in <%s> nicht öffnen."
+msgstr ""
+"Kann Vektorkarte <%s> nicht als Hintergrundkarte öffnen, da sie als zu "
+"editierende Karte ausgewählte wurde."
#: ../vector/v.edit/main.c:142
#, c-format
@@ -12853,9 +12787,8 @@
msgstr "Hintergrund Vektorkarte <%s> registriert."
#: ../vector/v.edit/main.c:181
-#, fuzzy
msgid "Selecting features..."
-msgstr "Sammle Statistiken..."
+msgstr "Selektiere Feature..."
#: ../vector/v.edit/main.c:193
msgid "No features selected, nothing to edit"
@@ -12931,6 +12864,8 @@
"Multiple background maps were given. Selected features will be copied only "
"from vector map <%s>."
msgstr ""
+"Mehrere Hintergrundkarten wurden angegeben. Selektierte Feature werden nur "
+"von der Vektorkarte <%s> kopiert."
#: ../vector/v.edit/main.c:329
#, c-format
@@ -12948,9 +12883,9 @@
msgstr "%d Linien beschriftet"
#: ../vector/v.edit/main.c:365
-#, fuzzy, c-format
+#, c-format
msgid "%d features converted"
-msgstr "%d Feature verschoben"
+msgstr "%d Feature konvertiert."
#: ../vector/v.edit/main.c:368
msgid "No feature modified"
@@ -12986,9 +12921,9 @@
msgstr "Unbekanntes Schlüsselwort '%s' im Vektor-Header."
#: ../vector/v.edit/a2b.c:328 ../vector/v.edit/snap.c:111
-#, fuzzy, c-format
+#, c-format
msgid "Unable to rewrite line %d"
-msgstr "Kann kein Face erzeugen."
+msgstr "Kann die Zeile %d nicht zurückschreiben."
#: ../vector/v.edit/select.c:72
#, c-format
@@ -13034,11 +12969,8 @@
msgstr ""
#: ../vector/v.edit/args.c:100
-#, fuzzy
msgid "ASCII file to be converted to binary vector map"
-msgstr ""
-"Konvertiert eine GRASS-ASCII-Datei oder eine Punktdatei in eine GRASS-"
-"Vektordatei."
+msgstr "ASCII-Datei, die in eine Vektorkarte konvertiert werden soll."
#: ../vector/v.edit/args.c:102
msgid "If not given (or \"-\") reads from standard input"
@@ -13047,15 +12979,16 @@
#: ../vector/v.edit/args.c:112
msgid "Difference in x,y direction for moving feature or vertex"
msgstr ""
+"Differenz in x,y Richtung für das Verschieben eines Features oder Vertex."
#: ../vector/v.edit/args.c:119
msgid "Threshold distance (coords,snap,query)"
msgstr "Schwellwerte (coords,snap,query)."
#: ../vector/v.edit/args.c:121
-#, fuzzy
msgid "'-1' for threshold based on the current resolution settings"
-msgstr "Gib die Ausdehnung der aktuellen Region aus."
+msgstr ""
+"'-1' um den Schwellwert auf Basis der aktuellen Auflösung zu bestimmen."
#: ../vector/v.edit/args.c:137
msgid "List of point coordinates"
@@ -13063,11 +12996,11 @@
#: ../vector/v.edit/args.c:146
msgid "Bounding box for selecting features"
-msgstr ""
+msgstr "Bounding box zur Auswahl von Features."
#: ../vector/v.edit/args.c:155
msgid "Polygon for selecting features"
-msgstr ""
+msgstr "Polygon zur Auswahl von Features."
#: ../vector/v.edit/args.c:165
msgid "Query tool"
@@ -13076,6 +13009,8 @@
#: ../vector/v.edit/args.c:167
msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
msgstr ""
+"Für 'Kürzere' verwenden Sie einen negativen Schwellwert und positive Werte "
+"für 'Längere'."
#: ../vector/v.edit/args.c:170
msgid ""
@@ -13084,9 +13019,8 @@
msgstr ""
#: ../vector/v.edit/args.c:178
-#, fuzzy
msgid "Name of background vector map(s)"
+msgstr "Name der Hintergrund-Vektorkarte(n)."
#: ../vector/v.edit/args.c:185
msgid ""
@@ -13102,24 +13036,24 @@
#: ../vector/v.edit/args.c:195
msgid "Starting value and step for z bulk-labeling"
-msgstr ""
+msgstr "Startwert und Schrittgröße für Massenbeschriftung von z."
#: ../vector/v.edit/args.c:196
msgid "Pair: value,step (e.g. 1100,10)"
-msgstr ""
+msgstr "Paar: Wert,Schrittgröße (z.B. 1100,10)"
#: ../vector/v.edit/args.c:207
msgid "Close added boundaries (using threshold distance)"
msgstr ""
+"Schließe hinzugefügte Grenzlinien (unter Verwendung der Schwellwert Distanz)."
#: ../vector/v.edit/args.c:211
-#, fuzzy
msgid "Do not expect header of input data"
-msgstr "Kann den Zellenheader nicht holen."
+msgstr "Erwarte keinen Header in den Inputdaten."
#: ../vector/v.edit/args.c:221
msgid "Modify only first found feature in bounding box"
-msgstr ""
+msgstr "Verändere nur das zuerst gefundene Feature in der Bouding Box."
#: ../vector/v.edit/args.c:233
msgid "Polygon must have at least 3 coordinate pairs"
@@ -13133,14 +13067,14 @@
#: ../vector/v.edit/args.c:303
#, c-format
msgid "At least one option from %s must be specified"
-msgstr "ZUmindest eine Option von %s muss angegeben werden."
+msgstr "Zumindest eine Option von %s muss angegeben werden."
#: ../vector/v.edit/args.c:309 ../vector/v.edit/args.c:318
#: ../vector/v.edit/args.c:325 ../vector/v.edit/args.c:332
#: ../vector/v.edit/args.c:336
#, c-format
msgid "Tool %s requires option %s"
-msgstr ""
+msgstr "Werkzeug %s erfordert Option %s."
#: ../vector/v.patch/main.c:69
#, fuzzy
@@ -13711,14 +13645,13 @@
msgstr "s von"
#: ../vector/v.univar/main.c:129
-#, fuzzy
msgid "Extended statistics is currently supported only for points/centroids"
-msgstr "Der Schalter '-z' würd nur für Punkte unterstützt."
+msgstr ""
+"Erweiterte Statistiken werden zur Zeit nur für Punkte/Zentroide unterstützt."
#: ../vector/v.univar/main.c:410
-#, fuzzy
msgid "Cannot sort the key/value array"
-msgstr "Kann nicht an Tabelle '%s' anfügen."
+msgstr "Kann das key/value array nicht sortieren."
#: ../vector/v.net.path/path.c:82
#, fuzzy, c-format
@@ -13859,12 +13792,11 @@
#: ../vector/v.build.polylines/main.c:110
msgid "Builds polylines from lines or boundaries."
-msgstr ""
+msgstr "Erstellt Poly-Linien aus Linien und Grenzen."
#: ../vector/v.build.polylines/main.c:120
-#, fuzzy
msgid "Category number mode"
-msgstr "Spaltenname für Kategoriewerte."
+msgstr "Kategorienummer-Modus."
#: ../vector/v.build.polylines/main.c:122
msgid ""
@@ -13879,9 +13811,9 @@
msgstr "%d Linien oder Grenzen in der Vektorkarte <%s@%s> gefunden."
#: ../vector/v.build.polylines/main.c:202
-#, fuzzy, c-format
+#, c-format
msgid "%d polylines stored in vector map <%s@%s>"
-msgstr "%d Punkte in die Vektorkarte geschrieben."
+msgstr "%d Polylinien in der Vektorkarte <%s@%s> gespeichert."
#: ../vector/v.perturb/main.c:74
#, fuzzy
@@ -15700,7 +15632,7 @@
#, c-format
msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
msgstr ""
-"Hinweis: Bitte benutzen Sie 'd.erase', um das Grafik-Fenster auf die neue "
+"Hinweis: Bitte benutzen Sie 'd.erase', um das Grafikfenster auf die neue "
"Region einzustellen.\n"
#: ../display/d.rast.num/main.c:72
@@ -15766,7 +15698,7 @@
#: ../display/d.vect/main.c:123
msgid "Displays vector data in the active frame on the graphics monitor."
-msgstr "Stellt GRASS Vektorkarten im aktiven Grafik-Fenster dar."
+msgstr "Stellt GRASS Vektorkarten im aktiven Grafikfenster dar."
#: ../display/d.vect/main.c:135
msgid "Display"
@@ -16127,7 +16059,7 @@
#: ../display/d.erase/main.c:32
msgid "Erase the contents of the active display frame with user defined color"
msgstr ""
-"Löscht den Inhalte des aktiven Grafik-Fensters mit einer benutzerdefinierten "
+"Löscht den Inhalte des aktiven Grafikfensters mit einer benutzerdefinierten "
"Farbe."
#: ../display/d.erase/main.c:40
@@ -16140,7 +16072,7 @@
#: ../display/d.erase/main.c:45
msgid "Remove all frames and erase the screen"
-msgstr "Entferne alle Frames und lösche den Inhalt des Grafik-Fensters."
+msgstr "Entferne alle Frames und lösche den Inhalt des Grafikfensters."
#: ../display/d.where/main.c:46
#, fuzzy
@@ -16154,12 +16086,13 @@
#: ../display/d.where/main.c:56
#, fuzzy
msgid "Display coordinates to convert"
-msgstr "Name des Grafik-Fensters, das gestartet werden soll."
+msgstr "Grafikfensters, das gestartet werden soll."
#: ../display/d.where/main.c:61
#, fuzzy
msgid "File from which to read coordinates (\"-\" to read from stdin)"
-msgstr "ASCII-Datei, die die spektralen Signaturen enthalten."
+msgstr ""
+"Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
#: ../display/d.where/main.c:65
msgid "Output lat/long in decimal degree"
@@ -16180,7 +16113,7 @@
#: ../display/d.where/main.c:81
msgid "Output frame coordinates of current display monitor (percentage)"
-msgstr "Gibt Rahmenkoordinaten des aktuellen Grafik-Fensters in Prozent aus."
+msgstr "Gibt Rahmenkoordinaten des aktuellen Grafikfensters in Prozent aus."
#: ../display/d.where/main.c:89
msgid "Ambiguous request for lat/long ellipsoids"
@@ -16331,7 +16264,7 @@
#: ../display/d.text/main.c:171
msgid "The screen line number on which text will begin to be drawn"
-msgstr "Die Zeile des Grafik-Fensters, in der der Text beginnt."
+msgstr "Die Zeile des Grafikfensters, in der der Text beginnt."
#: ../display/d.text/main.c:179
msgid ""
@@ -16565,7 +16498,7 @@
msgid ""
"Program for generating and displaying simple graphics on the display monitor."
msgstr ""
-"Programm zum Erstellen und Anzeigen von einfachen Grafiken im Grafik-Fenster."
+"Programm zum Erstellen und Anzeigen von einfachen Grafiken im Grafikfenster."
#: ../display/d.graph/main.c:66
msgid ""
@@ -16615,7 +16548,7 @@
#: ../display/d.info/main.c:34
msgid "Display information about the active display monitor"
-msgstr "Zeige Informationen über das aktive Grafik-Fenster."
+msgstr "Zeige Informationen über das aktive Grafikfenster."
#: ../display/d.info/main.c:39
msgid "Display screen rectangle (left, right, top, bottom)"
@@ -16642,7 +16575,7 @@
"Displays a legend for a raster map in the active frame of the graphics "
"monitor."
msgstr ""
-"Zeichnet eine Legende für eine Rasterkarte in dem aktiven Grafik-Fenster."
+"Zeichnet eine Legende für eine Rasterkarte in dem aktiven Grafikfenster."
#: ../display/d.legend/main.c:97
msgid "Sets the legend's text color"
@@ -16769,7 +16702,7 @@
msgid ""
"Displays text labels (created with v.label) to the active frame on the "
"graphics monitor."
-msgstr "Zeigt Text-Label (mit v.label erstellt) im aktiven Grafik-Fenster."
+msgstr "Zeigt Text-Label (mit v.label erstellt) im aktiven Grafikfenster."
#: ../display/d.labels/main.c:52
msgid "Ignore rotation setting and draw horizontally"
@@ -16797,7 +16730,7 @@
"Selects the font in which text will be displayed on the user's graphics "
"monitor."
msgstr ""
-"Selektiert die Schriftart, in welcher der Text im Grafik-Fenster angezeigt "
+"Selektiert die Schriftart, in welcher der Text im Grafikfenster angezeigt "
"wird."
#: ../display/d.font/main.c:56
@@ -16835,7 +16768,7 @@
#: ../display/d.vect.chart/main.c:65
msgid ""
"Displays charts of vector data in the active frame on the graphics monitor."
-msgstr "Stellt Diagramme von Vektordaten im aktiven Grafik-Fenster dar."
+msgstr "Stellt Diagramme von Vektordaten im aktiven Grafikfenster dar."
#: ../display/d.vect.chart/main.c:82
msgid "Chart type"
@@ -17006,11 +16939,10 @@
msgstr "Fehler beim Lesen eine Datenzeile."
#: ../display/d.thematic.area/main.c:78
-#, fuzzy
msgid ""
"Displays a thematic vector area map in the active frame on the graphics "
"monitor."
+msgstr "Stellt eine thematische Vektorkarte im aktiven Grafikfenster dar."
#: ../display/d.thematic.area/main.c:88
msgid "Data to be classified: column name or expression"
@@ -17174,7 +17106,7 @@
msgid ""
"Overlays a user-specified grid in the active display frame on the graphics "
"monitor."
-msgstr "Überlagert ein benutzerdefiniertes Gitter im aktiven Grafik-Fenster."
+msgstr "Überlagert ein benutzerdefiniertes Gitter im aktiven Grafikfenster."
#: ../display/d.grid/main.c:61
msgid "Size of grid to be drawn"
@@ -17332,8 +17264,8 @@
"Measures the lengths and areas of features drawn by the user in the active "
"display frame on the graphics monitor."
msgstr ""
-"Misst die Länge und Fläche von benutzergezeichneten Featuren im aktiven "
-"Grafik-Fenster."
+"Misst die Länge und Fläche von Features, gezeichnet vom Benutzer, im aktiven "
+"Grafikfenster."
#: ../display/d.measure/main.c:55
msgid "Line color 1"
@@ -17345,7 +17277,7 @@
#: ../display/d.measure/main.c:71
msgid "Suppress clear screen"
-msgstr "Unterdrücke das Löschen des Grafik-Fensters."
+msgstr "Unterdrücke das Löschen des Grafikfensters."
#: ../display/d.measure/main.c:75
msgid "Output in meters only"
@@ -17370,7 +17302,7 @@
#: ../display/d.barscale/main.c:54
msgid "Displays a barscale on the graphics monitor."
-msgstr "Zeigt einen Maßstabsbalken im Grafik-Fenster an."
+msgstr "Zeigt einen Maßstabsbalken im Grafikfenster an."
#: ../display/d.barscale/main.c:58
msgid "Use feet/miles instead of meters"
@@ -17410,13 +17342,11 @@
msgstr "Wähle entweder den Schalter -n oder -s."
#: ../display/d.linegraph/main.c:122
-#, fuzzy
msgid ""
"Generates and displays simple line graphs in the active graphics monitor "
"display frame."
msgstr ""
-"Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafik-Fenster "
-"dar."
+"Erzeugt und stellt einfache Liniengrafiken im aktiven Grafikfenster dar."
#: ../display/d.linegraph/main.c:126
#, fuzzy
@@ -17551,7 +17481,7 @@
"Displays and overlays raster map layers in the active display frame on the "
"graphics monitor."
msgstr ""
-"Stellt Rasterkarten im aktiven Grafik-Fenster dar. Überlagerung ist auch "
+"Stellt Rasterkarten im aktiven Grafikfenster dar. Überlagerung ist auch "
"möglich."
#: ../display/d.rast/main.c:59
@@ -18223,9 +18153,8 @@
msgstr "Erzeugt eine leere Datenbank."
#: ../db/drivers/sqlite/db.c:84
-#, fuzzy
msgid "Unable to open database: "
-msgstr "Kann die Datenbank <%s> nicht öffnen."
+msgstr "Kann Datenbank nicht öffnen:"
#: ../db/drivers/sqlite/describe.c:159
#, c-format
@@ -19117,7 +19046,7 @@
#: ../raster/r.sun/main.c:174
msgid "Solar irradiance and irradiation model."
-msgstr ""
+msgstr "Modell der Sonnen-Strahlungsdichte und -Strahlungssumme."
#: ../raster/r.sun/main.c:176
msgid ""
@@ -19185,7 +19114,7 @@
#: ../raster/r.horizon/main.c:238 ../raster/r.horizon/main.c:246
#: ../raster/r.horizon/main.c:254 ../raster/r.horizon/main.c:262
msgid "Input_options"
-msgstr ""
+msgstr "Eingabe Optionen"
#: ../raster/r.sun/main.c:199 ../raster/r.sun2/main.c:247
msgid ""
@@ -19557,7 +19486,7 @@
#: ../raster/r.out.gdal/main.c:136
msgid "Only applicable to Byte or UInt16 data types."
-msgstr ""
+msgstr "Nur anwendbar auf die Datentypen Byte oder UInt16."
#: ../raster/r.out.gdal/main.c:140
msgid "Name of raster map (or group) to export"
@@ -19583,21 +19512,23 @@
#: ../raster/r.out.gdal/main.c:185
msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma."
-msgstr ""
+msgstr "In der Form \"NAME=WERT\", trennen Sie mehrere Optionen durch Kommas."
#: ../raster/r.out.gdal/main.c:192
msgid "Metadata key(s) and value(s) to include"
-msgstr ""
+msgstr "Metadaten Schlüsselwort(e) und Wert(e), die eingefügt werden sollen."
#: ../raster/r.out.gdal/main.c:194
msgid ""
"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
"Not supported by all output format drivers."
msgstr ""
+"Im Format \"META-TAG=WERT\". Trennen Sie mehrere Einträge durch Kommas. "
+"Wird nicht von allen Treibern unterstützt."
#: ../raster/r.out.gdal/main.c:203
msgid "Assign a specified nodata value to output bands"
-msgstr ""
+msgstr "Weisen sie den Ausgabe-Kanälen einen bestimmten Nodate-Wert zu."
#: ../raster/r.out.gdal/main.c:236
#, c-format
@@ -19635,7 +19566,7 @@
#: ../raster/r.out.gdal/main.c:399
#, c-format
msgid "Exporting to GDAL data type: %s"
-msgstr ""
+msgstr "Exportiere in den GDAL-Datentyp: %s"
#: ../raster/r.out.gdal/main.c:419
msgid "Output file name not specified"
@@ -19695,6 +19626,9 @@
"used to represent no-data values in the input map. You can specify nodata "
"value by %s parameter."
msgstr ""
+"Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert "
+"%d wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie "
+"können Nodata-Wert mit dem Parameter %s bestimmen."
#: ../raster/r.out.gdal/export_band.c:296
#, c-format
@@ -19703,6 +19637,9 @@
msgstr ""
+"%g wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie "
#: ../raster/r.basins.fill/read_map.c:36 ../raster/r.what/main.c:195
#: ../raster/r.support/histo.c:25
@@ -19719,7 +19656,7 @@
#: ../raster/r.what/main.c:335
#, fuzzy, c-format
msgid "Error reading <%s>"
-msgstr "Fehler beim Lesen der Karte '%s'."
+msgstr "Fehler beim Lesen der Rasterkarte <%s>."
#: ../raster/r.basins.fill/main.c:55
msgid "Generates a raster map layer showing watershed subbasins."
@@ -19936,7 +19873,7 @@
#: ../raster/r.lake/main.c:151
msgid "Fills lake from seed at given level."
-msgstr ""
+msgstr "Fülle den See vom Startpunkt am definierten Level."
#: ../raster/r.lake/main.c:157
msgid "Water level"
@@ -19978,7 +19915,7 @@
# Einige Daten können u.U. verloren sein.er/r.lake/main.c:212
#: ../raster/r.lake/main.c:200
msgid "Seed coordinates and output map lake= must be set!"
-msgstr ""
+msgstr "Start-Koordinaten und Ausgabekarten müssen bestimmt werden."
#: ../raster/r.lake/main.c:203
msgid "Both lake and overwrite cannot be specified"
@@ -20005,6 +19942,9 @@
"Given water level at seed point is below earth surface. Increase water level "
"or move seed point."
msgstr ""
+"Der angegebene Wasserstand am Startpunkt befindet sich unter der "
+"Erdoberfläche. Erhöhen Sie den Wasserstand oder verschieben Sie den "
+"Startpunkt."
#: ../raster/r.lake/main.c:364
#, c-format
@@ -20051,9 +19991,9 @@
msgstr "Rasterkarte, von der die Kategorietabelle kopiert werden soll."
#: ../raster/r.category/main.c:84
-#, fuzzy
msgid "File containing category label rules (or \"-\" to read from stdin)"
+msgstr ""
#: ../raster/r.category/main.c:91
msgid "Default label or format string for dynamic labeling"
@@ -20077,9 +20017,9 @@
msgstr "Rasterkarte <%s> im aktuellen Mapset nicht gefunden."
#: ../raster/r.category/main.c:159
-#, fuzzy, c-format
+#, c-format
msgid "Category table for <%s> set from <%s>"
-msgstr "Farbtabelle für <%s> ist auf %s gesetzt."
+msgstr "Kategorietabelle für <%s> ist übernommen von <%s>."
#: ../raster/r.category/main.c:197 ../raster/r.category/main.c:243
#, c-format
@@ -20545,7 +20485,7 @@
#: ../raster/r.in.bin/main.c:241
msgid "Parsing bytes per cell"
-msgstr ""
+msgstr "Analysiere Bytes per Zelle."
#: ../raster/r.in.bin/main.c:243
msgid "Bad number of bytes per cell"
@@ -20560,6 +20500,8 @@
"Missing parameters ...\n"
"Must provide at least[north= south= east= west=] OR [r=\tc=]"
msgstr ""
+"Fehlende Parameter ...\n"
+"Sie müssen zumindest [north= south= east= west=] OR [r=\tc=] angeben."
#: ../raster/r.in.bin/main.c:292 ../raster/r.in.bin/main.c:332
msgid "You have to provide all limits of geographic region (n,s,e,w)"
@@ -20588,7 +20530,7 @@
#: ../raster/r.in.bin/main.c:320
#, c-format
msgid "Using N=%f S=%f E=%f W=%f"
-msgstr ""
+msgstr "Verwende N=%f S=%f E=%f W=%f"
#: ../raster/r.in.bin/main.c:345
#, c-format
@@ -20598,19 +20540,19 @@
#: ../raster/r.in.bin/main.c:450 ../raster/r.in.bin/main.c:460
#: ../raster/r.in.bin/main.c:472
msgid "Bytes do not match File size"
-msgstr ""
+msgstr "Bytes passen nicht zur Dateigröße."
#: ../raster/r.in.bin/main.c:451 ../raster/r.in.bin/main.c:461
#: ../raster/r.in.bin/main.c:473
#, c-format
msgid "File Size %d ... Total Bytes %d"
-msgstr ""
+msgstr "Dateigröße %d ... Gesamt-Bytes %d"
#: ../raster/r.in.bin/main.c:453 ../raster/r.in.bin/main.c:463
#: ../raster/r.in.bin/main.c:475
#, c-format
msgid "Try bytes=%d or adjusting input parameters"
-msgstr ""
+msgstr "Versuchen Sie bytes=%d oder passen Sie die Eingabe-Parameter an."
#: ../raster/r.in.bin/main.c:509
#, c-format
@@ -20618,6 +20560,8 @@
"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
"significantly. Did you assign east= and west= correctly?"
msgstr ""
+"Ost-West (ewres: %f) und Nord-Süd (nwres: %f) Auflösung unterscheiden sich "
+"wesentlich. Haben Sie east= and west= korrekt gesetzt?"
#: ../raster/r.in.bin/main.c:517
#, c-format
@@ -20814,6 +20758,9 @@
"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
"with r.mapcalc. Exiting."
msgstr ""
+"Die Rasterkarte <%s> ist eine reklassifizierte Version der Karte <%s@%s>. "
+"Bedenken Sie, dass es sinnvoll sein könnte eine Kopie mit r.mapcalc zu "
+"erzeugen. Beende mich."
#: ../raster/r.null/main.c:123
#, c-format
@@ -20876,31 +20823,26 @@
msgstr "Schreibe neue Daten für die Rasterkarte <%s>..."
#: ../raster/r.grow.distance/main.c:150
-#, fuzzy
msgid "Generates a raster map layer of distance to features in input layer."
msgstr ""
-"Erzeugt eine Rasterkarte mit kontinuierlich um eine Zelle gewachsenen "
-"Flächen."
+"Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
#: ../raster/r.grow.distance/main.c:157
-#, fuzzy
msgid "Name for distance output map"
-msgstr "Name der Ausgabekarte"
+msgstr "Name der Distanz-Ausgabekarte."
#: ../raster/r.grow.distance/main.c:162
-#, fuzzy
msgid "Name for value output map"
-msgstr "Name der Ausgabe-Rasterkarte."
+msgstr "Name der Wert-Ausgabekarte."
#: ../raster/r.grow.distance/main.c:174
#, fuzzy
msgid "Output distances in meters instead of map units"
#: ../raster/r.grow.distance/main.c:184
-#, fuzzy
msgid "At least one of distance= and value= must be given"
+msgstr "Entweder distance= oder value= muss angegeben werden."
#: ../raster/r.grow.distance/main.c:199
msgid "metric=geodesic is only valid for lat/lon"
@@ -20912,14 +20854,14 @@
msgstr "Unbekannte Maßzahl: [%s]."
#: ../raster/r.grow.distance/main.c:217
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create distance map <%s>"
-msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
+msgstr "Kann die Distanz-Karte <%s> nicht erzeugen."
#: ../raster/r.grow.distance/main.c:223
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create value map <%s>"
+msgstr "Kann die Wert-Karte <%s> nicht erzeugen."
#: ../raster/r.grow.distance/main.c:229
#, c-format
@@ -21092,7 +21034,7 @@
#: ../raster/r.proj/main.c:209 ../raster/r.neighbors/main.c:203
#, c-format
msgid "<%s=%s> unknown %s"
-msgstr ""
+msgstr "<%s=%s> unbekannt %s"
#: ../raster/r.statistics/main.c:121
#, c-format
@@ -21175,7 +21117,7 @@
#: ../raster/r.out.ascii/main.c:136
msgid "Both -s and -h doesn't make sense"
-msgstr ""
+msgstr "Beide -s und -h zusammen machen keinen Sinn."
#: ../raster/r.out.ascii/main.c:139
msgid "Use -M or -s, not both"
@@ -21696,7 +21638,7 @@
#: ../raster/r.resamp.stats/main.c:280
msgid "Weight according to area (slower)"
-msgstr ""
+msgstr "Gewichte in Bezug auf die Fläche (langsamer)."
#: ../raster/r.resamp.stats/main.c:289 ../raster/r.series/main.c:97
#, c-format
@@ -21735,7 +21677,7 @@
#: ../raster/r.rescale.eq/main.c:116
#, c-format
msgid "Rescale %s[%d,%d] to %s[%d,%d]"
-msgstr ""
+msgstr "Reskaliere %s[%d,%d] nach %s[%d,%d]"
#: ../raster/r.rescale.eq/get_stats.c:20 ../raster/r.rescale/get_range.c:25
#, c-format
@@ -21753,7 +21695,8 @@
#: ../raster/r.recode/main.c:59
#, fuzzy
msgid "File containing recode rules; \"-\" to read from stdin"
+msgstr ""
#: ../raster/r.recode/main.c:68 ../raster/r.reclass/main.c:72
msgid "Title for the resulting raster map"
@@ -21783,18 +21726,20 @@
msgstr "Keine Regeln angegeben."
#: ../raster/r.recode/read_rules.c:19
-#, c-format
+#, fuzzy, c-format
msgid "Unable to read f_range for map %s"
-msgstr "Kann f_range für die Karte <%s> nicht lesen."
+msgstr "Kann die Spanne für die Karte <%s> nicht lesen."
#: ../raster/r.recode/read_rules.c:23
+#, fuzzy
msgid "Data range is empty"
-msgstr "Datenspanne ist leer."
+msgstr "Datenspanne reicht von %ld bis %ld\n"
#: ../raster/r.recode/read_rules.c:29
#, fuzzy, c-format
msgid "Data range of %s is %s to %s (entire map)"
-msgstr "Wertebereich für %s ist %s bis %s (komplette Karte)."
+msgstr ""
+"Wertebereich der Rasterkarte <%s> reicht von %s bis %s (komplette Karte)."
#: ../raster/r.recode/read_rules.c:34 ../raster/r.stats/main.c:330
#, c-format
@@ -21804,12 +21749,12 @@
#: ../raster/r.recode/read_rules.c:38
#, fuzzy, c-format
msgid "Integer data range of %s is empty"
-msgstr "Integer Wertebereich von %s ist leer."
+msgstr "Integer Wertebereich der Rasterkarte <%s> ist leer."
#: ../raster/r.recode/read_rules.c:40
#, fuzzy, c-format
msgid "Integer data range of %s is %d to %d"
-msgstr "Integer Wertebereich von %s ist %d bis %d."
+msgstr "Integer Wertebereich der Rasterkarte <%s> reicht von %d bis %d."
#: ../raster/r.recode/read_rules.c:59
msgid "Enter the rule or 'help' for the format description"
@@ -21838,7 +21783,7 @@
#: ../raster/r.recode/read_rules.c:123 ../raster/r.quant/read_rules.c:157
#, fuzzy, c-format
msgid "%s is not a valid rule"
-msgstr "%s ist keine gültige Regel."
+msgstr "'%s' ist keine gültige Regel."
#: ../raster/r.profile/main.c:51
msgid "Outputs the raster map layer values lying on user-defined line(s)."
@@ -21884,11 +21829,12 @@
#, c-format
msgid "[Easting] [Northing] [Along Track Dist.(m)] [Elevation]"
msgstr ""
+"[Ost-Koordinate] [Nord-Koordinate] [Dist. entlang des Tracks(m)] [Höhe]"
#: ../raster/r.profile/main.c:157
#, c-format
msgid "[Along Track Dist.(m)] [Elevation]"
-msgstr ""
+msgstr "[Dist. entlang des Tracks(m)] [Höhe]"
#: ../raster/r.profile/main.c:159
msgid " [RGB Color]"
@@ -22024,21 +21970,16 @@
msgstr "<%s> erzeugt."
#: ../raster/r.external/main.c:524 ../raster/r.external.out/main.c:184
-#, fuzzy
msgid "Link GDAL supported raster file to a binary raster map layer."
-msgstr ""
-"Importiert Rasterdaten (aus Formaten die GDAL unterstützt) in eine GRASS "
-"Rasterkarte."
+msgstr "Verbinde GDAL-unterstützt Rasterdaten mit einer Rasterkarte."
#: ../raster/r.external/main.c:527
-#, fuzzy
msgid "Raster file to be linked"
-msgstr "Zu importierende Rasterdatei."
+msgstr "Rasterdatei die verbunden werden soll."
#: ../raster/r.external/main.c:533
-#, fuzzy
msgid "Name of non-file GDAL data source"
-msgstr "Name der neuen Datenbank."
+msgstr "Name einer nicht Dateiartigen GDAL-Datenquelle."
#: ../raster/r.external/main.c:545
msgid "Band to select"
@@ -22049,8 +21990,9 @@
msgstr ""
#: ../raster/r.external/main.c:576
+#, fuzzy
msgid "Flip horizontally"
-msgstr ""
+msgstr "Teile horizontal und nicht vertikal."
#: ../raster/r.external/main.c:580
msgid "Flip vertically"
@@ -22396,7 +22338,7 @@
#: ../raster/r.coin/make_coin.c:44
#, c-format
msgid "Tabulating Coincidence between '%s' and '%s'"
-msgstr ""
+msgstr "Tabelliere die Koinzidenz von '%s' und '%s'"
#: ../raster/r.coin/make_coin.c:54
msgid "Unable to create any tempfiles"
@@ -22439,6 +22381,9 @@
"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
msgstr ""
+"c(ells), p(rozent), x(Prozent der Kategorien [Spalte]), y(Prozent der "
+"Kategorien [Zeile]), a(cres), h(ektar), k(Quadrat-Kilometer), m(Quadrat-"
+"Meilen)"
#: ../raster/r.coin/main.c:97
msgid "Wide report, 132 columns (default: 80)"
@@ -22499,14 +22444,13 @@
msgstr "Verwendete maximale Distanz von der Betrachterposition (in Metern): %f"
#: ../raster/r.contour/main.c:85
-#, fuzzy
msgid "raster, DEM, contours, vector"
-msgstr "Weder Raster- noch Vektor-Ausgabe."
+msgstr "Raster, DGM, Konturen, Vektor"
#: ../raster/r.contour/main.c:86
-#, fuzzy
msgid "Produces a vector map of specified contours from a raster map."
-msgstr "Erzeugt eine Vektorkarte mit Kontourlinien aus einer Rasterkarte."
+msgstr ""
+"Erzeugt eine Vektorkarte mit bestimmten Kontourlinien aus einer Rasterkarte."
#: ../raster/r.contour/main.c:97
msgid "List of contour levels"
@@ -22538,34 +22482,31 @@
msgstr "Kann den fp Bereich der Rasterkarte <%s> nicht lesen."
#: ../raster/r.contour/main.c:244
-#, fuzzy, c-format
+#, c-format
msgid "Range of data: min=%f, max=%f"
-msgstr "Wertebereich: min = %f max = %f"
+msgstr "Wertebereich: min=%f, max=%f"
#: ../raster/r.contour/main.c:246
-#, fuzzy
msgid "Range of data: empty"
-msgstr "Wertebereich: leer."
+msgstr "Wertebereich: leer."
#: ../raster/r.contour/main.c:274 ../raster/r.contour/main.c:277
-#, fuzzy
msgid "This step value is not allowed"
msgstr "Diese Schrittgröße ist nicht erlaubt."
#: ../raster/r.contour/main.c:302
-#, fuzzy, c-format
+#, c-format
msgid "Range of levels: min = %f, max = %f"
-msgstr "Bereich der Stufen: min = %f max = %f"
+msgstr "Bereich der Stufen: min = %f, max = %f"
#: ../raster/r.contour/main.c:331
-#, fuzzy
msgid "Displacing data..."
-msgstr "Verschiebe Daten:"
+msgstr "Verschiebe Daten..."
#: ../raster/r.contour/cont.c:81
-#, fuzzy, c-format
+#, c-format
msgid "Writing vector contours (total levels %d)..."
-msgstr "Schreibe Vektorkarte <%s> ..."
+msgstr "Schreibe Vektorkonturen (Gesamtanzahl %d) ..."
#: ../raster/r.contour/cont.c:211
#, c-format
@@ -22652,32 +22593,29 @@
msgstr ""
#: ../raster/r.random.cells/main.c:45
-#, fuzzy
msgid "raster, random, cell"
-msgstr "Raster, Resamplen"
+msgstr "Raster, Zufall, Zelle"
#: ../raster/r.random.cells/main.c:47
msgid "Generates random cell values with spatial dependence."
msgstr "Erzeugt zufällig Zellwerte mit räumlicher Abhängigkeit."
#: ../raster/r.random.cells/main.c:57
-#, fuzzy
msgid "Maximum distance of spatial correlation (value(s) >= 0.0)"
-msgstr "Maximale Distanz vom Punkt zum Netzwerk."
+msgstr "Maximale Distanz der räumlichen Korrelation (Wert(e) >= 0.0)."
#: ../raster/r.random.cells/main.c:64
msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
msgstr ""
#: ../raster/r.random.cells/init.c:71
-#, fuzzy
msgid "Distance must be >= 0.0"
-msgstr "'layer' muss > 0 sein."
+msgstr "Distanz muss >= 0.0 sein."
#: ../raster/r.random.cells/init.c:90 ../raster/r.random.surface/main.c:128
-#, fuzzy, c-format
+#, c-format
msgid "Generating raster map <%s>..."
-msgstr "Lese Rasterkarte <%s> ..."
+msgstr "Erzeuge Rasterkarte <%s> ..."
#: ../raster/r.out.pov/main.c:122
msgid "Converts a raster map layer into a height-field file for POVRAY."
@@ -22753,7 +22691,7 @@
#: ../raster/r.external.out/main.c:207
#, fuzzy
msgid "Creation options"
-msgstr "Korrelation"
+msgstr "GeoTIFF Erzeugungsoption(en)"
#: ../raster/r.external.out/main.c:219
msgid "Cease using GDAL and revert to native output"
@@ -22855,9 +22793,8 @@
msgstr "Logarithmische Skalierung"
#: ../raster/r.colors/main.c:223
-#, fuzzy
msgid "Logarithmic-absolute scaling"
-msgstr "Logarithmische Skalierung"
+msgstr "Logarithmisch-absolute Skalierung"
#: ../raster/r.colors/main.c:228
msgid "Histogram equalization"
@@ -22883,9 +22820,8 @@
"aus."
#: ../raster/r.colors/main.c:257
-#, fuzzy
msgid "-g and -a flags are mutually exclusive"
-msgstr "-r und -e schliessen sich gegenseitig aus."
+msgstr "-g und -a schließen sich gegenseitig aus."
#: ../raster/r.colors/main.c:271
#, c-format
@@ -23032,7 +22968,7 @@
#: ../raster/r.statistics2/main.c:185 ../raster/r.statistics3/main.c:485
#, fuzzy, c-format
msgid "Unable to read range of base map <%s>"
-msgstr "Kann den fp Bereich der Rasterkarte <%s> nicht lesen."
+msgstr "Kann den Wertebereich der Rasterkarte <%s> nicht lesen."
#: ../raster/r.statistics2/main.c:249
msgid "First pass"
@@ -23464,7 +23400,8 @@
#: ../raster/r.reclass/main.c:63
#, fuzzy
msgid "File containing reclass rules; \"-\" to read from stdin"
+msgstr ""
#: ../raster/r.reclass/main.c:83
msgid "Input map can NOT be the same as output map"
@@ -23489,11 +23426,11 @@
#: ../raster/r.reclass/main.c:117
#, c-format
msgid " ignored\n"
-msgstr ""
+msgstr " ignoriert\n"
#: ../raster/r.reclass/main.c:120
msgid " - invalid reclass rule"
-msgstr ""
+msgstr " - ungültige Reklassifizierungs-Regel"
#: ../raster/r.reclass/main.c:136
#, c-format
@@ -23502,24 +23439,24 @@
#: ../raster/r.reclass/parse.c:41
msgid "poor quality"
-msgstr ""
+msgstr "geringe Qualität"
#: ../raster/r.reclass/parse.c:43
msgid "medium quality"
-msgstr ""
+msgstr "mittlere Qualität"
#: ../raster/r.reclass/parse.c:58
msgid "Can't have null on the left-hand side of the rule"
-msgstr ""
+msgstr "Es darf sich keine Null auf der linken Seite der Regel befinden."
#: ../raster/r.reclass/parse.c:87 ../raster/r.reclass/parse.c:99
msgid "Can't have null on the right-hand side of the rule"
-msgstr ""
+msgstr "Es darf sich keine Null auf der rechten Seite der Regel befinden."
#: ../raster/r.reclass/parse.c:195
#, c-format
msgid "%f rounded up to %d\n"
-msgstr ""
+msgstr "%f gerundet auf %d\n"
#: ../raster/r.what/main.c:93
msgid "Queries raster map layers on their category values and category labels."
@@ -23560,7 +23497,7 @@
"Interactive tool used to draw and save vector features on a graphics monitor "
"using a pointing device (mouse) and save to a raster map."
msgstr ""
-"Interaktives Werkzeug, welches Vektorobjekte in einem Grafik-Fenster mit der "
+"Interaktives Werkzeug, welches Vektorobjekte in einem Grafikfenster mit der "
"Maus zeichnet und als Rasterkarte speichert."
#: ../raster/r.digit/main.c:55
@@ -23973,9 +23910,9 @@
msgstr "Gebe die Sonnenposition im Shell-Skript-Style aus."
#: ../raster/r.sunmask/main.c:260
-#, fuzzy, c-format
+#, c-format
msgid "Using map center coordinates: %f %f"
-msgstr "Benutzte Koordinaten der Kartenmitte.\n"
+msgstr "Verwende die Koordinaten der Kartenmitte: %f %f"
#: ../raster/r.sunmask/main.c:267
msgid "Empty east coordinate specified!"
@@ -25192,23 +25129,20 @@
msgstr "%s: Kann die Farbtabelle für <%s@%s> nicht lesen."
#: ../raster/r.random.surface/main.c:56
-#, fuzzy
msgid "raster, random, surface"
-msgstr "Rasterkarte für die Oberfläche."
+msgstr "Raster, Zufall, Oberfläche"
#: ../raster/r.random.surface/main.c:58
msgid "Generates random surface(s) with spatial dependence."
msgstr "Erzeugt zufällige Oberfläche(n) mit räumlicher Abhängigkeit."
#: ../raster/r.random.surface/main.c:65
-#, fuzzy
msgid "Name for output raster map(s)"
+msgstr "Name der Ausgabe-Rasterkarte(n)."
#: ../raster/r.random.surface/main.c:74
-#, fuzzy
msgid "Maximum distance of spatial correlation (value >= 0.0)"
+msgstr "Maximale Distanz der räumlichen Korrelation (Wert >= 0.0)."
#: ../raster/r.random.surface/main.c:82
msgid "Distance decay exponent (value > 0.0)"
@@ -25223,33 +25157,31 @@
msgstr ""
#: ../raster/r.random.surface/main.c:105
-#, fuzzy
msgid "Maximum cell value of distribution"
-msgstr "Maximale Anzahl der Wiederholungen."
+msgstr "Maximaler Zellwert der Verteilung."
#: ../raster/r.random.surface/main.c:110
msgid "Uniformly distributed cell values"
msgstr ""
#: ../raster/r.random.surface/init.c:74
-#, fuzzy, c-format
+#, c-format
msgid "High (%d) must be greater than 1"
-msgstr "%s = %s -- muss größer als 0 (zero) sein."
+msgstr "High (%d) muss größer als 1 sein."
#: ../raster/r.random.surface/init.c:83
-#, fuzzy, c-format
+#, c-format
msgid "Rastar map <%s> repeated, maps must be unique"
-msgstr "Die Rasterkarte <%s> hat bereits eine NULL-Datei."
+msgstr "Die Rasterkarte <%s> wiederholt sich, Karten müssen eindeutig sein."
#: ../raster/r.random.surface/init.c:93
-#, fuzzy
msgid "Output raster map required"
#: ../raster/r.random.surface/init.c:109
-#, fuzzy, c-format
+#, c-format
msgid "Seed (%d) larger than maximum (%d)"
-msgstr "Startwert [%d] größer als das Maximum [%d]."
+msgstr "Startwert (%d) größer als das Maximum (%d)."
#: ../raster/r.random.surface/init.c:112 ../raster/r.random.surface/init.c:121
#, c-format
@@ -25257,9 +25189,9 @@
msgstr "Startwert wurde auf %d gesetzt."
#: ../raster/r.random.surface/init.c:117
-#, fuzzy, c-format
+#, c-format
msgid "Seed (%d) smaller than minimum (%d)"
-msgstr "Startwert [%d] kleiner als das Minimum [%d]."
+msgstr "Startwert (%d) kleiner als das Minimum (%d)."
#: ../raster/r.random.surface/init.c:160
#, c-format
@@ -25299,7 +25231,7 @@
#: ../raster/r.distance/distance.c:98
#, c-format
msgid "Reading maps <%s,%s> while finding 0 distance ..."
-msgstr ""
+msgstr "Lese die Karten <%s,%s> während ich die 0-Distanz finde..."
#: ../raster/r.distance/edges.c:42
#, c-format
@@ -25316,11 +25248,11 @@
#: ../raster/r.distance/parse.c:56
msgid "Report zero distance if rasters are overlapping"
-msgstr ""
+msgstr "Berichte Null-Distanz, wen Rasterkarten sich überlappen."
#: ../raster/r.proj/readcell.c:63
msgid "Allocating memory and reading input map..."
-msgstr ""
+msgstr "Allokiere Speicher und lese die Eingabekarte..."
#: ../raster/r.proj/readcell.c:81
msgid "Error reading input"
@@ -25332,7 +25264,7 @@
#: ../raster/r.proj/readcell.c:117
msgid "Internal error: cache miss on fully-cached map"
-msgstr ""
+msgstr "Interner Fehler: Cache miss on fully-cached map"
#: ../raster/r.proj/readcell.c:126
msgid "Error seeking on segment file"
@@ -25385,7 +25317,7 @@
#: ../raster/r.proj/main.c:221
msgid "You have to use a different location for input than the current"
-msgstr ""
+msgstr "Sie müssen eine andere Location als Input verwenden als die Aktuelle."
#: ../raster/r.proj/main.c:227
msgid "Unable to get projection info of output raster map"
@@ -25430,7 +25362,7 @@
#: ../raster/r.proj/main.c:288
msgid "Unable to work with unprojected data (xy location)"
-msgstr ""
+msgstr "Kann nicht mit unprojezierten Daten arbeiten (xy location)."
#: ../raster/r.proj/main.c:362
msgid "Input:"
@@ -25509,7 +25441,7 @@
#: ../raster/r.texture/h_measure.c:927
#, c-format
msgid "Too many iterations to required to find %s - giving up"
-msgstr ""
+msgstr "Zu viele Iterationen werden benötigt um %s zu finden - gebe auf."
#: ../raster/r.texture/main.c:76
msgid "Generate images with textural features from a raster map."
@@ -25600,7 +25532,7 @@
#: ../raster/r.texture/main.c:353
#, c-format
msgid "Calculated measure #%d <%s> (56 measures available)"
-msgstr ""
+msgstr "Habe die Kenngröße #%d <%s> berechnet (56 Kenngrößen verfügbar)."
#: ../raster/r.out.arc/main.c:60
msgid "Converts a raster map layer into an ESRI ARCGRID file."
@@ -25722,9 +25654,8 @@
msgstr "Erzeuge Rasterkarten von ASCII-Polygon/Linien/Punkt-Daten."
#: ../raster/r.in.poly/main.c:35
-#, fuzzy
msgid "Name of input file; or \"-\" to read from stdin"
-msgstr "Pfad zur Datei mit Regeln (\"-\" um Regeln von stdin zu lesen)."
+msgstr "Name der Eingabe-Datei; oder \"-\" um von stdin zu lesen."
#: ../raster/r.in.poly/main.c:59
msgid "Minimum number of rows to hold in memory is 1"
@@ -26290,12 +26221,10 @@
"wurde)."
#: ../raster/r.surf.idw/main.c:102
-#, fuzzy
msgid "raster, interpolation"
-msgstr "Vektor, Interpolation"
+msgstr "Raster, Interpolation"
#: ../raster/r.surf.idw/main.c:104
-#, fuzzy
msgid "Surface interpolation utility for raster map."
msgstr "Oberflächeninterpolationswerkzeug für Rasterkarten."
@@ -26304,14 +26233,14 @@
msgstr "Name der Karte, die Interpolationsfehler enthält."
#: ../raster/r.surf.idw/main.c:125
-#, fuzzy, c-format
+#, c-format
msgid "Illegal value for '%s' (%s)"
-msgstr "Ungültiger Wert für NULL."
+msgstr "Ungültiger Wert für '%s' (%s)."
#: ../raster/r.surf.idw/main.c:255
#, fuzzy, c-format
msgid "Interpolating raster map <%s> (%d rows)..."
-msgstr "Interpoliere Rasterkarte <%s> ... %d Zeilenn... "
+msgstr "Interpoliere Rasterkarte <%s> (%d Zeilen)... "
#: ../raster/r.surf.idw/main.c:263
msgid "Cannot read row"
@@ -26408,34 +26337,31 @@
#: ../raster/r.sun2/main.c:256
msgid "A single value of the orientation (aspect), 270 is south"
-msgstr ""
+msgstr "Ein einzelner Wert für die Orientierung (aspect), 270 ist Süden."
#: ../raster/r.sun2/main.c:272
-#, fuzzy
msgid "A single value of inclination (slope)"
-msgstr "Ein einfacher Wert des Breitengrads [in Grad]."
+msgstr "Ein einzelner Wert für die Inklination (slope)."
#: ../raster/r.sun2/main.c:335
-#, fuzzy
msgid "Name of the longitude input raster map [decimal degrees]"
-msgstr "Eingabe-Rasterkarte des Breitengrads [in Grad]."
+msgstr "Eingabe-Rasterkarte mit Längengraden [in Dezimal-Grad]."
#: ../raster/r.sun2/main.c:344
-#, fuzzy
msgid "Name of real-sky beam radiation coefficient input raster map [-]"
msgstr ""
-"Name der Rasterkarte mit dem Koeffizient der direkten Sonneneinstrahlung [-]."
+"Eingabe-Rasterkarte mit dem Koeffizient der direkten 'real-sky' "
+"Sonneneinstrahlung [-]."
#: ../raster/r.sun2/main.c:353
-#, fuzzy
msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
msgstr ""
-"Name der Rasterkarte mit dem Koeffizient der diffusen Sonneneinstrahlung [-]."
+"Eingabe-Rasterkarte mit dem Koeffizient der diffusen 'real-sky' "
#: ../raster/r.sun2/main.c:361
-#, fuzzy
msgid "The horizon information input map prefix"
-msgstr "Die Projektionsinformationen werden nicht aktualisiert."
+msgstr "Der Präfix, der Horizont-Informations-Eingabekarte."
#: ../raster/r.sun2/main.c:369 ../raster/r.horizon/main.c:213
msgid "Angle step size for multidirectional horizon [degrees]"
@@ -26471,19 +26397,16 @@
msgstr ""
#: ../raster/r.sun2/main.c:577
-#, fuzzy
msgid "Error reading time step size"
-msgstr "Fehler beim Lesen der temporären Datei."
+msgstr "Fehler beim Lesen der Zeitschrittgröße."
#: ../raster/r.sun2/main.c:581
-#, fuzzy
msgid "Error reading horizon step size"
-msgstr "Lese Koordinaten aus Datei."
+msgstr "Fehler beim Lesen der Horizont-Schrittgröße."
#: ../raster/r.sun2/main.c:585
-#, fuzzy
msgid "The horizon step size must be greater than 0."
+msgstr "Die Horizont-Schrittgröße muss größer sein als 0."
#: ../raster/r.sun2/main.c:589
msgid ""
@@ -26491,12 +26414,10 @@
msgstr ""
#: ../raster/r.sun2/main.c:596
-#, fuzzy
msgid "Time and insol_time are incompatible options"
-msgstr "time und insol_time sind nicht kompatible Optionen."
+msgstr "Time und insol_time sind nicht kompatible Optionen."
#: ../raster/r.sun2/main.c:597
-#, fuzzy
msgid ""
"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
"time"
@@ -26505,14 +26426,12 @@
"bekannter lokaler Zeit"
#: ../raster/r.sun2/main.c:602
-#, fuzzy
msgid "incidout requres time parameter to be set"
msgstr "incidout benötigt den Zeit-Parameter."
#: ../raster/r.sun2/main.c:603
-#, fuzzy
msgid "Mode 2: integrated daily irradiation"
-msgstr "Modus 2: integrierte tägliche Strahlung für einen Tag des Jahres"
+msgstr "Modus 2: integrierte tägliche Strahlung."
#: ../raster/r.sun2/main.c:656
msgid "If you use -s and no horizon rasters, numpartitions must be =1"
@@ -26525,9 +26444,9 @@
msgstr ""
#: ../raster/r.sun2/main.c:944
-#, fuzzy, c-format
+#, c-format
msgid "Horizon file no. %d <%s> not found"
-msgstr "3dview-Datei <%s> nicht gefunden."
+msgstr "Horizont-datei Nr. %d <%s> nicht gefunden."
#: ../raster/r.kappa/main.c:69
msgid ""
@@ -26676,17 +26595,15 @@
"Rasterkarte <%s> und ignoriere die Option '%s'."
#: ../raster/r.spread/main.c:103
-#, fuzzy
msgid ""
"Simulates elliptically anisotropic spread on a graphics window and generates "
"a raster map of the cumulative time of spread, given raster maps containing "
"the rates of spread (ROS), the ROS directions and the spread origins."
msgstr ""
-"Simuliert die elliptische anisotrophe Ausbreitung in einem Grafik-Fenster "
-"und generiert eine Rasterkarte mit der kumulativen Zeit der Ausbreitung. Als "
+"Simuliert elliptische anisotrophe Ausbreitung in einem Grafikfenster und "
+"erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als "
"Ausgangskarten dienen die Ausbreitungsrate (ROS), Ausbreitungsrichtung und "
-"Ausbreitungsursprung. Optional können Rasterkarten mit Rückverweisen auf UTM-"
-"Koordinaten zur Findung der Ausbreitungspfade erstellt werden."
+"Ausbreitungsursprung."
#: ../raster/r.spread/main.c:108
msgid ""
@@ -26786,7 +26703,7 @@
#: ../raster/r.spread/main.c:235
msgid "DISPLAY 'live' spread process on screen"
-msgstr "Zeige den Ausbreitungsprozess in Echtzeit im Grafik-Fenster."
+msgstr "Zeige den Ausbreitungsprozess in Echtzeit im Grafikfenster."
#: ../raster/r.spread/main.c:237
msgid "Live display - currently DISABLED"
@@ -27051,7 +26968,6 @@
"Name der Rasterkarte, die die Ost Informationen zu den Rückwegen enthält."
#: ../raster/r.spreadpath/main.c:107
-#, fuzzy
msgid "Name of raster map containing back-path northing information"
msgstr ""
"Name der Rasterkarte, die die Nord Informationen zu den Rückwegen enthält."
@@ -27685,7 +27601,7 @@
#: ../raster/r.to.vect/main.c:114
msgid "z flag is supported only for points"
+msgstr "Der Schalter '-z' wird nur für Punkte unterstützt."
#: ../raster/r.to.vect/main.c:125
msgid ""
@@ -27826,11 +27742,10 @@
msgstr "Raster, Komposite"
#: ../raster/r.composite/main.c:73
-#, fuzzy
msgid ""
"Combines red, green and blue raster maps into a single composite raster map."
msgstr ""
-"Kombiniert rote, grüne und blaue Karten zu einer zusammengestzten "
+"Kombiniert rote, grüne und blaue Rasterkarten zu einer zusammengesetzten "
"Rasterkarte."
#: ../raster/r.composite/main.c:99
@@ -27838,9 +27753,8 @@
msgstr "Anzahl der Level, welche für jeden Komponent benutzt werden sollen."
#: ../raster/r.composite/main.c:100 ../raster/r.composite/main.c:118
-#, fuzzy
msgid "Levels"
-msgstr "Label"
+msgstr "Stufen"
#: ../raster/r.composite/main.c:115
#, c-format
@@ -27886,11 +27800,11 @@
#: ../raster/r.out.gridatb/file_io.c:41 ../raster/r.in.gridatb/file_io.c:37
msgid "Rows changed"
-msgstr ""
+msgstr "Zeilen geändert"
#: ../raster/r.out.gridatb/file_io.c:44 ../raster/r.in.gridatb/file_io.c:40
msgid "Cols changed"
-msgstr ""
+msgstr "Spalten geändert"
#: ../raster/r.horizon/main.c:180
msgid "Horizon angle computation from a digital elevation model."
@@ -27946,60 +27860,58 @@
msgstr ""
#: ../raster/r.horizon/main.c:270
-#, fuzzy
msgid "Prefix of the horizon raster output maps"
-msgstr "Präfix für Ausgabe-Rasterkarte(n)."
+msgstr "Präfix für Horizont-Ausgabe-Rasterkarten."
#: ../raster/r.horizon/main.c:280
msgid "Coordinate for which you want to calculate the horizon"
msgstr ""
#: ../raster/r.horizon/main.c:295
-#, fuzzy
msgid "Write output in degrees (default is radians)"
-msgstr "Präfix der Ausgabebilder (Standard = NVIZ)."
+msgstr "Schreibe die Auisgabe in Grad (Standard ist Radians)."
#: ../raster/r.horizon/main.c:362
msgid "You didn't specify a direction value or step size. Aborting."
msgstr ""
+"Sie haben keine Wert für die Richtung oder Schrittgröße angegeben. Breche ab."
#: ../raster/r.horizon/main.c:368
msgid "You didn't specify a horizon raster name. Aborting."
-msgstr ""
+msgstr "Sie haben keine Horizont-Rasterkarte angegeben, Breche ab."
#: ../raster/r.horizon/main.c:379
msgid "You didn't specify an angle step size. Aborting."
-msgstr ""
+msgstr "Sie haben kein Schrittgröße für den Winkel angegeben. Breche ab."
#: ../raster/r.horizon/main.c:393
-#, fuzzy
msgid "Could not read bufferzone size. Aborting."
-msgstr "Kann die Range-Datei nicht lesen."
+msgstr "Konnte die Bufferzonengröße nicht lesen. Breche ab."
#: ../raster/r.horizon/main.c:399
msgid "Could not read east bufferzone size. Aborting."
-msgstr ""
+msgstr "Konnte die Ost-Bufferzonengröße nicht lesen. Breche ab."
#: ../raster/r.horizon/main.c:405
msgid "Could not read west bufferzone size. Aborting."
-msgstr ""
+msgstr "Konnte die West-Bufferzonengröße nicht lesen. Breche ab."
#: ../raster/r.horizon/main.c:412
msgid "Could not read south bufferzone size. Aborting."
-msgstr ""
+msgstr "Konnte die Süd-Bufferzonengröße nicht lesen. Breche ab."
#: ../raster/r.horizon/main.c:421
msgid "Could not read north bufferzone size. Aborting."
-msgstr ""
+msgstr "Konnte die Nord-Bufferzonengröße nicht lesen. Breche ab."
#: ../raster/r.horizon/main.c:427
msgid "Could not read maximum distance. Aborting."
-msgstr ""
+msgstr "Konnte die maximale Distanz nicht lesen. Breche ab."
#: ../raster/r.horizon/main.c:1144
-#, fuzzy, c-format
+#, c-format
msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+msgstr "Berechne Karte %01d von %01d (Winkel %lf, Rasterkarte <%s>)."
#: ../raster/r.surf.idw2/main.c:61
msgid "Surface generation program."
@@ -28167,17 +28079,15 @@
msgstr "Schreibe Ausgabe-Rasterkarte %s..."
#: ../raster/r.clump/main.c:45
-#, fuzzy
msgid "raster, statistics, reclass"
-msgstr "Raster, Statistik"
+msgstr "Raster, Statistik, Reklassifizieren"
#: ../raster/r.clump/main.c:47
-#, fuzzy
msgid ""
"Recategorizes data in a raster map by grouping cells that form physically "
"discrete areas into unique categories."
msgstr ""
-"Re-kategorisiert Daten einer Rasterkarte, indem Zellen physikalisch "
+"Re-Kategorisiert Daten einer Rasterkarte, indem Zellen physikalisch "
"diskreter Areale zu eindeutigen Kategorie gruppiert werden."
#: ../raster/r.clump/main.c:58
@@ -28186,17 +28096,17 @@
msgstr "Dateien"
#: ../raster/r.clump/main.c:97
-#, fuzzy, c-format
+#, c-format
msgid "%d clumps."
-msgstr "%d Klassen."
+msgstr "%d Klumpen."
#: ../raster/r.clump/clump.c:98
-#, fuzzy, c-format
+#, c-format
msgid "Pass %d..."
-msgstr "Durchgang: %d\n"
+msgstr "Durchgang %d..."
#: ../raster/r.clump/clump.c:101
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read raster map row %d "
msgstr "Kann die Zeile %d der Rasterkarte nicht lesen."
@@ -28283,23 +28193,22 @@
msgstr "Schreiben des Fenster-Headers fehlgeschlagen."
#: ../raster/r.surf.fractal/spec_syn.c:61
-#, fuzzy
msgid "Preliminary surface calculations..."
-msgstr "Vorläufige Berechnung der Oberfläche."
+msgstr "Vorläufige Berechnung der Oberfläche..."
#: ../raster/r.surf.fractal/spec_syn.c:120
-#, fuzzy, c-format
+#, c-format
msgid "Calculating surface %d (of %d)..."
-msgstr "Berechne die Oberfläche %d (von %d)."
+msgstr "Berechne die Oberfläche %d (von %d)..."
#: ../raster/r.surf.fractal/main.c:38
-#, fuzzy
msgid "raster, DEM, fractal"
-msgstr "Raster, NULL-Werte"
+msgstr "Raster, DGM, Fraktale"
#: ../raster/r.surf.fractal/main.c:40
msgid "Creates a fractal surface of a given fractal dimension."
msgstr ""
+"Erzeugt eine fraktale Oberfläche mit einer gegebenen Fraktalendimension."
#: ../raster/r.surf.fractal/main.c:46
msgid "Fractal dimension of surface (2 < D < 3)"
@@ -28310,14 +28219,15 @@
msgstr "Anzahl der zu produzierenden Zwischenschritte."
#: ../raster/r.surf.fractal/main.c:77
-#, fuzzy, c-format
+#, c-format
msgid "Fractal dimension of %.2lf must be between 2 and 3."
msgstr "Fraktale Dimension von [%.2lf] muss zwischen 2 und 3 liegen."
#: ../raster/r.surf.fractal/process.c:53
-#, fuzzy
msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr "Kann keinen Speicherplatz zum Lesen der Rasterkarte belegen."
+msgstr ""
+"Kann keinen Speicherplatz allokieren. Überprüfen Sie die aktuelle Region mit "
+"g.region."
#: ../raster/r.region/main.c:53
msgid "Sets the boundary definitions for a raster map."
@@ -29006,22 +28916,133 @@
msgid "%s: Dropping <s>"
msgstr "%s: Kann <%s> nicht öffnen."
+msgid "Transition probabilities: %f %f %f; %f"
+msgstr "Transition probabilities: %f %f %f; %f"
+#, fuzzy
+msgid "Ordering eigenvalues in descending order..."
+msgstr "Berechne Eigenwerte und Eigenvektoren..."
+msgid "Subgroup name in the above group"
+msgstr "Untergruppenname in der angegebenen Gruppe."
+msgid "sensor: LANDSAT"
+msgstr "Sensor: LANDSAT"
+msgid "sensor: QuickBird"
+msgstr "Sensor: QuickBird"
+msgid "sensor: SPOT"
+msgstr "Sensor: SPOT"
+msgid ""
+"%s: saving [%s] raster map layer.\n"
+"Percent complete:"
+msgstr ""
+"%s: Speichere [%s] Rasterkarte.\n"
+"Prozent fertig: "
+msgid "Starting filter #%d, distance: %.*lf, exponent: %.*lf, flat: %.*lf"
+msgstr "Beginne Filter Nr. %d, Distanz: %.*lf, Exponent: %.*lf, flach: %.*lf"
+msgid "CLUMP PASS %d ... "
+msgstr "CLUMP DURCHGANG %d ... "
+msgid "problem w/ astar algorithm"
+msgstr "Problem mit dem astar-Algorithmus."
+#, fuzzy
+msgid "CrossCorrelation: Mean = %.5lf\n"
+msgstr "Kann Feld-Information nicht lesen."
+#, fuzzy
+msgid "CrossCorrelation: lambda_i = %.3f\n"
+msgid ""
+"\n"
+"Results are over.\n"
+msgstr ""
+"\n"
+"Ergebnisse sind vorbei.\n"
+msgid "Query layer (used by 'query' option)"
+msgstr "Abfrage-Layer. Wird nur von der 'Query'-Option verwendet."
+#, fuzzy
+msgid ""
+"Elevation raster map <%s> does not cover the entire area of the input vector "
+"map <%s>. "
+msgstr "Kann die Eingabevektorkarte <%s> nicht finden."
+msgid ""
+"Optional where condition (without WHERE key word), e.g.:\n"
+"\t\tobec = 'Liptakov'"
+msgstr ""
+"Optionale 'where'-Angabe (ohne 'WHERE' Schlüsselwort), z.B.:\n"
+msgid "Group to remove"
+msgstr "Gruppe, die entfernt werden soll."
+msgid ""
+"Starting lake filling at level of %8.4f in %d passes. \n"
+"Percent done:"
+msgstr ""
+"Beginne mit dem Füllen des Sees bei Niveau von %8.4f mit %d Durchgängen. \n"
+"Prozent erledigt:"
+msgid "All done."
+msgstr "Alles erledigt."
+msgid "G_put_raster_row failed (file system full?)"
+msgstr "G_put_raster_row failed (Dateisystem voll?)"
+#, fuzzy
+msgid "Insufficent memory for allocation of data structure"
+msgstr "Ungenügend Speicher für das Belegen der Datenstruktur."
+msgid "Output file extension (inputfile(s) + extension)"
+msgstr ""
+"Dateieerweiterung der Ausgabekarte (Eingabedatei(en) + Dateierweiterung)."
+#, fuzzy
+msgid "Illegal file name. Please try another."
+msgstr "Ungültiger Name für den realen Teil: %s"
+#, fuzzy
+msgid "Insufficent memory for allocation of data sturcture"
+#, fuzzy
+msgid "Insufficent memory for allocation of data structure."
+#, fuzzy
+msgid "Can't work with xy data"
+msgstr "Kann die Daten nicht holen."
+#, fuzzy
+msgid "CrossCorrelation: It shouldn't take too long."
+msgstr "Kann Daten nicht aus der Tabelle selektieren."
+#, fuzzy
#~ msgid "Cannot open database %s by driver %s"
-#~ msgstr "Kann Datenbank '%s' mit Treiber '%s' nicht öffnen."
+#~ msgstr "Kann Datenbank <%s> nicht mit dem Treiber <%s> öffnen."
+#, fuzzy
#~ msgid "Cannot select attributes: %s"
-#~ msgstr "Kann folgende Attribute nicht auswählen: %s"
+#~ msgstr "Kann die Attribute für cat=%d nicht öffnen."
+#, fuzzy
#~ msgid ""
#~ "Background color, either a standard GRASS color, R:G:B triplet, or \"none"
-#~ msgstr ""
-#~ "Hintergrundfarbe, entweder eine GRASS Standardfarbe, ein R:G:B Tripel "
-#~ "oder \"none\" für nichts."
+#~ msgstr "Entweder eine Standard GRASS-Farbe, ein R:G:B-Tripel oder \"none\"."
#, fuzzy
#~ msgid "Output inverse raster map after IFFT"
-#~ msgstr "Invertierte Ausgabe-Rasterkarte (nach ifft)"
+#~ msgstr "Ausgabehöhenkarte nach dem Füllen"
#, fuzzy
#~ msgid "Unable to open real input map <%s>"
@@ -29031,8 +29052,9 @@
#~ msgid "Unable to open imaginary input map <%s>"
#~ msgstr "Kann die Rasterkarte <%s> nicht öffnen."
+#, fuzzy
#~ msgid "Reading the raster maps..."
-#~ msgstr "Lese die Rasterkarten..."
+#~ msgstr "Lese Rasterkarte <%s> ..."
#, fuzzy
#~ msgid "Error while reading real input raster map."
@@ -29042,64 +29064,82 @@
#~ msgid "Error while reading imaginary input raster map."
#~ msgstr "Ein Fehler trat während des Lesens der Eingabe-Rasterkarte auf."
+#, fuzzy
#~ msgid "Rotating data arrays..."
-#~ msgstr "Rotiere Daten-Arrays..."
+#~ msgstr "Drehe Daten..."
+#, fuzzy
#~ msgid "Inverse FFT completed..."
-#~ msgstr "Inverse FFT fertiggestellt...."
+#~ msgstr "Prozent fertig..."
#, fuzzy
#~ msgid "Writing output map..."
#~ msgstr "Schreibe Karte raus..."
+#, fuzzy
#~ msgid "Transform successful."
#~ msgstr "Transformation erfolgreich."
+#, fuzzy
#~ msgid "Hue map name"
-#~ msgstr "Name der Farbton-Karte"
+#~ msgstr "Keine Karte angegeben."
+#, fuzzy
#~ msgid "Intensity map name"
-#~ msgstr "Name der Intensitäts-Karte"
+#~ msgstr "Gebe den Namen des Mapsets aus."
+#, fuzzy
#~ msgid "Saturation map name"
-#~ msgstr "Name der Sättigungs-Karte"
+#~ msgstr "Setze den Kartennamen auf <%s>."
+#, fuzzy
#~ msgid "Output map representing the red"
-#~ msgstr "Ausgabekarte, die rot repräsentiert."
+#~ msgstr "Ausgabekarte <%s> ignoriert."
+#, fuzzy
#~ msgid "Output map representing the green"
-#~ msgstr "Ausgabekarte, die grün repräsentiert."
+#~ msgstr "Ausgabekarte mit Abflussrichtung."
+#, fuzzy
#~ msgid "Output map representing the blue"
-#~ msgstr "Ausgabekarte, die blau repräsentiert."
+#~ msgstr "2D-Rasterkarte, die die Schnitte repräsentiert."
+#, fuzzy
#~ msgid "Cannot read row from raster map"
-#~ msgstr "Kann Zeile nicht aus der Rasterkarte lesen."
+#~ msgstr "Kann die Zeile [%d] der Rasterkarte <%s> nicht lesen."
+#, fuzzy
#~ msgid "Cannot write row to raster map"
-#~ msgstr "Kann die Zeile nicht in die Rasterkarte schreiben."
+#~ msgstr "Kann Rasterkarten nicht schreiben."
+#, fuzzy
#~ msgid "Red input raster map"
-#~ msgstr "Eingabe-Rasterkarte für rot."
+#~ msgstr "Name der Eingabe-Rasterkarte."
+#, fuzzy
#~ msgid "Green input raster map"
-#~ msgstr "Eingabe-Rasterkarte für grün."
+#, fuzzy
#~ msgid "Blue input raster map"
-#~ msgstr "Eingabe-Rasterkartefür blau."
+#, fuzzy
#~ msgid "Output hue raster map"
-#~ msgstr "Ausgabe-Farbton-Rasterkarte (hue)."
+#~ msgstr "Ausgabekarte mit der Hangneigung."
+#, fuzzy
#~ msgid "Output intensity raster map"
-#~ msgstr "Ausgabe-Intensitäts-Rasterkarte (intensity)."
+#~ msgstr "Ausgabe-Rasterkarte der Fließdichte."
+#, fuzzy
#~ msgid "Output saturation raster map"
-#~ msgstr "Ausgabe-Sättigungs-Rasterkarte (saturation)."
+#~ msgstr "Name der Rasterkarte mit Abflussinformationen."
#~ msgid "pyramid constructed."
#~ msgstr "Pyramide erstellt."
+#, fuzzy
#~ msgid ""
#~ "\n"
#~ "Resolution = %d; period = %d"
@@ -29107,14 +29147,13 @@
#~ "\n"
#~ "Auflösung = %d, Periode =%d"
+#, fuzzy
#~ msgid "Class transition statistics."
-#~ msgstr "Klassenübergangs Statistik."
+#~ msgstr "Raster, Statistik"
-#~ msgid "Transition probabilities: %f %f %f; %f"
-#~ msgstr "Transition probabilities: %f %f %f; %f"
+#, fuzzy
#~ msgid "get_img: out of memory."
-#~ msgstr "get_img: Speicher voll."
+#~ msgstr "G_malloc: Kein Speicher mehr da."
#, fuzzy
#~ msgid "Subgroup [%s] in group [%s] contains no files."
@@ -29122,33 +29161,32 @@
#, fuzzy
#~ msgid "Writing [%s] ..."
-#~ msgstr "Schreibe <%s> ..."
+#~ msgstr "Schreibe %s"
#, fuzzy
#~ msgid "Name of imagery signaturefile"
-#~ msgstr "Bild Signatur-Datei."
+#~ msgstr "Name der Bildgruppe."
#~ msgid "Run quietly"
#~ msgstr "Arbeite schweigsam."
+#, fuzzy
#~ msgid "Group [%s] not found."
#~ msgstr "Gruppe [%s] nicht gefunden."
+#, fuzzy
#~ msgid "Subgroup [%s] not found."
-#~ msgstr "Untergruppe [%s] nicht gefunden."
+#~ msgstr "Untergruppe <%s> nicht gefunden."
#, fuzzy
#~ msgid "Signature file [%s] is missing or not readable."
-#~ msgstr "Signaturdatei <%s> fehlt oder kann nicht gelesen werden."
+#~ msgstr "Signaturdatei <%s> ist ungültig."
+#, fuzzy
#~ msgid "Calculating eigenvalues and eigenvectors..."
-#~ msgstr "Berechne Eigenwerte und Eigenvektoren..."
+#~ msgstr "Berechne die Klassenmittel..."
#, fuzzy
-#~ msgid "Ordering eigenvalues in descending order..."
-#, fuzzy
#~ msgid "Transposing eigen matrix..."
#~ msgstr "Transponierte Eigen Matrix..."
@@ -29156,46 +29194,56 @@
#~ msgid "Cannot allocate memory for raster row"
#~ msgstr "Kann kein Speicherplatz für Zeichenkette bekommen."
+#, fuzzy
#~ msgid "Cannot write color table of raster map <%s>"
#~ msgstr "Kann die Farbtabelle der Rasterkarte <%s> nicht schreiben."
+#, fuzzy
#~ msgid "Calculating class mean ..."
-#~ msgstr "Berechne Klassenmittel..."
+#, fuzzy
#~ msgid "Calculating class covariance matrix..."
-#~ msgstr "Berechne Klassenkovatianz-Matrix..."
+#~ msgstr "Berechne Klassenkovarianzmatrizen..."
+#, fuzzy
#~ msgid "Imagery group"
-#~ msgstr "Bildgruppe"
+#, fuzzy
#~ msgid "Subgroup containing image files"
-#~ msgstr "Untergruppe, die Bild-Dateien enthält."
+#~ msgstr "Untergruppe <%s> in Gruppe <%s> enthält keine Dateien."
+#, fuzzy
#~ msgid "Resultant signature file"
-#~ msgstr "Resultierende Signatur-Datei."
+#~ msgstr "Resultierende Signaturdatei: %s\n"
#, fuzzy
#~ msgid "1 class."
-#~ msgstr "%d Klassen."
+#~ msgstr "1 Klasse"
+#, fuzzy
#~ msgid "%d classes."
+#~ msgstr "%d Kreuzungen gefunden"
#, fuzzy
#~ msgid ""
#~ "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
#~ msgstr ""
-#~ "Kann die Signaturdatei <%s> der Untergruppe <%s> in Gruppe <%s> nicht "
-#~ "erzeugen."
+#~ "Kann die Signaturdatei <%s> für die Gruppe <%s>, Untergruppe <%s> nicht "
+#~ "schreiben."
+#, fuzzy
#~ msgid "Input raster map being fft"
-#~ msgstr "Eingabe-Rasterkarte, die fft ist."
+#~ msgstr "Titel der Ausgabe-Rasterkarte."
+#, fuzzy
#~ msgid "Reading the raster map..."
-#~ msgstr "Lese die Rasterkarte..."
+#~ msgstr "Lese Rasterkarte..."
+#, fuzzy
#~ msgid "FFT completed..."
-#~ msgstr "FFT fertiggestellt..."
+#~ msgstr "%s: fertig..."
#, fuzzy
#~ msgid "Unable to open real output map <%s>"
@@ -29205,13 +29253,13 @@
#~ msgid "Unable to open imaginary output map <%s>"
#~ msgstr "Kann Ausgabedatei <%s> nicht öffnen."
+#, fuzzy
#~ msgid ""
#~ "\n"
#~ " group <%s> not found"
-#~ msgstr ""
-#~ "\n"
-#~ "Gruppe <%s> nicht gefunden."
+#~ msgstr "Gruppe <%s> nicht gefunden."
+#, fuzzy
#~ msgid "subgroup <%s> not found"
@@ -29223,22 +29271,22 @@
#~ msgid "The subgroup must have at least 2 files to run %s"
#~ msgstr "Die Untergruppe muss mindestens 2 Dateien enthalten."
+#, fuzzy
#~ msgid "Unable to proceed"
-#~ msgstr "Kann nicht weitermachen."
+#~ msgstr "Kann <%s> nicht lesen."
#, fuzzy
#~ msgid "Can't open seed signature file <%s>"
#~ msgstr "Kann die Start-Signaturdatei <%s> nicht öffnen."
+#, fuzzy
#~ msgid "Can't read signature file <%s>"
#~ msgstr "Kann die Signaturdatei <%s> nicht lesen."
+#, fuzzy
#~ msgid "Group of imagery files to be clustered"
-#~ msgstr "Gruppe von Bilddateien, die in Cluster aufgeteilt werden."
+#~ msgstr "Name der Bildgruppe, die registriert werden soll."
-#~ msgid "Subgroup name in the above group"
-#~ msgstr "Untergruppenname in der angegebenen Gruppe."
#, fuzzy
#~ msgid "File containing initial signatures"
#~ msgstr "Datei die initiale Signatur enthält."
@@ -29255,19 +29303,21 @@
#~ "\n"
#~ "<%s> -- Ungültiger Wert für min_size."
+#, fuzzy
#~ msgid "Can't creat reportfile: "
-#~ msgstr "Kann Reportdatei nicht erzeugen:"
+#~ msgstr "Kann die temporäre Datei <%s> nicht erzeugen."
+#, fuzzy
#~ msgid "Reading image ... "
-#~ msgstr "Lese Bild..."
+#~ msgstr "Lese Karte ein ..."
#, fuzzy
#~ msgid "group=[%s] - not found."
-#~ msgstr "Gruppe=<%s> - nicht gefunden."
+#~ msgstr "Gruppe [%s] nicht gefunden."
#, fuzzy
#~ msgid "subgroup=[%s] (of group [%s]) - not found."
-#~ msgstr "Untergruppe=<%s> (der Gruppe <%s>) - nicht gefunden."
#, fuzzy
#~ msgid "Can't read signature file [%s]."
@@ -29275,61 +29325,55 @@
#, fuzzy
#~ msgid "[%s] has more than 255 signatures."
-#~ msgstr "<%s> hat mehr als 255 Signaturen."
+#~ msgstr "%s hat zu viele Signaturen."
#, fuzzy
#~ msgid "Unable to create reject layer [%s]."
-#~ msgstr "Kann die Reject-Karte <%s> nicht erzeugen."
+#~ msgstr "Kann die Projektionsdateien %s nicht erzeugen."
+#, fuzzy
#~ msgid "Imagery group to be classified"
-#~ msgstr "Bildgruppe, die klassifiziert werden soll."
+#~ msgstr "Rasterkarte, die neu klassifiziert werden soll."
+#, fuzzy
#~ msgid "Subgroup containing image files to be classified"
-#~ msgstr "Untergruppe, die die Bilder zur Klassifikation enthält."
+#~ msgstr "Markiere die Kontrollpunkte (GCP) auf dem zu entzerrenden Bild."
+#, fuzzy
#~ msgid "Signatures to use for classification"
-#~ msgstr "Signaturen, die für die Klassifikation genutzt werden sollen."
+#~ msgstr "Algorithmus, der zur Klassifikation verwendet werden sollen."
+#, fuzzy
#~ msgid "Raster map to hold classification results"
-#~ msgstr "Rasterkarte mit den Klassifikationsergebnissen"
+#~ msgstr "Name der Rasterkarte mit Klassifikationsergebnissen."
#, fuzzy
#~ msgid "raster, imagery, fusion"
#~ msgstr "Raster, Bilder, Import"
-#~ msgid "sensor: LANDSAT"
-#~ msgstr "Sensor: LANDSAT"
-#~ msgid "sensor: QuickBird"
-#~ msgstr "Sensor: QuickBird"
-#~ msgid "sensor: SPOT"
-#~ msgstr "Sensor: SPOT"
#, fuzzy
#~ msgid "raster input maps"
#~ msgstr "Eingabe-Rasterkarte"
-#, fuzzy
#~ msgid "Select multiple points"
-#~ msgstr "Dateityp"
+#~ msgstr "Selektiere mehrere Punkte."
-#, fuzzy
#~ msgid "run non-interactively"
-#~ msgstr "Gebe Regeln interaktive ein"
+#~ msgstr "nicht interaktiv"
-#, fuzzy
#~ msgid "Run non-interactively"
#~ msgid "Unable to open raster map <%s> in mapset <%s>"
#~ msgstr "Kann die Rasterkarte <%s> in Mapset <%s> nicht öffnen."
+#, fuzzy
#~ msgid "ERROR: Problem opening output file."
-#~ msgstr "FEHLER: Problem beim Öffnen der Ausgabedatei."
+#~ msgstr "Kann die Ausgabedatei nicht öffnen."
+#, fuzzy
#~ msgid "Name of fractal surface raster layer"
-#~ msgstr "Name der Karte mit der fraktalen Oberfläche."
+#~ msgstr "Name der Basis-Rasterkarte."
#~ msgid "File containing reclass rules"
#~ msgstr "Datei mit Reklassifizierungsregeln."
@@ -29350,20 +29394,24 @@
#~ msgid "%s: ERROR running %s command"
#~ msgstr "%s: Fehler beim Ausführen des Kommandos %s."
+#, fuzzy
#~ msgid "%s=%s - illegal value"
-#~ msgstr "%s=%s - unzulässiger Wert."
+#~ msgstr "%s - unzulässiger x-Wert."
+#, fuzzy
#~ msgid "Unable to read current region parameters"
-#~ msgstr "Kann die Parameter der aktuellen Region nicht lesen."
+#~ msgstr "Kann die aktuellen Fensterparameter nicht lesen."
#~ msgid "Unable to get current region"
#~ msgstr "Kann die aktuelle Region nicht bekommen."
+#, fuzzy
#~ msgid "Cannot open cover raster map <%s>"
-#~ msgstr "Kann die Bedeckungs-Rasterkarte <%s> nicht öffnen."
+#~ msgstr "Kann die Rasterkarte <%s> nicht öffnen."
+#, fuzzy
#~ msgid "Cannot open database <%s> by driver <%s>"
-#~ msgstr "Kann die Datenbank <%s> mit dem Treiber <%s> nicht öffnen."
#~ msgid ""
#~ "Finds the median of values in a cover map within areas assigned the same "
@@ -29378,34 +29426,24 @@
#~ msgid "Unable to read category labels of raster map <%s>"
#~ msgstr "Kann die Kategorietypen der Rasterkarte <%s> nicht lesen."
-#~ msgid ""
-#~ "%s: saving [%s] raster map layer.\n"
-#~ "Percent complete:"
-#~ msgstr ""
-#~ "%s: Speichere [%s] Rasterkarte.\n"
-#~ "Prozent fertig: "
+#, fuzzy
#~ msgid "Starting map [%s]"
-#~ msgstr "Ausgangskarte [%s]."
-#~ msgid "Starting filter #%d, distance: %.*lf, exponent: %.*lf, flat: %.*lf"
-#~ msgstr ""
-#~ "Beginne Filter Nr. %d, Distanz: %.*lf, Exponent: %.*lf, flach: %.*lf"
+#, fuzzy
#~ msgid "Percent done:"
#~ msgstr "Prozent fertig: "
#~ msgid "Unable to read current window parameters"
-#~ msgid "CLUMP PASS %d ... "
-#~ msgstr "CLUMP DURCHGANG %d ... "
+#, fuzzy
#~ msgid "Unable to properly read input raster map"
-#~ msgstr "Kann Eingabe-Rasterkarte nicht richtig lesen."
+#~ msgstr "Kann die Eingabe-Rasterkarte nicht schließen."
+#, fuzzy
#~ msgid "Unable to properly write output raster map"
-#~ msgstr "Kann Ausgabe-Rasterkarte nicht richtig schreiben."
+#~ msgstr "Kann die Ausgabe-Rasterkarte nicht schließen."
#, fuzzy
#~ msgid "SECTION %d beginning: Closing Maps."
@@ -29415,15 +29453,13 @@
#~ msgid "SECTION %d beginning: Watershed determination."
#~ msgstr "Abschnitt %d: Bestimme Wassereinzugsgebiet."
-#~ msgid "problem w/ astar algorithm"
-#~ msgstr "Problem mit dem astar-Algorithmus."
#, fuzzy
#~ msgid "Could not read range file"
#~ msgstr "Kann die Ausdehnungs-Datei nicht lesen."
+#, fuzzy
#~ msgid "Reading data: "
-#~ msgstr "Lese Daten:"
+#~ msgstr "Lese Daten..."
#~ msgid "Rowio_setup failed"
#~ msgstr "Rowio_setup fehlgeschlagen"
@@ -29434,29 +29470,36 @@
#~ msgid "File containing recode rules"
#~ msgstr "Datei die Regeln zum Umkodieren enthält."
+#, fuzzy
#~ msgid "Name of raster map layer to be used for <%s>"
-#~ msgstr "Name der Rasterkarte für <%s>"
+#~ msgstr "Name der Rasterkarte für <%s>."
#~ msgid "Elevation map not found"
#~ msgstr "Höhenkarte nicht gefunden."
+#, fuzzy
#~ msgid "%d points converted to centroids"
-#~ msgstr "%d Punkte in Zentroide verwandelt"
+#~ msgstr "%-5d Punkte sind in den Speicher gelesen worden.\n"
+#, fuzzy
#~ msgid "%d centroids converted to points"
-#~ msgstr "%d Zentroide in Punkte verwandelt"
+#~ msgstr "%d Feature konvertiert."
+#, fuzzy
#~ msgid "%d lines converted to boundaries"
-#~ msgstr "%d Linien zu Grenzen verwandelt"
+#~ msgstr "%s Datei(en), die entfernt werden sollen."
+#, fuzzy
#~ msgid "%d boundaries converted to lines"
-#~ msgstr "%d Grenzen zu Linien verwandelt"
+#~ msgstr "%d Grenzen geschlossen"
+#, fuzzy
#~ msgid "ID values"
-#~ msgstr "ID Werte"
+#~ msgstr "Eigenwert:"
+#, fuzzy
#~ msgid "CrossCorrelation: %d points read in region.\n"
-#~ msgstr "Kreuzkorrelation: %d Punkte gelesen in der Region.\n"
+#~ msgstr "%lu Punkte in der Region gefunden."
#, fuzzy
#~ msgid "CrossCorrelation: Cannot read field info"
@@ -29464,7 +29507,7 @@
#, fuzzy
#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
#, fuzzy
#~ msgid "CrossCorrelation: Column type not supported"
@@ -29472,7 +29515,7 @@
#, fuzzy
#~ msgid "CrossCorrelation: Cannot select data from table"
-#~ msgstr "Kann Daten nicht aus der Tabelle selektieren."
+#~ msgstr "Kann die Daten (%s) nicht aus der Tabelle selektieren."
#, fuzzy
#~ msgid "CrossCorrelation: %d records selected from table"
@@ -29480,50 +29523,43 @@
#, fuzzy
#~ msgid "CrossCorrelation: No record for point (cat = %d)"
-#~ msgstr "Kein Eintrag für Linie (cat = %d)."
+#~ msgstr "Interpolation: (%d,%d): Kein Eintrag für den Punkt (cat = %d)."
#, fuzzy
-#~ msgid "CrossCorrelation: Mean = %.5lf\n"
-#~ msgstr "Kann Feld-Information nicht lesen."
+#~ msgid "To_map"
+#~ msgstr "From_map"
#, fuzzy
-#~ msgid "CrossCorrelation: lambda_i = %.3f\n"
-#~ msgid ""
-#~ "\n"
-#~ "Results are over.\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Ergebnisse sind vorbei.\n"
-#~ msgid "To_map"
-#~ msgstr "To_map"
#~ msgid "From type"
-#~ msgstr "Art des Starts"
+#~ msgstr "Art der Kante"
+#, fuzzy
#~ msgid "To type"
-#~ msgstr "Art des Ziels"
+#, fuzzy
#~ msgid "From layer"
-#~ msgstr "Start Layer"
+#~ msgstr "Kanten-Layer"
+#, fuzzy
#~ msgid "To layer"
-#~ msgstr "Ziel Layer"
+#~ msgstr "Name der Eingabekarte."
+#, fuzzy
#~ msgid "vector, attribute table"
-#~ msgstr "Vektor, Attributtabelle"
+#~ msgstr "Vektor, Raster, Attributtabelle"
#, fuzzy
#~ msgid "Select type"
+#, fuzzy
#~ msgid "Cannot select records from database"
-#~ msgstr "Kann keine Einträge der Datenbank selektieren."
+#~ msgstr "Kann Daten nicht aus der Tabelle selektieren."
+#, fuzzy
#~ msgid "Cannot fetch data"
-#~ msgstr "Kann die Daten nicht holen."
+#~ msgstr "Kann die Zeile nicht holen."
#, fuzzy
#~ msgid "Calculating costs from centres..."
@@ -29547,19 +29583,23 @@
#, fuzzy
#~ msgid "Feature id(s)"
-#~ msgstr "Features"
+#~ msgstr "Art des Vektorobjekts."
+#, fuzzy
#~ msgid "Input vector was not found."
-#~ msgstr "Eingabevektorkarte wurde nicht gefunden."
+#~ msgstr "Vektorkarte <%s> nicht gefunden."
+#, fuzzy
#~ msgid "Cannot open dig_cats file."
-#~ msgstr "Kann dig_cats Datei nicht öffnen."
+#~ msgstr "Kann die dig_att Datei <%s> nicht öffnen.\n"
+#, fuzzy
#~ msgid "Cannot open database %s"
-#~ msgstr "Kann Datenbank '%s' nicht öffnen."
+#~ msgstr "Kann Datenquelle nicht öffnen."
+#, fuzzy
#~ msgid "Cannot insert into table: %s"
-#~ msgstr "Kann nicht an Tabelle '%s' anfügen."
+#~ msgstr "Kann nicht in Tabelle <%s> einfügen."
#, fuzzy
#~ msgid "%s: Unable to read font definition file; use the default"
@@ -29576,22 +29616,19 @@
#, fuzzy
#~ msgid "Node layer (points)"
-#~ msgstr "Name der Karte, die für den Farbton (HUE) verwendet werden soll"
+#~ msgstr "Knoten-Layer (verwendet für Städte)"
#, fuzzy
#~ msgid "Reading data from the map..."
#, fuzzy
#~ msgid "Type of elements"
#~ msgstr "Name des Elements."
-#~ msgid "Query layer (used by 'query' option)"
-#~ msgstr "Abfrage-Layer. Wird nur von der 'Query'-Option verwendet."
#, fuzzy
#~ msgid "%d categories read from map"
-#~ msgstr "geladen von Tabelle"
+#~ msgstr "%d Kategorien aus der Karte gelesen."
#, fuzzy
#~ msgid "%d update/insert errors"
@@ -29599,14 +29636,8 @@
#, fuzzy
#~ msgid "Current region does not include the entire input vector map <%s>"
-#~ msgstr "Kann die Eingabevektorkarte <%s> nicht finden."
+#~ msgstr "%d Kategorien mit mehr als einem Feature in der Vektorkarte <%s>."
-#, fuzzy
-#~ msgid ""
-#~ "Elevation raster map <%s> does not cover the entire area of the input "
-#~ "vector map <%s>. "
#~ msgid "Removing %s <%s>"
#~ msgstr "Entferne %s <%s>."
@@ -29636,7 +29667,7 @@
#, fuzzy
#~ msgid "Unable to find the real-image map <%s>"
-#~ msgstr "%s: %s - Kann das Realteil-Bild nicht finden."
+#~ msgstr "Kann die Wert-Karte <%s> nicht erzeugen."
#, fuzzy
#~ msgid ""
@@ -29648,7 +29679,7 @@
#, fuzzy
#~ msgid "Unable to find the imaginary-image <%s>"
-#~ msgstr "%s: %s - Kann das Bild mit dem imaginären Teil nicht finden."
+#~ msgstr "Kann der Startvektor <%s> nicht finden."
#, fuzzy
#~ msgid ""
@@ -29658,11 +29689,13 @@
#~ "Kann das Bild mit dem imaginären Teil im cell_misc Ordner nicht öffnen.\n"
#~ "Eingabekarte wurde wahrscheinlich nicht mit i.fft erstellt."
+#, fuzzy
#~ msgid "Power 2 values : [%d] rows [%d] columns."
-#~ msgstr "'hoch zwei'-Werte: [%d] Zeilen [%d] Spalten."
+#~ msgstr "'hoch zwei'-Werte: %d Zeilen %d Spalten."
+#, fuzzy
#~ msgid "Unable to open output file."
-#~ msgstr "Öffnen der Ausgabedatei nicht möglich"
#, fuzzy
#~ msgid "Writing data to file..."
@@ -29675,8 +29708,9 @@
#~ msgid "Range less than or equal to zero not allowed."
#~ msgstr "Bereich weniger oder gleich Null ist nicht erlaubt."
+#, fuzzy
#~ msgid "Initializing data...\n"
-#~ msgstr "Initialisiere Daten...\n"
+#~ msgstr "Initialisiere Daten..."
#, fuzzy
#~ msgid "Writing viewable versions of transformed data to files..."
@@ -29707,8 +29741,9 @@
#~ "Name einer Karte im Zielmapset. Sie wird sofort auf dem Bildschirm "
#~ "dargestellt."
+#, fuzzy
#~ msgid "Unable to read head of %s"
-#~ msgstr "Kann den Header von <%s> nicht lesen."
+#~ msgstr "Kann die Header-Datei für <%s> nicht lesen."
#, fuzzy
#~ msgid "Name of imagery group for ortho-rectification"
@@ -29723,12 +29758,12 @@
#~ msgid "Unable to write row %d"
#~ msgstr "Kann die Zeile %d nicht schreiben."
-#, fuzzy
#~ msgid "Name of GIS manager settings file (.grc)"
-#~ msgstr "Name der MAT-Datei (v4)"
+#~ msgstr "Name der Datei mit den Einstellungen des GIS-Managers (.grc)."
+#, fuzzy
#~ msgid "Creates explicitly the NULL-value bitmap file."
-#~ msgstr "Erzeugt ausdrücklich eine NULL-Wert Bitmap-Datei."
+#~ msgstr "Erstelle explizit ein 3D NULL-Wert Bitmap Datei."
#, fuzzy
#~ msgid ""
@@ -29744,19 +29779,23 @@
#, fuzzy
#~ msgid "Density of output walkers"
-#~ msgstr "Name der Ausgabedatei"
+#~ msgstr "Name der Ausgabedatei."
+#, fuzzy
#~ msgid "File [%s] not found"
-#~ msgstr "Datei [%s] nicht gefunden."
+#~ msgstr "Datei <%s> nicht gefunden."
+#, fuzzy
#~ msgid "Unable to open file [%s]"
-#~ msgstr "Kann die Datei [%s] nicht öffnen."
+#~ msgstr "Kann die Datei <%s> nicht öffnen."
+#, fuzzy
#~ msgid "Failed to guess file format"
-#~ msgstr "Das Erraten des Datei-Formates ist fehlgeschlagen."
+#~ msgstr "Das Erraten des Sites-Formates ist schief gegangen."
+#, fuzzy
#~ msgid "Reading sites map (%s) ..."
-#~ msgstr "Lese Sites-Karte (%s) ..."
+#~ msgstr "Lese Karte %s ..."
#, fuzzy
#~ msgid "Name of the output walkers vector points map"
@@ -29766,18 +29805,21 @@
#~ msgid "You are not outputting any raster or vector points maps"
#~ msgstr "Es werden weder Vektor- noch Rasterdaten ausgegeben."
+#, fuzzy
#~ msgid "No map specified"
-#~ msgstr "Keine Karte angegeben."
+#~ msgstr "Keine Eingabekarte angegeben."
+#, fuzzy
#~ msgid "%s - unable to remove color table"
-#~ msgstr "%s - kann die Farbtabelle nicht löschen."
+#~ msgstr "Kann die Farbtabelle für %s nicht lesen."
+#, fuzzy
#~ msgid "%s - color table not found"
-#~ msgstr "%s - Farbtabelle nicht gefunden."
+#~ msgstr "%s: Bedeckungs-Rasterkarte nicht gefunden."
+#, fuzzy
#~ msgid "Can't make logarithmic color table for floating point map"
-#~ msgstr ""
-#~ "Kann keine logarithmische Farbtabelle für Fließkomma-Karten erzeugen."
+#~ msgstr "vals-argument wird für Fließkomma-Karte benötigt."
#, fuzzy
#~ msgid "Removed vertices"
@@ -29792,9 +29834,11 @@
#~ "\t overlap: features partially or completely overlap"
#~ msgstr "Operator zwischen feature ist Ausgabe von ist feature ist von ist n"
+#, fuzzy
#~ msgid "Processing ainput lines ..."
-#~ msgstr "Verarbeite ainput Zeilen ..."
+#~ msgstr "Verarbeite Zeilen... "
+#, fuzzy
#~ msgid "Writing attributes ..."
#~ msgstr "Schreibe Attribute ..."
@@ -29811,32 +29855,23 @@
#~ msgid "Unable to read raster row"
#~ msgstr "Kann Rasterzeile nicht lesen."
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Optionale 'where'-Angabe (ohne 'WHERE' Schlüsselwort), z.B.:\n"
#~ msgid "Illegal output file name"
#~ msgstr "Ungültiger Ausgabedateiname."
#~ msgid "Width in pixels of new display monitor"
-#~ msgstr "Breite des neuen Grafik-Fensters in Pixel."
+#~ msgstr "Breite des neuen Grafikfensters in Pixel."
#~ msgid "Height in pixels of new display monitor"
-#~ msgstr "Höhe des neuen Grafik-Fensters in Pixel."
+#~ msgstr "Höhe des neuen Grafikfensters in Pixel."
-#, fuzzy
#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "Verwaltet Fenster im Grafik-Fenster des Benutzers."
+#~ msgstr "Verschiebt angezeigte Karten in ein anderes Grafikfenster."
-#, fuzzy
#~ msgid "Target monitor"
-#~ msgstr "Lösche Monitore... "
+#~ msgstr "Ziel Grafikfenster."
#~ msgid "Source monitor"
-#~ msgstr "Quell Grafik-Fenster."
+#~ msgstr "Quell Grafikfenster."
#~ msgid "display, export, GPS"
#~ msgstr "Anzeige, Export, GPS"
@@ -29847,11 +29882,9 @@
#~ msgid "display, export"
#~ msgstr "Anzeige, Export"
-#, fuzzy
#~ msgid "Saves the contents of the active display monitor to a graphics file."
#~ msgstr ""
-#~ "Löscht den Inhalte des aktiven Grafik-Fensters mit einer "
-#~ "benutzerdefinierten Farbe."
+#~ "Speichert den Inhalte des aktiven Grafikfensters in einer Grafikdatei."
#~ msgid "Compression for PNG files"
#~ msgstr "Komprimierung für PNG-Dateien."
@@ -29862,21 +29895,17 @@
#~ msgid "PostScript"
#~ msgstr "PostScript"
-#, fuzzy
#~ msgid "Set transparent background"
-#~ msgstr "Bestimmt die Farbe des Menü Hintergrunds."
+#~ msgstr "Stelle Hintergrund auf transparent."
-#, fuzzy
#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "Gebe die Namen aller im GRASS Fenster dargestellten Karten aus."
+#~ msgstr "Zeichnet aktives Fenster im GRASS Grafikfenster erneut."
-#, fuzzy
#~ msgid "Redraw all frames"
-#~ msgstr "Speichere alle Rahmen ab."
+#~ msgstr "Zeichnen aller Fenster erneut."
-#, fuzzy
#~ msgid "Resizes active display monitor"
-#~ msgstr "Zeige Informationen über das aktive Grafik-Fenster."
+#~ msgstr "Ändere die Größe des aktiven Grafikfenster."
#~ msgid "New width for window"
#~ msgstr "Neue Fensterbreite."
@@ -29884,72 +29913,71 @@
#~ msgid "New height for window"
#~ msgstr "Neue Fensterhöhe."
-#, fuzzy
#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "von"
+#~ msgstr "Diashow der GRASS Raster- / Vektorkarten."
#~ msgid "display, slideshow"
#~ msgstr "Anzeige, Diashow"
-#, fuzzy
#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "Setze Region angepasst an diese Rasterkarte."
+#~ msgstr "Zeige eher Vektorkarten als Rasterkarten."
-#, fuzzy
#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "Anzahl der Zellen zwischen Fließlinien."
+#~ msgstr "Pause zwischen den Bildern in Sekunden."
-#, fuzzy
#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr "Name der Rasterkarte, die angezeigt werden soll."
+#~ msgstr ""
+#~ "Geben Sie den Name der Rasterkarte ein, die im 1. Fenster gezeigt werden "
+#~ "soll."
#~ msgid "Enter command to execute in 1st frame"
#~ msgstr "Geben Sie den Befehl an, der im 1. Rahmen ausgeführt werden soll."
-#, fuzzy
#~ msgid "Enter raster map to display in 2nd frame"
+#~ msgstr ""
+#~ "Geben Sie den Name der Rasterkarte ein, die im 2. Fenster gezeigt werden "
+#~ "soll."
#~ msgid "Enter command to execute in 2nd frame"
#~ msgstr "Geben Sie den Befehl an, der im 2. Rahmen ausgeführt werden soll."
-#, fuzzy
#~ msgid "How to split display"
-#~ msgstr "Darzustellender Text"
+#~ msgstr "Wie das Fenster geteilt werden soll"
+#, fuzzy
#~ msgid "display, legend"
-#~ msgstr "Anzeige, Legende"
+#~ msgstr "Drehe Legende."
#, fuzzy
#~ msgid "Vector map to display thematically"
-#~ msgstr "Vektorkartentyp."
+#~ msgstr "Vektorkarte deren Attributtabelle edtiert werden soll."
#, fuzzy
#~ msgid "Theme_prefs"
-#~ msgstr "Theme_prefs"
+#~ msgstr "Thema"
+#, fuzzy
#~ msgid "Vector map type"
-#~ msgstr "Vektorkartentyp"
+#~ msgstr "Vektorkartentyp."
#, fuzzy
#~ msgid "Attribute column to use for thematic display (must be numeric)"
-#~ msgstr "Attribut-Spalte, die für die Pufferdistanz benutzt werden soll."
+#~ msgstr ""
+#~ "Name der Attribut-Spalte, die für die thematische Darstellung (muß "
+#~ "umerisch sein)."
-#, fuzzy
#~ msgid "Type of thematic display"
+#~ msgstr "Art der thematischen Darstellung."
#, fuzzy
#~ msgid "Layer to use for thematic display"
-#~ msgstr "Text für das vertikale Datum der Karte."
-#, fuzzy
#~ msgid "Vector point icon for point data"
-#~ msgstr "Vektordatei die Beispielpunkte enthält."
+#~ msgstr "Symbol für Punktdaten."
-#, fuzzy
#~ msgid "Number of classes for interval theme (integer)"
-#~ msgstr "Anzahl der Kopien."
+#~ msgstr "Anzahl der Klassen für das Interval-Thema (integer)."
#~ msgid "Misc"
#~ msgstr "Verschiedenes"
@@ -29958,8 +29986,9 @@
#~ msgid "Mapset(s) to list (default: current mapset search path)"
#~ msgstr "Aufzulistendes Mapset (Standard: aktueller Suchpfad)."
+#, fuzzy
#~ msgid "Output separator (default: newline)"
-#~ msgstr "Ausgabe-Trennzeichen (Standard: Zeilenumbruch)."
+#~ msgstr "Ausgabe-Rasterkarte (Standard: Eingabekachel)."
#, fuzzy
#~ msgid "Raster to remove"
@@ -29971,7 +30000,7 @@
#, fuzzy
#~ msgid "Vector to remove"
+#~ msgstr "Einzublendende Vektorkarte."
#, fuzzy
#~ msgid "Region to remove"
@@ -29979,14 +30008,12 @@
#, fuzzy
#~ msgid "Label to remove"
+#~ msgstr "Tabelle die gelöscht werden soll."
+#, fuzzy
#~ msgid "3dview to remove"
-#~ msgstr "3dview der gelöscht werden soll"
+#~ msgstr "%d Vertices gelöscht"
-#~ msgid "Group to remove"
-#~ msgstr "Gruppe, die entfernt werden soll."
#, fuzzy
#~ msgid "Keep band numbers instead of using band color names."
#~ msgstr "Verwende die Nummern der Kanäle anstatt der Farbbezeichnungen."
@@ -30018,24 +30045,21 @@
#~ msgid "Do not overwrite existing map"
#~ msgstr "Überschreibe nicht eine bereits existierende Karte."
-#, fuzzy
#~ msgid "Exports GRASS raster into GDAL supported formats."
#~ msgstr "Exportiert GRASS-Rasterkarten in GDAL-unterstütze Formate."
+#, fuzzy
#~ msgid "Output field seperator"
#~ msgstr "Ausgabe Feld-Trennzeichen"
-#, fuzzy
#~ msgid "calculates univariate statistics from a GRASS raster map"
-#~ msgstr ""
-#~ "Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
+#~ msgstr "Berechnet univariate Statistiken einer GRASS Rasterkarte."
#~ msgid "extended statistics (quartiles and percentile)"
#~ msgstr "Mehr statistische Kennzahlen (Quartile und Perzentile)."
-#, fuzzy
#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "Kann die Eingabekarte nicht schließen."
+#~ msgstr "Zu berechnendes Perzentil (erfordert den Schalter -e)."
#~ msgid "A (grid3D file)"
#~ msgstr "A (grid3D file)"
@@ -30060,29 +30084,35 @@
#, fuzzy
#~ msgid "raster, imagery, dehaze"
-#~ msgstr "Raster, Kartenalgebra"
+#~ msgstr "Raster, Bilder"
+#, fuzzy
#~ msgid "LANDSAT TM1 channel"
-#~ msgstr "LANDSAT TM1 Kanal"
+#~ msgstr "LANDSAT roter Kanal"
+#, fuzzy
#~ msgid "LANDSAT TM2 channel"
-#~ msgstr "LANDSAT TM2 Kanal"
+#, fuzzy
#~ msgid "LANDSAT TM3 channel"
-#~ msgstr "LANDSAT TM3 Kanal"
+#, fuzzy
#~ msgid "LANDSAT TM4 channel"
-#~ msgstr "LANDSAT TM4 Kanal"
+#, fuzzy
#~ msgid "LANDSAT TM5 channel"
-#~ msgstr "LANDSAT TM5 Kanal"
+#, fuzzy
#~ msgid "LANDSAT TM7 channel"
-#~ msgstr "LANDSAT TM7 Kanal"
#, fuzzy
#~ msgid "raster output dehazed maps prefix"
-#~ msgstr "Prefix der Ausgabe-Rasterkarte."
+#~ msgstr "Präfix für Ausgabe TC-Rasterkarten"
#~ msgid "%s: [%s] not found"
#~ msgstr "%s: [%s] nicht gefunden."
@@ -30196,21 +30226,25 @@
#~ msgid "Unable to find clump map"
#~ msgstr "Kann die Rasterkarte mit Klumpen nicht finden."
+#, fuzzy
#~ msgid "Memory allocation error"
-#~ msgstr "Speicherbelegungsfehler."
+#~ msgstr "Metrische Belegung."
+#, fuzzy
#~ msgid "Saving new map"
-#~ msgstr "Speichere neue Karte"
+#~ msgstr "Lese Karte"
#, fuzzy
#~ msgid "Terrain raster map (DEM)"
#~ msgstr "Name der Terrain Rasterkarte (DEM)."
+#, fuzzy
#~ msgid "Output raster map with lake"
-#~ msgstr "Ausgabe-Rasterkarte mit See"
+#, fuzzy
#~ msgid "Cannot write lake raster map <%s>!"
-#~ msgstr "Kann die See-Rasterkarte <%s> nicht schreiben!"
+#~ msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
#, fuzzy
#~ msgid "Terrain raster map <%s> not found!"
@@ -30218,19 +30252,23 @@
#, fuzzy
#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#~ msgstr "Kann die Rasterkarte <%s> nicht öffnen!"
+#, fuzzy
#~ msgid "Seed map <%s> not found!"
-#~ msgstr "Karte mit Startpunkten <%s> nicht gefunden."
+#~ msgstr "%s Karte <%s> nicht gefunden."
+#, fuzzy
#~ msgid "Cannot open seed map <%s@%s>!"
-#~ msgstr "Kann die Karte mit Startpunkten <%s@%s> nicht öffnen!"
+#, fuzzy
#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "Kann keinen Speicherplatz für Zeilen-Zeiger belegen."
+#~ msgstr "Kann keinen Speicherplatz für Zeilen-Puffer belegen."
+#, fuzzy
#~ msgid "Loading maps: "
-#~ msgstr "Lade Karten: "
#, fuzzy
#~ msgid "Error reading terrain raster map. Probably broken file."
@@ -30240,23 +30278,14 @@
#~ msgid "Error reading seed raster map. Probably broken file."
#~ msgstr "Fehler beim Lesen der temporären Datei."
+#, fuzzy
#~ msgid "Cannot write lake raster map <%s@%s>!"
-#~ msgstr "Kann die See-Rasterkarte <%s@%s> nicht schreiben!"
-#~ msgid ""
-#~ "Starting lake filling at level of %8.4f in %d passes. \n"
-#~ "Percent done:"
-#~ msgstr ""
-#~ "Beginne mit dem Füllen des Sees bei Niveau von %8.4f mit %d "
-#~ "Durchgängen. \n"
-#~ "Prozent erledigt:"
+#, fuzzy
#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "Fehler beim Schreiben der Farb-Datei für <%s@%s>!"
+#~ msgstr "Fehler beim Schreiben der Farb-Datei für <%s>."
-#~ msgid "All done."
-#~ msgstr "Alles erledigt."
#~ msgid "%s: base raster map not found"
#~ msgstr "%s: Basis-Rasterkarte nicht gefunden."
@@ -30307,21 +30336,25 @@
#~ "Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht "
#~ "schreiben."
+#, fuzzy
#~ msgid "Raster input maps(s)"
-#~ msgstr "Eingabe-Rasterkarte(n)"
+#~ msgstr "Eingabe-Rasterkarten"
+#, fuzzy
#~ msgid "Output file name"
-#~ msgstr "Ausgabe-Dateiname"
+#~ msgstr "Ausgabe-Tabellenname"
+#, fuzzy
#~ msgid "%s: can't read fp range for [%s]"
-#~ msgstr "%s: Kann die fp Spanne für [%s] nicht lesen."
+#~ msgstr "Kann die fp Spanne für <%s> nicht lesen."
+#, fuzzy
#~ msgid ""
#~ "Raster map [%s] already exists.\n"
#~ "Please try another."
#~ msgstr ""
-#~ "Rasterkarte [%s] existiert bereits.\n"
-#~ "Bitte wählen Sie eine Andere."
+#~ "Rasterkarte <%s> existiert bereits im Mapset <%s>, wählen Sie einen "
+#~ "anderen Namen."
#~ msgid "RGB raster map <%s> not found"
#~ msgstr "RGB Rasterkarte <%s> nicht gefunden."
@@ -30567,11 +30600,9 @@
#~ msgid "Apply filter only to zero data values"
#~ msgstr "Filter nur auf 0-Werte anwenden."
-#~ msgid "G_put_raster_row failed (file system full?)"
-#~ msgstr "G_put_raster_row failed (Dateisystem voll?)"
+#, fuzzy
#~ msgid "Run verbosly"
-#~ msgstr "Im gesprächigen Modus ausführen."
+#~ msgstr "Detaillierte Ausgabe"
#~ msgid "Run VERBOSELY"
#~ msgstr "Ausführliche Ausgabe."
@@ -30582,27 +30613,33 @@
#~ msgid "Vector map <%s> not found in the current mapset"
#~ msgstr "Vektorkarte <%s> im aktuellen Mapset nicht gefunden."
+#, fuzzy
#~ msgid "Cannot execute: %s"
-#~ msgstr "Kann nicht ausgeführt werden: %s"
+#~ msgstr "Kann Tabelle '%s' nicht erzeugen."
+#, fuzzy
#~ msgid "Cannot link table: %s"
-#~ msgstr "Kann Tabelle nicht verlinken: '%s'"
+#~ msgstr "Kann die Tabelle '%s' nicht verändern."
+#, fuzzy
#~ msgid "DXF input file"
-#~ msgstr "DXF Eingabedatei."
+#~ msgstr "DXF Ausgabedatei."
+#, fuzzy
#~ msgid "Cannot open dxf file <%s>"
-#~ msgstr "Kann die dxf-Datei <%s> nicht öffnen."
+#~ msgstr "Kann die Regel-Datei <%s> nicht öffnen."
#, fuzzy
#~ msgid "Use output= option to change vector map name"
-#~ msgstr "Ausgabe option"
+#~ msgstr "Verwende die Option '%s' um den Namen der Vektorkarte zu ändern."
+#, fuzzy
#~ msgid "Cannot open new vector map <%s>"
-#~ msgstr "Kann neue Vektorkarte <%s> nicht öffnen."
+#~ msgstr "Kann die Vektor-Punktkarte <%s> nicht öffnen."
+#, fuzzy
#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr "Konvertiere <%s> in eine Vektorkarte:"
+#~ msgstr "Kann die Vektordatei %s nicht erzeugen."
#~ msgid "Vector map <%s> is not in user mapset and cannot be updated"
#~ msgstr ""
@@ -30629,30 +30666,26 @@
#~ msgid "Hilight color for text"
#~ msgstr "für"
+#, fuzzy
#~ msgid "Line: %d\n"
-#~ msgstr "Zeile: %d\n"
+#~ msgstr "Länge der Linie: %f\n"
#, fuzzy
-#~ msgid "Insufficent memory for allocation of data structure"
-#~ msgstr "Ungenügend Speicher für das Belegen der Datenstruktur."
#~ msgid "Specified group does not exist"
-#~ msgstr "Angegebene Gruppe existiert nicht."
+#~ msgstr "Angegebene Gruppe existiert nicht im aktuellen Mapset."
+#, fuzzy
#~ msgid "imagery subgroup"
-#~ msgstr "Bilduntergruppe"
+#~ msgstr "Name der Bild-Untergruppe."
+#, fuzzy
#~ msgid "output raster map"
-#~ msgstr "Ausgabe-Rasterkarte"
#, fuzzy
#~ msgid "Name of input raster map(s)"
-#~ msgid "Output file extension (inputfile(s) + extension)"
-#~ msgstr ""
-#~ "Dateieerweiterung der Ausgabekarte (Eingabedatei(en) + Dateierweiterung)."
#~ msgid "name=%s\n"
#~ msgstr "Name=%s\n"
@@ -30665,21 +30698,23 @@
#~ msgid "usage: %s file [prompt %%x %%y]\n"
#~ msgstr "Verwendung: %s Datei [Prompt %%x %%y]\n"
+#, fuzzy
#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "Ungültiger Name für den realen Teil: %s"
+#~ msgstr "Ungültiges Filterdateiformat."
+#, fuzzy
#~ msgid "Illegal file name for imaginary part: %s"
-#~ msgstr "Ungültiger Dateiname für den imaginären Teil: %s"
+#, fuzzy
#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "** Kann die Signaturdatei <%s> nicht lesen. **"
+#~ msgstr "** Kann die Signatur-Datei <%s> nicht lesen. **"
+#, fuzzy
#~ msgid ""
#~ "\n"
#~ "<%s> -- illegal result signature file name"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- Ungültiger Dateiname für die resultierende Signatur."
+#~ msgstr "Ungültiger Signaturdateiname <%s>."
#~ msgid "Illegal group name <%s>"
#~ msgstr "Ungültiger Gruppen-Name <%s>."
@@ -30694,7 +30729,7 @@
#~ msgstr "Aktuelles Fenster nicht einstellbar."
#~ msgid "Can't clear current graphics window"
-#~ msgstr "Kann aktuelles Grafik-Fenster nicht säubern."
+#~ msgstr "Kann aktuelles Grafikfenster nicht säubern."
#~ msgid "Cannot use current window"
#~ msgstr "Kann aktuelles Fenster nicht benutzen."
@@ -30703,7 +30738,7 @@
#~ "Generates and displays simple graphics on map layers drawn in the active "
#~ "graphics monitor display frame."
#~ msgstr ""
-#~ "Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafik-Fenster "
+#~ "Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafikfenster "
#~ "dar."
#~ msgid ""
@@ -30807,7 +30842,7 @@
#~ msgstr "Fehler bei der Berechnung der Umwandlung."
#~ msgid "No current graphics window"
-#~ msgstr "Kein aktuelles Grafik-Fenster."
+#~ msgstr "Kein aktuelles Grafikfenster."
#~ msgid "Current graphics window not available"
#~ msgstr "Aktuelles Fenster ist nicht vorhanden."
@@ -30819,7 +30854,7 @@
#~ msgid "Getting graphics window coordinates"
-#~ msgstr "Hole Koordinaten des Grafik-Fensters."
+#~ msgstr "Hole Koordinaten des Grafikfensters."
#~ msgid "value [%.0f,%.0f] out of range [0-100]"
#~ msgstr "Wert [%.0f,%.0f] außerhalb der Spanne [0-100]"
@@ -30877,7 +30912,7 @@
#~ "if the monitor is refreshed)"
#~ msgstr ""
#~ "Nicht zu der Liste der Vektorkarten und Kommandos im Monitor hinzufügen "
-#~ "(Die Vektorkarte wird nicht gezeichnet, wenn das Grafik-Fenster "
+#~ "(Die Vektorkarte wird nicht gezeichnet, wenn das Grafikfenster "
#~ "aktualisiert wird)."
#~ msgid "No raster map exists in the current window"
@@ -30887,7 +30922,7 @@
#~ "Creates and displays a menu within the active frame on the graphics "
#~ "monitor."
#~ msgstr ""
-#~ "Erzeugt und stellt ein Menü im aktiven Frame des Grafik-Fensters dar."
+#~ "Erzeugt und stellt ein Menü im aktiven Frame des Grafikfensters dar."
#~ msgid "Sets the color of the menu background"
@@ -30989,7 +31024,7 @@
#~ msgstr "Benutzung des Schalters -j erzwungen."
#~ msgid "No map is displayed in GRASS monitor"
-#~ msgstr "Im Grafik-Fenster ist keine Karte dargestellt."
+#~ msgstr "Im Grafikfenster ist keine Karte dargestellt."
#~ msgid "Interactively select route"
#~ msgstr "Selectiere interaktiv eine Route."
@@ -31004,31 +31039,31 @@
#~ msgstr "Es wird keine Raster- oder Vektorkarte angezeigt."
#~ msgid "To establish and control use of a graphics display monitor."
-#~ msgstr "Erzeugt und kontrolliert ein Grafik-Fenster."
+#~ msgstr "Erzeugt und kontrolliert ein Grafikfenster."
#~ msgid "Name of graphics monitor to start"
-#~ msgstr "Name des Grafik-Fensters, das gestartet werden soll."
+#~ msgstr "Name des Grafikfensters, das gestartet werden soll."
#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "Name des Grafik-Fensters, das gestoppt werden soll."
+#~ msgstr "Name des Grafikfensters, das gestoppt werden soll."
#~ msgid "Name of graphics monitor to select"
-#~ msgstr "Name des Grafik-Fensters, das ausgewählt werden soll."
+#~ msgstr "Name des Grafikfensters, das selektiert werden soll."
#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "Name des Grafik-Fensters, das entriegelt werden soll."
+#~ msgstr "Name des Grafikfensters, das entriegelt werden soll."
#~ msgid "List all monitors"
-#~ msgstr "Liste aller Grafik-Fenster."
+#~ msgstr "Liste aller Grafikfenster."
#~ msgid "List all monitors (with current status)"
-#~ msgstr "Liste alle Grafik-Fenster (mit aktuellem Status)."
+#~ msgstr "Liste alle Grafikfenster (mit aktuellem Status)."
#~ msgid "Print name of currently selected monitor"
-#~ msgstr "Gib den Namen des aktuell selektierten Grafik-Fensters aus."
+#~ msgstr "Gib den Namen des momentan selektierten Grafikfensters aus."
#~ msgid "Release currently selected monitor"
-#~ msgstr "Gebe das aktuell ausgewählte Grafik-Fenster frei."
+#~ msgstr "Gebe das aktuell ausgewählte Grafikfenster frei."
#~ msgid "Do not automatically select when starting"
#~ msgstr "Nicht automatisch beim Starten selektieren."
@@ -31037,10 +31072,10 @@
#~ msgstr "Probleme beim Auswählen von %s. Einmal versuche ich es noch..."
#~ msgid "No such monitor as <%s>"
-#~ msgstr "Es gibt das Grafik-Fenster <%s> nicht."
+#~ msgstr "Es gibt das Grafikfenster <%s> nicht."
#~ msgid "Monitor <%s> released"
-#~ msgstr "Grafik-Fenster <%s> freigegeben."
+#~ msgstr "Grafikfenster <%s> freigegeben."
#~ msgid "Error - Locking mechanism failed"
#~ msgstr "Fehler - Sperrvorrichtung ist fehlgeschlagen."
@@ -31063,7 +31098,7 @@
#~ msgstr "Rechts: Akzeptiere Fenster\n"
#~ msgid "Manages display frames on the user's graphics monitor."
+#~ msgstr "Verwaltet Fenster im Grafikfenster des Benutzers."
#~ msgid "Create a new frame"
#~ msgstr "Erzeuge ein neues Fenster."
@@ -31107,7 +31142,7 @@
#~ "\n"
#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "Grafik-Fenster: Interaktives Kommando zum erneuten Zeichnen."
+#~ msgstr "Grafikfenster: Interaktives Kommando zum erneuten Zeichnen."
#~ msgid "found %d visuals of type TrueColor"
#~ msgstr "Habe %d Ansichten vom Typ TrueColor gefunden."
@@ -31122,13 +31157,13 @@
#~ msgstr "Verwende Standard-Ansicht %s"
#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "Grafik-Fenster: waitpid: erwartete %d, habe aber %d bekommen."
+#~ msgstr "Grafikfenster: waitpid: erwartete %d, habe aber %d bekommen."
#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "Grafik-Fenster: XGetWMName fehlgeschlagen."
+#~ msgstr "Grafikfenster: XGetWMName fehlgeschlagen."
#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "Grafik-Fenster: XGetWMName: Schlechtes Ergebnis."
+#~ msgstr "Grafikfenster: XGetWMName: Schlechtes Ergebnis."
#~ msgid ""
#~ "\n"
@@ -31151,19 +31186,18 @@
#~ msgid "<%s> is an illegal region name"
#~ msgstr "<%s> ist ein ungültiger Regions-Name."
+#, fuzzy
#~ msgid "No LatLong information for XY-Projection"
-#~ msgstr "Keine LatLong-Information für XY-Projektionen."
+#~ msgstr "Geo-Gitter Option ist für XY-Projektionen nicht verfügbar."
#~ msgid "Erasing monitors..."
-#, fuzzy
#~ msgid "Display manager for GRASS"
-#~ msgstr "Stelle die Anzahl der Farben dar."
+#~ msgstr "Manager der Grafikausgabe für GRASS."
-#, fuzzy
#~ msgid "Name of .dmrc settings file"
-#~ msgstr "Name der Workspace-Datei."
+#~ msgstr "Name der .dmrc Datei."
#, fuzzy
#~ msgid "Name of the vector points map with x,y locations"
@@ -31225,11 +31259,11 @@
#, fuzzy
#~ msgid "No such monitor as '%s'"
#, fuzzy
#~ msgid "Error - No such monitor as '%s'"
#, fuzzy
#~ msgid ""
@@ -31256,7 +31290,7 @@
#, fuzzy
#~ msgid "Skipping [%s]..."
+#~ msgstr "Lese %s..."
#, fuzzy
#~ msgid "Writing group REF"
@@ -31264,7 +31298,7 @@
#, fuzzy
#~ msgid "Writing subgroup REF"
#, fuzzy
#~ msgid "Unable to open file: <%s>"
@@ -31304,7 +31338,7 @@
#, fuzzy
#~ msgid "%s: can't read range for [%s]"
+#~ msgstr "Fehler beim Lesen der Datenspanne für [%s]."
#, fuzzy
#~ msgid "Raster file [%s] not found"
@@ -31332,11 +31366,11 @@
#, fuzzy
#~ msgid "Unable to write line %d"
-#~ msgstr "Kann kein Face erzeugen."
+#~ msgstr "Kann die Zeile %d nicht zurückschreiben."
#, fuzzy
#~ msgid "Unable to delete line %d"
#, fuzzy
#~ msgid "Unknown query tool '%s'"
@@ -31429,7 +31463,7 @@
#, fuzzy
#~ msgid "Raster map name for storing results"
+#~ msgstr "Name der Ausgabe-Rasterkarte."
#, fuzzy
#~ msgid "Height of the viewing location"
@@ -31437,7 +31471,7 @@
#, fuzzy
#~ msgid "%s: <%s> cellfile not found"
-#~ msgstr "%s: <%s> nicht gefunden."
+#~ msgstr "%s <%s> nicht gefunden."
#, fuzzy
#~ msgid "Cell file [%s] not found\n"
@@ -31489,7 +31523,7 @@
#, fuzzy
#~ msgid "%s file [%s] not found!"
+#~ msgstr "%s: [%s] nicht gefunden."
#, fuzzy
#~ msgid "%s: %s - map not found"
@@ -31517,7 +31551,7 @@
#, fuzzy
#~ msgid "elevation file [%s] not found"
+#~ msgstr "Label-Datei <%s> nicht gefunden."
#, fuzzy
#~ msgid "min computed aspect %.4f max computed aspect %.4f"
@@ -31535,7 +31569,7 @@
#, fuzzy
#~ msgid "Cannot insert values: %s"
+#~ msgstr "Kann Daten nicht einfügen: <%s>."
#, fuzzy
#~ msgid "%s given an illegal number of points [%d]"
@@ -31607,7 +31641,7 @@
#, fuzzy
#~ msgid "input raster map"
#, fuzzy
#~ msgid "Illegal file name: %s"
@@ -31631,7 +31665,7 @@
#, fuzzy
#~ msgid "%s: %s - illegal name"
+#~ msgstr "<%s> ist ein ungültiger Name."
#, fuzzy
#~ msgid "%s: ERROR reading category file for %s"
@@ -31643,7 +31677,7 @@
#, fuzzy
#~ msgid "%s: %s - illegal units"
+#~ msgstr "%s - ungültiger Longitude."
#, fuzzy
#~ msgid "%s: %s - can't open"
@@ -31651,7 +31685,7 @@
#, fuzzy
#~ msgid "Reading input map (%s) ... "
#, fuzzy
#~ msgid "%s - ERROR reading %s"
@@ -31683,7 +31717,7 @@
#, fuzzy
#~ msgid "Output separator character (default: tab)"
#, fuzzy
#~ msgid "Cannot read category file of raster map <%s> in <%s>"
@@ -31691,7 +31725,7 @@
#, fuzzy
#~ msgid "Cannot find file %s"
+#~ msgstr "Kann die Datei %s nicht finden."
#, fuzzy
#~ msgid "Cannot get header for %s"
@@ -31767,7 +31801,7 @@
#, fuzzy
#~ msgid "Cannot open TIFF file <%s>"
#, fuzzy
#~ msgid "Reading raster map"
@@ -31778,10 +31812,6 @@
#, fuzzy
-#~ msgid "Illegal file name. Please try another."
-#, fuzzy
#~ msgid "%s: can't open %s"
#~ msgstr "Kann %s nicht öffnen."
@@ -31791,7 +31821,7 @@
#, fuzzy
#~ msgid "memory allocation failure"
#, fuzzy
#~ msgid "Can't find data map."
@@ -31879,7 +31909,7 @@
#, fuzzy
#~ msgid "Cannot rewrite line %d"
#, fuzzy
#~ msgid "Editing tool"
@@ -31932,7 +31962,7 @@
#, fuzzy
#~ msgid "Cannot select attribute."
#, fuzzy
#~ msgid "Creating vector grid..."
@@ -31940,7 +31970,7 @@
#, fuzzy
#~ msgid "Could not find vector map <%s> in current mapset"
-#~ msgstr "Nicht in der Lage Vektorkarte in anderem Mapset zu ändern."
+#~ msgstr "Baut die Topologie aller Vektorkarten im aktuellen Mapset neu auf."
#, fuzzy
#~ msgid "Could not find input map <%s>."
@@ -31996,7 +32026,7 @@
#, fuzzy
#~ msgid "Cannot list databases."
+#~ msgstr "Kann Datenbanken nicht auflisten."
#, fuzzy
#~ msgid "database location"
@@ -32052,11 +32082,11 @@
#, fuzzy
#~ msgid "unable to open [%s] in [%s]"
+#~ msgstr "Kann die Karte <%s> nicht öffnen."
#, fuzzy
#~ msgid "warning: unable to open [%s] in [%s]"
+#~ msgstr "Kann die Datei mit Gewichten <%s> nicht öffnen."
#, fuzzy
#~ msgid "Unable to open raster map [%s] in [%s]"
@@ -32076,7 +32106,7 @@
#, fuzzy
#~ msgid "Input file [%s] not found."
+#~ msgstr "3dview-Datei <%s> nicht gefunden."
#, fuzzy
#~ msgid "Unable to open output file <%s>."
@@ -32167,7 +32197,7 @@
#, fuzzy
#~ msgid "Copying %s input lines ... "
+#~ msgstr "Kopiere Vektorlinien ..."
#, fuzzy
#~ msgid "Cannot create table <%s>"
@@ -32183,7 +32213,7 @@
#, fuzzy
#~ msgid "Cannot find line of cat %d"
-#~ msgstr "Kann die Vektorkarte [%s] nicht finden."
+#~ msgstr "Kann die Linie mit cat '%d' nicht finden."
#, fuzzy
#~ msgid "Unalbe to open vector map <%s>"
@@ -32239,7 +32269,7 @@
#, fuzzy
#~ msgid "[%s] is an illegal name"
-#~ msgstr "<%s> ist ein ungültiger Dateiname."
#, fuzzy
#~ msgid "Cannot write to <%s>"
@@ -32283,7 +32313,7 @@
#, fuzzy
#~ msgid "<%s> illegal name"
#, fuzzy
#~ msgid "Out of Memory!\n"
@@ -32291,21 +32321,13 @@
#, fuzzy
#~ msgid "%s: %s - Unable to open the input raster map\n"
#, fuzzy
-#~ msgid "Insufficent memory for allocation of data sturcture"
-#, fuzzy
#~ msgid "%s: %s - illegal name for output raster map."
#, fuzzy
-#~ msgid "Insufficent memory for allocation of data structure."
-#, fuzzy
#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
#~ msgstr "Exportiert Attributtabellen in verschiedene Formate."
@@ -32313,12 +32335,13 @@
#~ msgid "Couldn't find raster map %s"
+#, fuzzy
#~ msgid "%s: <%s> not found"
#, fuzzy
#~ msgid "%s: <%s> illegal name"
#, fuzzy
#~ msgid "%s: Cannot open <%s>"
@@ -32326,7 +32349,7 @@
#, fuzzy
#~ msgid "<%s> is not a valid GRASS map name"
-#~ msgstr "%s ist keine gültige Regel."
+#~ msgstr "'%s' ist keine gültige Regel."
#, fuzzy
#~ msgid "Cannot find %s"
@@ -32398,10 +32421,6 @@
#~ "Rasterkarte <%s> in der Location <%s> im Mapset <%s> nicht gefunden."
#, fuzzy
-#~ msgid "Can't work with xy data"
-#, fuzzy
#~ msgid "ns-res:\t%f"
#~ msgstr "nsres=%f"
@@ -32455,7 +32474,7 @@
#, fuzzy
#~ msgid "%s=%s - illegal name"
#, fuzzy
#~ msgid "%s: can't create %s"
@@ -32521,7 +32540,7 @@
#, fuzzy
#~ msgid "Could not find input map <%s> in current mapset."
#, fuzzy
#~ msgid "Vector file [%s] not available in search list"
@@ -32529,15 +32548,15 @@
#, fuzzy
#~ msgid "Cannot open database <%s>"
+#~ msgstr "Kann die Datenbank <%s> nicht öffnen."
#, fuzzy
#~ msgid "Cannot open table <%s>"
+#~ msgstr "Kann %s nicht öffnen."
#, fuzzy
#~ msgid "Cannot open driver <%s>"
#, fuzzy
#~ msgid "Could not find input vector map %s"
@@ -32628,7 +32647,7 @@
#, fuzzy
#~ msgid "Unable to open cellfile [%s]."
#, fuzzy
#~ msgid "Error reading wildcard."
@@ -32673,7 +32692,8 @@
#, fuzzy
#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr "Name der Vektorausgabekarte mit den angepassten Punkten im Fluss."
+#~ msgstr ""
+#~ "Name der Ausgabe-Vektorausgabekarte (auslassen für Ausgabe auf stdout)."
#, fuzzy
#~ msgid "Input vector map"
@@ -32721,7 +32741,7 @@
#, fuzzy
#~ msgid "File name of classification result"
#, fuzzy
#~ msgid "File name of reference classes"
@@ -32757,7 +32777,7 @@
#, fuzzy
#~ msgid "Problem opening output file [%s]"
+#~ msgstr "Kann Ausgabedatei <%s> nicht öffnen."
#, fuzzy
#~ msgid "can't write category file for <%s>"
@@ -32769,7 +32789,7 @@
#, fuzzy
#~ msgid "Unable to read row %d in raster map [%s]"
-#~ msgstr "Kann den fp Bereich der Rasterkarte <%s> nicht lesen."
+#~ msgstr "Kann den Wertebereich der Rasterkarte <%s> nicht lesen."
#, fuzzy
#~ msgid "Elevation map"
@@ -32810,7 +32830,7 @@
#, fuzzy
#~ msgid "Input vector map <%s> not found."
#, fuzzy
#~ msgid "Writing attributes ...\n"
@@ -32826,7 +32846,7 @@
#, fuzzy
#~ msgid "List available formats and exit"
-#~ msgstr "Zeigt die vorhandenen Layer und beendet sich."
+#~ msgstr "Listet verfügbare Layer und beendet sich."
#, fuzzy
#~ msgid "Vector map <%s> not fould"
@@ -32926,8 +32946,7 @@
#, fuzzy
#~ msgid "Vector map with points for which to modify the attribute table"
-#~ msgstr ""
-#~ "Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
+#~ msgstr "Vektorkarte deren Attributtabelle editiert werden soll."
#, fuzzy
#~ msgid "Layer of the vector for which to modify the attribute table"
@@ -32972,7 +32991,7 @@
#, fuzzy
#~ msgid "cannot open database %s by driver %s"
#, fuzzy
#~ msgid "column type not supported"
@@ -33015,8 +33034,8 @@
#~ "Number of column used as z coordinate (first column is 1) for points "
#~ "mode. If 0, z coordinate is not used."
#~ msgstr ""
-#~ "Nummer der Spalte im Punkt-Modus, die als X-Koordinate genutzt werden "
-#~ "soll (erste Spalte is 1)."
+#~ "Nummer der Spalte, die im Punkt-Modus als Z-Koordinate genutzt werden "
+#~ "soll (erste Spalte ist 1)."
#, fuzzy
#~ msgid "Can't open temp file %s"
@@ -33068,11 +33087,11 @@
#, fuzzy
#~ msgid "Unable to write color table to raster [%s]"
-#~ msgstr "Kann die Farbtabelle der Rasterkarte <%s> nicht lesen."
+#~ msgstr "Kann die Farbtabelle der Rasterkarte <%s> nicht schreiben."
#, fuzzy
#~ msgid "Cannot find map %s"
#, fuzzy
#~ msgid "Cannot open map %s"
@@ -33144,8 +33163,7 @@
#, fuzzy
#~ msgid "Screen coordinates to place the legend (as percentage)"
-#~ msgstr ""
-#~ "Gibt Rahmenkoordinaten des aktuellen Grafik-Fensters in Prozent aus."
+#~ msgstr "Gibt Rahmenkoordinaten des aktuellen Grafikfensters in Prozent aus."
#, fuzzy
#~ msgid "%s: o_open_file: raster map %s not found"
@@ -33177,7 +33195,7 @@
#, fuzzy
#~ msgid "Assign cats to boundaries too"
+#~ msgstr "Fügt fehlende Zentroide zu geschlossenen Grenzen hinzu."
#, fuzzy
#~ msgid "Lines could not be merged"
@@ -33292,13 +33310,9 @@
#, fuzzy
#~ msgid "CrossCorrelation: %d points read in region. "
#, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
-#, fuzzy
#~ msgid "No line found."
#~ msgstr "Nichts gefunden.\n"
@@ -33326,6 +33340,7 @@
#~ msgid "Option <%s>: <%s> exists."
#~ msgstr "Option <%s>: <%s> existiert."
+#, fuzzy
#~ msgid "Unable to create table: <%s>"
#~ msgstr "Kann die Tabelle <%s> nicht erzeugen."
@@ -33333,8 +33348,9 @@
#~ msgid "Cannot insert new record: <%s>"
#~ msgstr "Kann neuen Eintrag nicht einfügen: %s"
+#, fuzzy
#~ msgid "Unable to insert new record: <%s>"
-#~ msgstr "Kann neuen Datensatz <%s> nicht einfügen."
+#~ msgstr "Kann den neuen Datensatz '%s' nicht einfügen."
#, fuzzy
#~ msgid "No attribute table found"
@@ -33352,7 +33368,7 @@
#~ msgstr "Ungültiger Untergruppenname <%s>."
#~ msgid "No monitor selected"
-#~ msgstr "Kein Grafik-Fenster ausgewählt."
+#~ msgstr "Kein Grafikfenster ausgewählt."
#~ msgid "Invalid rendering method <%s>"
#~ msgstr "Ungültige Render-Methode <%s>."
@@ -33360,11 +33376,12 @@
#~ msgid "Unable to set size"
#~ msgstr "Kann die Größe nicht setzen."
-#, fuzzy
#~ msgid ""
#~ "Displays the rhumbline joining two user-specified points, in the active "
#~ "frame on the user's graphics monitor."
-#~ msgstr "Stellt GRASS Vektorkarten im aktiven Grafik-Fenster dar."
+#~ msgstr ""
+#~ "Stellt im aktiven Grafikfenster eine Linie dar, die zwei vom Benutzer "
+#~ "angegebene Punkte verbindet."
#~ msgid "Please choose a unit by entering one of the following letter codes:"
#~ msgstr ""
@@ -33378,18 +33395,21 @@
#~ "Rechts: Beende Profil und stop\n"
#~ "\n"
+#, fuzzy
#~ msgid "Cannot open raster map <%s>!"
+#, fuzzy
#~ msgid "Group <%s> not found."
+#, fuzzy
#~ msgid "Subgroup <%s> not found."
#, fuzzy
#~ msgid "Monitor <%s> terminated"
-#~ msgstr "Grafik-Fenster <%s> beendet."
+#~ msgstr "Grafikfenster <%s> beendet."
#~ msgid "format"
#~ msgstr "Format"
@@ -33412,12 +33432,12 @@
#, fuzzy
#~ msgid "Error - Monitor <%s> was not running"
-#~ msgstr "Fehler - Grafik-Fenster <%s> wurde nicht ausgeführt."
+#~ msgstr "Fehler - Grafikfenster '%s' ist nicht aktiv."
#, fuzzy
#~ msgid "Error - Monitor <%s> in use by another user"
#~ msgstr ""
-#~ "Fehler - Grafik-Fenster <%s> wird von einem anderen Benutzer verwendet."
+#~ "Fehler - Grafikfenster '%s' wird von einem anderen Benutzer verwendet."
#~ msgid "Middle: Keep original frame\n"
#~ msgstr "Middle: Behalte original Fenster\n"
@@ -33503,74 +33523,61 @@
#~ msgid "Unused"
#~ msgstr "nicht genutzt"
-#, fuzzy
#~ msgid "stay with source monitor"
+#~ msgstr "Bleib im Quell -Grafikfenster."
-#, fuzzy
#~ msgid "Name for output file (do NOT add extension)"
-#~ msgstr "Name der Ausgabedatei (Fügen Sie keine Dateiendung an)."
+#~ msgstr "Name für die Ausgabedatei (Fügen Sie keine Dateiendung an)."
-#, fuzzy
#~ msgid "Images"
-#~ msgstr "Bild"
+#~ msgstr "Bilder"
-#, fuzzy
#~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr "von"
+#~ msgstr ""
+#~ "Breite und Höhe des auszugebenden Bildes (übersteuert die Einstellung der "
+#~ "Auflösung)."
-#, fuzzy
#~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr "Papiergröße für die PostScript-Ausgabe"
+#~ msgstr ""
+#~ "Stelle die Orientierung der Seite auf Querformat (für die PostScript-"
+#~ "Ausgabe)."
-#, fuzzy
#~ msgid "Split the display into subframes."
+#~ msgstr "Teile das Fenster in Unterfenster."
-#, fuzzy
#~ msgid "Number of subframes"
-#~ msgstr "Anzahl der Frames."
+#~ msgstr "Anzahl der Unterfenster."
-#, fuzzy
#~ msgid "Displays thematic vector map"
-#~ msgstr "Name der Vektorkarte"
+#~ msgstr "Zeigt thematische Vektorkarten an."
-#, fuzzy
#~ msgid "display, vector, thematic, legend"
-#~ msgstr "Darstellung, Vektor"
+#~ msgstr "Darstellung, Vektor, thematisch, Legende"
-#, fuzzy
#~ msgid "Icon size for point data"
+#~ msgstr "Symbolgröße für Punktdaten."
-#, fuzzy
#~ msgid "Color for graduated points map"
-#~ msgstr "Farbe für die Y-Daten."
+#~ msgstr "Farbe für Karte mit gestaffelten Punkten (graduated points)."
-#, fuzzy
#~ msgid "Ending color for custom color gradient"
-#~ msgstr "für z"
+#~ msgstr "Schlußfarbe für benutzerdefinierten Farbgradienten."
-#, fuzzy
#~ msgid "Calculate new raster map from a r.mapcalc expression."
-#~ msgstr "Expertenmodus (Geben Sie ein Satz von r3.mapcalc Befehlen an)."
+#~ msgstr "Berechne eine neue Rasterkarte mit einem r.mapcalc-Ausdruck. "
-#, fuzzy
#~ msgid "Expert mode (enter a set of r.mapcalc expressions)"
+#~ msgstr "Expertenmodus (Geben Sie ein Satz von r.mapcalc Ausdrücken an)."
#~ msgid "Enter rules interactively"
-#, fuzzy
#~ msgid "Data range of raster map <%s> is empty"
+#~ msgstr "Wertebereich der Rasterkarte <%s> ist leer."
-#, fuzzy
#~ msgid "raster, recode category"
-#~ msgstr "Raster, Projektion"
+#~ msgstr "Raster, Rekodieren der Kategorien"
-#, fuzzy
#~ msgid "Unable to open rules file <%s>"
@@ -33590,6 +33597,230 @@
#~ msgid "Short user prompt message"
#~ msgstr "Gebe die Copyright-Informationen aus."
-#, fuzzy
#~ msgid "Name of raster map to print in legend"
+#~ msgstr "Name der Rasterkarte, wie er in der Legende erscheinen soll."
+#~ msgid "GIS manager for GRASS"
+#~ msgstr "GIS-Manager für GRASS."
+#~ msgid "Selects/starts specified monitor at specified size"
+#~ msgstr ""
+#~ "Selektiert/Startet das angegebene Grafikfenster in der angegebenen Größe."
+#~ msgid "clear target monitor before moving"
+#~ msgstr "Lösche das Ziel-Fenster vor dem Verschieben."
+#~ msgid "kill source monitor after moving"
+#~ msgstr "Beende das Quell-Fenster nach dem Verschieben."
+#~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
+#~ msgstr ""
+#~ "Exportiert das Grafikfenster in ein GpsDrive-kompatibles Hintergrundbild."
+#~ msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
+#~ msgstr "Name des neuen Kartenbildes (in ~/.gpsdrive/maps/)."
+#~ msgid "Saves active display monitor to PNG file in home directory"
+#~ msgstr ""
+#~ "Speichert den Inhalt des aktiven Grafikfensters in einer PNG-Datei im "
+#~ "Heimat-Verzeichnis."
+#~ msgid "Resolution of output file (single=1, double=2, quad=4)"
+#~ msgstr "Auflösung der Ausgabe-Datei (einfach=1, doppelt=2, vierfach=4)."
+#~ msgid "Dimensions of output file versus current window size"
+#~ msgstr "Größe der Ausgabe-Datei im Vergleich zum aktuellen Grafikfenster."
+#~ msgid "(same=1, double size=2, quadruple size=4)"
+#~ msgstr "(einfach=1, doppelte Größe=2, vierfache Größe=4)"
+#~ msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
+#~ msgstr ""
+#~ "(0=keine, 1=schnellste, 9=am meisten; verlustfrei, nur Zeit vs. "
+#~ "Dateigröße)."
+#~ msgid "File size/quality for JPEG files"
+#~ msgstr "Dateigröße/-qualität für JPEG-Dateien."
+#~ msgid "(10=smallest/worst, 100=largest/best)"
+#~ msgstr "(10=kleinste/schlechteste, 100=größste/beste)"
+#~ msgid "PostScript level (only limits functionality!)"
+#~ msgstr "PostScript Level (Limitiert nur die Funktionalität!)."
+#~ msgid "GeoTIFF"
+#~ msgstr "GeoTIFF"
+#~ msgid "GeoTIFF metadata key(s) and value(s) to add"
+#~ msgstr "GeoTIFF Metadaten Schlüsselwort(e) und Wert(e)"
+#~ msgid ""
+#~ "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
+#~ msgstr ""
+#~ "In der Form \"META-TAG=WERT\", trennen Sie mehrere Paare durch Kommas "
+#~ "voneinander."
+#~ msgid "Set background color to black (white default)"
+#~ msgstr "Setze die Hintergrundfarbe auf schwarz (Standard: weiß)."
+#~ msgid "Use the Cario driver to render images"
+#~ msgstr "Verwende der Cairo-Treiber um das Bild zu rendern."
+#~ msgid "Do not crop away margins"
+#~ msgstr "Schneide die Ränder nicht ab."
+#~ msgid "Position of vertical map-legend separator (in percent)"
+#~ msgstr "Position der vertikalen Legenden Trennelemente (in Prozent)."
+#~ msgid "Do not preserve individual regions when redrawing all frames"
+#~ msgstr ""
+#~ "Erhalte keine individuellen Regionen beim Neuzeichnen aller Fenster."
+#~ msgid "Map prefix. Specify character(s) to view selected maps only"
+#~ msgstr ""
+#~ "Karten-Präfix. Bestimmen Sie Buchstaben um nur ausgewählte Karten "
+#~ "anzusehen."
+#~ msgid "Map number show across the monitor"
+#~ msgstr "Zeige die Kartenummer waagerecht im Grafikfenster."
+#~ msgid "Map number show down the monitor"
+#~ msgstr "Zeige die Kartenummer senkrecht im Grafikfenster."
+#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
+#~ msgstr ""
+#~ "ZU verwendendes Mapset. Geben Sie mehrere Mapsets durch Kommas getrennt "
+#~ "an."
+#~ msgid ""
+#~ "Divides active display into two frames & displays maps/executes commands "
+#~ "in each frame."
+#~ msgstr ""
+#~ "Teilt das aktive Grafikfenster in zwei Fenster & zeigt Karten und führt "
+#~ "Befehle in beiden Fenstern aus."
+#~ msgid "Thematic divisions of data for display"
+#~ msgstr "Thematische Aufteilung der Daten für die Darstellung."
+#~ msgid "Break points for custom breaks option"
+#~ msgstr "Klassengrenzen für benutzerdefinierte Klassierung."
+#~ msgid "Separate values by spaces (0 10 20 30 ...)"
+#~ msgstr "Trenne Werte durch Leerzeichen (0 10 20 30 ...)."
+#~ msgid "Minimum icon size/line width for graduated points/lines)"
+#~ msgstr ""
+#~ "Kleinste Symbolgröße / Linienbreite für die gestufte Darstellung von "
+#~ "Punkten/Linien."
+#~ msgid "Maximum icon size/line width for graduated points and lines"
+#~ msgstr ""
+#~ "Größste Symbolgröße / Linienbreite für die gestufte Darstellung von "
+#~ msgid "Color scheme for graduated color mapping"
+#~ msgstr "Farbschema für farbgestufte Kartierung."
+#~ msgid "Select 'single_color' for graduated point/line display"
+#~ msgstr ""
+#~ "Wählen Sie 'single_color' für die Darstellung gestufter Punkte/Linien."
+#~ msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
+#~ msgstr ""
+#~ "GRASS Farbnamen oder R:G:B Triplets. Setze das Farbschema auf eine Farbe."
+#~ msgid "Color for graduated lines or point/area outlines"
+#~ msgstr "Farbe für den gestufte Linien oder den Rand der Punkte/Flächen."
+#~ msgid ""
+#~ "GRASS named color or R:G:B triplet. Set color scheme to single color."
+#~ msgstr ""
+#~ msgid "Beginning color for custom color gradient"
+#~ msgstr "Anfangsfarbe für benutzerdefinierten Farbgradienten."
+#~ msgid "Must be expressed as R:G:B triplet"
+#~ msgstr "Muß als R:G:B-Tripel angegeben werden."
+#~ msgid "Select x11 display monitor for legend"
+#~ msgstr "Selektiere das X11-Grafikfenster für die Legende."
+#~ msgid "Save thematic map commands to group file for GIS Manager"
+#~ msgstr ""
+#~ "Speichere die Befehle zur Erstellung der thematischen Karte in die group-"
+#~ "Datei für den GIS-Manager."
+#~ msgid ""
+#~ "Root for the name of psmap instruction files to be in current directory"
+#~ msgstr ""
+#~ "Dateiname (ohne Dateiendung) für die psmap-Datei. Die Datei wird im "
+#~ "aktuellen Verzeichnis gespeichert."
+#~ msgid "If not set, no psmap instruction files will be created)"
+#~ msgstr "Wenn nicht angegeben, wird keine psmap-Datei erzeugt."
+#~ msgid "Name of group file where thematic map commands will be saved"
+#~ msgstr ""
+#~ "Name der group-Datei, in der die Befehle zur Erstellung der thematischen "
+#~ "Karte gespeichert werden."
+#~ msgid "Create graphic legend in x11 display monitor"
+#~ msgstr "Erzeuge eine graphische Legende in X11 Grafikfenster."
+#~ msgid "Only draw fills (no outlines) for areas and points"
+#~ msgstr "Zeichne nur die Füllung der Punkte und Flächen (keine Ränder)."
+#~ msgid "Update color values to GRASSRGB column in attribute table"
+#~ msgstr "Aktualisiere Farbwerte mit der GRASSRGB Spalte der Attributtabelle."
+#~ msgid "Output legend for GIS Manager (for scripting use only)"
+#~ msgstr ""
+#~ "Gebe die Legende für den GIS-Maneger aus (nur für die Verwendung in "
+#~ "Skripten)."
+#~ msgid "Use math notation brackets in legend"
+#~ msgstr "Verwende mathematische Notation in der Legende."
+#~ msgid "1st map for mosaic (top of image stack)."
+#~ msgstr "1. Karte für das Mosaik (Spitze des Bildstapels)."
+#~ msgid "3rd map for mosaic."
+#~ msgstr "3. Bild für das Mosaik."
+#~ msgid "4th map for mosaic."
+#~ msgstr "4. Bild für das Mosaik."
+#~ msgid "Use image list and not group"
+#~ msgstr "Verwende eine Bild-Liste und keine Gruppe."
+#~ msgid "Verbose mode (print projection parameters and filenames to stderr)"
+#~ msgstr ""
+#~ "Gesprächiger Modus (Gebe Projektionsparameter und Dateinamen auf stderr "
+#~ "aus)."
+#~ msgid "Metadata key passed on the output dataset if possible"
+#~ msgstr ""
+#~ "Metadaten werden, wen möglich, an den Ausgabedatensatz weitergegeben."
+#~ msgid "Calculates new grid3D volume from r3.mapcalc expression."
+#~ msgstr "Berechnet neues grid3D Volumen mittels eines r3.mapcalc-Ausdruck."
+#~ msgid ""
+#~ "The database must be in form printed by v.db.connect -g, i.e. with "
+#~ "substituted variables"
+#~ msgstr ""
+#~ "Die Datenbank muß in der Form angegeben werden , wie sie von v.db.connect "
+#~ "-g ausgegeben wird, z.B mit ersetzten Variablen."
+#~ msgid "GIS Coincidence Tabulation Facility\n"
+#~ msgstr "GIS Koinzidenz-Tabellierungsanlage\n"
+#~ msgid ""
+#~ "This utility will allow you to compare the coincidence of two map layers\n"
+#~ msgstr ""
+#~ "Dieses Dienstprogramm ermöglicht Ihnen die Koinzidenz zweier Karten zu "
+#~ "vergleichen\n"
+#~ msgid "The report can be made in one of 8 units."
+#~ msgstr "DerBericht kann in einer von 8 Einheiten erstellt werden."
