[GRASS-SVN] r39641 - grass/branches/develbranch_6/locale/po
Wed Oct 28 19:28:37 EDT 2009
Author: neteler
Date: 2009-10-28 19:28:37 -0400 (Wed, 28 Oct 2009)
New Revision: 39641
   grass/branches/develbranch_6/locale/po/grasslibs_pl.po
   grass/branches/develbranch_6/locale/po/grassmods_pl.po
   grass/branches/develbranch_6/locale/po/grasstcl_pl.po
   grass/branches/develbranch_6/locale/po/grasswxpy_pl.po
Milena Nowotarska: cont'ed
Modified: grass/branches/develbranch_6/locale/po/grasslibs_pl.po
--- grass/branches/develbranch_6/locale/po/grasslibs_pl.po	2009-10-28 23:28:04 UTC (rev 39640)
+++ grass/branches/develbranch_6/locale/po/grasslibs_pl.po	2009-10-28 23:28:37 UTC (rev 39641)
@@ -1,17 +1,17 @@
-# translation of grasslibs_pl.po to Polska
 # translation of grasslibs_pl.po into Polski
 # This file is distributed under the same license as the GRASS package.
 # Copyright (C) 2005, 2009, GRASS Development Team
 # Artur Nieścior <nieart at interia.pl>, 2005, 2006.
-# Milena Nowotarska <do.milenki*gmail.com>, 2009.
+# Milena Nowotarska <do.milenki*gmail.com>, 2008, 2009.
 msgid ""
 msgstr ""
 "Project-Id-Version: grasslibs_pl\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2009-01-09 16:59+0100\n"
-"PO-Revision-Date: 2009-10-27 18:48+0200\n"
+"PO-Revision-Date: 2009-10-28 23:19+0100\n"
 "Last-Translator: Milena Nowotarska <do.milenki*gmail.com>\n"
-"Language-Team: Milena\n"
+"Language-Team: Polish <grass-translations at lists.osgeo.org>\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
@@ -337,7 +337,6 @@
 msgstr ""
 #: ../lib/gpde/N_parse_options.c:100
-#, fuzzy
 msgid "The calculation time in seconds"
 msgstr "Czas obliczeń w sekundach"
@@ -536,7 +535,7 @@
 msgstr ""
 #: ../lib/db/dbmi_client/copy_tab.c:231
-#, fuzzy, c-format
+#, c-format
 msgid "Column <%s> is not integer"
 msgstr "Kolumna <%s> nie jest integer"
@@ -586,9 +585,10 @@
 msgstr "Nie można otworzyć bazy danych <%s> przez sterownik <%s>"
 #: ../lib/driver/parse_ftcap.c:32
-#, fuzzy, c-format
+#, c-format
 msgid "%s: Unable to read font definition file; use the default"
-msgstr "%s: Nie można odczytać pliku FreeType; użyj ustawień domyślnych"
+msgstr ""
+"%s: Nie można odczytać pliku definicji czcionki; użyj ustawień domyślnych"
 #: ../lib/driver/parse_ftcap.c:38
 #, c-format
@@ -842,9 +842,9 @@
 msgstr "Nieznane narzędzie zapytań"
 #: ../lib/vector/vedit/cats.c:66
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to set category %d for (feature id %d)"
-msgstr "Nie można ustawić kategorii %d dla linii %d"
+msgstr "Nie można ustawić kategorii %d dla linii (id obiektu %d)"
 #: ../lib/vector/Vlib/intersect.c:127
 msgid "3D not supported by Vect_segment_intersection()"
@@ -873,44 +873,43 @@
 msgstr ""
 #: ../lib/vector/Vlib/build.c:123
-#, fuzzy, c-format
+#, c-format
 msgid "Building topology for vector map <%s>..."
-msgstr "Przebuduj topologiÄ™ dla wektora '%s@%s'"
+msgstr "BudujÄ™ topologiÄ™ dla mapy wektorowej <%s>..."
 #: ../lib/vector/Vlib/build.c:141
-#, fuzzy
 msgid "Topology was built"
-msgstr "Topologia została zbudowana\n"
+msgstr "Topologia została zbudowana"
 #: ../lib/vector/Vlib/build.c:153
-#, fuzzy, c-format
+#, c-format
 msgid "Number of nodes: %d"
-msgstr "Liczba węzłów     :    %d\n"
+msgstr "Liczba węzłów     :    %d"
 #: ../lib/vector/Vlib/build.c:154
-#, fuzzy, c-format
+#, c-format
 msgid "Number of primitives: %d"
-msgstr "Liczba prymitywów:   %d\n"
+msgstr "Liczba prymitywów:   %d"
 #: ../lib/vector/Vlib/build.c:155
-#, fuzzy, c-format
+#, c-format
 msgid "Number of points: %d"
-msgstr "Liczba punktów    :   %d\n"
+msgstr "Liczba punktów    :   %d"
 #: ../lib/vector/Vlib/build.c:156
-#, fuzzy, c-format
+#, c-format
 msgid "Number of lines: %d"
-msgstr "Liczba linii    :   %d\n"
+msgstr "Liczba linii    :   %d"
 #: ../lib/vector/Vlib/build.c:157
-#, fuzzy, c-format
+#, c-format
 msgid "Number of boundaries: %d"
-msgstr "Liczba granic:   %d\n"
+msgstr "Liczba granic    :   %d"
 #: ../lib/vector/Vlib/build.c:158
-#, fuzzy, c-format
+#, c-format
 msgid "Number of centroids: %d"
-msgstr "Liczba centroid :   %d\n"
+msgstr "Liczba centroidów   :   %d"
 #: ../lib/vector/Vlib/build.c:161
 #, fuzzy, c-format
@@ -923,44 +922,42 @@
 #: ../lib/vector/Vlib/build.c:205
-#, fuzzy, c-format
+#, c-format
 msgid "Number of areas: %d"
-msgstr "Liczba obszarów     :   %d\n"
+msgstr "Liczba obszarów     :   %d"
 #: ../lib/vector/Vlib/build.c:206
-#, fuzzy, c-format
+#, c-format
 msgid "Number of isles: %d"
-msgstr "Liczba wysp     :   %d\n"
+msgstr "Liczba wysp     :   %d"
 #: ../lib/vector/Vlib/build.c:209
-#, fuzzy, c-format
+#, c-format
 msgid "Number of incorrect boundaries: %d"
-msgstr "Liczba nieprawidłowych granic   :   %d\n"
+msgstr "Liczba nieprawidłowych granic   :   %d"
 #: ../lib/vector/Vlib/build.c:213
-#, fuzzy, c-format
+#, c-format
 msgid "Number of centroids outside area: %d"
-msgstr "Liczba centroid położonych poza obszarem :   %d\n"
+msgstr "Liczba centroidów położonych poza obszarami :   %d"
 #: ../lib/vector/Vlib/build.c:217
-#, fuzzy, c-format
+#, c-format
 msgid "Number of duplicate centroids: %d"
-msgstr "Liczba powtarzajÄ…cych siÄ™ centroid    :   %d\n"
+msgstr "Liczba powtarzających się centroidów    :   %d"
 #: ../lib/vector/Vlib/build.c:221
-#, fuzzy, c-format
+#, c-format
 msgid "Number of areas without centroid: %d"
-msgstr "Liczba obszarów bez centroid :   %d\n"
+msgstr "Liczba obszarów bez centroidów  :   %d"
 #: ../lib/vector/Vlib/build.c:226
-#, fuzzy
 msgid "Number of areas: -"
-msgstr "Liczba obszarów     :   -\n"
+msgstr "Liczba obszarów     :   -"
 #: ../lib/vector/Vlib/build.c:227
-#, fuzzy
 msgid "Number of isles: -"
-msgstr "Liczba wysp     :   -\n"
+msgstr "Liczba wysp     :   -"
 #: ../lib/vector/Vlib/build.c:256
 #, c-format
@@ -968,7 +965,6 @@
 msgstr ""
 #: ../lib/vector/Vlib/build.c:264
-#, fuzzy
 msgid "Error writing out topo file"
 msgstr "Błąd podczas zapisu pliku topo"
@@ -1028,7 +1024,7 @@
 #: ../lib/vector/Vlib/open.c:262
 #, c-format
 msgid "Unable to open category index file for vector map <%s>"
-msgstr ""
+msgstr "Nie można otworzyć pliku indeksu kategorii dla mapy wektorowej <%s>"
 #: ../lib/vector/Vlib/open.c:353 ../lib/vector/Vlib/open.c:576
 #, c-format
@@ -1065,7 +1061,7 @@
 #: ../lib/vector/Vlib/open.c:622
 #, fuzzy, c-format
 msgid "Unable to stat file <%s>"
-msgstr "Nie można otworzyć pliku %s"
+msgstr "Nie można otworzyć pliku <%s>"
 #: ../lib/vector/Vlib/open.c:731
 msgid "Size of 'coor' file differs from value saved in topology file"
@@ -1136,12 +1132,12 @@
 msgstr "Nazwa mapy wektorowej <%s> jest niedozwolona. Znak '%c'"
 #: ../lib/vector/Vlib/legal_vname.c:70
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
 msgstr ""
-"Nazwa mapy wektorowej <%s> jest niedozwolona. SQL keyword cannot be used as "
-"vector map name."
+"Nazwa mapy wektorowej <%s> jest niedozwolona. SQL keyword nie może być użyty "
+"jaki nazwa mapy wektorowej."
 #: ../lib/vector/Vlib/legal_vname.c:101 ../lib/vector/Vlib/legal_vname.c:105
 #, c-format
@@ -1149,9 +1145,9 @@
 msgstr "Nazwa pliku wyjściowego <%s> nie jest poprawną nazwą mapy wektorowej."
 #: ../lib/vector/Vlib/legal_vname.c:142 ../lib/vector/Vlib/legal_vname.c:146
-#, fuzzy, c-format
+#, c-format
 msgid "Output vector map <%s> is used as input"
-msgstr "Mapa wyjściowa '%s' jest używana jako plik wejścowy"
+msgstr "Mapa wyjściowa <%s> jest używana jako plik wejścowy"
 #: ../lib/vector/Vlib/read.c:99
 msgid "vector map is not opened"
@@ -1193,9 +1189,9 @@
 msgstr "Nie można wybrać rekordu z tabeli <%s> (klucz %s, gdzie %s)"
 #: ../lib/vector/Vlib/break_lines.c:115 ../lib/vector/Vlib/break_lines.c:370
-#, fuzzy, c-format
+#, c-format
 msgid "Intersections: %5d"
-msgstr "Inne rzutowanie"
+msgstr "Przecięcia: %5d"
 #: ../lib/vector/Vlib/poly.c:235
 msgid "Unable to find point in polygon"
@@ -1304,7 +1300,7 @@
 #: ../lib/vector/Vlib/build_nat.c:507
 #, fuzzy
 msgid "Registering primitives..."
+msgstr "Rejestrowanie prymitywów..."
 #: ../lib/vector/Vlib/build_nat.c:516
 msgid "Unable to read vector map"
@@ -1321,9 +1317,8 @@
 msgstr ""
 #: ../lib/vector/Vlib/build_nat.c:572
-#, fuzzy
 msgid "Building areas..."
-msgstr "Tworzenie obszarów:"
+msgstr "Tworzenie obszarów..."
 #: ../lib/vector/Vlib/build_nat.c:595
 #, c-format
@@ -1337,7 +1332,7 @@
 #: ../lib/vector/Vlib/build_nat.c:605
 msgid "Attaching islands..."
-msgstr ""
+msgstr "Dołączanie wysp ..."
 #: ../lib/vector/Vlib/build_nat.c:620
 msgid "Attaching centroids..."
@@ -1379,7 +1374,7 @@
 #: ../lib/vector/Vlib/build_ogr.c:349
 msgid "Feature: "
-msgstr ""
+msgstr "Obiekt:"
 #: ../lib/vector/Vlib/build_ogr.c:361
 #, c-format
@@ -1391,9 +1386,8 @@
 msgstr "Obiekt OGR bez ID został zignorowany."
 #: ../lib/vector/Vlib/level.c:38
-#, fuzzy
 msgid "Map structure was never initialized"
-msgstr "Niezainicjowana struktura wektora"
+msgstr "Struktura mapy nie została zainicjowana"
 #: ../lib/vector/Vlib/level.c:40
 msgid "Map structure has been closed"
@@ -1628,9 +1622,9 @@
 msgstr "Błąd w regule w wierszu %d w %s"
 #: ../lib/vector/Vlib/field.c:686
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open vector database definition file '%s'"
-msgstr "nie można otworzyć pliku tabeli danych: %s"
+msgstr "Nie można otworzyć pliku definicji bazy danych wektora '%s'"
 #: ../lib/vector/Vlib/field.c:774
 msgid "Bug: attempt to update map which is not in current mapset"
@@ -1804,9 +1798,8 @@
 msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:375
-#, fuzzy
 msgid "Line is not looped"
-msgstr "Niepoprawna macierz"
+msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:610 ../lib/vector/Vlib/buffer2.c:621
 msgid "Next edge was visited but it is not the first one !!! breaking loop"
@@ -1877,14 +1870,14 @@
 msgstr "Wciśnij ENTER aby anulować\n"
 #: ../lib/proj/datum.c:419 ../lib/proj/datum.c:484
-#, c-format
+#, fuzzy, c-format
 msgid "Unable to open datum table file <%s>"
-msgstr ""
+msgstr "nie można otworzyć pliku tabeli danych: %s"
 #: ../lib/proj/datum.c:432 ../lib/proj/datum.c:498
-#, c-format
+#, fuzzy, c-format
 msgid "Error in datum table file <%s>, line %d"
-msgstr ""
+msgstr "błąd w pliku tabeli danych, linia %d"
 #: ../lib/proj/convert.c:108
 msgid "Unable parse GRASS PROJ_INFO file"
@@ -2317,7 +2310,7 @@
 msgstr "nieprawidłowy typ: pole '%s' w pliku '%s'"
 #: ../lib/gis/opencell.c:1099
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s> is not xdr: byte_order: %s"
 msgstr "Mapa rastrowa <%s> nie jest xdr: byte_order: %s"
@@ -2357,7 +2350,7 @@
 msgstr ""
 #: ../lib/gis/find_file.c:82
-#, fuzzy, c-format
+#, c-format
 msgid "Using <%s@%s>"
 msgstr "Używa <%s@%s>"
@@ -2588,9 +2581,8 @@
 msgstr "MAPSET %s - brak dostępu"
 #: ../lib/gis/gisinit.c:108
-#, fuzzy
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr "\aBŁĄD: System nie został zainicjalizowany. Nie wywołano G_gisinit()\n"
+msgstr "System nie został zainicjalizowany. Nie wywołano G_gisinit()"
 #: ../lib/gis/get_row.c:46 ../lib/gis/get_row.c:1049
 #, c-format
@@ -2623,9 +2615,8 @@
 msgstr "Błąd podczas wczytywania wiersza NULL %d"
 #: ../lib/gis/get_row.c:1115
-#, fuzzy
 msgid "Unable to realloc buffer"
-msgstr "Nie można odczytać nagłówka pliku"
+msgstr "Nie można realokować bufora"
 #: ../lib/gis/get_projname.c:31
 #, fuzzy, c-format
@@ -2772,18 +2763,17 @@
 msgstr ""
 #: ../lib/gis/closecell.c:355
-#, fuzzy
 msgid "unable to write quant file!"
-msgstr "Nie można otworzyć automatycznego pliku maski"
+msgstr "nie można zapisać pliku 'quant'!"
 #: ../lib/gis/closecell.c:406
 msgid "unable to write f_format file for CELL maps"
 msgstr ""
 #: ../lib/gis/get_cellhd.c:71 ../lib/gis/get_cellhd.c:100
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read header file for raster map <%s@%s>."
-msgstr "Nie można utworzyć nagłówka pliku dla [%s w %s]"
+msgstr "Nie można odczytać nagłówka pliku dla mapy rastrowej <%s@%s>."
 #: ../lib/gis/get_cellhd.c:74
 #, c-format
@@ -2791,7 +2781,7 @@
 msgstr "To jest reklasyfikacja mapy rastrowej <%s@%s> "
 #: ../lib/gis/get_cellhd.c:78
-#, fuzzy, c-format
+#, c-format
 msgid "which is missing."
 msgstr "brakujÄ…cy."
@@ -2839,7 +2829,7 @@
 msgstr "wsparcie kategorii dla pliku wektorowego [%s] w mapsecie [%s] %s"
 #: ../lib/gis/get_ellipse.c:85
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file %s in <%s>"
 msgstr "W %s nie można otworzyć pliku %s"
@@ -2849,9 +2839,9 @@
 msgstr "niepoprawne a: pole %s w pliku %s w %s"
 #: ../lib/gis/get_ellipse.c:371
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr "niepoprawna elipsoida %s w pliku %s w %s"
+msgstr "Niewłaściwa elipsoida '%s' w pliku %s w <%s>"
 #: ../lib/gis/get_ellipse.c:388
 #, fuzzy, c-format
@@ -2859,7 +2849,7 @@
 #: ../lib/gis/get_ellipse.c:402
-#, fuzzy, c-format
+#, c-format
 msgid "No ellipsoid info given in file %s in <%s>"
 msgstr "Brak informacji o elipsoidzie w pliku %s w %s"
@@ -2899,14 +2889,14 @@
 msgstr "G_set_null_value: błędny typ danych!"
 #: ../lib/gis/get_projinfo.c:33 ../lib/gis/get_projinfo.c:60
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> file not found for location <%s>"
-msgstr "<%s> nie znaleziono pliku dla lokalizacji <%s>"
+msgstr "<%s> nie znaleziono pliku w lokacji <%s>"
 #: ../lib/gis/get_projinfo.c:39 ../lib/gis/get_projinfo.c:66
-#, fuzzy, c-format
+#, c-format
 msgid "ERROR in reading <%s> file for location <%s>"
-msgstr "BŁĄD podczas wczytywania pliku %s do %s\n"
+msgstr "BŁĄD podczas wczytywania pliku %s do lokacji <%s>"
 #: ../lib/gis/distance.c:160
 #, c-format
@@ -2949,14 +2939,12 @@
 msgstr "Nazwy kolumn(y) atrybutów"
 #: ../lib/gis/parser.c:384
-#, fuzzy
 msgid "Name of input imagery group"
-msgstr "Nazwa źródłowej mapy rastrowej"
+msgstr "Nazwa wejściowej grupy zobrazowań"
 #: ../lib/gis/parser.c:392
-#, fuzzy
 msgid "Name of input imagery subgroup"
+msgstr "Nazwa wejściowej podgrupy zobrazowań"
 #: ../lib/gis/parser.c:402 ../lib/gis/parser.c:427
 msgid "Name of input raster map"
@@ -2975,6 +2963,7 @@
 msgstr "Nazwa bazowej mapy rastrowej"
 #: ../lib/gis/parser.c:452
+#, fuzzy
 msgid "Name of cover raster map"
 msgstr "Nazwa "
@@ -3011,7 +3000,6 @@
 msgstr "Nazwa wyjściowej mapy wketorowej"
 #: ../lib/gis/parser.c:566
-#, fuzzy
 msgid "Feature type"
 msgstr "Typ obiektu"
@@ -3038,14 +3026,12 @@
 msgstr "Przykład: 1,3,7-9,13"
 #: ../lib/gis/parser.c:598
-#, fuzzy
 msgid "Feature id"
-msgstr "Typ obiektu"
+msgstr "ID obiektu"
 #: ../lib/gis/parser.c:605
-#, fuzzy
 msgid "Feature ids"
 #: ../lib/gis/parser.c:616
 msgid "Name of input file"
@@ -3089,7 +3075,7 @@
 msgstr ""
 #: ../lib/gis/parser.c:942
-#, fuzzy, c-format
+#, c-format
 msgid "Sorry <%s> is not a valid option\n"
 msgstr "<%s> nie jest poprawnÄ… opcjÄ…\n"
@@ -3197,9 +3183,8 @@
 msgstr ""
 #: ../lib/gis/parser.c:1980
-#, fuzzy
 msgid "Unable to determine program name"
-msgstr "nie można określić domowego katalogu użytkownika"
+msgstr "Nie można określić nazwy programu"
 #: ../lib/gis/parser.c:2037
 #, c-format
@@ -3231,7 +3216,7 @@
 "Błąd: niedopuszczalna składnia zakresu sla parametru <%s>\n"
 #: ../lib/gis/parser.c:2251
-#, fuzzy, c-format
+#, c-format
 msgid "       Presented as: %s\n"
 msgstr "       Przedstawiony jako: %s\n"
@@ -3486,7 +3471,6 @@
 "granicy (%g>%g)"
 #: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:299
-#, fuzzy
 msgid "North must be north of South"
 msgstr "Połnoc musi być na północ od Południa"
@@ -3527,7 +3511,6 @@
 msgstr "Niedozwolona wartość głębi"
 #: ../lib/gis/adj_cellhd.c:306
-#, fuzzy
 msgid "Top must be larger than Bottom"
 msgstr "Wartość dla północy musi być większa niż dla południa"
@@ -3924,9 +3907,8 @@
 msgstr "Wadliwe połączenie z serwerem"
 #: ../lib/nviz/render.c:118
-#, fuzzy
 msgid "Unable to create rendering context"
-msgstr "nie można utworzyć nowego procesu"
+msgstr "Nie można utworzyć kontekstu renderowania"
 #: ../lib/nviz/position.c:50
 msgid "Unable to set focus"
@@ -3968,9 +3950,8 @@
 msgstr ""
 #: ../lib/nviz/lights.c:144
-#, fuzzy
 msgid "Unable to define new light"
-msgstr "W %s nie można otworzyć pliku %s"
+msgstr "Nie można zdefiniować nowego światła"
 #: ../lib/sites/sites.c:97
 #, c-format
@@ -4010,7 +3991,7 @@
 #: ../lib/sites/sites.c:1249
 #, c-format
 msgid "Cannot open database %s by driver %s"
-msgstr "Nie można otworzyć bazy danych <%s> sterownikiem <%s>"
+msgstr "Nie można otworzyć bazy danych %s sterownikiem %s"
 #: ../lib/sites/sites.c:1257
 msgid "Cannot select attributes"
@@ -4116,9 +4097,8 @@
 msgstr ""
 #: ../lib/ogsf/gsd_img_mpeg.c:162
-#, fuzzy
 msgid "Unable to open codec"
-msgstr "Nie można otworzyć codec %s"
+msgstr "Nie można otworzyć kodeka"
 #: ../lib/ogsf/gsd_img_mpeg.c:181
 msgid "Unable to allocate picture"
@@ -4198,7 +4178,7 @@
 #: ../lib/ogsf/gsd_legend.c:502
 msgid "Try using smaller font!"
-msgstr ""
+msgstr "Spróbuj użyć mniejszej czcionki!"
 #: ../lib/ogsf/Gs3.c:133 ../lib/ogsf/Gs3.c:207 ../lib/ogsf/Gs3.c:364
 #: ../lib/ogsf/Gs3.c:479 ../lib/ogsf/Gs3.c:583
@@ -4271,7 +4251,7 @@
 #: ../lib/ogsf/gvl_file.c:471
 #, c-format
 msgid "Unable to close 3D raster map <%s>"
-msgstr ""
+msgstr "Nie można zamknąć mapy rastrowej 3D <%s>"
 #: ../lib/ogsf/trans.c:180
 msgid "Out of matrix stack space"
@@ -4320,7 +4300,6 @@
 msgstr "Macierz nie jest w pełni zainicjowana"
 #: ../lib/gmath/la.c:158
-#, fuzzy
 msgid "Unable to allocate space for matrix copy"
 msgstr "Nie można zaalokować miejsca na kopię macierzy"
@@ -4357,12 +4336,10 @@
 msgstr ""
 #: ../lib/gmath/la.c:464
-#, fuzzy
 msgid "Could not allocate space for solution matrix"
 msgstr "Nie można zaalokować miejsca na solution matrix"
 #: ../lib/gmath/la.c:470 ../lib/gmath/la.c:478
-#, fuzzy
 msgid "Could not allocate space for working matrix"
 msgstr "Nie można zaalokować miejsca na working matrix"
@@ -4371,9 +4348,8 @@
 msgstr ""
 #: ../lib/gmath/la.c:535
-#, fuzzy
 msgid "Problem in LA routine."
-msgstr "Problem z procedurÄ… LA"
+msgstr "Problem z procedurÄ… LA."
 #: ../lib/gmath/la.c:542
 msgid "Procedure not yet available for selected matrix type"
@@ -4905,17 +4881,14 @@
 #~ msgid "Unable to parse input file <%s>"
 #~ msgstr "Nie można otworzyć pliku %s"
-#, fuzzy
 #~ msgid "Invalid map type <%d>"
-#~ msgstr "Niedozwolona nazwa mapy wektorowej  <%s>"
+#~ msgstr "Niedozwolony typ mapy <%d>"
-#, fuzzy
 #~ msgid "Unable to load color rules <%s>"
-#~ msgstr "Nie można zamknąć wektora <%s>"
+#~ msgstr "Nie można wczytać reguł kolorów <%s>"
-#, fuzzy
 #~ msgid "Unable to open GDAL file"
-#~ msgstr "Nie można otworzyć pliku %s"
+#~ msgstr "Nie można otworzyć pliku GDAL"
 #, fuzzy
 #~ msgid "Unable to get <%s> driver"
@@ -4937,9 +4910,8 @@
 #~ msgid "Unable to set geo transform"
 #~ msgstr "Nie można odczytać mapy wektorowej "
-#, fuzzy
 #~ msgid "Unable to set projection"
-#~ msgstr "Nie można otworzyć codec %s"
+#~ msgstr "Nie można ustawić projekcji"
 #, fuzzy
 #~ msgid "Unable to create cell_misc/%s/gdal file"
@@ -4953,25 +4925,20 @@
 #~ msgid "Unable to create output file <%s> using driver <%s>"
 #~ msgstr "W %s nie można otworzyć pliku %s"
-#, fuzzy
 #~ msgid "       valid options: %s\n"
 #~ msgstr "     poprawne opcje: %s\n"
-#, fuzzy
 #~ msgid "Removing %s <%s>"
-#~ msgstr "Używa <%s@%s>"
+#~ msgstr "Usuwanie <%s@%s>"
-#, fuzzy
 #~ msgid "%s: missing"
-#~ msgstr "brakujÄ…cy."
+#~ msgstr "%s: brakuje"
-#, fuzzy
 #~ msgid "Copy %s <%s> to current mapset as <%s>"
-#~ msgstr "%s nie jest bieżącym mapsetem (%s)"
+#~ msgstr "Kopiuj %s <%s> do bieżącego mapsetu jako <%s>"
-#, fuzzy
 #~ msgid "Cannot rename <%s> to <%s>"
-#~ msgstr "Nie można otworzyć bazy danych <%s> sterownikiem <%s>"
+#~ msgstr "Nie można zmienić nazwy <%s> na <%s>"
 #, fuzzy
 #~ msgid "Unable to open range file for [%s in %s]"
@@ -5000,3 +4967,6 @@
 #, fuzzy
 #~ msgid "Can't stat %s\n"
 #~ msgstr "lista %s"
+#~ msgid "%s: copied"
+#~ msgstr "%s: skopiowane"
Modified: grass/branches/develbranch_6/locale/po/grassmods_pl.po
--- grass/branches/develbranch_6/locale/po/grassmods_pl.po	2009-10-28 23:28:04 UTC (rev 39640)
+++ grass/branches/develbranch_6/locale/po/grassmods_pl.po	2009-10-28 23:28:37 UTC (rev 39641)
@@ -2,18 +2,23 @@
 # Copyright (C) 2005, GRASS Development Team
 # Artur Nieścior <nieart at interia.pl>, 2005.
 msgid ""
 msgstr ""
 "Project-Id-Version: grassmodes_pl\n"
 "POT-Creation-Date: 2009-01-09 17:00+0100\n"
-"PO-Revision-Date: 2009-06-03 12:57+0100\n"
-"Language-Team: Polska <grass-translations at lists.osgeo.org>\n"
+"Language: pl\n"
+"Plural-Forms: nplurals=3; plural=(n==1 ? 0 : n%10>=2 && n%10<=4 && (n%100<10 "
+"|| n%100>=20) ? 1 : 2);\n"
+"X-Generator: Virtaal 0.4.0\n"
 "X-Poedit-Bookmarks: 2316,2891,3202,-1,-1,-1,-1,-1,-1,-1\n"
 "X-Poedit-Language: Polish\n"
 "X-Poedit-Country: POLAND\n"
@@ -277,7 +282,7 @@
 #: ../db/base/databases.c:92
 msgid "List all databases for a given driver and location."
-msgstr "Wyświetl listę baz danych dla danego sterownika i lokalizacji"
+msgstr "Wyświetl listę baz danych dla danego sterownika i lokacji"
 #: ../db/base/connect.c:47
 msgid "Prints/sets general DB connection for current mapset and exits."
@@ -574,9 +579,9 @@
 msgstr "Plik rastrowy który ma być importowany"
 #: ../raster3d/r3.in.ascii/main.c:242
-#, fuzzy
 msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-msgstr "Konwertuje tekstowy plik rastrowy ASCII do binarnej mapy rastrowej."
+msgstr ""
+"Konwertuje tekstowy plik rastrowy 3D ASCII na binarnÄ… mapÄ™ rastrowÄ… 3D."
 #: ../raster3d/r3.in.ascii/main.c:268 ../raster3d/r3.out.ascii/main.c:268
 #: ../raster3d/r3.in.v5d/main.c:215 ../raster3d/r3.out.v5d/main.c:315
@@ -615,8 +620,9 @@
 #: ../raster3d/r3.out.ascii/main.c:98 ../raster/r.transect/main.c:85
 #: ../raster/r.what/main.c:117
+#, fuzzy
 msgid "Char string to represent no data cell"
-msgstr ""
+msgstr "Znak reprezentujący komórki rastra dla których brak danych 'no data'"
 #: ../raster3d/r3.out.ascii/main.c:103 ../raster/r.out.ascii/main.c:104
 #: ../raster/r.out.arc/main.c:88
@@ -630,11 +636,11 @@
 #: ../raster3d/r3.out.ascii/main.c:244
 msgid "raster3d, voxel, export"
-msgstr ""
+msgstr "raster3d, voxel, eksport"
 #: ../raster3d/r3.out.ascii/main.c:246
 msgid "Converts a 3D raster map layer into an ASCII text file"
-msgstr ""
+msgstr "Konwertuje warstwÄ™ mapy rastrowej 3D na plik tekstowy ASCII."
 #: ../raster3d/r3.out.ascii/main.c:259 ../raster3d/r3.out.v5d/main.c:310
 #: ../raster3d/base/r3.null.main.c:106 ../raster3d/base/r3.mask.main.c:78
@@ -1267,7 +1273,7 @@
 #: ../raster3d/base/r3.timestamp.main.c:45
 msgid "Print/add/remove a timestamp for a 3D raster map"
-msgstr ""
+msgstr "Odświerz/dodaj/usuń znacznik czasu dla mapy rastrowej 3D"
 #: ../raster3d/base/r3.timestamp.main.c:52
 msgid "Input grid3 filename"
@@ -1441,7 +1447,7 @@
 #: ../raster3d/r3.out.vtk/main.c:378
 msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-msgstr ""
+msgstr "Konwertuje mapy rastrowe 3D GRASS-a (G3D) do formatu VTK-Ascii."
 #: ../raster3d/r3.out.vtk/main.c:389
 msgid "failed to interpret dp as an integer"
@@ -1517,7 +1523,7 @@
 #: ../raster3d/r3.to.rast/main.c:79
 msgid "3d raster map(s) to be converted to 2D raster slices"
-msgstr ""
+msgstr "Mapy rastrowe 3D do przekonwertowania na plastry 2D"
 #: ../raster3d/r3.to.rast/main.c:85
 msgid "Basename for resultant raster slice maps"
@@ -1573,7 +1579,7 @@
 #: ../raster3d/r3.to.rast/main.c:216
 msgid "Converts 3D raster maps to 2D raster maps"
-msgstr ""
+msgstr "Konwertuje mapy rastrowe 3D do map rastrowych 2D"
 #: ../raster3d/r3.to.rast/main.c:225
 #, c-format
@@ -1876,9 +1882,8 @@
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
 #: ../display/d.rast.edit/main.c:61
-#, fuzzy
 msgid "Interactively edit cell values in a raster map."
-msgstr "Zacznij od wartości w mapie rastrowej"
+msgstr "Edytuj interaktywnie wartości komórek na mapie rastrwej."
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
 #: ../display/d.rast.edit/main.c:59 ../display/d.rast/main.c:51
@@ -2343,20 +2348,16 @@
 msgstr "Nazwa kolumny"
 #: ../locale/scriptstrings/db.droptable_to_translate.c:1
-#, fuzzy
 msgid "Drops an attribute table."
-msgstr "wektor, raster, tabela atrybutów"
+msgstr "Usuwa tabelę atrybutów."
 #: ../locale/scriptstrings/db.droptable_to_translate.c:4
-#, fuzzy
 msgid "Table to drop"
-msgstr "Nie można kontynuować"
+msgstr "Tabela do usunięcia"
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
-#, fuzzy
 msgid "Imports attribute tables in various formats."
-msgstr ""
-"Eksportuje dane rastrowe GRASS do różnych formatów (wymaga biblioteki GDAL)"
+msgstr "Importuje tabele atrybutów w różnych formatach."
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
 msgid "Table file to be imported or DB connection string"
@@ -2383,22 +2384,22 @@
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
-#, fuzzy
 msgid "GRASS table name"
-msgstr "nazwa tabeli"
+msgstr "Nazwa tabeli GRASS"
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
 msgid "Table file to be exported or DB connection string"
 msgstr ""
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
-#, fuzzy
 msgid "Table format"
-msgstr "Format OGR."
+msgstr "Format tabeli"
 #: ../locale/scriptstrings/db.test_to_translate.c:1
 msgid "Test database driver, database must exist and set by db.connect."
 msgstr ""
+"Testuj driver bazy danych, baza danych musi istnieć i być ustawiona przy "
+"pomocy db.connect."
 #: ../locale/scriptstrings/db.test_to_translate.c:3
 msgid "Test name"
@@ -2636,7 +2637,7 @@
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:1
 msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-msgstr ""
+msgstr "Transformacja Cap (Kauth Thomas) dla danych LANDSAT-TM"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:2
 msgid "raster, imagery"
@@ -2684,7 +2685,7 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:1
 msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
+msgstr "Konwertuj współrzędne z danej projekcji do innej (cs2cs)"
 #: ../locale/scriptstrings/m.proj_to_translate.c:2
 #, fuzzy
@@ -2866,7 +2867,7 @@
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
 msgid "Import SRTM HGT files into GRASS"
-msgstr ""
+msgstr "Importuje pliki SRTM HGT do GRASS-a"
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
 #: ../raster/r.in.bin/main.c:122 ../raster/r.in.gdal/main.c:79
@@ -2888,7 +2889,7 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:1
 msgid "Downloads and imports data from WMS servers."
-msgstr ""
+msgstr "Ściąga i importuje dane z serwerów WMS."
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:2
 msgid "wms"
@@ -3083,7 +3084,7 @@
 #: ../locale/scriptstrings/r.mask_to_translate.c:1
 msgid "Create a MASK for limiting raster operation"
-msgstr ""
+msgstr "Tworzy MASKĘ do zawężenia operacji na rastrze"
 #: ../locale/scriptstrings/r.mask_to_translate.c:2
 msgid "raster, mask"
@@ -3235,7 +3236,7 @@
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:1
 msgid "Calculates linear regression from two raster maps: y = a + b*x"
-msgstr ""
+msgstr "Oblicza regresję linearną dla dwóch map rastrowych: y = a + b*x"
 #: ../locale/scriptstrings/r.regression.line_to_translate.c:2
 #: ../locale/scriptstrings/r.univar.sh_to_translate.c:2
@@ -3303,6 +3304,8 @@
 "Produces tilings of the source projection for use in the destination region "
 "and projection."
 msgstr ""
+"Tworzy kafelki projekcji źródłowej do zastosowania w docelowym regionie i "
+"projekcji."
 #: ../locale/scriptstrings/r.tileset_to_translate.c:2
 msgid "raster, tiling"
@@ -3337,7 +3340,7 @@
 #: ../locale/scriptstrings/r.tileset_to_translate.c:8
 #, fuzzy
 msgid "Destination projection, defaults to this location's projection"
-msgstr "Forsuj projekcję (użyj projekcji z lokalizacji)"
+msgstr "Forsuj projekcję (użyj projekcji z lokacji)"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:10
 #, fuzzy
@@ -3561,12 +3564,12 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
-#, fuzzy
 msgid ""
 "Adds one or more columns to the attribute table connected to a given vector "
 "map."
 msgstr ""
-"dodaje jedną lub więcej kolumn do tabeli atrybutów połączonej z daną  mapą"
+"Dodaje jedną lub więcej kolumn do tabeli atrybutów połączonej z zadaną mapą "
+"wektorowÄ…."
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:2
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
@@ -3603,11 +3606,12 @@
 "wszystkie wspierajÄ… VARCHAR(), INT, DOUBLE i DATE)"
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-#, fuzzy
 msgid ""
 "Creates and adds a new attribute table to a given layer of an existing "
 "vector map."
-msgstr "usuń istniejącą tabelę atrybutów mapy wektorowej"
+msgstr ""
+"Tworzy i dodaje nową tabelę atrybutów do zadanej warstwy istniejącej mapy "
+"wektorowej."
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
 #, fuzzy
@@ -3643,9 +3647,8 @@
 msgstr "Nieznany typ kolumny"
 #: ../locale/scriptstrings/v.db.join_to_translate.c:6
-#, fuzzy
 msgid "Other table name"
-msgstr "Wprowadź docelową nazwę tabeli"
+msgstr "Inna nazwa tabeli"
 #: ../locale/scriptstrings/v.db.join_to_translate.c:7
 #, fuzzy
@@ -3694,11 +3697,10 @@
 msgstr "nazwa mapy wektorowej z której ma być usunięta tabela atrybutów"
 #: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
-#, fuzzy
 msgid ""
 "Renames a column in the attribute table connected to a given vector map."
 msgstr ""
+"Zmienia nazwę kolumny w tabeli atrybutów połączonej z zadaną mapą wektorową."
 #: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
 #, fuzzy
@@ -3715,9 +3717,8 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-#, fuzzy
 msgid "Reconnects vectors to a new database."
-msgstr "Podłącz wektory do nowej bazy danych"
+msgstr "Podłącza wektory do nowej bazy danych."
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
 #, fuzzy
@@ -3739,9 +3740,8 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
-#, fuzzy
 msgid "New schema"
-msgstr "Struktura bazy danych"
+msgstr "Nowy schemat"
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:1
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:1
@@ -3787,11 +3787,11 @@
 msgstr "Sterownik bazy danych"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:1
-#, fuzzy
 msgid ""
 "Allows to update a column in the attribute table connected to a vector map."
 msgstr ""
+"Umożliwia aktualizację kolumny w tabeli atrybutów połączonej z zadaną mapą "
+"wektorowÄ…."
 #: ../locale/scriptstrings/v.db.update_to_translate.c:3
 #, fuzzy
@@ -3851,9 +3851,8 @@
 msgstr "Nazwa wyświetlanej kolumny"
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:1
-#, fuzzy
 msgid "Import E00 file into a vector map."
-msgstr "Import pliku E00 do mapy wektorowej"
+msgstr "Import pliku E00 do mapy wektorowej."
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:3
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:3
@@ -3988,7 +3987,7 @@
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
 msgid "Import Mapgen or Matlab vector maps into GRASS."
-msgstr ""
+msgstr "Importuje mapy wektorowe Mapgen i Matlab do GRASS-a."
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
 #, fuzzy
@@ -4035,6 +4034,8 @@
 msgid ""
 "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
 msgstr ""
+"Eksportuje mapę wektorową do odbiornika GPS lub pliku obsługiwanego przez "
+"bibliotekÄ™ GPSBabel."
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:2
 msgid "vector, export, GPS"
@@ -4510,14 +4511,14 @@
 msgstr "Skala pionowa"
 #: ../raster/r.proj.seg/main.c:135 ../raster/r.proj/main.c:129
-#, fuzzy
 msgid "raster, projection"
-msgstr "Mapa ma inne odwzorowanie"
+msgstr "raster, projekcja"
 #: ../raster/r.proj.seg/main.c:137 ../raster/r.proj/main.c:131
-#, fuzzy
 msgid "Re-projects a raster map from one location to the current location."
-msgstr "Przeprojektuj mapę rastrową z danej lokacji do bieżącej lokacji."
+msgstr ""
+"Zmienia projekcję mapy rastrowej z jednej lokacji do projekcji bieżącej "
+"lokacji."
 #: ../raster/r.proj.seg/main.c:140 ../raster/r.proj/main.c:134
 #, fuzzy
@@ -4595,7 +4596,7 @@
 #: ../raster/r.proj.seg/main.c:233 ../raster/r.proj/main.c:221
 #, fuzzy
 msgid "Unable to get projection key values of output raster map"
-msgstr "Nie można pobrać kluczowych wartości projekcji bieżącej lokalizacji"
+msgstr "Nie można pobrać kluczowych wartości projekcji bieżącej lokacji"
 #: ../raster/r.proj.seg/main.c:242 ../raster/r.proj/main.c:230
 #, fuzzy, c-format
@@ -4605,7 +4606,7 @@
 #: ../raster/r.proj.seg/main.c:244 ../raster/r.in.gdal/main.c:633
 #: ../raster/r.proj/main.c:232 ../imagery/i.rectify/target.c:33
 msgid "permission denied"
-msgstr ""
+msgstr "odmowa dostępu"
 #: ../raster/r.proj.seg/main.c:245 ../raster/r.in.gdal/main.c:634
 #: ../raster/r.proj/main.c:233 ../imagery/i.rectify/target.c:33
@@ -4613,9 +4614,9 @@
 msgstr "nie znaleziono"
 #: ../raster/r.proj.seg/main.c:250 ../raster/r.proj/main.c:238
-#, fuzzy, c-format
+#, c-format
 msgid "Checking location <%s>, mapset <%s>..."
-msgstr "Nie mozna otworzyć pliku etyiet <%s> w mapsecie <%s>"
+msgstr "Sprawdzam lokacjÄ™ <%s> w mapsecie <%s>..."
 #: ../raster/r.proj.seg/main.c:257 ../raster/r.out.gdal/main.c:223
 #: ../raster/r.in.gdal/main.c:199 ../raster/r.proj/main.c:245
@@ -4633,17 +4634,17 @@
 #: ../raster/r.proj.seg/main.c:268 ../raster/r.proj/main.c:256
 #, fuzzy
 msgid "Unable to get projection info of input map"
-msgstr "Nie można pobrać informacji o projekcji bieżącej lokalizacji"
+msgstr "Nie można pobrać informacji o projekcji bieżącej lokacji"
 #: ../raster/r.proj.seg/main.c:271 ../raster/r.proj/main.c:259
 #, fuzzy
 msgid "Unable to get projection units of input map"
-msgstr "Nie można pobrać jednostek projekcji bieżącej lokalizacji"
+msgstr "Nie można pobrać jednostek projekcji bieżącej lokacji"
 #: ../raster/r.proj.seg/main.c:274 ../raster/r.proj/main.c:262
 #, fuzzy
 msgid "Unable to get projection key values of input map"
 #: ../raster/r.proj.seg/main.c:288 ../raster/r.proj/main.c:276
 msgid "Unable to work with unprojected data (xy location)"
@@ -4965,7 +4966,7 @@
 #: ../raster/r.surf.fractal/interface.c:38
 msgid "Creates a fractal surface of a given fractal dimension."
-msgstr ""
+msgstr "Utwórz powierzchnię fraktalną dla zadanych rozmiarów fraktala."
 #: ../raster/r.surf.fractal/interface.c:49
 msgid "Fractal dimension of surface (2 < D < 3)"
@@ -5100,7 +5101,7 @@
 #: ../raster/r.reclass/main.c:119
 #, c-format
 msgid " ignored\n"
-msgstr ""
+msgstr "zignorowany\n"
 #: ../raster/r.reclass/main.c:122
 msgid " - invalid reclass rule"
@@ -5148,7 +5149,7 @@
 #: ../raster/r.los/main.c:97
 #, fuzzy
 msgid "Coordinate identifying the viewing position"
-msgstr "Identyfikacja współrzędnych lokalizacji widoku"
+msgstr "Identyfikacja współrzędnych lokacji widoku"
 #: ../raster/r.los/main.c:102
 msgid "Binary (1/0) raster map to use as a mask"
@@ -5874,9 +5875,9 @@
 #: ../raster/r.texture/main.c:240 ../raster/r.null/null.c:157
 #: ../raster/r.out.tiff/r.out.tiff.c:169 ../raster/r.bitpattern/main.c:114
 #: ../imagery/i.rectify/main.c:193 ../imagery/i.rectify/main.c:199
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read header of raster map <%s>"
-msgstr "Nie można utworzyć mapy rastrowej <%s>"
+msgstr "Nie można przeczytać nagłówka mapy rastrowej <%s>"
 #: ../raster/r.texture/main.c:373
 #, c-format
@@ -6182,7 +6183,7 @@
 "Can't get projection info of current location: please set latitude via 'lat' "
 "or 'latin' option!"
 msgstr ""
-"Nie można pobrać informacji o projekcji bieżącej lokalizacji: proszę ustawić "
+"Nie można pobrać informacji o projekcji bieżącej lokacji: proszę ustawić "
 "szerokość geogr. poprzez opcję 'lat' lub 'latin'!"
 #: ../raster/r.sun/main.c:477 ../raster/r.sun2/main.c:723
@@ -6190,7 +6191,7 @@
 #: ../general/g.region/printwindow.c:251 ../general/g.region/printwindow.c:492
 #: ../general/g.region/printwindow.c:611
 msgid "Can't get projection units of current location"
 #: ../raster/r.sun/main.c:481 ../raster/r.sun2/main.c:726
 #: ../raster/r.horizon/main.c:488 ../ps/ps.map/do_geogrid.c:272
@@ -6198,7 +6199,7 @@
 #: ../general/g.region/printwindow.c:254 ../general/g.region/printwindow.c:495
 #: ../general/g.region/printwindow.c:614
 msgid "Can't get projection key values of current location"
 #: ../raster/r.sun/main.c:491 ../raster/r.sun2/main.c:736
 #: ../raster/r.horizon/main.c:498 ../ps/ps.map/do_geogrid.c:278
@@ -6905,7 +6906,7 @@
 #: ../raster/r.in.bin/main.c:321
 #, c-format
 msgid "Using N=%f S=%f E=%f W=%f"
-msgstr ""
+msgstr "Używa N=%f S=%f E=%f W=%f"
 #: ../raster/r.in.bin/main.c:346
 #, fuzzy, c-format
@@ -7009,9 +7010,9 @@
 #: ../raster/r.surf.idw2/read_cell.c:38 ../raster/r.surf.idw/main.c:685
 #: ../raster/r.colors/stats.c:41 ../raster/r.colors/stats.c:104
 #: ../raster/r.series/main.c:195
-#, fuzzy, c-format
+#, c-format
 msgid "Reading raster map <%s>..."
-msgstr "Odczytywanie map rastrowych..."
+msgstr "Odczytywanie mapy rastrowej <%s>..."
 #: ../raster/r.transect/main.c:56
 msgid ""
@@ -7664,7 +7665,7 @@
 #: ../raster/r.compress/main.c:65
 #, fuzzy
 msgid "Compresses and decompresses raster maps."
-msgstr "Kompresuje i dekompresuje pliki rastrowe."
+msgstr "Kompresuj i dekompresuj mapy rastrowe."
 #: ../raster/r.compress/main.c:73 ../display/d.what.rast/main.c:81
 msgid "Name of existing raster map(s)"
@@ -7873,11 +7874,10 @@
 msgstr "Nie utworzono żadnej mapy"
 #: ../raster/r.grow2/main.c:130
-#, fuzzy
 msgid "Generates a raster map layer with contiguous areas grown by one cell."
 msgstr ""
 "Tworzy warstwę mapy rastrowej z ciągłymi obszarami powiększonymi o jedną "
-"komórkę"
+"komórkę."
 #: ../raster/r.grow2/main.c:141
 msgid "Radius of buffer in raster cells"
@@ -7916,11 +7916,9 @@
 msgstr "Błąd podczas zapisu pliku colr dla <%s>."
 #: ../raster/r.circle/dist.c:53
-#, fuzzy
 msgid "Creates a raster map containing concentric rings around a given point."
 msgstr ""
-"Tworzy rastrowÄ… i wektorowÄ… warstwÄ™ mapy zawierajÄ…ce przypadkowo "
-"rozmieszczone punkty."
+"Tworzy mapę rastrową zawierającą koncentryczne kręgi wokół zadanych pubktów."
 #: ../raster/r.circle/dist.c:63
 msgid "The coordinate of the center (east,north)"
@@ -8087,9 +8085,8 @@
 #: ../raster/r.li/r.li.shape/main.c:42
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
 #: ../raster/r.li/r.li.shannon/shannon.c:48
-#, fuzzy
 msgid "Configuration file"
-msgstr "Plik wyjściowy kluczowej klatki"
+msgstr "Plik konfiguracyjny"
 #: ../raster/r.li/r.li.richness/richness.c:39
 #: ../raster/r.li/r.li.dominance/dominance.c:41
@@ -8779,7 +8776,7 @@
 #: ../raster/r.in.gdal/main.c:107
 msgid "Name of location to read projection from for GCPs transformation"
 msgstr ""
-"Nazwa lokalizacji z której ma być odczytana projekcja dla transformacji GCP"
+"Nazwa lokacji z której ma być odczytana projekcja dla transformacji GCP"
 #: ../raster/r.in.gdal/main.c:115 ../raster/r.external/main.c:537
 msgid "Metadata"
@@ -8787,16 +8784,16 @@
 #: ../raster/r.in.gdal/main.c:121 ../vector/v.in.ogr/main.c:181
 msgid "Name for new location to create"
-msgstr "Nazwa lokalizacji która ma być utworzona"
+msgstr "Nazwa lokacji która ma być utworzona"
 #: ../raster/r.in.gdal/main.c:126 ../raster/r.external/main.c:542
 msgid "Override projection (use location's projection)"
 #: ../raster/r.in.gdal/main.c:130 ../raster/r.external/main.c:546
 #: ../vector/v.in.ogr/main.c:229
 msgid "Extend location extents based on new dataset"
-msgstr "Rozszerz zasięg lokalizacji opartej na nowych ustawieniach danych"
+msgstr "Rozszerz zasięg lokacji opartej na nowych ustawieniach danych"
 #: ../raster/r.in.gdal/main.c:134 ../raster/r.external/main.c:554
 #: ../vector/v.in.ogr/main.c:200
@@ -8938,24 +8935,22 @@
 msgstr "Błąd w pj_do_proj (projekcja wejściowej pary współrzędnych"
 #: ../raster/r.in.gdal/main.c:608
-#, fuzzy
 msgid "Unable to translate projection key values of input GCPs"
+msgstr "Nie można przełożyć kluczowych wartości projekcji punktów GCPs"
 #: ../raster/r.in.gdal/main.c:624
-#, fuzzy
 msgid "Unable to get projection info of target location"
+msgstr "Nie można pobrać informacji o projekcji  lokacji docelowej"
 #: ../raster/r.in.gdal/main.c:626
 #, fuzzy
 msgid "Unable to get projection units of target location"
 #: ../raster/r.in.gdal/main.c:628
 #, fuzzy
 msgid "Unable to get projection key values of target location"
 #: ../raster/r.in.gdal/main.c:631 ../imagery/i.rectify/target.c:32
 #, fuzzy, c-format
@@ -10188,7 +10183,7 @@
 #: ../raster/r.in.xyz/main.c:525 ../raster/r.in.poly/poly2rast.c:51
 #, fuzzy, c-format
 msgid "Pass #%d (of %d) ..."
-msgstr "Uznane #%d (z %d) ..."
+msgstr "2-przebiegowy"
 #: ../raster/r.in.xyz/main.c:596 ../raster/r.in.xyz/main.c:604
 #: ../raster/r.in.xyz/main.c:1100 ../raster/r.in.xyz/main.c:1108
@@ -10462,9 +10457,8 @@
 msgstr ""
 #: ../raster/r.colors/main.c:167
-#, fuzzy
 msgid "Creates/modifies the color table associated with a raster map layer."
-msgstr "Tworz/Modyfikuje paletę kolorów powiązaną z warstwą mapy rastrowej."
+msgstr "Tworzy/modyfikuje paletę kolorów związaną z warstwą mapy rastrowej."
 #: ../raster/r.colors/main.c:196
 #, fuzzy
@@ -10733,7 +10727,7 @@
 #: ../raster/r.timestamp/main.c:36
 msgid "Print/add/remove a timestamp for a raster map."
-msgstr ""
+msgstr "Odśwież/dodaj/usuń znacznik czasu dla mapy rastrowej 3D."
 #: ../raster/r.timestamp/main.c:80
 msgid "Invalid timestamp"
@@ -10839,9 +10833,8 @@
 msgstr "Nazwa mapy rastrowej"
 #: ../raster/r.mfilter.fp/main.c:59 ../raster/r.mfilter/main.c:52
-#, fuzzy
 msgid "Raster map matrix filter."
-msgstr "Filter matrycowy pliku rastrowego"
+msgstr "Matrycowy filtr map rastrowych."
 #: ../raster/r.mfilter.fp/main.c:70 ../raster/r.mfilter/main.c:63
 msgid "Name of filter file"
@@ -11057,8 +11050,8 @@
 "category values represent cost."
 msgstr ""
 "Tworzy wasrstwÄ™ mapy rastrowej ukazujÄ…cÄ… skumulowany koszt przemieszczania "
-"się pomiędzy dwoma lokalizacjami geograficznymi na wejściowej warstwie "
-"rastrowej której wartości kategorii komórek rastra reprezentują koszt."
+"się pomiędzy dwoma lokacjami geograficznymi na wejściowej warstwie rastrowej "
+"której wartości kategorii komórek rastra reprezentują koszt."
 #: ../raster/r.cost/main.c:133
 msgid "Name of raster map containing grid cell cost information"
@@ -12017,7 +12010,7 @@
 #: ../raster/r.clump/clump.c:98
 #, fuzzy, c-format
 msgid "Pass %d..."
-msgstr "Maska: %s\n"
 #: ../raster/r.clump/clump.c:101
 #, c-format
@@ -12436,9 +12429,8 @@
 msgstr ""
 #: ../raster/r.in.mat/main.c:94
-#, fuzzy
 msgid "Imports a binary MAT-File(v4) to a GRASS raster."
-msgstr "Import binarnego pliku MAT-File(v4) do rastrowego formatu GRASS"
+msgstr "Importuje binarny plik MAT (v4) do rastrowego formatu GRASS."
 #: ../raster/r.in.mat/main.c:103
 msgid "Name of an existing MAT-File(v4)"
@@ -13200,7 +13192,7 @@
 #: ../raster/r.watershed/front/main.c:53
 msgid "Watershed basin analysis program."
-msgstr ""
+msgstr "Program do analiz działów wodnych zlewni."
 #: ../raster/r.watershed/front/main.c:57
 msgid "Input map: elevation on which entire analysis is based"
@@ -13311,10 +13303,8 @@
 msgstr "Nie można utworzyć mapy rastrowej %s"
 #: ../raster/r.in.poly/main.c:31
-#, fuzzy
 msgid "Creates raster maps from ASCII polygon/line/point data files."
-msgstr ""
-"Tworzy mapę rastrową z danego pliku poligonów/linii ascii w bieżącym katalogu"
+msgstr "Tworzy mapę rastrową z poligonowych/liniowych/punktowych plików ASCII."
 #: ../raster/r.in.poly/main.c:35
 #, fuzzy
@@ -13349,10 +13339,8 @@
 msgstr "Zakres rozpiętości danych wynosi %ld do %ld\n"
 #: ../raster/r.quant/main.c:43
-#, fuzzy
 msgid "Produces the quantization file for a floating-point map."
-msgstr ""
-"Procedura która tworzy plik ilościowy dla map z danymi zmiennoprzecinkowymi."
+msgstr "Tworzy plik kwantyzacji dla mapy zmiennoprzecinkowej."
 #: ../raster/r.quant/main.c:51
 msgid "Base map to take quant rules from"
@@ -13855,8 +13843,8 @@
 "raster map layer whose cell values represent friction cost."
 msgstr ""
 #: ../raster/r.walk/main.c:188
 msgid "Name of elevation input raster map"
@@ -14126,14 +14114,14 @@
 #: ../raster/r.mapcalc/map3.c:190 ../raster/r.mapcalc/map.c:96
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create btree for raster map <%s@%s>"
+msgstr "Nie można btree utworzyć mapy rastrowej <%s@%s>"
 #: ../raster/r.mapcalc/map3.c:367 ../raster/r.mapcalc/map.c:309
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to close raster map <%s@%s>"
-msgstr "Nie można otworzyć mapy rastrowej <%s>"
+msgstr "Nie można zamknąć mapy rastrowej <%s@%s>"
 #: ../raster/r.mapcalc/map3.c:605
 msgid "Unable to close output raster map"
@@ -14666,7 +14654,7 @@
 #: ../raster/r.buffer/main.c:168
 #, fuzzy, c-format
 msgid "Pass %d (of %d)"
-msgstr "klasa %d (%d)\n"
 #: ../raster/r.buffer/write_map.c:48
 #, fuzzy, c-format
@@ -14679,9 +14667,8 @@
 msgstr "%s: %s - niewłaściwe jednostki"
 #: ../raster/r.support.stats/main.c:38
-#, fuzzy
 msgid "Update raster map statistics"
-msgstr "Nazwa mapy rastrowej dla której mają być obliczone statystyki"
+msgstr "Aktualizuj statystyki mapy rastrowej"
 #: ../raster/r.support.stats/main.c:52
 #, fuzzy, c-format
@@ -14712,13 +14699,11 @@
 msgstr ""
 #: ../raster/r.in.arc/main.c:61
-#, fuzzy
 msgid ""
 "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
 "map layer."
 msgstr ""
-"Konwertuje plik rastrowy ESRI ARC/INFO ascii (GRID) do binarnej mapy "
-"rastrowej."
+"Konwertuje ESRI ARC/INFO ascii rastr (GRID) na (binarnÄ…) mapÄ™ rastrowÄ…."
 #: ../raster/r.in.arc/main.c:69
 #, fuzzy
@@ -14726,18 +14711,16 @@
 msgstr "Plik rastrowy ARC/INFO ascii (GRID) który ma być importowany"
 #: ../raster/r.in.arc/main.c:228
-#, fuzzy
 msgid "Failed to copy file"
-msgstr "Nie można otworzyć pliku wyjściowego"
+msgstr "Nie udało się skopiować pliku"
 #: ../raster/r.proj/main.c:209 ../vector/v.proj/main.c:138
 msgid "Input and output locations can not be the same"
 msgstr ""
 #: ../raster/r.bitpattern/main.c:63
-#, fuzzy
 msgid "Compares bit patterns with a raster map."
-msgstr "Porównuje próbkę bitów z mapą rastrową"
+msgstr "Porównuje bitowe wypełnienia z mapą rastrową."
 #: ../raster/r.bitpattern/main.c:75
 msgid "Bit pattern position(s)"
@@ -14770,10 +14753,8 @@
 msgstr ""
 #: ../raster/r.to.rast3/main.c:196
-#, fuzzy
 msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr ""
-"Konwertuje plastry mapy rastrowej 2D do jednej rastrowej mapy objętości 3D"
+msgstr "Konwertuje serie map rastrowych 2D do jednej bryły 3D (volume)."
 #: ../raster/r.to.rast3/main.c:208
 msgid "No output map"
@@ -14903,11 +14884,10 @@
 msgstr "<%s> utworzonych"
 #: ../raster/r.external/main.c:507
-#, fuzzy
 msgid "Link GDAL supported raster file to a binary raster map layer."
 msgstr ""
-"Import plików rastrowych wspieranych przez bibliotekę GDAL do binarnej mapy "
-"rastrowej"
+"Tworzy link rastrowych plików wspieranych przez GDAL do binarnej mapy "
+"rastrowej."
 #: ../raster/r.external/main.c:510
 msgid "Raster file to be linked"
@@ -15203,7 +15183,7 @@
 #: ../vector/v.net.visibility/main.c:47
 msgid "Visibility graph construction."
-msgstr ""
+msgstr "Tworzenie grafu widoczności."
 #: ../vector/v.net.visibility/main.c:59
 msgid "One or more coordinates"
@@ -15387,6 +15367,7 @@
 "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
 "raster map layer."
 msgstr ""
+"Konwertuje binarnÄ… mapÄ™ wektorowÄ… GRASS (punkty) do mapy rastrowej 3D GRASS."
 #: ../vector/v.to.rast3/main.c:59
 msgid "Column name (type must be numeric)"
@@ -15439,6 +15420,7 @@
 #: ../vector/v.external/main.c:60
 msgid "Creates a new vector as a read-only link to OGR layer."
 msgstr ""
+"Tworzy nowÄ… warstwÄ™ wektorowÄ… jako link do warstwy OGR tylko do odczytu."
 #: ../vector/v.external/main.c:75
 msgid "Output vector. If not given, available layers are printed only."
@@ -15471,7 +15453,7 @@
 #: ../vector/v.perturb/main.c:75
 msgid "Random location perturbations of GRASS vector points"
-msgstr ""
+msgstr "Losowe rozrzucenie punktw wektorowych "
 #: ../vector/v.perturb/main.c:78
 msgid "Vector points to be spatially perturbed"
@@ -16065,7 +16047,7 @@
 #: ../vector/lidar/v.lidar.edgedetection/main.c:74
 msgid "Detects the object's edges from a LIDAR data set."
-msgstr ""
+msgstr "Wykrywa granice obiektów z danych LIDAR."
 #: ../vector/lidar/v.lidar.edgedetection/main.c:86
 #: ../vector/lidar/v.lidar.correction/main.c:90
@@ -16253,9 +16235,8 @@
 "Rozdzielczość = %d; okres = %d"
 #: ../vector/lidar/v.lidar.correction/main.c:268
-#, fuzzy
 msgid "Mean's calculation"
-msgstr "lokalizacja bazy danych"
+msgstr ""
 #: ../vector/lidar/v.lidar.correction/main.c:281
 msgid "Only TERRAIN points"
@@ -16296,9 +16277,9 @@
 #: ../vector/lidar/v.outlier/main.c:167
 #: ../vector/lidar/v.surf.bspline/main.c:228
 #: ../vector/lidar/v.surf.bspline/main.c:248
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open vector map <%s> at the topological level"
-msgstr "Nie można otworzyć mapy wektorowej [%s]"
+msgstr "Nie można otworzyć mapy wektorowej <%s> na poziomie topologicznym"
 #: ../vector/lidar/v.outlier/main.c:318
 #, fuzzy
@@ -16550,9 +16531,8 @@
 #: ../vector/v.net.salesman/main.c:110 ../vector/v.net.iso/main.c:85
 #: ../vector/v.net.path/main.c:50 ../vector/v.net.alloc/main.c:75
 #: ../vector/v.net.steiner/main.c:359 ../display/d.path/main.c:59
-#, fuzzy
 msgid "Arc type"
-msgstr "Typ wykresu"
+msgstr "Typ łuku"
 #: ../vector/v.net.salesman/main.c:114 ../vector/v.net.iso/main.c:89
 #: ../vector/v.net.path/main.c:55 ../vector/v.net/main.c:82
@@ -16580,7 +16560,7 @@
 #: ../vector/v.net.steiner/main.c:394 ../display/d.path/main.c:123
 #, fuzzy
 msgid "Use geodesic calculation for longitude-latitude locations"
-msgstr "%s nie działa w lokalizacjach o współrzędnych geograficznych"
+msgstr "%s nie działa w lokacjach o współrzędnych geograficznych"
 #: ../vector/v.net.salesman/main.c:193
 #, fuzzy, c-format
@@ -16612,9 +16592,8 @@
 #: ../vector/v.distance/main.c:122 ../vector/v.distance/main.c:134
 #: ../vector/v.distance/main.c:146
-#, fuzzy
 msgid "From"
-msgstr "Z typu"
+msgstr "Z"
 #: ../vector/v.distance/main.c:126
 #, fuzzy
@@ -16963,7 +16942,7 @@
 #: ../vector/v.in.ascii/in.c:50
 msgid "Creates a vector map from ASCII points file or ASCII vector file."
-msgstr ""
+msgstr "Tworzy mapę wektorową z pliku punktów lub wektorów ASCII."
 #: ../vector/v.in.ascii/in.c:56
 #, fuzzy
@@ -17288,11 +17267,10 @@
 msgstr "wctor, eksport"
 #: ../vector/v.out.ascii/out.c:47
-#, fuzzy
 msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
 msgstr ""
-"Tworzy binarną mapę wektorową w formacie GRASS określonych izolinii z "
-"warstwy rastrowej formatu GRASS."
+"Konwertuje binarnÄ… mapÄ™ wektorowÄ… GRASS-a do wektorowej mapy GRASS-a typu "
+"ASCII."
 #: ../vector/v.out.ascii/out.c:54
 msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
@@ -17354,7 +17332,7 @@
 #: ../vector/v.build/main.c:35
 msgid "Creates topology for GRASS vector map."
-msgstr ""
+msgstr "Tworzy topologiÄ™ dla wektorowej mapy GRASS."
 #: ../vector/v.build/main.c:42
 msgid "Name for vector map where erroneous vector features are written to"
@@ -17453,9 +17431,8 @@
 msgstr "Nazwa wejściowego pliku wektorowego"
 #: ../vector/v.db.select/main.c:53
-#, fuzzy
 msgid "Prints vector map attributes."
-msgstr "Mapa wektorowa punktów końcowych"
+msgstr "Wyświetla atrybuty mapy wektorowej."
 #: ../vector/v.db.select/main.c:82
 msgid ""
@@ -17894,9 +17871,8 @@
 #: ../vector/v.kernel/main.c:127
-#, fuzzy
 msgid "Output raster/vector map"
-msgstr "Wyjściowa mapa rastrowa"
+msgstr "Wyjściowa mapa rastrowa/wektorowa"
 #: ../vector/v.kernel/main.c:133
 #, fuzzy
@@ -18007,9 +17983,8 @@
 msgstr ""
 #: ../vector/v.sample/main.c:88
-#, fuzzy
 msgid "Samples a raster map at vector point locations."
-msgstr "Konwertuje mapÄ™ rastrowÄ… do warstwy wektorowej."
+msgstr "Próbkuje mapę rastrową w sąsiedztwie punktów wektorowych."
 #: ../vector/v.sample/main.c:91
 msgid "Vector map defining sample points"
@@ -18395,11 +18370,8 @@
 msgstr "  Komentarze"
 #: ../vector/v.in.ogr/main.c:103
-#, fuzzy
 msgid "Convert OGR vector layers to GRASS vector map."
-msgstr ""
+msgstr "Konwertuje warstwy wektorowe OGR na wektorowe mapy GRASS."
 #: ../vector/v.in.ogr/main.c:110
 #, fuzzy
@@ -18496,7 +18468,7 @@
 #: ../vector/v.in.ogr/main.c:219
 #, fuzzy
 msgid "Override dataset projection (use location's projection)"
 #: ../vector/v.in.ogr/main.c:224
 msgid "Limit import to the current region"
@@ -18736,9 +18708,8 @@
 msgstr "nazwa wejściowego pliku wektorowego"
 #: ../vector/v.in.sites/main.c:59
-#, fuzzy
 msgid "Converts a GRASS site_lists file into a vector map."
+msgstr "Konwertuje plik site_lists GRASS do mapy wektorowej."
 #: ../vector/v.in.sites/main.c:83
 #, fuzzy, c-format
@@ -18857,9 +18828,9 @@
 msgstr ""
 #: ../vector/v.patch/main.c:364
-#, fuzzy, c-format
+#, c-format
-msgstr "Nie można otworzyć mapy wektorowej <%s>"
+msgstr "Budowanie topologii dla mapy wektorowej <%s>..."
 #: ../vector/v.patch/main.c:370
 msgid "Intersections at borders will have to be snapped"
@@ -18936,6 +18907,8 @@
 "Surface interpolation from vector point data by Inverse Distance Squared "
 "Weighting."
 msgstr ""
+"Interpolacja powierzchni z punktów wektorowych metodą Inverse Distance "
+"Squared Weighting (IDW)."
 #: ../vector/v.surf.idw/main.c:106
 msgid ""
@@ -19188,6 +19161,8 @@
 "Performs an affine transformation (shift, scale and rotate, or GPCs) on "
 "vector map."
 msgstr ""
+"Wykonuje transformację afiniczną (przesuń, skaluj i obróć, lub GPC) mapy "
+"wektorowej."
 #: ../vector/v.transform/main.c:80
 #, fuzzy
@@ -19699,9 +19674,8 @@
 msgstr "wector, import, konwersja"
 #: ../vector/v.convert/main.c:37
-#, fuzzy
 msgid "Imports older versions of GRASS vector maps."
+msgstr "Importuje starsze wersje wektorowych map GRASS-a."
 #: ../vector/v.convert/main.c:54
 #, fuzzy
@@ -20220,9 +20194,8 @@
 msgstr "%s: Brak pliku definicji FreeType"
 #: ../vector/v.clean/main.c:44
-#, fuzzy
 msgid "Toolset for cleaning topology of vector map."
-msgstr "Błąd podczas zamykania mapy wektorowej g3d."
+msgstr "Narzędzia do usuwania topologii mapy wektorowej."
 #: ../vector/v.clean/main.c:53
 msgid "Name of output map where errors are written"
@@ -20581,9 +20554,8 @@
 msgstr "%s: Nie można zapisać pliku dxf."
 #: ../vector/v.out.dxf/main.c:50
-#, fuzzy
 msgid "Exports GRASS vector map layers to DXF file format."
-msgstr "Eksportuje wektorowe pliki GRASSa do formatu DXF."
+msgstr "Eksportuje warstwy mapy wektorowej GRASS-a do formatu DXF."
 #: ../vector/v.out.dxf/main.c:60
 msgid "DXF output file"
@@ -20802,7 +20774,7 @@
 #: ../vector/v.what/main.c:57
 msgid "Queries a vector map layer at given locations."
-msgstr "Odpytuje mapÄ™ wektorowych w zadanych lokalizacjach."
+msgstr "Odpytuje mapÄ™ wektorowych w zadanych lokacjach."
 #: ../vector/v.what/main.c:70
 msgid "If not given reads from standard input"
@@ -20876,9 +20848,8 @@
 msgstr "Opcja ta wymaga przynajmniej 2 kolumn"
 #: ../vector/v.out.svg/main.c:72
-#, fuzzy
 msgid "Exports a GRASS vector map to SVG."
+msgstr "Eksportuje mapÄ™ wektorowÄ… GRASS-a do SVG."
 #: ../vector/v.out.svg/main.c:78
 #, fuzzy
@@ -21042,9 +21013,8 @@
 msgstr ""
 #: ../vector/v.to.db/parse.c:102
-#, fuzzy
 msgid "Print only"
-msgstr "Wyświetl tylko zakres rozpiętości danych"
+msgstr "Tylko wydrukuj"
 #: ../vector/v.to.db/parse.c:107
 #, fuzzy
@@ -21156,11 +21126,8 @@
 msgstr ""
 #: ../vector/v.out.vtk/main.c:48
-#, fuzzy
 msgid "Converts a GRASS binary vector map to VTK ASCII output."
-msgstr ""
+msgstr "Konwertuje binarnÄ… mapÄ™ wektorowÄ… GRASS-a do VTK ASCII."
 #: ../vector/v.out.vtk/main.c:58
 #, fuzzy
@@ -21366,9 +21333,8 @@
 msgstr "Kąt obrotu w stopniach (kierunek przeciwny do ruchu wskazówek zegara)"
 #: ../vector/v.label/main.c:167
-#, fuzzy
 msgid "Border width"
-msgstr "Szerokość linii"
+msgstr "Szerokość ramki"
 #: ../vector/v.label/main.c:234 ../imagery/i.class/main.c:90
 #: ../imagery/i.points/main.c:123
@@ -21520,7 +21486,7 @@
 #: ../vector/v.surf.rst/main.c:193
 msgid "Use scale dependent tension"
-msgstr ""
+msgstr "Użyj naciągnięcia zależnego od skali"
 #: ../vector/v.surf.rst/main.c:214
 msgid ""
@@ -21615,6 +21581,8 @@
 #: ../vector/v.surf.rst/main.c:456
 msgid "Using anisotropy - both theta and scalex have to be specified"
 msgstr ""
+"Podczas użycia anizotropii współczynniki 'theta' i 'scalex' muszą być "
+"określone"
 #: ../vector/v.surf.rst/main.c:464
 msgid "Both smatt and smooth options specified - using constant"
@@ -21724,13 +21692,12 @@
 msgstr ""
 #: ../vector/v.to.rast/main.c:38
-#, fuzzy
 msgid "vector, raster, conversion"
-msgstr "wekor, interpolacja"
+msgstr "wekor, raster, konwersja"
 #: ../vector/v.to.rast/main.c:39
 msgid "Converts a binary GRASS vector map layer into a GRASS raster map layer."
-msgstr ""
+msgstr "Konwertuje binarnÄ… mapÄ™ wektorowÄ… GRASS do mapy rastrowej GRASS."
 #: ../vector/v.to.rast/main.c:52
 #, fuzzy
@@ -21878,9 +21845,9 @@
 #: ../vector/v.to.rast/vect2rast.c:156
-#, fuzzy, c-format
+#, c-format
 msgid "Pass %d of %d:"
+msgstr ""
 #: ../vector/v.to.rast/vect2rast.c:164
 #, c-format
@@ -21963,7 +21930,7 @@
 #: ../vector/v.out.ogr/main.c:88
 msgid "Converts to one of the supported OGR vector formats."
-msgstr ""
+msgstr "Konwertuje do jednego z dostępnych formatów wektorowych OGR."
 #: ../vector/v.out.ogr/main.c:96
 msgid "Feature type. Combination of types is not supported by all formats."
@@ -21976,26 +21943,24 @@
 #: ../vector/v.out.ogr/main.c:106
 msgid "For example: ESRI Shapefile: filename or directory for storage"
-msgstr ""
+msgstr "Na przykład: ESRI Shapefile: nazwa pliku lub ścieżka przechowywania"
 #: ../vector/v.out.ogr/main.c:113
 msgid "OGR layer name. If not specified, input name is used."
-msgstr ""
+msgstr "Nazwa warstwy OGR. W przypadku braku, zostanie użyta nazwa wejściowa."
 #: ../vector/v.out.ogr/main.c:114
 msgid "For example: ESRI Shapefile: shapefile name"
-msgstr ""
+msgstr "Na przykład: ESRI Shapefile: nazwa pliku"
 #: ../vector/v.out.ogr/main.c:115 ../vector/v.out.ogr/main.c:128
 #: ../vector/v.out.ogr/main.c:138 ../vector/v.out.ogr/main.c:148
-#, fuzzy
 msgid "Creation"
-msgstr "Korelacja"
+msgstr "Tworzenie"
 #: ../vector/v.out.ogr/main.c:127
-#, fuzzy
 msgid "OGR format"
+msgstr "Format OGR"
 #: ../vector/v.out.ogr/main.c:137
 msgid "OGR dataset creation option (format specific, NAME=VALUE)"
@@ -22025,9 +21990,9 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:246
-#, fuzzy, c-format
+#, c-format
 msgid "OGR driver <%s> not found"
-msgstr "Nie odnaleziono sterownika %s"
+msgstr "Nie odnaleziono sterownika OGR <%s>"
 #: ../vector/v.out.ogr/main.c:263
 #, c-format
@@ -22042,9 +22007,8 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:303
-#, fuzzy
 msgid "Unable to create OGR layer"
-msgstr "Nie można utworzyć elewacji"
+msgstr "Nie można utworzyć warstwy OGR"
 #: ../vector/v.out.ogr/main.c:312
 msgid "No attribute table found -> using only category numbers as attributes"
@@ -22474,33 +22438,30 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:349
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] lines read from input"
-msgstr "Wczytano %d kategorii z mapy"
+msgstr "Wczytano [%d] linii"
 #: ../vector/v.lrs/v.lrs.segment/main.c:350
 #, c-format
 msgid "[%d] lines written to output map (%d lost)"
-msgstr ""
+msgstr "[%d] linii zapisanych do mapy wejściowej(%d utraconych)"
 #: ../vector/v.lrs/v.lrs.create/main.c:121
-#, fuzzy
 msgid "Create Linear Reference System"
-msgstr "Utwórz system lokalizacji liniowej"
+msgstr "Utwórz Linear Reference System"
 #: ../vector/v.lrs/v.lrs.create/main.c:130
 msgid "Output vector map where oriented lines are written"
-msgstr ""
+msgstr "Wyjściowa mapawektorowa gdzie zapisano linie"
 #: ../vector/v.lrs/v.lrs.create/main.c:135
-#, fuzzy
 msgid "Output vector map of errors"
-msgstr "Wyjściowa mapa rastrowa obszarów problemowych"
+msgstr "Wyjściowa mapa wektorowa błędów"
 #: ../vector/v.lrs/v.lrs.create/main.c:140
-#, fuzzy
 msgid "Input vector map containing reference points"
-msgstr "Mapa(y) wektorowa(e) zawierajÄ…ca(e) punkt(y) startowy(e)"
+msgstr "Wejściowa mapa zawierająca punkty referencyjne"
 #: ../vector/v.lrs/v.lrs.create/main.c:148
 #: ../vector/v.lrs/v.lrs.where/main.c:79
@@ -22510,11 +22471,11 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:155
 msgid "Column containing line identifiers for lines"
-msgstr ""
+msgstr "Kolumna zawierajÄ…ca identyfikatory liniowe dla linii"
 #: ../vector/v.lrs/v.lrs.create/main.c:162
 msgid "Column containing line identifiers for points"
-msgstr ""
+msgstr "Kolumna zawierająca identyfikatory liniowe dla punktów"
 #: ../vector/v.lrs/v.lrs.create/main.c:170
 msgid "Column containing milepost position for the beginning of next segment"
@@ -22542,55 +22503,50 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:229
-#, fuzzy
 msgid "Maximum distance of point to line allowed"
-msgstr "Jednostki odległości"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:276
-#, fuzzy
 msgid "Cannot get layer info for lines"
-msgstr "Nie można pobrać informacji o warstwie"
+msgstr "Nie można pobrać informacji warstwy dla linii"
 #: ../vector/v.lrs/v.lrs.create/main.c:279
-#, fuzzy
 msgid "Cannot get layer info for points"
-msgstr "Nie można pobrać informacji o warstwie dla mapy wektorowej"
+msgstr "Nie można pobrać informacji warstwy dla punktów"
 #: ../vector/v.lrs/v.lrs.create/main.c:314
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to drop table: %s"
-msgstr "Nie można otworzyć [%s]"
+msgstr "Nie można usunąć tabeli: [%s]"
 #: ../vector/v.lrs/v.lrs.create/main.c:333
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to select line id values from %s.%s."
-msgstr "Nie mozna otworzyć pliku wejściowego <%s@%s>."
+msgstr "Nie można wybrać wartości id linii z %s.%s."
 #: ../vector/v.lrs/v.lrs.create/main.c:343
-#, fuzzy
 msgid "Line id column must be integer"
-msgstr "Nie określono kolumny szerokości linii."
+msgstr "Lokumna id linii musi być integer "
 #: ../vector/v.lrs/v.lrs.create/main.c:354
 #: ../vector/v.lrs/v.lrs.create/main.c:456
-#, fuzzy
 msgid "Unable to fetch line id from line table"
+msgstr "Nie można odczytać id linii z tabeli linii"
 #: ../vector/v.lrs/v.lrs.create/main.c:406
 #, c-format
 msgid "Line [%d] without category (layer [%d])"
-msgstr ""
+msgstr "Linia [%d] nie posiada kategorii (warstwa[%d])"
 #: ../vector/v.lrs/v.lrs.create/main.c:426
 #, c-format
 msgid "No lines selected for line id [%d]"
-msgstr ""
+msgstr "Nie wybrano żadnych linii dla id linii [%d]"
 #: ../vector/v.lrs/v.lrs.create/main.c:446
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to select point attributes from <%s>"
+msgstr "Nie można wybrać atrybutów punktu z <%s>"
 #: ../vector/v.lrs/v.lrs.create/main.c:477
 #, c-format
@@ -22603,9 +22559,9 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:525
-#, fuzzy, c-format
+#, c-format
 msgid "Point [%d] without category (layer [%d])"
-msgstr "Edytować plik kategorii dla [%s]? "
+msgstr "Punkt [%d] nie posiada kategorii (warstwa[%d])"
 #: ../vector/v.lrs/v.lrs.create/main.c:572
 #, c-format
@@ -22782,9 +22738,8 @@
 msgstr "wekor, projekcja"
 #: ../vector/v.proj/main.c:64
-#, fuzzy
 msgid "Allows projection conversion of vector maps."
-msgstr "Lokacja mapy wejściowej"
+msgstr "Umożliwia zmianę projekcji map wektorowych."
 #: ../vector/v.proj/main.c:76
 #, fuzzy
@@ -22988,7 +22943,7 @@
 #: ../vector/v.to.3d/main.c:38
 msgid "Performs transformation of 2D vector features to 3D."
-msgstr ""
+msgstr "Transformuje obiekty wektorowe 2D do obiektów 3D."
 #: ../vector/v.to.3d/main.c:51
 #, fuzzy, c-format
@@ -23378,9 +23333,8 @@
 msgstr "Wczytywanie plika wektorowego..."
 #: ../ps/ps.map/r_group.c:31
-#, fuzzy
 msgid "Can't get group information"
+msgstr "Nie można pobrać informacji o grupie"
 #: ../ps/ps.map/map_setup.c:88
 #, c-format
@@ -23510,8 +23464,9 @@
 msgstr ""
 #: ../misc/m.cogo/main.c:225
+#, fuzzy
 msgid "miscellaneous"
-msgstr ""
+msgstr "Różne"
 #: ../misc/m.cogo/main.c:226
 msgid ""
@@ -23520,8 +23475,9 @@
 msgstr ""
 #: ../misc/m.cogo/main.c:228
+#, fuzzy
 msgid "It assumes a cartesian coordinate system"
-msgstr ""
+msgstr "Przelicza kąty i odległości do współrzędnych i odwrotnie."
 #: ../misc/m.cogo/main.c:232
 msgid "Lines are labelled"
@@ -24442,18 +24398,16 @@
 msgstr ""
 #: ../imagery/i.rectify/main.c:84
-#, fuzzy
 msgid "imagery, rectify"
-msgstr "grupa obrazów"
+msgstr "grupa obrazów, rektyfikuj"
 #: ../imagery/i.rectify/main.c:86
-#, fuzzy
 msgid ""
 "Rectifies an image by computing a coordinate transformation for each pixel "
 "in the image based on the control points."
 msgstr ""
-"Rektyfikuje (poprawia geometriÄ™) obraz poprzez obliczenie transformacji "
-"współrzędnych,dla każdego piksela obrazu, opartej na punktach kontrolnych"
+"Rektyfikuje obraz poprzez obliczenie transformacji współrzędnych dla każdego "
+"piksela obrazu (oparte na punktach kontrolnych)."
 #: ../imagery/i.rectify/main.c:100
 #, fuzzy
@@ -24483,16 +24437,14 @@
 msgstr ""
 #: ../imagery/i.rectify/main.c:143
-#, fuzzy, c-format
+#, c-format
 msgid "Group <%s> does not exist"
-msgstr ""
-"\n"
-"grupy <%s> nie znaleziono"
+msgstr "Grupa <%s>  nie istnieje"
 #: ../imagery/i.rectify/main.c:146
-#, fuzzy, c-format
+#, c-format
 msgid "Group <%s> contains no raster maps; run i.group"
-msgstr "Grupa [%s] nie zawiera żadnych plików"
+msgstr "Grupa <%s> nie zawiera żadnych plików, użyj i.group"
 #: ../imagery/i.rectify/main.c:205
 #, c-format
@@ -24681,9 +24633,9 @@
 msgstr "Przedział mniejszy lub równy zero niedozwolony."
 #: ../imagery/i.fft/fftmain.c:166
-#, fuzzy, c-format
+#, c-format
 msgid "Reading the raster map <%s>..."
 #: ../imagery/i.fft/fftmain.c:182
 msgid "Starting FFT..."
@@ -25568,7 +25520,7 @@
 #: ../imagery/i.target/main.c:47
 msgid "Targets an imagery group to a GRASS location and mapset."
-msgstr "Ładuje grupę obrazów do lokacji i mapsetu GRASS'a."
+msgstr "Ładuje grupę obrazów do lokacji i mapsetu GRASS-a."
 #: ../imagery/i.target/main.c:56
 msgid "Name of imagery target location"
@@ -25658,9 +25610,8 @@
 msgstr ""
 #: ../visualization/ximgview/main.c:279
-#, fuzzy
 msgid "Image file"
-msgstr "Grupa obrazów"
+msgstr "Plik obrazu"
 #: ../visualization/ximgview/main.c:286
 msgid "Percentage of CPU time to use"
@@ -25692,7 +25643,7 @@
 #: ../visualization/nviz/src/nviz_init.c:54
 msgid "nviz - Visualization and animation tool for GRASS data."
-msgstr ""
+msgstr "NVIZ - narzędzie do wizualizacji i animacji danych GRASS-a."
 #: ../visualization/nviz/src/nviz_init.c:59
 #, fuzzy
@@ -25726,9 +25677,8 @@
 msgstr "Plik rastrowy punktów początkowych"
 #: ../visualization/nviz/src/nviz_init.c:95
-#, fuzzy
 msgid "Name of existing 3d raster map"
-msgstr "Nazwa mapy rastrowej"
+msgstr "Nazwa istniejÄ…cej mapy rastrowej 3D"
 #: ../visualization/nviz/src/nviz_init.c:100
 msgid "Quickstart - Do not load any data"
@@ -25775,7 +25725,7 @@
 #: ../visualization/nviz2/cmd/main.c:46
 msgid "visualization, raster, vector, raster3d"
-msgstr ""
+msgstr "wizualizacja,raster,wektor,raster3d"
 #: ../visualization/nviz2/cmd/main.c:47
 msgid "Experimental NVIZ CLI prototype."
@@ -26436,7 +26386,7 @@
 "\n"
 msgstr ""
 "\n"
-"Kliknij na wybranej lokalizacji\n"
+"Kliknij na wybranej lokacji\n"
 "\n"
 #: ../display/d.what.vect/what.c:517
@@ -26469,7 +26419,7 @@
 #: ../display/d.what.vect/main.c:74 ../display/d.what.rast/main.c:94
 msgid "Identify just one location"
-msgstr "Identyfikuj tylko jednÄ… lokalizacjÄ™"
+msgstr "Identyfikuj tylko jednÄ… lokacjÄ™"
 #: ../display/d.what.vect/main.c:85
 msgid "Name of existing vector map"
@@ -26930,7 +26880,7 @@
 #: ../display/d.legend/main.c:134
 msgid "Placement as percentage of screen coordinates (0,0 is lower left)"
-msgstr "Lokalizacja jako procent współrzędnych okna (0,0 to dolny lewy róg)"
+msgstr "Lokacja jako procent współrzędnych okna (0,0 to dolny lewy róg)"
 #: ../display/d.legend/main.c:144
 msgid "List of discrete category numbers/values for legend"
@@ -27447,7 +27397,7 @@
 msgid ""
 "Displays charts of vector data in the active frame on the graphics monitor."
 msgstr ""
-"Wyświetla wykresy dla danych wektorowych GRASS'a w aktywnej ramce "
+"Wyświetla wykresy dla danych wektorowych GRASS-a w aktywnej ramce "
 "wyświetlania w monitorze wyświetlania"
 #: ../display/d.vect.chart/main.c:82
@@ -27976,8 +27926,7 @@
 "parameters defined in current location (if available)"
 msgstr ""
 "Wyjściowe współrzędne odniesione do elipsoidy WGS84 z użyciem parametrów "
-"transformacji układu zdefiniowanych w bieżącej lokalizacji (jeśli są "
-"dostępne)"
+"transformacji układu zdefiniowanych w bieżącej lokacji (jeśli są dostępne)"
 #: ../display/d.where/main.c:69
 msgid "Output frame coordinates of current display monitor (percentage)"
@@ -27994,15 +27943,15 @@
 #: ../display/d.where/main.c:93 ../general/g.region/printwindow.c:248
 #: ../general/g.region/printwindow.c:489 ../general/g.region/printwindow.c:608
 msgid "Can't get projection info of current location"
 #: ../display/d.where/main.c:122
 msgid ""
 "WGS84 output not possible as this location does not contain\n"
 "datum transformation parameters. Try running g.setproj."
 msgstr ""
-"Utworzenie projekcji WGS84 nie było możliwe, lokalizacjanie posiada "
-"parametrów transformacji układu. Spróbuj uruchomić g.setproj."
+"Utworzenie projekcji WGS84 nie było możliwe, lokacja nie posiada parametrów "
+"transformacji układu. Spróbuj uruchomić g.setproj."
 #: ../display/d.paint.labels/do_labels.c:142
 #, c-format
@@ -28077,7 +28026,7 @@
 #: ../display/d.barscale/main.c:106
 #, c-format
 msgid "%s does not work with a latitude-longitude location"
 #: ../display/d.barscale/main.c:114
 msgid "Choose either -n or -s flag"
@@ -28944,15 +28893,15 @@
 #: ../general/g.gisenv/main.c:45
 msgid "GRASS variable to get"
-msgstr "Pobieranie zmiennych GRASS'a"
+msgstr "Pobieranie zmiennych GRASS-a"
 #: ../general/g.gisenv/main.c:52
 msgid "GRASS variable to set"
-msgstr "Zmienna GRASS'a do ustawienia"
+msgstr "Zmienna GRASS-a do ustawienia"
 #: ../general/g.gisenv/main.c:61
 msgid "Where GRASS variable is stored"
-msgstr "Gdzie zmienna GRASS'a jest zdeponowana"
+msgstr "Gdzie zmienna GRASS-a jest zdeponowana"
 #: ../general/g.gisenv/main.c:66
 msgid "Use shell syntax (for \"eval\")"
@@ -28968,7 +28917,7 @@
 #: ../general/g.access/main.c:39
 msgid "Controls access to the current mapset for other users on the system."
-msgstr ""
+msgstr "Kontrola dostępu innych użytkowników do bieżącego mapsetu."
 #: ../general/g.access/main.c:46
 msgid "Access for group"
@@ -29172,9 +29121,8 @@
 msgstr "Nazwa pliku wyjściowego"
 #: ../general/g.pnmcomp/main.c:323
-#, fuzzy
 msgid "Image width"
+msgstr "Szerokość obrazu"
 #: ../general/g.pnmcomp/main.c:329
 msgid "Image height"
@@ -29185,9 +29133,8 @@
 msgstr ""
 #: ../general/g.proj/input.c:82
-#, fuzzy
 msgid "Error reading WKT projection description"
-msgstr "Błąd podczas odczytu rzędu danych"
+msgstr "Błąd podczas czytania opisu projekcji WKT"
 #: ../general/g.proj/input.c:89
 #, c-format
@@ -29199,9 +29146,8 @@
 msgstr "Nie można dokonać interpretacji ciągu parametrów stylu-PROJ.4"
 #: ../general/g.proj/input.c:172
-#, fuzzy
 msgid "Unable to translate EPSG code"
+msgstr "Nie można przełożyć kodu EPSG"
 #: ../general/g.proj/input.c:209
 msgid "Trying to open with OGR..."
@@ -29313,7 +29259,7 @@
 #: ../general/g.proj/main.c:64
 msgid "Print projection information (in conventional GRASS format)"
-msgstr "Wyświetla informację o projekcji (w konwencjonalnym formacie GRASS'a)"
+msgstr "Wyświetla informację o projekcji (w konwencjonalnym formacie GRASS-a)"
 #: ../general/g.proj/main.c:70
 msgid "Verify datum information and print transformation parameters"
@@ -29345,19 +29291,16 @@
 "Plik danych referencyjnych z którego ma być odczytana informacja o projekcji"
 #: ../general/g.proj/main.c:111
-#, fuzzy
 msgid "ASCII file containing a WKT projection description (- for stdin)"
-msgstr ""
-"Plik ASCII zawierający pojedyńczą linię opisu projekcji WKT (- dla stdin)"
+msgstr "Plik ASCII zawierajÄ…cy opis projekcji WKT (- dla stdin)"
 #: ../general/g.proj/main.c:120
 msgid "PROJ.4 projection description (- for stdin)"
-msgstr "opis projekci PROJ.4 (- dla stdin)"
+msgstr "Opis projekcji PROJ.4 (- dla stdin)"
 #: ../general/g.proj/main.c:128
-#, fuzzy
 msgid "EPSG projection code"
-msgstr "Metoda reprojekcji"
+msgstr "Kod EPSG projekcji"
 #: ../general/g.proj/main.c:138
 msgid ""
@@ -29381,14 +29324,14 @@
 #: ../general/g.proj/main.c:160
 msgid "Name of new location to create"
-msgstr "Nazwa nowej lokalizacji która ma być utworzona"
+msgstr "Nazwa nowej lokacji, która ma być utworzona"
 #: ../general/g.proj/main.c:165
 msgid "Enable interactive prompting (for command-line use only)"
 msgstr ""
 #: ../general/g.proj/main.c:183
-#, fuzzy, c-format
+#, c-format
 msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
 msgstr "Tylko jedna z opcji '%s', '%s' lub '%s' może być określona"
@@ -29537,7 +29480,7 @@
 #: ../general/g.filename/main.c:40
 msgid "Prints GRASS data base file names."
-msgstr "Wyświetla nazwy plików bazy danych GRASS'a"
+msgstr "Wyświetla nazwy plików bazy danych GRASS-a"
 #: ../general/g.filename/main.c:54
 msgid "Name of a database file"
@@ -29548,9 +29491,8 @@
 msgstr "Nazwa mapsetu (domyślnie: bieżący)"
 #: ../general/g.region/main.c:70
-#, fuzzy
 msgid "Manages the boundary definitions for the geographic region."
-msgstr "Program do zarządzania definicjami granic regionów geograficznych."
+msgstr "Definiowanie granic geograficznych obszaru roboczego."
 #: ../general/g.region/main.c:77 ../general/g.region/main.c:82
 #: ../general/g.region/main.c:158 ../general/g.region/main.c:165
@@ -29772,8 +29714,8 @@
 "WGS84 output not possible as this location does not contain datum "
 "transformation parameters. Try running g.setproj."
 msgstr ""
-"Utworzenie projekcji WGS84 nie było możliwe, lokalizacja nie posiada "
 #: ../general/g.region/printwindow.c:769
 msgid "Lat/Long calculations are not possible from a simple XY system"
@@ -29869,18 +29811,16 @@
 msgstr ""
 #: ../general/g.version/main.c:35
-#, fuzzy
 msgid "Displays version and copyright information."
-msgstr "Wyswietla informacje o wersji i prawach autorskich"
+msgstr "Wyświetla numer wersji i informację o prawach autorskich."
 #: ../general/g.version/main.c:39
-#, fuzzy
 msgid "Print the copyright message"
-msgstr "Wyświetl również wiadomość o prawach autorskich"
+msgstr "Wyświetl informację prawach autorskich"
 #: ../general/g.version/main.c:43
 msgid "Print the GRASS build information"
-msgstr "Wyświetl informacje o kompilacji GRASS'a"
+msgstr "Wyświetl informacje o kompilacji GRASS-a"
 #: ../general/g.setproj/main.c:78
 #, fuzzy
@@ -29890,7 +29830,7 @@
 #: ../general/g.setproj/main.c:80
 #, fuzzy
 msgid "Interactively reset the location's projection settings."
 #: ../general/g.setproj/main.c:87
 msgid "You must be in the PERMANENT mapset to run g.setproj"
@@ -30050,7 +29990,7 @@
 msgstr ""
 "\n"
 "\n"
-"UWAGA!  Plik odwzorowania już istnieje w tej lokalizacji\n"
+"UWAGA!  Plik odwzorowania już istnieje w tej lokacji\n"
 #: ../general/g.setproj/main.c:646
 #, fuzzy
@@ -30106,9 +30046,8 @@
 msgstr ""
 #: ../general/g.mapset/main.c:49
-#, fuzzy
 msgid "Change current mapset."
-msgstr "Zmień bieżący mapset"
+msgstr "Zmień bieżący mapset."
 #: ../general/g.mapset/main.c:56
 msgid "New MAPSET name"
@@ -30116,11 +30055,11 @@
 #: ../general/g.mapset/main.c:63
 msgid "New LOCATION name (not location path)"
-msgstr "Nowa nazwa LOKALIZACJI (nie ścieżka dostępu)"
+msgstr "Nowa nazwa LOKACJI (nie ścieżka dostępu)"
 #: ../general/g.mapset/main.c:71
 msgid "New GISDBASE (full path to the directory where the new location is)"
-msgstr "Nowe GISDBASE (pełna ścieżka dostępu do nowej lokalizacji)"
+msgstr "Nowe GISDBASE (pełna ścieżka dostępu do nowej lokacji)"
 #: ../general/g.mapset/main.c:75
 msgid "Create mapset if it doesn't exist"
@@ -30132,19 +30071,17 @@
 msgstr "Lista dostępnych mapsetów"
 #: ../general/g.mapset/main.c:86
-#, fuzzy
 msgid "Either mapset= or -l must be used"
-msgstr "Należy określić 2 warstwy"
+msgstr "Musi być użyte mapset= lub -l"
 #: ../general/g.mapset/main.c:132
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> is already the current mapset"
-msgstr "%s jest już bieżącym mapsetem"
+msgstr "<%s> jest już bieżącym mapsetem"
 #: ../general/g.mapset/main.c:140
-#, fuzzy
 msgid "You don't have permission to use this mapset"
-msgstr "Nie masz uprawnienie do korzystania z tego mapsetu."
+msgstr "Nie masz uprawnienia do korzystania z tego mapsetu"
 #: ../general/g.mapset/main.c:149
 msgid "The mapset does not exist. Use -c flag to create it."
@@ -30168,9 +30105,8 @@
 msgstr "Zapiywanie %s ..."
 #: ../general/g.mapset/main.c:192
-#, fuzzy
 msgid "Cleaning up temporary files..."
-msgstr "Torzenie plików tymczasowych ..."
+msgstr "Czyszczenie plików tymczasowych..."
 #: ../general/g.mapset/main.c:206
 msgid "Your shell continues to use the history for the old mapset"
@@ -30235,7 +30171,7 @@
 #: ../general/g.mremove/main.c:104 ../general/g.mlist/main.c:155
 msgid "-r and -e are mutually exclusive"
-msgstr ""
+msgstr "-r i -e wzajemnie siÄ™ wykluczajÄ…"
 #: ../general/g.mremove/main.c:107
 msgid "The following files would be deleted:"
@@ -30243,9 +30179,9 @@
 #: ../general/g.mremove/main.c:130 ../general/g.mlist/main.c:164
 #: ../general/g.mlist/main.c:175
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to compile regular expression %s"
+msgstr "Nie można skompilować wyrażenia regularnego %s"
 #: ../general/g.mremove/main.c:158
 msgid "You must use the force flag to actually remove them. Exiting."
@@ -31779,7 +31715,7 @@
 #~ msgstr "Nie można otworzyć <%s>"
 #~ msgid "Prints and manipulates GRASS projection information files."
-#~ msgstr "Wyświetla i manipuluje plikami informacji o projekcjach GRASS'a."
+#~ msgstr "Wyświetla i manipuluje plikami informacji o projekcjach GRASS-a."
 #~ msgid "ERROR: <%s> illegal name\n"
 #~ msgstr "BŁĄD: <%s> niewłaściwa nazwa\n"
@@ -32479,9 +32415,8 @@
 #~ msgid "List fonts (default; provided for compatibility with d.font)"
 #~ msgstr "Tryb komend (Kompatybilność z d.text)"
-#, fuzzy
 #~ msgid "Input file"
-#~ msgstr "Plik wejściowy DXF"
+#~ msgstr "Plik wejściowy"
 #, fuzzy
 #~ msgid "Unable to read range for %s"
@@ -32509,9 +32444,8 @@
 #~ msgid "Range file for <%s> not available"
 #~ msgstr "Plik kategorii dla <%s> jest niedostępny"
-#, fuzzy
 #~ msgid "Only one of -%c, -%c, -%c, -%c or -%c flags may be specified"
-#~ msgstr "Tylko jedna z opcji '%s', '%s' lub '%s' może być określona"
+#~ msgstr "Tylko jedna z flag -%c, -%c, -%c, -%c or -%c może być określona"
 #, fuzzy
 #~ msgid "Unable to open training map <%s>"
@@ -32992,7 +32926,6 @@
 #~ msgid "Map <%s> is the wrong resolution"
 #~ msgstr "[%s]: Mapa ma złą rozdzielczość"
-#, fuzzy
 #~ msgid "Error reading row %d (error = %d)"
 #~ msgstr "Błąd podczas odczytu rzędu  %d danych"
@@ -33048,9 +32981,8 @@
 #~ msgid "Unable to open cover map <%s>"
 #~ msgstr "Nie można otworzyć mapy wektorowej <%s>"
-#, fuzzy
 #~ msgid "Computing histograms"
-#~ msgstr "Oblicza biny"
+#~ msgstr "Oblicza histogramy"
 #, fuzzy
 #~ msgid "Printing quantiles"
@@ -33064,7 +32996,6 @@
 #~ msgid "Writing output maps"
 #~ msgstr "Zapis do mapy ..."
-#, fuzzy
 #~ msgid "Resultant raster map(s)"
 #~ msgstr "Wynikowa mapa rastrowa"
@@ -33391,3 +33322,23 @@
 #, fuzzy
 #~ msgid "Right: "
 #~ msgstr "Prawy: wyjdź\n"
+#~ msgid ""
+#~ "Georeference, rectify, and import Terra-ASTER imagery and relative DEM's "
+#~ "using gdalwarp."
+#~ msgstr ""
+#~ "Nadaje georeferencje, rektifikuje i importuje zobrazowania w formacie "
+#~ "Terra-ASTER i zwiÄ…zane DEM przy pomocy gdalwarp."
+#~ msgid "Make null cells opaque"
+#~ msgstr "Ustaw komórki NULL jako nieprzezroczyste"
+#~ msgid "Flip horizontally"
+#~ msgstr "Odbij poziomo"
+#~ msgid "Flip vertically"
+#~ msgstr "Odbij pionowo"
+#, fuzzy
+#~ msgid "parse error"
+#~ msgstr "raster"
Modified: grass/branches/develbranch_6/locale/po/grasstcl_pl.po
--- grass/branches/develbranch_6/locale/po/grasstcl_pl.po	2009-10-28 23:28:04 UTC (rev 39640)
+++ grass/branches/develbranch_6/locale/po/grasstcl_pl.po	2009-10-28 23:28:37 UTC (rev 39641)
@@ -2,15 +2,16 @@
 # This file is distributed under the same license as the GRASS package.
 # Artur Nie¶cior <nieart at interia.pl>, 2005, 2006, 2007.
+# Milena Nowotarska <do.milenki*gmail.com>, 2008, 2009.
 msgid ""
 msgstr ""
 "Project-Id-Version: grasstcl_pl\n"
 "Report-Msgid-Bugs-To: \n"
-"PO-Revision-Date: 2008-11-11 01:36+0100\n"
+"PO-Revision-Date: 2009-10-28 23:20+0100\n"
 "Last-Translator: Milena Nowotarska <do.milenki*gmail.com>\n"
-"Language-Team: Polska <translation at grass.itc.it>\n"
+"Language-Team: Polish <grass-translations at lists.osgeo.org>\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=ISO-8859-2\n"
 "Content-Transfer-Encoding: 8bit\n"
@@ -315,9 +316,8 @@
 msgstr "Opcje"
 #: ../lib/gis/gui.tcl:361
-#, fuzzy
 msgid "Required"
-msgstr "wymagane"
+msgstr "Wymagane"
 #: ../lib/gis/gui.tcl:469 ../gui/tcltk/gis.m/gmmenu.tcl:170
 msgid "Copy"
@@ -388,7 +388,7 @@
 #: ../lib/gis/gui.tcl:583
 msgid "multiple"
-msgstr ""
+msgstr "wiele"
 #: ../lib/init/epsg_option.tcl:93
 msgid "WARNING: cant get enviromental variable"
@@ -1100,14 +1100,12 @@
 msgstr "Zapisz legendê do pliku EPS"
 #: ../gui/tcltk/gis.m/profile.tcl:54
-#, fuzzy
 msgid "Raster map for profile"
-msgstr "Legenda dla mapy rastrowej"
+msgstr "Mapa rastrowa do wykonania profilu"
 #: ../gui/tcltk/gis.m/profile.tcl:77
-#, fuzzy
 msgid "Profile Window"
-msgstr "Analizy profilu"
+msgstr "Okno profilu"
 #: ../gui/tcltk/gis.m/profile.tcl:110
 msgid ""
@@ -1236,9 +1234,9 @@
 msgstr "Witaj w GRASS GIS"
 #: ../gui/tcltk/gis.m/gm.tcl:295
-#, fuzzy, tcl-format
+#, tcl-format
 msgid "Map Display %d"
-msgstr "Wy¶wietl: "
+msgstr "Wy¶wietl mapê %d"
 #: ../gui/tcltk/gis.m/gm.tcl:320
 #, tcl-format
@@ -1275,14 +1273,12 @@
 msgstr "Uruchom (w Xterm)"
 #: ../gui/tcltk/gis.m/runandoutput.tcl:129
-#, fuzzy
 msgid " Save "
-msgstr "Zapisz"
+msgstr " Zapisz "
 #: ../gui/tcltk/gis.m/runandoutput.tcl:131
-#, fuzzy
 msgid " Clear "
-msgstr "Wyczy¶æ"
+msgstr " Wyczy¶æ "
 #: ../gui/tcltk/gis.m/runandoutput.tcl:152
 msgid "Output - GIS.m"
@@ -1587,22 +1583,18 @@
 "Wybierz mapy do animacji w jednym lub wiêcej okien (jedno okno wymagane)"
 #: ../gui/tcltk/gis.m/animate.tcl:492
-#, fuzzy
 msgid "Maps for frame 1 (required): "
 msgstr "Mapy dla okna 1 (wymagane):"
 #: ../gui/tcltk/gis.m/animate.tcl:503
-#, fuzzy
 msgid "Maps for frame 2 (optional): "
 msgstr "Mapy dla okna 2 (opcjonalne):"
 #: ../gui/tcltk/gis.m/animate.tcl:514
-#, fuzzy
 msgid "Maps for frame 3 (optional): "
 msgstr "Mapy dla okna 3 (opcjonalne):"
 #: ../gui/tcltk/gis.m/animate.tcl:525
-#, fuzzy
 msgid "Maps for frame 4 (optional): "
 msgstr "Mapy dla okna 4 (opcjonalne):"
@@ -1612,7 +1604,6 @@
 msgstr "Zastosuj"
 #: ../gui/tcltk/gis.m/animate.tcl:563
-#, fuzzy
 msgid "You must select maps to animate for frame 1"
 msgstr "Musisz wybraæ mapy do animacji w oknie 1"
@@ -1893,9 +1884,8 @@
 msgstr "Pliki Matlab i MapGen"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:125
-#, fuzzy
 msgid "Import grid 3D volume"
-msgstr "Zarz±dzaj znacznikami czasu dla bry³ grid3D"
+msgstr "Import grid 3D volume"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:126 ../gui/tcltk/gis.m/gmmenu.tcl:163
 msgid "ASCII 3D"
@@ -1969,9 +1959,8 @@
 msgstr "SVG"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:162
-#, fuzzy
 msgid "Export grid 3D volume"
-msgstr "Export grid3D volume"
+msgstr "Eksport do grid3D volume"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:167
 #, fuzzy
@@ -2007,14 +1996,12 @@
 msgstr "Mapa rastrowa do mapy wektorowej"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:182
-#, fuzzy
 msgid "Raster series to volume"
-msgstr "Seria map rastrowych do bry³y 3D"
+msgstr "Seria map rastrowych do bry³y rastrowej 3D"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:183
-#, fuzzy
 msgid "Raster 2.5D to volume"
-msgstr "Mapa rastrowa do bry³y 3D"
+msgstr "Mapa rastrowa 2,5D do bry³y rastrowej 3D"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:185 ../gui/tcltk/d.m/menu.tcl:163
 msgid "Vector to raster"
@@ -2025,12 +2012,10 @@
 msgstr "Wektor do 3D"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:187
-#, fuzzy
 msgid "Sites to vector"
-msgstr "Stary format punktowy Sites (GRASS 5.x) do wektora"
+msgstr "Punkty do wektora"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:189
-#, fuzzy
 msgid "Volume to raster series"
 msgstr "Bry³y 3D do serii map rastrowych"
@@ -2044,7 +2029,7 @@
 #: ../gui/tcltk/gis.m/gmmenu.tcl:196
 msgid "Bearing/distance to coordinates"
-msgstr ""
+msgstr "K±ty/odleg³o¶ci do wspó³rzêdnych"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:198
 msgid "3D rendering"
@@ -2154,11 +2139,11 @@
 #: ../gui/tcltk/gis.m/gmmenu.tcl:239
 msgid "Quantization"
-msgstr ""
+msgstr "Kwantyzacja"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:240
 msgid "Timestamps"
-msgstr ""
+msgstr "Znaczniki czasu"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:242 ../gui/tcltk/d.m/menu.tcl:233
 msgid "Resample using aggregate statistics"
@@ -2202,17 +2187,17 @@
 msgstr "Tabele kolorów"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:255
-#, fuzzy
 msgid "Color tables (stddev)"
-msgstr "Tabele kolorów"
+msgstr "Tabele kolorów (stddev)"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:256
 msgid "Color rules"
 msgstr "Regu³y kolorów"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:258
+#, fuzzy
 msgid "Blend"
-msgstr ""
+msgstr "Dorównaæ"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:259
 msgid "Create RGB"
@@ -2288,7 +2273,7 @@
 #: ../gui/tcltk/gis.m/gmmenu.tcl:282
 msgid "Shadows map"
-msgstr ""
+msgstr "Mapa cieniowana"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:284 ../gui/tcltk/d.m/menu.tcl:273
 msgid "Terrain analysis"
@@ -2307,9 +2292,8 @@
 msgstr ""
 #: ../gui/tcltk/gis.m/gmmenu.tcl:289
-#, fuzzy
 msgid "Shaded relief"
-msgstr "Cieniowanie rze¼by terenu"
+msgstr "Mapa cieniowanego reliefu"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:291 ../gui/tcltk/d.m/menu.tcl:279
 msgid "Slope and aspect"
@@ -2334,7 +2318,7 @@
 #: ../gui/tcltk/gis.m/gmmenu.tcl:298
 msgid "Horizon"
-msgstr ""
+msgstr "Horyzont"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:300 ../gui/tcltk/d.m/menu.tcl:285
 msgid "Transform features"
@@ -2345,7 +2329,6 @@
 msgstr ""
 #: ../gui/tcltk/gis.m/gmmenu.tcl:302
-#, fuzzy
 msgid "Grow"
 msgstr "Zrób grubsze"
@@ -2470,8 +2453,9 @@
 msgstr "Uzupe³niaj (³ataj) mapy sob± nawzajem"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:350
+#, fuzzy
 msgid "Dominance's diversity"
-msgstr ""
+msgstr "Dominanceova diverzita"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:351
 msgid "Shannon's diversity"
@@ -2578,9 +2562,8 @@
 msgstr "Wygeneruj krzywiznê Gaussa powierzchni."
 #: ../gui/tcltk/gis.m/gmmenu.tcl:388
-#, fuzzy
 msgid "Plane"
-msgstr "Przesuñ"
+msgstr "P³aszczyzna"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:390
 #, fuzzy
@@ -2691,9 +2674,8 @@
 msgstr "Kowariancja/korelacja"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:424
-#, fuzzy
 msgid "Linear regression"
-msgstr "Regresja liniowa pomiêdzy dwiema mapami"
+msgstr "Regresja linearna"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:425
 msgid "Mutual category occurences"
@@ -2819,13 +2801,12 @@
 msgstr "Lokalizacja liniowa dla wektorów"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:473
-#, fuzzy
 msgid "Create LRS"
 msgstr "Utwórz LRS"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:474
 msgid "Create stationing"
-msgstr ""
+msgstr "Utwórz stationing"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:475
 msgid "Create points/segments"
@@ -2852,7 +2833,6 @@
 msgstr "Utrzymanie sieci"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:482
-#, fuzzy
 msgid "Visibility network"
 msgstr "Linie widoczno¶ci"
@@ -2909,7 +2889,7 @@
 #: ../gui/tcltk/gis.m/gmmenu.tcl:506
 msgid "Convex hull"
-msgstr ""
+msgstr "Otoczka wypuk³a"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:507
 msgid "Delaunay triangles"
@@ -3059,7 +3039,7 @@
 #: ../gui/tcltk/gis.m/gmmenu.tcl:566
 msgid "Input for supervised MLC"
-msgstr ""
+msgstr "Input dla nadzorowanej klasifikacji MLC"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:567
 msgid "Input for supervised SMAP"
@@ -3075,7 +3055,7 @@
 #: ../gui/tcltk/gis.m/gmmenu.tcl:571
 msgid "Matrix/convolving filter"
-msgstr ""
 #: ../gui/tcltk/gis.m/gmmenu.tcl:573 ../gui/tcltk/d.m/menu.tcl:511
 msgid "Spectral response"
@@ -3119,7 +3099,7 @@
 #: ../gui/tcltk/gis.m/gmmenu.tcl:588
 msgid "&Volumes"
-msgstr ""
+msgstr "Raster 3d (volumes)"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:589 ../gui/tcltk/d.m/menu.tcl:530
 msgid "Develop grid3D volumes"
@@ -3135,7 +3115,7 @@
 #: ../gui/tcltk/gis.m/gmmenu.tcl:593
 msgid "3D MASK"
-msgstr ""
+msgstr "Maska 3D"
 #: ../gui/tcltk/gis.m/gmmenu.tcl:594
 msgid "3D Map calculator"
@@ -3365,9 +3345,8 @@
 msgstr ""
 #: ../gui/tcltk/gis.m/gmlib.tcl:86 ../gui/tcltk/gis.m/gmlib.tcl:116
-#, fuzzy
 msgid "All Files"
-msgstr "Plik Koloru"
+msgstr "Wszystkie pliki"
 #: ../gui/tcltk/gis.m/gmlib.tcl:90
 msgid "Open File"
@@ -3427,20 +3406,19 @@
 #: ../gui/tcltk/gis.m/dnviz.tcl:178
 msgid "Camera layback distance (in map units)"
-msgstr ""
+msgstr "Odleg³o¶æ po³o¿enia kamery (w jednostkach mapy)"
 #: ../gui/tcltk/gis.m/dnviz.tcl:180
-#, fuzzy
 msgid "Camera height "
-msgstr "  wysoko¶æ:"
+msgstr "Wysoko¶æ kamery"
 #: ../gui/tcltk/gis.m/dnviz.tcl:181
 msgid "Camera height above terrain"
-msgstr ""
+msgstr "Wysokosæ po³o¿enia kamery ponad terenem"
 #: ../gui/tcltk/gis.m/dnviz.tcl:188
 msgid "Number of frames "
-msgstr ""
+msgstr "Liczba klatek"
 #: ../gui/tcltk/gis.m/dnviz.tcl:189
 msgid "Number of frames to create for flythrough"
@@ -3460,7 +3438,7 @@
 #: ../gui/tcltk/gis.m/dnviz.tcl:201
 msgid "Full render (save images)"
-msgstr ""
+msgstr "Pe³ny rendering (zapisz obrazy)"
 #: ../gui/tcltk/gis.m/dnviz.tcl:203
 msgid "Render images offscreen"
@@ -3476,12 +3454,10 @@
 msgstr "Plik Wyj¶ciowy"
 #: ../gui/tcltk/gis.m/dnviz.tcl:219 ../gui/tcltk/gis.m/rules.tcl:147
-#, fuzzy
 msgid "Overwrite existing file"
-msgstr "nadpisz istniej±cy"
+msgstr "Nadpisz istniej±cy plik"
 #: ../gui/tcltk/gis.m/dnviz.tcl:224
-#, fuzzy
 msgid "Reset"
 msgstr "Reset"
@@ -3787,12 +3763,10 @@
 msgstr "Rysuj linie:"
 #: ../gui/tcltk/gis.m/maplabels.tcl:240
-#, fuzzy
 msgid "Border width:"
 msgstr "Szeroko¶æ ramki"
 #: ../gui/tcltk/gis.m/maplabels.tcl:243
-#, fuzzy
 msgid "Border color:"
 msgstr "Kolor obramowania "
@@ -3802,7 +3776,7 @@
 #: ../gui/tcltk/gis.m/maplabels.tcl:253
 msgid " Vertical: "
-msgstr ""
+msgstr "Pionowy"
 #: ../gui/tcltk/gis.m/maplabels.tcl:261
 msgid "Font"
@@ -3814,7 +3788,7 @@
 #: ../gui/tcltk/gis.m/maplabels.tcl:266
 msgid "family:"
-msgstr ""
+msgstr "Rodzina:"
 #: ../gui/tcltk/gis.m/maplabels.tcl:269
 msgid "size:"
@@ -4176,7 +4150,7 @@
 #: ../gui/tcltk/gis.m/vector.tcl:525
 msgid " or <"
-msgstr ""
+msgstr "lub <"
 #: ../gui/tcltk/gis.m/cmd.tcl:115 ../gui/tcltk/d.m/cmd.tcl:52
 msgid "Command:"
@@ -4246,12 +4220,10 @@
 msgstr "Przeci±gnij mysz± lub kliknij by pomniejszyæ"
 #: ../gui/tcltk/gis.m/mapcanvas.tcl:1487 ../gui/tcltk/gis.m/georect.tcl:2229
-#, fuzzy
 msgid "Drag with mouse to pan"
 msgstr "Przeci±gnij mysz± by wy¶wietliæ ca³± mapê"
 #: ../gui/tcltk/gis.m/mapcanvas.tcl:1614
-#, fuzzy
 msgid "Measurement"
 msgstr "Miara"
@@ -4641,9 +4613,8 @@
 msgstr "Zarz±dzaj terenowymi punktami kontrolnymi (GCP)"
 #: ../gui/tcltk/gis.m/georect.tcl:1112
-#, fuzzy
 msgid "Save GCPs to POINTS file"
-msgstr "zapisz GCP do pliku punktów"
+msgstr "Zapisz pubkty GCP do pliku POINTS"
 #: ../gui/tcltk/gis.m/georect.tcl:1119
 #, fuzzy
@@ -4706,9 +4677,8 @@
 msgstr "B³±d podczas tworzenia pliku regu³"
 #: ../gui/tcltk/gis.m/histogram.tcl:107
-#, fuzzy
 msgid "Raster map for histogram"
-msgstr "Legenda dla mapy rastrowej:"
+msgstr "Mapa rastrowa do wykonania histogramu"
 #: ../gui/tcltk/gis.m/histogram.tcl:110
 #, tcl-format
@@ -5299,7 +5269,6 @@
 msgstr "Przepróbkowanie (zmiana rozdzielczo¶ci)"
 #: ../gui/tcltk/d.m/menu.tcl:231
-#, fuzzy
 msgid "Resample using nearest neighbor method"
 msgstr "Przepróbkowanie z u¿yciem metody najbli¿szego s±siedztwa"
@@ -5308,7 +5277,6 @@
 msgstr "Przepróbkowanie z u¿yciem ró¿nych metod interpolacji"
 #: ../gui/tcltk/d.m/menu.tcl:234
-#, fuzzy
 msgid "Resample using regularized spline with tension method"
 msgstr "Przepróbkowanie z u¿yciem metody rst"
@@ -5523,9 +5491,8 @@
 msgstr "Utwórz powierzchniê fraktaln±"
 #: ../gui/tcltk/d.m/menu.tcl:341
-#, fuzzy
 msgid "Generate gaussian deviates surface"
-msgstr "Wygeneruj krzywiznê Gaussa powierzchni."
+msgstr "Wygeneruj krzywiznê Gaussa powierzchni"
 #: ../gui/tcltk/d.m/menu.tcl:342
 msgid "Generate plane"
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_pl.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_pl.po	2009-10-28 23:28:04 UTC (rev 39640)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_pl.po	2009-10-28 23:28:37 UTC (rev 39641)
@@ -1,16 +1,16 @@
 # translation of grasswxpy_pl.po to Polski
 # Copyright (C) 2008, 2009, GRASS Development Team
-# Milena Nowotarska <do.milenki*gmail.com>, 2009.
 msgid ""
 msgstr ""
 "Project-Id-Version: grasswxpy_pl\n"
 "POT-Creation-Date: 2009-01-09 17:00+0100\n"
-"PO-Revision-Date: 2009-10-27 22:20+0200\n"
+"PO-Revision-Date: 2009-10-28 23:18+0100\n"
-"Language-Team: Milena\n"
 "Content-Type: text/plain; charset=UTF-8\n"
@@ -1991,35 +1991,35 @@
 #: ../gui/wxpython/gui_modules/preferences.py:525
 msgid "box"
-msgstr "ramka"
+msgstr "box"
 #: ../gui/wxpython/gui_modules/preferences.py:526
 msgid "sphere"
-msgstr "sfera"
+msgstr "sphere"
 #: ../gui/wxpython/gui_modules/preferences.py:527
 msgid "cube"
-msgstr "sześcian"
+msgstr "cube"
 #: ../gui/wxpython/gui_modules/preferences.py:528
 msgid "diamond"
-msgstr ""
+msgstr "diamond"
 #: ../gui/wxpython/gui_modules/preferences.py:529
 msgid "dtree"
-msgstr ""
+msgstr "dtree"
 #: ../gui/wxpython/gui_modules/preferences.py:530
 msgid "ctree"
-msgstr ""
+msgstr "ctree"
 #: ../gui/wxpython/gui_modules/preferences.py:531
 msgid "aster"
-msgstr ""
+msgstr "aster"
 #: ../gui/wxpython/gui_modules/preferences.py:532
 msgid "gyro"
-msgstr ""
+msgstr "gyro"
 #: ../gui/wxpython/gui_modules/preferences.py:533
 msgid "histogram"
@@ -2091,7 +2091,7 @@
 "Display window(s) and use as default for next sessions."
 msgstr ""
 "Zapisz bieżącą pozycję i rozmiar Okna Menadżera warstw i Okna/Okien Map i "
-"użyj ich jako domyslnych w następnej sesji."
+"użyj ich jako domyślnych w następnej sesji."
 #: ../gui/wxpython/gui_modules/preferences.py:917
 msgid "Layer Manager settings"
@@ -2137,9 +2137,8 @@
 msgstr "Polecenie"
 #: ../gui/wxpython/gui_modules/preferences.py:1092
-#, fuzzy
 msgid "Command dialog settings"
-msgstr "Okno ustawień poleceń"
+msgstr "Ustawienia okna poleceń"
 #: ../gui/wxpython/gui_modules/preferences.py:1104
 msgid "Allow output files to overwrite existing files"
@@ -2263,7 +2262,7 @@
 #: ../gui/wxpython/gui_modules/preferences.py:1706
 msgid "Set/unset access to mapsets in current location"
-msgstr "Ustaw dostępy do mapsetów w bieżącej lokalizacji"
+msgstr "Ustaw dostępy do mapsetów w bieżącej lokacji"
 #: ../gui/wxpython/gui_modules/preferences.py:1720
 #, python-format
@@ -2539,8 +2538,8 @@
 "Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
 "exists in the table <%(table)s>."
 msgstr ""
-"Nie można zmienić nazwy kolumny <%(kolumna)s> na <%(kolumnaTo)s>. Kolumna "
-"już istnieje w tabeli <%(tabela)s>."
+"Nie można zmienić nazwy kolumny <%(column)s> na <%(columnTo)s>. Kolumna już "
+"istnieje w tabeli <%(table)s>."
 #: ../gui/wxpython/gui_modules/dbm.py:1457
 #, python-format
@@ -2548,8 +2547,8 @@
 "Unable to rename column. Column <%(column)s> doesn't exist in the table <%"
 "(table)s>."
 msgstr ""
-"Nie można zmienić nazwy kolumny. Kolumna <%(kolumna)s> nie istnieje w tabeli "
-"<%(tabela)s>."
+"Nie można zmienić nazwy kolumny. Kolumna <%(column)s> nie istnieje w tabeli <"
+"%(table)s>."
 #: ../gui/wxpython/gui_modules/dbm.py:1485
 msgid "Drop selected column"
@@ -3288,7 +3287,7 @@
 #: ../gui/wxpython/gui_modules/vdigit.py:1284
 msgid "Query tool"
-msgstr ""
+msgstr "Narzędzie zapytań"
 #: ../gui/wxpython/gui_modules/vdigit.py:1291
 msgid "Choose query tool"
@@ -3414,7 +3413,6 @@
 msgstr "Węzeł (dwie linie)"
 #: ../gui/wxpython/gui_modules/vdigit.py:1467
-#, fuzzy
 msgid "Vertex"
 msgstr "Węzeł"
@@ -3672,7 +3670,7 @@
 #: ../gui/wxpython/gui_modules/nviz_tools.py:149
 msgid "Twist:"
-msgstr "Otočení:"
+msgstr "Skręcenie:"
 #: ../gui/wxpython/gui_modules/nviz_tools.py:163
 msgid "Height:"
@@ -4329,12 +4327,15 @@
 msgstr "Proszę czekać, ładuję dane atrybutowe..."
 #: ../gui/wxpython/wxgui.py:1434
-#, fuzzy, python-format
+#, python-format
 msgid ""
 "Do you want to remove map layer(s)\n"
 "%s\n"
 "from layer tree?"
-msgstr "Czy chcesz usunąć warstwę mapy<%s> z listy warstw?"
+msgstr ""
+"Czy chcesz usunąć warstwę mapy (s)\n"
+"%s\n"
+" z listy warstw?"
 #: ../gui/wxpython/wxgui.py:1437
 msgid "Do you want to remove selected map layer(s) from layer tree?"
@@ -5432,7 +5433,6 @@
 msgstr "Przykryj mapy rastrowe"
 #: ../gui/wxpython/menustrings.py:263
-#, fuzzy
 msgid "Cross product"
 msgstr "Produkt poprzecznego łączenia rastrów"
@@ -7448,6 +7448,7 @@
 #: ../gui/wxpython/menustrings.py:721
 msgid "Prints/sets DB connection for a vector map to attribute table."
 msgstr ""
+"Wyświetla/ustawia połączenie DB dla mapy wektorowej z tabelą atrybutów."
 #: ../gui/wxpython/menustrings.py:722
 msgid "Help"
