[GRASS-SVN] r49634 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Fri Dec 9 05:32:56 EST 2011
Author: neteler
Date: 2011-12-09 02:32:56 -0800 (Fri, 09 Dec 2011)
New Revision: 49634
grass/branches/develbranch_6/locale/po/grasslibs_pl.po
Milena Nowotarska: cont'ed
Modified: grass/branches/develbranch_6/locale/po/grasslibs_pl.po
--- grass/branches/develbranch_6/locale/po/grasslibs_pl.po 2011-12-09 10:32:48 UTC (rev 49633)
+++ grass/branches/develbranch_6/locale/po/grasslibs_pl.po 2011-12-09 10:32:56 UTC (rev 49634)
@@ -2,24 +2,21 @@
# This file is distributed under the same license as the GRASS package.
# Copyright (C) 2005, 2009, GRASS Development Team
# Artur Nieścior <nieart at interia.pl>, 2005, 2006.
-# Milena Nowotarska <do.milenki*gmail.com>, 2008, 2009, 2010.
-# Milena Nowotarska <do.milenki * gmail.com>, 2010.
+# Milena Nowotarska <do.milenki * gmail.com>, 2008, 2009, 2010, 2011.
# Maciej Sieczka <msieczka "at" msieczka "dot" org>, 2011.
msgid ""
msgstr ""
"Project-Id-Version: grasslibs_pl\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2011-10-05 23:24+0200\n"
-"PO-Revision-Date: 2010-09-17 23:56+0100\n"
-"Last-Translator: Maciej Sieczka <msieczka at msieczka dot org>\n"
+"PO-Revision-Date: 2011-12-09 11:17+0100\n"
+"Last-Translator: Milena Nowotarska <do.milenki * gmail.com>\n"
"Language-Team: GRASS Translation Team\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"Language: pl\n"
-"Plural-Forms: nplurals=3; plural=(n==1 ? 0 : n%10>=2 && n%10<=4 && (n%100<10 "
-"|| n%100>=20) ? 1 : 2);\n"
-"X-Generator: Virtaal 0.6.1\n"
+"Plural-Forms: nplurals=3; plural=(n==1 ? 0 : n%10>=2 && n%10<=4 && (n%100<10 || n%100>=20) ? 1 : 2);\n"
#: ../lib/raster/rem_io.c:40
#, c-format
@@ -109,11 +106,8 @@
#: ../lib/symbol/read.c:259
#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"Nieprawidłowa nazwa symbolu: '%s' (powinno być: grupa/nazwa lub grupa/"
-"nazwa at mapset)"
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr "Nieprawidłowa nazwa symbolu: '%s' (powinno być: grupa/nazwa lub grupa/nazwa at mapset)"
#: ../lib/symbol/read.c:283
#, c-format
@@ -236,10 +230,8 @@
#: ../lib/proj/convert.c:127
#, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-"OGR nie może przetworzyć parametrów w stylu PROJ.4: %s (Kod błędu OGR to %d)"
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr "OGR nie może przetworzyć parametrów w stylu PROJ.4: %s (Kod błędu OGR to %d)"
#: ../lib/proj/convert.c:133
#, c-format
@@ -248,30 +240,22 @@
#: ../lib/proj/convert.c:390
msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
-"Brak nazwy odwzorowania! Parametry odwzorowania są prawdopodobnie błędne."
+msgstr "Brak nazwy odwzorowania! Parametry odwzorowania są prawdopodobnie błędne."
#: ../lib/proj/convert.c:426
#, c-format
msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr ""
-"Datum <%s> nie zostało rozpoznane przez GRASS i nie znaleziono parametrów"
+msgstr "Datum <%s> nie zostało rozpoznane przez GRASS i nie znaleziono parametrów"
#: ../lib/proj/convert.c:442
#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-"Datum <%s> najwyraźniej zostało rozpoznane przez GRASS, ale nie znaleziono "
-"parametrów. Należy to sprawdzić."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "Datum <%s> najwyraźniej zostało rozpoznane przez GRASS, ale nie znaleziono parametrów. Należy to sprawdzić."
#: ../lib/proj/convert.c:446
#, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "Niewłaściwy numer transformacji %d; właściwy zakres jest od 1 do %d. Parametry transformacji elipsoidy pozostaną niesprecyzowane."
#: ../lib/gis/sample.c:71
msgid "Unknown interpolation type"
@@ -385,11 +369,8 @@
msgstr "Nie można zapisać reguł kwantyzacji dla mapy %s"
#: ../lib/gis/set_window.c:76
-msgid ""
-"G_set_window(): projection/zone differs from that of currently open raster "
-"maps"
-msgstr ""
-"G_set_window(): odwzorowanie/strefa obecnie otwartych map rastrowych są inne"
+msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
+msgstr "G_set_window(): odwzorowanie/strefa obecnie otwartych map rastrowych są inne"
#: ../lib/gis/quant_io.c:89
#, c-format
@@ -409,8 +390,7 @@
#: ../lib/gis/put_row.c:215
#, c-format
msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
-msgstr ""
-"G_put_map_row: %s nie jest całkowitoliczbowa! Użyj G_put_[f/d]_raster_row()!"
+msgstr "G_put_map_row: %s nie jest całkowitoliczbowa! Użyj G_put_[f/d]_raster_row()!"
#: ../lib/gis/put_row.c:251
#, c-format
@@ -420,14 +400,12 @@
#: ../lib/gis/put_row.c:259
#, c-format
msgid "%s: map [%s] not open for random write - request ignored"
-msgstr ""
-"%s: mapa [%s] nie jest otwarta do losowego zapisu - żądanie zignorowane"
+msgstr "%s: mapa [%s] nie jest otwarta do losowego zapisu - żądanie zignorowane"
#: ../lib/gis/put_row.c:266
#, c-format
msgid "%s: map [%s] not open for sequential write - request ignored"
-msgstr ""
-"%s: mapa [%s] nie jest otwarta do sekwencyjnego zapisu - żądanie zignorowane"
+msgstr "%s: mapa [%s] nie jest otwarta do sekwencyjnego zapisu - żądanie zignorowane"
#: ../lib/gis/put_row.c:270
#, c-format
@@ -487,15 +465,12 @@
#: ../lib/gis/view.c:546
#, c-format
msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-" Region zapisany w \"%s\" jest całkowicie poza bieżącym regionem GRASS."
+msgstr " Region zapisany w \"%s\" jest całkowicie poza bieżącym regionem GRASS."
#: ../lib/gis/view.c:550
#, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-" Tylko %d%% regionu zapisanego w \"%s\" pokrywa się z obecnym regionem GRASS."
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Tylko %d%% regionu zapisanego w \"%s\" pokrywa się z obecnym regionem GRASS."
#: ../lib/gis/get_projname.c:31
#, c-format
@@ -574,9 +549,7 @@
#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:247
#, c-format
msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr ""
-"Korekta niewielkiego błędu zaokrąglenia danych wejściowych dla granicy "
-"północnej (%g>%g)"
+msgstr "Korekta niewielkiego błędu zaokrąglenia danych wejściowych dla granicy północnej (%g>%g)"
#: ../lib/gis/adj_cellhd.c:84 ../lib/gis/adj_cellhd.c:252
msgid "Illegal latitude for North"
@@ -585,9 +558,7 @@
#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:258
#, c-format
msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
-"południowej (%g>%g)"
+msgstr "Korekta niewielkiego błędu zaokrąglenia danych wejściowych dla granicy południowej (%g>%g)"
#: ../lib/gis/adj_cellhd.c:95 ../lib/gis/adj_cellhd.c:263
msgid "Illegal latitude for South"
@@ -596,16 +567,12 @@
#: ../lib/gis/adj_cellhd.c:107 ../lib/gis/adj_cellhd.c:275
#, c-format
msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr ""
-"zachodniej (%g>%g)"
+msgstr "Korekta niewielkiego błędu zaokrąglenia danych wejściowych dla granicy zachodniej (%g>%g)"
#: ../lib/gis/adj_cellhd.c:118 ../lib/gis/adj_cellhd.c:286
#, c-format
msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr ""
-"wschodniej (%g>%g)"
+msgstr "Korekta niewielkiego błędu zaokrąglenia danych wejściowych dla granicy wschodniej (%g>%g)"
#: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:299
msgid "North must be north of South"
@@ -748,12 +715,8 @@
msgstr "Numer warstwy"
#: ../lib/gis/parser.c:596
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use."
-msgstr ""
-"Mapa wektorowa może być podłączona do wielu tabel bazy danych. Ta liczba "
-"określa, która tabela zostanie użyta."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+msgstr "Mapa wektorowa może być podłączona do wielu tabel bazy danych. Ta liczba określa, która tabela zostanie użyta."
#: ../lib/gis/parser.c:605
msgid "Category value"
@@ -776,12 +739,10 @@
msgstr "ID obiektów"
#: ../lib/gis/parser.c:637
-#, fuzzy
msgid "Name to input file"
msgstr "Ścieżka do pliku wejściowego"
#: ../lib/gis/parser.c:645
-#, fuzzy
msgid "Name for output file"
msgstr "Ścieżka do pliku wyjściowego"
@@ -964,7 +925,7 @@
#: ../lib/gis/parser.c:2208
#, c-format
msgid "Option <%s> does not accept multiple answers\n"
-msgstr ""
+msgstr "Opcja <%s> nie obsługuje wielu odpowiedzi\n"
#: ../lib/gis/parser.c:2286
#, c-format
@@ -1144,8 +1105,7 @@
#: ../lib/gis/get_row.c:46 ../lib/gis/get_row.c:1049
#, c-format
msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-"Żądanie odczytu mapy rastrowej <%s@%s> dla wiersza %d jest poza regionem"
+msgstr "Żądanie odczytu mapy rastrowej <%s@%s> dla wiersza %d jest poza regionem"
#: ../lib/gis/get_row.c:324
#, c-format
@@ -1260,7 +1220,7 @@
#: ../lib/gis/open_misc.c:67
#, c-format
msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
+msgstr "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
#: ../lib/gis/home.c:39
msgid "unable to determine user's home directory"
@@ -1617,22 +1577,16 @@
#: ../lib/gis/distance.c:160
#, c-format
-msgid ""
-"G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%"
-"f)(%f,%f)"
-msgstr ""
-"G_distance_point_to_line_segment: to nie powinno się zdarzyć: code=%d P=(%f,%"
-"f) S=(%f,%f)(%f,%f)"
+msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgstr "G_distance_point_to_line_segment: to nie powinno się zdarzyć: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
-#, fuzzy
msgid "Unable to seek"
-msgstr "Nie można ustawić środka"
+msgstr "Nie można przeszukać"
#: ../lib/gis/seek.c:56
-#, fuzzy
msgid "Seek offset out of range"
-msgstr "Indeks warstwy jest poza zakresem"
+msgstr "Przesunięcie przeszukiwania jest poza zakresem"
#: ../lib/gis/alloc.c:43
#, c-format
@@ -1661,12 +1615,8 @@
#: ../lib/gis/opencell.c:188
#, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%"
-"s> which does not exist"
-msgstr ""
-"Nie można otworzyć mapy rastrowej <%s@%s> ponieważ jest ona reklasyfikacją "
-"mapy rastrowej <%s@%s>, która nie istnieje"
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr "Nie można otworzyć mapy rastrowej <%s@%s> ponieważ jest ona reklasyfikacją mapy rastrowej <%s@%s>, która nie istnieje"
#: ../lib/gis/opencell.c:212
#, c-format
@@ -1675,18 +1625,13 @@
#: ../lib/gis/opencell.c:219
#, c-format
-msgid ""
-"Raster map <%s@%s> is in different projection than current region. Found "
-"raster map <%s@%s>, should be <%s>."
-msgstr ""
-"Mapa rastrowa <%s@%s> jest w innym odwzorowaniu niż bieżący region. "
-"Znaleziona mapa rastrowa <%s@%s>, powinno być <%s>."
+msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
+msgstr "Mapa rastrowa <%s@%s> jest w innym odwzorowaniu niż bieżący region. Znaleziona mapa rastrowa <%s@%s>, powinno być <%s>."
#: ../lib/gis/opencell.c:226
#, c-format
msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
-msgstr ""
-"Mapa rastrowa <%s@%s> jest w innej strefie (%d) niż bieżący region (%d)"
+msgstr "Mapa rastrowa <%s@%s> jest w innej strefie (%d) niż bieżący region (%d)"
#: ../lib/gis/opencell.c:233
#, c-format
@@ -1696,9 +1641,7 @@
#: ../lib/gis/opencell.c:262
#, c-format
msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr ""
-"mapa <%s@%s> jest łączem do danych GDAL, ale GRASS został skompilowany bez "
-"obsługi GDAL"
+msgstr "mapa <%s@%s> jest łączem do danych GDAL, ale GRASS został skompilowany bez obsługi GDAL"
#: ../lib/gis/opencell.c:642
#, c-format
@@ -1720,11 +1663,8 @@
msgstr "G__open_raster_new(): pliki tymczasowe są niedostępne"
#: ../lib/gis/opencell.c:736
-msgid ""
-"Unable to write embedded null values for raster map open for random access"
-msgstr ""
-"Nie można zapisać wbudowanych wartości null mapy rastrowej przy losowym "
-"dostępie"
+msgid "Unable to write embedded null values for raster map open for random access"
+msgstr "Nie można zapisać wbudowanych wartości null mapy rastrowej przy losowym dostępie"
#: ../lib/gis/opencell.c:941
msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
@@ -1761,11 +1701,8 @@
msgstr "Mapa rastrowa <%s> nie jest xdr: byte_order: %s"
#: ../lib/gis/opencell.c:1179
-msgid ""
-"G_set_quant_rules() can be called only for raster maps opened for reading"
-msgstr ""
-"G_set_quant_rules() może być użyte tylko dla map rastrowych otwartych do "
-"odczytu"
+msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
+msgstr "G_set_quant_rules() może być użyte tylko dla map rastrowych otwartych do odczytu"
#: ../lib/gis/mask_info.c:40
#, c-format
@@ -1830,7 +1767,7 @@
#: ../lib/gis/open.c:84
#, c-format
msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
+msgstr "G__open(write): xmapset <%s> != G_mapset() <%s>"
#: ../lib/gis/gishelp.c:45
#, c-format
@@ -2130,9 +2067,7 @@
#: ../lib/gis/get_cellhd.c:105
#, c-format
msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-msgstr ""
-" To jest reklasyfikacja mapy rastrowej <%s@%s>, której plik nagłówkowy jest "
-"niepoprawny."
+msgstr " To jest reklasyfikacja mapy rastrowej <%s@%s>, której plik nagłówkowy jest niepoprawny."
#: ../lib/gis/get_cellhd.c:109
#, c-format
@@ -2140,12 +2075,8 @@
msgstr " Błędny format."
#: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:90
-msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
-msgstr ""
-"Wersja biblioteki niezgodna z modułem. Należy ponownie zbudować GRASS lub "
-"rozwiązać błędy wynikające z wielu instalacji."
+msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
+msgstr "Wersja biblioteki niezgodna z modułem. Należy ponownie zbudować GRASS lub rozwiązać błędy wynikające z wielu instalacji."
#: ../lib/gis/gisinit.c:63
#, c-format
@@ -2191,8 +2122,7 @@
#: ../lib/driver/parse_ftcap.c:32
#, c-format
msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s: Nie można odczytać pliku definicji czcionki; użyto ustawień domyślnych"
+msgstr "%s: Nie można odczytać pliku definicji czcionki; użyto ustawień domyślnych"
#: ../lib/driver/parse_ftcap.c:38
#, c-format
@@ -2206,9 +2136,7 @@
#: ../lib/vector/diglib/plus_node.c:217
#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
msgstr "Próba odczytu kąta linii nie połączonej z węzłem: węzeł %d, linia %d"
#: ../lib/vector/diglib/plus.c:288
@@ -2294,8 +2222,7 @@
#: ../lib/vector/diglib/plus_area.c:394
#, c-format
msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-"Martwy centroid %d zarejestrowany dla obszaru (bug w bibliotece vector)"
+msgstr "Martwy centroid %d zarejestrowany dla obszaru (bug w bibliotece vector)"
#: ../lib/vector/diglib/plus_area.c:418
#, c-format
@@ -2359,8 +2286,7 @@
#: ../lib/vector/Vlib/legal_vname.c:48
#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Niedozwolona nazwa mapy wektorowej <%s>. Nie może zawierać '.' lub 'NULL'."
+msgstr "Niedozwolona nazwa mapy wektorowej <%s>. Nie może zawierać '.' lub 'NULL'."
#: ../lib/vector/Vlib/legal_vname.c:55
#, c-format
@@ -2374,11 +2300,8 @@
#: ../lib/vector/Vlib/legal_vname.c:70
#, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"Niedozwolona nazwa mapy wektorowej <%s>. Słowo kluczowe SQL nie może być "
-"użyte jako nazwa mapy wektorowej."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr "Niedozwolona nazwa mapy wektorowej <%s>. Słowo kluczowe SQL nie może być użyte jako nazwa mapy wektorowej."
#: ../lib/vector/Vlib/legal_vname.c:101 ../lib/vector/Vlib/legal_vname.c:105
#, c-format
@@ -2436,12 +2359,8 @@
msgstr "Nie można usunąć obiektu %d z indeksu przestrzennego"
#: ../lib/vector/Vlib/sindex.c:127
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topo level 2"
-msgstr ""
-"Nie można utworzyć indeksu przestrzennego z topologii, mapa wektorowa nie "
-"jest otwarta na poziomie topologicznym"
+msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
+msgstr "Nie można utworzyć indeksu przestrzennego z topologii, mapa wektorowa nie jest otwarta na poziomie topologicznym"
#: ../lib/vector/Vlib/sindex.c:168
msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
@@ -2477,8 +2396,7 @@
#: ../lib/vector/Vlib/intersect.c:448
msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-"Vect_segment_intersection() BŁĄD (współliniowe segmenty nie-wierzchołkowe)"
+msgstr "Vect_segment_intersection() BŁĄD (współliniowe segmenty nie-wierzchołkowe)"
#: ../lib/vector/Vlib/intersect.c:1099 ../lib/vector/Vlib/intersect.c:1105
#: ../lib/vector/Vlib/intersect.c:1107 ../lib/vector/Vlib/intersect.c:1155
@@ -2540,12 +2458,8 @@
#: ../lib/vector/Vlib/geos.c:56
#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-"Vect_read_line_geos(): id %d obiektu nie ma sensu (max obiektów w mapie "
-"wektorowej <%s>: %d)"
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line_geos(): id %d obiektu nie ma sensu (max obiektów w mapie wektorowej <%s>: %d)"
#: ../lib/vector/Vlib/geos.c:61
msgid "only native format supported"
@@ -2587,8 +2501,7 @@
#: ../lib/vector/Vlib/snap.c:172
msgid "Snap vertices Pass 2: assign anchor vertices"
-msgstr ""
-"Dociąganie wierzchołków - etap 2: przydzielenie wierzchołków przyłączenia"
+msgstr "Dociąganie wierzchołków - etap 2: przydzielenie wierzchołków przyłączenia"
#: ../lib/vector/Vlib/snap.c:241
msgid "Snap vertices Pass 3: snap to assigned points"
@@ -2736,9 +2649,7 @@
#: ../lib/vector/Vlib/field.c:98
msgid "Unable to add database link, map is not opened in WRITE mode"
-msgstr ""
-"Nie można dodać połączenia do bazy danych. Mapa nie jest otwarta w trybie do "
-"zapisu"
+msgstr "Nie można dodać połączenia do bazy danych. Mapa nie jest otwarta w trybie do zapisu"
#: ../lib/vector/Vlib/field.c:104
msgid "Unable to add database link"
@@ -2782,12 +2693,8 @@
msgstr "Nie można otworzyć sterownika OGR DBMI"
#: ../lib/vector/Vlib/field.c:551
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
-"Wszystkie testy FID zawiodły. Żadne z 'FID', 'ogc_fid', 'ogr_fid', 'gid' nie "
-"jest dostępne w tabeli bazy danych OGR"
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr "Wszystkie testy FID zawiodły. Żadne z 'FID', 'ogc_fid', 'ogr_fid', 'gid' nie jest dostępne w tabeli bazy danych OGR"
#: ../lib/vector/Vlib/field.c:606
#, c-format
@@ -2806,8 +2713,7 @@
#: ../lib/vector/Vlib/field.c:804
msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
-"Bug: próba aktualizacji mapy, która nie znajduje się w bieżącym mapsecie"
+msgstr "Bug: próba aktualizacji mapy, która nie znajduje się w bieżącym mapsecie"
#: ../lib/vector/Vlib/area.c:53
msgid "Attempt to read points of nonexistent area"
@@ -2846,12 +2752,8 @@
#: ../lib/vector/Vlib/read.c:102
#, c-format
-msgid ""
-"Vect_read_line(): feature id %d is not reasonable (max features in vector "
-"map <%s>: %d)"
-msgstr ""
-"Vect_read_line(): obiekt o id %d nie ma sensu (max obiektów w mapie "
+msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line(): obiekt o id %d nie ma sensu (max obiektów w mapie wektorowej <%s>: %d)"
#: ../lib/vector/Vlib/build_nat.c:93
msgid "Unable to add area (map closed, topo saved)"
@@ -2925,8 +2827,7 @@
#: ../lib/vector/Vlib/buffer2.c:598 ../lib/vector/Vlib/buffer2.c:609
msgid "Next edge was visited but it is not the first one !!! breaking loop"
-msgstr ""
-"Następna krawędź została przetworzona ale nie jest pierwsza! Pętla przerwana"
+msgstr "Następna krawędź została przetworzona ale nie jest pierwsza! Pętla przerwana"
#: ../lib/vector/Vlib/buffer2.c:657
msgid "side != 0 feature not implemented"
@@ -2934,12 +2835,11 @@
#: ../lib/vector/Vlib/buffer2.c:899 ../lib/vector/Vlib/buffer2.c:946
msgid "zero area size"
-msgstr ""
+msgstr "zerowy rozmiar obszaru"
#: ../lib/vector/Vlib/buffer2.c:905 ../lib/vector/Vlib/buffer2.c:952
-#, fuzzy
msgid "Line was not closed"
-msgstr "Linia nie jest zapętlona"
+msgstr "Linia nie była domknięta"
#: ../lib/vector/Vlib/buffer2.c:918 ../lib/vector/Vlib/buffer2.c:969
msgid "Vect_get_point_in_poly() failed"
@@ -3046,21 +2946,13 @@
#: ../lib/vector/Vlib/open_nat.c:145
#, c-format
-msgid ""
-"Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
-msgstr ""
-"Plik coor mapy wektorowej <%s@%s> jest większy niż powinien (%ld bajtów za "
-"dużo)"
+msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+msgstr "Plik coor mapy wektorowej <%s@%s> jest większy niż powinien (%ld bajtów za dużo)"
#: ../lib/vector/Vlib/open_nat.c:149
#, c-format
-msgid ""
-"Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
-"missing)."
-msgstr ""
-"Plik coor mapy wektorowej <%s@%s> jest mniejszy niż powinien (%ld bajtów za "
-"mało)"
+msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr "Plik coor mapy wektorowej <%s@%s> jest mniejszy niż powinien (%ld bajtów za mało)"
#: ../lib/vector/Vlib/net.c:121
msgid "Building graph..."
@@ -3096,22 +2988,13 @@
#: ../lib/vector/Vlib/net.c:254
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
-msgstr ""
-"Nie znaleziono wpisu bazy danych dla linii %d (cat = %d, kierunek(ki) do "
-"przodu/w obie strony), pominięto kierunek(ki) do przodu/w obie strony tej "
-"linii"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgstr "Nie znaleziono wpisu bazy danych dla linii %d (cat = %d, kierunek(ki) do przodu/w obie strony), pominięto kierunek(ki) do przodu/w obie strony tej linii"
#: ../lib/vector/Vlib/net.c:273
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found"
-"(direction of line skipped)"
-msgstr ""
-"Nie znaleziono wpisu bazy danych dla linii %d (cat = %d, kierunek wstecz), "
-"pominęto kierunek tej linii"
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgstr "Nie znaleziono wpisu bazy danych dla linii %d (cat = %d, kierunek wstecz), pominęto kierunek tej linii"
#: ../lib/vector/Vlib/net.c:322
msgid "Cannot add network arc"
@@ -3124,9 +3007,7 @@
#: ../lib/vector/Vlib/net.c:402
#, c-format
msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"Nie znaleziono wpisu bazy danych dla węzła %d (cat = %d), koszt ustawiono na "
-"0"
+msgstr "Nie znaleziono wpisu bazy danych dla węzła %d (cat = %d), koszt ustawiono na 0"
#: ../lib/vector/Vlib/net.c:429
msgid "Flattening the graph..."
@@ -3193,19 +3074,13 @@
#: ../lib/vector/Vlib/write.c:219
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Nie można usunąć obiektu %d, mapa wektorowa <%s> nie jest otwarta na "
-"poziomie topologicznym"
+msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr "Nie można usunąć obiektu %d, mapa wektorowa <%s> nie jest otwarta na poziomie topologicznym"
#: ../lib/vector/Vlib/write.c:225
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Nie można usunąć obiektu %d, mapa wektorowa <%s> nie jest otwarta w trybie "
-"do zapisu"
+msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Nie można usunąć obiektu %d, mapa wektorowa <%s> nie jest otwarta w trybie do zapisu"
#: ../lib/vector/Vlib/write.c:239
#, c-format
@@ -3214,19 +3089,13 @@
#: ../lib/vector/Vlib/write.c:265
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Nie można przywrócić obiektu %d, mapa wektorowa <%s> nie jest otwarta na "
+msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr "Nie można przywrócić obiektu %d, mapa wektorowa <%s> nie jest otwarta na poziomie topologicznym"
#: ../lib/vector/Vlib/write.c:271
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Nie można przywrócić obiektu %d, mapa wektorowa <%s> nie jest otwarta w "
-"trybie do zapisu"
+msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Nie można przywrócić obiektu %d, mapa wektorowa <%s> nie jest otwarta w trybie do zapisu"
#: ../lib/vector/Vlib/write.c:285
#, c-format
@@ -3244,8 +3113,7 @@
msgstr "Żądanie nieznanego poziomu otwarcia %d"
#: ../lib/vector/Vlib/open.c:179
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
+msgid "Vector map which is not in the current mapset cannot be opened for update"
msgstr "Mapa wektorowa spoza bieżącego mapsecie nie może być otwarta do zapisu"
#: ../lib/vector/Vlib/open.c:199 ../lib/ogsf/Gv3.c:63 ../lib/ogsf/Gp3.c:115
@@ -3256,12 +3124,8 @@
#: ../lib/vector/Vlib/open.c:211 ../lib/vector/Vlib/open.c:279
#: ../lib/vector/Vlib/open.c:299
#, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"by v.build."
-msgstr ""
-"Nie znaleziono mapy wektorowej <%s> na poziomie %d. Spróbuj przebudować "
-"topologię za pomocą v.build."
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
+msgstr "Nie znaleziono mapy wektorowej <%s> na poziomie %d. Spróbuj przebudować topologię za pomocą v.build."
#: ../lib/vector/Vlib/open.c:214
msgid "Unable to read head file"
@@ -3299,8 +3163,7 @@
#: ../lib/vector/Vlib/open.c:731
msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-"Wielkość pliku 'coor' różni się od wartości zapisanej w pliku topologii"
+msgstr "Wielkość pliku 'coor' różni się od wartości zapisanej w pliku topologii"
#: ../lib/vector/Vlib/open.c:742
#, c-format
@@ -3328,21 +3191,13 @@
#: ../lib/vector/Vlib/open_ogr.c:147
#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
-"Format indeksu obietków wektorowych %d.%d nie jest obsługiwany w tym wydaniu "
-"GRASS. Przebuduj topologię lub zaktualizuj GRASS."
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgstr "Format indeksu obietków wektorowych %d.%d nie jest obsługiwany w tym wydaniu GRASS. Przebuduj topologię lub zaktualizuj GRASS."
#: ../lib/vector/Vlib/open_ogr.c:152
#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-"Format indeksu obietków wektorowych %d.%d nie jest w pełni obsługiwany w tym "
-"wydaniu GRASS. Przebuduj topologię lub zaktualizuj GRASS."
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Format indeksu obietków wektorowych %d.%d nie jest w pełni obsługiwany w tym wydaniu GRASS. Przebuduj topologię lub zaktualizuj GRASS."
#: ../lib/vector/Vlib/level_two.c:251 ../lib/vector/Vlib/level_two.c:276
#: ../lib/vector/Vlib/level_two.c:300 ../lib/vector/Vlib/level_two.c:319
@@ -3397,8 +3252,7 @@
msgstr "Częściowa przebudowa dla danych OGR nie jest obsługiwana"
#: ../lib/vector/Vlib/build_ogr.c:342
-msgid ""
-"Random read is not supported by OGR for this layer, cannot build support"
+msgid "Random read is not supported by OGR for this layer, cannot build support"
msgstr "Losowy odczyt danych OGR nie jest obsługiwany dla tej warstwy"
#: ../lib/vector/Vlib/build_ogr.c:349
@@ -3451,36 +3305,34 @@
#: ../lib/vector/neta/spanningtree.c:104
msgid "Computing minimum spanning tree..."
-msgstr ""
+msgstr "Oblicznie minimalnego drzewa rozpinającego (MST)..."
#: ../lib/vector/neta/utils.c:219 ../lib/vector/neta/utils.c:232
#, c-format
msgid "'%s' must be > 0 for '%s'"
-msgstr ""
+msgstr "'%s' musi być > 0 dla '%s'"
#: ../lib/vector/neta/utils.c:221
msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
-msgstr ""
+msgstr "Dostarczono parametry 'where' i 'cats', cat będzie zignorowane"
#: ../lib/vector/neta/utils.c:225
-#, fuzzy
msgid "Unable to load data from database"
-msgstr "Nie można dodać połączenia do bazy danych"
+msgstr "Nie można wczytać danych z bazy danych"
#: ../lib/vector/neta/utils.c:236
-#, fuzzy
msgid "Problem loading category values"
-msgstr "Problem podczas odczytu mapy rastrowej"
+msgstr "Problem z wczytaniem wartości kategorii"
#: ../lib/vector/neta/allpairs.c:53
msgid "Computing all pairs shortest paths..."
-msgstr ""
+msgstr "Obliczanie najkrótszych dróg dla wszystkich par..."
#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open select cursor: %s"
-msgstr "Nie można otworzyć kursora wyboru: '%s'"
+msgstr "Nie można otworzyć kursora wyboru: %s"
#: ../lib/nviz/render.c:104
msgid "Bad server connection"
@@ -3603,8 +3455,7 @@
msgstr "Zapisz tablicę 3d do mapy rastrowej 3D <%s>"
#: ../lib/gpde/N_parse_options.c:59
-msgid ""
-"The type of solver which should solve the symmetric linear equation system"
+msgid "The type of solver which should solve the symmetric linear equation system"
msgstr "Metoda, która powinna rozwiązać symetryczny układ równań liniowych"
#: ../lib/gpde/N_parse_options.c:71
@@ -3616,19 +3467,12 @@
msgstr "Maksymalna ilość powtórzeń rozwiązania układu równań liniowych"
#: ../lib/gpde/N_parse_options.c:89
-msgid ""
-"Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
-msgstr ""
-"Kryteria zatrzymania wskutek błędu dla metod iteracyjnych (jacobi, sor, cg "
-"lub bicgstab)"
+msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+msgstr "Kryteria zatrzymania wskutek błędu dla metod iteracyjnych (jacobi, sor, cg lub bicgstab)"
#: ../lib/gpde/N_parse_options.c:98
-msgid ""
-"The relaxation parameter used by the jacobi and sor solver for speedup or "
-"stabilizing"
-msgstr ""
-"Parametr relaksacji używany przez metodę Jacobiego i SOR dla przyspieszenia "
-"lub stabilizacji"
+msgid "The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing"
+msgstr "Parametr relaksacji używany przez metodę Jacobiego i SOR dla przyspieszenia lub stabilizacji"
#: ../lib/gpde/N_parse_options.c:106
msgid "The calculation time in seconds"
@@ -3712,7 +3556,7 @@
#: ../lib/gpde/test/test_main.c:85
msgid "test, gpde"
-msgstr ""
+msgstr "test, gpde"
#: ../lib/gpde/test/test_main.c:87
msgid "Performs unit and integration tests for gpde library"
@@ -3755,6 +3599,8 @@
"\n"
"++ Running solute_transport integration tests ++"
msgstr ""
+"\n"
+"++ Testy inegracji solute_transport w toku ++"
#: ../lib/gpde/test/test_solute_transport.c:45
msgid "\t 1. testing 2d solute_transport"
@@ -3935,16 +3781,16 @@
#: ../lib/init/lock.c:38
#, c-format
msgid "Usage: %s file pid"
-msgstr ""
+msgstr "Użycie: %s pid pliku"
#: ../lib/init/lock.c:42
msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
+msgstr "Jednoczesne blokowanie mapsetu nie jest obsługiwane w systemie Windows"
#: ../lib/init/lock.c:60
#, c-format
msgid "Unable to write lockfile %s (disk full? Permissions?)"
-msgstr ""
+msgstr "Nie można zapisać pliku lockfile %s (dysk pełny? pozwolenia dostępu?)"
#: ../lib/rst/interp_float/output2d.c:125
#, c-format
@@ -3952,21 +3798,13 @@
msgstr "Najpierw ustaw liczbę kolumn zgodnie z 'nsizc' %d %d"
#: ../lib/rst/interp_float/segmen2d.c:111
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"Odnajdowanie punktów do interpolacji trwa zbyt długo - ustaw region na "
-"obszar, gdzie znajdują się punkty. Obliczenia są kontynuowane..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "Odnajdowanie punktów do interpolacji trwa zbyt długo - ustaw region na obszar, gdzie znajdują się punkty. Obliczenia są kontynuowane..."
#: ../lib/rst/interp_float/interp2d.c:212
#, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
-msgstr ""
-"Przestrzelenie - zwiększenie parametru 'tension' może pomóc. Przestrzelenie "
-"miało miejsce w komórce (%d,%d). z = %f, z min. = %f, z maks. = %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgstr "Przestrzelenie - zwiększenie parametru 'tension' może pomóc. Przestrzelenie miało miejsce w komórce (%d,%d). z = %f, z min. = %f, z maks. = %f."
#: ../lib/rst/interp_float/input2d.c:47
#, c-format
@@ -4033,12 +3871,8 @@
#: ../lib/rst/interp_float/vinput2d.c:335
#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN=%"
-"d"
-msgstr ""
-"%d punktów podanych (po odchudzeniu danych) do interpolacji to mniej niż "
-"podany NPMIN=%d"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "%d punktów podanych (po odchudzeniu danych) do interpolacji to mniej niż podany NPMIN=%d"
#: ../lib/rst/interp_float/vinput2d.c:340
msgid "Zero points in the given region"
@@ -4046,22 +3880,13 @@
#: ../lib/rst/interp_float/vinput2d.c:345
#, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-"Parametry segmentacji ustawione błędnie: npmin= %d, segmax= %d. Aby uzyskać "
-"gładkie połączenia między segmentami npmin musi być większe od segmax (patrz "
-"podręcznik)"
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "Parametry segmentacji ustawione błędnie: npmin= %d, segmax= %d. Aby uzyskać gładkie połączenia między segmentami npmin musi być większe od segmax (patrz podręcznik)"
#: ../lib/rst/interp_float/vinput2d.c:351
#, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"Mniej niż %d punktów do interpolacji. Segmentacja nie jest potrzebna - aby "
-"przyśpieszyć interpolację ustaw segmax=%d (patrz podręcznik)"
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "Mniej niż %d punktów do interpolacji. Segmentacja nie jest potrzebna - aby przyśpieszyć interpolację ustaw segmax=%d (patrz podręcznik)"
#: ../lib/rst/interp_float/vinput2d.c:355
#, c-format
@@ -4097,8 +3922,7 @@
#: ../lib/g3d/g3dparam.c:61
msgid "Precision used in the output file (default, max, or 0 to 52)"
-msgstr ""
-"Liczba miejsc dziesiętnych pliku wyjściowego ('default', 'max' lub 0 - 52)"
+msgstr "Liczba miejsc dziesiętnych pliku wyjściowego ('default', 'max' lub 0 - 52)"
#: ../lib/g3d/g3dparam.c:71
msgid "The compression method used in the output file"
@@ -4190,8 +4014,7 @@
#: ../lib/arraystats/class.c:21
msgid "Discont algorithm currently not available because of bugs"
-msgstr ""
-"Algorytm 'discont' nie jest obecnie dostępny z powodu błędów w oprogramowaniu"
+msgstr "Algorytm 'discont' nie jest obecnie dostępny z powodu błędów w oprogramowaniu"
#: ../lib/arraystats/class.c:23
#, c-format
@@ -4205,12 +4028,8 @@
#: ../lib/arraystats/class.c:221
#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
-msgstr ""
-"Podano przedziały klas spoza zakresu min-max. Liczba klas zmniejszona do %i ,"
-"ale dla klas %i użyto wartości prawdopodobnych."
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
+msgstr "Podano przedziały klas spoza zakresu min-max. Liczba klas zmniejszona do %i ,ale dla klas %i użyto wartości prawdopodobnych."
#: ../lib/ogsf/GVL2.c:248
#, c-format
@@ -4238,8 +4057,7 @@
#: ../lib/ogsf/gsd_legend.c:268
#, c-format
msgid "Unable to read fp range of raster map <%s>"
-msgstr ""
-"Nie można odczytać zakresu danych zmiennoprzecinkowych mapy rastrowej <%s>"
+msgstr "Nie można odczytać zakresu danych zmiennoprzecinkowych mapy rastrowej <%s>"
#: ../lib/ogsf/gsd_legend.c:280
#, c-format
@@ -4252,8 +4070,7 @@
#: ../lib/ogsf/gsd_legend.c:384
msgid "Unable to show discrete FP range (use list"
-msgstr ""
-"Nie można pokazać dyskretnego zakresu zmiennoprzecinkowego. Użyto listy"
+msgstr "Nie można pokazać dyskretnego zakresu zmiennoprzecinkowego. Użyto listy"
#: ../lib/ogsf/gsd_legend.c:500
msgid "Too many categories to show as discrete!"
@@ -4265,7 +4082,7 @@
#: ../lib/ogsf/gsd_surf.c:1742
msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr ""
+msgstr "Punkty płaszczyzny cięcia nie pasują między powierzchniami. Sprawdź rozdzielczość."
#: ../lib/ogsf/gvl_file.c:104
msgid "Maximum number of datafiles exceeded"
@@ -4288,12 +4105,8 @@
#: ../lib/ogsf/gsd_prim.c:630
#, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot(): błędna definicja osi %c. Pominięto rotację. Poinformuj o tym "
-"błędzie programistów GRASSa"
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot(): błędna definicja osi %c. Pominięto rotację. Poinformuj o tym błędzie programistów GRASSa"
#: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/gsd_img_ppm.c:53
#: ../lib/ogsf/gsd_img_ppm.c:96 ../lib/ogsf/GK2.c:219
@@ -4319,9 +4132,7 @@
#: ../lib/ogsf/Gs3.c:647
#, c-format
msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-"Zakres palety kolorów nie zgadza się z zakresem wartości danych (kolor min. "
-"=%d, kolor maks. =%d)"
+msgstr "Zakres palety kolorów nie zgadza się z zakresem wartości danych (kolor min. =%d, kolor maks. =%d)"
#: ../lib/ogsf/Gs3.c:709 ../lib/ogsf/Gs3.c:781
#, c-format
@@ -4339,8 +4150,7 @@
#: ../lib/ogsf/Gv3.c:249
#, c-format
msgid "No features from vector map <%s> fall within current region"
-msgstr ""
-"Żaden z obiektów mapy wektorowej <%s> nie znajduje się w bieżącym regionie"
+msgstr "Żaden z obiektów mapy wektorowej <%s> nie znajduje się w bieżącym regionie"
#: ../lib/ogsf/Gv3.c:254
#, c-format
@@ -4364,8 +4174,7 @@
#: ../lib/ogsf/GS2.c:1636
#, c-format
msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
-"Mapa rastrowa <%s> jest poza bieżącym regionem. Odczyt nie powiódł się."
+msgstr "Mapa rastrowa <%s> jest poza bieżącym regionem. Odczyt nie powiódł się."
#: ../lib/ogsf/GS2.c:1714 ../lib/ogsf/GS2.c:1720 ../lib/ogsf/GS2.c:1728
#: ../lib/ogsf/GS2.c:1737 ../lib/ogsf/GS2.c:1745 ../lib/ogsf/GS2.c:1755
@@ -4388,8 +4197,7 @@
#: ../lib/ogsf/Gp3.c:204
#, c-format
msgid "No points from vector map <%s> fall within current region"
-msgstr ""
-"Żaden z punktów mapy wektorowej <%s> nie znajduje się w bieżącym regionie"
+msgstr "Żaden z punktów mapy wektorowej <%s> nie znajduje się w bieżącym regionie"
#: ../lib/ogsf/Gp3.c:209
#, c-format
@@ -4435,9 +4243,7 @@
#: ../lib/ogsf/gsd_img_mpeg.c:306
msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
-"Nie można odgadnąć formatu wyjściowego na podstawie rozszerzenia pliku. "
-"Użyto MPEG"
+msgstr "Nie można odgadnąć formatu wyjściowego na podstawie rozszerzenia pliku. Użyto MPEG"
#: ../lib/ogsf/gsd_img_mpeg.c:310
msgid "Unable to find suitable output format"
@@ -4576,13 +4382,8 @@
msgstr "Błąd pamięci podczas przydzielania znacznika czasu"
#: ../lib/sites/sites.c:348 ../lib/sites/sites.c:478
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
-msgstr ""
-"Uwaga programistyczna: Punkty wektorowe obsłużone przez zadaptowaną "
-"bibliotekę site'ów. Moduł powinien zostać zaktualizowany do biblioteki "
-"wektorowej GRASS 6."
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
+msgstr "Uwaga programistyczna: Punkty wektorowe obsłużone przez zadaptowaną bibliotekę site'ów. Moduł powinien zostać zaktualizowany do biblioteki wektorowej GRASS 6."
#: ../lib/sites/sites.c:397
msgid "Cannot fetch row"
@@ -4717,8 +4518,7 @@
#: ../lib/gmath/test/test_main.c:107
msgid "Performs benchmarks, unit and integration tests for the gmath library"
-msgstr ""
-"Wykonuje testy wydajności, jednostkowe i integracji dla biblioteki gmath"
+msgstr "Wykonuje testy wydajności, jednostkowe i integracji dla biblioteki gmath"
#: ../lib/gmath/test/test_solvers.c:37
msgid ""
@@ -5089,8 +4889,7 @@
#: ../lib/imagery/list_subgp.c:48
#, c-format
msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-"podgrupa <%s> grupy <%s> odwołuje się do następujących map rastrowych\n"
+msgstr "podgrupa <%s> grupy <%s> odwołuje się do następujących map rastrowych\n"
#~ msgid "Requested g3d map <%s> not found"
#~ msgstr "Żądana mapa rastrowa 3D <%s> nie została znaleziona"
