[GRASS-SVN] r45636 - in grass/branches/develbranch_6: . locale/po
Fri Mar 11 15:21:36 EST 2011
Author: neteler
Date: 2011-03-11 12:21:36 -0800 (Fri, 11 Mar 2011)
New Revision: 45636
   grass/branches/develbranch_6/locale/po/grassmods_it.po
   grass/branches/develbranch_6/translators.csv
Marco Curreli: cont'ed
Modified: grass/branches/develbranch_6/locale/po/grassmods_it.po
--- grass/branches/develbranch_6/locale/po/grassmods_it.po	2011-03-11 20:20:51 UTC (rev 45635)
+++ grass/branches/develbranch_6/locale/po/grassmods_it.po	2011-03-11 20:21:36 UTC (rev 45636)
@@ -1,6 +1,6 @@
 # translation of grassmods_it.po to Italiano
 # This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2005, 2006, 2008 GRASS Development Team
+# Copyright (C) 2005, 2006, 2008, 2011 GRASS Development Team
 # Maurizio Napolitano <napo at itc.it>, 2005.
 # Markus Neteler <neteler at itc.it>, 2005.
@@ -8,13 +8,14 @@
 # Giuseppe Patti <gpatt at tiscali.it>, 2006.
 # Stefano Costa <steko at iosa.it>, 2006.
 # Luca Delucchi <lucadeluge at gmail.com>, 2008.
+# Marco Curreli <marcocurreli at tiscali it>, 2011.
 msgid ""
 msgstr ""
 "Project-Id-Version: grassmods_it\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2011-01-03 15:46+0100\n"
 "PO-Revision-Date: 2008-03-26 17:32+0100\n"
-"Last-Translator: Luca Delucchi <lucadeluge at gmail.com>\n"
+"Last-Translator: Marco Curreli <marcocurreli at tiscali it>\n"
 "Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
@@ -50,7 +51,7 @@
 #: ../raster3d/r3.out.ascii/main.c:103 ../raster/r.out.ascii/main.c:104
 #: ../raster/r.out.arc/main.c:89
 msgid "Suppress printing of header information"
-msgstr "Sopprimi la stampa della informazioni di intestazione"
+msgstr "Sopprime la stampa della informazioni di intestazione"
 #: ../raster3d/r3.out.ascii/main.c:107 ../raster3d/r3.to.rast/main.c:90
 #: ../raster/r.to.rast3elev/main.c:232
@@ -58,9 +59,8 @@
 msgstr ""
 #: ../raster3d/r3.out.ascii/main.c:244
-#, fuzzy
 msgid "raster3d, voxel, export"
-msgstr "Nome mappa raster 3D"
+msgstr ""
 #: ../raster3d/r3.out.ascii/main.c:246
 msgid "Converts a 3D raster map layer into an ASCII text file"
@@ -80,7 +80,7 @@
 #: ../raster3d/r3.out.ascii/main.c:305
 #, fuzzy
 msgid "Error closing new ASCII file"
-msgstr "Errore nell'apertura del file g3d"
+msgstr "Errore nella chiusura del nuovo file ASCII"
 #: ../raster3d/r3.in.ascii/main.c:79
 msgid "Ascii raster map to be imported"
@@ -89,12 +89,12 @@
 #: ../raster3d/r3.in.ascii/main.c:90
 #, fuzzy
 msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr "Stringa rappresentante la cella con i valori NULL"
+msgstr "Stringa rappresentante la cella con valore NULL (usare 'none' se non ci sono valori null)"
 #: ../raster3d/r3.in.ascii/main.c:174
 #, c-format
 msgid "Loading data ...  (%dx%dx%d)"
-msgstr "Carica data ... (%dx%dx%d)"
+msgstr "Caricamento dei dati ... (%dx%dx%d)"
 #: ../raster3d/r3.in.ascii/main.c:190
 msgid "End of file reached while still loading data."
@@ -102,68 +102,61 @@
 #: ../raster3d/r3.in.ascii/main.c:209
 #, c-format
-msgid ""
-"Data exists in input file after fully importing expected data.  [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
 msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:240
-#, fuzzy
 msgid "raster3d, voxel, import"
+msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:242
 msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-msgstr ""
-"Converte un file testuale raster ASCII 3D in un layer raster 3D (binario)"
+msgstr "Converte un file testuale raster ASCII 3D in un layer raster 3D (binario)"
 #: ../raster3d/r3.in.ascii/main.c:274
 #, fuzzy
 msgid "Error closing new 3d raster map"
+msgstr "Errore nella chiusura della nuova mappa raster 3d"
 #: ../raster3d/r3.in.ascii/main.c:284
 #, fuzzy
 msgid "Error closing ascii file"
+msgstr "Errore nella chiusura del file ascii"
 #: ../raster3d/r3.cross.rast/main.c:55
 #, fuzzy
 msgid "Could not close G3D map"
-msgstr "impossibile aprire <%s>"
+msgstr "Impossibile chiudere la mappa G3D"
 #: ../raster3d/r3.cross.rast/main.c:77 ../raster3d/r3.cross.rast/main.c:392
 #: ../raster3d/r3.to.rast/main.c:194
 #, fuzzy
 msgid "Unable to close output map"
-msgstr "Nome del file in output"
+msgstr "Non è possibile chiudere la mappa di output"
 #: ../raster3d/r3.cross.rast/main.c:91
-#, fuzzy
 msgid "Input 3D raster map for cross section."
-msgstr "Stampa solo il tipo di mappa raster"
+msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:98
 msgid "2D elevation map used to create the cross section map"
-msgstr "Mappa di altezze 2D da utilizzare per la creazione della sezione"
+msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:105
-#, fuzzy
 msgid "Resulting cross section 2D raster map"
-msgstr "Mappa raster risultante"
+msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:110
 msgid "Use g3d mask (if exists) with input map"
-msgstr "Usa una mask G3d (se esiste) con la mappa in input"
+msgstr "Usa una mask g3d (se esiste) con la mappa in input"
 #: ../raster3d/r3.cross.rast/main.c:162
-#, fuzzy
 msgid "Unable to get elevation raster row"
-msgstr "Nome del raster"
+msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.cross.rast/main.c:237
-#, fuzzy
 msgid "Could not write raster row"
+msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:270 ../raster3d/r3.to.rast/main.c:215
 #: ../raster3d/r3.out.vtk/main.c:376 ../raster3d/r3.gwflow/main.c:184
@@ -172,25 +165,21 @@
 #: ../raster3d/base/r3.timestamp.main.c:43 ../raster3d/base/r3.mask.main.c:153
 #: ../raster3d/r3.out.v5d/main.c:289
 msgid "raster3d, voxel"
+msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:272
-msgid ""
-"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
-"map"
+msgid "Creates cross section 2D raster map from 3d raster map based on 2D elevation map"
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:284 ../raster3d/r3.to.rast/main.c:228
 #: ../visualization/nviz2/cmd/volume.c:40
 #, fuzzy, c-format
 msgid "3d raster map <%s> not found"
-msgstr "raster <%s> non trovato"
+msgstr "mappa raster 3d <%s> non trovata"
 #: ../raster3d/r3.cross.rast/main.c:298 ../raster/r.to.rast3elev/main.c:462
 #: ../raster/r.to.rast3/main.c:222
-msgid ""
-"The 2d and 3d region settings are different. I will use the g3d settings to "
-"adjust the 2d region."
+msgid "The 2d and 3d region settings are different. I will use the g3d settings to adjust the 2d region."
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:318 ../raster3d/r3.to.rast/main.c:243
@@ -198,71 +187,67 @@
 #: ../raster3d/r3.out.vtk/main.c:293 ../raster3d/r3.out.vtk/main.c:516
 #, fuzzy, c-format
 msgid "Error opening 3d raster map <%s>"
-msgstr "Non riesco a trovare il file raster %s"
+msgstr "Errore nell'apertura della mappa raster 3d <%s>"
 #: ../raster3d/r3.cross.rast/main.c:333
 msgid "Elevation map not found"
-msgstr "Mappa dell'elevazione non trovato"
+msgstr "Mappa di elevazione non trovata"
 #: ../raster3d/r3.cross.rast/main.c:338
 msgid "Unable to open elevation map"
-msgstr "Impossibile aprire la mappa dell'elevazione"
+msgstr "Impossibile aprire la mappa di elevazione"
 #: ../raster3d/r3.cross.rast/main.c:349 ../raster3d/r3.to.rast/main.c:302
 #: ../raster/r.to.rast3/main.c:239
 #, fuzzy
 msgid "Illegal output file name"
-msgstr "Nome del file di output"
+msgstr "Nome del file di output non valido"
 #: ../raster3d/r3.cross.rast/main.c:352
 #, fuzzy
 msgid "Output map already exists. Will be overwritten!"
-msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
+msgstr "Mappa in uscita già esistente. Sarà sovrascritta!"
 #: ../raster3d/r3.cross.rast/main.c:358 ../raster3d/r3.cross.rast/main.c:364
 #, fuzzy
 msgid "Unable to create raster map"
-msgstr "Nome della mappa raster risultante"
+msgstr "Impossibile creare il raster"
 #: ../raster3d/r3.cross.rast/main.c:394
 #, fuzzy
 msgid "Unable to close elevation map"
-msgstr "Nome della mappa di input"
+msgstr "Impossibile chiudere la mappa di elevazione"
 #: ../raster3d/r3.cross.rast/main.c:399
-#, fuzzy
 msgid "Wrong G3D Datatype! Cannot create raster map."
+msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:404
 #, fuzzy, c-format
 msgid "Could not close G3D map <%s>"
+msgstr "impossibile chiudere la mappa G3D <%s>"
 #: ../raster3d/r3.to.rast/main.c:55
 #, fuzzy
 msgid "Unable to close the 3d raster map"
+msgstr "Impossibile chiudere il raster 3d"
 #: ../raster3d/r3.to.rast/main.c:79
 msgid "3d raster map(s) to be converted to 2D raster slices"
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:85
-#, fuzzy
 msgid "Basename for resultant raster slice maps"
+msgstr ""
 #: ../raster3d/r3.to.rast/main.c:95
-msgid ""
-"Use the same resolution as the input G3D map for the 2d output maps, "
-"independent of the current region settings"
+msgid "Use the same resolution as the input G3D map for the 2d output maps, independent of the current region settings"
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:152 ../raster3d/r3.to.rast/main.c:159
 #, fuzzy
 msgid "Unable to write raster row"
+msgstr "Non è possibile scrivere la riga del raster"
 #: ../raster3d/r3.to.rast/main.c:183 ../raster/r.basins.fill/main.c:106
 #: ../raster/r.sun2/main.c:1166 ../raster/r.sun2/main.c:1173
@@ -301,21 +286,19 @@
 #: ../imagery/i.maxlik/open.c:74
 #, fuzzy, c-format
 msgid "Unable to create raster map <%s>"
+msgstr "Impossibile creare la mappa raster <%s>"
 #: ../raster3d/r3.to.rast/main.c:216
 msgid "Converts 3D raster maps to 2D raster maps"
 msgstr "Converte raster 3D in raster 2D"
 #: ../raster3d/r3.to.rast/main.c:225
-#, fuzzy, c-format
+#, c-format
 msgid "Open 3d raster map <%s>"
-msgstr "Nome del driver in input"
+msgstr ""
 #: ../raster3d/r3.to.rast/main.c:267
-msgid ""
-"The 2d and 3d region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
+msgid "The 2d and 3d region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
 msgstr ""
 #: ../raster3d/r3.to.rast/main.c:299 ../raster3d/r3.out.v5d/main.c:202
@@ -356,94 +339,92 @@
 #: ../raster3d/r3.to.rast/main.c:304
 #, fuzzy, c-format
 msgid "Creating %i raster maps"
+msgstr "Creazione di %i mappe raster"
 #: ../raster3d/r3.to.rast/main.c:310
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map %i Filename: %s"
-msgstr "Nome mappa raster"
+msgstr ""
 #: ../raster3d/r3.to.rast/main.c:313
 #, fuzzy, c-format
 msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
+msgstr "Mappa raster %d Nome del file: %s già esistente. Sarà sovrascritto!"
 #: ../raster3d/r3.out.vtk/main.c:99
 #, fuzzy, c-format
 msgid "Could not open map %s"
+msgstr "impossibile aprire la mappa %s"
 #: ../raster3d/r3.out.vtk/main.c:118
 msgid "You have to specify top and bottom map"
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:125
-#, fuzzy, c-format
+#, c-format
 msgid "Top cell map <%s> not found"
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:134
-#, fuzzy, c-format
+#, c-format
 msgid "Bottom cell map <%s> not found"
+msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:143
 #, fuzzy, c-format
 msgid "Requested 3d raster map <%s> not found"
+msgstr "Raster 3d richiesto <%s> non trovato"
 #: ../raster3d/r3.out.vtk/main.c:153
 #, fuzzy, c-format
 msgid "Requested g3d RGB map <%s> not found"
+msgstr "Raster g3d RGB richiesto <%s> non trovato"
 #: ../raster3d/r3.out.vtk/main.c:157
 msgid "Please provide three g3d RGB maps"
-msgstr ""
+msgstr "Fornire tre mappe g3d RGB"
 #: ../raster3d/r3.out.vtk/main.c:167
 #, fuzzy, c-format
 msgid "Requested g3d vector map <%s> not found"
+msgstr "Mappa vettoriale g3d <%s> non trovata"
 #: ../raster3d/r3.out.vtk/main.c:171
 msgid "Please provide three g3d vector maps [x,y,z]"
-msgstr ""
+msgstr "Fornire tre mappe vettoriali g3d [x,y,z]"
 #: ../raster3d/r3.out.vtk/main.c:178
-msgid ""
-"No g3d data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
+msgid "No g3d data, RGB or xyz-vector maps are provided! Will only write the geometry."
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:198
 #, fuzzy, c-format
 msgid "Open rgb 3d raster map %s"
+msgstr "Apre la mappa raster 3d rgb %s"
 #: ../raster3d/r3.out.vtk/main.c:211
 #, fuzzy
 msgid "No RGB Data will be created."
-msgstr "Nome del raster map in output"
+msgstr "Non verrà creato nessun dato RGB."
 #: ../raster3d/r3.out.vtk/main.c:254
 #, fuzzy
 msgid "Error closing g3d rgb map."
-msgstr "Nome di un file vettoriale in output"
+msgstr "Errore nella chiusura della mappa rgb g3d."
 #: ../raster3d/r3.out.vtk/main.c:295
 #, fuzzy
 msgid "No vector data will be created."
-msgstr "file vettoriale da creare"
+msgstr "Non verrà creato nessun dato vettoriale."
 #: ../raster3d/r3.out.vtk/main.c:339
 #, fuzzy
 msgid "Error closing g3d vector map."
+msgstr "Errore nella chiusura della mappa vettoriale g3d."
 #: ../raster3d/r3.out.vtk/main.c:378
 msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-msgstr "Converte raster 3D (G3D) in formato VTK-Ascii"
+msgstr "Converte una mappa raster 3D (G3D) nel formato VTK-Ascii"
 #: ../raster3d/r3.out.vtk/main.c:389
 msgid "failed to interpret dp as an integer"
@@ -454,26 +435,22 @@
 msgstr "dp deve essere fra 0 e 20"
 #: ../raster3d/r3.out.vtk/main.c:451
-msgid ""
-"The 2d and 3d region settings are different. The g3d settings are used to "
+msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:488
 #, fuzzy
 msgid "unable to close top raster map"
+msgstr "impossibile chiudere la mappa raster superiore"
 #: ../raster3d/r3.out.vtk/main.c:493
 #, fuzzy
 msgid "unable to close bottom raster map"
+msgstr "impossibile chiudere la mappa raster inferiore"
 #: ../raster3d/r3.out.vtk/main.c:545
 msgid "Error closing 3d raster map, the VTK file may be incomplete."
-msgstr ""
-"Errore nella chiusura della mappa g3d, il file VTK potrebbe essere "
-"incompleto."
+msgstr "Errore nella chiusura della mappa g3d, il file VTK potrebbe essere incompleto."
 #: ../raster3d/r3.out.vtk/main.c:560 ../raster/r.out.vtk/main.c:393
 msgid "Error closing VTK-ASCII file"
@@ -494,12 +471,12 @@
 #: ../raster3d/r3.out.vtk/errorHandling.c:52
 #, fuzzy
 msgid "unable to close input raster map"
+msgstr "impossibile chiudere la mappa raster di input"
 #: ../raster3d/r3.out.vtk/errorHandling.c:67
 #, fuzzy
 msgid "unable to close input 3d raster map"
+msgstr "impossibile chiudere la mappa raster 3d di input"
 #: ../raster3d/r3.out.vtk/parameters.c:30
 msgid "G3D map(s) to be converted to VTK-ASCII data format"
@@ -508,12 +485,12 @@
 #: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:38
 #, fuzzy
 msgid "Name for VTK-ASCII output file"
+msgstr "Nome del file VTK-ASCII di output"
 #: ../raster3d/r3.out.vtk/parameters.c:41
 #, fuzzy
 msgid "Float value to represent no data cell/points"
-msgstr "strighe che rappresentano le celle prive di valori"
+msgstr "Valori a virgola mobile per rappresentare le celle/punti prive di valori"
 #: ../raster3d/r3.out.vtk/parameters.c:47
 msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
@@ -522,22 +499,19 @@
 #: ../raster3d/r3.out.vtk/parameters.c:56
 #, fuzzy
 msgid "top surface 2D raster map"
-msgstr "Nome del driver in output"
+msgstr "mappa raster 2D della superficie superiore"
 #: ../raster3d/r3.out.vtk/parameters.c:65
 #, fuzzy
 msgid "bottom surface 2D raster map"
-msgstr "mappa raster di base"
+msgstr "mappa raster 2D della superficie inferiore"
 #: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3d elevation output with a top and a bottom surface, both raster maps "
-"are required."
+msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:82
-msgid ""
-"Three (r,g,b) 3d raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgid "Three (r,g,b) 3d raster maps to create rgb values [redmap,greenmap,bluemap]"
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:92
@@ -573,14 +547,13 @@
 msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:131
-#, fuzzy
 msgid "Could not get top raster row \n"
+msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:135
 #, fuzzy
 msgid "Could not get bottom raster row \n"
+msgstr "Impossibile acquisire la riga del raster inferiore \n"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:256
 msgid "write_vtk_unstructured_grid_cells: Writing the cells"
@@ -588,22 +561,17 @@
 #: ../raster3d/r3.out.vtk/writeVTKData.c:334
 #, fuzzy, c-format
-msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
-msgstr ""
-"vriteVTKData. Sto scrivendo Celldata %s con %i righe e %i colonne, "
-"profondità %i nel vtk-ascii file"
+msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
+msgstr "vrite_vtk_data: Scrittura in corso di Celldata %s con %i righe e %i colonne, profondità %i nel vtk-ascii file"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:392
 msgid "write_vtk_rgb_data: writing rgb data"
-msgstr ""
+msgstr "write_vtk_rgb_data: scrittura in corso dei dati rgb"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:429
 #: ../raster3d/r3.out.vtk/writeVTKData.c:462
 msgid "Wrong 3d raster map values! Values should in between 0 and 255!\n"
-msgstr ""
-"Valori della mappa g3d errati! I valori devono essere compresi tra 0 e 255!\n"
+msgstr "Valori della mappa g3d errati! I valori devono essere compresi tra 0 e 255!\n"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:492
 msgid "write_vtk_vector_data: writing vector data"
@@ -638,14 +606,11 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:111
-#, fuzzy
 msgid "Recharge raster map in m^3/s"
+msgstr ""
 #: ../raster3d/r3.gwflow/main.c:118
-msgid ""
-"The piezometric head result of the numerical calculation will be written to "
-"this map"
+msgid "The piezometric head result of the numerical calculation will be written to this map"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:125
@@ -658,17 +623,14 @@
 #: ../raster3d/r3.gwflow/main.c:138
 #, fuzzy
 msgid "Use G3D mask (if exists)"
+msgstr "Usa una mask G3D (se esiste)"
 #: ../raster3d/r3.gwflow/main.c:142
-msgid ""
-"Use a sparse linear equation system, only available with iterative solvers"
+msgid "Use a sparse linear equation system, only available with iterative solvers"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:185
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions"
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:202 ../raster/r.gwflow/main.c:242
@@ -678,32 +640,28 @@
 #: ../raster3d/r3.gwflow/main.c:300 ../raster/r.gwflow/main.c:516
 #, fuzzy
 msgid "Unable to create and solve the linear equation system"
+msgstr "Impossibile creare e risolvere il sistema di equazioni lineari"
 #: ../raster3d/r3.gwflow/main.c:380 ../raster3d/r3.stats/main.c:618
 #: ../raster/r.univar2/r3.univar_main.c:158
 #: ../raster/r.univar2/r3.univar_main.c:200
 #, fuzzy, c-format
 msgid "Error opening g3d map <%s>"
+msgstr "Errore nell'apertura della mappa g3d <%s>"
 #: ../raster3d/r3.gwflow/main.c:382
 #, fuzzy, c-format
 msgid "Write the result to g3d map <%s>"
+msgstr "Scrive il risultato nella mappa g3d"
 #: ../raster3d/r3.gwflow/main.c:426
 #, fuzzy
 msgid "Error closing g3d file"
+msgstr "Errore nella chiusura del file g3d"
 #: ../raster3d/r3.mkdspf/main.c:77
-msgid ""
-"Creates a display file from an existing grid3 file according to specified "
-"threshold levels."
-msgstr ""
-"Crea un file display da un file grid3 in base ai livelli di soglia "
-"specificati."
+msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
+msgstr "Crea un file display da un file grid3 in base ai livelli di soglia specificati."
 #: ../raster3d/r3.mkdspf/main.c:85
 msgid "Name of an existing 3d raster map"
@@ -720,25 +678,24 @@
 #: ../raster3d/r3.mkdspf/main.c:104
 #, fuzzy
 msgid "Minimum isosurface level"
-msgstr "Livello minimo di contorno"
+msgstr "Livello minimo delle isosuperfici"
 #: ../raster3d/r3.mkdspf/main.c:110
 #, fuzzy
 msgid "Maximum isosurface level"
-msgstr "Livello massimo di contorno"
+msgstr "Livello massimo delle isosuperfici"
 #: ../raster3d/r3.mkdspf/main.c:116
-#, fuzzy
 msgid "Positive increment between isosurface levels"
-msgstr "Incremento di contorno fra i livelli"
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:123
 msgid "Number of isosurface threshold levels"
-msgstr "Numero di livelli di contorno."
+msgstr ""
 #: ../raster3d/r3.mkdspf/main.c:127
 msgid "Suppress progress report & min/max information"
-msgstr "Annulla le informazioni sull'andamento & sul minimo/massimo"
+msgstr "Annulla le informazioni sull'andamento e sul minimo/massimo"
 #: ../raster3d/r3.mkdspf/main.c:131
 msgid "Use flat shading rather than gradient"
@@ -752,12 +709,12 @@
 #: ../raster3d/r3.mkdspf/main.c:151
 #, c-format
 msgid "Not able to find grid3 file for [%s]"
-msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgstr "Impossibile trovare il file grid3 per [%s]"
 #: ../raster3d/r3.mkdspf/main.c:163 ../raster3d/base/r3.info.main.c:128
 #, c-format
 msgid "Error opening grid3 file [%s]"
-msgstr "Errore nell'aperura del file grid3 [%s]"
+msgstr "Errore nell'apertura del file grid3 [%s]"
 #: ../raster3d/r3.mkdspf/main.c:166 ../raster3d/base/r3.info.main.c:287
 #: ../raster3d/base/r3.info.main.c:349
@@ -776,19 +733,16 @@
 msgstr "Sto scrivendo %s da %s..."
 #: ../raster3d/r3.stats/main.c:568 ../raster/r.univar2/r3.univar_main.c:104
-#, fuzzy
 msgid "raster3d, statistics"
-msgstr "Nome della mappa raster da utilizzare per <%s>"
+msgstr ""
 #: ../raster3d/r3.stats/main.c:569
-#, fuzzy
 msgid "Generates volume statistics for raster3d maps."
-msgstr "Genera statistiche per layer raster"
+msgstr ""
 #: ../raster3d/r3.stats/main.c:580
-#, fuzzy
 msgid "Number of sub-ranges to collect stats from"
-msgstr "Nome della mappa raster che contiene i risultati"
+msgstr ""
 #: ../raster3d/r3.stats/main.c:586
 msgid "Calculate statistics based on equal value groups"
@@ -802,7 +756,7 @@
 #: ../raster/r.univar2/r3.univar_main.c:193
 #, fuzzy, c-format
 msgid "Requested g3d map <%s> not found"
+msgstr "La mappa g3d richiesta <%s> non è stata trovata"
 #: ../raster3d/r3.stats/main.c:664
 msgid "Sort non-null values"
@@ -827,11 +781,11 @@
 #: ../raster3d/base/r3.null.main.c:113
 msgid "modifyNull: error opening map"
-msgstr "modifyNull. Errore nell'apertura della mappa"
+msgstr "modifyNull: errore nell'apertura della mappa"
 #: ../raster3d/base/r3.null.main.c:125
 msgid "modifyNull: error opening tmp file"
-msgstr "modifyNull. Errore nell'aperura del file tmp"
+msgstr "modifyNull: errore nell'aperura del file tmp"
 #: ../raster3d/base/r3.null.main.c:174
 msgid "modifyNull: error flushing tiles in cube"
@@ -860,7 +814,7 @@
 #: ../raster3d/base/r3.info.main.c:87
 #, fuzzy
 msgid "Name of input 3D raster map"
-msgstr "Nome di  2-%d mappe raster in input"
+msgstr "Nome della mappa raster 3D in input"
 #: ../raster3d/base/r3.info.main.c:91 ../raster/r.info/main.c:77
 msgid "Print range only"
@@ -869,28 +823,26 @@
 #: ../raster3d/base/r3.info.main.c:96
 #, fuzzy
 msgid "Print 3D raster map resolution (NS-res, EW-res, TB-res) only"
-msgstr "Stampa solo la risoluzione (NS-ris, OE-ris)"
+msgstr "Stampa solo la risoluzione della mappa raster 3D (NS-ris, OE-ris)"
 #: ../raster3d/base/r3.info.main.c:100
 #, fuzzy
 msgid "Print 3D raster map type (float/double) only"
+msgstr "Stampa solo il tipo di mappa raster 3D (float/double)"
 #: ../raster3d/base/r3.info.main.c:104
 #, fuzzy
 msgid "Print 3D raster map region only"
+msgstr "Stampa solo la regione della mappa raster 3D"
 #: ../raster3d/base/r3.info.main.c:108
 #, fuzzy
 msgid "Print 3D raster history instead of info"
-msgstr "tabelle di sistema invece che tabelle utente"
+msgstr "Stampa solo la cronologia del raster 3D invece delle informazioni"
 #: ../raster3d/base/r3.info.main.c:113
 msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr ""
-"Stampa esclusivamente il timestamp (giorno.mese.anno ora.minuti.secondi) di "
-"un raster 3D"
+msgstr "Stampa esclusivamente il timestamp (giorno.mese.anno ora.minuti.secondi) di un raster 3D"
 #: ../raster3d/base/r3.info.main.c:121 ../raster/r.out.bin/main.c:129
 #: ../raster/r.out.gridatb/check_ready.c:12 ../raster/r.median/main.c:75
@@ -996,7 +948,7 @@
 #: ../imagery/i.class/main.c:127
 #, fuzzy, c-format
 msgid "Raster map <%s> not found"
+msgstr "Mappa raster <%s> non trovata"
 #: ../raster3d/base/r3.info.main.c:158 ../raster3d/base/r3.info.main.c:166
 #: ../raster3d/base/r3.info.main.c:172 ../raster3d/base/r3.info.main.c:177
@@ -1016,7 +968,7 @@
 #: ../raster3d/base/r3.info.main.c:404
 #, fuzzy
 msgid "Error while reading history file"
+msgstr "Errore nella lettura del file della cronologia"
 #: ../raster3d/base/r3.timestamp.main.c:45
 msgid "Print/add/remove a timestamp for a 3D raster map"
@@ -1025,31 +977,30 @@
 #: ../raster3d/base/r3.timestamp.main.c:52
 #, fuzzy
 msgid "Input grid3 filename"
+msgstr "Nome del file grid3 di input"
 #: ../raster3d/base/r3.timestamp.main.c:59
-#, fuzzy
 msgid "Datetime, datetime1/datetime2, or none"
-msgstr "nessuno"
+msgstr ""
 #: ../raster3d/base/r3.timestamp.main.c:74
 #, fuzzy, c-format
 msgid "Grid3 <%s> not found %s"
+msgstr "Grid3 <%s> non trovato %s"
 #: ../raster3d/base/mask_functions.c:82
 #, c-format
 msgid "Adding rule: %lf - %lf"
-msgstr ""
+msgstr "Aggiunta della regola in corso: %lf - %lf"
 #: ../raster3d/base/mask_functions.c:100 ../raster/r.null/null.c:260
-#, fuzzy, c-format
+#, c-format
 msgid "%s: illegal value spec"
+msgstr ""
 #: ../raster3d/base/r3.mask.main.c:44
 msgid "3d raster map with reference values"
-msgstr "Mappa 3dcell con valori di riferimento"
+msgstr "Mappa raster 3d con valori di riferimento"
 #: ../raster3d/base/r3.mask.main.c:52
 msgid "List of cell values to be masked out"
@@ -1057,7 +1008,7 @@
 #: ../raster3d/base/r3.mask.main.c:84
 msgid "makeMask: error opening map."
-msgstr "makeMask. Errore nell'apertura della mappa"
+msgstr "makeMask: errore nell'apertura della mappa"
 #: ../raster3d/base/r3.mask.main.c:95
 msgid "makeMask: error opening g3d mask file"
@@ -1098,7 +1049,7 @@
 #: ../raster3d/r3.out.v5d/main.c:79
 #, fuzzy
 msgid "Name for v5d output file"
+msgstr "Nome del file v5d di output"
 #: ../raster3d/r3.out.v5d/main.c:149
 #, c-format
@@ -1126,7 +1077,7 @@
 #: ../raster3d/r3.out.v5d/main.c:298
 #, fuzzy
 msgid "Use map coordinates instead of xyz coordinates"
-msgstr "Utilizzando le coordinate del centro della mappa\n"
+msgstr "Utilizzare le coordinate della mappa invece delle coordinate xyz"
 #: ../raster/r.out.bin/main.c:63 ../raster/r.out.gridatb/main.c:44
 #: ../raster/r.median/main.c:46 ../raster/r.his/main.c:63
@@ -1176,12 +1127,12 @@
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
 #: ../imagery/i.zc/main.c:69
 msgid "Name of input raster map"
-msgstr "Nome della mappa raster d'inserimento dati"
+msgstr "Nome della mappa raster di input"
 #: ../raster/r.out.bin/main.c:80
 #, fuzzy
 msgid "Name for output binary map (use output=- for stdout)"
-msgstr "Nome della mappa binaria in output (usa out=- per lo standard output)"
+msgstr "Nome della mappa binaria di output (usare out=- per lo standard output)"
 #: ../raster/r.out.bin/main.c:87
 msgid "Value to write out for null"
@@ -1189,26 +1140,24 @@
 #: ../raster/r.out.bin/main.c:92 ../raster/r.what/main.c:143
 msgid "Output integer category values, not cell values"
-msgstr ""
-"Visualizzare i valori delle categorie integer e non i valori delle celle"
+msgstr "Visualizzare i valori delle categorie integer e non i valori delle celle"
 #: ../raster/r.out.bin/main.c:96
 #, fuzzy
 msgid "Export array with GMT compatible header"
-msgstr "Esporta un Array con l'intestazione GTM compatibile"
+msgstr "Esporta un array con l'intestazione GTM compatibile"
 #: ../raster/r.out.bin/main.c:100
 msgid "Generate BIL world and header files"
-msgstr "Genera file BILL word e header"
+msgstr "Genera file BIL, world e header"
 #: ../raster/r.out.bin/main.c:104
-#, fuzzy
 msgid "Byte swap output"
-msgstr "Crea output 3D"
+msgstr ""
 #: ../raster/r.out.bin/main.c:110
 msgid "Invalid value for null (integers only)"
-msgstr ""
+msgstr "Valore per null non valido (solo interi)"
 #: ../raster/r.out.bin/main.c:133 ../raster/r.his/main.c:131
 #: ../raster/r.his/main.c:154 ../raster/r.his/main.c:179
@@ -1276,37 +1225,36 @@
 #: ../imagery/i.cluster/open_files.c:56 ../imagery/i.maxlik/open.c:41
 #, fuzzy, c-format
 msgid "Unable to open raster map <%s>"
+msgstr "Impossibile aprire la mappa raster <%s>"
 #: ../raster/r.out.bin/main.c:145 ../raster/r.out.bin/main.c:231
 #: ../raster/r.out.bin/main.c:235
 #, fuzzy, c-format
 msgid "Unable to create file <%s>"
+msgstr "Impossibile creare il file <%s>"
 #: ../raster/r.out.bin/main.c:181
 msgid "Swapping header data"
 msgstr ""
 #: ../raster/r.out.bin/main.c:238
-#, fuzzy
 msgid "Creating BIL support files..."
-msgstr "Errore nella lettura del file dbmscap\n"
+msgstr ""
 #: ../raster/r.out.bin/main.c:239
 #, fuzzy, c-format
 msgid "Header File = %s"
+msgstr "File di intestazione = %s"
 #: ../raster/r.out.bin/main.c:240
 #, c-format
 msgid "World File = %s"
-msgstr ""
+msgstr "File world = %s"
 #: ../raster/r.out.bin/main.c:316
 #, fuzzy, c-format
 msgid "Exporting raster as integer values (bytes=%d)"
-msgstr "Nome del raster map esistente"
+msgstr "Esportazione in corso del raster come valori interi (bytes=%d)"
 #: ../raster/r.out.bin/main.c:319
 msgid "Writing GMT integer format ID=2"
@@ -1315,7 +1263,7 @@
 #: ../raster/r.out.bin/main.c:322
 #, fuzzy, c-format
 msgid "Exporting raster as floating values (bytes=%d)"
+msgstr "Esportazione in corso del raster come valori a virgola mobile (bytes=%d)"
 #: ../raster/r.out.bin/main.c:325
 msgid "Writing GMT float format ID=1"
@@ -1324,12 +1272,12 @@
 #: ../raster/r.out.bin/main.c:328
 #, fuzzy, c-format
 msgid "Exporting raster as double values (bytes=%d)"
+msgstr "Esportazione in corso del raster come valori a precisione doppia (double) (bytes=%d)"
 #: ../raster/r.out.bin/main.c:331
 #, fuzzy
 msgid "Using the current region settings..."
-msgstr "Utilizza la regione corrente"
+msgstr "Si stanno utilizzando le impostazioni della regione corrente..."
 #: ../raster/r.out.bin/main.c:332
 #, c-format
@@ -1364,11 +1312,11 @@
 #: ../raster/r.out.bin/main.c:341
 #, fuzzy
 msgid "Reading map"
+msgstr "Lettura della mappa"
 #: ../raster/r.out.gridatb/main.c:46
 msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
-msgstr "Esporta raster GRASS in un file GRIDATB.FOR (TOPMODEL)"
+msgstr "Esporta una mappa raster GRASS in un file GRIDATB.FOR (TOPMODEL)"
 #: ../raster/r.out.gridatb/main.c:50
 msgid "Input map"
@@ -1380,12 +1328,11 @@
 #: ../raster/r.out.gridatb/main.c:63
 msgid "Overwrite output map file"
-msgstr "Sovrascrivi file mappa in output"
+msgstr "Sovrascrive file mappa in output"
 #: ../raster/r.out.gridatb/file_io.c:38
-#, fuzzy
 msgid "Setting window header"
-msgstr "Punti di partenza del file raster"
+msgstr ""
 #: ../raster/r.out.gridatb/file_io.c:41 ../raster/r.in.gridatb/file_io.c:36
 msgid "Rows changed"
@@ -1396,25 +1343,23 @@
 msgstr ""
 #: ../raster/r.median/main.c:48
-msgid ""
-"Finds the median of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
+msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
 msgstr ""
 #: ../raster/r.median/main.c:54
 #, fuzzy
 msgid "Name of base raster map"
-msgstr "Nome della mappa raster"
+msgstr "Nome della mappa raster di base"
 #: ../raster/r.median/main.c:58 ../raster/r.random/main.c:62
 #, fuzzy
 msgid "Name of cover raster map"
+msgstr "Nome della mappa raster di copertura"
 #: ../raster/r.median/main.c:71
 #, fuzzy, c-format
 msgid "Base raster map <%s> not found"
+msgstr "Mappa raster di base <%s> non trovata"
 #: ../raster/r.median/main.c:77 ../raster/r.surf.gauss/main.c:77
 #: ../raster/r.walk/main.c:554 ../raster/r.walk/main.c:558
@@ -1444,7 +1389,7 @@
 #: ../imagery/i.fft/fftmain.c:121 ../imagery/i.fft/fftmain.c:124
 #, fuzzy, c-format
 msgid "<%s> is an illegal file name"
-msgstr "[%s] è un nome illegale"
+msgstr "<%s> è un nome di file non valido"
 #: ../raster/r.median/main.c:79
 #, c-format
@@ -1454,30 +1399,28 @@
 #: ../raster/r.median/main.c:82
 #, fuzzy, c-format
 msgid "Unable to read category labels of raster map <%s>"
-msgstr "Impossibile salvare la region <%s>"
+msgstr "Impossibile leggere le etichette di categoria della mappa raster <%s>"
 #: ../raster/r.median/read_stats.c:14 ../raster/r.statistics/read_stats.c:20
 #, fuzzy
 msgid "Reading r.stats output"
+msgstr "Lettura in corso dell'output di r.stats"
 #: ../raster/r.his/main.c:65
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Genera mappe raster separate per le componenti rosso, verde e blu combinando i valori di tonalità (hue), intensità (intensity), e saturazione (saturation) (HIS) di mappe raster di input definite dall’utente."
 #: ../raster/r.his/main.c:74 ../display/d.his/main.c:76
 msgid "Name of layer to be used for HUE"
-msgstr ""
+msgstr "Nome del layer da utilizzare per TONALITÀ"
 #: ../raster/r.his/main.c:81 ../display/d.his/main.c:83
 msgid "Name of layer to be used for INTENSITY"
-msgstr ""
+msgstr "Nome del layer da utilizzare per INTENSITÀ"
 #: ../raster/r.his/main.c:88 ../display/d.his/main.c:90
 msgid "Name of layer to be used for SATURATION"
-msgstr ""
+msgstr "Nome del layer da utilizzare per SATURAZIONE"
 #: ../raster/r.his/main.c:95
 msgid "Name of output layer to be used for RED"
@@ -1504,22 +1447,22 @@
 #: ../display/d.rast.num/number.c:278
 #, fuzzy, c-format
 msgid "Color file for <%s> not available"
-msgstr "file raster per la Vista%d"
+msgstr "File del colore per <%s> non disponibile"
 #: ../raster/r.his/main.c:243
 #, fuzzy
 msgid "Error reading 'hue' map"
+msgstr "Errore nella lettura della mappa 'tonalità'"
 #: ../raster/r.his/main.c:247
 #, fuzzy
 msgid "Error reading 'intensity' map"
+msgstr "Errore nella lettura della mappa 'intensità'"
 #: ../raster/r.his/main.c:251
 #, fuzzy
 msgid "Error reading 'saturation' map"
+msgstr "Errore nella lettura della mappa 'saturazione'"
 #: ../raster/r.out.mat/main.c:64 ../raster/r.out.ascii/main.c:59
 #: ../raster/r.out.ppm/main.c:54 ../raster/r.out.tiff/r.out.tiff.c:99
@@ -1531,7 +1474,7 @@
 #: ../raster/r.out.mat/main.c:65
 msgid "Exports a GRASS raster to a binary MAT-File."
-msgstr "Esporta a raster GRASS in un MAT-File binario"
+msgstr "Esporta un raster GRASS in un MAT-File binario"
 #: ../raster/r.out.mat/main.c:76
 msgid "Name for the output binary MAT-File"
@@ -1550,26 +1493,24 @@
 #: ../raster/r.out.tiff/r.out.tiff.c:144 ../raster/r.in.mat/main.c:125
 #: ../display/d.mon/pgms/release.c:36 ../display/d.vect/main.c:411
 #: ../vector/v.kernel/main.c:191 ../visualization/nviz/src/nviz_init.c:34
-msgid ""
-"The '-v' flag is superseded and will be removed in future. Please use '--"
-"verbose' instead."
-msgstr ""
+msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
+msgstr "Il flag '-v' è superato e in futuro verrà rimosso. Al suo posto usare '--verbose'."
 #: ../raster/r.out.mat/main.c:115 ../raster/r.out.pov/main.c:186
 #: ../raster/r.out.png/r.out.png.c:233 ../raster/r.colors.out/main.c:101
 #, fuzzy, c-format
 msgid "Unable to open output file <%s>"
+msgstr "impossibile aprire il file di output <%s>"
 #: ../raster/r.out.mat/main.c:137
 #, fuzzy, c-format
 msgid "Exporting <%s>"
-msgstr "Sto disegnando ..."
+msgstr "Esportazione di <%> in corso"
 #: ../raster/r.out.mat/main.c:197
 #, fuzzy
 msgid "Using the Current Region settings:"
+msgstr "Si stanno utilizzando le impostazioni della regione corrente:"
 #: ../raster/r.out.mat/main.c:198 ../raster/r.in.mat/main.c:415
 #, c-format
@@ -1604,58 +1545,53 @@
 #: ../raster/r.out.mat/main.c:204 ../raster/r.in.mat/main.c:421
 #, fuzzy, c-format
 msgid "rows=%d"
-msgstr "righe:    %d"
+msgstr "righe=%d"
 #: ../raster/r.out.mat/main.c:205 ../raster/r.in.mat/main.c:422
 #, fuzzy, c-format
 msgid "cols=%d"
-msgstr "colonne: %d"
+msgstr "colonne=%d"
 #: ../raster/r.out.mat/main.c:272
 #, fuzzy
 msgid "Exporting raster as integer values"
+msgstr "Esportazione del raster come valori interi"
 #: ../raster/r.out.mat/main.c:277
 msgid "Exporting raster as floating point values"
-msgstr ""
+msgstr "Esportazione del raster come valori a virgola mobile"
 #: ../raster/r.out.mat/main.c:282
 msgid "Exporting raster as double FP values"
-msgstr ""
+msgstr "Esportazione del raster come valori a virgola mobile con precisione doppia"
 #: ../raster/r.out.mat/main.c:325
-#, fuzzy
 msgid "Reading in map ... "
+msgstr ""
 #: ../raster/r.out.mat/main.c:339
-#, fuzzy
 msgid "Writing out map..."
+msgstr ""
 #: ../raster/r.out.mat/main.c:399
 #, fuzzy, c-format
 msgid "%ld bytes written to '%s'"
-msgstr "Valore da scrivere per null"
+msgstr "%ld byte scritti in '%s'"
 #: ../raster/r.in.poly/main.c:29 ../raster/r.in.gdal/main.c:79
 #: ../raster/r.in.bin/main.c:122 ../raster/r.external/main.c:506
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
-#, fuzzy
 msgid "raster, import"
-msgstr "File di input"
+msgstr ""
 #: ../raster/r.in.poly/main.c:31
 msgid "Creates raster maps from ASCII polygon/line/point data files."
-msgstr "Crea raster da file ASCII poligonale/lineare/puntuale"
+msgstr "Crea mappe raster da file ASCII poligonale/lineare/puntuale"
 #: ../raster/r.in.poly/main.c:35
 #, fuzzy
 msgid "Name of input file; or \"-\" to read from stdin"
-msgstr ""
-"File ASCII contenente la singola linea descrivente la proiezione WKT (- per "
-"stdin)"
+msgstr "Nome del file di input; o \"-\" per leggere dallo stdin"
 #: ../raster/r.in.poly/main.c:44 ../raster/r.in.gdal/main.c:120
 #: ../raster/r.in.bin/main.c:166 ../raster/r.external/main.c:536
@@ -1665,32 +1601,32 @@
 #: ../raster/r.in.poly/main.c:50 ../vector/v.to.rast/main.c:99
 msgid "Number of rows to hold in memory"
-msgstr "Nume di righe da tenere in memoria"
+msgstr "Numero di righe da tenere in memoria"
 #: ../raster/r.in.poly/main.c:59
 #, fuzzy
 msgid "Minimum number of rows to hold in memory is 1"
+msgstr "Il numero minimo di righe da tenere in memoria è 1"
 #: ../raster/r.in.poly/get_item.c:75
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal coordinate <%s, %s>, skipping."
+msgstr ""
 #: ../raster/r.in.poly/get_item.c:80
 #, fuzzy, c-format
 msgid "Illegal north coordinate <%s>, skipping."
-msgstr "Coordinate nord non validi <%s>"
+msgstr "Coordinate nord non valide <%s>"
 #: ../raster/r.in.poly/get_item.c:85
 #, fuzzy, c-format
 msgid "Illegal east coordinate <%s>, skipping."
-msgstr "Coordinate est non validi <%s>"
+msgstr "Coordinate est non valide <%s>"
 #: ../raster/r.in.poly/poly2rast.c:36
 #, fuzzy, c-format
 msgid "Can't create raster map <%s>"
 #: ../raster/r.in.poly/poly2rast.c:56 ../raster/r.in.xyz/main.c:528
 #, c-format
@@ -1701,36 +1637,35 @@
 #: ../vector/v.to.rast/vect2rast.c:182
 #, fuzzy
 msgid "Writing raster map..."
+msgstr "Scrittura della mappa raster in corso..."
 #: ../raster/r.contour/main.c:91
-#, fuzzy
 msgid "raster, DEM, contours, vector"
+msgstr ""
 #: ../raster/r.contour/main.c:92
 msgid "Produces a vector map of specified contours from a raster map."
-msgstr "Produce un vettore dei contorni specificati da un raster"
+msgstr "Produce una mappa vettoriale di curve di livello in base a parametri specificati a partire da una mappa raster"
 #: ../raster/r.contour/main.c:104
 msgid "List of contour levels"
-msgstr "List dei livelli di contorno"
+msgstr "Lista delle isoipse"
 #: ../raster/r.contour/main.c:110
 msgid "Minimum contour level"
+msgstr "Livello minimo delle isoipse"
 #: ../raster/r.contour/main.c:116
 msgid "Maximum contour level"
+msgstr "Livello massimo delle isoipse"
 #: ../raster/r.contour/main.c:122
 msgid "Increment between contour levels"
+msgstr "Incremento fra le isoipse (equidistanza)"
 #: ../raster/r.contour/main.c:130
 msgid "Minimum number of points for a contour line (0 -> no limit)"
-msgstr "Numero minimo di punto per una linea di contorno (0 > nessun limite)"
+msgstr "Numero minimo di punto per una curva di livello (0 -> nessun limite)"
 #: ../raster/r.contour/main.c:135 ../raster/r.describe/main.c:107
 #: ../raster/r.out.png/r.out.png.c:136 ../raster/r.compress/main.c:82
@@ -1749,10 +1684,8 @@
 msgstr ""
 #: ../raster/r.contour/main.c:147
-msgid ""
-"The '-q' and '-n' flag is superseded and will be removed in future. Please "
-"use '--quiet' instead."
-msgstr ""
+msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
+msgstr "I flag '-q' and '-n sono superati e in futuro verranno rimossi. Al loro posto usare '--quiet'."
 #: ../raster/r.contour/main.c:152
 msgid "Neither \"levels\" nor \"step\" parameter specified."
@@ -1762,7 +1695,7 @@
 #: ../raster/r.recode/read_rules.c:19
 #, fuzzy, c-format
 msgid "Unable to read fp range of raster map <%s>"
+msgstr "Impossibile leggere l'intervallo fp della mappa raster <%s>"
 #: ../raster/r.contour/main.c:185 ../raster/r.random/random.c:74
 #: ../raster/r.to.vect/main.c:158 ../display/d.vect.chart/plot.c:44
@@ -1805,7 +1738,7 @@
 #: ../ps/ps.map/catval.c:182
 #, fuzzy, c-format
 msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Non riesco ad aprire il database %s col driver %s"
+msgstr "Impossibile aprire il database <%s> col driver <%s>"
 #: ../raster/r.contour/main.c:196 ../vector/v.in.ogr/main.c:790
 #: ../vector/v.net.distance/main.c:208 ../vector/v.distance/main.c:818
@@ -1817,7 +1750,7 @@
 #: ../vector/v.net.components/main.c:147
 #, fuzzy, c-format
 msgid "Unable to create table: '%s'"
+msgstr "Impossibile creare la tabella: %s"
 #: ../raster/r.contour/main.c:201 ../vector/v.in.ogr/main.c:795
 #: ../vector/v.in.sites/main.c:174 ../vector/v.in.dxf/write_vect.c:225
@@ -1826,7 +1759,7 @@
 #: ../vector/v.in.ascii/in.c:505
 #, fuzzy, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
+msgstr "Impossibile creare l'indice per la tabella <%s>, chiave <%s>"
 #: ../raster/r.contour/main.c:206 ../raster/r.to.vect/main.c:203
 #: ../vector/v.sample/main.c:223 ../vector/v.in.ogr/main.c:801
@@ -1838,68 +1771,65 @@
 #: ../vector/v.in.ascii/in.c:395
 #, fuzzy, c-format
 msgid "Unable to grant privileges on table <%s>"
-msgstr "Permessi non sufficienti per accedere alla tabella %s"
+msgstr "Impossibile assegnare i privilegi sulla tabella <%s>"
 #: ../raster/r.contour/main.c:224 ../vector/v.overlay/line_area.c:217
 #: ../vector/v.overlay/area_area.c:238 ../vector/v.convert/att.c:110
 #: ../vector/v.to.points/main.c:63
 #, c-format
 msgid "Unable to insert new record: '%s'"
-msgstr "Non posso inserire un nuovo record: '%s'"
+msgstr "Impossibile inserire un nuovo record: '%s'"
 #: ../raster/r.contour/main.c:244 ../vector/v.generalize/displacement.c:78
 #, fuzzy
 msgid "Reading data..."
+msgstr "Lettura dei dati in corso ..."
 #: ../raster/r.contour/main.c:270
 #, fuzzy, c-format
 msgid "Range of data: min=%f, max=%f"
+msgstr "Intervallo dei dati: min=%f, max=%f"
 #: ../raster/r.contour/main.c:272
 #, fuzzy
 msgid "Range of data: empty"
+msgstr "Intervallo dei dati: vuoto"
 #: ../raster/r.contour/main.c:299 ../raster/r.contour/main.c:303
 #, fuzzy
 msgid "This step value is not allowed"
+msgstr "Questo valore di equidistanza non è consentito"
 #: ../raster/r.contour/main.c:327
 #, c-format
 msgid "Range of levels: min = %f, max = %f"
-msgstr ""
+msgstr "Campo di variazione delle isoipse: min = %f, max = %f"
 #: ../raster/r.contour/main.c:356
-#, fuzzy
 msgid "Displacing data..."
+msgstr ""
 #: ../raster/r.contour/cont.c:81
 #, fuzzy, c-format
 msgid "Writing vector contours (total levels %d)..."
+msgstr "Scrittura delle isoipse vettoriali in corso (isoipse totali %d)..."
 #: ../raster/r.contour/cont.c:211
-#, fuzzy, c-format
+#, c-format
 msgid "%d crossings founds"
+msgstr ""
 #: ../raster/r.contour/cont.c:262
-#, fuzzy
 msgid "Illegal edge number"
+msgstr ""
 #: ../raster/r.contour/cont.c:370
-#, fuzzy
 msgid "Edge number out of range"
-msgstr "Numero di righe"
+msgstr ""
 #: ../raster/r.out.pov/main.c:123
 msgid "Converts a raster map layer into a height-field file for POVRAY."
-msgstr ""
+msgstr "Converte una mappa raster in un file height field per POVRAY"
 #: ../raster/r.out.pov/main.c:131 ../raster/r.out.ascii/main.c:70
 msgid "Name of an existing raster map"
@@ -1924,12 +1854,12 @@
 #: ../raster/r.out.pov/main.c:183
 #, fuzzy, c-format
 msgid "Invalid output filename <%s>"
 #: ../raster/r.out.pov/main.c:193
 #, c-format
 msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr ""
+msgstr "La mappa raster è troppo grande! %d colonne o %d righe in eccedenza"
 #: ../raster/r.out.pov/main.c:214
 msgid "Negative elevation values in input"
@@ -1939,24 +1869,21 @@
 #: ../raster/r.watershed/front/main.c:56 ../raster/r.fill.dir/main.c:84
 #: ../raster/r.topmodel/main.c:55 ../raster/r.water.outlet/main.c:48
 #: ../raster/r.carve/main.c:77 ../raster/r.topidx/main.c:37
-#, fuzzy
 msgid "raster, hydrology"
+msgstr ""
 #: ../raster/r.basins.fill/main.c:55
 #, fuzzy
 msgid "Generates watershed subbasins raster map."
+msgstr "Genera una mappa rater di sottobacini idrografici"
 #: ../raster/r.basins.fill/main.c:59
-#, fuzzy
 msgid "Name of input coded stream network raster map"
+msgstr ""
 #: ../raster/r.basins.fill/main.c:63
-#, fuzzy
 msgid "Name of input thinned ridge network raster map"
+msgstr ""
 #: ../raster/r.basins.fill/main.c:72
 msgid "Number of passes through the dataset"
@@ -1965,22 +1892,21 @@
 #: ../raster/r.basins.fill/main.c:99 ../raster/r.in.gdal/main.c:229
 #, fuzzy, c-format
 msgid "Raster map <%s> already exists"
-msgstr "ERRORE: <%s> esiste già\n"
+msgstr "La mappa raster <%s> esiste già"
 #: ../raster/r.basins.fill/main.c:131
 msgid "Forward sweep complete"
 msgstr ""
 #: ../raster/r.basins.fill/main.c:148
-#, fuzzy
 msgid "Reverse sweep complete"
-msgstr "Mappa(e) raster da leggere"
+msgstr ""
 #: ../raster/r.basins.fill/main.c:155 ../raster/r.resample/main.c:152
 #: ../raster/r.cross/main.c:194
-#, fuzzy, c-format
+#, c-format
 msgid "Creating support files for <%s>..."
+msgstr ""
 #: ../raster/r.describe/main.c:61
 msgid "Prints terse list of category values found in a raster map layer."
@@ -1991,9 +1917,8 @@
 msgstr ""
 #: ../raster/r.describe/main.c:80
-#, fuzzy
 msgid "Number of quantization steps"
+msgstr ""
 #: ../raster/r.describe/main.c:86
 msgid "Print the output one value per line"
@@ -2027,9 +1952,7 @@
 #: ../raster/r.distance/parse.c:72 ../raster/r.carve/main.c:127
 #: ../raster/r.neighbors/main.c:292 ../vector/v.qcount/main.c:117
 #: ../vector/v.mkgrid/main.c:141
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
+msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
 msgstr ""
 #: ../raster/r.describe/main.c:126
@@ -2040,52 +1963,42 @@
 #: ../raster/r.describe/main.c:137
 #, fuzzy, c-format
 msgid "%s: [%s] not found"
+msgstr "%s: [%s] non trovato"
 #: ../raster/r.le/r.le.trace/main.c:59
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
 msgstr ""
 #: ../raster/r.le/r.le.setup/sample.c:1050
 #, fuzzy
 msgid "Cannot read vector"
-msgstr "Non riesco ad impostare user/password"
+msgstr "Impossibile leggere il vettore"
 #: ../raster/r.le/r.le.setup/main.c:63
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
 msgstr ""
 #: ../raster/r.le/r.le.setup/main.c:67
 #, fuzzy
 msgid "Raster map to use to setup sampling"
+msgstr "Mappa raster da usare per impostare il campionamento"
 #: ../raster/r.le/r.le.setup/main.c:71
 #, fuzzy
 msgid "Vector map to overlay"
+msgstr "Mappa vettoriale da sovrapporre"
 #: ../raster/r.le/r.le.patch/main.c:49
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
+msgstr "Calcola attributo, dimensione della patch, estensione dell'area centrale (interna), forma, dimensione frattale e misure di perimetro per insiemi di patch in un paesaggio"
 #: ../raster/r.le/r.le.pixel/main.c:47
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
 msgstr ""
 #: ../raster/r.mfilter.fp/main.c:58 ../raster/r.mfilter/main.c:51
-#, fuzzy
 msgid "raster, map algebra"
+msgstr ""
 #: ../raster/r.mfilter.fp/main.c:59
 msgid "Raster map matrix filter."
@@ -2094,7 +2007,7 @@
 #: ../raster/r.mfilter.fp/main.c:70
 #, fuzzy
 msgid "Name of filter file"
-msgstr "Nome del filtro file"
+msgstr "Nome del file filtro"
 #: ../raster/r.mfilter.fp/main.c:78 ../raster/r.mfilter/main.c:71
 msgid "Number of times to repeat the filter"
@@ -2118,24 +2031,22 @@
 #: ../raster/r.mfilter.fp/main.c:101
 #, fuzzy
 msgid "Apply filter only to null data values"
-msgstr "Applica soltanto il filtro per i valori uguali a zero"
+msgstr "Applica il filtro solo per i valori null"
 #: ../raster/r.mfilter.fp/main.c:109 ../raster/r.mfilter/main.c:104
 #: ../raster/r.out.ppm/main.c:81 ../raster/r.kappa/main.c:133
-msgid ""
-"quiet' instead"
+msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
 msgstr ""
 #: ../raster/r.mfilter.fp/main.c:138 ../raster/r.mfilter/main.c:133
 #, fuzzy
 msgid "Raster map too small for the size of the filter"
+msgstr "Mappa raster troppo piccola per le dimensioni del filtro"
 #: ../raster/r.mfilter.fp/getfilt.c:27 ../raster/r.mfilter/getfilt.c:26
 #, fuzzy, c-format
 msgid "Cannot open filter file '%s'"
+msgstr "Impossibile aprire il file del filtro '%s'"
 #: ../raster/r.mfilter.fp/getfilt.c:47 ../raster/r.mfilter/getfilt.c:46
 msgid "Illegal filter matrix size specified"
@@ -2148,14 +2059,14 @@
 #: ../raster/r.mfilter.fp/getfilt.c:72 ../raster/r.mfilter/getfilt.c:71
 #, fuzzy
 msgid "Illegal filter matrix"
-msgstr "Nome file non valido [%s]."
+msgstr "Matrice del filtro non valida."
 #: ../raster/r.mfilter.fp/getfilt.c:80 ../raster/r.mfilter.fp/getfilt.c:107
 #: ../raster/r.mfilter.fp/getfilt.c:124 ../raster/r.mfilter/getfilt.c:79
 #: ../raster/r.mfilter/getfilt.c:105 ../raster/r.mfilter/getfilt.c:122
 #, fuzzy
 msgid "Filter file format error"
+msgstr "Errore nel formato del file del filtro"
 #: ../raster/r.mfilter.fp/getfilt.c:83 ../raster/r.mfilter/getfilt.c:82
 msgid "Duplicate filter divisor specified"
@@ -2170,9 +2081,8 @@
 msgstr ""
 #: ../raster/r.mfilter.fp/getfilt.c:117 ../raster/r.mfilter/getfilt.c:115
-#, fuzzy
 msgid "Illegal filter type specified"
+msgstr ""
 #: ../raster/r.mfilter.fp/getfilt.c:127 ../raster/r.mfilter/getfilt.c:125
 msgid "Duplicate filter start specified"
@@ -2186,30 +2096,29 @@
 #: ../raster/r.mfilter.fp/getfilt.c:157 ../raster/r.mfilter/getfilt.c:155
 #, fuzzy
 msgid "Illegal filter file format"
+msgstr "Formato del file del filtro non valido"
 #: ../raster/r.mfilter.fp/getrow.c:12 ../raster/r.mfilter/getrow.c:12
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot read raster row %d"
+msgstr ""
 #: ../raster/r.mfilter.fp/getrow.c:23 ../raster/r.mfilter/getrow.c:23
-#, fuzzy
 msgid "Error reading temporary file"
+msgstr ""
 #: ../raster/r.mfilter.fp/perform.c:38 ../raster/r.mfilter/perform.c:38
 #: ../raster/r.topidx/file_io.c:16 ../raster/r.param.scale/open_files.c:26
 #: ../imagery/i.cca/main.c:218
 #, fuzzy, c-format
 msgid "Cannot open raster map <%s>"
-msgstr "Non riesco ad aprire il cellfile [%s]"
 #: ../raster/r.mfilter.fp/perform.c:43 ../raster/r.mfilter.fp/perform.c:54
 #: ../raster/r.mfilter/perform.c:43 ../raster/r.mfilter/perform.c:54
 #, fuzzy
 msgid "Unable to create temporary file"
+msgstr "Non è possibile creare il file temporaneo"
 #: ../raster/r.mfilter.fp/perform.c:84 ../raster/r.mfilter/perform.c:84
 #: ../raster/r.reclass/reclass.c:235 ../raster/r.topidx/file_io.c:88
@@ -2217,12 +2126,12 @@
 #: ../raster/r.param.scale/open_files.c:36 ../imagery/i.cca/main.c:224
 #, fuzzy, c-format
 msgid "Cannot create raster map <%s>"
 #: ../raster/r.mfilter.fp/perform.c:87 ../raster/r.mfilter/perform.c:87
 #, fuzzy, c-format
 msgid "Writing raster map <%s>"
+msgstr "Scrittura della mappa raster <%s>"
 #: ../raster/r.out.ascii/main.c:61
 msgid "Converts a raster map layer into an ASCII text file."
@@ -2231,13 +2140,10 @@
 #: ../raster/r.out.ascii/main.c:78
 #, fuzzy
 msgid "Name for output ASCII grid map (use out=- for stdout)"
-msgstr ""
-"Nome in output di una mappa ASCII grid (usa out=- per lo standard output)"
+msgstr "Nome in output di una mappa ASCII grid (usare out=- per lo standard output)"
 #: ../raster/r.out.ascii/main.c:92
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
 msgstr ""
 #: ../raster/r.out.ascii/main.c:100
@@ -2280,29 +2186,26 @@
 #: ../vector/v.out.vtk/main.c:176 ../vector/v.out.ascii/out.c:161
 #, fuzzy, c-format
 msgid "Unable to open file <%s>"
+msgstr "Impossibile aprire il file <%s>"
 #: ../raster/r.out.ascii/main.c:181
 #, fuzzy, c-format
 msgid "Unable to read fp range for <%s>"
+msgstr "Non è possibile leggere l'intervallo fp per <%s>"
 #: ../raster/r.out.ascii/main.c:197
-#, fuzzy, c-format
+#, c-format
 msgid "Read failed at row %d"
+msgstr ""
 #: ../raster/r.surf.gauss/main.c:48
-msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
+msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
 msgstr ""
 #: ../raster/r.surf.gauss/main.c:55
 #, fuzzy
 msgid "Name of the output random surface"
-msgstr "Nome del raster in output"
+msgstr "Nome della superficie casuale di output"
 #: ../raster/r.surf.gauss/main.c:59
 msgid "Distribution mean"
@@ -2314,24 +2217,22 @@
 msgstr "Deviazione standard"
 #: ../raster/r.out.png/r.out.png.c:110
-#, fuzzy
 msgid "raster, png"
+msgstr ""
 #: ../raster/r.out.png/r.out.png.c:112
 #, fuzzy
 msgid "Export GRASS raster as non-georeferenced PNG image."
-msgstr "Esporta raster GRASS in formati supportati da GDAL"
+msgstr "Esporta raster GRASS come immagine PNG non georeferenziata"
 #: ../raster/r.out.png/r.out.png.c:119
 #, fuzzy
 msgid "Name for new PNG file (use out=- for stdout)"
-msgstr "Nome del nuovo file PPM. (use out=- per lo standard output)"
+msgstr "Nome del nuovo file PNG (usare out=- per lo standard output)"
 #: ../raster/r.out.png/r.out.png.c:127
-#, fuzzy
 msgid "Compression level of PNG file"
+msgstr ""
 #: ../raster/r.out.png/r.out.png.c:128
 msgid "(0 = none, 1 = fastest, 9 = best)"
@@ -2344,7 +2245,7 @@
 #: ../raster/r.out.png/r.out.png.c:144
 #, fuzzy
 msgid "Output world file"
-msgstr "Mostra il titolo del file raster"
+msgstr "File world di output"
 #: ../raster/r.out.png/r.out.png.c:196 ../display/d.text.freetype/main.c:842
 #: ../display/d.graph/main.c:103 ../display/d.graph/do_graph.c:112
@@ -2353,17 +2254,17 @@
 #: ../display/d.rast/display.c:32
 #, c-format
 msgid "[%s]: No such color"
-msgstr ""
+msgstr "[%s]: Questo colore non esiste"
 #: ../raster/r.out.png/r.out.png.c:283
 #, fuzzy, c-format
 msgid "Converting <%s>..."
+msgstr "Conversione di <%s> in corso..."
 #: ../raster/r.out.png/r.out.png.c:298 ../raster/r.univar2/r.univar_main.c:183
-#, fuzzy, c-format
+#, c-format
 msgid "Raster <%s> type mismatch"
+msgstr ""
 #: ../raster/r.out.png/r.out.png.c:324 ../raster/r.surf.idw/main.c:690
 #: ../raster/r.proj/readcell.c:27 ../raster/r.mapcalc/map.c:234
@@ -2373,19 +2274,18 @@
 #: ../imagery/i.gensigset/read_train.c:10 ../imagery/i.gensig/covariance.c:34
 #: ../imagery/i.gensig/read_train.c:10 ../imagery/i.cluster/main.c:290
 #: ../imagery/i.maxlik/main.c:117
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read raster map row %d"
+msgstr ""
 #: ../raster/r.out.png/r.out.png.c:455
 #, fuzzy
 msgid "Writing world file"
+msgstr "Scrittura del file world in corso"
 #: ../raster/r.out.png/r.out.png.c:458 ../raster/r.out.tiff/r.out.tiff.c:417
-#, fuzzy
 msgid "Got null file name"
+msgstr ""
 #: ../raster/r.out.png/r.out.png.c:460 ../raster/r.out.tiff/r.out.tiff.c:419
 msgid "Got null region struct"
@@ -2394,25 +2294,20 @@
 #: ../raster/r.out.png/r.out.png.c:462
 #, fuzzy
 msgid "Unable to open world file for writing"
+msgstr "Non è possibile aprire il file world per la scrittura"
 #: ../raster/r.walk/main.c:179
-msgid ""
-"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input elevation raster map "
-"layer whose cell category values represent elevation combined with an input "
-"raster map layer whose cell values represent friction cost."
+msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
 msgstr ""
 #: ../raster/r.walk/main.c:191
 #, fuzzy
 msgid "Name of elevation input raster map"
+msgstr "Nome della mappa raster di elevazione di input"
 #: ../raster/r.walk/main.c:199
-#, fuzzy
 msgid "Name of input raster map containing friction costs"
-msgstr "Nome di una mappa raster contenente una superfice di altezze"
+msgstr ""
 #: ../raster/r.walk/main.c:206
 msgid "Name of raster map to contain results"
@@ -2425,11 +2320,11 @@
 #: ../raster/r.walk/main.c:221
 msgid "Starting points vector map"
-msgstr "Punti di partenza della mappa vettoriale"
+msgstr "Mappa vettoriale dei punti di partenza"
 #: ../raster/r.walk/main.c:228
 msgid "Stop points vector map"
-msgstr "Punti di blocco della mappa vettoriale"
+msgstr "Mappa vettoriale dei punti di arrivo"
 #: ../raster/r.walk/main.c:236
 msgid "The map E and N grid coordinates of a starting point (E,N)"
@@ -2445,9 +2340,7 @@
 #: ../raster/r.walk/main.c:260 ../raster/r.cost/main.c:201
 msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr ""
-"Costo assegnato alle celle vuote. Se non specificato i valori nulli vengono "
-"esclusi."
+msgstr "Costo assegnato alle celle vuote. Se non specificato i valori nulli vengono esclusi."
 #: ../raster/r.walk/main.c:268 ../raster/r.cost/main.c:210
 #: ../raster/r.in.xyz/main.c:235
@@ -2469,7 +2362,7 @@
 #: ../raster/r.walk/main.c:305
 #, fuzzy
 msgid "Slope factor determines travel energy cost per height step"
-msgstr "Pendenza"
+msgstr "Il fattore pendenza determina il costo di viaggio in termini di energia in relazione al dislivello"
 #: ../raster/r.walk/main.c:310 ../raster/r.cost/main.c:215
 msgid "Use the 'Knight's move'; slower, but more accurate"
@@ -2487,12 +2380,12 @@
 #: ../raster/wildfire/r.spread/main.c:338 ../raster/r.water.outlet/main.c:77
 #, fuzzy
 msgid "Unable to read current window parameters"
+msgstr "Non è possibile leggere i parametri correnti per la finestra"
 #: ../raster/r.walk/main.c:368 ../raster/r.cost/main.c:302
 #, c-format
 msgid "Inappropriate maximum cost: %d"
-msgstr ""
+msgstr "Costo massimo non appropriato: %d"
 #: ../raster/r.walk/main.c:372 ../raster/r.cost/main.c:306
 #, c-format
@@ -2523,7 +2416,7 @@
 #: ../raster/r.walk/main.c:397
 #, fuzzy, c-format
 msgid "Slope_factor is %lf"
-msgstr "Pendenza"
+msgstr "Il fattore pendenza è %lf"
 #: ../raster/r.walk/main.c:404
 #, c-format
@@ -2541,24 +2434,22 @@
 #: ../raster/r.walk/main.c:426
 #, fuzzy, c-format
 msgid "Unable to find starting vector <%s> "
+msgstr "Non è possibile trovare il vettore di partenza <%s>"
 #: ../raster/r.walk/main.c:473
 #, fuzzy, c-format
 msgid "Unable to find stop vector <%s>"
+msgstr "Non è possibile trovare il vettore di arrivo <%s>"
 #: ../raster/r.walk/main.c:512
 #, fuzzy
 msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"esclusi."
+msgstr "Attenzione: assegnazione di costi negativi alle celle vuote. I valori nulli vengono esclusi."
 #: ../raster/r.walk/main.c:584 ../raster/r.walk/main.c:586
 #, fuzzy, c-format
 msgid "Unable to read %s"
+msgstr "impossibile leggere %s"
 #: ../raster/r.walk/main.c:591
 msgid "Map with different projection"
@@ -2580,7 +2471,7 @@
 #: ../raster/r.walk/main.c:664
 #, fuzzy, c-format
 msgid " %d rows, %d cols"
-msgstr "%d raster%s, %d vettoriale%s\n"
+msgstr "%d righe, %d colonne"
 #: ../raster/r.walk/main.c:618
 msgid "COST_Source map is: Integer cell type"
@@ -2597,7 +2488,7 @@
 #: ../raster/r.walk/main.c:655
 #, fuzzy
 msgid "Output map is: Integer cell type"
+msgstr "La mappa di output è: cella di tipo a valori interi"
 #: ../raster/r.walk/main.c:658
 msgid "Output map is: Floating point (float) cell type"
@@ -2620,13 +2511,13 @@
 #: ../raster/r.walk/main.c:682 ../raster/r.cost/main.c:402
 #, fuzzy
 msgid "Creating some temporary files..."
+msgstr "Creazione di alcuni file temporanei in corso..."
 #: ../raster/r.walk/main.c:722 ../raster/r.walk/main.c:784
 #: ../raster/wildfire/r.spread/main.c:514 ../raster/r.sum/main.c:74
 #, fuzzy, c-format
 msgid "Reading %s..."
+msgstr "Lettura di %s in corso..."
 #: ../raster/r.walk/main.c:737 ../raster/r.walk/main.c:796
 #: ../raster/r.walk/main.c:940 ../raster/r.walk/main.c:1514
@@ -2653,7 +2544,7 @@
 #: ../imagery/i.gensig/get_train.c:32
 #, fuzzy, c-format
 msgid "Unable to read raster map <%s> row %d"
+msgstr "Non è possibile leggere la mappa raster <%s> riga %d"
 #: ../raster/r.walk/main.c:852
 msgid "Initializing output "
@@ -2662,7 +2553,7 @@
 #: ../raster/r.walk/main.c:860 ../raster/r.walk/main.c:889
 #, fuzzy
 msgid "Unable to allocate memory for segment fbuff == NULL"
+msgstr "Impossibile allocare memoria per il segmento fbuff == NULL"
 #: ../raster/r.walk/main.c:880 ../raster/r.cost/main.c:522
 #, fuzzy
@@ -2672,7 +2563,7 @@
 #: ../raster/r.walk/main.c:917
 #, fuzzy, c-format
 msgid "Raster output map <%s> not found (no start_points given)"
+msgstr "Mappa raster di output <%s> non trovata (nessun punto di partenza definito)"
 #: ../raster/r.walk/main.c:932
 #, c-format
@@ -2682,7 +2573,7 @@
 #: ../raster/r.walk/main.c:935
 #, fuzzy, c-format
 msgid "Reading %s... "
 #: ../raster/r.walk/main.c:982 ../raster/r.cost/main.c:717
 msgid "Specified starting location outside database window"
@@ -2703,12 +2594,12 @@
 #: ../raster/r.walk/main.c:1497
 #, fuzzy, c-format
 msgid "Writing output raster map %s... "
+msgstr "Scrittura della mappa raster di output %s in corso..."
 #: ../raster/r.walk/main.c:1501
 #, fuzzy
 msgid "Will copy input map null values into output map"
-msgstr "Copia i valori della cella in input sull'output"
+msgstr "Copia i valori null della mappa in input sull'output"
 #: ../raster/r.walk/main.c:1508
 msgid ""
@@ -2741,12 +2632,12 @@
 #: ../raster/r.walk/main.c:1698 ../raster/r.cost/main.c:1192
 #, fuzzy, c-format
 msgid "Illegal x coordinate <%s>"
+msgstr "Coordinata x <%s> non valida"
 #: ../raster/r.walk/main.c:1700 ../raster/r.cost/main.c:1194
 #, fuzzy, c-format
 msgid "Illegal y coordinate <%s>"
+msgstr "Coordinata y <%s> non valida"
 #: ../raster/r.walk/main.c:1704 ../raster/r.cost/main.c:1198
 #, c-format
@@ -2758,21 +2649,14 @@
 msgstr ""
 #: ../raster/r.sun2/main.c:232 ../raster/r.sun/main.c:178
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
 msgstr ""
 #: ../raster/r.sun2/main.c:246 ../raster/r.sun/main.c:208
 #: ../raster/r.horizon/main.c:227
 #, fuzzy
 msgid "Name of the input elevation raster map [meters]"
-msgstr "Nome del file raster in input"
+msgstr "Nome della mappa raster di elevazione di input [metri]"
 #: ../raster/r.sun2/main.c:247 ../raster/r.sun2/main.c:256
 #: ../raster/r.sun2/main.c:265 ../raster/r.sun2/main.c:274
@@ -2800,9 +2684,7 @@
 msgstr ""
 #: ../raster/r.sun2/main.c:255 ../raster/r.sun/main.c:217
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
 msgstr ""
 #: ../raster/r.sun2/main.c:264
@@ -2810,9 +2692,7 @@
 msgstr ""
 #: ../raster/r.sun2/main.c:273 ../raster/r.sun/main.c:227
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
 msgstr ""
 #: ../raster/r.sun2/main.c:281
@@ -2820,8 +2700,7 @@
 msgstr ""
 #: ../raster/r.sun2/main.c:290 ../raster/r.sun/main.c:236
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
 msgstr ""
 #: ../raster/r.sun2/main.c:300 ../raster/r.sun/main.c:247
@@ -2847,19 +2726,16 @@
 #: ../raster/r.sun2/main.c:348
-#, fuzzy
 msgid "Name of real-sky beam radiation coefficient input raster map [-]"
-msgstr "Nome di un nuovo file raster"
+msgstr ""
 #: ../raster/r.sun2/main.c:357
-#, fuzzy
 msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
+msgstr ""
 #: ../raster/r.sun2/main.c:365
-#, fuzzy
 msgid "The horizon information input map prefix"
-msgstr "Le informazioni sulla proiezione non saranno aggiornate"
+msgstr ""
 #: ../raster/r.sun2/main.c:373 ../raster/r.horizon/main.c:244
 msgid "Angle step size for multidirectional horizon [degrees]"
@@ -2894,32 +2770,24 @@
 msgstr ""
 #: ../raster/r.sun2/main.c:391 ../raster/r.sun/main.c:322
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun2/main.c:400 ../raster/r.sun/main.c:331
 #, fuzzy
 msgid "Output insolation time raster map [h] (mode 2 only)"
-msgstr "Visualizza il raster delle altezze dopo il riempimento"
+msgstr "Mappa raster del tempo di insolazione [h] (solo modalità 2)"
 #: ../raster/r.sun2/main.c:409 ../raster/r.sun/main.c:340
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun2/main.c:418 ../raster/r.sun/main.c:349
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun2/main.c:427
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
-"irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
 #: ../raster/r.sun2/main.c:434 ../raster/r.sun/main.c:356
@@ -2986,9 +2854,8 @@
 msgstr ""
 #: ../raster/r.sun2/main.c:599
-#, fuzzy
 msgid "Error reading time step size"
-msgstr "Non riesco a trovare il file raster %s"
+msgstr ""
 #: ../raster/r.sun2/main.c:601
 #, fuzzy
@@ -2996,18 +2863,15 @@
 msgstr "Area: %d  Numero di isole: %d\n"
 #: ../raster/r.sun2/main.c:605
-#, fuzzy
 msgid "Error reading horizon step size"
+msgstr ""
 #: ../raster/r.sun2/main.c:609
-#, fuzzy
 msgid "The horizon step size must be greater than 0."
-msgstr "%s = %s -- dev'essere maggiore di zero"
+msgstr ""
 #: ../raster/r.sun2/main.c:612
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
 msgstr ""
 #: ../raster/r.sun2/main.c:618
@@ -3015,9 +2879,7 @@
 msgstr ""
 #: ../raster/r.sun2/main.c:620
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
 msgstr ""
 #: ../raster/r.sun2/main.c:625 ../raster/r.sun/main.c:424
@@ -3033,9 +2895,7 @@
 msgstr ""
 #: ../raster/r.sun2/main.c:685
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
 msgstr ""
 #: ../raster/r.sun2/main.c:730 ../general/g.region/printwindow.c:248
@@ -3075,9 +2935,9 @@
 msgstr ""
 #: ../raster/r.sun2/main.c:951
-#, fuzzy, c-format
+#, c-format
 msgid "Horizon file no. %d <%s> not found"
-msgstr "raster <%s> non trovato"
+msgstr ""
 #: ../raster/r.in.gdal/main.c:81
 msgid "Import GDAL supported raster file into a binary raster map layer."
@@ -3130,7 +2990,7 @@
 #: ../vector/v.in.ogr/main.c:202
 #, fuzzy
 msgid "List supported formats and exit"
-msgstr "Visualizza i formati supportati ed esci"
+msgstr "Visualizza i formati supportati ed esce"
 #: ../raster/r.in.gdal/main.c:141 ../raster/r.stats/main.c:147
 #: ../raster/r.stats/main.c:152 ../raster/r.stats/main.c:157
@@ -3161,9 +3021,8 @@
 msgstr "Stampa"
 #: ../raster/r.in.gdal/main.c:146
-#, fuzzy
 msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
+msgstr ""
 #: ../raster/r.in.gdal/main.c:151
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:11
@@ -3179,9 +3038,8 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:194
-#, fuzzy
 msgid "Available GDAL Drivers:"
+msgstr ""
 #: ../raster/r.in.gdal/main.c:215 ../raster/r.proj/main.c:264
 #: ../raster/r.out.gdal/main.c:230 ../raster/r.proj.seg/main.c:301
@@ -3189,60 +3047,47 @@
 #: ../vector/v.proj/main.c:181 ../vector/v.select/main.c:90
 #, fuzzy, c-format
 msgid "Required parameter <%s> not set"
+msgstr "Parametro richiesto <%s> non impostato"
 #: ../raster/r.in.gdal/main.c:218 ../raster/r.external/main.c:585
 #, fuzzy
 msgid "Name for output raster map not specified"
+msgstr "Nome per la mappa rster di output non specificato"
 #: ../raster/r.in.gdal/main.c:226
 #, fuzzy, c-format
 msgid "Raster map <%s> already exists and will be overwritten"
-msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
+msgstr "Mappa raster <%s> già esistente. Sarà sovrascritta"
 #: ../raster/r.in.gdal/main.c:246
-msgid ""
-"The polynomial rectification used in i.rectify does not work well with NOAA/"
-"AVHRR data. Try using gdalwarp with thin plate spline rectification instead. "
-"(-tps)"
+msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:262 ../raster/r.external/main.c:202
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:304
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them "
-"with r.region before going any further."
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:324
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:330
 #, c-format
 msgid "Location <%s> created"
-msgstr "Location <%s> creata!"
+msgstr "Location <%s> creata"
 #: ../raster/r.in.gdal/main.c:337 ../raster/r.external/main.c:83
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:353 ../raster/r.external/main.c:99
 #: ../vector/v.in.ogr/main.c:509
-#, fuzzy
 msgid "Over-riding projection check"
-msgstr "Nome del raster"
+msgstr ""
 #: ../raster/r.in.gdal/main.c:364 ../raster/r.external/main.c:107
 #: ../vector/v.in.ogr/main.c:518
@@ -3254,29 +3099,25 @@
 #: ../raster/r.in.gdal/main.c:369 ../raster/r.external/main.c:112
 #, fuzzy
 msgid "Location PROJ_INFO is:\n"
-msgstr "Errore durante la scrittura di PROJ_INFO"
+msgstr "La location di PROJ_INFO è:\n"
 #: ../raster/r.in.gdal/main.c:380 ../raster/r.external/main.c:123
 msgid "Dataset PROJ_INFO is:\n"
-msgstr ""
+msgstr "Il dataset di PROJ_INFO è:\n"
 #: ../raster/r.in.gdal/main.c:407 ../raster/r.external/main.c:150
 #: ../vector/v.in.ogr/main.c:534 ../vector/v.in.ogr/main.c:541
-#, fuzzy
 msgid "Import dataset PROJ_INFO is:\n"
+msgstr ""
 #: ../raster/r.in.gdal/main.c:429
 msgid ""
 "\n"
-"You can use the -o flag to r.in.gdal to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:432 ../raster/r.external/main.c:175
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:437 ../raster/r.external/main.c:180
@@ -3287,17 +3128,17 @@
 #: ../raster/r.in.gdal/main.c:443 ../raster/r.external/main.c:614
 #, fuzzy
 msgid "Proceeding with import..."
-msgstr "Mappa raster risultante"
+msgstr "Si sta procedendo con l'importazione..."
 #: ../raster/r.in.gdal/main.c:469 ../raster/r.external/main.c:629
 #, fuzzy, c-format
 msgid "Selected band (%d) does not exist"
+msgstr "La banda (%d) selezionata non esiste"
 #: ../raster/r.in.gdal/main.c:548
-#, fuzzy, c-format
+#, c-format
 msgid "Copying %d GCPS in points file for <%s>"
+msgstr ""
 #: ../raster/r.in.gdal/main.c:553
 msgid "GCPs have the following OpenGIS WKT Coordinate System:"
@@ -3306,50 +3147,45 @@
 #: ../raster/r.in.gdal/main.c:560
 #, fuzzy
 msgid "Re-projecting GCPs table:"
+msgstr "Riproiezione della tabella dei GCP:"
 #: ../raster/r.in.gdal/main.c:561
-#, fuzzy, c-format
+#, c-format
 msgid "* Input projection for GCP table: %s"
-msgstr "Visualizza il raster della direzione"
+msgstr ""
 #: ../raster/r.in.gdal/main.c:563
-#, fuzzy, c-format
+#, c-format
 msgid "* Output projection for GCP table: %s"
+msgstr ""
 #: ../raster/r.in.gdal/main.c:580
-#, fuzzy, c-format
+#, c-format
 msgid "Error in pj_do_proj (can't re-projection GCP %i)"
 msgstr ""
-"Errore nell'esecuzione di 'pj do proj' (ovvero nella coppia di coordinate di "
-"proiezione in input)"
 #: ../raster/r.in.gdal/main.c:639
-#, fuzzy
 msgid "Unable to translate projection key values of input GCPs"
-msgstr "Nome della mappa di output"
+msgstr ""
 #: ../raster/r.in.gdal/main.c:655
 #, fuzzy
 msgid "Unable to get projection info of target location"
-msgstr "Stampa le informazioni di proiezione in formato WKT"
+msgstr "Impossibile ottenere informazioni sulla proiezione della location di destinazione"
 #: ../raster/r.in.gdal/main.c:657
-#, fuzzy
 msgid "Unable to get projection units of target location"
+msgstr ""
 #: ../raster/r.in.gdal/main.c:659
-#, fuzzy
 msgid "Unable to get projection key values of target location"
+msgstr ""
 #: ../raster/r.in.gdal/main.c:662 ../imagery/i.rectify/target.c:32
 #: ../imagery/i.ortho.photo/i.photo.rectify/target.c:31
-#, fuzzy, c-format
+#, c-format
 msgid "Mapset <%s> in target location <%s> - "
+msgstr ""
 #: ../raster/r.in.gdal/main.c:664 ../raster/r.proj/main.c:245
 #: ../raster/r.proj.seg/main.c:282 ../imagery/i.rectify/target.c:33
@@ -3360,40 +3196,40 @@
 #: ../raster/r.proj.seg/main.c:283 ../imagery/i.rectify/target.c:33
 #, fuzzy
 msgid "not found"
+msgstr "non trovato"
 #: ../raster/r.in.gdal/main.c:932
 #, fuzzy, c-format
 msgid "Setting grey color table for <%s> (8bit, full range)"
-msgstr "impossibile aprire <%s>"
+msgstr "Impostazione della tavola dei colori per il grigio per <%s>  (8 bit, intera gamma)"
 #: ../raster/r.in.gdal/main.c:945
 #, fuzzy, c-format
 msgid "Setting grey color table for <%s> (16bit, image range)"
+msgstr "Impostazione della tavola dei colori per il grigio per <%s> (16 bit, gamma dell'immagine)"
 #: ../raster/r.in.gdal/main.c:956 ../raster/r.circle/dist.c:155
 #: ../raster/r.surf.fractal/main.c:39 ../raster/r.recode/main.c:110
 #: ../raster/r.composite/main.c:273
 #, fuzzy, c-format
 msgid "Raster map <%s> created."
+msgstr "Mappa raster <%s> creata"
 #: ../raster/r.in.bin/main.c:124
 msgid "Import a binary raster file into a GRASS raster map layer."
-msgstr "Importa file raster binario in un raster GRASS"
+msgstr "Importa file raster binario in un tematismo raster GRASS"
 #: ../raster/r.in.bin/main.c:130
 msgid "Import as Floating Point Data (default: Integer)"
-msgstr "Importa come Floating Point Data (predefinito: Integer)"
+msgstr "Importa come dati a virgola mobile(predefinito: intero)"
 #: ../raster/r.in.bin/main.c:135
 msgid "Import as Double Precision Data (default: Integer)"
-msgstr "Importa come Double Precision Data (predefinito: Integer)"
+msgstr "Importa come dati a precisione doppia (predefinito: intero)"
 #: ../raster/r.in.bin/main.c:139
 msgid "Signed data (high bit means negative value)"
-msgstr ""
+msgstr "Dati costituiti da numeri relativi (un bit alto significa valore negativo)"
 #: ../raster/r.in.bin/main.c:140 ../raster/r.in.bin/main.c:145
 #: ../raster/r.in.bin/main.c:174 ../raster/r.in.bin/main.c:227
@@ -3437,7 +3273,7 @@
 #: ../raster/r.in.bin/main.c:149
 msgid "Get region info from GMT style header"
-msgstr "Recupera le informazioni di regione da una intestazione in stile GMT"
+msgstr "Recupera le informazioni sulla regione da una intestazione in stile GMT"
 #: ../raster/r.in.bin/main.c:150 ../raster/r.in.bin/main.c:182
 #: ../raster/r.in.bin/main.c:190 ../raster/r.in.bin/main.c:198
@@ -3453,7 +3289,7 @@
 #: ../raster/r.in.bin/main.c:156
 #, fuzzy
 msgid "Binary raster file to be imported"
-msgstr "Il file raster da importare"
+msgstr "Il file raster binario da importare"
 #: ../raster/r.in.bin/main.c:173
 msgid "Number of bytes per cell (1, 2, 4)"
@@ -3461,19 +3297,19 @@
 #: ../raster/r.in.bin/main.c:181
 msgid "Northern limit of geographic region (outer edge)"
-msgstr "Limite a nord della regione geografica (al di fuori dell'angolo)"
+msgstr "Limite a nord della regione geografica (bordo esterno)"
 #: ../raster/r.in.bin/main.c:189
 msgid "Southern limit of geographic region (outer edge)"
-msgstr "Limite sud della regione geografica (al di fuori dell'angolo)"
+msgstr "Limite sud della regione geografica (bordo esterno)"
 #: ../raster/r.in.bin/main.c:197
 msgid "Eastern limit of geographic region (outer edge)"
-msgstr "Limite est della regione geografica (al di fuori dell'angolo)"
+msgstr "Limite est della regione geografica (bordo esterno)"
 #: ../raster/r.in.bin/main.c:205
 msgid "Western limit of geographic region (outer edge)"
-msgstr "Limite ovest della regione geografica (al di fuori dell'angolo)"
+msgstr "Limite ovest della regione geografica (bordo esterno)"
 #: ../raster/r.in.bin/main.c:212
 msgid "Number of rows"
@@ -3485,17 +3321,16 @@
 #: ../raster/r.in.bin/main.c:226
 msgid "Set Value to NULL"
-msgstr "Definisci il valore per NULL"
+msgstr "Definisce il valore per NULL"
 #: ../raster/r.in.bin/main.c:242
-#, fuzzy
 msgid "Parsing bytes per cell"
-msgstr "Numero di byte per cella (1, 2, 4)"
+msgstr ""
 #: ../raster/r.in.bin/main.c:244
 #, fuzzy
 msgid "Bad number of bytes per cell"
+msgstr "Numero di byte per cella non corretto"
 #: ../raster/r.in.bin/main.c:250
 msgid "Byte Swapping Turned On."
@@ -3508,51 +3343,50 @@
 msgstr ""
 #: ../raster/r.in.bin/main.c:293 ../raster/r.in.bin/main.c:333
-#, fuzzy
 msgid "You have to provide all limits of geographic region (n,s,e,w)"
+msgstr ""
 #: ../raster/r.in.bin/main.c:295 ../raster/r.in.bin/main.c:335
 #: ../display/d.grid/main.c:181
 #, c-format
 msgid "Illegal north coordinate <%s>"
+msgstr "Coordinata nord <%s> non valida"
 #: ../raster/r.in.bin/main.c:297 ../raster/r.in.bin/main.c:337
 #, fuzzy, c-format
 msgid "Illegal south coordinate <%s>"
+msgstr "Coordinate sud <%s> non valida"
 #: ../raster/r.in.bin/main.c:299 ../raster/r.in.bin/main.c:339
 #: ../display/d.grid/main.c:175
 #, c-format
 msgid "Illegal east coordinate <%s>"
+msgstr "Coordinate est <%s> non valida"
 #: ../raster/r.in.bin/main.c:301 ../raster/r.in.bin/main.c:341
 #, fuzzy, c-format
 msgid "Illegal west coordinate <%s>"
+msgstr "Coordinate ovest <%s> non valida"
 #: ../raster/r.in.bin/main.c:303 ../raster/r.in.bin/main.c:313
 #, fuzzy, c-format
 msgid "Illegal number of rows <%s>"
+msgstr "Numero di righe <%s> non valido"
 #: ../raster/r.in.bin/main.c:305 ../raster/r.in.bin/main.c:316
 #, fuzzy, c-format
 msgid "Illegal number of columns <%s>"
-msgstr "Numero di colonne"
+msgstr "Numero di colonne <%s> non valido"
 #: ../raster/r.in.bin/main.c:321
 #, c-format
 msgid "Using N=%f S=%f E=%f W=%f"
-msgstr "Usa N=%f S=%f E=%f O=%f"
+msgstr "Si sta usando N=%f S=%f E=%f O=%f"
 #: ../raster/r.in.bin/main.c:346
 #, fuzzy, c-format
 msgid "Using rows=%d cols=%d\n"
+msgstr "Si sta usando righe=%d cols=%d\n"
 #: ../raster/r.in.bin/main.c:451 ../raster/r.in.bin/main.c:461
 #: ../raster/r.in.bin/main.c:473
@@ -3573,9 +3407,7 @@
 #: ../raster/r.in.bin/main.c:510
 #, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign east= and west= correctly?"
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
 msgstr ""
 #: ../raster/r.in.bin/main.c:518
@@ -3584,9 +3416,7 @@
 msgstr "Conversione fallita alla riga %d"
 #: ../raster/r.rescale.eq/main.c:54
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
 msgstr ""
 #: ../raster/r.rescale.eq/main.c:64 ../raster/r.rescale/main.c:61
@@ -3604,7 +3434,7 @@
 #: ../raster/r.rescale.eq/main.c:86 ../raster/r.rescale/main.c:83
 #, fuzzy
 msgid "The output data range"
-msgstr "Nome del database in output"
+msgstr "L'intervallo dei dati in output"
 #: ../raster/r.rescale.eq/main.c:93 ../raster/r.rescale/main.c:90
 msgid "Title for new raster map"
@@ -3618,7 +3448,7 @@
 #: ../raster/r.rescale.eq/get_stats.c:19 ../raster/r.rescale/get_range.c:25
 #, fuzzy, c-format
 msgid "Reading %s ..."
+msgstr "Lettura di %s in corso ..."
 #: ../raster/r.drain/main.c:110
 msgid "Traces a flow through an elevation model on a raster map."
@@ -3629,15 +3459,13 @@
 msgstr ""
 #: ../raster/r.drain/main.c:131
-msgid ""
-"Output drain vector map (recommended for cost surface made using knight's "
-"move)"
+msgid "Output drain vector map (recommended for cost surface made using knight's move)"
 msgstr ""
 #: ../raster/r.drain/main.c:139
 #, fuzzy
 msgid "Map coordinates of starting point(s) (E,N)"
-msgstr "Le coordinate E e N del punto(i) di partenza"
+msgstr "Le coordinate E e N del punto/i di partenza"
 #: ../raster/r.drain/main.c:140 ../raster/r.drain/main.c:146
 #: ../raster/r.cost/main.c:153 ../raster/r.cost/main.c:165
@@ -3648,7 +3476,7 @@
 #: ../raster/r.drain/main.c:145
 #, fuzzy
 msgid "Name of vector map(s) containing starting point(s)"
-msgstr "Mappa raster che contiene i valori delle altezze"
+msgstr "Nome della mappa/e vettoriale contenente il punto/i di partenza"
 #: ../raster/r.drain/main.c:150
 msgid "Copy input cell values on output"
@@ -3663,9 +3491,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:163
-msgid ""
-"The input surface is a cost surface (if checked, a direction surface must "
-"also be specified"
+msgid "The input surface is a cost surface (if checked, a direction surface must also be specified"
 msgstr ""
 #: ../raster/r.drain/main.c:175
@@ -3677,9 +3503,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:184
-msgid ""
-"Direction raster not specified, if direction flag is on, a direction raster "
-"must be given"
+msgid "Direction raster not specified, if direction flag is on, a direction raster must be given"
 msgstr ""
 #: ../raster/r.drain/main.c:191
@@ -3719,26 +3543,25 @@
 #: ../doc/vector/v.example/main.c:96
 #, fuzzy, c-format
 msgid "Unable to create vector map <%s>"
-msgstr "Nome della mappa raster risultante"
+msgstr "Non è possibile creare la mappa vettoriale <%s>"
 #: ../raster/r.drain/main.c:227
 msgid "Specify just one of the -c, -a and -n flags"
 msgstr ""
 #: ../raster/r.drain/main.c:250
-#, fuzzy
 msgid "Metrics allocation"
-msgstr "locazione del database"
+msgstr ""
 #: ../raster/r.drain/main.c:261
 #, fuzzy, c-format
 msgid "Starting point %d is outside the current region"
+msgstr "Il punto di partenza %d è al di fuori della regione corrente"
 #: ../raster/r.drain/main.c:269 ../raster/r.drain/main.c:310
 #, fuzzy
 msgid "Too many start points"
-msgstr "nome tabella"
+msgstr "Troppi punti di partenza"
 #: ../raster/r.drain/main.c:284 ../raster/r.cost/main.c:319
 #: ../raster/r.carve/main.c:173 ../raster/r.region/main.c:237
@@ -3787,7 +3610,7 @@
 #: ../visualization/nviz2/cmd/vector.c:81 ../doc/vector/v.example/main.c:73
 #, fuzzy, c-format
 msgid "Vector map <%s> not found"
+msgstr "Mappa vettoriale <%s> non trovata"
 #: ../raster/r.drain/main.c:290 ../raster/r.cost/main.c:563
 msgid "Failed to guess site file format"
@@ -3796,17 +3619,17 @@
 #: ../raster/r.drain/main.c:316
 #, fuzzy, c-format
 msgid "Starting vector map <%s> contains no points in the current region"
+msgstr "La mappa vettoriale di partenza <%s> non contiene punti nella regione corrente"
 #: ../raster/r.drain/main.c:322
 #, fuzzy
 msgid "No start/stop point(s) specified"
-msgstr "Nessuna mappa in input specificata"
+msgstr "Nessun punto di partenza/arrivo definito"
 #: ../raster/r.drain/main.c:397
 #, fuzzy
 msgid "Calculating flow directions..."
+msgstr "Calcolo delle direzioni di flusso in corso..."
 #: ../raster/r.drain/main.c:466 ../raster/r.drain/main.c:519
 #: ../raster/r.cost/main.c:1007 ../raster/r.random.surface/save.c:100
@@ -3814,7 +3637,7 @@
 #: ../imagery/i.smap/shapiro/write_img.c:12
 #, fuzzy, c-format
 msgid "Writing raster map <%s>..."
-msgstr "Nome del driver in input"
+msgstr "Scrittura della mappa raster <%s> in corso..."
 #: ../raster/r.drain/main.c:684
 #, c-format
@@ -3826,6 +3649,8 @@
 "\n"
 "Hit RETURN to continue -->"
 msgstr ""
+"\n"
+"Premere INVIO per continuare -->"
 #: ../raster/r.support/front/check.c:29
 #, c-format
@@ -3847,9 +3672,8 @@
 msgstr ""
 #: ../raster/r.support/front/front.c:54
-#, fuzzy
 msgid "raster, metadata"
+msgstr ""
 #: ../raster/r.support/front/front.c:55
 msgid "Allows creation and/or modification of raster map layer support files."
@@ -3858,7 +3682,7 @@
 #: ../raster/r.support/front/front.c:65
 #, fuzzy
 msgid "Text to use for map title"
+msgstr "Testo da usare per il titolo della mappa"
 #: ../raster/r.support/front/front.c:73
 msgid "Text to append to the next line of the map's metadata file"
@@ -3867,12 +3691,11 @@
 #: ../raster/r.support/front/front.c:79
 #, fuzzy
 msgid "Text to use for map data units"
-msgstr "Nome della mappa raster da utilizzare per <%s>"
+msgstr "Testo da usare per le unità dei dati della mappa"
 #: ../raster/r.support/front/front.c:85
-#, fuzzy
 msgid "Text to use for map vertical datum"
+msgstr ""
 #: ../raster/r.support/front/front.c:92
 msgid "Text to use for data source, line 1"
@@ -3889,17 +3712,17 @@
 #: ../raster/r.support/front/front.c:114 ../raster/r.cats/main.c:78
 #, fuzzy
 msgid "Raster map from which to copy category table"
-msgstr "Nome della mappa raster da cui copiare la tabella colore"
+msgstr "Nome della mappa raster da cui copiare la tavola dei colori"
 #: ../raster/r.support/front/front.c:125 ../raster/r.cats/main.c:136
 #, fuzzy, c-format
 msgid "Raster map <%s> not found in current mapset"
+msgstr "Mappa raster <%s> non trovata nel mapset corrente"
 #: ../raster/r.support/front/front.c:143
 #, fuzzy
 msgid "Not enough room in history file"
+msgstr "Spazio insufficiente nel file della cronologia"
 #: ../raster/r.support/front/front.c:230 ../raster/r.statistics/main.c:91
 #: ../raster/r.mapcalc/map3.c:186 ../raster/r.mapcalc/map.c:92
@@ -3907,7 +3730,7 @@
 #: ../raster/r.report/parse.c:264 ../display/d.title/main.c:112
 #, fuzzy, c-format
 msgid "Unable to read category file of raster map <%s@%s>"
+msgstr "Impossibile leggere il file delle categorie della mappa raster <%s@%s>"
 #: ../raster/r.support/front/front.c:234
 #, c-format
@@ -3943,7 +3766,7 @@
 #: ../raster/r.support/front/front.c:292
 #, fuzzy, c-format
 msgid "Edit the history file for [%s]? "
-msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgstr "Modificare il file della cronologia per [%s]? "
 #: ../raster/r.support/front/front.c:302
 #, c-format
@@ -3958,8 +3781,7 @@
 #, c-format
 msgid ""
 "\n"
-"Do you want to create/reset the null file for [%s] so that null cell values "
-"are considered valid data? "
+"Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
 msgstr ""
 #: ../raster/r.support/front/front.c:317 ../raster/r.support/front/front.c:354
@@ -4002,17 +3824,17 @@
 #: ../raster/r.support/modhead/ask_format.c:29
 #, fuzzy
 msgid "        Number of rows"
+msgstr "\tNumero di righe"
 #: ../raster/r.support/modhead/ask_format.c:30
 #, fuzzy
 msgid "        Number of cols"
+msgstr "\tNumero di colonne"
 #: ../raster/r.support/modhead/ask_format.c:32
 #, fuzzy
 msgid "        Number of bytes per cell"
+msgstr "\tNumero di byte per cella"
 #: ../raster/r.support/modhead/ask_format.c:33
 msgid "        Floating point map"
@@ -4062,7 +3884,7 @@
 #: ../raster/r.support/modhead/modhead.c:96
 #, fuzzy, c-format
 msgid "Cannot open raster map [%s]!"
+msgstr "Impossibile aprire la mapa raster [%s]!"
 #: ../raster/r.support/modhead/modhead.c:101
 #, c-format
@@ -4072,7 +3894,7 @@
 #: ../raster/r.support/modhead/modhead.c:103
 #, fuzzy, c-format
 msgid "Error reading raster map [%s]."
+msgstr "Errore nella lettura della mappa raster [%s]."
 #: ../raster/r.support/modhead/modhead.c:191
 #, c-format
@@ -4131,15 +3953,13 @@
 #: ../raster/r.support/modhead/modhead.c:271
 #, c-format
-msgid ""
-"Header indicates %d row%s in the raster map, but the actual file format "
-"indicates %d row%s"
+msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
 msgstr ""
 #: ../raster/r.support/modhead/modhead.c:303
 #, fuzzy, c-format
 msgid "Unable to write header for [%s]."
+msgstr "Impossibile scrivere l'intestazione per [%s]"
 #: ../raster/r.support/modhead/modhead.c:305
 #, c-format
@@ -4159,7 +3979,7 @@
 #: ../raster/r.support/modcolr/modcolr.c:53
 #, fuzzy, c-format
 msgid "Color table for <%s> updated"
+msgstr "Tavola dei colori per <%s> aggiornata"
 #: ../raster/r.support/modhist/modhist.c:38
 msgid "Which raster map needs an updated history? "
@@ -4168,7 +3988,7 @@
 #: ../raster/r.support/modhist/modhist.c:46
 #, fuzzy, c-format
 msgid "Raster file [%s] not found. Exiting."
+msgstr "File raster [%s] non trovato. Uscita."
 #: ../raster/r.support/modhist/modhist.c:51
 #, c-format
@@ -4192,23 +4012,23 @@
 #: ../raster/r.support/modcats/modcats.c:62
 #, fuzzy, c-format
 msgid "%s map <%s> not found"
+msgstr "mappa %s <%s> non trovata"
 #: ../raster/r.support/modcats/modcats.c:74
 #: ../raster/r.support/modcats/modcats.c:81
 #, fuzzy, c-format
 msgid "Category file for <%s> not updated"
-msgstr "File category per [%s] non disponibile"
+msgstr "File delle categorie per <%s> non aggiornato"
 #: ../raster/r.support/modcats/modcats.c:92
 #, fuzzy, c-format
 msgid "Category file for <%s> updated"
+msgstr "File delle categorie per <%s> aggiornato"
 #: ../raster/r.lake/main.c:79
-#, fuzzy, c-format
+#, c-format
 msgid "Failed writing output raster map row %d"
+msgstr ""
 #: ../raster/r.lake/main.c:149
 msgid "Fills lake from seed at given level."
@@ -4217,12 +4037,11 @@
 #: ../raster/r.lake/main.c:156
 #, fuzzy
 msgid "Water level"
-msgstr "Nome mappa raster"
+msgstr "Livello dell'acqua"
 #: ../raster/r.lake/main.c:166
-#, fuzzy
 msgid "Seed point coordinates"
-msgstr "Utilizzando le coordinate del centro della mappa\n"
+msgstr ""
 #: ../raster/r.lake/main.c:175
 #, fuzzy
@@ -4230,9 +4049,8 @@
 #: ../raster/r.lake/main.c:181
-#, fuzzy
 msgid "Use negative depth values for lake raster map"
-msgstr "Avvia con i valori nella mappa raster"
+msgstr ""
 #: ../raster/r.lake/main.c:186
 msgid "Overwrite seed map with result (lake) map"
@@ -4241,7 +4059,7 @@
 #: ../raster/r.lake/main.c:194
 #, fuzzy
 msgid "Both seed map and coordinates cannot be specified"
-msgstr "Sono state specificate delle coordinate ovest vuote."
+msgstr "."
 #: ../raster/r.lake/main.c:197
 msgid "Seed map or seed coordinates must be set!"
@@ -4252,28 +4070,24 @@
 msgstr ""
 #: ../raster/r.lake/main.c:203
-#, fuzzy
 msgid "Both lake and overwrite cannot be specified"
+msgstr ""
 #: ../raster/r.lake/main.c:206
 msgid "Output lake map or overwrite flag must be set!"
 msgstr ""
 #: ../raster/r.lake/main.c:236
-#, fuzzy
 msgid "Seed point outside the current region"
-msgstr "Utilizza la regione corrente"
+msgstr ""
 #: ../raster/r.lake/main.c:265
 #, fuzzy
 msgid "G_malloc: out of memory"
-msgstr "Memoria esaurita!\n"
+msgstr "G_malloc: memoria esaurita"
 #: ../raster/r.lake/main.c:291
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level "
-"or move seed point."
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
 msgstr ""
 #: ../raster/r.lake/main.c:374
@@ -4289,7 +4103,7 @@
 #: ../raster/r.lake/main.c:376
 #, c-format
 msgid "Lake volume %f cubic meters"
-msgstr "Volume del lago %f metri cubici"
+msgstr "Volume del lago %f metri cubi"
 #: ../raster/r.lake/main.c:377
 msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
@@ -4298,12 +4112,11 @@
 #: ../raster/r.lake/main.c:395 ../raster/r.composite/main.c:167
 #, fuzzy, c-format
 msgid "Unable to read color file of raster map <%s>"
+msgstr "Impossibile leggere il file dei colori della mappa raster <%s>"
 #: ../raster/r.surf.idw/main.c:69
-#, fuzzy
 msgid "raster, interpolation"
+msgstr ""
 #: ../raster/r.surf.idw/main.c:71
 msgid "Surface interpolation utility for raster map."
@@ -4321,17 +4134,17 @@
 #: ../raster/r.surf.idw/main.c:92
 #, fuzzy, c-format
 msgid "Illegal value for '%s' (%s)"
-msgstr "Valore da impostare a null non valido"
+msgstr "Valore per  '%s' (%s) non valido"
 #: ../raster/r.surf.idw/main.c:233
 #, fuzzy, c-format
 msgid "Interpolating raster map <%s> (%d rows)... "
+msgstr "Interpolazione della mappa raster <&s> (%d righe) in corso..."
 #: ../raster/r.surf.idw/main.c:241
 #, fuzzy
 msgid "Cannot read row"
+msgstr "Impossibile leggere la riga"
 #: ../raster/r.surf.idw/main.c:685 ../raster/r.cost/main.c:435
 #: ../raster/r.cost/main.c:669 ../raster/r.series/main.c:214
@@ -4339,38 +4152,37 @@
 #: ../raster/r.colors/stats.c:107
 #, fuzzy, c-format
 msgid "Reading raster map <%s>..."
+msgstr "Lettura della mappa raster <%s> in corso..."
 #: ../raster/r.colors.out/main.c:63
-#, fuzzy
 msgid "raster, export, color table"
+msgstr ""
 #: ../raster/r.colors.out/main.c:65
 #, fuzzy
 msgid "Exports the color table associated with a raster map layer."
-msgstr "Crea/Modifica la tabella colore associata ad un raster"
+msgstr "Esporta la tavola dei colori associata ad un tematismo raster"
 #: ../raster/r.colors.out/main.c:71
 #, fuzzy
 msgid "Path to output rules file"
-msgstr "Nome di un file vettoriale in output"
+msgstr "Percorso del file di regole di output"
 #: ../raster/r.colors.out/main.c:72
 #, fuzzy
 msgid "\"-\" to write to stdout"
+msgstr "\"-\" da scrivere per lo stdout"
 #: ../raster/r.colors.out/main.c:77
 #, fuzzy
 msgid "Output values as percentages"
-msgstr "Nome della tabella in output"
+msgstr "Valori di output in percentuale"
 #: ../raster/r.colors.out/main.c:91 ../raster/r.colors/main.c:391
 #: ../raster/r.grow.distance/main.c:322
 #, fuzzy, c-format
 msgid "Unable to read color table for raster map <%s>"
+msgstr "Impossibile leggere la tavola dei colori per la mappa raster <%s>"
 #: ../raster/r.stats/main.c:103 ../raster/r.statistics/main.c:42
 #: ../raster/r.report/main.c:64 ../raster/r.univar2/r.univar_main.c:97
@@ -4382,20 +4194,20 @@
 #: ../raster/r.stats/main.c:105
 msgid "Generates area statistics for raster map layers."
-msgstr "Genera statistiche per layer raster"
+msgstr "Genera statistiche di area per tematismi raster"
 #: ../raster/r.stats/main.c:114 ../raster/r.univar2/r.univar_main.c:42
 #: ../raster/r.univar2/r3.univar_main.c:43 ../vector/v.db.select/main.c:84
 #: ../db/base/select.c:238 ../locale/scriptstrings/r.out.xyz_to_translate.c:4
 #, fuzzy
 msgid "Name for output file (if omitted or \"-\" output to stdout)"
-msgstr "Nome della mappa binaria in output (usa out=- per lo standard output)"
+msgstr "Nome per il file di output (se omesso o \"-\" l'uscita è sullo stdout)"
 #: ../raster/r.stats/main.c:119 ../raster/r.cats/main.c:72
 #: ../raster/r.distance/parse.c:50 ../vector/v.db.select/main.c:64
 #: ../db/base/select.c:219 ../locale/scriptstrings/r.tileset_to_translate.c:13
 msgid "Output field separator"
-msgstr "Campo separatore in output"
+msgstr "Separatore di campo in output"
 #: ../raster/r.stats/main.c:136 ../raster/r.report/parse.c:91
 msgid "Number of fp subranges to collect stats from"
@@ -4406,9 +4218,8 @@
 msgstr ""
 #: ../raster/r.stats/main.c:146
-#, fuzzy
 msgid "Print averaged values instead of intervals"
-msgstr "tabelle di sistema invece che tabelle utente"
+msgstr ""
 #: ../raster/r.stats/main.c:151
 msgid "Print area totals"
@@ -4456,48 +4267,42 @@
 #: ../db/base/select.c:130
 #, fuzzy, c-format
 msgid "Unable to open file <%s> for writing"
+msgstr "Impossibile aprire il file per <%s> per la scrittura"
 #: ../raster/r.stats/main.c:214
 #, fuzzy, c-format
 msgid "'%s' must be greater than zero; using %s=255"
+msgstr "'%s' dev'essere maggiore di zero; si sta usando %s=255"
 #: ../raster/r.stats/main.c:261 ../raster/r.series/main.c:202
 #, fuzzy
 msgid "Raster map not found"
+msgstr "Mappa raster non trovata"
 #: ../raster/r.stats/main.c:284
 #, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
 msgstr ""
 #: ../raster/r.stats/main.c:301
 #, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
 msgstr ""
 #: ../raster/r.stats/main.c:308
 #, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
-"option"
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
 msgstr ""
 #: ../raster/r.stats/main.c:342
 #, fuzzy, c-format
 msgid "Unable to read range for map <%s>"
+msgstr "Non è possibile leggere l'intervallo per la mappa <%s>"
 #: ../raster/r.stats/cell_stats.c:51
 #, fuzzy, c-format
 msgid "Unable to read raster <map %d of %d> row %d"
+msgstr "Non è possibile leggere la mappa raster <map %d of %d> riga %d"
 #: ../raster/r.compress/main.c:65
 msgid "Compresses and decompresses raster maps."
@@ -4509,12 +4314,12 @@
 #: ../raster/r.compress/main.c:77
 msgid "Uncompress the map"
-msgstr "Decomprimi la mappa"
+msgstr "Decomprime la mappa"
 #: ../raster/r.compress/main.c:117
 #, fuzzy, c-format
 msgid "[%s] not found"
+msgstr "[%s] non trovato"
 #: ../raster/r.compress/main.c:123
 #, c-format
@@ -4586,7 +4391,7 @@
 #: ../raster/r.circle/dist.c:85
 #, fuzzy
 msgid "Generate binary raster map"
+msgstr "Genera una mappa raster binaria"
 #: ../raster/r.circle/dist.c:108
 msgid "Please specify a radius in which min < max"
@@ -4599,7 +4404,7 @@
 #: ../raster/r.sun/main.c:276
 #, fuzzy
 msgid "Name of the latitudes input raster map [decimal degrees]"
+msgstr "Nome della mappa raster delle latitudini di input [gradi decimali]"
 #: ../raster/r.sun/main.c:286
 msgid "A single value of latitude [decimal degrees]"
@@ -4618,63 +4423,59 @@
 msgstr ""
 #: ../raster/r.sun/main.c:419
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance given a set local "
-"time"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
 msgstr ""
 #: ../raster/r.sun/main.c:474 ../raster/r.horizon/main.c:473
-msgid ""
-"Can't get projection info of current location: please set latitude via 'lat' "
-"or 'latin' option!"
+msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
 msgstr ""
 #: ../raster/r.sun/main.c:529
 #, fuzzy, c-format
 msgid "elevin raster map <%s> not found"
+msgstr "mappa raster elevin <%s> non trovata"
 #: ../raster/r.sun/main.c:532
 #, fuzzy, c-format
 msgid "aspin raster map <%s> not found"
+msgstr "mappa raster aspin <%s> non trovata"
 #: ../raster/r.sun/main.c:535
 #, fuzzy, c-format
 msgid "slopein raster map <%s> not found"
+msgstr "mappa raster slopein <%s> non trovata"
 #: ../raster/r.sun/main.c:548
 #, fuzzy, c-format
 msgid "linkein raster map <%s> not found"
+msgstr "mappa raster linkein <%s> non trovata"
 #: ../raster/r.sun/main.c:560
 #, fuzzy, c-format
 msgid "albedo raster map <%s> not found"
+msgstr "mappa raster albedo <%s> non trovata"
 #: ../raster/r.sun/main.c:572
 #, fuzzy, c-format
 msgid "latin raster map <%s> not found"
+msgstr "mappa raster latin <%s> non trovata"
 #: ../raster/r.sun/main.c:584
 #, fuzzy, c-format
 msgid "coefbh raster map <%s> not found"
+msgstr "mappa raster coefbh <%s> non trovata"
 #: ../raster/r.sun/main.c:596
 #, fuzzy, c-format
 msgid "coefdh raster map <%s> not found"
+msgstr "mappa raster coefdh <%s> non trovata"
 #: ../raster/r.sun/main.c:736 ../raster/r.sun/main.c:743
 #: ../raster/r.sun/main.c:750 ../raster/r.sun/main.c:757
 #: ../raster/r.sun/main.c:764
 #, fuzzy, c-format
 msgid "Unable to create raster map %s"
+msgstr "Non è possibile creare la mappa raster %s"
 #: ../raster/r.sun/main.c:772
 #, c-format
@@ -4705,16 +4506,16 @@
 #: ../raster/r.out.vtk/main.c:79
 #, fuzzy, c-format
 msgid "RGB raster map <%s> not found"
+msgstr "mappa raster RGB <%s> non trovata"
 #: ../raster/r.out.vtk/main.c:86
 msgid "Cannot create RGB data, please provide three maps [r,g,b]"
 msgstr ""
 #: ../raster/r.out.vtk/main.c:102
-#, fuzzy, c-format
+#, c-format
 msgid "Vector cell map <%s> not found"
+msgstr ""
 #: ../raster/r.out.vtk/main.c:109
 msgid "Cannot create vector data, please provide three maps [x,y,z]"
@@ -4728,7 +4529,7 @@
 #: ../raster/r.out.vtk/main.c:307 ../raster/r.out.vtk/main.c:353
 #, fuzzy, c-format
 msgid "Open Raster file %s"
+msgstr "Apre il file raster %s"
 #: ../raster/r.out.vtk/main.c:324
 msgid "Writing VTK ImageData\n"
@@ -4743,32 +4544,29 @@
 msgstr ""
 #: ../raster/r.out.vtk/main.c:381
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:46
 #, fuzzy
 msgid "Elevation raster map"
+msgstr "Mappa raster di elevazione"
 #: ../raster/r.out.vtk/parameters.c:52
 #, fuzzy
 msgid "Value to represent no data cell"
-msgstr "strighe che rappresentano le celle prive di valori"
+msgstr "Valore per rappresentare le celle prive di dati"
 #: ../raster/r.out.vtk/parameters.c:60
 msgid "Elevation (if no elevation map is specified)"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:66
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:76
-msgid ""
-"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:86
@@ -4784,8 +4582,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:123
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:129
@@ -4823,7 +4620,7 @@
 #: ../raster/r.out.vtk/writeascii.c:479
 #, fuzzy, c-format
 msgid "Unable to read row %i\n"
+msgstr "Non è possibile leggere la riga  %i\n"
 #: ../raster/r.out.vtk/writeascii.c:227
 msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
@@ -4880,7 +4677,7 @@
 #: ../raster/r.quant/main.c:116
 #, fuzzy
 msgid "Rounding..."
+msgstr "Arrotondamento in corso..."
 #: ../raster/r.quant/main.c:144
 #, c-format
@@ -4888,19 +4685,18 @@
 msgstr ""
 #: ../raster/r.quant/main.c:154
-#, fuzzy
 msgid "No rules specified. Quant table(s) not changed."
+msgstr ""
 #: ../raster/r.quant/main.c:164
-#, fuzzy, c-format
+#, c-format
 msgid "Quant table not changed for %s"
+msgstr ""
 #: ../raster/r.quant/main.c:166
-#, fuzzy, c-format
+#, c-format
 msgid "New quant table created for %s"
+msgstr ""
 #: ../raster/r.quant/read_rules.c:49
 msgid "Old data range is empty"
@@ -4909,7 +4705,7 @@
 #: ../raster/r.quant/read_rules.c:55
 #, fuzzy, c-format
 msgid "Old data range is %s to %s"
-msgstr "L'intervallo dati è da %ld a %ld\n"
+msgstr "Il vecchio intervallo dati è da %s a %s"
 #: ../raster/r.quant/read_rules.c:58
 msgid "Old integer data range is empty"
@@ -4918,22 +4714,16 @@
 #: ../raster/r.quant/read_rules.c:60
 #, fuzzy, c-format
 msgid "Old integer data range is %d to %d"
+msgstr "Il vecchio intervallo dei dati di valori interi è da %s a %s"
 #: ../raster/r.slope.aspect/main.c:153
-#, fuzzy
 msgid "raster, terrain"
+msgstr ""
 #: ../raster/r.slope.aspect/main.c:154
 #, fuzzy
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"Genera raster della pendenza, esposizione, curvature e le derivate parziali "
-"da un raster con valori dell'elevazione. Esposizione è calcolata in senso "
-"antiorario partendo dall'est."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "Genera raster della pendenza, esposizione, curvature e le derivate parziali da un raster con valori dell'elevazione."
 #: ../raster/r.slope.aspect/main.c:156
 msgid "Aspect is calculated counterclockwise from east."
@@ -4942,7 +4732,7 @@
 #: ../raster/r.slope.aspect/main.c:163
 #, fuzzy
 msgid "Name for output slope raster map"
+msgstr "Nome della mappa raster delle pendenze di output"
 #: ../raster/r.slope.aspect/main.c:164 ../raster/r.slope.aspect/main.c:170
 #: ../raster/r.slope.aspect/main.c:196 ../raster/r.slope.aspect/main.c:203
@@ -4954,14 +4744,13 @@
 #: ../vector/v.surf.rst/main.c:252 ../vector/v.surf.rst/main.c:258
 #: ../vector/v.surf.rst/main.c:266 ../vector/v.surf.rst/main.c:273
 #: ../vector/v.surf.rst/main.c:280 ../vector/v.surf.rst/main.c:287
-#, fuzzy
 msgid "Outputs"
-msgstr "Mappa in output"
+msgstr ""
 #: ../raster/r.slope.aspect/main.c:169
 #, fuzzy
 msgid "Name for output aspect raster map"
+msgstr "Nome della mappa raster di output delle esposizioni"
 #: ../raster/r.slope.aspect/main.c:178
 msgid "Format for reporting the slope"
@@ -4970,42 +4759,39 @@
 #: ../raster/r.slope.aspect/main.c:188
 #, fuzzy
 msgid "Type of output aspect and slope maps"
-msgstr "Tipo"
+msgstr "Tipo di mappe di output di esposizione e di pendenza"
 #: ../raster/r.slope.aspect/main.c:195
 #, fuzzy
 msgid "Name for output profile curvature raster map"
-msgstr "Nome del driver in output"
+msgstr "Nome ella mappa raster di output della curvatura del profilo"
 #: ../raster/r.slope.aspect/main.c:202
-#, fuzzy
 msgid "Name for output tangential curvature raster map"
+msgstr ""
 #: ../raster/r.slope.aspect/main.c:209
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:216
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:223
 #, fuzzy
 msgid "Name for output second order partial derivative dxx raster map"
+msgstr "Nome della mappa raster di output della derivata parziale di secondo ordine dxx"
 #: ../raster/r.slope.aspect/main.c:230
 #, fuzzy
 msgid "Name for output second order partial derivative dyy raster map"
+msgstr "Nome della mappa raster di output della derivata parziale di secondo ordine dyy"
 #: ../raster/r.slope.aspect/main.c:237
 #, fuzzy
 msgid "Name for output second order partial derivative dxy raster map"
+msgstr "Nome della mappa raster di output della derivata parziale di secondo ordine dxy"
 #: ../raster/r.slope.aspect/main.c:243
 msgid "Multiplicative factor to convert elevation units to meters"
@@ -5022,24 +4808,22 @@
 #: ../raster/r.slope.aspect/main.c:327
 #, fuzzy, c-format
 msgid "%s=%s - must be a positive number"
+msgstr "%s=%s - dev'essere un numero positivo"
 #: ../raster/r.slope.aspect/main.c:333
 #, fuzzy, c-format
 msgid "%s=%s - must be a non-negative number"
+msgstr "%s=%s - dev'essere un numero non negativo"
 #: ../raster/r.slope.aspect/main.c:348
 #, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%"
-"s>, <%s>, <%s>, <%s> or <%s>"
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:378
 #, fuzzy, c-format
 msgid "Wrong raster type: %s"
+msgstr "Tipo di raster non corretto: %s"
 #: ../raster/r.slope.aspect/main.c:408
 #: ../imagery/i.ortho.photo/i.photo.rectify/angle.c:67
@@ -5053,9 +4837,9 @@
 msgstr "Percentuale completa..."
 #: ../raster/r.slope.aspect/main.c:990
-#, fuzzy, c-format
+#, c-format
 msgid "Elevation products for mapset <%s> in <%s>"
+msgstr ""
 #: ../raster/r.slope.aspect/main.c:1009
 #, c-format
@@ -5065,7 +4849,7 @@
 #: ../raster/r.slope.aspect/main.c:1071
 #, fuzzy, c-format
 msgid "Aspect raster map <%s> complete"
+msgstr "Mappa raster delle esposizioni <%s> completata"
 #: ../raster/r.slope.aspect/main.c:1113
 #, c-format
@@ -5075,91 +4859,80 @@
 #: ../raster/r.slope.aspect/main.c:1164
 #, fuzzy, c-format
 msgid "Slope raster map <%s> complete"
+msgstr "Mappa raster delle pendenze <%s> completata"
 #: ../raster/r.slope.aspect/main.c:1235
 #, fuzzy, c-format
 msgid "Profile curve raster map <%s> complete"
+msgstr "Mappa raster della curvatura del profilo <%s> completata"
 #: ../raster/r.slope.aspect/main.c:1261
 #, fuzzy, c-format
 msgid "Tangential curve raster map <%s> complete"
+msgstr "Mappa raster della curvatura tangenziale <%s> completata"
 #: ../raster/r.slope.aspect/main.c:1285
 #, fuzzy, c-format
 msgid "E-W slope raster map <%s> complete"
+msgstr "Mappa raster delle pendenze E-O  <%s> completata"
 #: ../raster/r.slope.aspect/main.c:1309
 #, fuzzy, c-format
 msgid "N-S slope raster map <%s> complete"
+msgstr "Mappa raster delle pendenze N-S <%s> completata"
 #: ../raster/r.slope.aspect/main.c:1333
 #, fuzzy, c-format
 msgid "Dxx raster map <%s> complete"
-msgstr "Mappa raster 3D <%s> non trovata"
+msgstr "Mappa raster Dxx <%s> completata"
 #: ../raster/r.slope.aspect/main.c:1357
 #, fuzzy, c-format
 msgid "Dyy raster map <%s> complete"
+msgstr "Mappa raster Dyy <%s> completata"
 #: ../raster/r.slope.aspect/main.c:1381
 #, fuzzy, c-format
 msgid "Dxy raster map <%s> complete"
+msgstr "Mappa raster Dxy <%s> completata"
 #: ../raster/r.cost/main.c:128
 msgid "raster, cost surface, cumulative costs"
 msgstr ""
 #: ../raster/r.cost/main.c:130
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Crea una mappa raster che mostra il costo cumulativo per muoversi tra diverse località geografiche su una mappa raster di input i cui valori di categoria delle celle rappresentano dei costi"
 #: ../raster/r.cost/main.c:137
 msgid "Name of raster map containing grid cell cost information"
-msgstr ""
-"Nome della mappa raster che contiene la griglia con le informazioni del costo"
+msgstr "Nome della mappa raster che contiene la griglia con le informazioni del costo"
 #: ../raster/r.cost/main.c:152
 #, fuzzy
 msgid "Name of starting vector points map"
-msgstr "Nome della mappa di input"
+msgstr "Nome della mappa vettoriale dei punti di partenza"
 #: ../raster/r.cost/main.c:158
 #, fuzzy
 msgid "Name of stop vector points map"
+msgstr "Nome della mappa vettoriale dei punti di arrivo"
 #: ../raster/r.cost/main.c:159 ../raster/r.cost/main.c:183
 msgid "Stop"
 msgstr ""
 #: ../raster/r.cost/main.c:164
-#, fuzzy
 msgid "Name of starting raster points map"
 msgstr ""
-"#-#-#-#-#  grassmods_it.po (grassmods_it)  #-#-#-#-#\n"
-"Nome di un file raster esistente\n"
-"Nome di una mappa raster esistente"
 #: ../raster/r.cost/main.c:173
-#, fuzzy
 msgid "Map grid coordinates of a starting point (E,N)"
+msgstr ""
 #: ../raster/r.cost/main.c:182
-#, fuzzy
 msgid "Map grid coordinates of a stopping point (E,N)"
+msgstr ""
 #: ../raster/r.cost/main.c:192
 #, fuzzy
@@ -5169,13 +4942,13 @@
 #: ../raster/r.cost/main.c:219
 #, fuzzy
 msgid "Keep null values in output raster map"
-msgstr "Tieni i valori nulli nella mappa in output"
+msgstr "Tiene i valori nulli nella mappa raster di output"
 #: ../raster/r.cost/main.c:229 ../raster/wildfire/r.spreadpath/main.c:110
 #: ../raster/wildfire/r.ros/main.c:301 ../display/d.vect/main.c:358
 #: ../vector/v.kernel/main.c:176
 msgid "Run verbosely"
-msgstr "Esegui in  modalità verbosa"
+msgstr "Esegui in modalità verbosa"
 #: ../raster/r.cost/main.c:290
 msgid "Must specify exactly one of start_points, start_rast or coordinate"
@@ -5184,40 +4957,35 @@
 #: ../raster/r.cost/main.c:295 ../raster/r.cost/main.c:596
 #: ../raster/r.cost/main.c:702
 msgid "No start points"
-msgstr ""
+msgstr "Nessun punto di partenza"
 #: ../raster/r.cost/main.c:324
-#, fuzzy
 msgid "Assigning negative cost to null cell. Null cells excluded."
 msgstr ""
-"esclusi."
 #: ../raster/r.cost/main.c:499
 #, fuzzy
 msgid "Initializing output..."
-msgstr "Sto disegnando ..."
+msgstr "Inizializzazione dell'output in corso ..."
 #: ../raster/r.cost/main.c:613
-#, fuzzy
 msgid "Failed to guess site file format\n"
-msgstr "File di input"
+msgstr ""
 #: ../raster/r.cost/main.c:667 ../raster/r.texture/h_measure.c:758
 #: ../imagery/i.smap/bouman/interp.c:69
 #, fuzzy
 msgid "Unable to allocate memory"
+msgstr "impossibile allocare memoria"
 #: ../raster/r.cost/main.c:733
-#, fuzzy
 msgid "Finding cost path..."
+msgstr ""
 #: ../raster/r.cost/main.c:983
 #, fuzzy
 msgid "No data"
-msgstr "Nome del filtro file"
+msgstr "Nessun dato"
 #: ../raster/r.cost/main.c:1170
 #, c-format
@@ -5232,7 +5000,7 @@
 #: ../raster/r.cost/btree.c:146
 #, fuzzy, c-format
 msgid "Unable to find row %d, col %d: %f"
+msgstr "Non è possibile trovare la riga %d, la colonna %d: %f"
 #: ../raster/r.cost/btree.c:185
 msgid "Illegal delete request"
@@ -5268,23 +5036,17 @@
 #: ../raster/r.bilinear/main.c:54 ../raster/r.bilinear/main.c:61
 #, fuzzy
-msgid ""
-"Specific input value to be assigned to the north and/or south poles for "
-"longitude-latitude grids"
-msgstr ""
-"specifica un valore di output con cui assegnare i poli nord e/o sud per la "
-"griglia di longitudine-latitudine"
+msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
+msgstr "Specifica un valore di input da assegnare ai poli nord e/o sud per le griglie di longitudine-latitudine"
 #: ../raster/r.bilinear/main.c:67
 #, fuzzy
 msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-msgstr ""
-"L'uso dell'istruzione \"scale\" dalla linea di comando è deprecato. Per "
-"favore inserisci l'istruzione \"scale\" nel file di istruzioni."
+msgstr "Questo modulo è deprecato. Al suo posto usare 'r.resamp.interp'."
 #: ../raster/r.in.gridatb/main.c:43
 msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
-msgstr "Importa file GRIDATB.FOR (TOPMODEL) in un raster GRASS"
+msgstr "Importa file GRIDATB.FOR (TOPMODEL) in una mappa raster GRASS"
 #: ../raster/r.in.gridatb/main.c:53
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
@@ -5297,17 +5059,16 @@
 #: ../imagery/i.ifft/ifftmain.c:83
 #, fuzzy
 msgid "Name for output raster map"
+msgstr "Nome della mappa raster di output"
 #: ../raster/r.in.gridatb/main.c:67
 #, fuzzy, c-format
 msgid "File not found: %s"
+msgstr "File non trovato: %s"
 #: ../raster/r.in.gridatb/file_io.c:33
-#, fuzzy
 msgid "Setting window header failed"
-msgstr "Punti di partenza del file raster"
+msgstr ""
 #: ../raster/r.mfilter/main.c:52
 msgid "Performs raster map matrix filter."
@@ -5316,12 +5077,12 @@
 #: ../raster/r.mfilter/main.c:63
 #, fuzzy
 msgid "Path to filter file"
+msgstr "Percorso del file del filtro"
 #: ../raster/r.mfilter/main.c:72 ../raster/r.mfilter/main.c:96
 #, fuzzy
 msgid "Filter"
-msgstr "Tipo di grafico"
+msgstr "Filtro"
 #: ../raster/r.mfilter/main.c:95
 msgid "Apply filter only to zero data values"
@@ -5347,12 +5108,10 @@
 #: ../raster/r.resample/main.c:165
 #, fuzzy
 msgid "Creating new cats file..."
-msgstr "Nome del raster map esistente"
+msgstr "Creazione di una nuovo file delle categorie in corso..."
 #: ../raster/r.patch/main.c:55
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
 msgstr ""
 #: ../raster/r.patch/main.c:62
@@ -5370,27 +5129,24 @@
 #: ../raster/r.patch/main.c:102
 #, fuzzy
 msgid "The minimum number of input raster maps is two"
-msgstr "Nome di  2-%d mappe raster in input"
+msgstr "Il numero minimo di mappe raster di input è due"
 #: ../raster/r.patch/main.c:139
 #, fuzzy
 msgid "One or more input raster maps not found"
+msgstr "Una o più mappe raster di input non è stata trovata"
 #: ../raster/r.patch/main.c:181
 #, fuzzy, c-format
 msgid "Creating support files for raster map <%s>"
-msgstr "Errore nella lettura del file dbmscap\n"
+msgstr "Creazione dei file di supporto per la mappa raster <%s>"
 #: ../raster/simwe/r.sim.sediment/main.c:111
-#, fuzzy
 msgid "raster, sediment flow, erosion, deposition"
-msgstr "Mostra il titolo del file raster"
+msgstr ""
 #: ../raster/simwe/r.sim.sediment/main.c:113
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
 msgstr ""
 #: ../raster/simwe/r.sim.sediment/main.c:121
@@ -5447,9 +5203,8 @@
 #: ../general/g.proj/main.c:128 ../vector/v.out.ogr/main.c:100
 #: ../vector/v.out.ogr/main.c:120 ../vector/v.edit/args.c:103
 #: ../vector/v.edit/args.c:212
-#, fuzzy
 msgid "Input"
-msgstr "Mappa di input"
+msgstr ""
 #: ../raster/simwe/r.sim.sediment/main.c:157
 #, fuzzy
@@ -5471,9 +5226,8 @@
 #: ../raster/simwe/r.sim.water/main.c:212 ../raster/r.topmodel/main.c:76
 #: ../raster/r.topmodel/main.c:83 ../raster/r.topmodel/main.c:90
 #: ../raster/r.topmodel/main.c:98 ../raster/r.topmodel/main.c:129
-#, fuzzy
 msgid "Output"
+msgstr ""
 #: ../raster/simwe/r.sim.sediment/main.c:179
 #, fuzzy
@@ -5498,7 +5252,7 @@
 #: ../raster/simwe/r.sim.sediment/main.c:206
 #, fuzzy
 msgid "Number of walkers"
-msgstr "Numero di righe"
+msgstr "Numero di walker"
 #: ../raster/simwe/r.sim.sediment/main.c:207
 #: ../raster/simwe/r.sim.sediment/main.c:215
@@ -5525,12 +5279,12 @@
 #: ../raster/simwe/r.sim.sediment/main.c:214
 #: ../raster/simwe/r.sim.water/main.c:236
 msgid "Time used for iterations [minutes]"
-msgstr ""
+msgstr "Tempo usato per le iterazioni [minuti]"
 #: ../raster/simwe/r.sim.sediment/main.c:223
 #: ../raster/simwe/r.sim.water/main.c:245
 msgid "Time interval for creating output maps [minutes]"
-msgstr ""
+msgstr "Intervallo di tempo per la creazione delle mappe di output [minuti]"
 #: ../raster/simwe/r.sim.sediment/main.c:241
 #: ../raster/simwe/r.sim.water/main.c:263
@@ -5555,27 +5309,25 @@
 msgstr ""
 #: ../raster/simwe/r.sim.sediment/main.c:347
-#, fuzzy
 msgid "You are not outputting any raster or site files"
+msgstr ""
 #: ../raster/simwe/r.sim.sediment/main.c:350
 #: ../raster/simwe/r.sim.water/main.c:476 ../vector/v.surf.rst/main.c:717
 #: ../vector/v.surf.rst/main.c:769
-#, fuzzy
 msgid "Input failed"
+msgstr ""
 #: ../raster/simwe/r.sim.sediment/main.c:409
 #: ../raster/simwe/r.sim.water/main.c:523
 #, fuzzy
 msgid "Cannot write raster maps"
+msgstr "Non è possibile scrivere la mappa raster"
 #: ../raster/simwe/r.sim.water/main.c:118
 #, fuzzy
 msgid "raster, flow, hydrology"
+msgstr "raster, flusso, idrologia"
 #: ../raster/simwe/r.sim.water/main.c:120
 msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
@@ -5589,7 +5341,7 @@
 #: ../raster/simwe/r.sim.water/main.c:147
 #, fuzzy
 msgid "Rainfall excess rate unique value [mm/hr]"
+msgstr "Un singolo valore del tasso di pioggia eccedente [mm/h]"
 #: ../raster/simwe/r.sim.water/main.c:154
 #, fuzzy
@@ -5599,11 +5351,11 @@
 #: ../raster/simwe/r.sim.water/main.c:163
 #, fuzzy
 msgid "Runoff infiltration rate unique value [mm/hr]"
+msgstr "Un singolo valore  della velocità di infiltrazione del deflusso superficiale [mm/h]"
 #: ../raster/simwe/r.sim.water/main.c:177
 msgid "Mannings n unique value"
-msgstr ""
+msgstr "Un singolo valore del coefficiente n di Manning"
 #: ../raster/simwe/r.sim.water/main.c:184
 #, fuzzy
@@ -5627,7 +5379,7 @@
 #: ../raster/simwe/r.sim.water/main.c:228
 msgid "Number of walkers, default is twice the no. of cells"
-msgstr ""
+msgstr "Numero di walker, il predefinito è due volte il num. delle celle"
 #: ../raster/simwe/r.sim.water/main.c:272
 msgid "Threshold water depth [m]"
@@ -5639,27 +5391,25 @@
 #: ../raster/simwe/r.sim.water/main.c:281
 msgid "Diffusion increase constant"
-msgstr ""
+msgstr "Costante di incremento della diffusione"
 #: ../raster/simwe/r.sim.water/main.c:290
 msgid "Weighting factor for water flow velocity vector"
-msgstr ""
+msgstr "Fattore di pesatura per il vettore della velocità di flusso"
 #: ../raster/simwe/r.sim.water/main.c:295
 #, fuzzy
 msgid "Time-series output"
-msgstr "Output completo"
+msgstr "Output dele serie temporali"
 #: ../raster/simwe/r.sim.water/main.c:473
 #, fuzzy
 msgid "You are not outputting any raster maps"
+msgstr "Non si sta producendo nessuna mappa raster"
 #: ../raster/simwe/simlib/input.c:409
 #, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
-"to process"
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
 msgstr ""
 #: ../raster/simwe/simlib/input.c:541
@@ -5695,7 +5445,7 @@
 #: ../raster/simwe/simlib/input.c:625
 #, fuzzy, c-format
 msgid "Number of iterations \t= %d cells\n"
+msgstr "Numero di iterazioni  \t= %d celle\n"
 #: ../raster/simwe/simlib/input.c:626
 #, c-format
@@ -5717,7 +5467,7 @@
 #: ../raster/simwe/simlib/input.c:682
 #, fuzzy
 msgid "Unable to write et file"
-msgstr "Valore da scrivere per null"
+msgstr "Non è possibile scrivere il file et"
 #: ../raster/simwe/simlib/hydro.c:211
 #, c-format
@@ -5727,22 +5477,22 @@
 #: ../raster/simwe/simlib/hydro.c:431
 #, fuzzy
 msgid "Unable to write raster maps"
 #: ../raster/r.to.rast3elev/main.c:138
 #, fuzzy
 msgid "The number of input and elevation maps is not equal"
+msgstr "Il numero delle mappe di input e di elevazione non è lo stesso"
 #: ../raster/r.to.rast3elev/main.c:171 ../raster/r.to.rast3/main.c:378
 #, fuzzy
 msgid "Unable to close input map"
+msgstr "Non è possibile chiudere la mappa di input"
 #: ../raster/r.to.rast3elev/main.c:183 ../raster/r.to.rast3/main.c:58
 #, fuzzy
 msgid "Could not close the map"
+msgstr "Non è possibile chiudere la mappa"
 #: ../raster/r.to.rast3elev/main.c:211
 msgid "The value to fill the upper cells, default is null"
@@ -5763,17 +5513,16 @@
 #: ../raster/r.to.rast3elev/main.c:276
 #, fuzzy
 msgid "Could not get raster row from input map"
+msgstr "Impossibile ottenere la riga raster per la mappa di input"
 #: ../raster/r.to.rast3elev/main.c:278
 #, fuzzy
 msgid "Could not get raster row from elev map"
+msgstr "Impossibile ottenere la riga raster per la mappa di elevazione"
 #: ../raster/r.to.rast3elev/main.c:326 ../raster/r.to.rast3elev/main.c:360
-#, fuzzy
 msgid "Error writing G3D double data"
+msgstr ""
 #: ../raster/r.to.rast3elev/main.c:400
 msgid "raster, raster3d, voxel, conversion"
@@ -5786,30 +5535,26 @@
 #: ../raster/r.to.rast3elev/main.c:433
 #, fuzzy
 msgid "The upper value is not valid"
+msgstr "Il valore superiore non è valido"
 #: ../raster/r.to.rast3elev/main.c:444
 #, fuzzy
 msgid "The lower value is not valid"
+msgstr "Il valore inferiore non è valido"
 #: ../raster/r.to.rast3elev/main.c:498 ../raster/r.to.rast3/main.c:285
 #, fuzzy
 msgid "Creating 3D raster map"
+msgstr "Creazione della mappa raste 3D"
 #: ../raster/r.out.ppm/main.c:56
-msgid ""
-"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
-"the currently defined region."
-msgstr ""
-"Converte un raster GRASS in un'immagine PPM con una risoluzione dei pixel "
-"della region corrente"
+msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
+msgstr "Converte un raster GRASS in un'immagine PPM con una risoluzione dei pixel della region corrente"
 #: ../raster/r.out.ppm/main.c:64
 #, fuzzy
 msgid "Name for new PPM file (use '-' for stdout)"
-msgstr "Nome del nuovo file PPM. (use out=- per lo standard output)"
+msgstr "Nome del nuovo file PPM. (usare '-' per lo standard output)"
 #: ../raster/r.out.ppm/main.c:73
 msgid "Output greyscale instead of color"
@@ -5818,30 +5563,26 @@
 #: ../raster/r.out.ppm/main.c:110 ../raster/r.out.ppm3/main.c:109
 #, fuzzy, c-format
 msgid "rows = %d, cols = %d"
-msgstr "%d raster%s, %d vettoriale%s\n"
+msgstr "righe = %d, colonne = %d"
 #: ../raster/r.out.ppm/main.c:138
 #, fuzzy, c-format
 msgid "Unable to open file <%s> for write"
+msgstr "Impossibile aprire il file <%s> per la scrittura]"
 #: ../raster/r.out.ppm/main.c:167
 #, fuzzy
 msgid "Converting..."
+msgstr "Conversione in corso ..."
 #: ../raster/r.out.ppm/main.c:250
 #, fuzzy, c-format
 msgid "File <%s> created"
-msgstr "Location %s creata!"
+msgstr "File <%s> creato"
 #: ../raster/r.out.ppm3/main.c:59
-msgid ""
-"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-"resolution of the CURRENTLY DEFINED REGION."
-msgstr ""
-"Converte 3 raster GRASS (R,G,B) in un'immagine PPM con la risoluzione del "
-"pixel della region corrente"
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
+msgstr "Converte 3 raster GRASS (R,G,B) in un'immagine PPM con la risoluzione del pixel della region corrente"
 #: ../raster/r.out.ppm3/main.c:65 ../raster/r.composite/main.c:88
 #, c-format
@@ -5850,7 +5591,7 @@
 #: ../raster/r.out.ppm3/main.c:85
 msgid "Name for new PPM file. (use out=- for stdout)"
+msgstr "Nome del nuovo file PPM. (usare out=- per lo standard output)"
 #: ../raster/r.out.ppm3/main.c:94
 msgid "Add comments to describe the region"
@@ -5859,11 +5600,10 @@
 #: ../raster/r.out.ppm3/main.c:176
 #, fuzzy
 msgid "Converting ... "
 #: ../raster/r.transect/main.c:56
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
 msgstr ""
 #: ../raster/r.transect/main.c:60
@@ -5879,16 +5619,13 @@
 msgstr ""
 #: ../raster/r.transect/main.c:155
-#, fuzzy, c-format
+#, c-format
 msgid "End coordinate: %.15g, %.15g"
+msgstr ""
 #: ../raster/r.random/main.c:53
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Crea un raster e vettore puntuale contenenti punti posizionati casualmente."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "Crea un raster e vettore puntuale contenenti punti posizionati casualmente."
 #: ../raster/r.random/main.c:69
 msgid "The number of points to allocate"
@@ -5922,7 +5659,7 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:23
 #, fuzzy
 msgid "Points"
-msgstr "Stampa"
+msgstr "Punti"
 #: ../raster/r.random/main.c:142
 #, c-format
@@ -5932,42 +5669,41 @@
 #: ../raster/r.random/main.c:160
 #, fuzzy, c-format
 msgid "<%s=%s> invalid percentage"
-msgstr "<%s=%s> ** input non valido **"
+msgstr "<%s=%s> percentuale non valida"
 #: ../raster/r.random/main.c:167
 #, fuzzy, c-format
 msgid "<%s=%s> invalid number of points"
+msgstr "<%s=%s> numero di punti non valido"
 #: ../raster/r.random/main.c:180
 #, fuzzy, c-format
 msgid "There aren't [%ld] cells in the current region"
+msgstr "Non ci sono [%ld] celle nella regione corrente"
 #: ../raster/r.random/main.c:183
 #, fuzzy, c-format
 msgid "There aren't [%ld] non-NULL cells in the current region"
+msgstr "Non ci sono [%ld] celle non NULL nella regione corrente"
 #: ../raster/r.random/main.c:188
 #, fuzzy
 msgid "There are no valid locations in the current region"
+msgstr "Non ci sono location valide nella regione corrente"
 #: ../raster/r.random/count.c:74
-#, fuzzy
 msgid "Collecting Stats..."
-msgstr "Non riesco a copiare la tabella"
+msgstr ""
 #: ../raster/r.random/count.c:78
 #, fuzzy, c-format
 msgid "Cannot read raster row [%d]"
+msgstr "Impossibile leggere la riga [%d] del raster"
 #: ../raster/r.random/count.c:82
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot read cover raster row [%d]"
+msgstr ""
 #: ../raster/r.random/count.c:131
 msgid "Programmer error in get_stats/switch"
@@ -5976,32 +5712,32 @@
 #: ../raster/r.random/random.c:100
 #, fuzzy
 msgid "Cannot create new table"
-msgstr "Non riesco a descrivere la tabella"
+msgstr "Impossibile creare la nuova tabella"
 #: ../raster/r.random/random.c:110
 #, fuzzy, c-format
 msgid "Writing raster map <%s> and vector map <%s> ..."
+msgstr "Scrittura della mappa raster <%s> e della mappa vettoriale <%s> in corso ..."
 #: ../raster/r.random/random.c:113
 #, fuzzy, c-format
 msgid "Writing raster map <%s> ..."
+msgstr "Scrittura della mappa raster <%s> in corso ..."
 #: ../raster/r.random/random.c:115
 #, fuzzy, c-format
 msgid "Writing vector map <%s> ..."
+msgstr "Scrittura della mappa vettoriale <%s> in corso ..."
 #: ../raster/r.random/random.c:129
 #, fuzzy, c-format
 msgid "Cannot read raster row [%d] from raster map <%s>"
-msgstr "Non riesco a trovare il file raster %s"
+msgstr "Impossibile leggere la riga [%d] del raster dalla mappa raster <%s>"
 #: ../raster/r.random/random.c:135
 #, fuzzy, c-format
 msgid "Cannot read raster row [%d] from cover raster map <%s>"
+msgstr "Impossibile leggere la riga [%d] del raster dal raster di copertura <%s>"
 #: ../raster/r.random/random.c:194 ../vector/v.net.distance/main.c:256
 #: ../vector/v.net.allpairs/main.c:228 ../vector/v.net.timetable/main.c:134
@@ -6010,7 +5746,7 @@
 #: ../vector/v.net.components/main.c:38
 #, fuzzy, c-format
 msgid "Cannot insert new record: %s"
+msgstr "Impossibile inserire il nuovo record: %s"
 #: ../raster/r.random/random.c:246
 #, c-format
@@ -6024,12 +5760,12 @@
 #: ../raster/r.los/main.c:97
 #, fuzzy
 msgid "Coordinate identifying the viewing position"
-msgstr "Coordinate per identificare la locazione visualizzata"
+msgstr "Coordinate per identificare la posizione del punto di osservazione"
 #: ../raster/r.los/main.c:102
 #, fuzzy
 msgid "Binary (1/0) raster map to use as a mask"
-msgstr "mappa raster binaria (1/0)"
+msgstr "mappa raster binaria (1/0) da usare come maschera"
 #: ../raster/r.los/main.c:109
 msgid "Viewing position height above the ground"
@@ -6051,27 +5787,26 @@
 #: ../raster/r.los/main.c:155
 #, fuzzy
 msgid "Specified observer coordinate is outside current region bounds."
+msgstr "L'osservatore specificato è al di fuori dei limiti della regione corrente"
 #: ../raster/r.los/main.c:177 ../raster/r.los/main.c:182
 #: ../raster/r.resamp.rst/main.c:405 ../raster/r.resamp.rst/main.c:428
 #, fuzzy, c-format
 msgid "[%s]: Cannot read map header"
-msgstr "Non riesco ad impostare user/password"
+msgstr "[%s]: Impossibile leggere l'intestazione della mappa"
 #: ../raster/r.los/main.c:211
 msgid "Pattern map should be a binary 0/1 CELL map"
 msgstr ""
 #: ../raster/r.los/main.c:245
-msgid ""
-"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
 msgstr ""
 #: ../raster/r.los/main.c:250
 #, fuzzy, c-format
 msgid "Using maximum distance from the viewing point (meters): %f"
-msgstr "Distanza massima dal punto visualizzato (metri)"
+msgstr "Si sta utilizzando la distanza massima dal punto di osservazione (metri): %f"
 #: ../raster/r.los/main.c:380 ../raster/r.buffer/write_map.c:78
 #: ../raster/r.proj/main.c:444 ../raster/r.texture/main.c:356
@@ -6079,19 +5814,14 @@
 #: ../raster/r.null/null.c:342 ../raster/r.proj.seg/main.c:515
 #, fuzzy, c-format
 msgid "Failed writing raster map <%s> row %d"
+msgstr "Scrittura della mappa raster <%s> riga %d non riuscita"
 #: ../raster/wildfire/r.spread/main.c:103
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
 msgstr ""
 #: ../raster/wildfire/r.spread/main.c:108
-msgid ""
-"It optionally produces raster maps to contain backlink UTM coordinates for "
-"tracing spread paths."
+msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
 msgstr ""
 #: ../raster/wildfire/r.spread/main.c:116
@@ -6103,7 +5833,7 @@
 #: ../raster/wildfire/r.spread/main.c:167
 #, fuzzy
 msgid "Input_maps"
+msgstr "Mappe di input"
 #: ../raster/wildfire/r.spread/main.c:118
 msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
@@ -6122,19 +5852,15 @@
 msgstr ""
 #: ../raster/wildfire/r.spread/main.c:153
-msgid ""
-"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
 msgstr ""
 #: ../raster/wildfire/r.spread/main.c:161
-msgid ""
-"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
+msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
 msgstr ""
 #: ../raster/wildfire/r.spread/main.c:169
-msgid ""
-"Name of raster map containing fine Fuel MOISture of the cell receiving a "
-"spotting firebrand (%) (required w/ -s)"
+msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
 msgstr ""
 #: ../raster/wildfire/r.spread/main.c:177
@@ -6162,21 +5888,19 @@
 #: ../raster/wildfire/r.spread/main.c:228
 #, fuzzy
 msgid "Output_maps"
+msgstr "Mappe in output"
 #: ../raster/wildfire/r.spread/main.c:214
 msgid "Name of raster map to contain OUTPUT spread time (min)"
 msgstr ""
 #: ../raster/wildfire/r.spread/main.c:222
-#, fuzzy
 msgid "Name of raster map to contain X_BACK coordinates"
-msgstr "Nome della mappa raster che contiene i risultati"
+msgstr ""
 #: ../raster/wildfire/r.spread/main.c:230
-#, fuzzy
 msgid "Name of raster map to contain Y_BACK coordinates"
+msgstr ""
 #: ../raster/wildfire/r.spread/main.c:235
 msgid "Run VERBOSELY"
@@ -6197,30 +5921,24 @@
 #: ../raster/wildfire/r.ros/main.c:439
 #, fuzzy, c-format
 msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-msgstr "ERRORE: <%s> esiste già\n"
+msgstr "La mappa raster <%s> esiste già nel mapset <%>, selezionare un altro nome"
 #: ../raster/wildfire/r.spread/main.c:463
 #, fuzzy
 msgid "Reading inputs..."
-msgstr "Mappa raster risultante"
+msgstr "Lettura dell'input in corso ..."
 #: ../raster/wildfire/r.spreadpath/main.c:74
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"Traccia ricorsivamente il percorso di minor costo partendo dalle celle da "
-"cui il costo complessivo è stato determinato."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr "Traccia ricorsivamente il percorso di minor costo partendo dalle celle da cui il costo complessivo è stato determinato."
 #: ../raster/wildfire/r.spreadpath/main.c:83
 msgid "Name of raster map containing back-path easting information"
 msgstr ""
 #: ../raster/wildfire/r.spreadpath/main.c:91
-#, fuzzy
 msgid "Name of raster map containing back-path northing information"
 msgstr ""
 #: ../raster/wildfire/r.spreadpath/main.c:99
 msgid "The map E and N grid coordinates of starting points"
@@ -6231,11 +5949,7 @@
 msgstr ""
 #: ../raster/wildfire/r.ros/main.c:214
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
 msgstr ""
 #: ../raster/wildfire/r.ros/main.c:224
@@ -6315,19 +6029,18 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:87
-#, fuzzy
 msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+msgstr ""
 #: ../raster/r.gwflow/main.c:91
 #, fuzzy
 msgid "Top surface of the aquifer in [m]"
+msgstr "Superficie superiore dell'acquifero in [m]"
 #: ../raster/r.gwflow/main.c:95
 #, fuzzy
 msgid "Bottom surface of the aquifer in [m]"
-msgstr "mappa raster di base"
+msgstr "Superficie inferiore dell'acquifero in [m]"
 #: ../raster/r.gwflow/main.c:99
 msgid "The map storing the numerical result [m]"
@@ -6346,7 +6059,7 @@
 #: ../raster/r.gwflow/main.c:121
 #, fuzzy
 msgid "The height of the river bed in [m]"
+msgstr "L'altezza del letto del fiume in [m]"
 #: ../raster/r.gwflow/main.c:128
 msgid "Water level (head) of the river with leakage connection in [m]"
@@ -6357,9 +6070,8 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:141
-#, fuzzy
 msgid "The height of the drainage bed in [m]"
+msgstr ""
 #: ../raster/r.gwflow/main.c:148
 msgid "The leakage coefficient of the drainage bed in [1/s]"
@@ -6370,15 +6082,13 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:191
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
 msgstr ""
 #: ../raster/r.gwflow/main.c:201 ../raster/r.topidx/main.c:50
 #, fuzzy, c-format
 msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr "driver pg: colonna '%s', di tipo %d non supportata"
+msgstr "La location Lat/Long non è supportata da %s. Prima riproiettare la mappa."
 #: ../raster/r.gwflow/main.c:215
 msgid "Please provide river_head, river_leak and river_bed maps"
@@ -6410,7 +6120,7 @@
 #: ../raster/r.profile/input.c:59
 #, fuzzy
 msgid "One coordinate pair per line, please"
+msgstr "Una coppia di coordinate per linea, per piacere"
 #: ../raster/r.profile/main.c:55
 msgid "Outputs the raster map layer values lying on user-defined line(s)."
@@ -6423,7 +6133,7 @@
 #: ../raster/r.profile/main.c:74
 #, fuzzy
 msgid "Profile coordinate pairs"
+msgstr "Coppia di coordinate del profilo"
 #: ../raster/r.profile/main.c:81
 msgid "Resolution along profile (default = current region resolution)"
@@ -6444,17 +6154,17 @@
 #: ../raster/r.profile/main.c:121
 #, fuzzy, c-format
 msgid "Illegal resolution! [%g]"
-msgstr "Risoluzione"
+msgstr "Risoluzione non valida! [%g]"
 #: ../raster/r.profile/main.c:130
 #, fuzzy, c-format
 msgid "Using resolution [%g]"
+msgstr "Si sta usando la risoluzione [%g]"
 #: ../raster/r.profile/main.c:176
 #, fuzzy
 msgid "Output Format:"
+msgstr "Formato di output:"
 #: ../raster/r.profile/main.c:179
 #, c-format
@@ -6473,12 +6183,12 @@
 #: ../raster/r.profile/main.c:193
 #, fuzzy, c-format
 msgid "Invalid coordinates %s %s"
+msgstr "Coordinate %s %s non valide"
 #: ../raster/r.profile/main.c:209
 #, c-format
 msgid "Use mouse to select Start Point\n"
-msgstr "Usa mouse per selezionare Punto di inizio\n"
+msgstr "Usare il mouse per selezionare Punto di inizio\n"
 #: ../raster/r.profile/main.c:214
 #, c-format
@@ -6487,20 +6197,17 @@
 "Use mouse to draw profile line\n"
 msgstr ""
 "\n"
-"Usa mouse per disegnare la linea di profilo\n"
+"Usare il mouse per disegnare la linea di profilo\n"
 #: ../raster/r.profile/main.c:215
 #, fuzzy, c-format
 msgid "Buttons:\n"
-msgstr ""
-"\n"
-"\n"
-"Bottoni:\n"
+msgstr "Bottoni:\n"
 #: ../raster/r.profile/main.c:216
 #, fuzzy, c-format
 msgid "Left:   Mark next point\n"
-msgstr " Sinistro:  mostra cosa c'è qui\n"
+msgstr "Sinistro:  Segna il prossimo punto\n"
 #: ../raster/r.profile/main.c:217
 #, c-format
@@ -6524,20 +6231,15 @@
 #: ../raster/r.profile/main.c:308
 #, fuzzy
 msgid "Endpoint coordinates are outside of current region settings"
+msgstr "Le coordinate del punto finale sono al di fuori della regione corrente"
 #: ../raster/r.buffer/main.c:69
-#, fuzzy
 msgid "raster, buffer"
+msgstr ""
 #: ../raster/r.buffer/main.c:71
-msgid ""
-"Creates a raster map layer showing buffer zones surrounding cells that "
-"contain non-NULL category values."
-msgstr ""
-"Crea un raster mostrando una zona di buffer intorno alle celle che "
-"contengono valori non nulli."
+msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Crea un raster mostrando una zona di buffer intorno alle celle che contengono valori non nulli."
 #: ../raster/r.buffer/main.c:83
 msgid "Distance zone(s)"
@@ -6563,37 +6265,35 @@
 #: ../raster/r.buffer/execute.c:34
 #, fuzzy
 msgid "Finding buffer zones..."
+msgstr "Ricerca delle zone di buffer in corso ..."
 #: ../raster/r.buffer/read_map.c:53
 #, fuzzy, c-format
 msgid "Reading input raster map <%s>..."
+msgstr "Lettura della mappa raster di input <%s> in corso..."
 #: ../raster/r.buffer/write_map.c:48
 #, fuzzy, c-format
 msgid "Writing output raster map <%s>..."
+msgstr "Scrittura della mappa raster di output <%s> in corso..."
 #: ../raster/r.buffer/parse_dist.c:54
 #, fuzzy, c-format
 msgid "%s: %s - illegal distance specification"
-msgstr "Nome del raster map in output"
+msgstr "%s: %s - definizione della distanza non valida"
 #: ../raster/r.series/main.c:101 ../raster/r.resamp.stats/main.c:290
 #, fuzzy, c-format
 msgid "Unknown method <%s>"
-msgstr "%s - colore sconosciuto\n"
+msgstr "Metodo <%s> sconosciuto"
 #: ../raster/r.series/main.c:133
 #, fuzzy
 msgid "raster, series"
-msgstr "Mappa(e) raster da leggere"
+msgstr "raster, serie"
 #: ../raster/r.series/main.c:135
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
 msgstr ""
 #: ../raster/r.series/main.c:149
@@ -6603,11 +6303,11 @@
 #: ../raster/r.series/main.c:156
 #, fuzzy
 msgid "Quantile to calculate for method=quantile"
+msgstr "Quantile da calcolare per method=quantile"
 #: ../raster/r.series/main.c:164
 msgid "Threshold to calculate for method=threshold"
-msgstr ""
+msgstr "Soglia da calcolare per method==threshold"
 #: ../raster/r.series/main.c:176
 msgid "Ignore values outside this range"
@@ -6621,46 +6321,43 @@
 #: ../ps/ps.map/outl_io.c:72
 #, fuzzy, c-format
 msgid "Unable to open raster map <%s> in mapset <%s>"
-msgstr "impossibile aprire <%s>"
+msgstr "Impossibile aprire la mappa raster <%s> nel mapset <%s>"
 #: ../raster/r.series/main.c:228
 msgid "output= and method= must have the same number of values"
 msgstr ""
 #: ../raster/r.average/main.c:53
-msgid ""
-"Finds the average of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
+msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Trova la media dei valori in una mappa di copertura all'interno di aree che hanno lo stesso valore di categoria in una mappa di base definita dall'utente."
 #: ../raster/r.average/main.c:66 ../raster/r.statistics/main.c:73
 msgid "Cover values extracted from the category labels of the cover map"
-msgstr ""
+msgstr "Esegue i calcoli sui valori estratti dalle etichette di categoria della mappa di copertura"
 #: ../raster/r.average/main.c:82 ../raster/r.grow2/main.c:212
 #, fuzzy, c-format
 msgid "Error reading category file for <%s>"
+msgstr "Errore nella lettura del file delle categorie per <%s>"
 #: ../raster/r.average/main.c:93
 #, c-format
 msgid "%s: ERROR running %s command"
-msgstr ""
+msgstr "%s: ERRORE nell'eseguire il comando %s"
 #: ../raster/r.average/main.c:102 ../raster/r.statistics/o_sum.c:43
 #: ../raster/r.statistics/o_average.c:41 ../raster/r.statistics/o_distrib.c:39
 #, fuzzy, c-format
 msgid "%s: unable to open temporary file"
+msgstr "%s: non è possibile aprire il file temporaneo"
 #: ../raster/r.surf.idw2/main.c:61
 #, fuzzy
 msgid "Surface generation program."
-msgstr "Comando per la generazione di superfice da contorni rasterizzati"
+msgstr "Programma per la generazione di superfici"
 #: ../raster/r.surf.idw2/main.c:80
-msgid ""
-"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
 msgstr ""
 #: ../raster/r.surf.idw2/main.c:87 ../vector/v.surf.idw/main.c:141
@@ -6669,19 +6366,19 @@
 msgstr ""
 #: ../raster/r.surf.idw2/main.c:96
-#, fuzzy, c-format
+#, c-format
 msgid "%s: no data points found"
-msgstr "raster <%s> non trovato"
+msgstr ""
 #: ../raster/r.surf.idw2/main.c:114
 #, fuzzy, c-format
 msgid "Interpolating raster map <%s>... %d rows... "
+msgstr "Interpolazione in corso della mappa raster <%s>... %d righe..."
 #: ../raster/r.surf.idw2/main.c:123
 #, fuzzy
 msgid "Cannot get row"
-msgstr "Non riesco a mostrare i database"
+msgstr "Impossibile ottenere la riga"
 #: ../raster/r.watershed/front/main.c:57
 #, fuzzy
@@ -6718,8 +6415,7 @@
 msgstr "Nome di una mappa raster contenente una superfice di altezze"
 #: ../raster/r.watershed/front/main.c:88
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
 msgstr ""
 #: ../raster/r.watershed/front/main.c:94
@@ -6762,8 +6458,7 @@
 #: ../raster/r.watershed/front/main.c:129
 #, fuzzy
-msgid ""
-"Name for output raster map useful for visual display of results (DEPRECATED)"
+msgid "Name for output raster map useful for visual display of results (DEPRECATED)"
 #: ../raster/r.watershed/front/main.c:135
@@ -6823,9 +6518,7 @@
 msgstr ""
 #: ../raster/r.watershed/front/main.c:197
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
 msgstr ""
 #: ../raster/r.watershed/front/main.c:202
@@ -6839,7 +6532,7 @@
 #: ../raster/r.watershed/front/main.c:221
 #, fuzzy
 msgid "Sorry, you must choose an output map."
-msgstr "Nome del file in output"
+msgstr "Spiacente, si deve scegliere una mappa di output"
 #: ../raster/r.watershed/front/main.c:237
 msgid ""
@@ -6869,7 +6562,7 @@
 #: ../raster/r.watershed/seg/close_maps.c:28
 #, fuzzy
 msgid "unable to open new accum map layer."
+msgstr "impossibile aprire nuovo tematismo accumulazione"
 #: ../raster/r.watershed/ram/close_maps.c:66
 #: ../raster/r.watershed/ram/close_maps.c:153
@@ -6880,27 +6573,27 @@
 #: ../raster/r.watershed/seg/close_maps.c:44
 #, fuzzy
 msgid "Close failed."
+msgstr "Chiusura non riuscita."
 #: ../raster/r.watershed/ram/close_maps.c:142
 #, fuzzy
 msgid "unable to open new aspect map layer."
+msgstr "impossibile aprire nuovo tematismo esposizione."
 #: ../raster/r.watershed/ram/close_maps.c:201
 #, fuzzy
 msgid "unable to open new LS factor map layer."
+msgstr "impossibile aprire nuovo tematismo fattore LS."
 #: ../raster/r.watershed/ram/close_maps.c:219
 #, fuzzy
 msgid "unable to open new slope length map layer."
+msgstr "impossibile aprire nuovo tematismo lunghezza dei versanti."
 #: ../raster/r.watershed/ram/close_maps.c:241
 #, fuzzy
 msgid "unable to open new S factor map layer."
+msgstr "impossibile aprire nuovo tematismo fattore S."
 #: ../raster/r.watershed/ram/sg_factor.c:13
 #: ../raster/r.watershed/seg/sg_factor.c:12
@@ -6932,21 +6625,13 @@
 #, c-format
 msgid ""
 "USAGE for basin delineation:\n"
-"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
-"[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
 "\n"
 "USAGE for ARMSED FILE creation:\n"
-"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
-"ha=half_basin_map ar=ARMSED_file_name\n"
+"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
 "\n"
 "USAGE for slope length determination:\n"
-"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
-"[de=depression_map] [ac=accumulation_map] [di=display_map] "
-"[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
-"LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
+"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
 msgstr ""
 #: ../raster/r.watershed/ram/do_astar.c:26
@@ -6968,29 +6653,28 @@
 #: ../raster/r.watershed/seg/init_vars.c:191
 #, fuzzy
 msgid "unable to open elevation map layer"
+msgstr "impossibile aprire il tematismo elevazione"
 #: ../raster/r.watershed/ram/init_vars.c:218
 #, fuzzy
 msgid "unable to open runoff map layer"
+msgstr "impossibile aprire il tematismo deflusso"
 #: ../raster/r.watershed/ram/init_vars.c:241
 #: ../raster/r.watershed/seg/init_vars.c:278
 #, fuzzy
 msgid "unable to open depression map layer"
-msgstr "Nome del file raster in input"
+msgstr "impossibile aprire il tematismo depressioni"
 #: ../raster/r.watershed/ram/init_vars.c:258
 #: ../raster/r.watershed/seg/init_vars.c:307
-#, fuzzy
 msgid "unable to open blocking map layer"
+msgstr ""
 #: ../raster/r.watershed/ram/init_vars.c:275
 #, fuzzy
 msgid "unable to open rill map layer"
-msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgstr "Impossibile aprire il tematismo rill"
 #: ../raster/r.watershed/ram/init_vars.c:303
 #: ../raster/r.watershed/seg/init_vars.c:366
@@ -6999,9 +6683,8 @@
 msgstr ""
 #: ../raster/r.watershed/seg/close_maps.c:52
-#, fuzzy
 msgid "unable to open flow accumulation map layer"
+msgstr ""
 #: ../raster/r.watershed/seg/init_vars.c:114
 #, c-format
@@ -7009,8 +6692,7 @@
 msgstr ""
 #: ../raster/r.watershed/seg/init_vars.c:150
-msgid ""
-"Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
+msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
 msgstr ""
 #: ../raster/r.watershed/shed/main.c:41
@@ -7025,17 +6707,17 @@
 #: ../raster/r.watershed/shed/main.c:72
 #, fuzzy
 msgid "unable to open output file"
+msgstr "impossibile aprire il file di output"
 #: ../raster/r.watershed/shed/file_in.c:15
 #, fuzzy
 msgid "unable to open ARMSED file"
+msgstr "impossibile aprire il file ARMSED"
 #: ../raster/r.watershed/shed/read.c:23
 #, fuzzy
 msgid "unable to open basin/half basin map"
+msgstr "impossibile aprire la mappa bacini/semibacini"
 #: ../raster/r.watershed/shed/com_line.c:23
 msgid ""
@@ -7111,18 +6793,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
+msgid "depression map indicates all the locations in the current map window where"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
+msgid "outlet streams and sinkholes are examples of `depressions'.  If you wish to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:86
@@ -7134,8 +6813,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
+msgid "Hit <return> by itself for the next question if there is no depression map."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:99
@@ -7146,14 +6824,11 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins.  The number of watershed basins is indirectly determined"
+msgid "watershed basins.  The number of watershed basins is indirectly determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value.  The basin threshold is the area necessary "
-"for"
+msgid "by the `basin threshold' value.  The basin threshold is the area necessary for"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:103
@@ -7162,18 +6837,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'.  An exterior drainage basin does not have any"
+msgid "`exterior drainage basins'.  An exterior drainage basin does not have any"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it.  Interior drainage basin size is determined"
+msgid "drainage basins flowing into it.  Interior drainage basin size is determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
+msgid "by the surface flow going into stream segments between stream interceptions."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:108
@@ -7186,18 +6858,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration rates)."
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
+msgid "The user can create a map layer with potential overland flow values, and"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:114
@@ -7303,8 +6972,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:297
@@ -7323,9 +6991,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:352
@@ -7341,7 +7007,7 @@
 #: ../raster/r.watershed/shed/com_line.c:365
 #, fuzzy
 msgid "be used for every cell in the current region."
-msgstr "Utilizza la regione corrente"
+msgstr "da utilizzare per ogni cella nella regione corrente."
 #: ../raster/r.watershed/shed/com_line.c:368
 #, c-format
@@ -7367,8 +7033,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long.  Normally,"
+msgid "that prevents the surface flow distance from getting too long.  Normally,"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:385
@@ -7382,8 +7047,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length.  You may input a raster map indicating the locations of these"
+msgid "slope length.  You may input a raster map indicating the locations of these"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:402
@@ -7391,8 +7055,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
+msgid "Hit <return> by itself for the next question if there is no blocking map."
 msgstr ""
 #: ../raster/r.watershed/shed/basin_maps.c:12
@@ -7476,9 +7139,8 @@
 msgstr ""
 #: ../raster/r.watershed/shed/valid.c:28
-#, fuzzy
 msgid "unable to open accum file in valid_basins()"
+msgstr ""
 #: ../raster/r.watershed/shed/intro.c:8
 #, c-format
@@ -7517,7 +7179,7 @@
 #: ../raster/r.info/main.c:82
 #, fuzzy
 msgid "Print raster map resolution (NS-res, EW-res) only"
-msgstr "Stampa solo la risoluzione (NS-ris, OE-ris)"
+msgstr "Stampa solo la risoluzione della mappa raster (NS-ris, EO-ris)"
 #: ../raster/r.info/main.c:86
 msgid "Print raster map type only"
@@ -7526,27 +7188,25 @@
 #: ../raster/r.info/main.c:90 ../vector/v.info/main.c:85
 #, fuzzy
 msgid "Print map region only"
-msgstr "Stampa solo il tipo di mappa raster"
+msgstr "Stampa solo la regione della mappa"
 #: ../raster/r.info/main.c:94
 #, fuzzy
 msgid "Print raster history instead of info"
-msgstr "tabelle di sistema invece che tabelle utente"
+msgstr "Stampa la cronologia del raster invece delle informazioni"
 #: ../raster/r.info/main.c:98
-#, fuzzy
 msgid "Print raster map data units only"
+msgstr ""
 #: ../raster/r.info/main.c:102
-#, fuzzy
 msgid "Print raster map vertical datum only"
+msgstr ""
 #: ../raster/r.info/main.c:106 ../vector/v.info/main.c:90
 #, fuzzy
 msgid "Print map title only"
+msgstr "Stampa solo il titolo della mappa"
 #: ../raster/r.info/main.c:111
 msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
@@ -7555,7 +7215,7 @@
 #: ../raster/r.info/main.c:142
 #, fuzzy
 msgid "Unable to read range file"
+msgstr "Impossibile leggere il file range"
 #: ../raster/r.surf.area/main.c:89
 msgid "Surface area estimation for rasters."
@@ -7570,14 +7230,13 @@
 msgstr ""
 #: ../raster/r.surf.fractal/process.c:53
-#, fuzzy
 msgid "Unable to allocate data buffer. Check current region with g.region."
+msgstr ""
 #: ../raster/r.surf.fractal/interface.c:36
 #, fuzzy
 msgid "raster, DEM, fractal"
+msgstr "raster, DEM, frattale"
 #: ../raster/r.surf.fractal/interface.c:38
 msgid "Creates a fractal surface of a given fractal dimension."
@@ -7585,7 +7244,7 @@
 #: ../raster/r.surf.fractal/interface.c:49
 msgid "Fractal dimension of surface (2 < D < 3)"
-msgstr ""
+msgstr "Dimensione frattale della superficie (2 < D < 3)"
 #: ../raster/r.surf.fractal/interface.c:56
 msgid "Number of intermediate images to produce"
@@ -7603,15 +7262,11 @@
 #: ../raster/r.surf.fractal/spec_syn.c:120
 #, fuzzy, c-format
 msgid "Calculating surface %d (of %d)..."
-msgstr "Sto calcolando la superficie %d (di %d)"
+msgstr "Calcolo della superficie %d (di %d) in corso..."
 #: ../raster/r.covar/main.c:55
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map layer"
-"(s)."
-msgstr ""
-"Output una matrice della covarianza/correlazione per un raster specificato "
-"dall'utente."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr "Output una matrice della covarianza/correlazione per un raster specificato dall'utente."
 #: ../raster/r.covar/main.c:62
 msgid "Print correlation matrix"
@@ -7646,7 +7301,7 @@
 #: ../raster/r.grow2/main.c:141
 #, fuzzy
 msgid "Radius of buffer in raster cells"
-msgstr "Raggio del buffer"
+msgstr "Raggio del buffer nelle celle raster"
 #: ../raster/r.grow2/main.c:148 ../raster/r.grow.distance/main.c:150
 msgid "Metric"
@@ -7668,22 +7323,22 @@
 #: ../raster/r.grow2/main.c:217
 #, fuzzy, c-format
 msgid "Error in reading color file for <%s>"
+msgstr "Errore nella lettura del file dei colori"
 #: ../raster/r.grow2/main.c:301
 #, fuzzy, c-format
 msgid "Error writing category file for <%s>"
+msgstr "Errore nella scrittura del file delle categorie per <%s>"
 #: ../raster/r.grow2/main.c:305
 #, fuzzy, c-format
 msgid "Error writing color file for <%s>"
+msgstr "Errore nella scrittura del file dei colori per <%s>"
 #: ../raster/r.proj/main.c:130 ../raster/r.proj.seg/main.c:141
 #, fuzzy
 msgid "raster, projection, transformation"
+msgstr "raster, proiezione, trasformazione"
 #: ../raster/r.proj/main.c:132 ../raster/r.proj.seg/main.c:143
 msgid "Re-projects a raster map from one location to the current location."
@@ -7692,7 +7347,7 @@
 #: ../raster/r.proj/main.c:135 ../raster/r.proj.seg/main.c:146
 #, fuzzy
 msgid "Name of input raster map to re-project"
+msgstr "Nome della mappa raster di input da riproiettare"
 #: ../raster/r.proj/main.c:137 ../raster/r.proj/main.c:154
 #: ../raster/r.proj/main.c:163 ../raster/r.proj.seg/main.c:148
@@ -7702,17 +7357,17 @@
 #: ../vector/v.net.flow/main.c:92 ../vector/v.net.flow/main.c:98
 #, fuzzy
 msgid "Source"
-msgstr "Superficie"
+msgstr "Origine"
 #: ../raster/r.proj/main.c:143 ../raster/r.proj.seg/main.c:154
 #, fuzzy
 msgid "Location containing input raster map"
-msgstr "Location contenente la mappa vettoriale di input"
+msgstr "Location contenente la mappa raster di input"
 #: ../raster/r.proj/main.c:151 ../raster/r.proj.seg/main.c:162
 #, fuzzy
 msgid "Mapset containing input raster map"
-msgstr "Mapset contenente la mappa vettoriale di input"
+msgstr "Mapset contenente la mappa raster di input"
 #: ../raster/r.proj/main.c:160 ../raster/r.proj.seg/main.c:171
 #: ../vector/v.proj/main.c:93
@@ -7722,7 +7377,7 @@
 #: ../raster/r.proj/main.c:167 ../raster/r.proj.seg/main.c:178
 #, fuzzy
 msgid "Name for output raster map (default: input)"
+msgstr "Nome per la mappa raster di output (predefinito: input)"
 #: ../raster/r.proj/main.c:168 ../raster/r.proj/main.c:179
 #: ../raster/r.proj/main.c:186 ../raster/r.proj.seg/main.c:179
@@ -7731,7 +7386,7 @@
 #: ../vector/v.proj/main.c:101 ../vector/v.proj/main.c:113
 #, fuzzy
 msgid "Target"
-msgstr "area"
+msgstr "Destinazione"
 #: ../raster/r.proj/main.c:178 ../raster/r.proj.seg/main.c:189
 #: ../imagery/i.rectify/main.c:145
@@ -7773,75 +7428,74 @@
 #: ../raster/r.proj/main.c:228 ../raster/r.proj.seg/main.c:265
 #, fuzzy
 msgid "Unable to get projection info of output raster map"
-msgstr "Nome della mappa di output"
+msgstr "Impossibile ottenere informazioni sulla proiezione per la mappa raster di output"
 #: ../raster/r.proj/main.c:231 ../raster/r.proj.seg/main.c:268
 #, fuzzy
 msgid "Unable to get projection units of output raster map"
+msgstr "Impossibile ottenere le unità della proiezione per la mappa raster di output"
 #: ../raster/r.proj/main.c:234 ../raster/r.proj.seg/main.c:271
 #, fuzzy
 msgid "Unable to get projection key values of output raster map"
+msgstr "Impossibile ottenere i valori chiave della proiezione per la mappa raster di output"
 #: ../raster/r.proj/main.c:243 ../raster/r.proj.seg/main.c:280
 #, fuzzy, c-format
 msgid "Mapset <%s> in input location <%s> - %s"
+msgstr "Mapset <%s> nella location di input <%s> - %s"
 #: ../raster/r.proj/main.c:252 ../raster/r.proj.seg/main.c:289
 #: ../vector/v.proj/main.c:169
 #, fuzzy, c-format
 msgid "Checking location <%s> mapset <%s>"
-msgstr "Mappa raster in input"
+msgstr "Controllo della location <%s> mapset <%s>"
 #: ../raster/r.proj/main.c:267 ../raster/r.proj.seg/main.c:304
 #, fuzzy, c-format
 msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
-msgstr "Impossibile trovare il vettoriale [%s]"
+msgstr "Mappa raster <%s> nella location <%s> nel mapset <%s> non trovata"
 #: ../raster/r.proj/main.c:275 ../raster/r.proj.seg/main.c:312
 #, fuzzy
 msgid "Unable to get projection info of input map"
-msgstr "Stampa le informazioni di proiezione in formato WKT"
+msgstr "Impossibile ottenere informazioni sulla proiezione per la mappa raster di input"
 #: ../raster/r.proj/main.c:278 ../raster/r.proj.seg/main.c:315
 #, fuzzy
 msgid "Unable to get projection units of input map"
+msgstr "Impossibile ottenere le unità della proiezione per la mappa raster di input"
 #: ../raster/r.proj/main.c:281 ../raster/r.proj.seg/main.c:318
 #, fuzzy
 msgid "Unable to get projection key values of input map"
+msgstr "Impossibile ottenere i valori chiave della proiezione per la mappa raster di intput"
 #: ../raster/r.proj/main.c:295 ../raster/r.proj.seg/main.c:332
 msgid "Unable to work with unprojected data (xy location)"
-msgstr ""
+msgstr "Impossibile lavorare con dati non proiettati (location xy)"
 #: ../raster/r.proj/main.c:369 ../raster/r.proj.seg/main.c:440
-#, fuzzy
 msgid "Input:"
+msgstr ""
 #: ../raster/r.proj/main.c:370 ../raster/r.proj/main.c:381
 #: ../raster/r.proj.seg/main.c:441 ../raster/r.proj.seg/main.c:452
 #, fuzzy, c-format
 msgid "Cols: %d (%d)"
-msgstr "righe:    %d"
+msgstr "Colonne: %d  (%d)"
 #: ../raster/r.proj/main.c:371 ../raster/r.proj/main.c:382
 #: ../raster/r.proj.seg/main.c:442 ../raster/r.proj.seg/main.c:453
 #, fuzzy, c-format
 msgid "Rows: %d (%d)"
-msgstr "righe:    %d"
+msgstr "Righe: %d (%d)"
 #: ../raster/r.proj/main.c:372 ../raster/r.proj/main.c:383
 #: ../raster/r.proj.seg/main.c:443 ../raster/r.proj.seg/main.c:454
 #, fuzzy, c-format
 msgid "North: %f (%f)"
-msgstr "Nodo %d: %f %f\n"
+msgstr "Nord:  %f (%f)"
 #: ../raster/r.proj/main.c:373 ../raster/r.proj/main.c:384
 #: ../raster/r.proj.seg/main.c:444 ../raster/r.proj.seg/main.c:455
@@ -7853,25 +7507,25 @@
 #: ../raster/r.proj.seg/main.c:445 ../raster/r.proj.seg/main.c:456
 #, fuzzy, c-format
 msgid "West: %f (%f)"
+msgstr "Ovest:  %f (%f)"
 #: ../raster/r.proj/main.c:375 ../raster/r.proj/main.c:386
 #: ../raster/r.proj.seg/main.c:446 ../raster/r.proj.seg/main.c:457
 #, fuzzy, c-format
 msgid "East: %f (%f)"
+msgstr "Est:  %f (%f)"
 #: ../raster/r.proj/main.c:376 ../raster/r.proj/main.c:387
 #: ../raster/r.proj.seg/main.c:447 ../raster/r.proj.seg/main.c:458
 #, c-format
 msgid "EW-res: %f"
-msgstr "risoluzione-EO: %f"
+msgstr "Risoluzione-EO: %f"
 #: ../raster/r.proj/main.c:377 ../raster/r.proj/main.c:388
 #: ../raster/r.proj.seg/main.c:448 ../raster/r.proj.seg/main.c:459
 #, c-format
 msgid "NS-res: %f"
-msgstr "risoluzione-NS: %f"
+msgstr "Risoluzione-NS: %f"
 #: ../raster/r.proj/main.c:380 ../raster/r.proj.seg/main.c:451
 #, fuzzy
@@ -7881,18 +7535,18 @@
 #: ../raster/r.proj/main.c:416 ../raster/r.proj.seg/main.c:487
 #, fuzzy
 msgid "Projecting..."
+msgstr "Proiezione in corso ..."
 #: ../raster/r.proj/bordwalk.c:182 ../raster/r.proj.seg/bordwalk.c:182
 #, fuzzy
 msgid "Input raster map is outside current region"
+msgstr "La mappa raster di input è al di fuori della regione corrente"
 #: ../raster/r.proj/readcell.c:22 ../raster/r.proj.seg/readcell.c:62
 #: ../imagery/i.rectify/readcell.c:63
 #: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:70
 msgid "Allocating memory and reading input map..."
-msgstr ""
+msgstr "Allocazione della memoria e lettura della mappa di input in corso..."
 #: ../raster/r.out.mpeg/main.c:88
 msgid "Either mpeg_encode or ppmtompeg must be installed"
@@ -7901,16 +7555,16 @@
 #: ../raster/r.out.mpeg/main.c:213
 #, fuzzy
 msgid "Reading file"
+msgstr "Lettura del file"
 #: ../raster/r.out.mpeg/main.c:285 ../raster/r.out.mpeg/main.c:318
 msgid "mpeg_encode ERROR"
-msgstr ""
+msgstr "ERRORE mpeg_encode"
 #: ../raster/r.out.mpeg/main.c:353 ../visualization/xganim/main.c:544
 #, fuzzy
 msgid "Error reading wildcard"
+msgstr "Errore nella lettura della wildcard"
 #: ../raster/r.out.mpeg/main.c:390
 #, fuzzy
@@ -7939,7 +7593,7 @@
 #: ../raster/r.out.mpeg/main.c:426
 #, fuzzy
 msgid "Quiet - suppress progress report"
-msgstr "Silenzioso"
+msgstr "Silenzioso - sopprime il rapporto sullo stato di avanzamento"
 #: ../raster/r.out.mpeg/main.c:430
 msgid "Convert on the fly, uses less disk space"
@@ -7956,17 +7610,15 @@
 #: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
 #, fuzzy
 msgid "Unable to open output file"
+msgstr "Impossibile aprire il file di output"
 #: ../raster/r.out.mpeg/write.c:215
 #, fuzzy
 msgid "Unable to create temporary files."
+msgstr "Impossibile creare i file temporanei"
 #: ../raster/r.fill.dir/main.c:86
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
 msgstr ""
 #: ../raster/r.fill.dir/main.c:90
@@ -7997,7 +7649,7 @@
 #: ../raster/r.fill.dir/main.c:116
 #, fuzzy
 msgid "Find unresolved areas only"
-msgstr "trova solamente le aree non risolte"
+msgstr "Trova solamente le aree non risolte"
 #: ../raster/r.fill.dir/main.c:122
 #, fuzzy, c-format
@@ -8011,7 +7663,7 @@
 #: ../raster/r.fill.dir/main.c:188 ../raster/r.topidx/file_io.c:36
 #, fuzzy
 msgid "Reading elevation map..."
+msgstr "Lettura della mappa di elevazione in corso..."
 #: ../raster/r.fill.dir/main.c:198
 msgid "Filling sinks..."
@@ -8043,12 +7695,12 @@
 #: ../raster/r.fill.dir/dopolys.c:83
 #, fuzzy, c-format
 msgid "Found %d unresolved areas"
+msgstr "Trovate %d aree non risolte"
 #: ../raster/r.resamp.interp/main.c:72 ../raster/r.resamp.stats/main.c:259
 #, fuzzy
 msgid "raster, resample"
+msgstr "raster, ricampionamento"
 #: ../raster/r.resamp.interp/main.c:74
 msgid "Resamples raster map layers to a finer grid using interpolation."
@@ -8057,27 +7709,25 @@
 #: ../raster/r.resamp.interp/main.c:83
 #, fuzzy
 msgid "Interpolation method"
+msgstr "Metodo di interpolazione"
 #: ../raster/r.resamp.interp/main.c:97
 #, fuzzy, c-format
 msgid "Invalid method: %s"
-msgstr "Area: %d  Numero di isole: %d\n"
+msgstr "Metodo non valido: %s"
 #: ../raster/r.resamp.interp/main.c:320 ../raster/r.resamp.stats/main.c:374
 #, fuzzy, c-format
 msgid "Unable to read color table for %s"
+msgstr "Impossibile leggere la tavola dei colori per %s"
 #: ../raster/r.resamp.interp/main.c:323 ../raster/r.resamp.stats/main.c:378
 #, fuzzy, c-format
 msgid "Unable to write color table for %s"
+msgstr "Impossibile scrivere la tavola dei colori per %s"
 #: ../raster/r.cross/main.c:77
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
+msgid "Creates a cross product of the category values from multiple raster map layers."
 msgstr ""
 #: ../raster/r.cross/main.c:86
@@ -8119,10 +7769,7 @@
 msgstr ""
 #: ../raster/r.resamp.rst/main.c:158
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
 msgstr ""
 #: ../raster/r.resamp.rst/main.c:169
@@ -8134,44 +7781,43 @@
 msgstr "Risoluzione nord-sud desiderata"
 #: ../raster/r.resamp.rst/main.c:182
-#, fuzzy
 msgid "Output z-file (elevation) map"
-msgstr "Nome del file di output"
+msgstr ""
 #: ../raster/r.resamp.rst/main.c:190
 #, fuzzy
 msgid "Output slope map (or fx)"
-msgstr "Nome del driver in output"
+msgstr "Mappa delle pendenze (o fx) di output"
 #: ../raster/r.resamp.rst/main.c:198
 #, fuzzy
 msgid "Output aspect map (or fy)"
+msgstr "Mappa delle esposizioni (o fy) di output"
 #: ../raster/r.resamp.rst/main.c:206
 #, fuzzy
 msgid "Output profile curvature map (or fxx)"
+msgstr "Mappa della curvatura del profilo (o fxx) di output"
 #: ../raster/r.resamp.rst/main.c:214
 #, fuzzy
 msgid "Output tangential curvature map (or fyy)"
-msgstr "Nome del database in output"
+msgstr "Mappa della curvatura tangenziale (o fyy) di output"
 #: ../raster/r.resamp.rst/main.c:222
 #, fuzzy
 msgid "Output mean curvature map (or fxy)"
-msgstr "Visualizza il raster delle altezze dopo il riempimento"
+msgstr "Mappa della curvatura media (o fxy) di output"
 #: ../raster/r.resamp.rst/main.c:230
 #, fuzzy
 msgid "Name of raster map containing smoothing"
+msgstr "Nome della mappa raster che contiene smoothing"
 #: ../raster/r.resamp.rst/main.c:238
 #, fuzzy
 msgid "Name of raster map to be used as mask"
-msgstr "Nome della mappa raster da utilizzare per <%s>"
+msgstr "Nome della mappa raster da utilizzare come maschera"
 #: ../raster/r.resamp.rst/main.c:246
 msgid "Rows/columns overlap for segmentation"
@@ -8212,12 +7858,12 @@
 #: ../raster/r.resamp.rst/main.c:321
 #, fuzzy
 msgid "Cannot read ew_res value"
+msgstr "Impossibile leggere il valore ew_res (risoluzione E-O)"
 #: ../raster/r.resamp.rst/main.c:324
 #, fuzzy
 msgid "Cannot read ns_res value"
+msgstr "Impossibile leggere il valore ns_res (risoluzione N-S)"
 #: ../raster/r.resamp.rst/main.c:327
 msgid "Invalid value for tension"
@@ -8338,7 +7984,7 @@
 #: ../vector/v.surf.rst/main.c:692
 #, fuzzy, c-format
 msgid "Unable to open temporary file <%s>"
+msgstr "Impossibile aprire il file temporaneo <%s>"
 #: ../raster/r.resamp.rst/main.c:622 ../raster/r.resamp.rst/main.c:635
 #: ../raster/r.resamp.rst/main.c:648 ../raster/r.resamp.rst/main.c:662
@@ -8347,27 +7993,25 @@
 #: ../vector/v.surf.rst/main.c:668 ../vector/v.surf.rst/main.c:678
 #: ../vector/v.surf.rst/main.c:687 ../vector/v.surf.rst/main.c:696
 msgid "Not enough disk space -- cannot write files"
-msgstr ""
+msgstr "Spazio nel disco insufficiente -- impossibile scrivere i file"
 #: ../raster/r.clump/main.c:49
 #, fuzzy
 msgid "raster, statistics, reclass"
+msgstr "raster, statistica, riclassificazione"
 #: ../raster/r.clump/main.c:51
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Ricategorizza i dati in una mappa raster raggruppando celle che formano aree fisicamente distinte in categorie singole."
 #: ../raster/r.clump/main.c:63
 msgid "Title, in quotes"
 msgstr "Titolo, fra virgolette"
 #: ../raster/r.clump/main.c:120
-#, fuzzy, c-format
+#, c-format
 msgid "%d clumps."
+msgstr ""
 #: ../raster/r.clump/clump.c:98
 #, c-format
@@ -8377,44 +8021,38 @@
 #: ../raster/r.clump/clump.c:101
 #, fuzzy, c-format
 msgid "Unable to read raster map row %d "
-msgstr "Nome della mappa raster risultante"
+msgstr "Impossibile leggere la riga %d della mappa raster"
 #: ../raster/r.clump/clump.c:238
 #, fuzzy, c-format
 msgid "Failed writing raster map row %d"
+msgstr "Scrittura della riga %d della mappa raster non riuscita"
 #: ../raster/r.out.tiff/r.out.tiff.c:101
-msgid ""
-"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-"resolution of the currently defined region."
-msgstr ""
-"Esporta un raster GRASS in un'immagine TIFF 8/24bit con la risoluzione del "
-"pixel definita della region corrente"
+msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
+msgstr "Esporta un raster GRASS in un'immagine TIFF 8/24bit con la risoluzione del pixel definita della regione corrente"
 #: ../raster/r.out.tiff/r.out.tiff.c:111
 #, fuzzy
 msgid "Name for new TIFF file"
-msgstr "Nome di un nuovo file raster"
+msgstr "Nome del nuovo file TIFF"
 #: ../raster/r.out.tiff/r.out.tiff.c:118
 msgid "TIFF file compression"
 msgstr ""
 #: ../raster/r.out.tiff/r.out.tiff.c:123
-#, fuzzy
 msgid "TIFF Palette output (8bit instead of 24bit)."
-msgstr "output verticale (invece che orizzontale)"
+msgstr ""
 #: ../raster/r.out.tiff/r.out.tiff.c:127
 #, fuzzy
 msgid "Output TIFF world file"
+msgstr "File TIFF world di output"
 #: ../raster/r.out.tiff/r.out.tiff.c:131
-#, fuzzy
 msgid "Output Tiled TIFF"
+msgstr ""
 #: ../raster/r.out.tiff/r.out.tiff.c:169 ../raster/r.texture/main.c:240
 #: ../raster/r.null/null.c:157 ../raster/r.topidx/file_io.c:20
@@ -8422,7 +8060,7 @@
 #: ../imagery/i.rectify/main.c:264
 #, fuzzy, c-format
 msgid "Unable to read header of raster map <%s>"
+msgstr "Impossibile leggere l'intestazione della mappa raster <%s>"
 #: ../raster/r.out.tiff/r.out.tiff.c:173 ../raster/r.in.ascii/main.c:190
 #: ../raster/r.in.arc/main.c:132
@@ -8431,57 +8069,47 @@
 #: ../raster/r.out.tiff/r.out.tiff.c:177
 #, c-format
-msgid ""
-"Raster map <%s> in mapset <%s> is a floating point map. Decimal values will "
-"be rounded to integer!"
+msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
 msgstr ""
 #: ../raster/r.out.tiff/r.out.tiff.c:183
-msgid ""
-"Color map for palette must have less than 256 colors for the available range "
-"of data"
+msgid "Color map for palette must have less than 256 colors for the available range of data"
 msgstr ""
 #: ../raster/r.out.tiff/r.out.tiff.c:198
 #, fuzzy, c-format
 msgid "Unable to open TIFF file <%s>"
+msgstr "Impossibile aprire il file TIFF <%s>"
 #: ../raster/r.out.tiff/r.out.tiff.c:283 ../raster/r.texture/main.c:261
 #: ../raster/r.carve/raster.c:12 ../imagery/i.zc/main.c:167
 #, fuzzy
 msgid "Reading raster map..."
+msgstr "Lettura della mappa raster in corso..."
 #: ../raster/r.out.tiff/r.out.tiff.c:414
 #, fuzzy
 msgid "Writing TIFF World file"
-msgstr "Nome del raster map esistente"
+msgstr "Scrittura del file TIFF  World"
 #: ../raster/r.out.tiff/r.out.tiff.c:422
 #, fuzzy
 msgid "Unable to open TIFF world file for writing"
+msgstr "Impossibile aprire il  file TIFF  World per la scrittura"
 #: ../raster/r.in.xyz/main.c:159
 #, fuzzy
 msgid "raster, import, LIDAR"
-msgstr "File di input"
+msgstr "raster, importazione, LIDAR"
 #: ../raster/r.in.xyz/main.c:161
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
-msgstr ""
-"Crea un raster da un assemblaggio di molte coordinate usando statistiche "
-"univariate"
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
+msgstr "Crea un raster da un assemblaggio di molte coordinate usando statistiche univariate"
 #: ../raster/r.in.xyz/main.c:165
 #, fuzzy
 msgid "ASCII file containing input data (or \"-\" to read from stdin)"
-msgstr ""
-"File ASCII contenente la singola linea descrivente la proiezione WKT (- per "
-"stdin)"
+msgstr "File ASCII contenente i dati di input (o \"-\" per leggere dallo stdin)"
 #: ../raster/r.in.xyz/main.c:173
 msgid "Statistic to use for raster values"
@@ -8517,14 +8145,11 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:242
-#, fuzzy
 msgid "pth percentile of the values"
-msgstr "strighe che rappresentano le celle prive di valori"
+msgstr ""
 #: ../raster/r.in.xyz/main.c:251
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
 msgstr ""
 #: ../raster/r.in.xyz/main.c:256
@@ -8534,8 +8159,7 @@
 #: ../raster/r.in.xyz/main.c:261
 #, fuzzy
 msgid "In scan mode, print using shell script style"
-msgstr ""
-"Stampa le impostazioni della region corrente (in stile script per la shell)"
+msgstr "In modalità scansione, stampa usando lo stile dello script di shell"
 #: ../raster/r.in.xyz/main.c:265
 msgid "Ignore broken lines"
@@ -8546,9 +8170,8 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:302
-#, fuzzy
 msgid "Invalid zrange"
-msgstr "Est non valido"
+msgstr ""
 #: ../raster/r.in.xyz/main.c:389
 msgid "Unable to calculate percentile without the pth option specified!"
@@ -8565,11 +8188,10 @@
 #: ../vector/v.net.path/path.c:49
 #, fuzzy, c-format
 msgid "Unable to open input file <%s>"
+msgstr "impossibile aprire il file di input <%s>"
 #: ../raster/r.in.xyz/main.c:477
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
+msgid "If input is not from a file it is only possible to perform a single pass."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:483
@@ -8579,14 +8201,13 @@
 #: ../raster/r.in.xyz/main.c:521
 #, fuzzy
 msgid "Reading data ..."
-msgstr "Sto disegnando ..."
+msgstr "Lettura dei dati in corso ..."
 #: ../raster/r.in.xyz/main.c:599 ../raster/r.in.xyz/main.c:607
 #: ../raster/r.in.xyz/main.c:1103 ../raster/r.in.xyz/main.c:1111
 #, c-format
 msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %lu:\n"
+"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
 "[%s]"
 msgstr ""
@@ -8612,7 +8233,7 @@
 #: ../raster/r.in.xyz/main.c:718
 #, fuzzy
 msgid "Writing to map ..."
+msgstr "Scrittura della mappa in corso ..."
 #: ../raster/r.in.xyz/main.c:1014
 #, c-format
@@ -8622,17 +8243,17 @@
 #: ../raster/r.in.xyz/main.c:1061
 #, fuzzy, c-format
 msgid "%lu points found in region."
+msgstr "Tovati %lu punti nella regione."
 #: ../raster/r.in.xyz/main.c:1088
 #, fuzzy
 msgid "Scanning data ..."
+msgstr "Scansione dei dati in corso ..."
 #: ../raster/r.in.xyz/main.c:1176
 #, c-format
 msgid "Range:     min         max\n"
-msgstr ""
+msgstr "Campo di variazione:     min         max\n"
 #: ../raster/r.texture/main.c:76
 msgid "Generate images with textural features from a raster map."
@@ -8641,7 +8262,7 @@
 #: ../raster/r.texture/main.c:87
 #, fuzzy
 msgid "Prefix for output raster map(s)"
-msgstr "Nome del raster in output"
+msgstr "Prefisso per la mappa/e raster di output"
 #: ../raster/r.texture/main.c:94
 msgid "The size of sliding window (odd and >= 3)"
@@ -8688,9 +8309,8 @@
 msgstr ""
 #: ../raster/r.texture/main.c:152
-#, fuzzy
 msgid "Sum Variance"
-msgstr "Varianza"
+msgstr ""
 #: ../raster/r.texture/main.c:157
 msgid "Sum Entropy"
@@ -8701,9 +8321,8 @@
 msgstr ""
 #: ../raster/r.texture/main.c:167
-#, fuzzy
 msgid "Difference Variance"
-msgstr "Varianza"
+msgstr ""
 #: ../raster/r.texture/main.c:172
 msgid "Difference Entropy"
@@ -8731,16 +8350,12 @@
 msgstr ""
 #: ../raster/r.texture/h_measure.c:84
-msgid ""
-"Negative or no data pixel found. This module is not yet able to process no "
-"data holes in a map, please fill with r.fillnulls or other algorithms"
+msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
 msgstr ""
 #: ../raster/r.texture/h_measure.c:88
 #, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
 msgstr ""
 #: ../raster/r.texture/h_measure.c:927
@@ -8749,14 +8364,11 @@
 msgstr ""
 #: ../raster/r.surf.random/main.c:44
-#, fuzzy
 msgid "raster, random"
-msgstr "Mostra il titolo del file raster"
+msgstr ""
 #: ../raster/r.surf.random/main.c:46
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
 msgstr ""
 #: ../raster/r.surf.random/main.c:53
@@ -8770,12 +8382,12 @@
 #: ../raster/r.surf.random/main.c:65
 #, fuzzy
 msgid "Create an integer raster map"
+msgstr "Crea una mappa raster di valori interi"
 #: ../raster/r.surf.random/main.c:79
 #, fuzzy, c-format
 msgid "Raster map <%s> generated."
+msgstr "La mappa raster <%s> è stata generata"
 #: ../raster/r.out.arc/main.c:62
 msgid "Converts a raster map layer into an ESRI ARCGRID file."
@@ -8818,25 +8430,23 @@
 msgstr ""
 #: ../raster/r.surf.contour/main.c:77
-msgid ""
-"Invoke slow, but memory frugal operation (generally not needed, will be "
-"removed in future)"
+msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
 msgstr ""
 #: ../raster/r.colors/main.c:175
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
 #, fuzzy
 msgid "raster, color table"
+msgstr "raster, tavola dei colori"
 #: ../raster/r.colors/main.c:177
 msgid "Creates/modifies the color table associated with a raster map layer."
-msgstr "Crea/modifica la tabella dei colori associata a un raster"
+msgstr "Crea/modifica la tavola dei colori associata a un raster"
 #: ../raster/r.colors/main.c:191
 #: ../locale/scriptstrings/v.colors_to_translate.c:9
 msgid "Type of color table"
-msgstr "Tipo di tabella colore"
+msgstr "Tipo di tavola dei colori"
 #: ../raster/r.colors/main.c:193 ../raster/r.colors/main.c:200
 #: ../raster/r.colors/main.c:206 ../raster/r.colors/main.c:225
@@ -8854,12 +8464,12 @@
 #: ../raster/r.colors/main.c:205
 #, fuzzy
 msgid "Path to rules file (\"-\" to read rules from stdin)"
-msgstr "File raster ascii da importare"
+msgstr "Percorso del file delle regole (\"-\" per leggere le regole dallo stdin)"
 #: ../raster/r.colors/main.c:210
 #, fuzzy
 msgid "Remove existing color table"
-msgstr "Mantieni la tabella colore esistente"
+msgstr "Rimuove la tavola dei colori esistente"
 #: ../raster/r.colors/main.c:211
 #: ../locale/scriptstrings/r.mask_to_translate.c:11
@@ -8868,51 +8478,47 @@
 #: ../raster/r.colors/main.c:216
 msgid "Only write new color table if one doesn't already exist"
-msgstr ""
+msgstr "Scrive una nuova tabella dei colori solo se non ne esite già una"
 #: ../raster/r.colors/main.c:220
 #, fuzzy
 msgid "List available rules then exit"
-msgstr "Visualizza i formati supportati ed esci"
+msgstr "Elenca le regole disponibili ed esce"
 #: ../raster/r.colors/main.c:224
 #: ../locale/scriptstrings/v.colors_to_translate.c:16
 #, fuzzy
 msgid "Invert colors"
-msgstr " nv colore\n"
+msgstr "Inverte i colori"
 #: ../raster/r.colors/main.c:229
 msgid "Logarithmic scaling"
-msgstr ""
+msgstr "Scaling logaritmico"
 #: ../raster/r.colors/main.c:234
 msgid "Logarithmic-absolute scaling"
-msgstr ""
+msgstr "Scaling logaritmico assoluto"
 #: ../raster/r.colors/main.c:239
 msgid "Histogram equalization"
-msgstr ""
+msgstr "Equalizzazione dell'istogramma"
 #: ../raster/r.colors/main.c:244
 msgid "Enter rules interactively"
-msgstr ""
+msgstr "Immissione delle regole in modo interattivo"
 #: ../raster/r.colors/main.c:277
 #, fuzzy
 msgid "No raster map specified"
-msgstr "Nessuna mappa in input specificata"
+msgstr "Nessuna mappa raster specificata"
 #: ../raster/r.colors/main.c:280
-msgid ""
-"One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be "
-"specified!"
-msgstr ""
+msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
+msgstr "Dev'essere specificato \"-i\" o \"-r\", o le opzioni \"color\", \"rast\" o \"rules\"!"
 #: ../raster/r.colors/main.c:283
-msgid ""
-"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
-"options"
-msgstr ""
+msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
+msgstr "La modalità interattiva è incompatibile con le opzioni \"color\", \"rules\" e \"raster\""
 #: ../raster/r.colors/main.c:290
 msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
@@ -8925,12 +8531,12 @@
 #: ../raster/r.colors/main.c:311
 #, fuzzy, c-format
 msgid "Unable to remove color table of raster map <%s>"
+msgstr "Non è possibile rimuovere la tavola dei colori della mappa raster <%s>"
 #: ../raster/r.colors/main.c:313
 #, fuzzy, c-format
 msgid "Color table of raster map <%s> not found"
+msgstr "Tavola dei colori <%s> non trovata"
 #: ../raster/r.colors/main.c:325
 msgid "Color table exists. Exiting."
@@ -8939,31 +8545,31 @@
 #: ../raster/r.colors/main.c:345
 #, fuzzy
 msgid "Color table 'random' is not supported for floating point raster map"
+msgstr "La tavola dei colori 'random' non è supportata dai raster con valori a virgola mobile"
 #: ../raster/r.colors/main.c:350
 #, fuzzy
 msgid "Color table 'grey.eq' is not supported for floating point raster map"
+msgstr "La tavola dei colori 'grey.eq' non è supportata dai raster con valori a virgola mobile"
 #: ../raster/r.colors/main.c:357
 msgid "Color table 'grey.log' is not supported for floating point raster map"
-msgstr ""
+msgstr "La tavola dei colori 'grey.log' non è supportata dai raster con valori a virgola mobile"
 #: ../raster/r.colors/main.c:370
 #, fuzzy, c-format
 msgid "Unknown color request '%s'"
+msgstr "Richiesta di colore '%s' sconosciuta"
 #: ../raster/r.colors/main.c:381
 #, fuzzy, c-format
 msgid "Unable to load rules file <%s>"
+msgstr "impossibile caricare il file di regole <%s>"
 #: ../raster/r.colors/main.c:428
 #, fuzzy, c-format
 msgid "Color table for raster map <%s> set to '%s'"
+msgstr "Tavola dei colori per la mappa raster <%s> impostata a '%s'"
 #: ../raster/r.colors/rules.c:42
 #, c-format
@@ -8973,7 +8579,7 @@
 #: ../raster/r.colors/rules.c:51
 #, fuzzy, c-format
 msgid "fp: Data range is %s to %s\n"
-msgstr "fp: l'intervallo di dati è da %.25f a %.25f\n"
+msgstr "fp: l'intervallo di dati è da %s a %s\n"
 #: ../raster/r.colors/rules.c:55 ../raster/r.reclass/main.c:110
 #, c-format
@@ -8985,7 +8591,9 @@
 msgid ""
 "Your color rules do not cover the whole range of data!\n"
 " (rules %f to %f but data %f to %f)"
-msgstr "Le tue regole color non ricoprono l'intero intervallo di dati!"
+msgstr ""
+"Le regole per i colori non ricoprono l'intero intervallo di dati!\n"
+" (le regole indicano da %f a %f ma i dati da %f da %f)"
 #: ../raster/r.colors/rules.c:106 ../raster/r.reclass/parse.c:40
 #, c-format
@@ -9025,12 +8633,12 @@
 #: ../raster/r.colors/rules.c:134
 #, fuzzy, c-format
 msgid "bad rule (%s); rule not added"
-msgstr "** regola non aggiunta **\n"
+msgstr "regola non corretta (%s); regola non aggiunta"
 #: ../raster/r.colors/rules.c:136
 #, c-format
 msgid "bad rule (%s): [%s]"
-msgstr ""
+msgstr "regola non corretta (%s)): [%s]"
 #: ../raster/r.colors/stats.c:79
 msgid "Unable to use logarithmic scaling if range includes zero"
@@ -9055,11 +8663,11 @@
 #: ../raster/r.statistics/main.c:110
 #, fuzzy, c-format
 msgid "Output map <%s> ignored"
-msgstr "Mappa in output"
+msgstr "Mappa di output <%s> ignorata"
 #: ../raster/r.statistics/main.c:177
 msgid "Not yet implemented!"
-msgstr ""
+msgstr "Non ancora implementato!"
 #: ../raster/r.statistics/main.c:187
 #, c-format
@@ -9117,28 +8725,24 @@
 #: ../raster/r.li/r.li.renyi/renyi.c:54
 #, fuzzy
 msgid "Configuration file"
+msgstr "File di configurazione"
 #: ../raster/r.li/r.li.mpa/mpa.c:39
-#, fuzzy
 msgid "Calculates mean pixel attribute index on a raster map"
+msgstr ""
 #: ../raster/r.li/r.li.patchnum/main.c:34
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr ""
 #: ../raster/r.li/r.li.mps/mps.c:40
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.pielou/pielou.c:57
 #, fuzzy
 msgid "Calculates Pielou's diversity index on a raster map"
-msgstr "Calcola l'indice di diversità di Simpson su un raster"
+msgstr "Calcola l'indice di diversità di  Pielou su una mappa raster"
 #: ../raster/r.li/r.li.pielou/pielou.c:59
 #: ../raster/r.li/r.li.dominance/dominance.c:43
@@ -9149,8 +8753,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:38
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.cwed/cwed.c:46
@@ -9175,8 +8778,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.patchdensity/main.c:33
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.simpson/simpson.c:39
@@ -9186,13 +8788,13 @@
 #: ../raster/r.li/r.li.daemon/worker.c:66
 #, fuzzy, c-format
 msgid "CHILD[pid = %i] cannot open raster map"
-msgstr "Non riesco a trovare il file raster %s"
+msgstr "CHILD[pid = %i] impossibile aprire la mappa raster"
 #: ../raster/r.li/r.li.daemon/worker.c:104
 #: ../raster/r.li/r.li.daemon/worker.c:111
-#, fuzzy, c-format
+#, c-format
 msgid "CHILD[pid = %i] cannot open receive channel"
+msgstr ""
 #: ../raster/r.li/r.li.daemon/worker.c:140
 #: ../raster/r.li/r.li.daemon/worker.c:150
@@ -9253,29 +8855,27 @@
 msgstr ""
 #: ../raster/r.li/r.li.daemon/daemon.c:78
-#, fuzzy
 msgid "Error in pipe creation"
-msgstr "Punto di riferimento"
+msgstr ""
 #: ../raster/r.li/r.li.daemon/daemon.c:86
-#, fuzzy, c-format
+#, c-format
 msgid "Error opening channel %i"
-msgstr "Errore nell'apertura del file g3d"
+msgstr ""
 #: ../raster/r.li/r.li.daemon/daemon.c:132
-#, fuzzy
 msgid "Cannot create random access file"
+msgstr ""
 #: ../raster/r.li/r.li.daemon/daemon.c:140
 #, fuzzy, c-format
 msgid "Cannot create %s/.r.li/ directory"
-msgstr "Non riesco a descrivere la tabella"
+msgstr "Impossibile creare la directory  %s/.r.li/"
 #: ../raster/r.li/r.li.daemon/daemon.c:145
 #, fuzzy, c-format
 msgid "Cannot create %s/.r.li/output/ directory"
+msgstr "Impossibile creare la directory  %s/.r.li/output/"
 #: ../raster/r.li/r.li.daemon/daemon.c:244
 #: ../raster/r.li/r.li.daemon/daemon.c:269
@@ -9292,53 +8892,50 @@
 #: ../raster/r.li/r.li.daemon/daemon.c:253
 #, fuzzy, c-format
 msgid "Cannot close %s file (PIPE)"
-msgstr "Non riesco ad impostare user/password"
+msgstr "Impossibile chiudere il file %s (PIPE)"
 #: ../raster/r.li/r.li.daemon/daemon.c:255
 #, fuzzy, c-format
 msgid "Cannot delete %s file (PIPE)"
+msgstr "Impossibile eliminare il file %s (PIPE)"
 #: ../raster/r.li/r.li.daemon/daemon.c:278
 #, fuzzy, c-format
 msgid "Cannot close %s file (PIPE2)"
+msgstr "Impossibile chiudere il file %s (PIPE2)"
 #: ../raster/r.li/r.li.daemon/daemon.c:280
 #, fuzzy, c-format
 msgid "Cannot delete %s file (PIPE2)"
+msgstr "Impossibile eliminare il file %s (PIPE2)"
 #: ../raster/r.li/r.li.daemon/daemon.c:299
-#, fuzzy
 msgid "Cannot close receive channel file"
+msgstr ""
 #: ../raster/r.li/r.li.daemon/daemon.c:302
 #, fuzzy, c-format
 msgid "Cannot delete %s file"
+msgstr "Impossibile eliminare il file %s"
 #: ../raster/r.li/r.li.daemon/daemon.c:321
 #, fuzzy, c-format
 msgid "Cannot find configuration file <%s>"
+msgstr "Impossibile trovare il file di configurazione <%s>"
 #: ../raster/r.li/r.li.daemon/daemon.c:328
 #: ../raster/r.li/r.li.daemon/daemon.c:332
-#, fuzzy
 msgid "Cannot read setup file"
+msgstr ""
 #: ../raster/r.li/r.li.daemon/daemon.c:336
-#, fuzzy
 msgid "Unable to parse configuration file"
+msgstr ""
 #: ../raster/r.li/r.li.daemon/daemon.c:346
 #, fuzzy
 msgid "Cannot read raster header file"
+msgstr "Impossibile leggere il file delle intestazioni del raster"
 #: ../raster/r.li/r.li.daemon/daemon.c:489
 msgid "Irregular maskedoverlay areas definition"
@@ -9350,28 +8947,24 @@
 msgstr ""
 #: ../raster/r.li/r.li.daemon/daemon.c:499
-#, fuzzy
 msgid "Illegal configuration file (sample area)"
+msgstr ""
 #: ../raster/r.li/r.li.daemon/daemon.c:533
-#, fuzzy
 msgid "Too many units to place"
-msgstr "nome tabella"
+msgstr ""
 #: ../raster/r.li/r.li.daemon/daemon.c:602
-#, fuzzy
 msgid "Too many strats for raster map"
+msgstr ""
 #: ../raster/r.li/r.li.daemon/daemon.c:636
 msgid "Illegal areas disposition"
 msgstr ""
 #: ../raster/r.li/r.li.daemon/daemon.c:705
-#, fuzzy
 msgid "Cannot make lseek"
+msgstr ""
 #: ../raster/r.li/r.li.padrange/padrange.c:39
 msgid "Calculates range of patch area size on a raster map"
@@ -9379,12 +8972,12 @@
 #: ../raster/r.li/r.li.shannon/shannon.c:38
 msgid "Calculates Shannon's diversity index on a raster map"
-msgstr "Calcola l'indice di diversità di Shannon su un raster"
+msgstr "Calcola l'indice di diversità di Shannon su una mappa raster"
 #: ../raster/r.li/r.li.renyi/renyi.c:44
 #, fuzzy
 msgid "Calculates Renyi's diversity index on a raster map"
+msgstr "Calcola l'indice di diversità di Renyi su una mappa raster"
 #: ../raster/r.li/r.li.renyi/renyi.c:62
 msgid "Alpha value is the order of the generalized entropy"
@@ -9393,7 +8986,7 @@
 #: ../raster/r.out.gdal/main.c:49
 #, fuzzy, c-format
 msgid "Supported formats:\n"
+msgstr "Formati supportati:\n"
 #: ../raster/r.out.gdal/main.c:127
 msgid "Exports GRASS raster maps into GDAL supported formats."
@@ -9403,12 +8996,12 @@
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:3
 #, fuzzy
 msgid "List supported output formats"
+msgstr "Elenca i formati di output supportati"
 #: ../raster/r.out.gdal/main.c:137
 #, fuzzy
 msgid "Do not write GDAL standard colortable"
+msgstr "Non scrive la tavola dei colori standard di GDAL"
 #: ../raster/r.out.gdal/main.c:138
 msgid "Only applicable to Byte or UInt16 data types."
@@ -9425,7 +9018,7 @@
 #: ../raster/r.out.gdal/main.c:147
 #, fuzzy
 msgid "Name of raster map (or group) to export"
-msgstr "Nome della mappa raster che contiene i risultati"
+msgstr "Nome della mappa raster (o gruppo) da esportare"
 #: ../raster/r.out.gdal/main.c:154
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:6
@@ -9436,12 +9029,12 @@
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:7
 #, fuzzy
 msgid "File type"
-msgstr "Tipo di grafico"
+msgstr "Tipo di file"
 #: ../raster/r.out.gdal/main.c:183
 #, fuzzy
 msgid "Name for output raster file"
-msgstr "Nome di un file vettoriale in output"
+msgstr "Nome del file vettoriale in output"
 #: ../raster/r.out.gdal/main.c:190
 msgid "Creation option(s) to pass to the output format driver"
@@ -9457,9 +9050,7 @@
 msgstr ""
 #: ../raster/r.out.gdal/main.c:201
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:210
@@ -9469,29 +9060,26 @@
 #: ../raster/r.out.gdal/main.c:243
 #, fuzzy, c-format
 msgid "Raster map or group <%s> not found"
+msgstr "Mappa raster o gruppo <%s> non trovato"
 #: ../raster/r.out.gdal/main.c:247
 #, fuzzy, c-format
 msgid "No raster maps in group <%s>"
-msgstr "Nome del driver in input"
+msgstr "Nessuna mappa raster nel gruppo <%s>"
 #: ../raster/r.out.gdal/main.c:261
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get <%s> driver"
+msgstr ""
 #: ../raster/r.out.gdal/main.c:267
 #, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:272
-#, fuzzy
 msgid "Unable to get in-memory raster driver"
+msgstr ""
 #: ../raster/r.out.gdal/main.c:276
 #, c-format
@@ -9499,9 +9087,9 @@
 msgstr ""
 #: ../raster/r.out.gdal/main.c:352
-#, fuzzy, c-format
+#, c-format
 msgid "Could not read data range of raster <%s>"
+msgstr ""
 #: ../raster/r.out.gdal/main.c:409
 #, c-format
@@ -9514,35 +9102,29 @@
 #: ../raster/r.out.gdal/main.c:435
 #, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
-"avoided by using %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:446
 #, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:454
 #, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
-"This can be avoided by using Float64"
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
 msgstr ""
 #: ../raster/r.out.gdal/main.c:463 ../raster/r.out.gdal/main.c:506
 #, fuzzy
 msgid "Forcing raster export."
+msgstr "Si sta forzando l'esportazione del raster."
 #: ../raster/r.out.gdal/main.c:465 ../raster/r.out.gdal/main.c:479
 #: ../raster/r.out.gdal/main.c:508 ../raster/r.out.gdal/main.c:512
 #, fuzzy
 msgid "Raster export aborted."
-msgstr "Il file raster da importare"
+msgstr "Esportazione del raster interrotta."
 #: ../raster/r.out.gdal/main.c:489
 msgid "Checking GDAL data type and nodata value"
@@ -9551,52 +9133,49 @@
 #: ../raster/r.out.gdal/main.c:492
 #, fuzzy, c-format
 msgid "Checking options for raster map <%s> (band %d)..."
+msgstr "Controllo delle opzioni per la mappa raster <%s> (banda %d) in corso..."
 #: ../raster/r.out.gdal/main.c:533
 #, fuzzy
 msgid "Output file name not specified"
-msgstr "file vettoriale da creare"
+msgstr "Nome del file di output non specificato"
 #: ../raster/r.out.gdal/main.c:539
-#, fuzzy
 msgid "Unable to create dataset using memory raster driver"
-msgstr "Non riesco ad aprire il database %s col driver %s"
+msgstr ""
 #: ../raster/r.out.gdal/main.c:548
 #, fuzzy, c-format
 msgid "Unable to create <%s> dataset using <%s> driver"
+msgstr "Impossibile creare il dataset <%s> usando il driver <%s>"
 #: ../raster/r.out.gdal/main.c:563
-#, fuzzy
 msgid "Unable to set geo transform"
+msgstr ""
 #: ../raster/r.out.gdal/main.c:571
 #, fuzzy
 msgid "Unable to set projection"
+msgstr "Non è possibile impostare la proiezione"
 #: ../raster/r.out.gdal/main.c:577
-#, fuzzy
 msgid "Exporting to GDAL raster"
-msgstr "Esporta al tipo di dato GDAL: %s"
+msgstr ""
 #: ../raster/r.out.gdal/main.c:580
 #, fuzzy, c-format
 msgid "Exporting raster map <%s> (band %d)..."
+msgstr "Esportazione della mappa raster <%s> (banda %d) in corso..."
 #: ../raster/r.out.gdal/main.c:593
 #, fuzzy, c-format
 msgid "Unable to export raster map <%s>"
+msgstr "Non è possibile esportare la mappa raster <%s>"
 #: ../raster/r.out.gdal/main.c:605
 #, fuzzy, c-format
 msgid "Unable to create raster map <%s> using driver <%s>"
+msgstr "Impossibile creare la mappa raster <%s> usando il driver <%s>"
 #: ../raster/r.out.gdal/main.c:628 ../raster/r.out.gdal/main.c:640
 #: ../raster/r.out.gdal/main.c:653 ../raster/r.out.gdal/main.c:666
@@ -9643,10 +9222,7 @@
 #: ../raster/r.out.gdal/main.c:746 ../raster/r.out.gdal/main.c:759
 #: ../raster/r.out.gdal/main.c:774
 #, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:722 ../raster/r.out.gdal/main.c:749
@@ -9662,10 +9238,7 @@
 #: ../raster/r.out.gdal/main.c:788
 #, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:791
@@ -9676,51 +9249,38 @@
 #: ../raster/r.out.gdal/export_band.c:67 ../raster/r.out.gdal/export_band.c:73
 #: ../raster/r.out.gdal/export_band.c:380
 #: ../raster/r.out.gdal/export_band.c:386
-#, fuzzy
 msgid "Unable to allocate buffer for reading raster map"
+msgstr ""
 #: ../raster/r.out.gdal/export_band.c:195
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will "
-"be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:200
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will "
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:210
 #, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:217
 #, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:261
-#, fuzzy
 msgid "Unable to get raster band"
+msgstr ""
 #: ../raster/r.out.gdal/export_band.c:426
 #: ../raster/r.out.gdal/export_band.c:460
 #: ../raster/r.out.gdal/export_band.c:494
-#, fuzzy
 msgid "Unable to write GDAL raster file"
-msgstr "Valore da scrivere per null"
+msgstr ""
 #: ../raster/r.out.gdal/export_band.c:515
 #: ../raster/r.out.gdal/export_band.c:527
@@ -9731,21 +9291,19 @@
 #: ../raster/r.out.gdal/export_band.c:592
 #, fuzzy, c-format
 msgid "Raster map <%s> range: %g - %g"
-msgstr "ERRORE: <%s> esiste già\n"
+msgstr "Mappa raster <%s> intervallo:  %g - %g"
 #: ../raster/r.null/null.c:58
-#, fuzzy
 msgid "raster, null data"
+msgstr ""
 #: ../raster/r.null/null.c:59
 msgid "Manages NULL-values of given raster map."
-msgstr "Gestisci valori nulli di un raster"
+msgstr "Gestisce i valori NULL di una data mappa raster"
 #: ../raster/r.null/null.c:62
-#, fuzzy
 msgid "Raster map for which to edit null file"
-msgstr "Mappa(e) raster da leggere"
+msgstr ""
 #: ../raster/r.null/null.c:81
 msgid "Only do the work if the map is floating-point"
@@ -9756,89 +9314,85 @@
 msgstr ""
 #: ../raster/r.null/null.c:90
-#, fuzzy
 msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
-msgstr "Crea separatamente un file bitmap 3D di valori nulli"
+msgstr ""
 #: ../raster/r.null/null.c:95
 msgid "Create NULL-value bitmap file validating all data cells"
 msgstr ""
 #: ../raster/r.null/null.c:99
-#, fuzzy
 msgid "Remove NULL-value bitmap file"
+msgstr ""
 #: ../raster/r.null/null.c:117
 #, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
 msgstr ""
 #: ../raster/r.null/null.c:123
 #, fuzzy, c-format
 msgid "Raster map <%s> is not in your mapset <%s>"
-msgstr "raster <%s> non trovato"
+msgstr "La mappa raster <%s> non è nel mapset <%s> dell'utente"
 #: ../raster/r.null/null.c:130
 #, fuzzy, c-format
 msgid "%s is illegal entry for null"
-msgstr "Valore da impostare a null non valido"
+msgstr "%s è un'immissione non valida per null"
 #: ../raster/r.null/null.c:137
 #, fuzzy, c-format
 msgid "Raster map <%s> already has a null bitmap file"
-msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
+msgstr "La mappa raster <%s> ha già un file bitmap di valori nulli"
 #: ../raster/r.null/null.c:141
 #, fuzzy, c-format
 msgid "<%s> is integer raster map (CELL)"
+msgstr "<%s> è una mappa raster con valori interi (CELL)"
 #: ../raster/r.null/null.c:145
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> is integer raster map (CELL). Using null=%d."
+msgstr ""
 #: ../raster/r.null/null.c:151
 #, fuzzy, c-format
 msgid "<%s> is floating pointing raster map"
-msgstr "Punti di partenza del file raster"
+msgstr "<%s> è una mappa raster con valori a virgola mobile"
 #: ../raster/r.null/null.c:169
 #, fuzzy, c-format
 msgid "Writing new null file for raster map <%s>..."
-msgstr "Errore nella lettura del file dbmscap\n"
+msgstr "Scrittura del nuovo file di valori nulli per la mappa raster <%s> in corso..."
 #: ../raster/r.null/null.c:176
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing null row %d"
+msgstr ""
 #: ../raster/r.null/null.c:181 ../raster/r.null/null.c:194
 #, fuzzy, c-format
 msgid "Raster map <%s> modified."
+msgstr "Mappa raster <%s> modificata."
 #: ../raster/r.null/null.c:188
 #, fuzzy, c-format
 msgid "Removing null file for raster map <%s>..."
+msgstr "Rimozione in corso del file di valori nulli per la mappa raster <%s>..."
 #: ../raster/r.null/null.c:258
-#, fuzzy, c-format
+#, c-format
 msgid "%s: %s: illegal value spec"
-msgstr "Nome del raster map in output"
+msgstr ""
 #: ../raster/r.null/null.c:327
 #, fuzzy, c-format
 msgid "Writing new data for raster map <%s>..."
+msgstr "Scrittura dei nuovi dati per la mappa raster <%s> in corso..."
 #: ../raster/r.out.vrml/main.c:47
 msgid "raster, export, VRML"
-msgstr ""
+msgstr "raster, esportazione, VRML"
 #: ../raster/r.out.vrml/main.c:49
 msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
@@ -9847,21 +9401,21 @@
 #: ../raster/r.out.vrml/main.c:56
 #, fuzzy
 msgid "Name of elevation map"
+msgstr "Nome della mappa di elevazione"
 #: ../raster/r.out.vrml/main.c:63
 #, fuzzy
 msgid "Name of color file"
-msgstr "Nome del filtro file"
+msgstr "Nome del file dei colori"
 #: ../raster/r.out.vrml/main.c:70 ../visualization/nviz2/cmd/args.c:498
 msgid "Vertical exaggeration"
-msgstr ""
+msgstr "Esagerazione verticale"
 #: ../raster/r.out.vrml/main.c:77
 #, fuzzy
 msgid "Name for new VRML file"
+msgstr "Nome del nuovo file VRML"
 #: ../raster/r.out.vrml/main.c:163
 #, c-format
@@ -9871,12 +9425,12 @@
 #: ../raster/r.out.vrml/put_grid.c:37
 #, fuzzy
 msgid "Writing vertices..."
+msgstr "Scrittura dei vertici in corso..."
 #: ../raster/r.out.vrml/put_grid.c:82
 #, fuzzy
 msgid "Writing color file..."
+msgstr "Scrittura del file dei colori in corso..."
 #: ../raster/r.mapcalc/main.c:145
 msgid "Floating point error(s) occured in the calculation"
@@ -9889,17 +9443,17 @@
 #: ../raster/r.mapcalc/expression.c:204
 #, c-format
 msgid "Undefined variable '%s'"
-msgstr ""
+msgstr "Variabile '%s' non definita"
 #: ../raster/r.mapcalc/expression.c:219
 #, fuzzy, c-format
 msgid "Invalid map <%s>"
+msgstr "Mappa <%s> non valida"
 #: ../raster/r.mapcalc/expression.c:261
-#, fuzzy, c-format
+#, c-format
 msgid "Undefined function '%s'"
-msgstr "Nome del raster"
+msgstr ""
 #: ../raster/r.mapcalc/expression.c:266
 #, c-format
@@ -9912,9 +9466,9 @@
 msgstr ""
 #: ../raster/r.mapcalc/expression.c:274
-#, fuzzy, c-format
+#, c-format
 msgid "Incorrect argument types to function %s()"
+msgstr ""
 #: ../raster/r.mapcalc/expression.c:277
 #, c-format
@@ -9928,12 +9482,12 @@
 #: ../raster/r.mapcalc/map.c:484
 #, fuzzy, c-format
 msgid "Invalid map modifier: '%c'"
+msgstr "Modificatore della mappa non valido: '%c'"
 #: ../raster/r.mapcalc/expression.c:447
 #, c-format
 msgid "Illegal number of arguments (%d) for operator '%s'"
-msgstr ""
+msgstr "Numero di argomenti (%d) non valido per l'operatore '%s'"
 #: ../raster/r.mapcalc/expression.c:487
 #, c-format
@@ -9944,78 +9498,75 @@
 #: ../raster/r.mapcalc/map3.c:152
 #, fuzzy
 msgid "Error writing data"
+msgstr "Errore nella scrittura dei dati"
 #: ../raster/r.mapcalc/map3.c:177 ../raster/r.mapcalc/map.c:83
 #, fuzzy, c-format
 msgid "Unable to read color file for raster map <%s@%s>"
+msgstr "Non è possibile leggere il file dei colori per la mappa raster <%s@%s>"
 #: ../raster/r.mapcalc/map3.c:190 ../raster/r.mapcalc/map.c:96
 #, fuzzy, c-format
 msgid "Unable to create btree for raster map <%s@%s>"
+msgstr "Non è possibile creare il btree per la mappa raster <%s@%s>"
 #: ../raster/r.mapcalc/map3.c:348 ../raster/r.mapcalc/map.c:280
 #: ../raster/r.mapcalc/evaluate.c:91 ../raster/r.mapcalc/evaluate.c:206
 #, fuzzy, c-format
 msgid "Unknown type: %d"
-msgstr "Tipo sconosciuto"
+msgstr "Tipo sconosciuto: %d"
 #: ../raster/r.mapcalc/map3.c:367 ../raster/r.mapcalc/map.c:309
 #, fuzzy, c-format
 msgid "Unable to close raster map <%s@%s>"
-msgstr "impossibile aprire <%s>"
+msgstr "Non è possibile chiudere la mappa raster <%s@%s>"
 #: ../raster/r.mapcalc/map3.c:605
 #, fuzzy
 msgid "Unable to close output raster map"
-msgstr "Nome della mappa di input"
+msgstr "Non è possibile chiudere la mappa raster di output"
 #: ../raster/r.mapcalc/map.c:249
-#, fuzzy
 msgid "Rowio_setup failed"
-msgstr "Non riesco a copiare la tabella"
+msgstr ""
 #: ../raster/r.mapcalc/map.c:292
-#, fuzzy
 msgid "Rowio_get failed"
+msgstr ""
 #: ../raster/r.mapcalc/map.c:442
 #, fuzzy, c-format
 msgid "Unable to open raster map <%s@%s>"
+msgstr "Non è possibile aprire la mappa raster <%s@%s>"
 #: ../raster/r.mapcalc/map.c:515
-#, fuzzy
 msgid "Failed writing raster map row"
-msgstr "Mappa raster risultante"
+msgstr ""
 #: ../raster/r.mapcalc/map.c:521
 #, fuzzy
 msgid "Unable to close raster map"
-msgstr "Nome del file in output"
+msgstr "Non è possibile chiudere la mappa raster"
 #: ../raster/r.mapcalc/evaluate.c:120
 #, fuzzy, c-format
 msgid "Invalid type: %d"
-msgstr "Utilizzando le coordinate del centro della mappa\n"
+msgstr "Tipo non valido: %d"
 #: ../raster/r.mapcalc/evaluate.c:151
 #, c-format
 msgid "Too few arguments for function '%s'"
-msgstr ""
+msgstr "Troppo pochi argomenti per la funzione '%s'"
 #: ../raster/r.mapcalc/evaluate.c:155
 #, fuzzy, c-format
 msgid "Too many arguments for function '%s'"
-msgstr "Troppi parametri per <reference>"
+msgstr "Troppi argomenti per la funzione  '%s'"
 #: ../raster/r.mapcalc/evaluate.c:159
 #, c-format
 msgid "Invalid argument type for function '%s'"
-msgstr ""
+msgstr "Tipo di argomento non valido per la funzione  '%s'"
 #: ../raster/r.mapcalc/evaluate.c:163
 #, c-format
@@ -10025,22 +9576,22 @@
 #: ../raster/r.mapcalc/evaluate.c:167
 #, fuzzy, c-format
 msgid "Unknown type for function '%s'"
+msgstr "Tipo sconosciuto per la funzione '%s'"
 #: ../raster/r.mapcalc/evaluate.c:170
 #, fuzzy, c-format
 msgid "Number of arguments for function '%s'"
-msgstr "Numero di righe"
+msgstr "Numero di argomenti per la funzione '%s'"
 #: ../raster/r.mapcalc/evaluate.c:174
 #, fuzzy, c-format
 msgid "Unknown error for function '%s'"
+msgstr "Errore sconosciuto per la funzione '%s'"
 #: ../raster/r.mapcalc/function.c:93
 #, c-format
 msgid "Known functions:"
-msgstr ""
+msgstr "Funzioni note:"
 #: ../raster/r.grow.distance/main.c:132
 msgid "Generates a raster map layer of distance to features in input layer."
@@ -10049,32 +9600,30 @@
 #: ../raster/r.grow.distance/main.c:139
 #, fuzzy
 msgid "Name for distance output map"
+msgstr "Nome della mappa di output delle distanze"
 #: ../raster/r.grow.distance/main.c:144
-#, fuzzy
 msgid "Name for value output map"
+msgstr ""
 #: ../raster/r.grow.distance/main.c:162
-#, fuzzy
 msgid "At least one of distance= and value= must be given"
+msgstr ""
 #: ../raster/r.grow.distance/main.c:182
 #, fuzzy, c-format
 msgid "Unable to create distance map <%s>"
+msgstr "Impossibile creare la mappa delle distanze <%s>"
 #: ../raster/r.grow.distance/main.c:188
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create value map <%s>"
+msgstr ""
 #: ../raster/r.grow.distance/main.c:194
 #, fuzzy, c-format
 msgid "Unable to create temporary file <%s>"
+msgstr "Impossibile creare il file temporaneo <%s>"
 #: ../raster/r.topmodel/main.c:57
 msgid "Simulates TOPMODEL which is a physically based hydrologic model."
@@ -10150,20 +9699,15 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:115
-#, fuzzy
 msgid "raster, sun position"
+msgstr ""
 #: ../raster/r.sunmask/main.c:116
-#, fuzzy
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
-msgstr "Calcola l'indice di diversità di posizione dominante su un raster"
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
+msgstr ""
 #: ../raster/r.sunmask/main.c:117
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
 msgstr ""
 #: ../raster/r.sunmask/main.c:131
@@ -10223,16 +9767,16 @@
 #: ../raster/r.sunmask/main.c:206
 #, fuzzy
 msgid "Easting coordinate (point of interest)"
+msgstr "Coordinate est (punto di interesse)"
 #: ../raster/r.sunmask/main.c:207 ../raster/r.sunmask/main.c:217
 msgid "Default: map center"
-msgstr ""
+msgstr "Predefinito: centro della mappa"
 #: ../raster/r.sunmask/main.c:216
 #, fuzzy
 msgid "Northing coordinate (point of interest)"
+msgstr "Coordinate nord (punto di interesse)"
 #: ../raster/r.sunmask/main.c:222
 msgid "Don't ignore zero elevation"
@@ -10253,12 +9797,12 @@
 #: ../raster/r.sunmask/main.c:251
 #, fuzzy, c-format
 msgid "Using map center coordinates: %f %f"
+msgstr "Si stanno utilizzando le coordinate del centro della mappa: %f %f"
 #: ../raster/r.sunmask/main.c:258
 #, fuzzy
 msgid "Empty east coordinate specified"
-msgstr "Sono state specificate delle coordinate ovest vuote."
+msgstr "Sono state specificate delle coordinate est vuote."
 #: ../raster/r.sunmask/main.c:260
 #, fuzzy
@@ -10271,26 +9815,22 @@
 msgstr "Definisci la posizione del sole oppure i parametri di luogo/data/tempo"
 #: ../raster/r.sunmask/main.c:282
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
 msgstr ""
 #: ../raster/r.sunmask/main.c:286
 #, fuzzy, c-format
 msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
-msgstr "Calcolo la posizione del sole (utilizzando solpos(V %S) da NREL)\n"
+msgstr "Calcolo della posizione del sole in corso... (utilizzando solpos(V. %s) da NREL)"
 #: ../raster/r.sunmask/main.c:291
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
 msgstr ""
 #: ../raster/r.sunmask/main.c:397
 #, fuzzy
 msgid "Please correct settings"
-msgstr "Nome di un file MAT-File(v4) esistente"
+msgstr "Per favore correggere le impostazioni"
 #: ../raster/r.sunmask/main.c:411
 #, c-format
@@ -10317,23 +9857,22 @@
 msgstr ""
 #: ../raster/r.sunmask/main.c:437
-#, fuzzy
 msgid "You already know the sun position"
+msgstr ""
 #: ../raster/r.sunmask/main.c:442
 #, fuzzy, c-format
 msgid "Option <%s> required"
-msgstr "Location <%s> creata!"
+msgstr "Opzione <%s> richiesta!"
 #: ../raster/r.sunmask/main.c:459
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open range file for raster map <%s>"
+msgstr ""
 #: ../raster/r.sunmask/main.c:475
 msgid "Calculating shadows from DEM..."
-msgstr ""
+msgstr "Calcolo delle ombre dal DEM in corso..."
 #: ../raster/r.sunmask/solpos00.c:949
 #, c-format
@@ -10426,32 +9965,26 @@
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:88
 #, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:98
 #, fuzzy
 msgid "Unable to get projection info of current location"
+msgstr "Non è possibile ottenere informazioni sulla proiezione della location corrente"
 #: ../raster/r.sunmask/g_solposition.c:101
-#, fuzzy
 msgid "Unable to get projection units of current location"
+msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:104
-#, fuzzy
 msgid "Unable to get projection key values of current location"
+msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:127 ../raster/r.proj.seg/main.c:355
 #: ../raster/r.proj.seg/main.c:357 ../general/g.region/printwindow.c:282
@@ -10462,14 +9995,11 @@
 #: ../general/g.region/printwindow.c:685 ../general/g.region/printwindow.c:693
 #: ../general/g.region/printwindow.c:701
 msgid "Error in pj_do_proj (projection of input coordinate pair)"
-msgstr ""
-"Errore nell'esecuzione di 'pj do proj' (ovvero nella coppia di coordinate di "
-"proiezione in input)"
+msgstr "Errore nell'esecuzione di 'pj do proj' (ovvero nella coppia di coordinate di proiezione in input)"
 #: ../raster/r.random.surface/main.c:43
-#, fuzzy
 msgid "raster, random, surface"
-msgstr "File raster per superficie"
+msgstr ""
 #: ../raster/r.random.surface/main.c:45
 msgid "Generates random surface(s) with spatial dependence."
@@ -10478,22 +10008,22 @@
 #: ../raster/r.random.surface/main.c:57 ../raster/r.random.cells/init.c:115
 #, fuzzy, c-format
 msgid "Generating raster map <%s>..."
+msgstr "Generazione della mappa raster <%s> in corso..."
 #: ../raster/r.random.surface/save.c:219 ../imagery/i.pca/support.c:27
 #, fuzzy, c-format
 msgid "Unable to write color table for raster map <%s>"
+msgstr "Non è possibile scrivere la tavola dei colori per la mappa raster <%s>"
 #: ../raster/r.random.surface/init.c:40
 #, fuzzy
 msgid "Name for output raster map(s)"
+msgstr "Nome della/e mappa/e raster di output"
 #: ../raster/r.random.surface/init.c:58
 #, fuzzy
 msgid "Maximum distance of spatial correlation (value >= 0.0)"
-msgstr "Distanza massima dal punto visualizzato (metri)"
+msgstr "Distanza massima della correlazione spaziale (valore >= 0.0)"
 #: ../raster/r.random.surface/init.c:67
 msgid "Distance decay exponent (value > 0.0)"
@@ -10508,9 +10038,8 @@
 msgstr ""
 #: ../raster/r.random.surface/init.c:91
-#, fuzzy
 msgid "Maximum cell value of distribution"
-msgstr "Numero di passi attraverso il dataset"
+msgstr ""
 #: ../raster/r.random.surface/init.c:96
 msgid "Uniformly distributed cell values"
@@ -10521,19 +10050,19 @@
 msgstr ""
 #: ../raster/r.random.surface/init.c:163
-#, fuzzy, c-format
+#, c-format
 msgid "High (%d) must be greater than 1"
-msgstr "%s = %s -- dev'essere maggiore di zero"
+msgstr ""
 #: ../raster/r.random.surface/init.c:173
-#, fuzzy, c-format
+#, c-format
 msgid "Rastar map <%s> repeated, maps must be unique"
+msgstr ""
 #: ../raster/r.random.surface/init.c:183
 #, fuzzy
 msgid "Output raster map required"
+msgstr "É richiesta la mappa raster di output"
 #: ../raster/r.random.surface/init.c:205
 #, c-format
@@ -10580,12 +10109,11 @@
 #: ../raster/r.random.surface/init.c:425
 #, fuzzy, c-format
 msgid "<%s> is an ilegal name"
-msgstr "[%s] è un nome illegale"
+msgstr "<%s> è un nome non valido"
 #: ../raster/r.thin/main.c:55
-#, fuzzy
 msgid "raster, thin"
+msgstr ""
 #: ../raster/r.thin/main.c:57
 msgid "Thins non-zero cells that denote linear features in a raster map."
@@ -10594,38 +10122,38 @@
 #: ../raster/r.thin/main.c:69
 #, fuzzy
 msgid "Maximal number of iterations"
+msgstr "Numero massimo di iterazioni"
 #: ../raster/r.thin/io.c:105
 #, fuzzy, c-format
 msgid "File %s -- %d rows X %d columns"
-msgstr "%d raster%s, %d vettoriale%s\n"
+msgstr "File %s -- %d righe X %d colonne"
 #: ../raster/r.thin/io.c:115
 #, fuzzy, c-format
 msgid "%s: Unable to create temporary file <%s> -- errno = %d"
+msgstr "%s: Non è possibile creare il file temporaneo <%s> -- errno = %d"
 #: ../raster/r.thin/io.c:124 ../raster/r.thin/io.c:136
 #: ../raster/r.thin/io.c:147
 #, fuzzy, c-format
 msgid "%s: Error writing temporary file"
+msgstr "%s: Errore nella scrittura del file temporaneo"
 #: ../raster/r.thin/io.c:131
 #, fuzzy, c-format
 msgid "%s: Error reading from raster map <%s> in mapset <%s>"
+msgstr "%s: Errore nel leggere dalla mappa raster <%s> nel mapset <%s>"
 #: ../raster/r.thin/io.c:173
 #, fuzzy, c-format
 msgid "Output file %d rows X %d columns"
+msgstr "File di output %d righe X %d colonne"
 #: ../raster/r.thin/io.c:174
 #, fuzzy, c-format
 msgid "Window %d rows X %d columns"
+msgstr "Finestra %d righe X %d colonne"
 #: ../raster/r.thin/thin_lines.c:67
 #, c-format
@@ -10645,7 +10173,7 @@
 #: ../raster/r.thin/thin_lines.c:170
 #, fuzzy, c-format
 msgid "Deleted %d  pixels "
-msgstr "Etichettate %d linee"
+msgstr "Eliminati %d  pixel "
 #: ../raster/r.thin/thin_lines.c:174
 msgid "Thinning completed successfully."
@@ -10653,9 +10181,7 @@
 #: ../raster/r.thin/thin_lines.c:176
 msgid "Thinning not completed, consider to increase 'iterations' parameter."
-msgstr ""
-"Assotigliamento non completato, considera di incrementare il parametro "
-"'iterations'"
+msgstr "Assotigliamento non completato, considera di incrementare il parametro 'iterations'"
 #: ../raster/r.reclass/main.c:49
 #, fuzzy
@@ -10669,12 +10195,8 @@
 #: ../raster/r.reclass/main.c:52
 #, fuzzy
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
-msgstr ""
-"Crea un nuovo layer dove i valori della categoria sono basati sulla "
-"riclassificazione delle categorie esistenti in un altro raster"
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
+msgstr "Crea un nuovo layer dove i valori della categoria sono basati sulla riclassificazione delle categorie esistenti in un altro raster"
 #: ../raster/r.reclass/main.c:57
 msgid "Raster map to be reclassified"
@@ -10683,7 +10205,7 @@
 #: ../raster/r.reclass/main.c:63
 #, fuzzy
 msgid "File containing reclass rules"
-msgstr "File contenente le direttive SQL"
+msgstr "File contenente le regole di riclassificazione"
 #: ../raster/r.reclass/main.c:71
 msgid "Title for the resulting raster map"
@@ -10691,17 +10213,17 @@
 #: ../raster/r.reclass/main.c:85 ../raster/r.recode/main.c:88
 msgid "Input map can NOT be the same as output map"
-msgstr "La mappa di input non può essere la stessa coma mappa di output"
+msgstr "La mappa di input NON può essere la stessa di quella di output"
 #: ../raster/r.reclass/main.c:91
 #, fuzzy, c-format
 msgid "Cannot open rules file <%s>"
+msgstr "Impossibile aprire il file delle regole <%s>"
 #: ../raster/r.reclass/main.c:105
 #, fuzzy, c-format
 msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr "Inserisci regola, \"end\" quando finito, \"help\" se ne hai bisogno.\n"
+msgstr "Inserire regola/e, \"end\" quando finito, \"help\" in caso di necessità.\n"
 #: ../raster/r.reclass/main.c:107
 #, fuzzy, c-format
@@ -10711,7 +10233,7 @@
 #: ../raster/r.reclass/main.c:118
 #, fuzzy, c-format
 msgid "Illegal reclass rule -"
+msgstr "Regola di riclassificazione non valida -"
 #: ../raster/r.reclass/main.c:119
 #, c-format
@@ -10725,12 +10247,12 @@
 #: ../raster/r.reclass/main.c:138
 #, fuzzy, c-format
 msgid "No rules specified. Raster map <%s> not created"
+msgstr "Nessuna regola specificata. La mappa raster <%s> non è stata creata"
 #: ../raster/r.reclass/main.c:141 ../raster/r.recode/main.c:103
 #, fuzzy
 msgid "No rules specified"
+msgstr "Non è stata specificata nessuna regola"
 #: ../raster/r.reclass/parse.c:41
 msgid "poor quality"
@@ -10756,41 +10278,39 @@
 #: ../raster/r.reclass/reclass.c:49 ../raster/r.reclass/reclass.c:109
 #, fuzzy
 msgid "Too many categories"
+msgstr "Troppe categorie"
 #: ../raster/r.reclass/reclass.c:214
 #, fuzzy, c-format
 msgid "Cannot read header file of <%s@%s>"
+msgstr "Impossibile leggere il file di intestazione di <%s@%s>"
 #: ../raster/r.reclass/reclass.c:229
 #, fuzzy, c-format
 msgid "Cannot create reclass file of <%s>"
+msgstr "Impossibile creare il file di riclassificazione di <%s>"
 #: ../raster/r.reclass/reclass.c:242
 #, fuzzy, c-format
 msgid "Cannot create category file of <%s>"
-msgstr "Impossibile salvare la region <%s>"
+msgstr "Impossibile creare il file delle categorie di <%s>"
 #: ../raster/r.timestamp/main.c:35
-#, fuzzy
 msgid "raster, metadata, timestamp"
+msgstr ""
 #: ../raster/r.timestamp/main.c:36
 #, fuzzy
 msgid "Modifies a timestamp for a raster map."
-msgstr "Stampa/aggiungi/rimuovi un timestamp di un raster"
+msgstr "Modifica un timestamp di una mappa raster"
 #: ../raster/r.timestamp/main.c:37
 msgid "Print/add/remove a timestamp for a raster map."
 #: ../raster/r.timestamp/main.c:46
-#, fuzzy
 msgid "Datetime, datetime1/datetime2, or 'none' to remove"
-msgstr "nessuno"
+msgstr ""
 #: ../raster/r.timestamp/main.c:47
 msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
@@ -10803,12 +10323,12 @@
 #: ../raster/r.to.vect/points.c:35
 #, fuzzy
 msgid "Extracting points..."
+msgstr "Estrazione dei punti in corso ..."
 #: ../raster/r.to.vect/main.c:50
 #, fuzzy
 msgid "raster, conversion, vectorization"
+msgstr "raster, conversione, vettorializzazione"
 #: ../raster/r.to.vect/main.c:51
 #, fuzzy
@@ -10837,9 +10357,7 @@
 msgstr "Attributi"
 #: ../raster/r.to.vect/main.c:79
-msgid ""
-"Write raster values as z coordinate. Table is not created. Currently "
-"supported only for points."
+msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
 msgstr ""
 #: ../raster/r.to.vect/main.c:86
@@ -10849,17 +10367,15 @@
 #: ../raster/r.to.vect/main.c:91
 #, fuzzy
 msgid "Quiet - Do not show progress"
-msgstr "Silenzioso"
+msgstr "Silenzioso - Non mostra lo stato di avanzamento"
 #: ../raster/r.to.vect/main.c:109
 #, fuzzy
 msgid "z flag is supported only for points"
+msgstr "il flag z è supportato solo per i punti"
 #: ../raster/r.to.vect/main.c:123
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
 msgstr ""
 #: ../raster/r.to.vect/main.c:194 ../vector/v.in.sites/main.c:170
@@ -10868,24 +10384,24 @@
 #: ../vector/v.in.ascii/in.c:386
 #, fuzzy, c-format
 msgid "Unable to create table: %s"
-msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgstr "Non è possibile creare la tabella: %s"
 #: ../raster/r.to.vect/main.c:198 ../vector/v.mkgrid/main.c:259
 #: ../vector/v.overlay/main.c:461
 #, fuzzy
 msgid "Unable to create index"
+msgstr "Non è possibile creare l'indice"
 #: ../raster/r.to.vect/main.c:273
 #, fuzzy, c-format
 msgid "Unable to insert into table: %s"
+msgstr "Non è possibile inserire nella tabella : %s"
 #: ../raster/r.to.vect/util.c:156 ../raster/r.to.vect/areas_io.c:371
 #: ../vector/v.in.ogr/main.c:926 ../vector/v.random/main.c:300
 #, c-format
 msgid "Cannot insert new row: %s"
-msgstr ""
+msgstr "Impossibile inserire una nuova regola: %s"
 #: ../raster/r.to.vect/areas_io.c:105
 #, c-format
@@ -10908,12 +10424,12 @@
 #: ../raster/r.to.vect/areas.c:119
 #, fuzzy
 msgid "Extracting areas..."
+msgstr "Estrazione delle aree in corso ..."
 #: ../raster/r.to.vect/lines.c:69
 #, fuzzy
 msgid "Extracting lines..."
+msgstr "Estrazione delle linee in corso ..."
 #: ../raster/r.to.vect/lines.c:493
 msgid ""
@@ -10942,63 +10458,57 @@
 msgstr ""
 #: ../raster/r.cats/main.c:53
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
-msgstr ""
-"Gestisce i valori delle categorie e le etichette associate con un raster "
-"specificato dall'utente"
+msgid "Manages category values and labels associated with user-specified raster map layers."
+msgstr "Gestisce i valori delle categorie e le etichette associate con un raster specificato dall'utente"
 #: ../raster/r.cats/main.c:66
 #, fuzzy
 msgid "Comma separated value list"
-msgstr "Lista di valori separati da virgola: es. 1.4,3.8,13"
+msgstr "Lista di valori separati da virgola"
 #: ../raster/r.cats/main.c:67
 msgid "Example: 1.4,3.8,13"
-msgstr ""
+msgstr "Esempio: 1.4,3.8,13"
 #: ../raster/r.cats/main.c:84
 #, fuzzy
 msgid "File containing category label rules (or \"-\" to read from stdin)"
-msgstr ""
-"stdin)"
+msgstr "File contenente le regole per le etichette di categoria (oppure \"-\" per leggere dallo stdin)"
 #: ../raster/r.cats/main.c:91
 msgid "Default label or format string for dynamic labeling"
-msgstr ""
+msgstr "Etichetta predefinita o stringa del formato per l'etichettatura dinamica"
 #: ../raster/r.cats/main.c:93
 msgid "Used when no explicit label exists for the category"
-msgstr ""
+msgstr "Usato quando non esiste nessuna etichetta esplicita per la categoria"
 #: ../raster/r.cats/main.c:101
 msgid "Dynamic label coefficients"
-msgstr ""
+msgstr "Coefficienti dell'etichetta dinamica"
 #: ../raster/r.cats/main.c:103
 msgid "Two pairs of category multiplier and offsets, for $1 and $2"
-msgstr ""
+msgstr "Moltiplicatore di categoria e offset per $1 e per $2"
 #: ../raster/r.cats/main.c:159
 #, fuzzy, c-format
 msgid "Category table for <%s> set from <%s>"
+msgstr "Tabella delle categorie per <%s> ricavata da <%s>"
 #: ../raster/r.cats/main.c:197 ../raster/r.cats/main.c:243
 #, fuzzy, c-format
 msgid "Cannot create category file for <%s>"
+msgstr "Impossibile creare il file delle categorie per <%s>"
 #: ../raster/r.cats/main.c:252
 #, fuzzy, c-format
 msgid "Unable to read category file of raster map <%s> in <%s>"
+msgstr "Impossibile leggere il file delle categorie della mappa raster <%s> in <%s>"
 #: ../raster/r.cats/main.c:268
 msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr ""
+msgstr "La mappa è con valori a virgola mobile! La lista delle categorie verrà ignorata, si sta usando la lista di valori"
 #: ../raster/r.cats/main.c:285
 msgid "vals argument is required for floating point map!"
@@ -11007,38 +10517,33 @@
 #: ../raster/r.cats/cats.c:35
 #, fuzzy, c-format
 msgid "Cannot read header of raster map <%s> in <%s>"
-msgstr "Impossibile leggere l'intestazione del raster 3D <%s> in <%s>"
+msgstr "Impossibile leggere l'intestazione del raster <%s> in <%s>"
 #: ../raster/r.cats/cats.c:43
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot open cell file of raster map <%s> in <%s>"
+msgstr ""
 #: ../raster/r.cats/cats.c:51
-#, fuzzy, c-format
+#, c-format
 msgid "Reading <%s> in <%s>"
+msgstr ""
 #: ../raster/r.kappa/main.c:69
-msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
-"classification result."
+msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
 msgstr ""
 #: ../raster/r.kappa/main.c:75
-#, fuzzy
 msgid "Name of raster map containing classification result"
-msgstr "Nome di una mappa raster contenente una superfice di altezze"
+msgstr ""
 #: ../raster/r.kappa/main.c:80
-#, fuzzy
 msgid "Name of raster map containing reference classes"
+msgstr ""
 #: ../raster/r.kappa/main.c:85
-#, fuzzy
 msgid "Name for output file containing error matrix and kappa"
+msgstr ""
 #: ../raster/r.kappa/main.c:91
 msgid "Title for error matrix and kappa"
@@ -11055,32 +10560,32 @@
 #: ../raster/r.kappa/main.c:106
 #, fuzzy
 msgid "No header in the report"
-msgstr "nessuna intestazione nel report"
+msgstr "Nessuna intestazione nel report"
 #: ../raster/r.kappa/main.c:121 ../imagery/i.cca/main.c:117
 #, fuzzy, c-format
 msgid "Illegal output file name <%s>"
-msgstr "Nome del file di output"
+msgstr "Nome del file di output <%s> non valido"
 #: ../raster/r.kappa/prt_hdr.c:17
 #, fuzzy, c-format
 msgid "Cannot open file <%s> to write header"
-msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
+msgstr "Impossibile aprire il file <%s> per scrivere l'intestazione"
 #: ../raster/r.kappa/calc_kappa.c:32
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot open file <%s> to write kappa and relevant parameters"
+msgstr ""
 #: ../raster/r.kappa/prt_label.c:16
 #, fuzzy, c-format
 msgid "Can't open file <%s> to write label"
+msgstr "Impossibile aprire il file <%s> per scrivere l'etichetta"
 #: ../raster/r.kappa/prt_mat.c:39
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot open file <%s> to write cats and counts (error matrix)"
+msgstr ""
 #: ../raster/r.kappa/stats.c:13 ../raster/r.report/stats.c:99
 msgid "Problem reading r.stats output"
@@ -11091,9 +10596,8 @@
 msgstr ""
 #: ../raster/r.coin/inter.c:35
-msgid ""
-"This utility will allow you to compare the coincidence of two map layers\n"
-msgstr ""
+msgid "This utility will allow you to compare the coincidence of two map layers\n"
+msgstr "Questo programma di utilità consente di confrontare le coincidenze di due tematismi raster\n"
 #: ../raster/r.coin/inter.c:52
 msgid "The report can be made in one of 8 units."
@@ -11105,41 +10609,41 @@
 #: ../raster/r.coin/inter.c:55
 msgid "     'c': cells"
-msgstr ""
+msgstr "     'c': celle"
 #: ../raster/r.coin/inter.c:56
 msgid "     'p': percent cover of region"
-msgstr ""
+msgstr "     'p': percentuale di regione coperta"
 #: ../raster/r.coin/inter.c:57
 #, c-format
 msgid "     'x': percent of '%s' category (column)"
-msgstr ""
+msgstr "     'x': percentuale sulla categoria di '%s' (colonna)"
 #: ../raster/r.coin/inter.c:58
 #, c-format
 msgid "     'y': percent of '%s' category (row)"
-msgstr ""
+msgstr "     'y': percentuale sulla categoria di '%s' (riga)"
 #: ../raster/r.coin/inter.c:59
 msgid "     'a': acres"
-msgstr ""
+msgstr "     'a': acri"
 #: ../raster/r.coin/inter.c:60
 msgid "     'h': hectares"
-msgstr ""
+msgstr "     'h': ettari"
 #: ../raster/r.coin/inter.c:61
 msgid "     'k': square kilometers"
-msgstr ""
+msgstr "     'k': chilometri quadrati"
 #: ../raster/r.coin/inter.c:62
 msgid "     'm': square miles\n"
-msgstr ""
+msgstr "     'm': miglia quadrate\n"
 #: ../raster/r.coin/inter.c:63
 msgid "     'Q': quit"
-msgstr ""
+msgstr "     'Q': uscita"
 #: ../raster/r.coin/inter.c:95
 #, c-format
@@ -11151,7 +10655,9 @@
 msgid ""
 "Enter the file name or path\n"
+msgstr ""
+"Inserire il nome del file o il persorso\n"
 #: ../raster/r.coin/inter.c:108
 #, c-format
@@ -11160,8 +10666,7 @@
 #: ../raster/r.coin/inter.c:117
 #, c-format
-msgid ""
-"Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
 msgstr ""
 #: ../raster/r.coin/inter.c:126
@@ -11173,35 +10678,30 @@
 #: ../raster/r.coin/inter.c:142
 #, c-format
-msgid ""
-"Do you wish to run this report with a different unit of measure? (y/n) [y] "
+msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
 msgstr ""
 #: ../raster/r.coin/main.c:68
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
-msgstr ""
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgstr "Riporta in forma tabellare le reciproche occorrenze (coincidenze) delle categorie di due tematismi raster."
 #: ../raster/r.coin/main.c:76
 #, fuzzy
 msgid "Name of first raster map"
-msgstr "Nome di una mappa raster esistente"
+msgstr "Nome della prima mappa raster"
 #: ../raster/r.coin/main.c:83
 #, fuzzy
 msgid "Name of second raster map"
-msgstr "Nome della mappa raster"
+msgstr "Nome della seconda mappa raster"
 #: ../raster/r.coin/main.c:89
 #, fuzzy
 msgid "Unit of measure"
-msgstr "Unità della distanza"
+msgstr "Unità di misura"
 #: ../raster/r.coin/main.c:91
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
 msgstr ""
 #: ../raster/r.coin/main.c:98
@@ -11216,32 +10716,29 @@
 #: ../raster/r.coin/make_coin.c:54
 #, fuzzy
 msgid "Unable to create any tempfiles"
+msgstr "Non è possibile creare nessun file temporaneo"
 #: ../raster/r.coin/make_coin.c:58
 #, fuzzy
 msgid "Unable to run r.stats"
+msgstr "impossibile eseguire r.stats"
 #: ../raster/r.coin/make_coin.c:67
 #, fuzzy
 msgid "Unexpected output from r.stats"
+msgstr "Output inaspettato da r.stats"
 #: ../raster/r.coin/make_coin.c:78
-#, fuzzy
 msgid "Unable to open tempfile"
+msgstr ""
 #: ../raster/r.coin/print_coin.c:44
 #, fuzzy, c-format
 msgid "Preparing report ..."
+msgstr "Preparazione del report in corso ..."
 #: ../raster/r.digit/main.c:47
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
 msgstr ""
 #: ../raster/r.digit/main.c:56 ../vector/v.digit/main.c:117
@@ -11251,7 +10748,7 @@
 #: ../raster/r.digit/main.c:79
 #, fuzzy
 msgid "No graphics device selected!"
-msgstr "Nessun device grafico selezionato"
+msgstr "Nessun dispositivo grafico selezionato!"
 #: ../raster/r.digit/main.c:98
 msgid "No map created"
@@ -11259,7 +10756,7 @@
 #: ../raster/r.digit/digitize.c:49
 msgid "Quit without creating a map?? "
-msgstr "Esci senza creare una mappa??"
+msgstr "Esci senza creare una mappa13??"
 #: ../raster/r.digit/get_type.c:31
 #, c-format
@@ -11322,12 +10819,12 @@
 #: ../raster/r.water.outlet/main.c:84
 #, fuzzy, c-format
 msgid "Illegal east coordinate <%s>\n"
+msgstr "Coordinate est non valide <%s>\n"
 #: ../raster/r.water.outlet/main.c:89
 #, fuzzy, c-format
 msgid "Illegal north coordinate <%s>\n"
-msgstr "Sono state specificate delle coordinate nord vuote."
+msgstr "Coordinate nord non valide <%s>"
 #: ../raster/r.water.outlet/main.c:96
 #, c-format
@@ -11337,33 +10834,23 @@
 msgstr ""
 #: ../raster/r.water.outlet/main.c:113
-#, fuzzy
 msgid "Unable to open drainage pointer map"
+msgstr ""
 #: ../raster/r.water.outlet/main.c:138
-#, fuzzy
 msgid "Unable to open new basin map"
+msgstr ""
 #: ../raster/r.water.outlet/main.c:149
-#, fuzzy
 msgid "Unable to close new basin map layer"
+msgstr ""
 #: ../raster/r.horizon/main.c:181
 msgid "Horizon angle computation from a digital elevation model."
 msgstr ""
 #: ../raster/r.horizon/main.c:183
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has "
-"two different modes of operation:  1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction.  The input for this is the angle (in "
-"degrees), which is measured  counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
+msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation:  1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction.  The input for this is the angle (in degrees), which is measured  counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
 msgstr ""
 #: ../raster/r.horizon/main.c:236
@@ -11371,33 +10858,23 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:252
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:260
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:268
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:276
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:284
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:292
@@ -11405,9 +10882,8 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:301
-#, fuzzy
 msgid "Prefix of the horizon raster output maps"
-msgstr "Nome del raster in output"
+msgstr ""
 #: ../raster/r.horizon/main.c:311
 msgid "Coordinate for which you want to calculate the horizon"
@@ -11430,14 +10906,12 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:377
-#, fuzzy
 msgid "You didn't specify an angle step size. Aborting."
+msgstr ""
 #: ../raster/r.horizon/main.c:390
-#, fuzzy
 msgid "Could not read bufferzone size. Aborting."
+msgstr ""
 #: ../raster/r.horizon/main.c:395 ../raster/r.horizon/main.c:401
 #: ../raster/r.horizon/main.c:408 ../raster/r.horizon/main.c:415
@@ -11466,9 +10940,8 @@
 msgstr "nord=%f"
 #: ../raster/r.horizon/main.c:421
-#, fuzzy
 msgid "Could not read maximum distance. Aborting."
+msgstr ""
 #: ../raster/r.horizon/main.c:617 ../raster/r.in.ascii/main.c:193
 #: ../raster/r.in.arc/main.c:135
@@ -11490,79 +10963,76 @@
 #: ../raster/r.external/main.c:54
 #, fuzzy, c-format
 msgid "Supported Formats:\n"
 #: ../raster/r.external/main.c:172
 msgid ""
 "\n"
-"You can use the -o flag to r.external to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
 msgstr ""
 #: ../raster/r.external/main.c:300
-#, fuzzy
 msgid "Complex types not supported"
-msgstr "Tipo di colonna non supportata"
+msgstr ""
 #: ../raster/r.external/main.c:315
-#, fuzzy, c-format
+#, c-format
 msgid "Copying color table for %s"
+msgstr ""
 #: ../raster/r.external/main.c:333
-#, fuzzy, c-format
+#, c-format
 msgid "Setting grey color table for <%s> (full 8bit range)"
+msgstr ""
 #: ../raster/r.external/main.c:339
-#, fuzzy, c-format
+#, c-format
 msgid "Setting grey color table for <%s> (data range)"
+msgstr ""
 #: ../raster/r.external/main.c:353
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create cell/%s file"
+msgstr ""
 #: ../raster/r.external/main.c:362
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create fcell/%s file"
+msgstr ""
 #: ../raster/r.external/main.c:394
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create cell_misc/%s/gdal file"
+msgstr ""
 #: ../raster/r.external/main.c:397
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing cell_misc/%s/gdal file"
+msgstr ""
 #: ../raster/r.external/main.c:422
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create cell_misc/%s/f_format file"
+msgstr ""
 #: ../raster/r.external/main.c:425
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing cell_misc/%s/f_format file"
+msgstr ""
 #: ../raster/r.external/main.c:440
-#, fuzzy
 msgid "Unable to write quant file"
+msgstr ""
 #: ../raster/r.external/main.c:472
-#, fuzzy, c-format
+#, c-format
 msgid "Creating support files for %s"
+msgstr ""
 #: ../raster/r.external/main.c:482
 #, fuzzy, c-format
 msgid "Link to raster map <%s> created"
+msgstr "Collegamento alla mappa raster <%s> creato"
 #: ../raster/r.external/main.c:508
 msgid "Link GDAL supported raster file to a binary raster map layer."
@@ -11571,26 +11041,24 @@
 #: ../raster/r.external/main.c:511
 #, fuzzy
 msgid "Raster file to be linked"
+msgstr "Il file raster da collegare"
 #: ../raster/r.external/main.c:517
-#, fuzzy
 msgid "Name of non-file GDAL data source"
+msgstr ""
 #: ../raster/r.external/main.c:529
 #, fuzzy
 msgid "Band to select (default: all)"
-msgstr "Banda da selezionare (il valore predefinito è tutte)"
+msgstr "Banda da selezionare (valore predefinito: tutte)"
 #: ../raster/r.external/main.c:550
 msgid "Require exact range"
 msgstr ""
 #: ../raster/r.external/main.c:579
-#, fuzzy
 msgid "Name for input source not specified"
+msgstr ""
 #: ../raster/r.external/main.c:582
 msgid "input= and source= are mutually exclusive"
@@ -11599,28 +11067,25 @@
 #: ../raster/r.external/main.c:607
 #, fuzzy
 msgid "Unable to set window"
+msgstr "Non è possibile impostare la finestra"
 #: ../raster/r.external/main.c:618
-#, fuzzy, c-format
+#, c-format
 msgid "Imagery group <%s> already exists and will be overwritten."
+msgstr ""
 #: ../raster/r.external/main.c:658
-#, fuzzy, c-format
+#, c-format
 msgid "Imagery group <%s> created"
+msgstr ""
 #: ../raster/r.proj.seg/main.c:216
-#, fuzzy
 msgid "Print input map's bounds in the current projection and exit"
-msgstr "Mostra mappe raster della location d input ed esci"
+msgstr ""
 #: ../raster/r.proj.seg/main.c:222
-#, fuzzy
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
-msgstr "mostra i parametri della connessione in uso ed esce"
+msgid "Print input map's bounds in the current projection and exit (shell style)"
+msgstr ""
 #: ../raster/r.proj.seg/main.c:255
 msgid "Input and output locations are the same"
@@ -11629,25 +11094,24 @@
 #: ../raster/r.proj.seg/main.c:351
 #, fuzzy, c-format
 msgid "Input map <%s@%s> in location <%s>:"
+msgstr "Mappa di input  <%s@%s> nella location <%s>:"
 #: ../raster/r.proj.seg/readcell.c:56 ../imagery/i.rectify/readcell.c:57
 #: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:62
 #, fuzzy
 msgid "Unable to open temporary file"
+msgstr "Non è possibile aprire il file temporaneo"
 #: ../raster/r.proj.seg/readcell.c:80
 #, fuzzy
 msgid "Error reading input"
+msgstr "Errore nella lettura dell'input"
 #: ../raster/r.proj.seg/readcell.c:89 ../raster/r.proj.seg/readcell.c:128
 #: ../imagery/i.rectify/readcell.c:89 ../imagery/i.rectify/readcell.c:128
 #: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:98
-#, fuzzy
 msgid "Error writing segment file"
+msgstr ""
 #: ../raster/r.proj.seg/readcell.c:116 ../imagery/i.rectify/readcell.c:116
 #: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:128
@@ -11656,14 +11120,12 @@
 #: ../raster/r.proj.seg/readcell.c:125 ../imagery/i.rectify/readcell.c:125
 #: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:137
-#, fuzzy
 msgid "Error seeking on segment file"
+msgstr ""
 #: ../raster/r.recode/main.c:42
-#, fuzzy
 msgid "raster, recode category"
+msgstr ""
 #: ../raster/r.recode/main.c:43
 msgid "Recodes categorical raster maps."
@@ -11672,27 +11134,27 @@
 #: ../raster/r.recode/main.c:46
 #, fuzzy
 msgid "Name of raster map to be recoded"
-msgstr "Nome della mappa raster da mostrare"
+msgstr "Nome della mappa raster da ricodificare"
 #: ../raster/r.recode/main.c:53
 #, fuzzy
 msgid "File containing recode rules"
+msgstr "File contenente le regole di ricodifica"
 #: ../raster/r.recode/main.c:54
 #, fuzzy
 msgid "\"-\" to read from stdin"
+msgstr "\"-\" per leggere dallo stdin"
 #: ../raster/r.recode/main.c:61
 #, fuzzy
 msgid "Title for output raster map"
-msgstr "Titolo del file raster in output"
+msgstr "Titolo della mappa raster di output"
 #: ../raster/r.recode/main.c:65
 #, fuzzy
 msgid "Align the current region to the input raster map"
-msgstr "Utilizza la regione corrente"
+msgstr "Allinea la regione corrente alla mappa raster di input"
 #: ../raster/r.recode/main.c:69
 msgid "Force output to 'double' raster map type (DCELL)"
@@ -11701,42 +11163,42 @@
 #: ../raster/r.recode/main.c:100
 #, fuzzy, c-format
 msgid "No rules specified. Raster map <%s> not created."
 #: ../raster/r.recode/read_rules.c:24
 #, fuzzy, c-format
 msgid "Data range of raster map <%s> is empty"
+msgstr "L'intervallo dati della mappa raster <%s> è vuoto"
 #: ../raster/r.recode/read_rules.c:31
 #, fuzzy, c-format
 msgid "Data range of raster map <%s> is %s to %s (entire map)"
-msgstr "fp: l'intervallo di dati è da %.25f a %.25f\n"
+msgstr "L'intervallo dati della mappa raster <%s> è da %s a %s (l'intera mappa)"
 #: ../raster/r.recode/read_rules.c:36
 #, fuzzy, c-format
 msgid "Unable to read range of raster map <%s>"
+msgstr "Non è possibile leggere l'intervallo dati della mappa raster <%s>"
 #: ../raster/r.recode/read_rules.c:41
 #, fuzzy, c-format
 msgid "Integer data range of raster map <%s> is empty"
+msgstr "L'intervallo dati dei valori interi della mappa raster <%s> è vuoto"
 #: ../raster/r.recode/read_rules.c:44
 #, fuzzy, c-format
 msgid "Integer data range of raster mao <%s> is %d to %d"
-msgstr "L'intervallo dati è da %ld a %ld\n"
+msgstr "L'intervallo dati dei valori interi della mappa raster <%s> è da %d a %d"
 #: ../raster/r.recode/read_rules.c:63
 #, fuzzy
 msgid "Enter the rule or 'help' for the format description"
-msgstr "Inserisci una regola secondo questi formati:\n"
+msgstr "Inserire una regola o 'help' per la descrizione dei formati"
 #: ../raster/r.recode/read_rules.c:87
 #, fuzzy
 msgid "Enter a rule in one of these formats:"
+msgstr "Inserire una regola in uno di questi formati:"
 #: ../raster/r.recode/read_rules.c:89
 msgid "old_low:old_high:new_low:new_high"
@@ -11764,12 +11226,8 @@
 msgstr ""
 #: ../raster/r.volume/main.c:59
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
-msgstr ""
-"Calcola il volume dei \"gruppi\" di dati, e (opzionalmente) produce un "
-"vettoriale contenendo i centroidi calcolati di questi gruppi"
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "Calcola il volume dei \"gruppi\" di dati, e (opzionalmente) produce un vettoriale contenendo i centroidi calcolati di questi gruppi"
 #: ../raster/r.volume/main.c:69
 msgid "Existing raster map representing data that will be summed within clumps"
@@ -11790,7 +11248,7 @@
 #: ../raster/r.volume/main.c:117
 #, fuzzy
 msgid "No data map specified"
-msgstr "Nessuna mappa in input specificata"
+msgstr "Nessuna mappa specificata per i dati"
 #: ../raster/r.volume/main.c:128
 msgid "No clump map specified and MASK not set."
@@ -11799,22 +11257,21 @@
 #: ../raster/r.volume/main.c:133
 #, fuzzy
 msgid "Unable to find data map"
-msgstr "Non riesco a trovare il file raster %s"
+msgstr "Non è possibile trovare la mappa dei dati"
 #: ../raster/r.volume/main.c:141
 #, fuzzy
 msgid "Unable to find clump map"
+msgstr "Non è possibile trovare la mappa dei gruppi"
 #: ../raster/r.volume/main.c:149
 #, fuzzy
 msgid "Unable to open centroids vector points map"
+msgstr "Non è possibile aprire la mappa vettoriale dei centroidi"
 #: ../raster/r.volume/main.c:171
-#, fuzzy
 msgid "Data or Clump file not open"
+msgstr ""
 #: ../raster/r.distance/main.c:40
 msgid "Locates the closest points between objects in two raster maps."
@@ -11823,7 +11280,7 @@
 #: ../raster/r.distance/edges.c:42
 #, fuzzy, c-format
 msgid "Reading map %s ..."
+msgstr "Lettura della mappa %s in corso ..."
 #: ../raster/r.distance/parse.c:41
 msgid "Maps for computing inter-class distances"
@@ -11845,16 +11302,15 @@
 #: ../raster/r.distance/report.c:41
 #, fuzzy
 msgid "Processing..."
-msgstr "Sto disegnando ..."
+msgstr "Elaborazione in corso ..."
 #: ../raster/r.carve/enforce_ds.c:81
 #, fuzzy
 msgid "Processing lines... "
+msgstr "Elaborazione delle linee in corso ..."
 #: ../raster/r.carve/enforce_ds.c:173
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
 msgstr ""
 #: ../raster/r.carve/main.c:78
@@ -11862,15 +11318,13 @@
 msgstr ""
 #: ../raster/r.carve/main.c:79
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
 msgstr ""
 #: ../raster/r.carve/main.c:84
 #, fuzzy
 msgid "Name of input raster elevation map"
-msgstr "Nome di  2-%d mappe raster in input"
+msgstr "Nome della mappa raster di elevazione di input"
 #: ../raster/r.carve/main.c:89
 #, fuzzy
@@ -11878,9 +11332,8 @@
 msgstr "Inserisci il vettore con i punti di controllo"
 #: ../raster/r.carve/main.c:97
-#, fuzzy
 msgid "Name for output vector map for adjusted stream points"
+msgstr ""
 #: ../raster/r.carve/main.c:102
 msgid "Stream width (in meters)"
@@ -11917,9 +11370,7 @@
 msgstr ""
 #: ../raster/r.mode/main.c:52
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
 msgstr ""
 #: ../raster/r.mode/main.c:58
@@ -11937,12 +11388,12 @@
 #: ../raster/r.mode/main.c:86
 #, fuzzy, c-format
 msgid "%s: base raster map not found"
+msgstr "%s: mappa raster di base non trovata"
 #: ../raster/r.mode/main.c:91
 #, fuzzy, c-format
 msgid "%s: cover raster map not found"
+msgstr "%s: mappa raster di copertura non trovata"
 #: ../raster/r.mode/main.c:97
 #, c-format
@@ -11952,7 +11403,7 @@
 #: ../raster/r.mode/main.c:101
 #, fuzzy, c-format
 msgid "%s: Unable to read category labels"
+msgstr "%s: Non è possibile leggere le etichette di categoria"
 #: ../raster/r.mode/read_stats.c:14
 msgid "reading r.stats output"
@@ -11972,12 +11423,8 @@
 #: ../raster/r.report/parse.c:46
 #, fuzzy
-msgid ""
-"mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent "
-"cover"
-msgstr ""
-"mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p"
-"(ercent_cover)"
+msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
+msgstr "mi;miglia;me;metri;k;chilometri;a;acri;h;ettari;c;conteggio delle celle;p;percentuale di copertura"
 #: ../raster/r.report/parse.c:56
 msgid "Character representing no data cell value"
@@ -11986,9 +11433,8 @@
 #: ../raster/r.report/parse.c:57 ../raster/r.report/parse.c:66
 #: ../raster/r.report/parse.c:75 ../raster/r.report/parse.c:100
 #: ../raster/r.report/parse.c:105 ../raster/r.report/parse.c:110
-#, fuzzy
 msgid "Formatting"
-msgstr "Interrotto."
+msgstr ""
 #: ../raster/r.report/parse.c:63
 #, c-format
@@ -12031,11 +11477,11 @@
 #: ../raster/r.report/parse.c:177
 #, fuzzy
 msgid "Illegal page length"
+msgstr "Lunghezza della pagina non valida"
 #: ../raster/r.report/parse.c:184
 msgid "Illegal page width"
-msgstr ""
+msgstr "Larghezza della pagina non valida"
 #: ../raster/r.report/parse.c:223
 #, c-format
@@ -12043,23 +11489,21 @@
 msgstr ""
 #: ../raster/r.report/parse.c:256
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read fp range for raster map <%s>"
+msgstr ""
 #: ../raster/r.report/stats.c:65
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open result file <%s>"
+msgstr ""
 #: ../raster/r.composite/main.c:72
-#, fuzzy
 msgid "raster, composite"
-msgstr "File di input"
+msgstr ""
 #: ../raster/r.composite/main.c:74
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
 msgstr "Combina raster rosso, verde e blu in un singolo raster"
 #: ../raster/r.composite/main.c:100
@@ -12086,17 +11530,17 @@
 #: ../raster/r.composite/main.c:210
 #, fuzzy, c-format
 msgid "Error reading raster map <%s>"
+msgstr "Errore nella lettura della mappa raster <%s>"
 #: ../raster/r.composite/main.c:258 ../doc/raster/r.example/main.c:181
 #, fuzzy, c-format
 msgid "Failed writing raster map <%s>"
-msgstr "Nome del driver in input"
+msgstr "Scrittura della mappa raster <%s> non riuscita"
 #: ../raster/r.composite/main.c:297
 #, fuzzy
 msgid "Creating color table for output raster map..."
+msgstr "Creazione della tavola dei colori per la mappa raster in corso..."
 #: ../raster/r.to.rast3/main.c:77
 msgid "2d raster maps which represent the slices"
@@ -12105,12 +11549,11 @@
 #: ../raster/r.to.rast3/main.c:83
 #, fuzzy
 msgid "Use G3D mask (if exists) with output map"
-msgstr "Usa una mask G3d (se esiste) con la mappa in input"
+msgstr "Usa una mask G3d (se esiste) con la mappa di output"
 #: ../raster/r.to.rast3/main.c:117
-#, fuzzy
 msgid "Could not get raster row"
+msgstr ""
 #: ../raster/r.to.rast3/main.c:194
 msgid "raster, volume, conversion"
@@ -12123,12 +11566,12 @@
 #: ../raster/r.to.rast3/main.c:208
 #, fuzzy
 msgid "No output map"
-msgstr "Nome della mappa di output"
+msgstr "Nessuna mappa di output"
 #: ../raster/r.to.rast3/main.c:260
 #, fuzzy
 msgid "Cell file not found"
+msgstr "File di celle non trovato"
 #: ../raster/r.to.rast3/main.c:268
 #, c-format
@@ -12146,16 +11589,14 @@
 #: ../raster/r.flow/calc.c:408
 #, fuzzy
 msgid "Unable to get current region"
-msgstr "aggiornamento della regione corrente non riuscito"
+msgstr "Non è possibile ottenere la regione corrente"
 #: ../raster/r.flow/calc.c:412
 msgid "Constructs flow lines."
 msgstr ""
 #: ../raster/r.flow/calc.c:414
-msgid ""
-"Construction of slope curves (flowlines), flowpath lengths, and flowline "
-"densities (upslope areas) from a raster digital elevation model (DEM)"
+msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)"
 msgstr ""
 #: ../raster/r.flow/calc.c:453
@@ -12169,14 +11610,12 @@
 msgstr "Nome della mappa raster d'inserimento dati"
 #: ../raster/r.flow/calc.c:465
-#, fuzzy
 msgid "Number of cells between flowlines"
-msgstr "Nume di righe da tenere in memoria"
+msgstr ""
 #: ../raster/r.flow/calc.c:473
-#, fuzzy
 msgid "Maximum number of segments per flowline"
+msgstr ""
 #: ../raster/r.flow/calc.c:479
 #, fuzzy
@@ -12210,20 +11649,18 @@
 msgstr ""
 #: ../raster/r.flow/calc.c:536
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
 msgstr ""
 #: ../raster/r.flow/io.c:68
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get header for %s"
+msgstr ""
 #: ../raster/r.flow/io.c:85
 #, fuzzy
 msgid "Reading input files: elevation"
+msgstr "Lettura dei file di input: elevazione"
 #: ../raster/r.flow/io.c:89
 msgid "Elevation file's resolution differs from current region resolution"
@@ -12232,7 +11669,7 @@
 #: ../raster/r.flow/io.c:101
 #, fuzzy
 msgid "Reading input files: aspect"
+msgstr "Lettura dei file di input: esposizione"
 #: ../raster/r.flow/io.c:104
 msgid "Resolution of aspect file differs from current region resolution"
@@ -12243,44 +11680,42 @@
 msgstr ""
 #: ../raster/r.flow/io.c:146
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot create segment file %s"
+msgstr ""
 #: ../raster/r.flow/io.c:151
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot format segment file %s"
-msgstr "Non riesco ad impostare user/password"
+msgstr ""
 #: ../raster/r.flow/io.c:157
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot open segment file %s"
+msgstr ""
 #: ../raster/r.flow/io.c:203
 #, fuzzy
 msgid "Cannot reset current region"
+msgstr "Impossibile reimpostare la regione corrente"
 #: ../raster/r.flow/io.c:205
-#, fuzzy
 msgid "Writing density file"
-msgstr "Nome del raster map esistente"
+msgstr ""
 #: ../raster/r.flow/io.c:228
 #, fuzzy, c-format
 msgid "Unable to find file %s"
+msgstr "Impossibile trovare il file %s"
 #: ../raster/r.flow/mem.c:39
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to write segment file for %s"
+msgstr ""
 #: ../raster/r.flow/precomp.c:47
-#, fuzzy
 msgid "Precomputing: e/w distances"
-msgstr "Mappe per calcolare le distanza fra classi"
+msgstr ""
 #: ../raster/r.flow/precomp.c:49
 msgid "Precomputing: quantization tolerances"
@@ -12299,9 +11734,8 @@
 msgstr ""
 #: ../raster/r.flow/precomp.c:66
-#, fuzzy
 msgid "Precomputing: aspects"
+msgstr ""
 #: ../raster/r.flow/precomp.c:110
 #, c-format
@@ -12319,37 +11753,36 @@
 #: ../raster/r.what.color/main.c:89
 #, fuzzy
 msgid "Queries colors for a raster map layer."
-msgstr "Statistiche per raster"
+msgstr "Effettua un'interrogazione sui colori di un tematismo raster."
 #: ../raster/r.what.color/main.c:97
 #, fuzzy
 msgid "Name of existing raster map to query colors"
+msgstr "Nome di una mappa raster esistente da interrogare sui colori"
 #: ../raster/r.what.color/main.c:104
-#, fuzzy
 msgid "Values to query colors for"
-msgstr "Impossible leggere i colori per la barra colori"
+msgstr ""
 #: ../raster/r.what.color/main.c:111
 #, fuzzy
 msgid "Output format (printf-style)"
-msgstr "Mappa in output"
+msgstr "Formato di output (in stile printf)"
 #: ../raster/r.what.color/main.c:115
 #, fuzzy
 msgid "Read values from stdin"
+msgstr "Legge i valori dallo stdin"
 #: ../raster/r.what.color/main.c:121
 #, fuzzy
 msgid "Either \"-i\" or \"value=\" must be given"
-msgstr "Devono essere fornite sia l'opzione 'from_table' che 'select' "
+msgstr "Dev'essere fornita una delle opzione \"-i\" o \"value=\""
 #: ../raster/r.in.ascii/main.c:68
 #, fuzzy
 msgid "raster, import, conversion"
+msgstr "raster, importazione, conversione"
 #: ../raster/r.in.ascii/main.c:70
 msgid "Converts ASCII raster file to binary raster map layer."
@@ -12357,14 +11790,13 @@
 #: ../raster/r.in.ascii/main.c:74
 #, fuzzy
-msgid ""
-"ASCII raster file to be imported. If not given reads from standard input"
-msgstr "File raster ascii da importare"
+msgid "ASCII raster file to be imported. If not given reads from standard input"
+msgstr "File raster ASCII da importare. Se non è dato legge dallo standard input"
 #: ../raster/r.in.ascii/main.c:92 ../raster/r.in.arc/main.c:94
 #, fuzzy
 msgid "Multiplier for ASCII data"
-msgstr "Titolo della mappa raster risultante"
+msgstr "Moltiplicatore per i dati ASCII"
 #: ../raster/r.in.ascii/main.c:100
 msgid "String representing NULL value data cell"
@@ -12373,17 +11805,17 @@
 #: ../raster/r.in.ascii/main.c:104
 #, fuzzy
 msgid "Integer values are imported"
-msgstr "i valori integer sono stati importati"
+msgstr "I valori integer sono stati importati"
 #: ../raster/r.in.ascii/main.c:108
 #, fuzzy
 msgid "Floating point values are imported"
-msgstr "i valori floating point sono stati importati"
+msgstr "I valori floating point sono stati importati"
 #: ../raster/r.in.ascii/main.c:112
 #, fuzzy
 msgid "Double floating point values are imported"
-msgstr "i valori double floating point sono stati importati"
+msgstr "I valori double floating point sono stati importati"
 #: ../raster/r.in.ascii/main.c:117
 #, fuzzy
@@ -12398,12 +11830,12 @@
 #: ../raster/r.in.ascii/main.c:158
 #, fuzzy
 msgid "Unable to read input from stdin"
+msgstr "Non è possibile leggere l'input dallo stdin"
 #: ../raster/r.in.ascii/main.c:165
 #, fuzzy, c-format
 msgid "Unable to read input from <%s>"
+msgstr "Non è possibile leggere l'input da <%s>"
 #: ../raster/r.in.ascii/main.c:185 ../raster/r.in.arc/main.c:127
 msgid "Can't get cell header"
@@ -12417,7 +11849,7 @@
 #: ../raster/r.in.ascii/main.c:285
 #, fuzzy
 msgid "Unable to write to file"
-msgstr "Valore da scrivere per null"
+msgstr "Non è possibile scrivere sul file"
 #: ../raster/r.in.ascii/gethead.c:34
 msgid "input file is not a Surfer ascii grid file"
@@ -12440,9 +11872,8 @@
 msgstr ""
 #: ../raster/r.in.ascii/gethead.c:105
-#, fuzzy
 msgid "error getting file position"
-msgstr "Punto di riferimento"
+msgstr ""
 #: ../raster/r.in.ascii/gethead.c:164
 msgid "illegal type field: using type int"
@@ -12467,7 +11898,7 @@
 #: ../raster/r.in.ascii/gethead.c:218
 #, fuzzy
 msgid "error in ascii data format"
+msgstr "errore nel formato dei dati ascii"
 #: ../raster/r.in.ascii/gethead.c:251 ../raster/r.in.arc/gethead.c:160
 #, c-format
@@ -12512,14 +11943,12 @@
 msgstr ""
 #: ../raster/r.what/main.c:131
-#, fuzzy
 msgid "Output header row"
-msgstr "Output solo in metri"
+msgstr ""
 #: ../raster/r.what/main.c:135
-#, fuzzy
 msgid "Show the category labels of the grid cell(s)"
+msgstr ""
 #: ../raster/r.what/main.c:139
 msgid "Output color values as RRR:GGG:BBB"
@@ -12535,9 +11964,8 @@
 msgstr ""
 #: ../raster/r.sum/main.c:47
-#, fuzzy
 msgid "Sums up the raster cell values."
-msgstr "numeri delle celle raster"
+msgstr ""
 #: ../raster/r.sum/main.c:54
 msgid "Name of incidence or density file."
@@ -12546,7 +11974,7 @@
 #: ../raster/r.random.cells/main.c:35
 #, fuzzy
 msgid "raster, random, cell"
-msgstr "Mappa(e) raster da leggere"
+msgstr "raster, casuale, cella"
 #: ../raster/r.random.cells/main.c:37
 msgid "Generates random cell values with spatial dependence."
@@ -12560,7 +11988,7 @@
 #: ../raster/r.random.cells/init.c:34
 #, fuzzy
 msgid "Maximum distance of spatial correlation (value(s) >= 0.0)"
+msgstr "Distanza massima della correlazione spaziale (valore/i >=0.0)"
 #: ../raster/r.random.cells/init.c:41
 msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
@@ -12569,31 +11997,26 @@
 #: ../raster/r.random.cells/init.c:96
 #, fuzzy
 msgid "Distance must be >= 0.0"
-msgstr "'%s' dev'essere > 0 per '%s'"
+msgstr "La distanza dev'essere >= 0.0"
 #: ../raster/r.random.cells/init.c:156
 #, fuzzy, c-format
 msgid "<%s> is an illegal name"
 #: ../raster/r.topidx/main.c:39
 #, fuzzy
 msgid "Creates topographic index map from elevation raster map."
-msgstr ""
-"Crea mappa dell'ombreggiatura dei rilievi da una mappa dell'elevatione (DEM)"
+msgstr "Crea mappa dell'ombreggiatura dei rilievi da una mappa dell'elevatione (DEM)"
 #: ../raster/r.topidx/file_io.c:32
 #, c-format
-msgid ""
-"Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx"
-"%.2f]! Needs to be at least identical or the current region resolution lower "
-"than the input map resolution"
+msgid "Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx%.2f]! Needs to be at least identical or the current region resolution lower than the input map resolution"
 msgstr ""
 #: ../raster/r.topidx/file_io.c:90
-#, fuzzy
 msgid "Writing topographic index map..."
+msgstr ""
 #: ../raster/r.univar2/r.univar_main.c:37
 msgid "Raster map used for zoning, must be of type CELL"
@@ -12628,15 +12051,14 @@
 msgstr ""
 #: ../raster/r.univar2/r.univar_main.c:99
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
 msgstr "Calcola le statistiche univariate per le celle non nulle di un raster"
 #: ../raster/r.univar2/r.univar_main.c:274
 #: ../raster/r.univar2/r.univar_main.c:277
 #, fuzzy, c-format
 msgid "Reading row %d"
+msgstr "Lettura della riga %d"
 #: ../raster/r.univar2/r3.univar_main.c:38
 msgid "3D Raster map used for zoning, must be of type CELL"
@@ -12644,10 +12066,8 @@
 #: ../raster/r.univar2/r3.univar_main.c:106
 #, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
-msgstr "Calcola le statistiche univariate per le celle non nulle di un raster"
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
+msgstr "Calcola le statistiche univariate per le celle 3d non nulle di un raster3d"
 #: ../raster/r.regression.line/main.c:44
 #, fuzzy
@@ -12663,17 +12083,14 @@
 msgstr ""
 #: ../raster/r.regression.line/main.c:59
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
 msgstr ""
 #: ../raster/r.regression.line/main.c:63 ../general/g.region/main.c:147
 #: ../locale/scriptstrings/i.oif_to_translate.c:9
 #, fuzzy
 msgid "Print in shell script style"
-msgstr ""
-"Stampa le impostazioni della region corrente (in stile script per la shell)"
+msgstr "Stampa in stile script per la shell"
 #: ../raster/r.resamp.stats/main.c:261
 msgid "Resamples raster map layers to a coarser grid using aggregation."
@@ -12744,17 +12161,17 @@
 #: ../general/g.region/main.c:830 ../display/d.title/main.c:108
 #, fuzzy, c-format
 msgid "Unable to read header of raster map <%s@%s>"
+msgstr "Non è possibile leggere l'intestazione della mappa raster <%s@%s>"
 #: ../raster/r.region/main.c:182 ../general/g.region/main.c:420
 #, fuzzy, c-format
 msgid "Region <%s> not found"
-msgstr "raster <%s> non trovato"
+msgstr "Regione <%s> non trovata"
 #: ../raster/r.region/main.c:184 ../general/g.region/main.c:422
 #, fuzzy, c-format
 msgid "Unable to read region <%s> in <%s>"
+msgstr "Impossibile leggere la regione <%s> in <%s>"
 #: ../raster/r.region/main.c:195 ../general/g.region/main.c:434
 #, c-format
@@ -12764,32 +12181,32 @@
 #: ../raster/r.region/main.c:201 ../general/g.region/main.c:439
 #, fuzzy, c-format
 msgid "Unable to open 3dview file <%s> in <%s>"
+msgstr "Impossibile aprire il file   3dview <%s> in <%s>"
 #: ../raster/r.region/main.c:206 ../general/g.region/main.c:445
 #, fuzzy, c-format
 msgid "Unable to read 3dview file <%s> in <%s>"
+msgstr "Impossibile leggere il file 3dview <%s> in <%s>"
 #: ../raster/r.region/main.c:209 ../general/g.region/main.c:448
-#, fuzzy, c-format
+#, c-format
 msgid "Old 3dview file. Region <%s> not found in <%s>"
+msgstr ""
 #: ../raster/r.region/main.c:241
 #, fuzzy, c-format
 msgid "Unable to open vector map <%s> in <%s>"
+msgstr "Impossibile aprire la mappa vettoriale <%s> in <%s>"
 #: ../raster/r.region/main.c:360 ../general/g.region/adjust.c:11
 #, fuzzy, c-format
 msgid "Invalid region: %s"
+msgstr "Regione non valida: %s"
 #: ../raster/r.region/main.c:368
 #, fuzzy
 msgid "Unable to update boundaries"
+msgstr "Non è possibile aggiornare i confini"
 #: ../raster/r.in.mat/main.c:94
 msgid "Imports a binary MAT-File(v4) to a GRASS raster."
@@ -12806,7 +12223,7 @@
 #: ../raster/r.in.mat/main.c:168
 #, fuzzy
 msgid "Reading MAT-File..."
+msgstr "Lettura del MAT-File in corso..."
 #: ../raster/r.in.mat/main.c:194
 msgid "Array contains no data"
@@ -12851,7 +12268,7 @@
 #: ../raster/r.in.mat/main.c:291
 #, fuzzy
 msgid "Error reading 'map_title' array"
+msgstr "Errore nella lettura dell'array 'map_title'"
 #: ../raster/r.in.mat/main.c:304
 msgid "Invalid 'map_data' array"
@@ -12880,7 +12297,7 @@
 #: ../raster/r.in.mat/main.c:377
 #, fuzzy, c-format
 msgid "Setting map name to <%s>"
+msgstr "Impostazione del nome della mappa a <%s>"
 #: ../raster/r.in.mat/main.c:381
 msgid "No 'map_name' array found; using <MatFile>"
@@ -12902,12 +12319,12 @@
 #: ../raster/r.in.mat/main.c:433
 #, fuzzy
 msgid "Writing new raster map..."
+msgstr "Scrittura della nuova mappa raster in corso..."
 #: ../raster/r.in.mat/main.c:491
 #, fuzzy, c-format
 msgid "Writing raster map, row %d"
+msgstr "Scrittura della mappa raster, riga %d"
 #: ../raster/r.param.scale/main.c:35
 #, fuzzy
@@ -12921,21 +12338,19 @@
 #: ../raster/r.param.scale/write_cats.c:47
 #, fuzzy, c-format
 msgid "Cannot write category file for raster map <%s>"
+msgstr "Impossibile scrivere il file delle categorie per la mappa raster <%s>"
 #: ../raster/r.param.scale/interface.c:54
 #, fuzzy
 msgid "raster, geomorphology"
+msgstr "raster, geomorfologia"
 #: ../raster/r.param.scale/interface.c:55
 msgid "Extracts terrain parameters from a DEM."
 msgstr "Estrae parametri del terreno da un DEM."
 #: ../raster/r.param.scale/interface.c:56
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
 msgstr ""
 #: ../raster/r.param.scale/interface.c:74
@@ -12943,9 +12358,8 @@
 msgstr ""
 #: ../raster/r.param.scale/interface.c:78
-#, fuzzy
 msgid "Slope tolerance that defines a 'flat' surface (degrees)"
-msgstr "Pendenza"
+msgstr ""
 #: ../raster/r.param.scale/interface.c:85
 msgid "Curvature tolerance that defines 'planar' surface"
@@ -12977,31 +12391,28 @@
 msgstr ""
 #: ../raster/r.in.arc/main.c:61
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
-"map layer."
-msgstr ""
-"Converte un file raster ESRI ARC/INFO acii (GRID) in un raster (binario)"
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
+msgstr "Converte un file raster ESRI ARC/INFO acii (GRID) in un raster (binario)"
 #: ../raster/r.in.arc/main.c:69
 #, fuzzy
 msgid "ARC/INFO ASCII raster file (GRID) to be imported"
-msgstr "raster map ARC/INFO (GRID) da importare"
+msgstr "File raster ASCII di ARC/INFO (GRID) da importare"
 #: ../raster/r.in.arc/main.c:228
 #, fuzzy
 msgid "Failed to copy file"
-msgstr "Nome del file in output"
+msgstr "Copiatura del file non riuscita"
 #: ../raster/r.in.arc/gethead.c:88
 #, fuzzy
 msgid "Illegal line in header"
+msgstr "Riga non valida nell'intestazione"
 #: ../raster/r.in.arc/gethead.c:165
 #, c-format
 msgid "Illegal \"%s\" value in header: \"%s\""
-msgstr ""
+msgstr "Valore \"%s\" non valido nell'intestazione: \"%s\""
 #: ../raster/r.support.stats/main.c:38
 msgid "Update raster map statistics"
@@ -13010,7 +12421,7 @@
 #: ../raster/r.support.stats/main.c:53
 #, fuzzy, c-format
 msgid "Statistics for <%s> updated"
-msgstr "impossibile aprire <%s>"
+msgstr "Statistiche per <%s> aggiornate"
 #: ../raster/r.support.stats/check.c:42
 #, c-format
@@ -13027,10 +12438,7 @@
 msgstr ""
 #: ../raster/r.neighbors/main.c:110
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
 msgstr ""
 #: ../raster/r.neighbors/main.c:133
@@ -13053,7 +12461,7 @@
 #: ../raster/r.neighbors/main.c:156
 #, fuzzy
 msgid "File containing weights"
+msgstr "File contenente i pesi"
 #: ../raster/r.neighbors/main.c:162
 msgid "Sigma (in cells) for Gaussian filter"
@@ -13091,12 +12499,12 @@
 #: ../raster/r.neighbors/readweights.c:18
 #, fuzzy, c-format
 msgid "Unable to open weights file %s"
+msgstr "impossibile aprire il file dei pesi %s"
 #: ../raster/r.neighbors/readweights.c:23
 #, fuzzy, c-format
 msgid "Error reading weights file %s"
-msgstr "Errore nella lettura del file dbmscap\n"
+msgstr "Errore nella lettura del file dei pesi"
 #: ../raster/r.bitpattern/main.c:63
 msgid "Compares bit patterns with a raster map."
@@ -13113,50 +12521,46 @@
 #: ../raster/r.bitpattern/main.c:151
 #, fuzzy, c-format
 msgid "Unable to write to <%s>"
+msgstr "Non è possibile scrivere su <%s>"
 #: ../raster/r.quantile/main.c:62
 msgid "Computing histogram"
 msgstr ""
 #: ../raster/r.quantile/main.c:96
-#, fuzzy
 msgid "Computing bins"
-msgstr "Importando punti ..."
+msgstr ""
 #: ../raster/r.quantile/main.c:133
-#, fuzzy
 msgid "Binning data"
+msgstr ""
 #: ../raster/r.quantile/main.c:178
-#, fuzzy
 msgid "Sorting bins"
+msgstr ""
 #: ../raster/r.quantile/main.c:188
 #, fuzzy
 msgid "Computing quantiles"
-msgstr "Sto copiando le tabelle..."
+msgstr "Calcolo dei quantili"
 #: ../raster/r.quantile/main.c:255
 msgid "Compute quantiles using two passes."
-msgstr "Calcola quantili utilizzando due raster."
+msgstr ""
 #: ../raster/r.quantile/main.c:263
 #, fuzzy
 msgid "Number of quantiles"
-msgstr "Numero di righe"
+msgstr "Numero di quantili"
 #: ../raster/r.quantile/main.c:271
 #, fuzzy
 msgid "List of percentiles"
-msgstr "List dei livelli di contorno"
+msgstr "Elenco di percentuali"
 #: ../raster/r.quantile/main.c:277
-#, fuzzy
 msgid "Number of bins to use"
+msgstr ""
 #: ../raster/r.quantile/main.c:282
 msgid "Generate recode rules based on quantile-defined intervals."
@@ -13177,11 +12581,11 @@
 #: ../general/g.version/main.c:47
 #, fuzzy
 msgid "Print the copyright message"
-msgstr "Stampa anche il messaggio sul copyright"
+msgstr "Stampa il messaggio sul copyright"
 #: ../general/g.version/main.c:51
 msgid "Print the GRASS build information"
-msgstr "Stampa le informazioni sulla versione di GRASS"
+msgstr "Stampa le informazioni sulle opzioni di compilazione di GRASS"
 #: ../general/g.version/main.c:56
 msgid "Print the GIS library revision number and time"
@@ -13194,10 +12598,7 @@
 msgstr ""
 #: ../general/manage/cmd/copy.c:41
-msgid ""
-"Copies available data files in the user's current mapset search path and "
-"location to the appropriate element directories under the user's current "
-"mapset."
+msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
 msgstr ""
 #: ../general/manage/cmd/copy.c:58
@@ -13244,7 +12645,7 @@
 #: ../general/manage/cmd/remove.c:106
 #, fuzzy
 msgid "Force remove"
-msgstr "vettore da rimuovere"
+msgstr "Forza la rimozione"
 #: ../general/manage/cmd/remove.c:120 ../general/g.mremove/main.c:96
 #, c-format
@@ -13252,15 +12653,13 @@
 msgstr "%s file da rimuovere"
 #: ../general/manage/cmd/list.c:43 ../general/g.mlist/main.c:67
-msgid ""
-"Lists available GRASS data base files of the user-specified data type to "
-"standard output."
+msgid "Lists available GRASS data base files of the user-specified data type to standard output."
 msgstr ""
 #: ../general/manage/cmd/list.c:72 ../general/g.mlist/main.c:121
 #, fuzzy
 msgid "Mapset to list (default: current search path)"
-msgstr "Mapset del quale fornire la lista (default: percorso corrente)"
+msgstr "Mapset del quale fornire la lista (predefinito: percorso di ricerca corrente)"
 #: ../general/manage/cmd/list.c:76 ../general/g.mlist/main.c:147
 #, fuzzy
@@ -13289,12 +12688,11 @@
 #: ../general/manage/cmd/rename.c:89
 #, fuzzy, c-format
 msgid "%s=%s,%s: files could be the same, no rename possible"
-msgstr "%s=%s,%s: sono gli stessi file, non è necessario rinominarli"
+msgstr "%s=%s,%s: i file devono essere gli stessi, non è possibile rinominarli"
 #: ../general/manage/cmd/rename.c:99
-#, fuzzy
 msgid "Renaming reclass maps"
-msgstr "Mappa raster risultante"
+msgstr ""
 #: ../general/g.access/main.c:39
 msgid "Controls access to the current mapset for other users on the system."
@@ -13319,12 +12717,12 @@
 #: ../general/g.access/main.c:71
 #, fuzzy
 msgid "Unable to determine mapset permissions"
+msgstr "Non è possibile determinare i permessi del mapset"
 #: ../general/g.access/set_perms.c:26
 #, fuzzy
 msgid "Unable to change mapset permissions"
+msgstr "Non è possibile cambiare i permessi del mapset"
 #: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
 msgid "have"
@@ -13370,12 +12768,12 @@
 #: ../general/g.proj/input.c:82
 #, fuzzy
 msgid "Error reading WKT projection description"
+msgstr "Errore nella lettura della descrizione della proiezione WKT"
 #: ../general/g.proj/input.c:89
 #, fuzzy, c-format
 msgid "Unable to open file [%s] for reading"
+msgstr "Impossibile aprire il file [%s] per la lettura"
 #: ../general/g.proj/input.c:134
 msgid "Can't parse PROJ.4-style parameter string"
@@ -13384,7 +12782,7 @@
 #: ../general/g.proj/input.c:172
 #, fuzzy
 msgid "Unable to translate EPSG code"
-msgstr "Nome della mappa raster risultante"
+msgstr "Non è possibile tradurre il codice EPSG"
 #: ../general/g.proj/input.c:209
 msgid "Trying to open with OGR..."
@@ -13405,31 +12803,21 @@
 #: ../general/g.proj/input.c:250
 #, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
-msgstr ""
-"Lettura del file %s avvenuta con successo, ma non contiene alcuna "
-"informazione sullaproiezione. Verrà usata la proiezione 'XY (nessuna "
-"proiezione)'"
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+msgstr "Lettura del file %s avvenuta con successo, ma non contiene alcuna informazione sullaproiezione. Verrà usata la proiezione 'XY (nessuna proiezione)'"
 #: ../general/g.proj/main.c:54 ../general/g.setproj/main.c:78
-#, fuzzy
 msgid "general, projection"
-msgstr "Nome del raster"
+msgstr ""
 #: ../general/g.proj/main.c:56
-msgid ""
-"Converts co-ordinate system descriptions (i.e. projection information) "
-"between various formats (including GRASS format)."
-msgstr ""
-"Converte le descrizioni del sistema di coordinate (es. informazioni sulla "
-"proiezione) utilizzando diversi formati (incluso quello di GRASS)."
+msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
+msgstr "Converte le descrizioni del sistema di coordinate (es. informazioni sulla proiezione) utilizzando diversi formati (incluso quello di GRASS)."
 #: ../general/g.proj/main.c:59
 #, fuzzy
 msgid "Can also be used to create GRASS locations."
+msgstr "Può essere usato anche per creare le location di GRASS"
 #: ../general/g.proj/main.c:65
 msgid "Print projection information (in conventional GRASS format)"
@@ -13437,8 +12825,7 @@
 #: ../general/g.proj/main.c:71
 msgid "Verify datum information and print transformation parameters"
-msgstr ""
-"Verifica le informazioni sul datum e stampa i parametri di trasformazione"
+msgstr "Verifica le informazioni sul datum e stampa i parametri di trasformazione"
 #: ../general/g.proj/main.c:77
 msgid "Print projection information in PROJ.4 format"
@@ -13453,23 +12840,17 @@
 msgstr "Usa formato in stile ESRI (solo per il formato WKT)"
 #: ../general/g.proj/main.c:94
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
-msgstr ""
-"Stampa output 'flat' senza interruzioni di riga (applicabile ad output WKT e "
-"PROJ4)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgstr "Stampa output 'flat' senza interruzioni di riga (applicabile ad output WKT e PROJ4)"
 #: ../general/g.proj/main.c:103
 msgid "Georeferenced data file to read projection information from"
-msgstr ""
-"File di dati georeferenziati dai quali leggere le informazioni di proiezione"
+msgstr "File di dati georeferenziati dai quali leggere le informazioni di proiezione"
 #: ../general/g.proj/main.c:112
 #, fuzzy
 msgid "ASCII file containing a WKT projection description (- for stdin)"
-msgstr ""
-"File ASCII contenente la singola linea descrivente la proiezione WKT (- per "
-"stdin)"
+msgstr "File ASCII contenente la descrizione della proiezione WKT (- per stdin)"
 #: ../general/g.proj/main.c:121
 msgid "PROJ.4 projection description (- for stdin)"
@@ -13478,40 +12859,32 @@
 #: ../general/g.proj/main.c:129
 #, fuzzy
 msgid "EPSG projection code"
+msgstr "Codice EPSG della proiezione"
 #: ../general/g.proj/main.c:137 ../general/g.proj/main.c:143
 msgid "Datum"
 msgstr "Datum"
 #: ../general/g.proj/main.c:138
-#, fuzzy
 msgid "Index number of datum transform parameters"
 msgstr ""
 #: ../general/g.proj/main.c:139
 msgid "\"0\" for unspecified or \"-1\" to list and exit"
 msgstr ""
 #: ../general/g.proj/main.c:145
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
+msgid "Force override of datum transformation information in input co-ordinate system"
 msgstr ""
 #: ../general/g.proj/main.c:150 ../general/g.proj/main.c:159
 #, fuzzy
 msgid "Create/Edit"
-msgstr "Campo separatore in output"
+msgstr "Crea/Modifica"
 #: ../general/g.proj/main.c:151
-msgid ""
-"Create new projection files (modifies current location unless 'location' "
-"option specified)"
-msgstr ""
-"Crea un nuovo file contenente le informazioni sulla proiezione (modifica la "
-"location attuale a meno che l'opzione 'location' venga specificata)"
+msgid "Create new projection files (modifies current location unless 'location' option specified)"
+msgstr "Crea un nuovo file contenente le informazioni sulla proiezione (modifica la location attuale a meno che l'opzione 'location' venga specificata)"
 #: ../general/g.proj/main.c:160
 #, fuzzy
@@ -13525,8 +12898,7 @@
 #: ../general/g.proj/main.c:183
 #, fuzzy, c-format
 msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
-msgstr ""
-"Solo una delle seguenti opzioni: '%s', '%s' or '%s' deve essere specificata"
+msgstr "Solo una delle seguenti opzioni: '%s', '%s' o '%s' può essere specificata"
 #: ../general/g.proj/main.c:210
 msgid "Projection files missing"
@@ -13545,25 +12917,21 @@
 #: ../general/g.proj/output.c:155
 #, fuzzy, c-format
 msgid "Unable to create location: %s"
+msgstr "Non è possibile creare la location: %s"
 #: ../general/g.proj/output.c:158
 #, fuzzy, c-format
 msgid "Unable to create projection files: %s"
+msgstr "Non è possibile creare i file della proiezione: %s"
 #: ../general/g.proj/output.c:162
 msgid "Unspecified error while creating new location"
-msgstr "Errore non specificato mentre si creava la nuovo location"
+msgstr "Errore non specificato durante la creazione della nuova location"
 #: ../general/g.proj/output.c:174
 #, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection. (Current mapset is %s)"
-msgstr ""
-"Devi selezionare il mapset PERMANENT prima di aggiornare la proioezione "
-"corrente della localtion. (Il mapset corrente è %s)"
+msgid "You must select the PERMANENT mapset before updating the current location's projection. (Current mapset is %s)"
+msgstr "Devi selezionare il mapset PERMANENT prima di aggiornare la proioezione corrente della localtion. (Il mapset corrente è %s)"
 #: ../general/g.proj/output.c:190
 #, c-format
@@ -13589,19 +12957,13 @@
 msgstr "Errore durante la scrittura di PROJ_UNITS"
 #: ../general/g.proj/output.c:243
-msgid ""
-"N.B. The default region was updated to the new projection, but if you have "
-"multiple mapsets g.region -d should be run in each to update the region from "
-"the default."
+msgid "N.B. The default region was updated to the new projection, but if you have multiple mapsets g.region -d should be run in each to update the region from the default."
 msgstr ""
 #: ../general/g.proj/output.c:247
 #, fuzzy
 msgid "Projection information updated!"
-msgstr ""
-"\n"
-"Informazioni sulla proiezione aggiornate!\n"
-"\n"
+msgstr "Informazioni sulla proiezione aggiornate!"
 #: ../general/g.proj/output.c:250
 msgid "The projection information will not be updated."
@@ -13619,7 +12981,7 @@
 #: ../general/g.pnmcomp/main.c:53
 #, fuzzy
 msgid "Error reading PPM file"
+msgstr "Errore durante la lettura del file PPM"
 #: ../general/g.pnmcomp/main.c:68 ../general/g.pnmcomp/main.c:73
 #: ../general/g.pnmcomp/main.c:82 ../general/g.pnmcomp/main.c:133
@@ -13643,7 +13005,7 @@
 #: ../general/g.pnmcomp/main.c:111
 #, fuzzy, c-format
 msgid "Invalid magic number: 'P%c'"
-msgstr "Area: %d  Numero di isole: %d\n"
+msgstr "Magic number non valido: 'P%c'"
 #: ../general/g.pnmcomp/main.c:124 ../general/g.pnmcomp/main.c:141
 msgid "Invalid PGM file"
@@ -13652,16 +13014,16 @@
 #: ../general/g.pnmcomp/main.c:246
 #, fuzzy
 msgid "Error writing PPM file"
+msgstr "Errore nella scrittura del file PPM"
 #: ../general/g.pnmcomp/main.c:263
 #, fuzzy
 msgid "Error writing PGM file"
+msgstr "Errore nella scrittura del file PGM"
 #: ../general/g.pnmcomp/main.c:289
 msgid "Names of input files"
-msgstr "Nomi di file di input"
+msgstr "Nomi dei file di input"
 #: ../general/g.pnmcomp/main.c:296
 msgid "Names of mask files"
@@ -13676,9 +13038,8 @@
 #: ../general/g.pnmcomp/main.c:316
-#, fuzzy
 msgid "Name of output mask file"
-msgstr "Nome del display file in output."
+msgstr ""
 #: ../general/g.pnmcomp/main.c:323
 msgid "Image width"
@@ -13695,13 +13056,11 @@
 msgstr "Colore di sfondo"
 #: ../general/g.message/main.c:33
-#, fuzzy
 msgid "general, scripts"
+msgstr ""
 #: ../general/g.message/main.c:35
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
 msgstr ""
 #: ../general/g.message/main.c:37
@@ -13712,9 +13071,7 @@
 #: ../general/g.message/main.c:51 ../general/g.message/main.c:56
 #, fuzzy
 msgid "Type"
-msgstr ""
-"Layer: %d\n"
-"categoria: %d\n"
+msgstr "Tipo"
 #: ../general/g.message/main.c:42
 msgid "Print message as warning"
@@ -13748,7 +13105,7 @@
 #: ../general/g.message/main.c:74
 #, fuzzy
 msgid "Text of the message to be printed"
+msgstr "Testo del messaggio da stampare"
 #: ../general/g.message/main.c:83
 msgid "Level to use for debug messages"
@@ -13761,7 +13118,7 @@
 #: ../general/g.message/main.c:104
 #, fuzzy
 msgid "Unable to parse input message"
-msgstr "Nome della mappa di input"
+msgstr "Non è possibile eseguire il parsing del messaggio di input"
 #: ../general/g.setproj/main.c:80
 msgid "Interactively reset the location's projection settings."
@@ -13778,7 +13135,7 @@
 #: ../general/g.setproj/main.c:104
 #, fuzzy
 msgid "Current region cannot be set"
-msgstr "La region corrente non può essere settata."
+msgstr "La regione corrente non può essere impostata."
 #: ../general/g.setproj/main.c:134
 msgid "Would you still like to change some of the parameters?"
@@ -13803,7 +13160,7 @@
 #: ../general/g.setproj/main.c:191
 #, fuzzy
 msgid "Unknown projection"
+msgstr "Proiezione sconosciuta"
 #: ../general/g.setproj/main.c:197
 #, c-format
@@ -13822,13 +13179,12 @@
 #: ../general/g.setproj/main.c:216
 #, fuzzy
 msgid "Do you wish to change the datum (or datum transformation parameters)?"
-msgstr ""
+msgstr "Si vuole cambiare il datum (o i parametri di trasformazione del datum)?"
 #: ../general/g.setproj/main.c:224
 #, fuzzy
 msgid "The datum information has not been changed"
-msgstr "Le informazioni sulla proiezione non saranno aggiornate"
+msgstr "Le informazioni sul datum non sono state cambiate"
 #: ../general/g.setproj/main.c:287
 #, c-format
@@ -13840,9 +13196,8 @@
 msgstr ""
 #: ../general/g.setproj/main.c:293
-#, fuzzy
 msgid "The ellipse information has not been changed"
+msgstr ""
 #: ../general/g.setproj/main.c:310
 #, c-format
@@ -13860,7 +13215,7 @@
 #: ../general/g.setproj/main.c:335
 #, fuzzy
 msgid "Invalid input ellipsoid"
-msgstr "Utilizzando le coordinate del centro della mappa\n"
+msgstr "Ellissoide di input non valido"
 #: ../general/g.setproj/main.c:446
 #, c-format
@@ -13874,13 +13229,10 @@
 #: ../general/g.setproj/main.c:450
 #, fuzzy
 msgid "UTM zone information has not been updated"
+msgstr "Le informazioni sulla zona UTM non sono state aggiornate"
 #: ../general/g.setproj/main.c:455
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
 msgstr ""
 #: ../general/g.setproj/main.c:460
@@ -13890,7 +13242,7 @@
 #: ../general/g.setproj/main.c:496
 #, fuzzy, c-format
 msgid "Error writing PROJ_INFO file <%s>"
-msgstr "Errore durante la scrittura di PROJ_INFO"
+msgstr "Errore durante la scrittura del file PROJ_INFO <%s>"
 #: ../general/g.setproj/main.c:570
 #, c-format
@@ -13905,17 +13257,16 @@
 #: ../general/g.setproj/main.c:610
 #, fuzzy, c-format
 msgid "Enter conversion factor from %s to meters: "
-msgstr "Nome di un file vettoriale in output"
+msgstr "Inserire il fattore di conversione da %s a metri"
 #: ../general/g.setproj/main.c:635
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing into UNITS output file <%s>"
-msgstr "Mappa raster in input"
+msgstr ""
 #: ../general/g.setproj/main.c:642
-#, fuzzy
 msgid "Unable to write to DEFAULT_WIND region file"
+msgstr ""
 #: ../general/g.setproj/main.c:644
 #, fuzzy, c-format
@@ -13925,13 +13276,12 @@
 "\n"
 msgstr ""
 "\n"
-"\n"
-"ATTENZIONE!  Un file della proiezione esiste già per questa location\n"
+"Le informaizoni sulla proiezione sono state registrate per questa location\n"
 #: ../general/g.setproj/main.c:646
 #, fuzzy
 msgid "The geographic region information in WIND is now obsolete"
+msgstr "Le informazioni geografiche contenute in WIND ora sono obsolete"
 #: ../general/g.setproj/main.c:647
 msgid "Run g.region -d to update it"
@@ -13942,9 +13292,8 @@
 msgstr ""
 #: ../general/g.setproj/get_stp.c:99
-#, fuzzy
 msgid "Unable to open FIPS code file"
+msgstr ""
 #: ../general/g.setproj/get_stp.c:125
 #, c-format
@@ -13952,24 +13301,20 @@
 msgstr ""
 #: ../general/g.setproj/get_stp.c:179
-#, fuzzy
 msgid "Reading sf key_value temp file"
+msgstr ""
 #: ../general/g.setproj/get_stp.c:212
-#, fuzzy
 msgid "Invalid State FIPS code"
+msgstr ""
 #: ../general/g.setproj/get_stp.c:302
-#, fuzzy
 msgid "Reading cf key_value temp file"
+msgstr ""
 #: ../general/g.setproj/get_stp.c:336
-#, fuzzy
 msgid "Invalid County FIPS code"
+msgstr ""
 #: ../general/g.setproj/proj.c:168
 #, c-format
@@ -13987,9 +13332,9 @@
 msgstr ""
 #: ../general/g.transform/main.c:101
-#, fuzzy, c-format
+#, c-format
 msgid "Error conducting transform (%d)"
-msgstr "Stampa solo il tipo di mappa raster"
+msgstr ""
 #: ../general/g.transform/main.c:199
 msgid "Poorly placed control points"
@@ -14002,7 +13347,7 @@
 #: ../general/g.transform/main.c:203
 #, fuzzy
 msgid "Parameter error"
-msgstr "Parametri"
+msgstr "Errore del parametro"
 #: ../general/g.transform/main.c:205
 msgid "No active control points"
@@ -14011,12 +13356,11 @@
 #: ../general/g.transform/main.c:300
 #, fuzzy, c-format
 msgid "Invalid coordinates: [%s]"
+msgstr "Coordinate non valide: [%s]"
 #: ../general/g.transform/main.c:320
-#, fuzzy
 msgid "general, transformation, GCP"
+msgstr ""
 #: ../general/g.transform/main.c:322
 msgid "Computes a coordinate transformation based on the control points."
@@ -14027,52 +13371,42 @@
 msgstr ""
 #: ../general/g.transform/main.c:339
-msgid ""
-"idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
-"forward coordinates (destination);rev;reverse coordinates (source);fxy;"
-"forward coordinates difference (destination);rxy;reverse coordinates "
-"difference (source);fd;forward error (destination);rd;reverse error (source)"
+msgid "idx;point index;src;source coordinates;dst;destination coordinates;fwd;forward coordinates (destination);rev;reverse coordinates (source);fxy;forward coordinates difference (destination);rxy;reverse coordinates difference (source);fd;forward error (destination);rd;reverse error (source)"
 msgstr ""
 #: ../general/g.transform/main.c:349 ../vector/v.out.ascii/out.c:63
 #, fuzzy
 msgid "Output format"
+msgstr "Formato di output"
 #: ../general/g.transform/main.c:353
-#, fuzzy
 msgid "Display summary information"
-msgstr "Mostra le informazioni sulla versione ed il copyright"
+msgstr ""
 #: ../general/g.transform/main.c:359
 #, fuzzy
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
-msgstr ""
-"stdin)"
+msgstr "File contenente le coordinate da trasformare (\"-\" per leggere dallo stdin)"
 #: ../general/g.transform/main.c:360
-#, fuzzy
 msgid "Local x,y coordinates to target east,north"
-msgstr "Le coordinate del centro (est,nord)"
+msgstr ""
 #: ../general/g.transform/main.c:364
 msgid "Reverse transform of coords file or coeff. dump"
 msgstr ""
 #: ../general/g.transform/main.c:365
-#, fuzzy
 msgid "Target east,north coordinates to local x,y"
+msgstr ""
 #: ../general/g.transform/main.c:369
 msgid "Display transform matrix coefficients"
 msgstr ""
 #: ../general/g.mapset/main.c:48
-#, fuzzy
 msgid "general, settings"
+msgstr ""
 #: ../general/g.mapset/main.c:49
 #, fuzzy
@@ -14080,55 +13414,48 @@
 msgstr "Cambia il mapset corrente."
 #: ../general/g.mapset/main.c:50
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
+msgid "Optionally create new mapset or list available mapsets in given location."
 msgstr ""
 #: ../general/g.mapset/main.c:57
-#, fuzzy
 msgid "Name of mapset where to switch"
+msgstr ""
 #: ../general/g.mapset/main.c:65
 #, fuzzy
 msgid "Location name (not location path)"
-msgstr "Nome della nuova LOCATION (non il percorso della location)"
+msgstr "Nome della location (non il percorso della location)"
 #: ../general/g.mapset/main.c:75
 #, fuzzy
-msgid ""
-"GIS data directory (full path to the directory where the new location is)"
-msgstr ""
-"Nuovo GISDBASE (percorso intero della directory dove la nuova location è "
-"situata)"
+msgid "GIS data directory (full path to the directory where the new location is)"
+msgstr "Directory dei dati GIS (percorso intero della directory dove la nuova location è situata)"
 #: ../general/g.mapset/main.c:80
 #, fuzzy
 msgid "Create mapset if it doesn't exist"
+msgstr "Crea il mapset se non ne esiste uno"
 #: ../general/g.mapset/main.c:82
 #: ../locale/scriptstrings/r.mask_to_translate.c:4
 #: ../locale/scriptstrings/r.mask_to_translate.c:6
 #: ../locale/scriptstrings/r.mask_to_translate.c:8
-#, fuzzy
 msgid "Create"
+msgstr ""
 #: ../general/g.mapset/main.c:86
 #, fuzzy
 msgid "List available mapsets"
-msgstr "Visualizza i formati supportati ed esci"
+msgstr "Elenco dei mapset disponibili"
 #: ../general/g.mapset/main.c:93
-#, fuzzy
 msgid "Either mapset= or -l must be used"
-msgstr "file vettoriale da creare"
+msgstr ""
 #: ../general/g.mapset/main.c:139
 #, fuzzy, c-format
 msgid "<%s> is already the current mapset"
-msgstr "ERRORE: <%s> esiste già nel mapset <%s>\n"
+msgstr "<%s> è già il mapset corrente"
 #: ../general/g.mapset/main.c:147
 #, fuzzy
@@ -14137,29 +13464,26 @@
 #: ../general/g.mapset/main.c:156
 msgid "The mapset does not exist. Use -c flag to create it."
-msgstr "Il mapset non esiste. Usa l'opzione -c per crearla"
+msgstr "Il mapset non esiste. Usa l'opzione -c per crearlo"
 #: ../general/g.mapset/main.c:165
 #, fuzzy
 msgid "Unable to read GIS_LOCK environment variable"
-msgstr "Non riesco a descrivere la tabella"
+msgstr "Non è possibile leggere la variabile d'ambiente GIS_LOCK"
 #: ../general/g.mapset/main.c:179
 #, c-format
-msgid ""
-"%s is currently running GRASS in selected mapset or lock file cannot be "
-"checked"
+msgid "%s is currently running GRASS in selected mapset or lock file cannot be checked"
 msgstr ""
 #: ../general/g.mapset/main.c:183
 #, fuzzy
 msgid "Erasing monitors..."
+msgstr "Cancellazione dei monitor in corso ..."
 #: ../general/g.mapset/main.c:199
-#, fuzzy
 msgid "Cleaning up temporary files..."
+msgstr ""
 #: ../general/g.mapset/main.c:213
 msgid "Your shell continues to use the history for the old mapset"
@@ -14182,56 +13506,51 @@
 #: ../general/g.mapset/main.c:228
 #, fuzzy, c-format
 msgid "Your current mapset is <%s>"
+msgstr "Il mapset corrente è <%s>"
 #: ../general/g.mapsets/dsply_path.c:30
-#, fuzzy, c-format
+#, c-format
 msgid "Your mapset search list:\n"
+msgstr ""
 #: ../general/g.mapsets/dsply_path.c:38
 #, fuzzy, c-format
 msgid "<%s> not found in mapset list"
+msgstr "<%s> non trovato nella lista dei mapset"
 #: ../general/g.mapsets/main.c:59
 #, fuzzy
 msgid "general, settings, search path"
+msgstr "general, impostazioni, percorso di ricerca"
 #: ../general/g.mapsets/main.c:60
 #, fuzzy
 msgid "Modifies the user's current mapset search path."
+msgstr "Modifica il percorso di ricerca corrente dell'utente"
 #: ../general/g.mapsets/main.c:61
-#, fuzzy
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
 msgstr ""
-"Copia i file disponibili nell'attuale percorso di ricerca del mapset e della "
-"location in uso dall'utente nelle appropriate cartelle del mapset corrente"
 #: ../general/g.mapsets/main.c:69
 #, fuzzy
 msgid "Name(s) of existing mapset(s)"
-msgstr "Nome di mappa(e) raster esistente(i)"
+msgstr "Nome di uno o più mapset esistenti"
 #: ../general/g.mapsets/main.c:70 ../general/g.mapsets/main.c:79
 #: ../general/g.mapsets/main.c:88
 msgid "Search path"
-msgstr ""
+msgstr "Percorso di ricerca"
 #: ../general/g.mapsets/main.c:78
 #, fuzzy
 msgid "Name(s) of existing mapset(s) to add to search path"
-msgstr "Nome di una mappa raster esistente"
+msgstr "Nome di uno o più mapset esistenti da aggiungere al percorso di ricerca"
 #: ../general/g.mapsets/main.c:87
 #, fuzzy
 msgid "Name(s) of existing mapset(s) to remove from search path"
+msgstr "Nome di uno o più mapset esistenti da rimuovere dal percorso di ricerca"
 #: ../general/g.mapsets/main.c:91
 #: ../locale/scriptstrings/m.proj_to_translate.c:7
@@ -14239,7 +13558,7 @@
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
 #, fuzzy
 msgid "Field separator"
-msgstr "campo separatore in output"
+msgstr "Separatore di campo"
 #: ../general/g.mapsets/main.c:92
 msgid "Special characters: newline, space, comma, tab"
@@ -14248,12 +13567,11 @@
 #: ../general/g.mapsets/main.c:97
 #, fuzzy
 msgid "List all available mapsets in alphabetical order"
+msgstr "Elenca tutti i mapset disponibili in ordine alfabetico"
 #: ../general/g.mapsets/main.c:102
-#, fuzzy
 msgid "Print mapsets in current search path"
+msgstr ""
 #: ../general/g.mapsets/main.c:107
 msgid "Show mapset selection dialog"
@@ -14262,17 +13580,17 @@
 #: ../general/g.mapsets/main.c:132 ../general/g.mapsets/main.c:161
 #, fuzzy, c-format
 msgid "Mapset <%s> not found"
+msgstr "Mapset <%s> non trovato"
 #: ../general/g.mapsets/main.c:163
 #, fuzzy, c-format
 msgid "Mapset <%s> added to search path"
+msgstr "Mapset <%s> aggiunto al percorso di ricerca"
 #: ../general/g.mapsets/main.c:189
 #, c-format
 msgid "Mapset <%s> removed from search path"
-msgstr ""
+msgstr "Mapset <%s> rimosso dal percorso di ricerca"
 #: ../general/g.mapsets/main.c:222
 msgid "Cannot open SEARCH_PATH for write"
@@ -14281,7 +13599,7 @@
 #: ../general/g.mapsets/dsply_maps.c:23
 #, fuzzy, c-format
 msgid "Available mapsets:"
+msgstr "Mapset disponibili:"
 #: ../general/g.mapsets/dsply_maps.c:33
 #, c-format
@@ -14305,7 +13623,7 @@
 #: ../general/g.mremove/main.c:80
 #, fuzzy
 msgid "Remove base maps"
-msgstr "Rimuove un database."
+msgstr "Rimuove le mappe di base"
 #: ../general/g.mremove/main.c:104 ../general/g.mlist/main.c:155
 msgid "-r and -e are mutually exclusive"
@@ -14317,9 +13635,9 @@
 #: ../general/g.mremove/main.c:130 ../general/g.mlist/main.c:164
 #: ../general/g.mlist/main.c:175
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to compile regular expression %s"
-msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgstr ""
 #: ../general/g.mremove/main.c:158
 msgid "You must use the force flag to actually remove them. Exiting."
@@ -14336,12 +13654,12 @@
 #: ../general/g.mremove/do_remove.c:21
 #, fuzzy, c-format
 msgid "Removing %s <%s>"
+msgstr "Rimozione di %s <%s>"
 #: ../general/g.mremove/do_remove.c:42 ../general/g.mremove/do_remove.c:84
 #, fuzzy
 msgid "couldn't be removed"
+msgstr "non può essere rimosso"
 #: ../general/g.mremove/do_remove.c:55 ../general/g.region/main.c:505
 #, c-format
@@ -14351,7 +13669,7 @@
 #: ../general/g.mremove/do_remove.c:62
 #, fuzzy, c-format
 msgid "%s: couldn't be removed"
-msgstr "%s file da rimuovere"
+msgstr "%s: non può essere rimosso"
 #: ../general/g.mremove/do_remove.c:67 ../general/g.mremove/do_remove.c:89
 #, c-format
@@ -14361,16 +13679,16 @@
 #: ../general/g.mremove/do_remove.c:71 ../general/g.mremove/do_remove.c:93
 #, fuzzy, c-format
 msgid "%s: removed"
+msgstr "%s: rimosso"
 #: ../general/g.mremove/do_remove.c:100
 #, fuzzy, c-format
 msgid "<%s> nothing removed"
-msgstr "<%s> non trovato"
+msgstr "<%s> non è stato rimosso nulla"
 #: ../general/g.gisenv/main.c:40
 msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr "Esporta e modifica le impostazioni del corrente utente di GRASS"
+msgstr ""
 #: ../general/g.gisenv/main.c:45
 msgid "GRASS variable to get"
@@ -14399,7 +13717,7 @@
 #: ../general/g.filename/main.c:40
 #, fuzzy
 msgid "Prints GRASS data base file names."
-msgstr "Nome del database in input"
+msgstr "Stampa i nomi dei file del database di GRASS"
 #: ../general/g.filename/main.c:48 ../general/g.findfile/main.c:48
 msgid "Name of an element"
@@ -14414,14 +13732,12 @@
 msgstr "Nome di un mapset (predefinito: corrente)"
 #: ../general/g.mlist/main.c:97
-#, fuzzy
 msgid "Map name search pattern (default: all)"
-msgstr "Carattere di separatore in output (predefinito: tab)"
+msgstr ""
 #: ../general/g.mlist/main.c:104
-#, fuzzy
 msgid "Map name exclusion pattern (default: none)"
+msgstr ""
 #: ../general/g.mlist/main.c:113
 msgid "One-character output separator, newline, comma, space, or tab"
@@ -14430,17 +13746,16 @@
 #: ../general/g.mlist/main.c:135
 #, fuzzy
 msgid "Print data types"
+msgstr "Stampa i tipi di dati"
 #: ../general/g.mlist/main.c:139
 #, fuzzy
 msgid "Print mapset names"
-msgstr "Nome mappa raster"
+msgstr "Stampa i nomi dei mapset"
 #: ../general/g.mlist/main.c:143
-#, fuzzy
 msgid "Pretty printing in human readable format"
-msgstr "Sopprimi la stampa della informazioni di intestazione"
+msgstr ""
 #: ../general/g.region/main.c:72
 msgid "Manages the boundary definitions for the geographic region."
@@ -14464,40 +13779,38 @@
 #: ../general/g.region/main.c:93
 #, fuzzy
 msgid "Print the current region in lat/long using the current ellipsoid/datum"
+msgstr "Stampa la regione corrente in lat/long usando ellissoide/datum corrente"
 #: ../general/g.region/main.c:99
 #, fuzzy
 msgid "Print the current region extent"
+msgstr "Stampa l'estensione della regione corrente"
 #: ../general/g.region/main.c:105
 #, fuzzy
 msgid "Print the current region map center coordinates"
+msgstr "Stampa le coordinate del centro della mappa della regione corrente"
 #: ../general/g.region/main.c:111
 #, fuzzy
 msgid "Print the current region in GMT style"
+msgstr "Stampa la regione corrente in stile GMT"
 #: ../general/g.region/main.c:117
 #, fuzzy
 msgid "Print the current region in WMS style"
+msgstr "Stampa la regione corrente in stile WMS"
 #: ../general/g.region/main.c:123
 msgid "Print region resolution in meters (geodesic)"
-msgstr "Stampa la risoluzione della region in metri (proiezione geodetica)"
+msgstr "Stampa la risoluzione della regione in metri (proiezione geodetica)"
 #: ../general/g.region/main.c:128
 msgid "Print the convergence angle (degrees CCW)"
 msgstr ""
 #: ../general/g.region/main.c:130
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
 msgstr ""
 #: ../general/g.region/main.c:136
@@ -14507,23 +13820,16 @@
 #: ../general/g.region/main.c:142
 #, fuzzy
 msgid "Print the maximum bounding box in lat/long on WGS84"
-msgstr ""
-"Stampa l'estensione massima in lat/long per la proiezione WGS84 (solo "
-"modalità -g)"
+msgstr "Stampa l'estensione massima in lat/long per la proiezione WGS84"
 #: ../general/g.region/main.c:153
 #, fuzzy
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
-msgstr ""
-"Allinea la region alla risoluzione (default = allinea ai margini, funziona "
-"solo per la risoluzione 2D)"
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
+msgstr "Allinea la regione alla risoluzione (predefinito = allinea ai margini, funziona solo per la risoluzione 2D)"
 #: ../general/g.region/main.c:159
-#, fuzzy
 msgid "Do not update the current region"
+msgstr ""
 #: ../general/g.region/main.c:160 ../general/g.region/main.c:363
 #: ../vector/v.label/main.c:91 ../vector/v.label/main.c:96
@@ -14537,9 +13843,7 @@
 #: ../general/g.region/main.c:186
 msgid "Set region to match this 3D raster map (both 2D and 3D values)"
-msgstr ""
-"Imposta la regione in modo che corrisponda a questa mappa raster (sia valori "
-"2D che 3D)"
+msgstr "Imposta la regione in modo che corrisponda a questa mappa raster (sia valori 2D che 3D)"
 #: ../general/g.region/main.c:253
 msgid "Value for the top edge"
@@ -14595,12 +13899,12 @@
 #: ../general/g.region/main.c:361
 #, fuzzy
 msgid "Save current region settings in named region file"
-msgstr "Imposta la region corrente alla region salvata"
+msgstr "Salva le impostazioni della regione corrente in un file di regione con nome"
 #: ../general/g.region/main.c:508
 #, fuzzy, c-format
 msgid "Unable to read header of 3D raster map <%s@%s>"
 #: ../general/g.region/main.c:551
 #, c-format
@@ -14620,31 +13924,31 @@
 #: ../general/g.region/main.c:843
 #, fuzzy, c-format
 msgid "Unable to set region <%s>"
+msgstr "Non è possibile impostare la regione <%s>"
 #: ../general/g.region/main.c:849
 #, fuzzy
 msgid "Unable to update current region"
+msgstr "Non è possibile aggiornare la regione corrente"
 #: ../general/g.region/main.c:857
 msgid "Unable to change default region. The current mapset is not <PERMANENT>."
-msgstr ""
+msgstr "Non è possibile cambiare la regione predefintia. Il mapset corrente non è <PERMANENT>"
 #: ../general/g.region/main.c:874
 #, fuzzy, c-format
 msgid "Invalid input <%s=%s>"
+msgstr "Input <%s=%s> non valido"
 #: ../general/g.region/main.c:895
 #, fuzzy
 msgid "format"
+msgstr "formato"
 #: ../general/g.region/zoom.c:23
 #, fuzzy, c-format
 msgid "Unable to open raster map <%s> in <%s>"
+msgstr "impossibile aprire la mappa raster <%s> in <%s>"
 #: ../general/g.region/zoom.c:35
 #, c-format
@@ -14655,34 +13959,27 @@
 #: ../general/g.region/printwindow.c:648
 #, fuzzy
 msgid "Unable to update lat/long projection parameters"
+msgstr "Non è possibile aggiornare i parametri della proiezione lat/long"
 #: ../general/g.region/printwindow.c:411
 msgid "You are already in Lat/Long. Use the -p flag instead."
 msgstr ""
 #: ../general/g.region/printwindow.c:413
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
 msgstr ""
 #: ../general/g.region/printwindow.c:638
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
-msgstr ""
-"Output WGS84 impossible a causa dell'assenza di parametri di trasformazione "
-"del datum. Prova ad eseguire g.setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+msgstr "Output WGS84 impossible a causa dell'assenza di parametri di trasformazione del datum. Prova ad eseguire g.setproj."
 #: ../general/g.region/printwindow.c:784
 msgid "Lat/Long calculations are not possible from a simple XY system"
 msgstr ""
 #: ../general/g.gui/main.c:36
-#, fuzzy
 msgid "general, gui"
+msgstr ""
 #: ../general/g.gui/main.c:38
 msgid "Launches a GRASS graphical user interface (GUI) session."
@@ -14691,23 +13988,20 @@
 #: ../general/g.gui/main.c:43
 #, fuzzy
 msgid "GUI type"
-msgstr "Tipo sconosciuto"
+msgstr "Tipo i GUI"
 #: ../general/g.gui/main.c:44
 msgid "Default value: GRASS_GUI if defined, otherwise wxpython"
 msgstr ""
 #: ../general/g.gui/main.c:45
-msgid ""
-"wxpython;wxPython based next generation GUI;tcltk;Tcl/Tk based GUI - GIS "
-"Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;"
-"command line interface only"
+msgid "wxpython;wxPython based next generation GUI;tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command line interface only"
 msgstr ""
 #: ../general/g.gui/main.c:54
 #, fuzzy
 msgid "Name of workspace file"
-msgstr "Nome del filtro file"
+msgstr "Nome del file dello spazio di lavoro (workspace)"
 #: ../general/g.gui/main.c:58
 msgid "Update default GUI setting"
@@ -14738,12 +14032,12 @@
 #: ../general/g.findfile/main.c:54
 #, fuzzy
 msgid "Name of an existing map"
+msgstr "Nome di una mappa esistente"
 #: ../general/g.findfile/main.c:60
 #, fuzzy
 msgid "Name of a mapset"
+msgstr "Nome di un mapset"
 #: ../general/g.findfile/main.c:65
 msgid "Don't add quotes"
@@ -14751,9 +14045,7 @@
 #: ../general/g.findfile/main.c:79
 #, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%"
-"s> does not correspond"
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
 msgstr ""
 #: ../display/d.profile/main.c:61 ../display/d.font/main.c:46
@@ -14783,18 +14075,16 @@
 msgstr ""
 #: ../display/d.profile/main.c:71
-#, fuzzy
 msgid "Raster map to be profiled"
+msgstr ""
 #: ../display/d.profile/main.c:78
 msgid "Optional display raster"
 msgstr ""
 #: ../display/d.profile/main.c:85
-#, fuzzy
 msgid "Output profile data to file(s) with prefix 'name'"
-msgstr "Mostra il titolo del file raster"
+msgstr ""
 #: ../display/d.profile/main.c:106
 #, c-format
@@ -14835,7 +14125,7 @@
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:97
 #: ../imagery/i.class/main.c:90
 msgid "No graphics device selected"
-msgstr "Nessun device grafico selezionato"
+msgstr "Nessun dispositivo grafico selezionato"
 #: ../display/d.profile/main.c:199 ../display/d.profile/main.c:393
 msgid "Use 'd.frame -e' to remove left over frames"
@@ -14844,12 +14134,12 @@
 #: ../display/d.profile/main.c:283
 #, fuzzy
 msgid "Error opening cell-file"
-msgstr "Errore nell'apertura del file g3d"
+msgstr "Errore nell'apertura del file di celle"
 #: ../display/d.profile/main.c:285
 #, fuzzy
 msgid "Error reading from cell-file"
-msgstr "Non riesco a trovare il file raster %s"
+msgstr "Errore nella lettura del file di celle"
 #: ../display/d.profile/main.c:287
 msgid "Mysterious window inconsistancy error"
@@ -14858,12 +14148,12 @@
 #: ../display/d.profile/main.c:430
 #, fuzzy, c-format
 msgid "%s: Couldn't open raster <%s@%s>"
-msgstr "Impossibile aprire <%s>"
+msgstr "%s: Impossibile aprire il raster <%s@%s>"
 #: ../display/d.profile/main.c:434
 #, fuzzy, c-format
 msgid "%s: Couldn't read color table for <%s@%s>"
+msgstr "%s: Impossibile leggere la tavola dei colori per <%s@%s>"
 #: ../display/d.profile/What.c:29
 msgid "Error reading raster map"
@@ -14889,22 +14179,17 @@
 msgstr ""
 #: ../display/d.font/main.c:48 ../display/d.font.freetype/main.c:61
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
-msgstr ""
-"Seleziona il tipo di carattere con cui il testo deve essere rappresentato "
-"nel monitor grafico dell'utente."
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
+msgstr "Seleziona il tipo di carattere con cui il testo deve essere rappresentato nel monitor grafico dell'utente."
 #: ../display/d.font/main.c:56
-#, fuzzy
 msgid "Choose new current font"
-msgstr "Utilizza la regione corrente"
+msgstr ""
 #: ../display/d.font/main.c:63
 #, fuzzy
 msgid "Path to Freetype-compatible font including file name"
-msgstr "Percorso del carattere TrueType (nome del file incluso)"
+msgstr "Percorso del font compatibile con Freetype nome del file incluso"
 #: ../display/d.font/main.c:71 ../display/d.font.freetype/main.c:75
 msgid "Character encoding"
@@ -14913,17 +14198,17 @@
 #: ../display/d.font/main.c:75
 #, fuzzy
 msgid "List fonts"
+msgstr "Lista dei font"
 #: ../display/d.font/main.c:79
 #, fuzzy
 msgid "List fonts verbosely"
+msgstr "Elenca i font in modo dettagliato"
 #: ../display/d.font/main.c:105
 #, fuzzy, c-format
 msgid "Unable to access font path %s: %s"
-msgstr "Impossibile leggere l'input: %s"
+msgstr "Non è possibile accedere al percorso dei font %s: %s"
 #: ../display/d.font/main.c:109
 #, c-format
@@ -14932,20 +14217,17 @@
 #: ../display/d.font/main.c:126
 #, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
 msgstr ""
 #: ../display/d.rast.arrow/arrow.c:112
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
 msgstr ""
 #: ../display/d.rast.arrow/arrow.c:121
 #, fuzzy
 msgid "Name of raster aspect map to be displayed"
-msgstr "Nome del raster map in output"
+msgstr "Nome della mappa raster delle esposizioni da visualizzare"
 #: ../display/d.rast.arrow/arrow.c:129
 msgid "Type of existing raster aspect map"
@@ -14974,7 +14256,7 @@
 #: ../display/d.rast.arrow/arrow.c:177
 #, fuzzy
 msgid "Raster map containing values used for arrow length"
-msgstr "Mappa raster che contiene i valori delle altezze"
+msgstr "Mappa raster che contiene i valori utilizzati per la lunghezza della freccia"
 #: ../display/d.rast.arrow/arrow.c:184
 msgid "Scale factor for arrows (magnitude map)"
@@ -14983,12 +14265,11 @@
 #: ../display/d.rast.arrow/arrow.c:224
 #, fuzzy
 msgid "Illegal value for scale factor"
-msgstr "Valore da impostare a null non valido"
+msgstr "Valore per il fattore di scala non valido"
 #: ../display/d.rast.arrow/arrow.c:228
-#, fuzzy
 msgid "Illegal value for skip factor"
+msgstr ""
 #: ../display/d.rast.arrow/arrow.c:233
 msgid "Magnitude is only supported for GRASS and compass aspect maps."
@@ -15044,18 +14325,15 @@
 msgstr ""
 #: ../display/d.rast.arrow/arrow.c:313
-#, fuzzy
 msgid "Problem reading range file"
+msgstr ""
 #: ../display/d.rast.arrow/arrow.c:368
 msgid "No raster map exists in the current window"
 msgstr ""
 #: ../display/d.text.new/main.c:144 ../display/d.text/main.c:68
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
 msgstr ""
 #: ../display/d.text.new/main.c:150 ../display/d.text.freetype/main.c:146
@@ -15074,16 +14352,14 @@
 #: ../display/d.text.new/main.c:175
 #, fuzzy
 msgid "Text background color, either a standard GRASS color or R:G:B triplet"
-msgstr "nessuno"
+msgstr "Colore per lo sfondo del testo, o un colore GRASS standard o una tripletta R:G:B"
 #: ../display/d.text.new/main.c:184 ../display/d.text/main.c:94
 msgid "The screen line number on which text will begin to be drawn"
 msgstr ""
 #: ../display/d.text.new/main.c:192 ../display/d.text/main.c:103
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
 msgstr ""
 #: ../display/d.text.new/main.c:200 ../display/d.text.freetype/main.c:209
@@ -15103,12 +14379,12 @@
 #: ../display/d.vect/main.c:306 ../vector/v.label/main.c:123
 #, fuzzy
 msgid "Font name"
-msgstr "nome tabella"
+msgstr "Nome del font"
 #: ../display/d.text.new/main.c:227
 #, fuzzy
 msgid "Path to font file"
+msgstr "Percorso del file del font"
 #: ../display/d.text.new/main.c:235
 msgid "Text encoding (only applicable to TrueType fonts)"
@@ -15123,9 +14399,8 @@
 msgstr ""
 #: ../display/d.text.new/main.c:247 ../display/d.text.freetype/main.c:232
-#, fuzzy
 msgid "Screen position in geographic coordinates"
+msgstr ""
 #: ../display/d.text.new/main.c:251 ../display/d.text.freetype/main.c:236
 #: ../display/d.text/main.c:114
@@ -15150,7 +14425,7 @@
 #: ../display/d.text.new/main.c:345
 msgid "Invalid coordinates"
-msgstr "Coordinate non validi"
+msgstr "Coordinate non valide"
 #: ../display/d.text.new/main.c:413
 #, c-format
@@ -15170,9 +14445,9 @@
 msgstr ""
 #: ../display/d.text.new/main.c:633
-#, fuzzy, c-format
+#, c-format
 msgid " Left:    Place text here\n"
-msgstr " Sinistro:  mostra cosa c'è qui\n"
+msgstr ""
 #: ../display/d.text.new/main.c:634
 #, c-format
@@ -15186,13 +14461,8 @@
 msgstr ""
 #: ../display/d.grid/main.c:53
-#, fuzzy
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
 msgstr ""
 #: ../display/d.grid/main.c:61
 msgid "Size of grid to be drawn"
@@ -15203,9 +14473,8 @@
 msgstr ""
 #: ../display/d.grid/main.c:71
-#, fuzzy
 msgid "Lines of the grid pass through this coordinate"
-msgstr "Numero di passi attraverso il dataset"
+msgstr ""
 #: ../display/d.grid/main.c:75
 msgid "Grid color"
@@ -15233,7 +14502,7 @@
 #: ../vector/v.lrs/v.lrs.label/main.c:193 ../vector/v.label/main.c:152
 #, fuzzy
 msgid "Text color"
-msgstr " colore predefinito\n"
+msgstr "Colore del testo"
 #: ../display/d.grid/main.c:95
 msgid "Font size for gridline coordinate labels"
@@ -15303,9 +14572,7 @@
 msgid ""
 "WGS84 grid output not possible as this location does not contain\n"
 "datum transformation parameters. Try running g.setproj."
-msgstr ""
+msgstr "Output WGS84 impossible a causa dell'assenza di parametri di trasformazione del datum in questa location. Provare ad eseguire g.setproj."
 #: ../display/d.grid/plot.c:487
 msgid "Error in pj_do_proj1"
@@ -15328,35 +14595,28 @@
 msgstr ""
 #: ../display/d.grid/fiducial.c:52
-#, fuzzy
 msgid "Reading symbol"
+msgstr ""
 #: ../display/d.frame/frame.c:62
-#, fuzzy
 msgid "Manages display frames on the user's graphics monitor."
 msgstr ""
 #: ../display/d.frame/frame.c:66
-#, fuzzy
 msgid "Create a new frame"
+msgstr ""
 #: ../display/d.frame/frame.c:70
-#, fuzzy
 msgid "Select a frame"
-msgstr "Estrae dati dal database."
+msgstr ""
 #: ../display/d.frame/frame.c:74 ../display/d.erase/main.c:47
 msgid "Remove all frames and erase the screen"
 msgstr ""
 #: ../display/d.frame/frame.c:78
-#, fuzzy
 msgid "Print name of current frame"
-msgstr "Stampa la regione corrente"
+msgstr ""
 #: ../display/d.frame/frame.c:82
 msgid "Print names of all frames"
@@ -15365,7 +14625,7 @@
 #: ../display/d.frame/frame.c:86
 #, fuzzy
 msgid "List map names displayed in GRASS monitor"
-msgstr "Non è mostrata nessuna mappa nel monitor GRASS"
+msgstr "Elenca i nomi di mappa visualizzati nel monitor GRASS"
 #: ../display/d.frame/frame.c:90
 msgid "Debugging output"
@@ -15376,9 +14636,8 @@
 msgstr "nnome"
 #: ../display/d.frame/frame.c:98
-#, fuzzy
 msgid "Frame to be created/selected"
+msgstr ""
 #: ../display/d.frame/frame.c:102
 msgid "bottom,top,left,right"
@@ -15389,9 +14648,9 @@
 msgstr ""
 #: ../display/d.frame/select.c:41
-#, fuzzy, c-format
+#, c-format
 msgid "Error choosing frame [%s]\n"
-msgstr "Errore nel leggere il range di [%s]"
+msgstr ""
 #: ../display/d.frame/select.c:51
 #, c-format
@@ -15403,9 +14662,9 @@
 "Bottoni:\n"
 #: ../display/d.frame/select.c:52
-#, fuzzy, c-format
+#, c-format
 msgid "Left:   Select frame\n"
+msgstr ""
 #: ../display/d.frame/select.c:53
 #, c-format
@@ -15413,18 +14672,16 @@
 msgstr ""
 #: ../display/d.frame/select.c:54
-#, fuzzy, c-format
+#, c-format
 msgid "Right:  Accept frame\n"
-msgstr "%s Esce dal menu\n"
+msgstr ""
 #: ../display/d.erase/main.c:34
 msgid "Erase the contents of the active display frame with user defined color"
 msgstr ""
 #: ../display/d.erase/main.c:42
-msgid ""
-"Color to erase with, either a standard GRASS color or R:G:B triplet "
-"(separated by colons)"
+msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
 msgstr ""
 #: ../display/d.erase/main.c:52 ../display/d.rgb/main.c:65
@@ -15442,16 +14699,13 @@
 msgstr ""
 #: ../display/d.geodesic/main.c:47
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
 msgstr ""
 #: ../display/d.geodesic/main.c:56 ../display/d.path/main.c:66
 #: ../display/d.rhumbline/main.c:55
-#, fuzzy
 msgid "Starting and ending coordinates"
+msgstr ""
 #: ../display/d.geodesic/main.c:62 ../display/d.rhumbline/main.c:61
 #: ../display/d.vect/main.c:166
@@ -15461,12 +14715,12 @@
 #: ../display/d.geodesic/main.c:70
 #, fuzzy
 msgid "Text color or \"none\""
+msgstr "Colore del testo o  \"none\""
 #: ../display/d.geodesic/main.c:78 ../display/d.rhumbline/main.c:79
 #, fuzzy, c-format
 msgid "Location is not %s"
-msgstr "Location: %s\n"
+msgstr "La location non è %s"
 #: ../display/d.geodesic/main.c:83 ../display/d.path/main.c:143
 #: ../display/d.rhumbline/main.c:85
@@ -15479,15 +14733,11 @@
 #: ../display/d.rhumbline/main.c:98 ../display/d.rhumbline/main.c:102
 #, fuzzy, c-format
 msgid "%s - illegal longitude"
-msgstr "%s - valore x non valido"
+msgstr "%s - longitudine non valida"
 #: ../display/d.menu/main.c:68
-#, fuzzy
-msgid ""
-"Creates and displays a menu within the active frame on the graphics monitor."
+msgid "Creates and displays a menu within the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.menu/main.c:77
 msgid "Sets the color of the menu background"
@@ -15523,56 +14773,51 @@
 #: ../display/drivers/XDRIVER/Graph_set.c:112
 #, fuzzy
 msgid "searching for highest bit depth"
-msgstr "ricerca del valore massimo di bit depth\n"
+msgstr "ricerca del valore massimo di bit depth"
 #: ../display/drivers/XDRIVER/Graph_set.c:128
 #, fuzzy, c-format
 msgid "selected %d bit depth"
-msgstr "bit depth %d selezionata\n"
+msgstr "bit depth %d selezionata"
 #: ../display/drivers/XDRIVER/Graph_set.c:188
 #, fuzzy, c-format
 msgid "using default visual which is %s"
-msgstr "la vista predefinita utilizzata è %s\n"
+msgstr "si sta usando la vista predefinita che è %s"
 #: ../display/drivers/XDRIVER/Get_w_box.c:34
 #: ../display/drivers/XDRIVER/Get_w_pointer.c:21
 #: ../display/drivers/XDRIVER/Get_w_line.c:35
 #, fuzzy
 msgid "Monitor: interactive command in redraw"
-msgstr "Monitore: comandi interattivi per il ridisegnamento\n"
+msgstr "Monitor: comandi interattivi per il ridisegnamento"
 #: ../display/drivers/XDRIVER/Serve_Xevent.c:125
 #, fuzzy, c-format
 msgid "Monitor: waitpid: expected %d but got %d"
-msgstr "Monitor: waitpid: atteso %d ma ricevuto %d\n"
+msgstr "Monitor: waitpid: atteso %d ma ricevuto %d"
 #: ../display/drivers/XDRIVER/Serve_Xevent.c:331
 #, fuzzy
 msgid "Monitor: XGetWMName failed"
-msgstr "Monitor: XGetWMName fallito\n"
+msgstr "Monitor: XGetWMName fallito"
 #: ../display/drivers/XDRIVER/Serve_Xevent.c:336
 #, fuzzy
 msgid "Monitor: XGetWMName: bad result"
-msgstr "Monitor: XGetWMName: risultato sbagliato\n"
+msgstr "Monitor: XGetWMName: risultato sbagliato"
 #: ../display/d.font.freetype/main.c:68
-#, fuzzy
 msgid "Font name or pathname of TTF file"
-msgstr "Nome di un nuovo file raster"
+msgstr ""
 #: ../display/d.font.freetype/main.c:173
 #, fuzzy
 msgid "Setting release of FreeType"
-msgstr ""
-"\n"
-"Imposta la versione di FreeType\n"
+msgstr "Imposta la versione di FreeType"
 #: ../display/d.ask/main.c:38
-msgid ""
-"Prompts the user to select a GRASS data base file from among files displayed "
-"in a menu on the graphics monitor."
+msgid "Prompts the user to select a GRASS data base file from among files displayed in a menu on the graphics monitor."
 msgstr ""
 #: ../display/d.ask/main.c:46
@@ -15580,9 +14825,8 @@
 msgstr ""
 #: ../display/d.ask/main.c:52
-#, fuzzy
 msgid "Short user prompt message"
+msgstr ""
 #: ../display/d.ask/main.c:85
 #, c-format
@@ -15607,7 +14851,7 @@
 #: ../vector/v.net.steiner/main.c:359 ../vector/v.net.path/main.c:50
 #, fuzzy
 msgid "Arc type"
-msgstr "Tipo di grafico"
+msgstr "Tipo di arco"
 #: ../display/d.path/main.c:71 ../vector/v.net.alloc/main.c:80
 #: ../vector/v.net/main.c:82 ../vector/v.net.iso/main.c:89
@@ -15639,18 +14883,17 @@
 #: ../display/d.path/main.c:100 ../display/d.extract/main.c:65
 #, fuzzy
 msgid "Original line color"
-msgstr "Colore del bordo"
+msgstr "Colore della linea originale"
 #: ../display/d.path/main.c:102 ../display/d.path/main.c:110
 #: ../display/d.path/main.c:118 ../display/d.path/main.c:128
-#, fuzzy
 msgid "Rendering"
+msgstr ""
 #: ../display/d.path/main.c:108 ../display/d.extract/main.c:71
 #, fuzzy
 msgid "Highlight color"
-msgstr "Colore di evidenziazione del testo"
+msgstr "Colore di evidenziazione"
 #: ../display/d.path/main.c:123 ../vector/v.net.alloc/main.c:117
 #: ../vector/v.net.iso/main.c:127 ../vector/v.net.salesman/main.c:136
@@ -15689,13 +14932,12 @@
 "Mouse Buttons:"
 msgstr ""
 "\n"
-"\n"
-"Bottoni:\n"
+"Tasti del mouse"
 #: ../display/d.path/select.c:36
-#, fuzzy, c-format
+#, c-format
 msgid "Left:   Select From\n"
+msgstr ""
 #: ../display/d.path/select.c:37
 #, c-format
@@ -15707,7 +14949,9 @@
 msgid ""
 "Right:  Quit\n"
 "\n"
-msgstr " Destro: esce\n"
+msgstr ""
+" Destro: esce\n"
+"\n"
 #: ../display/d.path/select.c:65 ../display/d.path/select.c:242
 #: ../display/d.path/select.c:259
@@ -15730,7 +14974,9 @@
 msgid ""
 "  Distance to the network = %f, distance from the network = %f\n"
 "\n"
-msgstr " Distanza dalla rete = %f, distanza dalla rete = %f\n"
+msgstr ""
+" Distanza verso la rete = %f, distanza dalla rete = %f\n"
+"\n"
 #: ../display/d.extend/main.c:31
 #: ../locale/scriptstrings/d.split_to_translate.c:2
@@ -15756,14 +15002,13 @@
 msgstr "Modifica interattivamente i valori delle celle in un raster."
 #: ../display/d.rast.edit/cell.c:43
-#, fuzzy
 msgid "Can't clear current graphics window"
+msgstr ""
 #: ../display/d.rast.edit/cell.c:86 ../display/d.rast/display.c:75
 #, fuzzy
 msgid "Cannot use current window"
+msgstr "Non è possibile uilizzare la finestra corrente"
 #: ../display/d.info/main.c:36
 msgid "Display information about the active display monitor"
@@ -15782,9 +15027,8 @@
 msgstr ""
 #: ../display/d.info/main.c:53
-#, fuzzy
 msgid "Display screen rectangle of current region"
+msgstr ""
 #: ../display/d.info/main.c:58
 msgid "Display geographic coordinates and resolution of entire screen"
@@ -15795,9 +15039,7 @@
 msgstr "Mostra numero di colori"
 #: ../display/d.legend/main.c:88
-msgid ""
-"Displays a legend for a raster map in the active frame of the graphics "
-"monitor."
+msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
 msgstr ""
 #: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:90
@@ -15862,7 +15104,7 @@
 #: ../ps/ps.map/ps_clrtbl.c:35
 #, fuzzy, c-format
 msgid "Category file for <%s> not available"
-msgstr "File category per [%s] non disponibile"
+msgstr "File delle categorie per <%s> non disponibile"
 #: ../display/d.legend/main.c:340
 msgid "Legend box lies outside of frame. Text may not display properly."
@@ -15875,12 +15117,12 @@
 #: ../display/d.legend/main.c:355
 #, fuzzy, c-format
 msgid "Range information for <%s> not available (run r.support)"
-msgstr "Informazioni sul range non disponibile (esegui r.support)."
+msgstr "Informazioni sul range non disponibile (eseguire r.support)"
 #: ../display/d.legend/main.c:360
 #, fuzzy
 msgid "Input map contains no data"
-msgstr "Inserisci il vettore con i punti di controllo"
+msgstr "La mappa di input non contiene dati"
 #: ../display/d.legend/main.c:373 ../display/d.legend/main.c:531
 msgid "Color range exceeds lower limit of actual data"
@@ -15906,7 +15148,7 @@
 #: ../display/d.legend/main.c:517 ../display/d.histogram/main.c:171
 #, fuzzy, c-format
 msgid "Range information for <%s> not available"
+msgstr "Informazioni sul range per <%s> non disponibile"
 #: ../display/d.legend/main.c:542
 #, c-format
@@ -15918,12 +15160,8 @@
 msgstr ""
 #: ../display/d.vect.chart/main.c:65
-#, fuzzy
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.vect.chart/main.c:82
 msgid "Chart type"
@@ -15933,9 +15171,8 @@
 #: ../display/d.vect.chart/main.c:105 ../display/d.vect.chart/main.c:112
 #: ../display/d.vect.chart/main.c:120 ../display/d.vect.chart/main.c:129
 #: ../display/d.vect.chart/main.c:135
-#, fuzzy
 msgid "Chart properties"
+msgstr ""
 #: ../display/d.vect.chart/main.c:90
 msgid "Attribute columns containing data"
@@ -15991,27 +15228,21 @@
 #: ../vector/v.to.3d/trans2.c:45 ../doc/vector/v.example/main.c:103
 #, fuzzy, c-format
 msgid "Database connection not defined for layer %d"
-msgstr "Connessione al database non definita\n"
+msgstr "Connessione al database non definita per il tematismo %d"
 #: ../display/d.vect.chart/plot.c:85 ../display/d.vect/attr.c:112
 #: ../vector/v.in.db/main.c:163
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open select cursor: '%s'"
-msgstr "Non riesco ad impostare user/password"
+msgstr ""
 #: ../display/d.rgb/main.c:54
-#, fuzzy
 msgid "display, raster, RGB"
-msgstr "mostra"
+msgstr ""
 #: ../display/d.rgb/main.c:56
-#, fuzzy
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
 msgstr ""
 #: ../display/d.rgb/main.c:61 ../display/d.rast/main.c:88
 msgid "Overlay (non-null values only)"
@@ -16020,17 +15251,15 @@
 #: ../display/d.rgb/main.c:70
 #, fuzzy, c-format
 msgid "Name of raster map to be used for '%s'"
-msgstr "Nome della mappa raster da utilizzare per <%s>"
+msgstr "Nome della mappa raster da utilizzare per '%s'"
 #: ../display/d.rgb/main.c:119
 #, fuzzy
 msgid "Error reading row of data"
+msgstr "Errore nella lettura della riga dei dati"
 #: ../display/d.where/main.c:44
-msgid ""
-"Identifies the geographic coordinates associated with point locations in the "
-"active frame on the graphics monitor."
+msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.where/main.c:49
@@ -16046,9 +15275,7 @@
 msgstr ""
 #: ../display/d.where/main.c:63
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
 msgstr ""
 #: ../display/d.where/main.c:69
@@ -16070,38 +15297,24 @@
 msgstr ""
 #: ../display/d.rhumbline/main.c:47
-#, fuzzy
-msgid ""
-"Displays the rhumbline joining two user-specified points, in the active "
-"frame on the user's graphics monitor."
+msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
 msgstr ""
 #: ../display/d.mapgraph/main.c:50
-msgid ""
-"Generates and displays simple graphics on map layers drawn in the active "
-"graphics monitor display frame."
+msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
 msgstr ""
 #: ../display/d.mapgraph/main.c:57
-msgid ""
-"Unix file containg graphing instructions, if not given reads from standard "
-"input"
+msgid "Unix file containg graphing instructions, if not given reads from standard input"
 msgstr ""
 #: ../display/d.mapgraph/main.c:67
-msgid ""
-"Color to draw with, either a standard GRASS color or R:G:B triplet "
+msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
 msgstr ""
 #: ../display/d.barscale/main.c:57
-#, fuzzy
 msgid "Displays a barscale on the graphics monitor."
 msgstr ""
 #: ../display/d.barscale/main.c:61
 msgid "Use mouse to interactively place scale"
@@ -16110,7 +15323,7 @@
 #: ../display/d.barscale/main.c:65
 #, fuzzy
 msgid "Use feet/miles instead of meters"
-msgstr "tabelle di sistema invece che tabelle utente"
+msgstr "Usa piedi/miglia al posto dei metri"
 #: ../display/d.barscale/main.c:69
 msgid "Draw a line scale instead of a bar scale"
@@ -16129,9 +15342,7 @@
 msgstr "Disegna solo la barra della scala"
 #: ../display/d.barscale/main.c:98
-msgid ""
-"The screen coordinates for top-left corner of label ([0,0] is top-left of "
-"frame)"
+msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
 msgstr ""
 #: ../display/d.barscale/main.c:106
@@ -16144,23 +15355,16 @@
 msgstr ""
 #: ../display/d.measure/main.c:51
-#, fuzzy
-msgid ""
-"Measures the lengths and areas of features drawn by the user in the active "
-"display frame on the graphics monitor."
+msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
 msgstr ""
 #: ../display/d.measure/main.c:57
-#, fuzzy
 msgid "Line color 1"
-msgstr " nv colore\n"
+msgstr ""
 #: ../display/d.measure/main.c:65
-#, fuzzy
 msgid "Line color 2"
+msgstr ""
 #: ../display/d.measure/main.c:73
 msgid "Suppress clear screen"
@@ -16175,9 +15379,7 @@
 msgstr ""
 #: ../display/d.text.freetype/main.c:140
-msgid ""
-"Draws text in the graphics monitor's active display frame using TrueType "
-"fonts."
+msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
 msgstr ""
 #: ../display/d.text.freetype/main.c:154
@@ -16197,9 +15399,8 @@
 msgstr ""
 #: ../display/d.text.freetype/main.c:255
-#, fuzzy
 msgid "Either text or -c should be given"
-msgstr "Devono essere fornite sia l'opzione 'from_table' che 'select' "
+msgstr ""
 #: ../display/d.text.freetype/main.c:260
 msgid "Choose only one coordinate system for placement"
@@ -16227,7 +15428,7 @@
 #: ../display/d.text.freetype/main.c:478
 #, fuzzy
 msgid "Unable to set size"
-msgstr "impossibile aprire <%s>"
+msgstr "impossibile impostare la dimensione"
 #: ../display/d.text.freetype/main.c:349 ../display/d.text.freetype/main.c:568
 msgid "Unable to create text conversion context"
@@ -16240,12 +15441,12 @@
 #: ../display/d.text.freetype/main.c:415
 #, fuzzy
 msgid "Unable to write the temporary file"
-msgstr "Valore da scrivere per null"
+msgstr "Non è possibile scrivere il file temporaneo"
 #: ../display/d.text.freetype/main.c:435
 #, fuzzy
 msgid "No predefined font"
-msgstr "Nome del file con le regole predefinite"
+msgstr "Nessun font predefinito"
 #: ../display/d.text.freetype/main.c:451
 #, c-format
@@ -16268,9 +15469,7 @@
 msgstr ""
 #: ../display/d.his/main.c:67
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(his) values from user-specified input raster map layers."
+msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
 msgstr ""
 #: ../display/d.his/main.c:95
@@ -16278,9 +15477,8 @@
 msgstr ""
 #: ../display/d.his/main.c:120 ../display/d.what.rast/main.c:119
-#, fuzzy
 msgid "No current graphics window"
+msgstr ""
 #: ../display/d.his/main.c:123 ../display/d.what.rast/main.c:122
 msgid "Current graphics window not available"
@@ -16289,34 +15487,30 @@
 #: ../display/d.his/main.c:219
 #, fuzzy
 msgid "Error reading hue data"
+msgstr "Errore nella lettura dei dati di tonalità"
 #: ../display/d.his/main.c:224
 #, fuzzy
 msgid "Error reading intensity data"
+msgstr "Errore nella lettura dei dati di intensità"
 #: ../display/d.his/main.c:229
 #, fuzzy
 msgid "Error reading saturation data"
+msgstr "Errore nella lettura dei dati di saturazione"
 #: ../display/d.what.rast/main.c:54
-msgid ""
-"Allows the user to interactively query the category contents of multiple "
-"raster map layers at user specified locations within the current geographic "
-"region."
+msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
 msgstr ""
 #: ../display/d.what.rast/main.c:89
 #, fuzzy
 msgid "Field separator (terse mode only)"
+msgstr "Separatore di campo (solo in modalità concisa)"
 #: ../display/d.what.rast/main.c:94 ../display/d.what.vect/main.c:74
-#, fuzzy
 msgid "Identify just one location"
-msgstr "locazione del database"
+msgstr ""
 #: ../display/d.what.rast/main.c:98 ../display/d.what.vect/main.c:89
 msgid "Terse output. For parsing by programs"
@@ -16333,25 +15527,19 @@
 #: ../display/d.what.rast/main.c:131
 #, fuzzy
 msgid "Can't set current graphics window"
+msgstr "Impossibile impostare la finestra grafica corrente"
 #: ../display/d.what.rast/main.c:135
-#, fuzzy
 msgid "Getting graphics window coordinates"
+msgstr ""
 #: ../display/d.what.rast/what.c:57
 msgid "You are clicking outside the map"
 msgstr "Stai cliccando fuori la mappa"
 #: ../display/d.thematic.area/main.c:80
-#, fuzzy
-msgid ""
-"Displays a thematic vector area map in the active frame on the graphics "
-"monitor."
+msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.thematic.area/main.c:90
 msgid "Data to be classified: column name or expression"
@@ -16364,18 +15552,16 @@
 #: ../display/d.thematic.area/main.c:105 ../vector/v.class/main.c:68
 #, fuzzy
 msgid "Algorithm to use for classification"
-msgstr "Nome del file con il risultato della classificazione"
+msgstr "Algoritmo da usare per la classificazione"
 #: ../display/d.thematic.area/main.c:106 ../vector/v.class/main.c:69
-msgid ""
-"int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable "
-"(normal distribution);"
+msgid "int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable (normal distribution);"
 msgstr ""
 #: ../display/d.thematic.area/main.c:117 ../vector/v.class/main.c:80
 #, fuzzy
 msgid "Number of classes to define"
-msgstr "Nume di righe da tenere in memoria"
+msgstr "Numero di classi da definire"
 #: ../display/d.thematic.area/main.c:124
 msgid "Colors (one per class)."
@@ -16414,7 +15600,7 @@
 #: ../vector/v.net.centrality/main.c:107 ../vector/v.net.centrality/main.c:109
 #, fuzzy
 msgid "Selection"
-msgstr "Risoluzione"
+msgstr "Selezionee"
 #: ../display/d.thematic.area/main.c:140 ../display/d.thematic.area/main.c:148
 msgid "Boundaries"
@@ -16434,10 +15620,7 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:160
-msgid ""
-"d;use the display library basic functions (features: polylines);c;use the "
-"display library clipping functions (features: clipping);l;use the display "
-"library culling functions (features: culling, polylines)"
+msgid "d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
 msgstr ""
 #: ../display/d.thematic.area/main.c:168
@@ -16445,36 +15628,33 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:179
-msgid ""
-"When printing legend info , include extended statistical info from "
-"classification algorithm"
+msgid "When printing legend info , include extended statistical info from classification algorithm"
 msgstr ""
 #: ../display/d.thematic.area/main.c:183
-#, fuzzy
 msgid "Do not draw map, only output the legend"
-msgstr "Non allineare l'output con l'input"
+msgstr ""
 #: ../display/d.thematic.area/main.c:196
 #, fuzzy, c-format
 msgid "Invalid rendering method <%s>"
+msgstr "Metodo di rendering <%s> non valido"
 #: ../display/d.thematic.area/main.c:218
 #, fuzzy, c-format
 msgid "%s: You must build topology on vector map. Run v.build."
-msgstr "Devi creare la topologia sul vettore <%s>"
+msgstr "%s: Si deve creare la topologia sulla mappa vettoriale. Eseguire v.build"
 #: ../display/d.thematic.area/main.c:225
 #, fuzzy
 msgid "'layer' must be > 0"
-msgstr "'%s' dev'essere > 0 per '%s'"
+msgstr "'layer' dev'essere > 0"
 #: ../display/d.thematic.area/main.c:227 ../display/d.what.vect/what.c:446
 #: ../display/d.vect/main.c:510 ../vector/v.db.connect/main.c:171
 #, fuzzy, c-format
 msgid "Database connection not defined"
+msgstr "Connessione al database non definita"
 #: ../display/d.thematic.area/main.c:231 ../display/d.vect/main.c:514
 #: ../vector/v.out.svg/main.c:141 ../vector/v.extract/main.c:286
@@ -16488,7 +15668,7 @@
 #: ../db/base/databases.c:52 ../db/base/select.c:67 ../db/base/dropdb.c:43
 #, c-format
 msgid "Unable to start driver <%s>"
-msgstr "Impossibile avviare il driver '%s'"
+msgstr "Impossibile avviare il driver <%s>"
 #: ../display/d.thematic.area/main.c:236 ../display/d.vect/main.c:519
 #: ../vector/v.convert/att.c:73 ../db/base/describe.c:57
@@ -16500,7 +15680,7 @@
 #: ../display/d.thematic.area/main.c:251
 #, fuzzy, c-format
 msgid "Data (%s) not numeric. Column must be numeric."
-msgstr "Nessuna mappa in input specificata"
+msgstr "I dati (%s) non sono numerici. La colonna dev'essere di tipo numerico"
 #: ../display/d.thematic.area/main.c:255
 #: ../display/d.thematic.area/plot1.c:222
@@ -16510,17 +15690,15 @@
 #: ../display/d.vect/plot1.c:321
 #, fuzzy, c-format
 msgid "Cannot select data (%s) from table"
-msgstr "Non riesco a mostrare i database"
+msgstr "Impossibile selezionare i dati (%s) dalla tabella"
 #: ../display/d.thematic.area/main.c:318 ../display/d.vect/main.c:471
 #, fuzzy, c-format
 msgid "Unknown color: [%s]"
-msgstr "%s - colore sconosciuto\n"
+msgstr "Colore sconosciuto: [%s]"
 #: ../display/d.thematic.area/main.c:329
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
 msgstr ""
 #: ../display/d.thematic.area/main.c:366
@@ -16537,27 +15715,25 @@
 #: ../display/d.thematic.area/main.c:384
 #, fuzzy, c-format
 msgid "Error interpreting color %s"
-msgstr "Errore nella lettura del file dbmscap\n"
+msgstr "Errore nell'interpretazione del colore %s"
 #: ../display/d.thematic.area/main.c:402 ../display/d.vect/main.c:652
-#, fuzzy
 msgid "Plotting ..."
-msgstr "Sto disegnando ..."
+msgstr ""
 #: ../display/d.thematic.area/main.c:409 ../display/d.vect/main.c:660
 #, fuzzy
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
-msgstr ""
-"Il box di confine della mappa è al di fuori della regione in uso, non "
-"verràvisualizzato nulla.\n"
+msgid "The bounding box of the map is outside the current region, nothing drawn."
+msgstr "Il box di confine della mappa è al di fuori della regione in uso, non verrà visualizzato nulla."
 #: ../display/d.thematic.area/main.c:458
 #, fuzzy, c-format
 msgid ""
 "\n"
 "Total number of records: %.0f\n"
+msgstr ""
+"\n"
+"Numero totale di record: %.0f\n"
 #: ../display/d.thematic.area/main.c:460
 #, c-format
@@ -16572,7 +15748,7 @@
 #: ../display/d.thematic.area/main.c:464 ../vector/v.class/main.c:196
 #, fuzzy, c-format
 msgid "Mean: %f\tStandard deviation = %f\n"
-msgstr "Deviazione standard"
+msgstr "Media: %f\tDeviazione standard = %f\n"
 #: ../display/d.thematic.area/main.c:468
 #, c-format
@@ -16585,23 +15761,19 @@
 msgstr ""
 #: ../display/d.thematic.area/plot1.c:207 ../display/d.vect/plot1.c:216
-#, fuzzy
 msgid "Color definition column not specified"
+msgstr ""
 #: ../display/d.thematic.area/plot1.c:217 ../display/d.vect/area.c:79
 #: ../display/d.vect/plot1.c:226
 #, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
-"BBB where RGB values range 0-255."
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
 msgstr ""
 #: ../display/d.thematic.area/plot1.c:235 ../display/d.vect/area.c:98
 #: ../display/d.vect/plot1.c:244
-#, fuzzy
 msgid "Line width column not specified."
+msgstr ""
 #: ../display/d.thematic.area/plot1.c:246 ../display/d.vect/area.c:109
 #, c-format
@@ -16619,9 +15791,7 @@
 #: ../display/d.thematic.area/plot1.c:366
 #, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring [%"
-"s]"
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
 msgstr ""
 #: ../display/d.thematic.area/plot1.c:373
@@ -16632,8 +15802,7 @@
 #: ../display/d.thematic.area/plot1.c:441 ../display/d.vect/area.c:345
 #: ../display/d.vect/plot1.c:537
 #, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
 msgstr ""
 #: ../display/d.save/main.c:81
@@ -16641,20 +15810,15 @@
 msgstr ""
 #: ../display/d.save/main.c:86
-#, fuzzy
 msgid "Name of frame(s) to save"
-msgstr "Nome della mappa raster"
+msgstr ""
 #: ../display/d.save/main.c:126
-msgid ""
-"List of object numbers to remove which are displayed after \"#\". -1 for the "
-"last object."
+msgid "List of object numbers to remove which are displayed after \"#\". -1 for the last object."
 msgstr ""
 #: ../display/d.save/main.c:134
-msgid ""
-"List of object numbers to move (\"from\" to \"to\"). remove= option will be "
-"done first, if any."
+msgid "List of object numbers to move (\"from\" to \"to\"). remove= option will be done first, if any."
 msgstr ""
 #: ../display/d.save/main.c:143
@@ -16681,26 +15845,24 @@
 #: ../display/d.colortable/main.c:64
 #, fuzzy
 msgid "Displays the color table associated with a raster map layer."
-msgstr "Crea/Modifica la tabella colore associata ad un raster"
+msgstr "Visualizza la tavola dei colori associata ad un tematismo raster"
 #: ../display/d.colortable/main.c:68
 #, fuzzy
 msgid "Name of raster map whose color table is to be displayed"
+msgstr "Nome della mappa raster la cui tavola dei colori dev'essere visualizzata"
 #: ../display/d.colortable/main.c:76
 msgid "Color of lines separating the colors of the color table"
 msgstr ""
 #: ../display/d.colortable/main.c:82
-#, fuzzy
 msgid "Number of lines to appear in the color table"
+msgstr ""
 #: ../display/d.colortable/main.c:88
-#, fuzzy
 msgid "Number of columns to appear in the color table"
+msgstr ""
 #: ../display/d.colortable/main.c:93
 msgid "Don't draw a collar showing the NULL color in FP maps"
@@ -16708,32 +15870,28 @@
 #: ../display/d.colortable/main.c:118
 #, c-format
-msgid ""
-"<%s> is a floating point map. Ignoring [lines] and drawing continuous color "
-"ramp"
+msgid "<%s> is a floating point map. Ignoring [lines] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:132
 #, c-format
-msgid ""
-"<%s> is a floating point map. Ignoring [cols] and drawing continuous color "
-"ramp"
+msgid "<%s> is a floating point map. Ignoring [cols] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:141
-#, fuzzy, c-format
+#, c-format
 msgid "R_color file for [%s] not available"
-msgstr "file raster per la Vista%d"
+msgstr ""
 #: ../display/d.colortable/main.c:143
-#, fuzzy, c-format
+#, c-format
 msgid "Range file for [%s] not available"
+msgstr ""
 #: ../display/d.colortable/main.c:156
 #, fuzzy
 msgid "Data range is empty"
-msgstr "L'intervallo dati è da %ld a %ld\n"
+msgstr "L'intervallo dati è vuoto"
 #: ../display/d.extract/main.c:52
 msgid "Selects and extracts vectors with mouse into new vector map."
@@ -16744,9 +15902,8 @@
 msgstr "Sto copiando le tabelle..."
 #: ../display/d.extract/main.c:125
-#, fuzzy
 msgid "Cannot get db link info -> cannot copy table."
+msgstr ""
 #: ../display/d.extract/extract.c:44
 msgid "Select vector(s) with mouse"
@@ -16769,15 +15926,13 @@
 msgstr "L: aggiungi  M: rimuovi  R: esci e salva\n"
 #: ../display/d.histogram/main.c:73
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
 msgstr ""
 #: ../display/d.histogram/main.c:77
 #, fuzzy
 msgid "Raster map for which histogram will be displayed"
-msgstr "Mappa(e) raster da leggere"
+msgstr "Mappa raster per la quale visualizzare l'istogramma"
 #: ../display/d.histogram/main.c:81
 msgid "Indicate if a pie or bar chart is desired"
@@ -16808,36 +15963,29 @@
 msgstr ""
 #: ../display/d.histogram/main.c:149
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid number of steps: %s"
-msgstr "Area: %d  Numero di isole: %d\n"
+msgstr ""
 #: ../display/d.histogram/main.c:154
 msgid "When -C flag is set, the nsteps argument is ignored"
 msgstr ""
 #: ../display/d.linegraph/linegraph.c:115
-#, fuzzy
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
 msgstr ""
 #: ../display/d.linegraph/linegraph.c:119
-#, fuzzy
 msgid "Name of data file for X axis of graph"
+msgstr ""
 #: ../display/d.linegraph/linegraph.c:125
 msgid "Name of data file(s) for Y axis of graph"
 msgstr ""
 #: ../display/d.linegraph/linegraph.c:132
-#, fuzzy
 msgid "Path to file location"
-msgstr "Nome di un file vettoriale in output"
+msgstr ""
 #: ../display/d.linegraph/linegraph.c:139
 msgid "Color for Y data"
@@ -16850,12 +15998,12 @@
 #: ../display/d.linegraph/linegraph.c:156
 #, fuzzy
 msgid "Title for X data"
-msgstr "Titolo della mappa raster risultante"
+msgstr "Titolo per i dati di X"
 #: ../display/d.linegraph/linegraph.c:163
 #, fuzzy
 msgid "Title for Y data"
+msgstr "Titolo per i dati di Y"
 #: ../display/d.linegraph/linegraph.c:170
 msgid "Title for Graph"
@@ -16881,33 +16029,31 @@
 msgstr ""
 #: ../display/d.linegraph/linegraph.c:355
-#, fuzzy, c-format
+#, c-format
 msgid "Problem reading X data file at line %d"
+msgstr ""
 #: ../display/d.linegraph/linegraph.c:366
-#, fuzzy, c-format
+#, c-format
 msgid "Problem reading <%s> data file at line %d"
+msgstr ""
 #: ../display/d.title/main.c:47
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
 msgstr ""
 #: ../display/d.title/main.c:58
 #, fuzzy
 msgid "Sets the text color"
+msgstr "Imposta il colore del testo"
 #: ../display/d.title/main.c:66
 msgid "Sets the text size as percentage of the frame's height"
 msgstr ""
 #: ../display/d.title/main.c:70
-#, fuzzy
 msgid "Draw title on current display"
+msgstr ""
 #: ../display/d.title/main.c:74
 msgid "Do a fancier title"
@@ -16924,17 +16070,14 @@
 #: ../display/d.title/main.c:100
 #, fuzzy
 msgid "No map name given"
+msgstr "Nessun nome di mappa assegnato"
 #: ../display/d.graph/main.c:56
-msgid ""
-"Program for generating and displaying simple graphics on the display monitor."
+msgid "Program for generating and displaying simple graphics on the display monitor."
 msgstr ""
 #: ../display/d.graph/main.c:63
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
+msgid "Name of file containing graphics commands, if not given reads from standard input"
 msgstr ""
 #: ../display/d.graph/main.c:71
@@ -16946,9 +16089,9 @@
 msgstr ""
 #: ../display/d.graph/main.c:89
-#, fuzzy, c-format
+#, c-format
 msgid "Graph file <%s> not found"
-msgstr "raster <%s> non trovato"
+msgstr ""
 #: ../display/d.graph/do_graph.c:54 ../display/d.graph/do_graph.c:83
 #, c-format
@@ -16958,7 +16101,7 @@
 #: ../display/d.graph/do_graph.c:105
 #, fuzzy
 msgid "Unable to read color"
+msgstr "Non è possibile leggere il colore"
 #: ../display/d.graph/do_graph.c:136 ../display/d.graph/do_graph.c:213
 #: ../display/d.graph/do_graph.c:234 ../display/d.graph/do_graph.c:292
@@ -17009,9 +16152,8 @@
 msgstr "Errore - Il monitor '%s' è in uso da un altro utente"
 #: ../display/d.mon/pgms/stop.c:82
-#, fuzzy
 msgid "Error - Locking mechanism failed"
+msgstr ""
 #: ../display/d.mon/pgms/release.c:68
 #, c-format
@@ -17063,7 +16205,7 @@
 #: ../display/d.mon/cmd/main.c:87
 #, fuzzy
 msgid "Print name of currently selected monitor"
+msgstr "Stampa il nome del monitor attualmente selezionato"
 #: ../display/d.mon/cmd/main.c:91
 msgid "Release currently selected monitor"
@@ -17079,9 +16221,7 @@
 msgstr ""
 #: ../display/d.paint.labels/main.c:48
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.paint.labels/main.c:54
@@ -17091,7 +16231,7 @@
 #: ../display/d.paint.labels/main.c:61
 #, fuzzy
 msgid "Name of label file"
+msgstr "Nome del file delle etichette"
 #: ../display/d.paint.labels/main.c:68
 msgid "Minimum region size (diagonal) when labels are displayed"
@@ -17104,24 +16244,20 @@
 #: ../display/d.paint.labels/main.c:87
 #, fuzzy, c-format
 msgid "Label file <%s> not found"
+msgstr "File delle etichette <%s> non trovato"
 #: ../display/d.paint.labels/main.c:102 ../display/d.vect/main.c:431
 msgid "Region size is lower than minreg, nothing displayed."
-msgstr ""
-"La dimensione della regione è inferiore rispetto al valore di minreg, non "
-"verrà visualizzato nulla."
+msgstr "La dimensione della regione è inferiore rispetto al valore di minreg, non verrà visualizzato nulla."
 #: ../display/d.paint.labels/main.c:111 ../display/d.vect/main.c:440
 msgid "Region size is greater than maxreg, nothing displayed."
-msgstr ""
-"La dimensione della regione è superiore rispetto al valore di maxreg, non "
+msgstr "La dimensione della regione è superiore rispetto al valore di maxreg, non verrà visualizzato nulla."
 #: ../display/d.paint.labels/main.c:121 ../vector/v.lrs/v.lrs.label/main.c:299
 #, fuzzy, c-format
 msgid "Unable to open label file <%s>"
+msgstr "Non è possibile aprire il file delle etichette <%s>"
 #: ../display/d.paint.labels/do_labels.c:142
 #, c-format
@@ -17129,15 +16265,13 @@
 msgstr "Errore: %s\n"
 #: ../display/d.what.vect/main.c:56
-msgid ""
-"Allows the user to interactively query a vector map layer at user-selected "
-"locations within the current geographic region."
+msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
 msgstr ""
 #: ../display/d.what.vect/main.c:85
 #, fuzzy
 msgid "Name of existing vector map"
+msgstr "Nome della mappa vettoriale esistente"
 #: ../display/d.what.vect/main.c:94
 msgid "Print information as plain text to terminal window"
@@ -17174,7 +16308,7 @@
 #: ../doc/vector/v.example/main.c:85
 #, fuzzy, c-format
 msgid "Unable to open vector map <%s>"
+msgstr "Impossibile aprire la mappa vettoriale <%s>"
 #: ../display/d.what.vect/main.c:151
 #, c-format
@@ -17185,7 +16319,7 @@
 #: ../vector/v.what/main.c:162
 #, fuzzy
 msgid "Building spatial index..."
-msgstr "Creazione dell'indice spaziale ..."
+msgstr "Creazione dell'indice spaziale in corso..."
 #: ../display/d.what.vect/what.c:179 ../display/d.what.vect/what.c:181
 #: ../vector/v.what/what.c:105 ../vector/v.what/what.c:107
@@ -17207,7 +16341,7 @@
 #: ../display/d.what.vect/what.c:257
 #, fuzzy, c-format
 msgid "  Node[%d]: %d  Number of lines: %d  Coordinates: %.6f, %.6f, %.6f\n"
-msgstr "  Nodo[%d]: %d Numero di linee: %d\n"
+msgstr "  Nodo[%d]: %d Numero di linee: %d  Coordinate:  %.6f, %.6f, %.6f\n"
 #: ../display/d.what.vect/what.c:266
 #, c-format
@@ -17333,11 +16467,8 @@
 msgstr ""
 #: ../display/d.rast/main.c:52
-#, fuzzy
 msgid "Displays user-specified raster map in the active graphics frame."
 msgstr ""
 #: ../display/d.rast/main.c:57 ../imagery/i.class/main.c:62
 msgid "Name of raster map to be displayed"
@@ -17350,7 +16481,7 @@
 #: ../display/d.rast/main.c:74
 #, fuzzy
 msgid "List of values to be displayed (FP maps)"
+msgstr "Lista dei valori da visualizzare (mappe di valori a virgola mobile [FP])"
 #: ../display/d.rast/main.c:83
 msgid "Background color (for null)"
@@ -17378,17 +16509,12 @@
 #: ../display/d.rast.num/number.c:86
 #, fuzzy
-msgid ""
-"Overlays cell category values on a raster map layer displayed to the "
-msgstr ""
+msgid "Overlays cell category values on a raster map layer displayed to the graphics monitor."
+msgstr "Sovrappone i valori di categoria delle celle su un tematismo raster visualizzato sul monitor grafico"
 #: ../display/d.rast.num/number.c:99
-#, fuzzy
 msgid "Color for drawing grid, or \"none\""
-msgstr "nessuno"
+msgstr ""
 #: ../display/d.rast.num/number.c:108
 msgid "Color for drawing text"
@@ -17405,7 +16531,7 @@
 #: ../display/d.rast.num/number.c:206
 #, fuzzy
 msgid "Current window size:"
-msgstr "Non riesco a descrivere la tabella"
+msgstr "Dimensioni della finestra corrente"
 #: ../display/d.rast.num/number.c:207
 #, fuzzy, c-format
@@ -17420,8 +16546,7 @@
 #: ../display/d.rast.num/number.c:210
 msgid ""
 "\n"
-"Your current window setting may be too large. Cells displayed on your "
-"graphics window may be too small for cell category number to be visible."
+"Your current window setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
 msgstr ""
 #: ../display/d.rast.num/number.c:216
@@ -17435,7 +16560,7 @@
 #: ../display/d.nviz/main.c:74
 #, fuzzy
 msgid "Name of output script"
-msgstr "Nome della mappa di output"
+msgstr "Nome dello script di output"
 #: ../display/d.nviz/main.c:80
 msgid "Prefix of output images (default = NVIZ)"
@@ -17456,7 +16581,7 @@
 #: ../display/d.nviz/main.c:106
 #, fuzzy
 msgid "Number of frames"
-msgstr "Numero di righe"
+msgstr "Numero di riquadri"
 #: ../display/d.nviz/main.c:112
 msgid "Start frame number (default=0)"
@@ -17471,9 +16596,8 @@
 msgstr ""
 #: ../display/d.nviz/main.c:125
-#, fuzzy
 msgid "Fly at constant elevation (ht)"
+msgstr ""
 #: ../display/d.nviz/main.c:130
 msgid "Include command in the script to output a KeyFrame file"
@@ -17514,22 +16638,18 @@
 msgstr ""
 #: ../display/d.nviz/main.c:537
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
 msgstr ""
 #: ../display/d.zoom/main.c:59
-msgid ""
-"Allows the user to change the current geographic region settings "
-"interactively, with a mouse."
+msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
 msgstr ""
 #: ../display/d.zoom/main.c:100
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:4
 #, fuzzy
 msgid "Name of vector map"
+msgstr "Nome della mappa vettoriale"
 #: ../display/d.zoom/main.c:108
 msgid "Magnification: >1.0 zooms in, <1.0 zooms out"
@@ -17562,12 +16682,12 @@
 #: ../display/d.zoom/main.c:162
 #, fuzzy
 msgid "ERROR: can not get \"list\" items"
-msgstr "ERRORE: non riesco ad ottenere la \"lista\" degli oggetti\n"
+msgstr "ERRORE: non riesco ad ottenere la \"lista\" degli oggetti"
 #: ../display/d.zoom/main.c:163
 #, fuzzy
 msgid "-j flag forced"
-msgstr "-j flag forzato\n"
+msgstr "-j flag forzato"
 #: ../display/d.zoom/main.c:196
 msgid "No map is displayed in GRASS monitor"
@@ -17581,7 +16701,7 @@
 #: ../display/d.zoom/main.c:307
 #, fuzzy
 msgid "No previous zoom available"
-msgstr "Non sono presenti zoom precedenti"
+msgstr "Non sono disponibili zoom precedenti"
 #: ../display/d.zoom/main.c:311
 msgid "Returning to previous zoom"
@@ -17605,7 +16725,7 @@
 #: ../display/d.zoom/zoom.c:16
 #, fuzzy, c-format
 msgid "Left:   Zoom menu\n"
-msgstr "%s Zoom menu\n"
+msgstr "Sinistra:   Menù Zoom\n"
 #: ../display/d.zoom/zoom.c:17
 #, c-format
@@ -17615,7 +16735,7 @@
 #: ../display/d.zoom/zoom.c:18
 #, fuzzy, c-format
 msgid "Right:  Quit menu\n"
+msgstr "Destra: Esce dal menu\n"
 #: ../display/d.zoom/zoom.c:40
 #, c-format
@@ -17629,9 +16749,7 @@
 #: ../display/d.zoom/zoom.c:42
 #, c-format
 msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
-msgstr ""
-"Nota: esegue 'd.erase. affinché la nuova regione abbia effetto sul monitor "
-"grafico\n"
+msgstr "Nota: esegue 'd.erase. affinché la nuova regione abbia effetto sul monitor grafico\n"
 #: ../display/d.zoom/pan.c:18
 #, c-format
@@ -17647,36 +16765,28 @@
 #: ../display/d.vect/attr.c:54
 #, fuzzy
 msgid "Can't read vector map"
+msgstr "Impossibile leggere la mappa vettoriale"
 #: ../display/d.vect/main.c:122
-#, fuzzy
 msgid "display, vector"
-msgstr "mostra"
+msgstr ""
 #: ../display/d.vect/main.c:123
-#, fuzzy
 msgid "Displays user-specified vector map in the active graphics frame."
 msgstr ""
 #: ../display/d.vect/main.c:135
 msgid "Display"
 msgstr "Visualizza"
 #: ../display/d.vect/main.c:136
-msgid ""
-"shape;Display geometry of features;cat;Display category numbers of features;"
-"topo;Display topology information (nodes, edges);dir;Display direction of "
-"linear features;attr;Display selected attribute based on 'attrcol';zcoor;"
-"Display z-coordinate of features (only for 3D vector maps)"
+msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
 msgstr ""
 #: ../display/d.vect/main.c:151
 #, fuzzy
 msgid "Layer number (if -1, all layers are displayed)"
-msgstr "Numero di layer. Se -1, tutti i layer sono estratti"
+msgstr "Numero di layer (se -1, tutti i layer sono visualizzati"
 #: ../display/d.vect/main.c:167 ../display/d.vect/main.c:177
 #: ../display/d.vect/main.c:184 ../display/d.vect/main.c:195
@@ -17694,18 +16804,17 @@
 #: ../locale/scriptstrings/v.colors_to_translate.c:14
 #: ../locale/scriptstrings/v.colors_to_translate.c:17
 msgid "Colors"
-msgstr ""
+msgstr "Colori"
 #: ../display/d.vect/main.c:170 ../display/d.vect/main.c:180
 #: ../display/d.vect/main.c:283 ../display/d.vect/main.c:293
-#, fuzzy
 msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr "nessuno"
+msgstr ""
 #: ../display/d.vect/main.c:176
 #, fuzzy
 msgid "Area fill color"
-msgstr " val colore\n"
+msgstr "Colore di riempimento dell'area"
 #: ../display/d.vect/main.c:185
 msgid "Name of color definition column (for use with -a flag)"
@@ -17714,26 +16823,25 @@
 #: ../display/d.vect/main.c:193
 #, fuzzy
 msgid "Type of color table (for use with -z flag)"
-msgstr "Tipo di tabella colore"
+msgstr "Tipo di tavola dei colori (da usare con il flag -z)"
 #: ../display/d.vect/main.c:202 ../display/d.vect/main.c:207
 #: ../display/d.vect/main.c:215
 msgid "Lines"
-msgstr ""
+msgstr "Linee"
 #: ../display/d.vect/main.c:203
 #, fuzzy
 msgid "Line width"
-msgstr "Grandezza Linea"
+msgstr "Spessore di linea"
 #: ../display/d.vect/main.c:209
 msgid "Name of column for line widths (these values will be scaled by wscale)"
 msgstr ""
 #: ../display/d.vect/main.c:216
-#, fuzzy
 msgid "Scale factor for wcolumn"
-msgstr "Utilizzando le coordinate del centro della mappa\n"
+msgstr ""
 #: ../display/d.vect/main.c:224 ../display/d.vect/main.c:234
 #: ../display/d.vect/main.c:241 ../display/d.vect/main.c:247
@@ -17755,12 +16863,12 @@
 #: ../display/d.vect/main.c:243
 #, fuzzy
 msgid "Name of numeric column containing symbol size"
-msgstr "Nome della colonna contenente le coordinate y"
+msgstr "Nome della colonna numerica contenente le dimensioni del simbolo"
 #: ../display/d.vect/main.c:249
 #, fuzzy
 msgid "Name of numeric column containing symbol rotation angle"
+msgstr "Nome della colonna contenente l'angolo di rotazione del simbolo"
 #: ../display/d.vect/main.c:251
 msgid "Measured in degrees CCW from east"
@@ -17772,7 +16880,7 @@
 #: ../display/d.vect/main.c:305 ../display/d.vect/main.c:311
 #: ../display/d.vect/main.c:319
 msgid "Labels"
-msgstr ""
+msgstr "Etichette"
 #: ../display/d.vect/main.c:258
 msgid "Layer number for labels (default: the given layer number)"
@@ -17781,17 +16889,17 @@
 #: ../display/d.vect/main.c:264
 #, fuzzy
 msgid "Name of column to be displayed"
+msgstr "Nome della colonna da visualizzare"
 #: ../display/d.vect/main.c:270
 #, fuzzy
 msgid "Label color"
+msgstr "Colore dell'etichetta"
 #: ../display/d.vect/main.c:273
 #, fuzzy
 msgid "Either a standard color name or R:G:B triplet"
-msgstr "nessuno"
+msgstr "O un nome di colore standard o una tripletta R:G:B"
 #: ../display/d.vect/main.c:280
 msgid "Label background color"
@@ -17814,22 +16922,15 @@
 msgstr ""
 #: ../display/d.vect/main.c:329
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
+msgid "Minimum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:337
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
+msgid "Maximum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:349
-msgid ""
-"g;use the libgis render functions (features: clipping);r;use the raster "
-"graphics library functions (features: polylines);d;use the display library "
-"basic functions (features: polylines);c;use the display library clipping "
-"functions (features: clipping);l;use the display library culling functions "
-"(features: culling, polylines)"
+msgid "g;use the libgis render functions (features: clipping);r;use the raster graphics library functions (features: polylines);d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
 msgstr ""
 #: ../display/d.vect/main.c:365
@@ -17837,9 +16938,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:371
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is "
-"given)"
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
 msgstr ""
 #: ../display/d.vect/main.c:378
@@ -17847,9 +16946,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:383
-msgid ""
-"Don't add to list of vectors and commands in monitor (it won't be drawn if "
-"the monitor is refreshed)"
+msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
 msgstr ""
 #: ../display/d.vect/main.c:388
@@ -17857,15 +16954,13 @@
 msgstr ""
 #: ../display/d.vect/main.c:455
-msgid ""
-"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
-"ignored!"
+msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
 msgstr ""
 #: ../display/d.vect/main.c:486
 #, fuzzy, c-format
 msgid "Unknown color: '%s'"
+msgstr "Colore sconosciuto: '%s'"
 #: ../display/d.vect/main.c:507 ../vector/v.extract/main.c:274
 #: ../vector/v.univar/main.c:172 ../vector/v.surf.rst/main.c:450
@@ -17884,17 +16979,17 @@
 #: ../display/d.vect/main.c:694
 #, fuzzy
 msgid "Unable to display areas, topology not available"
-msgstr "Non posso mostrare le aree, topologia non disponibile"
+msgstr "Non è possibile mostrare le aree, topologia non disponibile"
 #: ../display/d.vect/main.c:699
 #, fuzzy
 msgid "Unable to display lines by id, topology not available"
-msgstr "Non posso mostrare le linee, topologia non disponibile"
+msgstr "Non è possibile mostrare le linee per id, topologia non disponibile"
 #: ../display/d.vect/main.c:742
 #, fuzzy
 msgid "Unable to display topology, not available"
-msgstr "Non posso mostrare la topologia, non è disponibile"
+msgstr "Non è possibile mostrare la topologia, non è disponibile"
 #: ../display/d.vect/area.c:69
 msgid "Color definition column not specified."
@@ -17902,8 +16997,7 @@
 #: ../display/d.vect/area.c:278
 #, c-format
-msgid ""
-"Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
+msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
 msgstr ""
 #: ../display/d.vect/area.c:284
@@ -17914,45 +17008,42 @@
 #: ../display/d.vect/plot1.c:255
 #, fuzzy, c-format
 msgid "Line width column (%s) is not numeric."
+msgstr "La colonna dello spessore di linea (%s) non è numerica."
 #: ../display/d.vect/plot1.c:275
 #, fuzzy
 msgid "Symbol size column not specified."
+msgstr "Colonna delle dimensioni dei simboli non specificata"
 #: ../display/d.vect/plot1.c:286
 #, fuzzy, c-format
 msgid "Symbol size column (%s) is not numeric."
+msgstr "La colonna delle dimensioni dei simboli (%s) non è numerica."
 #: ../display/d.vect/plot1.c:306
 #, fuzzy
 msgid "Symbol rotation column not specified."
+msgstr "Colonna della rotazione dei simboli non specificata"
 #: ../display/d.vect/plot1.c:317
 #, fuzzy, c-format
 msgid "Symbol rotation column (%s) is not numeric."
+msgstr "La colonna della rotazione dei simboli (%s) non è numerica."
 #: ../display/d.vect/plot1.c:338 ../display/d.vect/plot1.c:639
-#, fuzzy
 msgid "Unable to read symbol, unable to display points"
+msgstr ""
 #: ../display/d.vect/plot1.c:369 ../vector/v.label.sa/labels.c:147
 #: ../vector/v.label/main.c:297 ../vector/v.info/main.c:388
 #: ../vector/v.to.3d/trans3.c:81 ../vector/v.to.3d/trans2.c:81
 #, fuzzy
 msgid "Unable to read vector map"
-msgstr "Nome della mappa raster risultante"
+msgstr "Non è possibile leggere la mappa vettoriale"
 #: ../display/d.vect/plot1.c:461
 #, c-format
-msgid ""
-"Error in color definition column '%s', feature id %d with cat %d: "
-"colorstring '%s'"
+msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
 msgstr ""
 #: ../display/d.vect/plot1.c:469
@@ -17962,23 +17053,22 @@
 #: ../display/d.vect/plot1.c:591
 #, c-format
-msgid ""
-"Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
+msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
 msgstr ""
 #: ../display/d.vect/plot1.c:679
-#, fuzzy, c-format
+#, c-format
 msgid "Error in color definition column '%s': %d features affected"
+msgstr ""
 #: ../display/d.vect/attr.c:30
 msgid "attrcol not specified, cannot display attributes"
 msgstr ""
 #: ../display/d.vect/attr.c:131
-#, fuzzy, c-format
+#, c-format
 msgid "No attribute found for cat %d: %s"
-msgstr "Nessun record per la cat = %d"
+msgstr ""
 #: ../vector/v.sample/main.c:86 ../vector/v.perturb/main.c:73
 #: ../vector/v.in.region/main.c:38 ../vector/v.out.vtk/main.c:46
@@ -18001,9 +17091,8 @@
 msgstr ""
 #: ../vector/v.sample/main.c:98
-#, fuzzy
 msgid "Vector map attribute column to use for comparison"
+msgstr ""
 #: ../vector/v.sample/main.c:101
 msgid "Vector map to store differences"
@@ -18014,9 +17103,7 @@
 msgstr "Mappa raster da leggere"
 #: ../vector/v.sample/main.c:113
-msgid ""
-"Option scaling factor for values read from raster map. Sampled values will "
-"be multiplied by this factor"
+msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
 msgstr ""
 #: ../vector/v.sample/main.c:119
@@ -18032,9 +17119,9 @@
 msgstr ""
 #: ../vector/v.sample/main.c:181
-#, fuzzy, c-format
+#, c-format
 msgid "Column type <%s> not supported (must be integer or double precision)"
-msgstr "driver pg: colonna '%s', di tipo %d non supportata"
+msgstr ""
 #: ../vector/v.sample/main.c:185 ../vector/lidar/v.surf.bspline/main.c:348
 #: ../vector/v.to.rast3/main.c:96 ../vector/v.class/main.c:126
@@ -18044,7 +17131,7 @@
 #: ../ps/ps.map/catval.c:199
 #, fuzzy
 msgid "Unable to select data from table"
-msgstr "Non riesco a selezionare dati dalla tabella"
+msgstr "Non è possibile selezionare dati dalla tabella"
 #: ../vector/v.sample/main.c:187 ../vector/v.normal/main.c:155
 #: ../vector/v.surf.idw/read_sites.c:54
@@ -18055,7 +17142,7 @@
 #: ../vector/v.sample/main.c:216 ../vector/v.patch/main.c:285
 #, fuzzy, c-format
 msgid "Unable to create table <%s>"
+msgstr "Non è possibile creare la tabella <%s>"
 #: ../vector/v.sample/main.c:219 ../vector/v.net.distance/main.c:212
 #: ../vector/v.net.timetable/main.c:107 ../vector/v.net.flow/main.c:172
@@ -18067,7 +17154,7 @@
 #: ../vector/v.sample/main.c:227
 #, fuzzy
 msgid "Checking vector points..."
-msgstr "Non riesco a copiare la tabella"
+msgstr "Controllo dei punti vettoriali in corso ..."
 #: ../vector/v.sample/main.c:252 ../vector/v.sample/main.c:260
 #: ../vector/v.label.sa/labels.c:179 ../vector/v.vol.rst/user1.c:170
@@ -18077,7 +17164,7 @@
 #: ../vector/v.buffer/main.c:543 ../vector/v.what.rast/main.c:313
 #, fuzzy, c-format
 msgid "No record for category %d in table <%s>"
-msgstr "Nessun record di categoria '%d' nella tabella"
+msgstr "Nessun record per la categoria %d nella tabella <%s>"
 #: ../vector/v.sample/main.c:266 ../vector/lidar/v.surf.bspline/main.c:345
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:133
@@ -18091,7 +17178,7 @@
 #: ../vector/v.sample/main.c:289 ../vector/v.kcv/main.c:270
 #, fuzzy, c-format
 msgid "Unable to insert row: %s"
-msgstr "Nome del raster"
+msgstr "Non è possibile inserire la riga: %s"
 #: ../vector/v.db.select/main.c:53 ../vector/v.to.db/main.c:33
 #: ../vector/v.distance/main.c:115 ../vector/v.db.connect/main.c:50
@@ -18104,9 +17191,8 @@
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
 #: ../locale/scriptstrings/v.db.dropcol_to_translate.c:2
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:2
-#, fuzzy
 msgid "vector, database, attribute table"
+msgstr ""
 #: ../vector/v.db.select/main.c:54
 msgid "Prints vector map attributes."
@@ -18123,7 +17209,7 @@
 #: ../vector/v.db.select/main.c:69 ../db/base/select.c:224
 #, fuzzy
 msgid "Output vertical record separator"
-msgstr "output verticale del separatore di record "
+msgstr "output verticale del separatore di record"
 #: ../vector/v.db.select/main.c:77 ../db/base/select.c:232
 #, fuzzy
@@ -18131,46 +17217,43 @@
 msgstr "indicatore di valore nullo"
 #: ../vector/v.db.select/main.c:89
-msgid ""
-"Print minimal region extent of selected vector features instead of attributes"
+msgid "Print minimal region extent of selected vector features instead of attributes"
 msgstr ""
 #: ../vector/v.db.select/main.c:93 ../db/base/select.c:242
 #, fuzzy
 msgid "Do not include column names in output"
-msgstr "non includere i nomi delle colonne nell'output"
+msgstr "Non include i nomi delle colonne nell'output"
 #: ../vector/v.db.select/main.c:98 ../db/base/select.c:252
 #, fuzzy
 msgid "Vertical output (instead of horizontal)"
-msgstr "output verticale (invece che orizzontale)"
+msgstr "Output verticale (invece che orizzontale)"
 #: ../vector/v.db.select/main.c:141
-#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
+#, c-format
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
+msgstr ""
 #: ../vector/v.db.select/main.c:176
 #, fuzzy
 msgid "Unable to open select cursor"
+msgstr "Non è possibile aprire il cursore selezionato"
 #: ../vector/v.db.select/main.c:197 ../vector/v.reclass/main.c:237
 #, fuzzy, c-format
 msgid "Unable to fetch data from table <%s>"
+msgstr "Non è possibile recuperare i dati dalla tabella <%s>"
 #: ../vector/v.db.select/main.c:243
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get bounding box of area %d"
-msgstr "Non riesco a trovare il file raster %s"
+msgstr ""
 #: ../vector/v.db.select/main.c:248
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get bounding box of line %d"
+msgstr ""
 #: ../vector/v.net.alloc/main.c:61 ../vector/v.net/main.c:47
 #: ../vector/v.net.iso/main.c:73 ../vector/v.net.salesman/main.c:97
@@ -18183,28 +17266,24 @@
 msgstr "Assegna sottoreti per i centri più vicini (direzione dal centro)."
 #: ../vector/v.net.alloc/main.c:65
-msgid ""
-"Centre node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation"
-msgstr ""
+msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
+msgstr "Il nodo definito come centro dev'essere aperto (costi >= 0). I costi del nodo centrale vengono utilizzati nel calcolo"
 #: ../vector/v.net.alloc/main.c:92 ../vector/v.net.iso/main.c:99
 msgid "Arc forward/both direction(s) cost column (number)"
-msgstr ""
+msgstr "Colonna costo direzione in avanti (o tutte) per gli archi (numero)"
 #: ../vector/v.net.alloc/main.c:98 ../vector/v.net.iso/main.c:103
 msgid "Arc backward direction cost column (number)"
-msgstr ""
+msgstr "Colonna costo direzione indietro per gli archi (numero)"
 #: ../vector/v.net.alloc/main.c:104 ../vector/v.net.iso/main.c:107
 #, fuzzy
 msgid "Node cost column (number)"
-msgstr "Numero di colonne"
+msgstr "Colonna costo per i nodi (numero)"
 #: ../vector/v.net.alloc/main.c:110
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
+msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
 msgstr ""
 #: ../vector/v.net.alloc/main.c:186
@@ -18222,9 +17301,8 @@
 #: ../vector/v.net.alloc/main.c:340 ../vector/v.net.alloc/main.c:351
 #: ../vector/v.net.iso/main.c:508
-#, fuzzy
 msgid "Cannot get line segment, segment out of line"
-msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgstr ""
 #: ../vector/v.net/main.c:48
 msgid "Performs network maintenance."
@@ -18233,7 +17311,7 @@
 #: ../vector/v.net/main.c:55
 #, fuzzy
 msgid "Name of input point vector map"
-msgstr "Nome della mappa di input"
+msgstr "Nome della mappa vettoriale di punti di input"
 #: ../vector/v.net/main.c:56
 msgid "Required for operation 'connect'"
@@ -18243,15 +17321,10 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:5
 #, fuzzy
 msgid "Operation to be performed"
+msgstr "Operazione da eseguire"
 #: ../vector/v.net/main.c:71
-msgid ""
-"nodes;new point is placed on each node (line end) if doesn't exist;connect;"
-"connect still unconnected points to vector network by inserting new line(s);"
-"report;print to standard output {line_category start_point_category "
-"end_point_category};nreport;print to standard output {point_category "
-"line_category[,line_category...]}"
+msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
 msgstr ""
 #: ../vector/v.net/main.c:97
@@ -18261,17 +17334,17 @@
 #: ../vector/v.net/main.c:101
 #, fuzzy
 msgid "Assign unique categories to new points"
-msgstr "Assegna un unica categoria ai nuovi punti (operazione=nodes)"
+msgstr "Assegna un'unica categoria ai nuovi punti"
 #: ../vector/v.net/main.c:102
 #, fuzzy
 msgid "For operation 'nodes'"
+msgstr "Per l'operazione 'nodes'"
 #: ../vector/v.net/main.c:120
 #, fuzzy
 msgid "Unknown operation"
+msgstr "Operazione sconosciuta"
 #: ../vector/v.net/main.c:124
 msgid "Output vector map must be specified"
@@ -18292,12 +17365,12 @@
 #: ../vector/v.net/main.c:174
 #, fuzzy, c-format
 msgid "Unable to open vector map <%s> at topology level %d"
+msgstr "Impossibile aprire la mappa vettoriale <%s> al livello topologico %d"
 #: ../vector/v.net/main.c:190
 #, fuzzy, c-format
 msgid "%d arcs added to network (nlayer %d)"
-msgstr "%d categrie caricate dalla tabella"
+msgstr "%d archi aggiunti alla rete (nlayer %d)"
 #: ../vector/v.net/main.c:197 ../vector/v.type/main.c:234
 #: ../vector/v.proj/main.c:296 ../vector/v.kcv/main.c:161
@@ -18305,7 +17378,7 @@
 #: ../vector/v.clean/main.c:281 ../vector/v.category/main.c:555
 #, fuzzy
 msgid "Failed to copy attribute table to output map"
+msgstr "Copiatura della tabella degli attributi sulla mappa di output non riuscita"
 #: ../vector/v.net/nodes.c:85
 #, c-format
@@ -18315,7 +17388,7 @@
 #: ../vector/v.net/report.c:44
 #, fuzzy, c-format
 msgid "Line %d has no category"
+msgstr "La linea %d non ha categorie"
 #: ../vector/v.net/report.c:67
 #, c-format
@@ -18344,7 +17417,7 @@
 #: ../vector/v.out.svg/main.c:87
 #, fuzzy
 msgid "Output type"
-msgstr "Mappa in output"
+msgstr "Tipo di output"
 #: ../vector/v.out.svg/main.c:88
 msgid "Defines which feature-type will be extracted"
@@ -18355,9 +17428,8 @@
 msgstr ""
 #: ../vector/v.out.svg/main.c:103
-#, fuzzy
 msgid "Attribute(s) to include in output SVG"
-msgstr "Nome della mappa raster che contiene i risultati"
+msgstr ""
 #: ../vector/v.out.svg/main.c:116
 msgid "Precision must not be negative"
@@ -18383,9 +17455,8 @@
 msgstr "Non posso aprire il file SVG <%s>"
 #: ../vector/v.out.svg/main.c:205
-#, fuzzy
 msgid "No areas found, skipping type=poly"
-msgstr "Utilizza la regione corrente"
+msgstr ""
 #: ../vector/v.out.svg/main.c:215 ../vector/v.extrude/main.c:203
 #, c-format
@@ -18398,9 +17469,8 @@
 msgstr "Estratte %d aree"
 #: ../vector/v.out.svg/main.c:248
-#, fuzzy
 msgid "No points found, skipping type=point"
+msgstr ""
 #: ../vector/v.out.svg/main.c:271
 #, c-format
@@ -18408,9 +17478,8 @@
 msgstr "Estratti %d punti"
 #: ../vector/v.out.svg/main.c:277
-#, fuzzy
 msgid "No lines found, skipping type=line"
+msgstr ""
 #: ../vector/v.out.svg/main.c:298
 #, c-format
@@ -18427,12 +17496,11 @@
 #: ../vector/v.overlay/main.c:357
 #, fuzzy
 msgid "Unable to fetch data from table"
+msgstr "Non è possibile recuperare i dati dalla tabella"
 #: ../vector/v.net.visibility/main.c:46
-#, fuzzy
 msgid "vector, path, visibility"
-msgstr "File di input"
+msgstr ""
 #: ../vector/v.net.visibility/main.c:47
 msgid "Visibility graph construction."
@@ -18441,7 +17509,7 @@
 #: ../vector/v.net.visibility/main.c:59
 #, fuzzy
 msgid "One or more coordinates"
+msgstr "Una o o più coordinate"
 #: ../vector/v.net.visibility/main.c:65
 msgid "Add points after computing the vis graph"
@@ -18450,12 +17518,12 @@
 #: ../vector/v.net.visibility/main.c:98
 #, fuzzy, c-format
 msgid "Unable to copy elements from vector map <%s>"
+msgstr "Non è possibile copiare elementi dalla mappa vettoriale <%s>"
 #: ../vector/v.net.visibility/main.c:104
 #, fuzzy
 msgid "Lat-long projection"
+msgstr "Proiezione Lat-long"
 #: ../vector/v.to.db/main.c:34
 msgid "Populates database values from vector features."
@@ -18465,7 +17533,7 @@
 #: ../vector/v.to.db/update.c:32 ../vector/v.to.db/query.c:83
 #, fuzzy, c-format
 msgid "Database connection not defined for layer %d. Use v.db.connect first."
+msgstr "Connessione al database non definita per il layer %d. Usare prima v.db.connect"
 #: ../vector/v.to.db/update.c:82
 msgid "Updating database..."
@@ -18479,27 +17547,27 @@
 #: ../vector/v.to.db/update.c:213
 #, fuzzy, c-format
 msgid "Record (cat %d) already exists (not inserted)"
-msgstr "La mappa vettoriale <%s> esiste già e sarà sovrascritta"
+msgstr "Il record (cat %d) esiste già (non inserito)"
 #: ../vector/v.to.db/update.c:221 ../vector/v.to.3d/trans3.c:128
 #, fuzzy, c-format
 msgid "Record (cat %d) does not exist (not updated)"
+msgstr "Il record (cat %d) non esiste (non aggiornato)"
 #: ../vector/v.to.db/parse.c:38
 #, fuzzy
 msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr "Tipo"
+msgstr "Per coor sono validi point/centroid, per length sono validi line/boundary"
 #: ../vector/v.to.db/parse.c:42
 #, fuzzy
 msgid "Layer number (write to)"
-msgstr "Numero di layer"
+msgstr "Numero del layer (su cui scrivere)"
 #: ../vector/v.to.db/parse.c:46
 #, fuzzy
 msgid "Query layer number (read from)"
+msgstr "Numero del layer da interrogare (da cui leggere)"
 #: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:99
 #: ../db/base/execute.c:114 ../db/base/select.c:197 ../db/base/select.c:202
@@ -18513,14 +17581,15 @@
 #: ../vector/v.to.db/parse.c:87
 #, fuzzy
-msgid ""
-"mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
-msgstr "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
+msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
+msgstr ""
+"mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)\n"
+"(miglia, piedi, metri, chilometri, acri, ettari, radianti, gradi)"
 #: ../vector/v.to.db/parse.c:93
 #, fuzzy
 msgid "Name of attribute column used for 'query' option"
+msgstr "Nome colonna degli attributi da usare per l'opzione 'query'"
 #: ../vector/v.to.db/parse.c:94
 msgid "E.g. 'cat', 'count(*)', 'sum(val)'"
@@ -18529,12 +17598,12 @@
 #: ../vector/v.to.db/parse.c:103
 #, fuzzy
 msgid "Print only"
-msgstr "Stampa esclusivamente l'intervallo"
+msgstr "Stampa solo"
 #: ../vector/v.to.db/parse.c:108
 #, fuzzy
 msgid "Only print SQL statements"
-msgstr "nome del file con istruzione sql"
+msgstr "Stampa solo le istruzioni SQL"
 #: ../vector/v.to.db/parse.c:114
 msgid "In print mode prints totals for options: length,area,count"
@@ -18571,13 +17640,13 @@
 #: ../vector/v.to.db/areas.c:28 ../vector/v.to.rast/do_areas.c:33
 #, fuzzy
 msgid "Reading areas..."
+msgstr "Lettura delle aree in corso ..."
 #: ../vector/v.to.db/query.c:23 ../vector/v.to.db/lines.c:74
 #: ../vector/v.to.rast/do_lines.c:35
 #, fuzzy
 msgid "Reading features..."
+msgstr "Lettura degli elementi in corso ..."
 #: ../vector/v.to.db/query.c:93
 msgid "Querying database... "
@@ -18585,9 +17654,7 @@
 #: ../vector/v.to.db/query.c:108
 #, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many (%"
-"d) query categories. All later reported values for cat 0 are not valid."
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
 msgstr ""
 #: ../vector/v.to.db/query.c:145
@@ -18596,44 +17663,43 @@
 msgstr ""
 #: ../vector/v.to.db/query.c:152
-#, fuzzy
 msgid "Unable to fetch record"
+msgstr ""
 #: ../vector/v.to.db/report.c:187
 #, fuzzy, c-format
 msgid "%d categories read from vector map (layer %d)"
+msgstr "%d categrie lette dalla mappa vettoriale (layer %d)"
 #: ../vector/v.to.db/report.c:191
 #, fuzzy, c-format
 msgid "%d records selected from table (layer %d)"
-msgstr "%d records aggiornati"
+msgstr "%d record letti dalla tabella (layer %d)"
 #: ../vector/v.to.db/report.c:194
-#, fuzzy, c-format
+#, c-format
 msgid "%d categories read from vector map exist in selection from table"
-msgstr "%d categorie dal vettoriale mancano nella tabella"
+msgstr ""
 #: ../vector/v.to.db/report.c:197
 #, fuzzy, c-format
 msgid "%d categories read from vector map don't exist in selection from table"
+msgstr "%d categorie lette dalla mappa vettoriale mancano nella selezione dalla tabella"
 #: ../vector/v.to.db/report.c:199
 #, fuzzy, c-format
 msgid "%d records updated/inserted (layer %d)"
-msgstr "%d record aggiornati/inseriti"
+msgstr "%d record aggiornati/inseriti (layer %d)"
 #: ../vector/v.to.db/report.c:202
 #, fuzzy, c-format
 msgid "%d update/insert errors (layer %d)"
-msgstr "%s errori di aggiornamento/inserimento"
+msgstr "%s errori di aggiornamento/inserimento (layer %d)"
 #: ../vector/v.to.db/report.c:205
 #, fuzzy, c-format
 msgid "%d categories with more points (coordinates not loaded)"
-msgstr "%d categorie caricate dal vettoriale"
+msgstr "%d categorie con più punti (coordinate non caricate)"
 #: ../vector/lidar/v.outlier/outlier.c:75
 #: ../vector/lidar/v.outlier/outlier.c:112
@@ -18688,20 +17754,16 @@
 #: ../vector/lidar/v.surf.bspline/main.c:96
 #: ../vector/lidar/v.lidar.edgedetection/main.c:86
 #: ../vector/lidar/v.lidar.correction/main.c:81
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
 msgstr ""
 #: ../vector/lidar/v.outlier/main.c:92
-#, fuzzy
 msgid "Name of output outlier vector map"
+msgstr ""
 #: ../vector/lidar/v.outlier/main.c:100
-#, fuzzy
 msgid "Name of vector map for visualization in QGIS"
-msgstr "Nome di una mappa raster esistente"
+msgstr ""
 #: ../vector/lidar/v.outlier/main.c:108
 #: ../vector/lidar/v.lidar.edgedetection/main.c:98
@@ -18729,7 +17791,7 @@
 #: ../vector/lidar/v.lidar.correction/main.c:152
 #, fuzzy
 msgid "Unable to read name of database"
+msgstr "Non è possibile leggere il nome del database"
 #: ../vector/lidar/v.outlier/main.c:142
 #: ../vector/lidar/v.surf.bspline/main.c:194
@@ -18737,7 +17799,7 @@
 #: ../vector/lidar/v.lidar.correction/main.c:155
 #, fuzzy
 msgid "Unable to read name of driver"
+msgstr "Non è possibile leggere il nome del driver"
 #: ../vector/lidar/v.outlier/main.c:171 ../vector/lidar/v.outlier/main.c:237
 #: ../vector/lidar/v.surf.bspline/main.c:210
@@ -18750,30 +17812,29 @@
 #: ../vector/lidar/v.lidar.correction/main.c:229
 #, fuzzy, c-format
 msgid "No database connection for driver <%s> is defined. Run db.connect."
+msgstr "Non è stata definita nessuna connessione al database per il driver <%s>. Eseguire db.connect."
 #: ../vector/lidar/v.outlier/main.c:174
 #: ../vector/lidar/v.surf.bspline/main.c:213
 #: ../vector/lidar/v.lidar.edgedetection/main.c:196
 #: ../vector/lidar/v.lidar.edgedetection/main.c:208
 #: ../vector/lidar/v.lidar.correction/main.c:172
-#, fuzzy
 msgid "Old auxiliar table could not be dropped"
+msgstr ""
 #: ../vector/lidar/v.outlier/main.c:181
 #: ../vector/lidar/v.surf.bspline/main.c:223
 #: ../vector/lidar/v.surf.bspline/main.c:277
 #, fuzzy, c-format
 msgid "Unable to open vector map <%s> at the topological level"
+msgstr "Non è possibile  aprire la mappa vettoriale <%s> al livello topologico"
 #: ../vector/lidar/v.outlier/main.c:186
 #: ../vector/lidar/v.lidar.edgedetection/main.c:227
 #: ../vector/lidar/v.lidar.correction/main.c:190
 #, fuzzy, c-format
 msgid "Input vector map <%s> is not 3D!"
-msgstr "Mappa vettoriale <%s> non è 3D"
+msgstr "La mappa vettoriale di input <%s> non è 3D!"
 #: ../vector/lidar/v.outlier/main.c:196
 #: ../vector/lidar/v.surf.bspline/main.c:241
@@ -18781,12 +17842,12 @@
 #: ../vector/lidar/v.lidar.correction/main.c:200
 #, fuzzy
 msgid "No points in current region!"
+msgstr "Nessun punto nella regione corrente!"
 #: ../vector/lidar/v.outlier/main.c:243
 #, fuzzy, c-format
 msgid "It was impossible to create <%s> table."
+msgstr "Non è stato possibile creare la tabella <%s>."
 #: ../vector/lidar/v.outlier/main.c:276
 #: ../vector/lidar/v.surf.bspline/main.c:416
@@ -18820,9 +17881,8 @@
 msgstr ""
 #: ../vector/lidar/v.outlier/main.c:405
-#, fuzzy
 msgid "Outlier detection"
-msgstr "Colore del bordo"
+msgstr ""
 #: ../vector/lidar/v.outlier/main.c:423
 #: ../vector/lidar/v.lidar.edgedetection/main.c:460
@@ -18834,9 +17894,8 @@
 #: ../vector/lidar/v.surf.bspline/main.c:731
 #: ../vector/lidar/v.lidar.edgedetection/main.c:470
 #: ../vector/lidar/v.lidar.correction/main.c:440
-#, fuzzy
 msgid "Auxiliar table could not be dropped"
+msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:83 ../vector/v.surf.idw/main.c:84
 msgid "vector, interpolation"
@@ -18844,19 +17903,16 @@
 #: ../vector/lidar/v.surf.bspline/main.c:85
 msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
-msgstr ""
-"Interpolazione spline bicubica o bilineare con regolarizzazione Tykhonov"
+msgstr "Interpolazione spline bicubica o bilineare con regolarizzazione Tykhonov"
 #: ../vector/lidar/v.surf.bspline/main.c:90
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:104
 #, fuzzy
 msgid "Name of input vector map of sparse points"
+msgstr "Nome della mappa vettoriale di punti sparsi di input"
 #: ../vector/lidar/v.surf.bspline/main.c:119
 msgid "Length of each spline step in the east-west direction"
@@ -18869,7 +17925,7 @@
 #: ../vector/lidar/v.surf.bspline/main.c:135
 #, fuzzy
 msgid "Spline interpolation algorithm"
-msgstr "Numero di punti per l'interpolazione"
+msgstr "Algoritmo di interpolazione delle spline"
 #: ../vector/lidar/v.surf.bspline/main.c:144
 msgid "Tykhonov regularization parameter (affects smoothing)"
@@ -18882,25 +17938,23 @@
 #: ../vector/lidar/v.surf.bspline/main.c:159
 #, fuzzy
 msgid "Attribute table column with values to interpolate (if layer>0)"
-msgstr "Nome della mappa raster da utilizzare per <%s>"
+msgstr "Colonna della tabella degli attributi coi valori da interpolare (se layer>0)"
 #: ../vector/lidar/v.surf.bspline/main.c:172
 msgid "Choose either vector or raster output, not both"
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:175
-#, fuzzy
 msgid "No raster or vector or cross-validation output"
-msgstr "Nome del file in output"
+msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:229
 msgid "Need either 3D vector or layer and column with z values"
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:231
-#, fuzzy
 msgid "Layer but not column with z values given"
+msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:254
 msgid "Cross validation didn't finish correctly"
@@ -18914,13 +17968,11 @@
 #: ../vector/lidar/v.surf.bspline/main.c:269
 #, fuzzy, c-format
 msgid "Vector map <%s> of sparse points will be interpolated"
+msgstr "La mappa vettoriale di punti sparsi <%s> sarà interpolata"
 #: ../vector/lidar/v.surf.bspline/main.c:285
 #, c-format
-msgid ""
-"Sorry, <%s> driver is not allowed for vector output in this module. Try with "
-"a raster output or other driver."
+msgid "Sorry, <%s> driver is not allowed for vector output in this module. Try with a raster output or other driver."
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:307
@@ -18940,23 +17992,21 @@
 #: ../vector/lidar/v.surf.bspline/main.c:350
 #, fuzzy, c-format
 msgid "[%d] records selected from table"
+msgstr "[%d] record selezionati dalla tabella"
 #: ../vector/lidar/v.surf.bspline/main.c:369
 #, fuzzy, c-format
 msgid "Interpolation: Creating table: It was impossible to create table <%s>."
+msgstr "Interpolazione: Creazione della tabella: Non è stato possibile creare la tabella <%s>."
 #: ../vector/lidar/v.surf.bspline/main.c:392
-msgid ""
-"Cannot allocate memory for auxiliar matrix.Consider changing region "
-"resolution"
+msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/main.c:590
 #, fuzzy, c-format
 msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
+msgstr "Interpolazione: (%d,%d): Nessun record per il punto (cat = %d)"
 #: ../vector/lidar/v.surf.bspline/main.c:709
 msgid "No data within this subregion. Consider increasing spline step values."
@@ -18965,7 +18015,7 @@
 #: ../vector/lidar/v.surf.bspline/main.c:715
 #, fuzzy
 msgid "Writing output..."
+msgstr "Scrittura dell'output in corso ..."
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:77
 #, c-format
@@ -18975,12 +18025,10 @@
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:86
 #, fuzzy, c-format
 msgid "%d points read in region"
+msgstr "%d punti letti nella regione"
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:90
-msgid ""
-"Maybe, it takes too long. It will depend on how many points you are "
-"considering."
+msgid "Maybe, it takes too long. It will depend on how many points you are considering."
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:119
@@ -18991,12 +18039,11 @@
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:136
 #, fuzzy, c-format
 msgid "No records selected from table <%s> "
+msgstr "Nessun record selezionato dalla tabella <%s> "
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:151
 #, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:169
@@ -19008,7 +18055,7 @@
 #: ../vector/v.surf.idw/read_sites.c:86
 #, fuzzy, c-format
 msgid "No record for point (cat = %d)"
+msgstr "Nessun record per il punto (cat = %d)"
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:289
 #, c-format
@@ -19016,26 +18063,22 @@
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:290
-#, fuzzy, c-format
+#, c-format
 msgid "Root Means Square (RMS) = %.5lf"
+msgstr ""
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:306
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:308
 #, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:316
-#, fuzzy
 msgid "Results into a table:"
-msgstr "Nome della mappa con il risultato"
+msgstr ""
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:317
 msgid " lambda    | mean        | rms         |"
@@ -19047,9 +18090,8 @@
 msgstr ""
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:327
-#, fuzzy
 msgid "No point lies into the current region"
+msgstr ""
 #: ../vector/lidar/v.lidar.edgedetection/main.c:78
 msgid "vector, LIDAR, edges"
@@ -19064,14 +18106,12 @@
 msgstr ""
 #: ../vector/lidar/v.lidar.edgedetection/main.c:124
-#, fuzzy
 msgid "High gradient threshold for edge classification"
+msgstr ""
 #: ../vector/lidar/v.lidar.edgedetection/main.c:133
-#, fuzzy
 msgid "Low gradient threshold for edge classification"
+msgstr ""
 #: ../vector/lidar/v.lidar.edgedetection/main.c:141
 msgid "Angle range for same direction detection"
@@ -19084,7 +18124,7 @@
 #: ../vector/lidar/v.lidar.edgedetection/main.c:260
 #, fuzzy, c-format
 msgid "It was impossible to create <%s>."
-msgstr "impossibile aprire <%s>"
+msgstr "Non è stato possibile creare <%s>"
 #: ../vector/lidar/v.lidar.edgedetection/main.c:263
 #, c-format
@@ -19104,9 +18144,8 @@
 msgstr ""
 #: ../vector/lidar/v.lidar.edgedetection/main.c:446
-#, fuzzy
 msgid "Point classification"
+msgstr ""
 #: ../vector/lidar/v.lidar.edgedetection/main.c:468
 #: ../vector/lidar/v.lidar.correction/main.c:438
@@ -19119,22 +18158,19 @@
 #: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:308
 #: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:326
 #: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:356
-#, fuzzy
 msgid "Impossible to read from aux table"
+msgstr ""
 #: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:237
 #: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:313
-#, fuzzy
 msgid "Impossible to update aux table"
-msgstr "Nome del filtro file"
+msgstr ""
 #: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:250
 #: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:262
 #: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:383
-#, fuzzy
 msgid "Impossible to write to aux table"
-msgstr "Valore da scrivere per null"
+msgstr ""
 #: ../vector/lidar/lidarlib/TcholBand.c:28
 msgid "Decomposition failed"
@@ -19146,7 +18182,7 @@
 #: ../vector/lidar/lidarlib/raster.c:168 ../vector/lidar/lidarlib/raster.c:181
 #, fuzzy, c-format
 msgid "Unable to access table <%s>"
+msgstr "Non è possibile accedere alla tabella <%s>"
 #: ../vector/lidar/lidarlib/zones.c:413 ../vector/lidar/lidarlib/zones.c:450
 #, c-format
@@ -19156,7 +18192,7 @@
 #: ../vector/lidar/lidarlib/zones.c:417 ../vector/lidar/lidarlib/zones.c:454
 #, fuzzy, c-format
 msgid "<%s> has not been created in database."
-msgstr "La tabella <%s> non esiste nel database <%s>"
+msgstr "<%s> non è stata creata nel database"
 #: ../vector/lidar/v.lidar.growing/main.c:79
 #: ../vector/lidar/v.lidar.correction/main.c:73
@@ -19164,9 +18200,7 @@
 msgstr ""
 #: ../vector/lidar/v.lidar.growing/main.c:81
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
 msgstr ""
 #: ../vector/lidar/v.lidar.growing/main.c:86
@@ -19174,9 +18208,8 @@
 msgstr ""
 #: ../vector/lidar/v.lidar.growing/main.c:96
-#, fuzzy
 msgid "Name of the first pulse vector map"
+msgstr ""
 #: ../vector/lidar/v.lidar.growing/main.c:103
 msgid "Threshold for cell object frequency in region growing"
@@ -19189,7 +18222,7 @@
 #: ../vector/lidar/v.lidar.growing/main.c:179
 #, fuzzy, c-format
 msgid "Unable to open table <%s>"
-msgstr "Impossibile copiare la tabella <%s>"
+msgstr "Impossibile aprire la tabella <%s>"
 #: ../vector/lidar/v.lidar.growing/main.c:204
 msgid "Setting regions and boxes"
@@ -19198,31 +18231,27 @@
 #: ../vector/lidar/v.lidar.growing/main.c:270
 #, fuzzy, c-format
 msgid "Rows = %d"
-msgstr "righe:    %d"
+msgstr "Righe = %d"
 #: ../vector/lidar/v.lidar.growing/main.c:271
 #, fuzzy, c-format
 msgid "Columns = %d"
-msgstr "colonne: %d"
+msgstr "Colonne = %d"
 #: ../vector/lidar/v.lidar.growing/main.c:291
-#, fuzzy
 msgid "read points in input vector"
-msgstr "Leggere mappa vettoriale"
+msgstr ""
 #: ../vector/lidar/v.lidar.growing/main.c:440
-#, fuzzy
 msgid "Region Growing"
-msgstr "Mappa raster risultante"
+msgstr ""
 #: ../vector/lidar/v.lidar.growing/ConvexHull.c:269
 msgid "...now exiting to system..."
 msgstr ""
 #: ../vector/lidar/v.lidar.correction/main.c:75
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
 msgstr ""
 #: ../vector/lidar/v.lidar.correction/main.c:85
@@ -19232,21 +18261,19 @@
 #: ../vector/lidar/v.lidar.correction/main.c:88
 #, fuzzy
 msgid "Output classified vector map name"
-msgstr "Nome della tabella in output"
+msgstr "Nome della mappa vettoriale classificata di output"
 #: ../vector/lidar/v.lidar.correction/main.c:97
-#, fuzzy
 msgid "Only 'terrain' points output vector map"
-msgstr "Punti di partenza della mappa vettoriale"
+msgstr ""
 #: ../vector/lidar/v.lidar.correction/main.c:120
 msgid "Regularization weight in reclassification evaluation"
 msgstr ""
 #: ../vector/lidar/v.lidar.correction/main.c:128
-#, fuzzy
 msgid "High threshold for object to terrain reclassification"
-msgstr "Nome del file con il risultato della classificazione"
+msgstr ""
 #: ../vector/lidar/v.lidar.correction/main.c:136
 msgid "Low threshold for terrain to object reclassification"
@@ -19263,9 +18290,8 @@
 msgstr ""
 #: ../vector/lidar/v.lidar.correction/main.c:361
-#, fuzzy
 msgid "read vector region map"
+msgstr ""
 #: ../vector/lidar/v.lidar.correction/main.c:366
 #, c-format
@@ -19275,7 +18301,7 @@
 #: ../vector/lidar/v.lidar.correction/main.c:372
 #, fuzzy
 msgid "Mean calculation"
-msgstr "locazione del database"
+msgstr "Calcolo della media"
 #: ../vector/lidar/v.lidar.correction/main.c:386
 msgid "Only TERRAIN points"
@@ -19302,9 +18328,7 @@
 #: ../vector/v.generalize/main.c:79
-msgid ""
-"vector, generalization, simplification, smoothing, displacement, network "
-"generalization"
+msgid "vector, generalization, simplification, smoothing, displacement, network generalization"
 msgstr ""
 #: ../vector/v.generalize/main.c:80
@@ -19312,17 +18336,7 @@
 msgstr "Generalizzazione vettoriale"
 #: ../vector/v.generalize/main.c:98
-msgid ""
-"douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker "
-"Algorithm with reduction parameter;lang;Lang Simplification Algorithm;"
-"reduction;Vertex Reduction Algorithm eliminates points close to each other;"
-"reumann;Reumann-Witkam Algorithm;remove_small;Removes lines shorter than "
-"threshold and areas of area less than threshold;boyle;Boyle's Forward-"
-"Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;"
-"distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's "
-"Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes "
-"method for line smoothing;network;Network generalization;displacement;"
-"Displacement of lines close to each other;"
+msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;remove_small;Removes lines shorter than threshold and areas of area less than threshold;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
 msgstr ""
 #: ../vector/v.generalize/main.c:113
@@ -19362,19 +18376,17 @@
 msgstr ""
 #: ../vector/v.generalize/main.c:187
-#, fuzzy
 msgid "Snakes alpha parameter"
-msgstr "Nome del file raster in input"
+msgstr ""
 #: ../vector/v.generalize/main.c:194
-#, fuzzy
 msgid "Snakes beta parameter"
+msgstr ""
 #: ../vector/v.generalize/main.c:201
 #, fuzzy
 msgid "Number of iterations"
+msgstr "Numero di iterazioni"
 #: ../vector/v.generalize/main.c:210
 msgid "Copy attributes"
@@ -19382,12 +18394,12 @@
 #: ../vector/v.generalize/main.c:214
 msgid "Remove lines and areas smaller than threshold"
-msgstr "Rimuove linee e aree più piccole dello threshold"
+msgstr "Rimuove linee e aree più piccole del valore di soglia"
 #: ../vector/v.generalize/main.c:272
 #, fuzzy
 msgid "Unknown method"
-msgstr "%s - colore sconosciuto\n"
+msgstr "Metodo sconosciuto"
 #: ../vector/v.generalize/main.c:320 ../vector/v.generalize/main.c:332
 #, c-format
@@ -19401,17 +18413,17 @@
 #: ../vector/v.generalize/main.c:327
 #, fuzzy
 msgid "Unable to load data from database"
+msgstr "Non è possibile caricare i dati dal database"
 #: ../vector/v.generalize/main.c:337
 #, fuzzy
 msgid "Problem loading category values"
+msgstr "Problemi nel caricamento dei valori di categoria"
 #: ../vector/v.generalize/main.c:363
-#, fuzzy, c-format
+#, c-format
 msgid "Generalization (%s)..."
+msgstr ""
 #: ../vector/v.generalize/main.c:453
 #, c-format
@@ -19421,7 +18433,7 @@
 #: ../vector/v.generalize/main.c:476
 #, fuzzy, c-format
 msgid "Unable to calculate centroid for area %d"
-msgstr "Non riesco ad impostare user/password"
+msgstr "Non è possibile calcolare il centroide per l'area %d"
 #: ../vector/v.generalize/main.c:483
 msgid "New centroids were calculated, attribute attachment may be changed"
@@ -19433,8 +18445,7 @@
 msgstr ""
 #: ../vector/v.generalize/main.c:508
-msgid ""
-"Areas may have disappeared and/or area attribute attachment may have changed"
+msgid "Areas may have disappeared and/or area attribute attachment may have changed"
 msgstr ""
 #: ../vector/v.generalize/main.c:509
@@ -19443,9 +18454,8 @@
 msgstr ""
 #: ../vector/v.generalize/network.c:163
-#, fuzzy
 msgid "Calculating centrality measures..."
+msgstr ""
 #: ../vector/v.generalize/smoothing.c:85
 #: ../vector/v.generalize/smoothing.c:145
@@ -19455,57 +18465,52 @@
 #: ../vector/v.generalize/smoothing.c:480
 #, fuzzy
 msgid "Unable to find the inverse matrix"
+msgstr "Non è possibile trovare la matrice inversa"
 #: ../vector/v.generalize/smoothing.c:487
-#, fuzzy
 msgid "Unable to calculate the output vectors"
+msgstr ""
 #: ../vector/v.generalize/displacement.c:196
 #, fuzzy
 msgid "Inverting matrix..."
-msgstr "Sto disegnando ..."
+msgstr "Inversione della matrice in corso ..."
 #: ../vector/v.generalize/displacement.c:198
 #, fuzzy
 msgid "Unable to calculate the inverse matrix"
+msgstr "Non è possibile calcolare la matrice inversa"
 #: ../vector/v.generalize/displacement.c:201
 #, fuzzy
 msgid "Resolving conflicts..."
+msgstr "Risoluzione dei conflitti in corso ..."
 #: ../vector/v.build/main.c:34 ../vector/v.clean/main.c:43
-#, fuzzy
 msgid "vector, topology"
-msgstr "vettore da rimuovere"
+msgstr ""
 #: ../vector/v.build/main.c:35
 msgid "Creates topology for GRASS vector map."
-msgstr "Crea topologia per un vettore GRASS"
+msgstr "Crea la topologia per una mappa vettoriale di GRASS"
 #: ../vector/v.build/main.c:42
-#, fuzzy
 msgid "Name for vector map where erroneous vector features are written to"
+msgstr ""
 #: ../vector/v.build/main.c:53
 msgid "Build topology or dump topology or spatial index to stdout"
 msgstr ""
 #: ../vector/v.build/main.c:55
-msgid ""
-"build;build topology;dump;write topology to stdout;sdump;write spatial index "
-"to stdout;cdump;write category index to stdout"
+msgid "build;build topology;dump;write topology to stdout;sdump;write spatial index to stdout;cdump;write category index to stdout"
 msgstr ""
 #: ../vector/v.build/main.c:84 ../vector/v.support/main.c:129
 #: ../vector/v.edit/main.c:119 ../vector/v.neighbors/main.c:77
 #, fuzzy, c-format
 msgid "Vector map <%s> not found in the current mapset"
+msgstr "La mappa vettoriale <%s> non è stata trovata nel mapset corrente"
 #: ../vector/v.in.ogr/main.c:103 ../vector/v.in.dxf/main.c:60
 #: ../vector/v.in.dwg/main.c:65 ../vector/v.in.ascii/in.c:48
@@ -19513,18 +18518,16 @@
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:2
 #: ../locale/scriptstrings/v.in.lines_to_translate.c:2
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
-#, fuzzy
 msgid "vector, import"
+msgstr ""
 #: ../vector/v.in.ogr/main.c:105
 msgid "Convert OGR vector layers to GRASS vector map."
 msgstr "Converte vettore OGR in vettore GRASS"
 #: ../vector/v.in.ogr/main.c:112
-#, fuzzy
 msgid "OGR datasource name"
-msgstr "nome database"
+msgstr ""
 #: ../vector/v.in.ogr/main.c:113
 msgid ""
@@ -19547,7 +18550,7 @@
 #: ../vector/v.in.ogr/main.c:140
 #, fuzzy
 msgid "Import subregion only"
-msgstr "Stampa solo il tipo di mappa raster"
+msgstr "Importa solamente la sottoregione"
 #: ../vector/v.in.ogr/main.c:141 ../vector/v.in.ogr/main.c:225
 msgid "Subregion"
@@ -19572,27 +18575,22 @@
 #: ../vector/v.in.ogr/main.c:162
 #, fuzzy
 msgid "Optionally change default input type"
-msgstr "Mostra il titolo del file raster"
+msgstr "Opzionalmente cambia il tipo di input predefinito"
 #: ../vector/v.in.ogr/main.c:164
-msgid ""
-"point;import area centroids as points;line;import area boundaries as lines;"
-"boundary;import lines as area boundaries;centroid;import points as centroids"
+msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:175
-#, fuzzy
 msgid "Snapping threshold for boundaries"
-msgstr "Lista delle soglie per le isosuperfici."
+msgstr ""
 #: ../vector/v.in.ogr/main.c:177
 msgid "'-1' for no snap"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:191
-msgid ""
-"List of column names to be used instead of original names, first is used for "
-"category column"
+msgid "List of column names to be used instead of original names, first is used for category column"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:198
@@ -19612,17 +18610,17 @@
 #: ../vector/v.to.points/main.c:213
 #, fuzzy
 msgid "Do not create attribute table"
+msgstr "Non crea la tabella degli attributi"
 #: ../vector/v.in.ogr/main.c:221
 #, fuzzy
 msgid "Override dataset projection (use location's projection)"
-msgstr "Sovrascrivi la proiezione (utilizza quella della locazione)"
+msgstr "Sovrascrive la proiezione (utilizza quella della locazione)"
 #: ../vector/v.in.ogr/main.c:226
 #, fuzzy
 msgid "Limit import to the current region"
+msgstr "Limita l'importazione alla regione corrente"
 #: ../vector/v.in.ogr/main.c:236
 msgid "Change column names to lowercase characters"
@@ -19635,7 +18633,7 @@
 #: ../vector/v.in.ogr/main.c:293
 #, fuzzy, c-format
 msgid "Unable to open data source <%s>"
+msgstr "Impossibile aprire la sorgente dati <%s>"
 #: ../vector/v.in.ogr/main.c:301
 #, c-format
@@ -19655,7 +18653,7 @@
 #: ../vector/v.in.ogr/main.c:361 ../vector/v.external/main.c:128
 #, fuzzy, c-format
 msgid "Layer <%s> not available"
-msgstr "file raster per la Vista%d"
+msgstr "Layer <%s> non disponibile"
 #: ../vector/v.in.ogr/main.c:377
 msgid "Select either the current region flag or the spatial option, not both"
@@ -19666,15 +18664,11 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:482
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location"
+msgid "Unable to convert input map projection to GRASS format; cannot create new location"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:494
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
+msgid "Unable to convert input map projection information to GRASS format for checking"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:524
@@ -19689,15 +18683,13 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:587
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:610
 #, fuzzy, c-format
 msgid "Using temporary vector <%s>"
+msgstr "Si sta usando il vettore temporaneo <%s>"
 #: ../vector/v.in.ogr/main.c:629
 #, c-format
@@ -19716,9 +18708,7 @@
 #: ../vector/v.in.ogr/main.c:752
 #, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:764
@@ -19734,17 +18724,17 @@
 #: ../vector/v.in.ogr/main.c:783
 #, fuzzy, c-format
 msgid "Unable open database <%s> by driver <%s>"
-msgstr "Non riesco ad aprire il database %s col driver %s"
+msgstr "Non è possibile aprire il database <%s> col driver <%s>"
 #: ../vector/v.in.ogr/main.c:820
 #, fuzzy, c-format
 msgid "Counting polygons for %d features..."
-msgstr "Sto copiando le tabelle..."
+msgstr "Conteggio dei poligoni per %d elementi in corso..."
 #: ../vector/v.in.ogr/main.c:842
-#, fuzzy, c-format
+#, c-format
 msgid "Boundary splitting distance in map units: %G"
-msgstr "Uso la massima distanza tra punti. %f"
+msgstr ""
 #: ../vector/v.in.ogr/main.c:847
 #, c-format
@@ -19798,9 +18788,8 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1035
-#, fuzzy
 msgid "Merge boundaries:"
+msgstr ""
 #: ../vector/v.in.ogr/main.c:1053 ../vector/v.buffer2/main.c:535
 #: ../vector/v.buffer2/main.c:606 ../vector/v.voronoi/dt_main.c:142
@@ -19810,21 +18799,17 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1069
-#, fuzzy, c-format
+#, c-format
 msgid "Find centroids for layer: %s"
+msgstr ""
 #: ../vector/v.in.ogr/main.c:1090
-#, fuzzy
 msgid "Write centroids:"
-msgstr "Sto scrivendo i centroidi..."
+msgstr ""
 #: ../vector/v.in.ogr/main.c:1140
 #, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table. "
-"The number of features for those areas is stored as category in layer %d"
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1150
@@ -19840,43 +18825,41 @@
 #: ../vector/v.in.ogr/main.c:1154
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)\n"
-msgstr "Area totale: %e (%d areas)"
+msgstr "Area totale: %G (%d aree)\n"
 #: ../vector/v.in.ogr/main.c:1155
 #, fuzzy, c-format
 msgid "Total area: %G (%d areas)"
+msgstr "Area totale: %G (%d aree)"
 #: ../vector/v.in.ogr/main.c:1158
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)\n"
+msgstr "Area di sovrapposizione: %G (%d aree)\n"
 #: ../vector/v.in.ogr/main.c:1160
 #, fuzzy, c-format
 msgid "Overlapping area: %G (%d areas)"
+msgstr "Area di sovrapposizione: %G (%d aree)"
 #: ../vector/v.in.ogr/main.c:1164
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)\n"
-msgstr "Aree senza categoria: %e (%d areas)"
+msgstr "Aree senza categoria: %G (%d aree)\n"
 #: ../vector/v.in.ogr/main.c:1166
 #, fuzzy, c-format
 msgid "Area without category: %G (%d areas)"
+msgstr "Aree senza categoria: %G (%d aree)"
 #: ../vector/v.in.ogr/main.c:1208
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, use -z flag to "
-"import 3D vector"
+msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
 msgstr ""
 #: ../vector/v.in.ogr/geom.c:193
 #, fuzzy
 msgid "Cannot read part of geometry"
-msgstr "Non posso scrivere parte della geometria"
+msgstr "Non è possibile leggere parte della geometria"
 #: ../vector/v.in.ogr/geom.c:232 ../vector/v.in.ogr/geom.c:245
 #: ../vector/v.in.ogr/geom.c:273 ../vector/v.in.ogr/geom.c:319
@@ -19908,16 +18891,14 @@
 #: ../vector/v.in.ogr/geom.c:424
 #, fuzzy
 msgid "Unknown geometry type"
-msgstr "Tipo sconosciuto"
+msgstr "Tipo di geometria sconosciuto"
 #: ../vector/v.to.rast3/main.c:45
 msgid "vector, volume, conversion"
 msgstr ""
 #: ../vector/v.to.rast3/main.c:46
-msgid ""
-"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
-"raster map layer."
+msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
 msgstr ""
 #: ../vector/v.to.rast3/main.c:59
@@ -19931,12 +18912,12 @@
 #: ../ps/ps.map/catval.c:111 ../ps/ps.map/catval.c:177
 #, fuzzy
 msgid "Unable to get layer info for vector map"
-msgstr "Impossibile ottenere informazioni sul layer vettoriale"
+msgstr "Impossibile ottenere informazioni sul layer per la mappa vettoriale"
 #: ../vector/v.to.rast3/main.c:108
 #, fuzzy
 msgid "Unable to create output map"
+msgstr "Non è possibile creare la mappa di output"
 #: ../vector/v.to.rast3/main.c:150 ../vector/v.to.rast/do_lines.c:51
 #: ../vector/v.to.rast/do_lines.c:59
@@ -19947,20 +18928,15 @@
 #: ../vector/v.to.rast3/main.c:162
 #, fuzzy
 msgid "Unable to close new 3d raster map"
+msgstr "Non è possibile chiudere la nuova mappa raster 3d"
 #: ../vector/v.extract/main.c:91
-#, fuzzy
 msgid "vector, extract"
+msgstr ""
 #: ../vector/v.extract/main.c:93
-msgid ""
-"Selects vector objects from an existing vector map and creates a new map "
-"containing only the selected objects."
-msgstr ""
-"Seleziona oggetti vettoriali da una mappa esistente e crea una nuova mappa "
-"contenento solo gli oggetti selezionati."
+msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
+msgstr "Seleziona oggetti vettoriali da una mappa esistente e crea una nuova mappa contenento solo gli oggetti selezionati."
 #: ../vector/v.extract/main.c:98
 msgid "Dissolve common boundaries (default is no)"
@@ -19974,18 +18950,15 @@
 #: ../vector/v.edit/args.c:201
 #, fuzzy
 msgid "Reverse selection"
-msgstr "Mappa(e) raster da leggere"
+msgstr "Selezione inversa"
 #: ../vector/v.extract/main.c:116
-#, fuzzy
 msgid "Types to be extracted"
-msgstr "Il file raster da importare"
+msgstr ""
 #: ../vector/v.extract/main.c:122
-#, fuzzy
-msgid ""
-"Layer number (if -1, all features in all layers of given type are extracted)"
+msgid "Layer number (if -1, all features in all layers of given type are extracted)"
+msgstr ""
 #: ../vector/v.extract/main.c:136
 msgid "Input text file with category numbers/number ranges to be extracted"
@@ -19994,7 +18967,7 @@
 #: ../vector/v.extract/main.c:137
 #, fuzzy
 msgid "If '-' given reads from standard input"
-msgstr "File raster ascii da importare"
+msgstr "Se si immette il segno '-' legge dallo standard input"
 #: ../vector/v.extract/main.c:145
 msgid "Number of random categories matching vector objects to extract"
@@ -20013,9 +18986,7 @@
 msgstr ""
 #: ../vector/v.extract/main.c:175
-msgid ""
-"List, file, where and random options are exclusive. Please specify only one "
-"of them"
+msgid "List, file, where and random options are exclusive. Please specify only one of them"
 msgstr ""
 #: ../vector/v.extract/main.c:204 ../vector/v.drape/main.c:220
@@ -20035,7 +19006,7 @@
 #: ../vector/v.extract/main.c:249
 #, fuzzy, c-format
 msgid "Unable to open specified file <%s>"
+msgstr "Non è possibile aprire il file specificato <%s>"
 #: ../vector/v.extract/main.c:259
 #, c-format
@@ -20045,17 +19016,15 @@
 #: ../vector/v.extract/main.c:297
 #, fuzzy, c-format
 msgid "Unable select records from table <%s>"
+msgstr "Non è possibile selezionare i record dalla tabella <%s>"
 #: ../vector/v.extract/main.c:298
 #, fuzzy, c-format
 msgid "%d categories loaded from table <%s>"
+msgstr "%d categrie caricate dalla tabella <%s>"
 #: ../vector/v.extract/main.c:313
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
 msgstr ""
 #: ../vector/v.extract/main.c:319
@@ -20064,27 +19033,23 @@
 #: ../vector/v.extract/main.c:323
 #, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
 msgstr ""
 #: ../vector/v.extract/main.c:346
 #, c-format
-msgid ""
-"Random category count is larger or equal to uniq \"%s\" feature category "
-"count %d"
+msgid "Random category count is larger or equal to uniq \"%s\" feature category count %d"
 msgstr ""
 #: ../vector/v.extract/main.c:383
 #, fuzzy
 msgid "Extracting features..."
+msgstr "Estrazione degli elementi in corso ..."
 #: ../vector/v.extract/main.c:466 ../vector/v.voronoi/vo_main.c:339
 #, fuzzy
 msgid "No table"
+msgstr "Nessuna tabella"
 #: ../vector/v.extract/main.c:481 ../vector/v.in.db/main.c:225
 msgid "Unable to copy table"
@@ -20093,16 +19058,14 @@
 #: ../vector/v.extract/main.c:498
 #, fuzzy
 msgid "Removing duplicate centroids..."
+msgstr "Rimozione dei centroidi duplicati in corso ..."
 #: ../vector/v.in.db/main.c:52
-#, fuzzy
 msgid "vector, import, database, points"
+msgstr ""
 #: ../vector/v.in.db/main.c:54
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
+msgid "Creates new vector (points) map from database table containing coordinates."
 msgstr "Crea un nuovo vettoriale (punti) da una tabella contenente coordinate"
 #: ../vector/v.in.db/main.c:58
@@ -20114,7 +19077,7 @@
 #: ../db/base/select.c:210 ../db/base/select.c:216
 #, fuzzy
 msgid "Connection"
-msgstr "Campo separatore in output"
+msgstr "Connessione"
 #: ../vector/v.in.db/main.c:72
 msgid "Name of column containing x coordinate"
@@ -20135,29 +19098,28 @@
 #: ../vector/v.in.db/main.c:87 ../vector/v.db.connect/main.c:73
 #, fuzzy
 msgid "Must refer to an integer column"
-msgstr "Nome della chiave (deve riferirsi a una colonna di tipo integer)"
+msgstr "Deve riferirsi a una colonna di tipo integer"
 #: ../vector/v.in.db/main.c:130
 #, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
 msgstr ""
 #: ../vector/v.in.db/main.c:138 ../vector/v.transform/trans_digit.c:93
 #: ../vector/v.db.connect/main.c:280
 #, fuzzy, c-format
 msgid "Missing column <%s> in table <%s>"
-msgstr "raster <%s> non trovato"
+msgstr "Manca la colonna <%s> nella tabella <%s>"
 #: ../vector/v.in.db/main.c:141 ../vector/v.db.connect/main.c:286
 #, fuzzy
 msgid "Data type of key column must be integer"
-msgstr "Nessuna mappa in input specificata"
+msgstr "Il tipo di dati della colonna chiave dev'essere integer"
 #: ../vector/v.in.db/main.c:173
 #, fuzzy
 msgid "Writing features..."
+msgstr "Scrittura degli elementi in corso ..."
 #: ../vector/v.in.db/main.c:180
 msgid "Key column must be integer"
@@ -20171,28 +19133,23 @@
 #: ../vector/v.to.3d/main.c:127
 #, fuzzy
 msgid "Copying attributes..."
-msgstr "Mostra attributi"
+msgstr "Copia degli attributi in corso ..."
 #: ../vector/v.in.db/main.c:235
 #, fuzzy, c-format
 msgid "%d points written to vector map."
-msgstr "Punti di blocco della mappa vettoriale"
+msgstr "scritti %d punti nella mappa vettoriale"
 #: ../vector/v.net.iso/main.c:72
 msgid "Splits net by cost isolines."
 msgstr "Dividi rete dal costo delle linee."
 #: ../vector/v.net.iso/main.c:75
-msgid ""
-"Splits net to bands between cost isolines (direction from centre). Centre "
-"node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation."
+msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
 msgstr ""
 #: ../vector/v.net.iso/main.c:113
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated. "
-"Layer for this categories is given by nlayer option."
+msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
 msgstr ""
 #: ../vector/v.net.iso/main.c:122
@@ -20225,22 +19182,19 @@
 #: ../vector/v.net.iso/main.c:224
 #, fuzzy, c-format
 msgid "Number of centres: %d (nlayer %d)"
+msgstr "Numero di centri: %d (nlayer %d)"
 #: ../vector/v.net.iso/main.c:247
 #, fuzzy, c-format
 msgid "Calculating costs from centre %d..."
+msgstr "Calcolo dei costi dal centro %d in corso ..."
 #: ../vector/v.net.salesman/main.c:99
 msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
-"Crea un ciclo connettendo i nodi dati (problema del commesso viaggiatore)"
+msgstr "Crea un ciclo connettendo i nodi dati (problema del commesso viaggiatore)"
 #: ../vector/v.net.salesman/main.c:101
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
 msgstr ""
 #: ../vector/v.net.salesman/main.c:119
@@ -20253,22 +19207,22 @@
 #: ../vector/v.net.salesman/main.c:130
 msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
-msgstr ""
+msgstr "Categorie dei punti ('città') sui nodi (il layer è definito da nlayer)"
 #: ../vector/v.net.salesman/main.c:193
 #, fuzzy, c-format
 msgid "Number of cities: [%d]"
+msgstr "Numero di città: [%d]"
 #: ../vector/v.net.salesman/main.c:195
 #, fuzzy
 msgid "Not enough cities (< 2)"
-msgstr "Nome mappa raster"
+msgstr "Non ci sono abbastanza città (< 2)"
 #: ../vector/v.net.salesman/main.c:228
 #, fuzzy, c-format
 msgid "Destination node [%d] is unreachable from node [%d]"
-msgstr "Destinazione non raggiungibile\n"
+msgstr "Il nodo di destinazione [%d] non è raggiungibile dal nodo [%d]"
 #: ../vector/v.perturb/main.c:75
 msgid "Random location perturbations of GRASS vector points"
@@ -20283,10 +19237,7 @@
 msgstr "Distribuzione della perturbazione"
 #: ../vector/v.perturb/main.c:96
-msgid ""
-"Parameter(s) of distribution. If the distribution is uniform, only one "
-"parameter, the maximum, is needed. For a normal distribution, two "
-"parameters, the mean and standard deviation, are required."
+msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
 msgstr ""
 #: ../vector/v.perturb/main.c:106
@@ -20310,9 +19261,8 @@
 msgstr ""
 #: ../vector/v.perturb/main.c:232
-#, fuzzy
 msgid "Cannot get db link info"
-msgstr "Non riesco a descrivere la tabella"
+msgstr ""
 #: ../vector/v.perturb/normalsv.c:29
 msgid "normalsv: save of unitialized block"
@@ -20337,15 +19287,11 @@
 #: ../vector/v.net.distance/main.c:61
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
+msgid "Computes shortest distance via the network between the given sets of features."
 msgstr ""
 #: ../vector/v.net.distance/main.c:64
-msgid ""
-"Finds the shortest paths from a feature 'to' to every feature 'from' and "
-"various information about this realtion are uploaded to the attribute table."
+msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this realtion are uploaded to the attribute table."
 msgstr ""
 #: ../vector/v.net.distance/main.c:73
@@ -20358,7 +19304,7 @@
 #: ../vector/v.distance/main.c:134 ../vector/v.distance/main.c:146
 #, fuzzy
 msgid "From"
-msgstr "Tipo di grafico"
+msgstr "Da"
 #: ../vector/v.net.distance/main.c:78
 #, fuzzy
@@ -20399,82 +19345,69 @@
 #: ../vector/v.net.timetable/main.c:112 ../vector/v.net.flow/main.c:176
 #: ../vector/v.net.path/path.c:117 ../vector/v.net.centrality/main.c:248
 #: ../vector/v.net.components/main.c:155
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot grant privileges on table <%s>"
-msgstr "Permessi non sufficienti per accedere alla tabella %s"
+msgstr ""
 #: ../vector/v.distance/main.c:117
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
-msgstr ""
-"Trova l'elemento più vicino nel vettoriale 'to' per gli elementi nel "
-"vettoriale 'from'."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgstr "Trova l'elemento più vicino nel vettoriale 'to' per gli elementi nel vettoriale 'from'."
 #: ../vector/v.distance/main.c:121
 #, fuzzy
 msgid "Name of existing vector map (from)"
-msgstr "Nome di un file vettoriale in output"
+msgstr "Nome di una mappa vettoriale esistente (da)"
 #: ../vector/v.distance/main.c:126
 #, fuzzy
 msgid "Name of existing vector map (to)"
+msgstr "Nome di una mappa vettoriale esistente (a)"
 #: ../vector/v.distance/main.c:133
 #, fuzzy
 msgid "Feature type (from)"
+msgstr "Tipo di elemento (da)"
 #: ../vector/v.distance/main.c:140
 #, fuzzy
 msgid "Feature type (to)"
+msgstr "Tipo di elemento (a)"
 #: ../vector/v.distance/main.c:145
 #, fuzzy
 msgid "Layer number (from)"
+msgstr "Numero del layer (da)"
 #: ../vector/v.distance/main.c:150
 #, fuzzy
 msgid "Layer number (to)"
+msgstr "Numero del layer (a)"
 #: ../vector/v.distance/main.c:156
 #, fuzzy
 msgid "Name for output vector map containing lines connecting nearest elements"
+msgstr "Nome di una mappa vettoriale di output contenente le linee che collegano gli elementi più vicini"
 #: ../vector/v.distance/main.c:164
 #, fuzzy
 msgid "Maximum distance or -1 for no limit"
-msgstr "Distanza massima dal punto visualizzato (metri)"
+msgstr "Distanza massima  o -1 per nessun limite"
 #: ../vector/v.distance/main.c:171
 #, fuzzy
 msgid "Minimum distance or -1 for no limit"
+msgstr "Distanza minima o -1 per nessun limite"
 #: ../vector/v.distance/main.c:180
 msgid "Values describing the relation between two nearest features"
 msgstr ""
 #: ../vector/v.distance/main.c:182
-msgid ""
-"cat;category of the nearest feature;dist;minimum distance to nearest feature;"
-"to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of "
-"the nearest point on 'to' feature;to_along;distance between points/centroids "
-"in 'from' map and the linear feature's start point in 'to' map, along this "
-"linear feature;to_angle;angle between the linear feature in 'to' map and the "
-"positive x axis, at the location of point/centroid in 'from' map, "
-"counterclockwise, in radians, which is between -PI and PI inclusive;to_attr;"
-"attribute of nearest feature given by to_column option"
+msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of the nearest point on 'to' feature;to_along;distance between points/centroids in 'from' map and the linear feature's start point in 'to' map, along this linear feature;to_angle;angle between the linear feature in 'to' map and the positive x axis, at the location of point/centroid in 'from' map, counterclockwise, in radians, which is between -PI and PI inclusive;to_attr;attribute of nearest feature given by to_column option"
 msgstr ""
 #: ../vector/v.distance/main.c:200
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
 #: ../vector/v.distance/main.c:201
@@ -20502,9 +19435,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:225
-msgid ""
-"The output is written to stdout but may be uploaded to a new table created "
-"by this module. From categories are may be multiple."
+msgid "The output is written to stdout but may be uploaded to a new table created by this module. From categories are may be multiple."
 msgstr ""
 #: ../vector/v.distance/main.c:276
@@ -20514,44 +19445,42 @@
 #: ../vector/v.distance/main.c:288
 #, fuzzy
 msgid "Too many column names"
-msgstr "nome tabella"
+msgstr "Troppi nomi di colonna"
 #: ../vector/v.distance/main.c:295
 #, fuzzy
 msgid "Not enough column names"
+msgstr "Nomi di colonna non sufficienti"
 #: ../vector/v.distance/main.c:302
 #, fuzzy, c-format
 msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgstr "La mappa vettoriale <%s> non è nel mapset dell'utente e non può essere aggiornata"
 #: ../vector/v.distance/main.c:373 ../vector/v.distance/main.c:407
 #: ../vector/v.out.ascii/b2a.c:227 ../vector/v.reclass/main.c:137
 #: ../vector/v.to.3d/trans3.c:61 ../vector/v.to.3d/trans2.c:60
 #, fuzzy, c-format
 msgid "Column <%s> not found in table <%s>"
+msgstr "Colonna <%s> non trovata nella tabella <%s>"
 #: ../vector/v.distance/main.c:383
 #, fuzzy
 msgid "Unable to open default database"
-msgstr "Non posso scrivere i collegamenti del database"
+msgstr "Non è possibile aprire il database predefinito"
 #: ../vector/v.distance/main.c:439
 #, fuzzy
 msgid "Incompatible column types"
+msgstr "Tipi di colonna incompatibili"
 #: ../vector/v.distance/main.c:512
-#, fuzzy
 msgid "Finding nearest lines..."
+msgstr ""
 #: ../vector/v.distance/main.c:642
-#, fuzzy
 msgid "Finding nearest areas..."
+msgstr ""
 #: ../vector/v.distance/main.c:714
 #, c-format
@@ -20565,12 +19494,12 @@
 #: ../vector/v.distance/main.c:1104
 #, fuzzy, c-format
 msgid "%d categories with more than 1 feature in vector map <%s>"
+msgstr "%d categorie con più di 1 elemento nella mappa vettoriale <%s>"
 #: ../vector/v.distance/main.c:1107
-#, fuzzy, c-format
+#, c-format
 msgid "%d categories - no nearest feature found"
+msgstr ""
 #: ../vector/v.distance/main.c:1116
 #, c-format
@@ -20580,71 +19509,68 @@
 #: ../vector/v.distance/main.c:1117
 #, fuzzy, c-format
 msgid "%d records inserted"
+msgstr "%d record inseriti"
 #: ../vector/v.distance/main.c:1119
 #, fuzzy, c-format
 msgid "%d insert errors"
-msgstr "%s errori di aggiornamento\n"
+msgstr "%d errori di inserimento"
 #: ../vector/v.distance/main.c:1123
 #, fuzzy, c-format
 msgid "%d categories read from the map"
+msgstr "%d categrie lette dalla mappa"
 #: ../vector/v.distance/main.c:1125
 #, fuzzy, c-format
 msgid "%d categories exist in the table"
+msgstr "%d categorie sono presenti nella tabella"
 #: ../vector/v.distance/main.c:1127
 #, fuzzy, c-format
 msgid "%d categories read from the map exist in the table"
+msgstr "%d categorie lette dalla mappa sono presenti nella tabella"
 #: ../vector/v.distance/main.c:1130
 #, fuzzy, c-format
 msgid "%d categories read from the map don't exist in the table"
+msgstr "%d categorie lette dalla mappa mancano nella tabella"
 #: ../vector/v.distance/main.c:1132 ../vector/v.what.rast/main.c:372
 #, c-format
 msgid "%d records updated"
+msgstr "%d record aggiornati"
 #: ../vector/v.distance/main.c:1134 ../vector/v.what.rast/main.c:373
 #, fuzzy, c-format
 msgid "%d update errors"
+msgstr "%d errori di aggiornamento"
 #: ../vector/v.in.sites/main.c:57
-#, fuzzy
 msgid "vector, import, sites"
+msgstr ""
 #: ../vector/v.in.sites/main.c:59
 msgid "Converts a GRASS site_lists file into a vector map."
 msgstr ""
 #: ../vector/v.in.sites/main.c:83
-#, fuzzy, c-format
+#, c-format
 msgid "Site file <%s> not found"
+msgstr ""
 #: ../vector/v.in.sites/main.c:86
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open site file <%s@%s>"
+msgstr ""
 #: ../vector/v.in.sites/main.c:89
-#, fuzzy
 msgid "Unable to guess site_list format"
+msgstr ""
 #: ../vector/v.in.sites/main.c:92
-#, fuzzy
 msgid "Failed to allocate site structure"
+msgstr ""
 #: ../vector/v.in.sites/main.c:94
 #, c-format
@@ -20660,66 +19586,62 @@
 msgstr ""
 #: ../vector/v.in.sites/main.c:183
-#, fuzzy
 msgid "Transferring sites to vector point map..."
+msgstr ""
 #: ../vector/v.in.sites/main.c:240 ../vector/v.in.dxf/write_vect.c:58
 #: ../vector/v.mkgrid/main.c:309 ../vector/v.in.ascii/points.c:405
 #, fuzzy, c-format
 msgid "Unable to insert new record: %s"
-msgstr "Non riesco a trovare il file raster %s"
+msgstr "Non è possibile inserire un nuovo record: %s"
 #: ../vector/v.in.sites/main.c:255
-#, fuzzy, c-format
+#, c-format
 msgid "%d sites written."
+msgstr ""
 #: ../vector/v.random/main.c:85
 msgid "Randomly generate a 2D/3D vector points map."
-msgstr "Genera casualmente un mappa puntuale 2D/3D"
+msgstr "Genera casualmente un mappa vettoriale di punti 2D/3D"
 #: ../vector/v.random/main.c:93
 #, fuzzy
 msgid "Number of points to be created"
-msgstr "Numero di passi attraverso il dataset"
+msgstr "Numero di punti da creare"
 #: ../vector/v.random/main.c:100
 #, fuzzy
 msgid "Minimum z height (needs -z flag or column name)"
-msgstr "Minimo valore di altezza z (necessita del parametro -z)"
+msgstr "Minimo valore di altezza z (necessita del parametro -z o del nome di colonna)"
 #: ../vector/v.random/main.c:102 ../vector/v.random/main.c:111
 #: ../vector/v.random/main.c:123 ../vector/v.random/main.c:128
 #, fuzzy
 msgid "3D output"
-msgstr "Crea output 3D"
+msgstr "Output 3D"
 #: ../vector/v.random/main.c:109
 #, fuzzy
 msgid "Maximum z height (needs -z flag or column name)"
-msgstr "Massimo valore di altezza z (necessita del parametro -z)"
+msgstr "Massimo valore di altezza z (necessita del parametro -z o del nome di colonna)"
 #: ../vector/v.random/main.c:119
 msgid "Column name and type (i.e. INTEGER, DOUBLE PRECISION) for z values"
 msgstr ""
 #: ../vector/v.random/main.c:121
-msgid ""
-"If type is not given then DOUBLE PRECISION is used. Writes Z data to column "
-"instead of 3D vector."
+msgid "If type is not given then DOUBLE PRECISION is used. Writes Z data to column instead of 3D vector."
 msgstr ""
 #: ../vector/v.random/main.c:132
 #, fuzzy
 msgid "Use drand48() function instead of rand()"
-msgstr ""
-"Usa la funzione drand48() invece di quella di default (default=rand() )"
+msgstr "Usa la funzione drand48() invece di rand()"
 #: ../vector/v.random/main.c:136 ../vector/v.in.dxf/main.c:74
 #: ../vector/v.edit/args.c:216
 msgid "Do not build topology"
-msgstr "Topologia non costruita"
+msgstr "Non costruisce la topologia"
 #: ../vector/v.random/main.c:142
 msgid "v.random can't create 3D vector and attribute table at same time"
@@ -20728,21 +19650,19 @@
 #: ../vector/v.random/main.c:150
 #, fuzzy, c-format
 msgid "Number of points must be > 0 (%d given)"
+msgstr "Il numero di punti dev'essere > 0 (%d definiti)"
 #: ../vector/v.random/main.c:179
-#, fuzzy, c-format
+#, c-format
 msgid "Using 'double precision' for column <%s>"
-msgstr "Impossibile usare la colonna <%s>"
+msgstr ""
 #: ../vector/v.random/main.c:221
 msgid "Table should contain only two columns"
 msgstr ""
 #: ../vector/v.random/main.c:234
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
 msgstr ""
 #: ../vector/v.random/main.c:264
@@ -20754,9 +19674,8 @@
 msgstr "Converte un vettore GRASS in un VTK ASCII"
 #: ../vector/v.out.vtk/main.c:58
-#, fuzzy
 msgid "Path to resulting VTK file"
+msgstr ""
 #: ../vector/v.out.vtk/main.c:83
 #: ../locale/scriptstrings/v.report_to_translate.c:6
@@ -20788,8 +19707,7 @@
 msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:187
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
 msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:575 ../vector/v.out.ogr/main.c:988
@@ -20798,25 +19716,23 @@
 msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:622
-#, fuzzy
 msgid "Cannot export attribute table fields for layer < 1. Skipping export"
+msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:630
 #, fuzzy
 msgid "No attribute table found"
+msgstr "Non è stata trovata nessuna tabella degli attributi"
 #: ../vector/v.out.vtk/writeVTK.c:662
-#, fuzzy
 msgid "No numerical attributes found. Skipping export"
+msgstr ""
 #: ../vector/v.out.vtk/writeVTK.c:716 ../vector/v.out.vtk/writeVTK.c:743
 #: ../vector/v.out.vtk/writeVTK.c:770 ../vector/v.out.vtk/writeVTK.c:796
 #, fuzzy, c-format
 msgid "Error reading value of attribute '%s'"
-msgstr "Errore nella lettura del file dbmscap\n"
+msgstr "Errore nella lettura del valore dell'attributo '%s'"
 #: ../vector/v.out.ascii/out.c:47
 msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
@@ -20827,14 +19743,12 @@
 msgstr ""
 #: ../vector/v.out.ascii/out.c:66
-#, fuzzy
 msgid "Field separator (points mode)"
-msgstr "campo separatore in output"
+msgstr ""
 #: ../vector/v.out.ascii/out.c:83
-#, fuzzy
 msgid "Name of attribute column(s) to be exported (point mode)"
+msgstr ""
 #: ../vector/v.out.ascii/out.c:91
 msgid "Create old (version 4) ASCII file"
@@ -20847,7 +19761,7 @@
 #: ../vector/v.out.ascii/out.c:111
 #, fuzzy, c-format
 msgid "Parameter '%s' ignored in standard mode"
+msgstr "Parametro '%s' ignorato in modalità standard"
 #: ../vector/v.out.ascii/out.c:119
 msgid "Format 'point' is not supported for old version"
@@ -20862,14 +19776,14 @@
 msgstr ""
 #: ../vector/v.out.ascii/out.c:180
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open dig_att file <%s>"
+msgstr ""
 #: ../vector/v.out.ascii/b2a.c:150
-#, fuzzy, c-format
+#, c-format
 msgid "got type %d"
+msgstr ""
 #: ../vector/v.out.ascii/b2a.c:192
 #, c-format
@@ -20877,14 +19791,14 @@
 msgstr ""
 #: ../vector/v.out.ascii/b2a.c:202
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to select record from table <%s> (key %s, column %s)"
-msgstr "Non riesco a selezionare dati dalla tabella"
+msgstr ""
 #: ../vector/v.out.ascii/b2a.c:229
 #, fuzzy, c-format
 msgid "Column <%s>: unsupported data type"
-msgstr "Tipo di colonna (%s) non supportata"
+msgstr "Colonna <%s>: tipo di dati non supportato"
 #: ../vector/v.net.allpairs/main.c:56
 msgid "Computes the shortest path between all pairs of nodes in the network."
@@ -20918,24 +19832,22 @@
 msgstr ""
 #: ../vector/v.label.sa/main.c:56
-#, fuzzy
 msgid "Create optimally placed labels for vector map(s)"
-msgstr "Crea nuova tavola dei colori per vettoriale"
+msgstr ""
 #: ../vector/v.label.sa/main.c:103 ../vector/v.label/main.c:79
 #, fuzzy
 msgid "Name of attribute column to be used for labels"
+msgstr "Nome della colonna della tabella degli attributi da utilizzare per le etichette"
 #: ../vector/v.label.sa/main.c:107 ../vector/v.label/main.c:68
-#, fuzzy
 msgid "Name for new paint-label file"
-msgstr "Nome di un nuovo file raster"
+msgstr ""
 #: ../vector/v.label.sa/main.c:117
 #, fuzzy
 msgid "Name of TrueType font (as listed in the fontcap)"
-msgstr "Percorso del carattere TrueType (nome del file incluso)"
+msgstr "Nome del carattere TrueType (come elencato nel file fontcap)"
 #: ../vector/v.label.sa/main.c:118 ../vector/v.label.sa/main.c:119
 #: ../vector/v.label.sa/main.c:126 ../vector/v.lrs/v.lrs.label/main.c:180
@@ -20971,9 +19883,7 @@
 msgstr "Spessore del bordo (solo per l'output di ps.map)"
 #: ../vector/v.label.sa/main.c:207
-msgid ""
-"Numeric column to give precedence in case of overlapping labels. The label "
-"with a smaller weight is hidden."
+msgid "Numeric column to give precedence in case of overlapping labels. The label with a smaller weight is hidden."
 msgstr ""
 #: ../vector/v.label.sa/labels.c:74
@@ -20984,7 +19894,7 @@
 #: ../vector/v.label.sa/labels.c:96
 #, fuzzy, c-format
 msgid "Unable to find font '%s'\n"
+msgstr "Non è possibile trovare il carattere '%s'\n"
 #: ../vector/v.label.sa/labels.c:98
 #, c-format
@@ -20998,17 +19908,17 @@
 #: ../vector/v.label.sa/labels.c:104
 #, fuzzy
 msgid "Font file can not be loaded"
+msgstr "Il file dei font non può essere caricato"
 #: ../vector/v.label.sa/labels.c:113
 #, fuzzy
 msgid "Unable to set font size"
+msgstr "Non è possibile impostare la dimensione del carattere"
 #: ../vector/v.label.sa/labels.c:134
 #, fuzzy
 msgid "Cannot allocate more memory"
+msgstr "Impossibile allocare più memoria"
 #: ../vector/v.label.sa/labels.c:175 ../vector/v.overlay/main.c:296
 #: ../vector/v.label/main.c:323
@@ -21017,14 +19927,13 @@
 #: ../vector/v.label.sa/labels.c:229
 #, c-format
-msgid ""
-"Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
+msgid "Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
 msgstr ""
 #: ../vector/v.label.sa/labels.c:287
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot load glyph for '%c'"
+msgstr ""
 #: ../vector/v.label.sa/font.c:55
 #, c-format
@@ -21032,17 +19941,16 @@
 msgstr ""
 #: ../vector/v.label.sa/font.c:61
-#, fuzzy, c-format
+#, c-format
 msgid "%s: No font definition file"
+msgstr ""
 #: ../vector/v.type/main.c:47 ../vector/v.hull/main.c:273
 #: ../vector/v.overlay/main.c:55 ../vector/v.segment/main.c:52
 #: ../vector/v.to.points/main.c:173 ../vector/v.parallel/main.c:39
 #: ../vector/v.parallel2/main.c:44 ../vector/v.split/main.c:42
-#, fuzzy
 msgid "vector, geometry"
+msgstr ""
 #: ../vector/v.type/main.c:48
 msgid "Change the type of geometry elements."
@@ -21070,32 +19978,28 @@
 #: ../vector/v.type/main.c:92
 #, fuzzy
 msgid "Nothing to do"
-msgstr "Non ho trovato nulla.\n"
+msgstr "Non c'è nulla da fare"
 #: ../vector/v.type/main.c:141 ../vector/v.type/main.c:174
 #, fuzzy
 msgid "Incompatible types"
+msgstr "Tipi incopatibili"
 #: ../vector/v.type/main.c:186
-#, fuzzy
 msgid "Not enough types"
+msgstr ""
 #: ../vector/v.type/main.c:189
-#, fuzzy
 msgid "Odd number of types"
-msgstr "Area: %d  Numero di isole: %d\n"
+msgstr ""
 #: ../vector/v.in.dxf/add_lwpolyline.c:33 ../vector/v.in.dxf/add_line.c:28
 #: ../vector/v.in.dxf/add_arc.c:36 ../vector/v.in.dxf/add_polyline.c:90
 #: ../vector/v.in.dxf/add_text.c:35 ../vector/v.in.dxf/add_3dface.c:29
 #: ../vector/v.in.dxf/add_circle.c:32 ../vector/v.in.dxf/add_point.c:27
-#, fuzzy, c-format
+#, c-format
 msgid "Layer %d: %s\n"
 msgstr ""
-"Layer: %d\n"
-"categoria: %d\n"
 #: ../vector/v.in.dxf/main.c:62
 msgid "Converts files in DXF format to GRASS vector map format."
@@ -21106,9 +20010,8 @@
 msgstr ""
 #: ../vector/v.in.dxf/main.c:70
-#, fuzzy
 msgid "Do not create attribute tables"
+msgstr ""
 #: ../vector/v.in.dxf/main.c:78
 msgid "Import polyface meshes as 3D wire frame"
@@ -21118,13 +20021,12 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:3
 #, fuzzy
 msgid "List available layers and exit"
-msgstr "Visualizza i formati supportati ed esci"
+msgstr "Elenca i layer disponibili ed esce"
 #: ../vector/v.in.dxf/main.c:83 ../vector/v.in.dxf/main.c:89
 #: ../vector/v.in.dxf/main.c:94 ../vector/v.in.dxf/main.c:108
-#, fuzzy
 msgid "DXF layers"
-msgstr " nv colore\n"
+msgstr ""
 #: ../vector/v.in.dxf/main.c:88 ../vector/v.in.dwg/main.c:84
 msgid "Invert selection by layers (don't import layers in list)"
@@ -21137,7 +20039,7 @@
 #: ../vector/v.in.dxf/main.c:97
 #, fuzzy
 msgid "Name of input DXF file"
-msgstr "Nomi di file di input"
+msgstr "Nomi del file DXF di input"
 #: ../vector/v.in.dxf/main.c:107 ../vector/v.in.dwg/main.c:79
 msgid "List of layers to import"
@@ -21146,7 +20048,7 @@
 #: ../vector/v.in.dxf/main.c:122
 #, fuzzy, c-format
 msgid "Unable to open DXF file <%s>"
-msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgstr "Non è possibile aprire il file DXF <%S>"
 #: ../vector/v.in.dxf/main.c:157
 #, c-format
@@ -21154,9 +20056,9 @@
 msgstr ""
 #: ../vector/v.in.dxf/main.c:162
-#, fuzzy, c-format
+#, c-format
 msgid "Use '%s' option to change vector map name"
-msgstr "Nome del database in output"
+msgstr ""
 #: ../vector/v.in.dxf/main.c:189
 msgid "Building topology failed"
@@ -21179,16 +20081,14 @@
 msgstr ""
 #: ../vector/v.in.dxf/write_vect.c:91
-#, fuzzy, c-format
+#, c-format
 msgid "Layer %d: %s"
 msgstr ""
-"Layer: %d\n"
-"categoria: %d\n"
 #: ../vector/v.in.dxf/write_vect.c:230
 #, fuzzy, c-format
 msgid "Unable to add database link for vector map <%s>"
+msgstr "Impossibile aggiungere il collegamento al database per la mappa vettoriale <%s>"
 #: ../vector/v.in.dxf/read_dxf.c:57
 msgid "end of file while looking for HEADER"
@@ -21199,18 +20099,16 @@
 msgstr ""
 #: ../vector/v.qcount/main.c:76
-#, fuzzy
 msgid "Vector of points defining sample points"
-msgstr "Mappa raster che contiene i valori delle altezze"
+msgstr ""
 #: ../vector/v.qcount/main.c:84
 msgid "Output quadrant centres, number of points is written as category"
 msgstr ""
 #: ../vector/v.qcount/main.c:91
-#, fuzzy
 msgid "Number of quadrats"
-msgstr "Numero di righe"
+msgstr ""
 #: ../vector/v.qcount/main.c:98
 msgid "Quadrat radius"
@@ -21219,18 +20117,15 @@
 #: ../vector/v.qcount/main.c:103
 #, fuzzy
 msgid "Print results in shell script style"
-msgstr ""
-"Stampa le impostazioni della region corrente (in stile script per la shell)"
+msgstr "Stampa i risultati in stile script per la shell"
 #: ../vector/v.qcount/main.c:134
-#, fuzzy
 msgid "Finding quadrats..."
+msgstr ""
 #: ../vector/v.qcount/main.c:139
-#, fuzzy
 msgid "Counting sites in quadrats..."
+msgstr ""
 #: ../vector/v.mkgrid/main.c:65
 msgid "Creates a GRASS vector map of a user-defined grid."
@@ -21239,7 +20134,7 @@
 #: ../vector/v.mkgrid/main.c:76
 #, fuzzy
 msgid "Number of rows and columns in grid"
-msgstr "Nume di righe da tenere in memoria"
+msgstr "Numero di righe e di colonne nella griglia"
 #: ../vector/v.mkgrid/main.c:85
 msgid "Where to place the grid"
@@ -21250,24 +20145,21 @@
 msgstr ""
 #: ../vector/v.mkgrid/main.c:96
-#, fuzzy
 msgid "Lower left easting and northing coordinates of map"
-msgstr "Utilizzando le coordinate del centro della mappa\n"
+msgstr ""
 #: ../vector/v.mkgrid/main.c:104
-#, fuzzy
 msgid "Width and height of boxes in grid"
-msgstr "Spessore dell'evidenziazione"
+msgstr ""
 #: ../vector/v.mkgrid/main.c:111
 #, fuzzy
 msgid "Angle of rotation (in degrees counter-clockwise)"
-msgstr "Angolo di rotazione (in gradi antiorari da est)"
+msgstr "Angolo di rotazione (in gradi in senso antiorario)"
 #: ../vector/v.mkgrid/main.c:119
-#, fuzzy
 msgid "Number of horizontal vertex points per grid cell"
+msgstr ""
 #: ../vector/v.mkgrid/main.c:126
 msgid "Create grid of points instead of areas and centroids"
@@ -21280,7 +20172,7 @@
 #: ../vector/v.mkgrid/main.c:189
 #, fuzzy
 msgid "'coor' option missing"
-msgstr "Mancano le informazioni sulla proiezione"
+msgstr "Opzione 'coor' mancante"
 #: ../vector/v.mkgrid/main.c:192
 msgid "'box' option missing"
@@ -21303,14 +20195,12 @@
 msgstr "Sto creando centroidi...."
 #: ../vector/v.mkgrid/write_grid.c:42
-#, fuzzy
 msgid "Writing out vector rows..."
+msgstr ""
 #: ../vector/v.mkgrid/write_grid.c:79
-#, fuzzy
 msgid "Writing out vector columns..."
+msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:58
 #: ../vector/v.lrs/v.lrs.create/main.c:120
@@ -21320,18 +20210,15 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:60
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:65
 #: ../vector/v.lrs/v.lrs.create/main.c:125
 #: ../vector/v.lrs/v.lrs.label/main.c:107
 #: ../vector/v.lrs/v.lrs.segment/main.c:76 ../vector/v.to.points/main.c:178
-#, fuzzy
 msgid "Input vector map containing lines"
-msgstr "Inserisci il vettore con i punti di controllo"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:69
 msgid "Input vector map containing points"
@@ -21341,15 +20228,13 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:144
 #: ../vector/v.lrs/v.lrs.label/main.c:116
 #: ../vector/v.lrs/v.lrs.segment/main.c:85 ../vector/v.segment/main.c:66
-#, fuzzy
 msgid "Line layer"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:79
 #: ../vector/v.lrs/v.lrs.create/main.c:148
-#, fuzzy
 msgid "Point layer"
-msgstr "Nome del database in input"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:85
 #: ../vector/v.lrs/v.lrs.create/main.c:204
@@ -21368,9 +20253,8 @@
 #: ../vector/v.lrs/v.lrs.where/main.c:101
 #: ../vector/v.lrs/v.lrs.label/main.c:138
 #: ../vector/v.lrs/v.lrs.segment/main.c:107
-#, fuzzy
 msgid "Name of the reference system table"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:108
 msgid "Maximum distance to nearest line"
@@ -21380,35 +20264,34 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:303
 #: ../vector/v.lrs/v.lrs.label/main.c:308
 #: ../vector/v.lrs/v.lrs.segment/main.c:151
-#, fuzzy
 msgid "Unable to open database for reference table"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:220
 #: ../vector/v.lrs/v.lrs.segment/main.c:346
 #, fuzzy, c-format
 msgid "[%d] points read from input"
-msgstr "%d categrie caricate dalla tabella"
+msgstr "[%d] punti letti dall'input"
 #: ../vector/v.lrs/v.lrs.where/main.c:221
 #, fuzzy, c-format
 msgid "[%d] positions found"
+msgstr "Trovate [%d] positioni"
 #: ../vector/v.lrs/v.lrs.where/main.c:223
 #, fuzzy, c-format
 msgid "[%d] points outside threshold"
-msgstr "%d punti esterni ai limiti"
+msgstr "[%d] punti esterni alla soglia"
 #: ../vector/v.lrs/v.lrs.where/main.c:225
 #, fuzzy, c-format
 msgid "[%d] points - no record found"
-msgstr "Utilizza la regione corrente"
+msgstr "[%d] punti - nessun record trovato"
 #: ../vector/v.lrs/v.lrs.where/main.c:227
 #, fuzzy, c-format
 msgid "[%d] points - too many records found"
+msgstr "[%d] punti - trovati troppi record"
 #: ../vector/v.lrs/v.lrs.create/main.c:121
 msgid "Create Linear Reference System"
@@ -21417,17 +20300,17 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:130
 #, fuzzy
 msgid "Output vector map where oriented lines are written"
+msgstr "Nome della mappa vettoriale di output dove sono scritte le linee orientate"
 #: ../vector/v.lrs/v.lrs.create/main.c:135
 #, fuzzy
 msgid "Output vector map of errors"
-msgstr "Visualizza il raster delle aree problematiche"
+msgstr "Mappa vettoriale degli errori di output"
 #: ../vector/v.lrs/v.lrs.create/main.c:140
 #, fuzzy
 msgid "Input vector map containing reference points"
+msgstr "Mappa vettoriale di output contenente i punti di riferimento"
 #: ../vector/v.lrs/v.lrs.create/main.c:155
 msgid "Column containing line identifiers for lines"
@@ -21442,8 +20325,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:179
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
+msgid "Column containing offset from milepost for the beginning of next segment"
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:188
@@ -21457,26 +20339,23 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:221
 #, fuzzy
 msgid "Name of table where the reference system will be written"
+msgstr "Nome della tabella dove verrà scritto il sistema di riferimento"
 #: ../vector/v.lrs/v.lrs.create/main.c:222
 msgid "New table is created by this module"
 msgstr "Una nuova tabella è creata da questo modulo"
 #: ../vector/v.lrs/v.lrs.create/main.c:229
-#, fuzzy
 msgid "Maximum distance of point to line allowed"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:276
-#, fuzzy
 msgid "Cannot get layer info for lines"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:279
-#, fuzzy
 msgid "Cannot get layer info for points"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:314
 #, c-format
@@ -21486,33 +20365,32 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:333
 #, fuzzy, c-format
 msgid "Unable to select line id values from %s.%s."
+msgstr "Non è possibile selezionare i valori id della linea da %s.%s."
 #: ../vector/v.lrs/v.lrs.create/main.c:343
 #, fuzzy
 msgid "Line id column must be integer"
+msgstr "La colonna id della linea dev'essere di tipo integer"
 #: ../vector/v.lrs/v.lrs.create/main.c:354
 #: ../vector/v.lrs/v.lrs.create/main.c:456
-#, fuzzy
 msgid "Unable to fetch line id from line table"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:406
 #, fuzzy, c-format
 msgid "Line [%d] without category (layer [%d])"
+msgstr "Linea [%d] senza categoria (layer [%d])"
 #: ../vector/v.lrs/v.lrs.create/main.c:426
 #, fuzzy, c-format
 msgid "No lines selected for line id [%d]"
+msgstr "Nessuna linea selezionata per l'id della linea [%d]"
 #: ../vector/v.lrs/v.lrs.create/main.c:446
 #, fuzzy, c-format
 msgid "Unable to select point attributes from <%s>"
-msgstr "Non riesco a mostrare i database"
+msgstr "Non è possibile selezionare gli attributi del punto da <%s>"
 #: ../vector/v.lrs/v.lrs.create/main.c:477
 #, c-format
@@ -21527,7 +20405,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:525
 #, fuzzy, c-format
 msgid "Point [%d] without category (layer [%d])"
-msgstr "%d punti senza categoria non considerati"
+msgstr "[%d] punti senza categoria (layer [%d])"
 #: ../vector/v.lrs/v.lrs.create/main.c:572
 #, c-format
@@ -21535,9 +20413,9 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:704
-#, fuzzy, c-format
+#, c-format
 msgid "End > start for point cat [%d]"
-msgstr "Nessun record per la cat = %d"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:721
 msgid "Start of 1. MP >= end of 2. MP for points' cats %[d], [%d]"
@@ -21569,33 +20447,32 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:821
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to insert reference records: %s"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:862
 #, fuzzy
 msgid "Building topology for output (out_lines) map..."
+msgstr "Costruzione della topologia per la mappa di output (out_lines) in corso..."
 #: ../vector/v.lrs/v.lrs.create/main.c:868
 #, fuzzy
 msgid "Building topology for error (err) map..."
+msgstr "Costruzione della topologia per la mappa degli errori (err) in corso..."
 #: ../vector/v.lrs/v.lrs.label/main.c:103
 msgid "Create stationing from input lines, and linear reference system"
 msgstr " Crea dislocazioni da linee, e il sistema di riferimento lineare"
 #: ../vector/v.lrs/v.lrs.label/main.c:111
-#, fuzzy
 msgid "Output vector map where stationing will be written"
-msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.label/main.c:146
 #, fuzzy
 msgid "Label file"
-msgstr " val colore\n"
+msgstr "File delle etichette"
 #: ../vector/v.lrs/v.lrs.label/main.c:155
 msgid "PM left, MP right, stationing left, stationing right offset"
@@ -21604,28 +20481,27 @@
 #: ../vector/v.lrs/v.lrs.label/main.c:160
 #, fuzzy
 msgid "Offset label in label x-direction in map units"
-msgstr "Offset delle etichette nella direzione x"
+msgstr "Offset delle etichette nella direzione x dell'etichetta in unità di mappa"
 #: ../vector/v.lrs/v.lrs.label/main.c:167
 #, fuzzy
 msgid "Offset label in label y-direction in map units"
-msgstr "Offset delle etichette nella direzione y"
+msgstr "Offset delle etichette nella direzione y dell'etichetta in unità di mappa"
 #: ../vector/v.lrs/v.lrs.label/main.c:173 ../vector/v.label/main.c:114
 msgid "Reference position"
 msgstr "Punto di riferimento"
 #: ../vector/v.lrs/v.lrs.label/main.c:202
-#, fuzzy
 msgid "Line width of text"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.label/main.c:203
 #: ../vector/v.lrs/v.lrs.label/main.c:211
 #: ../vector/v.lrs/v.lrs.label/main.c:221
 #, fuzzy
 msgid "Only for d.label output"
-msgstr "Spessore del bordo (solo per l'output di ps.map)"
+msgstr "Solo per l'output di d.label"
 #: ../vector/v.lrs/v.lrs.label/main.c:220
 #, fuzzy
@@ -21635,44 +20511,38 @@
 #: ../vector/v.lrs/v.lrs.label/main.c:246
 #, fuzzy
 msgid "Opaque to vector"
+msgstr "Opaco ai vettori"
 #: ../vector/v.lrs/v.lrs.label/main.c:247
 #, fuzzy
 msgid "Only relevant if background color is selected"
-msgstr "Opaco ai vettori (rilevante solo se si sceglie un colore di sfondo)"
+msgstr "Rilevante solo se si sceglie un colore di sfondo"
 #: ../vector/v.lrs/v.lrs.label/main.c:338
 #, fuzzy, c-format
 msgid "Unable to select records from LRS table: %s"
+msgstr "Non è possibile selezionare i record dalla tabella LRS: %s"
 #: ../vector/v.lrs/v.lrs.label/main.c:428
 #, fuzzy
 msgid "No record in LR table"
-msgstr "Nessun record di categoria '%d' nella tabella"
+msgstr "Nessun record nella tabella LR"
 #: ../vector/v.lrs/v.lrs.label/main.c:432
 msgid "More than one record in LR table"
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:72
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
-msgstr ""
-"Crea punti/segmenti da linee, il sistema di riferimento lineare e i punti "
-"sono letti dallo stdin o da file"
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgstr "Crea punti/segmenti da linee, il sistema di riferimento lineare e i punti sono letti dallo stdin o da file"
 #: ../vector/v.lrs/v.lrs.segment/main.c:80
-#, fuzzy
 msgid "Output vector map where segments will be written"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:112 ../vector/v.segment/main.c:71
-#, fuzzy
 msgid "Name of file containing segment rules. If not given, read from stdin."
+msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:179
 #: ../vector/v.lrs/v.lrs.segment/main.c:233
@@ -21683,18 +20553,18 @@
 #: ../vector/v.lrs/v.lrs.segment/main.c:191
 #, fuzzy, c-format
 msgid "No record in LR table for: %s"
-msgstr "impossibile aprire <%s>"
+msgstr "Nessun record nella tabella LR per: %s"
 #: ../vector/v.lrs/v.lrs.segment/main.c:195
 #, fuzzy, c-format
 msgid "More than one record in LR table for: %s"
+msgstr "Più di un record nella tabella LR per: %s"
 #: ../vector/v.lrs/v.lrs.segment/main.c:202
 #: ../vector/v.lrs/v.lrs.segment/main.c:289
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to find line of cat [%d]"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:212
 #, c-format
@@ -21704,11 +20574,11 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:248
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "No record in LRS table for 1. point of:\n"
 "  %s"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:253
 #, c-format
@@ -21725,11 +20595,11 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:268
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "No record in LRS table for 2. point of:\n"
 "  %s"
+msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:273
 #, c-format
@@ -21764,112 +20634,105 @@
 #: ../vector/v.lrs/v.lrs.segment/main.c:331 ../vector/v.segment/main.c:222
 #, fuzzy, c-format
 msgid "Incorrect segment type: %s"
+msgstr "Tipo di segmento non corretto: %s"
 #: ../vector/v.lrs/v.lrs.segment/main.c:347
 #, fuzzy, c-format
 msgid "[%d] points written to output map (%d lost)"
+msgstr "Scritti [%d] punti sulla mappa di output (%d persi)"
 #: ../vector/v.lrs/v.lrs.segment/main.c:349
 #, fuzzy, c-format
 msgid "[%d] lines read from input"
+msgstr "[%d] linee lette dall'input"
 #: ../vector/v.lrs/v.lrs.segment/main.c:350
 #, fuzzy, c-format
 msgid "[%d] lines written to output map (%d lost)"
+msgstr "Scritte [%d] linee sulla mappa di output (%d perse)"
 #: ../vector/v.reclass/main.c:63
-#, fuzzy
 msgid "vector, reclass, attributes"
+msgstr ""
 #: ../vector/v.reclass/main.c:65
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-"Cambia i valori delle categorie per un esistente vettoriale secondo "
-"risultati di interrogazioni SQL o valori di una colonna della tabella degli "
-"attributi"
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr "Cambia i valori delle categorie per un esistente vettoriale secondo risultati di interrogazioni SQL o valori di una colonna della tabella degli attributi"
 #: ../vector/v.reclass/main.c:82
 #, fuzzy
 msgid "The name of the column whose values are to be used as new categories"
-msgstr "Nome della mappa raster da utilizzare per <%s>"
+msgstr "Il nome della colonna i cui valori devono essere usati come nuove categorie"
 #: ../vector/v.reclass/main.c:83
-#, fuzzy
 msgid "The source for the new key column must be type integer or string"
+msgstr ""
 #: ../vector/v.reclass/main.c:88
 #, fuzzy
 msgid "Full path to the reclass rule file"
+msgstr "Percorso completo del file delle regole di riclassificazione"
 #: ../vector/v.reclass/main.c:99
 #, fuzzy
 msgid "Either 'rules' or 'col' must be specified"
-msgstr "file vettoriale da creare"
+msgstr "Dev'essere specificato il parametro 'rules' o 'col'"
 #: ../vector/v.reclass/main.c:186 ../vector/v.to.rast/vect2rast.c:73
 #: ../vector/v.to.rast/support.c:142 ../vector/v.to.rast/support.c:294
 #, fuzzy, c-format
 msgid "No records selected from table <%s>"
-msgstr "%d records aggiornati"
+msgstr "Nessun record selezionato dalla tabella <%s>"
 #: ../vector/v.reclass/main.c:199
 #, fuzzy
 msgid "Key column type is not integer"
-msgstr "driver pg: colonna '%s', di tipo %d non supportata"
+msgstr "Il formato della colonna chiave non è di tipo integer"
 #: ../vector/v.reclass/main.c:263
 #, fuzzy, c-format
 msgid "Cannot insert data: [%s]"
+msgstr "Impossibile inserire i dati: [%s]"
 #: ../vector/v.reclass/main.c:289
 #, fuzzy
 msgid "Column type must be integer or string"
+msgstr "Il formato della colonna chiave dev'essere di tipo integer o string"
 #: ../vector/v.reclass/main.c:301
 #, fuzzy, c-format
 msgid "Unable to open rule file <%s>"
+msgstr "Non è possibile aprire il file delle regole  <%s>"
 #: ../vector/v.reclass/main.c:317
 #, fuzzy, c-format
 msgid "Category %d overwritten by '%s'"
-msgstr "Valore da scrivere per null"
+msgstr "Categoria %d sovrascritta da '%s'"
 #: ../vector/v.reclass/main.c:321
 #, fuzzy, c-format
 msgid "Category '%s' invalid"
+msgstr "Categoria %s non valida"
 #: ../vector/v.reclass/main.c:325
 #, fuzzy, c-format
 msgid "Label '%s' overwritten by '%s'"
+msgstr "Etichetta '%s' sovrascritta da '%s"
 #: ../vector/v.reclass/main.c:331
 #, c-format
 msgid "Condition '%s' overwritten by '%s'"
-msgstr ""
+msgstr "Condizione '%s'sovrascritta da '%s"
 #: ../vector/v.reclass/main.c:336
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown rule option: '%s'"
-msgstr "Nome del raster"
+msgstr ""
 #: ../vector/v.reclass/main.c:350
 #, fuzzy
 msgid "Cannot select values from database"
+msgstr "Non è possibile selezionare i valori dal database"
 #: ../vector/v.reclass/main.c:366
 #, c-format
@@ -21879,12 +20742,12 @@
 #: ../vector/v.reclass/main.c:392
 #, fuzzy
 msgid "Incomplete rule"
+msgstr "Regola incompleta"
 #: ../vector/v.reclass/main.c:428
 #, fuzzy, c-format
 msgid "%d features reclassed."
-msgstr "%d categorie duplicate nel vettoriale"
+msgstr "%d elementi riclassificati."
 #: ../vector/v.kernel/main.c:72
 #, c-format
@@ -21896,10 +20759,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:111
-msgid ""
-"Generates a raster density map from vector points data using a moving 2D "
-"isotropic Gaussian kernel or optionally generates a vector density map on "
-"vector network with a 1D kernel."
+msgid "Generates a raster density map from vector points data using a moving 2D isotropic Gaussian kernel or optionally generates a vector density map on vector network with a 1D kernel."
 msgstr ""
 #: ../vector/v.kernel/main.c:115
@@ -21909,12 +20769,12 @@
 #: ../vector/v.kernel/main.c:119
 #, fuzzy
 msgid "Input network vector map"
-msgstr "Nome del driver in output"
+msgstr "Mappa vettoriale della rete di input"
 #: ../vector/v.kernel/main.c:127
 #, fuzzy
 msgid "Output raster/vector map"
+msgstr "Mappa raster/vettoriale di output"
 #: ../vector/v.kernel/main.c:133
 #, fuzzy
@@ -21934,31 +20794,25 @@
 #: ../vector/v.kernel/main.c:153
 #, fuzzy
 msgid "Maximum distance from point to network"
+msgstr "Distanza massima dal punto alla rete"
 #: ../vector/v.kernel/main.c:160
 #, fuzzy
 msgid "Multiply the density result by this number"
-msgstr "Moltiplica il risultato di densità per questo fattore"
+msgstr "Moltiplica il risultato di densità per questo numero"
 #: ../vector/v.kernel/main.c:166
-msgid ""
-"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
-"maximum (experimental)"
-msgstr ""
-"Prova a calcolare una deviazione standard ottimale con 'stddeviation' presa "
-"come massimo (sperimentale)"
+msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
+msgstr "Prova a calcolare una deviazione standard ottimale con 'stddeviation' presa come massimo (sperimentale)"
 #: ../vector/v.kernel/main.c:171
 msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr ""
-"Calcola solo la deviazione standard ottimale ed esci (nessuna mappa verrà "
-"creata)"
+msgstr "Calcola solo la deviazione standard ottimale ed esci (nessuna mappa verrà creata)"
 #: ../vector/v.kernel/main.c:230
 #, fuzzy, c-format
 msgid "Network input map <%s> not found"
+msgstr "Mappa della rete <%s> non trovata"
 #: ../vector/v.kernel/main.c:257
 #, c-format
@@ -21967,12 +20821,8 @@
 #: ../vector/v.kernel/main.c:285
 #, c-format
-msgid ""
-"Automatic choose of smoothing parameter (standard deviation), maximum "
-"possible value of standard deviation is was set to %f"
-msgstr ""
-"Scegli automaticamente i parametri di smoothing (deviazione standard), il "
-"massimo valore possibile della deviazione standard è stato posto pari a %f"
+msgid "Automatic choose of smoothing parameter (standard deviation), maximum possible value of standard deviation is was set to %f"
+msgstr "Scegli automaticamente i parametri di smoothing (deviazione standard), il massimo valore possibile della deviazione standard è stato posto pari a %f"
 #: ../vector/v.kernel/main.c:292
 #, c-format
@@ -21991,17 +20841,13 @@
 #: ../vector/v.kernel/main.c:310
 #, fuzzy, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
-msgstr ""
-"Le distanza tra tutti i punti sono oltre %e (4 * deviazione standard), "
-"impossibile calcolare il valore ottimale."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
+msgstr "Le distanze tra tutti i punti sono oltre %e (4 * deviazione standard), impossibile calcolare il valore ottimale."
 #: ../vector/v.kernel/main.c:321
 #, c-format
 msgid "Optimal smoothing parameter (standard deviation): %f."
-msgstr "Parametro di smoothing ottimale (deviazione standard). %f"
+msgstr "Parametro di smoothing ottimale (deviazione standard): %f."
 #: ../vector/v.kernel/main.c:344
 #, c-format
@@ -22010,8 +20856,7 @@
 "Writing output vector map using smooth parameter=%f."
 msgstr ""
 "\n"
-"Sto scrivendo il file vettoriale in output usando il parametro di smoothing=%"
-"f."
+"Sto scrivendo il file vettoriale in output usando il parametro di smoothing=%f."
 #: ../vector/v.kernel/main.c:346 ../vector/v.kernel/main.c:419
 #, c-format
@@ -22038,22 +20883,19 @@
 #: ../vector/v.kernel/main.c:450
 #, fuzzy, c-format
 msgid "Maximum value in output: %e."
-msgstr "Tieni i valori nulli nella mappa in output"
+msgstr "Massimo valore in output: %e"
 #: ../vector/v.out.ogr/main.c:90
 msgid "Converts to one of the supported OGR vector formats."
 msgstr "Converte in uno dei formati vettoriali supportati da OGR"
 #: ../vector/v.out.ogr/main.c:98
-msgid ""
-"Feature type(s). Combinations not supported by all output formats. Default: "
-"first type found in input."
+msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:106
-#, fuzzy
 msgid "OGR output datasource name"
-msgstr "nome database"
+msgstr ""
 #: ../vector/v.out.ogr/main.c:108
 msgid "For example: ESRI Shapefile: filename or directory for storage"
@@ -22071,7 +20913,7 @@
 #: ../vector/v.out.ogr/main.c:140 ../vector/v.out.ogr/main.c:150
 #, fuzzy
 msgid "Creation"
+msgstr "Creazione"
 #: ../vector/v.out.ogr/main.c:129
 msgid "OGR format"
@@ -22094,15 +20936,12 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:163
-msgid ""
-"Export features with category (labeled) only. Otherwise all features are "
-"exported"
+msgid "Export features with category (labeled) only. Otherwise all features are exported"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:168
 msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr ""
-"Usa il file .prj in formato ESRI-style  (applicato solo all'output Shapefile)"
+msgstr "Usa il file .prj in formato ESRI-style  (applicato solo all'output Shapefile)"
 #: ../vector/v.out.ogr/main.c:173
 msgid "Export lines as polygons"
@@ -22118,40 +20957,36 @@
 msgstr "Nome della colonna (che sarà aggiornata con i valori raster)"
 #: ../vector/v.out.ogr/main.c:254
-#, fuzzy
 msgid "Could not determine input map's feature type(s)."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:299
 msgid "The combination of types is not supported by all formats."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:313
-msgid ""
-"The map contains islands. To preserve them in the output map, use the -c flag"
+msgid "The map contains islands. To preserve them in the output map, use the -c flag"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:343
 #, fuzzy, c-format
 msgid "OGR driver <%s> not found"
+msgstr "Driver OGR <%s> non trovato"
 #: ../vector/v.out.ogr/main.c:368
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open OGR data source '%s'"
+msgstr ""
 #: ../vector/v.out.ogr/main.c:389 ../vector/v.out.ogr/main.c:396
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
-"'lco') to export in 3D rather than 2D (default)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:409
 #, fuzzy
 msgid "Unable to create OGR layer"
+msgstr "Non è possibile creare il layer OGR"
 #: ../vector/v.out.ogr/main.c:419
 msgid "No attribute table found -> using only category numbers as attributes"
@@ -22164,106 +20999,84 @@
 #: ../vector/v.out.ogr/main.c:500
 #, fuzzy, c-format
 msgid "Key column '%s' not found"
+msgstr "Colonna chiave '%s' non trovata"
 #: ../vector/v.out.ogr/main.c:510
 #, c-format
-msgid ""
-"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:515
 #, c-format
-msgid ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:521
 #, c-format
-msgid ""
-"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:527
 #, c-format
-msgid ""
-"%d centroid(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:532
 #, c-format
-msgid ""
-"%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:536
 #, c-format
-msgid ""
-"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d face(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:542
 #, c-format
-msgid ""
-"%d kernel(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:547
 #, c-format
-msgid ""
-"%d volume(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d volume(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:553
-msgid ""
-"No points found, but requested to be exported. Will skip this geometry type."
+msgid "No points found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:563
-msgid ""
-"No lines found, but requested to be exported. Will skip this geometry type."
+msgid "No lines found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:574
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this geometry "
-"type."
+msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:584
-msgid ""
-"No areas found, but requested to be exported. Will skip this geometry type."
+msgid "No areas found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:594
-msgid ""
-"No centroids found, but requested to be exported. Will skip this geometry "
-"type."
+msgid "No centroids found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:604
-msgid ""
-"No faces found, but requested to be exported. Will skip this geometry type."
+msgid "No faces found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:614
-msgid ""
-"No kernels found, but requested to be exported. Will skip this geometry type."
+msgid "No kernels found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:624
-msgid ""
-"No volumes found, but requested to be exported. Will skip this geometry type."
+msgid "No volumes found, but requested to be exported. Will skip this geometry type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:635
 #, fuzzy
 msgid "Nothing to export"
+msgstr "Niente da esportare"
 #: ../vector/v.out.ogr/main.c:641
 #, fuzzy, c-format
@@ -22281,9 +21094,9 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:861
-#, fuzzy, c-format
+#, c-format
 msgid "Exporting %i kernels..."
-msgstr "Esportando %i punti/linee..."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:920
 #, fuzzy, c-format
@@ -22302,32 +21115,31 @@
 #: ../vector/v.out.ogr/main.c:936
 #, fuzzy, c-format
 msgid "%d features without category were written"
+msgstr "Sono stati scritti %d elementi senza categoria"
 #: ../vector/v.out.ogr/main.c:938
 #, fuzzy, c-format
 msgid "%d features without attributes were written"
+msgstr "Sono stati scritti %d elementi senza attributi"
 #: ../vector/v.out.ogr/main.c:940
 #, fuzzy, c-format
 msgid "%d features found without category were skipped"
+msgstr "%d elementi trovati senza categoria non considerati"
 #: ../vector/v.out.ogr/main.c:1004
-#, fuzzy, c-format
+#, c-format
 msgid "No database record for cat = %d and export of 'cat' disabled"
-msgstr "Nessun record nel database per la categoria %d"
+msgstr ""
 #: ../vector/v.proj/main.c:63
-#, fuzzy
 msgid "vector, projection, transformation"
+msgstr ""
 #: ../vector/v.proj/main.c:64
 #, fuzzy
 msgid "Re-projects a vector map from one location to the current location."
-msgstr "Riproietta un raster da una location alla location corrente"
+msgstr "Riproietta una mappa vettoriale da una location alla location corrente"
 #: ../vector/v.proj/main.c:76
 msgid "Location containing input vector map"
@@ -22340,7 +21152,7 @@
 #: ../vector/v.proj/main.c:100
 #, fuzzy
 msgid "Name for output vector map (default: input)"
-msgstr "Mostra il titolo del file raster"
+msgstr "Nome della mappa vettoriale di output (predefinito: input)"
 #: ../vector/v.proj/main.c:105
 msgid "List vector maps in input location and exit"
@@ -22370,23 +21182,21 @@
 msgstr "Mapset <%s> nella location di input <%s> non trovato"
 #: ../vector/v.proj/main.c:270
-#, fuzzy, c-format
+#, c-format
 msgid "Reprojecting primitives: "
+msgstr ""
 #: ../vector/v.proj/main.c:281
-#, fuzzy
 msgid "Reading input vector map"
-msgstr "Leggere mappa vettoriale"
+msgstr ""
 #: ../vector/v.proj/main.c:287
 msgid "Error in pj_do_transform"
 msgstr ""
 #: ../vector/v.hull/main.c:141
-#, fuzzy
 msgid "Simple planar hulls not implemented yet"
+msgstr ""
 #: ../vector/v.hull/main.c:275
 msgid "Produces a convex hull for a given vector map."
@@ -22400,7 +21210,7 @@
 #: ../locale/scriptstrings/v.centroids_to_translate.c:3
 #, fuzzy
 msgid "Name of input vector map"
-msgstr "Nome della mappa di input"
+msgstr "Nome della mappa vettoriale di input"
 #: ../vector/v.hull/main.c:279
 msgid "For vector lines reads their vertices"
@@ -22409,7 +21219,7 @@
 #: ../vector/v.hull/main.c:286
 #, fuzzy
 msgid "Use all vector points (do not limit to current region)"
+msgstr "Utilizza tutti i punti vettoriali (non solo quelli nella regione corrente)"
 #: ../vector/v.hull/main.c:291
 msgid "Create a 'flat' 2D hull even if the input is 3D points"
@@ -22418,7 +21228,7 @@
 #: ../vector/v.hull/main.c:314
 #, fuzzy, c-format
 msgid "Error loading vector points from <%s>"
+msgstr "Errore nel caricare i punti vettoriali da <%s>"
 #: ../vector/v.hull/main.c:318
 msgid "Convex hull calculation requires at least three points. Exiting."
@@ -22427,22 +21237,22 @@
 #: ../vector/v.hull/main.c:320
 #, fuzzy, c-format
 msgid "%d points read from vector map <%s>"
+msgstr "Letti %d punti dalla mappa vettoriale <&s>"
 #: ../vector/v.in.dwg/main.c:66
 #, fuzzy
 msgid "Converts DWG/DXF to GRASS vector map"
-msgstr "Importa un file raster binario in una mappa raster GRASS"
+msgstr "Converte un file DWG/DXF in una mappa vettoriale di GRASS"
 #: ../vector/v.in.dwg/main.c:69
 #, fuzzy
 msgid "Name of DWG or DXF file"
+msgstr "Nome del file DWG o DXF"
 #: ../vector/v.in.dwg/main.c:88 ../vector/v.in.ascii/in.c:141
 #, fuzzy
 msgid "Create 3D vector map"
+msgstr "Crea una mappa vettoriale 3D"
 #: ../vector/v.in.dwg/main.c:92
 msgid "Write circles as points (centre)"
@@ -22453,19 +21263,19 @@
 msgstr ""
 #: ../vector/v.in.dwg/main.c:120
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to initialize OpenDWG Toolkit, error: %d: %s."
+msgstr ""
 #: ../vector/v.in.dwg/main.c:123
 #, fuzzy, c-format
 msgid "%s Cannot open %s"
-msgstr "Non riesco ad impostare user/password"
+msgstr "%s Impossibile aprire %s"
 #: ../vector/v.in.dwg/main.c:131
 #, fuzzy, c-format
 msgid "Unable to open input file <%s>. Error %d: %s"
+msgstr "Impossibile aprire il file di input <%s>. Errore %d: %s"
 #: ../vector/v.in.dwg/main.c:266
 #, c-format
@@ -22478,15 +21288,13 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:204
-msgid ""
-"Interpolates point data to a G3D grid volume using regularized spline with "
-"tension (RST) algorithm."
+msgid "Interpolates point data to a G3D grid volume using regularized spline with tension (RST) algorithm."
 msgstr ""
 #: ../vector/v.vol.rst/main.c:237
 #, fuzzy
 msgid "Name of the vector map with input x,y,z,w"
+msgstr "Nome della mappa vettoriale con input x,y,z,w"
 #: ../vector/v.vol.rst/main.c:245
 msgid "Name of the surface raster map for cross-section"
@@ -22495,8 +21303,7 @@
 #: ../vector/v.vol.rst/main.c:252
 #, fuzzy
 msgid "Name of the column containing w attribute to interpolate"
-msgstr ""
-"Nome della mappa raster che contiene la griglia con le informazioni del costo"
+msgstr "Nome della colonna contenente l'attributo w da interpolare"
 #: ../vector/v.vol.rst/main.c:260 ../vector/v.surf.rst/main.c:308
 msgid "Tension parameter"
@@ -22509,16 +21316,15 @@
 #: ../vector/v.vol.rst/main.c:276
 #, fuzzy
 msgid "Name of the column with smoothing parameters"
-msgstr "Nome del file raster in input"
+msgstr "Nome della colonna coi parametri di smoothing"
 #: ../vector/v.vol.rst/main.c:286 ../vector/v.surf.rst/main.c:265
-#, fuzzy
 msgid "Output deviations vector point file"
-msgstr "Visualizza il raster delle altezze dopo il riempimento"
+msgstr ""
 #: ../vector/v.vol.rst/main.c:287 ../vector/v.vol.rst/main.c:295
 msgid "Analysis"
-msgstr ""
+msgstr "Analisi"
 #: ../vector/v.vol.rst/main.c:294
 msgid "Output cross-validation vector map"
@@ -22531,17 +21337,15 @@
 #: ../vector/v.vol.rst/main.c:309 ../vector/v.surf.rst/main.c:331
 #, fuzzy
 msgid "Maximum number of points in a segment"
+msgstr "Numero massimo di punti in un segmento"
 #: ../vector/v.vol.rst/main.c:318 ../vector/v.surf.rst/main.c:340
-#, fuzzy
 msgid "Minimum number of points for approximation in a segment (>segmax)"
-msgstr "Numero minimo di punto per una linea di contorno (0 > nessun limite)"
+msgstr ""
 #: ../vector/v.vol.rst/main.c:327
-#, fuzzy
 msgid "Maximum number of points for approximation in a segment (>npmin)"
+msgstr ""
 #: ../vector/v.vol.rst/main.c:336 ../vector/v.surf.rst/main.c:349
 msgid "Minimum distance between points (to remove almost identical points)"
@@ -22556,14 +21360,12 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:361
-#, fuzzy
 msgid "Output cross-section raster map"
-msgstr "Nome della tabella in output"
+msgstr ""
 #: ../vector/v.vol.rst/main.c:370
-#, fuzzy
 msgid "Output elevation g3d-file"
+msgstr ""
 #: ../vector/v.vol.rst/main.c:378
 msgid "Output gradient magnitude g3d-file"
@@ -22574,23 +21376,20 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:397
-#, fuzzy
 msgid "Output gradient vertical angle g3d-file"
+msgstr ""
 #: ../vector/v.vol.rst/main.c:406
 msgid "Output change of gradient g3d-file"
 msgstr ""
 #: ../vector/v.vol.rst/main.c:415
-#, fuzzy
 msgid "Output gaussian curvature g3d-file"
+msgstr ""
 #: ../vector/v.vol.rst/main.c:424
-#, fuzzy
 msgid "Output mean curvature g3d-file"
+msgstr ""
 #: ../vector/v.vol.rst/main.c:430
 msgid "Perform a cross-validation procedure without volume interpolation"
@@ -22620,18 +21419,15 @@
 #: ../vector/v.vol.rst/main.c:612
 #, fuzzy, c-format
 msgid "Cannot open %s"
+msgstr "Impossibile aprire %s"
 #: ../vector/v.vol.rst/user1.c:107
-#, fuzzy
 msgid "Column type of wcolumn is not supported (must be integer or double)"
+msgstr ""
 #: ../vector/v.vol.rst/user1.c:126
-#, fuzzy
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
+msgstr ""
 #: ../vector/v.net.timetable/main.c:218
 #, fuzzy, c-format
@@ -22714,21 +21510,17 @@
 msgstr "Crea un nuovo vettoriale contenendo altri vettoriali."
 #: ../vector/v.patch/main.c:80
-#, fuzzy
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
+msgstr ""
 #: ../vector/v.patch/main.c:84
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
+msgid "Append files to existing file (overwriting existing files must be activated)"
 msgstr ""
 #: ../vector/v.patch/main.c:89
 #, fuzzy
 msgid "Copy also attribute table"
+msgstr "Copia anche la tabella degli attributi"
 #: ../vector/v.patch/main.c:91
 msgid "Only the table of layer 1 is currently supported"
@@ -22741,27 +21533,26 @@
 #: ../vector/v.patch/main.c:193
 #, fuzzy
 msgid "Key columns differ"
+msgstr "Le colonne chiave sono differenti"
 #: ../vector/v.patch/main.c:199
 #, fuzzy
 msgid "Number of columns differ"
-msgstr "Numero di colonne"
+msgstr "Il numero di colonne è differente"
 #: ../vector/v.patch/main.c:211
 #, fuzzy
 msgid "Column names differ"
+msgstr "I nomi di colonna sono differenti"
 #: ../vector/v.patch/main.c:219
 #, fuzzy
 msgid "Column types differ"
+msgstr "I tipi di colonna sono differenti"
 #: ../vector/v.patch/main.c:224
-#, fuzzy
 msgid "Length of string columns differ"
+msgstr ""
 #: ../vector/v.patch/main.c:238
 msgid "Key column not found"
@@ -22770,12 +21561,12 @@
 #: ../vector/v.patch/main.c:245
 #, fuzzy
 msgid "The output map is not 3D"
-msgstr "Nome della mappa di output"
+msgstr "La mappa di output non è 3D"
 #: ../vector/v.patch/main.c:298
-#, fuzzy, c-format
+#, c-format
 msgid "Patching vector map <%s@%s>..."
-msgstr "Sto disegnando ..."
+msgstr ""
 #: ../vector/v.patch/main.c:322
 #, c-format
@@ -22796,34 +21587,32 @@
 msgstr ""
 #: ../vector/v.patch/main.c:372
-#, fuzzy
 msgid "The header information also may have to be edited"
-msgstr "Le informazioni sulla proiezione non saranno aggiornate"
+msgstr ""
 #: ../vector/v.patch/main.c:374
-#, fuzzy, c-format
+#, c-format
 msgid "%d vector maps patched"
+msgstr ""
 #: ../vector/v.patch/main.c:397
 #, fuzzy, c-format
 msgid "Cannot open select cursor: '%s'"
+msgstr "Impossibile aprire il cursore selezionato: '%s'"
 #: ../vector/v.patch/main.c:408
-#, fuzzy
 msgid "Cannot fetch row"
+msgstr ""
 #: ../vector/v.patch/main.c:459
 #, fuzzy
 msgid "Unknown column type"
-msgstr "Tipo sconosciuto"
+msgstr "Tipo di colonna sconosciuto"
 #: ../vector/v.patch/main.c:467
 #, fuzzy, c-format
 msgid "Cannot insert new record: '%s'"
+msgstr "Impossibile inserire un nuovo record: '%s'"
 #: ../vector/v.net.connectivity/main.c:53
 #, fuzzy
@@ -22899,7 +21688,7 @@
 #: ../vector/v.kcv/main.c:87
 #, fuzzy
 msgid "Number of partitions"
+msgstr "Numero di partizioni"
 #: ../vector/v.kcv/main.c:97
 msgid "Name for new column to which partition number is written"
@@ -22912,12 +21701,12 @@
 #: ../vector/v.kcv/main.c:137 ../vector/v.edit/main.c:130
 #, fuzzy, c-format
 msgid "Unable to open vector map <%s> at topological level %d"
+msgstr "Impossibile aprire la mappa vettoriale <%s> al livello topologico %d"
 #: ../vector/v.kcv/main.c:174
 #, fuzzy, c-format
 msgid "Unable to get layer info for vector map <%s>"
-msgstr "Impossibile ottenere informazioni sul layer vettoriale"
+msgstr "Impossibile ottenere informazioni sul layer per la mappa vettoriale <%s>"
 #: ../vector/v.kcv/main.c:198
 #, c-format
@@ -22925,14 +21714,13 @@
 msgstr "Non posso modificare la tabella: %s"
 #: ../vector/v.support/main.c:40
-#, fuzzy
 msgid "vector, metadata"
-msgstr "File di input"
+msgstr ""
 #: ../vector/v.support/main.c:41
 #, fuzzy
 msgid "Updates vector map metadata."
-msgstr "Metadati basilari per vettoriale"
+msgstr "Aggiorna i metadati della mappa vettoriale"
 #: ../vector/v.support/main.c:52
 msgid "Organization where vector map was created"
@@ -22959,9 +21747,8 @@
 msgstr ""
 #: ../vector/v.support/main.c:95
-#, fuzzy
 msgid "Vector map projection zone"
+msgstr ""
 #: ../vector/v.support/main.c:102
 msgid "Vector map digitizing threshold number (e.g., 0.5)"
@@ -22972,8 +21759,7 @@
 msgstr ""
 #: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
 msgstr ""
 #: ../vector/v.support/main.c:122
@@ -22983,115 +21769,108 @@
 #: ../vector/v.support/main.c:188
 #, fuzzy, c-format
 msgid "Unable to open history file for vector map <%s>"
+msgstr "Non è possibile aprire il file della cronologia per la mappa vettoriale <%s>"
 #: ../vector/v.select/main.c:52
-#, fuzzy
 msgid "vector, spatial query"
-msgstr "vettore da rimuovere"
+msgstr ""
 #: ../vector/v.select/main.c:54
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
-"Elementi selezionati di un vettoriale (A) con gli elementi di un altro "
-"vettoriale (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgstr "Elementi selezionati di un vettoriale (A) con gli elementi di un altro vettoriale (B)."
 #: ../vector/v.select/main.c:87
 #, fuzzy
 msgid "Unknown operator"
+msgstr "Operatore sconosciuto"
 #: ../vector/v.select/main.c:124
 #, fuzzy
 msgid "Output from v.select"
-msgstr "Mappa in output"
+msgstr "Output da v.select"
 #: ../vector/v.select/main.c:149 ../vector/v.category/main.c:231
 #, fuzzy
 msgid "Processing features..."
+msgstr "Elaborazione degli elementi in corso ..."
 #: ../vector/v.select/main.c:172
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read line id %d from vector map <%s>"
+msgstr ""
 #: ../vector/v.select/main.c:278
 #, fuzzy
 msgid "Processing areas..."
+msgstr "Elaborazione delle aree in corso ..."
 #: ../vector/v.select/main.c:301
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read area id %d from vector map <%s>"
+msgstr ""
 #: ../vector/v.select/main.c:446
 #, fuzzy
 msgid "Writing selected features..."
-msgstr "Sto scrivendo i centroidi..."
+msgstr "Scrittura degli elementi selezionati in corso..."
 #: ../vector/v.select/main.c:512
 #, fuzzy, c-format
 msgid "Layer %d - no table"
-msgstr "file raster per la Vista%d"
+msgstr "Layer %d - nessuna tabella"
 #: ../vector/v.select/main.c:527
 #, fuzzy, c-format
 msgid "Layer %d - unable to copy table"
-msgstr "Impossibile copiare la tabella"
+msgstr "Layer %d - impossibile copiare la tabella"
 #: ../vector/v.select/main.c:542
 #, fuzzy, c-format
 msgid "%d features without category skipped"
+msgstr "%d elementi senza categoria non considerati"
 #: ../vector/v.select/main.c:545
 #, fuzzy, c-format
 msgid "%d features written to output."
+msgstr "Scritti %d elementi nell'output"
 #: ../vector/v.select/args.c:10 ../vector/v.overlay/main.c:59
 #, fuzzy
 msgid "Name of input vector map (A)"
+msgstr "Nome della mappa vettoriale di input (A)"
 #: ../vector/v.select/args.c:14 ../vector/v.overlay/main.c:63
 #, fuzzy
 msgid "Feature type (vector map A)"
-msgstr "Nome di un file vettoriale in output"
+msgstr "Tipo di elemento (mappa vettoriale A)"
 #: ../vector/v.select/args.c:19 ../vector/v.overlay/main.c:69
 #, fuzzy
 msgid "Layer number (vector map A)"
+msgstr "Numero del layer (mappa vettoriale A)"
 #: ../vector/v.select/args.c:24 ../vector/v.overlay/main.c:73
 #, fuzzy
 msgid "Name of input vector map (B)"
+msgstr "Nome della mappa vettoriale di input (B)"
 #: ../vector/v.select/args.c:28 ../vector/v.overlay/main.c:77
 #, fuzzy
 msgid "Feature type (vector map B)"
+msgstr "Tipo di elemento (mappa vettoriale B)"
 #: ../vector/v.select/args.c:33 ../vector/v.overlay/main.c:83
 #, fuzzy
 msgid "Layer number (vector map B)"
+msgstr "Numero del layer (mappa vettoriale B)"
 #: ../vector/v.select/args.c:45
 #, fuzzy
 msgid "Operator defines required relation between features"
-msgstr "Punti di blocco della mappa vettoriale"
+msgstr "L'operatore definisce la relazione fra elementi richiesta"
 #: ../vector/v.select/args.c:47
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.select/args.c:53
@@ -23099,15 +21878,7 @@
 msgstr ""
 #: ../vector/v.select/args.c:58
-msgid ""
-"overlap;features partially or completely overlap;equals;features are "
-"spatially equals (using GEOS);disjoint;features do not spatially intersect "
-"(using GEOS);intersects;features spatially intersect (using GEOS);touches;"
-"features spatially touches (using GEOS);crosses;features spatially crosses "
-"(using GEOS);within;feature A is completely inside feature B (using GEOS);"
-"contains;feature B is completely inside feature A (using GEOS);overlaps;"
-"features spatially overlap (using GEOS);relate;feature A is spatially "
-"related to feature B (using GEOS, requires 'relate' option);"
+msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
 msgstr ""
 #: ../vector/v.select/args.c:75
@@ -23117,60 +21888,49 @@
 #: ../vector/v.select/args.c:84
 #, fuzzy
 msgid "Do not skip features without category"
+msgstr "Considera anche gli elementi senza categoria"
 #: ../vector/v.buffer2/main.c:146
-#, fuzzy
 msgid "vector, buffer"
+msgstr ""
 #: ../vector/v.buffer2/main.c:148 ../vector/v.buffer/main.c:256
-msgid ""
-"Creates a buffer around features of given type (areas must contain centroid)."
-msgstr ""
-"Crea un buffer intorno agli elementi di un dato tipo (aree devono contenere "
-"centroide)."
+msgid "Creates a buffer around features of given type (areas must contain centroid)."
+msgstr "Crea un buffer intorno agli elementi di un dato tipo (aree devono contenere centroide)."
 #: ../vector/v.buffer2/main.c:166
-#, fuzzy
 msgid "Buffer distance along major axis in map units"
-msgstr "Uso la massima distanza tra punti. %f"
+msgstr ""
 #: ../vector/v.buffer2/main.c:167 ../vector/v.buffer2/main.c:175
 #: ../vector/v.buffer2/main.c:183 ../vector/v.buffer2/main.c:189
 #: ../vector/v.buffer2/main.c:197 ../vector/v.buffer2/main.c:206
 #, fuzzy
 msgid "Distance"
-msgstr "Distanza dalla zona(e)"
+msgstr "Distanza"
 #: ../vector/v.buffer2/main.c:174
-#, fuzzy
 msgid "Buffer distance along minor axis in map units"
+msgstr ""
 #: ../vector/v.buffer2/main.c:182 ../vector/v.parallel2/main.c:73
 msgid "Angle of major axis in degrees"
 msgstr ""
 #: ../vector/v.buffer2/main.c:188
-#, fuzzy
 msgid "Name of column to use for buffer distances"
+msgstr ""
 #: ../vector/v.buffer2/main.c:196 ../vector/v.buffer/main.c:286
 msgid "Scaling factor for attribute column values"
 msgstr ""
 #: ../vector/v.buffer2/main.c:205 ../vector/v.buffer/main.c:296
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of "
-"buffer"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
 msgstr ""
 #: ../vector/v.buffer2/main.c:221
-msgid ""
-"This is an alias to the distance option. It is retained for backwards "
-"compatibility"
+msgid "This is an alias to the distance option. It is retained for backwards compatibility"
 msgstr ""
 #: ../vector/v.buffer2/main.c:223 ../vector/v.buffer/main.c:271
@@ -23190,16 +21950,11 @@
 msgstr ""
 #: ../vector/v.buffer2/main.c:249 ../vector/v.buffer/main.c:319
-msgid ""
-"The bufcol option may contain bugs during the cleaning step. If you "
-"encounter problems, use the debug option or clean manually with v.clean "
-"tool=break; v.category step=0; v.extract -d type=area"
+msgid "The bufcol option may contain bugs during the cleaning step. If you encounter problems, use the debug option or clean manually with v.clean tool=break; v.category step=0; v.extract -d type=area"
 msgstr ""
 #: ../vector/v.buffer2/main.c:255
-msgid ""
-"The buffer option has been replaced by the distance option and will be "
-"removed in future."
+msgid "The buffer option has been replaced by the distance option and will be removed in future."
 msgstr ""
 #: ../vector/v.buffer2/main.c:258
@@ -23209,60 +21964,58 @@
 #: ../vector/v.buffer2/main.c:262
 #, fuzzy, c-format
 msgid "The tolerance was reset to %g"
-msgstr "La zona UTM è ora impostata a %d"
+msgstr "La tolleranza è stata reimpostata a %g"
 #: ../vector/v.buffer2/main.c:286
 #, fuzzy, c-format
 msgid "The tolerance in map units = %g"
+msgstr "La tolleranza in unità di mappa = %g"
 #: ../vector/v.buffer2/main.c:331
 #, fuzzy, c-format
 msgid "Unable to select data from table <%s>"
+msgstr "Non è possibile selezionare dati dalla tabella <%s>"
 #: ../vector/v.buffer2/main.c:371
 #, fuzzy
 msgid "Buffering lines..."
-msgstr "Sto rompendo le linee"
+msgstr "Creazione dei buffer attorno alle linee in corso..."
 #: ../vector/v.buffer2/main.c:394 ../vector/v.buffer2/main.c:460
 #: ../vector/v.buffer/main.c:473 ../vector/v.buffer/main.c:550
-#, fuzzy, c-format
+#, c-format
 msgid "Attribute is of invalid size (%.3f) for category %d"
-msgstr "L'attributo della categoria %d ha una dimensione errata (%.3f)"
+msgstr ""
 #: ../vector/v.buffer2/main.c:408 ../vector/v.buffer2/main.c:474
 #: ../vector/v.buffer/main.c:335 ../vector/v.buffer/main.c:485
 #: ../vector/v.buffer/main.c:562
 #, c-format
 msgid "The tolerance in map units: %g"
-msgstr ""
+msgstr "La tolleranza in unità di mappa: %g"
 #: ../vector/v.buffer2/main.c:438
 #, fuzzy
 msgid "Buffering areas..."
+msgstr "Creazione dei buffer attorno alle aree in corso ..."
 #: ../vector/v.buffer2/main.c:498 ../vector/v.buffer/main.c:607
 msgid "Building parts of topology..."
 msgstr "Sto creando parti della topologia..."
 #: ../vector/v.buffer2/main.c:501 ../vector/v.buffer/main.c:619
-#, fuzzy
 msgid "Snapping boundaries..."
+msgstr ""
 #: ../vector/v.buffer2/main.c:504 ../vector/v.buffer/main.c:622
-#, fuzzy
 msgid "Breaking boundaries..."
+msgstr ""
 #: ../vector/v.buffer2/main.c:507 ../vector/v.overlay/area_area.c:43
 #: ../vector/v.buffer/main.c:625
 #, fuzzy
 msgid "Removing duplicates..."
+msgstr "Rimozione dei duplicati in corso..."
 #: ../vector/v.buffer2/main.c:519 ../vector/v.overlay/area_area.c:55
 #: ../vector/v.buffer/main.c:637
@@ -23275,56 +22028,45 @@
 msgstr "Sto attaccando i centroidi..."
 #: ../vector/v.voronoi/vo_main.c:119
-msgid ""
-"Creates a Voronoi diagram from an input vector map containing points or "
-"centroids."
-msgstr ""
-"Crea un diagramma di Voronoi da un vettoriale contenente punti o centroidi."
+msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
+msgstr "Crea un diagramma di Voronoi da un vettoriale contenente punti o centroidi."
 #: ../vector/v.voronoi/vo_main.c:134
 msgid "Output tessellation as a graph (lines), not areas"
 msgstr ""
 #: ../vector/v.voronoi/vo_main.c:175
-#, fuzzy
 msgid "Reading sites..."
-msgstr "Mappa raster risultante"
+msgstr ""
 #: ../vector/v.voronoi/vo_main.c:185
-#, fuzzy
 msgid "Voronoi triangulation..."
+msgstr ""
 #: ../vector/v.voronoi/vo_main.c:270
-#, fuzzy
 msgid "Writing sites to output..."
+msgstr ""
 #: ../vector/v.voronoi/vo_main.c:354
 msgid "Cannot copy table"
 msgstr "Non posso copiare la tabella"
 #: ../vector/v.voronoi/dt_main.c:47 ../vector/v.delaunay2/main.c:87
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"Crea una triangolazione Delaunay da un vettoriale contenente punti o "
-"centroidi."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr "Crea una triangolazione Delaunay da un vettoriale contenente punti o centroidi."
 #: ../vector/v.voronoi/dt_main.c:55 ../vector/v.delaunay2/main.c:95
 #, fuzzy
 msgid "Use only points in current region"
+msgstr "Utilizza solo i punti della regione corrente"
 #: ../vector/v.voronoi/dt_main.c:60 ../vector/v.delaunay2/main.c:100
 msgid "Output triangulation as a graph (lines), not areas"
 msgstr ""
 #: ../vector/v.voronoi/dt_main.c:149
-#, fuzzy
 msgid "Cannot calculate area centroid z coordinate"
-msgstr "Non posso calcolare i centroidi"
+msgstr ""
 #: ../vector/v.net.steiner/main.c:58
 #, c-format
@@ -23336,9 +22078,7 @@
 msgstr "Crea albero di Streiner per la rete e i punti scelti"
 #: ../vector/v.net.steiner/main.c:349
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal"
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
 msgstr ""
 #: ../vector/v.net.steiner/main.c:369
@@ -23352,12 +22092,12 @@
 #: ../vector/v.net.steiner/main.c:389
 #, fuzzy
 msgid "Number of steiner points (-1 for all possible)"
-msgstr "Punti di partenza del file raster"
+msgstr "Numero di punti di steiner (-1 per tutti quelli possibili"
 #: ../vector/v.net.steiner/main.c:453
 #, fuzzy
 msgid "Not enough terminals (< 2)"
-msgstr "Nome mappa raster"
+msgstr "Terminali insufficienti (< 2)"
 #: ../vector/v.net.steiner/main.c:459
 msgid "Requested number of Steiner points > than possible"
@@ -23370,8 +22110,7 @@
 #: ../vector/v.net.steiner/main.c:527
 #, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
 msgstr ""
 #: ../vector/v.net.steiner/main.c:532
@@ -23394,9 +22133,8 @@
 msgstr ""
 #: ../vector/v.what/main.c:56
-#, fuzzy
 msgid "vector, querying"
+msgstr ""
 #: ../vector/v.what/main.c:57
 msgid "Queries a vector map layer at given locations."
@@ -23405,7 +22143,7 @@
 #: ../vector/v.what/main.c:70
 #, fuzzy
 msgid "If not given reads from standard input"
-msgstr "File raster ascii da importare"
+msgstr "Se non è dato legge dallo tandard input"
 #: ../vector/v.what/main.c:77
 msgid "Query threshold distance"
@@ -23421,9 +22159,9 @@
 msgstr "Devi creare la topologia sul vettore <%s>"
 #: ../vector/v.what/main.c:178
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown input format, skipping: '%s'"
+msgstr ""
 #: ../vector/v.what/what.c:157
 #, fuzzy, c-format
@@ -23432,7 +22170,11 @@
 "Type: %s\n"
 "Left: %d\n"
 "Right: %d\n"
-msgstr "Linea: %d  Tipo: %s Sinistra: %d  Destra: %d  "
+msgstr ""
+"Id: %d\n"
+"Tipo: %s\n"
+"Sinistra: %d\n"
+"Destra: %d\n"
 #: ../vector/v.what/what.c:180
 #, fuzzy, c-format
@@ -23441,9 +22183,9 @@
 "Number_lines=%d\n"
 "Coordinates=%.6f,%.6f,%.6f\n"
 msgstr ""
-"Nodo[%d]: %d \n"
-"Numero di linee: %d \n"
-"Coordinate: %.6f, %.6f, %.6f\n"
+"Nodo[%d]=%d\n"
+"Numero di linee=%d\n"
+"Coordinate=%.6f,%.6f,%.6f\n"
 #: ../vector/v.what/what.c:185
 #, fuzzy, c-format
@@ -23452,8 +22194,8 @@
 "Number of lines: %d\n"
 "Coordinates: %.6f, %.6f, %.6f\n"
 msgstr ""
-"Nodo[%d]: %d \n"
+"Nodo[%d]: %d\n"
+"Numero di linee: %d\n"
 #: ../vector/v.what/what.c:199
@@ -23461,71 +22203,79 @@
 msgid ""
 "Id: %5d\n"
 "Angle: %.8f\n"
-msgstr "    Linea: %5d  Angolo: %.8f\n"
+msgstr ""
+"Id: %5d\n"
+"Angolo: %.8f\n"
 #: ../vector/v.what/what.c:214
 #, fuzzy, c-format
 msgid "Type: %s"
-msgstr ""
-"Layer: %d\n"
-"categoria: %d\n"
+msgstr "Tipo: %s"
 #: ../vector/v.what/what.c:215
 #, fuzzy, c-format
 msgid "Id: %d\n"
-msgstr "  Isola[%d]: %d\n"
+msgstr "Id: %d\n"
 #: ../vector/v.what/what.c:259
 #, fuzzy, c-format
 msgid ""
 "Line height min: %f\n"
 "Line height max: %f\n"
-msgstr "Altezza linea min: %f max: %f\n"
+msgstr ""
+"Altezza linea min: %f\n"
+"Altezza linea max: %f\n"
 #: ../vector/v.what/what.c:273
 #, fuzzy, c-format
 msgid ""
 "Type: Area\n"
 "Area height: %f\n"
-msgstr "Altezza area: %f\n"
+msgstr ""
+"Tipo: Area\n"
+"Altezza area: %f\n"
 #: ../vector/v.what/what.c:281
 #, fuzzy, c-format
 msgid "Type: Area\n"
-msgstr ""
-"Layer: %d\n"
-"categoria: %d\n"
+msgstr "Tipo: Area\n"
 #: ../vector/v.what/what.c:303
 #, fuzzy, c-format
 msgid ""
 "Area: %d\n"
 "Number of isles: %d\n"
-msgstr "Area: %d  Numero di isole: %d\n"
+msgstr ""
+"Area: %d\n"
+"Numero di isole: %d\n"
 #: ../vector/v.what/what.c:313
 #, fuzzy, c-format
 msgid "Isle[%d]: %d\n"
+msgstr "Isola[%d]: %d\n"
 #: ../vector/v.what/what.c:326
 #, fuzzy, c-format
 msgid "Island: %d In area: %d\n"
-msgstr "Isola: %d nella area: %d\n"
+msgstr "Isola: %d Nella area: %d\n"
 #: ../vector/v.what/what.c:339 ../vector/v.what/what.c:346
 #, fuzzy, c-format
 msgid ""
 "Sq Meters: %.3f\n"
 "Hectares: %.3f\n"
-msgstr "Dimensione - Metri quadri: %.3f\t\tEttari: %.3f\n"
+msgstr ""
+"Metri quadri: %.3f\n"
+"Ettari: %.3f\n"
 #: ../vector/v.what/what.c:341 ../vector/v.what/what.c:349
 #, fuzzy, c-format
 msgid ""
 "Acres: %.3f\n"
 "Sq Miles: %.4f\n"
-msgstr "           Acri: %.3f\t\tMiglia quadrate: %.4f\n"
+msgstr ""
+"Acri: %.3f\n"
+"Miglia quadrate: %.4f\n"
 #: ../vector/v.what/what.c:372
 #, fuzzy, c-format
@@ -23534,7 +22284,7 @@
 "Category: %d\n"
 msgstr ""
 "Layer: %d\n"
-"categoria: %d\n"
+"Categoria: %d\n"
 #: ../vector/v.what/what.c:386
 #, fuzzy, c-format
@@ -23553,25 +22303,19 @@
 #: ../vector/v.transform/get_coor.c:36
 #, fuzzy
 msgid "Reading coordinates from file."
+msgstr "Lettura delle coordinate dal file"
 #: ../vector/v.transform/main.c:72
-#, fuzzy
 msgid "vector, transformation"
+msgstr ""
 #: ../vector/v.transform/main.c:74
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
-msgstr ""
-"Esegue un'attenta trasformazione (shift, riscalare e ruotare, o GPCs) su un "
-"vettoriale"
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
+msgstr "Esegue una trasformazione affine (shift, riscalare e ruotare, o GPCs) su una mappa vettoriale"
 #: ../vector/v.transform/main.c:80
-#, fuzzy
 msgid "Suppress display of residuals or other information"
-msgstr "Sopprimi la stampa della informazioni di intestazione"
+msgstr ""
 #: ../vector/v.transform/main.c:84
 msgid "Shift all z values to bottom=0"
@@ -23580,12 +22324,10 @@
 #: ../vector/v.transform/main.c:89
 #, fuzzy
 msgid "Print the transformation matrix to stdout"
-msgstr "Stampa matrice di correlazione"
+msgstr "Stampa la matrice di trasformazione sullo stdout"
 #: ../vector/v.transform/main.c:95
-msgid ""
-"Instead of points use transformation parameters (xshift, yshift, zshift, "
-"xscale, yscale, zscale, zrot)"
+msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
 msgstr ""
 #: ../vector/v.transform/main.c:97 ../vector/v.transform/main.c:119
@@ -23598,45 +22340,39 @@
 msgstr "Personalizza"
 #: ../vector/v.transform/main.c:106
-#, fuzzy
 msgid "ASCII file holding transform coordinates"
+msgstr ""
 #: ../vector/v.transform/main.c:107
-msgid ""
-"If not given, transformation parameters (xshift, yshift, zshift, xscale, "
-"yscale, zscale, zrot) are used instead"
+msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
 msgstr ""
 #: ../vector/v.transform/main.c:117
-#, fuzzy
 msgid "Shifting value for x coordinates"
+msgstr ""
 #: ../vector/v.transform/main.c:126
-#, fuzzy
 msgid "Shifting value for y coordinates"
+msgstr ""
 #: ../vector/v.transform/main.c:135 ../vector/v.extrude/main.c:84
-#, fuzzy
 msgid "Shifting value for z coordinates"
+msgstr ""
 #: ../vector/v.transform/main.c:144
 #, fuzzy
 msgid "Scaling factor for x coordinates"
+msgstr "Fattore di scala per le coordinate x"
 #: ../vector/v.transform/main.c:153
 #, fuzzy
 msgid "Scaling factor for y coordinates"
+msgstr "Fattore di scala per le coordinate y"
 #: ../vector/v.transform/main.c:162
 #, fuzzy
 msgid "Scaling factor for z coordinates"
+msgstr "Fattore di scala per le coordinate z"
 #: ../vector/v.transform/main.c:172
 msgid "Rotation around z axis in degrees counterclockwise"
@@ -23645,12 +22381,11 @@
 #: ../vector/v.transform/main.c:178
 #, fuzzy
 msgid "Name of table containing transformation parameters"
+msgstr "Nome della tabella contenente i parametri di trasformazione"
 #: ../vector/v.transform/main.c:183
-#, fuzzy
 msgid "Name of attribute column(s) used as transformation parameters"
+msgstr ""
 #: ../vector/v.transform/main.c:185
 msgid "Format: parameter:column, e.g. xshift:xs,yshift:ys,zrot:zr"
@@ -23658,17 +22393,13 @@
 #: ../vector/v.transform/main.c:201
 #, c-format
-msgid ""
-"The '%c' flag is deprecated and will be removed in future. Transformation "
-"parameters are used automatically when no pointsfile is given."
+msgid "The '%c' flag is deprecated and will be removed in future. Transformation parameters are used automatically when no pointsfile is given."
 msgstr ""
 #: ../vector/v.transform/main.c:206
 #, fuzzy, c-format
-msgid ""
-"The '%c' flag is deprecated and will be removed in future. Please use '--"
-"quiet' instead."
+msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
+msgstr "Il flag '%c' è deprecato e in futuro verrà rimosso. Al suo posto usare '--quiet'"
 #: ../vector/v.transform/main.c:212
 #, c-format
@@ -23676,27 +22407,25 @@
 msgstr ""
 #: ../vector/v.transform/main.c:217
-msgid ""
-"Name of table and name for output vector map must be different. Otherwise "
-"the table is overwritten."
+msgid "Name of table and name for output vector map must be different. Otherwise the table is overwritten."
 msgstr ""
 #: ../vector/v.transform/main.c:231
 #, fuzzy, c-format
 msgid "Unable to open file with coordinates <%s>"
-msgstr "Non riesco a trovare il file raster %s"
+msgstr "Non è possibile trovare il file con le coordinate <%s>"
 #: ../vector/v.transform/main.c:311
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to tokenize column string: [%s]"
-msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgstr ""
 #: ../vector/v.transform/main.c:338
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "\n"
 "New vector map <%s> boundary coordinates:"
-msgstr "raster <%s> non trovato"
+msgstr ""
 #: ../vector/v.transform/main.c:340
 #, c-format
@@ -23714,22 +22443,19 @@
 msgstr ""
 #: ../vector/v.transform/trans_digit.c:96
-#, fuzzy, c-format
+#, c-format
 msgid "Unsupported column type of <%s>"
+msgstr ""
 #: ../vector/v.transform/trans_digit.c:104
 #, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
 msgstr ""
 #: ../vector/v.transform/trans_digit.c:115
 #, fuzzy
 msgid "No category number defined. Using default transformation parameters."
-msgstr ""
-"Verifica le informazioni sul datum e stampa i parametri di trasformazione"
+msgstr "Nessun numero di categoria definito. Si stanno usando i parametri di trasformazione predefiniti"
 #: ../vector/v.transform/creat_trans.c:69
 #, c-format
@@ -23743,17 +22469,17 @@
 #: ../vector/v.transform/creat_trans.c:118
 #, fuzzy
 msgid "Error reading coordinates file"
+msgstr "Errore nella lettura del file delle coordinate"
 #: ../vector/v.transform/creat_trans.c:123
 #, fuzzy, c-format
 msgid "Number of points that have been entered [%d]"
-msgstr "Numero di passi attraverso il dataset"
+msgstr "Numero di punti che sono stati inseriti [%d]"
 #: ../vector/v.transform/creat_trans.c:126
 #, fuzzy
 msgid "Error creating transformation"
-msgstr "Stampa solo il tipo di mappa raster"
+msgstr "Errore nel creare la trasformazione"
 #: ../vector/v.transform/setup_trans.c:83
 msgid "The points weren't spread out enough."
@@ -23773,23 +22499,15 @@
 msgstr "Overlay due vettoriali."
 #: ../vector/v.overlay/main.c:95
-#, fuzzy
 msgid "Operator defines features written to output vector map"
+msgstr ""
 #: ../vector/v.overlay/main.c:98
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.overlay/main.c:103
-msgid ""
-"and;also known as 'intersection' in GIS;or;also known as 'union' in GIS "
-"(only for atype=area);not;features from ainput not overlayed by features "
-"from binput;xor;features from either ainput or binput but not those from "
-"ainput overlayed by binput (only for atype=area)"
+msgid "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS (only for atype=area);not;features from ainput not overlayed by features from binput;xor;features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
 msgstr ""
 #: ../vector/v.overlay/main.c:114
@@ -23808,12 +22526,11 @@
 #: ../vector/v.overlay/main.c:199
 #, fuzzy, c-format
 msgid "Copying vector objects from vector map <%s>..."
+msgstr "Copia in corso degli oggetti vettoriali dalla mappa vettoriale <%s>..."
 #: ../vector/v.overlay/main.c:261
-#, fuzzy
 msgid "Collecting input attributes..."
-msgstr "Non riesco a copiare la tabella"
+msgstr ""
 #: ../vector/v.overlay/main.c:344
 #, c-format
@@ -23821,9 +22538,9 @@
 msgstr "Tipo di colonna sconosciuto '%s'"
 #: ../vector/v.overlay/main.c:409
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown column type '%s' values lost"
+msgstr ""
 #: ../vector/v.overlay/main.c:474
 msgid "Building partial topology..."
@@ -23842,12 +22559,11 @@
 #: ../vector/v.overlay/area_area.c:211
 #, fuzzy
 msgid "Attribute not found"
+msgstr "Attributo non trovato"
 #: ../vector/v.overlay/area_area.c:46
-#, fuzzy
 msgid "Cleaning boundaries at nodes..."
+msgstr ""
 #: ../vector/v.overlay/area_area.c:78
 #, c-format
@@ -23865,17 +22581,14 @@
 #: ../vector/v.class/main.c:58
 #, fuzzy
 msgid "Column name or expression"
-msgstr "nome tabella"
+msgstr "Nome di colonna o espressione"
 #: ../vector/v.class/main.c:85
 msgid "Print only class breaks (without min and max)"
 msgstr ""
 #: ../vector/v.class/main.c:166
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
 msgstr ""
 #: ../vector/v.class/main.c:193
@@ -23906,49 +22619,42 @@
 msgstr ""
 #: ../vector/v.build.polylines/main.c:108
-#, fuzzy
 msgid "vector, geometry, topology"
+msgstr ""
 #: ../vector/v.build.polylines/main.c:109
 msgid "Builds polylines from lines or boundaries."
 msgstr "Crea polilinee da linee o confini."
 #: ../vector/v.build.polylines/main.c:119
-#, fuzzy
 msgid "Category number mode"
+msgstr ""
 #: ../vector/v.build.polylines/main.c:121
-msgid ""
-"no;Do not assign any category number to polyline;first;Assign category "
-"number of first line to polyline;multi;Assign multiple category numbers to "
-"polyline"
+msgid "no;Do not assign any category number to polyline;first;Assign category number of first line to polyline;multi;Assign multiple category numbers to polyline"
 msgstr ""
 #: ../vector/v.build.polylines/main.c:206
 #, fuzzy, c-format
 msgid "%d lines or boundaries found in vector map <%s@%s>"
+msgstr "%d linee o confini trovati nella mappa vettoriale  <%s@%s>"
 #: ../vector/v.build.polylines/main.c:208
 #, fuzzy, c-format
 msgid "%d polylines stored in vector map <%s@%s>"
+msgstr "%d polilinee memorizzate nella mappa vettoriale <%s@%s>"
 #: ../vector/v.convert/main.c:36
-#, fuzzy
 msgid "vector, import, conversion"
+msgstr ""
 #: ../vector/v.convert/main.c:37
 msgid "Imports older versions of GRASS vector maps."
 msgstr "Importa vecchie versione di vettori GRASS"
 #: ../vector/v.convert/main.c:54
-#, fuzzy
 msgid "Endian of input vector map"
+msgstr ""
 #: ../vector/v.convert/type.c:29
 #, c-format
@@ -23975,7 +22681,7 @@
 #: ../vector/v.convert/old2new.c:72
 #, fuzzy
 msgid "Attaching categories..."
+msgstr "Assegnazione delle categorie in corso..."
 #: ../vector/v.convert/old2new.c:89
 #, c-format
@@ -23990,82 +22696,75 @@
 #: ../vector/v.convert/old2new.c:103
 #, fuzzy
 msgid "Writing new file..."
-msgstr "Nome del raster map esistente"
+msgstr "Scrittura del nuovo file in corso..."
 #: ../vector/v.convert/old2new.c:125
 #, fuzzy, c-format
 msgid "[%d] points and lines written to output file."
+msgstr "Scritti [%d] punti e linee nel file di output."
 #: ../vector/v.convert/old2new.c:139
 #, fuzzy, c-format
 msgid "[%d] centroids written to output file."
+msgstr "Scritti [%d] centroidi nel file di output."
 #: ../vector/v.convert/att.c:36
 msgid "No category labels (dig_cats) found, no table created"
 msgstr ""
 #: ../vector/v.convert/att.c:41
-#, fuzzy
 msgid "Unable to open dig_cats file"
+msgstr ""
 #: ../vector/v.convert/att.c:67 ../vector/v.info/main.c:212
 #, fuzzy, c-format
 msgid "Unable to open driver <%s>"
+msgstr "Impossibile aprire il driver <%s>"
 #: ../vector/v.convert/read.c:41
-#, fuzzy
 msgid "Reading dig file..."
+msgstr ""
 #: ../vector/v.convert/read.c:82
-#, fuzzy
 msgid "Input file is version 3."
+msgstr ""
 #: ../vector/v.convert/read.c:86
-#, fuzzy
 msgid "Input file is version 4."
+msgstr ""
 #: ../vector/v.convert/read.c:96
-#, fuzzy
 msgid "Input file is portable."
+msgstr ""
 #: ../vector/v.convert/read.c:99
-msgid ""
-"Input file is not portable. We will attempt to convert anyway but conversion "
-"may fail. Please read manual for detail information."
+msgid "Input file is not portable. We will attempt to convert anyway but conversion may fail. Please read manual for detail information."
 msgstr ""
 #: ../vector/v.convert/read.c:185
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] points read to memory"
+msgstr ""
 #: ../vector/v.convert/read.c:186
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] lines read to memory"
-msgstr "%d distanza lette dalla mappa."
+msgstr ""
 #: ../vector/v.convert/read.c:189
 #, fuzzy, c-format
 msgid "[%d] points read and written to output"
+msgstr "[%d] punti letti e scritti sull'output"
 #: ../vector/v.convert/read.c:190
 #, fuzzy, c-format
 msgid "[%d] lines read and written to output"
+msgstr "[%d] linee lette e scritte sull'output"
 #: ../vector/v.convert/read.c:192
 #, fuzzy, c-format
 msgid "[%d] area boundaries read and written to output"
+msgstr "[%d] confini di area letti e scritti sull'output"
 #: ../vector/v.convert/read.c:193
 #, c-format
@@ -24088,14 +22787,13 @@
 msgstr ""
 #: ../vector/v.convert/read.c:198
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] elements read to memory"
+msgstr ""
 #: ../vector/v.convert/read.c:241
-#, fuzzy
 msgid "Reading dig_att file..."
+msgstr ""
 #: ../vector/v.convert/read.c:249
 #, c-format
@@ -24110,27 +22808,27 @@
 #: ../vector/v.convert/read.c:293
 #, fuzzy, c-format
 msgid "[%d] point categories read"
+msgstr "Lette [%d] categorie di punti"
 #: ../vector/v.convert/read.c:294
 #, fuzzy, c-format
 msgid "[%d] line categories read"
+msgstr "Lette [%d] categorie di linee"
 #: ../vector/v.convert/read.c:295
 #, fuzzy, c-format
 msgid "[%d] centroids read"
-msgstr "Non riesco a descrivere la tabella"
+msgstr "Letti [%d] centroidi"
 #: ../vector/v.convert/read.c:296
 #, fuzzy, c-format
 msgid "[%d] dead point categories skipped"
-msgstr "%d punti senza categoria non considerati"
+msgstr "[%d] punti senza categoria non considerati"
 #: ../vector/v.convert/read.c:297
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] dead line categories skipped"
+msgstr ""
 #: ../vector/v.convert/read.c:298
 #, c-format
@@ -24138,14 +22836,14 @@
 msgstr ""
 #: ../vector/v.convert/read.c:299
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] categories of unknown type skipped"
-msgstr "%d categrie caricate dalla tabella"
+msgstr ""
 #: ../vector/v.convert/read.c:301
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] categories read into memory"
+msgstr ""
 #: ../vector/v.net.flow/main.c:58
 #, fuzzy
@@ -24222,12 +22920,12 @@
 #: ../vector/v.segment/main.c:57
 #, fuzzy
 msgid "Name of input vector map containing lines"
-msgstr "Inserisci il vettore con i punti di controllo"
+msgstr "Nome della mappa vettoriale di input contenente le linee"
 #: ../vector/v.segment/main.c:61
 #, fuzzy
 msgid "Name for output vector map where segments will be written"
-msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
+msgstr "Nome della mappa vettoriale di output su cui scrivere i segmenti"
 #: ../vector/v.segment/main.c:137 ../vector/v.segment/main.c:177
 #, c-format
@@ -24237,7 +22935,7 @@
 #: ../vector/v.segment/main.c:147 ../vector/v.segment/main.c:186
 #, fuzzy, c-format
 msgid "Unable to find line of cat %d"
+msgstr "Impossibile trovare la linea di categoria %d"
 #: ../vector/v.segment/main.c:157
 #, c-format
@@ -24260,22 +22958,22 @@
 #: ../vector/v.segment/main.c:227
 #, fuzzy, c-format
 msgid "%d points read from input"
+msgstr "%d punti letti dall'input"
 #: ../vector/v.segment/main.c:228
 #, fuzzy, c-format
 msgid "%d points written to output map (%d lost)"
+msgstr "Scritti %d punti nella mappa di output (%d persi)"
 #: ../vector/v.segment/main.c:230
 #, fuzzy, c-format
 msgid "%d lines read from input"
+msgstr "%d linee lette dall'input"
 #: ../vector/v.segment/main.c:231
 #, fuzzy, c-format
 msgid "%d lines written to output map (%d lost)"
+msgstr "Scritte %d linee nella mappa di output (%d perse)"
 #: ../vector/v.normal/main.c:80
 msgid "Tests for normality for points."
@@ -24284,27 +22982,22 @@
 #: ../vector/v.normal/main.c:223
 #, fuzzy
 msgid "Doing log transformation"
+msgstr "Si sta effettuando la trasformazione logaritmica"
 #: ../vector/v.net.path/main.c:42
 msgid "Finds shortest path on vector network."
 msgstr "Trova il percorso più breve in una rete vettoriale."
 #: ../vector/v.net.path/main.c:65
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
+msgid "Name of file containing start and end points. If not given, read from stdin"
 msgstr ""
 #: ../vector/v.net.path/main.c:92
-#, fuzzy
 msgid "Maximum distance to the network"
-msgstr "Distanza massima dal punto visualizzato (metri)"
+msgstr ""
 #: ../vector/v.net.path/main.c:93
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
 msgstr ""
 #: ../vector/v.net.path/main.c:106
@@ -24314,17 +23007,17 @@
 #: ../vector/v.net.path/path.c:82
 #, fuzzy, c-format
 msgid "[%d] points without category (nfield: [%d])"
+msgstr "[%d] punti senza categoria (nfield: [%d])"
 #: ../vector/v.net.path/path.c:168 ../vector/v.net.path/path.c:186
 #, fuzzy, c-format
 msgid "No point with category [%d]"
+msgstr "Nessun punto con categoria [%d]"
 #: ../vector/v.net.path/path.c:205
 #, c-format
 msgid "Point with category [%d] is not reachable from point with category [%d]"
-msgstr ""
+msgstr "Il punto con categoria [%d] non è raggiungibile dal punto con categoria [%d]"
 #: ../vector/v.net.path/path.c:262
 #, c-format
@@ -24334,12 +23027,12 @@
 #: ../vector/v.net.path/path.c:327
 #, fuzzy, c-format
 msgid "[%d] input format errors"
-msgstr "%s errori di aggiornamento\n"
+msgstr "[%d] errori nel formato di input"
 #: ../vector/v.net.path/path.c:329
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] points of given category missing"
+msgstr ""
 #: ../vector/v.net.path/path.c:331
 #, c-format
@@ -24347,12 +23040,8 @@
 msgstr ""
 #: ../vector/v.univar/main.c:73
-msgid ""
-"Calculates univariate statistics for attribute. Variance and standard "
-"deviation is calculated only for points if specified."
-msgstr ""
-"Calcola statistiche univariate per gli attributi. Varianza e deviazione "
-"standard è calcolate solo per punti se specificato."
+msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
+msgstr "Calcola statistiche univariate per gli attributi. Varianza e deviazione standard è calcolate solo per punti se specificato."
 #: ../vector/v.univar/main.c:86
 msgid "Column name"
@@ -24367,28 +23056,27 @@
 msgid ""
 "Required parameter <%s> not set:\n"
 "\t(%s)"
+msgstr ""
+"Il parametro richiesto <%s> non è stato impostato:\n"
+"\t(%s)"
 #: ../vector/v.univar/main.c:145
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
 msgstr ""
 #: ../vector/v.univar/main.c:150
 #, fuzzy
 msgid "Extended statistics is currently supported only for points/centroids"
-msgstr "Visualizza i formati supportati ed esci"
+msgstr "Le statistiche estese attualmente sono supportate solo per punti/centroidi"
 #: ../vector/v.univar/main.c:187
 #, fuzzy, c-format
 msgid "Unable select categories from table <%s>"
-msgstr "Non riesco a selezionare dati dalla tabella"
+msgstr "Non è possibile selezionare le categorie dalla tabella <%s>"
 #: ../vector/v.univar/main.c:547
-#, fuzzy
 msgid "Cannot sort the key/value array"
+msgstr ""
 #: ../vector/v.label/main.c:63
 msgid "Creates paint labels for a vector map from attached attributes."
@@ -24421,9 +23109,7 @@
 #: ../vector/v.label/main.c:138
 msgid "Space between letters for curled labels (in map-units)"
-msgstr ""
-"Spazio tra le lettere per le etichette disposte lungo la linea (in unità "
-"della mappa)"
+msgstr "Spazio tra le lettere per le etichette disposte lungo la linea (in unità della mappa)"
 #: ../vector/v.label/main.c:145
 msgid "Label size (in points)"
@@ -24439,11 +23125,8 @@
 msgstr ""
 #: ../vector/v.label/main.c:252
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
-msgstr ""
-"Dimensione e spaziatura variano significativamente e possono fornire un "
-"output insoddisfacente!"
+msgid "size and space options vary significantly which may lead to crummy output"
+msgstr "Dimensione e spaziatura variano significativamente e possono fornire un output insoddisfacente!"
 #: ../vector/v.label/main.c:260
 msgid "Too many parameters for <reference>"
@@ -24457,7 +23140,7 @@
 #: ../vector/v.delaunay2/main.c:141
 #, fuzzy
 msgid "no points to triangulate"
-msgstr "Utilizzando le coordinate del centro della mappa\n"
+msgstr "nessun punto da triangolare"
 #: ../vector/v.delaunay2/main.c:149
 msgid "Delaunay triangulation..."
@@ -24471,17 +23154,17 @@
 #: ../vector/v.delaunay2/main.c:162
 #, fuzzy
 msgid "Calculate area centroids..."
-msgstr "Centroidi dell'area duplicati"
+msgstr "Calcolo dei centroidi dell'area in corso..."
 #: ../vector/v.delaunay2/main.c:172 ../vector/v.category/main.c:263
 #, fuzzy
 msgid "Unable to calculate area centroid"
+msgstr "Non è possibile calcolare il centroide dell'area"
 #: ../vector/v.delaunay2/main.c:178
 #, fuzzy
 msgid "Unable to calculate area centroid z coordinate"
+msgstr "Non è possibile calcolare la coordinata z del centroide dell'area"
 #: ../vector/v.delaunay2/memory.c:64 ../vector/v.delaunay2/memory.c:70
 #: ../vector/v.delaunay2/memory.c:74 ../vector/v.delaunay2/memory.c:84
@@ -24489,39 +23172,33 @@
 #: ../vector/v.delaunay2/memory.c:108
 #, fuzzy
 msgid "Not enough memory."
+msgstr "Memoria insufficiente"
 #: ../vector/v.delaunay2/memory.c:124
 msgid "All allocated edges have been used."
 msgstr ""
 #: ../vector/v.to.rast/main.c:38
-#, fuzzy
 msgid "vector, raster, conversion"
-msgstr "Nome della mappa raster da utilizzare per <%s>"
+msgstr ""
 #: ../vector/v.to.rast/main.c:39
 #, fuzzy
 msgid "Converts (rasterize) a vector map into a raster map."
-msgstr "Converte vettore binario GRASS in raster GRASS"
+msgstr "Converte una mappa vettoriale in una mappa raster (la rasterizza)."
 #: ../vector/v.to.rast/main.c:60
-#, fuzzy
 msgid "Source of raster values"
-msgstr "Forza l'output usando valori interi"
+msgstr ""
 #: ../vector/v.to.rast/main.c:61
-msgid ""
-"attr;read values from attribute table;cat;use category values;val;use value "
-"specified by value option;z;use z coordinate (points or contours only);dir;"
-"output as flow direction (lines only)"
+msgid "attr;read values from attribute table;cat;use category values;val;use value specified by value option;z;use z coordinate (points or contours only);dir;output as flow direction (lines only)"
 msgstr ""
 #: ../vector/v.to.rast/main.c:70
 #, fuzzy
 msgid "Name of column for 'attr' parameter (data type must be numeric)"
-msgstr ""
-"Nome della colonna per il parametro attr (tipo di dato dovrà essere numerico)"
+msgstr "Nome della colonna per il parametro 'attr' (il tipo di dato dev'essere numerico)"
 #: ../vector/v.to.rast/main.c:76
 msgid "Name of color definition column (with RRR:GGG:BBB entries)"
@@ -24529,12 +23206,11 @@
 #: ../vector/v.to.rast/main.c:82
 msgid "Name of column used as raster category labels"
-msgstr "Nome della colonna usata come categoria del raster"
+msgstr "Nome della colonna usata come etichette di categoria del raster"
 #: ../vector/v.to.rast/main.c:91
-#, fuzzy
 msgid "Raster value (for use=val)"
-msgstr "File raster per superficie"
+msgstr ""
 #: ../vector/v.to.rast/main.c:112
 msgid "Column parameter missing (or use value parameter)"
@@ -24555,7 +23231,7 @@
 #: ../vector/v.to.rast/main.c:133
 #, fuzzy, c-format
 msgid "Unknown option '%s'"
-msgstr "Nome del raster"
+msgstr "Opzione '%s' sconosciuta"
 #: ../vector/v.to.rast/do_lines.c:65 ../vector/v.to.rast/do_areas.c:63
 msgid "Unable to use column specified"
@@ -24579,12 +23255,12 @@
 #: ../vector/v.what.rast/main.c:155
 #, fuzzy, c-format
 msgid "Column <%s> not found"
+msgstr "Colonna <%s> non trovata"
 #: ../vector/v.to.rast/vect2rast.c:69
-#, fuzzy, c-format
+#, c-format
 msgid "Column type (%s) not supported (did you mean 'labelcolumn'?)"
-msgstr "driver pg: colonna '%s', di tipo %d non supportata"
+msgstr ""
 #: ../vector/v.to.rast/vect2rast.c:101
 #, c-format
@@ -24599,12 +23275,12 @@
 #: ../vector/v.to.rast/vect2rast.c:132
 #, fuzzy
 msgid "Unknown raster map type"
+msgstr "Tipo di mappa raster sconosciuta"
 #: ../vector/v.to.rast/vect2rast.c:140
 #, fuzzy, c-format
 msgid "Unable to process areas from vector map <%s>"
-msgstr "impossibile aprire <%s>"
+msgstr "Impossibile elaborare aree dalla mappa vettoriale <%s>"
 #: ../vector/v.to.rast/vect2rast.c:156
 #, c-format
@@ -24612,9 +23288,9 @@
 msgstr ""
 #: ../vector/v.to.rast/vect2rast.c:164
-#, fuzzy, c-format
+#, c-format
 msgid "Problem processing areas from vector map <%s>, continuing..."
+msgstr ""
 #: ../vector/v.to.rast/vect2rast.c:175
 #, c-format
@@ -24624,7 +23300,7 @@
 #: ../vector/v.to.rast/vect2rast.c:199
 #, fuzzy
 msgid "Creating support files for raster map..."
-msgstr "Errore nella lettura del file dbmscap\n"
+msgstr "Creazione dei file di supporto per la mappa raster in corso..."
 #: ../vector/v.to.rast/vect2rast.c:206
 msgid "Color can be updated from database only if use=attr"
@@ -24673,14 +23349,13 @@
 msgstr "Tipo di colonna (%s) non supportata"
 #: ../vector/v.to.rast/support.c:427
-#, fuzzy
 msgid "Cannot allocate memory for row buffer"
+msgstr ""
 #: ../vector/v.to.rast/support.c:495
 #, fuzzy, c-format
 msgid "Unable to write categories for raster map <%s>"
-msgstr "Nome della mappa raster risultante"
+msgstr "Impossibile scrivere le categorie per la mappa rster <%s>"
 #: ../vector/v.to.rast/do_areas.c:49 ../vector/v.to.rast/do_areas.c:57
 #, c-format
@@ -24688,9 +23363,9 @@
 msgstr "Nessun record per l'area (cat = %d)"
 #: ../vector/v.to.rast/do_areas.c:78
-#, fuzzy, c-format
+#, c-format
 msgid "Get area %d failed"
+msgstr ""
 #: ../vector/v.to.rast/do_areas.c:118
 msgid "Area without centroid (may be OK for island)"
@@ -24707,17 +23382,17 @@
 #: ../vector/v.to.points/main.c:182
 #, fuzzy
 msgid "Output vector map where points will be written"
+msgstr "Mappa vettoriale di output su cui scrivere i punti"
 #: ../vector/v.to.points/main.c:194
 #, fuzzy
 msgid "Write line nodes"
-msgstr "Titolo, fra virgolette"
+msgstr "Scrive i nodi della linea"
 #: ../vector/v.to.points/main.c:198
 #, fuzzy
 msgid "Write line vertices"
+msgstr "Scrive i vertici della linea"
 #: ../vector/v.to.points/main.c:202
 msgid "Interpolate points between line vertices"
@@ -24726,7 +23401,7 @@
 #: ../vector/v.to.points/main.c:209
 #, fuzzy
 msgid "Maximum distance between points in map units"
+msgstr "Distanza massima tra i punti in unità di mappa"
 #: ../vector/v.to.points/main.c:229
 msgid "Use either -n or -v flag, not both"
@@ -24735,27 +23410,26 @@
 #: ../vector/v.to.points/main.c:384
 #, fuzzy, c-format
 msgid "%d points written to output vector map"
+msgstr "Scritti %d punti nella mappa vettoriale di output"
 #: ../vector/v.in.ascii/points.c:83
-#, fuzzy
 msgid "Scanning input for column types..."
+msgstr ""
 #: ../vector/v.in.ascii/points.c:165
-#, fuzzy, c-format
+#, c-format
 msgid "Unparsable longitude value in column <%d>: %s"
+msgstr ""
 #: ../vector/v.in.ascii/points.c:184
-#, fuzzy, c-format
+#, c-format
 msgid "Unparsable latitude value in column <%d>: %s"
+msgstr ""
 #: ../vector/v.in.ascii/points.c:265
-#, fuzzy, c-format
+#, c-format
 msgid "Skipping %d of %d rows falling outside of current region"
-msgstr "Utilizza la regione corrente"
+msgstr ""
 #: ../vector/v.in.ascii/points.c:293
 msgid "Importing points..."
@@ -24764,49 +23438,47 @@
 #: ../vector/v.in.ascii/a2b.c:52
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad type) [%s]"
+msgstr "Errore nella lettura del file ASCII: (bad type) [%s]"
 #: ../vector/v.in.ascii/a2b.c:90
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (unknown type) [%s]"
+msgstr "Errore nella lettura del file ASCII: (tipo sconosciuto) [%s]"
 #: ../vector/v.in.ascii/a2b.c:103 ../vector/v.edit/a2b.c:136
-#, fuzzy
 msgid "End of ASCII file reached before end of coordinates"
+msgstr ""
 #: ../vector/v.in.ascii/a2b.c:114
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading ASCII file: (bad point) [%s]"
+msgstr ""
 #: ../vector/v.in.ascii/a2b.c:118
-#, fuzzy, c-format
+#, c-format
 msgid "Unparsable longitude value: [%s]"
+msgstr ""
 #: ../vector/v.in.ascii/a2b.c:121
-#, fuzzy, c-format
+#, c-format
 msgid "Unparsable latitude value: [%s]"
+msgstr ""
 #: ../vector/v.in.ascii/a2b.c:154
-#, fuzzy
 msgid "End of ASCII file reached before end of categories"
+msgstr ""
 #: ../vector/v.in.ascii/a2b.c:164
 #, fuzzy, c-format
 msgid "Error reading categories: [%s]"
+msgstr "Errore nella lettura delle categorie : [%s]"
 #: ../vector/v.in.ascii/head.c:22
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Unexpected data in vector head:\n"
 "[%s]"
+msgstr ""
 #: ../vector/v.in.ascii/head.c:56
 #, c-format
@@ -24820,7 +23492,7 @@
 #: ../vector/v.in.ascii/in.c:56
 #, fuzzy
 msgid "ASCII file to be imported, if not given reads from standard input"
+msgstr "File ASCII da importare, se non viene fornito legge dallo standard input"
 #: ../vector/v.in.ascii/in.c:67
 msgid "point;simple x,y[,z] list;standard;GRASS vector ASCII format"
@@ -24834,7 +23506,7 @@
 #: ../vector/v.in.ascii/in.c:152
 #, fuzzy
 msgid "Input format"
-msgstr "Formato del file di input"
+msgstr "Formato di input"
 #: ../vector/v.in.ascii/in.c:83
 msgid "Number of header lines to skip at top of input file (points mode)"
@@ -24845,9 +23517,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/in.c:93
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name varchar"
-"(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
 msgstr ""
 #: ../vector/v.in.ascii/in.c:105 ../vector/v.in.ascii/in.c:115
@@ -24857,12 +23527,12 @@
 #: ../vector/v.in.ascii/in.c:114
 #, fuzzy
 msgid "Number of column used as y coordinate (points mode)"
+msgstr "Numero di colonna utilizzata come coordinata y (points mode)"
 #: ../vector/v.in.ascii/in.c:124
 #, fuzzy
 msgid "Number of column used as z coordinate (points mode)"
+msgstr "Numero di colonna utilizzata come coordinata z (points mode)"
 #: ../vector/v.in.ascii/in.c:125
 msgid "First column is 1. If 0, z coordinate is not used"
@@ -24871,12 +23541,10 @@
 #: ../vector/v.in.ascii/in.c:135
 #, fuzzy
 msgid "Number of column used as category (points mode)"
+msgstr "Nome della colonna usata come categoria (points mode)"
 #: ../vector/v.in.ascii/in.c:137
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written "
-"to new column 'cat'"
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
 msgstr ""
 #: ../vector/v.in.ascii/in.c:146
@@ -24910,12 +23578,12 @@
 #: ../vector/v.in.ascii/in.c:200
 #, fuzzy
 msgid "Column numbers must not be negative"
-msgstr "Nessuna mappa in input specificata"
+msgstr "I numeri della colonna non devono essere negativi"
 #: ../vector/v.in.ascii/in.c:204 ../vector/v.edit/main.c:77
 #, fuzzy, c-format
 msgid "Unable to open ASCII file <%s>"
+msgstr "impossibile aprire il file ASCII <%s>"
 #: ../vector/v.in.ascii/in.c:256
 #, c-format
@@ -24925,12 +23593,12 @@
 #: ../vector/v.in.ascii/in.c:257
 #, fuzzy, c-format
 msgid "Maximum number of columns: %d"
+msgstr "Numero massimo di colonne: %d"
 #: ../vector/v.in.ascii/in.c:258
 #, fuzzy, c-format
 msgid "Minimum number of columns: %d"
+msgstr "Numero minimo di colonne: %d"
 #: ../vector/v.in.ascii/in.c:263
 msgid ""
@@ -24945,13 +23613,11 @@
 msgstr ""
 #: ../vector/v.in.ascii/in.c:271
-msgid ""
-"z column number > minimum last column number (incorrect field separator?)"
+msgid "z column number > minimum last column number (incorrect field separator?)"
 msgstr ""
 #: ../vector/v.in.ascii/in.c:276
-msgid ""
-"cat column number > minimum last column number (incorrect field separator?)"
+msgid "cat column number > minimum last column number (incorrect field separator?)"
 msgstr ""
 #: ../vector/v.in.ascii/in.c:282
@@ -24976,8 +23642,7 @@
 #: ../vector/v.in.ascii/in.c:417
 #, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in input"
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
 msgstr ""
 #: ../vector/v.in.ascii/in.c:445
@@ -24991,9 +23656,9 @@
 msgstr ""
 #: ../vector/v.in.ascii/in.c:458
-#, fuzzy, c-format
+#, c-format
 msgid "Column number %d <%s> defined as integer has double values"
+msgstr ""
 #: ../vector/v.in.ascii/in.c:463
 #, c-format
@@ -25016,14 +23681,11 @@
 msgstr ""
 #: ../vector/v.in.ascii/in.c:523
-#, fuzzy
 msgid "Populating table..."
+msgstr ""
 #: ../vector/v.in.ascii/in.c:530
-msgid ""
-"Could not close attribute table. The DBMI driver did not accept all "
-"attributes"
+msgid "Could not close attribute table. The DBMI driver did not accept all attributes"
 msgstr ""
 #: ../vector/v.external/main.c:60
@@ -25031,9 +23693,8 @@
 msgstr "Crea nuovo vettore come link in sola lettura a un layer OGR"
 #: ../vector/v.external/main.c:75
-#, fuzzy
 msgid "Output vector. If not given, available layers are printed only."
+msgstr ""
 #: ../vector/v.external/main.c:83
 msgid ""
@@ -25043,14 +23704,12 @@
 msgstr ""
 #: ../vector/v.external/main.c:91
-#, fuzzy
 msgid "Output vector name was not specified"
-msgstr "file vettoriale da creare"
+msgstr ""
 #: ../vector/v.external/main.c:96
-#, fuzzy
 msgid "Cannot open data source"
+msgstr ""
 #: ../vector/v.clean/main.c:44
 msgid "Toolset for cleaning topology of vector map."
@@ -25059,35 +23718,18 @@
 #: ../vector/v.clean/main.c:53
 #, fuzzy
 msgid "Name of output map where errors are written"
+msgstr "Nome della mappa di output dove sono scritti gli errori"
 #: ../vector/v.clean/main.c:64
 msgid "Cleaning tool"
 msgstr ""
 #: ../vector/v.clean/main.c:66
-msgid ""
-"break;break lines at each intersection;rmdupl;remove duplicate geometry "
-"features (pay attention to categories!);rmdangle;remove dangles, threshold "
-"ignored if < 0;chdangle;change the type of boundary dangle to line, "
-"threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges "
-"connecting area and island or 2 islands;chbridge;change the type of bridges "
-"connecting area and island or 2 islands from boundary to line;snap;snap "
-"lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' "
-"option ignored);bpol;break (topologically clean) polygons (imported from non "
-"topological format, like ShapeFile). Boundaries are broken on each point "
-"shared between 2 and more polygons where angles of segments are different;"
-"prune;remove vertices in threshold from lines and boundaries, boundary is "
-"pruned only if topology is not damaged (new intersection, changed "
-"attachement of centroid), first and last segment of the boundary is never "
-"changed;rmarea;remove small areas, the longest boundary with adjacent area "
-"is removed;rmline;remove all lines or boundaries of zero length, threshold "
-"is ignored;rmsa;remove small angles between lines at nodes"
+msgid "break;break lines at each intersection;rmdupl;remove duplicate geometry features (pay attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;chdangle;change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges connecting area and island or 2 islands;chbridge;change the type of bridges connecting area and island or 2 islands from boundary to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed;rmarea;remove small a
 reas, the longest boundary with adjacent area is removed;rmline;remove all lines or boundaries of zero length, threshold is ignored;rmsa;remove small angles between lines at nodes"
 msgstr ""
 #: ../vector/v.clean/main.c:94
-msgid ""
-"Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
 msgstr ""
 #: ../vector/v.clean/main.c:100
@@ -25148,9 +23790,8 @@
 msgstr ""
 #: ../vector/v.clean/main.c:220
-#, fuzzy
 msgid "Prune"
-msgstr "Stampa"
+msgstr ""
 #: ../vector/v.clean/main.c:223
 msgid "Remove small areas"
@@ -25244,14 +23885,13 @@
 msgstr "Sto ricostruendo la topologia per la mappa vettoriale di output..."
 #: ../vector/v.clean/main.c:386
-#, fuzzy
 msgid "Building topology for error vector map..."
+msgstr ""
 #: ../vector/v.clean/rmdac.c:61
-#, fuzzy, c-format
+#, c-format
 msgid "Duplicate area centroids: %d"
+msgstr ""
 #: ../vector/v.clean/prune.c:214
 #, c-format
@@ -25268,69 +23908,58 @@
 #: ../vector/v.clean/rmline.c:62
 #, fuzzy, c-format
 msgid "Lines / boundaries removed: %d"
-msgstr "%d linee / confini rimossi"
+msgstr "Linee / confini rimossi: %d"
 #: ../vector/v.surf.idw/main.c:86
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
-msgstr ""
-"Interpolazione della superficie da un vettore puntuale con peso inverso "
-"delle distanze al quadrato IDW"
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr "Interpolazione della superficie da un vettore puntuale con peso inverso delle distanze al quadrato IDW"
 #: ../vector/v.surf.idw/main.c:95
 msgid "If set to 0, z coordinates are used (3D vector only)"
 msgstr ""
 #: ../vector/v.surf.idw/main.c:98 ../vector/v.surf.idw/main.c:106
-#, fuzzy
 msgid "Values"
-msgstr "colonne: %d"
+msgstr ""
 #: ../vector/v.surf.idw/main.c:104
 #, fuzzy
 msgid "Attribute table column with values to interpolate"
+msgstr "Colonna della tabella degli attributi coi valori da interpolare"
 #: ../vector/v.surf.idw/main.c:105
 msgid "Required if layer > 0"
 msgstr ""
 #: ../vector/v.surf.idw/main.c:122
-msgid ""
-"Power parameter; greater values assign greater influence to closer points"
+msgid "Power parameter; greater values assign greater influence to closer points"
 msgstr ""
 #: ../vector/v.surf.idw/main.c:127
-#, fuzzy
 msgid "Don't index points by raster cell"
+msgstr ""
 #: ../vector/v.surf.idw/main.c:128
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
 msgstr ""
 #: ../vector/v.surf.idw/main.c:147
-#, fuzzy
 msgid "No attribute column specified"
+msgstr ""
 #: ../vector/v.surf.idw/main.c:182
-#, fuzzy
 msgid "No data points found"
+msgstr ""
 #: ../vector/v.surf.idw/main.c:267
 #, fuzzy, c-format
 msgid "Interpolating raster map <%s> (%d rows, %d cols)... "
+msgstr "Interpolazione della mappa raster <%s> in corso (%d righe, %d colonne)..."
 #: ../vector/v.surf.idw/read_sites.c:102
 #, fuzzy, c-format
 msgid "%d points loaded"
-msgstr "%d categorie duplicate nel vettoriale"
+msgstr "%d punti caricati"
 #: ../vector/v.parallel/main.c:40
 msgid "Create parallel line to input lines"
@@ -25341,9 +23970,8 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:278
-#, fuzzy
 msgid "Attribute column to use for buffer distances"
+msgstr ""
 #: ../vector/v.buffer/main.c:305
 msgid "Stop the process at a certain stage"
@@ -25355,9 +23983,8 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:432
-#, fuzzy
 msgid "Lines buffers... "
+msgstr ""
 #: ../vector/v.buffer/main.c:492 ../vector/v.buffer/main.c:569
 #, c-format
@@ -25365,63 +23992,55 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:509
-#, fuzzy
 msgid "Areas buffers... "
+msgstr ""
 #: ../vector/v.buffer/main.c:644 ../vector/v.buffer/main.c:734
 #, fuzzy
 msgid "Calculating centroids for areas..."
+msgstr "Calcolo dei centroidi per le aree in corso..."
 #: ../vector/v.buffer/main.c:686
 #, fuzzy
 msgid "Generating list of boundaries to be deleted..."
-msgstr "Sto disegnando ..."
+msgstr "Generazione dell'elenco dei confini da cancellare in corso..."
 #: ../vector/v.buffer/main.c:718
 #, fuzzy
 msgid "Deleting boundaries..."
+msgstr "Cancellazione dei confini in corso..."
 #: ../vector/v.edit/main.c:55
-#, fuzzy
 msgid "vector, editing, geometry"
+msgstr ""
 #: ../vector/v.edit/main.c:56
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-"Modifica un vettore, permette aggiunte, eliminzione e modifica degli "
-"elementi del vettore selezionato"
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr "Modifica un vettore, permette aggiunte, eliminzione e modifica degli elementi del vettore selezionato"
 #: ../vector/v.edit/main.c:65
 #, fuzzy, c-format
 msgid "Unable to get category list <%s>"
+msgstr "Impossibile ottenere la lista delle categorie <%s>"
 #: ../vector/v.edit/main.c:98
 msgid "Creating new DB connection based on default mapset settings..."
 msgstr ""
 #: ../vector/v.edit/main.c:153
-#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
+#, c-format
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
+msgstr ""
 #: ../vector/v.edit/main.c:168
 #, fuzzy, c-format
 msgid "Background vector map <%s> registered"
+msgstr "La mappa vettoriale di sfondo <%s> è stata registrata"
 #: ../vector/v.edit/main.c:208
 #, fuzzy
 msgid "Selecting features..."
+msgstr "Selezione degli elementi in corso..."
 #: ../vector/v.edit/main.c:220
 msgid "No features selected, nothing to edit"
@@ -25429,104 +24048,100 @@
 #: ../vector/v.edit/main.c:228
 #, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
 msgstr ""
 #: ../vector/v.edit/main.c:266
 #, fuzzy, c-format
 msgid "%d features added"
+msgstr "%d elementi aggiunti"
 #: ../vector/v.edit/main.c:268 ../vector/v.edit/main.c:289
 #: ../vector/v.edit/main.c:297 ../vector/v.edit/main.c:322
 #: ../vector/v.edit/main.c:359
-#, fuzzy, c-format
+#, c-format
 msgid "Threshold value for snapping is %.2f"
-msgstr "Il valore di Threshold dev'essere specificato"
+msgstr ""
 #: ../vector/v.edit/main.c:277
 #, fuzzy, c-format
 msgid "%d boundaries closed"
+msgstr "%d confini chiusi"
 #: ../vector/v.edit/main.c:284
 #, fuzzy, c-format
 msgid "%d features deleted"
+msgstr "%d elementi cancellati"
 #: ../vector/v.edit/main.c:292
 #, fuzzy, c-format
 msgid "%d features moved"
+msgstr "%d elementi spostati"
 #: ../vector/v.edit/main.c:301
 #, fuzzy, c-format
 msgid "%d vertices moved"
+msgstr "%d vertici spostati"
 #: ../vector/v.edit/main.c:305
 #, fuzzy, c-format
 msgid "%d vertices added"
+msgstr "%d vertici aggiunti"
 #: ../vector/v.edit/main.c:309
 #, fuzzy, c-format
 msgid "%d vertices removed"
+msgstr "%d vertici rimossi"
 #: ../vector/v.edit/main.c:319
 #, fuzzy, c-format
 msgid "%d lines broken"
+msgstr "%d linee spezzate."
 #: ../vector/v.edit/main.c:325
 #, fuzzy, c-format
 msgid "%d lines connected"
+msgstr "%d linee collegate"
 #: ../vector/v.edit/main.c:329
 #, fuzzy, c-format
 msgid "%d lines merged"
+msgstr "%d linee unite"
 #: ../vector/v.edit/main.c:337 ../vector/v.edit/main.c:341
 #, fuzzy, c-format
 msgid "%d features modified"
+msgstr "%d elementi modificati"
 #: ../vector/v.edit/main.c:346
 #, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
 msgstr ""
 #: ../vector/v.edit/main.c:356
 #, fuzzy, c-format
 msgid "%d features copied"
+msgstr "%d %d elementi copiati"
 #: ../vector/v.edit/main.c:365
-#, fuzzy, c-format
+#, c-format
 msgid "%d lines flipped"
+msgstr ""
 #: ../vector/v.edit/main.c:385
 #, fuzzy, c-format
 msgid "%d lines labeled"
+msgstr "%d linee etichettate"
 #: ../vector/v.edit/main.c:392
 #, fuzzy, c-format
 msgid "%d features converted"
+msgstr "%d elementi convertiti"
 #: ../vector/v.edit/main.c:395
 #, fuzzy
 msgid "No feature modified"
+msgstr "Nessun elemento modificato"
 #: ../vector/v.edit/main.c:400
 msgid "Operation not implemented"
@@ -25535,56 +24150,43 @@
 #: ../vector/v.edit/args.c:38
 #, fuzzy
 msgid "Name of vector map to edit"
+msgstr "Nome della mappa vettoriale da modificare"
 #: ../vector/v.edit/args.c:54
 msgid "Tool"
-msgstr ""
+msgstr "Strumenti"
 #: ../vector/v.edit/args.c:55
-msgid ""
-"create;Create new (empty) vector map;add;Add new features to existing vector "
-"map;delete;Delete selected features from vector map;move;Move selected "
-"features in vector map;vertexmove;Move vertex of selected vector lines;"
-"vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex "
-"to selected vector lines;merge;Merge selected vector lines;break;Break/split "
-"vector lines;select;Select lines and print their ID's;catadd;Set new "
-"categories to selected vector features for defined layer;catdel;Delete "
-"categories from selected vector features for defined layer;copy;Copy "
-"selected features;snap;Snap vector features in given threshold;flip;Flip "
-"direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-"
-"labeling (automated assignment of z coordinate to vector lines);chtype;"
-"Change feature type (point<->centroid, line<->boundary)"
+msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
 msgstr ""
 #: ../vector/v.edit/args.c:100
 #, fuzzy
 msgid "ASCII file to be converted to binary vector map"
+msgstr "File ASCII da convertire in una mappa vettoriale binaria"
 #: ../vector/v.edit/args.c:102
 #, fuzzy
 msgid "If not given (or \"-\") reads from standard input"
+msgstr "Se non è dato (o \"-\") legge dallo standard input"
 #: ../vector/v.edit/args.c:112
 msgid "Difference in x,y direction for moving feature or vertex"
 msgstr ""
 #: ../vector/v.edit/args.c:119
-#, fuzzy
 msgid "Threshold distance (coords,snap,query)"
+msgstr ""
 #: ../vector/v.edit/args.c:121
 #, fuzzy
 msgid "'-1' for threshold based on the current resolution settings"
+msgstr "'-1' per soglia basata sulle impostazioni di risoluzione correnti"
 #: ../vector/v.edit/args.c:137
 #, fuzzy
 msgid "List of point coordinates"
+msgstr "Lista delle coordinate dei punti"
 #: ../vector/v.edit/args.c:146
 msgid "Bounding box for selecting features"
@@ -25603,26 +24205,20 @@
 msgstr ""
 #: ../vector/v.edit/args.c:170
-msgid ""
-"length;Select only lines or boundaries shorter/longer than threshold "
-"distance;dangle;Select dangles shorter/longer than threshold distance"
+msgid "length;Select only lines or boundaries shorter/longer than threshold distance;dangle;Select dangles shorter/longer than threshold distance"
 msgstr ""
 #: ../vector/v.edit/args.c:178
 #, fuzzy
 msgid "Name of background vector map(s)"
-msgstr "Nome di un file vettoriale in output"
+msgstr "Nome della mappa/e vettoriale di sfondo"
 #: ../vector/v.edit/args.c:185
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
 msgstr ""
 #: ../vector/v.edit/args.c:187
-msgid ""
-"no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to "
-"vertex"
+msgid "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to vertex"
 msgstr ""
 #: ../vector/v.edit/args.c:195
@@ -25638,9 +24234,8 @@
 msgstr ""
 #: ../vector/v.edit/args.c:211
-#, fuzzy
 msgid "Do not expect header of input data"
-msgstr "Non riesco ad impostare user/password"
+msgstr ""
 #: ../vector/v.edit/args.c:221
 msgid "Modify only first found feature in bounding box"
@@ -25649,17 +24244,17 @@
 #: ../vector/v.edit/args.c:233
 #, fuzzy
 msgid "Polygon must have at least 3 coordinate pairs"
-msgstr "Nome del file in output"
+msgstr "Il poligono deve avere almeno 3 coppie di coordinate"
 #: ../vector/v.edit/args.c:294
 #, fuzzy, c-format
 msgid "Operation '%s' not implemented"
+msgstr "Operazione '%s' non implementata"
 #: ../vector/v.edit/args.c:303
 #, fuzzy, c-format
 msgid "At least one option from %s must be specified"
+msgstr "Si deve specificare almeno un'opzione da %s"
 #: ../vector/v.edit/args.c:309 ../vector/v.edit/args.c:318
 #: ../vector/v.edit/args.c:325 ../vector/v.edit/args.c:332
@@ -25672,22 +24267,21 @@
 #: ../vector/v.edit/a2b.c:147
 #, fuzzy, c-format
 msgid "Error reading ASCII file: '%s'"
+msgstr "Errore nella lettura del file ASCII: '%s'"
 #: ../vector/v.edit/a2b.c:178
-#, fuzzy
 msgid "End of ascii file reached before end of categories"
+msgstr ""
 #: ../vector/v.edit/a2b.c:189
 #, fuzzy, c-format
 msgid "Error reading categories: '%s'"
+msgstr "Errore nella lettura delle categorie: '%s'"
 #: ../vector/v.edit/a2b.c:236
-#, fuzzy, c-format
+#, c-format
 msgid "Unexpected data in vector head: '%s'"
+msgstr ""
 #: ../vector/v.edit/a2b.c:270
 #, c-format
@@ -25697,31 +24291,30 @@
 #: ../vector/v.edit/a2b.c:328 ../vector/v.edit/snap.c:111
 #, fuzzy, c-format
 msgid "Unable to rewrite line %d"
+msgstr "Impossibile riscrivere la linea %d"
 #: ../vector/v.edit/select.c:72
 #, fuzzy, c-format
 msgid "Threshold value for coordinates is %.2f"
+msgstr "Il valore di soglia per le coordinate è %.2f"
 #: ../vector/v.edit/select.c:159
 #, fuzzy, c-format
 msgid "Threshold value for querying is %.2f"
+msgstr "Il valore di soglia per le interrogazioni è %.2f"
 #: ../vector/v.edit/select.c:175
 #, fuzzy, c-format
 msgid "%d of %d features selected from vector map <%s>"
+msgstr "%d di %d elementi selezionati dalla mappa vettoriale <%s>"
 #: ../vector/v.edit/select.c:500
 msgid "Layer must be > 0 for 'where'"
 msgstr ""
 #: ../vector/v.info/main.c:63
-#, fuzzy
 msgid "vector, metadata, history"
-msgstr "File di input"
+msgstr ""
 #: ../vector/v.info/main.c:65
 msgid "Outputs basic information about a user-specified vector map."
@@ -25730,7 +24323,7 @@
 #: ../vector/v.info/main.c:74
 #, fuzzy
 msgid "Print vector history instead of info"
-msgstr "tabelle di sistema invece che tabelle utente"
+msgstr "Stampa la cronologia del vettoriale invece delle informazioni"
 #: ../vector/v.info/main.c:80
 msgid "Print types/names of table columns for specified layer instead of info"
@@ -25739,12 +24332,12 @@
 #: ../vector/v.info/main.c:95
 #, fuzzy
 msgid "Print topology information only"
+msgstr "Stampa solo le informazioni sulla topologia"
 #: ../vector/v.info/main.c:199 ../vector/v.db.connect/main.c:160
 #, fuzzy, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
-msgstr "Connessione al database non definita\n"
+msgstr "La connessione al database per la mappa <%s> non è definita nel file DB"
 #: ../vector/v.info/main.c:205
 #, c-format
@@ -25754,9 +24347,7 @@
 #: ../vector/v.info/main.c:240
 #, fuzzy, c-format
 msgid "Layer:           %s"
-msgstr ""
-"Layer: %d\n"
-"categoria: %d\n"
+msgstr "Layer:           %s"
 #: ../vector/v.info/main.c:242
 #, c-format
@@ -25789,9 +24380,9 @@
 msgstr "Formato della mappa:      %s"
 #: ../vector/v.info/main.c:254
-#, fuzzy, c-format
+#, c-format
 msgid "Name of creator: %s"
-msgstr "Nome della mappa raster"
+msgstr ""
 #: ../vector/v.info/main.c:256
 #, c-format
@@ -25816,7 +24407,7 @@
 #: ../vector/v.info/main.c:277
 #, c-format
 msgid "  Number of lines:        %-9ld       Number of islands:    %-9ld"
-msgstr "  Numero di linee:       %-9ld       Numero di isolee:      %-9ld"
+msgstr "  Numero di linee:       %-9ld       Numero di isole:      %-9ld"
 #: ../vector/v.info/main.c:282
 #, c-format
@@ -25831,12 +24422,12 @@
 #: ../vector/v.info/main.c:292
 #, fuzzy, c-format
 msgid "  Map is 3D:              %s"
-msgstr "  La mappa è 3D:              %d"
+msgstr "  La mappa è 3D:              %s"
 #: ../vector/v.info/main.c:295
-#, fuzzy, c-format
+#, c-format
 msgid "  Number of dblinks:      %-9ld"
+msgstr ""
 #: ../vector/v.info/main.c:304
 #, c-format
@@ -25859,9 +24450,8 @@
 msgstr ""
 #: ../vector/v.extrude/main.c:68
-#, fuzzy
 msgid "vector, geometry, 3D"
-msgstr "vettore da rimuovere"
+msgstr ""
 #: ../vector/v.extrude/main.c:70
 msgid "Extrudes flat vector object to 3D with defined height."
@@ -25874,12 +24464,12 @@
 #: ../vector/v.extrude/main.c:77
 #, fuzzy
 msgid "Name of input 2D vector map"
-msgstr "Nome della mappa di input"
+msgstr "Nome della mappa vettoriale 2D di input"
 #: ../vector/v.extrude/main.c:80
 #, fuzzy
 msgid "Name of resulting 3D vector map"
+msgstr "Nome della mappa vettoriale 3D risultante"
 #: ../vector/v.extrude/main.c:92
 msgid "Elevation raster for height extraction"
@@ -25890,35 +24480,33 @@
 msgstr ""
 #: ../vector/v.extrude/main.c:104
-#, fuzzy
 msgid "Name of attribute column with object heights"
-msgstr "Nome del file raster in input"
+msgstr ""
 #: ../vector/v.extrude/main.c:118
 #, fuzzy, c-format
 msgid "One of '%s' or '%s' parameters must be set"
-msgstr ""
-"Solo una delle seguenti opzioni: '%s', '%s' or '%s' deve essere specificata"
+msgstr "Dev'essere impostato uno dei seguenti parametri: '%s' o '%s'"
 #: ../vector/v.extrude/main.c:193
 #, fuzzy
 msgid "Extruding areas..."
+msgstr "Estrusione delle aree in corso..."
 #: ../vector/v.extrude/main.c:218
 #, fuzzy, c-format
 msgid "Cannot select attributes for area %d"
-msgstr "Non riesco a mostrare i database"
+msgstr "Impossibile selezionare gli attributi per l'area %d"
 #: ../vector/v.extrude/main.c:257
 #, fuzzy
 msgid "Extruding vector primitives..."
+msgstr "Estrusione delle primitive vettoriali in corso..."
 #: ../vector/v.extrude/main.c:290
 #, fuzzy, c-format
 msgid "Cannot select attributes for area #%d"
+msgstr "Impossibile selezionare gli attributi per l'area #%d"
 #: ../vector/v.extrude/main.c:308
 #, c-format
@@ -25926,9 +24514,8 @@
 msgstr ""
 #: ../vector/v.category/main.c:69
-#, fuzzy
 msgid "vector, category"
+msgstr ""
 #: ../vector/v.category/main.c:71
 msgid "Attach, delete or report vector categories to map geometry."
@@ -25937,15 +24524,10 @@
 #: ../vector/v.category/main.c:85
 #, fuzzy
 msgid "Action to be done"
+msgstr "Azione da eseguire"
 #: ../vector/v.category/main.c:86
-msgid ""
-"add;add a new category;del;delete all categories of given layer;chlayer;"
-"change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the "
-"value specified by cat option to the current category value;report;print "
-"report (statistics), in shell style: layer type count min max;print;print "
-"category values, more cats in the same layer are separated by '/'"
+msgid "add;add a new category;del;delete all categories of given layer;chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
 msgstr ""
 #: ../vector/v.category/main.c:102
@@ -25966,20 +24548,17 @@
 msgstr ""
 #: ../vector/v.category/main.c:137
-msgid ""
-"Database connection and attribute tables for concerned layers are not changed"
+msgid "Database connection and attribute tables for concerned layers are not changed"
 msgstr ""
 #: ../vector/v.category/main.c:155
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
 msgstr ""
 #: ../vector/v.category/main.c:164
 #, fuzzy, c-format
 msgid "%d errors in id option"
-msgstr "Punto di riferimento"
+msgstr "%d errori nell'opzione id"
 #: ../vector/v.category/main.c:185
 msgid "Too many layers for this operation"
@@ -25990,21 +24569,18 @@
 msgstr ""
 #: ../vector/v.category/main.c:192
-#, fuzzy
 msgid "Output vector wasn't entered"
+msgstr ""
 #: ../vector/v.category/main.c:276
-#, fuzzy, c-format
+#, c-format
 msgid "%d new centroids placed in output map"
-msgstr "Punti di blocco della mappa vettoriale"
+msgstr ""
 #: ../vector/v.category/main.c:465
 #, fuzzy
 msgid "Layer/table"
-msgstr ""
-"Layer: %d\n"
-"categoria: %d\n"
+msgstr "Layer/tabella"
 #: ../vector/v.category/main.c:469
 msgid "Layer"
@@ -26018,11 +24594,11 @@
 #: ../vector/v.category/main.c:472
 #, fuzzy
 msgid "point"
-msgstr "Stampa"
+msgstr "punto"
 #: ../vector/v.category/main.c:476
 msgid "line"
-msgstr ""
+msgstr "linea"
 #: ../vector/v.category/main.c:480
 #, fuzzy
@@ -26031,7 +24607,7 @@
 #: ../vector/v.category/main.c:484
 msgid "centroid"
-msgstr ""
+msgstr "centroide"
 #: ../vector/v.category/main.c:488
 msgid "area"
@@ -26048,23 +24624,20 @@
 #: ../vector/v.category/main.c:500
 msgid "all"
-msgstr ""
+msgstr "tutti"
 #: ../vector/v.category/main.c:553
 #, fuzzy
 msgid "Copying attribute table(s)..."
+msgstr "Copia in corso della tabella/e degli attributi..."
 #: ../vector/v.category/main.c:559
 #, fuzzy, c-format
 msgid "%d features modified."
+msgstr "%d elementi modificati."
 #: ../vector/v.surf.rst/main.c:166
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
 msgstr ""
 #: ../vector/v.surf.rst/main.c:192
@@ -26080,33 +24653,32 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:227
-#, fuzzy
 msgid "Output surface raster map (elevation)"
-msgstr "Mostra il titolo del file raster"
+msgstr ""
 #: ../vector/v.surf.rst/main.c:233
 msgid "Output slope raster map"
-msgstr "Nome della mappa raster della pendenza"
+msgstr "Mappa raster di output delle pendenze"
 #: ../vector/v.surf.rst/main.c:239
 #, fuzzy
 msgid "Output aspect raster map"
-msgstr "Nome della tabella in output"
+msgstr "Mappa raster di output delle esposizioni"
 #: ../vector/v.surf.rst/main.c:245
 #, fuzzy
 msgid "Output profile curvature raster map"
-msgstr "Nome del driver in output"
+msgstr "Mappa raster di output della curvatura del profilo"
 #: ../vector/v.surf.rst/main.c:251
 #, fuzzy
 msgid "Output tangential curvature raster map"
-msgstr "Nome del database in output"
+msgstr "Mappa raster di output della curvatura tangenziale"
 #: ../vector/v.surf.rst/main.c:257
 #, fuzzy
 msgid "Output mean curvature raster map"
+msgstr "Mappa raster di output della curvatura media"
 #: ../vector/v.surf.rst/main.c:272
 msgid "Output cross-validation errors vector point file"
@@ -26121,20 +24693,15 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:300
-#, fuzzy
-msgid ""
-"Name of the attribute column with values to be used for approximation (if "
-"layer>0)"
+msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
+msgstr ""
 #: ../vector/v.surf.rst/main.c:323
-#, fuzzy
 msgid "Name of the attribute column with smoothing parameters"
+msgstr ""
 #: ../vector/v.surf.rst/main.c:358
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
+msgid "Maximum distance between points on isoline (to insert additional points)"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:367
@@ -26149,23 +24716,18 @@
 #: ../vector/v.surf.rst/main.c:418 ../vector/v.surf.rst/main.c:423
 #, fuzzy, c-format
 msgid "Output vector map name <%s> is not valid map name"
+msgstr "Il nome della mappa vettoriale di output  <%s> non è un nome di mappa valido"
 #: ../vector/v.surf.rst/main.c:436
-#, fuzzy
 msgid "You are not outputting any raster or vector maps"
+msgstr ""
 #: ../vector/v.surf.rst/main.c:456
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:459
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or "
-"devi file"
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:462
@@ -26189,24 +24751,20 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:549
-#, fuzzy
 msgid "Cannot create quaddata"
+msgstr ""
 #: ../vector/v.surf.rst/main.c:555
-#, fuzzy
 msgid "Cannot create quadfunc"
+msgstr ""
 #: ../vector/v.surf.rst/main.c:558
-#, fuzzy
 msgid "Cannot create tree"
+msgstr ""
 #: ../vector/v.surf.rst/main.c:562
-#, fuzzy
 msgid "Cannot create tree info"
+msgstr ""
 #: ../vector/v.surf.rst/main.c:755
 #, c-format
@@ -26243,9 +24801,8 @@
 msgstr ""
 #: ../vector/v.mapcalc/vector.c:244
-#, fuzzy
 msgid "Can't call bad function"
-msgstr "locazione del database"
+msgstr ""
 #: ../vector/v.mapcalc/vector.c:281
 #, c-format
@@ -26272,9 +24829,9 @@
 msgstr ""
 #: ../vector/v.mapcalc/map.c:90
-#, fuzzy, c-format
+#, c-format
 msgid "Performing map %s + %s"
+msgstr ""
 #: ../vector/v.mapcalc/map.c:264
 msgid "Can't call bad map-function"
@@ -26297,27 +24854,24 @@
 #: ../vector/v.parallel2/main.c:57
 #, fuzzy
 msgid "Offset along major axis in map units"
-msgstr "Offset delle etichette nella direzione x"
+msgstr "Offset lungo l'asse maggiore in unità di mappa"
 #: ../vector/v.parallel2/main.c:65
 #, fuzzy
 msgid "Offset along minor axis in map units"
+msgstr "Offset lungo l'asse minore in unità di mappa"
 #: ../vector/v.parallel2/main.c:82
 msgid "Side"
 msgstr ""
 #: ../vector/v.parallel2/main.c:84
-msgid ""
-"left;Parallel line is on the left;right;Parallel line is on the right;both;"
-"Parallel lines on both sides"
+msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
 msgstr ""
 #: ../vector/v.parallel2/main.c:94
-#, fuzzy
 msgid "Tolerance of arc polylines in map units"
-msgstr "Uso la massima distanza tra punti. %f"
+msgstr ""
 #: ../vector/v.parallel2/main.c:98
 msgid "Make outside corners round"
@@ -26345,8 +24899,7 @@
 #: ../vector/v.digit/main.c:157
 #, c-format
-msgid ""
-"Map <%s> does not exist in current mapset. Add flag -n to create a new map."
+msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
 msgstr ""
 #: ../vector/v.digit/centre.c:178
@@ -26359,9 +24912,7 @@
 #: ../vector/v.net.centrality/main.c:97
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
 msgstr ""
 #: ../vector/v.net.centrality/main.c:127
@@ -26419,30 +24970,27 @@
 #: ../vector/v.db.connect/main.c:52
 msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-"Visualizza/imposta la connessione per una mappa vettoriale alla tabella "
-"degli attributi"
+msgstr "Visualizza/imposta la connessione per una mappa vettoriale alla tabella degli attributi"
 #: ../vector/v.db.connect/main.c:72
 #, fuzzy
 msgid "Key column name"
+msgstr "Nome della colonna chiave"
 #: ../vector/v.db.connect/main.c:79
 #, fuzzy
 msgid "Field separator for shell script style output"
-msgstr ""
-"Stampa le impostazioni della region corrente (in stile script per la shell)"
+msgstr "Separatore di campo per l'output in stile script per la shell"
 #: ../vector/v.db.connect/main.c:85
 #, fuzzy
 msgid "Print all map connection parameters and exit"
-msgstr "mostra i parametri della connessione in uso ed esce"
+msgstr "Stampa tutti i parametri di connessione al database della mappa ed esce"
 #: ../vector/v.db.connect/main.c:90
 #, fuzzy
 msgid "Print all map connection parameters and exit in shell script style"
+msgstr "Stampa tutti i parametri di connessione della mappa ed esce in stile script per la shell"
 #: ../vector/v.db.connect/main.c:93
 msgid "Format: layer[/layer name] table key database driver"
@@ -26454,32 +25002,30 @@
 #: ../vector/v.db.connect/main.c:108
 msgid "Print types/names of table columns for specified layer and exit"
-msgstr ""
-"Stampa i tipi/nomi delle colonne della tabella del layer selezionato ed esce"
+msgstr "Stampa i tipi/nomi delle colonne della tabella del layer selezionato ed esce"
 #: ../vector/v.db.connect/main.c:115
 #, fuzzy
 msgid "Overwrite connection parameter for certain layer"
+msgstr "Sovrascrive il parametro di connessione per alcuni layer"
 #: ../vector/v.db.connect/main.c:120
 msgid "Delete connection for certain layer (not the table)"
-msgstr "Cancella la connessione al database del layer (ma non la tabella)"
+msgstr "Cancella la connessione al database di alcuni layer (ma non la tabella)"
 #: ../vector/v.db.connect/main.c:153
 #, fuzzy
 msgid "Unable to modify vector map stored in other mapset"
-msgstr "Converti una mappa raster in file height field per POVRAY"
+msgstr "Impossibile modificare la mappa vettoriale che si trova in un altro mapset"
 #: ../vector/v.db.connect/main.c:166
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> is connected by:"
-msgstr "raster <%s> non trovato"
+msgstr ""
 #: ../vector/v.db.connect/main.c:194
 #, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:257
@@ -26494,12 +25040,8 @@
 #: ../vector/v.db.connect/main.c:293 ../vector/v.db.connect/main.c:311
 #, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
-msgstr ""
-"La tabella <%s> è ora parte del vettoriale <%s> e può essere cancellata o "
-"sovrascritta dai moduli GRASS"
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
+msgstr "La tabella <%s> è ora parte del vettoriale <%s> e può essere cancellata o sovrascritta dai moduli GRASS"
 #: ../vector/v.db.connect/main.c:332
 #, c-format
@@ -26511,12 +25053,8 @@
 msgstr "Permessi selezionati concessi alla tabella"
 #: ../vector/v.db.connect/main.c:342
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
-msgstr ""
-"Per definire una nuova connessione, devi specificare i seguenti parametri: "
-"driver, database, tabella [, chiave [, layer]]"
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
+msgstr "Per definire una nuova connessione, devi specificare i seguenti parametri: driver, database, tabella [, chiave [, layer]]"
 #: ../vector/v.net.components/main.c:69
 #, fuzzy
@@ -26537,18 +25075,16 @@
 msgstr "Nome di un elemento"
 #: ../vector/v.drape/main.c:166
-#, fuzzy
 msgid "vector, geometry, sampling"
+msgstr ""
 #: ../vector/v.drape/main.c:168
 msgid "Converts vector map to 3D by sampling of elevation raster map."
 msgstr "Converte vettoriale a 3D utilizzando un raster dell'elevazione"
 #: ../vector/v.drape/main.c:180
-#, fuzzy
 msgid "Elevation raster map for height extraction"
-msgstr "Mappa raster risultante"
+msgstr ""
 #: ../vector/v.drape/main.c:194
 msgid "Sampling method"
@@ -26559,9 +25095,8 @@
 msgstr ""
 #: ../vector/v.drape/main.c:206
-#, fuzzy
 msgid "Layer is only used for WHERE SQL statement"
-msgstr "Usa db.select per i comandi SELECT SQL"
+msgstr ""
 #: ../vector/v.drape/main.c:211
 msgid "Vector Z value for unknown height"
@@ -26580,8 +25115,7 @@
 msgstr ""
 #: ../vector/v.drape/main.c:425
-msgid ""
-"No features drapped. Check Your computational region and input raster map."
+msgid "No features drapped. Check Your computational region and input raster map."
 msgstr ""
 #: ../vector/v.neighbors/main.c:48
@@ -26589,25 +25123,21 @@
 msgstr ""
 #: ../vector/v.what.rast/main.c:80
-#, fuzzy
 msgid "vector, raster, attribute table"
+msgstr ""
 #: ../vector/v.what.rast/main.c:82
 msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
-"Carica valori di un raster nella tabella degli attributi di un vettoriale "
-"puntuale"
+msgstr "Carica valori di un raster nella tabella degli attributi di un vettoriale puntuale"
 #: ../vector/v.what.rast/main.c:87
 msgid "Name of input vector points map for which to edit attribute table"
-msgstr ""
-"Nome della mappa vettoriale di punti della quale editare la tabella attributi"
+msgstr "Nome della mappa vettoriale di punti della quale editare la tabella attributi"
 #: ../vector/v.what.rast/main.c:91
 #, fuzzy
 msgid "Name of existing raster map to be queried"
-msgstr "Nome di una mappa raster esistente"
+msgstr "Nome della mappa raster esistente da interrogare"
 #: ../vector/v.what.rast/main.c:100
 msgid "Column name (will be updated by raster values)"
@@ -26619,14 +25149,12 @@
 #: ../vector/v.what.rast/main.c:164
 msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr ""
-"Il raster è di tipo float mentre la colonna è di tipo integer, attenzione "
-"alla possibile perdita di dati!"
+msgstr "Il raster è di tipo float mentre la colonna è di tipo integer, attenzione alla possibile perdita di dati!"
 #: ../vector/v.what.rast/main.c:244
 #, fuzzy, c-format
 msgid "%d points outside current region were skipped"
+msgstr "%d punti al di fuori della regione corrente non considerati"
 #: ../vector/v.what.rast/main.c:248
 #, fuzzy, c-format
@@ -26636,8 +25164,7 @@
 #: ../vector/v.what.rast/main.c:302
 #, c-format
 msgid "More points (%d) of category %d, value set to 'NULL'"
-msgstr ""
-"Ho assegnato il valore 'NULL' agli ulteriori punti (%d) con categoria %d."
+msgstr "Ho assegnato il valore 'NULL' agli ulteriori punti (%d) con categoria %d."
 #: ../vector/v.what.rast/main.c:367
 #, c-format
@@ -26660,9 +25187,8 @@
 #: ../vector/v.to.3d/main.c:37
-#, fuzzy
 msgid "vector, transformation, 3D"
+msgstr ""
 #: ../vector/v.to.3d/main.c:39
 msgid "Performs transformation of 2D vector features to 3D."
@@ -26671,18 +25197,17 @@
 #: ../vector/v.to.3d/main.c:52
 #, fuzzy, c-format
 msgid "Either '%s' or '%s' parameter have to be used"
-msgstr ""
+msgstr "Dev'essere usato uno dei parametri '%s' o '%s'"
 #: ../vector/v.to.3d/main.c:58
 #, fuzzy, c-format
 msgid "Parameters '%s' ignored"
+msgstr "Parametri '%s' ignorati"
 #: ../vector/v.to.3d/main.c:63
 #, fuzzy
 msgid "Attribute table required"
+msgstr "Tabella degli attributi richiesta"
 #: ../vector/v.to.3d/main.c:76
 #, c-format
@@ -26697,17 +25222,17 @@
 #: ../vector/v.to.3d/main.c:99 ../vector/v.to.3d/main.c:129
 #, fuzzy
 msgid "Unable to copy attributes"
-msgstr "Impossibile selezionare gli attributi"
+msgstr "Impossibile copiare gli attributi"
 #: ../vector/v.to.3d/main.c:103
 #, fuzzy
 msgid "Transforming features..."
+msgstr "Trasformazione degli elementi in corso..."
 #: ../vector/v.to.3d/main.c:123
-#, fuzzy, c-format
+#, c-format
 msgid "%s failed"
+msgstr ""
 #: ../vector/v.to.3d/main.c:138
 #, c-format
@@ -26719,9 +25244,8 @@
 msgstr ""
 #: ../vector/v.to.3d/args.c:15
-#, fuzzy
 msgid "Do not copy table"
-msgstr "Non posso copiare la tabella"
+msgstr ""
 #: ../vector/v.to.3d/args.c:30
 msgid "Fixed height for 3D vector features"
@@ -26733,9 +25257,8 @@
 msgstr "Altezza"
 #: ../vector/v.to.3d/args.c:37
-#, fuzzy
 msgid "Name of attribute column used for height"
+msgstr ""
 #: ../vector/v.to.3d/args.c:39
 msgid "Can be used for reverse transformation, to store height of points"
@@ -26744,27 +25267,26 @@
 #: ../vector/v.to.3d/trans3.c:66 ../vector/v.to.3d/trans2.c:65
 #, fuzzy
 msgid "Column must be numeric"
+msgstr "La colonna dev'essere di tipo numerico"
 #: ../vector/v.to.3d/trans3.c:99
-#, fuzzy, c-format
+#, c-format
 msgid "Feature id %d has no category - skipping"
+msgstr ""
 #: ../vector/v.to.3d/trans3.c:102
-#, fuzzy, c-format
+#, c-format
 msgid "Feature id %d has more categories. Using category %d."
+msgstr ""
 #: ../vector/v.to.3d/trans2.c:98
-#, fuzzy
 msgid "Skipping feature without category"
+msgstr ""
 #: ../vector/v.to.3d/trans2.c:113
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get height for feature category %d"
-msgstr "Impossibile ottenere informazioni sul layer vettoriale"
+msgstr ""
 #: ../vector/v.out.dxf/main.c:50
 msgid "Exports GRASS vector map layers to DXF file format."
@@ -26777,22 +25299,22 @@
 #: ../vector/v.out.dxf/main.c:97
 #, fuzzy, c-format
 msgid "%d features written to '%s'."
-msgstr "Valore da scrivere per null"
+msgstr "%d elementi scritti in '%s'."
 #: ../vector/v.out.dxf/write_dxf.c:21
 #, fuzzy, c-format
 msgid "The file '%s' already exists."
-msgstr "ERRORE: <%s> esiste già\n"
+msgstr "Il file '%s' esiste già."
 #: ../vector/v.out.dxf/write_dxf.c:23
 #, fuzzy, c-format
 msgid "The file '%s' already exists and will be overwritten."
+msgstr "Il file '%s' esiste già e verrà sovrascritto."
 #: ../vector/v.out.dxf/write_dxf.c:27
 #, fuzzy, c-format
 msgid "%s: Cannot write dxf file."
+msgstr "%s: Impossibile scrivere il file dxf"
 #: ../vector/v.net.spanningtree/main.c:46
 #, fuzzy
@@ -26813,9 +25335,7 @@
 msgstr ""
 #: ../misc/m.cogo/main.c:226
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
 msgstr ""
 #: ../misc/m.cogo/main.c:228
@@ -26835,24 +25355,22 @@
 msgstr ""
 #: ../misc/m.cogo/main.c:256
-#, fuzzy
 msgid "Starting coordinate pair"
+msgstr ""
 #: ../misc/m.cogo/main.c:266
 #, fuzzy, c-format
 msgid "Couldn't open COGO file <%s>"
-msgstr "Non riesco a trovare il file raster %s"
+msgstr "Impossibile aprire il file COGO <%s>"
 #: ../misc/m.cogo/main.c:275
 #, fuzzy, c-format
 msgid "Couldn't open output file <%s>"
+msgstr "Impossibile aprire il file di output <%s>"
 #: ../misc/m.cogo/main.c:305 ../misc/m.cogo/main.c:308
-#, fuzzy
 msgid "Converting starting coordinate pair"
+msgstr ""
 #: ../misc/m.cogo/main.c:324
 #, c-format
@@ -26862,22 +25380,22 @@
 #: ../visualization/xganim/main.c:362
 #, fuzzy, c-format
 msgid "Reading file [%s]..."
+msgstr "Lettura del file [%s] in corso..."
 #: ../visualization/xganim/main.c:384
 #, fuzzy
 msgid "Unable to determine raster cell type"
-msgstr "Nome del raster map esistente"
+msgstr "Impossibile determinare il tipo di cella raster"
 #: ../visualization/xganim/main.c:388
 #, fuzzy
 msgid "Unable to read color file"
+msgstr "Impossibile leggere il file dei colori"
 #: ../visualization/xganim/main.c:393
 #, fuzzy
 msgid "Unable to read raster row"
+msgstr "Impossibile leggere la riga del raster"
 #: ../visualization/xganim/Clr_table.c:94
 #: ../visualization/xganim/Clr_table.c:292
@@ -26903,18 +25421,16 @@
 msgstr ""
 #: ../visualization/nviz/src/nvizMain.c:71
-#, fuzzy
 msgid "raster, vector, visualization"
+msgstr ""
 #: ../visualization/nviz/src/nvizMain.c:73
 msgid "nviz - Visualization and animation tool for GRASS data."
 msgstr "nviz - Strumento per la visualizzazione e l'animazione per dati GRASS"
 #: ../visualization/nviz/src/nvizMain.c:78
-#, fuzzy
 msgid "Name of raster map(s) for Elevation"
+msgstr ""
 #: ../visualization/nviz/src/nvizMain.c:79
 #: ../visualization/nviz/src/nvizMain.c:88
@@ -26923,14 +25439,12 @@
 msgstr "Raster"
 #: ../visualization/nviz/src/nvizMain.c:87
-#, fuzzy
 msgid "Name of raster map(s) for Color"
+msgstr ""
 #: ../visualization/nviz/src/nvizMain.c:96
-#, fuzzy
 msgid "Name of vector lines/areas overlay map(s)"
-msgstr "Nome di mappa(e) raster esistente(i)"
+msgstr ""
 #: ../visualization/nviz/src/nvizMain.c:97
 #: ../visualization/nviz/src/nvizMain.c:106
@@ -26938,14 +25452,13 @@
 msgstr "Vettore"
 #: ../visualization/nviz/src/nvizMain.c:105
-#, fuzzy
 msgid "Name of vector points overlay file(s)"
-msgstr "Punti di partenza del file raster"
+msgstr ""
 #: ../visualization/nviz/src/nvizMain.c:114
 #, fuzzy
 msgid "Name of existing 3d raster map"
+msgstr "Nome di una mappa raster 3d esistente"
 #: ../visualization/nviz/src/nvizMain.c:119
 msgid "Quickstart - Do not load any data"
@@ -26982,7 +25495,7 @@
 #: ../visualization/nviz/src/nviz_init.c:166
 #, fuzzy
 msgid "Loading data failed"
+msgstr "Caricamento dei dati non riuscito"
 #: ../visualization/nviz2/cmd/main.c:48
 msgid "visualization, raster, vector, raster3d"
@@ -26993,9 +25506,7 @@
 msgstr ""
 #: ../visualization/nviz2/cmd/main.c:50
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in a 3D space."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in a 3D space."
 msgstr ""
 #: ../visualization/nviz2/cmd/main.c:128
@@ -27009,14 +25520,13 @@
 msgstr ""
 #: ../visualization/nviz2/cmd/main.c:201
-#, fuzzy
 msgid "Unsupported output format"
+msgstr ""
 #: ../visualization/nviz2/cmd/main.c:203 ../imagery/i.cluster/main.c:346
 #, fuzzy, c-format
 msgid "File <%s> created."
-msgstr "Location %s creata!"
+msgstr "File <%s> creato."
 #: ../visualization/nviz2/cmd/args.c:49
 msgid "Use draw mode for all loaded surfaces"
@@ -27030,77 +25540,72 @@
 #: ../visualization/nviz2/cmd/args.c:197 ../visualization/nviz2/cmd/args.c:207
 #, fuzzy
 msgid "Surfaces"
-msgstr "Superficie"
+msgstr "Superfici"
 #: ../visualization/nviz2/cmd/args.c:81
-#, fuzzy
 msgid "Name for output image file (without extension)"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:82 ../visualization/nviz2/cmd/args.c:96
 #: ../visualization/nviz2/cmd/args.c:106
 #, fuzzy
 msgid "Image"
+msgstr "Immagine"
 #: ../visualization/nviz2/cmd/args.c:94
 #: ../locale/scriptstrings/d.out.file_to_translate.c:4
-#, fuzzy
 msgid "Graphics file format"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:104
-#, fuzzy
 msgid "Size (width, height) of output image"
-msgstr "Spessore dell'evidenziazione"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:121
 #, fuzzy
 msgid "Name of raster map(s) for elevation"
+msgstr "Nome della mappa/e raster per l'elevazione"
 #: ../visualization/nviz2/cmd/args.c:130
 #, fuzzy
 msgid "Elevation value(s)"
+msgstr "Valore/i di elevazione"
 #: ../visualization/nviz2/cmd/args.c:137
 #, fuzzy
 msgid "Name of raster map(s) for color"
-msgstr "Nome della mappa raster che contiene i risultati"
+msgstr "Nome della mappa/e raster per i colori"
 #: ../visualization/nviz2/cmd/args.c:143
 #, fuzzy
 msgid "Color value(s)"
+msgstr "Valore del colore/i"
 #: ../visualization/nviz2/cmd/args.c:151
 #, fuzzy
 msgid "Name of raster map(s) for mask"
+msgstr "Nome della mappa/e raster per la maschera"
 #: ../visualization/nviz2/cmd/args.c:160
 #, fuzzy
 msgid "Name of raster map(s) for transparency"
-msgstr "Nome della mappa raster da mostrare"
+msgstr "Nome della mappa/e raster per la trasparenza"
 #: ../visualization/nviz2/cmd/args.c:170
 msgid "Transparency value(s)"
-msgstr ""
+msgstr "Valore/i di trasparenza"
 #: ../visualization/nviz2/cmd/args.c:178
-#, fuzzy
 msgid "Name of raster map(s) for shininess"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:188
 msgid "Shininess value(s)"
 msgstr ""
 #: ../visualization/nviz2/cmd/args.c:196
-#, fuzzy
 msgid "Name of raster map(s) for emission"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:206
 msgid "Emission value(s)"
@@ -27121,31 +25626,28 @@
 #: ../visualization/nviz2/cmd/args.c:232
 #, fuzzy
 msgid "Fine resolution"
-msgstr "Risoluzione"
+msgstr "Alta risoluzione"
 #: ../visualization/nviz2/cmd/args.c:243
 #, fuzzy
 msgid "Coarse resolution"
+msgstr "Bassa risoluzione"
 #: ../visualization/nviz2/cmd/args.c:254
-#, fuzzy
 msgid "Draw style"
-msgstr "Tipo di grafico"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:266 ../visualization/nviz2/cmd/args.c:287
 msgid "Shading"
 msgstr ""
 #: ../visualization/nviz2/cmd/args.c:275
-#, fuzzy
 msgid "Wire color"
-msgstr " nv colore\n"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:311
-#, fuzzy
 msgid "Name of line vector overlay map(s)"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:312 ../visualization/nviz2/cmd/args.c:323
 #: ../visualization/nviz2/cmd/args.c:334 ../visualization/nviz2/cmd/args.c:346
@@ -27156,12 +25658,12 @@
 #: ../visualization/nviz2/cmd/args.c:322
 #, fuzzy
 msgid "Vector line width"
-msgstr "Il vettore non è 3D"
+msgstr "Spessore della linea vettoriale"
 #: ../visualization/nviz2/cmd/args.c:331
 #, fuzzy
 msgid "Vector line color"
-msgstr "Colore del bordo"
+msgstr "Colore della linea vettoriale"
 #: ../visualization/nviz2/cmd/args.c:343
 msgid "Vector line display mode"
@@ -27169,12 +25671,11 @@
 #: ../visualization/nviz2/cmd/args.c:355
 msgid "Vector line height"
-msgstr ""
+msgstr "Altezza della linea vettoriale"
 #: ../visualization/nviz2/cmd/args.c:379
-#, fuzzy
 msgid "Name of point vector overlay map(s)"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:380 ../visualization/nviz2/cmd/args.c:391
 #: ../visualization/nviz2/cmd/args.c:403 ../visualization/nviz2/cmd/args.c:414
@@ -27193,16 +25694,15 @@
 #: ../visualization/nviz2/cmd/args.c:411
 #, fuzzy
 msgid "Icon color"
+msgstr "Colore dell'icona"
 #: ../visualization/nviz2/cmd/args.c:423
 msgid "Icon marker"
 msgstr ""
 #: ../visualization/nviz2/cmd/args.c:453
-#, fuzzy
 msgid "Viewpoint position (x,y model coordinates)"
-msgstr "Utilizzando le coordinate del centro della mappa\n"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:454 ../visualization/nviz2/cmd/args.c:465
 #: ../visualization/nviz2/cmd/args.c:475 ../visualization/nviz2/cmd/args.c:487
@@ -27210,9 +25710,8 @@
 msgstr ""
 #: ../visualization/nviz2/cmd/args.c:464
-#, fuzzy
 msgid "Viewpoint height (in map units)"
-msgstr "Dimensione delle etichette (in unità della mappa)"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:474
 msgid "Viewpoint field of view (in degrees)"
@@ -27224,9 +25723,8 @@
 #: ../visualization/nviz2/cmd/args.c:507 ../visualization/nviz2/cmd/args.c:542
 #: ../visualization/nviz2/cmd/args.c:554 ../visualization/nviz2/cmd/args.c:564
-#, fuzzy
 msgid "Volumes"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:517
 msgid "Volume draw mode"
@@ -27237,35 +25735,29 @@
 msgstr ""
 #: ../visualization/nviz2/cmd/args.c:541
-#, fuzzy
 msgid "Volume position"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:552
-#, fuzzy
 msgid "Volume resolution"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:563
-#, fuzzy
 msgid "Isosurface level"
-msgstr "Livello minimo di contorno"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:578
-#, fuzzy
 msgid "Light position (x,y,z model coordinates)"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:579 ../visualization/nviz2/cmd/args.c:585
 #: ../visualization/nviz2/cmd/args.c:594 ../visualization/nviz2/cmd/args.c:604
-#, fuzzy
 msgid "Lighting"
-msgstr "Esistente"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:584
-#, fuzzy
 msgid "Light color"
-msgstr "Colore di evidenziazione del testo"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:593
 msgid "Light brightness"
@@ -27276,30 +25768,25 @@
 msgstr ""
 #: ../visualization/nviz2/cmd/args.c:615
-msgid ""
-"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
 msgstr ""
 #: ../visualization/nviz2/cmd/args.c:619
-#, fuzzy
 msgid "Fringe edges"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:620 ../visualization/nviz2/cmd/args.c:626
 #: ../visualization/nviz2/cmd/args.c:635
-#, fuzzy
 msgid "Fringe"
-msgstr "Interrotto."
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:625
-#, fuzzy
 msgid "Fringe color"
-msgstr "Colore della linea"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:634
-#, fuzzy
 msgid "Fringe elevation"
-msgstr "Mappa(e) raster da leggere"
+msgstr ""
 #: ../visualization/nviz2/cmd/args.c:679
 #, c-format
@@ -27335,9 +25822,8 @@
 msgstr ""
 #: ../visualization/nviz2/cmd/vector.c:179
-#, fuzzy
 msgid "Unknown icon marker"
-msgstr "Tipo sconosciuto"
+msgstr ""
 #: ../visualization/nviz2/cmd/surface.c:71
 #, c-format
@@ -27345,80 +25831,74 @@
 msgstr ""
 #: ../visualization/nviz2/cmd/surface.c:124
-#, fuzzy, c-format
+#, c-format
 msgid "Color attribute not defined, using default <%s>"
+msgstr ""
 #: ../visualization/nviz2/cmd/surface.c:201
-#, fuzzy, c-format
+#, c-format
 msgid "Surface id %d doesn't exist"
+msgstr ""
 #: ../visualization/nviz2/cmd/surface.c:248
 #: ../visualization/nviz2/cmd/surface.c:255
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to set draw mode for surface id %d"
+msgstr ""
 #: ../visualization/nviz2/cmd/volume.c:72
-#, fuzzy, c-format
+#, c-format
 msgid "Error tokenize '%s'"
-msgstr "Errore nell'apertura del file g3d"
+msgstr ""
 #: ../visualization/nviz2/cmd/volume.c:79
-#, fuzzy, c-format
+#, c-format
 msgid "Volume set number %d is not available"
-msgstr "file raster per la Vista%d"
+msgstr ""
 #: ../visualization/nviz2/cmd/volume.c:85
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to add isosurface (volume set %d)"
-msgstr "Nome del raster"
+msgstr ""
 #: ../visualization/nviz2/cmd/volume.c:93
 #: ../visualization/nviz2/cmd/volume.c:99
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
+msgstr ""
 #: ../visualization/ximgview/main.c:62
 #, fuzzy
 msgid "Unable to open display"
-msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgstr "Impossibile aprire il display"
 #: ../visualization/ximgview/main.c:82
-#, fuzzy
 msgid "Unable to get window attributes"
+msgstr ""
 #: ../visualization/ximgview/main.c:238
-#, fuzzy
 msgid "Unable to open image file"
+msgstr ""
 #: ../visualization/ximgview/main.c:241
-#, fuzzy
 msgid "Unable to read BMP header"
-msgstr "impossibile aprire <%s>"
+msgstr ""
 #: ../visualization/ximgview/main.c:244
-#, fuzzy
 msgid "Invalid BMP header"
+msgstr ""
 #: ../visualization/ximgview/main.c:250
-#, fuzzy
 msgid "Unable to map image file"
+msgstr ""
 #: ../visualization/ximgview/main.c:271
 msgid "View BMP images from the PNG driver."
 msgstr ""
 #: ../visualization/ximgview/main.c:279
-#, fuzzy
 msgid "Image file"
+msgstr ""
 #: ../visualization/ximgview/main.c:286
 msgid "Percentage of CPU time to use"
@@ -27434,9 +25914,9 @@
 msgstr "Il mio primo modulo raster"
 #: ../doc/raster/r.example/main.c:127
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read file header of <%s>"
-msgstr "Non riesco ad aprire il file header di [%s]"
+msgstr ""
 #: ../doc/vector/v.example/main.c:50
 msgid "vector, keyword2, keyword3"
@@ -27445,27 +25925,26 @@
 #: ../doc/vector/v.example/main.c:51
 #, fuzzy
 msgid "My first vector module"
-msgstr "Il mio primo modulo raster"
+msgstr "Il mio primo modulo vettoriale"
 #: ../doc/vector/v.example/main.c:79
-#, fuzzy
 msgid "Unable to set predetermined vector open level"
+msgstr ""
 #: ../doc/vector/v.example/main.c:167
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get attribute data for cat %d"
-msgstr "Non posso selezionare gli attributi per cat=%d"
+msgstr ""
 #: ../doc/vector/v.example/main.c:176
-#, fuzzy, c-format
+#, c-format
 msgid "Error while retrieving database record for cat %d"
-msgstr "Nessun record nel database per la categoria %d"
+msgstr ""
 #: ../doc/vector/v.example/main.c:209
 #, fuzzy, c-format
 msgid "Unable to copy attribute table to vector map <%s>"
+msgstr "Impossibile copiare la tabella degli attributi nella mappa vettoriale <%s>"
 #: ../ps/ps.map/ps_vlines.c:55 ../ps/ps.map/ps_vpoints.c:71
 #: ../ps/ps.map/ps_vareas.c:163
@@ -27506,43 +25985,34 @@
 #: ../ps/ps.map/main.c:110
 #, fuzzy
 msgid "List paper formats ( name width height left right top bottom(margin) )"
-msgstr ""
-"Formati di pagina per la stampa (nome largh. altezza sinistra destra alto "
-"basso[margine])"
+msgstr "Elenco dei formati di pagina per la stampa (nome largh. altezza sinistra destra alto basso[margine])"
 #: ../ps/ps.map/main.c:115
 msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
 msgstr "Crea file EPS (Encapsulated PostScript) invece di PostScript"
 #: ../ps/ps.map/main.c:121
-msgid ""
-"File containing mapping instructions (or use input=- to enter from keyboard)"
+msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
 msgstr "File contenente le istruzioni (o usa input=- per inserire da tastiera)"
 #: ../ps/ps.map/main.c:129
 #, fuzzy
 msgid "PostScript output file"
-msgstr "File raster in output"
+msgstr "File PostScript di output"
 #: ../ps/ps.map/main.c:137
 msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-msgstr ""
-"Scala della mappa in output, e.g. 1:25000 (default: Adatta alla pagina)"
+msgstr "Scala della mappa in output, e.g. 1:25000 (default: Adatta alla pagina)"
 #: ../ps/ps.map/main.c:143
 #, fuzzy
 msgid "Number of copies to print"
-msgstr "Nume di righe da tenere in memoria"
+msgstr "Numero di copie da stampare"
 #: ../ps/ps.map/main.c:238
-#, fuzzy, c-format
-msgid ""
-"Using <%s> from the command line is depreciated. Please use the <%s> mapping "
-"instruction instead. The parameter <%s> will be removed in future versions "
-"of GRASS."
+#, c-format
+msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
 msgstr ""
-"L'uso dell'istruzione \"scale\" dalla linea di comando è deprecato. Per "
-"favore inserisci l'istruzione \"scale\" nel file di istruzioni."
 #: ../ps/ps.map/main.c:263
 #, fuzzy, c-format
@@ -27550,27 +26020,27 @@
 "\n"
 "ERROR: Required parameter <%s> not set:\n"
 "    (%s).\n"
+msgstr ""
+"\n"
+"ERRORE: Il parametro richiesto <%s> non è stato impostato:\n"
+"    (%s).\n"
 #: ../ps/ps.map/main.c:274
 msgid "Current region cannot be set."
-msgstr "La region corrente non può essere settata."
+msgstr "La regione corrente non può essere impostata."
 #: ../ps/ps.map/main.c:283
 msgid "Data exists after final 'end' instruction!"
 msgstr "Ci sono ancora dati dopo l'ultima istruzione end!"
 #: ../ps/ps.map/main.c:316
-msgid ""
-"GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping "
-"instruction. This mapping instruction is superseded and will be removed in "
-"future versions of GRASS. Please use --verbose instead."
+msgid "GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping instruction. This mapping instruction is superseded and will be removed in future versions of GRASS. Please use --verbose instead."
 msgstr ""
 #: ../ps/ps.map/main.c:323
 #, fuzzy
 msgid "Cannot set GRASS_VERBOSE variable."
+msgstr "Impossibile impostare la variabile GRASS_VERBOSE."
 #: ../ps/ps.map/main.c:725
 #, c-format
@@ -27579,35 +26049,33 @@
 #: ../ps/ps.map/r_vpoints.c:244
 #, c-format
-msgid ""
-"The mapping instruction <%s> will be renamed to <%s> in future versions of "
-"GRASS. Please use <%s> instead."
+msgid "The mapping instruction <%s> will be renamed to <%s> in future versions of GRASS. Please use <%s> instead."
 msgstr ""
 #: ../ps/ps.map/r_group.c:31
 #, fuzzy
 msgid "Can't get group information"
-msgstr "Non riesco a descrivere la tabella"
+msgstr "Impossibile ottenere informazioni sul gruppo"
 #: ../ps/ps.map/do_psfiles.c:20
-#, fuzzy, c-format
+#, c-format
 msgid "Reading PostScript include file <%s> ..."
+msgstr ""
 #: ../ps/ps.map/ps_fclrtbl.c:46 ../ps/ps.map/ps_clrtbl.c:31
 #, fuzzy, c-format
 msgid "Creating color table for <%s in %s>..."
+msgstr "Creazione della tavola dei colori per <%s in %s> in corso..."
 #: ../ps/ps.map/ps_fclrtbl.c:51
 #, fuzzy
 msgid "Range information not available (run r.support)"
-msgstr "Informazioni sul range non disponibile (esegui r.support)."
+msgstr "Informazioni sul range non disponibile (eseguire r.support)"
 #: ../ps/ps.map/ps_fclrtbl.c:64
 #, fuzzy
 msgid "A floating point colortable must contain a range of values"
-msgstr "Una tabella colori a virgola mobile deve contenere un range di valori."
+msgstr "Una tabella colori a virgola mobile deve contenere un intervallo di valori"
 #: ../ps/ps.map/ps_fclrtbl.c:69 ../ps/ps.map/ps_clrtbl.c:40
 msgid "Unable to read colors for colorbar"
@@ -27616,66 +26084,50 @@
 #: ../ps/ps.map/ps_fclrtbl.c:92 ../ps/ps.map/ps_fclrtbl.c:97
 #: ../ps/ps.map/ps_clrtbl.c:65
 msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr ""
-"Posizione y della barra colori esterna ai margini della pagina. Li "
-"aggiusto...."
+msgstr "Posizione y della barra colori esterna ai margini della pagina. Li aggiusto...."
 #: ../ps/ps.map/ps_fclrtbl.c:103 ../ps/ps.map/ps_fclrtbl.c:108
 #: ../ps/ps.map/ps_clrtbl.c:71
 msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr ""
-"Posizione x della barra colori esterna ai margini della pagina. Li "
-"aggiusto...."
+msgstr "Posizione x della barra colori esterna ai margini della pagina. Li aggiusto...."
 #: ../ps/ps.map/catval.c:64
-#, fuzzy
 msgid "Column type not supported (must be string)"
-msgstr "driver pg: colonna '%s', di tipo %d non supportata"
+msgstr ""
 #: ../ps/ps.map/catval.c:129
-#, fuzzy
 msgid "Size column type must be numeric"
-msgstr "Nessuna mappa in input specificata"
+msgstr ""
 #: ../ps/ps.map/catval.c:196
-#, fuzzy
 msgid "Rotation column type must be numeric"
+msgstr ""
 #: ../ps/ps.map/ps_raster.c:43
-#, fuzzy
 msgid "Can't create temporary PostScript mask file."
+msgstr ""
 #: ../ps/ps.map/ps_raster.c:103
 #, fuzzy, c-format
 msgid "Reading raster map <%s in %s> ..."
+msgstr "Lettura della mappa raster <%s in %s> in corso ..."
 #: ../ps/ps.map/ps_raster.c:106
 #, fuzzy, c-format
 msgid "Reading raster maps in group <%s> ..."
+msgstr "Lettura della mappa raster nel gruppo <%s> in corso ..."
 #: ../ps/ps.map/ps_clrtbl.c:50
-#, fuzzy
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
 msgstr ""
-"Il tuo file cats/ non è valido. Un file cats/ con categorie e labels è "
-"richiesto per il parametro 'colortable' quando si usano rasters CELL. "
-"Nessuna tabella colori verrà assegnata al file Postscript in uscita."
 #: ../ps/ps.map/scale.c:137
 msgid "PSmap: do_scale(): shouldn't happen"
 msgstr ""
 #: ../ps/ps.map/do_masking.c:23
-#, fuzzy
 msgid "Can't open temporary PostScript mask file."
-msgstr "Impossibile aprire il file label temporaneo <%s>"
+msgstr ""
 #: ../ps/ps.map/map_setup.c:88
 #, c-format
@@ -27683,14 +26135,14 @@
 msgstr ""
 #: ../ps/ps.map/makeprocs.c:29
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open prolog <%s>"
+msgstr ""
 #: ../ps/ps.map/read_cfg.c:64
-#, fuzzy, c-format
+#, c-format
 msgid "Paper '%s' not found, using defaults"
+msgstr ""
 #: ../ps/ps.map/do_labels.c:43
 #, c-format
@@ -27700,7 +26152,7 @@
 #: ../ps/ps.map/do_labels.c:47
 #, fuzzy, c-format
 msgid "Reading labels file <%s in %s> ..."
+msgstr "Lettura del file delle etichette <%s in %s> in corso ..."
 #: ../ps/ps.map/do_labels.c:65
 #, c-format
@@ -27709,18 +26161,15 @@
 #: ../ps/ps.map/do_labels.c:68
 msgid "Reading text file ..."
-msgstr "Leggendo il file testuale ..."
+msgstr "Lettura del file di testo in corso ..."
 #: ../ps/ps.map/do_labels.c:161
 msgid "Text labels: 'fontsize' given so ignoring 'size'"
 msgstr ""
-"Parametro 'fontsize' fornito per le etichette tesutali, quindi ignoro  il "
-"parametro 'size'"
 #: ../ps/ps.map/do_plt.c:41
-#, fuzzy
 msgid "Reading point/line file ..."
+msgstr ""
 #: ../ps/ps.map/do_plt.c:147 ../ps/ps.map/ps_vpoints.c:87
 msgid "Cannot read symbol, using default icon"
@@ -27729,31 +26178,31 @@
 #: ../ps/ps.map/ps_vpoints.c:181
 #, fuzzy, c-format
 msgid "Attribute is of invalid size [%.3f] for category [%d]"
-msgstr "L'attributo della categoria %d ha una dimensione errata (%.3f)"
+msgstr "L'attributo della categoria [%d] ha una dimensione errata [%.3f]"
 #: ../ps/ps.map/ps_outline.c:41
-#, fuzzy, c-format
+#, c-format
 msgid "Outlining areas in raster map <%s in %s> ..."
+msgstr ""
 #: ../ps/ps.map/do_vectors.c:34
 #, fuzzy, c-format
 msgid "Reading vector map <%s in %s> ..."
+msgstr "Lettura della mappa vettoriale <%s in %s> in corso..."
 #: ../ps/ps.map/do_vectors.c:139
 #, fuzzy, c-format
 msgid "Reading vector points file <%s in %s> ..."
+msgstr "Lettura del file di punti vettoriali <%s in %s> in corso..."
 #: ../db/drivers/postgres/fetch.c:172
 msgid "Cannot recognize boolean value"
 msgstr "Non riesco ad individuare il valore booleano"
 #: ../db/drivers/postgres/describe.c:103
-#, fuzzy, c-format
+#, c-format
 msgid "pg driver: PostGIS column '%s', type 'geometry'  will not be converted"
+msgstr ""
 #: ../db/drivers/postgres/describe.c:109
 #, c-format
@@ -27762,30 +26211,18 @@
 #: ../db/drivers/postgres/describe.c:116
 #, c-format
-msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
-msgstr ""
-"colonna '%s' : type int8 (bigint) è archiviata come integer (4 byte) alcuni "
-"dati possono essere corrotti"
+msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
+msgstr "colonna '%s' : type int8 (bigint) è archiviata come integer (4 byte) alcuni dati possono essere corrotti"
 #: ../db/drivers/postgres/describe.c:120
 #, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
-msgstr ""
-"colonna '%s' : tipo character varying è archiviata come varchar(250) alcuni "
-"dati possono essere persi"
+msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
+msgstr "colonna '%s' : tipo character varying è archiviata come varchar(250) alcuni dati possono essere persi"
 #: ../db/drivers/postgres/describe.c:126
 #, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
-msgstr ""
-"colonna '%s' : tipo bool (boolean) è archiviata come char(1), valori: 0 "
-"(false), 1 (true)"
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
+msgstr "colonna '%s' : tipo bool (boolean) è archiviata come char(1), valori: 0 (false), 1 (true)"
 #: ../db/drivers/postgres/parse.c:55 ../db/drivers/mysql/parse.c:71
 msgid "'user' in database definition is not supported, use db.login"
@@ -27793,8 +26230,7 @@
 #: ../db/drivers/postgres/parse.c:59 ../db/drivers/mysql/parse.c:75
 msgid "'password' in database definition is not supported, use db.login"
-msgstr ""
-"'password' non è supportata nella definizione del database, usa db.login"
+msgstr "'password' non è supportata nella definizione del database, usa db.login"
 #: ../db/drivers/postgres/parse.c:63
 msgid "Unknown option in database definition for PostgreSQL: "
@@ -27803,7 +26239,7 @@
 #: ../db/drivers/mysql/fetch.c:34
 #, fuzzy
 msgid "Cursor not found"
+msgstr "Cursore non trovato"
 #: ../db/drivers/mysql/fetch.c:52
 msgid "Cursor position is not supported by MySQL driver"
@@ -27818,72 +26254,58 @@
 msgstr "Formato della data sbagliato"
 #: ../db/drivers/mysql/fetch.c:212
-#, fuzzy
 msgid "Cannot scan date: "
+msgstr ""
 #: ../db/drivers/mysql/fetch.c:225
-#, fuzzy
 msgid "Cannot scan time: "
+msgstr ""
 #: ../db/drivers/mysql/fetch.c:240
-#, fuzzy
 msgid "Cannot scan datetime: "
+msgstr ""
 #: ../db/drivers/mysql/cursor.c:46
-#, fuzzy
 msgid "Cannot allocate cursor."
+msgstr ""
 #: ../db/drivers/mysql/cursor.c:55
-#, fuzzy
 msgid "Cannot ad new token."
+msgstr ""
 #: ../db/drivers/mysql/describe.c:120
 #, fuzzy, c-format
 msgid "MySQL driver: column '%s', type %d is not supported"
+msgstr "Driver MySQL: colonna '%s', di tipo %d non supportata"
 #: ../db/drivers/mysql/describe.c:126
 #, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
-msgstr ""
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
+msgstr "colonna '%s' : il tipo BIGINT è archiviata come integer (4 byte) alcuni dati possono essere corrotti"
 #: ../db/drivers/mysql/parse.c:60
-#, fuzzy
 msgid "Wrong port number in MySQL database definition: "
-msgstr "Opzione sconosciuta nel database mysql: '%s'"
+msgstr ""
 #: ../db/drivers/mysql/parse.c:79
-#, fuzzy
 msgid "Unknown option in database definition for "
+msgstr ""
 #: ../db/drivers/mysql/db.c:67
 msgid "Cannot connect to MySQL: "
 msgstr "Non riesco a connettermi a MySQL"
 #: ../db/drivers/mysql/db.c:83
-#, fuzzy
 msgid "Cannot parse MySQL embedded database name"
-msgstr "Non posso scrivere i collegamenti del database"
+msgstr ""
 #: ../db/drivers/mysql/db.c:99
-#, fuzzy
 msgid "Cannot initialize MySQL embedded server"
+msgstr ""
 #: ../db/drivers/mysql/db.c:118
-#, fuzzy
 msgid "Cannot connect to MySQL embedded server: "
+msgstr ""
 #: ../db/drivers/mysql/error.c:29
 msgid "DBMI-MySQL driver error:\n"
@@ -27908,22 +26330,18 @@
 #: ../db/drivers/ogr/describe.c:157
 #, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
-msgstr ""
-"colonna '%s', tipo 'string': dimensione sconosciuta -> archiviata come "
-"varchar(250) alcuni dati possono essere persi"
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
+msgstr "colonna '%s', tipo 'string': dimensione sconosciuta -> archiviata come varchar(250) alcuni dati possono essere persi"
 #: ../db/drivers/sqlite/describe.c:159
 #, fuzzy, c-format
 msgid "SQLite driver: column '%s', SQLite type %d  is not supported"
+msgstr "Driver SQLite: colonna '%s', il tipo %d SQLite non è supportato"
 #: ../db/drivers/sqlite/db.c:84
 #, fuzzy
 msgid "Unable to open database: "
-msgstr "Impossibile aprire il database <%s>"
+msgstr "Impossibile aprire il database: "
 #: ../db/base/columns.c:92 ../db/base/drivers.c:74 ../db/base/connect.c:45
 #: ../db/base/describe.c:125 ../db/base/tables.c:95
@@ -27934,7 +26352,7 @@
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
 #, fuzzy
 msgid "database, attribute table"
+msgstr "database, tabella degli attributi"
 #: ../db/base/columns.c:93
 msgid "List all columns for a given table."
@@ -27959,7 +26377,7 @@
 #: ../db/base/copy.c:34 ../db/base/execute.c:108 ../db/base/select.c:262
 #, fuzzy
 msgid "database, attribute table, SQL"
+msgstr "database, tabella degli attributi, SQL"
 #: ../db/base/copy.c:35
 msgid "Copy a table."
@@ -27967,12 +26385,8 @@
 #: ../db/base/copy.c:37
 #, fuzzy
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-"Copia una tabella. Sia le clausole 'from table' (in opzione con 'where') che "
-"'select' posso non essere utilizzate, ma non contemporaneamente."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr "Può essere utilizzata sia l'opzione 'from_table' (in opzione con 'where') che 'select', ma non contemporaneamente."
 #: ../db/base/copy.c:43
 msgid "Input driver name"
@@ -28001,14 +26415,11 @@
 #: ../db/base/copy.c:84
 #, fuzzy
 msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr ""
-"Selezione completa della tabella (solo se from_table a where non sono "
-"utilizzati), es.:\n"
-"\t\tSELECT dedek FROM starobince WHERE obec = 'Frimburg'"
+msgstr "Istruzione select completa (solo se from_table a where non sono utilizzati)"
 #: ../db/base/copy.c:85
 msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
-msgstr ""
+msgstr "Es.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
 #: ../db/base/copy.c:93
 msgid "Cannot combine 'from_table' and 'select' options"
@@ -28028,41 +26439,34 @@
 #: ../db/base/connect.c:47
 msgid "Prints/sets general DB connection for current mapset and exits."
-msgstr ""
-"Stampa/imposta la connessione generale al DB per il mapset corrente ed esce."
+msgstr "Stampa/imposta la connessione generale al DB per il mapset corrente ed esce."
 #: ../db/base/connect.c:51
 msgid "Print current connection parameters and exit"
 msgstr "Mostra i parametri della connessione in uso ed esce"
 #: ../db/base/connect.c:57
-#, fuzzy
 msgid "Check connection parameters, set if uninitialized, and exit"
-msgstr "Mostra i parametri della connessione in uso ed esce"
+msgstr ""
 #: ../db/base/connect.c:74
 #, fuzzy
 msgid "Database schema"
-msgstr "Nome del database"
+msgstr "Schema del database"
 #: ../db/base/connect.c:75
 #, fuzzy
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
-msgstr ""
-"Schema del database. Non utilizzare questa opzione se lo schema non "
-"supportato dal driver/database server"
+msgid "Do not use this option if schemas are not supported by driver/database server"
+msgstr "Non utilizzare questa opzione se lo schema non è supportato dal driver/database server"
 #: ../db/base/connect.c:85
 #, fuzzy
 msgid "Default group of database users to which select privilege is granted"
-msgstr ""
-"Gruppo utenti predefinito del database per il quale i privilegi sono "
-"garantiti"
+msgstr "Gruppo utenti predefinito del database al quale è assegnato il privilegio select"
 #: ../db/base/connect.c:121
 msgid "Database connection not defined. Run db.connect."
-msgstr "Connessione al database non definita. Esegui db.connect"
+msgstr "Connessione al database non definita. Eseguire db.connect"
 #: ../db/base/connect.c:141
 #, c-format
@@ -28079,13 +26483,12 @@
 #: ../db/base/connect.c:151
 #, fuzzy
 msgid "Default database is not set"
-msgstr "Nome del database in input"
+msgstr "Il database predefinito non è impostato"
 #: ../db/base/describe.c:104
 #, fuzzy
 msgid "Print column names only instead of full column descriptions"
-msgstr ""
-"mostra soltanto i nomi delle colonne invece che la completa descrizione"
+msgstr "Mostra soltanto i nomi delle colonne invece che la completa descrizione"
 #: ../db/base/describe.c:109
 msgid "Print table structure"
@@ -28098,7 +26501,7 @@
 #: ../db/base/execute.c:78 ../db/base/execute.c:83
 #, fuzzy, c-format
 msgid "Error while executing: '%s'"
-msgstr "Errore durante l'esecuzione: \"%s\""
+msgstr "Errore durante l'esecuzione: '%s'"
 #: ../db/base/execute.c:109
 msgid "Executes any SQL statement."
@@ -28150,11 +26553,9 @@
 msgstr "Mostra tutti i database di un dato driver e locazione"
 #: ../db/base/select.c:93
-#, fuzzy, c-format
+#, c-format
 msgid "Test %s."
 msgstr ""
-"Layer: %d\n"
-"categoria: %d\n"
 #: ../db/base/select.c:93 ../imagery/i.rectify/report.c:16
 #: ../imagery/i.ortho.photo/i.photo.rectify/report.c:10
@@ -28164,18 +26565,16 @@
 #, fuzzy
 msgid "succeeded"
-msgstr "....successo!"
+msgstr "successo"
 #: ../db/base/select.c:194
 msgid "SQL select statement"
-msgstr "Comando SQL select"
+msgstr "Istruzione SQL select"
 #: ../db/base/select.c:196
 #, fuzzy
 msgid "For example: 'select * from rybniky where kapri = 'hodne'"
-msgstr ""
-"istruzione SQL select, ad esempio: 'select * from rybniky where kapri = "
-"'hodne'"
+msgstr "Ad esempio: 'select * from rybniky where kapri = 'hodne'"
 #: ../db/base/select.c:201
 #, fuzzy
@@ -28241,42 +26640,34 @@
 #: ../db/db.login/main.c:110
 #, fuzzy
 msgid "The password was stored in file"
-msgstr "La password è stata archiviata nel file."
+msgstr "La password è stata archiviata nel file"
 #: ../locale/scriptstrings/d.split_to_translate.c:1
-msgid ""
-"Divides active display into two frames & displays maps/executes commands in "
-"each frame."
+msgid "Divides active display into two frames & displays maps/executes commands in each frame."
 msgstr ""
 #: ../locale/scriptstrings/d.split_to_translate.c:3
-#, fuzzy
 msgid "Enter raster map to display in 1st frame"
+msgstr ""
 #: ../locale/scriptstrings/d.split_to_translate.c:4
-#, fuzzy
 msgid "Enter command to execute in 1st frame"
+msgstr ""
 #: ../locale/scriptstrings/d.split_to_translate.c:5
-#, fuzzy
 msgid "Enter raster map to display in 2nd frame"
+msgstr ""
 #: ../locale/scriptstrings/d.split_to_translate.c:6
-#, fuzzy
 msgid "Enter command to execute in 2nd frame"
+msgstr ""
 #: ../locale/scriptstrings/d.split_to_translate.c:7
-#, fuzzy
 msgid "How to split display"
+msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
+msgid "Displays spectral response at user specified locations in group or images."
 msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:2
@@ -28290,12 +26681,11 @@
 #: ../locale/scriptstrings/i.spectral_to_translate.c:4
 #, fuzzy
 msgid "Raster input maps"
-msgstr "Mappa raster in input"
+msgstr "Mappe raster in input"
 #: ../locale/scriptstrings/i.spectral_to_translate.c:5
-#, fuzzy
 msgid "Write output to PNG image"
-msgstr "Sovrascrivi file mappa in output"
+msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:6
 msgid "Use image list and not group"
@@ -28304,20 +26694,15 @@
 #: ../locale/scriptstrings/i.spectral_to_translate.c:7
 #, fuzzy
 msgid "Select multiple points"
+msgstr "Seleziona punti multipli"
 #: ../locale/scriptstrings/i.spectral_to_translate.c:8
-#, fuzzy
 msgid "Label with coordinates instead of numbering"
+msgstr ""
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-msgid ""
-"Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
-"format"
-msgstr ""
-"Converte tutte le vecchie mappe vettoriali di GRASS < Ver5.7 nel corrente "
-"mapset e formato"
+msgid "Convert all old GRASS < Ver5.7 vector maps in current mapset to current format"
+msgstr "Converte tutte le vecchie mappe vettoriali di GRASS < Ver5.7 del mapset corrente nel formato corrente"
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:3
 msgid "run non-interactively"
@@ -28326,16 +26711,14 @@
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:1
 #, fuzzy
 msgid "Exports GRASS raster into GDAL supported formats."
-msgstr "Esporta un raster grass come array binario"
+msgstr "Esporta un raster GRASS nei formati supportati da GDAL"
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:4
-#, fuzzy
 msgid "Region sensitive output"
+msgstr ""
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:9
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed"
+msgid "Creation option to the output format driver. Multiple options may be listed"
 msgstr ""
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:10
@@ -28363,26 +26746,21 @@
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:4
 #, fuzzy
 msgid "Name for output vector map"
+msgstr "Nome della mappa vettoriale di output"
 #: ../locale/scriptstrings/r.plane_to_translate.c:1
-#, fuzzy
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
 msgstr ""
-"Crea un raster e vettore puntuale contenenti punti posizionati casualmente."
 #: ../locale/scriptstrings/r.plane_to_translate.c:2
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
 #, fuzzy
 msgid "raster, elevation"
+msgstr "raster, elevazione"
 #: ../locale/scriptstrings/r.plane_to_translate.c:3
-#, fuzzy
 msgid "Name of raster plane to be created"
+msgstr ""
 #: ../locale/scriptstrings/r.plane_to_translate.c:4
 msgid "Dip of plane. Value must be between -90 and 90 degrees"
@@ -28395,22 +26773,22 @@
 #: ../locale/scriptstrings/r.plane_to_translate.c:6
 #, fuzzy
 msgid "Easting coordinate of a point on the plane"
+msgstr "Coordinate est di un punto nel piano"
 #: ../locale/scriptstrings/r.plane_to_translate.c:7
 #, fuzzy
 msgid "Northing coordinate of a point on the plane"
+msgstr "Coordinate nord di un punto nel piano"
 #: ../locale/scriptstrings/r.plane_to_translate.c:8
 #, fuzzy
 msgid "Elevation coordinate of a point on the plane"
+msgstr "Coordinate dell'altezza di un punto nel piano"
 #: ../locale/scriptstrings/r.plane_to_translate.c:9
 #, fuzzy
 msgid "Type of the raster map to be created"
+msgstr "Nome della mappa raster da creare"
 #: ../locale/scriptstrings/m.proj_to_translate.c:1
 msgid "Convert coordinates from one projection to another (cs2cs frontend)."
@@ -28419,12 +26797,11 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:2
 #, fuzzy
 msgid "miscellaneous, projection"
+msgstr "N"
 #: ../locale/scriptstrings/m.proj_to_translate.c:3
-#, fuzzy
 msgid "Input coordinate file (omit to read from stdin)"
-msgstr "File raster ascii da importare"
+msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:4
 #: ../locale/scriptstrings/m.proj_to_translate.c:6
@@ -28432,19 +26809,16 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:18
 #: ../locale/scriptstrings/m.proj_to_translate.c:20
 #: ../locale/scriptstrings/m.proj_to_translate.c:22
-#, fuzzy
 msgid "Files & format"
-msgstr "Mappa in output"
+msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:5
-#, fuzzy
 msgid "Output coordinate file (omit to send to stdout)"
+msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:9
-#, fuzzy
 msgid "Input projection parameters (PROJ.4 style)"
-msgstr "Visualizza il raster della direzione"
+msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:10
 #: ../locale/scriptstrings/m.proj_to_translate.c:12
@@ -28452,12 +26826,11 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:16
 #, fuzzy
 msgid "Projections"
-msgstr "Sto disegnando ..."
+msgstr "Proiezioni"
 #: ../locale/scriptstrings/m.proj_to_translate.c:11
-#, fuzzy
 msgid "Output projection parameters (PROJ.4 style)"
+msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:13
 msgid "Use LL WGS84 as input and current location as output projection"
@@ -28468,9 +26841,7 @@
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:17
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:19
@@ -28479,8 +26850,7 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:21
-msgid ""
-"Script style output in CSV format respecting the field separator settings"
+msgid "Script style output in CSV format respecting the field separator settings"
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:23
@@ -28488,22 +26858,18 @@
 msgstr ""
 #: ../locale/scriptstrings/d.out.file_to_translate.c:1
-#, fuzzy
 msgid "Saves the contents of the active display monitor to a graphics file."
 msgstr ""
-"Seleziona il tipo di carattere con cui il testo deve essere rappresentato "
-"nel monitor grafico dell'utente."
 #: ../locale/scriptstrings/d.out.file_to_translate.c:2
 #: ../locale/scriptstrings/d.out.png_to_translate.c:2
-#, fuzzy
 msgid "display, export"
-msgstr "mostra"
+msgstr ""
 #: ../locale/scriptstrings/d.out.file_to_translate.c:3
 #, fuzzy
 msgid "Name for output file (do NOT add extension)"
-msgstr "Nome di un file vettoriale in output"
+msgstr "Nome del file di output (senza aggiungere l'estensione)"
 #: ../locale/scriptstrings/d.out.file_to_translate.c:5
 msgid "Dimensions of output file versus current window size"
@@ -28521,17 +26887,17 @@
 #: ../locale/scriptstrings/d.out.file_to_translate.c:30
 #, fuzzy
 msgid "Images"
-msgstr "File di input"
+msgstr "Immagini"
 #: ../locale/scriptstrings/d.out.file_to_translate.c:8
 #, fuzzy
 msgid "Width and height of output image (overrides resolution setting)"
+msgstr "Larghezza e altezza dell'immagine di output (sovrascrive le impostazioni della risoluzione)"
 #: ../locale/scriptstrings/d.out.file_to_translate.c:10
 #, fuzzy
 msgid "Compression for PNG files"
-msgstr "Nome del filtro file"
+msgstr "Compressione per i file PNG"
 #: ../locale/scriptstrings/d.out.file_to_translate.c:11
 msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
@@ -28546,16 +26912,15 @@
 msgstr ""
 #: ../locale/scriptstrings/d.out.file_to_translate.c:16
-#, fuzzy
 msgid "Paper size for PostScript output"
+msgstr ""
 #: ../locale/scriptstrings/d.out.file_to_translate.c:17
 #: ../locale/scriptstrings/d.out.file_to_translate.c:19
 #: ../locale/scriptstrings/d.out.file_to_translate.c:32
 #, fuzzy
 msgid "PostScript"
+msgstr "PostScript"
 #: ../locale/scriptstrings/d.out.file_to_translate.c:18
 msgid "PostScript level (only limits functionality!)"
@@ -28576,8 +26941,7 @@
 msgstr ""
 #: ../locale/scriptstrings/d.out.file_to_translate.c:24
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
 msgstr ""
 #: ../locale/scriptstrings/d.out.file_to_translate.c:26
@@ -28594,160 +26958,140 @@
 #: ../locale/scriptstrings/d.out.file_to_translate.c:31
 msgid "Set paper orientation to landscape (for PostScript output)"
-msgstr ""
-"Imposta l'orientazione del foglio in orizzontale (per uscita PostScript)"
+msgstr "Imposta l'orientazione del foglio in orizzontale (per uscita PostScript)"
 #: ../locale/scriptstrings/d.out.file_to_translate.c:33
-#, fuzzy
 msgid "Do not crop away margins"
+msgstr ""
 #: ../locale/scriptstrings/db.test_to_translate.c:1
 msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Prova il driver del database, il database deve esistere e impostato "
-"utilizzando db.connect"
+msgstr "Prova il driver del database, il database deve esistere e impostato utilizzando db.connect"
 #: ../locale/scriptstrings/db.test_to_translate.c:3
-#, fuzzy
 msgid "Test name"
-msgstr "nome tabella"
+msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:2
-#, fuzzy
 msgid "raster, tiling"
+msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:3
-#, fuzzy
 msgid "Produces shell script output"
+msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:4
-#, fuzzy
 msgid "Produces web map server query string output"
+msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
+msgid "Name of region to use instead of current region for bounds and resolution"
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:6
-#, fuzzy
 msgid "Source projection"
+msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:7
 #: ../locale/scriptstrings/r.tileset_to_translate.c:9
 #, fuzzy
 msgid "Conversion factor from units to meters in source projection"
+msgstr "Fattore di conversione da unità a metri nella proiezione di origine"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:8
-#, fuzzy
 msgid "Destination projection, defaults to this location's projection"
-msgstr "Sovrascrivi la proiezione (utilizza quella della locazione)"
+msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:10
 #, fuzzy
 msgid "Maximum number of columns for a tile in the source projection"
-msgstr "Numero di passi attraverso il dataset"
+msgstr "Numero massimo di colonne per una tile nella proiezione di origine"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:11
 #, fuzzy
 msgid "Maximum number of rows for a tile in the source projection"
+msgstr "Numero massimo di righe per una tile nella proiezione di origine"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:12
-#, fuzzy
 msgid "Number of cells tiles should overlap in each direction"
-msgstr "Numero di livelli da utilizzare per ogni componente"
+msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:14
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:50
-#, fuzzy
 msgid "Verbosity level"
-msgstr "Nome mappa raster"
+msgstr ""
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
+msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
 msgstr ""
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
-#, fuzzy
 msgid "imagery, fusion, Brovey"
+msgstr ""
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
 msgid "LANDSAT sensor"
-msgstr ""
+msgstr "Sensore LANDSAT"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:4
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
 msgid "Sensor"
-msgstr ""
+msgstr "Sensore"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
 msgid "QuickBird sensor"
-msgstr ""
+msgstr "Sensore QuickBird"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:7
 msgid "SPOT sensor"
-msgstr ""
+msgstr "Sensore SPOT"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
 #, fuzzy
 msgid "Name of input raster map (green: tm2 | qbird_green | spot1)"
-msgstr "Nome di  2-%d mappe raster in input"
+msgstr "Nome della mappa raster di input (green: tm2 | qbird_green | spot1)"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
 #, fuzzy
 msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
+msgstr "Nome della mappa raster di input (NIR: tm4 | qbird_nir | spot2)"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
 #, fuzzy
 msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
+msgstr "Nome della mappa raster di input (MIR; tm5 | qbird_red | spot3)"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:12
 #, fuzzy
 msgid "Name of input raster map (etmpan | qbird_pan | spotpan)"
+msgstr "Nome della mappa raster di input (etmpan | qbird_pan | spotpan)"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:13
 #, fuzzy
 msgid "Name for output raster map prefix (e.g. 'brov')"
+msgstr "Nome del prefisso per la mappa raster di output (e.g. 'brov')"
 #: ../locale/scriptstrings/g.extension_to_translate.c:1
 msgid "Tool to maintain GRASS extensions in local GRASS installation."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads, installs extensions from GRASS Addons SVN repository into local "
-"GRASS installation or removes installed extensions."
+msgid "Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
-#, fuzzy
 msgid "general, extensions"
+msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:4
 #, fuzzy
 msgid "Name of extension to install/remove"
-msgstr "Nome della nuova locazione da creare"
+msgstr "Nome dell'estensione da installare/rimuovere"
 #: ../locale/scriptstrings/g.extension_to_translate.c:6
 msgid "SVN Addons repository URL"
@@ -28760,7 +27104,7 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:8
 #, fuzzy
 msgid "List available modules in the GRASS Addons SVN repository"
-msgstr "Visualizza i formati supportati ed esci"
+msgstr "Elenca i moduli disponibili nel repository SVN Addons di GRASS "
 #: ../locale/scriptstrings/g.extension_to_translate.c:10
 msgid "Install system-wide (may need system administrator rights)"
@@ -28772,9 +27116,8 @@
 #: ../locale/scriptstrings/d.correlate_to_translate.c:2
 #: ../locale/scriptstrings/d.polar_to_translate.c:2
-#, fuzzy
 msgid "display, diagram"
-msgstr "mostra"
+msgstr ""
 #: ../locale/scriptstrings/d.correlate_to_translate.c:3
 #: ../locale/scriptstrings/d.correlate_to_translate.c:4
@@ -28782,7 +27125,7 @@
 #: ../locale/scriptstrings/d.correlate_to_translate.c:6
 #, fuzzy
 msgid "raster input map"
+msgstr "mappa raster in input"
 #: ../locale/scriptstrings/d.correlate_to_translate.c:7
 msgid "Draw a trend line"
@@ -28793,9 +27136,8 @@
 msgstr ""
 #: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
-#, fuzzy
 msgid "raster, imagery, mosaicking"
+msgstr ""
 #: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
 msgid "1st map for mosaic (top of image stack)."
@@ -28818,36 +27160,28 @@
 msgstr ""
 #: ../locale/scriptstrings/r.blend_to_translate.c:3
-#, fuzzy
 msgid "Name of first raster map for blending"
+msgstr ""
 #: ../locale/scriptstrings/r.blend_to_translate.c:4
-#, fuzzy
 msgid "Name of second raster map for blending"
+msgstr ""
 #: ../locale/scriptstrings/r.blend_to_translate.c:5
 msgid "Base name for red, green and blue output maps containing the blend"
 msgstr ""
 #: ../locale/scriptstrings/r.blend_to_translate.c:6
-#, fuzzy
 msgid "Percentage weight of first map for color blending"
+msgstr ""
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Riclassifica un raster maggiore o minore della dimensione di un'area "
-"specifica dall'utente (in ettaari)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "Riclassifica un raster maggiore o minore della dimensione di un'area specificata dall'utente (in ettaari)."
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
-#, fuzzy
 msgid "raster, statistics, aggregation"
-msgstr "Nome della mappa raster da utilizzare per <%s>"
+msgstr ""
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
 msgid "Lesser value option that sets the <= area size limit [hectares]"
@@ -28859,19 +27193,16 @@
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:1
 msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-"Carica valori di un vettoriale nella tabella degli attributi di un "
-"vettoriale puntuale"
+msgstr "Carica valori di un vettoriale nella tabella degli attributi di un vettoriale puntuale"
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:3
 #, fuzzy
 msgid "Vector map to modify"
-msgstr "Stampa solo il tipo di mappa raster"
+msgstr "Mappa vettoriale da modificare"
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:4
-#, fuzzy
 msgid "Layer in the vector to be modified"
-msgstr "file vettoriale da creare"
+msgstr ""
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:5
 msgid "Column to be updated with the query result"
@@ -28880,22 +27211,20 @@
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:6
 #, fuzzy
 msgid "Vector map to be queried"
+msgstr "Mappa vettoriale da interrogare"
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:7
-#, fuzzy
 msgid "Layer of the query vector containing data"
+msgstr ""
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:8
 #, fuzzy
 msgid "Column to be queried"
+msgstr "Colonna da interrogare"
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:9
-#, fuzzy
 msgid "Maximum query distance in map units"
-msgstr "Uso la massima distanza tra punti. %f"
+msgstr ""
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
 msgid "Import SRTM HGT files into GRASS"
@@ -28906,9 +27235,8 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
-#, fuzzy
 msgid "Output raster map (default: input tile)"
-msgstr "Mostra il titolo del file raster"
+msgstr ""
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
 msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
@@ -28921,38 +27249,32 @@
 #: ../locale/scriptstrings/v.report_to_translate.c:2
 #, fuzzy
 msgid "vector, report, statistics"
+msgstr "N"
 #: ../locale/scriptstrings/v.report_to_translate.c:3
-#, fuzzy
 msgid "Reverse sort the result"
+msgstr ""
 #: ../locale/scriptstrings/v.report_to_translate.c:4
-#, fuzzy
 msgid "Sort the result"
-msgstr "Nome della mappa con il risultato"
+msgstr ""
 #: ../locale/scriptstrings/v.report_to_translate.c:7
 #, fuzzy
 msgid "Value to calculate"
+msgstr "Valore da calcolare"
 #: ../locale/scriptstrings/v.report_to_translate.c:8
 msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
 msgstr "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:1
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
-msgstr ""
-"Permette di aggiornare una colonna nella tabella degli attributi connessa a "
-"una mappa vettoriale"
+msgid "Allows to update a column in the attribute table connected to a vector map."
+msgstr "Permette di aggiornare una colonna nella tabella degli attributi connessa a una mappa vettoriale"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:3
-#, fuzzy
 msgid "Vector map to edit the attribute table for"
+msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:4
 msgid "Layer to which the table to be changed is connected"
@@ -28961,31 +27283,25 @@
 #: ../locale/scriptstrings/v.db.update_to_translate.c:5
 #, fuzzy
 msgid "Column to update"
+msgstr "Colonna da aggiornare"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:6
-msgid ""
-"Value to update the column with (varchar values have to be in single quotes, "
-"e.g. 'grass')"
+msgid "Value to update the column with (varchar values have to be in single quotes, e.g. 'grass')"
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:7
 #, fuzzy
 msgid "Column to query"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:8
-msgid ""
-"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
-"col2>1)"
+msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
 msgstr ""
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
 #, fuzzy
 msgid "Displays a raster map and its legend on a graphics window"
-msgstr ""
+msgstr "Visualizza una mappa raster e la sua legenda in una finestra grafica"
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
 msgid "Omit entries with missing label"
@@ -28999,17 +27315,16 @@
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
 #, fuzzy
 msgid "Number of lines to appear in the legend"
+msgstr "Numero di righe che devono apparire nella legenda"
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
 #, fuzzy
 msgid "Name of raster map to generate legend from"
+msgstr "Nome della mappa raster da cui generare la legenda"
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:8
-#, fuzzy
 msgid "Name of raster map to print in legend"
+msgstr ""
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:9
 msgid "Position of vertical map-legend separator (in percent)"
@@ -29020,9 +27335,8 @@
 msgstr ""
 #: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:2
-#, fuzzy
 msgid "display, export, GPS"
-msgstr "mostra"
+msgstr ""
 #: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:3
 msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
@@ -29034,11 +27348,8 @@
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:1
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-#, fuzzy
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr "Calcola le statistiche univariate per le celle non nulle di un raster"
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+msgstr ""
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:3
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:3
@@ -29049,25 +27360,23 @@
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:4
 #, fuzzy
 msgid "Name of data table"
+msgstr "Nome della tabella dei dati"
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:5
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-#, fuzzy
 msgid "Column on which to calculate statistics (must be numeric)"
+msgstr ""
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:6
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:6
-#, fuzzy
 msgid "Database/directory for table"
+msgstr ""
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:7
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:7
 #, fuzzy
 msgid "Database driver"
-msgstr "Nome del database:"
+msgstr "Driver del database:"
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:8
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:13
@@ -29081,57 +27390,44 @@
 msgstr "Visualizza la pagina di supporto HTML di GRASS "
 #: ../locale/scriptstrings/g.manual_to_translate.c:2
-#, fuzzy
 msgid "general, manual, help"
+msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:3
-#, fuzzy
 msgid "Display index"
+msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:4
 msgid "Display as MAN text page instead of HTML page in browser"
 msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:5
-#, fuzzy
 msgid "Manual entry to be displayed"
+msgstr ""
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-#, fuzzy
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgid "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
 msgstr ""
-"mapset e formato"
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
-#, fuzzy
 msgid "sites, vector, import"
+msgstr ""
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
 msgid "Run non-interactively"
 msgstr ""
 #: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Rinomina una colonna nella tabella degli attributi connessa a una mappa "
-"vettoriale"
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr "Rinomina una colonna nella tabella degli attributi connessa a una mappa vettoriale"
 #: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
-#, fuzzy
 msgid "Vector map for which to rename attribute column"
+msgstr ""
 #: ../locale/scriptstrings/v.db.renamecol_to_translate.c:4
-#, fuzzy
 msgid "Layer where to rename column"
+msgstr ""
 #: ../locale/scriptstrings/v.db.renamecol_to_translate.c:5
 msgid "Old and new name of the column (old,new)"
@@ -29143,9 +27439,8 @@
 msgstr "Crea una MASK per limitare le operazioni raster"
 #: ../locale/scriptstrings/r.mask_to_translate.c:2
-#, fuzzy
 msgid "raster, mask"
-msgstr "Nome del driver in input"
+msgstr ""
 #: ../locale/scriptstrings/r.mask_to_translate.c:3
 #, fuzzy
@@ -29171,53 +27466,46 @@
 msgstr ""
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-msgstr ""
-"Esporta un vettore in un GPS o un file con un formato supportato da GPSBabel"
+msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+msgstr "Esporta un vettore in un GPS o un file con un formato supportato da GPSBabel"
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:2
-#, fuzzy
 msgid "vector, export, GPS"
+msgstr ""
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:3
-#, fuzzy
 msgid "Export as waypoints"
+msgstr ""
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:4
-#, fuzzy
 msgid "Export as routes"
+msgstr ""
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:5
 #, fuzzy
 msgid "Export as tracks"
-msgstr "Importa tracce"
+msgstr "Esporta come tracce"
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:7
 #, fuzzy
 msgid "Feature type(s)"
+msgstr "Tipo/i di elemento"
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:8
 #, fuzzy
 msgid "Name for output file or GPS device"
-msgstr "Nome del file in output"
+msgstr "Nome del file in output o del dispositivo GPS"
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:9
 #, fuzzy
 msgid "GpsBabel supported output format"
+msgstr "Formato di output supportato da GpsBabel"
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:11
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:6
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use."
-msgstr ""
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+msgstr "Una singola mappa vettoriale può essere connessa a più tabelle di un database. Questo numero determina quale tabella viene utilizzata."
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:12
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:15
@@ -29230,45 +27518,40 @@
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
 msgid "Reconnects vectors to a new database."
-msgstr "Riconnetti vettoriale a un nuovo database"
+msgstr "Riconnette i vettoriali a un nuovo database"
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
 #, fuzzy
 msgid "Name of old database"
+msgstr "Nome del vecchio database"
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
-msgid ""
-"The database must be in form printed by v.db.connect -g, i.e. with "
-"substituted variables"
+msgid "The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
 msgstr ""
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
 #, fuzzy
 msgid "Name of new database"
+msgstr "Nome del nuovo database"
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
 #, fuzzy
 msgid "Old schema"
+msgstr "Vecchio schema"
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
 #, fuzzy
 msgid "New schema"
+msgstr "Nuovo schema"
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
+msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:2
 #: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
-#, fuzzy
 msgid "raster, imagery, import"
+msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:3
 msgid "Input ASTER image to be georeferenced & rectified"
@@ -29279,35 +27562,30 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:5
-msgid ""
-"L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
-"single band"
+msgid "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a single band"
 msgstr ""
 #: ../locale/scriptstrings/v.colors_to_translate.c:1
-msgid ""
-"Set color rules for features in a vector using a numeric attribute column."
+msgid "Set color rules for features in a vector using a numeric attribute column."
 msgstr ""
 #: ../locale/scriptstrings/v.colors_to_translate.c:2
-#, fuzzy
 msgid "vector, color table"
+msgstr ""
 #: ../locale/scriptstrings/v.colors_to_translate.c:4
 #, fuzzy
 msgid "Name of column containing numeric data"
-msgstr "Nome della colonna contenente le coordinate x"
+msgstr "Nome della colonna contenente dati numerici"
 #: ../locale/scriptstrings/v.colors_to_translate.c:5
 #, fuzzy
 msgid "Layer number of data column"
+msgstr "Numero del layer della colonna dei dati"
 #: ../locale/scriptstrings/v.colors_to_translate.c:6
-#, fuzzy
 msgid "Name of color column to populate"
-msgstr "Nome del raster map in output"
+msgstr ""
 #: ../locale/scriptstrings/v.colors_to_translate.c:8
 msgid "Manually set range (min,max)"
@@ -29315,17 +27593,16 @@
 #: ../locale/scriptstrings/v.colors_to_translate.c:11
 msgid "Raster map name from which to copy color table"
-msgstr "Nome della mappa raster da cui copiare la tabella colore"
+msgstr "Nome della mappa raster da cui copiare la tavola dei colori"
 #: ../locale/scriptstrings/v.colors_to_translate.c:13
 #, fuzzy
 msgid "Path to rules file"
+msgstr "Percorso del file di regole"
 #: ../locale/scriptstrings/v.colors_to_translate.c:15
-#, fuzzy
 msgid "Save placeholder raster map for use with d.legend"
-msgstr "Nome della mappa raster da mostrare"
+msgstr ""
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
 msgid "Exports attribute tables into various formats."
@@ -29334,7 +27611,7 @@
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
 #, fuzzy
 msgid "GRASS table name"
+msgstr "Nome tabella di GRASS"
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
 msgid "Table file to be exported or DB connection string"
@@ -29343,7 +27620,7 @@
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
 #, fuzzy
 msgid "Table format"
+msgstr "Formato della tabella"
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
@@ -29356,26 +27633,21 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.lines_to_translate.c:3
-#, fuzzy
 msgid "Create a 3D line from 3 column data"
-msgstr "Crea un nuovo vettoriale (punti) da una tabella contenente coordinate"
+msgstr ""
 #: ../locale/scriptstrings/v.in.lines_to_translate.c:4
 #, fuzzy
 msgid "Name of input file (or \"-\" to read from stdin)"
-msgstr ""
-"File ASCII contenente la singola linea descrivente la proiezione WKT (- per "
-"stdin)"
+msgstr "Nome del file di input (o \"-\" per leggere dallo stdin)"
 #: ../locale/scriptstrings/d.redraw_to_translate.c:1
-#, fuzzy
 msgid "Redraws the current display frame in the GRASS monitor"
-msgstr "Non è mostrata nessuna mappa nel monitor GRASS"
+msgstr ""
 #: ../locale/scriptstrings/d.redraw_to_translate.c:3
-#, fuzzy
 msgid "Redraw all frames"
-msgstr "Numero di righe"
+msgstr ""
 #: ../locale/scriptstrings/d.redraw_to_translate.c:4
 msgid "Do not preserve individual regions when redrawing all frames"
@@ -29384,17 +27656,16 @@
 #: ../locale/scriptstrings/d.slide.show_to_translate.c:1
 #, fuzzy
 msgid "Slide show of GRASS raster/vector maps."
-msgstr "Slide show dei file raster e vettoriali presenti"
+msgstr "Slide show delle mappe raster e vettoriali."
 #: ../locale/scriptstrings/d.slide.show_to_translate.c:2
-#, fuzzy
 msgid "display, slideshow"
-msgstr "mostra"
+msgstr ""
 #: ../locale/scriptstrings/d.slide.show_to_translate.c:3
 #, fuzzy
 msgid "Show vector maps rather than raster maps"
-msgstr "Converti una mappa raster in file height field per POVRAY"
+msgstr "Mostra le mappe vettoriali piuttosto che quelle raster"
 #: ../locale/scriptstrings/d.slide.show_to_translate.c:4
 msgid "Map prefix. Specify character(s) to view selected maps only"
@@ -29413,22 +27684,17 @@
 msgstr "Mapset da usare. Specificare multipli mapset separati dalla virgola"
 #: ../locale/scriptstrings/d.slide.show_to_translate.c:8
-#, fuzzy
 msgid "Number of seconds to pause between slides"
+msgstr ""
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:1
-msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
-msgstr ""
-"Scarica punti di interesse, rotte e tracce da un GPS Garmin in un vettore"
+msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+msgstr "Scarica punti di interesse, rotte e tracce da un GPS Garmin in un vettore"
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
-#, fuzzy
 msgid "vector, import, GPS"
+msgstr ""
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:4
 msgid "Download Waypoints from GPS"
@@ -29440,7 +27706,7 @@
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:6
 msgid "Download Track from GPS"
-msgstr "Scarica Tracca da un GPS"
+msgstr "Scarica Traccia da un GPS"
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:7
 msgid "Force import of track or route data as points"
@@ -29462,23 +27728,20 @@
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:11
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:10
-#, fuzzy
 msgid "Name for output vector map (omit for display to stdout)"
-msgstr "Nome del nuovo file PPM. (use out=- per lo standard output)"
+msgstr ""
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:12
 msgid "Port Garmin receiver is connected to"
-msgstr "La porta del ricevitore Garmin è connesso a"
+msgstr "La porta del ricevitore Garmin è connessa a"
 #: ../locale/scriptstrings/d.split.frame_to_translate.c:1
-#, fuzzy
 msgid "Split the display into subframes."
+msgstr ""
 #: ../locale/scriptstrings/d.split.frame_to_translate.c:2
-#, fuzzy
 msgid "Number of subframes"
+msgstr ""
 #: ../locale/scriptstrings/d.split.frame_to_translate.c:3
 msgid "Split horizontally not vertically"
@@ -29562,9 +27825,8 @@
 msgstr "Mostra mappa vettoriale tematica"
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:2
-#, fuzzy
 msgid "display, vector, thematic, legend"
-msgstr "mostra"
+msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:3
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
@@ -29586,14 +27848,12 @@
 msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
-#, fuzzy
 msgid "Name of attribute column to use for thematic display (must be numeric)"
+msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
-#, fuzzy
 msgid "Type of thematic display"
+msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:12
 msgid "Thematic divisions of data for display"
@@ -29614,7 +27874,7 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:21
 #, fuzzy
 msgid "Icon size for point data"
-msgstr "Icona di punti vettoriali per dati puntiformi"
+msgstr "Dimensione dell'icona per dati puntiformi"
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
 msgid "Minimum icon size/line width for graduated points/lines)"
@@ -29625,9 +27885,8 @@
 msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:26
-#, fuzzy
 msgid "Number of classes for interval theme (integer)"
+msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
 msgid "Color scheme for graduated color mapping"
@@ -29654,27 +27913,24 @@
 msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
-#, fuzzy
 msgid "Beginning color for custom color gradient"
-msgstr "Utilizzando le coordinate del centro della mappa\n"
+msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
 #, fuzzy
 msgid "Must be expressed as R:G:B triplet"
+msgstr "Dev'essere espresso come tripletta R:G:B"
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
-#, fuzzy
 msgid "Ending color for custom color gradient"
+msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:59
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:61
-#, fuzzy
 msgid "Misc"
-msgstr "Metrico"
+msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:43
 msgid "Select x11 display monitor for legend"
@@ -29721,21 +27977,17 @@
 msgstr "Elimina una tabella degli attributi"
 #: ../locale/scriptstrings/db.droptable_to_translate.c:4
-#, fuzzy
 msgid "Table to drop"
-msgstr "impossibile aprire <%s>"
+msgstr ""
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
 msgstr ""
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:2
 #: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
-#, fuzzy
 msgid "vector, import, gazetteer"
+msgstr ""
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:3
 msgid "Uncompressed GNS file from NGA (with .txt extension)"
@@ -29743,56 +27995,45 @@
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
 #, fuzzy
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygons "
-"and uploads statistics to new attribute columns."
-msgstr ""
-"Calcola statistiche univariate da un raster basandosi su poligoni vettoriale "
-"e carica le statistiche in una nuova colonna della tabella degli attributi."
+msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
+msgstr "Calcola statistiche univariate da un raster basandosi su poligoni vettoriali e carica le statistiche in una nuova colonna della tabella degli attributi."
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
-#, fuzzy
 msgid "vector, raster, statistics"
+msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
 msgid "Continue if upload column(s) already exist"
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
-#, fuzzy
 msgid "Name of vector polygon map"
+msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
-msgid ""
-"number determines which table to use"
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use"
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
-#, fuzzy
 msgid "Name of raster map to calculate statistics from"
-msgstr "Nome della mappa raster che contiene i risultati"
+msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
 #, fuzzy
 msgid "Column prefix for new attribute columns"
+msgstr "Prefisso di colonna per la nuova colonna della tabella degli attributi"
 #: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
-#, fuzzy
 msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr "Importa vecchie versione di vettori GRASS"
+msgstr ""
 #: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
 msgid "Uncompressed geonames file from (with .txt extension)"
 msgstr ""
 #: ../locale/scriptstrings/d.m_to_translate.c:1
-#, fuzzy
 msgid "Display manager for GRASS"
-msgstr "Numero di colonne"
+msgstr ""
 #: ../locale/scriptstrings/d.m_to_translate.c:2
 #, fuzzy
@@ -29800,36 +28041,29 @@
 msgstr "Nome di un file MAT-File(v4) esistente"
 #: ../locale/scriptstrings/gis.m_to_translate.c:1
-#, fuzzy
 msgid "GIS manager for GRASS"
+msgstr ""
 #: ../locale/scriptstrings/gis.m_to_translate.c:2
-#, fuzzy
 msgid "Name of GIS manager settings file (.grc)"
-msgstr "Nome di un file MAT-File(v4) esistente"
+msgstr ""
 #: ../locale/scriptstrings/db.dropcol_to_translate.c:1
-#, fuzzy
 msgid "Drops a column from selected attribute table"
+msgstr ""
 #: ../locale/scriptstrings/db.dropcol_to_translate.c:4
-#, fuzzy
 msgid "Table from which to drop attribute column"
+msgstr ""
 #: ../locale/scriptstrings/db.dropcol_to_translate.c:5
 #, fuzzy
 msgid "Name of the column"
+msgstr "Nome della colonna"
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-"Esporta un raster in un file di testo come valori x,y,z basato sui centri "
-"delle celle"
+msgid "Export a raster map to a text file as x,y,z values based on cell centers."
+msgstr "Esporta un raster in un file di testo come valori x,y,z basato sui centri delle celle"
 #: ../locale/scriptstrings/d.resize_to_translate.c:1
 msgid "Resizes active display monitor"
@@ -29850,27 +28084,25 @@
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
 #, fuzzy
 msgid "Input map is in Matlab format"
+msgstr "La mappa di input è nel formato di Matlab"
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
-#, fuzzy
 msgid "Create a 3D vector points map from 3 column Matlab data"
+msgstr ""
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
 #, fuzzy
 msgid "Name of input file in Mapgen/Matlab format"
+msgstr "Nome di un file di input in formato Mapgen/Matlab"
 #: ../locale/scriptstrings/v.build.all_to_translate.c:1
 #, fuzzy
 msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr "Non riesco a trovare il file raster %s"
+msgstr "Ricostruisce la topologia in tutte le mappe vettoriali nel mapset corrente"
 #: ../locale/scriptstrings/r.univar.sh_to_translate.c:1
-#, fuzzy
 msgid "calculates univariate statistics from a GRASS raster map"
+msgstr ""
 #: ../locale/scriptstrings/r.univar.sh_to_translate.c:3
 msgid "extended statistics (quartiles and percentile)"
@@ -29879,7 +28111,7 @@
 #: ../locale/scriptstrings/r.univar.sh_to_translate.c:5
 #, fuzzy
 msgid "Percentile to calculate (requires -e flag)"
-msgstr "Nome della mappa di input"
+msgstr "Percentuale da calcolare (richiede il flag -e)"
 #: ../locale/scriptstrings/r.mapcalculator_to_translate.c:1
 msgid "Calculate new raster map from a r.mapcalc expression."
@@ -29927,16 +28159,15 @@
 #: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:12
 #, fuzzy
 msgid "Do not overwrite existing map"
-msgstr "Usa il flag -o per sovrascrivere il link esistente del layer <%d>"
+msgstr "Non sovrascrive la mappa esistente"
 #: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:1
 msgid "Performs auto-balancing of colors for LANDSAT images."
-msgstr "Eseguisce l'auto bilanciamento dei colori per immagini LANDSAT"
+msgstr "Esegue l'auto bilanciamento dei colori per immagini LANDSAT"
 #: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
-#, fuzzy
 msgid "raster, imagery, colors"
+msgstr ""
 #: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
 msgid "LANDSAT red channel"
@@ -29963,9 +28194,8 @@
 msgstr ""
 #: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:9
-#, fuzzy
 msgid "Reset to standard color range"
-msgstr "Mantieni la tabella colore esistente"
+msgstr ""
 #: ../locale/scriptstrings/d.monsize_to_translate.c:1
 msgid "Selects/starts specified monitor at specified size"
@@ -29976,51 +28206,40 @@
 msgstr "Mostra monitor all'avvio"
 #: ../locale/scriptstrings/d.monsize_to_translate.c:4
-#, fuzzy
 msgid "Width in pixels of new display monitor"
-msgstr "Ridimensiona il monitor attivo visualizzato"
+msgstr ""
 #: ../locale/scriptstrings/d.monsize_to_translate.c:5
-#, fuzzy
 msgid "Height in pixels of new display monitor"
+msgstr ""
 #: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
 msgid "Drapes a color raster over a shaded relief map using d.his"
 msgstr ""
 #: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
-#, fuzzy
 msgid "Name of shaded relief or aspect map"
-msgstr "Nome di un nuovo file raster"
+msgstr ""
 #: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
-#, fuzzy
 msgid "Name of raster to drape over relief map"
-msgstr "Nome della mappa raster"
+msgstr ""
 #: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
-#, fuzzy
 msgid "Percent to brighten"
-msgstr "Percentuale fatta:"
+msgstr ""
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-"file into a vector map."
-msgstr ""
-"Scarica punti di interesse, rotte e tracce da un GPS o da un file di dati "
-"scaricati da un GPS in un vettore"
+msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+msgstr "Scarica punti di interesse, rotte e tracce da un GPS o da un file di dati scaricati da un GPS in un vettore"
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:4
-#, fuzzy
 msgid "Import waypoints"
+msgstr ""
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:5
-#, fuzzy
 msgid "Import routes"
+msgstr ""
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:6
 msgid "Import track"
@@ -30033,19 +28252,15 @@
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:9
 #, fuzzy
 msgid "Device or file used to import data"
-msgstr "Il file raster da importare"
+msgstr "Dispositivo o file utilizzato per l'importazione dei dati"
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:11
 msgid "Format of GPS input data (use gpsbabel supported formats)"
-msgstr ""
-"Formato dei dati di input del GPS (usare formati supportati da gpsbabel)"
+msgstr "Formato dei dati di input del GPS (usare formati supportati da gpsbabel)"
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:12
-msgid ""
-"Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-msgstr ""
-"Proiezione dei dati in input (modello PROJ.4), se non impostato è utilizzato "
-"WGS84 Lat/Lon"
+msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
+msgstr "Proiezione dei dati in input (modello PROJ.4), se non impostato è utilizzato WGS84 Lat/Lon"
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:1
 msgid "Downloads and imports data from WMS servers."
@@ -30070,7 +28285,7 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:49
 #, fuzzy
 msgid "Request"
-msgstr "silenzioso"
+msgstr "Interrogazione"
 msgid "Skip to downloading (to resume downloads faster)"
@@ -30112,43 +28327,36 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:20
-#, fuzzy
 msgid "Mapserver to request data from"
-msgstr "Non riesco a selezionare dati dalla tabella"
+msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:22
-#, fuzzy
 msgid "Layers to request from map server"
+msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:24
-#, fuzzy
 msgid "Styles to request from map server"
+msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:26
-#, fuzzy
 msgid "Source projection to request from server"
+msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:28
-#, fuzzy
 msgid "Image format requested from the server"
+msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:30
 msgid "Addition query options for server"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:32
-#, fuzzy
 msgid "Maximum columns to request at a time"
-msgstr "Distanza massima dal punto più vicino"
+msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:34
-#, fuzzy
 msgid "Maximum rows to request at a time"
+msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:36
 msgid "Additional options for r.tileset"
@@ -30171,75 +28379,60 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:45
-#, fuzzy
 msgid "Reprojection method to use"
+msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:47
 msgid "Filename to save capabilities XML file to"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:48
-#, fuzzy
 msgid "Requires list available layers flag"
+msgstr ""
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
 msgid "Set color rules based on stddev from a map's mean value."
 msgstr ""
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
-#, fuzzy
 msgid "Color using standard deviation bands"
-msgstr "Deviazione standard"
+msgstr ""
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
 msgid "Force center at zero"
 msgstr ""
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
-msgid ""
-"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-msgstr ""
-"Riempi aree senza dati di un raster usando interpolazione spline v.surf.rst "
+msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+msgstr "Riempi aree senza dati di un raster usando interpolazione spline v.surf.rst "
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
-#, fuzzy
 msgid "raster, elevation, interpolation"
+msgstr ""
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
-#, fuzzy
 msgid "Raster map in which to fill nulls"
-msgstr "Mappa(e) raster da leggere"
+msgstr ""
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
-msgid ""
-"Output raster map with nulls filled by interpolation from surrounding values"
+msgid "Output raster map with nulls filled by interpolation from surrounding values"
 msgstr ""
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
-#, fuzzy
 msgid "Spline tension parameter"
-msgstr "Nome del file raster in input"
+msgstr ""
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
-#, fuzzy
 msgid "Spline smoothing parameter"
+msgstr ""
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Dissolve i confini tra aree adiacenti che condividono categorie o attributi "
-"comuni."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Dissolve i confini tra aree adiacenti che condividono categorie o attributi comuni."
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:2
-#, fuzzy
 msgid "vector, area, dissolve"
+msgstr ""
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:5
 #, fuzzy
@@ -30247,68 +28440,56 @@
 msgstr "Numero di layer. Se -1, tutti i layer sono estratti"
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:7
-#, fuzzy
 msgid "Name of column used to dissolve common boundaries"
+msgstr ""
 #: ../locale/scriptstrings/v.centroids_to_translate.c:1
 msgid "Adds missing centroids to closed boundaries."
 msgstr "Aggiungi i centroidi mancanti ai confini chiusi."
 #: ../locale/scriptstrings/v.centroids_to_translate.c:2
-#, fuzzy
 msgid "vector, centroid, area"
-msgstr "Non riesco a descrivere la tabella"
+msgstr ""
 #: ../locale/scriptstrings/v.centroids_to_translate.c:5
-#, fuzzy
 msgid "Action to be taken"
+msgstr ""
 #: ../locale/scriptstrings/v.centroids_to_translate.c:7
-#, fuzzy
 msgid "Category number starting value"
+msgstr ""
-#, fuzzy
 msgid "Calculates new grid3D volume from r3.mapcalc expression."
-msgstr "Calcola una nuova mappa raster da un'espressione di r.mapcalc"
+msgstr ""
 #: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:2
-#, fuzzy
 msgid "A (grid3D file)"
-msgstr "Nome del file di output"
+msgstr ""
 #: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:3
-#, fuzzy
 msgid "B (grid3D file)"
+msgstr ""
 #: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:4
-#, fuzzy
 msgid "C (grid3D file)"
+msgstr ""
 #: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:5
-#, fuzzy
 msgid "D (grid3D file)"
+msgstr ""
 #: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:6
-#, fuzzy
 msgid "E (grid3D file)"
+msgstr ""
 #: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:7
-#, fuzzy
 msgid "F (grid3D file)"
+msgstr ""
 #: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:9
-#, fuzzy
 msgid "Name for output grid3D volume"
+msgstr ""
 #: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:11
 msgid "Expert mode (enter a set of r3.mapcalc expressions)"
@@ -30317,7 +28498,7 @@
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
 #, fuzzy
 msgid "Removes existing attribute table of a vector map."
+msgstr "Rimuove la tabella degli attributi esistente di una mappa vettoriale"
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
 msgid "Force removal (required for actual deletion of table)"
@@ -30326,56 +28507,48 @@
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
 #, fuzzy
 msgid "Vector map from which to remove attribute table"
+msgstr "Mappa vettoriale dalla quale rimuovere la tabella degli attributi"
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
 #, fuzzy
 msgid "Name of existing attribute table (default: vector map name)"
+msgstr "Nome della tabella degli attributi esistente (predefinito: nome della mappa vettoriale"
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
-#, fuzzy
 msgid "Layer from which to drop linked attribute table"
+msgstr ""
 #: ../locale/scriptstrings/v.db.join_to_translate.c:1
-#, fuzzy
 msgid "Allows to join a table to a vector map table."
+msgstr ""
 #: ../locale/scriptstrings/v.db.join_to_translate.c:3
-#, fuzzy
 msgid "Vector map to which to join other table"
+msgstr ""
 #: ../locale/scriptstrings/v.db.join_to_translate.c:4
-#, fuzzy
 msgid "Layer where to join"
+msgstr ""
 #: ../locale/scriptstrings/v.db.join_to_translate.c:5
-#, fuzzy
 msgid "Join column in map table"
-msgstr "Tipo sconosciuto"
+msgstr ""
 #: ../locale/scriptstrings/v.db.join_to_translate.c:6
-#, fuzzy
 msgid "Other table name"
-msgstr "Nome della tabella in output"
+msgstr ""
 #: ../locale/scriptstrings/v.db.join_to_translate.c:7
-#, fuzzy
 msgid "Join column in other table"
+msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:1
 msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:2
-#, fuzzy
 msgid "raster, imagery"
+msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:3
 msgid "use transformation rules for LANDSAT-4"
@@ -30392,75 +28565,67 @@
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:6
 #, fuzzy
 msgid "raster input map (LANDSAT channel 1)"
+msgstr "mappa raster di input (LANDSAT canale 1)"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:7
 #, fuzzy
 msgid "raster input map (LANDSAT channel 2)"
+msgstr "mappa raster di input (LANDSAT canale 2)"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:8
 #, fuzzy
 msgid "raster input map (LANDSAT channel 3)"
+msgstr "mappa raster di input (LANDSAT canale 3)"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:9
 #, fuzzy
 msgid "raster input map (LANDSAT channel 4)"
+msgstr "mappa raster di input (LANDSAT canale 4)"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:10
 #, fuzzy
 msgid "raster input map (LANDSAT channel 5)"
+msgstr "mappa raster di input (LANDSAT canale 5)"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:11
 #, fuzzy
 msgid "raster input map (LANDSAT channel 7)"
+msgstr "mappa raster di input (LANDSAT canale 7)"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:12
-#, fuzzy
 msgid "raster output TC maps prefix"
-msgstr "File raster in output"
+msgstr ""
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-#, fuzzy
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr ""
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
 #, fuzzy
 msgid "Vector map for which to add new attribute table"
+msgstr "Mappa vettoriale per la quale aggiungere una nuova tabella degli attributi"
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
 #, fuzzy
 msgid "Name of new attribute table (default: vector map name)"
+msgstr "Nome della nuova tabella degli attributi (predefinito: nome della mappa vettoriale)"
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
-#, fuzzy
 msgid "Layer where to add new attribute table"
+msgstr ""
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
-msgid ""
-"Name and type of the new column(s) (types depend on database backend, but "
-"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
+msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
 #, fuzzy
 msgid "Import GetFeature from WFS"
-msgstr "importa GetFeature da WFS"
+msgstr "Importa GetFeature da WFS"
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
-#, fuzzy
 msgid "vector, import, wfs"
+msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
 msgid "GetFeature URL starting with 'http'"
@@ -30468,18 +28633,16 @@
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
 msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr ""
-"Crea mappa dell'ombreggiatura dei rilievi da una mappa dell'elevatione (DEM)"
+msgstr "Crea mappa dell'ombreggiatura dei rilievi da una mappa dell'elevatione (DEM)"
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
 #, fuzzy
 msgid "Input elevation map"
+msgstr "Mappa di elevazione di input"
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:4
-#, fuzzy
 msgid "Output shaded relief map name"
-msgstr "Nome del driver in output"
+msgstr ""
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:5
 msgid "Altitude of the sun in degrees above the horizon"
@@ -30498,19 +28661,17 @@
 msgstr ""
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
-msgid ""
-"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
 msgstr ""
 #: ../locale/scriptstrings/d.out.png_to_translate.c:1
 msgid "Saves active display monitor to PNG file in home directory"
-msgstr ""
-"Salva il monitor attivo visualizzato in un file PNG nella directory home"
+msgstr "Salva il monitor attivo visualizzato in un file PNG nella directory home"
 #: ../locale/scriptstrings/d.out.png_to_translate.c:3
 #, fuzzy
 msgid "Name of PNG file"
+msgstr "Nome del file PNG"
 #: ../locale/scriptstrings/d.out.png_to_translate.c:4
 msgid "Resolution of output file (single=1, double=2, quad=4)"
@@ -30521,9 +28682,8 @@
 msgstr ""
 #: ../locale/scriptstrings/i.oif_to_translate.c:2
-#, fuzzy
 msgid "raster, imagery, statistics"
+msgstr ""
 #: ../locale/scriptstrings/i.oif_to_translate.c:3
 msgid "LANDSAT TM band 1."
@@ -30550,14 +28710,13 @@
 msgstr ""
 #: ../locale/scriptstrings/r.li.setup_to_translate.c:1
-#, fuzzy
 msgid "Configuration editor for r.li.'index'"
+msgstr ""
 #: ../locale/scriptstrings/r.li.setup_to_translate.c:2
 #, fuzzy
 msgid "raster, landscape structure analysis"
+msgstr "raster, analisi della struttura del paesaggio"
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
 msgid "Imports attribute tables in various formats."
@@ -30572,54 +28731,48 @@
 msgstr "Nome della tabella della tabella del DB SQL"
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
-#, fuzzy
 msgid "Name for auto-generated unique key column"
+msgstr ""
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
 #, fuzzy
 msgid "Name of aspect raster map"
+msgstr "Nome della mappa raster delle esposizioni"
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
 msgid "Width of display canvas"
 msgstr ""
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
-#, fuzzy
 msgid "Height of display canvas"
+msgstr ""
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
 #, fuzzy
 msgid "Minimum size of each cell"
-msgstr "Livello minimo di contorno"
+msgstr "Dimensione minima di ogni cella"
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
 #, fuzzy
 msgid "Maximum number of rows to load"
+msgstr "Numero massimo di righe da caaricare"
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
 #, fuzzy
 msgid "Maximum number of columns to load"
+msgstr "Numero massimo di colonne da caricare"
 #: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
-#, fuzzy
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+msgid "Drops a column from the attribute table connected to a given vector map."
+msgstr ""
 #: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
-#, fuzzy
 msgid "Vector map for which to drop attribute column"
+msgstr ""
 #: ../locale/scriptstrings/v.db.dropcol_to_translate.c:4
-#, fuzzy
 msgid "Layer where to drop column"
+msgstr ""
 #: ../locale/scriptstrings/v.db.dropcol_to_translate.c:5
 #, fuzzy
@@ -30631,9 +28784,8 @@
 msgstr ""
 #: ../locale/scriptstrings/d.polar_to_translate.c:3
-#, fuzzy
 msgid "Name of raster angle map"
+msgstr ""
 #: ../locale/scriptstrings/d.polar_to_translate.c:4
 msgid "Pixel value to be interpreted as undefined (different from NULL)"
@@ -30642,7 +28794,7 @@
 #: ../locale/scriptstrings/d.polar_to_translate.c:5
 #, fuzzy
 msgid "Name of optional EPS output file"
+msgstr "Nome del file EPS opzionale di output"
 #: ../locale/scriptstrings/d.polar_to_translate.c:6
 msgid "Plot using Xgraph"
@@ -30661,48 +28813,37 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Aggiunge una o più colonne alla tabella degli attributi connessa ad una "
-"mappa vettoriale"
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "Aggiunge una o più colonne alla tabella degli attributi connessa ad una mappa vettoriale"
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
-#, fuzzy
 msgid "Name of vector map for which to edit attribute table"
+msgstr ""
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:4
-#, fuzzy
 msgid "Layer number where to add column(s)"
+msgstr ""
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:6
 msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:7
-msgid ""
-"Data types depend on database backend, but all support VARCHAR(), INT, "
-"DOUBLE PRECISION and DATE"
+msgid "Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE"
 msgstr ""
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:1
 #, fuzzy
 msgid "Moves displayed maps to another monitor"
-msgstr ""
+msgstr "Sposta le mappe visualizzate su un altro monitor"
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:3
 msgid "clear target monitor before moving"
 msgstr ""
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:4
-#, fuzzy
 msgid "stay with source monitor"
-msgstr "Nome del raster"
+msgstr ""
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:5
 msgid "kill source monitor after moving"
@@ -30711,12 +28852,12 @@
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:6
 #, fuzzy
 msgid "Target monitor"
+msgstr "Monitor di destinazione"
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:7
 #, fuzzy
 msgid "Source monitor"
+msgstr "Monitori di origine"
 #: ../sites/s.out.ascii/main.c:47 ../sites/s.in.ascii/main.c:50
 msgid "sites"
@@ -30729,12 +28870,12 @@
 #: ../imagery/i.smap/bouman/interp.c:237
 #, fuzzy
 msgid "Invalid parameter values"
-msgstr "Area: %d  Numero di isole: %d\n"
+msgstr "Valori del parametro non validi"
 #: ../imagery/i.smap/bouman/segment.c:70
 #, fuzzy
 msgid "Number of classes must be < 256"
-msgstr "Nume di righe da tenere in memoria"
+msgstr "Il numero delle classi dev'essere < 256"
 #: ../imagery/i.smap/bouman/segment.c:95
 #, c-format
@@ -30752,49 +28893,45 @@
 msgstr ""
 #: ../imagery/i.smap/shapiro/main.c:38 ../imagery/i.gensigset/main.c:40
-#, fuzzy
 msgid "imagery, classification, supervised, SMAP"
-msgstr "Nome del file con il risultato della classificazione"
+msgstr ""
 #: ../imagery/i.smap/shapiro/main.c:40
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
 msgstr ""
 #: ../imagery/i.smap/shapiro/read_sig.c:13
 #: ../imagery/i.smap/shapiro/openfiles.c:15
 #: ../imagery/i.gensigset/openfiles.c:15 ../imagery/i.gensig/openfiles.c:16
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read REF file for subgroup <%s> in group <%s>"
-msgstr "Impossibile salvare la region <%s>"
+msgstr ""
 #: ../imagery/i.smap/shapiro/read_sig.c:17
 #: ../imagery/i.smap/shapiro/openfiles.c:19
 #, fuzzy, c-format
 msgid "Subgroup <%s> in group <%s> contains no raster maps"
-msgstr "Gruppo [%s] non contiene mappe, avvia i.group"
+msgstr "Il sottogruppo <%s> nel gruppo <%s> non contiene mappe raster"
 #: ../imagery/i.smap/shapiro/read_sig.c:23
 #: ../imagery/i.cluster/open_files.c:70 ../imagery/i.maxlik/open.c:54
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read signature file <%s>"
-msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgstr ""
 #: ../imagery/i.smap/shapiro/read_sig.c:27
-#, fuzzy, c-format
+#, c-format
 msgid "Signature file <%s> is invalid"
-msgstr "raster <%s> non trovato"
+msgstr ""
 #: ../imagery/i.smap/shapiro/read_sig.c:30
-#, fuzzy, c-format
+#, c-format
 msgid "Signature file <%s> is empty"
+msgstr ""
 #: ../imagery/i.smap/shapiro/parse.c:21 ../imagery/i.maxlik/main.c:79
-#, fuzzy
 msgid "Name of file containing signatures"
-msgstr "Nome del file contenente i comandi SQL"
+msgstr ""
 #: ../imagery/i.smap/shapiro/parse.c:22
 msgid "Generated by i.gensigset"
@@ -30823,9 +28960,8 @@
 msgstr "Sottogruppo <%s> non trovato"
 #: ../imagery/i.pca/main.c:63
-#, fuzzy
 msgid "imagery, image transformation, PCA"
+msgstr ""
 #: ../imagery/i.pca/main.c:64
 msgid "Principal components analysis (PCA) for image processing."
@@ -30834,22 +28970,19 @@
 #: ../imagery/i.pca/main.c:69
 #, fuzzy
 msgid "Name of two or more input raster maps"
+msgstr "Nome di due o più mappe raster di input"
 #: ../imagery/i.pca/main.c:72
-#, fuzzy
 msgid "Base name for output raster maps"
-msgstr "Nome di un file vettoriale in output"
+msgstr ""
 #: ../imagery/i.pca/main.c:74
-#, fuzzy
 msgid "A numerical suffix will be added for each component map"
+msgstr ""
 #: ../imagery/i.pca/main.c:87
-#, fuzzy
 msgid "Rescaling range for output maps"
-msgstr "Mappa raster in input"
+msgstr ""
 #: ../imagery/i.pca/main.c:89
 msgid "For no rescaling use 0,0"
@@ -30862,12 +28995,12 @@
 #: ../imagery/i.pca/main.c:100
 #, fuzzy
 msgid "Sorry, at least 2 input bands must be provided"
+msgstr "Spiacente, ma si devono fornire almeno due bande di input"
 #: ../imagery/i.pca/main.c:134
 #, fuzzy
 msgid "Calculating covariance matrix..."
+msgstr "Calcolo della matrice di covarianza in corso..."
 #: ../imagery/i.pca/main.c:216
 msgid "Scale range length should be > 0. Using default values: 0,255."
@@ -30875,29 +29008,27 @@
 #: ../imagery/i.pca/main.c:253 ../imagery/i.pca/main.c:302
 #: ../imagery/i.pca/main.c:435
-#, fuzzy
 msgid "Unable allocate memory for row buffer"
+msgstr ""
 #: ../imagery/i.pca/main.c:255
 #, fuzzy, c-format
 msgid "Computing means for band %d..."
-msgstr "Sto copiando le tabelle..."
+msgstr "Calcolo delle medie per la banda %d in corso..."
 #: ../imagery/i.pca/main.c:304
-#, fuzzy, c-format
+#, c-format
 msgid "Computing row %d (of %d) of covariance matrix..."
+msgstr ""
 #: ../imagery/i.pca/main.c:321
-#, fuzzy
 msgid "Unable to allocate memory for row buffer"
+msgstr ""
 #: ../imagery/i.pca/main.c:383
 #, fuzzy
 msgid "Unable to allocate memory for raster row"
+msgstr "Impossibile allocare memoria per la riga raster"
 #: ../imagery/i.pca/main.c:392
 #, c-format
@@ -30905,9 +29036,9 @@
 msgstr "Sto trasformando <%s>..."
 #: ../imagery/i.pca/main.c:411
-#, fuzzy, c-format
+#, c-format
 msgid "Rescaling <%s> to range %d,%d..."
-msgstr "Mappa raster risultante"
+msgstr ""
 #: ../imagery/i.pca/support.c:44
 msgid "Eigen values, (vectors), and [percent importance]:"
@@ -30927,34 +29058,11 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:100
-msgid ""
-"mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;"
-"surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;"
-"LST 1Km 8-days (Day/Night);"
+msgid "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:111
-msgid ""
-"Name of QC type to extract:adjcorr;mod09: Adjacency Correction;atcorr;mod09: "
-"Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-"
-"Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different "
-"Orbit than 500m;modland_qa_bits;mod09: MODIS Land General Quality Assessment;"
-"mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;"
-"data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;"
-"mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average "
-"LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality "
-"Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;"
-"mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;"
-"lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: "
-"StateQA Internal Snow Maskbrdf_correction_performed;mod09A1s: StateQA "
-"Internal Snow Maskcirrus_detected;mod09A1s: StateQA Internal Snow "
-"Maskcloud_shadow;mod09A1s: StateQA Internal Snow Maskcloud_state;mod09A1s: "
-"StateQA Internal Snow Maskinternal_cloud_algorithm;mod09A1s: StateQA "
-"Internal Snow Maskinternal_fire_algorithm;mod09A1s: StateQA Internal Snow "
-"Maskinternal_snow_mask;mod09A1s: StateQA Internal Snow Maskland_water;"
-"mod09A1s: StateQA Internal Snow Maskmod35_snow_ice;mod09A1s: StateQA "
-"Internal Snow Maskpixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow "
-"Mask"
+msgid "Name of QC type to extract:adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa_bits;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Maskbrdf_correction_performed;mod09A1s: StateQA Internal Snow Maskcirrus_detected;mod09A1s: StateQA Internal Snow Maskcloud_shadow;mod09A1s: StateQA Internal Sno
 w Maskcloud_state;mod09A1s: StateQA Internal Snow Maskinternal_cloud_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_fire_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_snow_mask;mod09A1s: StateQA Internal Snow Maskland_water;mod09A1s: StateQA Internal Snow Maskmod35_snow_ice;mod09A1s: StateQA Internal Snow Maskpixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Mask"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:142
@@ -30967,10 +29075,7 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:151
-msgid ""
-"1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;"
-"mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;"
-"mod09A1 Band 7: SWIR 3;"
+msgid "1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;mod09A1 Band 7: SWIR 3;"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:162
@@ -31019,9 +29124,8 @@
 msgstr ""
 #: ../imagery/i.zc/main.c:78
-#, fuzzy
 msgid "Zero crossing raster map"
+msgstr ""
 #: ../imagery/i.zc/main.c:86
 msgid "x-y extent of the Gaussian filter"
@@ -31032,9 +29136,8 @@
 msgstr ""
 #: ../imagery/i.zc/main.c:102
-#, fuzzy
 msgid "Number of azimuth directions categorized"
-msgstr "Numero di passi attraverso il dataset"
+msgstr ""
 #: ../imagery/i.zc/main.c:123
 msgid "Threshold less than or equal to zero not allowed"
@@ -31049,14 +29152,13 @@
 msgstr ""
 #: ../imagery/i.zc/main.c:147
-#, fuzzy, c-format
+#, c-format
 msgid "Power 2 values : %d rows %d columns"
-msgstr "%d raster%s, %d vettoriale%s\n"
+msgstr ""
 #: ../imagery/i.zc/main.c:157
-#, fuzzy
 msgid "Initializing data..."
-msgstr "Sto disegnando ..."
+msgstr ""
 #: ../imagery/i.zc/main.c:170 ../imagery/i.fft/fftmain.c:170
 msgid "Error while reading input raster map."
@@ -31075,16 +29177,14 @@
 msgstr ""
 #: ../imagery/i.rectify/main.c:101
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
 msgstr ""
 #: ../imagery/i.rectify/main.c:115
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:100
 #, fuzzy
 msgid "Output raster map(s) suffix"
+msgstr "Suffisso per la mappa/e raster di output"
 #: ../imagery/i.rectify/main.c:121
 msgid "Rectification polynom order (1-3)"
@@ -31102,16 +29202,13 @@
 #: ../imagery/i.rectify/main.c:150
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:134
-#, fuzzy
-msgid ""
-"Use current region settings in target location (def.=calculate smallest area)"
-msgstr "Imposta la region corrente alla region salvata"
+msgid "Use current region settings in target location (def.=calculate smallest area)"
+msgstr ""
 #: ../imagery/i.rectify/main.c:154
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:138
-#, fuzzy
 msgid "Rectify all raster maps in group"
+msgstr ""
 #: ../imagery/i.rectify/main.c:194
 #, c-format
@@ -31127,7 +29224,7 @@
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:184
 #, fuzzy, c-format
 msgid "Group <%s> contains no raster maps; run i.group"
+msgstr "Il gruppo <%s> non contiene mappe raster; eseguire i.group"
 #: ../imagery/i.rectify/main.c:252
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:309
@@ -31138,13 +29235,13 @@
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:316
 #, fuzzy, c-format
 msgid "Using region: N=%f S=%f, E=%f W=%f"
-msgstr "Usa N=%f S=%f E=%f O=%f"
+msgstr "Si sta usando la regione: N=%f S=%f E=%f O=%f"
 #: ../imagery/i.rectify/main.c:283
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:381
 #, fuzzy, c-format
 msgid "Input raster map <%s> does not exist in group <%s>."
-msgstr "Mappa raster <%s> non esiste nel sottogruppo <%s>"
+msgstr "La mappa raster di input <%s> non esiste nel gruppo <%s>"
 #: ../imagery/i.rectify/main.c:285
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:383
@@ -31155,22 +29252,22 @@
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:388
 #, fuzzy
 msgid "Exit!"
-msgstr "Esistente"
+msgstr "Uscita!"
 #: ../imagery/i.rectify/get_wind.c:113
 #, fuzzy, c-format
 msgid "Region N=%f S=%f E=%f W=%f"
+msgstr "Regione N=%f S=%f E=%f O=%f"
 #: ../imagery/i.rectify/get_wind.c:115
 #, fuzzy, c-format
 msgid "Resolution EW=%f NS=%f"
-msgstr "Risoluzione"
+msgstr "Risoluzionen EW=%f NS=%f"
 #: ../imagery/i.rectify/cp.c:15
 #, fuzzy, c-format
 msgid "Control Point file for group <%s@%s> - "
+msgstr "File dei punti di controllo per il gruppo <%s@%s> - "
 #: ../imagery/i.rectify/cp.c:21
 #, c-format
@@ -31184,27 +29281,27 @@
 #: ../imagery/i.rectify/cp.c:26
 #, fuzzy
 msgid " Can not generate the transformation equation."
-msgstr "Stampa matrice di correlazione"
+msgstr "Impossibile generare l'equazione di trasformazione."
 #: ../imagery/i.rectify/cp.c:29
 #, fuzzy
 msgid "Not enough memory to solve for transformation equation"
+msgstr "Memoria insufficiente per risolvere l'equazione di trasformazione"
 #: ../imagery/i.rectify/cp.c:32
 #, fuzzy
 msgid "Invalid order"
-msgstr "Coordinate non validi"
+msgstr "Ordine non valido"
 #: ../imagery/i.rectify/target.c:14
 #, fuzzy, c-format
 msgid "Target information for group <%s> missing"
-msgstr "Informazioni sul range non disponibile (esegui r.support)."
+msgstr "Mancano le informazioni sulla destinazione per il gruppo <%s>"
 #: ../imagery/i.rectify/target.c:20
 #, fuzzy, c-format
 msgid "Target location <%s> not found"
+msgstr "Location di destinazione <%s> non trovata"
 #: ../imagery/i.rectify/target.c:35
 msgid "Please run i.target for group."
@@ -31212,20 +29309,19 @@
 #: ../imagery/i.rectify/report.c:12 ../imagery/i.rectify/rectify.c:44
 #: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:46
-#, fuzzy, c-format
+#, c-format
 msgid "Rectify <%s@%s> (location <%s>)"
+msgstr ""
 #: ../imagery/i.rectify/report.c:15
-#, fuzzy, c-format
+#, c-format
 msgid "into  <%s@%s> (location <%s>) ... %s"
+msgstr ""
 #: ../imagery/i.rectify/report.c:16
 #: ../imagery/i.ortho.photo/i.photo.rectify/report.c:10
-#, fuzzy
 msgid "complete"
+msgstr ""
 #: ../imagery/i.rectify/report.c:27
 #, c-format
@@ -31245,36 +29341,33 @@
 #: ../imagery/i.ortho.photo/i.photo.rectify/exec.c:72
 #, fuzzy, c-format
 msgid "Rectified input raster map <%s> will be saved as <%s>"
+msgstr "La mappa raster di input rettificata <%s> verrà salvata come <%s>"
 #: ../imagery/i.rectify/rectify.c:48
 #: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:50
 #, fuzzy, c-format
 msgid "into  <%s@%s> (location <%s>) ..."
+msgstr "in  <%s@%s> (location <%s>) ..."
 #: ../imagery/i.rectify/rectify.c:110
 #: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:131
 #, fuzzy, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
+msgstr "Mappa raster <%s@%s>: la proiezione non corrisponde alle impostazioni correnti"
 #: ../imagery/i.rectify/rectify.c:116
 #: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:137
 #, fuzzy, c-format
 msgid "Raster map <%s@%s>: zone don't match current settings"
+msgstr "Mappa raster <%s@%s>: la zona non corrisponde alle impostazioni correnti"
 #: ../imagery/i.vpoints/main.c:96
-msgid ""
-"Set registration points for an imagery group from a vector map or keyboard "
-"entry."
+msgid "Set registration points for an imagery group from a vector map or keyboard entry."
 msgstr ""
 #: ../imagery/i.vpoints/main.c:104 ../imagery/i.points/main.c:105
-#, fuzzy
 msgid "Name of imagery group to be registered"
+msgstr ""
 #: ../imagery/i.vpoints/main.c:127 ../imagery/i.points/main.c:130
 #, c-format
@@ -31304,125 +29397,119 @@
 #: ../imagery/i.rgb.his/openfiles.c:37 ../imagery/i.rgb.his/openfiles.c:39
 #: ../imagery/i.rgb.his/openfiles.c:41 ../imagery/i.his.rgb/openfiles.c:23
 #: ../imagery/i.his.rgb/openfiles.c:25 ../imagery/i.his.rgb/openfiles.c:27
-#, fuzzy
 msgid "Unable to allocate the input row buffer"
+msgstr ""
 #: ../imagery/i.rgb.his/r2hmain.c:45 ../imagery/i.his.rgb/h2rmain.c:45
-#, fuzzy
 msgid "imagery, color transformation, RGB, HIS"
+msgstr ""
 #: ../imagery/i.rgb.his/r2hmain.c:47
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
 msgstr ""
 #: ../imagery/i.rgb.his/r2hmain.c:53
 #, fuzzy
 msgid "Name of input raster map (red)"
-msgstr "Nome della mappe raster in input"
+msgstr "Nome della mappe raster di input (rosso)"
 #: ../imagery/i.rgb.his/r2hmain.c:57
 #, fuzzy
 msgid "Name of input raster map (green)"
+msgstr "Nome della mappe raster di input (verde)"
 #: ../imagery/i.rgb.his/r2hmain.c:61
 #, fuzzy
 msgid "Name of input raster map (blue)"
+msgstr "Nome della mappe raster di input (blu)"
 #: ../imagery/i.rgb.his/r2hmain.c:65
 #, fuzzy
 msgid "Name for output raster map (hue)"
+msgstr "Nome della mappe raster di output (tonalità)"
 #: ../imagery/i.rgb.his/r2hmain.c:69
 #, fuzzy
 msgid "Name for output raster map (intensity)"
+msgstr "Nome della mappe raster di output (intensità)"
 #: ../imagery/i.rgb.his/r2hmain.c:73
 #, fuzzy
 msgid "Name for output raster map (saturation)"
-msgstr "Mostra il titolo del file raster"
+msgstr "Nome della mappe raster di output (saturazione)"
 #: ../imagery/i.rgb.his/r2hmain.c:93 ../imagery/i.his.rgb/h2rmain.c:95
 #, fuzzy, c-format
 msgid "Unable to read raster map row %ld"
-msgstr "Nome della mappa raster risultante"
+msgstr "Impossibile leggere la riga %ld della mappa raster"
 #: ../imagery/i.rgb.his/r2hmain.c:102 ../imagery/i.his.rgb/h2rmain.c:104
 #, fuzzy, c-format
 msgid "Failed writing raster map row %ld"
+msgstr "Scrittura della riga %ld della mappa raster non riuscita"
 #: ../imagery/i.his.rgb/h2rmain.c:47
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
 msgstr ""
 #: ../imagery/i.his.rgb/h2rmain.c:53
 #, fuzzy
 msgid "Name of input raster map (hue)"
+msgstr "Nome della mappe raster in input (tonalità)"
 #: ../imagery/i.his.rgb/h2rmain.c:57
 #, fuzzy
 msgid "Name of input raster map (intensity)"
+msgstr "Nome della mappe raster in input (intensità)"
 #: ../imagery/i.his.rgb/h2rmain.c:61
 #, fuzzy
 msgid "Name of input raster map (saturation)"
+msgstr "Nome della mappe raster in input (saturazione)"
 #: ../imagery/i.his.rgb/h2rmain.c:65
 #, fuzzy
 msgid "Name for output raster map (red)"
+msgstr "Nome della mappe raster di output (rosso)"
 #: ../imagery/i.his.rgb/h2rmain.c:69
 #, fuzzy
 msgid "Name for output raster map (green)"
+msgstr "Nome della mappe raster di output (verde)"
 #: ../imagery/i.his.rgb/h2rmain.c:73
 #, fuzzy
 msgid "Name for output raster map (blue)"
+msgstr "Nome della mappe raster di output (blu)"
 #: ../imagery/i.gensigset/main.c:42
 msgid "Generates statistics for i.smap from raster map."
 msgstr "Genera statistiche per i.smap per il raster."
 #: ../imagery/i.gensigset/main.c:52
-#, fuzzy, c-format
+#, c-format
 msgid "Clustering class %d (%d pixels)..."
+msgstr ""
 #: ../imagery/i.gensigset/main.c:55
 #, fuzzy, c-format
 msgid "Number of subclasses is %d"
+msgstr "Il numero di sottoclassi è %d"
 #: ../imagery/i.gensigset/subcluster.c:75
 #, fuzzy, c-format
 msgid "Not enough pixels in class %d"
-msgstr "Nome mappa raster"
+msgstr "Pixel insufficienti nella classe %d"
 #: ../imagery/i.gensigset/subcluster.c:85
-#, fuzzy, c-format
+#, c-format
 msgid "Too many subclasses for class index %d"
+msgstr ""
 #: ../imagery/i.gensigset/subcluster.c:87
 #, fuzzy, c-format
 msgid "Number of subclasses set to %d"
+msgstr "Numero di sottoclassi impostato a %d"
 #: ../imagery/i.gensigset/subcluster.c:102
 #, c-format
@@ -31444,9 +29531,8 @@
 msgstr ""
 #: ../imagery/i.gensigset/get_train.c:32 ../imagery/i.gensig/get_train.c:28
-#, fuzzy
 msgid "Finding training classes..."
-msgstr "File contenente le direttive SQL"
+msgstr ""
 #: ../imagery/i.gensigset/get_train.c:57 ../imagery/i.gensig/get_train.c:53
 #, c-format
@@ -31454,19 +29540,18 @@
 msgstr ""
 #: ../imagery/i.gensigset/get_train.c:62 ../imagery/i.gensig/get_train.c:58
-#, fuzzy
 msgid "Training map has no classes"
+msgstr ""
 #: ../imagery/i.gensigset/get_train.c:78 ../imagery/i.gensig/get_train.c:73
 #, fuzzy
 msgid "1 class found"
-msgstr "Non ho trovato nulla.\n"
+msgstr "Trovata 1 classe"
 #: ../imagery/i.gensigset/get_train.c:80 ../imagery/i.gensig/get_train.c:75
 #, fuzzy, c-format
 msgid "%d classes found"
+msgstr "Trovate %d classi"
 #: ../imagery/i.gensigset/parse.c:13 ../imagery/i.gensig/parse.c:14
 msgid "Ground truth training map"
@@ -31474,40 +29559,37 @@
 #: ../imagery/i.gensigset/parse.c:21 ../imagery/i.gensig/parse.c:22
 #: ../imagery/i.cluster/main.c:97
-#, fuzzy
 msgid "Name for output file containing result signatures"
+msgstr ""
 #: ../imagery/i.gensigset/parse.c:27
-#, fuzzy
 msgid "Maximum number of sub-signatures in any class"
+msgstr ""
 #: ../imagery/i.gensigset/parse.c:52
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal number of sub-signatures (%s)"
+msgstr ""
 #: ../imagery/i.gensigset/openfiles.c:19 ../imagery/i.gensig/openfiles.c:20
 #, fuzzy, c-format
 msgid "Subgroup <%s> in group <%s> contains no raster maps."
+msgstr "Il sottogruppo <%s> nel gruppo <%s> non contiene mappe raster."
 #: ../imagery/i.gensigset/read_data.c:19 ../imagery/i.ifft/ifftmain.c:144
 #: ../imagery/i.cluster/main.c:285
 #, fuzzy
 msgid "Reading raster maps..."
+msgstr "Lettura delle mappe raster in corso..."
 #: ../imagery/i.gensigset/write_sig.c:13 ../imagery/i.gensig/write_sig.c:15
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create signature file <%s>"
+msgstr ""
 #: ../imagery/i.gensigset/write_sig.c:16 ../imagery/i.gensig/write_sig.c:18
-#, fuzzy
 msgid "Writing signatures..."
-msgstr "Sto scrivendo gli attributi"
+msgstr ""
 #: ../imagery/i.ifft/orig_wind.c:27
 msgid "The real and imaginary original windows did not match"
@@ -31522,43 +29604,35 @@
 msgstr ""
 #: ../imagery/i.ifft/ifftmain.c:75
-#, fuzzy
 msgid "Name of input raster map (image fft, real part)"
+msgstr ""
 #: ../imagery/i.ifft/ifftmain.c:79
-#, fuzzy
 msgid "Name of input raster map (image fft, imaginary part"
+msgstr ""
 #: ../imagery/i.ifft/ifftmain.c:101
-#, fuzzy
-msgid ""
-"Unable to open real-image in the 'cell_misc' directory. Raster map probably "
-"wasn't created by i.fft"
+msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
+msgstr ""
 #: ../imagery/i.ifft/ifftmain.c:111
-#, fuzzy
-msgid ""
-"Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
-"probably wasn't created by i.fft"
+msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
+msgstr ""
 #: ../imagery/i.ifft/ifftmain.c:134
-#, fuzzy, c-format
+#, c-format
 msgid "Power 2 values: %d rows %d columns"
+msgstr ""
 #: ../imagery/i.ifft/ifftmain.c:151
 #, fuzzy
 msgid "Masking raster maps..."
-msgstr "mappa raster di base"
+msgstr "Mascheramento delle mappe raster in corso..."
 #: ../imagery/i.ifft/ifftmain.c:172 ../imagery/i.fft/fftmain.c:201
 #, fuzzy
 msgid "Rotating data..."
+msgstr "Rotaizone dei dati in corso..."
 #: ../imagery/i.ifft/ifftmain.c:211
 msgid "Starting Inverse FFT..."
@@ -31567,7 +29641,7 @@
 #: ../imagery/i.ifft/ifftmain.c:225
 #, fuzzy
 msgid "Writing data..."
+msgstr "Scrittura dei dati in corso..."
 #: ../imagery/i.find/main.c:63
 #, c-format
@@ -31583,9 +29657,8 @@
 msgstr ""
 #: ../imagery/i.cca/main.c:93 ../imagery/i.class/main.c:72
-#, fuzzy
 msgid "Name of input imagery subgroup"
+msgstr ""
 #: ../imagery/i.cca/main.c:99
 msgid "Ascii file containing spectral signatures"
@@ -31594,22 +29667,22 @@
 #: ../imagery/i.cca/main.c:102
 #, fuzzy
 msgid "Output raster map prefix name"
+msgstr "Nome del prefisso per la mappa raster di output"
 #: ../imagery/i.cca/main.c:108
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal group name <%s>"
+msgstr ""
 #: ../imagery/i.cca/main.c:111
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal subgroup name <%s>"
+msgstr ""
 #: ../imagery/i.cca/main.c:114
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal signature file name <%s>"
-msgstr "Nome file non valido [%s]."
+msgstr ""
 #: ../imagery/i.cca/main.c:122
 msgid "Unknown imagery group."
@@ -31620,9 +29693,8 @@
 msgstr ""
 #: ../imagery/i.cca/main.c:131
-#, fuzzy
 msgid "Unable to open the signature file"
+msgstr ""
 #: ../imagery/i.cca/main.c:135
 msgid "Error while reading the signatures file."
@@ -31634,9 +29706,7 @@
 #: ../imagery/i.cca/main.c:240
 #, c-format
-msgid ""
-"The output cell map <%s.%d> has values outside the 0-255 range. Min: %d Max: "
-"%d"
+msgid "The output cell map <%s.%d> has values outside the 0-255 range. Min: %d Max: %d"
 msgstr ""
 #: ../imagery/i.cca/transform.c:24
@@ -31671,9 +29741,7 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.init/main.c:46
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.init/main.c:52
@@ -31682,72 +29750,65 @@
 #: ../imagery/i.ortho.photo/i.photo.elev/main.c:68
 #: ../imagery/i.ortho.photo/i.photo.target/main.c:52
 #: ../imagery/i.ortho.photo/menu/menu.c:48
-#, fuzzy
 msgid "Name of imagery group for ortho-rectification"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.init/main.c:64
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:102
 #, fuzzy, c-format
 msgid "Group [%s] not found"
-msgstr "Gruppo <%s> non trovato"
+msgstr "Gruppo [%s] non trovato"
 #: ../imagery/i.ortho.photo/i.photo.camera/main.c:57
-msgid ""
-"Interactively select and modify the imagery group camera reference file."
+msgid "Interactively select and modify the imagery group camera reference file."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.camera/main.c:68
-#, fuzzy
 msgid "Name of camera reference file to use"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.camera/main.c:84
-#, fuzzy
 msgid "Enter a camera reference file to be used with this imagery group"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.camera/main.c:101
-#, fuzzy, c-format
+#, c-format
 msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2image/main.c:56
 msgid "Interactively mark fiducial or reseau points on an image."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2image/main.c:86
-#, fuzzy, c-format
+#, c-format
 msgid "Image Group [%s] not found"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2image/main.c:98
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:114
-#, fuzzy, c-format
+#, c-format
 msgid "No camera reference file selected for group [%s]"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2image/main.c:102
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:118
-#, fuzzy, c-format
+#, c-format
 msgid "Bad format in camera file for group [%s]"
-msgstr "Errore nella lettura del file dbmscap\n"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/angle.c:36
-#, fuzzy
 msgid "Calculating camera angle to local surface..."
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/angle.c:51
 #: ../imagery/i.ortho.photo/i.photo.rectify/exec.c:43
 #, fuzzy
 msgid "Could not open elevation raster"
+msgstr "Impossibile aprire il raster di elevazione"
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:88
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:129
@@ -31757,40 +29818,39 @@
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:181
 #, fuzzy, c-format
 msgid "Could not read REF file for group <%s>"
-msgstr "Non riesco a leggere da <%s>"
+msgstr "Impossibile leggere il file REF per il gruppo <%s>"
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:238
-#, fuzzy, c-format
+#, c-format
 msgid "No camera reference file selected for group <%s>"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:242
-#, fuzzy, c-format
+#, c-format
 msgid "Bad format in camera file for group <%s>"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:248
-#, fuzzy, c-format
+#, c-format
 msgid "Bad format in initial exposure station file for group <%s>"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:278
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:109
 #, fuzzy, c-format
 msgid "Extension <%s> is illegal"
-msgstr "[%s] è un nome illegale"
+msgstr "L'estensione <%s> non è valida"
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:281
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:290
-#, fuzzy
 msgid "The following raster map already exists in"
-msgstr "ERRORE: <%s> esiste già\n"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:282
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:291
 #, c-format
 msgid "target LOCATION %s, MAPSET %s:"
-msgstr ""
+msgstr "LOCATION di destinazione %s, MAPSET %s:"
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:285
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:294
@@ -31801,31 +29861,29 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:324
-#, fuzzy, c-format
+#, c-format
 msgid "No target elevation model selected for group <%s>"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:140
-#, fuzzy
 msgid "Error reading segment file"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:13
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Control Z Point file for group [%s] in [%s] \n"
 " \n"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:16
 #, fuzzy
 msgid "Computing equations..."
+msgstr "Calcolo delle equazioni in corso......"
 #: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:22
-#, fuzzy
 msgid "Poorly placed Control Points!\n"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:23
 #: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:28
@@ -31833,7 +29891,7 @@
 #: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:58
 #, fuzzy
 msgid "Can not generate the transformation equation.\n"
+msgstr "Impossibile generare l'equazione di trasformazione.\n"
 #: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:24
 msgid "Run OPTION 7 of i.ortho.photo again!\n"
@@ -31848,11 +29906,11 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:45
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Reference Point file for group [%s] in [%s] \n"
 " \n"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:51
 msgid "Poorly placed Reference Points!\n"
@@ -31871,26 +29929,26 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/target.c:13
-#, fuzzy, c-format
+#, c-format
 msgid "Target information for group <%s> missing.\n"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.rectify/target.c:19
 #, fuzzy, c-format
 msgid "Target location <%s> not found\n"
+msgstr "Location di destinazione <%s> non trovata\n"
 #: ../imagery/i.ortho.photo/i.photo.rectify/target.c:32
 #: ../imagery/i.ortho.photo/i.photo.elev/main.c:128
 #, fuzzy
 msgid "permission denied\n"
-msgstr "permesso negato"
+msgstr "permesso negato\n"
 #, fuzzy
 msgid "not found\n"
+msgstr "non trovato\n"
 #: ../imagery/i.ortho.photo/i.photo.rectify/report.c:21
 #, c-format
@@ -31912,19 +29970,19 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.elev/main.c:91
-#, fuzzy, c-format
+#, c-format
 msgid "Target information for group [%s] missing\n"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.elev/main.c:98
 #, fuzzy, c-format
 msgid "Target location [%s] not found\n"
+msgstr "Location di destinazione [%s] non trovata\n"
 #: ../imagery/i.ortho.photo/i.photo.elev/main.c:127
 #, fuzzy, c-format
 msgid "Mapset [%s] in target location [%s] - "
+msgstr "Mapset [%s] nella location di destinazione [%s] - "
 #: ../imagery/i.ortho.photo/i.photo.elev/main.c:131
 msgid "Please select a target for group"
@@ -31936,49 +29994,47 @@
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:62
 #: ../imagery/i.group/main.c:58
-#, fuzzy
 msgid "Name of imagery group"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:66
 msgid "Name of image to be rectified which will be initially drawn on screen"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:72
-msgid ""
-"Name of a map from target mapset which will be initially drawn on screen"
+msgid "Name of a map from target mapset which will be initially drawn on screen"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:125
-#, fuzzy, c-format
+#, c-format
 msgid "No initial camera exposure station for group [%s]"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:129
-#, fuzzy, c-format
+#, c-format
 msgid "Bad format in initial camera exposure station for group [%s]"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:143
-#, fuzzy, c-format
+#, c-format
 msgid "No photo points for group [%s]"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:145
-#, fuzzy, c-format
+#, c-format
 msgid "Poorly placed photo points for group [%s]"
+msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:167
 #, fuzzy
 msgid "Computing equations ..."
+msgstr "Calcolo delle equazioni in corso..."
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:202
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:233
 #, fuzzy, c-format
 msgid "Unable to read raster header of <%s>"
-msgstr "Non riesco ad aprire il file header di [%s]"
+msgstr "Impossibile leggere l'intestazione del raster di <%s>"
 #: ../imagery/i.ortho.photo/i.photo.2target/curses.c:22
 #: ../imagery/i.class/curses.c:22
@@ -31997,9 +30053,9 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/i.photo.target/main.c:66
-#, fuzzy, c-format
+#, c-format
 msgid "Group [%s] targeted for location [%s], mapset [%s]"
+msgstr ""
 #: ../imagery/i.ortho.photo/menu/menu.c:44
 msgid "Menu driver for the photo imagery programs."
@@ -32008,24 +30064,21 @@
 #: ../imagery/i.ortho.photo/menu/menu.c:62
 #, fuzzy, c-format
 msgid "Pre-selected group <%s> not found"
-msgstr ""
-"\n"
-" gruppo <%s> non trovato"
+msgstr "Il gruppo preselezionato <%s> non è stato trovato"
 #: ../imagery/i.ortho.photo/menu/menu.c:68
-#, fuzzy
 msgid "Enter imagery group for ortho-rectification"
+msgstr ""
 #: ../imagery/i.ortho.photo/menu/menu.c:74
 #, fuzzy, c-format
 msgid "Group [%s] contains no files"
+msgstr "Il gruppo [%s] non contiene file"
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:44
 #, fuzzy, c-format
 msgid "Could not read REF file for group [%s]"
+msgstr "Impossibile leggere il file REF per il gruppo [%s]"
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:45
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:50
@@ -32043,7 +30096,9 @@
 msgid ""
 "\n"
 "Rectify all images in the group? "
-msgstr "Nome del driver in input"
+msgstr ""
+"\n"
+"Rettificare tutte le immagini del gruppo? "
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:71
 #, c-format
@@ -32064,11 +30119,10 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:110
-#, fuzzy
 msgid ""
 "\n"
 "Choose another extension? "
+msgstr ""
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:122
 msgid ""
@@ -32077,32 +30131,32 @@
 msgstr ""
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:132
-#, fuzzy
 msgid "Enter a name for the camera angle map:"
+msgstr ""
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:141
 #, fuzzy, c-format
 msgid "Map name <%s> is illegal"
+msgstr "Il nome della mappa <%s> non è valido"
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:142
 msgid ""
 "\n"
 "Choose another name? "
 msgstr ""
+"\n"
+"Si vuol scegliere un altro nome? "
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:156
-#, fuzzy
 msgid ""
 "\n"
 "Overwrite maps in target location/mapset? "
+msgstr ""
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:224
 #, fuzzy, c-format
 msgid "Please select one of the following interpolation methods\n"
-msgstr "Per favore scegli uno dei seguenti\n"
+msgstr "Selezionare uno dei seguenti metodi di interpolazione\n"
 #: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:225
 #, c-format
@@ -32149,19 +30203,16 @@
 msgstr ""
 #: ../imagery/i.fft/fftmain.c:84
-#, fuzzy
 msgid "Name for output real part arrays stored as raster map"
-msgstr "Visualizza il raster delle altezze dopo il riempimento"
+msgstr ""
 #: ../imagery/i.fft/fftmain.c:88
-#, fuzzy
 msgid "Name for output imaginary part arrays stored as raster map"
+msgstr ""
 #: ../imagery/i.fft/fftmain.c:96
-#, fuzzy
 msgid "Range of values in output display files"
-msgstr "Tieni i valori nulli nella mappa in output"
+msgstr ""
 #: ../imagery/i.fft/fftmain.c:115
 msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
@@ -32174,36 +30225,33 @@
 #: ../imagery/i.fft/fftmain.c:166
 #, fuzzy, c-format
 msgid "Reading the raster map <%s>..."
+msgstr "Lettura della mappa raster  <%s> in corso..."
 #: ../imagery/i.fft/fftmain.c:182
-#, fuzzy
 msgid "Starting FFT..."
+msgstr ""
 #: ../imagery/i.fft/fftmain.c:225
 #, fuzzy
 msgid "Writing transformed data..."
-msgstr "Nome del raster map esistente"
+msgstr "Scrittura dei dati trasformati in corso..."
 #: ../imagery/i.fft/fftmain.c:231
-#, fuzzy
 msgid "Writing viewable versions of transformed data..."
+msgstr ""
 #: ../imagery/i.fft/fftmain.c:274
 msgid " "
 msgstr " "
 #: ../imagery/i.fft/save_fft.c:17 ../imagery/i.fft/save_fft.c:22
-#, fuzzy
 msgid "Unable to open file in the 'cell_misc' directory"
+msgstr ""
 #: ../imagery/i.ask/main.c:26
 #, c-format
 msgid "usage: %s file [prompt %%x %%y]\n"
-msgstr "uso %s file [prompt %%x %%y]\n"
+msgstr "uso: %s file [prompt %%x %%y]\n"
 #: ../imagery/i.ask/popup.c:239
 #, c-format
@@ -32221,9 +30269,8 @@
 msgstr "fullname=%s\n"
 #: ../imagery/i.gensig/main.c:39
-#, fuzzy
 msgid "imagery, classification, supervised, MLC"
+msgstr ""
 #: ../imagery/i.gensig/main.c:41
 msgid "Generates statistics for i.maxlik from raster map."
@@ -32234,24 +30281,23 @@
 msgstr ""
 #: ../imagery/i.gensig/means.c:24
-#, fuzzy
 msgid "Calculating class means..."
+msgstr ""
 #: ../imagery/i.gensig/check.c:21
 #, fuzzy, c-format
 msgid "Signature %d not invertible"
-msgstr "file raster per la Vista%d"
+msgstr "f"
 #: ../imagery/i.gensig/check.c:27
-#, fuzzy, c-format
+#, c-format
 msgid "Signature %d unable to get eigen values"
+msgstr ""
 #: ../imagery/i.gensig/check.c:33
-#, fuzzy, c-format
+#, c-format
 msgid "Signature %d not positive definite"
+msgstr ""
 #: ../imagery/i.cluster/print1.c:12
 #, c-format
@@ -32271,20 +30317,15 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:80
-#, fuzzy
 msgid "imagery, classification, signatures"
+msgstr ""
 #: ../imagery/i.cluster/main.c:82
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
 msgstr ""
 #: ../imagery/i.cluster/main.c:85
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
 msgstr ""
 #: ../imagery/i.cluster/main.c:104
@@ -32292,9 +30333,8 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:112
-#, fuzzy
 msgid "Name of file containing initial signatures"
+msgstr ""
 #: ../imagery/i.cluster/main.c:120
 msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
@@ -32309,53 +30349,51 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:144
-#, fuzzy
 msgid "Cluster separation"
-msgstr "Campo separatore in output"
+msgstr ""
 #: ../imagery/i.cluster/main.c:152
 msgid "Minimum number of pixels in a class"
 msgstr ""
 #: ../imagery/i.cluster/main.c:159
-#, fuzzy
 msgid "Name for output file containing final report"
-msgstr "Nome della mappa di input"
+msgstr ""
 #: ../imagery/i.cluster/main.c:182
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal number of initial classes (%s)"
+msgstr ""
 #: ../imagery/i.cluster/main.c:193
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal value(s) of sample intervals (%s)"
-msgstr "Valore da impostare a null non valido"
+msgstr ""
 #: ../imagery/i.cluster/main.c:207
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal value of iterations (%s>)"
+msgstr ""
 #: ../imagery/i.cluster/main.c:213
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal value of convergence (%s)"
+msgstr ""
 #: ../imagery/i.cluster/main.c:218
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal value of separation (%s)"
+msgstr ""
 #: ../imagery/i.cluster/main.c:223
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal value of min_size (%s)"
+msgstr ""
 #: ../imagery/i.cluster/main.c:234
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create report file <%s>"
-msgstr "Valore da scrivere per null"
+msgstr ""
 #: ../imagery/i.cluster/main.c:242
 #, c-format
@@ -32390,9 +30428,9 @@
 msgstr " %s\n"
 #: ../imagery/i.cluster/main.c:252
-#, fuzzy, c-format
+#, c-format
 msgid "Result signature file: %s\n"
-msgstr "Non riesco a trovare il file raster %s"
+msgstr ""
 #: ../imagery/i.cluster/main.c:254
 #, c-format
@@ -32432,7 +30470,7 @@
 #: ../imagery/i.cluster/main.c:266
 #, fuzzy, c-format
 msgid " Number of initial classes:    %d"
+msgstr " Numero di classi iniziali:    %d"
 #: ../imagery/i.cluster/main.c:268
 #, c-format
@@ -32479,13 +30517,11 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:306
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
 msgstr ""
 #: ../imagery/i.cluster/main.c:310
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)."
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
 msgstr ""
 #: ../imagery/i.cluster/main.c:323
@@ -32501,9 +30537,9 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:335
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr "impossibile aprire <%s>"
+msgstr ""
 #: ../imagery/i.cluster/main.c:340
 #, c-format
@@ -32588,37 +30624,37 @@
 #: ../imagery/i.cluster/open_files.c:21 ../imagery/i.maxlik/open.c:19
 #, fuzzy, c-format
 msgid "Subgroup <%s> in group <%s> not found"
-msgstr "Sottogruppo <%s> non trovato"
+msgstr "Sottogruppo <%s> non trovato nel gruppo <%s>"
 #: ../imagery/i.cluster/open_files.c:33
 #, c-format
 msgid "Raster map <%s> do not exists in subgroup <%s>"
+msgstr "La mappa raster <%s> non esiste nel sottogruppo <%s>"
 #: ../imagery/i.cluster/open_files.c:38
 #, fuzzy
 msgid "No raster maps found"
-msgstr "Nessun mappa raster rimossa"
+msgstr "Nessun mappa raster trovata"
 #: ../imagery/i.cluster/open_files.c:42
 #, fuzzy, c-format
 msgid "Subgroup <%s> doesn't have any raster maps"
-msgstr "Sottogruppo [%s] non ha alcun file"
+msgstr "Il sottogruppo <%s> non ha nessuna mappa raster"
 #: ../imagery/i.cluster/open_files.c:45
 #, fuzzy, c-format
 msgid "Subgroup <%s> only has 1 raster map"
+msgstr "Il sottogruppo <%s> ha solo 1 mappa raster"
 #: ../imagery/i.cluster/open_files.c:46
 #, fuzzy
 msgid "Subgroup must have at least 2 raster maps"
-msgstr "Nome del file in output"
+msgstr "Il sottogruppo deve avere almeno 2 mappe raster"
 #: ../imagery/i.cluster/open_files.c:64
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open seed signature file <%s>"
+msgstr ""
 #: ../imagery/i.cluster/open_files.c:74 ../imagery/i.maxlik/open.c:58
 #, c-format
@@ -32650,17 +30686,16 @@
 #: ../imagery/i.group/main.c:54
 msgid "Creates, edits, and lists groups and subgroups of imagery files."
-msgstr "Crea, modifica e visualizza gruppi e sottogruppi di file di immagini."
+msgstr "Crea, modifica ed elenca gruppi e sottogruppi di file di immagini."
 #: ../imagery/i.group/main.c:64
-#, fuzzy
 msgid "Name of imagery sub-group"
-msgstr "Nome della mappa raster"
+msgstr ""
 #: ../imagery/i.group/main.c:68
 #, fuzzy
 msgid "Name of raster map(s) to include in group"
-msgstr "Nome della mappa raster che contiene i risultati"
+msgstr "Nome della mappa/e raster da includere nel gruppo"
 #: ../imagery/i.group/main.c:72
 msgid "Remove selected files from specified group"
@@ -32677,28 +30712,28 @@
 #: ../imagery/i.group/main.c:102
 #, fuzzy
 msgid "No input raster map(s) specified"
-msgstr "Nessuna mappa in input specificata"
+msgstr "Nessuna mappa raster di input specificata"
 #: ../imagery/i.group/main.c:110 ../imagery/i.target/main.c:79
 #: ../imagery/i.class/main.c:103
 #, fuzzy
 msgid "Group must exist in the current mapset"
-msgstr "ERRORE: <%s> esiste già nel mapset <%s>\n"
+msgstr "Il gruppo deve esistere nel mapset corrente"
 #: ../imagery/i.group/main.c:120 ../imagery/i.group/main.c:141
 #, fuzzy
 msgid "Specified group does not exist in current mapset"
-msgstr "Il gruppo specificato non esiste"
+msgstr "Il gruppo specificato non esiste nel mapset corrente"
 #: ../imagery/i.group/main.c:124
 #, c-format
 msgid "Removing raster maps from subgroup <%s>..."
-msgstr "Rimuovi la mappa raster dal sottogruppo <%s>..."
+msgstr "Rimozione della mappa raster dal sottogruppo <%s> in corso..."
 #: ../imagery/i.group/main.c:129
 #, c-format
 msgid "Removing raster maps from group <%s>..."
-msgstr "Rimuovi la mappa raster  dal gruppo <%s>..."
+msgstr "Rimozione della mappa raster dal gruppo <%s> in corso..."
 #: ../imagery/i.group/main.c:164
 #, c-format
@@ -32721,14 +30756,14 @@
 msgstr "Aggiungi la mappa raster <%s> al gruppo"
 #: ../imagery/i.group/main.c:209
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s> exists in group. Skipping..."
+msgstr ""
 #: ../imagery/i.group/main.c:243
 #, c-format
 msgid "Adding raster map <%s> to subgroup"
-msgstr "Aggiungi la mappa raster <%s> al sottogruppo"
+msgstr "Aggiunta della mappa raster <%s> al sottogruppo"
 #: ../imagery/i.group/main.c:249
 #, c-format
@@ -32760,7 +30795,7 @@
 #: ../imagery/i.target/main.c:62
 #, fuzzy
 msgid "Name of target mapset"
+msgstr "Nome del mapset di destinazione"
 #: ../imagery/i.target/main.c:67
 msgid "Set current location and mapset as target for of imagery group"
@@ -32785,18 +30820,15 @@
 msgstr ""
 #: ../imagery/i.maxlik/main.c:63
-#, fuzzy
 msgid "imagery, classification, MLC"
+msgstr ""
 #: ../imagery/i.maxlik/main.c:65
 msgid "Classifies the cell spectral reflectances in imagery data."
 msgstr "Classifica la riflettanza spettrale nei dati dell'immagine"
 #: ../imagery/i.maxlik/main.c:67
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, i.class, or i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
 msgstr ""
 #: ../imagery/i.maxlik/main.c:80
@@ -32804,33 +30836,27 @@
 msgstr ""
 #: ../imagery/i.maxlik/main.c:85
-#, fuzzy
 msgid "Name for raster map holding classification results"
-msgstr "Nome di una mappa raster contenente una superfice di altezze"
+msgstr ""
 #: ../imagery/i.maxlik/main.c:91
-#, fuzzy
 msgid "Name for raster map holding reject threshold results"
-msgstr "Mappa raster con il nome dei risultati archiviati"
+msgstr ""
 #: ../imagery/i.maxlik/open.c:26
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:29
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
-"least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:48
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open signature file <%s>"
+msgstr ""
 #: ../imagery/i.maxlik/invert.c:28
 #, c-format
@@ -32843,26 +30869,20 @@
 msgstr ""
 #: ../imagery/i.class/main.c:55
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
 msgstr ""
 #: ../imagery/i.class/main.c:58
-msgid ""
-"The resulting signature file can be used as input for i.maxlik or as a seed "
-"signature file for i.cluster."
+msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
 msgstr ""
 #: ../imagery/i.class/main.c:77
-#, fuzzy
 msgid "File to contain result signatures"
+msgstr ""
 #: ../imagery/i.class/main.c:82
-#, fuzzy
 msgid "File containing input signatures (seed)"
+msgstr ""
 #: ../imagery/i.class/main.c:94
 msgid "You have a mask set. Unset mask and run again"
@@ -32888,9 +30908,8 @@
 msgstr ""
 #: ../imagery/i.class/main.c:232
-#, fuzzy
 msgid "Unable to read cell header for first band file"
+msgstr ""
 #: ../imagery/i.class/main.c:237
 msgid ""
@@ -32899,9 +30918,9 @@
 msgstr ""
 #: ../imagery/i.class/main.c:242
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open output signature file '%s'"
-msgstr "Nome del raster in output"
+msgstr ""
 #: ../imagery/i.class/main.c:248
 msgid ""
@@ -32910,14 +30929,14 @@
 msgstr ""
 #: ../imagery/i.class/main.c:254
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read signature file [%s]"
+msgstr ""
 #: ../imagery/i.class/main.c:257
-#, fuzzy, c-format
+#, c-format
 msgid "** Unable to read signature file [%s] **"
+msgstr ""
 #: ../imagery/i.class/main.c:264
 #, c-format
@@ -32925,9 +30944,8 @@
 msgstr ""
 #: ../imagery/i.class/band_files.c:22
-#, fuzzy
 msgid "Unable to open band files."
+msgstr ""
 #: ../imagery/i.class/signature.c:50 ../imagery/i.class/signature.c:55
 msgid "Unable to allocate space for signature statistics."
@@ -33030,2616 +31048,2573 @@
 msgstr ""
 #, fuzzy
-#~ msgid "raster, projection"
-#~ msgstr "Nome del raster"
+msgid "raster, projection"
+msgstr "Nome del raster"
 #, fuzzy
-#~ msgid "Location of input raster map"
-#~ msgstr "Nome di  2-%d mappe raster in input"
+msgid "Create an integer map"
+msgstr "Mappa raster risultante"
-#, fuzzy
-#~ msgid "Mapset of input raster map"
+msgid "Empty east coordinate specified!"
+msgstr "Sono state specificate delle coordinate ovest vuote."
-#, fuzzy
-#~ msgid "Checking location <%s>, mapset <%s>..."
-#~ msgstr "Mappa raster in input"
+msgid "Empty north coordinate specified!"
+msgstr "Sono state specificate delle coordinate nord vuote."
-#, fuzzy
-#~ msgid "Create an integer map"
-#~ msgstr "Mappa raster risultante"
+msgid "Either define sun position or location/date/time parameters."
+msgstr "Definisci la posizione del sole oppure i parametri di luogo/data/tempo"
-#~ msgid "Empty east coordinate specified!"
-#~ msgstr "Sono state specificate delle coordinate ovest vuote."
-#~ msgid "Empty north coordinate specified!"
-#~ msgstr "Sono state specificate delle coordinate nord vuote."
-#~ msgid "Either define sun position or location/date/time parameters."
-#~ msgstr ""
-#~ "Definisci la posizione del sole oppure i parametri di luogo/data/tempo"
 #, fuzzy
-#~ msgid "Calculating sun position... (using solpos (V. %s) from NREL)\n"
-#~ msgstr "Calcolo la posizione del sole (utilizzando solpos(V %S) da NREL)\n"
+msgid "Calculating sun position... (using solpos (V. %s) from NREL)\n"
+msgstr "Calcolo la posizione del sole (utilizzando solpos(V %S) da NREL)\n"
-#, fuzzy
-#~ msgid "Can't open range file for %s"
-#~ msgstr "Non riesco ad impostare user/password"
+msgid "Change current mapset."
+msgstr "Cambia il mapset corrente."
 #, fuzzy
-#~ msgid "Can't read row in input elevation map"
+msgid "Modifies the user's current mapset search path, affecting the user's access to data existing under the other GRASS mapsets in the current location."
+msgstr "Copia i file disponibili nell'attuale percorso di ricerca del mapset e della location in uso dall'utente nelle appropriate cartelle del mapset corrente"
 #, fuzzy
-#~ msgid "<%s> created"
-#~ msgstr "Location %s creata!"
+msgid "Name(s) of existing mapset(s) to add to search list"
+msgstr "Nome di una mappa raster esistente"
 #, fuzzy
-#~ msgid "Unable to open rules file <%s>"
-#~ msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgid "Name(s) of existing mapset(s) to remove from search list"
-#~ msgid "Change current mapset."
-#~ msgstr "Cambia il mapset corrente."
 #, fuzzy
-#~ msgid ""
-#~ "Modifies the user's current mapset search path, affecting the user's "
-#~ "access to data existing under the other GRASS mapsets in the current "
-#~ "location."
-#~ msgstr ""
-#~ "Copia i file disponibili nell'attuale percorso di ricerca del mapset e "
-#~ "della location in uso dall'utente nelle appropriate cartelle del mapset "
-#~ "corrente"
+msgid "Unhandled vector feature type <%s>"
+msgstr "Nome della mappa raster risultante"
 #, fuzzy
-#~ msgid "Name(s) of existing mapset(s) to add to search list"
-#~ msgstr "Nome di una mappa raster esistente"
+msgid "No areas found, skipping type=area"
+msgstr "Utilizza la regione corrente"
 #, fuzzy
-#~ msgid "Name(s) of existing mapset(s) to remove from search list"
+msgid "No points found, skipping%s%s"
 #, fuzzy
-#~ msgid ""
-#~ "Displays and overlays raster map layers in the active display frame on "
-#~ "the graphics monitor."
-#~ msgstr ""
-#~ "Seleziona il tipo di carattere con cui il testo deve essere rappresentato "
-#~ "nel monitor grafico dell'utente."
+msgid "No lines found, skipping%s%s"
-#, fuzzy
-#~ msgid "Raster map to be displayed"
-#~ msgstr "Mappa(e) raster da leggere"
+msgid "Total area: %e (%d areas)"
+msgstr "Area totale: %e (%d areas)"
-#, fuzzy
-#~ msgid "Displays vector data in the active frame on the graphics monitor."
-#~ msgstr ""
+msgid "Area without category: %e (%d areas)"
+msgstr "Aree senza categoria: %e (%d areas)"
-#, fuzzy
-#~ msgid "Unhandled vector feature type <%s>"
-#~ msgstr "Nome della mappa raster risultante"
+msgid "Converts a binary GRASS vector map into a GRASS raster map ."
+msgstr "Converte vettore binario GRASS in raster GRASS"
-#, fuzzy
-#~ msgid "No areas found, skipping type=area"
-#~ msgstr "Utilizza la regione corrente"
+msgid "Name of column for attr parameter (data type must be numeric)"
+msgstr "Nome della colonna per il parametro attr (tipo di dato dovrà essere numerico)"
-#, fuzzy
-#~ msgid "No points found, skipping%s%s"
+msgid "Duplicate area centroids"
+msgstr "Centroidi dell'area duplicati"
 #, fuzzy
-#~ msgid "No lines found, skipping%s%s"
+msgid "installation"
+msgstr "visualizzazione"
-#~ msgid "Total area: %e (%d areas)"
-#~ msgstr "Area totale: %e (%d areas)"
-#~ msgid "Area without category: %e (%d areas)"
-#~ msgstr "Aree senza categoria: %e (%d areas)"
 #, fuzzy
-#~ msgid "vector, projection"
+msgid "GDAL datatype: %s, range: %f - %f"
+msgstr "ERRORE: <%s> esiste già\n"
-#~ msgid "Allows projection conversion of vector maps."
-#~ msgstr "Permette la conversione di proiezione per vettoriali"
-#~ msgid "Converts a binary GRASS vector map into a GRASS raster map ."
-#~ msgstr "Converte vettore binario GRASS in raster GRASS"
-#~ msgid "Name of column for attr parameter (data type must be numeric)"
-#~ msgstr ""
-#~ "Nome della colonna per il parametro attr (tipo di dato dovrà essere "
-#~ "numerico)"
-#~ msgid "Raster value"
-#~ msgstr "Valore del raster"
-#~ msgid "Duplicate area centroids"
-#~ msgstr "Centroidi dell'area duplicati"
 #, fuzzy
-#~ msgid "Vector output map"
-#~ msgstr "Mappa vettoriale in uscita"
+msgid "The hight of the river bed in [m]"
+msgstr "Nome del driver in output"
 #, fuzzy
-#~ msgid "Error while writing to temp file"
-#~ msgstr "Non riesco a trovare il file raster %s"
+msgid "The hight of the drainage bed in [m]"
 #, fuzzy
-#~ msgid "Error writing row %d"
+msgid "Pass %d:"
+msgstr "Password"
 #, fuzzy
-#~ msgid "Cannot generate the transformation equation."
-#~ msgstr "Stampa matrice di correlazione"
+msgid "The '-q' flag is superseded and will be removed "
+msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
-#~ msgid "Unable to write temp file: %s"
-#~ msgstr "Impossibile scrivere il file temp: %s"
-#~ msgid "Unable to open map %s"
-#~ msgstr "Impossibile aprire la mappa %s"
-#~ msgid "Unable to write row %d"
-#~ msgstr "Impossibile scrivere la riga %d"
 #, fuzzy
-#~ msgid "%s@%s: projection doesn't match current settings"
-#~ msgstr "Sto uscendo. Senza cambiare le impostazioni correnti"
+msgid "Unable to create table <%s_edge_Interpolation>"
+msgstr "Impossibile aprire il database <%s>"
 #, fuzzy
-#~ msgid "%s@%s: zone doesn't match current settings"
+msgid "Rescale output raster map [0,255]"
-#, fuzzy
-#~ msgid "installation"
-#~ msgstr "visualizzazione"
+msgid "Use db.select for SELECT SQL statements"
+msgstr "Usa db.select per i comandi SELECT SQL"
 #, fuzzy
-#~ msgid "GDAL datatype: %s, range: %f - %f"
-#~ msgstr "ERRORE: <%s> esiste già\n"
+msgid "Can't find %d,%d:%f"
+msgstr "Non riesco a mostrare i database"
-#, fuzzy
-#~ msgid "The hight of the river bed in [m]"
-#~ msgstr "Nome del driver in output"
+msgid "Nothing to show"
+msgstr "Niente da mostrare"
-#, fuzzy
-#~ msgid "The hight of the drainage bed in [m]"
+msgid "Starting points raster map"
+msgstr "Punti di partenza del file raster"
 #, fuzzy
-#~ msgid "Pass %d:"
-#~ msgstr "Password"
+msgid "Reading %s"
 #, fuzzy
-#~ msgid "The '-q' flag is superseded and will be removed "
-#~ msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
+msgid "Writing %s"
+msgstr "Sto disegnando ..."
-#, fuzzy
-#~ msgid "Unable to create table <%s_edge_Interpolation>"
-#~ msgstr "Impossibile aprire il database <%s>"
+msgid "Please choose only one print style"
+msgstr "Per favore scegli un solo stile di output"
 #, fuzzy
-#~ msgid "Rescale output raster map [0,255]"
+msgid "Output more comments (default=quiet)"
+msgstr "Mostra il titolo del file raster"
-#~ msgid "Use db.select for SELECT SQL statements"
-#~ msgstr "Usa db.select per i comandi SELECT SQL"
 #, fuzzy
-#~ msgid "Can't find %d,%d:%f"
-#~ msgstr "Non riesco a mostrare i database"
+msgid "Vector map to display thematically"
+msgstr "Mappa(e) raster da leggere"
-#~ msgid "Nothing to show"
-#~ msgstr "Niente da mostrare"
-#~ msgid "Starting points raster map"
-#~ msgstr "Punti di partenza del file raster"
 #, fuzzy
-#~ msgid "Reading %s"
+msgid "Vector map type"
+msgstr "File di input"
 #, fuzzy
-#~ msgid "Writing %s"
-#~ msgstr "Sto disegnando ..."
+msgid "Layer to use for thematic display"
+msgstr "Nome della mappa raster da utilizzare per <%s>"
-#~ msgid "Please choose only one print style"
-#~ msgstr "Per favore scegli un solo stile di output"
 #, fuzzy
-#~ msgid "Output more comments (default=quiet)"
-#~ msgstr "Mostra il titolo del file raster"
+msgid "Data type"
+msgstr "Tipo di grafico"
 #, fuzzy
-#~ msgid "Vector map to display thematically"
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "Mapset del quale fornire la lista (default: percorso corrente)"
 #, fuzzy
-#~ msgid "Vector map type"
-#~ msgstr "File di input"
+msgid "Output separator (default: newline)"
+msgstr "Carattere di separatore in output (predefinito: tab)"
 #, fuzzy
-#~ msgid "Layer to use for thematic display"
-#~ msgstr "Nome della mappa raster da utilizzare per <%s>"
+msgid "Raster to remove"
+msgstr "impossibile aprire <%s>"
 #, fuzzy
-#~ msgid "Data type"
-#~ msgstr "Tipo di grafico"
+msgid "3d raster to remove"
 #, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "Mapset del quale fornire la lista (default: percorso corrente)"
+msgid "Vector to remove"
 #, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "Carattere di separatore in output (predefinito: tab)"
+msgid "Region to remove"
 #, fuzzy
-#~ msgid "Raster to remove"
-#~ msgstr "impossibile aprire <%s>"
+msgid "Label to remove"
 #, fuzzy
-#~ msgid "3d raster to remove"
+msgid "3dview to remove"
 #, fuzzy
-#~ msgid "Vector to remove"
+msgid "Group to remove"
-#, fuzzy
-#~ msgid "Region to remove"
+msgid "sensor: LANDSAT"
+msgstr "sensore: LANDSAT"
-#, fuzzy
-#~ msgid "Label to remove"
+msgid "sensor: QuickBird"
+msgstr "sensore: QuickBird"
-#, fuzzy
-#~ msgid "3dview to remove"
+msgid "sensor: SPOT"
+msgstr "sensore: SPOT"
 #, fuzzy
-#~ msgid "Group to remove"
+msgid "raster input maps"
+msgstr "Mappa raster in input"
-#~ msgid "sensor: LANDSAT"
-#~ msgstr "sensore: LANDSAT"
-#~ msgid "sensor: QuickBird"
-#~ msgstr "sensore: QuickBird"
-#~ msgid "sensor: SPOT"
-#~ msgstr "sensore: SPOT"
 #, fuzzy
-#~ msgid "raster input maps"
+msgid "reclass raster output map"
+msgstr "Nome della mappa di output"
 #, fuzzy
-#~ msgid "reclass raster output map"
-#~ msgstr "Nome della mappa di output"
+msgid "Output field seperator"
+msgstr "Campo separatore in output"
-#, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "Campo separatore in output"
+msgid "Steps=%d"
+msgstr "Scala=%d"
-#~ msgid "Steps=%d"
-#~ msgstr "Scala=%d"
 #, fuzzy
-#~ msgid "ERROR: Problem opening output file."
+msgid "ERROR: Problem opening output file."
 #, fuzzy
-#~ msgid "Creates explicitly the NULL-value bitmap file."
-#~ msgstr "Crea separatamente un file bitmap 3D di valori nulli"
+msgid "Creates explicitly the NULL-value bitmap file."
+msgstr "Crea separatamente un file bitmap 3D di valori nulli"
 #, fuzzy
-#~ msgid "Name of the sampling locations vector points map"
-#~ msgstr "Nome della mappa di input"
+msgid "Name of the sampling locations vector points map"
+msgstr "Nome della mappa di input"
 #, fuzzy
-#~ msgid "Density of output walkers"
-#~ msgstr "Nome del file in output"
+msgid "Density of output walkers"
+msgstr "Nome del file in output"
 #, fuzzy
-#~ msgid "File [%s] not found"
-#~ msgstr "raster <%s> non trovato"
+msgid "File [%s] not found"
+msgstr "raster <%s> non trovato"
 #, fuzzy
-#~ msgid "Unable to open file [%s]"
+msgid "Unable to open file [%s]"
+msgstr "Non riesco ad aprire il cellfile per [%s]"
 #, fuzzy
-#~ msgid "Reading sites map (%s) ..."
+msgid "Reading sites map (%s) ..."
 #, fuzzy
-#~ msgid "Name of the output walkers vector points map"
+msgid "Name of the output walkers vector points map"
 #, fuzzy
-#~ msgid "You are not outputting any raster or vector points maps"
-#~ msgstr "Nome di un file vettoriale in output"
+msgid "You are not outputting any raster or vector points maps"
+msgstr "Nome di un file vettoriale in output"
 #, fuzzy
-#~ msgid "%s=%s - illegal value"
-#~ msgstr "Nome del raster map in output"
+msgid "%s=%s - illegal value"
+msgstr "Nome del raster map in output"
 #, fuzzy
-#~ msgid "Unable to read current region parameters"
+msgid "Unable to read current region parameters"
 #, fuzzy
-#~ msgid "Cannot open cover raster map <%s>"
-#~ msgstr "Non riesco ad aprire il cellfile [%s]"
+msgid "Cannot open cover raster map <%s>"
+msgstr "Non riesco ad aprire il cellfile [%s]"
 #, fuzzy
-#~ msgid "Cannot open database <%s> by driver <%s>"
-#~ msgstr "Non riesco ad eseguire il driver '%s'"
+msgid "Cannot open database <%s> by driver <%s>"
+msgstr "Non riesco ad eseguire il driver '%s'"
 #, fuzzy
-#~ msgid "No map specified"
-#~ msgstr "Nessuna mappa in input specificata"
+msgid "No map specified"
+msgstr "Nessuna mappa in input specificata"
 #, fuzzy
-#~ msgid "%s - unable to remove color table"
-#~ msgstr "Valore da scrivere per null"
+msgid "%s - unable to remove color table"
+msgstr "Valore da scrivere per null"
 #, fuzzy
-#~ msgid "%s - color table not found"
+msgid "%s - color table not found"
 #, fuzzy
-#~ msgid "Unable to properly read input raster map"
+msgid "Unable to properly read input raster map"
+msgstr "Non riesco a trovare il file raster %s"
 #, fuzzy
-#~ msgid "Unable to properly write output raster map"
-#~ msgstr "Nome del raster in output"
+msgid "Unable to properly write output raster map"
+msgstr "Nome del raster in output"
 #, fuzzy
-#~ msgid "Unable to read f_range for map %s"
+msgid "Unable to read f_range for map %s"
-#~ msgid "Name of raster map layer to be used for <%s>"
+msgid "Name of raster map layer to be used for <%s>"
 #, fuzzy
-#~ msgid "%d points converted to centroids"
-#~ msgstr "Punti di blocco della mappa vettoriale"
+msgid "%d points converted to centroids"
+msgstr "Punti di blocco della mappa vettoriale"
 #, fuzzy
-#~ msgid "%d centroids converted to points"
+msgid "%d centroids converted to points"
 #, fuzzy
-#~ msgid "%d lines converted to boundaries"
-#~ msgstr "%d linee / confini rimossi"
+msgid "%d lines converted to boundaries"
+msgstr "%d linee / confini rimossi"
 #, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region.\n"
+msgid "CrossCorrelation: %d points read in region.\n"
 #, fuzzy
-#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
-#~ msgstr "Non riesco ad aprire il database %s col driver %s"
+msgid "CrossCorrelation: Cannot open database %s by driver %s"
+msgstr "Non riesco ad aprire il database %s col driver %s"
 #, fuzzy
-#~ msgid "CrossCorrelation: Column type not supported"
-#~ msgstr "Tipo di colonna non supportata"
+msgid "CrossCorrelation: Column type not supported"
+msgstr "Tipo di colonna non supportata"
 #, fuzzy
-#~ msgid "CrossCorrelation: Cannot select data from table"
-#~ msgstr "Non riesco a selezionare dati dalla tabella"
+msgid "CrossCorrelation: Cannot select data from table"
+msgstr "Non riesco a selezionare dati dalla tabella"
 #, fuzzy
-#~ msgid "CrossCorrelation: No record for point (cat = %d)"
-#~ msgstr "Nessun record per la cat = %d"
+msgid "CrossCorrelation: No record for point (cat = %d)"
+msgstr "Nessun record per la cat = %d"
 #, fuzzy
-#~ msgid "vector, attribute table"
-#~ msgstr "Non riesco a descrivere la tabella"
+msgid "vector, attribute table"
+msgstr "Non riesco a descrivere la tabella"
 #, fuzzy
-#~ msgid "Select type"
+msgid "Select type"
 #, fuzzy
-#~ msgid "Cannot select records from database"
+msgid "Cannot select records from database"
 #, fuzzy
-#~ msgid "Cannot fetch data"
+msgid "Cannot fetch data"
-#~ msgid "Cannot open database %s by driver %s"
+msgid "Cannot open database %s by driver %s"
 #, fuzzy
-#~ msgid "Cannot open database %s"
-#~ msgstr "Non posso scrivere i collegamenti del database"
+msgid "Cannot open database %s"
+msgstr "Non posso scrivere i collegamenti del database"
 #, fuzzy
-#~ msgid "Hilight color for text"
-#~ msgstr "Colore di evidenziazione del testo"
+msgid "Hilight color for text"
+msgstr "Colore di evidenziazione del testo"
-#~ msgid "Removed vertices"
-#~ msgstr "Vertici rimossi"
+msgid "Removed vertices"
+msgstr "Vertici rimossi"
-#~ msgid "Line: %d\n"
-#~ msgstr "Linea: %d\n"
+msgid "Line: %d\n"
+msgstr "Linea: %d\n"
-#~ msgid "Reading data from the map..."
-#~ msgstr "Sto leggendo dati dalla mappa"
+msgid "Reading data from the map..."
+msgstr "Sto leggendo dati dalla mappa"
 #, fuzzy
-#~ msgid "Query layer (used by 'query' option)"
+msgid "Query layer (used by 'query' option)"
-#~ msgid "%d categories read from map"
-#~ msgstr "%d categorie caricate dalla mappa"
+msgid "%d categories read from map"
+msgstr "%d categorie caricate dalla mappa"
-#~ msgid "Writing attributes ..."
-#~ msgstr "Sto scrivendo gli attributi ..."
+msgid "Writing attributes ..."
+msgstr "Sto scrivendo gli attributi ..."
 #, fuzzy
-#~ msgid "Current region does not include the entire input vector map <%s>"
+msgid "Current region does not include the entire input vector map <%s>"
 #, fuzzy
-#~ msgid "Output inverse raster map after IFFT"
+msgid "Output inverse raster map after IFFT"
-#~ msgid "Reading the raster maps..."
-#~ msgstr "Leggendo la mappa raster"
+msgid "Reading the raster maps..."
+msgstr "Leggendo la mappa raster"
-#~ msgid "Unable to open output file."
-#~ msgstr "Impossibile aprire il file di output"
+msgid "Unable to open output file."
+msgstr "Impossibile aprire il file di output"
 #, fuzzy
-#~ msgid "Hue map name"
+msgid "Hue map name"
 #, fuzzy
-#~ msgid "Intensity map name"
-#~ msgstr "Nome mappa raster"
+msgid "Intensity map name"
+msgstr "Nome mappa raster"
 #, fuzzy
-#~ msgid "Saturation map name"
+msgid "Saturation map name"
 #, fuzzy
-#~ msgid "Output map representing the red"
-#~ msgstr "strighe che rappresentano le celle prive di valori"
+msgid "Output map representing the red"
+msgstr "strighe che rappresentano le celle prive di valori"
 #, fuzzy
-#~ msgid "Output map representing the green"
+msgid "Output map representing the green"
 #, fuzzy
-#~ msgid "Output map representing the blue"
+msgid "Output map representing the blue"
-#~ msgid "Cannot read row from raster map"
-#~ msgstr "Non posso leggere la riga dalla mappa raster"
+msgid "Cannot read row from raster map"
+msgstr "Non posso leggere la riga dalla mappa raster"
-#~ msgid "Cannot write row to raster map"
-#~ msgstr "Non posso scrivere la riga alla mappa raster"
+msgid "Cannot write row to raster map"
+msgstr "Non posso scrivere la riga alla mappa raster"
 #, fuzzy
-#~ msgid "Red input raster map"
-#~ msgstr "Nome del driver in input"
+msgid "Red input raster map"
+msgstr "Nome del driver in input"
 #, fuzzy
-#~ msgid "Green input raster map"
+msgid "Green input raster map"
 #, fuzzy
-#~ msgid "Blue input raster map"
+msgid "Blue input raster map"
 #, fuzzy
-#~ msgid "Output intensity raster map"
-#~ msgstr "Nome della tabella in output"
+msgid "Output intensity raster map"
+msgstr "Nome della tabella in output"
 #, fuzzy
-#~ msgid "Output saturation raster map"
-#~ msgstr "Visualizza il raster della direzione"
+msgid "Output saturation raster map"
+msgstr "Visualizza il raster della direzione"
-#~ msgid "Writing [%s] ..."
-#~ msgstr "Sto scrivendo [%s] ..."
+msgid "Writing [%s] ..."
+msgstr "Sto scrivendo [%s] ..."
 #, fuzzy
-#~ msgid "Name of imagery signaturefile"
-#~ msgstr "Nome della mappa raster"
+msgid "Name of imagery signaturefile"
+msgstr "Nome della mappa raster"
-#~ msgid "Subgroup [%s] not found."
-#~ msgstr "Sottogruppo <%s> non trovato"
+msgid "Subgroup [%s] not found."
+msgstr "Sottogruppo <%s> non trovato"
 #, fuzzy
-#~ msgid "Cannot write color table of raster map <%s>"
+msgid "Cannot write color table of raster map <%s>"
-#~ msgid "Imagery group"
-#~ msgstr "Gruppo di immagini"
+msgid "Imagery group"
+msgstr "Gruppo di immagini"
 #, fuzzy
-#~ msgid "Subgroup containing image files"
+msgid "Subgroup containing image files"
 #, fuzzy
-#~ msgid "Resultant signature file"
-#~ msgstr "mappa raster con il risultato"
+msgid "Resultant signature file"
+msgstr "mappa raster con il risultato"
 #, fuzzy
-#~ msgid "Input raster map being fft"
+msgid "Input raster map being fft"
 #, fuzzy
-#~ msgid "Illegal file name for real part: %s"
+msgid "Illegal file name for real part: %s"
 #, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
+msgid "Illegal file name for imaginary part: %s"
 #, fuzzy
-#~ msgid "Reading the raster map..."
+msgid "Reading the raster map..."
-#~ msgid "subgroup <%s> not found"
-#~ msgstr "sottogruppo <%s> non trovato"
+msgid "subgroup <%s> not found"
+msgstr "sottogruppo <%s> non trovato"
 #, fuzzy
-#~ msgid "Unable to proceed"
+msgid "Unable to proceed"
 #, fuzzy
-#~ msgid "Unable to read head of %s"
-#~ msgstr "Non riesco ad aprire il file header di [%s]"
+msgid "Unable to read head of %s"
+msgstr "Non riesco ad aprire il file header di [%s]"
-#~ msgid "group=[%s] - not found."
-#~ msgstr "gruppo=[%s] - non trovato"
+msgid "group=[%s] - not found."
+msgstr "gruppo=[%s] - non trovato"
 #, fuzzy
-#~ msgid "subgroup=[%s] (of group [%s]) - not found."
+msgid "subgroup=[%s] (of group [%s]) - not found."
 #, fuzzy
-#~ msgid "Can't read signature file [%s]."
+msgid "Can't read signature file [%s]."
 #, fuzzy
-#~ msgid "Unable to create reject layer [%s]."
+msgid "Unable to create reject layer [%s]."
 #, fuzzy
-#~ msgid "Signatures to use for classification"
-#~ msgstr "Nome del file con il risultato della classificazione"
+msgid "Signatures to use for classification"
+msgstr "Nome del file con il risultato della classificazione"
 #, fuzzy
-#~ msgid "Raster map to hold classification results"
+msgid "Raster map to hold classification results"
 #, fuzzy
-#~ msgid "Cannot select attributes: %s"
+msgid "Cannot select attributes: %s"
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Condizione opzionale where (senza la parola chiave WHERE), e.s.:\n"
+msgid ""
+"Optional where condition (without WHERE key word), e.g.:\n"
+"\t\tobec = 'Liptakov'"
+msgstr ""
+"Condizione opzionale where (senza la parola chiave WHERE), e.s.:\n"
 #, fuzzy
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr "Usa i numeri delle bande invece che i nomi dei colori"
+msgid "Keep band numbers instead of using band color names."
+msgstr "Usa i numeri delle bande invece che i nomi dei colori"
 #, fuzzy
-#~ msgid "Saving new map"
+msgid "Saving new map"
 #, fuzzy
-#~ msgid "Output raster map with lake"
+msgid "Output raster map with lake"
 #, fuzzy
-#~ msgid "Cannot write lake raster map <%s>!"
+msgid "Cannot write lake raster map <%s>!"
 #, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
+msgid "Terrain raster map <%s> not found!"
 #, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
+msgid "Cannot open terrain raster map <%s@%s>!"
 #, fuzzy
-#~ msgid "Seed map <%s> not found!"
+msgid "Seed map <%s> not found!"
 #, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
+msgid "Cannot open seed map <%s@%s>!"
 #, fuzzy
-#~ msgid "Failure to allocate memory for row pointers"
+msgid "Failure to allocate memory for row pointers"
 #, fuzzy
-#~ msgid "Loading maps: "
+msgid "Loading maps: "
 #, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
+msgid "Error reading terrain raster map. Probably broken file."
 #, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
+msgid "Error reading seed raster map. Probably broken file."
 #, fuzzy
-#~ msgid "Cannot write lake raster map <%s@%s>!"
+msgid "Cannot write lake raster map <%s@%s>!"
 #, fuzzy
-#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "Errore nella lettura del file dbmscap\n"
+msgid "Error writing color file for <%s@%s>!"
+msgstr "Errore nella lettura del file dbmscap\n"
 #, fuzzy
-#~ msgid "All done."
-#~ msgstr "Fatto.\n"
+msgid "All done."
+msgstr "Fatto.\n"
 #, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
+msgid "Name of the vector points map with x,y locations"
 #, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "Numero di passi attraverso il dataset"
+msgid "Number of time iterations (sec.)"
+msgstr "Numero di passi attraverso il dataset"
 #, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "locazione del database"
+msgid "Multiscale simulation"
+msgstr "locazione del database"
 #, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "Nome del file raster in input"
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
+msgstr "Nome del file raster in input"
 #, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
 #, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgid "Raster input maps(s)"
-#~ msgstr "Mappe raster in input"
+msgid "Raster input maps(s)"
+msgstr "Mappe raster in input"
 #, fuzzy
-#~ msgid "Output file name"
-#~ msgstr "Nome del file di output"
+msgid "Output file name"
+msgstr "Nome del file di output"
 #, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
 #, fuzzy
-#~ msgid "Error reading '%s' map"
+msgid "Error reading '%s' map"
 #, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "Unità della distanza"
+msgid "Threshold distance"
+msgstr "Unità della distanza"
 #, fuzzy
-#~ msgid "Cannot execute: %s"
+msgid "Cannot execute: %s"
+msgstr "Non riesco ad impostare user/password"
 #, fuzzy
-#~ msgid "Cannot link table: %s"
+msgid "Cannot link table: %s"
 #, fuzzy
-#~ msgid "DXF input file"
+msgid "DXF input file"
 #, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
+msgid "Cannot open dxf file <%s>"
 #, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
+msgid "Cannot open new vector map <%s>"
 #, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
+msgid "Conversion of <%s> to vector map:"
 #, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "file raster per la Vista%d"
+msgid "Raster file(s) for Elevation"
+msgstr "file raster per la Vista%d"
 #, fuzzy
-#~ msgid "Raster file(s) for Color"
+msgid "Raster file(s) for Color"
 #, fuzzy
-#~ msgid "Raster map to zoom into"
+msgid "Raster map to zoom into"
-#~ msgid "Save the current region to region definition file"
-#~ msgstr ""
-#~ "Salva le impostazione della region corrente in un file di definizione "
-#~ "della region"
+msgid "Save the current region to region definition file"
+msgstr "Salva le impostazione della region corrente in un file di definizione della region"
 #, fuzzy
-#~ msgid "Could not open input file <%s>."
+msgid "Could not open input file <%s>."
 #, fuzzy
-#~ msgid "Unable to open file: <%s>"
+msgid "Unable to open file: <%s>"
 #, fuzzy
-#~ msgid "Name of the resultant map"
-#~ msgstr "Nome della mappa con il risultato"
+msgid "Name of the resultant map"
+msgstr "Nome della mappa con il risultato"
 #, fuzzy
-#~ msgid "Raster map not found."
+msgid "Raster map not found."
 #, fuzzy
-#~ msgid "Raster file [%s] not found"
+msgid "Raster file [%s] not found"
 #, fuzzy
-#~ msgid "It was not possible writing in <%s>."
+msgid "It was not possible writing in <%s>."
 #, fuzzy
-#~ msgid "Cannot create table: '%s'"
+msgid "Cannot create table: '%s'"
 #, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "Non riesco a leggere da <%s>"
+msgid "Unable to get category list <%s>, editing terminated"
+msgstr "Non riesco a leggere da <%s>"
 #, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
+msgid "Unable to delete layer/category [%d/%d] line %d"
 #, fuzzy
-#~ msgid "Unable to write line %d"
+msgid "Unable to write line %d"
 #, fuzzy
-#~ msgid "Unable to delete line %d"
+msgid "Unable to delete line %d"
 #, fuzzy
-#~ msgid "Unknown query tool '%s'"
+msgid "Unknown query tool '%s'"
 #, fuzzy
-#~ msgid "No layer database connection"
+msgid "No layer database connection"
 #, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "Estrae dati dal database."
+msgid "%d categories loaded from the database"
+msgstr "Estrae dati dal database."
 #, fuzzy
-#~ msgid "Cannot create layer"
+msgid "Cannot create layer"
 #, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "Impossibile trovare il vettoriale [%s]"
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgstr "Impossibile trovare il vettoriale [%s]"
 #, fuzzy
-#~ msgid "Column type [%d] not supported"
+msgid "Column type [%d] not supported"
 #, fuzzy
-#~ msgid "Cannot read map header for <%s>"
+msgid "Cannot read map header for <%s>"
 #, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#~ msgstr "Impossibile salvare la region <%s>"
+msgid "Cannot read category file for <%s>"
+msgstr "Impossibile salvare la region <%s>"
-#~ msgid "Print;Shell Script"
-#~ msgstr "Stampa; script per la shell"
+msgid "Print;Shell Script"
+msgstr "Stampa; script per la shell"
 #, fuzzy
-#~ msgid "%s: <%s> raster map not found"
+msgid "%s: <%s> raster map not found"
 #, fuzzy
-#~ msgid "%s: <%s> raster map exists already"
+msgid "%s: <%s> raster map exists already"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
+msgid "Cannot read category file of raster map <%s>"
 #, fuzzy
-#~ msgid "%s - map not found"
+msgid "%s - map not found"
 #, fuzzy
-#~ msgid "%s not found"
+msgid "%s not found"
 #, fuzzy
-#~ msgid "Could not access %s layer"
+msgid "Could not access %s layer"
 #, fuzzy
-#~ msgid "Vector map %s - not found"
+msgid "Vector map %s - not found"
-#~ msgid "Raster map containing elevation data"
-#~ msgstr "Mappa raster che contiene i valori delle altezze"
+msgid "Raster map containing elevation data"
+msgstr "Mappa raster che contiene i valori delle altezze"
-#~ msgid "Raster map name for storing results"
-#~ msgstr "Mappa raster con il nome dei risultati archiviati"
+msgid "Raster map name for storing results"
+msgstr "Mappa raster con il nome dei risultati archiviati"
-#~ msgid "Height of the viewing location"
-#~ msgstr "Altezza della locazione visualizzata"
+msgid "Height of the viewing location"
+msgstr "Altezza della locazione visualizzata"
 #, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
+msgid "%s: <%s> cellfile not found"
 #, fuzzy
-#~ msgid "Cell file [%s] not found\n"
+msgid "Cell file [%s] not found\n"
 #, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
+msgid "rgb cell map [%s] not found\n"
 #, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
+msgid "vector cell map [%s] not found\n"
 #, fuzzy
-#~ msgid "%s - %s not found"
+msgid "%s - %s not found"
 #, fuzzy
-#~ msgid "Unable to read category file for raster map <%s>"
+msgid "Unable to read category file for raster map <%s>"
 #, fuzzy
-#~ msgid "Creating support files"
+msgid "Creating support files"
 #, fuzzy
-#~ msgid "%s file [%s] not found!"
+msgid "%s file [%s] not found!"
 #, fuzzy
-#~ msgid "%s: %s - map not found"
+msgid "%s: %s - map not found"
 #, fuzzy
-#~ msgid "%s: unable to open %s"
+msgid "%s: unable to open %s"
 #, fuzzy
-#~ msgid "%s - not found"
+msgid "%s - not found"
 #, fuzzy
-#~ msgid "Cannot read %s"
+msgid "Cannot read %s"
 #, fuzzy
-#~ msgid "Reading %s ... "
+msgid "Reading %s ... "
 #, fuzzy
-#~ msgid "[%s] map not found."
+msgid "[%s] map not found."
 #, fuzzy
-#~ msgid "[%s] map not found"
+msgid "[%s] map not found"
 #, fuzzy
-#~ msgid "Cannot describe table <%s>"
+msgid "Cannot describe table <%s>"
 #, fuzzy
-#~ msgid "Cannot insert values: %s"
+msgid "Cannot insert values: %s"
 #, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr "%s ha dato un numero non valido di sites [%d]"
+msgid "%s given an illegal number of points [%d]"
+msgstr "%s ha dato un numero non valido di sites [%d]"
 #, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
+msgid "Unable to open database %s by driver %s"
 #, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr ""
-#~ "Nessuna impostazione definita per il database. Fallo usando db.connect"
+msgid "No DB connection settings defined. Set with db.connect"
+msgstr "Nessuna impostazione definita per il database. Fallo usando db.connect"
-#~ msgid "Could not find input %s"
-#~ msgstr "Non riesco a trovare l'input %s"
+msgid "Could not find input %s"
+msgstr "Non riesco a trovare l'input %s"
-#~ msgid "Could not open input"
-#~ msgstr "Non riesco ad aprire l'input"
+msgid "Could not open input"
+msgstr "Non riesco ad aprire l'input"
-#~ msgid "Could not open output"
-#~ msgstr "Non riesco ad aprire l'output"
+msgid "Could not open output"
+msgstr "Non riesco ad aprire l'output"
 #, fuzzy
-#~ msgid "Could not find input map <%s>"
+msgid "Could not find input map <%s>"
-#~ msgid "Database connection not defined\n"
-#~ msgstr "Connessione al database non definita\n"
+msgid "Database connection not defined\n"
+msgstr "Connessione al database non definita\n"
 #, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
-#~ msgstr "Impossibile leggere l'intestazione del raster 3D <%s> in <%s>"
+msgid "Can't read header for <%s> in <%s>"
+msgstr "Impossibile leggere l'intestazione del raster 3D <%s> in <%s>"
 #, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
+msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgid "%s in %s: %s"
-#~ msgstr "%s in %s: %s"
+msgid "%s in %s: %s"
+msgstr "%s in %s: %s"
 #, fuzzy
-#~ msgid "Can't write region <%s>"
+msgid "Can't write region <%s>"
-#~ msgid "<%s=%s> ** invalid input **"
-#~ msgstr "<%s=%s> ** input non valido **"
+msgid "<%s=%s> ** invalid input **"
+msgstr "<%s=%s> ** input non valido **"
 #, fuzzy
-#~ msgid "No graphics device selected."
-#~ msgstr "Nessun device grafico selezionato"
+msgid "No graphics device selected."
+msgstr "Nessun device grafico selezionato"
 #, fuzzy
-#~ msgid "Unable to read raster row."
+msgid "Unable to read raster row."
 #, fuzzy
-#~ msgid "%s map not found"
+msgid "%s map not found"
 #, fuzzy
-#~ msgid "cannot read head of %s"
+msgid "cannot read head of %s"
 #, fuzzy
-#~ msgid "input raster map"
+msgid "input raster map"
 #, fuzzy
-#~ msgid "Illegal file name: %s"
-#~ msgstr "Nome file non valido [%s]."
+msgid "Illegal file name: %s"
+msgstr "Nome file non valido [%s]."
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr "Impossibile ottenere informazioni sul layer vettoriale"
+msgid "Cannot get layer info for vector map"
+msgstr "Impossibile ottenere informazioni sul layer vettoriale"
 #, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
+msgid "Cannot open raster map <%s> in <%s>"
 #, fuzzy
-#~ msgid "%s: %s - raster map not found"
+msgid "%s: %s - raster map not found"
 #, fuzzy
-#~ msgid "%s: %s - illegal name"
+msgid "%s: %s - illegal name"
 #, fuzzy
-#~ msgid "%s: ERROR reading category file for %s"
+msgid "%s: ERROR reading category file for %s"
 #, fuzzy
-#~ msgid "%s: %s - not found"
+msgid "%s: %s - not found"
 #, fuzzy
-#~ msgid "%s: %s - illegal units"
+msgid "%s: %s - illegal units"
 #, fuzzy
-#~ msgid "%s: %s - can't open"
+msgid "%s: %s - can't open"
 #, fuzzy
-#~ msgid "Reading input map (%s)    ... "
+msgid "Reading input map (%s)    ... "
 #, fuzzy
-#~ msgid "%s - ERROR reading %s"
+msgid "%s - ERROR reading %s"
 #, fuzzy
-#~ msgid "%s: %s - can't create raster map"
+msgid "%s: %s - can't create raster map"
 #, fuzzy
-#~ msgid "Writing output map (%s)   ... "
+msgid "Writing output map (%s)   ... "
 #, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
+msgid "%s - ERROR re-reading %s"
 #, fuzzy
-#~ msgid "Reading raster map... "
+msgid "Reading raster map... "
 #, fuzzy
-#~ msgid "Writing raster map... "
-#~ msgstr "Nome del raster map esistente"
+msgid "Writing raster map... "
+msgstr "Nome del raster map esistente"
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "Categoria lista: es. 1,3-8,13"
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "Categoria lista: es. 1,3-8,13"
-#~ msgid "Output separator character (default: tab)"
+msgid "Output separator character (default: tab)"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
+msgid "Cannot read category file of raster map <%s> in <%s>"
 #, fuzzy
-#~ msgid "Cannot find file %s"
+msgid "Cannot find file %s"
 #, fuzzy
-#~ msgid "Cannot get header for %s"
+msgid "Cannot get header for %s"
 #, fuzzy
-#~ msgid "Cannot create raster map %s"
+msgid "Cannot create raster map %s"
 #, fuzzy
-#~ msgid "Cannot create vector map %s"
+msgid "Cannot create vector map %s"
 #, fuzzy
-#~ msgid "Cannot create raster map '%s'"
+msgid "Cannot create raster map '%s'"
 #, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "Nume di righe da tenere in memoria"
+msgid "Number of raster rows to hold in memory"
+msgstr "Nume di righe da tenere in memoria"
 #, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "Stampa solo il tipo di mappa raster"
+msgid "Print raster map title only"
+msgstr "Stampa solo il tipo di mappa raster"
 #, fuzzy
-#~ msgid "unknown type: %d"
-#~ msgstr "Tipo sconosciuto"
+msgid "unknown type: %d"
+msgstr "Tipo sconosciuto"
-#~ msgid "Cannot open raster map [%s]"
+msgid "Cannot open raster map [%s]"
 #, fuzzy
-#~ msgid "Cannot get raster band."
+msgid "Cannot get raster band."
 #, fuzzy
-#~ msgid "Cannot read GRASS raster."
+msgid "Cannot read GRASS raster."
 #, fuzzy
-#~ msgid "Cannot write GDAL raster."
+msgid "Cannot write GDAL raster."
 #, fuzzy
-#~ msgid "Cannot get [%s] driver"
+msgid "Cannot get [%s] driver"
 #, fuzzy
-#~ msgid "Couldn't set geo transform."
+msgid "Couldn't set geo transform."
 #, fuzzy
-#~ msgid "Couldn't set projection."
+msgid "Couldn't set projection."
 #, fuzzy
-#~ msgid "Cannot export [%s] raster map."
+msgid "Cannot export [%s] raster map."
 #, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
+msgid "Cannot create [%s] raster map using [%s] driver."
 #, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
+msgid "Cannot read header of raster map <%s>"
 #, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
+msgid "Cannot open TIFF file <%s>"
 #, fuzzy
-#~ msgid "Reading raster map"
+msgid "Reading raster map"
 #, fuzzy
-#~ msgid "Cannot open output map."
+msgid "Cannot open output map."
 #, fuzzy
-#~ msgid "Illegal file name. Please try another."
+msgid "Illegal file name. Please try another."
 #, fuzzy
-#~ msgid "%s: can't open %s"
+msgid "%s: can't open %s"
 #, fuzzy
-#~ msgid "Reading raster map <%s> ..."
+msgid "Reading raster map <%s> ..."
 #, fuzzy
-#~ msgid "memory allocation failure"
+msgid "memory allocation failure"
 #, fuzzy
-#~ msgid "Can't find data map."
+msgid "Can't find data map."
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
+msgid "Cannot open vector map <%s> at the topological level"
 #, fuzzy
-#~ msgid "Rebuilding topology ..."
+msgid "Rebuilding topology ..."
-#~ msgid "No record for cat = %d"
+msgid "No record for cat = %d"
 #, fuzzy
-#~ msgid "Removing duplicates ..."
+msgid "Removing duplicates ..."
 #, fuzzy
-#~ msgid "Attaching islands ..."
+msgid "Attaching islands ..."
 #, fuzzy
-#~ msgid "Attaching centroids ..."
+msgid "Attaching centroids ..."
 #, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
+msgid "Vector map <%s> not found in current mapset"
 #, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
+msgid "The number of lines in the input vector map is [%d]"
+msgstr "Nome di  2-%d mappe raster in input"
 #, fuzzy
-#~ msgid "The number of polylines in the output vector map is [%d]"
+msgid "The number of polylines in the output vector map is [%d]"
 #, fuzzy
-#~ msgid "Database connection not defined for layer <%d>"
+msgid "Database connection not defined for layer <%d>"
 #, fuzzy
-#~ msgid "Cannot open select cursor"
+msgid "Cannot open select cursor"
 #, fuzzy
-#~ msgid "Cannot get layer info"
+msgid "Cannot get layer info"
 #, fuzzy
-#~ msgid "cell file [%s] not found"
+msgid "cell file [%s] not found"
 #, fuzzy
-#~ msgid "can't open raster map [%s]"
+msgid "can't open raster map [%s]"
 #, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "Impossibile creare l'indice"
+msgid "Cannot rewrite line %d"
+msgstr "Impossibile creare l'indice"
 #, fuzzy
-#~ msgid "Editing tool"
-#~ msgstr "Esistente"
+msgid "Editing tool"
+msgstr "Esistente"
 #, fuzzy
-#~ msgid "Close boundaries"
-#~ msgstr "Non riesco a copiare la tabella"
+msgid "Close boundaries"
+msgstr "Non riesco a copiare la tabella"
 #, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
+msgid "Cannot copy line %d, editing terminated"
 #, fuzzy
-#~ msgid "No layer database connection."
+msgid "No layer database connection."
 #, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
+msgid "Cannot snap lines %d,%d"
 #, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "%d categorie duplicate nel vettoriale"
+msgid "%d lines modified"
+msgstr "%d categorie duplicate nel vettoriale"
 #, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
+msgid "Could not open ASCII file <%s>"
 #, fuzzy
-#~ msgid "Print vector map region only"
+msgid "Print vector map region only"
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
+msgid "Cannot open vector map <%s> at topo level [%d]"
 #, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
+msgid "Cannot get layer info for vector map <%s>"
 #, fuzzy
-#~ msgid "Cannot select attribute."
+msgid "Cannot select attribute."
 #, fuzzy
-#~ msgid "Creating vector grid..."
+msgid "Creating vector grid..."
 #, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
+msgid "Could not find vector map <%s> in current mapset"
 #, fuzzy
-#~ msgid "Could not find input map <%s>."
+msgid "Could not find input map <%s>."
 #, fuzzy
-#~ msgid "Output map where segments will be written"
+msgid "Output map where segments will be written"
 #, fuzzy
-#~ msgid "<%s> cellfile not found"
+msgid "<%s> cellfile not found"
 #, fuzzy
-#~ msgid "Not able to open vector map <%s>"
+msgid "Not able to open vector map <%s>"
 #, fuzzy
-#~ msgid "Can't read raster"
+msgid "Can't read raster"
-#~ msgid "driver name"
-#~ msgstr "nome driver"
+msgid "driver name"
+msgstr "nome driver"
-#~ msgid "database name"
-#~ msgstr "nome database"
+msgid "database name"
+msgstr "nome database"
 #, fuzzy
-#~ msgid "Driver name"
+msgid "Driver name"
-#~ msgid "Cannot list databases."
+msgid "Cannot list databases."
-#~ msgid "database location"
+msgid "database location"
-#~ msgid "Table name, select all from this table"
-#~ msgstr "Nome tabella, seleziona tutto da questa tabella"
+msgid "Table name, select all from this table"
+msgstr "Nome tabella, seleziona tutto da questa tabella"
-#~ msgid "output field separator"
-#~ msgstr "campo separatore in output"
+msgid "output field separator"
+msgstr "campo separatore in output"
-#~ msgid "output vertical record separator"
-#~ msgstr "output verticale del separatore di record "
+msgid "output vertical record separator"
+msgstr "output verticale del separatore di record "
-#~ msgid "null value indicator"
-#~ msgstr "indicatore di valore nullo"
+msgid "null value indicator"
+msgstr "indicatore di valore nullo"
-#~ msgid "do not include column names in output"
-#~ msgstr "non includere i nomi delle colonne nell'output"
+msgid "do not include column names in output"
+msgstr "non includere i nomi delle colonne nell'output"
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "output verticale (invece che orizzontale)"
+msgid "vertical output (instead of horizontal)"
+msgstr "output verticale (invece che orizzontale)"
 #, fuzzy
-#~ msgid "Cannot find mapset for %s"
+msgid "Cannot find mapset for %s"
 #, fuzzy
-#~ msgid "Cannot open File %s"
+msgid "Cannot open File %s"
 #, fuzzy
-#~ msgid "Not able to open file for [%s]"
+msgid "Not able to open file for [%s]"
 #, fuzzy
-#~ msgid "Can't open label file [%s]"
+msgid "Can't open label file [%s]"
 #, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
+msgid "unable to open [%s] in [%s]"
 #, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
+msgid "warning: unable to open [%s] in [%s]"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s] in [%s]"
+msgid "Unable to open raster map [%s] in [%s]"
 #, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
+msgid "Unable to find input cell map '%s'"
 #, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
+msgid "Unable to open cellfile for <%s>"
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]"
+msgid "Unable to create raster map [%s]"
 #, fuzzy
-#~ msgid "Unable to create output <%s>"
+msgid "Unable to create output <%s>"
 #, fuzzy
-#~ msgid "Input file [%s] not found."
+msgid "Input file [%s] not found."
 #, fuzzy
-#~ msgid "Unable to open output file <%s>."
+msgid "Unable to open output file <%s>."
 #, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
+msgid "Could not open temporary file: [%s]"
 #, fuzzy
-#~ msgid "Could not open input file [%s]"
+msgid "Could not open input file [%s]"
 #, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
+msgid "Unable to create output raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
+msgid "%s: Unable to find raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgid "%s: Unable to open raster map <%s> in mapset <%s>"
 #, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
+msgid "%s:  Unable to open output raster map <%s>"
 #, fuzzy
-#~ msgid "Vector <%s> could not be opened"
+msgid "Vector <%s> could not be opened"
 #, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
-#~ msgstr ""
+msgid "No db connection for driver <%s> defined. Run db.connect."
 #, fuzzy
-#~ msgid "Table name"
-#~ msgstr "nome tabella"
+msgid "Table name"
+msgstr "nome tabella"
-#~ msgid ""
-#~ "Print current map connection parameters and exit (shell script style)\n"
-#~ "\tformat:  layer[/layer name] table key database driver"
-#~ msgstr ""
-#~ "Stampa i parametri di connessione correnti ed esce (stile shell script)\n"
+msgid ""
+"Print current map connection parameters and exit (shell script style)\n"
+"\tformat:  layer[/layer name] table key database driver"
+msgstr ""
+"Stampa i parametri di connessione correnti ed esce (stile shell script)\n"
 #, fuzzy
-#~ msgid "x column name"
+msgid "x column name"
 #, fuzzy
-#~ msgid "z column name"
+msgid "z column name"
 #, fuzzy
-#~ msgid "Cannot drop table: %s"
+msgid "Cannot drop table: %s"
 #, fuzzy
-#~ msgid "Cannot open labels <%s>"
+msgid "Cannot open labels <%s>"
 #, fuzzy
-#~ msgid "Cannot fetch data from table"
+msgid "Cannot fetch data from table"
 #, fuzzy
-#~ msgid "Cannot open file [%s]"
+msgid "Cannot open file [%s]"
 #, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
+msgid "SVG file <%s> cannot be opened"
 #, fuzzy
-#~ msgid "Querying input '%s' ... "
+msgid "Querying input '%s' ... "
 #, fuzzy
-#~ msgid "Copying %s input lines ... "
+msgid "Copying %s input lines ... "
 #, fuzzy
-#~ msgid "Cannot create table <%s>"
+msgid "Cannot create table <%s>"
 #, fuzzy
-#~ msgid "cannot insert row: %s"
+msgid "cannot insert row: %s"
 #, fuzzy
-#~ msgid "Cannot find line of cat %d"
+msgid "Cannot find line of cat %d"
 #, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
+msgid "Unalbe to open vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer [%d]. Use v.db.connect first"
+msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
 #, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr "Esporta un raster grass come array binario"
+msgid "Transforms a vector map via a set of tie points."
+msgstr "Esporta un raster grass come array binario"
 #, fuzzy
-#~ msgid "Raster map <%s>] not found"
+msgid "Raster map <%s>] not found"
-#~ msgid "Cannot start driver '%s'."
+msgid "Cannot start driver '%s'."
-#~ msgid "Cannot describe table"
+msgid "Cannot describe table"
-#~ msgid "Cannot start driver <%s>."
-#~ msgstr "Non riesco ad eseguire il driver <%s>."
+msgid "Cannot start driver <%s>."
+msgstr "Non riesco ad eseguire il driver <%s>."
-#~ msgid "Could not open <%s>"
-#~ msgstr "Impossibile aprire <%s>"
+msgid "Could not open <%s>"
+msgstr "Impossibile aprire <%s>"
-#~ msgid "Cannot write to <%s>"
-#~ msgstr "Non riesco a scrivere su <%s>"
+msgid "Cannot write to <%s>"
+msgstr "Non riesco a scrivere su <%s>"
-#~ msgid "Not able to open cellfile for [%s]"
+msgid "Not able to open cellfile for [%s]"
 #, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
+msgid "Not able to find cellfile [%s]"
 #, fuzzy
-#~ msgid "Raster file [%s] not available"
+msgid "Raster file [%s] not available"
 #, fuzzy
-#~ msgid "Raster map [%s] not found"
+msgid "Raster map [%s] not found"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]"
+msgid "Unable to open raster map [%s]"
-#~ msgid "Vector file [%s] not available"
+msgid "Vector file [%s] not available"
 #, fuzzy
-#~ msgid "Cannot open driver %s"
+msgid "Cannot open driver %s"
 #, fuzzy
-#~ msgid "<%s> illegal name"
+msgid "<%s> illegal name"
-#~ msgid "Out of Memory!\n"
-#~ msgstr "Memoria esaurita!\n"
+msgid "Out of Memory!\n"
+msgstr "Memoria esaurita!\n"
 #, fuzzy
-#~ msgid "%s: %s - illegal name for output raster map."
+msgid "%s: %s - illegal name for output raster map."
 #, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
+msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgid "Couldn't find raster map %s"
+msgid "Couldn't find raster map %s"
 #, fuzzy
-#~ msgid "%s: <%s> not found"
+msgid "%s: <%s> not found"
 #, fuzzy
-#~ msgid "%s: <%s> illegal name"
+msgid "%s: <%s> illegal name"
 #, fuzzy
-#~ msgid "%s: Cannot open <%s>"
+msgid "%s: Cannot open <%s>"
 #, fuzzy
-#~ msgid "could not read range file"
+msgid "could not read range file"
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]."
+msgid "Unable to create raster map [%s]."
 #, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
+msgid "Filtering [%s] in [%s]"
 #, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
+msgid "Open raster map %s in %s = %d"
 #, fuzzy
-#~ msgid "Closing raster map"
+msgid "Closing raster map"
 #, fuzzy
-#~ msgid "Swap temp files"
+msgid "Swap temp files"
 #, fuzzy
-#~ msgid "Writing [%s]"
+msgid "Writing [%s]"
 #, fuzzy
-#~ msgid "%s: illegal map name"
+msgid "%s: illegal map name"
 #, fuzzy
-#~ msgid "%s: <%s> illegal file name"
+msgid "%s: <%s> illegal file name"
 #, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
-#~ msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
+msgid "can't open raster map <%s> in mapset %s"
+msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
 #, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
+msgid "Checking location %s, mapset %s:"
 #, fuzzy
-#~ msgid "Error writing output map"
+msgid "Error writing output map"
 #, fuzzy
-#~ msgid "<%s> is illegal file name"
-#~ msgstr "[%s] è un nome illegale"
+msgid "<%s> is illegal file name"
+msgstr "[%s] è un nome illegale"
 #, fuzzy
-#~ msgid "[%s] is an illegal file name"
+msgid "[%s] is an illegal file name"
 #, fuzzy
-#~ msgid "no rules specified"
+msgid "no rules specified"
 #, fuzzy
-#~ msgid "Can't open temp file [%s]"
+msgid "Can't open temp file [%s]"
 #, fuzzy
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
+msgid "Unable to open input map <%s> in mapset <%s>"
 #, fuzzy
-#~ msgid "%s - illegal name "
+msgid "%s - illegal name "
 #, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
+msgid "Couldn't find raster map [%s]"
 #, fuzzy
-#~ msgid "%s - can't create raster map"
+msgid "%s - can't create raster map"
 #, fuzzy
-#~ msgid "Normalized"
-#~ msgstr "Normalizzata"
+msgid "Normalized"
+msgstr "Normalizzata"
 #, fuzzy
-#~ msgid "Cell file [%s] not found"
+msgid "Cell file [%s] not found"
 #, fuzzy
-#~ msgid "Requested 3d raster map not found <%s>"
+msgid "Requested 3d raster map not found <%s>"
 #, fuzzy
-#~ msgid "Could not open output map"
+msgid "Could not open output map"
 #, fuzzy
-#~ msgid "unable to close output map"
+msgid "unable to close output map"
 #, fuzzy
-#~ msgid "Could not close the 3d raster map"
+msgid "Could not close the 3d raster map"
 #, fuzzy
-#~ msgid "Cannot create output map [%s]"
+msgid "Cannot create output map [%s]"
 #, fuzzy
-#~ msgid "Database's name couldn't be read"
+msgid "Database's name couldn't be read"
 #, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
+msgid "Cannot open vector points map <%s>"
 #, fuzzy
-#~ msgid "Cannot create vector map <%s>"
+msgid "Cannot create vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Interpolation: No database connection for driver <%s> defined. Run db."
-#~ "connect"
-#~ msgstr ""
+msgid "Interpolation: No database connection for driver <%s> defined. Run db.connect"
 #, fuzzy
-#~ msgid "Vector file [%s] not available in search list"
+msgid "Vector file [%s] not available in search list"
 #, fuzzy
-#~ msgid "Cannot open database <%s>"
+msgid "Cannot open database <%s>"
 #, fuzzy
-#~ msgid "Cannot open table <%s>"
+msgid "Cannot open table <%s>"
 #, fuzzy
-#~ msgid "Cannot open driver <%s>"
+msgid "Cannot open driver <%s>"
 #, fuzzy
-#~ msgid "Could not find input map '%s'."
+msgid "Could not find input map '%s'."
 #, fuzzy
-#~ msgid "Could not find network input map '%s'."
+msgid "Could not find network input map '%s'."
 #, fuzzy
-#~ msgid "error opening raster map [%s]."
-#~ msgstr "Nome di mappa(e) raster esistente(i)"
+msgid "error opening raster map [%s]."
+msgstr "Nome di mappa(e) raster esistente(i)"
 #, fuzzy
-#~ msgid "Topology is not available"
+msgid "Topology is not available"
 #, fuzzy
-#~ msgid "Cannot describe table %s"
+msgid "Cannot describe table %s"
 #, fuzzy
-#~ msgid "Patching file <%s@%s>"
+msgid "Patching file <%s@%s>"
 #, fuzzy
-#~ msgid "[%d] files patched"
-#~ msgstr "%d records aggiornati"
+msgid "[%d] files patched"
+msgstr "%d records aggiornati"
 #, fuzzy
-#~ msgid "Column type  not supported"
+msgid "Column type  not supported"
 #, fuzzy
-#~ msgid "Could not open vector map <%s>"
+msgid "Could not open vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer <%d>. Use v.db.connect first."
+msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
 #, fuzzy
-#~ msgid "Can't create output map"
+msgid "Can't create output map"
 #, fuzzy
-#~ msgid "Could not close new 3d raster map"
+msgid "Could not close new 3d raster map"
 #, fuzzy
-#~ msgid "%s: cellfile [%s] not found."
+msgid "%s: cellfile [%s] not found."
 #, fuzzy
-#~ msgid "Unable to open cellfile [%s]."
+msgid "Unable to open cellfile [%s]."
 #, fuzzy
-#~ msgid "Unable to open the temporary file."
+msgid "Unable to open the temporary file."
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]."
+msgid "Unable to open raster map [%s]."
 #, fuzzy
-#~ msgid "Unable to find raster [%s]."
+msgid "Unable to find raster [%s]."
 #, fuzzy
-#~ msgid "name for new raster map"
-#~ msgstr "Nome di un nuovo file raster"
+msgid "name for new raster map"
+msgstr "Nome di un nuovo file raster"
 #, fuzzy
-#~ msgid "Output GRASS image file"
+msgid "Output GRASS image file"
 #, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr "Nome del nuovo file PPM. (use out=- per lo standard output)"
+msgid "name for new vector map (omit for display to stdout)"
+msgstr "Nome del nuovo file PPM. (use out=- per lo standard output)"
 #, fuzzy
-#~ msgid "Input vector map"
+msgid "Input vector map"
 #, fuzzy
-#~ msgid "%s: ERROR can't open tempfile"
+msgid "%s: ERROR can't open tempfile"
 #, fuzzy
-#~ msgid "unable to find raster map [%s]"
+msgid "unable to find raster map [%s]"
 #, fuzzy
-#~ msgid "<%s> raster map not found"
+msgid "<%s> raster map not found"
 #, fuzzy
-#~ msgid "<%s> unable to open raster map"
+msgid "<%s> unable to open raster map"
 #, fuzzy
-#~ msgid "Cannot find vector map [%s]"
+msgid "Cannot find vector map [%s]"
 #, fuzzy
-#~ msgid "%s - can't open raster map"
+msgid "%s - can't open raster map"
 #, fuzzy
-#~ msgid "Can't get row %d from raster map %s"
+msgid "Can't get row %d from raster map %s"
 #, fuzzy
-#~ msgid "%s - raster map not found"
+msgid "%s - raster map not found"
-#~ msgid "string representing no data cell value"
+msgid "string representing no data cell value"
-#~ msgid "quiet"
-#~ msgstr "silenzioso"
+msgid "quiet"
+msgstr "silenzioso"
 #, fuzzy
-#~ msgid "<%s> - illegal output file name"
+msgid "<%s> - illegal output file name"
 #, fuzzy
-#~ msgid "%s: <%s> reference map not found"
+msgid "%s: <%s> reference map not found"
-#~ msgid "Base raster map"
-#~ msgstr "Mappa raster di base"
+msgid "Base raster map"
+msgstr "Mappa raster di base"
-#~ msgid "Resultant raster map"
+msgid "Resultant raster map"
 #, fuzzy
-#~ msgid "%s: raster map not found"
+msgid "%s: raster map not found"
 #, fuzzy
-#~ msgid "Problem opening input file [%s]"
+msgid "Problem opening input file [%s]"
 #, fuzzy
-#~ msgid "Problem opening output file [%s]"
+msgid "Problem opening output file [%s]"
 #, fuzzy
-#~ msgid "can't write category file for <%s>"
+msgid "can't write category file for <%s>"
 #, fuzzy
-#~ msgid "%s: can't open tempfile"
+msgid "%s: can't open tempfile"
 #, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
+msgid "Unable to read row %d in raster map [%s]"
 #, fuzzy
-#~ msgid "Output verbosely"
+msgid "Output verbosely"
 #, fuzzy
-#~ msgid "Can't open raster map %s"
+msgid "Can't open raster map %s"
 #, fuzzy
-#~ msgid "It could not be find input map <%s>"
+msgid "It could not be find input map <%s>"
 #, fuzzy
-#~ msgid "It could not be found input map <%s>"
+msgid "It could not be found input map <%s>"
 #, fuzzy
-#~ msgid "Cannot find input map <%s>"
+msgid "Cannot find input map <%s>"
 #, fuzzy
-#~ msgid "Input vector map <%s> not found."
+msgid "Input vector map <%s> not found."
 #, fuzzy
-#~ msgid "Category ranges: e.g. 1,3-8,13"
+msgid "Category ranges: e.g. 1,3-8,13"
 #, fuzzy
-#~ msgid "Writing attributes ...\n"
+msgid "Writing attributes ...\n"
 #, fuzzy
-#~ msgid "Could not open ascii file <%s>"
+msgid "Could not open ascii file <%s>"
 #, fuzzy
-#~ msgid "Could not open temp file <%s>"
+msgid "Could not open temp file <%s>"
 #, fuzzy
-#~ msgid "List available formats and exit"
-#~ msgstr "Visualizza i formati supportati ed esci"
+msgid "List available formats and exit"
+msgstr "Visualizza i formati supportati ed esci"
 #, fuzzy
-#~ msgid "Vector map <%s> not fould"
+msgid "Vector map <%s> not fould"
 #, fuzzy
-#~ msgid "SVG output file"
+msgid "SVG output file"
 #, fuzzy
-#~ msgid "Could not find vector '%s'"
+msgid "Could not find vector '%s'"
 #, fuzzy
-#~ msgid "Could not find vector map %s"
+msgid "Could not find vector map %s"
 #, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
+msgid "Unable to get row %d from <%s>"
-#~ msgid "Input file"
+msgid "Input file"
-#~ msgid "Raster output file"
-#~ msgstr "File raster in output"
+msgid "Raster output file"
+msgstr "File raster in output"
 #, fuzzy
-#~ msgid "Writing raster map ... "
+msgid "Writing raster map ... "
-#~ msgid "Keep existing color table"
-#~ msgstr "Mantieni la tabella colore esistente"
+msgid "Keep existing color table"
+msgstr "Mantieni la tabella colore esistente"
-#~ msgid "List rules"
-#~ msgstr "Mostra regole"
+msgid "List rules"
+msgstr "Mostra regole"
 #, fuzzy
-#~ msgid " %d rows, %d cols."
-#~ msgstr "%d raster%s, %d vettoriale%s\n"
+msgid " %d rows, %d cols."
+msgstr "%d raster%s, %d vettoriale%s\n"
 #, fuzzy
-#~ msgid "%s in %s - can't read header file"
+msgid "%s in %s - can't read header file"
 #, fuzzy
-#~ msgid "%s - unable to create raster map"
+msgid "%s - unable to create raster map"
 #, fuzzy
-#~ msgid "%s - unable to create category file"
+msgid "%s - unable to create category file"
 #, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
+msgid "Vector map with points for which to modify the attribute table"
 #, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#~ msgstr ""
-#~ "Nome della mappa vettoriale di punti della quale editare la tabella "
-#~ "attributi"
+msgid "Layer of the vector for which to modify the attribute table"
+msgstr "Nome della mappa vettoriale di punti della quale editare la tabella attributi"
 #, fuzzy
-#~ msgid "Path to the input file"
-#~ msgstr "Nome del filtro file"
+msgid "Path to the input file"
+msgstr "Nome del filtro file"
 #, fuzzy
-#~ msgid "Path to an output file"
+msgid "Path to an output file"
 #, fuzzy
-#~ msgid "Name of existing raster map to be displayed"
+msgid "Name of existing raster map to be displayed"
-#~ msgid "driver name:"
-#~ msgstr "nome del driver:"
+msgid "driver name:"
+msgstr "nome del driver:"
-#~ msgid "Database name:"
-#~ msgstr "Nome del database:"
+msgid "Database name:"
+msgstr "Nome del database:"
 #, fuzzy
-#~ msgid "could not find input map <%s>"
+msgid "could not find input map <%s>"
 #, fuzzy
-#~ msgid "unable to open raster map [%s]"
+msgid "unable to open raster map [%s]"
 #, fuzzy
-#~ msgid "cannot get layer info for vector map"
+msgid "cannot get layer info for vector map"
 #, fuzzy
-#~ msgid "cannot open database %s by driver %s"
+msgid "cannot open database %s by driver %s"
 #, fuzzy
-#~ msgid "column type not supported"
-#~ msgstr "driver pg: colonna '%s', di tipo %d non supportata"
+msgid "column type not supported"
+msgstr "driver pg: colonna '%s', di tipo %d non supportata"
 #, fuzzy
-#~ msgid "cannot select data from table"
+msgid "cannot select data from table"
 #, fuzzy
-#~ msgid "cannot create table: %s"
+msgid "cannot create table: %s"
 #, fuzzy
-#~ msgid "cannot create index"
+msgid "cannot create index"
 #, fuzzy
-#~ msgid "cannot grant privileges on table %s"
+msgid "cannot grant privileges on table %s"
 #, fuzzy
 #, fuzzy
-#~ msgid "Cannot find vector map"
-#~ msgstr "Non riesco ad impostare user/password"
+msgid "Cannot find vector map"
 #, fuzzy
-#~ msgid "Cannot find raster map"
+msgid "Cannot find raster map"
 #, fuzzy
-#~ msgid "Cannot open raster map"
+msgid "Cannot open raster map"
 #, fuzzy
-#~ msgid "Can't open temp file %s"
+msgid "Can't open temp file %s"
 #, fuzzy
-#~ msgid "Error while reading cell map."
+msgid "Error while reading cell map."
 #, fuzzy
-#~ msgid "Error while writing new cell map."
-#~ msgstr "Errore nella scrittura della grid. Disco pieno?"
+msgid "Error while writing new cell map."
+msgstr "Errore nella scrittura della grid. Disco pieno?"
 #, fuzzy
-#~ msgid "Error in opening output file <%s>"
+msgid "Error in opening output file <%s>"
 #, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
+msgid "Unable to find input cell map <%s>"
 #, fuzzy
-#~ msgid "Error in opening input file <%s>"
+msgid "Error in opening input file <%s>"
 #, fuzzy
-#~ msgid "Unable to open cell man <%s> for input.\n"
+msgid "Unable to open cell man <%s> for input.\n"
 #, fuzzy
-#~ msgid "Unable to open cell map <%s> for output.\n"
+msgid "Unable to open cell map <%s> for output.\n"
 #, fuzzy
-#~ msgid "Unable to read map raster row %d"
-#~ msgstr "Nome del raster"
+msgid "Unable to read map raster row %d"
+msgstr "Nome del raster"
 #, fuzzy
-#~ msgid "Cannot find map %s"
+msgid "Cannot find map %s"
 #, fuzzy
-#~ msgid "Cannot open map %s"
+msgid "Cannot open map %s"
-#~ msgid "Name of predefined rules file"
-#~ msgstr "Nome del file con le regole predefinite"
+msgid "Name of predefined rules file"
+msgstr "Nome del file con le regole predefinite"
 #, fuzzy
-#~ msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-#~ msgstr ""
-#~ "** attenzione: valore(i) R:G:B al di fuori dell'intervallo [0..255]: %d:%"
-#~ "d:%d **\n"
+msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
+msgstr "** attenzione: valore(i) R:G:B al di fuori dell'intervallo [0..255]: %d:%d:%d **\n"
 #, fuzzy
-#~ msgid "R G B value(s) out of range [0..255]: %d %d %d"
-#~ msgstr ""
-#~ "** attenzione: valore(i) R G B al di fuori dell'intervallo [0..255]: %d %"
-#~ "d %d **\n"
+msgid "R G B value(s) out of range [0..255]: %d %d %d"
+msgstr "** attenzione: valore(i) R G B al di fuori dell'intervallo [0..255]: %d %d %d **\n"
 #, fuzzy
-#~ msgid "no such value"
-#~ msgstr "** attenzione: non trovo il valore **\n"
+msgid "no such value"
+msgstr "** attenzione: non trovo il valore **\n"
 #, fuzzy
-#~ msgid "%s:line %d:%s"
-#~ msgstr "%s:linea %d:%s\n"
+msgid "%s:line %d:%s"
+msgstr "%s:linea %d:%s\n"
 #, fuzzy
-#~ msgid "bad color specification"
-#~ msgstr "** definizione errata del colore **\n"
+msgid "bad color specification"
+msgstr "** definizione errata del colore **\n"
 #, fuzzy
-#~ msgid "%s - unknown color"
-#~ msgstr "%s - colore sconosciuto\n"
+msgid "%s - unknown color"
+msgstr "%s - colore sconosciuto\n"
-#~ msgid "Valid colors are:\n"
-#~ msgstr "I colori validi sono:\n"
+msgid "Valid colors are:\n"
+msgstr "I colori validi sono:\n"
 #, fuzzy
-#~ msgid "Unable to find base map <%s>"
+msgid "Unable to find base map <%s>"
 #, fuzzy
-#~ msgid "Unable to find cover map <%s>"
+msgid "Unable to find cover map <%s>"
 #, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
-#~ msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgid "%s: unable to open raster map [%s]"
 #, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
-#~ msgstr "Nome della mappa raster risultante"
+msgid "%s: unable to create raster map [%s]"
+msgstr "Nome della mappa raster risultante"
 #, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
+msgid "Unable to open database %s with driver %s"
 #, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
+msgid "%s: Unable to read raster map [%s]"
 #, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
+msgid "%s: unable to open raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
+msgid "%s: Failed to read raster row %d"
 #, fuzzy
-#~ msgid "Unable to find [%s]."
+msgid "Unable to find [%s]."
 #, fuzzy
-#~ msgid "Unable to read cats table for %s"
+msgid "Unable to read cats table for %s"
 #, fuzzy
-#~ msgid "Could not open raster <%s>"
+msgid "Could not open raster <%s>"
-#~ msgid ""
-#~ "Font name (not supported interactively, see also -l flag) or path to "
-#~ "TrueType font (including file name)"
-#~ msgstr ""
-#~ "Nome del tipo carattere (non supportato in maniera interattiva, in tal "
-#~ "caso vedi il flag -l) oppure percorso del font TrueType (completo del "
-#~ "nome del file)"
+msgid "Font name (not supported interactively, see also -l flag) or path to TrueType font (including file name)"
+msgstr "Nome del tipo carattere (non supportato in maniera interattiva, in tal caso vedi il flag -l) oppure percorso del font TrueType (completo del nome del file)"
 #, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
+msgid "%s: o_open_file: raster map %s not found"
 #, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
+msgid "%s: o_open_file: could not open raster map %s in %s"
 #, fuzzy
-#~ msgid "No record for category for [%d]"
+msgid "No record for category for [%d]"
 #, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
+msgid "Error reading ASCII file <%s>"
 #, fuzzy
-#~ msgid "Error reading categories: <%s>"
+msgid "Error reading categories: <%s>"
 #, fuzzy
-#~ msgid "category [%d]"
-#~ msgstr ""
-#~ "Layer: %d\n"
-#~ "categoria: %d\n"
+msgid "category [%d]"
+msgstr ""
+"Layer: %d\n"
+"categoria: %d\n"
 #, fuzzy
-#~ msgid "Could not find input vector '%s'"
-#~ msgstr "Non riesco a trovare il file raster %s"
+msgid "Could not find input vector '%s'"
 #, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
+msgid "Failed opening output vector map '%s'"
 #, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
+msgid "Error reading ascii file: [%s]"
 #, fuzzy
-#~ msgid "%s: <%s> vector map not found"
+msgid "%s: <%s> vector map not found"
 #, fuzzy
-#~ msgid "Vector <%s> could not be open"
+msgid "Vector <%s> could not be open"
 #, fuzzy
-#~ msgid "Raster <%s> could not be open."
+msgid "Raster <%s> could not be open."
 #, fuzzy
-#~ msgid "Interpolation()"
+msgid "Interpolation()"
+msgstr "Mostra il titolo del file raster"
 #, fuzzy
-#~ msgid "Interpolation: nsply = %d"
+msgid "Interpolation: nsply = %d"
 #, fuzzy
-#~ msgid "%s: Dropping <s>"
+msgid "%s: Dropping <s>"
 #, fuzzy
-#~ msgid "Interpolation was a success!"
+msgid "Interpolation was a success!"
 #, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#~ msgstr "Utilizza la regione corrente"
+msgid "CrossCorrelation: %d points read in region. "
+msgstr "Utilizza la regione corrente"
 #, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
+msgid "CrossCorrelation: It shouldn't take too long."
 #, fuzzy
-#~ msgid "%s -- illegal output file name"
+msgid "%s -- illegal output file name"
 #, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
+msgid "Sorry, with method '%s' you have to define an output map."
 #, fuzzy
-#~ msgid "Writing "
-#~ msgstr "Sto disegnando ..."
+msgid "Writing "
+msgstr "Sto disegnando ..."
 #, fuzzy
-#~ msgid "Existing raster map name"
+msgid "Existing raster map name"
 #, fuzzy
-#~ msgid "%s - can't read raster cellhd"
+msgid "%s - can't read raster cellhd"
 #, fuzzy
-#~ msgid "error reading cell data"
+msgid "error reading cell data"
 #, fuzzy
-#~ msgid "Done!"
+msgid "Done!"
+msgstr "Fatto.\n"
 #, fuzzy
-#~ msgid "No line found."
-#~ msgstr "Non ho trovato nulla.\n"
+msgid "No line found."
+msgstr "Non ho trovato nulla.\n"
 #, fuzzy
-#~ msgid "Nothing Found."
+msgid "Nothing Found."
 #, fuzzy
-#~ msgid "Could not open ascii file [%s]"
+msgid "Could not open ascii file [%s]"
-#~ msgid "vector map to be created"
-#~ msgstr "file vettoriale da creare"
+msgid "vector map to be created"
+msgstr "file vettoriale da creare"
 #, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr "Mappa raster risultante"
+msgid "Conversion of [%s] to vector map ..."
+msgstr "Mappa raster risultante"
 #, fuzzy
-#~ msgid "EPSG code of projection to be created"
+msgid "EPSG code of projection to be created"
-#~ msgid "must be even number of names"
-#~ msgstr "deve essere un numero pari di nomi"
+msgid "must be even number of names"
+msgstr "deve essere un numero pari di nomi"
-#~ msgid "ERROR: <%s> not found\n"
-#~ msgstr "ERRORE: <%s> non trovato\n"
+msgid "ERROR: <%s> not found\n"
+msgstr "ERRORE: <%s> non trovato\n"
-#~ msgid "ERROR: <%s> illegal name\n"
-#~ msgstr "ERRORE: <%s> nome illegale\n"
+msgid "ERROR: <%s> illegal name\n"
+msgstr "ERRORE: <%s> nome illegale\n"
 #, fuzzy
-#~ msgid "Cannot open toolbox: %s"
+msgid "Cannot open toolbox: %s"
 #, fuzzy
-#~ msgid "Cannot open toolbox."
+msgid "Cannot open toolbox."
 #, fuzzy
-#~ msgid "Vector map(s) -- source for composite"
-#~ msgstr "File di input"
+msgid "Vector map(s) -- source for composite"
+msgstr "File di input"
 #, fuzzy
-#~ msgid "New vector composite"
+msgid "New vector composite"
 #, fuzzy
-#~ msgid ""
-#~ "Name of output vector points map (if not specified, the program writes to "
-#~ "standard output)"
-#~ msgstr ""
-#~ "attributi"
+msgid "Name of output vector points map (if not specified, the program writes to standard output)"
 #, fuzzy
-#~ msgid "Vector map '%s' not found"
+msgid "Vector map '%s' not found"
 #, fuzzy
-#~ msgid "vector, segment, curvature"
-#~ msgstr "vettore da rimuovere"
+msgid "vector, segment, curvature"
+msgstr "vettore da rimuovere"
 #, fuzzy
-#~ msgid "More lines with category %d found"
+msgid "More lines with category %d found"
 #, fuzzy
-#~ msgid "%s\n"
-#~ msgstr "%s Sposta\n"
+msgid "%s\n"
+msgstr "%s Sposta\n"
 #, fuzzy
-#~ msgid "Raster '%s' not found"
+msgid "Raster '%s' not found"
 #, fuzzy
-#~ msgid "Cold not get raster row"
+msgid "Cold not get raster row"
 #, fuzzy
-#~ msgid "ILLEGAL Resolution!"
-#~ msgstr "Risoluzione"
+msgid "ILLEGAL Resolution!"
+msgstr "Risoluzione"
 #, fuzzy
-#~ msgid "Error opening raster map %s"
+msgid "Error opening raster map %s"
 #, fuzzy
-#~ msgid "Copy raster map <%s> into the memory"
-#~ msgstr "raster <%s> non trovato"
+msgid "Copy raster map <%s> into the memory"
+msgstr "raster <%s> non trovato"
 #, fuzzy
-#~ msgid "Query layer"
+msgid "Query layer"
 #, fuzzy
-#~ msgid "Query column name"
+msgid "Query column name"
 #, fuzzy
-#~ msgid "Enter imagery group to be registered"
+msgid "Enter imagery group to be registered"
 #, fuzzy
-#~ msgid "output layer name"
+msgid "output layer name"
-#~ msgid "L: from  M: to R: quit\n"
-#~ msgstr "L: da  M: a R: esci\n"
+msgid "L: from  M: to R: quit\n"
+msgstr "L: da  M: a R: esci\n"
-#~ msgid "Prints and manipulates GRASS projection information files."
-#~ msgstr "Stampa e modifica i file di proiezione di GRASS"
+msgid "Prints and manipulates GRASS projection information files."
+msgstr "Stampa e modifica i file di proiezione di GRASS"
-#~ msgid ""
-#~ "\n"
-#~ "Where %s is one of:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Dove %s è uno di:\n"
+msgid ""
+"\n"
+"Where %s is one of:\n"
+msgstr ""
+"\n"
+"Dove %s è uno di:\n"
 #, fuzzy
-#~ msgid "%s: - no such database %s\n"
+msgid "%s: - no such database %s\n"
 #, fuzzy
-#~ msgid "No database updates."
+msgid "No database updates."
 #, fuzzy
-#~ msgid "Input aspect file"
+msgid "Input aspect file"
 #, fuzzy
-#~ msgid "Input barrier file"
+msgid "Input barrier file"
 #, fuzzy
-#~ msgid "Quiet operation"
-#~ msgstr "%s Esce dal menu\n"
+msgid "Quiet operation"
+msgstr "%s Esce dal menu\n"
 #, fuzzy
-#~ msgid "datetime, datetime1/datetime2, or none"
-#~ msgstr "nessuno"
+msgid "datetime, datetime1/datetime2, or none"
+msgstr "nessuno"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Done\n"
-#~ msgstr "Fatto\n"
+msgid ""
+"\n"
+"Done\n"
+msgstr "Fatto\n"
 #, fuzzy
-#~ msgid "Open vector 3d raster map %s"
+msgid "Open vector 3d raster map %s"
+msgstr "Non riesco a trovare il file raster %s"
 #, fuzzy
-#~ msgid "Open 3d raster map %s"
+msgid "Open 3d raster map %s"
 #, fuzzy
-#~ msgid "Vector import complete"
+msgid "Vector import complete"
 #, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
+msgid "Unable to create raster map for [%s]"
+msgstr "Non riesco ad aprire il cellfile per [%s]"
-#~ msgid "Done\n"
+msgid "Done\n"
+msgstr "Fatto\n"
 #, fuzzy
-#~ msgid "Open Raster file %s in Mapset %s"
+msgid "Open Raster file %s in Mapset %s"
 #, fuzzy
-#~ msgid "Open 3d raster map %s\n"
+msgid "Open 3d raster map %s\n"
 #, fuzzy
-#~ msgid "Open elev raster map %s\n"
+msgid "Open elev raster map %s\n"
 #, fuzzy
-#~ msgid "Could not open map %s\n"
-#~ msgstr "impossibile aprire <%s>"
+msgid "Could not open map %s\n"
+msgstr "impossibile aprire <%s>"
-#~ msgid "Bin raster map to be imported"
-#~ msgstr "Il file raster bin è stato importato"
+msgid "Bin raster map to be imported"
+msgstr "Il file raster bin è stato importato"
-#~ msgid "Region size is lower than minreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "La dimensione della regione è inferiore rispetto al valore di minreg, non "
-#~ "verrà visualizzato nulla.\n"
+msgid "Region size is lower than minreg, nothing displayed.\n"
+msgstr "La dimensione della regione è inferiore rispetto al valore di minreg, non verrà visualizzato nulla.\n"
-#~ msgid "Region size is greater than maxreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "La dimensione della regione è superiore rispetto al valore di maxreg, non "
+msgid "Region size is greater than maxreg, nothing displayed.\n"
+msgstr "La dimensione della regione è superiore rispetto al valore di maxreg, non verrà visualizzato nulla.\n"
 #, fuzzy
-#~ msgid "Maximum distance"
-#~ msgstr "Livello massimo di contorno"
+msgid "Maximum distance"
+msgstr "Livello massimo di contorno"
 #, fuzzy
-#~ msgid "Makes 3D trees from input point vector map"
-#~ msgstr "Nome di un file vettoriale in output"
+msgid "Makes 3D trees from input point vector map"
+msgstr "Nome di un file vettoriale in output"
 #, fuzzy
-#~ msgid "Name of the column with tree crown width"
+msgid "Name of the column with tree crown width"
 #, fuzzy
-#~ msgid "Cannot select attributes for point #%d"
-#~ msgstr "Non riesco a mostrare i database"
+msgid "Cannot select attributes for point #%d"
+msgstr "Non riesco a mostrare i database"
-#~ msgid "%s Pan\n"
+msgid "%s Pan\n"
-#~ msgid "%s Quit\n"
-#~ msgstr "%s Esce\n"
+msgid "%s Quit\n"
+msgstr "%s Esce\n"
-#~ msgid "Draw geographic grid"
-#~ msgstr "Disegna griglia geografica"
+msgid "Draw geographic grid"
+msgstr "Disegna griglia geografica"
 #, fuzzy
-#~ msgid "Quiet mode"
+msgid "Quiet mode"
 #, fuzzy
-#~ msgid "%s[%d]: No raster map specified."
+msgid "%s[%d]: No raster map specified."
 #, fuzzy
-#~ msgid "done."
+msgid "done."
+msgstr "Fatto.\n"
 #, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
+msgid "name for new binary vector map (omit for display to stdout)"
 #, fuzzy
-#~ msgid "Name for G3d raster map"
+msgid "Name for G3d raster map"
 #, fuzzy
-#~ msgid "No output maps"
-#~ msgstr "Nome della mappa di output"
+msgid "No output maps"
+msgstr "Nome della mappa di output"
 #, fuzzy
-#~ msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
-#~ msgstr ""
-#~ "Valori della mappa g3d errati! I valori devono essere compresi tra 0 e "
-#~ "255!\n"
+msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
+msgstr "Valori della mappa g3d errati! I valori devono essere compresi tra 0 e 255!\n"
 #, fuzzy
-#~ msgid "unable to open new L map layer."
+msgid "unable to open new L map layer."
 #, fuzzy
-#~ msgid "unable to open new S map layer."
+msgid "unable to open new S map layer."
 #, fuzzy
-#~ msgid "Do not export long colortable"
+msgid "Do not export long colortable"
 #, fuzzy
-#~ msgid "Output aspect filename"
+msgid "Output aspect filename"
 #, fuzzy
-#~ msgid "Vector map for which to edit attribute table"
-#~ msgstr "Non riesco a descrivere la tabella"
+msgid "Vector map for which to edit attribute table"
+msgstr "Non riesco a descrivere la tabella"
 #, fuzzy
-#~ msgid "Cannot make stat of %s configuration file"
+msgid "Cannot make stat of %s configuration file"
 #, fuzzy
-#~ msgid "Illegal configuration file"
+msgid "Illegal configuration file"
 #, fuzzy
-#~ msgid "vector, query"
+msgid "vector, query"
 #, fuzzy
-#~ msgid "Computing row %d of covariance matrix..."
+msgid "Computing row %d of covariance matrix..."
 #, fuzzy
-#~ msgid "Converting %s..."
+msgid "Converting %s..."
-#~ msgid "New LOCATION name (not location path)"
-#~ msgstr "Nome della nuova LOCATION (non il percorso della location)"
+msgid "New LOCATION name (not location path)"
+msgstr "Nome della nuova LOCATION (non il percorso della location)"
-#~ msgid "New GISDBASE (full path to the directory where the new location is)"
-#~ msgstr ""
-#~ "Nuovo GISDBASE (percorso intero della directory dove la nuova location è "
-#~ "situata)"
+msgid "New GISDBASE (full path to the directory where the new location is)"
+msgstr "Nuovo GISDBASE (percorso intero della directory dove la nuova location è situata)"
 #, fuzzy
-#~ msgid "Name for output file (do not add extension)"
+msgid "Name for output file (do not add extension)"
 #, fuzzy
-#~ msgid "Width and height of output image"
-#~ msgstr "Spessore dell'evidenziazione"
+msgid "Width and height of output image"
+msgstr "Spessore dell'evidenziazione"
-#~ msgid "Surface"
-#~ msgstr "Superficie"
+msgid "Surface"
+msgstr "Superficie"
 #, fuzzy
-#~ msgid "Volume"
-#~ msgstr "colonne: %d"
+msgid "Volume"
+msgstr "colonne: %d"
 #, fuzzy
-#~ msgid "Layer where to add column"
+msgid "Layer where to add column"
+#, fuzzy
+msgid "Unable to read symbol, unable todisplay points"
+#, fuzzy
+#~ msgid "Location of input raster map"
+#~ msgstr "Nome di  2-%d mappe raster in input"
+#, fuzzy
+#~ msgid "Mapset of input raster map"
+#, fuzzy
+#~ msgid "Checking location <%s>, mapset <%s>..."
+#~ msgstr "Mappa raster in input"
+#, fuzzy
+#~ msgid "Can't open range file for %s"
+#~ msgstr "Non riesco ad impostare user/password"
+#, fuzzy
+#~ msgid "Can't read row in input elevation map"
+#, fuzzy
+#~ msgid "<%s> created"
+#~ msgstr "Location %s creata!"
+#, fuzzy
+#~ msgid "Unable to open rules file <%s>"
+#~ msgstr "Non riesco ad aprire il cellfile per [%s]"
+#, fuzzy
+#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
+#~ msgstr "Seleziona il tipo di carattere con cui il testo deve essere rappresentato nel monitor grafico dell'utente."
+#, fuzzy
+#~ msgid "Raster map to be displayed"
+#~ msgstr "Mappa(e) raster da leggere"
+#, fuzzy
+#~ msgid "Displays vector data in the active frame on the graphics monitor."
+#, fuzzy
+#~ msgid "vector, projection"
+#~ msgstr "Nome del raster"
+#~ msgid "Allows projection conversion of vector maps."
+#~ msgstr "Permette la conversione di proiezione per vettoriali"
+#~ msgid "Raster value"
+#~ msgstr "Valore del raster"
+#, fuzzy
+#~ msgid "Vector output map"
+#~ msgstr "Mappa vettoriale in uscita"
+#, fuzzy
+#~ msgid "Error while writing to temp file"
+#~ msgstr "Errore durante la scrittura sul file temporaneo"
+#, fuzzy
+#~ msgid "Error writing row %d"
+#~ msgstr "Errore durante la scrittura della riga %d"
+#, fuzzy
+#~ msgid "Cannot generate the transformation equation."
+#~ msgstr "Stampa matrice di correlazione"
+#~ msgid "Unable to write temp file: %s"
+#~ msgstr "Impossibile scrivere il file temp: %s"
+#~ msgid "Unable to open map %s"
+#~ msgstr "Impossibile aprire la mappa %s"
+#~ msgid "Unable to write row %d"
+#~ msgstr "Impossibile scrivere la riga %d"
+#, fuzzy
+#~ msgid "%s@%s: projection doesn't match current settings"
+#~ msgstr "Sto uscendo. Senza cambiare le impostazioni correnti"
+#, fuzzy
+#~ msgid "%s@%s: zone doesn't match current settings"
 #~ msgid "New MAPSET name"
 #~ msgstr "Nome del nuovo MAPSET"
@@ -35647,14 +33622,8 @@
 #~ msgid "Failed in attempt to open %s"
-#~ msgid ""
-#~ "Generates raster map layers of slope, aspect, curvatures and partial "
-#~ "derivatives from a raster map layer of true elevation values. Aspect is "
-#~ "calculated counterclockwise from east."
-#~ msgstr ""
-#~ "Genera raster della pendenza, esposizione, curvature e le derivate "
-#~ "parziali da un raster con valori dell'elevazione. Esposizione è calcolata "
-#~ "in senso antiorario partendo dall'est."
+#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
+#~ msgstr "Genera raster della pendenza, esposizione, curvature e le derivate parziali da un raster con valori dell'elevazione. Esposizione è calcolata in senso antiorario partendo dall'est."
 #, fuzzy
 #~ msgid "Output slope filename"
@@ -35678,67 +33647,45 @@
 #, fuzzy
 #~ msgid "Name of vector input map containing stream(s)"
-#~ msgstr "Nome della mappa raster che contiene i risultati"
+#~ msgstr "Nome della mappa vettoriale che contiene i corsi d'acqua"
 #, fuzzy
 #~ msgid "Name of terrain raster map (DEM)"
-#~ msgstr "Nome del driver in input"
+#~ msgstr "Nome della mappa raster del terreno (DEM)"
 #, fuzzy
 #~ msgid "Name for output raster map with lake"
+#~ msgstr "Nome per la mappa raster di output con il lago"
 #, fuzzy
 #~ msgid "Name of the elevation raster map [m]"
+#~ msgstr "Nome della mappa raster di elevazione [m]"
 #, fuzzy
 #~ msgid "Output water depth raster map [m]"
-#~ msgstr "Nome della tabella in output"
+#~ msgstr "Mappa raster di output delle altezze d'acqua"
 #, fuzzy
 #~ msgid "Input elevation raster map"
+#~ msgstr "Mappa raster di elevazione in input"
 #, fuzzy
 #~ msgid "Input aspect raster map"
+#~ msgstr "Mappa raster delle esposizioni in input"
 #, fuzzy
-#~ msgid "Input barrier raster map"
-#, fuzzy
-#~ msgid "Output flowline vector map"
-#, fuzzy
-#~ msgid "East coordinate (point of interest, default: map center)"
-#~ msgstr "Utilizzando le coordinate del centro della mappa\n"
-#, fuzzy
-#~ msgid "North coordinate (point of interest, default: map center)"
-#, fuzzy
 #~ msgid "(i)   Elevation map"
-#~ msgstr "Mappa raster in input"
+#~ msgstr "(i)   Mappa di elevazione"
 #, fuzzy
 #~ msgid "Reading map..."
+#~ msgstr "Lettura della mappa in corso..."
-#, fuzzy
-#~ msgid "The map N grid coordinates"
 #~ msgid "                No topology present"
 #~ msgstr "                Nessuna topologia presente"
 #~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr ""
-#~ "Usa un vettoriale di punti per produrre un vettoriale di poligoni "
-#~ "convessi."
+#~ msgstr "Usa un vettoriale di punti per produrre un vettoriale di poligoni convessi."
 #, fuzzy
 #~ msgid "Name of input vector points map"
@@ -35781,7 +33728,7 @@
 #, fuzzy
 #~ msgid "Name of the longitude input raster map [decimal degrees]"
+#~ msgstr "Nome della mappa raster delle longitudini di input [gradi decimali]"
 #, fuzzy
 #~ msgid "Starting map [%s]"
@@ -35791,47 +33738,19 @@
 #~ msgstr "Percentuale fatta:"
 #, fuzzy
-#~ msgid "Could not read east bufferzone size. Aborting."
-#, fuzzy
-#~ msgid "Could not read west bufferzone size. Aborting."
-#, fuzzy
-#~ msgid "Could not read south bufferzone size. Aborting."
-#, fuzzy
-#~ msgid "Could not read north bufferzone size. Aborting."
-#, fuzzy
-#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
-#, fuzzy
 #~ msgid "Lat/Long location is not supported"
+#~ msgstr "La location Lat/Long non è supportata"
 #, fuzzy
-#~ msgid "Unable to read symbol, unable todisplay points"
-#, fuzzy
 #~ msgid "Cannot allocate %d bytes of memory"
+#~ msgstr "Impossibile allocare % byte di memoria"
 #~ msgid "Exporting %i points/lines..."
 #~ msgstr "Esportando %i punti/linee..."
 #, fuzzy
-#~ msgid "Writing edges..."
-#, fuzzy
 #~ msgid "Raster map to use as MASK"
-#~ msgstr "Mappa(e) raster da leggere"
+#~ msgstr "Mappa raster da usare come MASK"
 #~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
 #~ msgstr "Categorie dei valori da usare per la MASK (formato: 1 2 3 thru 7 *)"
@@ -35840,80 +33759,68 @@
 #~ msgstr "Crea una MASK inversa da un specificata lista di 'maskcats'"
 #, fuzzy
-#~ msgid "Name of raster map with seed (at least 1 cell > 0)"
-#~ msgstr "Nome della mappa raster da utilizzare per <%s>"
-#, fuzzy
 #~ msgid "Name of the water depth raster map [m]"
-#~ msgstr "Nome del file raster in input"
+#~ msgstr "Nome della mappa raster delle altezze d'acqua [m]"
 #, fuzzy
 #~ msgid "Name of the x-derivatives raster map [m/m]"
+#~ msgstr "Nome della mappa raster delle derivate rispetto a x [m/m]"
 #, fuzzy
 #~ msgid "Name of the y-derivatives raster map [m/m]"
+#~ msgstr "Nome della mappa raster delle derivate rispetto a y [m/m]"
 #, fuzzy
 #~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#~ msgstr "Nome della mappa raster del coefficiente della capacità di distacco [s/m]"
 #, fuzzy
 #~ msgid "Name of the transport capacity coefficient raster map [s]"
+#~ msgstr "Nome della mappa raster del coefficiente della capacità di trasporto [s]"
 #, fuzzy
-#~ msgid "Name of the critical shear stress raster map [Pa]"
-#, fuzzy
 #~ msgid "Name of the Mannings n raster map"
+#~ msgstr "Nome della mappa raster dei coefficienti n di Manning"
 #, fuzzy
 #~ msgid "Name of the Mannings n value"
+#~ msgstr "Nome del valore del coefficiente n di Manning"
 #, fuzzy
 #~ msgid "Output transport capacity raster map [kg/ms]"
+#~ msgstr "Mappa raster della capacità di trasporto [kg/ms]"
 #, fuzzy
-#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
-#, fuzzy
 #~ msgid "Output sediment concentration raster map [particle/m3]"
-#~ msgstr "Visualizza il raster della direzione"
+#~ msgstr "Mappa raster di output della concentrazione di sedimenti [parcicelle/m3]"
 #, fuzzy
 #~ msgid "Output sediment flux raster map [kg/ms]"
+#~ msgstr "Mappa raster di output del flusso dei sedimenti [kg/ms]"
 #, fuzzy
 #~ msgid "Output erosion-deposition raster map [kg/m2s]"
+#~ msgstr "Mappa raster di output di erosione-deposizione [kg/m2s]"
 #, fuzzy
 #~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+#~ msgstr "Nome della mappa raster del tasso di pioggia eccedente (intensità di pioggia - velocità di infiltrazione) [mm/h]"
 #, fuzzy
 #~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+#~ msgstr "Nome della mappa raster della velocità di infiltrazione del deflusso superficiale [mm/h]"
 #, fuzzy
 #~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+#~ msgstr "Nome della mappa raster delle strutture per il controllo del flusso(coeff. di permeabilità 0-1)"
 #, fuzzy
 #~ msgid "Output water discharge raster map [m3/s]"
-#~ msgstr "Nome del driver in output"
+#~ msgstr "Mappa raster di output delle portate [m3/s]"
 #, fuzzy
 #~ msgid "Output simulation error raster map [m]"
+#~ msgstr "Mappa raster di output degli errori di simulazione [m]"
 #~ msgid "Name of existing raster map containing elevation surface"
 #~ msgstr "Nome di una mappa raster contenente una superfice di altezze"
@@ -35930,39 +33837,42 @@
 #~ msgid "Name of elevation raster map"
 #~ msgstr "Nome della mappa raster dell'elevazione"
-#~ msgid ""
-#~ "Creates a new map layer whose category values are based upon a "
-#~ "reclassification of the categories in an existing raster map layer."
-#~ msgstr ""
-#~ "Crea un nuovo layer dove i valori della categoria sono basati sulla "
-#~ "riclassificazione delle categorie esistenti in un altro raster"
+#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
+#~ msgstr "Crea un nuovo layer dove i valori delle categorie sono basati sulla riclassificazione delle categorie esistenti in un altro raster"
 #~ msgid "Converts a raster map into a vector map layer."
 #~ msgstr "Converte un raster in un vettore"
-#, fuzzy
-#~ msgid "The map E grid coordinates"
+#~ msgid "Name of file with sql statement"
+#~ msgstr "Nome del file con l'istruzione sql"
 #, fuzzy
-#~ msgid "Output flowpath length raster map"
+#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
+#~ msgstr "Importa mappe vettoriali Mapgen o Matlab-ASCII in GRASS"
 #, fuzzy
-#~ msgid "Output flowline density raster map"
+#~ msgid "raster, terrain analysis"
+#~ msgstr "Nome della mappa raster da utilizzare per <%s>"
-#, fuzzy
-#~ msgid "Output topographic index map"
+#~ msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
+#~ msgstr "Altezza d'acqua di soglia [m] (la diffusione aumenta una volta raggiuntaquesta altezza)"
-#~ msgid "Name of file with sql statement"
-#~ msgstr "Nome del file con comandi sql"
+#~ msgid "Watershed basin analysis program."
+#~ msgstr "Programma per l'analisi dei bacini idrografici."
-#, fuzzy
-#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
-#~ msgstr "Importa vettori Mapgen o Matlab in GRASS"
+#~ msgid "Raster File Series to MPEG Conversion Program."
+#~ msgstr "Programma di conversione per serie di file raster in MPEG"
+#~ msgid "Stream width (in meters). Default is raster cell width"
+#~ msgstr "Ampiezza del corso d'acqua (in metri). Il valore predefinito è l'ampiezza della cella del raster"
+#~ msgid "Calculates linear regression from two raster maps: y = a + b*x"
+#~ msgstr "Calcola la regressione lineare per due raster: y = a + b*x"
 #, fuzzy
-#~ msgid "raster, terrain analysis"
+#~ msgid ""
+#~ "Input raster map <%s> does not exist in group <%s>.\n"
+#~ " Try:\n"
+#~ msgstr ""
+#~ "La mappa raster <%s> non esiste nel gruppo <%s>.\n"
+#~ " Provare:\n"
Modified: grass/branches/develbranch_6/translators.csv
--- grass/branches/develbranch_6/translators.csv	2011-03-11 20:20:51 UTC (rev 45635)
+++ grass/branches/develbranch_6/translators.csv	2011-03-11 20:21:36 UTC (rev 45636)
@@ -34,6 +34,7 @@
 Luciano Montanaro,<mikelima cirulla.net>,IT
 Tobias Vigl,<vigltobias icqmail.com>,IT
 Stefano Costa,<steko iosa.it>,IT
+Marco Curreli,<marcocurreli tiscali it>,IT
 Susumu Nonogaki,<nonogaki sci.osaka-cu.ac.jp>,JA
 Naoki Ueda,<nao locapoint.com>,JA
 Akira Taniguchi,<taniguti apptec.co.jp>,JA
