[GRASS-SVN] r49102 - in grass-addons/raster/LandDyn/devs_landcover_scripts: . r.villages.py
Fri Nov 4 19:07:34 EDT 2011
Author: isaacullah
Date: 2011-11-04 16:07:34 -0700 (Fri, 04 Nov 2011)
New Revision: 49102
Added:
   grass-addons/raster/LandDyn/devs_landcover_scripts/r.villages.py/
   grass-addons/raster/LandDyn/devs_landcover_scripts/r.villages.py/r.villages.py
New script needed by ApSim to make village clearings.
Added: grass-addons/raster/LandDyn/devs_landcover_scripts/r.villages.py/r.villages.py
--- grass-addons/raster/LandDyn/devs_landcover_scripts/r.villages.py/r.villages.py	                        (rev 0)
+++ grass-addons/raster/LandDyn/devs_landcover_scripts/r.villages.py/r.villages.py	2011-11-04 23:07:34 UTC (rev 49102)
@@ -0,0 +1,103 @@
+#!/usr/bin/pythonr.villages.py
+# MODULE:       	r.villages
+# AUTHOR(S):		Isaac Ullah, Michael Barton, Arizona State University
+# PURPOSE:		patches a map of village locations on a landcover landcover map
+# ACKNOWLEDGEMENTS:	National Science Foundation Grant #BCS0410269
+# COPYRIGHT:		(C) 2009 by Isaac Ullah, Michael Barton, Arizona State University
+#			This program is free software under the GNU General Public
+#			License (>=v2). Read the file COPYING that comes with GRASS
+#			for details.
+#%Module
+#%  description: patches a map of village locations on a landcover landcover map
+#%END
+#%option
+#% key: inmap
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: input landcover map
+#% required : yes
+#%END
+#%option
+#% key: villages
+#% type: string
+#% description: input map of village locations (coded as all one value)
+#% required : yes
+#%END
+#%option
+#% key: val
+#% type: integer
+#% answer: 40
+#% description: value for villages to be coded onto output map
+#% required : yes
+#%END
+#%option
+#% key: output
+#% type: string
+#% gisprompt: string
+#% description: name for output map
+#% answer: year1
+#% required : yes
+#%END
+import sys
+import os
+import subprocess
+import tempfile
+grass_install_tree = os.getenv('GISBASE')
+sys.path.append(grass_install_tree + os.sep + 'etc' + os.sep + 'python')
+import grass.script as grass
+# m is a grass/bash command that will generate some info to stdout. You must invoke this command in the form of "variable to be made" = out2var('command')
+def out2var(m):
+        pn = subprocess.Popen('%s' % m, stdout=subprocess.PIPE, shell='bash')
+        return pn.stdout.read()
+#main block of code starts here
+def main():
+    #setting up variables for use later on
+    inmap = os.getenv('GIS_OPT_inmap')
+    villages = os.getenv('GIS_OPT_villages')
+    val = os.getenv('GIS_OPT_val')
+    outmap = os.getenv('GIS_OPT_output')
+    temp_villages = outmap + '_temporary_village_reclass'
+    #setting initial conditions of map area
+    grass.run_command('r.mask', quiet = True, input = inmap, maskcats = '*')
+    #discovering the value of the input villages map
+    inval = grass.read_command('r.stats',  flags = 'n',  input = villages, fs = 'space', nv = '*', nsteps = '1')
+    #setting up color and reclass rules
+    colors = tempfile.NamedTemporaryFile()
+    colors.write('%s red' % val)
+    colors.flush()
+    reclass =  tempfile.NamedTemporaryFile()
+    reclass.write('%s = %s Village\n' % (inval.strip('\n'),  val))
+    reclass.flush()
+    #doing reclass and recolor
+    grass.run_command('r.reclass', quiet = True, input = villages, output = temp_villages, rules = reclass.name)
+    grass.run_command('r.colors', quiet = True,  map = temp_villages, rules = colors.name)
+    #patching maps together
+    grass.run_command('r.patch', quiet = True,  input = temp_villages + ',' + inmap, output= outmap)
+    grass.message('\nCleaning up...\n')
+    grass.run_command('g.remove', quiet = True, rast ='MASK,' + temp_villages)
+    colors.close()
+    reclass.close()
+    grass.message('\n\nDONE!\n')
+# here is where the code in "main" actually gets executed. This way of programming is neccessary for the way g.parser needs to run.
+if __name__ == "__main__":
+    if ( len(sys.argv) <= 1 or sys.argv[1] != "@ARGS_PARSED@" ):
+        os.execvp("g.parser", [sys.argv[0]] + sys.argv)
+    else:
+        main()
Property changes on: grass-addons/raster/LandDyn/devs_landcover_scripts/r.villages.py/r.villages.py
___________________________________________________________________
Added: svn:executable
