[GRASS-SVN] r53725 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Wed Nov 7 13:05:12 PST 2012
Author: neteler
Date: 2012-11-07 13:05:11 -0800 (Wed, 07 Nov 2012)
New Revision: 53725
grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po
Sylvain Maillard: cont'ed
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po 2012-11-07 20:32:06 UTC (rev 53724)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po 2012-11-07 21:05:11 UTC (rev 53725)
@@ -10,7 +10,7 @@
"Project-Id-Version: grasswxpy_fr\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2012-11-05 10:54+0100\n"
-"PO-Revision-Date: 2012-10-11 20:52+0200\n"
+"PO-Revision-Date: 2012-11-07 17:44+0100\n"
"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: français <grass-translations at lists.osgeo.org>\n"
"Language: fr\n"
@@ -64,15 +64,12 @@
msgstr "Inclinaison :"
#: ../gui/wxpython/nviz/tools.py:263
-msgid ""
-"Adjusts the viewing height above the surface (angle of view automatically "
-"adjusts to maintain the same center of view)"
+msgid "Adjusts the viewing height above the surface (angle of view automatically adjusts to maintain the same center of view)"
msgstr ""
#: ../gui/wxpython/nviz/tools.py:268
-#, fuzzy
msgid "Adjusts the relative height of features above the plane of the surface"
-msgstr "Ajuster la hauteur de la vue au dessus de la scène"
+msgstr "Ajuster la hauteur relative des objets au dessus de la surface"
#: ../gui/wxpython/nviz/tools.py:276 ../gui/wxpython/nviz/tools.py:1036
#: ../gui/wxpython/nviz/tools.py:1674 ../gui/wxpython/gui_core/dialogs.py:2189
@@ -97,12 +94,8 @@
msgstr "curseur"
#: ../gui/wxpython/nviz/tools.py:301
-msgid ""
-"Allows you to select a point on the surface that becomes the new center of "
-"view. Click on the button and then on the surface."
-msgstr ""
-"Permet de sélectionner un point sur la surface qui deviendra le nouveau "
-"centre de la vue. Cliquer sur le bouton puis sur la surface."
+msgid "Allows you to select a point on the surface that becomes the new center of view. Click on the button and then on the surface."
+msgstr "Permet de sélectionner un point sur la surface qui deviendra le nouveau centre de la vue. Cliquer sur le bouton puis sur la surface."
#: ../gui/wxpython/nviz/tools.py:307
msgid "center"
@@ -117,12 +110,8 @@
msgstr "nord"
#: ../gui/wxpython/nviz/tools.py:317
-msgid ""
-"Sets the viewer directly over the scene's center position. This top view "
-"orients approximately north south."
-msgstr ""
-"Définir la vue directement au dessus du centre de la scène. Cette vue du "
-"haut est orientée approximativement nord-sud."
+msgid "Sets the viewer directly over the scene's center position. This top view orients approximately north south."
+msgstr "Définir la vue directement au dessus du centre de la scène. Cette vue du haut est orientée approximativement nord-sud."
#: ../gui/wxpython/nviz/tools.py:321
msgid "reset"
@@ -142,14 +131,8 @@
msgstr "Couleur d'arrière-plan :"
#: ../gui/wxpython/nviz/tools.py:385
-#, fuzzy
-msgid ""
-"Press 'Record' button and start changing the view. It is recommended to use "
-"fly-through mode (Map Display toolbar) to achieve smooth motion."
-msgstr ""
-"Appuyez sur le bouton 'Enregistrer' et commencez à changer la vue. Il est "
-"recommandé d'utiliser le mode avion (barre d'outils d'affichage) pour "
-"obtenir un déplacement fluide."
+msgid "Press 'Record' button and start changing the view. It is recommended to use fly-through mode (Map Display toolbar) to achieve smooth motion."
+msgstr "Appuyez sur le bouton 'Enregistrer' et commencez à changer la vue. Il est recommandé d'utiliser le mode avion (barre d'outils d'affichage) pour obtenir un déplacement fluide."
#: ../gui/wxpython/nviz/tools.py:396
msgid "Record"
@@ -213,11 +196,8 @@
msgstr "Préfix :"
#: ../gui/wxpython/nviz/tools.py:483
-msgid ""
-"Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
-msgstr ""
-"Les noms de fichiers générés ressembleront à ceci : prefix_1.ppm, prefix_2."
-"ppm, ..."
+msgid "Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
+msgstr "Les noms de fichiers générés ressembleront à ceci : prefix_1.ppm, prefix_2.ppm, ..."
#: ../gui/wxpython/nviz/tools.py:484
msgid "File format:"
@@ -249,14 +229,12 @@
msgstr "Frange"
#: ../gui/wxpython/nviz/tools.py:606
-#, fuzzy
msgid "Decorations"
-msgstr "Description"
+msgstr "Décorations"
#: ../gui/wxpython/nviz/tools.py:626 ../gui/wxpython/nviz/tools.py:937
-#, fuzzy
msgid "Cutting planes"
-msgstr "Plan de coupe"
+msgstr "Plans de coupe"
#: ../gui/wxpython/nviz/tools.py:648 ../gui/wxpython/nviz/mapwindow.py:1611
#: ../gui/wxpython/psmap/dialogs.py:1143
@@ -397,9 +375,8 @@
msgstr "Revenir à la position par défaut"
#: ../gui/wxpython/nviz/tools.py:943
-#, fuzzy
msgid "Active cutting plane:"
-msgstr "Activer les plans de coupe"
+msgstr "Activer les plans de coupe :"
#: ../gui/wxpython/nviz/tools.py:955
msgid "clear"
@@ -450,12 +427,8 @@
msgstr "Effectue une rotation sur l'axe horizontal du plan de coupe"
#: ../gui/wxpython/nviz/tools.py:1038
-msgid ""
-"Sets the Z coordinate of the current cutting plane (only meaningful when "
-"tilt is not 0)"
-msgstr ""
-"Définit la coordonnée Z du plan de coupe actuel (n'a de sens que si "
-"l'inclinaison n'est pas à 0)"
+msgid "Sets the Z coordinate of the current cutting plane (only meaningful when tilt is not 0)"
+msgstr "Définit la coordonnée Z du plan de coupe actuel (n'a de sens que si l'inclinaison n'est pas à 0)"
#: ../gui/wxpython/nviz/tools.py:1090 ../gui/wxpython/menustrings.py:4
#: ../gui/wxpython/menustrings.py:858
@@ -671,9 +644,7 @@
#: ../gui/wxpython/nviz/tools.py:1958
msgid "Do you want to record new animation without saving the previous one?"
-msgstr ""
-"Voulez-vous enregistrer une nouvelle animation sans sauvegarder la "
-"précédente ?"
+msgstr "Voulez-vous enregistrer une nouvelle animation sans sauvegarder la précédente ?"
#: ../gui/wxpython/nviz/tools.py:1961
msgid "Animation already axists"
@@ -782,9 +753,8 @@
msgstr "%(features)d primitives (%(points)d points)"
#: ../gui/wxpython/nviz/tools.py:4647
-#, fuzzy
msgid "range:"
-msgstr "fourchette"
+msgstr "intervalle:"
# Easting et Northing sont ici traduits resp. Abscisse et Ordonnée, désignant plutôt des valeurs numériques que des directions cardinales.
#: ../gui/wxpython/nviz/tools.py:4715 ../gui/wxpython/nviz/tools.py:4726
@@ -835,12 +805,8 @@
msgstr ""
#: ../gui/wxpython/nviz/tools.py:4872
-msgid ""
-"Adjusts the light direction. Click and drag the puck to change the light "
-"direction."
-msgstr ""
-"Ajuster la direction de la lumière. Cliquez et déplacez le point pour "
-"changer l'origine de la lumière."
+msgid "Adjusts the light direction. Click and drag the puck to change the light direction."
+msgstr "Ajuster la direction de la lumière. Cliquez et déplacez le point pour changer l'origine de la lumière."
#: ../gui/wxpython/nviz/preferences.py:31
msgid "3D view settings"
@@ -848,8 +814,7 @@
#: ../gui/wxpython/nviz/preferences.py:48
msgid "Revert settings to default, changes are not applied"
-msgstr ""
-"Revenir aux réglages par défaut, les changements ne seront pas appliqués"
+msgstr "Revenir aux réglages par défaut, les changements ne seront pas appliqués"
#: ../gui/wxpython/nviz/preferences.py:71
#: ../gui/wxpython/nviz/preferences.py:134
@@ -927,16 +892,8 @@
msgstr "Paramètres de vue 3D enregistrés dans le fichier %s."
#: ../gui/wxpython/nviz/wxnviz.py:32 ../gui/wxpython/wxplot/profile.py:31
-msgid ""
-"This module requires the NumPy module, which could not be imported. It "
-"probably is not installed (it's not part of the standard Python "
-"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
-"information on downloading source or binaries."
-msgstr ""
-"Ce module requiert le module NumPy, qui n'a pas pu êter importé. Il n'est "
-"probablement pas installé (n'est pas compris dans la distribution standard "
-"Python). Voir le site Numeric Python (http://numpy.scipy.org) pour "
-"télécharger les binaires ou le code source."
+msgid "This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries."
+msgstr "Ce module requiert le module NumPy, qui n'a pas pu êter importé. Il n'est probablement pas installé (n'est pas compris dans la distribution standard Python). Voir le site Numeric Python (http://numpy.scipy.org) pour télécharger les binaires ou le code source."
#: ../gui/wxpython/nviz/wxnviz.py:49
#, python-format
@@ -961,12 +918,8 @@
#: ../gui/wxpython/nviz/mapwindow.py:506
#, python-format
-msgid ""
-"Image is too large, your OpenGL implementation supports maximum texture size "
-"%d px."
-msgstr ""
-"L'image est trop grande, votre installation OpenGL supporte une taille de "
-"texture d'un maximum de %d pixels."
+msgid "Image is too large, your OpenGL implementation supports maximum texture size %d px."
+msgstr "L'image est trop grande, votre installation OpenGL supporte une taille de texture d'un maximum de %d pixels."
#: ../gui/wxpython/nviz/mapwindow.py:768
#: ../gui/wxpython/mapdisp/mapwindow.py:1121
@@ -1172,9 +1125,7 @@
#: ../gui/wxpython/lmgr/frame.py:360 ../gui/wxpython/gis_set.py:427
msgid "Do you want to set the default region extents and resolution now?"
-msgstr ""
-"Voulez-vous définir les limites et la résolution la région par défaut "
-"maintenant ?"
+msgstr "Voulez-vous définir les limites et la résolution la région par défaut maintenant ?"
#: ../gui/wxpython/lmgr/frame.py:362 ../gui/wxpython/gis_set.py:429
#, python-format
@@ -1209,9 +1160,7 @@
#: ../gui/wxpython/lmgr/frame.py:586
msgid "Editing is allowed only for vector maps from the current mapset."
-msgstr ""
-"L'édition n'est permise que pour des cartes vectorielles du jeux de cartes "
-"actuel."
+msgstr "L'édition n'est permise que pour des cartes vectorielles du jeux de cartes actuel."
#: ../gui/wxpython/lmgr/frame.py:601
msgid "Choose script file to run"
@@ -1228,12 +1177,8 @@
#: ../gui/wxpython/lmgr/frame.py:621
#, python-format
-msgid ""
-"Script <%s> is not executable. Do you want to set the permissions that "
-"allows you to run this script (note that you must be the owner of the file)?"
-msgstr ""
-"Le script <%s> n'est pas exécutable. Voulez-vous définir les permissions "
-"d'exécution du script (vous devez être l'utilisateur propriétaire) ?"
+msgid "Script <%s> is not executable. Do you want to set the permissions that allows you to run this script (note that you must be the owner of the file)?"
+msgstr "Le script <%s> n'est pas exécutable. Voulez-vous définir les permissions d'exécution du script (vous devez être l'utilisateur propriétaire) ?"
#: ../gui/wxpython/lmgr/frame.py:626
msgid "Set permission?"
@@ -1245,12 +1190,8 @@
#: ../gui/wxpython/lmgr/frame.py:646
#, python-format
-msgid ""
-"Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
-"directory to GRASS_ADDON_PATH?"
-msgstr ""
-"Le dossier '%s' n'est pas définit dans GRASS_ADDON_PATH. Voulez-vous ajouter "
-"ce dossier à GRASS_ADDON_PATH ?"
+msgid "Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this directory to GRASS_ADDON_PATH?"
+msgstr "Le dossier '%s' n'est pas définit dans GRASS_ADDON_PATH. Voulez-vous ajouter ce dossier à GRASS_ADDON_PATH ?"
#: ../gui/wxpython/lmgr/frame.py:649
msgid "Update Addons path?"
@@ -1292,34 +1233,27 @@
#: ../gui/wxpython/lmgr/frame.py:765
msgid "System Info"
-msgstr ""
+msgstr "Information système"
#: ../gui/wxpython/lmgr/frame.py:773
-#, fuzzy
msgid "GRASS version"
-msgstr "Démarrer une session GRASS"
+msgstr "Version de GRASS"
#: ../gui/wxpython/lmgr/frame.py:774
-#, fuzzy
msgid "GRASS SVN Revision"
msgstr "Version SVN :"
#: ../gui/wxpython/lmgr/frame.py:775 ../gui/wxpython/gui_core/ghelp.py:439
-#, fuzzy
msgid "GIS Library Revision"
-msgstr "Révision de Bibliothèque SIG :"
+msgstr "Version de la bibliothèque SIG :"
#: ../gui/wxpython/lmgr/frame.py:779
msgid "Platform"
-msgstr ""
+msgstr "Plateforme"
#: ../gui/wxpython/lmgr/frame.py:831
-msgid ""
-"Current workspace is not empty. Do you want to store current settings to "
-"workspace file?"
-msgstr ""
-"L'espace de travail n'est pas vide. Voulez-vous enregistrer les paramètres "
-"actuels dans un fichier ?"
+msgid "Current workspace is not empty. Do you want to store current settings to workspace file?"
+msgstr "L'espace de travail n'est pas vide. Voulez-vous enregistrer les paramètres actuels dans un fichier ?"
#: ../gui/wxpython/lmgr/frame.py:834
msgid "Create new workspace?"
@@ -1361,9 +1295,7 @@
#: ../gui/wxpython/lmgr/frame.py:1066 ../gui/wxpython/lmgr/frame.py:1082
#, python-format
msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
-msgstr ""
-"Le fichier d'environnement <%s> existe déjà. Voulez-vous écraser ce "
-"fichier ?"
+msgstr "Le fichier d'environnement <%s> existe déjà. Voulez-vous écraser ce fichier ?"
#: ../gui/wxpython/lmgr/frame.py:1068 ../gui/wxpython/lmgr/frame.py:1085
#: ../gui/wxpython/menustrings.py:9
@@ -1387,8 +1319,7 @@
#: ../gui/wxpython/lmgr/frame.py:1163
#, python-format
msgid "GRASS GIS Map Display: %(name)s - Location: %(loc)s"
-msgstr ""
-"SIG GRASS - Moniteur d'affichage des cartes : %(name)s - Secteur : %(loc)s"
+msgstr "SIG GRASS - Moniteur d'affichage des cartes : %(name)s - Secteur : %(loc)s"
#: ../gui/wxpython/lmgr/frame.py:1375
msgid "Nothing to import. No WMS layer selected."
@@ -1408,12 +1339,8 @@
msgstr "Type de couche <%s> non pris en charge"
#: ../gui/wxpython/lmgr/frame.py:1640
-msgid ""
-"Note that cell values can only be displayed for regions of less than 10,000 "
-"cells."
-msgstr ""
-"A noter que les valeurs des cellules ne peuvent être affichées que pour les "
-"régions de moins de 10 000 cellules."
+msgid "Note that cell values can only be displayed for regions of less than 10,000 cells."
+msgstr "A noter que les valeurs des cellules ne peuvent être affichées que pour les régions de moins de 10 000 cellules."
#: ../gui/wxpython/lmgr/frame.py:1722
#, python-format
@@ -1428,9 +1355,7 @@
#: ../gui/wxpython/lmgr/frame.py:1725
msgid "Do you want to remove selected map layer(s) from layer tree?"
-msgstr ""
-"Voulez-vous retirer la(les) carte(s) sélectionnée(s) de l'arborescence des "
-"couches ?"
+msgstr "Voulez-vous retirer la(les) carte(s) sélectionnée(s) de l'arborescence des couches ?"
#: ../gui/wxpython/lmgr/frame.py:1729
msgid "Remove map layer"
@@ -1451,14 +1376,8 @@
msgstr "Message"
#: ../gui/wxpython/lmgr/frame.py:1835
-msgid ""
-"Display resolution is currently not constrained to computational settings. "
-"It's suggested to constrain map to region geometry. Do you want to constrain "
-"the resolution?"
-msgstr ""
-"La résolution de l'affichage n'est actuellement pas restreint aux limite de "
-"la région de calculs. Il est suggéré de restreindre les cartes aux limites "
-"de la région. Voulez-vous restreindre la résolution ?"
+msgid "Display resolution is currently not constrained to computational settings. It's suggested to constrain map to region geometry. Do you want to constrain the resolution?"
+msgstr "La résolution de l'affichage n'est actuellement pas restreint aux limite de la région de calculs. Il est suggéré de restreindre les cartes aux limites de la région. Voulez-vous restreindre la résolution ?"
#: ../gui/wxpython/lmgr/frame.py:1844
msgid "Constrain map to region geometry?"
@@ -1699,8 +1618,7 @@
#: ../gui/wxpython/lmgr/layertree.py:159
#, python-format
msgid "GRASS GIS Map Display: %(id)d - Location: %(loc)s"
-msgstr ""
-"SIG GRASS - Moniteur d'affichage des cartes : %(id)d - Secteur : %(loc)s"
+msgstr "SIG GRASS - Moniteur d'affichage des cartes : %(id)d - Secteur : %(loc)s"
#: ../gui/wxpython/lmgr/layertree.py:169
msgid "Map Layers"
@@ -1734,8 +1652,7 @@
#: ../gui/wxpython/lmgr/layertree.py:362
msgid "Set computational region from selected map(s)"
-msgstr ""
-"Définir la région calculée à partir de la(des) carte(s) sélectionnée(s)"
+msgstr "Définir la région calculée à partir de la(des) carte(s) sélectionnée(s)"
#: ../gui/wxpython/lmgr/layertree.py:374 ../gui/wxpython/lmgr/layertree.py:447
msgid "Export"
@@ -1776,9 +1693,7 @@
#: ../gui/wxpython/lmgr/layertree.py:443
msgid "Set computational region from selected map(s) (ignore NULLs)"
-msgstr ""
-"Définir la région de calcul à partir de la(des) carte(s) sélectionnée(s) "
-"(ignore les NULLs)"
+msgstr "Définir la région de calcul à partir de la(des) carte(s) sélectionnée(s) (ignore les NULLs)"
#: ../gui/wxpython/lmgr/layertree.py:455 ../gui/wxpython/menustrings.py:717
msgid "Histogram"
@@ -1821,9 +1736,7 @@
#: ../gui/wxpython/lmgr/layertree.py:587
msgid "Unable to display histogram of raster map. No map name defined."
-msgstr ""
-"Impossible d'afficher l'histogramme de carte raster. Pas de nom de carte "
-"définit."
+msgstr "Impossible d'afficher l'histogramme de carte raster. Pas de nom de carte définit."
#: ../gui/wxpython/lmgr/layertree.py:667
#, python-format
@@ -2003,12 +1916,8 @@
msgstr "Assistant de création de secteur"
#: ../gui/wxpython/gis_set.py:138
-msgid ""
-"Start location wizard. After location is created successfully, GRASS session "
-"is started."
-msgstr ""
-"Lancement de l'assistant. Une fois qu'un secteur est créé, la session GRASS "
-"sera lancée."
+msgid "Start location wizard. After location is created successfully, GRASS session is started."
+msgstr "Lancement de l'assistant. Une fois qu'un secteur est créé, la session GRASS sera lancée."
#: ../gui/wxpython/gis_set.py:142
msgid "Rename mapset"
@@ -2036,9 +1945,7 @@
#: ../gui/wxpython/gis_set.py:209 ../gui/wxpython/gis_set.py:638
msgid "Unable to set GRASS database. Check your locale settings."
-msgstr ""
-"Impossible de déterminer la base de données GRASS. Vérifiez vos paramètres "
-"de langue."
+msgstr "Impossible de déterminer la base de données GRASS. Vérifiez vos paramètres de langue."
#: ../gui/wxpython/gis_set.py:227
#, python-format
@@ -2057,12 +1964,8 @@
#: ../gui/wxpython/gis_set.py:407
#, python-format
-msgid ""
-"Do you want to import data source <%(name)s> to created location? Default "
-"region will be set to match imported map."
-msgstr ""
-"Voulez-vous importer la source de données <%(name)s> pour créer le secteur ? "
-"la région par défaut sera alignée sur la carte importée."
+msgid "Do you want to import data source <%(name)s> to created location? Default region will be set to match imported map."
+msgstr "Voulez-vous importer la source de données <%(name)s> pour créer le secteur ? la région par défaut sera alignée sur la carte importée."
#: ../gui/wxpython/gis_set.py:411
msgid "Import data"
@@ -2081,9 +1984,7 @@
#: ../gui/wxpython/gis_set.py:475
#, python-format
msgid "Attempt to import data source <%(name)s> as raster or vector failed. "
-msgstr ""
-"L'import de la source de données <%(name)s> en tant que raster ou vecteur a "
-"échoué."
+msgstr "L'import de la source de données <%(name)s> en tant que raster ou vecteur a échoué."
#: ../gui/wxpython/gis_set.py:479
#, python-format
@@ -2096,8 +1997,7 @@
"\n"
"This mapset cannot be renamed."
msgstr ""
-"Le jeu de cartes <PERMANENT> est requis pour qu'un secteur GRASS soit "
-"valide.\n"
+"Le jeu de cartes <PERMANENT> est requis pour qu'un secteur GRASS soit valide.\n"
"\n"
"Ce jeu de cartes ne peut être renommé."
@@ -2170,24 +2070,20 @@
"\n"
"This mapset cannot be deleted."
msgstr ""
-"valide.\n"
"\n"
"Ce jeu de cartes ne peut être supprimé."
#: ../gui/wxpython/gis_set.py:588
#, python-format
msgid ""
-"Do you want to continue with deleting mapset <%(mapset)s> from location <"
-"%(location)s>?\n"
+"Do you want to continue with deleting mapset <%(mapset)s> from location <%(location)s>?\n"
"\n"
"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
msgstr ""
-"Voulez-vous vraiment supprimer le jeu de cartes <%(mapset)s> du secteur <"
-"%(location)s>?\n"
+"Voulez-vous vraiment supprimer le jeu de cartes <%(mapset)s> du secteur <%(location)s>?\n"
"\n"
-"TOUTES LES CARTES incluses dans ce jeu de cartes seront DÉFINITIVEMENT "
-"SUPPRIMÉES !"
+"TOUTES LES CARTES incluses dans ce jeu de cartes seront DÉFINITIVEMENT SUPPRIMÉES !"
#: ../gui/wxpython/gis_set.py:593
msgid "Delete selected mapset"
@@ -2238,16 +2134,14 @@
"\n"
"Concurrent use not allowed.\n"
"\n"
-"Do you want to try to remove .gislock (note that you need permission for "
-"this operation) and continue?"
+"Do you want to try to remove .gislock (note that you need permission for this operation) and continue?"
msgstr ""
"GRASS s'exécute déjà dans le jeu de cartes <%(mapset)s> sélectionné\n"
"(fichier %(lock)s détecté).\n"
"\n"
"L'accès concurrent n'est pas autorisé.\n"
"\n"
-"Souhaitez-vous essayer de supprimer .gislock (notez qu'il vous faut disposer "
-"de droits pour cette opération) et continuer ?"
+"Souhaitez-vous essayer de supprimer .gislock (notez qu'il vous faut disposer de droits pour cette opération) et continuer ?"
#: ../gui/wxpython/gis_set.py:823 ../gui/wxpython/gis_set.py:835
msgid "Lock file found"
@@ -2257,13 +2151,11 @@
msgid ""
"ARE YOU REALLY SURE?\n"
"\n"
-"If you really are running another GRASS session doing this could corrupt "
-"your data. Have another look in the processor manager just to be sure..."
+"If you really are running another GRASS session doing this could corrupt your data. Have another look in the processor manager just to be sure..."
msgstr ""
"ÊTES-VOUS VRAIMENT SÛR ?\n"
"\n"
-"Si vous avez une autre session GRASS en cours, vous risquez de corrompre vos "
-"données. Vérifiez dans votre gestionnaire de tâches pour en être sûr ..."
+"Si vous avez une autre session GRASS en cours, vous risquez de corrompre vos données. Vérifiez dans votre gestionnaire de tâches pour en être sûr ..."
#: ../gui/wxpython/gis_set.py:846
#, python-format
@@ -2281,14 +2173,8 @@
msgstr "Démarrage de GRASS pour la première fois"
#: ../gui/wxpython/gis_set.py:947
-msgid ""
-"GRASS needs a directory in which to store its data. Create one now if you "
-"have not already done so. A popular choice is \"grassdata\", located in your "
-"home directory."
-msgstr ""
-"GRASS nécéssite un dossier dans lequel enregistrer ses données. Créez en un "
-"si vous ne l'avez pas déjà fait. Un choix populaire est « grassdata », dans "
-"votre dossier personnel."
+msgid "GRASS needs a directory in which to store its data. Create one now if you have not already done so. A popular choice is \"grassdata\", located in your home directory."
+msgstr "GRASS nécéssite un dossier dans lequel enregistrer ses données. Créez en un si vous ne l'avez pas déjà fait. Un choix populaire est « grassdata », dans votre dossier personnel."
#: ../gui/wxpython/dbmgr/manager.py:145
msgid "Loading data..."
@@ -2296,12 +2182,8 @@
#: ../gui/wxpython/dbmgr/manager.py:152
#, python-format
-msgid ""
-"Attribute table <%s> not found. For creating the table switch to 'Manage "
-"layers' tab."
-msgstr ""
-"Table d'attributs <%s> non trouvée. Pour créer la table passer à l'onglet "
-"'Gérer les couches'."
+msgid "Attribute table <%s> not found. For creating the table switch to 'Manage layers' tab."
+msgstr "Table d'attributs <%s> non trouvée. Pour créer la table passer à l'onglet 'Gérer les couches'."
#: ../gui/wxpython/dbmgr/manager.py:163
#, python-format
@@ -2314,13 +2196,8 @@
#: ../gui/wxpython/dbmgr/manager.py:244
#, python-format
-msgid ""
-"Inconsistent number of columns in the table <%(table)s>. Try to change field "
-"separator in GUI Settings, Attributes tab, Data browser section."
-msgstr ""
-"Nombre de colonnes de la table <%(table)s> non valide. Essayez de modifier "
-"le séparateur de champs dans les paramètres de l'interface, onglet "
-"Attributs, Naviguateur de données."
+msgid "Inconsistent number of columns in the table <%(table)s>. Try to change field separator in GUI Settings, Attributes tab, Data browser section."
+msgstr "Nombre de colonnes de la table <%(table)s> non valide. Essayez de modifier le séparateur de champs dans les paramètres de l'interface, onglet Attributs, Naviguateur de données."
#: ../gui/wxpython/dbmgr/manager.py:256
msgid "Limit 100000 records."
@@ -2340,21 +2217,16 @@
# Conserver le sigle GUI me semble plus clair pour l'utilisateur que sa traduction française (IGU) peu voire pas usitée.
#: ../gui/wxpython/dbmgr/manager.py:303 ../gui/wxpython/dbmgr/vinfo.py:42
msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
-msgstr ""
-"Valeur impossible à décoder. Fixer l'encodage dans les préférences du GUI "
-"('Attributs')"
+msgstr "Valeur impossible à décoder. Fixer l'encodage dans les préférences du GUI ('Attributs')"
#: ../gui/wxpython/dbmgr/manager.py:312
#, python-format
msgid ""
-"Error loading attribute data. Record number: %(rec)d. Unable to convert "
-"value '%(val)s' in key column (%(key)s) to integer.\n"
+"Error loading attribute data. Record number: %(rec)d. Unable to convert value '%(val)s' in key column (%(key)s) to integer.\n"
"\n"
"Details: %(detail)s"
msgstr ""
-"Erreur au chargement des données attributaires. Numéro d'enregistrement "
-"%(rec)d. Impossible de convertir la valeur '%(val)s' dans la colonne clé "
-"(%(key)s) en nombre entier.\n"
+"Erreur au chargement des données attributaires. Numéro d'enregistrement %(rec)d. Impossible de convertir la valeur '%(val)s' dans la colonne clé (%(key)s) en nombre entier.\n"
"\n"
"Détails: %(detail)s"
@@ -2412,13 +2284,8 @@
#: ../gui/wxpython/dbmgr/manager.py:601
#, python-format
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file. You can "
-"define new connection in 'Manage layers' tab."
-msgstr ""
-"La connexion à une base de données n'est pas définie dans le fichier DB pour "
-"la carte vecteur <%s>. Vous pouvez définir une nouvelle connexion dans "
-"l'onglet 'Gérer les couches'."
+msgid "Database connection for vector map <%s> is not defined in DB file. You can define new connection in 'Manage layers' tab."
+msgstr "La connexion à une base de données n'est pas définie dans le fichier DB pour la carte vecteur <%s>. Vous pouvez définir une nouvelle connexion dans l'onglet 'Gérer les couches'."
#: ../gui/wxpython/dbmgr/manager.py:627
msgid "Browse data"
@@ -2442,8 +2309,7 @@
#: ../gui/wxpython/dbmgr/manager.py:690
msgid "Attribute data - right-click to edit/manage records"
-msgstr ""
-"Données attributaires - clic droit pour éditer/gérer les enregistrements"
+msgstr "Données attributaires - clic droit pour éditer/gérer les enregistrements"
#: ../gui/wxpython/dbmgr/manager.py:703 ../gui/wxpython/dbmgr/manager.py:843
#: ../gui/wxpython/dbmgr/manager.py:2317 ../gui/wxpython/dbmgr/manager.py:2447
@@ -2584,12 +2450,8 @@
#: ../gui/wxpython/dbmgr/manager.py:1187
#, python-format
-msgid ""
-"Selected data records (%d) will be permanently deleted from table. Do you "
-"want to delete them?"
-msgstr ""
-"Les enregistrements sélectionnés (%d) vont être définitivement supprimés de "
-"la table. Souhaitez-vous les supprimer ?"
+msgid "Selected data records (%d) will be permanently deleted from table. Do you want to delete them?"
+msgstr "Les enregistrements sélectionnés (%d) vont être définitivement supprimés de la table. Souhaitez-vous les supprimer ?"
#: ../gui/wxpython/dbmgr/manager.py:1190 ../gui/wxpython/dbmgr/manager.py:1236
#: ../gui/wxpython/gmodeler/dialogs.py:851
@@ -2598,18 +2460,13 @@
#: ../gui/wxpython/dbmgr/manager.py:1233
#, python-format
-msgid ""
-"All data records (%d) will be permanently deleted from table. Do you want to "
-"delete them?"
-msgstr ""
-"Tous les enregistrements (%d) seront définitivement supprimés de la table. "
-"Souhaitez-vous les supprimer ?"
+msgid "All data records (%d) will be permanently deleted from table. Do you want to delete them?"
+msgstr "Tous les enregistrements (%d) seront définitivement supprimés de la table. Souhaitez-vous les supprimer ?"
#: ../gui/wxpython/dbmgr/manager.py:1391
#, python-format
msgid "Record with category number %d already exists in the table."
-msgstr ""
-"L'enregistrement portant la catégorie numéro %d existe déjà dans la table."
+msgstr "L'enregistrement portant la catégorie numéro %d existe déjà dans la table."
#: ../gui/wxpython/dbmgr/manager.py:1401
#, python-format
@@ -2649,21 +2506,13 @@
#: ../gui/wxpython/dbmgr/manager.py:1631
#, python-format
-msgid ""
-"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
-"exists in the table <%(table)s>."
-msgstr ""
-"Impossible de renommer la colonne <%(column)s> en <%(columnTo)s>. La "
-"colonne existe déjà dans la table <%(table)s>."
+msgid "Unable to rename column <%(column)s> to <%(columnTo)s>. Column already exists in the table <%(table)s>."
+msgstr "Impossible de renommer la colonne <%(column)s> en <%(columnTo)s>. La colonne existe déjà dans la table <%(table)s>."
#: ../gui/wxpython/dbmgr/manager.py:1647
#, python-format
-msgid ""
-"Unable to rename column. Column <%(column)s> doesn't exist in the table <"
-"%(table)s>."
-msgstr ""
-"Impossible de renommer la colonne. La colonnes<%(column)s> n'existe pas dans "
-"la table <%(table)s>."
+msgid "Unable to rename column. Column <%(column)s> doesn't exist in the table <%(table)s>."
+msgstr "Impossible de renommer la colonne. La colonnes<%(column)s> n'existe pas dans la table <%(table)s>."
#: ../gui/wxpython/dbmgr/manager.py:1674
msgid "Drop selected column"
@@ -2675,12 +2524,8 @@
#: ../gui/wxpython/dbmgr/manager.py:1692
#, python-format
-msgid ""
-"Selected column '%s' will PERMANENTLY removed from table. Do you want to "
-"drop the column?"
-msgstr ""
-"Les colonnes sélectionnées '%s' seront DÉFINITIVEMENT supprimées de la "
-"table. Souhaitez-vous supprimer ces colonnes ?"
+msgid "Selected column '%s' will PERMANENTLY removed from table. Do you want to drop the column?"
+msgstr "Les colonnes sélectionnées '%s' seront DÉFINITIVEMENT supprimées de la table. Souhaitez-vous supprimer ces colonnes ?"
#: ../gui/wxpython/dbmgr/manager.py:1695 ../gui/wxpython/dbmgr/manager.py:1732
msgid "Drop column(s)"
@@ -2695,8 +2540,7 @@
msgstr ""
"Les colonnes sélectionnées\n"
"%s\n"
-"seront DÉFINITIVEMENT supprimées de la table. Souhaitez-vous supprimer ces "
-"colonnes ?"
+"seront DÉFINITIVEMENT supprimées de la table. Souhaitez-vous supprimer ces colonnes ?"
#: ../gui/wxpython/dbmgr/manager.py:1767
msgid "Unable to add column to the table. No column name defined."
@@ -2783,12 +2627,8 @@
msgstr "Clé"
#: ../gui/wxpython/dbmgr/manager.py:2393
-msgid ""
-"Unknown default DB connection. Please define DB connection using db.connect "
-"module."
-msgstr ""
-"Connexion DB par défaut inconnue. Merci de définir une connexion DB en "
-"utilisant le module db.connect."
+msgid "Unknown default DB connection. Please define DB connection using db.connect module."
+msgstr "Connexion DB par défaut inconnue. Merci de définir une connexion DB en utilisant le module db.connect."
#: ../gui/wxpython/dbmgr/manager.py:2412
msgid "Add layer"
@@ -2861,25 +2701,17 @@
#: ../gui/wxpython/dbmgr/manager.py:2891
msgid "Unable to create new table. Table name or key column name is missing."
-msgstr ""
-"Impossible de créer la nouvelle table. Il manque le nom de la table ou de la "
-"colonne clé."
+msgstr "Impossible de créer la nouvelle table. Il manque le nom de la table ou de la colonne clé."
#: ../gui/wxpython/dbmgr/manager.py:2897
#, python-format
msgid "Unable to create new table. Table <%s> already exists in the database."
-msgstr ""
-"Impossible de créer la nouvelle table. La table <%s> existe déjà dans la "
-"base."
+msgstr "Impossible de créer la nouvelle table. La table <%s> existe déjà dans la base."
#: ../gui/wxpython/dbmgr/manager.py:2934
#, python-format
-msgid ""
-"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
-"exists."
-msgstr ""
-"Impossible d'ajouter la nouvelle couche à la carte vecteur <%(vector)s>. La "
-"couche %(layer)d existe déjà."
+msgid "Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already exists."
+msgstr "Impossible d'ajouter la nouvelle couche à la carte vecteur <%(vector)s>. La couche %(layer)d existe déjà."
#: ../gui/wxpython/dbmgr/sqlbuilder.py:68
#, python-format
@@ -2970,13 +2802,11 @@
msgid ""
"No attribute table found.\n"
"\n"
-"Do you want to create a new attribute table and defined a link to vector map "
-"<%s>?"
+"Do you want to create a new attribute table and defined a link to vector map <%s>?"
msgstr ""
"Pas de table attributaire trouvée.\n"
"\n"
-"Voulez-vous créer une nouvelle table attributaire et la lier au vecteur <"
-"%s> ?"
+"Voulez-vous créer une nouvelle table attributaire et la lier au vecteur <%s> ?"
#: ../gui/wxpython/dbmgr/dialogs.py:74
msgid "Create table?"
@@ -3017,8 +2847,7 @@
#: ../gui/wxpython/dbmgr/dialogs.py:226
#, python-format
msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
-msgstr ""
-"Colonne<%(col)s> : La valeur '%(value)s' doit être entrée comme %(type)s."
+msgstr "Colonne<%(col)s> : La valeur '%(value)s' doit être entrée comme %(type)s."
#: ../gui/wxpython/dbmgr/dialogs.py:426
msgid "Unknown"
@@ -3065,11 +2894,8 @@
#: ../gui/wxpython/gui_core/preferences.py:89
#: ../gui/wxpython/wxplot/dialogs.py:381 ../gui/wxpython/wxplot/dialogs.py:765
#: ../gui/wxpython/gcp/manager.py:2372
-msgid ""
-"Apply and save changes to user settings file (default for next sessions)"
-msgstr ""
-"Appliquer et enregistrer les changements dans le fichier de configuration "
-"personnel (valeurs par défaut pour la prochaine session)"
+msgid "Apply and save changes to user settings file (default for next sessions)"
+msgstr "Appliquer et enregistrer les changements dans le fichier de configuration personnel (valeurs par défaut pour la prochaine session)"
#: ../gui/wxpython/gui_core/preferences.py:92
#: ../gui/wxpython/psmap/dialogs.py:354 ../gui/wxpython/wxplot/dialogs.py:383
@@ -3094,11 +2920,8 @@
#: ../gui/wxpython/gui_core/preferences.py:219
#, python-format
-msgid ""
-"Field separator must be ASCII character not <%s> (use e.g. ';', '&', '#')"
-msgstr ""
-"Le séparateur de champ doit être un caractères ASCII et pas <%s> (utiliser "
-"par exemple ';', '&', '#')"
+msgid "Field separator must be ASCII character not <%s> (use e.g. ';', '&', '#')"
+msgstr "Le séparateur de champ doit être un caractères ASCII et pas <%s> (utiliser par exemple ';', '&', '#')"
#: ../gui/wxpython/gui_core/preferences.py:256
msgid "GUI Settings"
@@ -3131,9 +2954,7 @@
#: ../gui/wxpython/gui_core/preferences.py:337
msgid "Automatically copy selected text to clipboard (in Command console)"
-msgstr ""
-"Copier automatiquement le texte dans le bloc-notes (dans la console de "
-"commande)"
+msgstr "Copier automatiquement le texte dans le bloc-notes (dans la console de commande)"
#: ../gui/wxpython/gui_core/preferences.py:351
msgid "Workspace settings"
@@ -3152,13 +2973,8 @@
msgstr "Sauvegarder la configuration de fenêtre actuelle comme défaut"
#: ../gui/wxpython/gui_core/preferences.py:385
-msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
-msgstr ""
-"Sauvegarder position et taille actuelles de la fenêtre de gestionnaire de "
-"couches et de la (des) fenêtre(s) d'affichage de carte ; utiliser par défaut "
-"pour les sessions suivantes."
+msgid "Save current position and size of Layer Manager window and opened Map Display window(s) and use as default for next sessions."
+msgstr "Sauvegarder position et taille actuelles de la fenêtre de gestionnaire de couches et de la (des) fenêtre(s) d'affichage de carte ; utiliser par défaut pour les sessions suivantes."
#: ../gui/wxpython/gui_core/preferences.py:412
#: ../gui/wxpython/gui_core/preferences.py:587
@@ -3374,12 +3190,8 @@
msgstr "Fichier EPSG :"
#: ../gui/wxpython/gui_core/preferences.py:1154
-msgid ""
-"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
-"directly."
-msgstr ""
-"Charger les codes EPSG (patience), entrer le code EPSG ou insérer la chaîne "
-"Proj.4 directement."
+msgid "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string directly."
+msgstr "Charger les codes EPSG (patience), entrer le code EPSG ou insérer la chaîne Proj.4 directement."
#: ../gui/wxpython/gui_core/preferences.py:1162
msgid "&Load EPSG codes"
@@ -3748,8 +3560,7 @@
#: ../gui/wxpython/gui_core/ghelp.py:272
msgid "You must run this command from the menu or command line"
-msgstr ""
-"Vous devez exécuter cette commande depuis le menu ou la ligne de commande"
+msgstr "Vous devez exécuter cette commande depuis le menu ou la ligne de commande"
#: ../gui/wxpython/gui_core/ghelp.py:327
#: ../gui/wxpython/gui_core/goutput.py:698
@@ -3767,9 +3578,8 @@
msgstr "Site officiel de GRASS :"
#: ../gui/wxpython/gui_core/ghelp.py:428
-#, fuzzy
msgid "SVN Revision"
-msgstr "Version SVN :"
+msgstr "Version SVN"
#: ../gui/wxpython/gui_core/ghelp.py:477 ../gui/wxpython/gui_core/ghelp.py:710
msgid "Language"
@@ -3885,12 +3695,8 @@
msgstr "Fermer la boîte de dialogue après exécution"
#: ../gui/wxpython/gui_core/forms.py:514
-msgid ""
-"Close dialog when command is successfully finished. Change this settings in "
-"Preferences dialog ('Command' tab)."
-msgstr ""
-"Fermer la fenêtre de dialogue quand la commande se termine avec succès. "
-"Modifier ce réglage dans les Préférences (onglet 'Commande')."
+msgid "Close dialog when command is successfully finished. Change this settings in Preferences dialog ('Command' tab)."
+msgstr "Fermer la fenêtre de dialogue quand la commande se termine avec succès. Modifier ce réglage dans les Préférences (onglet 'Commande')."
#: ../gui/wxpython/gui_core/forms.py:682
#, python-format
@@ -4015,9 +3821,7 @@
msgstr "Protocole"
#: ../gui/wxpython/gui_core/goutput.py:270
-msgid ""
-"Toggle to save list of executed commands into file; content saved when "
-"switching off."
+msgid "Toggle to save list of executed commands into file; content saved when switching off."
msgstr ""
#: ../gui/wxpython/gui_core/goutput.py:486
@@ -4034,12 +3838,8 @@
#: ../gui/wxpython/gui_core/goutput.py:524
#, python-format
-msgid ""
-"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
-"layer instead."
-msgstr ""
-"La commande '%s' n'est pas encore implantée dans wxGUI. Essayez plutôt de "
-"l'ajouter en tant que couche de commande."
+msgid "Command '%s' not yet implemented in the WxGUI. Try adding it as a command layer instead."
+msgstr "La commande '%s' n'est pas encore implantée dans wxGUI. Essayez plutôt de l'ajouter en tant que couche de commande."
#: ../gui/wxpython/gui_core/goutput.py:565
#, python-format
@@ -4052,8 +3852,7 @@
"impossible de lancer la commande :\n"
"%(cmd)s\n"
"\n"
-"Option <%(opt)s> : la lecture depuis l'entrée standard n'ets pas supportée "
-"par wxGUI"
+"Option <%(opt)s> : la lecture depuis l'entrée standard n'ets pas supportée par wxGUI"
#: ../gui/wxpython/gui_core/goutput.py:655
#: ../gui/wxpython/gui_core/goutput.py:801
@@ -4108,11 +3907,8 @@
msgstr "%(min)d min %(sec)d sec"
#: ../gui/wxpython/gui_core/goutput.py:854
-msgid ""
-"Please note that the data are left in inconsistent state and may be corrupted"
-msgstr ""
-"Veuillez noter que les données sont laissées dans un état inconsitant et "
-"peuvent être corrompues"
+msgid "Please note that the data are left in inconsistent state and may be corrupted"
+msgstr "Veuillez noter que les données sont laissées dans un état inconsitant et peuvent être corrompues"
#: ../gui/wxpython/gui_core/goutput.py:856
msgid "Command aborted"
@@ -4130,9 +3926,7 @@
#: ../gui/wxpython/gui_core/mapdisp.py:84 ../gui/wxpython/core/render.py:434
#, python-format
msgid "GRASS module '%s' not found. Unable to start map display window."
-msgstr ""
-"Module GRASS '%s' introuvable. Impossible de démarrer la fenêtre d'affichage "
-"des cartes."
+msgstr "Module GRASS '%s' introuvable. Impossible de démarrer la fenêtre d'affichage des cartes."
#: ../gui/wxpython/gui_core/dialogs.py:114
msgid "Type of element:"
@@ -4184,12 +3978,8 @@
#: ../gui/wxpython/gui_core/dialogs.py:384
#, python-format
-msgid ""
-"Vector map <%s> already exists in the current mapset. Do you want to "
-"overwrite it?"
-msgstr ""
-"La carte vecteur <%s> existe déjà dans le jeu de cartes courant. Voulez-"
-"vous l'écraser ?"
+msgid "Vector map <%s> already exists in the current mapset. Do you want to overwrite it?"
+msgstr "La carte vecteur <%s> existe déjà dans le jeu de cartes courant. Voulez-vous l'écraser ?"
#: ../gui/wxpython/gui_core/dialogs.py:387
msgid "Overwrite?"
@@ -4213,9 +4003,7 @@
msgstr "Taille et position"
#: ../gui/wxpython/gui_core/dialogs.py:530
-msgid ""
-"Click and drag on the map display to set legend size and position and then "
-"press OK"
+msgid "Click and drag on the map display to set legend size and position and then press OK"
msgstr ""
#: ../gui/wxpython/gui_core/dialogs.py:541
@@ -4233,8 +4021,7 @@
"Define raster map name for legend in properties dialog."
msgstr ""
"\n"
-"Définir le nom de la carte 'raster' pour créer la légende dans la boîte de "
-"dialogue des propriétés."
+"Définir le nom de la carte 'raster' pour créer la légende dans la boîte de dialogue des propriétés."
#: ../gui/wxpython/gui_core/dialogs.py:593
#, python-format
@@ -4272,14 +4059,11 @@
#: ../gui/wxpython/gui_core/dialogs.py:881
msgid "Close dialog, changes are not applied"
-msgstr ""
-"Fermer la boîte de dialogue, les modifications ne seront pas appliquées"
+msgstr "Fermer la boîte de dialogue, les modifications ne seront pas appliquées"
#: ../gui/wxpython/gui_core/dialogs.py:922
msgid "Select the group you want to edit or enter name of new group:"
-msgstr ""
-"Sélectionner le groupe que vous voulez modifier ou entrez le nom d'un "
-"nouveau groupe :"
+msgstr "Sélectionner le groupe que vous voulez modifier ou entrez le nom d'un nouveau groupe :"
#: ../gui/wxpython/gui_core/dialogs.py:933
msgid "Layers in selected group:"
@@ -4290,7 +4074,6 @@
msgstr "Sélectionner la couche et l'ajouter à la liste"
#: ../gui/wxpython/gui_core/dialogs.py:949
-#, fuzzy
msgid "Remove selected layer(s) from list."
msgstr "Suprimer la(les) couche(s) sélectionnée(s) de la liste."
@@ -4305,8 +4088,7 @@
#: ../gui/wxpython/gui_core/dialogs.py:1008
#, python-format
msgid "Group <%s> was changed, do you want to apply changes?"
-msgstr ""
-"Le groupe <%s> a été modifié, voulez-vous enregistrer les modifications ?"
+msgstr "Le groupe <%s> a été modifié, voulez-vous enregistrer les modifications ?"
#: ../gui/wxpython/gui_core/dialogs.py:1010
msgid "Unapplied changes"
@@ -4608,12 +4390,8 @@
msgstr "Importation et maillage de points ASCII x,y,z"
#: ../gui/wxpython/menustrings.py:33
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
-msgstr ""
-"Créer une carte raster à partir d'un assemblage d'un lot de coordonnées en "
-"utilisant des statistiques univariées."
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
+msgstr "Créer une carte raster à partir d'un assemblage d'un lot de coordonnées en utilisant des statistiques univariées."
#: ../gui/wxpython/menustrings.py:34
msgid "ASCII grid import"
@@ -4644,12 +4422,8 @@
msgstr "Importer une grille ASCII ESRI"
#: ../gui/wxpython/menustrings.py:41
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
-"map layer."
-msgstr ""
-"Convertir un fichier raster ESRI ARC/INFO ASCII (GRID) en carte raster "
-"(binaire)."
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
+msgstr "Convertir un fichier raster ESRI ARC/INFO ASCII (GRID) en carte raster (binaire)."
#: ../gui/wxpython/menustrings.py:42
msgid "GRIDATB.FOR import"
@@ -4657,8 +4431,7 @@
#: ../gui/wxpython/menustrings.py:43
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
-msgstr ""
-"Importer un fichier carte GRIDATB.FOR (TOPMODEL) vers une carte raster GRASS"
+msgstr "Importer un fichier carte GRIDATB.FOR (TOPMODEL) vers une carte raster GRASS"
#: ../gui/wxpython/menustrings.py:44
msgid "Matlab 2D array import"
@@ -4689,12 +4462,8 @@
msgstr "Importer un Terra ASTER HDF"
#: ../gui/wxpython/menustrings.py:51
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
-msgstr ""
-"Géoréférencer, rectifier et importer une image Terra-ASTER et ses DEM's "
-"associés avec gdalwarp."
+msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
+msgstr "Géoréférencer, rectifier et importer une image Terra-ASTER et ses DEM's associés avec gdalwarp."
#: ../gui/wxpython/menustrings.py:52
msgid "WMS import"
@@ -4705,7 +4474,6 @@
msgstr "Télécharger et importer des données depuis un serveur WMS"
#: ../gui/wxpython/menustrings.py:54
-#, fuzzy
msgid "Unpack raster map"
msgstr "Dépaqueter une carte raster"
@@ -4727,9 +4495,7 @@
#: ../gui/wxpython/menustrings.py:60
msgid "Creates a vector map from ASCII points file or ASCII vector file."
-msgstr ""
-"Crée une carte vecteur depuis un fichier de points ASCII ou un fichier "
-"vecteur ASCII."
+msgstr "Crée une carte vecteur depuis un fichier de points ASCII ou un fichier vecteur ASCII."
#: ../gui/wxpython/menustrings.py:61
msgid "ASCII points as a vector lines"
@@ -4749,16 +4515,11 @@
#: ../gui/wxpython/menustrings.py:65
msgid "Historical GRASS vector import (all maps)"
-msgstr ""
-"Import de cartes vecteurs ancienne version de GRASS (toutes les cartes)"
+msgstr "Import de cartes vecteurs ancienne version de GRASS (toutes les cartes)"
#: ../gui/wxpython/menustrings.py:66
-msgid ""
-"Converts all older versions of GRASS vector maps in current mapset to "
-"current format."
-msgstr ""
-"Convertir toutes les cartes vectorielles en ancien format GRASS du jeux de "
-"cartes courant vers le nouveau format."
+msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
+msgstr "Convertir toutes les cartes vectorielles en ancien format GRASS du jeux de cartes courant vers le nouveau format."
#: ../gui/wxpython/menustrings.py:67
msgid "DXF import"
@@ -4789,24 +4550,16 @@
msgstr "Importer depuis un GPS Garmin"
#: ../gui/wxpython/menustrings.py:74
-msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
-msgstr ""
-"Télécharger des waypoints, routes, traces depuis un récepteur GPS garmin "
-"vers une carte vectorielle."
+msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+msgstr "Télécharger des waypoints, routes, traces depuis un récepteur GPS garmin vers une carte vectorielle."
#: ../gui/wxpython/menustrings.py:75
msgid "GPSBabel GPS import"
msgstr "Import GPS depuis GPSBabel"
#: ../gui/wxpython/menustrings.py:76
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-"file into a vector map."
-msgstr ""
-"Importer des waypoints, routes, et traces depuis un récepteur GPS ou un "
-"fichier GPS vers une carte vectorielle."
+msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+msgstr "Importer des waypoints, routes, et traces depuis un récepteur GPS ou un fichier GPS vers une carte vectorielle."
#: ../gui/wxpython/menustrings.py:77
msgid "Geonames import"
@@ -4814,20 +4567,15 @@
#: ../gui/wxpython/menustrings.py:78
msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr ""
-"Importer des fichiers de pays geonames.org vers une carte vecteur de points."
+msgstr "Importer des fichiers de pays geonames.org vers une carte vecteur de points."
#: ../gui/wxpython/menustrings.py:79
msgid "GEOnet import"
msgstr "Importer depuis GEOnet"
#: ../gui/wxpython/menustrings.py:80
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-"Importer un fichier de pays US-NGA GEOnet Names Server (GNS) vers une carte "
-"vecteur de points."
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
+msgstr "Importer un fichier de pays US-NGA GEOnet Names Server (GNS) vers une carte vecteur de points."
#: ../gui/wxpython/menustrings.py:81
msgid "Matlab array or Mapgen format import"
@@ -4846,22 +4594,16 @@
msgstr "Importer un ASCII 3D"
-msgid ""
-"Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-msgstr ""
-"Convertit un fichier texte raster ASCII 3D en carte raster 3D (binaire)"
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+msgstr "Convertit un fichier texte raster ASCII 3D en carte raster 3D (binaire)"
#: ../gui/wxpython/menustrings.py:86
msgid "Vis5D import"
msgstr "Importer en Vis5D"
#: ../gui/wxpython/menustrings.py:87
-msgid ""
-"Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 "
-"time step)."
-msgstr ""
-"Importer un fichier 3D Vis5D (i.e. fichier V5D avec 1 variable et 1 pas de "
-"temps)."
+msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
+msgstr "Importer un fichier 3D Vis5D (i.e. fichier V5D avec 1 variable et 1 pas de temps)."
#: ../gui/wxpython/menustrings.py:88
msgid "Import database table"
@@ -4900,11 +4642,8 @@
msgstr "Export en points ASCII x,y,z"
#: ../gui/wxpython/menustrings.py:97
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-"Exporte une carte raster en fichier texte comme valeurs x,y,z en se fondant "
-"sur le centre des cellules."
+msgid "Export a raster map to a text file as x,y,z values based on cell centers."
+msgstr "Exporte une carte raster en fichier texte comme valeurs x,y,z en se fondant sur le centre des cellules."
#: ../gui/wxpython/menustrings.py:98
msgid "ESRI ASCII grid export"
@@ -4959,24 +4698,16 @@
msgstr "Exporter en PPM"
#: ../gui/wxpython/menustrings.py:111
-msgid ""
-"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
-"the currently defined region."
-msgstr ""
-"Convertit une carte raster GRASS en fichier image PPM à la résolution de la "
-"région courante."
+msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
+msgstr "Convertit une carte raster GRASS en fichier image PPM à la résolution de la région courante."
#: ../gui/wxpython/menustrings.py:112
msgid "PPM from RGB export"
msgstr "Export PPM depuis RVB"
#: ../gui/wxpython/menustrings.py:113
-msgid ""
-"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-"resolution of the CURRENTLY DEFINED REGION."
-msgstr ""
-"Convertit 3 cartes raster (R,V,B) en fichier image PPM à la résolution de la "
-"RÉGION COURANTE."
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
+msgstr "Convertit 3 cartes raster (R,V,B) en fichier image PPM à la résolution de la RÉGION COURANTE."
#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:133
msgid "POV-Ray export"
@@ -4991,12 +4722,8 @@
msgstr "Export TIFF"
#: ../gui/wxpython/menustrings.py:117
-msgid ""
-"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-"resolution of the currently defined region."
-msgstr ""
-"Exporte une carte raster en fichier image TIFFbit à la résolution de la "
-"région courante. "
+msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
+msgstr "Exporte une carte raster en fichier image TIFFbit à la résolution de la région courante. "
#: ../gui/wxpython/menustrings.py:118
msgid "VRML export"
@@ -5004,8 +4731,7 @@
#: ../gui/wxpython/menustrings.py:119
msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
-msgstr ""
-"Exporte une carte raster vers le langage Virtual Reality Modeling (VRML)"
+msgstr "Exporte une carte raster vers le langage Virtual Reality Modeling (VRML)"
#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:137
#: ../gui/wxpython/menustrings.py:144
@@ -5017,13 +4743,12 @@
msgstr "Convertit des cartes raster au format VTK-Ascii"
#: ../gui/wxpython/menustrings.py:122
-#, fuzzy
msgid "Pack raster map"
-msgstr "Combiner des cartes raster"
+msgstr "Empaqueter des cartes raster"
#: ../gui/wxpython/menustrings.py:123
msgid "Packs up a raster map and support files for copying."
-msgstr ""
+msgstr "Empaqueter une carte raster et les fichiers associée pour la copie."
#: ../gui/wxpython/menustrings.py:124
msgid "Export vector map"
@@ -5031,8 +4756,7 @@
#: ../gui/wxpython/menustrings.py:126
msgid "Converts GRASS vector map to one of the supported OGR vector formats."
-msgstr ""
-"Convertir une carte vecteur vers un des formats pris en charge par OGR."
+msgstr "Convertir une carte vecteur vers un des formats pris en charge par OGR."
#: ../gui/wxpython/menustrings.py:127
msgid "ASCII points/GRASS ASCII vector export"
@@ -5040,8 +4764,7 @@
#: ../gui/wxpython/menustrings.py:128
msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-msgstr ""
-"Convertir une carte vecteur binaire GRASS en carte vecteur ASCII GRASS."
+msgstr "Convertir une carte vecteur binaire GRASS en carte vecteur ASCII GRASS."
#: ../gui/wxpython/menustrings.py:129
msgid "DXF export"
@@ -5056,11 +4779,8 @@
msgstr "Exporter vers des formats GPS avec GPSBABEL"
#: ../gui/wxpython/menustrings.py:132
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-msgstr ""
-"Exporte une carte vecteur vers un récepteur GPS ou vers un fichier au format "
-"reconnu par GpsBabel."
+msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+msgstr "Exporte une carte vecteur vers un récepteur GPS ou vers un fichier au format reconnu par GpsBabel."
#: ../gui/wxpython/menustrings.py:134
msgid "Converts to POV-Ray format, GRASS x,y,z -> POV-Ray x,z,y"
@@ -5120,14 +4840,11 @@
#: ../gui/wxpython/menustrings.py:151
msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
-msgstr ""
-"Lier des données prises en charge par GDAL en tant que pseudocarte raster."
+msgstr "Lier des données prises en charge par GDAL en tant que pseudocarte raster."
#: ../gui/wxpython/menustrings.py:153
msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
-msgstr ""
-"Crée une nouvelle pseudo carte vecteur comme lien vers une couche prise en "
-"charge par OGR."
+msgstr "Crée une nouvelle pseudo carte vecteur comme lien vers une couche prise en charge par OGR."
#: ../gui/wxpython/menustrings.py:154
msgid "Manage maps and volumes"
@@ -5138,14 +4855,8 @@
msgstr "Copier"
#: ../gui/wxpython/menustrings.py:156
-msgid ""
-"Copies available data files in the user's current mapset search path and "
-"location to the appropriate element directories under the user's current "
-"mapset."
-msgstr ""
-"Copier les fichiers de données disponibles dans le chemin de recherche et le "
-"Secteur vers le répertoire approprié sous le jeu de données courant de "
-"l'utilisateur."
+msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
+msgstr "Copier les fichiers de données disponibles dans le chemin de recherche et le Secteur vers le répertoire approprié sous le jeu de données courant de l'utilisateur."
#: ../gui/wxpython/menustrings.py:157
msgid "List"
@@ -5153,33 +4864,23 @@
#: ../gui/wxpython/menustrings.py:158
msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr ""
-"Lister les fichiers de base de données GRASS disponibles du type spécifié "
-"par l'utilisateur."
+msgstr "Lister les fichiers de base de données GRASS disponibles du type spécifié par l'utilisateur."
#: ../gui/wxpython/menustrings.py:159
msgid "List filtered"
msgstr "Liste filtrée"
#: ../gui/wxpython/menustrings.py:160
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-"par l'utilisateur en utilisant un modèle de recherche."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "Lister les fichiers de base de données GRASS disponibles du type spécifié par l'utilisateur en utilisant un modèle de recherche."
#: ../gui/wxpython/menustrings.py:162
msgid "Renames data base element files in the user's current mapset."
-msgstr ""
-"Renommer les fichiers éléments de la base de données dans le jeu de données "
-"courant de l'utilisateur"
+msgstr "Renommer les fichiers éléments de la base de données dans le jeu de données courant de l'utilisateur"
#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:166
msgid "Removes data base element files from the user's current mapset."
-msgstr ""
-"Supprimer les fichiers éléments de base de données du jeu de données courant "
-"de l'utilisateur"
+msgstr "Supprimer les fichiers éléments de base de données du jeu de données courant de l'utilisateur"
#: ../gui/wxpython/menustrings.py:165
msgid "Delete filtered"
@@ -5204,8 +4905,7 @@
#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:303
msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr ""
-"Convertir des tranches de cartes raster 2D en une carte volumique raster 3D. "
+msgstr "Convertir des tranches de cartes raster 2D en une carte volumique raster 3D. "
#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:304
msgid "Raster 2.5D to volume"
@@ -5213,8 +4913,7 @@
#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:305
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-"Crée un volume 3D à partir de cartes raster 2D d'altitude et de valeurs."
+msgstr "Crée un volume 3D à partir de cartes raster 2D d'altitude et de valeurs."
#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:579
msgid "Vector to raster"
@@ -5229,12 +4928,8 @@
msgstr "Vectorielle vers volume"
#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:582
-msgid ""
-"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
-"raster map layer."
-msgstr ""
-"Convertir une carte vecteur binaire GRASS (uniquement des points) en carte "
-"raster 3D GRASS."
+msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
+msgstr "Convertir une carte vecteur binaire GRASS (uniquement des points) en carte raster 3D GRASS."
#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:583
msgid "2D vector to 3D vector"
@@ -5305,12 +5000,8 @@
msgstr "Gisement/distance vers coordonnées"
#: ../gui/wxpython/menustrings.py:195
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
-msgstr ""
-"Un utilitaire simple pour convertir des mesures de gisements et distances "
-"vers des coordonnées et vice-versa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+msgstr "Un utilitaire simple pour convertir des mesures de gisements et distances vers des coordonnées et vice-versa."
#: ../gui/wxpython/menustrings.py:197
msgid "Launch Cartographic Composer"
@@ -5362,8 +5053,7 @@
#: ../gui/wxpython/menustrings.py:210
msgid "Set/unset access to other mapsets in current location"
-msgstr ""
-"Active/désactive l'accès aux autres jeux de données dans le secteur courant"
+msgstr "Active/désactive l'accès aux autres jeux de données dans le secteur courant"
#: ../gui/wxpython/menustrings.py:211
msgid "User access"
@@ -5371,9 +5061,7 @@
#: ../gui/wxpython/menustrings.py:212
msgid "Controls access to the current mapset for other users on the system."
-msgstr ""
-"Contrôle l'accès au jeu de cartes courant pour les autres utilisateurs du "
-"système."
+msgstr "Contrôle l'accès au jeu de cartes courant pour les autres utilisateurs du système."
#: ../gui/wxpython/menustrings.py:213
msgid "Change working environment"
@@ -5405,8 +5093,7 @@
#: ../gui/wxpython/menustrings.py:220 ../gui/wxpython/menustrings.py:222
msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr ""
-"Affiche et modifie les réglages de variables GRASS de l'utilisateur courant."
+msgstr "Affiche et modifie les réglages de variables GRASS de l'utilisateur courant."
#: ../gui/wxpython/menustrings.py:221
msgid "Change settings"
@@ -5430,9 +5117,7 @@
#: ../gui/wxpython/menustrings.py:228
msgid "Creates new mapset in the current location, changes current mapset."
-msgstr ""
-"Crée un nouveau jeux de cartes dans le secteur de travail courant, et change "
-"le jeux de cartes courant."
+msgstr "Crée un nouveau jeux de cartes dans le secteur de travail courant, et change le jeux de cartes courant."
#: ../gui/wxpython/menustrings.py:229
msgid "Version"
@@ -5452,20 +5137,15 @@
#: ../gui/wxpython/menustrings.py:233
msgid "Print projection information (in conventional GRASS format)."
-msgstr ""
-"Imprimer les informations de projection (dans le format GRASS conventionnel)."
+msgstr "Imprimer les informations de projection (dans le format GRASS conventionnel)."
#: ../gui/wxpython/menustrings.py:234
msgid "Manage projections"
msgstr "Gérer les projections"
#: ../gui/wxpython/menustrings.py:235
-msgid ""
-"Converts co-ordinate system descriptions (i.e. projection information) "
-"between various formats (including GRASS format)."
-msgstr ""
-"Convertit les descriptions de systèmes de coordonnées (c.-à-d. les "
-"informations de projection) entre divers formats (dont le format GRASS)."
+msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
+msgstr "Convertit les descriptions de systèmes de coordonnées (c.-à-d. les informations de projection) entre divers formats (dont le format GRASS)."
#: ../gui/wxpython/menustrings.py:236
msgid "Change projection for current location"
@@ -5482,18 +5162,15 @@
# L'usage en traduction française semble être de conserver les anglicismes frontend et backend
#: ../gui/wxpython/menustrings.py:239
msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-"Convertir les coordonnées d'une projection à une autre (frontend cs2cs)."
+msgstr "Convertir les coordonnées d'une projection à une autre (frontend cs2cs)."
#: ../gui/wxpython/menustrings.py:240
-#, fuzzy
msgid "Addons extensions"
msgstr "Liste des extentions"
#: ../gui/wxpython/menustrings.py:241
-#, fuzzy
msgid "Install extension from addons"
-msgstr "Installer une extension depuis les add-ons"
+msgstr "Installer une extension depuis les addons"
#: ../gui/wxpython/menustrings.py:242
msgid "Installs new extension from GRASS AddOns SVN repository."
@@ -5522,8 +5199,7 @@
#: ../gui/wxpython/menustrings.py:248
msgid "User GUI preferences (display font, commands, digitizer, etc.)"
-msgstr ""
-"Préférences utilisateur GUI (police d'affichage, commandes, numériseur, etc.)"
+msgstr "Préférences utilisateur GUI (police d'affichage, commandes, numériseur, etc.)"
#: ../gui/wxpython/menustrings.py:249
msgid "&Raster"
@@ -5538,13 +5214,8 @@
msgstr "Numériser un raster (requiert XTerm)"
#: ../gui/wxpython/menustrings.py:252
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
-msgstr ""
-"Outil interactif utilisé pour dessiner et sauvegarder des objets vectoriels "
-"dans un moniteur graphique, en utilisant un dispositif de pointage (souris) "
-"et sauver dans une carte raster."
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
+msgstr "Outil interactif utilisé pour dessiner et sauvegarder des objets vectoriels dans un moniteur graphique, en utilisant un dispositif de pointage (souris) et sauver dans une carte raster."
#: ../gui/wxpython/menustrings.py:253
msgid "Compress/decompress"
@@ -5576,8 +5247,7 @@
#: ../gui/wxpython/menustrings.py:260
msgid "Produces the quantization file for a floating-point map."
-msgstr ""
-"Produit le fichier de quantification pour une carte en virgule flottante."
+msgstr "Produit le fichier de quantification pour une carte en virgule flottante."
#: ../gui/wxpython/menustrings.py:261
msgid "Timestamp"
@@ -5593,9 +5263,7 @@
#: ../gui/wxpython/menustrings.py:264
msgid "Resamples raster map layers to a coarser grid using aggregation."
-msgstr ""
-"Ré-échantillonner une carte raster avec un maillage plus grossier en "
-"procédant par agrégation."
+msgstr "Ré-échantillonner une carte raster avec un maillage plus grossier en procédant par agrégation."
#: ../gui/wxpython/menustrings.py:265
msgid "Resample using multiple methods"
@@ -5603,9 +5271,7 @@
#: ../gui/wxpython/menustrings.py:266
msgid "Resamples raster map layers to a finer grid using interpolation."
-msgstr ""
-"Ré-échantillonner la carte raster avec un maillage plus fin en procédant par "
-"interpolation"
+msgstr "Ré-échantillonner la carte raster avec un maillage plus fin en procédant par interpolation"
#: ../gui/wxpython/menustrings.py:267
msgid "Resample using nearest neighbor"
@@ -5620,14 +5286,8 @@
msgstr "Ré-échantillonner par les splines avec tension"
#: ../gui/wxpython/menustrings.py:270
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-"Ré-interpole et en option calcule une analyse topographique d'une carte "
-"raster (éventuellement à une résolution différente) en utilisant les splines "
-"régulées avec tension et lissage."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+msgstr "Ré-interpole et en option calcule une analyse topographique d'une carte raster (éventuellement à une résolution différente) en utilisant les splines régulées avec tension et lissage."
# Pour désigner les support files, je propose la traduction fichiers de maintenance. Guère d'autre idée pour englober à la fois la dimension historique du fichier, méta-infos, lien vers un éventuel autre raster...
#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:544
@@ -5637,9 +5297,7 @@
#: ../gui/wxpython/menustrings.py:272
msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-"Permet la création et/ou la modification de fichiers de maintenance de "
-"cartes raster."
+msgstr "Permet la création et/ou la modification de fichiers de maintenance de cartes raster."
#: ../gui/wxpython/menustrings.py:273
msgid "Update map statistics"
@@ -5662,12 +5320,8 @@
msgstr "Mosaïquer"
#: ../gui/wxpython/menustrings.py:278
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"Produit une mosaïque de la projection source pour utilisation dans la région "
-"et projection de destination."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgstr "Produit une mosaïque de la projection source pour utilisation dans la région et projection de destination."
#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:563
msgid "Manage colors"
@@ -5687,9 +5341,7 @@
#: ../gui/wxpython/menustrings.py:283
msgid "Set color rules based on stddev from a map's mean value."
-msgstr ""
-"Définir les règles de couleurs depuis l'écart-type des valeurs moyennes "
-"d'une carte."
+msgstr "Définir les règles de couleurs depuis l'écart-type des valeurs moyennes d'une carte."
#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:566
msgid "Color rules"
@@ -5713,32 +5365,23 @@
#: ../gui/wxpython/menustrings.py:289
msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-"Mélange les composantes de couleur de deux cartes raster d'un ratio donné."
+msgstr "Mélange les composantes de couleur de deux cartes raster d'un ratio donné."
#: ../gui/wxpython/menustrings.py:290
msgid "Create RGB"
msgstr "Créer RVB"
#: ../gui/wxpython/menustrings.py:291
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
-msgstr ""
-"Combine des cartes raster rouge, vert et bleu en une unique carte raster "
-"composite."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
+msgstr "Combine des cartes raster rouge, vert et bleu en une unique carte raster composite."
#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:713
msgid "RGB to HIS"
msgstr "RVB vers TSV"
#: ../gui/wxpython/menustrings.py:293
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-"Génère des cartes raster rouge, vert et bleu en combinant des valeurs de "
-"teinte, saturation, valeur (TSV) de cartes raster indiquées par "
-"l'utilisateur."
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Génère des cartes raster rouge, vert et bleu en combinant des valeurs de teinte, saturation, valeur (TSV) de cartes raster indiquées par l'utilisateur."
#: ../gui/wxpython/menustrings.py:294
msgid "Query raster maps"
@@ -5750,8 +5393,7 @@
#: ../gui/wxpython/menustrings.py:296
msgid "Queries raster map layers on their category values and category labels."
-msgstr ""
-"Interroger des cartes raster sur leurs valeurs de catégories et d'étiquettes."
+msgstr "Interroger des cartes raster sur leurs valeurs de catégories et d'étiquettes."
#: ../gui/wxpython/menustrings.py:297
msgid "Query colors by value"
@@ -5766,12 +5408,8 @@
msgstr "Zone tampon raster"
#: ../gui/wxpython/menustrings.py:307
-msgid ""
-"Creates a raster map layer showing buffer zones surrounding cells that "
-"contain non-NULL category values."
-msgstr ""
-"Crée une carte raster montrant des zones tampons entourant des cellules "
-"contenant des valeurs de catégorie non-NULL."
+msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Crée une carte raster montrant des zones tampons entourant des cellules contenant des valeurs de catégorie non-NULL."
#: ../gui/wxpython/menustrings.py:308
msgid "Concentric circles"
@@ -5779,9 +5417,7 @@
#: ../gui/wxpython/menustrings.py:309
msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-"Crée une carte raster contenant des cercles concentriques autour d'un point "
-"donné."
+msgstr "Crée une carte raster contenant des cercles concentriques autour d'un point donné."
#: ../gui/wxpython/menustrings.py:310
msgid "Closest points"
@@ -5789,9 +5425,7 @@
#: ../gui/wxpython/menustrings.py:311
msgid "Locates the closest points between objects in two raster maps."
-msgstr ""
-"Localise les points de plus grande proximité entre objets de deux cartes "
-"raster."
+msgstr "Localise les points de plus grande proximité entre objets de deux cartes raster."
#: ../gui/wxpython/menustrings.py:313
msgid "Creates a MASK for limiting raster operation."
@@ -5814,28 +5448,16 @@
msgstr "Fenêtre mouvante"
#: ../gui/wxpython/menustrings.py:318
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-"Rend la catégorie de chaque cellule une fontion des valeurs de catégorie des "
-"cellules voisines, et enregistre la nouvelle valeur dans une carte raster de "
-"sortie."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr "Rend la catégorie de chaque cellule une fontion des valeurs de catégorie des cellules voisines, et enregistre la nouvelle valeur dans une carte raster de sortie."
#: ../gui/wxpython/menustrings.py:319
msgid "Neighborhood points"
msgstr "Points voisins"
#: ../gui/wxpython/menustrings.py:320
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map layer."
-msgstr ""
-"Rend la valeur de chaque cellule une fonction des valeurs d'attributs des "
-"points ou centroids voisins, et enregistre la nouvelle valeur de cellule "
-"dans une carte raster de sortie."
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map layer."
+msgstr "Rend la valeur de chaque cellule une fonction des valeurs d'attributs des points ou centroids voisins, et enregistre la nouvelle valeur de cellule dans une carte raster de sortie."
#: ../gui/wxpython/menustrings.py:321
msgid "Overlay rasters"
@@ -5846,35 +5468,24 @@
msgstr "Produit en croix"
#: ../gui/wxpython/menustrings.py:323
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-"Crée un produit croisé des valeurs de catégories de multiples cartes raster."
+msgid "Creates a cross product of the category values from multiple raster map layers."
+msgstr "Crée un produit croisé des valeurs de catégories de multiples cartes raster."
#: ../gui/wxpython/menustrings.py:324
msgid "Raster series"
msgstr "Série raster"
#: ../gui/wxpython/menustrings.py:325
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-"Rend la valeur de sortie des cellules une foncton des valeurs des cellules "
-"correspondantes dans les cartes raster d'entrée."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "Rend la valeur de sortie des cellules une foncton des valeurs des cellules correspondantes dans les cartes raster d'entrée."
#: ../gui/wxpython/menustrings.py:326
msgid "Patch raster maps"
#: ../gui/wxpython/menustrings.py:327
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"Crée une carte raster composite en utilisant les valeurs connues d'une (ou "
-"plusieurs) carte pour remplir les zones de \"no data\" d'une autre carte."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr "Crée une carte raster composite en utilisant les valeurs connues d'une (ou plusieurs) carte pour remplir les zones de \"no data\" d'une autre carte."
#: ../gui/wxpython/menustrings.py:328
msgid "Statistical overlay"
@@ -5901,12 +5512,8 @@
msgstr "Carte des ombres"
#: ../gui/wxpython/menustrings.py:334
-#, fuzzy
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
-msgstr ""
-"Calcule les zones d'ombre depuis la position du soleil et une carte "
-"d'altitude."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
+msgstr "Calcule les zones d'ombre depuis la position du soleil et une carte d'altitude."
#: ../gui/wxpython/menustrings.py:335
msgid "Terrain analysis"
@@ -5918,38 +5525,23 @@
#: ../gui/wxpython/menustrings.py:337
msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-"Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
+msgstr "Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
#: ../gui/wxpython/menustrings.py:338
msgid "Cost surface"
msgstr "Surface de coût"
#: ../gui/wxpython/menustrings.py:339
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-"Crée une carte raster montrant le coût cumulé d'un déplacement entre "
-"différents points sur une carte raster d'altitude dont les valeurs de "
-"catégories représentent un coût."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Crée une carte raster montrant le coût cumulé d'un déplacement entre différents points sur une carte raster d'altitude dont les valeurs de catégories représentent un coût."
#: ../gui/wxpython/menustrings.py:340
msgid "Cumulative movement costs"
msgstr "Coûts de déplacement cumulés"
#: ../gui/wxpython/menustrings.py:341
-msgid ""
-"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input elevation raster map "
-"layer whose cell category values represent elevation combined with an input "
-"raster map layer whose cell values represent friction cost."
-msgstr ""
-"Crée une carte raster montrant le coût anisotropique cumulé d'un déplacement "
-"entre différents points sur la combinaison d'une carte raster d'altitude "
-"dont les valeurs de catégories représentent l'altitude et d'une carte raster "
-"dont les valeurs de cellule représentent un coût de frottement."
+msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
+msgstr "Crée une carte raster montrant le coût anisotropique cumulé d'un déplacement entre différents points sur la combinaison d'une carte raster d'altitude dont les valeurs de catégories représentent l'altitude et d'une carte raster dont les valeurs de cellule représentent un coût de frottement."
#: ../gui/wxpython/menustrings.py:342
msgid "Least cost route or flow"
@@ -5957,8 +5549,7 @@
#: ../gui/wxpython/menustrings.py:343
msgid "Traces a flow through an elevation model on a raster map."
-msgstr ""
-"Trace un écoulement à travers un modèle d'altitude sur une carte raster."
+msgstr "Trace un écoulement à travers un modèle d'altitude sur une carte raster."
#: ../gui/wxpython/menustrings.py:344
msgid "Shaded relief"
@@ -5973,12 +5564,8 @@
msgstr "Pente et exposition"
#: ../gui/wxpython/menustrings.py:347
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"Génère des cartes raster de pente, exposition, courbure et dérivées "
-"partielles à partir d'une carte raster d'altitude."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "Génère des cartes raster de pente, exposition, courbure et dérivées partielles à partir d'une carte raster d'altitude."
#: ../gui/wxpython/menustrings.py:348
msgid "Terrain parameters"
@@ -6010,16 +5597,13 @@
#: ../gui/wxpython/menustrings.py:355
msgid "Generates a raster map layer of distance to features in input layer."
-msgstr ""
-"Génère une carte raster de distance à des objets dans la carte en entrée."
+msgstr "Génère une carte raster de distance à des objets dans la carte en entrée."
#: ../gui/wxpython/menustrings.py:356
-#, fuzzy
msgid "Horizon angle"
msgstr "Angle d'hoziron"
#: ../gui/wxpython/menustrings.py:357
-#, fuzzy
msgid "Horizon angle computation from a digital elevation model."
msgstr "Calcule l'angle d'horizon depuis un modèle numérique d'altitude."
@@ -6032,12 +5616,8 @@
msgstr "Agglomérer"
#: ../gui/wxpython/menustrings.py:360
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Reclasser les données dans une couche raster en regroupant les cellules qui "
-"forment des zones physiques discrètes."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Reclasser les données dans une couche raster en regroupant les cellules qui forment des zones physiques discrètes."
#: ../gui/wxpython/menustrings.py:361
msgid "Grow"
@@ -6045,9 +5625,7 @@
#: ../gui/wxpython/menustrings.py:362
msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"Produit une couche raster où les aires contiguës ont été agrandies d'une "
-"cellule."
+msgstr "Produit une couche raster où les aires contiguës ont été agrandies d'une cellule."
#: ../gui/wxpython/menustrings.py:363
msgid "Thin"
@@ -6055,9 +5633,7 @@
#: ../gui/wxpython/menustrings.py:364
msgid "Thins non-zero cells that denote linear features in a raster map."
-msgstr ""
-"\"Amincit\" les cellules de valeur non-nulles qui semblent appartenir à des "
-"entités linéaires dans une couche raster."
+msgstr "\"Amincit\" les cellules de valeur non-nulles qui semblent appartenir à des entités linéaires dans une couche raster."
#: ../gui/wxpython/menustrings.py:365
msgid "Hydrologic modeling"
@@ -6068,12 +5644,8 @@
msgstr "Creuser des chenaux d'écoulement"
#: ../gui/wxpython/menustrings.py:367
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
-msgstr ""
-"Prends les données vectorielles de cours d'eau, les transforme en raster, et "
-"soustrait la profondeur du modèle de terrain en sortie."
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+msgstr "Prends les données vectorielles de cours d'eau, les transforme en raster, et soustrait la profondeur du modèle de terrain en sortie."
#: ../gui/wxpython/menustrings.py:368
msgid "Fill lake"
@@ -6088,12 +5660,8 @@
msgstr "Carte sans dépressions ni lignes de flux"
#: ../gui/wxpython/menustrings.py:371
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-"Filtrer et générer une couche d'altitude sans dépressions et une couche de "
-"direction d'écoulement depuis une couche d'altitude donnée."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr "Filtrer et générer une couche d'altitude sans dépressions et une couche de direction d'écoulement depuis une couche d'altitude donnée."
#: ../gui/wxpython/menustrings.py:372
msgid "Flow accumulation"
@@ -6108,13 +5676,8 @@
msgstr "Lignes de flux"
#: ../gui/wxpython/menustrings.py:375
-msgid ""
-"Construction of slope curves (flowlines), flowpath lengths, and flowline "
-"densities (upslope areas) from a raster digital elevation model (DEM)."
-msgstr ""
-"Constructin de courbes de terrain (lignes du courant), longueur des "
-"courants, et densité de lignes de courants (zones amont) à partir d'un "
-"modèle numérique d'altitudes (MNA) raster."
+msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
+msgstr "Constructin de courbes de terrain (lignes du courant), longueur des courants, et densité de lignes de courants (zones amont) à partir d'un modèle numérique d'altitudes (MNA) raster."
#: ../gui/wxpython/menustrings.py:376
msgid "Watershed analysis"
@@ -6145,9 +5708,7 @@
msgstr "Modélisation d'hydro-géologie"
#: ../gui/wxpython/menustrings.py:383
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
msgstr ""
#: ../gui/wxpython/menustrings.py:384
@@ -6163,9 +5724,7 @@
msgstr "Modélisation SIMWE des flux de sédiments"
#: ../gui/wxpython/menustrings.py:387
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
msgstr ""
#: ../gui/wxpython/menustrings.py:388
@@ -6174,9 +5733,7 @@
#: ../gui/wxpython/menustrings.py:389
msgid "Creates topographic index map from elevation raster map."
-msgstr ""
-"Créer une carte d'index topographique à partir d'une carte raster "
-"d'altitudes."
+msgstr "Créer une carte d'index topographique à partir d'une carte raster d'altitudes."
#: ../gui/wxpython/menustrings.py:390
msgid "TOPMODEL simulation"
@@ -6195,33 +5752,23 @@
msgstr "Paramètrage (requiert XTerm)"
#: ../gui/wxpython/menustrings.py:394
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
-msgstr ""
-"Outil interactif utiliser pour paramétrer l'échantillonnage et l'analyse qui "
-"sera utilisée par les autres programmes r.le ."
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
+msgstr "Outil interactif utiliser pour paramétrer l'échantillonnage et l'analyse qui sera utilisée par les autres programmes r.le ."
#: ../gui/wxpython/menustrings.py:395
msgid "Analyze landscape"
msgstr "Analyse de paysage"
#: ../gui/wxpython/menustrings.py:396
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
-msgstr ""
-"Contient un jeu de mesures des attributs, diversité, texture, juuxtaposition "
-"et angle."
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
+msgstr "Contient un jeu de mesures des attributs, diversité, texture, juuxtaposition et angle."
#: ../gui/wxpython/menustrings.py:397
msgid "Analyze patches"
msgstr "Analyser les parcelles"
#: ../gui/wxpython/menustrings.py:398
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
msgstr ""
#: ../gui/wxpython/menustrings.py:399
@@ -6229,10 +5776,7 @@
msgstr "Résumé et affichage (requiert XTerm)"
#: ../gui/wxpython/menustrings.py:400
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
msgstr ""
#: ../gui/wxpython/menustrings.py:401
@@ -6252,8 +5796,7 @@
msgstr "Densité du bord"
#: ../gui/wxpython/menustrings.py:405
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
#: ../gui/wxpython/menustrings.py:406
@@ -6269,9 +5812,7 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:409
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
msgstr ""
#: ../gui/wxpython/menustrings.py:410
@@ -6303,8 +5844,7 @@
msgstr "Module de densité"
#: ../gui/wxpython/menustrings.py:417
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
#: ../gui/wxpython/menustrings.py:418
@@ -6312,8 +5852,7 @@
msgstr "Module nombre"
#: ../gui/wxpython/menustrings.py:419
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
msgstr ""
#: ../gui/wxpython/menustrings.py:420
@@ -6361,11 +5900,7 @@
msgstr "Taux de propagation"
#: ../gui/wxpython/menustrings.py:432
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
msgstr ""
#: ../gui/wxpython/menustrings.py:433
@@ -6373,9 +5908,7 @@
msgstr "Propagation par chemins de moindre coût "
#: ../gui/wxpython/menustrings.py:434
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
msgstr ""
#: ../gui/wxpython/menustrings.py:435
@@ -6383,10 +5916,7 @@
msgstr "Simulation de diffusion anisotrope"
#: ../gui/wxpython/menustrings.py:436
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
msgstr ""
#: ../gui/wxpython/menustrings.py:437
@@ -6406,9 +5936,7 @@
msgstr "Reclasser en fonction de la taille"
#: ../gui/wxpython/menustrings.py:441
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
msgstr ""
#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:648
@@ -6416,9 +5944,7 @@
msgstr "Reclasser"
#: ../gui/wxpython/menustrings.py:443
-msgid ""
-"Creates a new map layer whose category values are based upon a "
-"reclassification of the categories in an existing raster map layer."
+msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
msgstr ""
#: ../gui/wxpython/menustrings.py:444
@@ -6442,9 +5968,7 @@
msgstr "Recalculer l'échelle des valeurs par histogramme"
#: ../gui/wxpython/menustrings.py:449
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
msgstr ""
#: ../gui/wxpython/menustrings.py:450
@@ -6464,9 +5988,7 @@
msgstr "Cellules aléatoires et points vectoriels"
#: ../gui/wxpython/menustrings.py:454
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
msgstr ""
#: ../gui/wxpython/menustrings.py:455
@@ -6486,9 +6008,7 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:459
-msgid ""
-"Generates a raster density map from vector point data using a moving kernel "
-"or optionally generates a vector density map on a vector network."
+msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
msgstr ""
#: ../gui/wxpython/menustrings.py:460
@@ -6496,29 +6016,20 @@
msgstr "Déviance gaussienne de surface"
#: ../gui/wxpython/menustrings.py:461
-msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
+msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
msgstr ""
# Dip traduit ici pendage, en référence à la terminologie des géologues.
#: ../gui/wxpython/menustrings.py:463
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Crée une carte raster plane définie par un pendage (inclinaison), une "
-"orientation (azimuth) et un point."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr "Crée une carte raster plane définie par un pendage (inclinaison), une orientation (azimuth) et un point."
#: ../gui/wxpython/menustrings.py:464
msgid "Random deviates surface"
msgstr "Déviance aléatoire de surface"
#: ../gui/wxpython/menustrings.py:465
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
msgstr ""
#: ../gui/wxpython/menustrings.py:466
@@ -6570,9 +6081,7 @@
msgstr "IDW de points vecteur"
#: ../gui/wxpython/menustrings.py:478
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
msgstr ""
#: ../gui/wxpython/menustrings.py:479
@@ -6588,10 +6097,7 @@
msgstr "Splines régulées avec tension"
#: ../gui/wxpython/menustrings.py:482
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
msgstr ""
#: ../gui/wxpython/menustrings.py:483
@@ -6607,11 +6113,8 @@
msgstr "Remplir les cellules NULL"
#: ../gui/wxpython/menustrings.py:486
-#, fuzzy
msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-"interpolation"
+msgstr "Remplir les zones de no-data de la carte raster par interpolation spline."
#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:764
msgid "Report and statistics"
@@ -6630,9 +6133,7 @@
msgstr "Gérer les informations de catégories"
#: ../gui/wxpython/menustrings.py:491
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
+msgid "Manages category values and labels associated with user-specified raster map layers."
msgstr ""
#: ../gui/wxpython/menustrings.py:492
@@ -6657,8 +6158,7 @@
#: ../gui/wxpython/menustrings.py:497
msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-"Afficher la liste des valeurs de catégories trouvées dans une carte raster."
+msgstr "Afficher la liste des valeurs de catégories trouvées dans une carte raster."
#: ../gui/wxpython/menustrings.py:498
msgid "Sum category values"
@@ -6681,9 +6181,7 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:503
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
msgstr ""
#: ../gui/wxpython/menustrings.py:504
@@ -6695,8 +6193,7 @@
msgstr "Estimer les surfaces pour les matrices."
#: ../gui/wxpython/menustrings.py:507
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
msgstr ""
#: ../gui/wxpython/menustrings.py:508
@@ -6705,29 +6202,22 @@
#: ../gui/wxpython/menustrings.py:509
msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Affiche en sortie les valeurs de carte raster suivant une(des) ligne(s) "
-"définie(s) par l'utilisateur."
+msgstr "Affiche en sortie les valeurs de carte raster suivant une(des) ligne(s) définie(s) par l'utilisateur."
#: ../gui/wxpython/menustrings.py:510
msgid "Sample transects (bearing/distance)"
msgstr "Exemple de transects (parcours/distance)"
#: ../gui/wxpython/menustrings.py:511
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-"Affiche en sortie les valeurs de carte raster suivant un(des) transect(s) "
-"défini(s) par l'utilisateur."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
+msgstr "Affiche en sortie les valeurs de carte raster suivant un(des) transect(s) défini(s) par l'utilisateur."
#: ../gui/wxpython/menustrings.py:512
msgid "Covariance/correlation"
msgstr "Covariance/corrélation"
#: ../gui/wxpython/menustrings.py:513
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map layer"
-"(s)."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
msgstr ""
#: ../gui/wxpython/menustrings.py:514
@@ -6743,9 +6233,7 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:517
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
msgstr ""
#: ../gui/wxpython/menustrings.py:518
@@ -6773,12 +6261,8 @@
msgstr "Éditer une carte vecteur (de façon non interactive)"
#: ../gui/wxpython/menustrings.py:525
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-"Édite une carte vecteur, permet d'ajouter, supprimer et modifier les objets "
-"vectoriels sélectionnés."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr "Édite une carte vecteur, permet d'ajouter, supprimer et modifier les objets vectoriels sélectionnés."
#: ../gui/wxpython/menustrings.py:526
msgid "Convert object types"
@@ -6801,12 +6285,8 @@
msgstr "Fusionner des contours"
#: ../gui/wxpython/menustrings.py:531
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Fusionne des contours entre surfaces adjacentes partageant un attribut ou "
-"une catégorie commun(e)."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Fusionne des contours entre surfaces adjacentes partageant un attribut ou une catégorie commun(e)."
#: ../gui/wxpython/menustrings.py:532
msgid "Create 3D vector over raster"
@@ -6814,9 +6294,7 @@
#: ../gui/wxpython/menustrings.py:533
msgid "Converts vector map to 3D by sampling of elevation raster map."
-msgstr ""
-"Convertit une carte vecteur en 3D par échantillonnage d'altitude d'une carte "
-"raster."
+msgstr "Convertit une carte vecteur en 3D par échantillonnage d'altitude d'une carte raster."
#: ../gui/wxpython/menustrings.py:534
msgid "Extrude 3D vector map"
@@ -6840,21 +6318,15 @@
#: ../gui/wxpython/menustrings.py:539
msgid "Create optimally placed labels for vector map(s)"
-msgstr ""
-"Créer des étiquettes placées de manière optimale pour une(des) carte(s) "
-"vecteur"
+msgstr "Créer des étiquettes placées de manière optimale pour une(des) carte(s) vecteur"
#: ../gui/wxpython/menustrings.py:540
msgid "Reposition vector map"
msgstr "Repositionner une carte vecteur"
#: ../gui/wxpython/menustrings.py:541
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
-msgstr ""
-"Réalise une transformation affine (translation, échelle et rotation, ou "
-"points d'amer) de carte vecteur."
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
+msgstr "Réalise une transformation affine (translation, échelle et rotation, ou points d'amer) de carte vecteur."
#: ../gui/wxpython/menustrings.py:542
msgid "Reproject vector map"
@@ -6862,8 +6334,7 @@
#: ../gui/wxpython/menustrings.py:543
msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-"Re-projette une carte vecteur depuis un secteur dans le secteur courant."
+msgstr "Re-projette une carte vecteur depuis un secteur dans le secteur courant."
#: ../gui/wxpython/menustrings.py:545
msgid "Updates vector map metadata."
@@ -6889,9 +6360,7 @@
#: ../gui/wxpython/menustrings.py:550
msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr ""
-"Reconstruire la topologie de toutes les cartes vectorielles dans le jeux de "
-"cartes courant."
+msgstr "Reconstruire la topologie de toutes les cartes vectorielles dans le jeux de cartes courant."
#: ../gui/wxpython/menustrings.py:551
msgid "Build polylines"
@@ -6915,9 +6384,7 @@
#: ../gui/wxpython/menustrings.py:556
msgid "Creates points/segments from input vector lines and positions."
-msgstr ""
-"Crée des points/segments à partir de lignes vectorielles et positions en "
-"entrée."
+msgstr "Crée des points/segments à partir de lignes vectorielles et positions en entrée."
#: ../gui/wxpython/menustrings.py:557
msgid "Clean vector map"
@@ -6944,11 +6411,8 @@
msgstr "Ajoute les centroïdes manquants aux contours fermés."
#: ../gui/wxpython/menustrings.py:565
-msgid ""
-"Set color rules for features in a vector using a numeric attribute column."
-msgstr ""
-"Fixe les règles de coloration pour les objets d'une carte vecteur via une "
-"colonne attributaire numérique."
+msgid "Set color rules for features in a vector using a numeric attribute column."
+msgstr "Fixe les règles de coloration pour les objets d'une carte vecteur via une colonne attributaire numérique."
#: ../gui/wxpython/menustrings.py:567
msgid "Interactive management of vector color tables."
@@ -6983,34 +6447,24 @@
msgstr "Sélection par attribut"
#: ../gui/wxpython/menustrings.py:575
-msgid ""
-"Selects vector objects from an existing vector map and creates a new map "
-"containing only the selected objects."
-msgstr ""
-"Sélectionner les objets vectoriels d'une carte raster existante et créer une "
-"nouvelle carte contenant seulement ces objets sélectionnés."
+msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
+msgstr "Sélectionner les objets vectoriels d'une carte raster existante et créer une nouvelle carte contenant seulement ces objets sélectionnés."
#: ../gui/wxpython/menustrings.py:576
msgid "Spatial query"
msgstr ""
#: ../gui/wxpython/menustrings.py:577
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
-"Sélectionne des objets d'une carte vecteur (A) par des objets d'une autre "
-"carte vecteur (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgstr "Sélectionne des objets d'une carte vecteur (A) par des objets d'une autre carte vecteur (B)."
#: ../gui/wxpython/menustrings.py:587
msgid "Buffer vectors"
msgstr "Vecteurs tampons"
#: ../gui/wxpython/menustrings.py:588
-msgid ""
-"Creates a buffer around features of given type (areas must contain centroid)."
-msgstr ""
-"Crée un tampon autour d'objet d'un type donné (les surfaces doivent contenir "
-"un centroïde)."
+msgid "Creates a buffer around features of given type (areas must contain centroid)."
+msgstr "Crée un tampon autour d'objet d'un type donné (les surfaces doivent contenir un centroïde)."
#: ../gui/wxpython/menustrings.py:589
msgid "Lidar analysis"
@@ -7029,9 +6483,7 @@
msgstr "Détecter intérieurs"
#: ../gui/wxpython/menustrings.py:593
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
msgstr ""
#: ../gui/wxpython/menustrings.py:594
@@ -7039,9 +6491,7 @@
msgstr "Corriger et classifier les objets"
#: ../gui/wxpython/menustrings.py:595
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
msgstr ""
#: ../gui/wxpython/menustrings.py:596
@@ -7069,9 +6519,7 @@
msgstr "Créer points/segments"
#: ../gui/wxpython/menustrings.py:602
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
msgstr ""
#: ../gui/wxpython/menustrings.py:603
@@ -7079,9 +6527,7 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:604
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
msgstr ""
#: ../gui/wxpython/menustrings.py:605
@@ -7089,9 +6535,7 @@
msgstr "Objets les plus proches"
#: ../gui/wxpython/menustrings.py:606
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
msgstr ""
#: ../gui/wxpython/menustrings.py:607
@@ -7135,11 +6579,8 @@
msgstr "Plus court chemin pour un jeu d'objets"
#: ../gui/wxpython/menustrings.py:617
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
-msgstr ""
-"Calcule la plus courte distance via le réseau entre les jeux d'objets donnés."
+msgid "Computes shortest distance via the network between the given sets of features."
+msgstr "Calcule la plus courte distance via le réseau entre les jeux d'objets donnés."
#: ../gui/wxpython/menustrings.py:618
msgid "Shortest path using timetables"
@@ -7155,8 +6596,7 @@
#: ../gui/wxpython/menustrings.py:621
msgid "Computes the shortest path between all pairs of nodes in the network."
-msgstr ""
-"Calcule le plus court chemin entre toutes les paires de nœuds du réseau."
+msgstr "Calcule le plus court chemin entre toutes les paires de nœuds du réseau."
#: ../gui/wxpython/menustrings.py:622
msgid "Visibility network"
@@ -7203,9 +6643,7 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:633
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
msgstr ""
#: ../gui/wxpython/menustrings.py:634
@@ -7246,9 +6684,7 @@
#: ../gui/wxpython/menustrings.py:644
msgid "Create a new vector map layer by combining other vector map layers."
-msgstr ""
-"Créer une nouvelle carte vecteur en combinant d'autres couches de cartes "
-"vecteur."
+msgstr "Créer une nouvelle carte vecteur en combinant d'autres couches de cartes vecteur."
#: ../gui/wxpython/menustrings.py:645
msgid "Change attributes"
@@ -7260,27 +6696,18 @@
#: ../gui/wxpython/menustrings.py:647
msgid "Attach, delete or report vector categories to map geometry."
-msgstr ""
-"Attache, supprime ou rend compte de catégories à la géométrie de carte "
-"vecteur."
+msgstr "Attache, supprime ou rend compte de catégories à la géométrie de carte vecteur."
#: ../gui/wxpython/menustrings.py:649
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-"Change les valeurs de catégorie pour une carte vecteur existante en fonction "
-"des résultats de requêtes SQL ou d'un valeur dans une colonne de table "
-"attributaire."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr "Change les valeurs de catégorie pour une carte vecteur existante en fonction des résultats de requêtes SQL ou d'un valeur dans une colonne de table attributaire."
#: ../gui/wxpython/menustrings.py:651
msgid "Update area attributes from raster"
msgstr "Mise à jour des attributs surfaciques à partir d'une carte raster"
#: ../gui/wxpython/menustrings.py:652
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygons "
-"and uploads statistics to new attribute columns."
+msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
msgstr ""
#: ../gui/wxpython/menustrings.py:653
@@ -7313,8 +6740,7 @@
#: ../gui/wxpython/menustrings.py:660
msgid "Samples a raster map at vector point locations."
-msgstr ""
-"Échantillonne une carte raster au droit des points d'une carte vecteur."
+msgstr "Échantillonne une carte raster au droit des points d'une carte vecteur."
#: ../gui/wxpython/menustrings.py:661
msgid "Generate area for current region"
@@ -7341,24 +6767,16 @@
msgstr "Triangles de Delaunay"
#: ../gui/wxpython/menustrings.py:667
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"Crée une triangulation de Delaunay à partir d'une carte vecteur contenant "
-"des points ou centroïdes."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr "Crée une triangulation de Delaunay à partir d'une carte vecteur contenant des points ou centroïdes."
#: ../gui/wxpython/menustrings.py:668
msgid "Voronoi diagram/Thiessen polygons"
msgstr "Diagramme de Voronoï/polygones de Thiessen"
#: ../gui/wxpython/menustrings.py:669
-msgid ""
-"Creates a Voronoi diagram from an input vector map containing points or "
-"centroids."
-msgstr ""
-"Crée un diagramme de Voronoï à partir d'une carte vecteur contenant des "
-"points ou centroïdes."
+msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
+msgstr "Crée un diagramme de Voronoï à partir d'une carte vecteur contenant des points ou centroïdes."
#: ../gui/wxpython/menustrings.py:670
msgid "Generate grid"
@@ -7377,11 +6795,8 @@
msgstr "Générer à partir d'une base de données"
#: ../gui/wxpython/menustrings.py:674
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-"Crée une nouvelle carte vecteur (points) à partir d'une table de base de "
-"données contenant des coordonnées."
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr "Crée une nouvelle carte vecteur (points) à partir d'une table de base de données contenant des coordonnées."
#: ../gui/wxpython/menustrings.py:675
msgid "Generate points along lines"
@@ -7389,9 +6804,7 @@
#: ../gui/wxpython/menustrings.py:676
msgid "Create points along input lines in new vector with 2 layers."
-msgstr ""
-"Créer des points le long de lignes dans une nouvelle carte vecteur à deux "
-"couches."
+msgstr "Créer des points le long de lignes dans une nouvelle carte vecteur à deux couches."
#: ../gui/wxpython/menustrings.py:677
msgid "Generate random points"
@@ -7407,8 +6820,7 @@
#: ../gui/wxpython/menustrings.py:680
msgid "Random location perturbations of GRASS vector points"
-msgstr ""
-"Modifie de manière aléatoire la position des points dans un fichier vectoriel"
+msgstr "Modifie de manière aléatoire la position des points dans un fichier vectoriel"
#: ../gui/wxpython/menustrings.py:681
msgid "Remove outliers in point sets"
@@ -7459,9 +6871,7 @@
msgstr "Statistiques univariées pour des points"
#: ../gui/wxpython/menustrings.py:693
-msgid ""
-"Calculates univariate statistics for attribute. Variance and standard "
-"deviation is calculated only for points if specified."
+msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
msgstr ""
#: ../gui/wxpython/menustrings.py:694
@@ -7469,9 +6879,7 @@
msgstr "Statistiques univariées pour les colonnes d'attributs"
#: ../gui/wxpython/menustrings.py:695
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
msgstr ""
#: ../gui/wxpython/menustrings.py:696
@@ -7503,9 +6911,8 @@
msgstr "Créer/éditer un groupe d'images"
#: ../gui/wxpython/menustrings.py:703
-#, fuzzy
msgid "Creates, edits, and lists groups of imagery files."
-msgstr "Crée, édite, et liste groupes et sous-groupes de fichiers d'imagerie."
+msgstr "Crée, édite, et liste les groupes d'images."
#: ../gui/wxpython/menustrings.py:704
msgid "Target group"
@@ -7541,32 +6948,20 @@
msgstr "TSV vers RVB"
#: ../gui/wxpython/menustrings.py:712
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
-msgstr ""
-"Transforme une carte raster de l'espace colorimétrique TSV (Teinte-"
-"Saturation-Valeur) vers l'espace colorimétrique RVB (Rouge-Vert-Bleu)."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
+msgstr "Transforme une carte raster de l'espace colorimétrique TSV (Teinte-Saturation-Valeur) vers l'espace colorimétrique RVB (Rouge-Vert-Bleu)."
#: ../gui/wxpython/menustrings.py:714
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
-msgstr ""
-"Transforme une carte raster de l'espace colorimétrique RVB (Rouge-Vert-Bleu) "
-"vers l'espace colorimétrique TSV (Teinte-Saturation-Valeur)."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
+msgstr "Transforme une carte raster de l'espace colorimétrique RVB (Rouge-Vert-Bleu) vers l'espace colorimétrique TSV (Teinte-Saturation-Valeur)."
#: ../gui/wxpython/menustrings.py:715
msgid "Rectify image or raster"
msgstr "Rectifier une image ou une carte raster"
#: ../gui/wxpython/menustrings.py:716
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-"Redresse une image en calculant une transformation de coordonnées pour "
-"chaque pixel de l'image basée sur des points de contrôle."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr "Redresse une image en calculant une transformation de coordonnées pour chaque pixel de l'image basée sur des points de contrôle."
#: ../gui/wxpython/menustrings.py:718
msgid "Generate histogram of image"
@@ -7577,8 +6972,7 @@
msgstr "Réponse spectrale"
#: ../gui/wxpython/menustrings.py:720
-msgid ""
-"Displays spectral response at user specified locations in group or images."
+msgid "Displays spectral response at user specified locations in group or images."
msgstr ""
#: ../gui/wxpython/menustrings.py:721
@@ -7586,8 +6980,7 @@
msgstr "Transformée de Brovey"
#: ../gui/wxpython/menustrings.py:722
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
+msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
msgstr ""
#: ../gui/wxpython/menustrings.py:723
@@ -7599,9 +6992,7 @@
msgstr "Regroupement pour classification non-supervisée"
#: ../gui/wxpython/menustrings.py:725
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
msgstr ""
#: ../gui/wxpython/menustrings.py:726
@@ -7625,9 +7016,7 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:731
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
msgstr ""
#: ../gui/wxpython/menustrings.py:732
@@ -7643,9 +7032,7 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:735
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
msgstr ""
#: ../gui/wxpython/menustrings.py:736
@@ -7713,9 +7100,7 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:752
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+."
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
msgstr ""
#: ../gui/wxpython/menustrings.py:753
@@ -7728,20 +7113,19 @@
#: ../gui/wxpython/menustrings.py:755
msgid "Modis quality control"
-msgstr ""
+msgstr "Contrôle de qualité MODIS"
#: ../gui/wxpython/menustrings.py:756
-#, fuzzy
msgid "Extracts quality control parameters from Modis QC layers."
-msgstr "Extraires les paramètres de terrain à partir d'une MNA."
+msgstr "Extraire le sparamètres de contrôle de qualité d'une couche MODIS QC."
#: ../gui/wxpython/menustrings.py:757
msgid "Atmospheric correction"
-msgstr ""
+msgstr "Corrections atmosphériques"
#: ../gui/wxpython/menustrings.py:758
msgid "Performs atmospheric correction using the 6S algorithm."
-msgstr ""
+msgstr "Effectue une correction atmosphérique par l'algorithme 6S."
#: ../gui/wxpython/menustrings.py:759
msgid "Topographic correction"
@@ -7749,7 +7133,7 @@
#: ../gui/wxpython/menustrings.py:760
msgid "Computes topographic correction of reflectance."
-msgstr ""
+msgstr "Calcule la correction topographique de la réflectance."
#: ../gui/wxpython/menustrings.py:761
msgid "Satellite images products"
@@ -7776,9 +7160,7 @@
msgstr "Analyse Kappa"
#: ../gui/wxpython/menustrings.py:768
-msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
-"classification result."
+msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
msgstr ""
#: ../gui/wxpython/menustrings.py:769
@@ -7834,15 +7216,11 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:785
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map."
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
msgstr ""
#: ../gui/wxpython/menustrings.py:787
-msgid ""
-"Calculates numerically transient, confined groundwater flow in three "
-"dimensions."
+msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
msgstr ""
#: ../gui/wxpython/menustrings.py:788
@@ -7850,9 +7228,7 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:789
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
msgstr ""
#: ../gui/wxpython/menustrings.py:790
@@ -7880,9 +7256,7 @@
msgstr "Statistiques univariées pour les volumes"
#: ../gui/wxpython/menustrings.py:796
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
msgstr ""
#: ../gui/wxpython/menustrings.py:797
@@ -7898,9 +7272,8 @@
msgstr "Lister les pilotes"
#: ../gui/wxpython/menustrings.py:800
-#, fuzzy
msgid "Lists all database drivers."
-msgstr "Lister tous les pilotes de base de données"
+msgstr "Lister tous les pilotes de bases de données."
#: ../gui/wxpython/menustrings.py:801
msgid "List tables"
@@ -7976,9 +7349,7 @@
#: ../gui/wxpython/menustrings.py:819
msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Tester un pilote de base de données ; la base doit exister et être connectée "
-"via db.connect"
+msgstr "Tester un pilote de base de données ; la base doit exister et être connectée via db.connect"
#: ../gui/wxpython/menustrings.py:821
msgid "Query any table"
@@ -7986,9 +7357,7 @@
#: ../gui/wxpython/menustrings.py:822
msgid "Selects data from attribute table (performs SQL query statement(s))."
-msgstr ""
-"Sélectionne des données d'une table attributaire (exécute des expressions "
-"SQL)."
+msgstr "Sélectionne des données d'une table attributaire (exécute des expressions SQL)."
#: ../gui/wxpython/menustrings.py:825
msgid "SQL statement"
@@ -8007,12 +7376,8 @@
msgstr "Nouvelle table"
#: ../gui/wxpython/menustrings.py:829
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"Créée et connecte une table attributaire à une couche donnée d'une carte "
-"vecteur existante."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr "Créée et connecte une table attributaire à une couche donnée d'une carte vecteur existante."
#: ../gui/wxpython/menustrings.py:830
msgid "Remove table"
@@ -8028,45 +7393,31 @@
#: ../gui/wxpython/menustrings.py:833
msgid "Allows to join a table to a vector map table."
-msgstr ""
-"Permet de joindre une table à la table attributaire d'une carte vecteur."
+msgstr "Permet de joindre une table à la table attributaire d'une carte vecteur."
#: ../gui/wxpython/menustrings.py:834
msgid "Add columns"
msgstr "Ajouter des colonnes"
#: ../gui/wxpython/menustrings.py:835
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Ajoute une ou des colonnes à la table attributaire connectée à une carte "
-"vecteur donnée."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "Ajoute une ou des colonnes à la table attributaire connectée à une carte vecteur donnée."
#: ../gui/wxpython/menustrings.py:837
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
-"Supprime une colonne d'une table attributaire connectée à une carte vecteur "
-"donnée."
+msgid "Drops a column from the attribute table connected to a given vector map."
+msgstr "Supprime une colonne d'une table attributaire connectée à une carte vecteur donnée."
#: ../gui/wxpython/menustrings.py:839
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Renomme une colonne dans une table attributaire connectée à une carte "
-"vecteur donnée."
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr "Renomme une colonne dans une table attributaire connectée à une carte vecteur donnée."
#: ../gui/wxpython/menustrings.py:840
msgid "Change values"
msgstr "Changer les valeurs"
#: ../gui/wxpython/menustrings.py:841
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
-msgstr ""
-"Permet de mettre à jour une colonne dans une table attributaire connectée à "
-"une carte vecteur."
+msgid "Allows to update a column in the attribute table connected to a vector map."
+msgstr "Permet de mettre à jour une colonne dans une table attributaire connectée à une carte vecteur."
#: ../gui/wxpython/menustrings.py:842
msgid "Reconnect vectors to database"
@@ -8106,9 +7457,8 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:852
-#, fuzzy
msgid "Prints system information"
-msgstr "Information sur la base de données"
+msgstr "Afficher les informations système"
#: ../gui/wxpython/menustrings.py:859
msgid "Create new model"
@@ -8164,14 +7514,12 @@
msgstr "&Modèle"
#: ../gui/wxpython/menustrings.py:878
-#, fuzzy
msgid "Add command"
-msgstr "Ajouter une couche de commande"
+msgstr "Ajouter une commande"
#: ../gui/wxpython/menustrings.py:879
-#, fuzzy
msgid "Add action (GRASS command) to model"
-msgstr "Ajouter un nouveau module GRASS au modèle"
+msgstr "Ajouter une action (commande GRASS) au modèle"
#: ../gui/wxpython/menustrings.py:880
msgid "Add data"
@@ -8190,14 +7538,12 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:884
-#, fuzzy
msgid "Add loop / series"
-msgstr "Ajouter une boucle"
+msgstr "Ajouter une boucle / série"
#: ../gui/wxpython/menustrings.py:885
-#, fuzzy
msgid "Adds loop (series) to model"
-msgstr "Ajouter une nouvelle variable au modèle"
+msgstr "Ajouter une boucle (série) au modèle"
#: ../gui/wxpython/menustrings.py:886
msgid "Add condition"
@@ -8274,9 +7620,7 @@
#: ../gui/wxpython/psmap/frame.py:230
msgid "Program ps2pdf is not available. Please install it first to create PDF."
-msgstr ""
-"Le programme ps2pdf n'est pas disponible. Merci de l'installer pour "
-"permettre la création de fichiers PDF."
+msgstr "Le programme ps2pdf n'est pas disponible. Merci de l'installer pour permettre la création de fichiers PDF."
#: ../gui/wxpython/psmap/frame.py:274
msgid "Generating PDF..."
@@ -8307,8 +7651,7 @@
"\n"
" %s"
msgstr ""
-"permettre la création de fichiers PDF.\n"
+"Le programme ps2pdf n'est pas disponible. Merci de l'installer pour permettre la création de fichiers PDF.\n"
"\n"
" %s"
@@ -8353,13 +7696,8 @@
"\n"
#: ../gui/wxpython/psmap/frame.py:1021 ../gui/wxpython/gmodeler/frame.py:708
-msgid ""
-"This program is free software under the GNU General Public License(>=v2). "
-"Read the file COPYING that comes with GRASS for details."
-msgstr ""
-"Ce programme est un logiciel libre placé sous la licence GNU General Public "
-"License (>=v2). Lisez le fichier COPYING fourni avec GRASS pour plus de "
-"détails."
+msgid "This program is free software under the GNU General Public License(>=v2). Read the file COPYING that comes with GRASS for details."
+msgstr "Ce programme est un logiciel libre placé sous la licence GNU General Public License (>=v2). Lisez le fichier COPYING fourni avec GRASS pour plus de détails."
#: ../gui/wxpython/psmap/frame.py:1324
msgid "Click and drag to resize object"
@@ -8508,28 +7846,18 @@
#: ../gui/wxpython/psmap/instructions.py:811
#: ../gui/wxpython/psmap/instructions.py:1693
#, python-format
-msgid ""
-"Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding "
-"which is required by module ps.map."
-msgstr ""
-"Les caractères en position %s ne sont pas pris en charge par l'encodage "
-"ISO-8859-1 (Latin 1) requis pour le module ps.map."
+msgid "Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
+msgstr "Les caractères en position %s ne sont pas pris en charge par l'encodage ISO-8859-1 (Latin 1) requis pour le module ps.map."
#: ../gui/wxpython/psmap/instructions.py:815
#: ../gui/wxpython/psmap/instructions.py:1697
-msgid ""
-"Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
-"required by module ps.map."
-msgstr ""
-"Tous les caractères ne sont pas supportés par l'encodage ISO-8859-1 (Latin "
-"1) requis pour le module ps.map."
+msgid "Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
+msgstr "Tous les caractères ne sont pas supportés par l'encodage ISO-8859-1 (Latin 1) requis pour le module ps.map."
#: ../gui/wxpython/psmap/instructions.py:931
-#, fuzzy, python-format
+#, python-format
msgid "Failed to read instruction %(inst)s: file %(file)s not found."
-msgstr ""
-"Échec à la lecture de l'instruction %s.\n"
-"Utiliser la notation 1:25000."
+msgstr "Échec à la lecture de l'instruction %(inst)s : fichier %(file)s non trouvé."
#: ../gui/wxpython/psmap/toolbars.py:52
msgid "Generate text file with mapping instructions"
@@ -8592,9 +7920,8 @@
msgstr "Texte"
#: ../gui/wxpython/psmap/toolbars.py:77
-#, fuzzy
msgid "Map info"
-msgstr "Ajouter les informations sur la carte"
+msgstr "Informations sur la carte"
#: ../gui/wxpython/psmap/toolbars.py:79 ../gui/wxpython/wxplot/dialogs.py:576
#: ../gui/wxpython/wxplot/dialogs.py:618
@@ -8603,13 +7930,12 @@
#: ../gui/wxpython/psmap/toolbars.py:83 ../gui/wxpython/psmap/dialogs.py:4061
#: ../gui/wxpython/psmap/dialogs.py:4109
-#, fuzzy
msgid "Image"
-msgstr "&Imagerie"
+msgstr "Image"
#: ../gui/wxpython/psmap/toolbars.py:87
msgid "Add simple graphics"
-msgstr ""
+msgstr "Ajouter un graphique simple"
#: ../gui/wxpython/psmap/toolbars.py:89 ../gui/wxpython/psmap/dialogs.py:4522
#: ../gui/wxpython/vdigit/preferences.py:516
@@ -8622,9 +7948,8 @@
msgstr "Ligne"
#: ../gui/wxpython/psmap/toolbars.py:93
-#, fuzzy
msgid "Rectangle"
-msgstr "Sélection des pendants"
+msgstr "Rectangle"
#: ../gui/wxpython/psmap/dialogs.py:197
msgid "Units:"
@@ -8955,8 +8280,7 @@
#: ../gui/wxpython/psmap/dialogs.py:1675
msgid "Database connection is not defined in DB file."
-msgstr ""
-"La connexion à la base de données n'est pas définie dans le fichier DB."
+msgstr "La connexion à la base de données n'est pas définie dans le fichier DB."
#: ../gui/wxpython/psmap/dialogs.py:1676
msgid "Select layer:"
@@ -9028,8 +8352,7 @@
#: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
msgid "Type filename or click browse to choose file"
-msgstr ""
-"Taper un nom de fichier ou cliquer sur Parcourir pour choisir un fichier"
+msgstr "Taper un nom de fichier ou cliquer sur Parcourir pour choisir un fichier"
#: ../gui/wxpython/psmap/dialogs.py:1972 ../gui/wxpython/psmap/dialogs.py:2161
msgid "Choose a file"
@@ -9195,8 +8518,7 @@
#: ../gui/wxpython/psmap/dialogs.py:2728
msgid "Leave the edit field empty, to use default values."
-msgstr ""
-"Laisser vide le champ d'édition afin d'utiliser les valeurs par défaut."
+msgstr "Laisser vide le champ d'édition afin d'utiliser les valeurs par défaut."
#: ../gui/wxpython/psmap/dialogs.py:2750
msgid ""
@@ -9233,7 +8555,6 @@
msgstr "pas de carte raster"
#: ../gui/wxpython/psmap/dialogs.py:3221
-#, fuzzy
msgid "Mapinfo settings"
msgstr "Paramètres de la carte"
@@ -9351,74 +8672,70 @@
msgstr "Pas de texte saisi !"
#: ../gui/wxpython/psmap/dialogs.py:4120
-#, fuzzy
msgid "Choose a directory with images"
-msgstr "Choisir le répertoire d'entrée"
+msgstr "Choisir un répertoire avec des images"
#: ../gui/wxpython/psmap/dialogs.py:4152
msgid "Note: only EPS format supported"
-msgstr ""
+msgstr "Note : seul le format EPS est supporté"
#: ../gui/wxpython/psmap/dialogs.py:4161
-#, fuzzy
msgid "Scale And Rotation"
-msgstr "Échelle et direction du Nord"
+msgstr "Échelle et rotation"
#: ../gui/wxpython/psmap/dialogs.py:4192 ../gui/wxpython/psmap/dialogs.py:4650
-#, fuzzy
msgid "Rotation angle (deg):"
-msgstr "Rotation :"
+msgstr "Angle de rotation (deg) :"
#: ../gui/wxpython/psmap/dialogs.py:4201 ../gui/wxpython/psmap/dialogs.py:4659
msgid "Counterclockwise rotation in degrees"
-msgstr ""
+msgstr "Rotation anti-horaire en degrés"
#: ../gui/wxpython/psmap/dialogs.py:4299
-#, fuzzy
msgid ""
"PIL\n"
"missing"
-msgstr "Émission"
+msgstr ""
+"PIL\n"
+"manquant"
#: ../gui/wxpython/psmap/dialogs.py:4316
+#, python-format
msgid "Unable to read file %s"
-msgstr "Impossible de lire le fichier %s."
+msgstr "Impossible de lire le fichier %s"
#: ../gui/wxpython/psmap/dialogs.py:4374
#, python-format
msgid "size: %(width)s x %(height)s pts"
-msgstr ""
+msgstr "taille : %(width)s x %(height)s pts"
#: ../gui/wxpython/psmap/dialogs.py:4396
-#, fuzzy
msgid "No image selected."
-msgstr "Pas de carte sélectionnée !"
+msgstr "Pas d'image sélectionnée."
#: ../gui/wxpython/psmap/dialogs.py:4493
-#, fuzzy
msgid "North Arrow settings"
-msgstr "Montrer les paramètres"
+msgstr "Paramètres de la flèche nord"
#: ../gui/wxpython/psmap/dialogs.py:4504
msgid "Compute convergence"
msgstr ""
#: ../gui/wxpython/psmap/dialogs.py:4560
-#, fuzzy
msgid "Symbol"
msgstr "symbole"
#: ../gui/wxpython/psmap/dialogs.py:4566
-#, fuzzy
msgid "Select symbol:"
-msgstr "Sélection par boîte"
+msgstr "Sélectionner le symbole :"
#: ../gui/wxpython/psmap/dialogs.py:4580
msgid ""
"Note: Selected symbol is not displayed\n"
"in draft mode (only in preview mode)"
msgstr ""
+"Note : le symbol sélectionné n'est pas affiché\n"
+"en mode brouillon (seulement en mode aperçu"
#: ../gui/wxpython/psmap/dialogs.py:4598 ../gui/wxpython/psmap/dialogs.py:4852
#, fuzzy
@@ -9426,43 +8743,36 @@
msgstr "Couleur de ligne"
#: ../gui/wxpython/psmap/dialogs.py:4613 ../gui/wxpython/psmap/dialogs.py:4873
-#, fuzzy
msgid "Fill color:"
-msgstr "remplir par la couleur"
+msgstr "Remplir par la couleur"
#: ../gui/wxpython/psmap/dialogs.py:4636
-#, fuzzy
msgid "Size and Rotation"
-msgstr "Taille et position"
+msgstr "Taille et rotation"
#: ../gui/wxpython/psmap/dialogs.py:4641
-#, fuzzy
msgid "Size (pt):"
-msgstr "Taille:"
+msgstr "Taille (pt) :"
#: ../gui/wxpython/psmap/dialogs.py:4643
-#, fuzzy
msgid "Symbol size in points"
-msgstr "Taille de symbole :"
+msgstr "Taille de symbole en points"
#: ../gui/wxpython/psmap/dialogs.py:4817
-#, fuzzy
msgid "Rectangle settings"
-msgstr "Modifier les paramètres"
+msgstr "Paramètres du rectangle"
#: ../gui/wxpython/psmap/dialogs.py:4819
-#, fuzzy
msgid "Line settings"
+msgstr "Paramètres de la ligne"
#: ../gui/wxpython/psmap/dialogs.py:4896 ../gui/wxpython/gcp/manager.py:2528
msgid "Line width:"
msgstr "Épaisseur de ligne :"
#: ../gui/wxpython/psmap/dialogs.py:4905
-#, fuzzy
msgid "Line width in points"
-msgstr "Largeur de ligne (en pixels) :"
+msgstr "Épaisseur de ligne en points :"
#: ../gui/wxpython/modules/histogram.py:176
#: ../gui/wxpython/mapdisp/mapwindow.py:438
@@ -9470,9 +8780,8 @@
msgstr "Merci de patienter, export de l'image en cours ..."
#: ../gui/wxpython/modules/histogram.py:266
-#, fuzzy
msgid "GRASS GIS Histogramming Tool (d.histogram)"
-msgstr "Histogramme GRASS de carte raster"
+msgstr "Histogramme GRASS"
#: ../gui/wxpython/modules/histogram.py:368
msgid "Select font for histogram text"
@@ -9482,9 +8791,7 @@
#: ../gui/wxpython/gcp/mapdisplay.py:456 ../gui/wxpython/mapdisp/frame.py:567
#: ../gui/wxpython/gmodeler/frame.py:544
msgid "Choose a file name to save the image (no need to add extension)"
-msgstr ""
-"Choisissez un nom de fichier pour enregistrer l'image (extension non "
-"nécessaire)"
+msgstr "Choisissez un nom de fichier pour enregistrer l'image (extension non nécessaire)"
#: ../gui/wxpython/modules/histogram.py:447 ../gui/wxpython/wxplot/base.py:485
#: ../gui/wxpython/gcp/mapdisplay.py:489 ../gui/wxpython/mapdisp/frame.py:600
@@ -9680,15 +8987,12 @@
msgstr "Ajouter la carte raster créée dans l'arborescence des couches"
#: ../gui/wxpython/modules/mcalc_builder.py:458
-#, fuzzy
msgid "You must enter the name of a new raster map to create."
-msgstr "Vous devez entrer le nom de la nouvelle carte à créer"
+msgstr "Vous devez entrer le nom de la nouvelle carte à créer."
#: ../gui/wxpython/modules/mcalc_builder.py:468
-#, fuzzy
msgid "You must enter an expression to create a new raster map."
-msgstr ""
-"Vous devez entrer une expression mapcalc pour créer une nouvelle cartes"
+msgstr "Vous devez entrer une expression pour créer une nouvelle carte."
#: ../gui/wxpython/modules/mcalc_builder.py:503
msgid "Choose a file name to save the expression"
@@ -9704,23 +9008,20 @@
msgstr "Choisir un fichier pour charger une formule"
#: ../gui/wxpython/modules/colorrules.py:71
-#, fuzzy
msgid "Check all"
-msgstr "Fermer la boîte de dialogue"
+msgstr "(Dé)cocher tout"
#: ../gui/wxpython/modules/colorrules.py:74
-#, fuzzy
msgid "Clear all"
+msgstr "Effacer tout"
#: ../gui/wxpython/modules/colorrules.py:130
-#, fuzzy
msgid "Enter vector attribute values"
-msgstr "Interroger la carte vecteur depuis la table d'attributs"
+msgstr "Entrer les valeurs d'attributs"
#: ../gui/wxpython/modules/colorrules.py:287
msgid "Bad color format. Use color format '0:0:0'"
-msgstr ""
+msgstr "Mauvais format de couleur. Utiliser le format '0:0:0'"
#: ../gui/wxpython/modules/colorrules.py:369
msgid "Select raster map:"
@@ -9731,45 +9032,36 @@
msgstr "Sélectionner une carte vecteur :"
#: ../gui/wxpython/modules/colorrules.py:388
-#, fuzzy
msgid "Import or export color table:"
-msgstr "Exporter la table de couleurs"
+msgstr "Importer ou exporter la table de couleurs :"
#: ../gui/wxpython/modules/colorrules.py:393
-#, fuzzy
msgid "Load color table from file:"
-msgstr "Enregistrer la table de couleur dans un fichier"
+msgstr "Charger la table de couleur depuis un fichier :"
#: ../gui/wxpython/modules/colorrules.py:394
-#, fuzzy
msgid "Choose file to load color table"
-msgstr "Choisir un fichier GRC à charger"
+msgstr "Choisir le fichier de table de couleur à charger"
#: ../gui/wxpython/modules/colorrules.py:395
msgid "Load"
msgstr "Charger"
#: ../gui/wxpython/modules/colorrules.py:396
-#, fuzzy
msgid "Type filename or click to choose file and load color table"
-msgstr ""
+msgstr "Entrer un nom de fichier ou cliquer sur Parcourir pour charger une table de couleur"
#: ../gui/wxpython/modules/colorrules.py:402
-#, fuzzy
msgid "Save color table to file:"
+msgstr "Enregistrer la table de couleur dans le fichier :"
#: ../gui/wxpython/modules/colorrules.py:403
-#, fuzzy
msgid "Choose file to save color table"
msgstr "Choisir le fichier à enregistrer"
#: ../gui/wxpython/modules/colorrules.py:404
-#, fuzzy
msgid "Type filename or click to choose file and save color table"
-msgstr ""
+msgstr "Entrer un nom de fichier ou cliquer sur Parcourir pour enregistrer une table de couleur"
#: ../gui/wxpython/modules/colorrules.py:410
#, fuzzy
@@ -9786,18 +9078,16 @@
#: ../gui/wxpython/modules/colorrules.py:534
msgid "No valid color rules given."
-msgstr ""
+msgstr "Pas de règle de couleur valide."
#: ../gui/wxpython/modules/colorrules.py:600
-#, fuzzy
msgid "Invalid color table format"
-msgstr "Échelle ou centre de carte non valide !"
+msgstr "Format de table de couleur invalide"
#: ../gui/wxpython/modules/colorrules.py:677
#, python-format
msgid "Invalid rule value '%s'. Unable to apply color table."
-msgstr ""
-"Valeur '%s' de règle non valide. Impossible d'appliquer la table de couleur."
+msgstr "Valeur '%s' de règle non valide. Impossible d'appliquer la table de couleur."
#: ../gui/wxpython/modules/colorrules.py:752
msgid "Create new color table for raster map"
@@ -9814,31 +9104,25 @@
#: ../gui/wxpython/modules/colorrules.py:837
#, python-format
msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
-msgstr ""
-"Saisir les valeurs de catégorie ou le pourcentage (%(range)s = %(min)d-"
-"%(max)d)"
+msgstr "Saisir les valeurs de catégorie ou le pourcentage (%(range)s = %(min)d-%(max)d)"
#: ../gui/wxpython/modules/colorrules.py:926
-#, fuzzy
msgid "Create new color rules for vector map"
-msgstr "Créer une nouvelle table de couleur pour une carte vecteur"
+msgstr "Créer une nouvelle règle de couleur pour une carte vecteur"
#: ../gui/wxpython/modules/colorrules.py:937
#: ../gui/wxpython/modules/colorrules.py:1462
-#, fuzzy
msgid "Enter vector attribute values or percents:"
-msgstr "Saisir les valeurs ou la plage (n ou n1 à n2) d'attributs vecteur "
+msgstr "Entrer les valeurs d'attributs ou les pourcentages :"
#: ../gui/wxpython/modules/colorrules.py:939
#: ../gui/wxpython/modules/colorrules.py:1464
-#, fuzzy
msgid "Enter vector attribute values:"
+msgstr "Entrer les valeurs d'attributs :"
#: ../gui/wxpython/modules/colorrules.py:950
-#, fuzzy
msgid "Select vector columns"
-msgstr "Sélectionner une carte vecteur"
+msgstr "Sélectionner les colonnes"
#: ../gui/wxpython/modules/colorrules.py:952
msgid "Layer:"
@@ -9849,93 +9133,73 @@
msgstr "Colonne d'attribut :"
#: ../gui/wxpython/modules/colorrules.py:957
-#, fuzzy
msgid "Load color from column:"
-msgstr "Colonne de couleur RVB :"
+msgstr "Charger les couleurs depuis la colonne :"
-#, fuzzy
msgid "Save color to column:"
+msgstr "Enregistrer les couleurs dans la colonne :"
#: ../gui/wxpython/modules/colorrules.py:959
-#, fuzzy
msgid "Load size from column:"
-msgstr "Charger le modèle depuis un fichier"
+msgstr "Charger la taille depuis la colonne :"
-#, fuzzy
msgid "Save size to column:"
-msgstr "Raster vers volume"
+msgstr "Entregistrer la taille dans la colonne :"
#: ../gui/wxpython/modules/colorrules.py:961
-#, fuzzy
msgid "Load width from column:"
+msgstr "Charger l'épaisseur depuis la colonne :"
msgid "Save width to column:"
-msgstr ""
+msgstr "Enregistrer l'épaisseur dans la colonne :"
#: ../gui/wxpython/modules/colorrules.py:965
msgid "Use color column instead of color table:"
-msgstr ""
+msgstr "Utiliser la colonne de couleur à la place de la table de couleur :"
#: ../gui/wxpython/modules/colorrules.py:980
-#, fuzzy
msgid "Add GRASSRGB column to current attribute table."
-msgstr "Supprimer une colonne de la table d'attributs sélectionnée"
+msgstr "Ajouter la colonne GRASSRGV à la table d'attributs."
#: ../gui/wxpython/modules/colorrules.py:1035
#: ../gui/wxpython/modules/colorrules.py:1084
-#, fuzzy
msgid "Import or export color table"
+msgstr "Importer ou exporter la table de couleurs"
#: ../gui/wxpython/modules/colorrules.py:1096
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file. Do you "
-"want to create and connect new attribute table?"
-msgstr ""
-"La connexion à une base de données n'est pas définie dans le fichier DB pour "
-"la carte vecteur <%s>. Vous pouvez définir une nouvelle connexion dans "
-"l'onglet 'Gérer les couches'."
+msgid "Database connection for vector map <%s> is not defined in DB file. Do you want to create and connect new attribute table?"
+msgstr "La connexion à une base de données n'est pas définie dans le fichier DB pour la carte vecteur <%s>. Voulez-vous la créer et connecter la nouvelle table d'attributs ?"
#: ../gui/wxpython/modules/colorrules.py:1099
-#, fuzzy
msgid "No database connection defined"
-msgstr "Connections vecteur base de données"
+msgstr "Pas de connexion à une base de données définie"
#: ../gui/wxpython/modules/colorrules.py:1171
#, python-format
-msgid ""
-"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Color rules "
-"cannot be edited."
+msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Color rules cannot be edited."
msgstr ""
#: ../gui/wxpython/modules/colorrules.py:1176
#, python-format
-msgid ""
-"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
-"table cannot be edited."
+msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute table cannot be edited."
msgstr ""
#: ../gui/wxpython/modules/colorrules.py:1318
+#, python-format
msgid "%s column already exists."
-msgstr "Le fichier existe déjà"
+msgstr "La colonne %s existe déjà."
#: ../gui/wxpython/modules/colorrules.py:1350
-#, fuzzy
msgid "Please wait, loading data from attribute table..."
msgstr "Patientez, chargement des données attributaires .."
#: ../gui/wxpython/modules/colorrules.py:1411
#, python-format
-msgid ""
-"Number of loaded records reached %d, displaying all the records will be time-"
-"consuming and may lead to computer freezing, do you still want to continue?"
+msgid "Number of loaded records reached %d, displaying all the records will be time-consuming and may lead to computer freezing, do you still want to continue?"
msgstr ""
#: ../gui/wxpython/modules/colorrules.py:1415
@@ -9958,9 +9222,8 @@
msgstr "Merci de sélectionner un outil de nettoyage à ôter"
#: ../gui/wxpython/modules/colorrules.py:1633
-#, fuzzy
msgid "No color column defined. Operation canceled."
-msgstr "Aucune carte sélectionnée. Opération annulée."
+msgstr "Pas de colonne de couleur définie. Opération annulée"
#: ../gui/wxpython/modules/extensions.py:43
msgid "Fetch & install extension from GRASS Addons"
@@ -9984,9 +9247,7 @@
#: ../gui/wxpython/modules/extensions.py:95
msgid "Fetch list of available modules from GRASS Addons SVN repository"
-msgstr ""
-"Récupérer la liste des modules disponibles depuis le dépôt svn des GRASS "
-"AddOns"
+msgstr "Récupérer la liste des modules disponibles depuis le dépôt svn des GRASS AddOns"
#: ../gui/wxpython/modules/extensions.py:98
msgid "&Install"
@@ -10002,9 +9263,7 @@
#: ../gui/wxpython/modules/extensions.py:186
msgid "Fetch list of available extensions by clicking on 'Fetch' button"
-msgstr ""
-"Récupérer la liste des extensions disponibles en cliquant sur le bouton "
-"'Récupérer'"
+msgstr "Récupérer la liste des extensions disponibles en cliquant sur le bouton 'Récupérer'"
#: ../gui/wxpython/modules/extensions.py:194
#, python-format
@@ -10013,9 +9272,7 @@
#: ../gui/wxpython/modules/extensions.py:207
msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
-msgstr ""
-"Récupération de la liste des modules à partir du svn GRASS AddOns (soyez "
-"patient)..."
+msgstr "Récupération de la liste des modules à partir du svn GRASS AddOns (soyez patient)..."
#: ../gui/wxpython/modules/extensions.py:386
msgid "Uninstall GRASS Addons extensions"
@@ -10268,12 +9525,8 @@
msgstr "Impossible de créer le secteur"
#: ../gui/wxpython/location_wizard/wizard.py:197
-msgid ""
-"Title of the location is limited only to one line and 256 characters. The "
-"rest of the text will be ignored."
-msgstr ""
-"Le titre de secteur est limité à une ligne et 256 caractères. Le reste du "
-"texte sera ignoré."
+msgid "Title of the location is limited only to one line and 256 characters. The rest of the text will be ignored."
+msgstr "Le titre de secteur est limité à une ligne et 256 caractères. Le reste du texte sera ignoré."
#: ../gui/wxpython/location_wizard/wizard.py:204
msgid "Choose method for creating a new location"
@@ -10289,9 +9542,7 @@
#: ../gui/wxpython/location_wizard/wizard.py:216
msgid "Read projection and datum terms from a georeferenced data file"
-msgstr ""
-"Lire la projection et les termes du datum depuis un fichier de "
-"géréférencement"
+msgstr "Lire la projection et les termes du datum depuis un fichier de géréférencement"
#: ../gui/wxpython/location_wizard/wizard.py:219
msgid "Read projection and datum terms from a WKT or PRJ file"
@@ -10299,9 +9550,7 @@
#: ../gui/wxpython/location_wizard/wizard.py:222
msgid "Specify projection and datum terms using custom PROJ.4 parameters"
-msgstr ""
-"Spécifier la projection et les termes du datum en utilisant des paramètres "
-"PROJ.4 personnalisés"
+msgstr "Spécifier la projection et les termes du datum en utilisant des paramètres PROJ.4 personnalisés"
#: ../gui/wxpython/location_wizard/wizard.py:225
#, fuzzy
@@ -10508,13 +9757,8 @@
#: ../gui/wxpython/location_wizard/wizard.py:1954
#, python-format
-msgid ""
-"Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will "
-"need to change the default GIS data directory in the GRASS startup screen."
-msgstr ""
-"Le secteur <%(loc)s> va être créé dans le répertoire SIG <%(dir)s>. Il vous "
-"faudra changer le répertoire SIG par défaut dans l'écran de démarrage de "
-"GRASS."
+msgid "Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will need to change the default GIS data directory in the GRASS startup screen."
+msgstr "Le secteur <%(loc)s> va être créé dans le répertoire SIG <%(dir)s>. Il vous faudra changer le répertoire SIG par défaut dans l'écran de démarrage de GRASS."
#: ../gui/wxpython/location_wizard/wizard.py:1959
msgid "New GIS data directory"
@@ -10738,8 +9982,7 @@
#: ../gui/wxpython/wxplot/profile.py:265
msgid "You must draw a transect to profile in the map display window."
-msgstr ""
-"Vous devez dessiner un transect dans la fenêtre d'affichage des cartes."
+msgstr "Vous devez dessiner un transect dans la fenêtre d'affichage des cartes."
#: ../gui/wxpython/wxplot/profile.py:266
msgid "Nothing to profile"
@@ -10751,9 +9994,7 @@
#: ../gui/wxpython/wxplot/profile.py:336
msgid "Path and prefix (for raster name) to save profile values..."
-msgstr ""
-"Chemin et préfixe (du nom de carte raster) pour sauvegarder les valeurs du "
-"profil..."
+msgstr "Chemin et préfixe (du nom de carte raster) pour sauvegarder les valeurs du profil..."
#: ../gui/wxpython/wxplot/profile.py:362
#, fuzzy
@@ -10879,9 +10120,7 @@
#: ../gui/wxpython/wxplot/dialogs.py:378 ../gui/wxpython/wxplot/dialogs.py:764
msgid "Apply changes for the current session and close dialog"
-msgstr ""
-"Appliquer les changements pour la session courante et fermer la boite de "
-"dialogue"
+msgstr "Appliquer les changements pour la session courante et fermer la boite de dialogue"
#: ../gui/wxpython/wxplot/dialogs.py:434
@@ -10906,8 +10145,7 @@
#: ../gui/wxpython/wxplot/dialogs.py:535
#, fuzzy
msgid "Settings for selected map"
-msgstr ""
-"Définir la région calculée à partir de la(des) carte(s) sélectionnée(s)"
+msgstr "Définir la région calculée à partir de la(des) carte(s) sélectionnée(s)"
#: ../gui/wxpython/wxplot/dialogs.py:550
msgid "Line color"
@@ -10940,8 +10178,7 @@
msgstr "Échelle"
#: ../gui/wxpython/wxplot/dialogs.py:662
-msgid ""
-"Automatic axis scaling, custom max and min, or scale matches data range (min)"
+msgid "Automatic axis scaling, custom max and min, or scale matches data range (min)"
msgstr ""
#: ../gui/wxpython/wxplot/dialogs.py:667
@@ -11007,15 +10244,11 @@
#: ../gui/wxpython/gcp/manager.py:383
msgid "You must select a valid location before selecting a mapset"
-msgstr ""
-"Vous devez sélectionner un secteur valide avant de sélectionner un jeu de "
-"cartes"
+msgstr "Vous devez sélectionner un secteur valide avant de sélectionner un jeu de cartes"
#: ../gui/wxpython/gcp/manager.py:396
msgid "You must select a valid location and mapset in order to continue"
-msgstr ""
-"Vous devez sélectionner un secteur et un jeu de cartes valides pour pouvoir "
-"continuer"
+msgstr "Vous devez sélectionner un secteur et un jeu de cartes valides pour pouvoir continuer"
#: ../gui/wxpython/gcp/manager.py:415
msgid "Select image/map group to georectify"
@@ -11043,9 +10276,7 @@
#: ../gui/wxpython/gcp/manager.py:521
msgid "You must select a valid image/map group in order to continue"
-msgstr ""
-"Vous devez sélectionner un groupe d'images ou de cartes valides pour pouvoir "
-"continuer"
+msgstr "Vous devez sélectionner un groupe d'images ou de cartes valides pour pouvoir continuer"
#: ../gui/wxpython/gcp/manager.py:528
msgid "You must enter an map name extension in order to continue"
@@ -11053,8 +10284,7 @@
#: ../gui/wxpython/gcp/manager.py:594
msgid "Select maps to display for ground control point (GCP) creation"
-msgstr ""
-"Sélectionner les cartes à afficher pour la création des points de contrôle"
+msgstr "Sélectionner les cartes à afficher pour la création des points de contrôle"
#: ../gui/wxpython/gcp/manager.py:602 ../gui/wxpython/gcp/manager.py:2560
msgid "Select source map to display:"
@@ -11138,14 +10368,12 @@
#: ../gui/wxpython/gcp/manager.py:1305
msgid ""
-"Insufficient points defined and active (checked) for selected rectification "
-"method.\n"
+"Insufficient points defined and active (checked) for selected rectification method.\n"
"3+ points needed for 1st order,\n"
"6+ points for 2nd order, and\n"
"10+ points for 3rd order."
msgstr ""
-"Pas assez de points définis et activés pour la méthode de rectification "
-"choisie.\n"
+"Pas assez de points définis et activés pour la méthode de rectification choisie.\n"
"3 points ou + nécessaires pour le 1er ordre,\n"
"7 points ou + nécessaires pour le 2ème ordre, et\n"
"10 points ou + nécessaires pour le 3ème ordre."
@@ -11166,11 +10394,8 @@
#: ../gui/wxpython/gcp/manager.py:1443
#, python-format
-msgid ""
-"Vector map <%s> already exists. Change extension name and georectify again."
-msgstr ""
-"La carte vecteur <%s> existe déjà. Changez le suffixe et géoréférencez à "
-"nouveau."
+msgid "Vector map <%s> already exists. Change extension name and georectify again."
+msgstr "La carte vecteur <%s> existe déjà. Changez le suffixe et géoréférencez à nouveau."
#: ../gui/wxpython/gcp/manager.py:1453
msgid "For all vector maps georectified successfully,"
@@ -11369,9 +10594,7 @@
#: ../gui/wxpython/gcp/manager.py:2773
#, python-format
msgid "GCP Manager settings saved to file '%s'."
-msgstr ""
-"Paramètres du gestionnaire de points de contrôle enregistrés dans le fichier "
-"'%s'."
+msgstr "Paramètres du gestionnaire de points de contrôle enregistrés dans le fichier '%s'."
msgid "GRASS GIS Manage Ground Control Points"
@@ -11489,9 +10712,7 @@
#: ../gui/wxpython/mapdisp/frame.py:654
msgid "No raster or vector map layer selected for querying."
-msgstr ""
-"Pas de carte rater ou couche de carte vecteur sélectionnée pour "
-"interrogation."
+msgstr "Pas de carte rater ou couche de carte vecteur sélectionnée pour interrogation."
#: ../gui/wxpython/mapdisp/frame.py:735
#, python-format
@@ -11511,9 +10732,7 @@
msgid ""
"Click and drag with left mouse button to measure.\n"
"Double click with left button to clear."
-msgstr ""
-"Cliquer et glisser avec le bouton gauche de la souris pour mesurer. %s "
-"Double-cliquer avec le bouton gauche pour annuler."
+msgstr "Cliquer et glisser avec le bouton gauche de la souris pour mesurer. %s Double-cliquer avec le bouton gauche pour annuler."
#: ../gui/wxpython/mapdisp/frame.py:942
msgid "Measuring distance"
@@ -11626,8 +10845,7 @@
msgstr "Glisser avec la souris pour se déplacer"
#: ../gui/wxpython/mapdisp/toolbars.py:57
-msgid ""
-"Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
+msgid "Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
msgstr ""
#: ../gui/wxpython/mapdisp/toolbars.py:59
@@ -11651,15 +10869,8 @@
msgstr "Raison : %s"
#: ../gui/wxpython/mapdisp/toolbars.py:90
-msgid ""
-"Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
-"(hopefully this will be fixed soon). Please keep an eye out for updated "
-"versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
-msgstr ""
-"Notez que le mode de vue 3D de wxGUI est actuellement indisponible sur MS "
-"Windows (cela sera prochainement résolu). Merci de garder un œil sur les "
-"mises à jour de GRASS. En attendant, vous pouvez utiliser le module \"NVIZ"
-"\", accessible depuis le menu Fichier."
+msgid "Note that the wxGUI's 3D view mode is currently disabled on MS Windows (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
+msgstr "Notez que le mode de vue 3D de wxGUI est actuellement indisponible sur MS Windows (cela sera prochainement résolu). Merci de garder un œil sur les mises à jour de GRASS. En attendant, vous pouvez utiliser le module \"NVIZ\", accessible depuis le menu Fichier."
#: ../gui/wxpython/mapdisp/toolbars.py:98
#: ../gui/wxpython/vdigit/toolbars.py:695
@@ -11671,15 +10882,8 @@
msgstr "La numérisation de vector n'est pas disponible"
#: ../gui/wxpython/mapdisp/toolbars.py:107
-msgid ""
-"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
-"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
-"In the meantime you can use \"v.digit\" from the Develop Vector menu."
-msgstr ""
-"Notez que le module de digitalisation de wxGUI est actuellement indisponible "
-"(en espérant que cela soit prochainement résolu). Merci de garder un œil sur "
-"les mises à jour de GRASS. En attendant, vous pouvez utiliser le module \"v."
-"digit\", accessible depuis le menu Vecteur."
+msgid "Note that the wxGUI's vector digitizer is currently disabled (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"v.digit\" from the Develop Vector menu."
+msgstr "Notez que le module de digitalisation de wxGUI est actuellement indisponible (en espérant que cela soit prochainement résolu). Merci de garder un œil sur les mises à jour de GRASS. En attendant, vous pouvez utiliser le module \"v.digit\", accessible depuis le menu Vecteur."
#: ../gui/wxpython/mapdisp/statusbar.py:357
msgid "Render"
@@ -11698,50 +10902,31 @@
msgstr "Afficher les limites de calculs"
#: ../gui/wxpython/mapdisp/statusbar.py:392
-msgid ""
-"Show/hide computational region extent (set with g.region). Display region "
-"drawn as a blue box inside the computational region, computational region "
-"inside a display region as a red box)."
-msgstr ""
-"Afficher/cacher les limites de la région de calcul (définie avec g.region). "
-"Région de l'affichage dessinée comme rectangle bleu à l'intérieur de la "
-"région de calcul, région de calcul comme rectangle rouge à l'intérieur de la "
-"région de l'affichage."
+msgid "Show/hide computational region extent (set with g.region). Display region drawn as a blue box inside the computational region, computational region inside a display region as a red box)."
+msgstr "Afficher/cacher les limites de la région de calcul (définie avec g.region). Région de l'affichage dessinée comme rectangle bleu à l'intérieur de la région de calcul, région de calcul comme rectangle rouge à l'intérieur de la région de l'affichage."
#: ../gui/wxpython/mapdisp/statusbar.py:432
msgid "Display mode"
msgstr "Mode d'affichage"
#: ../gui/wxpython/mapdisp/statusbar.py:439
-msgid ""
-"Align region extent based on display size from center point. Default value "
-"for new map displays can be set up in 'User GUI settings' dialog."
-msgstr ""
-"Aligner l'étendue de la région sur la taille de l'affichage depuis le point "
-"central. La valeur par défaut pour les nouveaux affichages peut être définie "
-"dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
+msgid "Align region extent based on display size from center point. Default value for new map displays can be set up in 'User GUI settings' dialog."
+msgstr "Aligner l'étendue de la région sur la taille de l'affichage depuis le point central. La valeur par défaut pour les nouveaux affichages peut être définie dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
#: ../gui/wxpython/mapdisp/statusbar.py:452
msgid "Display resolution"
msgstr "Résolution de l'affichage"
#: ../gui/wxpython/mapdisp/statusbar.py:459
-msgid ""
-"Constrain display resolution to computational region settings. Default value "
-msgstr ""
-"Contraindre la résolution d'affichage aux réglages de région calculée. La "
-"valeur par défaut pour les nouveaux affichages de cartes peut être réglée "
+msgid "Constrain display resolution to computational region settings. Default value for new map displays can be set up in 'User GUI settings' dialog."
+msgstr "Contraindre la résolution d'affichage aux réglages de région calculée. La valeur par défaut pour les nouveaux affichages de cartes peut être réglée dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
#: ../gui/wxpython/mapdisp/statusbar.py:483
msgid "Map scale"
msgstr "Échelle de la carte"
#: ../gui/wxpython/mapdisp/statusbar.py:497
-msgid ""
-"As everyone's monitors and resolutions are set differently these values are "
-"not true map scales, but should get you into the right neighborhood."
+msgid "As everyone's monitors and resolutions are set differently these values are not true map scales, but should get you into the right neighborhood."
msgstr ""
#: ../gui/wxpython/mapdisp/statusbar.py:550
@@ -11766,13 +10951,8 @@
msgstr "Utiliser une projection définie"
#: ../gui/wxpython/mapdisp/statusbar.py:695
-msgid ""
-"Reproject coordinates displayed in the statusbar. Projection can be defined "
-"in GUI preferences dialog (tab 'Projection')"
-msgstr ""
-"Re-projeter les coordonnées affichées dans la barre d'état. La projection "
-"peut être définie dans les préférences de l'interface utilisateur (onglet "
-"'Affichage de la carte')"
+msgid "Reproject coordinates displayed in the statusbar. Projection can be defined in GUI preferences dialog (tab 'Projection')"
+msgstr "Re-projeter les coordonnées affichées dans la barre d'état. La projection peut être définie dans les préférences de l'interface utilisateur (onglet 'Affichage de la carte')"
#: ../gui/wxpython/mapdisp/statusbar.py:720
msgid "MASK"
@@ -11851,14 +11031,8 @@
#: ../gui/wxpython/vdigit/wxdisplay.py:869
#, python-format
-msgid ""
-"Topology for vector map <%s> is not available. Topology is required by "
-"digitizer. Do you want to rebuild topology (takes some time) and open the "
-"vector map for editing?"
-msgstr ""
-"La topologie pour la carte vecteur <%s> n'est pas disponible. La topologie "
-"est requise pour la digitalisation. Voulez-vous reconstruire la topologie "
-"(peut prendre du temps) et ouvrir la carte vecteur pour édition ?"
+msgid "Topology for vector map <%s> is not available. Topology is required by digitizer. Do you want to rebuild topology (takes some time) and open the vector map for editing?"
+msgstr "La topologie pour la carte vecteur <%s> n'est pas disponible. La topologie est requise pour la digitalisation. Voulez-vous reconstruire la topologie (peut prendre du temps) et ouvrir la carte vecteur pour édition ?"
#: ../gui/wxpython/vdigit/wxdisplay.py:873
msgid "Topology missing"
@@ -11870,9 +11044,7 @@
#: ../gui/wxpython/vdigit/preferences.py:56
msgid "Close dialog and save changes to user settings file"
-msgstr ""
-"Fermer la boîte de dialogue et sauvegarder les modifications dans le fichier "
-"de réglages utilisateur"
+msgstr "Fermer la boîte de dialogue et sauvegarder les modifications dans le fichier de réglages utilisateur"
#: ../gui/wxpython/vdigit/preferences.py:148
msgid "Snapping"
@@ -11915,11 +11087,8 @@
msgstr "Ne sélectionner que les objets inclus dans la boîte de sélection"
#: ../gui/wxpython/vdigit/preferences.py:220
-msgid ""
-"By default are selected all features overlapping selection bounding box "
-msgstr ""
-"Par défaut sont sélectionnés tous les objets intersectant la boîte de "
-"sélection"
+msgid "By default are selected all features overlapping selection bounding box "
+msgstr "Par défaut sont sélectionnés tous les objets intersectant la boîte de sélection"
#: ../gui/wxpython/vdigit/preferences.py:223
msgid "Check for duplicates"
@@ -12030,12 +11199,8 @@
msgstr "périmètre"
#: ../gui/wxpython/vdigit/preferences.py:484
-msgid ""
-"Note: These settings are stored in the workspace not in the vector digitizer "
-"preferences."
-msgstr ""
-"Note : ces réglages sont stockés dans l'espace de travail, non dans les "
-"préférences du module de numérisation."
+msgid "Note: These settings are stored in the workspace not in the vector digitizer preferences."
+msgstr "Note : ces réglages sont stockés dans l'espace de travail, non dans les préférences du module de numérisation."
#: ../gui/wxpython/vdigit/preferences.py:512
msgid "Digitize new line segment"
@@ -12104,9 +11269,7 @@
#: ../gui/wxpython/vdigit/preferences.py:598
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
-msgstr ""
-"Le seuil de magnétisme vaut %(value).1f %(units)s (fondé sur la résolution "
-"calculée)"
+msgstr "Le seuil de magnétisme vaut %(value).1f %(units)s (fondé sur la résolution calculée)"
#: ../gui/wxpython/vdigit/preferences.py:654
#, python-format
@@ -12147,16 +11310,12 @@
#: ../gui/wxpython/vdigit/wxdigit.py:89
#, python-format
msgid "Unable to start database driver <%s>. Operation canceled."
-msgstr ""
-"Impossible de démarrer le pilote de base de données <%s>. Opération annulée."
+msgstr "Impossible de démarrer le pilote de base de données <%s>. Opération annulée."
#: ../gui/wxpython/vdigit/wxdigit.py:97
#, python-format
-msgid ""
-"Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
-msgstr ""
-"Impossible d'ouvrir la base de données <%(db)s> avec le pilote <"
-"%(driver)s> . Opération annulée."
+msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
+msgstr "Impossible d'ouvrir la base de données <%(db)s> avec le pilote <%(driver)s> . Opération annulée."
#: ../gui/wxpython/vdigit/wxdigit.py:105
#, python-format
@@ -12198,9 +11357,7 @@
#: ../gui/wxpython/vdigit/toolbars.py:88 ../gui/wxpython/vdigit/toolbars.py:91
#: ../gui/wxpython/vdigit/toolbars.py:112
msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
-msgstr ""
-"Gauche : nouveau point ; Ctrl+gauche : annuler le dernier point ; Droite : "
-"fermer la ligne"
+msgstr "Gauche : nouveau point ; Ctrl+gauche : annuler le dernier point ; Droite : fermer la ligne"
#: ../gui/wxpython/vdigit/toolbars.py:90
msgid "Digitize new boundary"
@@ -12211,12 +11368,8 @@
msgstr "Numériser un nouveau centroïde"
#: ../gui/wxpython/vdigit/toolbars.py:96
-msgid ""
-"Digitize new area (composition of boundaries without category and one "
-"centroid with category)"
-msgstr ""
-"Numériser une nouvelle surface (composée d'un contour sans catégorie et d'un "
-"centroïde avec catégorie)"
+msgid "Digitize new area (composition of boundaries without category and one centroid with category)"
+msgstr "Numériser une nouvelle surface (composée d'un contour sans catégorie et d'un centroïde avec catégorie)"
#: ../gui/wxpython/vdigit/toolbars.py:99
msgid "Add new vertex"
@@ -12229,8 +11382,7 @@
#: ../gui/wxpython/vdigit/toolbars.py:121
#: ../gui/wxpython/vdigit/toolbars.py:130
msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
-msgstr ""
-"Gauche : Sélectionner ; Ctrl+Gauche : Dé-sélectionner : Droite : Confirmer"
+msgstr "Gauche : Sélectionner ; Ctrl+Gauche : Dé-sélectionner : Droite : Confirmer"
#: ../gui/wxpython/vdigit/toolbars.py:102
msgid "Delete feature(s)"
@@ -12374,9 +11526,7 @@
#: ../gui/wxpython/vdigit/toolbars.py:740
#, python-format
msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
-msgstr ""
-"Merci de patienter, fermeture et reconstruction de la topologie de la carte "
-"vecteur <%s>..."
+msgstr "Merci de patienter, fermeture et reconstruction de la topologie de la carte vecteur <%s>..."
#: ../gui/wxpython/vdigit/toolbars.py:750
#, python-format
@@ -12513,8 +11663,7 @@
#: ../gui/wxpython/gmodeler/frame.py:234
msgid "Do you want to store current model settings to model file?"
-msgstr ""
-"Voulez-vous enregistrer les paramètres du modèle courants dans un fichier ?"
+msgstr "Voulez-vous enregistrer les paramètres du modèle courants dans un fichier ?"
#: ../gui/wxpython/gmodeler/frame.py:240
msgid "Quit Graphical Modeler"
@@ -12539,12 +11688,8 @@
msgstr "%d cartes supprimées du jeu de cartes courant"
#: ../gui/wxpython/gmodeler/frame.py:335 ../gui/wxpython/gmodeler/frame.py:450
-msgid ""
-"Current model is not empty. Do you want to store current settings to model "
-"file?"
-msgstr ""
-"le modèle courant n'est pas vide. Voulez-vous enregistrer les paramètres "
-"courants dans un fichier ?"
+msgid "Current model is not empty. Do you want to store current settings to model file?"
+msgstr "le modèle courant n'est pas vide. Voulez-vous enregistrer les paramètres courants dans un fichier ?"
#: ../gui/wxpython/gmodeler/frame.py:338 ../gui/wxpython/gmodeler/frame.py:453
msgid "Create new model?"
@@ -12562,8 +11707,7 @@
#: ../gui/wxpython/gmodeler/frame.py:390 ../gui/wxpython/gmodeler/frame.py:427
#, python-format
msgid "Model file <%s> already exists. Do you want to overwrite this file?"
-msgstr ""
-"Le fichier de modèle <%s> existe déjà. Voulez-vous écraser ce fichier ?"
+msgstr "Le fichier de modèle <%s> existe déjà. Voulez-vous écraser ce fichier ?"
#: ../gui/wxpython/gmodeler/frame.py:400 ../gui/wxpython/gmodeler/frame.py:440
#, python-format
@@ -12752,9 +11896,7 @@
msgstr "Enegistrer le fichier"
#: ../gui/wxpython/gmodeler/frame.py:1604
-msgid ""
-"Python script is locally modificated. Refresh will discard all changes. Do "
-"you really want to continue?"
+msgid "Python script is locally modificated. Refresh will discard all changes. Do you really want to continue?"
msgstr ""
#: ../gui/wxpython/gmodeler/frame.py:1607
@@ -13032,12 +12174,8 @@
#: ../gui/wxpython/gmodeler/dialogs.py:848
#, python-format
-msgid ""
-"Selected data records (%d) will permanently deleted from table. Do you want "
-"to delete them?"
-msgstr ""
-"Les enregistrements sélectionnés (%d) vont être définitivement supprimés de "
-"la table. Souhaitez-vous les supprimer ?"
+msgid "Selected data records (%d) will permanently deleted from table. Do you want to delete them?"
+msgstr "Les enregistrements sélectionnés (%d) vont être définitivement supprimés de la table. Souhaitez-vous les supprimer ?"
#: ../gui/wxpython/gmodeler/dialogs.py:905
msgid "Normalize"
@@ -13065,16 +12203,12 @@
#: ../gui/wxpython/core/render.py:421
msgid "GISBASE not set. You must be in GRASS GIS to run this program."
-msgstr ""
-"GISBASE non définie. Vous devez être dans GRASS GIS pou exécuter ce "
-"programme."
+msgstr "GISBASE non définie. Vous devez être dans GRASS GIS pou exécuter ce programme."
#: ../gui/wxpython/core/render.py:466
#, python-format
msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
-msgstr ""
-"Erreur : impossible d'ouvrir '%(file)s'. Raison : %(ret)s. Sortie de "
-"wxGUI.\n"
+msgstr "Erreur : impossible d'ouvrir '%(file)s'. Raison : %(ret)s. Sortie de wxGUI.\n"
#: ../gui/wxpython/core/render.py:642
#, python-format
@@ -13092,12 +12226,8 @@
msgstr "Impossible de zoomer sur la carte vecteur <%s>."
#: ../gui/wxpython/core/render.py:648
-msgid ""
-"Unable to get current geographic extent. Force quiting wxGUI. Please "
-"manually run g.region to fix the problem."
-msgstr ""
-"Impossible d'obtenir l’extension géographique courante. Sortie forcée de "
-"wxGUI. Merci d'exécuter manuellement g.region pour résoudre ce problème."
+msgid "Unable to get current geographic extent. Force quiting wxGUI. Please manually run g.region to fix the problem."
+msgstr "Impossible d'obtenir l’extension géographique courante. Sortie forcée de wxGUI. Merci d'exécuter manuellement g.region pour résoudre ce problème."
#: ../gui/wxpython/core/render.py:931
#, python-format
@@ -13296,8 +12426,7 @@
"\n"
"Number of skipped lines: %(line)d"
msgstr ""
-"Certaines lignes ont été sautées à la lecture des réglages du fichier <"
-"%(file)s>.\n"
+"Certaines lignes ont été sautées à la lecture des réglages du fichier <%(file)s>.\n"
"Voir la fenêtre 'Sortie de commande' pour des détails.\n"
"\n"
"Nombre de lignes sautées : %(line)d"
@@ -13341,28 +12470,14 @@
#~ msgid "Adjusts the viewer's angle of view"
#~ msgstr "Ajuster l'angle de vue"
-#~ msgid ""
-#~ "Rotates the scene about the horizontal axis. An angle of 0 is flat. The "
-#~ "scene rotates between -90 and 90 degrees."
-#~ msgstr ""
-#~ "Effectue une rotation sur l'axe horitontal. Un angle de 0 est plat. "
-#~ "L'angle de rotation doit être entre -90 et 90 degrés."
+#~ msgid "Rotates the scene about the horizontal axis. An angle of 0 is flat. The scene rotates between -90 and 90 degrees."
+#~ msgstr "Effectue une rotation sur l'axe horitontal. Un angle de 0 est plat. L'angle de rotation doit être entre -90 et 90 degrés."
-#~ msgid ""
-#~ "Adjusts the vertical exaggeration of the surface. As an example, if the "
-#~ "easting and northing are in meters and the elevation in feet, a vertical "
-#~ "exaggeration of .305 would produce a true (unexaggerated) surface. "
-#~ msgstr ""
-#~ "Ajuster l'exagération verticale. Par exemple, si les abscisse et ordonnée "
-#~ "sont en mètres et l'altitude en pieds, une exagération verticale de 0,305 "
-#~ "produira une surface vraie (non exagérée)."
+#~ msgid "Adjusts the vertical exaggeration of the surface. As an example, if the easting and northing are in meters and the elevation in feet, a vertical exaggeration of .305 would produce a true (unexaggerated) surface. "
+#~ msgstr "Ajuster l'exagération verticale. Par exemple, si les abscisse et ordonnée sont en mètres et l'altitude en pieds, une exagération verticale de 0,305 produira une surface vraie (non exagérée)."
-#~ msgid ""
-#~ "Adjusts the look direction (azimuth). Click and drag the puck to change "
-#~ "the current eye position."
-#~ msgstr ""
-#~ "Ajuster la direction de la vue (azimuth). Cliquez et déplacez le point "
-#~ "pour changer l'angle de vue."
+#~ msgid "Adjusts the look direction (azimuth). Click and drag the puck to change the current eye position."
+#~ msgstr "Ajuster la direction de la vue (azimuth). Cliquez et déplacez le point pour changer l'angle de vue."
#~ msgid "Profile line settings"
#~ msgstr "Réglages de ligne du profil"
@@ -13387,17 +12502,12 @@
#~ "\n"
#~ "New attribute table can be created by Attribute Table Manager."
#~ msgstr ""
-#~ "Aucune table attributaire liée à la carte vecteur <%(vector)s> trouvée. "
-#~ "%(msg)s\n"
+#~ "Aucune table attributaire liée à la carte vecteur <%(vector)s> trouvée. %(msg)s\n"
#~ "\n"
-#~ "Une nouvelle table attributaire peut être créée par le gestionnaire de "
-#~ "table attributaire."
+#~ "Une nouvelle table attributaire peut être créée par le gestionnaire de table attributaire."
-#~ msgid ""
-#~ "Module r.mapcalc cannot be used in the model. Use r.mapcalculator instead."
-#~ msgstr ""
-#~ "Le module r.mapcalc ne peut pas être utilisé dans le modèle. Utiliser r."
-#~ "mapcalculator à la place."
+#~ msgid "Module r.mapcalc cannot be used in the model. Use r.mapcalculator instead."
+#~ msgstr "Le module r.mapcalc ne peut pas être utilisé dans le modèle. Utiliser r.mapcalculator à la place."
#~ msgid "Change ID"
#~ msgstr "Modifier l'ID"
@@ -13512,16 +12622,10 @@
#~ msgstr "Remplacer la table de couleur existante"
#~ msgid "Please select attribute column and RGB color column first"
-#~ msgstr ""
-#~ "Merci de sélectionner d'abord une colonne d'attribut et une colonne de "
-#~ "couleur RVG"
+#~ msgstr "Merci de sélectionner d'abord une colonne d'attribut et une colonne de couleur RVG"
-#~ msgid ""
-#~ "Color table already exists. Check out 'replace existing color table' to "
-#~ "overwrite it."
-#~ msgstr ""
-#~ "La table de couleur existe déjà. Cochez la case « remplacer la table de "
-#~ "couleur existante » pour la remplacer."
+#~ msgid "Color table already exists. Check out 'replace existing color table' to overwrite it."
+#~ msgstr "La table de couleur existe déjà. Cochez la case « remplacer la table de couleur existante » pour la remplacer."
#~ msgid "Function not implemented yet"
#~ msgstr "Fonction pas encore implantée"
@@ -13558,8 +12662,7 @@
#~ "Layer and category number must be integer.\n"
#~ "Layer number must be greater then zero."
#~ msgstr ""
-#~ "Impossible d'ajouter la nouvelle couche/catégorie <%(layer)s/%(category)"
-#~ "s>.\n"
+#~ "Impossible d'ajouter la nouvelle couche/catégorie <%(layer)s/%(category)s>.\n"
#~ "Les numéros de couche et de catégorie doivent être des nombres entiers.\n"
#~ "Le numéro de couche doit être supérieur à zéro."
@@ -13572,16 +12675,11 @@
#~ msgid "GRASS Quickstart"
#~ msgstr "Démarrage rapide de GRASS"
-#~ msgid ""
-#~ "Hardcopy Map Output Utility is not available. You can install it by %s"
-#~ msgstr ""
-#~ "L'utilitaire de sortie papier n'est pas disponible. Vous pouvez "
-#~ "l'installer via %s"
+#~ msgid "Hardcopy Map Output Utility is not available. You can install it by %s"
+#~ msgstr "L'utilitaire de sortie papier n'est pas disponible. Vous pouvez l'installer via %s"
#~ msgid "Unable to switch to location <%(loc)s> mapset <%(mapset)s>."
-#~ msgstr ""
-#~ "Impossible d'aller dans le jeux de cartes <%(mapset)s> du secteur de "
-#~ "travail <%(loc)s>."
+#~ msgstr "Impossible d'aller dans le jeux de cartes <%(mapset)s> du secteur de travail <%(loc)s>."
#~ msgid "Starting GRASS GUI..."
#~ msgstr "Démarrage de l'interface graphique de GRASS"
@@ -13732,8 +12830,7 @@
#~ msgstr "Interrogation de vecteur"
#~ msgid "Query raster/vector map(s) (display mode)"
-#~ msgstr ""
-#~ "Interroger une(des) carte(s) 'raster'/vectorielle(s) (mode affichage)"
+#~ msgstr "Interroger une(des) carte(s) 'raster'/vectorielle(s) (mode affichage)"
#~ msgid "Query vector map (edit mode)"
#~ msgstr "Interroger une carte vecteur (mode édition)"
@@ -13752,8 +12849,7 @@
#~ msgstr "<obligatoire>"
#~ msgid "Unable to fetch interface description for command '%s'."
-#~ msgstr ""
-#~ "Impossible de trouver la description de l'interface pour la commande '%s'."
+#~ msgstr "Impossible de trouver la description de l'interface pour la commande '%s'."
#~ msgid "Menu style:"
#~ msgstr "Style de menu :"
@@ -13802,9 +12898,7 @@
#~ msgstr "Reclassifier une carte 'raster' selon des règles"
#~ msgid "Attribute management is available only for vector maps."
-#~ msgstr ""
-#~ "La gestion des attributs est seulement disponible pour les cartes "
-#~ "vectorielles"
+#~ msgstr "La gestion des attributs est seulement disponible pour les cartes vectorielles"
#~ msgid "Display zoom management"
#~ msgstr "Gestion des zooms"
@@ -13847,9 +12941,7 @@
#~ msgstr "Aide à la localisation"
#~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#~ msgstr ""
-#~ "Importer un fichier 'raster' supporté par GDAL dans une carte 'raster' "
-#~ "binaire"
+#~ msgstr "Importer un fichier 'raster' supporté par GDAL dans une carte 'raster' binaire"
#, fuzzy
#~ msgid "Bulk import of raster data"
@@ -13857,23 +12949,15 @@
#, fuzzy
#~ msgid "Converts multiple GDAL supported layers to GRASS raster maps."
-#~ msgstr ""
-#~ "Convertir des couches GDAL sélectionnées en 'raster' GRASS au moyen de r."
-#~ "in.gdal"
+#~ msgstr "Convertir des couches GDAL sélectionnées en 'raster' GRASS au moyen de r.in.gdal"
#, fuzzy
#~ msgid "Link GDAL supported raster file to a binary raster map layer."
-#~ msgstr ""
-#~ "binaire"
#, fuzzy
-#~ msgid ""
-#~ "Link multiple GDAL supported raster maps as pseudo GRASS raster map "
-#~ "layers."
-#~ msgstr ""
-#~ "binaire"
+#~ msgid "Link multiple GDAL supported raster maps as pseudo GRASS raster map layers."
#, fuzzy
#~ msgid "Bulk import of vector data"
@@ -13881,22 +12965,15 @@
#, fuzzy
#~ msgid "Converts selected OGR layers to GRASS vector maps using v.in.ogr"
-#~ msgstr ""
-#~ "Convertit les couches OGR sélectionées en cartes vectorielles GRASS en "
-#~ "utilisant v.in.ogr."
+#~ msgstr "Convertit les couches OGR sélectionées en cartes vectorielles GRASS en utilisant v.in.ogr."
#, fuzzy
-#~ msgid ""
-#~ "Creates multiple new pseduo-vector maps as a read-only links using OGR."
-#~ msgstr ""
-#~ "Crée un carte vectorielle depuis un fichier de points ASCII ou un fichier "
-#~ "vecteur ASCII."
+#~ msgid "Creates multiple new pseduo-vector maps as a read-only links using OGR."
+#~ msgstr "Crée un carte vectorielle depuis un fichier de points ASCII ou un fichier vecteur ASCII."
#, fuzzy
#~ msgid "Converts multiple DXF layers to GRASS vector maps."
-#~ msgstr ""
#, fuzzy
#~ msgid "Georectify raster and vector maps"
@@ -13913,13 +12990,11 @@
#, fuzzy
#~ msgid "Allows projection conversion of vector maps."
-#~ msgstr ""
-#~ "Importe des cartes vectorielles au format d'anciennes versions de GRASS."
+#~ msgstr "Importe des cartes vectorielles au format d'anciennes versions de GRASS."
#, fuzzy
#~ msgid "Set colors interactively by entering color rules"
-#~ msgstr ""
-#~ "Créer une nouvelle table de couleur en utilisant des règles de coloriage"
+#~ msgstr "Créer une nouvelle table de couleur en utilisant des règles de coloriage"
#~ msgid "Reclassify objects interactively"
#~ msgstr "Classification interactive d'objets"
@@ -13933,16 +13008,13 @@
#~ msgstr "SIG GRASS - Moniteur d'affichage des cartes"
#~ msgid "Select image/map to display for ground control point (GCP) creation"
-#~ msgstr ""
-#~ "Sélectionner une image ou une carte à afficher pour la création des "
-#~ "points de contrôle au sol (PCS)"
+#~ msgstr "Sélectionner une image ou une carte à afficher pour la création des points de contrôle au sol (PCS)"
#~ msgid "Select display image/map:"
#~ msgstr "Sélectionner l'image ou la carte à afficher :"
#~ msgid "You must select a valid image/map in order to continue"
-#~ msgstr ""
-#~ "Vous devez choisir une image ou une carte valide pour pouvoir continuer"
+#~ msgstr "Vous devez choisir une image ou une carte valide pour pouvoir continuer"
#, fuzzy
#~ msgid "Define/manage ground control points"
@@ -13961,8 +13033,7 @@
#~ msgstr "Paramètres de géo-rectification"
#~ msgid "RMS error for selected points forward: %(fwd)s backward: %(bkw)s"
-#~ msgstr ""
-#~ "Erreur RMS pour les points sélectionnés avant : %(fwd)s arrière : %(bkw)s"
+#~ msgstr "Erreur RMS pour les points sélectionnés avant : %(fwd)s arrière : %(bkw)s"
#~ msgid "use| X coord"
#~ msgstr "Utiliser| coord X"
@@ -13986,8 +13057,7 @@
#~ msgstr "Entrer les règles"
#~ msgid "Create new color table using color rules"
-#~ msgstr ""
#~ msgid "Raster map:"
#~ msgstr "Carte 'raster' :"
@@ -14092,8 +13162,7 @@
#~ "\n"
#~ "Details: %s"
#~ msgstr ""
-#~ "Impossible de démarrer Nviz. L'extension Python pour Nviz n'a pas été "
-#~ "trouvée ou chargée correctement. Retour au mode d'affichage 2D.\n"
+#~ "Impossible de démarrer Nviz. L'extension Python pour Nviz n'a pas été trouvée ou chargée correctement. Retour au mode d'affichage 2D.\n"
#~ "\n"
#~ "Détails : %s"
@@ -14105,8 +13174,7 @@
#~ "\n"
#~ "Details: %s"
#~ msgstr ""
-#~ "Impossible de démarrer Nviz. La classe GLCanvas n'a pas été incluse dans "
-#~ "cette compilation de wxPython! Retour au mode d'affichage 2D.\n"
+#~ "Impossible de démarrer Nviz. La classe GLCanvas n'a pas été incluse dans cette compilation de wxPython! Retour au mode d'affichage 2D.\n"
#~ "\n"
#~ "Détails : %s"
@@ -14194,17 +13262,13 @@
#~ msgstr "Setup pour la géo-rectification"
#~ msgid "Use coordinate system of selected georeferenced file"
-#~ msgstr ""
-#~ "Utiliser le système de coordonnées du fichier géo-référencé sélectionné"
+#~ msgstr "Utiliser le système de coordonnées du fichier géo-référencé sélectionné"
#~ msgid "Use coordinate system of selected WKT or PRJ file"
-#~ msgstr ""
-#~ "Utiliser le système de coordonnées du fichier WKT ou PRJ sélectionné"
+#~ msgstr "Utiliser le système de coordonnées du fichier WKT ou PRJ sélectionné"
#~ msgid "Create custom PROJ.4 parameters string for coordinate system"
-#~ msgstr ""
-#~ "Créer une chaîne de paramètres PROJ.4 particuliers pour le système de "
-#~ "coordonnées"
+#~ msgstr "Créer une chaîne de paramètres PROJ.4 particuliers pour le système de coordonnées"
#~ msgid "Select ellipsoid"
#~ msgstr "Choisir l'ellipsoïde"
@@ -14231,14 +13295,11 @@
#~ msgstr "Données : "
#~ msgid ""
-#~ "Unable to start Nviz. The OpenGL package was not found. You can get it at "
-#~ "http://PyOpenGL.sourceforge.net. Switching back to 2D display mode.\n"
+#~ "Unable to start Nviz. The OpenGL package was not found. You can get it at http://PyOpenGL.sourceforge.net. Switching back to 2D display mode.\n"
#~ "\n"
#~ "Details: %s"
#~ msgstr ""
-#~ "Impossible de démarrer Nviz. Le package OpenGL n'a pas été trouvé. Vous "
-#~ "pouvez le trouver sur http://PyOpenGL.sourceforge.net. Retour au mode "
-#~ "d'affichage 2D.\n"
+#~ "Impossible de démarrer Nviz. Le package OpenGL n'a pas été trouvé. Vous pouvez le trouver sur http://PyOpenGL.sourceforge.net. Retour au mode d'affichage 2D.\n"
#~ "\n"
#~ "Détails : %s"
@@ -14255,9 +13316,7 @@
#~ msgstr "Ouvrir un espace de travail existant"
#~ msgid "Load map layers from GRC file to layer tree (not fully implemented)"
-#~ msgstr ""
-#~ "Charger des cartes depuis un fichier GRC dans l'arborescence des couches "
-#~ "(pas totalement implémenté)"
+#~ msgstr "Charger des cartes depuis un fichier GRC dans l'arborescence des couches (pas totalement implémenté)"
#~ msgid "Save workspace as"
#~ msgstr "Sauver l'espace de travail sous"
@@ -14302,9 +13361,7 @@
#~ "Invalid file, unable to parse XML document.\n"
#~ "\n"
#~ "%(err)s"
-#~ msgstr ""
-#~ "Lecture du fichier d'environnement <%s> impossible. Fichier invalide, "
-#~ "incapable de déchiffrer le document XML"
+#~ msgstr "Lecture du fichier d'environnement <%s> impossible. Fichier invalide, incapable de déchiffrer le document XML"
#~ msgid "Import raster map"
#~ msgstr "Importer une carte raster"
@@ -14337,9 +13394,7 @@
#~ msgstr "Crée des lignes vectorielles depuis un fichier de points ASCII x,y."
#~ msgid "Create new workspace file (erase current workspace settings first)"
-#~ msgstr ""
-#~ "Créer un nouvel espace de travail (efface d'abord les paramètres de "
-#~ "l'espace en cours)"
+#~ msgstr "Créer un nouvel espace de travail (efface d'abord les paramètres de l'espace en cours)"
#~ msgid "Unable to open workspace file <%s> for writing."
#~ msgstr "Impossible d'ouvrir le fichier d'environnement <%s> en écriture."
@@ -14368,17 +13423,11 @@
#~ msgid "Run the command"
#~ msgstr "Exécuter la commande"
-#~ msgid ""
-#~ "Reading workspace file <%s> failed. Invalid file, unable to parse XML "
-#~ "document."
-#~ msgstr ""
+#~ msgid "Reading workspace file <%s> failed. Invalid file, unable to parse XML document."
#~ msgid "Writing current settings to workspace file failed (%s)."
-#~ msgstr ""
-#~ "Ecriture des paramètres courant dans le fichier d'environnement (%s) non "
-#~ "réussie."
+#~ msgstr "Ecriture des paramètres courant dans le fichier d'environnement (%s) non réussie."
#, fuzzy
#~ msgid "Add various vector-based map layer"
@@ -14481,8 +13530,7 @@
#~ msgstr "Nom de la carte GRASS"
#~ msgid "GRASS GIS Layer Manager (Experimental Prototype)"
-#~ msgstr ""
-#~ "Gestionnaire de couches d'information GRASS GIS (prototype expérimental)"
+#~ msgstr "Gestionnaire de couches d'information GRASS GIS (prototype expérimental)"
#, fuzzy
#~ msgid "Copying attributes..."
