[GRASS-SVN] r59797 - in grass/branches/releasebranch_7_0: . locale/po
svn_grass at osgeo.org
Sat Apr 19 05:15:41 PDT 2014
Author: neteler
Date: 2014-04-19 05:15:41 -0700 (Sat, 19 Apr 2014)
New Revision: 59797
grass/branches/releasebranch_7_0/locale/po/grasslibs_zh.po
grass/branches/releasebranch_7_0/translators.csv
YusiJi: Chinese translation cont'ed
Modified: grass/branches/releasebranch_7_0/locale/po/grasslibs_zh.po
--- grass/branches/releasebranch_7_0/locale/po/grasslibs_zh.po 2014-04-19 12:14:16 UTC (rev 59796)
+++ grass/branches/releasebranch_7_0/locale/po/grasslibs_zh.po 2014-04-19 12:15:41 UTC (rev 59797)
@@ -3,22 +3,21 @@
# Copyright (C) 2005, GRASS Development Team
# Zhang Jun <nilarcs at gmail.com>, 2005, 2006.
-# Su Yongheng <night2008 at gmail.com>
+# Su Yongheng <night2008 at gmail.com>, 2007.
+# YusiJi <jiyusi0001 at gmail.com>, 2014.
msgid ""
msgstr ""
"Project-Id-Version: grasslibs_zh\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2014-03-27 20:41+0100\n"
-"PO-Revision-Date: 2007-12-13 16:42+0100\n"
-"Last-Translator: Su Yongheng <night2008 at gmail.com>\n"
+"PO-Revision-Date: 2014-04-16 12:27+0100\n"
+"Last-Translator: YusiJi <jiyusi0001 at gmail.com>\n"
"Language-Team: Simplified Chinese <translations at grass.itc.it>\n"
"Language: zh_ZH\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
-"X-Poedit-Language: Chinese\n"
-"X-Poedit-Country: CHINA\n"
-"X-Generator: KBabel 1.11.2\n"
+"X-Generator: Poedit 1.6.4\n"
#: ../lib/raster/color_rules.c:125
msgid "syntax error"
@@ -185,21 +184,15 @@
msgstr "无法打开矢量'%s'的历史记录"
#: ../lib/raster/window.c:18
-msgid ""
-"Internal error: Rast_get_window() called with split window. Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
+msgid "Internal error: Rast_get_window() called with split window. Use Rast_get_input_window() or Rast_get_output_window() instead."
msgstr ""
#: ../lib/raster/window.c:77
-msgid ""
-"Internal error: Rast_window_rows() called with split window. Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
+msgid "Internal error: Rast_window_rows() called with split window. Use Rast_input_window_rows() or Rast_output_window_rows() instead."
msgstr ""
#: ../lib/raster/window.c:112
-msgid ""
-"Internal error: Rast_window_cols() called with split window. Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
+msgid "Internal error: Rast_window_cols() called with split window. Use Rast_input_window_cols() or Rast_output_window_cols() instead."
msgstr ""
#: ../lib/raster/quant_rw.c:88
@@ -228,9 +221,7 @@
#: ../lib/raster/set_window.c:131
#, fuzzy
-msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
+msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
msgstr "G_set_window():投影/区域与当前打开的栅格文件不同"
#: ../lib/raster/set_window.c:158
@@ -425,11 +416,8 @@
#: ../lib/raster/get_cellhd.c:66
#, fuzzy, c-format
-msgid ""
-"Unable to read header file for raster map <%s@%s>.It is a reclass of raster "
-"map <%s@%s> %s"
-msgstr ""
-"无法打开[%s](在[%s]中),因为它是[%s](在[%s]中)的一个重分类,而它并不存在。"
+msgid "Unable to read header file for raster map <%s@%s>.It is a reclass of raster map <%s@%s> %s"
+msgstr "无法打开[%s](在[%s]中),因为它是[%s](在[%s]中)的一个重分类,而它并不存在。"
#: ../lib/raster/get_cellhd.c:70
#, fuzzy
@@ -513,9 +501,7 @@
#: ../lib/raster/gdal.c:497
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
msgstr ""
#: ../lib/raster/gdal.c:503
@@ -606,11 +592,8 @@
#: ../lib/raster/open.c:190
#, fuzzy, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
-msgstr ""
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
#: ../lib/raster/open.c:195
#, fuzzy, c-format
@@ -629,9 +612,7 @@
#: ../lib/raster/open.c:219
#, fuzzy, c-format
-msgid ""
-"Raster map <%s> is in different projection than current region. Found <%s>, "
-"should be <%s>."
+msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
msgstr ""
"[%s]在地图集[%s]中 - 与当前范围的投影不同:\n"
" 找到的地图[%s]在<%s>投影下,当前的投影应该是<%s> "
@@ -648,8 +629,7 @@
#: ../lib/raster/open.c:256
#, c-format
-msgid ""
-"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
msgstr ""
#: ../lib/raster/open.c:264
@@ -717,8 +697,7 @@
msgstr "输入矢量'%s'未找到"
#: ../lib/raster/open.c:929
-msgid ""
-"Rast_set_quant_rules() can be called only for raster maps opened for reading"
+msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
msgstr ""
#: ../lib/raster/color_rand.c:33
@@ -755,11 +734,11 @@
#: ../lib/ogsf/gk.c:320
msgid "Need at least 3 keyframes for spline"
-msgstr ""
+msgstr "样条需要至少三个关键帧"
#: ../lib/ogsf/gk.c:622
msgid "Need at least 2 keyframes for interpolation"
-msgstr ""
+msgstr "插值需要至少两个关键帧"
#: ../lib/ogsf/Gv3.c:60 ../lib/ogsf/Gv3.c:326 ../lib/ogsf/Gp3.c:56
#: ../lib/ogsf/Gp3.c:189 ../lib/manage/do_rename.c:54
@@ -780,7 +759,7 @@
#: ../lib/ogsf/Gv3.c:262
#, c-format
msgid "No features from vector map <%s> fall within current region"
-msgstr ""
+msgstr "矢量图中没有地物落在当前区域 <%s>"
#: ../lib/ogsf/Gv3.c:267
#, fuzzy, c-format
@@ -828,14 +807,12 @@
#: ../lib/ogsf/Gv3.c:407
#, c-format
-msgid ""
-"%d features without category. Unable to determine color rules for features "
-"without category."
+msgid "%d features without category. Unable to determine color rules for features without category."
msgstr ""
#: ../lib/ogsf/gvl_file.c:103
msgid "Maximum number of datafiles exceeded"
-msgstr ""
+msgstr "超出数据文件的最大值"
#: ../lib/ogsf/gvl_file.c:427 ../lib/ogsf/Gvl3.c:40
#: ../lib/gpde/N_arrays_io.c:273 ../lib/manage/do_rename.c:76
@@ -871,7 +848,7 @@
#: ../lib/ogsf/Gp3.c:146
#, c-format
msgid "No points from vector map <%s> fall within current region"
-msgstr ""
+msgstr "矢量图中没有点落在当前区域 <%s>"
#: ../lib/ogsf/Gp3.c:151
#, fuzzy, c-format
@@ -885,18 +862,16 @@
#: ../lib/ogsf/Gp3.c:286
#, c-format
-msgid ""
-"%d points without category. Unable to determine color rules for features "
+msgid "%d points without category. Unable to determine color rules for features without category."
msgstr ""
#: ../lib/ogsf/trans.c:180
msgid "Out of matrix stack space"
-msgstr ""
+msgstr "超出矩阵堆栈空间"
#: ../lib/ogsf/trans.c:200
msgid "Tried to pop an empty stack"
-msgstr ""
+msgstr "尝试弹出一个空堆栈"
#: ../lib/ogsf/GK2.c:216 ../lib/ogsf/gsd_img_ppm.c:52
#: ../lib/ogsf/gsd_img_ppm.c:95 ../lib/ogsf/gsd_img_tif.c:64
@@ -906,11 +881,11 @@
#: ../lib/ogsf/GK2.c:272 ../lib/ogsf/GK2.c:285
msgid "Check no. of frames requested and keyframes marked"
-msgstr ""
+msgstr "检查请求的帧数和标记的关键帧数"
#: ../lib/ogsf/gsds.c:109
msgid "Maximum number of datasets exceeded"
-msgstr ""
+msgstr "超出数据集的最大值"
#: ../lib/ogsf/gsdrape.c:207
#, fuzzy
@@ -919,7 +894,7 @@
#: ../lib/ogsf/gsd_label.c:58
msgid "Max. number of labels reached!"
-msgstr ""
+msgstr "达到标签的最大值"
#: ../lib/ogsf/gsd_img_mpeg.c:72
#, fuzzy
@@ -954,11 +929,11 @@
#: ../lib/ogsf/gsd_img_mpeg.c:328
#, c-format
msgid "Opening MPEG stream <%s>..."
-msgstr ""
+msgstr "正在打开MPEG流 <%s>..."
#: ../lib/ogsf/gsd_img_mpeg.c:340
msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
+msgstr "无法推断出文件扩展名的输出格式:使用MPEG"
#: ../lib/ogsf/gsd_img_mpeg.c:348
#, fuzzy
@@ -977,7 +952,7 @@
#: ../lib/ogsf/gsd_img_mpeg.c:414
msgid "OGSF library has not been built with MPEG output support"
-msgstr ""
+msgstr "MPEG输出支持下OGSF库尚未建成"
#: ../lib/ogsf/gsd_prim.c:146
#, c-format
@@ -986,20 +961,18 @@
#: ../lib/ogsf/gsd_prim.c:630
#, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot(): %c是无效的轴定义。旋转忽略。请告知GRASS开发这个错误。"
#: ../lib/ogsf/GS2.c:1211
#, c-format
msgid "no category info"
-msgstr ""
+msgstr "没有种类信息"
#: ../lib/ogsf/GS2.c:1230
#, c-format
msgid "no data"
-msgstr ""
+msgstr "没有数据"
#: ../lib/ogsf/GS2.c:1655
#, fuzzy, c-format
@@ -1010,7 +983,7 @@
#: ../lib/ogsf/GS2.c:1756 ../lib/ogsf/GS2.c:1764 ../lib/ogsf/GS2.c:1774
#: ../lib/ogsf/GS2.c:1822
msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr ""
+msgstr "GS_load_att_map(): 内存不足,不能加载地图。"
#: ../lib/ogsf/GS2.c:1850
#, fuzzy
@@ -1031,7 +1004,7 @@
#: ../lib/ogsf/Gs3.c:596
#, c-format
msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
+msgstr "色彩表序列不能匹配数据(mincol=%d, maxcol=%d"
#: ../lib/ogsf/Gs3.c:658 ../lib/ogsf/Gs3.c:730
#, fuzzy, c-format
@@ -1040,11 +1013,11 @@
#: ../lib/ogsf/Gs3.c:967
msgid "View not saved by this program,there may be some inconsistancies"
-msgstr ""
+msgstr "视图没有被程序保存,可能存在矛盾。"
#: ../lib/ogsf/gs_bm.c:124
msgid "Bitmap mismatch"
-msgstr ""
+msgstr "位图不匹配。"
#: ../lib/ogsf/GP2.c:705
msgid "Unknown icon marker, using \"sphere\""
@@ -1052,7 +1025,7 @@
#: ../lib/ogsf/gsd_surf.c:1742
msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr ""
+msgstr "表面之间切面点不匹配。"
#: ../lib/ogsf/gsd_legend.c:246
#, fuzzy, c-format
@@ -1076,7 +1049,7 @@
#: ../lib/ogsf/gsd_legend.c:295
msgid "Range request error for legend"
-msgstr ""
+msgstr "图例范围请求错误。"
#: ../lib/ogsf/gsd_legend.c:385
#, fuzzy
@@ -1090,7 +1063,7 @@
#: ../lib/ogsf/gsd_legend.c:503
msgid "Try using smaller font!"
-msgstr ""
+msgstr "请使用小字体。"
#: ../lib/gpde/N_arrays_io.c:93
#, fuzzy, c-format
@@ -1141,7 +1114,7 @@
#: ../lib/gpde/N_parse_options.c:106
msgid "The calculation time in seconds"
-msgstr ""
+msgstr "数秒的计算时间"
#: ../lib/segment/format.c:143
msgid "Segment format: file size too large"
@@ -1209,7 +1182,7 @@
#: ../lib/proj/get_proj.c:294
msgid "Option input overflowed option table"
-msgstr ""
+msgstr "选项输出溢出选项表"
#: ../lib/proj/get_proj.c:325
#, fuzzy, c-format
@@ -1249,7 +1222,7 @@
#: ../lib/proj/ellipse.c:103
msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr ""
+msgstr "无二次椭球描述符( rf,es或b )的文件"
#: ../lib/proj/ellipse.c:107
#, fuzzy
@@ -1293,8 +1266,7 @@
#: ../lib/proj/convert.c:139
#, fuzzy, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
msgstr ""
"OGR不能解析PROJ.4类型的参数字符串:\\n\n"
"%s\\n\n"
@@ -1314,26 +1286,22 @@
#: ../lib/proj/convert.c:442
#, c-format
msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr ""
+msgstr "日期<%s>不能被GRASS识别并且找不到参数"
#: ../lib/proj/convert.c:458
#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "日期<%s>不能被GRASS识别并且找不到参数。您可能想查阅这里。"
#: ../lib/proj/convert.c:462
#, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "无效的转换码%d;有小的序列是1到%d.委托基准变换参数不详。"
#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
#, c-format
msgid "pj_transform() failed: %s"
-msgstr ""
+msgstr "pj转换()失败: %s"
#: ../lib/nviz/position.c:56
#, fuzzy
@@ -1342,7 +1310,7 @@
#: ../lib/nviz/render.c:106
msgid "Bad server connection"
-msgstr ""
+msgstr "连接不到服务器"
#: ../lib/nviz/render.c:112
#, fuzzy
@@ -1361,11 +1329,11 @@
#: ../lib/nviz/map_obj.c:59
msgid "Maximum surfaces loaded!"
-msgstr ""
+msgstr "最大表面已加载"
#: ../lib/nviz/map_obj.c:88
msgid "Maximum vector line maps loaded!"
-msgstr ""
+msgstr "最大矢量线性地图已加载"
#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
#, fuzzy, c-format
@@ -1374,11 +1342,11 @@
#: ../lib/nviz/map_obj.c:116
msgid "Maximum vector point maps loaded!"
-msgstr ""
+msgstr "最大矢量点地图已加载"
#: ../lib/nviz/map_obj.c:143
msgid "Maximum volumes loaded!"
-msgstr ""
+msgstr "最大容积已加载"
#: ../lib/nviz/map_obj.c:152
#, fuzzy, c-format
@@ -1387,7 +1355,7 @@
#: ../lib/nviz/map_obj.c:160
msgid "Nviz_new_map_obj(): unsupported data type"
-msgstr ""
+msgstr "Nviz新地图对象():不被支持的数据类型"
#: ../lib/nviz/lights.c:171
#, fuzzy
@@ -1401,21 +1369,19 @@
#: ../lib/sites/sites.c:151
msgid "Category must be integer"
-msgstr ""
+msgstr "类别必须是整型"
#: ../lib/sites/sites.c:226
msgid "Memory error in writing timestamp"
-msgstr ""
+msgstr "时间戳存储错误。"
#: ../lib/sites/sites.c:228
msgid "Illegal TimeStamp string"
-msgstr ""
+msgstr "非法的时间戳串"
#: ../lib/sites/sites.c:255 ../lib/sites/sites.c:385
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
-msgstr ""
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
+msgstr "Dev 笔记:改编站点库用于矢量点。(模块应更新为 GRASS 6向量库)"
#: ../lib/sites/sites.c:288 ../lib/db/dbmi_client/table.c:110
#: ../lib/db/dbmi_client/copy_tab.c:218 ../lib/db/dbmi_client/copy_tab.c:295
@@ -1434,8 +1400,7 @@
msgstr ""
#: ../lib/sites/sites.c:668
-msgid ""
-"G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
+msgid "G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
msgstr ""
#: ../lib/db/dbmi_driver/d_error.c:35
@@ -1616,7 +1581,7 @@
#: ../lib/db/dbmi_base/default_name.c:136
msgid "Programmer error"
-msgstr ""
+msgstr "程序错误"
#: ../lib/db/dbmi_client/table.c:46 ../lib/db/dbmi_client/delete_tab.c:40
#, fuzzy, c-format
@@ -1686,11 +1651,11 @@
#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
#: ../lib/db/dbmi_client/select.c:288
msgid "Missing column name"
-msgstr ""
+msgstr "缺少列名。"
#: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
msgid "Missing key column name"
-msgstr ""
+msgstr "缺少关键列名"
#: ../lib/db/dbmi_client/select.c:317 ../lib/vector/Vlib/cats.c:603
#, fuzzy, c-format
@@ -1897,8 +1862,7 @@
#: ../lib/cairodriver/read_ppm.c:56
#, c-format
-msgid ""
-"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
msgstr ""
#: ../lib/cairodriver/Graph.c:67
@@ -2084,8 +2048,7 @@
#: ../lib/init/grass.py:264
#, fuzzy, python-format
-msgid ""
-"Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
+msgid "Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
msgstr "无法分配内存\n"
#: ../lib/init/grass.py:348
@@ -2149,9 +2112,7 @@
#: ../lib/init/grass.py:612
#, python-format
-msgid ""
-"Mapset <%s> doesn't exist in GRASS location <%s>. A new mapset can be "
-"created by '-c' switch."
+msgid "Mapset <%s> doesn't exist in GRASS location <%s>. A new mapset can be created by '-c' switch."
msgstr ""
#: ../lib/init/grass.py:631
@@ -2171,15 +2132,12 @@
#: ../lib/init/grass.py:686
#, python-format
-msgid ""
-"Invalid user interface specified - <%s>. Use the --help option to see valid "
-"interface names."
+msgid "Invalid user interface specified - <%s>. Use the --help option to see valid interface names."
msgstr ""
#: ../lib/init/grass.py:700
msgid ""
-"Error in GUI startup. If necessary, please report this error to the GRASS "
-"developers.\n"
+"Error in GUI startup. If necessary, please report this error to the GRASS developers.\n"
"Switching to text mode now.\n"
"\n"
"Hit RETURN to continue..."
@@ -2214,9 +2172,7 @@
#: ../lib/init/grass.py:859
#, python-format
-msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s "
-"found). Concurrent use not allowed."
+msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed."
msgstr ""
#: ../lib/init/grass.py:863
@@ -2244,8 +2200,7 @@
#: ../lib/init/grass.py:941
#, python-format
msgid ""
-"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
-"found. Exiting.\n"
+"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
"\n"
"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
msgstr ""
@@ -2337,8 +2292,7 @@
"Unable to start GRASS. You can:\n"
" - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
" - Create manually GISRC file (%s)\n"
-" - Launch GRASS with path to the location/mapset as an argument (`grass70 /"
-"path/to/location/mapset`)"
+" - Launch GRASS with path to the location/mapset as an argument (`grass70 /path/to/location/mapset`)"
msgstr ""
#: ../lib/init/grass.py:1352
@@ -2365,11 +2319,11 @@
#: ../lib/init/lock.c:38
#, c-format
msgid "Usage: %s file pid"
-msgstr ""
+msgstr "使用:%s文件 pid"
#: ../lib/init/lock.c:42
msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
+msgstr "Windows 不支持当前锁定地图集"
#: ../lib/init/lock.c:60
#, fuzzy, c-format
@@ -2413,8 +2367,7 @@
#: ../lib/symbol/read.c:260
#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
msgstr "不正确的符号名称: '%s' (应该是:group/name 或者 group/name at mapset)"
#: ../lib/symbol/read.c:284
@@ -2431,12 +2384,12 @@
#: ../lib/driver/parse_ftcap.c:84
#, c-format
msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
+msgstr "%s:"
#: ../lib/driver/parse_ftcap.c:90
#, c-format
msgid "%s: No font definition file"
-msgstr ""
+msgstr "%s:没有字体定义文件"
#: ../lib/raster3d/maskfn.c:77
#, c-format
@@ -2653,11 +2606,11 @@
#: ../lib/gmath/del2g.c:50
msgid " taking FFT of image..."
-msgstr ""
+msgstr "获取图像FFT"
#: ../lib/gmath/del2g.c:56
msgid " computing del**2 g..."
-msgstr ""
+msgstr "正在计算del**2 g..."
#: ../lib/gmath/del2g.c:59
msgid " taking FFT of del**2 g..."
@@ -2665,11 +2618,11 @@
#: ../lib/gmath/del2g.c:63
msgid " multiplying transforms..."
-msgstr ""
+msgstr "多样变换"
#: ../lib/gmath/del2g.c:66
msgid " taking inverse FFT..."
-msgstr ""
+msgstr "采取逆FFT ..."
#: ../lib/gmath/la.c:60 ../lib/gmath/la.c:116
msgid "Matrix dimensions out of range"
@@ -2712,11 +2665,11 @@
#: ../lib/gmath/la.c:449
msgid "Principal matrix is not properly dimensioned"
-msgstr ""
+msgstr "主矩阵尺寸不正确"
#: ../lib/gmath/la.c:454
msgid "Input: you must have at least one array to solve"
-msgstr ""
+msgstr "输入:至少解答一个阵列"
#: ../lib/gmath/la.c:460
msgid "Could not allocate space for solution matrix"
@@ -2724,15 +2677,15 @@
#: ../lib/gmath/la.c:466 ../lib/gmath/la.c:474
msgid "Could not allocate space for working matrix"
-msgstr ""
+msgstr "不能分配空间矩阵工作"
#: ../lib/gmath/la.c:527
msgid "Matrix (or submatrix is singular). Solution undetermined"
-msgstr ""
+msgstr "矩阵(子矩阵或单数矩阵) 解决方案未定"
#: ../lib/gmath/la.c:531
msgid "Problem in LA routine."
-msgstr ""
+msgstr "LA例行程序中的问题"
#: ../lib/gmath/la.c:538
msgid "Procedure not yet available for selected matrix type"
@@ -2841,7 +2794,7 @@
#: ../lib/gmath/solvers_krylov.c:262
#, c-format
msgid "Sparse PCG -- iteration %i error %g\n"
-msgstr ""
+msgstr "稀疏PCG迭代 %i 错误 %g\n"
#: ../lib/gmath/solvers_krylov.c:264
#, c-format
@@ -2871,22 +2824,22 @@
#: ../lib/gmath/solvers_classic_iter.c:84
#, c-format
msgid "sparse Jacobi -- iteration %5i error %g\n"
-msgstr ""
+msgstr "稀疏雅克比迭代法 %5i错误 %g\n"
#: ../lib/gmath/solvers_classic_iter.c:156
#, c-format
msgid "sparse SOR -- iteration %5i error %g\n"
-msgstr ""
+msgstr "稀疏SOP迭代 %5i 错误 %g\n"
#: ../lib/gmath/solvers_classic_iter.c:218
#, c-format
msgid "Jacobi -- iteration %5i error %g\n"
-msgstr ""
+msgstr "雅克比迭代法 %5i 错误 %g\n"
#: ../lib/gmath/solvers_classic_iter.c:275
#, c-format
msgid "SOR -- iteration %5i error %g\n"
-msgstr ""
+msgstr " SOR-迭代%5i 错误 %g\n"
#: ../lib/gmath/test/test_main.c:61
msgid "The size of the matrices and vectors for benchmarking"
@@ -3184,9 +3137,7 @@
msgstr "双精度属性索引越界"
#: ../lib/gis/gisinit.c:51 ../lib/gis/gisinit.c:83
-msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
+msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
msgstr ""
#: ../lib/gis/gisinit.c:61
@@ -3361,8 +3312,7 @@
#: ../lib/gis/view.c:549
#, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
msgstr "只有 %d %%的窗口(存储于\"%s\"中)与当前GRASS窗口重叠。"
#: ../lib/gis/error.c:344
@@ -3384,9 +3334,7 @@
#: ../lib/gis/parser_standard_options.c:149
#, fuzzy
msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"SQL 语句的 WHERE 子句不使用'where'关键字。(如:income < 1000 and inhab >= "
-"10000)"
+msgstr "SQL 语句的 WHERE 子句不使用'where'关键字。(如:income < 1000 and inhab >= 10000)"
#: ../lib/gis/parser_standard_options.c:150
msgid "Example: income < 1000 and inhab >= 10000"
@@ -3413,8 +3361,7 @@
msgstr "数据库名"
#: ../lib/gis/parser_standard_options.c:186
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
+msgid "Do not use this option if schemas are not supported by driver/database server"
msgstr ""
#: ../lib/gis/parser_standard_options.c:195
@@ -3541,9 +3488,7 @@
msgstr "输出文件要使用的数据类型"
#: ../lib/gis/parser_standard_options.c:385
-msgid ""
-"Number of digits used as mantissa in the internal map storage, 0 -23 for "
-"float, 0 - 52 for double, max or default"
+msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
msgstr ""
#: ../lib/gis/parser_standard_options.c:395
@@ -3553,9 +3498,7 @@
#: ../lib/gis/parser_standard_options.c:405
#, fuzzy
-msgid ""
-"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
-"default: 16x16x8)"
+msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
msgstr "输出文件要使用的扩展维度值"
#: ../lib/gis/parser_standard_options.c:415
@@ -3603,10 +3546,7 @@
#: ../lib/gis/parser_standard_options.c:479
#, fuzzy
-msgid ""
-"Vector features can have category values in different layers. This number "
-"determines which layer to use. When used with direct OGR access this is the "
-"layer name."
+msgid "Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name."
msgstr "一个矢量地图能够连接多个数据库表。这个数字决定使用那个表。"
#: ../lib/gis/parser_standard_options.c:489
@@ -3616,10 +3556,7 @@
#: ../lib/gis/parser_standard_options.c:491
#, fuzzy
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use. When used with direct OGR access this "
-"is the layer name."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
#: ../lib/gis/parser_standard_options.c:500
@@ -3802,12 +3739,8 @@
#: ../lib/gis/parser_standard_options.c:796
#, fuzzy
-msgid ""
-"WHERE conditions of SQL statement without 'where' keyword used in the "
-"temporal GIS framework"
-msgstr ""
-"10000)"
+msgid "WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework"
#: ../lib/gis/parser_standard_options.c:797
msgid "Example: start_time > '2001-01-01 12:30:00'"
@@ -4592,9 +4525,7 @@
#: ../lib/arraystats/class.c:220
#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
msgstr ""
#: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
@@ -4694,9 +4625,7 @@
msgstr "无法打开栅格图[%s在%s中]"
#: ../lib/python/temporal/core.py:514
-msgid ""
-"Unable to initialize the temporal DBMI interface. Use t.connect to specify "
-"the driver and the database string"
+msgid "Unable to initialize the temporal DBMI interface. Use t.connect to specify the driver and the database string"
msgstr ""
#: ../lib/python/temporal/core.py:582
@@ -4756,9 +4685,7 @@
#: ../lib/python/temporal/abstract_map_dataset.py:339
-msgid ""
-"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
-"%(l)s"
+msgid "Start time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
msgstr "无法为%s创建时间戳文件, 地图%s 地图集%s"
#: ../lib/python/temporal/abstract_map_dataset.py:345
@@ -4768,8 +4695,7 @@
#: ../lib/python/temporal/abstract_map_dataset.py:352
-msgid ""
-"End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
+msgid "End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
msgstr "对%s是无效的时间戳文件,地图%s 地图集%s"
#: ../lib/python/temporal/abstract_map_dataset.py:358
@@ -4779,9 +4705,7 @@
#: ../lib/python/temporal/abstract_map_dataset.py:366
-msgid ""
-"End time must be greater than start time for %(type)s map <%(id)s> with "
-"layer: %(l)s"
+msgid "End time must be greater than start time for %(type)s map <%(id)s> with layer: %(l)s"
msgstr "东经值必须比西经值大"
#: ../lib/python/temporal/abstract_map_dataset.py:373
@@ -4796,16 +4720,12 @@
#: ../lib/python/temporal/abstract_dataset.py:428
#: ../lib/python/temporal/abstract_dataset.py:469
#, python-format
-msgid ""
-"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. "
-"The mapset of the dataset does not match the current mapset"
+msgid "Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:443
-msgid ""
-"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
-"%(l)s: %(u)s"
+msgid "Unsupported relative time unit type for %(type)s map <%(id)s> with layer %(l)s: %(u)s"
#: ../lib/python/temporal/abstract_map_dataset.py:448
@@ -4815,22 +4735,17 @@
#: ../lib/python/temporal/abstract_map_dataset.py:457
-msgid ""
-"layer %(l)s"
+msgid "End time must be greater than start time for %(type)s map <%(id)s> with layer %(l)s"
msgstr "东经值必须比西经值大"
#: ../lib/python/temporal/abstract_map_dataset.py:766
#, python-format
-msgid ""
-"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is "
-"greater than end time"
+msgid "Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is greater than end time"
msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:772
#, python-format
-msgid ""
-"Map <%s> has incorrect time interval, start time is greater than end time"
+msgid "Map <%s> has incorrect time interval, start time is greater than end time"
msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:777
@@ -4841,9 +4756,7 @@
#: ../lib/python/temporal/abstract_map_dataset.py:805
#: ../lib/python/temporal/abstract_space_time_dataset.py:1918
#, python-format
-msgid ""
-"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
-"database. The mapset of the dataset does not match the current mapset"
+msgid "Unable to delete dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/abstract_map_dataset.py:821
@@ -4853,9 +4766,7 @@
#: ../lib/python/temporal/abstract_map_dataset.py:870
#, python-format
-msgid ""
-"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
+msgid "Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:153
@@ -4904,23 +4815,17 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:1575
#, python-format
-msgid ""
-"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgid "Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1742
#, python-format
-msgid ""
-"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgid "Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1842
#, python-format
-msgid ""
-"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgid "Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:1849
@@ -4944,15 +4849,11 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:2012
-msgid ""
-"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
-"the dataset does not match the current mapset"
+msgid "Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of the dataset does not match the current mapset"
#: ../lib/python/temporal/abstract_space_time_dataset.py:2020
-msgid ""
-"Only a map that was inserted in the temporal database can be registered in a "
-"space time dataset"
+msgid "Only a map that was inserted in the temporal database can be registered in a space time dataset"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:2040
@@ -4967,15 +4868,12 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:2061
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
-"%(l)s are different"
+msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
#: ../lib/python/temporal/abstract_space_time_dataset.py:2066
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
+msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
#: ../lib/python/temporal/abstract_space_time_dataset.py:2080
@@ -4985,16 +4883,12 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:2089
#, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
-"layer %(l)s are different"
+msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:2095
#, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
-"different"
+msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> are different"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:2101
@@ -5013,17 +4907,12 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:2158
#, python-format
-msgid ""
-"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
-"temporal database. The mapset of the dataset does not match the current "
-"mapset"
+msgid "Unable to unregister map from dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/abstract_space_time_dataset.py:2169
-msgid ""
-"Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
-"%(base)s>"
+msgid "Map <%(map)s> with layer %(l)s is not registered in space time dataset <%(base)s>"
msgstr "错误:试图更新不在当前地图集中的地图。"
#: ../lib/python/temporal/abstract_space_time_dataset.py:2174
@@ -5033,8 +4922,7 @@
#: ../lib/python/temporal/abstract_space_time_dataset.py:2230
#, python-format
-msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
msgstr ""
#: ../lib/python/temporal/register.py:77
@@ -5063,9 +4951,7 @@
#: ../lib/python/temporal/register.py:101
#, python-format
-msgid ""
-"Space time %(sp)s dataset <%(name)s> with relative time found, but no "
-"relative unit set for %(sp)s maps"
+msgid "Space time %(sp)s dataset <%(name)s> with relative time found, but no relative unit set for %(sp)s maps"
msgstr ""
#: ../lib/python/temporal/register.py:167
@@ -5079,16 +4965,12 @@
#: ../lib/python/temporal/register.py:196
-msgid ""
-"Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
-"timestamp and the start time is not set."
+msgid "Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has timestamp and the start time is not set."
#: ../lib/python/temporal/register.py:202
-msgid ""
-"Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
-"start time is not set."
+msgid "Unable to register %(t)s map <%(id)s>. The map has no timestamp and the start time is not set."
#: ../lib/python/temporal/register.py:210
@@ -5103,23 +4985,17 @@
#: ../lib/python/temporal/register.py:224
-msgid ""
-"Map is already registered in temporal database. Unable to update %(t)s map <"
-"%(id)s> with layer %(l)s. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s> with layer %(l)s. Overwrite flag is not set."
msgstr "矢量'%s'已经存在,它将会被覆盖。"
#: ../lib/python/temporal/register.py:231
-msgid ""
-"%(id)s>. Overwrite flag is not set."
+msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s>. Overwrite flag is not set."
#: ../lib/python/temporal/register.py:255
-msgid ""
-"Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are "
-"different."
+msgid "Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are different."
#: ../lib/python/temporal/register.py:261
@@ -5155,9 +5031,7 @@
#: ../lib/python/temporal/register.py:399
-msgid ""
-"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
-"%(end)s"
+msgid "Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - %(end)s"
#: ../lib/python/temporal/register.py:404
@@ -5167,8 +5041,7 @@
#: ../lib/python/temporal/register.py:421
-msgid ""
-"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
#: ../lib/python/temporal/register.py:426
@@ -5178,9 +5051,7 @@
#: ../lib/python/temporal/abstract_dataset.py:391
#, python-format
-msgid ""
-"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgid "Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
msgstr ""
#: ../lib/python/temporal/stds_import.py:84
@@ -5303,9 +5174,7 @@
#: ../lib/python/temporal/stds_import.py:396
-msgid ""
-"Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
-"overwrite flag."
+msgid "Space time %(t)s dataset <%(sp)s> is already in the database. Use the overwrite flag."
#: ../lib/python/temporal/stds_import.py:416
@@ -5324,25 +5193,19 @@
#: ../lib/python/temporal/spatial_extent.py:125
-msgid ""
-"Projections are different. Unable to compute overlapping_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute overlapping_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:536
-msgid ""
-"Projections are different. Unable to compute is_in_2d for spatial extents"
+msgid "Projections are different. Unable to compute is_in_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:676
-msgid ""
-"Projections are different. Unable to compute equivalent_2d for spatial "
-"extents"
+msgid "Projections are different. Unable to compute equivalent_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:783
-msgid ""
-"Projections are different. Unable to compute cover_2d for spatial extents"
+msgid "Projections are different. Unable to compute cover_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:854
@@ -5359,9 +5222,7 @@
#: ../lib/python/temporal/temporal_vector_algebra.py:641
#, python-format
-msgid ""
-"Error vector maps with basename %s exist. Use --o flag to overwrite existing "
-"file"
+msgid "Error vector maps with basename %s exist. Use --o flag to overwrite existing file"
msgstr ""
#: ../lib/python/temporal/temporal_vector_algebra.py:673
@@ -5391,9 +5252,7 @@
#: ../lib/python/temporal/temporal_algebra.py:844
#: ../lib/python/temporal/temporal_algebra.py:848
#, python-format
-msgid ""
-"Wrong temporal type of space time dataset <"
-"%s> <%s> time is required"
+msgid "Wrong temporal type of space time dataset <%s> <%s> time is required"
msgstr ""
#: ../lib/python/temporal/list_stds.py:101
@@ -5411,9 +5270,7 @@
#: ../lib/python/temporal/aggregation.py:138
-msgid ""
-"Raster map <%s> is already in temporal database, use overwrite flag to "
-"overwrite"
+msgid "Raster map <%s> is already in temporal database, use overwrite flag to overwrite"
#: ../lib/python/temporal/aggregation.py:142
@@ -5454,10 +5311,7 @@
msgstr ""
#: ../lib/python/temporal/mapcalc.py:151
-msgid ""
-"Found more than a single map in a sample granule. Only the first map is used "
-"for computation. Use t.rast.aggregate.ds to create synchronous raster "
-"datasets."
+msgid "Found more than a single map in a sample granule. Only the first map is used for computation. Use t.rast.aggregate.ds to create synchronous raster datasets."
msgstr ""
#: ../lib/python/temporal/mapcalc.py:169
@@ -5472,8 +5326,7 @@
#: ../lib/python/temporal/open_stds.py:205
#: ../lib/python/temporal/extract.py:112
-msgid ""
-"Map <%s> is already in temporal database, use overwrite flag to overwrite"
+msgid "Map <%s> is already in temporal database, use overwrite flag to overwrite"
#: ../lib/python/temporal/mapcalc.py:255
@@ -5521,9 +5374,7 @@
#: ../lib/python/temporal/open_stds.py:121
-msgid ""
-"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
-"overwrite flag."
+msgid "Space time %(sp)s dataset <%(name)s> is already in the database. Use the overwrite flag."
#: ../lib/python/temporal/open_stds.py:155
@@ -5684,8 +5535,7 @@
#: ../lib/python/script/db.py:142
#, python-format
-msgid ""
-"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+msgid "Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
msgstr ""
#: ../lib/python/script/db.py:154
@@ -5728,9 +5578,7 @@
#: ../lib/python/script/raster.py:47
-msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
+msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
msgstr "无法删除线,地图'%s'没有以写模式打开"
#: ../lib/python/script/raster.py:105
@@ -5858,9 +5706,7 @@
#: ../lib/rst/interp_float/interp2d.c:214
#, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
msgstr ""
#: ../lib/rst/interp_float/resout2d.c:77
@@ -5887,11 +5733,8 @@
#: ../lib/rst/interp_float/segmen2d.c:118
#, fuzzy
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"寻找内插的点花费了太长的时间 -- 请将范围改为点所在的区域。 然后继续计算..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "寻找内插的点花费了太长的时间 -- 请将范围改为点所在的区域。 然后继续计算..."
#: ../lib/rst/interp_float/write2d.c:40 ../lib/rst/interp_float/write2d.c:51
#: ../lib/rst/interp_float/write2d.c:66 ../lib/rst/interp_float/write2d.c:75
@@ -5965,9 +5808,7 @@
#: ../lib/rst/interp_float/vinput2d.c:256
#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
msgstr "用于内插的(稀化后的) %d 点少于给定的 NPMIN=%d"
#: ../lib/rst/interp_float/vinput2d.c:261
@@ -5976,19 +5817,13 @@
#: ../lib/rst/interp_float/vinput2d.c:266
#, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
msgstr ""
#: ../lib/rst/interp_float/vinput2d.c:272
#, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"用于内插的点少于 %d 个。如果不需要分段,为了让程序运行更快,请设置 segmax=%d "
-"(参阅手册)"
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "用于内插的点少于 %d 个。如果不需要分段,为了让程序运行更快,请设置 segmax=%d (参阅手册)"
#: ../lib/rst/interp_float/vinput2d.c:276
#, fuzzy, c-format
@@ -6124,9 +5959,7 @@
#: ../lib/imagery/sigsetfile.c:41
#, fuzzy, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
msgstr "无法为[%s在%s中]创建头文件"
#: ../lib/imagery/sigsetfile.c:57
@@ -6245,9 +6078,7 @@
msgstr ""
#: ../lib/imagery/iscatt_core.c:579
-msgid ""
-"Data inconsistent. Value computed for scatter plot is out of initialized "
-"range."
+msgid "Data inconsistent. Value computed for scatter plot is out of initialized range."
msgstr ""
#: ../lib/imagery/iscatt_core.c:745
@@ -6296,9 +6127,7 @@
#: ../lib/vector/diglib/plus_node.c:214
#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
msgstr ""
#: ../lib/vector/diglib/plus.c:222
@@ -6368,9 +6197,7 @@
#: ../lib/vector/diglib/cindex_rw.c:156
#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this category index format. "
-"Try to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this category index format. Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr ""
#: ../lib/vector/diglib/port_init.c:158
@@ -6415,28 +6242,22 @@
#: ../lib/vector/diglib/test.c:75
#, c-format
-msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
+msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
msgstr ""
#: ../lib/vector/diglib/test.c:89
#, c-format
-msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
+msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
msgstr ""
#: ../lib/vector/diglib/test.c:104
#, c-format
-msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
msgstr ""
#: ../lib/vector/diglib/test.c:119
#, c-format
-msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
msgstr ""
#: ../lib/vector/diglib/test.c:134
@@ -6446,8 +6267,7 @@
#: ../lib/vector/diglib/test.c:150
#, c-format
-msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
msgstr ""
#: ../lib/vector/diglib/test.c:165
@@ -6457,23 +6277,17 @@
#: ../lib/vector/diglib/plus_struct.c:523
#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this topology format. Try "
-"to rebuild topology or upgrade GRASS to at least version %d."
+msgid "This version of GRASS (%d.%d) is too old to read this topology format. Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr ""
#: ../lib/vector/diglib/plus_struct.c:529
#, c-format
-msgid ""
-"Your GRASS version does not fully support topology format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
+msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
msgstr ""
#: ../lib/vector/diglib/plus_struct.c:539
#, c-format
-msgid ""
-"Old topology format version %d.%d is not supported by this release. Try to "
-"rebuild topology."
+msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology."
msgstr ""
#: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
@@ -6511,23 +6325,17 @@
#: ../lib/vector/diglib/spindex_rw.c:302
#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this spatial index format. "
+msgid "This version of GRASS (%d.%d) is too old to read this spatial index format. Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr ""
#: ../lib/vector/diglib/spindex_rw.c:308
#, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
+msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
msgstr ""
#: ../lib/vector/diglib/spindex_rw.c:317
#, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
+msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
msgstr ""
#: ../lib/vector/diglib/plus_area.c:217 ../lib/vector/diglib/plus_area.c:719
@@ -7005,8 +6813,7 @@
#: ../lib/vector/Vlib/legal_vname.c:65
#, fuzzy, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
msgstr "非法的矢量地图名称<%s>。不允许有字符<%c>。\n"
#: ../lib/vector/Vlib/legal_vname.c:97 ../lib/vector/Vlib/legal_vname.c:101
@@ -7081,16 +6888,12 @@
#: ../lib/vector/Vlib/net.c:251
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
msgstr ""
#: ../lib/vector/Vlib/net.c:270
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not "
-"found(direction of line skipped)"
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
msgstr ""
#: ../lib/vector/Vlib/net.c:319
@@ -7391,9 +7194,7 @@
msgstr ""
#: ../lib/vector/Vlib/field.c:185
-msgid ""
-"More DB links defined for input vector map. Using only first DB link for "
-"output."
+msgid "More DB links defined for input vector map. Using only first DB link for output."
msgstr ""
#: ../lib/vector/Vlib/field.c:261
@@ -7446,15 +7247,12 @@
msgstr "无法打开OGR DBMI驱动。"
#: ../lib/vector/Vlib/field.c:758
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
msgstr ""
#: ../lib/vector/Vlib/field.c:825
#, c-format
-msgid ""
-"Feature table <%s> has no primary key defined. Unable to define DB links."
+msgid "Feature table <%s> has no primary key defined. Unable to define DB links."
msgstr ""
#: ../lib/vector/Vlib/field.c:845
@@ -7544,15 +7342,12 @@
#: ../lib/vector/Vlib/open_nat.c:154
#, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
+msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
msgstr ""
#: ../lib/vector/Vlib/open_nat.c:158
#, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
msgstr ""
#: ../lib/vector/Vlib/box.c:228
@@ -7818,9 +7613,7 @@
#: ../lib/vector/Vlib/geos.c:55
#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
msgstr ""
#: ../lib/vector/Vlib/geos.c:60
@@ -7898,8 +7691,7 @@
msgstr ""
#: ../lib/vector/Vlib/build_ogr.c:82
-msgid ""
-"Random read is not supported by OGR for this layer. Unable to build topology."
+msgid "Random read is not supported by OGR for this layer. Unable to build topology."
msgstr ""
#: ../lib/vector/Vlib/build_ogr.c:88 ../lib/vector/Vlib/build_pg.c:101
@@ -8057,9 +7849,7 @@
#: ../lib/vector/Vlib/ascii.c:860
#, c-format
-msgid ""
-"%d features without category skipped. To export also features without "
-"category use '%s=-1'."
+msgid "%d features without category skipped. To export also features without category use '%s=-1'."
msgstr ""
#: ../lib/vector/Vlib/simple_features.c:225
@@ -8161,16 +7951,12 @@
#: ../lib/vector/Vlib/open_ogr.c:279
#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
msgstr ""
#: ../lib/vector/Vlib/open_ogr.c:284
#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
msgstr ""
#: ../lib/vector/Vlib/level.c:34
@@ -8204,8 +7990,7 @@
#: ../lib/vector/Vlib/read_pg.c:365
#, c-format
-msgid ""
-"Requesting invalid feature from cache (%d). Number of features in cache: %d"
+msgid "Requesting invalid feature from cache (%d). Number of features in cache: %d"
msgstr ""
#: ../lib/vector/Vlib/read_pg.c:368
@@ -8356,9 +8141,7 @@
#: ../lib/vector/Vlib/dgraph.c:432
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
+msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
msgstr ""
#: ../lib/vector/Vlib/select.c:116
@@ -8449,8 +8232,7 @@
#: ../lib/vector/Vlib/build_pg.c:1018
#, c-format
-msgid ""
-"Unable to build simple features from topogeometry data. Unsupported type %d."
+msgid "Unable to build simple features from topogeometry data. Unsupported type %d."
msgstr ""
#: ../lib/vector/Vlib/buffer2.c:361
@@ -8464,13 +8246,11 @@
msgstr ""
#: ../lib/vector/Vlib/buffer2.c:589
-msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
msgstr ""
#: ../lib/vector/Vlib/buffer2.c:600
-msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
msgstr ""
#: ../lib/vector/Vlib/buffer2.c:648
@@ -8675,8 +8455,7 @@
#: ../lib/vector/Vlib/open.c:264
#, fuzzy
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
+msgid "Vector map which is not in the current mapset cannot be opened for update"
msgstr "不在当前地图集中的地图不能被打开并更新。"
#: ../lib/vector/Vlib/open.c:298
@@ -8696,9 +8475,7 @@
#: ../lib/vector/Vlib/open.c:406 ../lib/vector/Vlib/open.c:428
#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"by v.build."
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
msgstr "无法打开旧的矢量%s在级别%d上"
#: ../lib/vector/Vlib/open.c:437
@@ -8946,9 +8723,7 @@
#: ../lib/vector/Vlib/build.c:1186
#, fuzzy
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topology level 2"
+msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
msgstr "无法删除线,地图'%s'没有在级别2上打开"
#: ../lib/vector/Vlib/build.c:1209
@@ -9005,202 +8780,465 @@
msgid "Unknown query tool"
msgstr "未知区域"
-#~ msgid "Line%s of ellipsoid table file <%s> is invalid"
-#~ msgstr "%s 行在椭球表文件<%s>中是无效的"
+#, fuzzy
+msgid "Unable to select space time dataset register table <%s>"
+msgstr "无法打开文件 %s 在 %s 中"
-#~ msgid "Lines%s of ellipsoid table file <%s> are invalid"
+#, fuzzy
+msgid "Unable to create timestamp file for raster3d map <%s>"
+msgstr "无法为[%s在%s中]创建头文件"
#, fuzzy
-#~ msgid "Unable to select space time dataset register table <%s>"
-#~ msgstr "无法打开文件 %s 在 %s 中"
+msgid "Invalid datetime in timestamp for raster3d map <%s>"
+msgstr "对%s是无效的时间戳文件,地图%s 地图集%s"
#, fuzzy
-#~ msgid "Unable to create timestamp file for raster3d map <%s>"
-#~ msgstr "无法为[%s在%s中]创建头文件"
+msgid "Unable to remove timestamp for raster3d map <%s>"
#, fuzzy
-#~ msgid "Invalid datetime in timestamp for raster3d map <%s>"
-#~ msgstr "对%s是无效的时间戳文件,地图%s 地图集%s"
+msgid "Raster3d map <%s> not found"
+msgstr "输入矢量'%s'未找到"
#, fuzzy
-#~ msgid "Unable to remove timestamp for raster3d map <%s>"
+msgid "Inconsistency in topology: line %d - unexpected feature type"
+msgstr "要素类型"
#, fuzzy
-#~ msgid "Raster3d map <%s> not found"
-#~ msgstr "输入矢量'%s'未找到"
+msgid ""
+"Unable to read PostGIS features\n"
+"%s"
#, fuzzy
-#~ msgid "Inconsistency in topology: line %d - unexpected feature type"
-#~ msgstr "要素类型"
+msgid "%d %s without geometry skipped"
+msgstr "没有几何形状的要素 %d 被忽略"
#, fuzzy
-#~ msgid ""
-#~ "Unable to read PostGIS features\n"
-#~ "%s"
+msgid "Performs unit and integration tests for the g3d library"
+msgstr "执行gpde库单元和综合测试"
#, fuzzy
-#~ msgid "%d %s without geometry skipped"
-#~ msgstr "没有几何形状的要素 %d 被忽略"
+msgid ""
+"\n"
+"++ Running g3d coordinate transform unit tests ++"
+msgstr ""
+"\n"
+"++ 运行坡度单元测试 ++"
#, fuzzy
-#~ msgid "Layer or category index out of range"
-#~ msgstr "双精度属性索引越界"
+msgid ""
+"\n"
+"-- g3d coordinate transform unit tests failure --"
+msgstr ""
+"\n"
+"-- geom_data 单元测试失败 --"
#, fuzzy
-#~ msgid "Performs unit and integration tests for the g3d library"
-#~ msgstr "执行gpde库单元和综合测试"
+msgid ""
+"\n"
+"-- g3d coordinate transform unit tests finished successfully --"
+msgstr ""
+"\n"
+"-- geom_data单元测试成功完成 --"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "++ Running g3d coordinate transform unit tests ++"
-#~ msgstr ""
-#~ "\n"
-#~ "++ 运行坡度单元测试 ++"
+msgid ""
+"\n"
+"++ Running g3d put/get value large file unit tests ++"
+msgstr ""
+"\n"
+"++ 运行解算单元测试 ++"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- g3d coordinate transform unit tests failure --"
-#~ msgstr ""
-#~ "\n"
-#~ "-- geom_data 单元测试失败 --"
+msgid ""
+"\n"
+"-- g3d put/get value large file unit tests failure --"
+msgstr ""
+"\n"
+"-- 解算单元测试失败 --"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- g3d coordinate transform unit tests finished successfully --"
-#~ msgstr ""
-#~ "\n"
-#~ "-- geom_data单元测试成功完成 --"
+msgid ""
+"\n"
+"-- g3d put/get value large file unit tests finished successfully --"
+msgstr ""
+"\n"
+"-- 解算单元测试成功完成 --"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "++ Running g3d put/get value large file unit tests ++"
-#~ msgstr ""
-#~ "\n"
-#~ "++ 运行解算单元测试 ++"
+msgid ""
+"\n"
+"++ Running g3d put/get value unit tests ++"
+msgstr ""
+"\n"
+"++ 运行解算单元测试 ++"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- g3d put/get value large file unit tests failure --"
-#~ msgstr ""
-#~ "\n"
-#~ "-- 解算单元测试失败 --"
+msgid ""
+"\n"
+"-- g3d put/get value unit tests failure --"
+msgstr ""
+"\n"
+"-- 解算单元测试失败 --"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- g3d put/get value large file unit tests finished successfully --"
-#~ msgstr ""
-#~ "\n"
-#~ "-- 解算单元测试成功完成 --"
+msgid ""
+"\n"
+"-- g3d put/get value unit tests finished successfully --"
+msgstr ""
+"\n"
+"-- 解算单元测试成功完成 --"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "++ Running g3d put/get value unit tests ++"
-#~ msgstr ""
-#~ "\n"
+msgid "Registering maps in the temporal database"
+msgstr "无法打开栅格图[%s在%s中]"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- g3d put/get value unit tests failure --"
-#~ msgstr ""
-#~ "\n"
+msgid "Space time %(t)s dataset <%(i)s> is already in database, use overwrite flag to overwrite"
+msgstr "矢量'%s'已经存在,它将会被覆盖。"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- g3d put/get value unit tests finished successfully --"
-#~ msgstr ""
-#~ "\n"
+msgid "Space time %(type)s dataset <%(id)s> not found"
#, fuzzy
-#~ msgid "Registering maps in the temporal database"
-#~ msgstr "无法打开栅格图[%s在%s中]"
+msgid "Please specify base="
+msgstr ""
+"\n"
+"请指定基准面名称\n"
#, fuzzy
-#~ msgid ""
-#~ "Space time %(t)s dataset <%(i)s> is already in database, use overwrite "
-#~ "flag to overwrite"
-#~ msgstr "矢量'%s'已经存在,它将会被覆盖。"
+msgid "Space time %(type)s dataset <%(id)s> is already in database, use overwrite flag to overwrite"
#, fuzzy
-#~ msgid "Space time %(type)s dataset <%(id)s> not found"
+msgid "OGR feature %d without ID skipped"
+msgstr "没有 ID 的 OGR 要素被忽略。 "
#, fuzzy
-#~ msgid "Please specify base="
-#~ msgstr ""
-#~ "\n"
-#~ "请指定基准面名称\n"
+msgid "database"
+msgstr "数据库名"
#, fuzzy
-#~ msgid ""
-#~ "Space time %(type)s dataset <%(id)s> is already in database, use "
-#~ "overwrite flag to overwrite"
+msgid ""
+"Default TGIS driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
+msgstr ""
+"默认驱动 / 数据库设置:\n"
+"驱动: dbf\n"
+"数据库: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/"
#, fuzzy
-#~ msgid "OGR feature %d without ID skipped"
-#~ msgstr "没有 ID 的 OGR 要素被忽略。 "
+msgid "Default TGIS driver is not set"
+msgstr "默认驱动未设置"
#, fuzzy
-#~ msgid "database"
-#~ msgstr "数据库名"
+msgid "Default TGIS database is not set"
+msgstr "默认数据库未设置"
#, fuzzy
-#~ msgid ""
-#~ "Default TGIS driver / database set to:\n"
-#~ "driver: %s\n"
-#~ "database: %s"
-#~ msgstr ""
-#~ "默认驱动 / 数据库设置:\n"
-#~ "驱动: dbf\n"
-#~ "数据库: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/"
+msgid "Unregister %(type)s map <%(map)s> from space time datasets"
#, fuzzy
-#~ msgid "Default TGIS driver is not set"
-#~ msgstr "默认驱动未设置"
+msgid "Register %s map <%s> with layer %s in space time %s dataset <%s>"
#, fuzzy
-#~ msgid "Default TGIS database is not set"
-#~ msgstr "默认数据库未设置"
+msgid "Register %s map <%s> in space time %s dataset <%s>"
#, fuzzy
-#~ msgid "Unregister %(type)s map <%(map)s> from space time datasets"
+msgid "Created register table <%s> for %s map <%s> with layer %s"
+msgstr "无法为地图 %s 写入量化规则"
#, fuzzy
-#~ msgid "Register %s map <%s> with layer %s in space time %s dataset <%s>"
+msgid "Unregister %s map <%s> with layer %s"
+msgstr " 栅格图%s@%s是空的"
#, fuzzy
-#~ msgid "Register %s map <%s> in space time %s dataset <%s>"
+msgid "Unregister %s map <%s>"
#, fuzzy
-#~ msgid "Created register table <%s> for %s map <%s> with layer %s"
-#~ msgstr "无法为地图 %s 写入量化规则"
+msgid "Attempt to read dead feature %d"
+msgstr "无法为区域 %d 计算质心"
#, fuzzy
-#~ msgid "Unregister %s map <%s> with layer %s"
-#~ msgstr " 栅格图%s@%s是空的"
+msgid "Reading failed: %s"
+msgstr "连接失败。\n"
#, fuzzy
-#~ msgid "Unregister %s map <%s>"
+msgid "Unable to get features"
+#, fuzzy
+msgid "Could not find isle box"
+msgstr "无法统计文件'%s'"
+#, fuzzy
+msgid "<%s> is not the current mapset (%s)"
+msgstr "当前地图集中没有 %s 文件\n"
+#, fuzzy
+msgid "Unable to get feature type"
+#, fuzzy
+msgid "Topology not available. Unable to insert new edge."
+msgstr "命令[%s]没有可用的帮助\n"
+#, fuzzy
+msgid "Unable to attach centroids"
+#, fuzzy
+msgid "Unexpected feature type (%s) - should be (%d)"
+msgstr "要素类型"
+#, fuzzy
+msgid "Unable to read centroid %d: %s"
+#, fuzzy
+msgid "Unable to export node %d. Exiting."
+msgstr "无法分配内存\n"
+#, fuzzy
+msgid "Unable to look up account id"
+msgstr "无法打开%s"
+#, fuzzy
+msgid "Unable to allocate memory for account name"
+msgstr "无法分配内存\n"
+#, fuzzy
+msgid "Unable to allocate memory for domain name"
+msgstr "无法分配内存\n"
+#, fuzzy
+msgid "Unable to remove space time dataset register table <%s>"
+#, fuzzy
+msgid "Unable to drop table <%s>"
+#, fuzzy
+msgid "Unable to create the space time %s dataset register table for map <%s> with layer %s"
+msgstr "无法为[%s]创建头文件"
+#, fuzzy
+msgid "Unable to find map <%s> with layer %s in temporal database"
+#, fuzzy
+msgid "Could not find area box"
+#, fuzzy
+msgid "Unable to read read line %d"
+msgstr "无法打开临时文件"
+#, fuzzy
+msgid "Unable to delete feature id %d from vector map <%s>"
+msgstr "无法将目录改变到%s"
+#, fuzzy
+msgid "Unable to open null device"
+msgstr "无法打开%s"
+#, fuzzy
+msgid "The support for OGR vector maps wasn't compiled in"
+msgstr "矢量文件[%s]在地图集[%s]中的类别 %s"
+#, fuzzy
+msgid "End time must be later than start time"
+msgstr "东经值必须比西经值大"
+#, fuzzy
+msgid "None"
+msgstr "无"
+#, fuzzy
+msgid "Unknown"
+msgstr "未知"
+#, fuzzy
+msgid "Uknown column <%s>"
+msgstr "无法读取平滑字段的类型"
+#, fuzzy
+msgid " valid options: %s\n"
+msgstr " 选项: %s\n"
+#, fuzzy
+msgid "Not enough room in history file to record command line"
+msgstr "历史信息文件没有足够的空间来记录命令行。"
+#, fuzzy
+msgid "Not enough room in history file for command line (truncated)"
+msgstr "历史信息文件没有足够的空间来记录命令行(截取的)。"
+#, fuzzy
+msgid "Raster map <%s> - unable to write row %d"
+msgstr "地图[%s] - 无法写入行%d"
+#, fuzzy
+msgid "Error writing floating point format file for map <%s>"
+msgstr "将地图 %s 写入浮点型指针类型文件错误"
+#, fuzzy
+msgid "Unable to write feature, OGR layer not defined"
+msgstr "无法写入线,地图尚未打开"
+#, fuzzy
+msgid "Unable to create a new process!"
+msgstr "不能创建新进程"
+#, fuzzy
+msgid "Region for current mapset %s. Run \"g.region\" to fix the current region."
+msgstr ""
+"要得到当前地图集%s的范围\n"
+"请运行 \"g.region\""
+#, fuzzy
+msgid "Default region %s"
+msgstr "默认范围 %s"
+#, fuzzy
+msgid "Failed writing raster map"
+msgstr "读取栅格单元文件问题"
+#, fuzzy
+msgid "Unable to query drawable"
+#, fuzzy
+msgid "Failed to initialize Xlib surface"
+#, fuzzy
+msgid "test, gmath"
+msgstr "测试,gpde"
+msgid "taking too long to find points for interpolation--please change the region to area where your points are. Continuing calculations..."
+msgid "Reading lines from vector map ... "
+msgstr "从矢量地图中读入行 ..."
+msgid "Reading nodes from vector map ... "
+msgstr "读取矢量地图上的节点..."
+msgid "strip exists with insufficient data"
+msgstr "去掉不合适的数据"
+#, fuzzy
+msgid "there are points outside specified 2D/3D region--ignored %d points"
+msgstr "有点在指定的范围之外--忽略 %d 个点"
+msgid "ignoring %d points -- too dense"
+msgstr "忽略 %d 个点 -- 过于密集"
+msgid "some points outside of region -- will ignore..."
+msgstr "范围之外的点 -- 将被忽略..."
+msgid " The raster map %s@%s is empty"
+#, fuzzy
+msgid "All vertices"
+msgstr "允许覆盖"
+#, fuzzy
+msgid "Unable to delete file '%s'. Reason: %s"
+#, fuzzy
+msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
+#, fuzzy
+msgid "Unable to delete prior null-cells file"
+#, fuzzy
+msgid "Unable to close the null-cells file"
+msgstr "无法打开临时文件"
+#, fuzzy
+msgid "closecell: can't move [%s] to null-cells file [%s]"
+msgstr ""
+"closecell: 无法将 %s\n"
+"移动到空文件 %s"
+#, fuzzy
+msgid "Unable to delete the temporary null-cells file"
+msgstr "找不到临时空文件:%s"
+#, fuzzy
+msgid "Unable to delete the empty temporary null-cells file"
+#, fuzzy
+msgid "Unable to delete the prior null-cells file"
+msgstr "无法打开临时文件"
+#, fuzzy
+msgid "Unable to close the 'cell' file"
+msgstr "无法打开临时文件"
+#, fuzzy
+msgid "Unable to delete prior 'fcell' file"
+#, fuzzy
+msgid "Unable to delete the prior %s file"
+#, fuzzy
+msgid "Unable to close file"
+#, fuzzy
+msgid "Unable to delete the prior 'cell' file"
+msgstr "无法打开临时文件"
+#, fuzzy
+msgid "closecell: can't move [%s] to cell file [%s]"
+msgstr ""
+"closecell: 不能将 %s\n"
+"移动到cell文件 %s"
+#, fuzzy
+msgid "Unable to delete the temporary 'cell' file"
+#, fuzzy
+msgid "Unable to write quant file!"
+msgstr "不能创建新进程"
+#, fuzzy
+msgid "Unable to delete the %s file"
+#, fuzzy
+msgid "Unable to write f_format file for CELL maps"
+msgstr "无法将CELL地图写入f_format文件"
+#~ msgid "Line%s of ellipsoid table file <%s> is invalid"
+#~ msgstr "%s 行在椭球表文件<%s>中是无效的"
+#~ msgid "Lines%s of ellipsoid table file <%s> are invalid"
+#, fuzzy
+#~ msgid "Layer or category index out of range"
+#~ msgstr "双精度属性索引越界"
#~ msgid ""
#~ "\n"
#~ "++ Running assembling unit tests ++"
@@ -9438,58 +9476,27 @@
#~ msgstr "无法打开空间索引文件进行写操作: %s\n"
#, fuzzy
-#~ msgid "Attempt to read dead feature %d"
-#~ msgstr "无法为区域 %d 计算质心"
-#, fuzzy
-#~ msgid "Reading failed: %s"
-#~ msgstr "连接失败。\n"
-#, fuzzy
-#~ msgid "Unable to get features"
-#, fuzzy
-#~ msgid "Could not find isle box"
-#~ msgstr "无法统计文件'%s'"
-#, fuzzy
-#~ msgid "<%s> is not the current mapset (%s)"
-#~ msgstr "当前地图集中没有 %s 文件\n"
-#, fuzzy
#~ msgid "Unable to read line %d"
#~ msgstr "无法打开临时文件"
#, fuzzy
-#~ msgid "Unable to get feature type"
-#, fuzzy
#~ msgid "Unable to rewrite feature, vector map is not opened"
#~ msgstr "无法重写线,地图尚未打开"
#, fuzzy
-#~ msgid ""
-#~ "Unable to delete feature %d, vector map <%s> is not opened on topology "
-#~ "level"
+#~ msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
#~ msgstr "无法删除线,地图'%s'没有在级别2上打开"
#, fuzzy
-#~ msgid ""
-#~ "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+#~ msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
#~ msgstr "无法删除线,地图'%s'没有以写模式打开"
#, fuzzy
-#~ msgid ""
-#~ "Unable to restore feature %d, vector map <%s> is not opened on topology "
-#~ "level"
+#~ msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
#, fuzzy
-#~ msgid ""
-#~ "Unable to restore feature %d, vector map <%s> is not opened in 'write' "
-#~ "mode"
+#~ msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
#, fuzzy
@@ -9497,16 +9504,11 @@
#~ msgstr "无法为写入打开%s"
#, fuzzy
-#~ msgid "Topology not available. Unable to insert new edge."
-#~ msgstr "命令[%s]没有可用的帮助\n"
-#, fuzzy
#~ msgid "input vector map is not open"
#, fuzzy
-#~ msgid ""
-#~ "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
+#~ msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
#, fuzzy
@@ -9514,34 +9516,6 @@
#~ msgstr "无法打开拓扑文件进行写操作: %s\n"
#, fuzzy
-#~ msgid "Unable to attach centroids"
-#, fuzzy
-#~ msgid "Unexpected feature type (%s) - should be (%d)"
-#~ msgstr "要素类型"
-#, fuzzy
-#~ msgid "Unable to read centroid %d: %s"
-#, fuzzy
-#~ msgid "Unable to export node %d. Exiting."
-#~ msgstr "无法分配内存\n"
-#, fuzzy
-#~ msgid "Unable to look up account id"
-#~ msgstr "无法打开%s"
-#, fuzzy
-#~ msgid "Unable to allocate memory for account name"
-#, fuzzy
-#~ msgid "Unable to allocate memory for domain name"
-#, fuzzy
#~ msgid "cell_values_float: xdr_float failed for index %d"
#~ msgstr "cell_values_double:第 %d 个xdr_double值错误。"
@@ -9556,43 +9530,13 @@
#~ msgstr "第 %d 行的第 %d 个xdr_double值错误。"
#, fuzzy
-#~ msgid "Unable to remove space time dataset register table <%s>"
-#, fuzzy
-#~ msgid "Unable to drop table <%s>"
-#, fuzzy
-#~ msgid ""
-#~ "Unable to create the space time %s dataset register table for map <%s> "
-#~ "with layer %s"
-#~ msgstr "无法为[%s]创建头文件"
-#, fuzzy
-#~ msgid "Unable to find map <%s> with layer %s in temporal database"
-#, fuzzy
-#~ msgid "Could not find area box"
-#, fuzzy
#~ msgid "Unable to open fidx file for vector map <%s@%s>"
#~ msgstr "无法打开矢量'%s'的历史记录"
#, fuzzy
-#~ msgid "Unable to read read line %d"
-#~ msgstr "无法打开临时文件"
-#, fuzzy
#~ msgid "Unable to write feature (negative offset)"
#~ msgstr "无法写入线 (负向偏移)"
-#, fuzzy
-#~ msgid "Unable to delete feature id %d from vector map <%s>"
-#~ msgstr "无法将目录改变到%s"
#~ msgid "Don't know how to read links for format %d"
#~ msgstr "不知道如何从格式%d中读取链接"
@@ -9606,81 +9550,6 @@
#~ msgstr "数据库名"
#, fuzzy
-#~ msgid "Unable to open null device"
-#~ msgstr "无法打开%s"
-#, fuzzy
-#~ msgid "The support for OGR vector maps wasn't compiled in"
-#~ msgstr "矢量文件[%s]在地图集[%s]中的类别 %s"
-#, fuzzy
-#~ msgid "End time must be later than start time"
-#~ msgstr "东经值必须比西经值大"
-#, fuzzy
-#~ msgid "None"
-#~ msgstr "无"
-#, fuzzy
-#~ msgid "Unknown"
-#~ msgstr "未知"
-#, fuzzy
-#~ msgid "Uknown column <%s>"
-#~ msgstr "无法读取平滑字段的类型"
-#, fuzzy
-#~ msgid " valid options: %s\n"
-#~ msgstr " 选项: %s\n"
-#, fuzzy
-#~ msgid "Not enough room in history file to record command line"
-#~ msgstr "历史信息文件没有足够的空间来记录命令行。"
-#, fuzzy
-#~ msgid "Not enough room in history file for command line (truncated)"
-#~ msgstr "历史信息文件没有足够的空间来记录命令行(截取的)。"
-#, fuzzy
-#~ msgid "Raster map <%s> - unable to write row %d"
-#~ msgstr "地图[%s] - 无法写入行%d"
-#, fuzzy
-#~ msgid "Error writing floating point format file for map <%s>"
-#~ msgstr "将地图 %s 写入浮点型指针类型文件错误"
-#, fuzzy
-#~ msgid "Unable to write feature, OGR layer not defined"
-#~ msgstr "无法写入线,地图尚未打开"
-#, fuzzy
-#~ msgid "Unable to create a new process!"
-#~ msgstr "不能创建新进程"
-#, fuzzy
-#~ msgid ""
-#~ "Region for current mapset %s. Run \"g.region\" to fix the current region."
-#~ msgstr ""
-#~ "要得到当前地图集%s的范围\n"
-#~ "请运行 \"g.region\""
-#, fuzzy
-#~ msgid "Default region %s"
-#~ msgstr "默认范围 %s"
-#, fuzzy
-#~ msgid "Failed writing raster map"
-#~ msgstr "读取栅格单元文件问题"
-#, fuzzy
-#~ msgid "Unable to query drawable"
-#, fuzzy
-#~ msgid "Failed to initialize Xlib surface"
-#, fuzzy
#~ msgid "Cannot open database %s by driver %s"
#~ msgstr "无法打开数据库 %s"
@@ -9734,35 +9603,6 @@
#~ msgid "Precision used in the output file (default, max, or 0 to 52)"
#~ msgstr "输出文件要使用的数据精度(默认,最大,或0-52)"
-#, fuzzy
-#~ msgid "test, gmath"
-#~ msgstr "测试,gpde"
-#~ msgid ""
-#~ "taking too long to find points for interpolation--please change the "
-#~ "region to area where your points are. Continuing calculations..."
-#~ msgstr ""
-#~ "寻找内插的点花费了太长的时间 -- 请将范围改为点所在的区域。 然后继续计算..."
-#~ msgid "Reading lines from vector map ... "
-#~ msgstr "从矢量地图中读入行 ..."
-#~ msgid "Reading nodes from vector map ... "
-#~ msgstr "读取矢量地图上的节点..."
-#~ msgid "strip exists with insufficient data"
-#~ msgstr "去掉不合适的数据"
-#, fuzzy
-#~ msgid "there are points outside specified 2D/3D region--ignored %d points"
-#~ msgstr "有点在指定的范围之外--忽略 %d 个点"
-#~ msgid "ignoring %d points -- too dense"
-#~ msgstr "忽略 %d 个点 -- 过于密集"
-#~ msgid "some points outside of region -- will ignore..."
-#~ msgstr "范围之外的点 -- 将被忽略..."
#~ msgid " Presented as: %s\n"
#~ msgstr " 应表述为: %s\n"
@@ -9857,9 +9697,6 @@
#~ msgid "Problem reading raster map"
-#~ msgid " The raster map %s@%s is empty"
#~ msgid ""
#~ "\n"
#~ "\n"
@@ -9907,9 +9744,7 @@
#~ msgstr "无法写入量化规则:地图 %s 是整型的"
#, fuzzy
-#~ msgid ""
-#~ "G_set_window(): projection/zone differs from that of currently open "
-#~ "raster maps"
+#~ msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
#~ msgstr "G_set_window():投影/区域与当前打开的栅格文件不同"
#~ msgid "The floating data range for %s@%s is empty"
@@ -10003,9 +9838,7 @@
#~ msgid "Layer number"
#~ msgstr "图层号"
-#~ msgid ""
-#~ "A single vector map can be connected to multiple database tables. This "
-#~ "number determines which table to use."
+#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
#~ msgstr "一个矢量地图能够连接多个数据库表。这个数字决定使用那个表。"
#~ msgid ""
@@ -10279,16 +10112,13 @@
#~ msgstr "无法找到[%s]"
#, fuzzy
-#~ msgid ""
-#~ "Raster map <%s@%s> is in different projection than current region. Found "
-#~ "raster map <%s@%s>, should be <%s>."
+#~ msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
#~ msgstr ""
#~ "[%s]在地图集[%s]中 - 与当前范围的投影不同:\n"
#~ " 找到的地图[%s]在<%s>投影下,当前的投影应该是<%s> "
#, fuzzy
-#~ msgid ""
-#~ "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
+#~ msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
#~ msgstr "[%s]在地图集[%s]中 - 区域[%d]与当前的范围[%d]不同"
#, fuzzy
@@ -10300,8 +10130,7 @@
#~ msgstr "<%s>在地图集<%s>中"
#, fuzzy
-#~ msgid ""
-#~ "Unable to write embedded null values for raster map open for random access"
+#~ msgid "Unable to write embedded null values for raster map open for random access"
#~ msgstr "以随机存取打开的地图不能写入嵌入的空值"
#, fuzzy
@@ -10417,15 +10246,13 @@
#~ msgid "Matrix is not symmetric!"
#~ msgstr "该矩阵是非对称的"
-#~ msgid ""
-#~ "The type of solver which should solve the symmetric linear equation system"
+#~ msgid "The type of solver which should solve the symmetric linear equation system"
#~ msgstr "应该解算线性对称方程式系统的解算类型"
#~ msgid "The type of solver which should solve the linear equation system"
#~ msgstr "应该解算线性方程式系统的解算类型"
-#~ msgid ""
-#~ "Maximum number of iteration used to solver the linear equation system"
+#~ msgid "Maximum number of iteration used to solver the linear equation system"
#~ msgstr "解算线性方程式系统的最大迭代次数"
#~ msgid "test, gpde"
@@ -10465,10 +10292,6 @@
#~ msgstr "注册线: "
#, fuzzy
-#~ msgid "All vertices"
-#~ msgstr "允许覆盖"
-#, fuzzy
#~ msgid "Registered points"
#~ msgstr "注册线: "
@@ -10489,13 +10312,11 @@
#, fuzzy
-#~ msgid ""
-#~ "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
+#~ msgid "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
#, fuzzy
-#~ msgid ""
-#~ "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
+#~ msgid "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
#, fuzzy
@@ -10808,9 +10629,7 @@
#~ msgid "decimal field %i not present in sites file"
#~ msgstr "十进制字段 %i 不在站点文件中"
-#~ msgid ""
-#~ "I'm finding records that do not have a floating point attributes (fields "
-#~ "prefixed with '%')."
+#~ msgid "I'm finding records that do not have a floating point attributes (fields prefixed with '%')."
#~ msgstr "这些记录没有浮点属性(字段以'%'为前缀)."
#~ msgid "Sorry <%s> is not a valid option\n"
@@ -10954,14 +10773,6 @@
#, fuzzy
-#~ msgid "Unable to delete file '%s'. Reason: %s"
-#, fuzzy
-#~ msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
-#, fuzzy
#~ msgid "%s is not in the current mapset (%s)"
@@ -11067,76 +10878,170 @@
#~ "\n"
#~ "请指定基准面名称\n"
+#~ msgid "%s - ** illegal name **"
+#~ msgstr "%s - ** 非法的名称 **"
+#~ msgid "Failed to convert string attribute."
+#~ msgstr "转换字符串属性失败。"
+#~ msgid "Probably program error."
+#~ msgstr "可能的程序错误"
+#~ msgid "Connect attempt timed out."
+#~ msgstr "超出连接时间"
#, fuzzy
-#~ msgid "Unable to delete prior null-cells file"
+#~ msgid "Connection failed."
+#~ msgstr "连接失败。\n"
#, fuzzy
-#~ msgid "Unable to close the null-cells file"
+#~ msgid "Unable to open raster map <%s>"
+#~ msgstr "无法将目录改变到%s"
#, fuzzy
-#~ msgid "closecell: can't move [%s] to null-cells file [%s]"
-#~ msgstr ""
-#~ "closecell: 无法将 %s\n"
-#~ "移动到空文件 %s"
+#~ msgid "Unable to close input map"
+#~ msgstr "无法打开%s"
#, fuzzy
-#~ msgid "Unable to delete the temporary null-cells file"
-#~ msgstr "找不到临时空文件:%s"
+#~ msgid "Unable to create raster map <%s>"
+#~ msgid "The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing"
+#~ msgstr "所用的雅可比松弛参数和加速或稳定的sor求解器"
+#~ msgid "Memory error in allocating timestamp"
+#~ msgstr "时间戳非配存储错误"
#, fuzzy
-#~ msgid "Unable to delete the empty temporary null-cells file"
+#~ msgid "Cannot select attributes"
+#~ msgstr "无法删除想线"
+#~ msgid "Login file corrupted"
+#~ msgstr "登录文件损坏"
+#~ msgid "Cairo_draw_bitmap: Failed to create source"
+#~ msgstr "Cairo绘制位图:创建源失败。"
+#~ msgid "Unable to write lockfile %s (disk full? Permissions?)"
+#~ msgstr "不能写入锁定文件%s (磁盘空间已满或没有许可)"
+#~ msgid "Graphics driver [%s] started"
+#~ msgstr "图形驱动 [%s] 已开启"
+#~ msgid "Unknown command: %d last: %d"
+#~ msgstr "未知的指令:%d last: %d"
+#~ msgid "Monitor: get_command: Premature EOF"
+#~ msgstr "检测器:获取指令:未预期的EOF"
+#~ msgid "MAPSET %s not found"
+#~ msgstr "未找到地图集%s"
#, fuzzy
-#~ msgid "Unable to delete the prior null-cells file"
+#~ msgid "The raster map <%s@%s> is empty"
+#~ msgstr " 栅格图%s@%s是空的"
+#~ msgid ""
+#~ "\n"
+#~ "%s invalid; Try again > "
+#~ msgstr ""
+#~ "\n"
+#~ "%s无效:重试 > "
#, fuzzy
-#~ msgid "Unable to close the 'cell' file"
+#~ msgid "unable to write quant file!"
+#~ msgstr "不能创建新进程"
+#~ msgid "LOCATION << %s >> not available"
+#~ msgstr "区域<< %s >>无效"
#, fuzzy
-#~ msgid "Unable to delete prior 'fcell' file"
+#~ msgid "Unable to open file %s in <%s>"
#, fuzzy
-#~ msgid "Unable to delete the prior %s file"
+#~ msgid "Name of input raster3d map"
+#~ msgstr "输入栅格的名称"
#, fuzzy
-#~ msgid "Unable to close file"
+#~ msgid "Name for output raster3d map"
+#~ msgstr "输出栅格的名称"
#, fuzzy
-#~ msgid "Unable to delete the prior 'cell' file"
+#~ msgid "Feature type"
+#~ msgstr "要素类型"
#, fuzzy
-#~ msgid "closecell: can't move [%s] to cell file [%s]"
-#~ msgstr ""
-#~ "closecell: 不能将 %s\n"
-#~ "移动到cell文件 %s"
+#~ msgid "Attempt to restore alive feature"
+#~ msgstr "无法为区域 %d 计算质心"
#, fuzzy
-#~ msgid "Unable to delete the temporary 'cell' file"
+#~ msgid "Unable to add database link"
+#~ msgstr "无法添加数据库链接。"
#, fuzzy
-#~ msgid "Unable to write quant file!"
+#~ msgid "Unable to open vector database definition file '%s'"
+#~ msgstr "无法打开基准面表文件:%s"
#, fuzzy
-#~ msgid "Unable to delete the %s file"
+#~ msgid "%d primitives registered"
+#~ msgstr "\r%d 条原始线被注册 \n"
+#, fuzzy
+#~ msgid "%d vertices registered"
+#, fuzzy
+#~ msgid "%d areas built"
+#~ msgstr "拓扑建立完成。\n"
+#, fuzzy
+#~ msgid "%d isles built"
+#, fuzzy
+#~ msgid "Vector map <%s> is not open on level >= 2"
+#~ msgstr "输入矢量'%s'未找到"
+#~ msgid "Feature %d without geometry ignored"
+#~ msgstr "没有几何形状的要素 %d 被忽略"
+#, fuzzy
+#~ msgid "Error writing out category index file <%s>"
+#~ msgstr "写空间索引文件时出错。\n"
+#, fuzzy
+#~ msgid "Unable to open layer <%s>"
#, fuzzy
-#~ msgid "Unable to write f_format file for CELL maps"
-#~ msgstr "无法将CELL地图写入f_format文件"
+#~ msgid "Unable to write feature, vector map is not opened"
+#~ msgstr "无法写入线,地图尚未打开"
-#~ msgid "%s - ** illegal name **"
-#~ msgstr "%s - ** 非法的名称 **"
+#, fuzzy
+#~ msgid "Unable to restore feature %d from vector map <%s>"
-#~ msgid "Failed to convert string attribute."
-#~ msgstr "转换字符串属性失败。"
+#, fuzzy
+#~ msgid "Unable to read head file"
+#~ msgstr "无法打开临时文件"
+#, fuzzy
+#~ msgid "Unable to feature %d from vector map <%s>"
+#~ msgid "Cannot open database %s"
+#~ msgstr "无法打开数据库 %s"
+#~ msgid "Building topology ...\n"
+#~ msgstr "建立拓扑...\n"
+#, fuzzy
+#~ msgid "Cannot delete line"
+#~ msgstr "无法重写线"
+#~ msgid "Could not stat file '%s'"
+#~ msgstr "无法统计文件'%s'"
+#~ msgid "Not connected...\n"
+#~ msgstr "未连接...\n"
Modified: grass/branches/releasebranch_7_0/translators.csv
--- grass/branches/releasebranch_7_0/translators.csv 2014-04-19 12:14:16 UTC (rev 59796)
+++ grass/branches/releasebranch_7_0/translators.csv 2014-04-19 12:15:41 UTC (rev 59797)
@@ -93,3 +93,4 @@
Shulin Yang,<shulin.yang.9 gmail.com>,ZH
Su Yongheng,<night2008 gmail.com>,ZH
Zhang Jun,<nilarcs gmail.com>,ZH
+YusiJi, <jiyusi0001 gmail.com>,ZH
