[GRASS-SVN] r67852 - in grass/trunk/gui/wxpython: datacatalog docs gui_core lmgr
svn_grass at osgeo.org
Tue Feb 16 19:27:51 PST 2016
Author: wenzeslaus
Date: 2016-02-16 19:27:50 -0800 (Tue, 16 Feb 2016)
New Revision: 67852
grass/trunk/gui/wxpython/datacatalog/tree.py
grass/trunk/gui/wxpython/docs/wxGUI.html
grass/trunk/gui/wxpython/gui_core/preferences.py
grass/trunk/gui/wxpython/lmgr/frame.py
wxGUI/lmgr: simplify notebook tabs names
This saves horizonatal space, so all items can
fit well on all platfroms.
GRASS-dev Layer Manager notebook
https://lists.osgeo.org/pipermail/grass-dev/2016-January/078645.html
https://lists.osgeo.org/pipermail/grass-dev/2016-February/078935.html
Modified: grass/trunk/gui/wxpython/datacatalog/tree.py
--- grass/trunk/gui/wxpython/datacatalog/tree.py 2016-02-17 01:13:35 UTC (rev 67851)
+++ grass/trunk/gui/wxpython/datacatalog/tree.py 2016-02-17 03:27:50 UTC (rev 67852)
@@ -451,14 +451,14 @@
label = _("Displaying {name}...").format(name=string)
self.showNotification.emit(message=label)
label = "d." + self.selected_type.label[:4] + " --q map=" + string + \
- _(" -- completed. Go to Map layers for further operations.")
+ _(" -- completed. Go to Layers tab for further operations.")
if self.selected_type.label == 'vector':
self._giface.lmgr.AddMaps(layerName, 'vector', True)
elif self.selected_type.label == 'raster':
self._giface.lmgr.AddMaps(layerName, 'raster', True)
else:
self._giface.lmgr.AddMaps(layerName, 'raster_3d', True)
- label = "d.rast --q map=" + string + _(" -- completed. Go to 'Map layers' for further operations.") # generate this message (command) automatically?
+ label = "d.rast --q map=" + string + _(" -- completed. Go to Layers tab for further operations.") # generate this message (command) automatically?
Debug.msg(1, "LAYER " + self.selected_layer.label + " DISPLAYED")
else:
Modified: grass/trunk/gui/wxpython/docs/wxGUI.html
--- grass/trunk/gui/wxpython/docs/wxGUI.html 2016-02-17 01:13:35 UTC (rev 67851)
+++ grass/trunk/gui/wxpython/docs/wxGUI.html 2016-02-17 03:27:50 UTC (rev 67852)
@@ -569,7 +569,7 @@
<dl>
<dt>Ctrl+Tab</dt>
- <dd>Switch 'Map layers' and 'Command output' tab</dd>
+ <dd>Switch 'Layers' and 'Console' tab</dd>
<dt>Ctrl+Q</dt>
<dd>Quit</dd>
</dl>
@@ -584,7 +584,7 @@
<dd>Close workspace</dd>
</dl>
-<b>Map Layers</b>
+<b>Layers</b>
<dl>
<dt>Ctrl+Shift+L</dt>
<dd>Add multiple raster or vector map layers to current map display</dd>
@@ -596,7 +596,7 @@
<dd>Close current map display</dd>
</dl>
-<b>Command line prompt</b>
+<b>Console</b>
<dl>
<dt>Tab</dt>
<dd>Show command tooltips</dd>
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2016-02-17 01:13:35 UTC (rev 67851)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2016-02-17 03:27:50 UTC (rev 67852)
@@ -279,7 +279,7 @@
row += 1
hideSearch = wx.CheckBox(parent = panel, id = wx.ID_ANY,
- label = _("Hide '%s' tab (requires GUI restart)") % _("Search module"),
+ label = _("Hide '%s' tab (requires GUI restart)") % _("Modules"),
name = 'IsChecked')
hideSearch.SetValue(self.settings.Get(group = 'manager', key = 'hideTabs', subkey = 'search'))
self.winId['manager:hideTabs:search'] = hideSearch.GetId()
@@ -289,7 +289,7 @@
row += 1
hidePyShell = wx.CheckBox(parent = panel, id = wx.ID_ANY,
- label = _("Hide '%s' tab (requires GUI restart)") % _("Python shell"),
+ label = _("Hide '%s' tab (requires GUI restart)") % _("Python"),
name = 'IsChecked')
hidePyShell.SetValue(self.settings.Get(group = 'manager', key = 'hideTabs', subkey = 'pyshell'))
self.winId['manager:hideTabs:pyshell'] = hidePyShell.GetId()
@@ -302,7 +302,7 @@
row += 1
copySelectedTextToClipboard = wx.CheckBox(parent = panel, id = wx.ID_ANY,
- label = _("Automatically copy selected text to clipboard (in Command console)"),
+ label = _("Automatically copy selected text to clipboard (in the Console tab)"),
name = 'IsChecked')
copySelectedTextToClipboard.SetValue(self.settings.Get(group = 'manager', key = 'copySelectedTextToClipboard', subkey = 'enabled'))
self.winId['manager:copySelectedTextToClipboard:enabled'] = copySelectedTextToClipboard.GetId()
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2016-02-17 01:13:35 UTC (rev 67851)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2016-02-17 03:27:50 UTC (rev 67852)
@@ -291,7 +291,7 @@
self.notebookLayers.SetTabAreaColour(globalvar.FNPageColor)
menu = self._createTabMenu()
self.notebookLayers.SetRightClickMenu(menu)
- self.notebook.AddPage(page = self.notebookLayers, text = _("Map layers"), name = 'layers')
+ self.notebook.AddPage(page = self.notebookLayers, text = _("Layers"), name = 'layers')
# create 'command output' text area
self._gconsole = GConsole(guiparent = self, giface = self._giface,
@@ -302,7 +302,7 @@
self.goutput = GConsoleWindow(parent=self.notebook, gconsole=self._gconsole,
menuModel=self._moduleTreeBuilder.GetModel(),
gcstyle = GC_PROMPT)
- self.notebook.AddPage(page = self.goutput, text = _("Command console"), name = 'output')
+ self.notebook.AddPage(page = self.goutput, text = _("Console"), name = 'output')
self.goutput.showNotification.connect(lambda message: self.SetStatusText(message))
@@ -320,19 +320,19 @@
self.search = SearchModuleWindow(parent=self.notebook, handlerObj=self,
model=self._moduleTreeBuilder.GetModel())
self.search.showNotification.connect(lambda message: self.SetStatusText(message))
- self.notebook.AddPage(page = self.search, text = _("Search modules"), name = 'search')
+ self.notebook.AddPage(page = self.search, text = _("Modules"), name = 'search')
else:
self.search = None
# create 'data catalog' notebook page
self.datacatalog = DataCatalog(parent=self.notebook, giface=self._giface)
self.datacatalog.showNotification.connect(lambda message: self.SetStatusText(message))
- self.notebook.AddPage(page = self.datacatalog, text = _("Data catalog"), name = 'catalog')
+ self.notebook.AddPage(page = self.datacatalog, text = _("Data"), name = 'catalog')
# create 'python shell' notebook page
if not UserSettings.Get(group = 'manager', key = 'hideTabs', subkey = 'pyshell'):
self.pyshell = PyShellWindow(parent=self.notebook, giface=self._giface)
- self.notebook.AddPage(page = self.pyshell, text = _("Python shell"), name = 'pyshell')
+ self.notebook.AddPage(page = self.pyshell, text = _("Python"), name = 'pyshell')
else:
self.pyshell = None
