[GRASS-SVN] r70915 - grass/branches/releasebranch_7_2/locale/po
Sat Apr 22 05:42:31 PDT 2017
Author: neteler
Date: 2017-04-22 05:42:31 -0700 (Sat, 22 Apr 2017)
New Revision: 70915
   grass/branches/releasebranch_7_2/locale/po/grasslibs_pt.po
grasslibs_pt.po: convert to UTF-8 for transifex compatibility
Modified: grass/branches/releasebranch_7_2/locale/po/grasslibs_pt.po
--- grass/branches/releasebranch_7_2/locale/po/grasslibs_pt.po	2017-04-22 12:41:33 UTC (rev 70914)
+++ grass/branches/releasebranch_7_2/locale/po/grasslibs_pt.po	2017-04-22 12:42:31 UTC (rev 70915)
@@ -1,4 +1,4 @@
-# translation of grasslibs_pt.po to Português
+# translation of grasslibs_pt.po to Português
 # translation of grasslibs_pt.po to Portuguese
 # This file is distributed under the same license as the GRASS package.
 # Copyright (C) 2004 GRASS Development Team
@@ -16,7 +16,7 @@
 "Language-Team: gem12lte at student.lu.se\n"
 "Language: pt\n"
 "MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=ISO-8859-1\n"
+"Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
 "X-Generator: Virtaal 0.7.1\n"
@@ -28,12 +28,12 @@
 #: ../lib/arraystats/class.c:42
 msgid "Discont algorithm currently not available because of bugs"
-msgstr "O algoritmo de desconto não se encontra disponível devido a bugs"
+msgstr "O algoritmo de desconto não se encontra disponível devido a bugs"
 #: ../lib/arraystats/class.c:49
 #, fuzzy
 msgid "Classification algorithm failed"
-msgstr "%s: Erro no algoritmo de classificação"
+msgstr "%s: Erro no algoritmo de classificação"
 #: ../lib/arraystats/class.c:227
 msgid "Equiprobable classbreaks currently limited to 10 classes"
@@ -45,72 +45,72 @@
 "There are classbreaks outside the range min-max. Number of classes reduced "
 "to %i, but using probabilities for %i classes."
 msgstr ""
-"Há quebras de classes for dos limites min-máx. O número de classes foi "
+"Há quebras de classes for dos limites min-máx. O número de classes foi "
 "reduzido para %i mas usando probabilidades para %i classes."
 #: ../lib/symbol/read.c:211
 #, c-format
 msgid "Cannot read symbol line coordinates: %s"
-msgstr "Incapaz de ler as coordenadas da linha de símbolos: %s"
+msgstr "Incapaz de ler as coordenadas da linha de símbolos: %s"
 #: ../lib/symbol/read.c:260
 #, c-format
 msgid ""
 "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
 msgstr ""
-"Nome de símbolo incorreto: '%s' (deveria ser: grupo/nome ou grupo/"
+"Nome de símbolo incorreto: '%s' (deveria ser: grupo/nome ou grupo/"
 "nome at mapset)"
 #: ../lib/symbol/read.c:284
 #, c-format
 msgid "Cannot find/open symbol: '%s'"
-msgstr "Incapaz de encontrar/abrir símbolo: '%s'"
+msgstr "Incapaz de encontrar/abrir símbolo: '%s'"
 #: ../lib/symbol/read.c:393 ../lib/symbol/read.c:411 ../lib/symbol/read.c:421
 #: ../lib/symbol/read.c:439
 #, c-format
 msgid "Incorrect symbol color: '%s', using default."
-msgstr "Símbolo de cor incorreto: '%s', usando valor pré-definido."
+msgstr "Símbolo de cor incorreto: '%s', usando valor pré-definido."
 #: ../lib/ogsf/gsd_surf.c:1742
 #, fuzzy
 msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
 msgstr ""
-"Os pontos de corte do plano não correspondem nas diferentes superfícies. "
-"Confirme resolução(ões)."
+"Os pontos de corte do plano não correspondem nas diferentes superfícies. "
+"Confirme resolução(ões)."
 #: ../lib/ogsf/gvl_file.c:103
 msgid "Maximum number of datafiles exceeded"
-msgstr "Número máximo de ficheiros excedido"
+msgstr "Número máximo de ficheiros excedido"
 #: ../lib/ogsf/gvl_file.c:427 ../lib/ogsf/gvl3.c:40
 #: ../lib/gpde/n_arrays_io.c:273 ../lib/manage/do_remove.c:78
 #: ../lib/manage/do_rename.c:76
 #, c-format
 msgid "3D raster map <%s> not found"
-msgstr "Mapa raster 3d <%s> não encontrado"
+msgstr "Mapa raster 3d <%s> não encontrado"
 #: ../lib/ogsf/gvl_file.c:436 ../lib/gpde/n_arrays_io.c:281
 #: ../lib/python/temporal/c_libraries_interface.py:677
 #, c-format, python-format
 msgid "Unable to open 3D raster map <%s>"
-msgstr "Não foi possível abrir o mapa raster 3D <%s>"
+msgstr "Não foi possível abrir o mapa raster 3D <%s>"
 #: ../lib/ogsf/gvl_file.c:442
 #, c-format
 msgid "Unable to read range of 3D raster map <%s>"
-msgstr "Não foi possível ler o intervalo de valores do mapa raster 3D <%s>"
+msgstr "Não foi possível ler o intervalo de valores do mapa raster 3D <%s>"
 #: ../lib/ogsf/gvl_file.c:470 ../lib/raster3d/close.c:120
 #: ../lib/raster3d/close.c:130 ../lib/raster3d/close.c:159
 #: ../lib/python/temporal/c_libraries_interface.py:707
 msgid "Unable to close 3D raster map <%s>"
-msgstr "Não foi possível fechar o mapa raster 3D <%s>"
+msgstr "Não foi possível fechar o mapa raster 3D <%s>"
 #: ../lib/ogsf/gsd_label.c:58
 msgid "Max. number of labels reached!"
-msgstr "Número máximo de etiquetas atingido!"
+msgstr "Número máximo de etiquetas atingido!"
 #: ../lib/ogsf/gvl2.c:267
 #, c-format
@@ -155,7 +155,7 @@
 #: ../lib/rst/interp_float/resout2d.c:426
 #, c-format
 msgid "Raster map <%s> not found"
-msgstr "Mapa raster <%s> não encontrado"
+msgstr "Mapa raster <%s> não encontrado"
 #: ../lib/ogsf/gs3.c:132 ../lib/ogsf/gs3.c:196 ../lib/ogsf/gs3.c:348
 #: ../lib/ogsf/gs3.c:454 ../lib/ogsf/gs3.c:540
@@ -167,7 +167,7 @@
 #, c-format
 msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
 msgstr ""
-"O intervalo de valores da tabela de cor não corresponde aos dados (mincol="
+"O intervalo de valores da tabela de cor não corresponde aos dados (mincol="
 "%d, maxcol=%d"
 #: ../lib/ogsf/gs3.c:658 ../lib/ogsf/gs3.c:730
@@ -178,13 +178,13 @@
 #: ../lib/ogsf/gs3.c:967
 msgid "View not saved by this program,there may be some inconsistancies"
 msgstr ""
-"Visualização não gravada por este programa, podem haver algumas "
-"inconsistências"
+"Visualização não gravada por este programa, podem haver algumas "
+"inconsistências"
 #: ../lib/ogsf/gs2.c:1211
 #, c-format
 msgid "no category info"
-msgstr "sem informação sobre categoria"
+msgstr "sem informação sobre categoria"
 #: ../lib/ogsf/gs2.c:1230
 #, c-format
@@ -194,13 +194,13 @@
 #: ../lib/ogsf/gs2.c:1655
 #, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr "O mapa raster <%s> está fora da região atual. O carregamento falhou."
+msgstr "O mapa raster <%s> está fora da região atual. O carregamento falhou."
 #: ../lib/ogsf/gs2.c:1733 ../lib/ogsf/gs2.c:1739 ../lib/ogsf/gs2.c:1747
 #: ../lib/ogsf/gs2.c:1756 ../lib/ogsf/gs2.c:1764 ../lib/ogsf/gs2.c:1774
 #: ../lib/ogsf/gs2.c:1822
 msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr "GS_load_att_map(): Memória esgotada. Não é possível carregar o mapa"
+msgstr "GS_load_att_map(): Memória esgotada. Não é possível carregar o mapa"
 #: ../lib/ogsf/gs2.c:1850
 msgid "Loading failed"
@@ -214,22 +214,22 @@
 #: ../lib/ogsf/gsd_legend.c:246
 #, c-format
 msgid "Unable to read color file of raster map <%s>"
-msgstr "Não foi possível ler o ficheiro de cor do mapa raster <%s>"
+msgstr "Não foi possível ler o ficheiro de cor do mapa raster <%s>"
 #: ../lib/ogsf/gsd_legend.c:252
 #, c-format
 msgid "Unable to read category file of raster map <%s>"
-msgstr "Não foi possível ler o ficheiro de categorias do mapa raster <%s>"
+msgstr "Não foi possível ler o ficheiro de categorias do mapa raster <%s>"
 #: ../lib/ogsf/gsd_legend.c:269
 #, c-format
 msgid "Unable to read fp range of raster map <%s>"
-msgstr "Não foi possível ler o intervalo de valores fp do mapa raster <%s>"
+msgstr "Não foi possível ler o intervalo de valores fp do mapa raster <%s>"
 #: ../lib/ogsf/gsd_legend.c:281
 #, c-format
 msgid "Unable to read range of raster map <%s>"
-msgstr "Não foi possível ler o intervalo de valores do mapa raster <%s>"
+msgstr "Não foi possível ler o intervalo de valores do mapa raster <%s>"
 #: ../lib/ogsf/gsd_legend.c:295
 msgid "Range request error for legend"
@@ -239,7 +239,7 @@
 #, fuzzy
 msgid "Unable to show discrete FP range (use list)"
 msgstr ""
-"Não foi possível mostrar o intervalo de valores discretos para FP (use lista"
+"Não foi possível mostrar o intervalo de valores discretos para FP (use lista"
 #: ../lib/ogsf/gsd_legend.c:501
 msgid "Too many categories to show as discrete!"
@@ -253,12 +253,12 @@
 #: ../lib/ogsf/gsd_img_ppm.c:95 ../lib/ogsf/gsd_img_tif.c:66
 #, c-format
 msgid "Unable to open file <%s> for writing"
-msgstr "Não foi possíve abrir o ficheiro <%s> para escrita"
+msgstr "Não foi possíve abrir o ficheiro <%s> para escrita"
 #: ../lib/ogsf/gk2.c:272 ../lib/ogsf/gk2.c:285
 #, fuzzy
 msgid "Check no. of frames requested and keyframes marked"
-msgstr "Verifique o nº de janelas pedidas e keyframes marcadas"
+msgstr "Verifique o nº de janelas pedidas e keyframes marcadas"
 #: ../lib/ogsf/gp3.c:56 ../lib/ogsf/gp3.c:191 ../lib/ogsf/gv3.c:60
 #: ../lib/ogsf/gv3.c:333 ../lib/vector/Vlib/legal_vname.c:141
@@ -267,7 +267,7 @@
 #: ../lib/manage/do_rename.c:54
 #, c-format
 msgid "Vector map <%s> not found"
-msgstr "Mapa vectorial <%s> não encontrado"
+msgstr "Mapa vectorial <%s> não encontrado"
 #: ../lib/ogsf/gp3.c:62 ../lib/ogsf/gp3.c:196 ../lib/ogsf/gv3.c:66
 #: ../lib/ogsf/gv3.c:338 ../lib/vector/Vlib/open.c:301
@@ -276,18 +276,18 @@
 #: ../lib/python/temporal/c_libraries_interface.py:748
 msgid "Unable to open vector map <%s>"
-msgstr "Não foi possível abrir o mapa vectorial <%s>"
+msgstr "Não foi possível abrir o mapa vectorial <%s>"
 #: ../lib/ogsf/gp3.c:92 ../lib/vector/Vlib/copy.c:168
 #: ../lib/vector/Vlib/copy.c:245
 #, c-format
 msgid "Unable to read vector map <%s>"
-msgstr "Não foi possível ler o mapa vectorial <%s>"
+msgstr "Não foi possível ler o mapa vectorial <%s>"
 #: ../lib/ogsf/gp3.c:148
 #, c-format
 msgid "No points from vector map <%s> fall within current region"
-msgstr "Nenhum ponto do mapa vectorial <%s> situa-se na região atual"
+msgstr "Nenhum ponto do mapa vectorial <%s> situa-se na região atual"
 #: ../lib/ogsf/gp3.c:153
 #, c-format
@@ -303,7 +303,7 @@
 #: ../lib/vector/Vlib/net_build.c:971 ../lib/rst/interp_float/vinput2d.c:100
 #, c-format
 msgid "Database connection not defined for layer %d"
-msgstr "Ligação à base de dados não definida para a capa %d"
+msgstr "Ligação à base de dados não definida para a capa %d"
 #: ../lib/ogsf/gp3.c:208 ../lib/ogsf/gv3.c:350
 #: ../lib/vector/neta/timetables.c:133 ../lib/vector/neta/utils.c:119
@@ -317,22 +317,22 @@
 #: ../lib/db/dbmi_client/copy_tab.c:133 ../lib/rst/interp_float/vinput2d.c:109
 #, c-format
 msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Não foi possível abrir a base de dados <%s> com o driver <%s>"
+msgstr "Não foi possível abrir a base de dados <%s> com o driver <%s>"
 #: ../lib/ogsf/gp3.c:211
 #, fuzzy, c-format
 msgid "Loading thematic points layer <%s>..."
-msgstr "Carregando mapa raster <%s> na memória"
+msgstr "Carregando mapa raster <%s> na memória"
 #: ../lib/ogsf/gp3.c:235 ../lib/ogsf/gv3.c:377
 #, fuzzy, c-format
 msgid "No color rule defined for category %d"
-msgstr "Impossível mudar de diretório para %s"
+msgstr "Impossível mudar de diretório para %s"
 #: ../lib/ogsf/gp3.c:249 ../lib/ogsf/gv3.c:392
 #, fuzzy, c-format
 msgid "Invalid color definition (%s)"
-msgstr "Coordenadas inválidas"
+msgstr "Coordenadas inválidas"
 #: ../lib/ogsf/gp3.c:288
 #, c-format
@@ -344,7 +344,7 @@
 #: ../lib/ogsf/gv3.c:269
 #, c-format
 msgid "No features from vector map <%s> fall within current region"
-msgstr "Nenhum elemento do mapa vectorial <%s> situa-se na região atual"
+msgstr "Nenhum elemento do mapa vectorial <%s> situa-se na região atual"
 #: ../lib/ogsf/gv3.c:274
 #, c-format
@@ -354,7 +354,7 @@
 #: ../lib/ogsf/gv3.c:353
 #, fuzzy, c-format
 msgid "Loading thematic vector layer <%s>..."
 #: ../lib/ogsf/gv3.c:414
 #, c-format
@@ -374,22 +374,22 @@
 "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
 "advise GRASS developers of this error"
 msgstr ""
-"gsd_rot(): %c é uma especificação inválida de eixo. Rotação ignorada. Por "
-"favor comunique este erro à equipa do GRASS"
+"gsd_rot(): %c é uma especificação inválida de eixo. Rotação ignorada. Por "
+"favor comunique este erro à equipa do GRASS"
 #: ../lib/ogsf/gsds.c:109
 msgid "Maximum number of datasets exceeded"
-msgstr "Número máximo de conjuntos de dados excedido"
+msgstr "Número máximo de conjuntos de dados excedido"
 #: ../lib/ogsf/gs_bm.c:124
 #, fuzzy
 msgid "Bitmap mismatch"
-msgstr "Não correspondência de bitmap"
+msgstr "Não correspondência de bitmap"
 #: ../lib/ogsf/trans.c:180
 #, fuzzy
 msgid "Out of matrix stack space"
-msgstr "Sem espaço para stack na matriz"
+msgstr "Sem espaço para stack na matriz"
 #: ../lib/ogsf/trans.c:200
 #, fuzzy
@@ -398,32 +398,32 @@
 #: ../lib/ogsf/gsdrape.c:207
 msgid "Unable to process vector map - out of memory"
-msgstr "Não foi possível processar o mapa vectorial - sem memória"
+msgstr "Não foi possível processar o mapa vectorial - sem memória"
 #: ../lib/gmath/solvers_classic_iter.c:84
 #, c-format
 msgid "sparse Jacobi -- iteration %5i error %g\n"
-msgstr "Jacobi esparso -- iteração %5i erro %g\n"
+msgstr "Jacobi esparso -- iteração %5i erro %g\n"
 #: ../lib/gmath/solvers_classic_iter.c:156
 #, c-format
 msgid "sparse SOR -- iteration %5i error %g\n"
-msgstr "SOR esparso -- iteração %5i erro %g\n"
+msgstr "SOR esparso -- iteração %5i erro %g\n"
 #: ../lib/gmath/solvers_classic_iter.c:218
 #, c-format
 msgid "Jacobi -- iteration %5i error %g\n"
-msgstr "Jacobi -- iteração %5i erro %g\n"
+msgstr "Jacobi -- iteração %5i erro %g\n"
 #: ../lib/gmath/solvers_classic_iter.c:275
 #, c-format
 msgid "SOR -- iteration %5i error %g\n"
-msgstr "SOR -- iteração %5i erro %g\n"
+msgstr "SOR -- iteração %5i erro %g\n"
 #: ../lib/gmath/solvers_krylov.c:254 ../lib/gmath/solvers_krylov.c:482
 #: ../lib/gmath/solvers_krylov.c:646 ../lib/gmath/solvers_direct.c:134
 msgid "Unable to solve the linear equation system"
-msgstr "Incapaz de resolver o sistema de equações lineares"
+msgstr "Incapaz de resolver o sistema de equações lineares"
 #: ../lib/gmath/solvers_krylov.c:262
 #, c-format
@@ -433,39 +433,39 @@
 #: ../lib/gmath/solvers_krylov.c:264
 #, c-format
 msgid "PCG -- iteration %i error  %g\n"
-msgstr "PCG -- iteração %i erro  %g\n"
+msgstr "PCG -- iteração %i erro  %g\n"
 #: ../lib/gmath/solvers_krylov.c:490
 #, fuzzy, c-format
 msgid "Sparse CG -- iteration %i error  %g\n"
-msgstr "Sparse CG -- iteração %i erro  %g\n"
+msgstr "Sparse CG -- iteração %i erro  %g\n"
 #: ../lib/gmath/solvers_krylov.c:492
 #, c-format
 msgid "CG -- iteration %i error  %g\n"
-msgstr "CG -- iteração %i erro  %g\n"
+msgstr "CG -- iteração %i erro  %g\n"
 #: ../lib/gmath/solvers_krylov.c:695
 #, c-format
 msgid "Sparse BiCGStab -- iteration %i error  %g\n"
-msgstr "Sparse BiCGStab -- iteraçãoi %i erro  %g\n"
+msgstr "Sparse BiCGStab -- iteraçãoi %i erro  %g\n"
 #: ../lib/gmath/solvers_krylov.c:698
 #, c-format
 msgid "BiCGStab -- iteration %i error  %g\n"
-msgstr "BiCGStab -- iteração %i erro  %g\n"
+msgstr "BiCGStab -- iteração %i erro  %g\n"
 #: ../lib/gmath/solvers_direct.c:45
 msgid "Starting direct gauss elimination solver"
-msgstr "A iniciar diretamente a solução de eliminação de Gauss"
+msgstr "A iniciar diretamente a solução de eliminação de Gauss"
 #: ../lib/gmath/solvers_direct.c:73
 msgid "Starting direct lu decomposition solver"
-msgstr "A iniciar diretamente a solução de decomposição lu"
+msgstr "A iniciar diretamente a solução de decomposição lu"
 #: ../lib/gmath/solvers_direct.c:131
 msgid "Starting cholesky decomposition solver"
-msgstr "A iniciar a solução de decomposição Cholesky"
+msgstr "A iniciar a solução de decomposição Cholesky"
 #: ../lib/gmath/solvers_direct_cholesky_band.c:33
 #, c-format
@@ -474,64 +474,64 @@
 #: ../lib/gmath/la.c:61 ../lib/gmath/la.c:117
 msgid "Matrix dimensions out of range"
-msgstr "As dimensões da matriz estão além dos limites"
+msgstr "As dimensões da matriz estão além dos limites"
 #: ../lib/gmath/la.c:150
 msgid "Matrix is not initialised fully."
-msgstr "Matrix não iniciou completamente."
+msgstr "Matrix não iniciou completamente."
 #: ../lib/gmath/la.c:155
 msgid "Unable to allocate space for matrix copy"
-msgstr "Não foi possível alocar espaço para cópia da matriz"
+msgstr "Não foi possível alocar espaço para cópia da matriz"
 #: ../lib/gmath/la.c:220
 #, fuzzy
 msgid "Input matrix is uninitialized"
-msgstr "Vector de saída não iniciado"
+msgstr "Vector de saída não iniciado"
 #: ../lib/gmath/la.c:285
 msgid "First scalar multiplier must be non-zero"
-msgstr "Primeiro multiplicador escalar não pode ser zero"
+msgstr "Primeiro multiplicador escalar não pode ser zero"
 #: ../lib/gmath/la.c:291 ../lib/gmath/la.c:299 ../lib/gmath/la.c:364
 msgid "One or both input matrices uninitialised"
-msgstr "Uma ou ambas matrizes de entrada não iniciadas"
+msgstr "Uma ou ambas matrizes de entrada não iniciadas"
 #: ../lib/gmath/la.c:304 ../lib/gmath/la.c:369
 msgid "Matrix order does not match"
-msgstr "Ordem das matrizes não corresponde"
+msgstr "Ordem das matrizes não corresponde"
 #: ../lib/gmath/la.c:310
 msgid "Unable to allocate space for matrix sum"
-msgstr "Não foi possível alocar espaço para soma matricial"
+msgstr "Não foi possível alocar espaço para soma matricial"
 #: ../lib/gmath/la.c:374
 msgid "Unable to allocate space for matrix product"
-msgstr "Não foi possível alocar espaço para multiplicação matricial"
+msgstr "Não foi possível alocar espaço para multiplicação matricial"
 #: ../lib/gmath/la.c:486
 msgid "Input: one or both data matrices uninitialised"
-msgstr "Entrada: uma ou ambas matrizes não iniciadas"
+msgstr "Entrada: uma ou ambas matrizes não iniciadas"
 #: ../lib/gmath/la.c:491
 msgid "Principal matrix is not properly dimensioned"
-msgstr "Matriz principal não está dimensionada corretamente"
+msgstr "Matriz principal não está dimensionada corretamente"
 #: ../lib/gmath/la.c:496
 msgid "Input: you must have at least one array to solve"
-msgstr "Entrada: você deve ter pelo menos um sistema para resolver"
+msgstr "Entrada: você deve ter pelo menos um sistema para resolver"
 #: ../lib/gmath/la.c:502
 msgid "Could not allocate space for solution matrix"
-msgstr "Não foi possível alocar espaço para a matriz solução"
+msgstr "Não foi possível alocar espaço para a matriz solução"
 #: ../lib/gmath/la.c:508 ../lib/gmath/la.c:516
 msgid "Could not allocate space for working matrix"
-msgstr "Não foi possível alocar espaço para a matriz de trabalho"
+msgstr "Não foi possível alocar espaço para a matriz de trabalho"
 #: ../lib/gmath/la.c:569
 msgid "Matrix (or submatrix is singular). Solution undetermined"
-msgstr "Matriz (ou submatriz) é singular. Solução indeterminada"
+msgstr "Matriz (ou submatriz) é singular. Solução indeterminada"
 #: ../lib/gmath/la.c:573
 msgid "Problem in LA routine."
@@ -539,19 +539,19 @@
 #: ../lib/gmath/la.c:580
 msgid "Procedure not yet available for selected matrix type"
-msgstr "Procedimento não disponível para o tipo de matriz selecionada"
+msgstr "Procedimento não disponível para o tipo de matriz selecionada"
 #: ../lib/gmath/la.c:614
 msgid "Matrix is not square. Cannot determine inverse"
-msgstr "Matriz não é quadrada. Não é possível determinar inversa"
+msgstr "Matriz não é quadrada. Não é possível determinar inversa"
 #: ../lib/gmath/la.c:619
 msgid "Unable to allocate space for matrix"
-msgstr "Não foi possível alocar espaço para a matriz"
+msgstr "Não foi possível alocar espaço para a matriz"
 #: ../lib/gmath/la.c:636
 msgid "Matrix is singular"
-msgstr "Matriz é singular"
+msgstr "Matriz é singular"
 #: ../lib/gmath/la.c:641
 msgid "Problem in LA procedure."
@@ -559,36 +559,36 @@
 #: ../lib/gmath/la.c:729
 msgid "Element array has not been allocated"
-msgstr "Conjunto de elementos não foi alocado"
+msgstr "Conjunto de elementos não foi alocado"
 #: ../lib/gmath/la.c:734
 msgid "Specified element is outside array bounds"
-msgstr "Elemento especificado está fora dos limites do conjunto"
+msgstr "Elemento especificado está fora dos limites do conjunto"
 #: ../lib/gmath/la.c:788
 msgid "Specified matrix column index is outside range"
-msgstr "Índice de coluna especificado para a matriz fora do intervalo"
+msgstr "Índice de coluna especificado para a matriz fora do intervalo"
 #: ../lib/gmath/la.c:793 ../lib/gmath/la.c:834 ../lib/gmath/la.c:1198
 #: ../lib/gmath/la.c:1250 ../lib/gmath/la.c:1325
 msgid "Matrix is not initialised"
-msgstr "Matriz não iniciada"
+msgstr "Matriz não iniciada"
 #: ../lib/gmath/la.c:798 ../lib/gmath/la.c:839
 msgid "Could not allocate space for vector structure"
-msgstr "Não foi possível alocar espaço para a estrutura de vectores"
+msgstr "Não foi possível alocar espaço para a estrutura de vectores"
 #: ../lib/gmath/la.c:829
 msgid "Specified matrix row index is outside range"
-msgstr "Índice da linha especificada para a matriz fora do intervalo"
+msgstr "Índice da linha especificada para a matriz fora do intervalo"
 #: ../lib/gmath/la.c:869
 msgid "Specified row index is outside range"
-msgstr "Índice de linha especificado fora do intervalo"
+msgstr "Índice de linha especificado fora do intervalo"
 #: ../lib/gmath/la.c:874
 msgid "Specified column index is outside range"
-msgstr "Índice de coluna especificado fora do intervalo"
+msgstr "Índice de coluna especificado fora do intervalo"
 #: ../lib/gmath/la.c:894
 msgid "Unknown vector type."
@@ -597,35 +597,35 @@
 #: ../lib/gmath/la.c:949
 #, fuzzy
 msgid "Input matrix and vector have differing dimensions1"
-msgstr "Vectores tem dimensões diferentes"
+msgstr "Vectores tem dimensões diferentes"
 #: ../lib/gmath/la.c:955 ../lib/gmath/la.c:1071 ../lib/gmath/la.c:1361
 msgid "Output vector is uninitialized"
 #: ../lib/gmath/la.c:1076 ../lib/gmath/la.c:1366
 msgid "Vectors are not of the same type"
-msgstr "Vectores não são do mesmo tipo"
+msgstr "Vectores não são do mesmo tipo"
 #: ../lib/gmath/la.c:1081
 msgid "Output vector is of incorrect type"
-msgstr "Vector de saída é de tipo incorreto"
+msgstr "Vector de saída é de tipo incorreto"
 #: ../lib/gmath/la.c:1086 ../lib/gmath/la.c:1376
 msgid "Matrices not allowed"
-msgstr "Matrizes não são permitidas"
+msgstr "Matrizes não são permitidas"
 #: ../lib/gmath/la.c:1092 ../lib/gmath/la.c:1383
 msgid "Vectors have differing dimensions"
 #: ../lib/gmath/la.c:1098 ../lib/gmath/la.c:1390
 msgid "Output vector has incorrect dimension"
-msgstr "Vector de saída tem dimensões incorreta"
+msgstr "Vector de saída tem dimensões incorreta"
 #: ../lib/gmath/la.c:1143
 msgid "Vector dimensions out of range"
-msgstr "Dimensões do vector além dos limites"
+msgstr "Dimensões do vector além dos limites"
 #: ../lib/gmath/la.c:1148
 msgid "Row/column out of range"
@@ -634,11 +634,11 @@
 #: ../lib/gmath/la.c:1371
 #, fuzzy
 msgid "Output vector is not the same type as others"
 #: ../lib/gmath/la.c:1437
 msgid "Vector structure is not initialised"
-msgstr "Estrutura de vectores não inicializada"
+msgstr "Estrutura de vectores não inicializada"
 #: ../lib/gmath/la.c:1558 ../lib/gmath/la.c:1566 ../lib/gmath/la.c:1571
 msgid "Input format error"
@@ -706,7 +706,7 @@
 "++ Running solver unit tests ++"
 msgstr ""
 "\n"
-"++ A executar testes da unidade de solução ++"
+"++ A executar testes da unidade de solução ++"
 #: ../lib/gmath/test/test_solvers.c:42
 msgid ""
@@ -714,7 +714,7 @@
 "-- Solver unit tests failure --"
 msgstr ""
 "\n"
-"-- Falha nos testes da unidade de solução --"
+"-- Falha nos testes da unidade de solução --"
 #: ../lib/gmath/test/test_solvers.c:44
 msgid ""
@@ -722,7 +722,7 @@
 "-- Solver unit tests finished successfully --"
 msgstr ""
 "\n"
-"-- Testes da unidade de solução completados com sucesso --"
+"-- Testes da unidade de solução completados com sucesso --"
 #: ../lib/gmath/test/bench_blas3.c:34
 #, fuzzy
@@ -780,7 +780,7 @@
 #: ../lib/gmath/test/test_main.c:54 ../lib/db/dbmi_base/test/test_main.c:54
 msgid "Choose the integration tests to run"
-msgstr "Escolha os testes de integração a executar"
+msgstr "Escolha os testes de integração a executar"
 #: ../lib/gmath/test/test_main.c:61
 msgid "The size of the matrices and vectors for benchmarking"
@@ -800,16 +800,16 @@
 #: ../lib/gmath/test/test_main.c:83 ../lib/db/dbmi_base/test/test_main.c:62
 msgid "Run all integration tests"
-msgstr "Executar todos os testes de integração"
+msgstr "Executar todos os testes de integração"
 #: ../lib/gmath/test/test_main.c:87 ../lib/db/dbmi_base/test/test_main.c:66
 msgid "Run all unit and integration tests"
-msgstr "Executar todos os testes de unidade e de integração"
+msgstr "Executar todos os testes de unidade e de integração"
 #: ../lib/gmath/test/test_main.c:106
 #, fuzzy
 msgid "Performs benchmarks, unit and integration tests for the gmath library"
-msgstr "Executar teste de unidade e de integração para a biblioteca gpde"
+msgstr "Executar teste de unidade e de integração para a biblioteca gpde"
 #: ../lib/gmath/test/test_blas2.c:38
 #, fuzzy
@@ -931,14 +931,14 @@
 "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
 "is not current mapset"
 msgstr ""
-"Não foi possível criar o ficheiro <%s> para o subgrupo <%s> do grupo <%s> - <"
-"%s> não está no mapset actual"
+"Não foi possível criar o ficheiro <%s> para o subgrupo <%s> do grupo <%s> - <"
+"%s> não está no mapset actual"
 #: ../lib/imagery/sigsetfile.c:57
 #, c-format
 msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
 msgstr ""
-"Não foi possível criar o ficheiro <%s> para o subgrupo <%s> do grupo <%s>"
+"Não foi possível criar o ficheiro <%s> para o subgrupo <%s> do grupo <%s>"
 #: ../lib/imagery/iclass_perimeter.c:109
 #, c-format
@@ -960,17 +960,17 @@
 #: ../lib/imagery/iclass.c:83
 #, fuzzy, c-format
 msgid "No areas in category %d"
 #: ../lib/imagery/iclass.c:127
 #, fuzzy, c-format
 msgid "Raster map <%s@%s> in subgroup <%s> does not exist"
-msgstr "Impossível abrir topologia para mapa vetorial <%s>"
+msgstr "Impossível abrir topologia para mapa vetorial <%s>"
 #: ../lib/imagery/iclass.c:131
 #, fuzzy, c-format
 msgid "Raster map <%s@%s> in group <%s> does not exist"
 #: ../lib/imagery/iclass.c:143
 #, c-format
@@ -986,7 +986,7 @@
 #, c-format
 msgid "Unable to open control point file for group [%s in %s]"
 msgstr ""
-"Não foi possível abrir o ficheiro de pontos de controle do grupo [%s em %s]"
+"Não foi possível abrir o ficheiro de pontos de controle do grupo [%s em %s]"
 #: ../lib/imagery/points.c:132
 #, c-format
@@ -997,12 +997,12 @@
 #, c-format
 msgid "Unable to create control point file for group [%s in %s]"
 msgstr ""
-"Não foi possível criar o ficheiro de pontos de controle do grupo [%s em %s]"
+"Não foi possível criar o ficheiro de pontos de controle do grupo [%s em %s]"
 #: ../lib/imagery/target.c:38
 #, fuzzy, c-format
 msgid "Unable to read target file for group [%s]"
-msgstr "Não foi possível ler o ficheiro destino para o grupo [%s]"
+msgstr "Não foi possível ler o ficheiro destino para o grupo [%s]"
 #: ../lib/imagery/list_subgp.c:72
 #, c-format
@@ -1017,58 +1017,58 @@
 #: ../lib/imagery/fopen.c:23
 #, c-format
 msgid "Unable to create file [%s] of group [%s in %s]"
-msgstr "Não foi possível criar o ficheiro [%s] do grupo [%s em %s]"
+msgstr "Não foi possível criar o ficheiro [%s] do grupo [%s em %s]"
 #: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
 #, c-format
 msgid "Unable to open file [%s] of group [%s in %s]"
-msgstr "Não foi possível abrir o ficheiro [%s] do grupo [%s em %s]"
+msgstr "Não foi possível abrir o ficheiro [%s] do grupo [%s em %s]"
 #: ../lib/imagery/fopen.c:49
 #, c-format
 msgid "Unable to find file [%s] of group [%s in %s]"
-msgstr "Não foi possível encontrar o ficheiro [%s] do grupo [%s em %s]"
+msgstr "Não foi possível encontrar o ficheiro [%s] do grupo [%s em %s]"
 #: ../lib/imagery/fopen.c:79
 #, c-format
 msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
 msgstr ""
-"Não foi possível criar o ficheiro [%s] para o subgrupo [%s] do grupo [%s em "
+"Não foi possível criar o ficheiro [%s] para o subgrupo [%s] do grupo [%s em "
 "%s]"
 #: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
 #, c-format
 msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
 msgstr ""
-"Não foi possível abrir o ficheiro [%s] para o subgrupo [%s] do grupo [%s em "
+"Não foi possível abrir o ficheiro [%s] para o subgrupo [%s] do grupo [%s em "
 "%s]"
 #: ../lib/imagery/fopen.c:116
 #, c-format
 msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
 msgstr ""
-"Não foi possível encontrar o ficheiro [%s] para o subgrupo [%s] do o grupo "
+"Não foi possível encontrar o ficheiro [%s] para o subgrupo [%s] do o grupo "
 "[%s em %s]"
 #: ../lib/imagery/iscatt_core.c:81
 #, fuzzy, c-format
 msgid "Unable to write header into category raster condition file <%s>."
 #: ../lib/imagery/iscatt_core.c:98
 #, fuzzy, c-format
 msgid "Unable to write into category raster condition file <%s>."
-msgstr "não consegui escrever os dados históricos para [%s]"
+msgstr "não consegui escrever os dados históricos para [%s]"
 #: ../lib/imagery/iscatt_core.c:255
 #, fuzzy, c-format
 msgid "Unable to open category raster condtions file <%s>."
-msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
+msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
 #: ../lib/imagery/iscatt_core.c:263
 #, fuzzy, c-format
 msgid "Unable to find patch raster <%s>."
 #: ../lib/imagery/iscatt_core.c:280
 #, c-format
@@ -1083,12 +1083,12 @@
 #: ../lib/imagery/iscatt_core.c:338
 #, fuzzy, c-format
 msgid "Unable to write into category raster conditions file <%s>"
 #: ../lib/imagery/iscatt_core.c:526
 #, fuzzy
 msgid "Unable to read from category raster condtition file."
-msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
+msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
 #: ../lib/imagery/iscatt_core.c:533
 msgid "Invalid size of category raster conditions file."
@@ -1103,27 +1103,27 @@
 #: ../lib/imagery/iscatt_core.c:745
 #, fuzzy, c-format
 msgid "Unbale to read find raster <%s>"
 #: ../lib/imagery/iscatt_core.c:755
 #, fuzzy, c-format
 msgid "Unbale to open raster <%s>"
-msgstr "Impossível abrir arquivo %s"
+msgstr "Impossível abrir arquivo %s"
 #: ../lib/imagery/iscatt_core.c:761
 #, fuzzy, c-format
 msgid "Raster <%s> type is not <%s>"
-msgstr "Vetor de entrada '%s' não encontrado"
+msgstr "Vetor de entrada '%s' não encontrado"
 #: ../lib/imagery/iscatt_core.c:775
 #, fuzzy, c-format
 msgid "Unable to read range of raster <%s>"
 #: ../lib/imagery/iscatt_core.c:803
 #, fuzzy, c-format
 msgid "Unable to open category raster condtition file <%s>"
 #: ../lib/imagery/iscatt_core.c:817
 msgid "Corrupted category raster conditions file (fseek failed)"
@@ -1141,7 +1141,7 @@
 #: ../lib/imagery/list_gp.c:34
 #, c-format
 msgid "group <%s> is empty\n"
-msgstr "grupo <%s> está vazio\n"
+msgstr "grupo <%s> está vazio\n"
 #: ../lib/imagery/list_gp.c:44
 #, c-format
@@ -1161,7 +1161,7 @@
 #: ../lib/imagery/georef_tps.c:293
 #, fuzzy, c-format
 msgid "%s: out of memory"
-msgstr "G_malloc: memória esgotada"
+msgstr "G_malloc: memória esgotada"
 #: ../lib/imagery/iclass_statistics.c:218
 msgid "prepare_signature: outline has odd number of points."
@@ -1183,17 +1183,17 @@
 #: ../lib/imagery/iclass_statistics.c:758
 #, fuzzy
 msgid "Band index out of range"
-msgstr "Dimensões da matriz além dos limites"
+msgstr "Dimensões da matriz além dos limites"
 #: ../lib/imagery/iclass_statistics.c:684
 #, fuzzy
 msgid "Cell category value out of range"
-msgstr "Dimensões do vetor além dos limites"
+msgstr "Dimensões do vetor além dos limites"
 #: ../lib/imagery/iclass_signatures.c:120
 #, fuzzy, c-format
 msgid "Unable to open output signature file '%s'"
 #: ../lib/raster/color_rand.c:33
 #, c-format
@@ -1223,7 +1223,7 @@
 #: ../lib/raster/put_row.c:462
 #, fuzzy, c-format
 msgid "Error writing data via GDAL for row %d of <%s>"
-msgstr "Erro de escrita no arquivo de índices espaciais."
+msgstr "Erro de escrita no arquivo de índices espaciais."
 #: ../lib/raster/put_row.c:486
 msgid "GDAL output doesn't support writing null rows separately"
@@ -1232,7 +1232,7 @@
 #: ../lib/raster/put_row.c:489
 #, fuzzy, c-format
 msgid "No null file for <%s>"
-msgstr "Impossível abrir histórico para mapa vetorial %s"
+msgstr "Impossível abrir histórico para mapa vetorial %s"
 #: ../lib/raster/put_row.c:513 ../lib/raster/put_row.c:518
 #, fuzzy, c-format
@@ -1247,12 +1247,12 @@
 #: ../lib/raster/put_row.c:680
 #, fuzzy, c-format
 msgid "put_raster_row: raster map <%s> not open for write - request ignored"
-msgstr "%s: map [%s] não está aberto para escrita - pedido ignorado"
+msgstr "%s: map [%s] não está aberto para escrita - pedido ignorado"
 #: ../lib/raster/put_row.c:687
 #, fuzzy
 msgid "put_raster_row: unopened file descriptor - request ignored"
-msgstr "%s: descritor de arquivo não foi aberto - pedido ignorado"
+msgstr "%s: descritor de arquivo não foi aberto - pedido ignorado"
 #: ../lib/raster/cats.c:109
 #, fuzzy, c-format
@@ -1262,7 +1262,7 @@
 #: ../lib/raster/cats.c:112
 #, fuzzy, c-format
 msgid "Category support for <%s@%s> invalid"
-msgstr "a informação de categoria para [%s] em [%s] é inválida"
+msgstr "a informação de categoria para [%s] em [%s] é inválida"
 #: ../lib/raster/cats.c:145
 #, fuzzy, c-format
@@ -1277,7 +1277,7 @@
 #: ../lib/raster/cats.c:968
 #, fuzzy, c-format
 msgid "Unable to open %s file for map <%s>"
 #: ../lib/raster/open.c:193
 #, c-format
@@ -1285,13 +1285,13 @@
 "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
 "%s> which does not exist"
 msgstr ""
-"Não foi possível abrir o mapa raster <%s@%s> porque este é uma "
-"reclassificação do mapa raster <%s@%s> que não existe"
+"Não foi possível abrir o mapa raster <%s@%s> porque este é uma "
+"reclassificação do mapa raster <%s@%s> que não existe"
 #: ../lib/raster/open.c:198
 #, fuzzy, c-format
 msgid "Error reading reclass file for raster map <%s>"
-msgstr "não consegui ler arquivo de intervalo para [%s em %s]"
+msgstr "não consegui ler arquivo de intervalo para [%s em %s]"
 #: ../lib/raster/open.c:209
 #, fuzzy, c-format
@@ -1302,12 +1302,12 @@
 #, c-format
 msgid "Raster map <%s@%s>: format field in header file invalid"
 msgstr ""
-"Mapa raster <%s@%s>: o campo formato do ficheiro do cabeçalho é inválido"
+"Mapa raster <%s@%s>: o campo formato do ficheiro do cabeçalho é inválido"
 #: ../lib/raster/open.c:236
 #, fuzzy, c-format
 msgid "Compression with %s is not supported"
-msgstr "Feição OGR tipo %d não suportada)"
+msgstr "Feição OGR tipo %d não suportada)"
 #: ../lib/raster/open.c:240
 #, fuzzy, c-format
@@ -1315,19 +1315,19 @@
 "Raster map <%s> is in different projection than current region. Found <%s>, "
 "should be <%s>."
 msgstr ""
-"[%s] no mapset [%s] - está numa projeção diferente da região atual:\n"
+"[%s] no mapset [%s] - está numa projeção diferente da região atual:\n"
 "o mapa [%s] em: <%s>, deveria ser <%s> "
 #: ../lib/raster/open.c:247
 #, fuzzy, c-format
 msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
 msgstr ""
-"[%s] no mapset [%s] - está em uma zona diferente [%d] da região atual [%d]"
+"[%s] no mapset [%s] - está em uma zona diferente [%d] da região atual [%d]"
 #: ../lib/raster/open.c:252
 #, fuzzy, c-format
 msgid "Raster map <%s>: bytes per cell (%d) too large"
-msgstr "[%s] em [%s] - bytes demais por célula (%d)"
+msgstr "[%s] em [%s] - bytes demais por célula (%d)"
 #: ../lib/raster/open.c:277
 #, c-format
@@ -1338,7 +1338,7 @@
 #: ../lib/raster/open.c:285
 #, fuzzy, c-format
 msgid "Unable to open %s file for raster map <%s@%s>"
-msgstr "Impossível abrir índice de categoria para mapa vetorial <%s>"
+msgstr "Impossível abrir índice de categoria para mapa vetorial <%s>"
 #: ../lib/raster/open.c:322
 #, fuzzy, c-format
@@ -1348,32 +1348,32 @@
 #: ../lib/raster/open.c:527
 #, fuzzy
 msgid "Unable to create GDAL link"
 #: ../lib/raster/open.c:599 ../lib/raster/gdal.c:476
 #, fuzzy, c-format
 msgid "Invalid map type <%d>"
 #: ../lib/raster/open.c:604 ../lib/raster/open.c:759
 #, c-format
 msgid "Raster map <%s> is not in the current mapset (%s)"
-msgstr "Mapa raster <%s> não está mapset atual (%s)"
+msgstr "Mapa raster <%s> não está mapset atual (%s)"
 #: ../lib/raster/open.c:611
 #, c-format
 msgid "<%s> is an illegal file name"
-msgstr "<%s> é um nome de ficheiro ilegal"
+msgstr "<%s> é um nome de ficheiro ilegal"
 #: ../lib/raster/open.c:626 ../lib/raster/open.c:706 ../lib/raster/open.c:782
 #, fuzzy, c-format
 msgid "No temp files available: %s"
-msgstr "não há arquivos %s disponíveis no mapset %s\n"
+msgstr "não há arquivos %s disponíveis no mapset %s\n"
 #: ../lib/raster/open.c:755
 #, fuzzy, c-format
 msgid "Raster map <%s> does not exist in the current mapset (%s)"
 #: ../lib/raster/open.c:821
 msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
@@ -1382,27 +1382,27 @@
 #: ../lib/raster/open.c:879
 #, c-format
 msgid "Raster map <%s> not found in mapset <%s>"
-msgstr "Mapa raster <%s> não encontrado no mapset <%s>"
+msgstr "Mapa raster <%s> não encontrado no mapset <%s>"
 #: ../lib/raster/open.c:940
 #, c-format
 msgid "Unable to find '%s'"
-msgstr "Não foi possível encontrar '%s'"
+msgstr "Não foi possível encontrar '%s'"
 #: ../lib/raster/open.c:951
 #, c-format
 msgid "Invalid type: field '%s' in file '%s'"
-msgstr "Tipo inválido: campo '%s' no ficheiro '%s'"
+msgstr "Tipo inválido: campo '%s' no ficheiro '%s'"
 #: ../lib/raster/open.c:956
 #, fuzzy, c-format
 msgid "Missing type: field in file '%s'"
-msgstr "tipo inválido: campo %s no arquivo %s"
+msgstr "tipo inválido: campo %s no arquivo %s"
 #: ../lib/raster/open.c:961
 #, c-format
 msgid "Raster map <%s> is not xdr: byte_order: %s"
-msgstr "Mapa raster <%s> não é xdr: byte_order: %s"
+msgstr "Mapa raster <%s> não é xdr: byte_order: %s"
 #: ../lib/raster/open.c:1030
 msgid ""
@@ -1422,61 +1422,61 @@
 #: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
 #, fuzzy, c-format
 msgid "Unable to create <%s> file for map <%s>"
 #: ../lib/raster/close.c:77 ../lib/raster/close.c:110
 #, fuzzy, c-format
 msgid "Invalid descriptor: %d"
 #: ../lib/raster/close.c:391 ../lib/raster/close.c:519
 #, fuzzy, c-format
 msgid "Unable to rename null file '%s' to '%s': %s"
 #: ../lib/raster/close.c:461
 #, fuzzy, c-format
 msgid "Unable to rename cell file '%s' to '%s': %s"
 #: ../lib/raster/close.c:541
 msgid "unable to write f_format file for CELL maps"
-msgstr "impossível escrever ficheiro f_format para mapas CELL"
+msgstr "impossível escrever ficheiro f_format para mapas CELL"
 #: ../lib/raster/range.c:102
 #, fuzzy, c-format
 msgid "Unable to read fp range file for <%s>"
 #: ../lib/raster/range.c:169
 #, fuzzy, c-format
 msgid "Unable to read quant rules for raster map <%s>"
 #: ../lib/raster/range.c:206 ../lib/raster/range.c:226
 #, fuzzy, c-format
 msgid "Unable to read range file for <%s>"
 #: ../lib/raster/range.c:264 ../lib/raster/range.c:270
 #: ../lib/raster/range.c:300 ../lib/raster/range.c:314
 #, fuzzy, c-format
 msgid "Unable to write range file for <%s>"
 #: ../lib/raster/auto_mask.c:69
 msgid "Unable to open automatic MASK file"
-msgstr "Não é possível abrir o ficheiro automático MASK"
+msgstr "Não é possível abrir o ficheiro automático MASK"
 #: ../lib/raster/history.c:115 ../lib/raster/history.c:123
 #, fuzzy, c-format
 msgid "Unable to get history information for <%s@%s>"
 #: ../lib/raster/history.c:162
 #, fuzzy, c-format
 msgid "Unable to write history information for <%s>"
 #: ../lib/raster/history.c:235
 #, c-format
@@ -1487,26 +1487,26 @@
 #, c-format
 msgid "category information for [%s] in [%s] missing or invalid"
 msgstr ""
-"a informação da categoria para [%s] em [%s] está em falta ou é inválida"
+"a informação da categoria para [%s] em [%s] está em falta ou é inválida"
 #: ../lib/raster/put_title.c:37
 msgid "G_put_title - can't create a temp file"
-msgstr "G_put_title - não foi possível criar um ficheiro temporário"
+msgstr "G_put_title - não foi possível criar um ficheiro temporário"
 #: ../lib/raster/put_title.c:53
 #, c-format
 msgid "category information for [%s] in [%s] invalid"
-msgstr "a informação da categoria para [%s] em [%s] é inválida"
+msgstr "a informação da categoria para [%s] em [%s] é inválida"
 #: ../lib/raster/put_title.c:60
 msgid "G_put_title - can't reopen temp file"
-msgstr "G_put_title - não foi possível reabrir o ficheiro temporário"
+msgstr "G_put_title - não foi possível reabrir o ficheiro temporário"
 #: ../lib/raster/put_title.c:67
 #, c-format
 msgid "can't write category information for [%s] in [%s]"
 msgstr ""
-"não foi possível escrever as informações da categoria para [%s] em [%s]"
+"não foi possível escrever as informações da categoria para [%s] em [%s]"
 #: ../lib/raster/null_val.c:64
 #, fuzzy
@@ -1534,51 +1534,51 @@
 #: ../lib/raster/interp.c:211
 #, fuzzy, c-format
 msgid "Unknown interpolation method: %s"
-msgstr "Tipo de interpolação desconhecida"
+msgstr "Tipo de interpolação desconhecida"
 #: ../lib/raster/put_cellhd.c:34
 #, fuzzy, c-format
 msgid "Unable to create header file for <%s>"
-msgstr "não consegui criar o cabeçalho para o arquivo [%s]"
+msgstr "não consegui criar o cabeçalho para o arquivo [%s]"
 #: ../lib/raster/quant_io.c:43
 #, fuzzy, c-format
 msgid "Floating data range for raster map <%s> is empty"
-msgstr "O intervalo de dados float para %s@%s está vazio"
+msgstr "O intervalo de dados float para %s@%s está vazio"
 #: ../lib/raster/quant_io.c:52
 #, fuzzy, c-format
 msgid "Integer data range for raster map <%s> is empty"
-msgstr "O intervalo de dados inteiros para %s@%s está vazio"
+msgstr "O intervalo de dados inteiros para %s@%s está vazio"
 #: ../lib/raster/quant_io.c:105
 #, fuzzy, c-format
 msgid "Attempt to open quantization table for CELL raster map <%s>"
 #: ../lib/raster/quant_io.c:135
 #, fuzzy, c-format
 msgid "Quantization file for raster map <%s> is missing"
 #: ../lib/raster/quant_io.c:145
 #, fuzzy, c-format
 msgid "Quantization file for raster map <%s> is empty"
 #: ../lib/raster/sample.c:70
 msgid "Unknown interpolation type"
 #: ../lib/raster/sample.c:327
 msgid "\"no data\" label found; setting to zero"
-msgstr "rótulo \"no data\" encontrado; ajustando para zero"
+msgstr "rótulo \"no data\" encontrado; ajustando para zero"
 #: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:898
 #, fuzzy, c-format
 msgid "Reading raster map <%s@%s> request for row %d is outside region"
 msgstr ""
-"O pedido de leitura da linha %d do mapa raster <%s@%s> está fora da região"
+"O pedido de leitura da linha %d do mapa raster <%s@%s> está fora da região"
 #: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:137
 #: ../lib/raster/get_row.c:144 ../lib/raster/get_row.c:187
@@ -1595,7 +1595,7 @@
 #: ../lib/raster/get_row.c:227
 #, fuzzy, c-format
 msgid "Error reading raster data via GDAL for row %d of <%s>"
 #: ../lib/raster/get_row.c:827 ../lib/raster/get_row.c:832
 #: ../lib/raster/get_row.c:842
@@ -1616,55 +1616,55 @@
 #: ../lib/raster/reclass.c:168
 #, fuzzy, c-format
 msgid "Too many reclass categories for <%s@%s>"
-msgstr "Categorias de reclassificação demais para [%s em %s]"
+msgstr "Categorias de reclassificação demais para [%s em %s]"
 #: ../lib/raster/reclass.c:171
 #, fuzzy, c-format
 msgid "Illegal reclass format in header file for <%s@%s>"
 msgstr ""
-"Formato de reclassificação ilegal no cabeçalho do arquivo para [%s em %s]"
+"Formato de reclassificação ilegal no cabeçalho do arquivo para [%s em %s]"
 #: ../lib/raster/reclass.c:273
 msgid "Illegal reclass request"
-msgstr "Pedido de reclassificação ilegal"
+msgstr "Pedido de reclassificação ilegal"
 #: ../lib/raster/reclass.c:278
 msgid "Illegal reclass type"
-msgstr "Tipo de reclassificação ilegal"
+msgstr "Tipo de reclassificação ilegal"
 #: ../lib/raster/reclass.c:284
 #, fuzzy, c-format
 msgid "Unable to create header file for <%s@%s>"
 #: ../lib/raster/reclass.c:332
 #, fuzzy, c-format
 msgid "Unable to create dependency file in <%s@%s>"
-msgstr "não é possível criar arquivo de dependência [%s em %s]"
+msgstr "não é possível criar arquivo de dependência [%s em %s]"
 #: ../lib/raster/gdal.c:88
 #, c-format
 msgid "Unable to locate symbol <%s>"
-msgstr "Não foi possível localizar símbolo <%s>"
+msgstr "Não foi possível localizar símbolo <%s>"
 #: ../lib/raster/gdal.c:142
 msgid "Unable to load GDAL library"
-msgstr "Não foi possível carregar a biblioteca GDAL"
+msgstr "Não foi possível carregar a biblioteca GDAL"
 #: ../lib/raster/gdal.c:372
 #, fuzzy
 msgid "Unable to open GDAL file"
 #: ../lib/raster/gdal.c:482
 #, fuzzy, c-format
 msgid "Unable to get <%s> driver"
-msgstr "não consegui abrir [%s]"
+msgstr "não consegui abrir [%s]"
 #: ../lib/raster/gdal.c:491
 #, fuzzy, c-format
 msgid "Unable to create <%s> dataset using <%s> driver"
 #: ../lib/raster/gdal.c:499
 #, c-format
@@ -1676,12 +1676,12 @@
 #: ../lib/raster/gdal.c:505
 #, fuzzy
 msgid "Unable to get in-memory raster driver"
 #: ../lib/raster/gdal.c:512
 #, fuzzy, c-format
 msgid "Unable to create <%s> dataset using memory driver"
-msgstr "Impossível abrir base de dados <%s> com driver <%s>"
+msgstr "Impossível abrir base de dados <%s> com driver <%s>"
 #: ../lib/raster/gdal.c:516
 #, c-format
@@ -1691,27 +1691,27 @@
 #: ../lib/raster/gdal.c:532
 #, fuzzy
 msgid "Unable to set geo transform"
 #: ../lib/raster/gdal.c:536
 #, fuzzy
 msgid "Unable to set projection"
 #: ../lib/raster/gdal.c:540
 #, fuzzy, c-format
 msgid "Unable to create cell_misc/%s/gdal file"
-msgstr "Impossível ler arquivo de cabeçalho"
+msgstr "Impossível ler arquivo de cabeçalho"
 #: ../lib/raster/gdal.c:556
 #, fuzzy, c-format
 msgid "Error writing cell_misc/%s/gdal file"
 #: ../lib/raster/gdal.c:604
 #, fuzzy, c-format
 msgid "Unable to create output file <%s> using driver <%s>"
-msgstr "não foi possível abrir o arquivo %s em %s"
+msgstr "não foi possível abrir o arquivo %s em %s"
 #: ../lib/raster/color_rules.c:125
 msgid "syntax error"
@@ -1723,7 +1723,7 @@
 #: ../lib/raster/color_rules.c:129
 msgid "invalid color name"
-msgstr "nome de cor inválido"
+msgstr "nome de cor inválido"
 #: ../lib/raster/color_rules.c:131
 msgid "percentage not in range 0-100"
@@ -1731,7 +1731,7 @@
 #: ../lib/raster/color_rules.c:133
 msgid "invalid value"
-msgstr "valor inválido"
+msgstr "valor inválido"
 #: ../lib/raster/color_rules.c:135
 msgid "unknown error"
@@ -1745,13 +1745,13 @@
 #: ../lib/raster/color_rules.c:328
 #, c-format
 msgid "Unable to load color rules <%s>"
-msgstr "Não foi possível carregar as regras de cor <%s>"
+msgstr "Não foi possível carregar as regras de cor <%s>"
 #: ../lib/raster/init.c:61
 #, fuzzy
 msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
 msgstr ""
-"\aERRO: Sistema não iniciado. O programador não incluiu a chamada a "
+"\aERRO: Sistema não iniciado. O programador não incluiu a chamada a "
 "G_gisinit()\n"
 #: ../lib/raster/init.c:109
@@ -1772,37 +1772,37 @@
 #: ../lib/raster/raster_metadata.c:109
 #, fuzzy, c-format
 msgid "Unable to read <%s> for raster map <%s@%s>"
 #: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
 #, fuzzy, c-format
 msgid "Error closing <%s> metadata file for raster map <%s@%s>"
 #: ../lib/raster/raster_metadata.c:142
 #, fuzzy, c-format
 msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
 #: ../lib/raster/quant_rw.c:88
 #, fuzzy, c-format
 msgid "Unable to read fp range for raster map <%s>"
 #: ../lib/raster/quant_rw.c:92
 #, fuzzy, c-format
 msgid "Raster map <%s> is empty"
-msgstr "O raster %s@%s está vazio"
+msgstr "O raster %s@%s está vazio"
 #: ../lib/raster/quant_rw.c:157
 #, fuzzy, c-format
 msgid "Unable to write quant rules: raster map <%s> is integer"
-msgstr "não consegui escrever regras de quantização : o mapa %s é inteiro"
+msgstr "não consegui escrever regras de quantização : o mapa %s é inteiro"
 #: ../lib/raster/quant_rw.c:166
 #, fuzzy, c-format
 msgid "Unable to write quant rules for raster map <%s>"
 #: ../lib/raster/histogram.c:55
 #, c-format
@@ -1812,17 +1812,17 @@
 #: ../lib/raster/histogram.c:62
 #, c-format
 msgid "Can't read histogram for [%s in %s]"
-msgstr "Não foi possível ler o histograma para [%s em %s]"
+msgstr "Não foi possível ler o histograma para [%s em %s]"
 #: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
 #, c-format
 msgid "Invalid histogram file for [%s in %s]"
-msgstr "Ficheiro do histograma inválido para [%s em %s]"
+msgstr "Ficheiro do histograma inválido para [%s em %s]"
 #: ../lib/raster/histogram.c:331
 #, fuzzy, c-format
 msgid "Unable to create histogram file for <%s>"
 #: ../lib/raster/set_window.c:48
 msgid "Rast_set_window() called while window split"
@@ -1834,7 +1834,7 @@
 "Rast_set_read_window(): projection/zone differs from that of currently open "
 "raster maps"
 msgstr ""
-"G_set_window(): projeção/zona difere daquela nos arquivos raster abertos"
+"G_set_window(): projeção/zona difere daquela nos arquivos raster abertos"
 #: ../lib/raster/set_window.c:158
 #, c-format
@@ -1852,21 +1852,21 @@
 "Unable to read header file for raster map <%s@%s>. It is a reclass of raster "
 "map <%s@%s> %s"
 msgstr ""
-"não foi possível abrir [%s] em [%s] pois este é uma reclassificação de [%s] "
-"em [%s] que não existe"
+"não foi possível abrir [%s] em [%s] pois este é uma reclassificação de [%s] "
+"em [%s] que não existe"
 #: ../lib/raster/get_cellhd.c:70
 msgid "which is missing."
-msgstr "que está faltando."
+msgstr "que está faltando."
 #: ../lib/raster/get_cellhd.c:71
 msgid "whose header file can't be opened."
-msgstr "cujo ficheiro de cabeçalho não pode ser aberto."
+msgstr "cujo ficheiro de cabeçalho não pode ser aberto."
 #: ../lib/raster/get_cellhd.c:76
 #, c-format
 msgid "Unable to open header file for raster map <%s@%s>"
-msgstr "Não foi possível abrir o ficheiro de cabeçalho do mapa raster <%s@%s>"
+msgstr "Não foi possível abrir o ficheiro de cabeçalho do mapa raster <%s@%s>"
 #: ../lib/raster/window.c:31
 msgid ""
@@ -1899,13 +1899,13 @@
 #: ../lib/raster/color_read.c:103
 #, fuzzy
 msgid "missing"
-msgstr "que está faltando"
+msgstr "que está faltando"
 #: ../lib/raster/color_read.c:106
 #, fuzzy
 msgid "invalid"
 msgstr ""
-"é inválido\n"
+"é inválido\n"
 "%s"
 #: ../lib/raster/color_read.c:112
@@ -1916,34 +1916,34 @@
 #: ../lib/nviz/nviz.c:128
 #, c-format
 msgid "Invalid color (%s), using \"white\" as default"
-msgstr "Cor inválida (%s), \"branco\" vai ser usado como valor pré-definido"
+msgstr "Cor inválida (%s), \"branco\" vai ser usado como valor pré-definido"
 #: ../lib/nviz/render.c:106
 msgid "Bad server connection"
-msgstr "Má ligação ao servidor"
+msgstr "Má ligação ao servidor"
 #: ../lib/nviz/render.c:112
 #, fuzzy
 msgid "Unable to get visual info"
 #: ../lib/nviz/render.c:119
 #, fuzzy
 msgid "Unable to create rendering context"
-msgstr "Não foi possível criar novo processo"
+msgstr "Não foi possível criar novo processo"
 #: ../lib/nviz/lights.c:171
 #, fuzzy
 msgid "Unable to define new light"
-msgstr "Não foi possível definir nova iluminação"
+msgstr "Não foi possível definir nova iluminação"
 #: ../lib/nviz/map_obj.c:59
 msgid "Maximum surfaces loaded!"
-msgstr "Número máximo de superfícies carregado!"
+msgstr "Número máximo de superfícies carregado!"
 #: ../lib/nviz/map_obj.c:88
 msgid "Maximum vector line maps loaded!"
-msgstr "Número máximo de mapas vectoriais de linhas carregados!"
+msgstr "Número máximo de mapas vectoriais de linhas carregados!"
 #: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
 #, c-format
@@ -1952,11 +1952,11 @@
 #: ../lib/nviz/map_obj.c:116
 msgid "Maximum vector point maps loaded!"
-msgstr "Número máximo de mapas vectoriais de pontos carregados!"
+msgstr "Número máximo de mapas vectoriais de pontos carregados!"
 #: ../lib/nviz/map_obj.c:143
 msgid "Maximum volumes loaded!"
-msgstr "Número máximo de volumes carregado!"
+msgstr "Número máximo de volumes carregado!"
 #: ../lib/nviz/map_obj.c:152
 #, c-format
@@ -1965,17 +1965,17 @@
 #: ../lib/nviz/map_obj.c:160
 msgid "Nviz_new_map_obj(): unsupported data type"
-msgstr "Nviz_new_map_obj(): tipo de dado não suportado"
+msgstr "Nviz_new_map_obj(): tipo de dado não suportado"
 #: ../lib/nviz/position.c:56
 #, fuzzy
 msgid "Unable to set focus"
-msgstr "Não foi possível definir o foco"
+msgstr "Não foi possível definir o foco"
 #: ../lib/htmldriver/graph_set.c:97
 #, fuzzy, c-format
 msgid "html: collecting to file '%s'"
-msgstr "não consegui obter informações sobre o arquivo '%s'"
+msgstr "não consegui obter informações sobre o arquivo '%s'"
 #: ../lib/htmldriver/graph_set.c:98
 #, c-format
@@ -1991,7 +1991,7 @@
 #: ../lib/raster3d/color.c:354
 #, fuzzy, c-format
 msgid "mapset <%s> is not the current mapset"
-msgstr "Bug: tentativa de atualizar mapa que não está no mapset atual."
+msgstr "Bug: tentativa de atualizar mapa que não está no mapset atual."
 #: ../lib/raster3d/open.c:20
 #, fuzzy
@@ -2016,7 +2016,7 @@
 #: ../lib/raster3d/open.c:98
 #, fuzzy
 msgid "Rast3d_open_cell_old: can't rewind file"
-msgstr "Rast3d_openCellOld: não posso rebobinar aquivo"
+msgstr "Rast3d_openCellOld: não posso rebobinar aquivo"
 #: ../lib/raster3d/open.c:111
 #, fuzzy
@@ -2026,22 +2026,22 @@
 #: ../lib/raster3d/open.c:119
 #, fuzzy
 msgid "Rast3d_open_cell_old: projection does not match window projection"
-msgstr "Rast3d_openCellOld: projeção não coincide com a projeção na janela"
+msgstr "Rast3d_openCellOld: projeção não coincide com a projeção na janela"
 #: ../lib/raster3d/open.c:123
 #, fuzzy
 msgid "Rast3d_open_cell_old: zone does not match window zone"
-msgstr "Rast3d_openCellOld: zona não coincide com a zona da janela"
+msgstr "Rast3d_openCellOld: zona não coincide com a zona da janela"
 #: ../lib/raster3d/open.c:135 ../lib/raster3d/open.c:152
 #, fuzzy
 msgid "Rast3d_open_cell_old: can't read header"
-msgstr "Rast3d_openCellOld: não consigo ler cabeçalho"
+msgstr "Rast3d_openCellOld: não consigo ler cabeçalho"
 #: ../lib/raster3d/open.c:141
 #, fuzzy
 msgid "Rast3d_open_cell_old: index does not fit into long"
-msgstr "Rast3d_openCellOld: index não cabe num long"
+msgstr "Rast3d_openCellOld: index não cabe num long"
 #: ../lib/raster3d/open.c:145
 #, fuzzy
@@ -2066,17 +2066,17 @@
 #: ../lib/raster3d/open.c:233
 #, fuzzy, c-format
 msgid "map <%s> is not in the current mapset"
 #: ../lib/raster3d/open.c:243
 #, fuzzy
 msgid "Rast3d_open_cell_new: could not open file"
-msgstr "Rast3d_openCellNew: não consegui abrir arquivo"
+msgstr "Rast3d_openCellNew: não consegui abrir arquivo"
 #: ../lib/raster3d/open.c:287 ../lib/raster3d/open.c:292
 #, fuzzy
 msgid "Rast3d_open_cell_new: can't write header"
-msgstr "Rast3d_openCellNew: não consegui escrever cabeçalho"
+msgstr "Rast3d_openCellNew: não consegui escrever cabeçalho"
 #: ../lib/raster3d/open.c:314
 #, fuzzy
@@ -2086,38 +2086,38 @@
 #: ../lib/raster3d/close.c:47
 #, fuzzy, c-format
 msgid "Unable to write history for 3D raster map <%s>"
 #: ../lib/raster3d/close.c:62
 #, fuzzy, c-format
 msgid "Unable to move temp raster map <%s> to 3D raster map <%s>"
-msgstr "não foi possível abrir o mapa raster [%s em %s]"
+msgstr "não foi possível abrir o mapa raster [%s em %s]"
 #: ../lib/raster3d/close.c:79
 #, fuzzy
 msgid "Unable to flush all tiles"
 #: ../lib/raster3d/close.c:84
 #, fuzzy
 msgid "Unable to flush index"
-msgstr "não consegui encontrar [%s]"
+msgstr "não consegui encontrar [%s]"
 #: ../lib/raster3d/close.c:94
 #, fuzzy
 msgid "Unable to position file"
 #: ../lib/raster3d/close.c:99 ../lib/raster3d/close.c:105
 #: ../lib/raster3d/close.c:191 ../lib/raster3d/header.c:217
 #, fuzzy, c-format
 msgid "Unable to write header for 3D raster map <%s>"
 #: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
 #, fuzzy, c-format
 msgid "Unable to create 3D raster map <%s>"
 #: ../lib/raster3d/close.c:169
 #, fuzzy
@@ -2127,22 +2127,22 @@
 #: ../lib/raster3d/range.c:73
 #, fuzzy, c-format
 msgid "Unable to open range file for [%s in %s]"
 #: ../lib/raster3d/range.c:88
 #, fuzzy, c-format
 msgid "Error reading range file for [%s in %s]"
 #: ../lib/raster3d/range.c:150
 #, fuzzy, c-format
 msgid "Unable to open range file for <%s>"
 #: ../lib/raster3d/history.c:43
 #, c-format
 msgid "can't get history information for [%s] in mapset [%s]"
-msgstr "não é possível obter dados históricos para [%s] no mapset [%s]"
+msgstr "não é possível obter dados históricos para [%s] no mapset [%s]"
 #: ../lib/raster3d/maskfn.c:77
 #, c-format
@@ -2157,16 +2157,16 @@
 #: ../lib/raster3d/param.c:84
 #, fuzzy
 msgid "Rast3d_get_standard3d_params: precision value invalid"
-msgstr "Rast3d_getStandard3dParams: valores de precisão inválidos"
+msgstr "Rast3d_getStandard3dParams: valores de precisão inválidos"
 #: ../lib/raster3d/param.c:105
 #, fuzzy
 msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
-msgstr "Rast3d_getStandard3dParams: dimensão do recorte inválido"
+msgstr "Rast3d_getStandard3dParams: dimensão do recorte inválido"
 #: ../lib/raster3d/param.c:129
 msgid "Window replacing the default"
-msgstr "Janela substituindo o padrão"
+msgstr "Janela substituindo o padrão"
 #: ../lib/raster3d/test/test_main.c:98
 msgid "raster3d"
@@ -2179,7 +2179,7 @@
 #: ../lib/gis/lrand48.c:84
 #, fuzzy, c-format
 msgid "gettimeofday failed: %s"
-msgstr "Falha na conexão."
+msgstr "Falha na conexão."
 #: ../lib/gis/lrand48.c:114
 msgid "Pseudo-random number generator not seeded"
@@ -2188,32 +2188,32 @@
 #: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
 #, c-format
 msgid "Current region rows: %d, cols: %d"
-msgstr "Linhas de região actual: %d, colunas: %d"
+msgstr "Linhas de região actual: %d, colunas: %d"
 #: ../lib/gis/alloc.c:47
 #, c-format
 msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr "G_malloc: não foi possível alocar %lu bytes de memória em %s:%d"
+msgstr "G_malloc: não foi possível alocar %lu bytes de memória em %s:%d"
 #: ../lib/gis/alloc.c:89
 #, c-format
 msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
-msgstr "G_calloc: não foi possível alocar %lu * %lu bytes de memória em %s:%d"
+msgstr "G_calloc: não foi possível alocar %lu * %lu bytes de memória em %s:%d"
 #: ../lib/gis/alloc.c:135
 #, c-format
 msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr "G_realloc: não foi possível alocar %lu bytes de memória em %s:%d"
+msgstr "G_realloc: não foi possível alocar %lu bytes de memória em %s:%d"
 #: ../lib/gis/open.c:68
 #, c-format
 msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr "G__open(read): o mapset <%s> não corresponde ao xmapset <%s>"
+msgstr "G__open(read): o mapset <%s> não corresponde ao xmapset <%s>"
 #: ../lib/gis/open.c:89
 #, fuzzy, c-format
 msgid "G__open(read): Unable to open '%s': %s"
-msgstr "G_spawn: Não foi possível abrir o ficheiro %s"
+msgstr "G_spawn: Não foi possível abrir o ficheiro %s"
 #: ../lib/gis/open.c:98
 #, c-format
@@ -2223,7 +2223,7 @@
 #: ../lib/gis/open.c:122
 #, fuzzy, c-format
 msgid "G__open(write): Unable to open '%s': %s"
 #: ../lib/gis/spawn.c:386
 #, c-format
@@ -2233,85 +2233,85 @@
 #: ../lib/gis/spawn.c:421
 #, c-format
 msgid "G_spawn: unable to redirect descriptor %d"
-msgstr "G_spawn: Não foi possível redirecionar o descritor %d"
+msgstr "G_spawn: Não foi possível redirecionar o descritor %d"
 #: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
 #, c-format
 msgid "G_spawn: unable to open file %s"
 #: ../lib/gis/spawn.c:503 ../lib/gis/spawn.c:689
 msgid "Unable to execute command"
-msgstr "Não foi possível executar o comando"
+msgstr "Não foi possível executar o comando"
 #: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
 #, c-format
 msgid "G_spawn: unable to restore signal %d"
-msgstr "G_spawn: não é possível restabelecer o sinal %d"
+msgstr "G_spawn: não é possível restabelecer o sinal %d"
 #: ../lib/gis/spawn.c:567
 #, c-format
 msgid "G_spawn: unable to reset signal %d"
-msgstr "G_spawn: não é possível reiniciar o sinal %d"
+msgstr "G_spawn: não é possível reiniciar o sinal %d"
 #: ../lib/gis/spawn.c:576
 #, c-format
 msgid "G_spawn: unable to ignore signal %d"
-msgstr "G_spawn: não é possível ignorar o sinal %d"
+msgstr "G_spawn: não é possível ignorar o sinal %d"
 #: ../lib/gis/spawn.c:587
 #, c-format
 msgid "G_spawn: unable to block signal %d"
-msgstr "G_spawn: não é possível bloquear o sinal %d"
+msgstr "G_spawn: não é possível bloquear o sinal %d"
 #: ../lib/gis/spawn.c:595
 #, c-format
 msgid "G_spawn: unable to unblock signal %d"
-msgstr "G_spawn: não é possível desbloquear o sinal %d"
+msgstr "G_spawn: não é possível desbloquear o sinal %d"
 #: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
 #, c-format
 msgid "G_spawn: unable to duplicate descriptor %d to %d"
-msgstr "G_spawn: Não foi possível duplicar o descritor %d para %d"
+msgstr "G_spawn: Não foi possível duplicar o descritor %d para %d"
 #: ../lib/gis/spawn.c:666
 msgid "Unable to create a new process"
 #: ../lib/gis/spawn.c:681
 #, c-format
 msgid "Unable to change directory to %s"
-msgstr "Não foi possível mudar o diretório para %s"
+msgstr "Não foi possível mudar o diretório para %s"
 #: ../lib/gis/parser.c:355
 #, fuzzy, c-format
 msgid "BUG in option name, '%s' is not valid"
-msgstr "BUG nas descrições, opção '%s' em <%s> não existe"
+msgstr "BUG nas descrições, opção '%s' em <%s> não existe"
 #: ../lib/gis/parser.c:407
 #, c-format
 msgid "BUG in descriptions, option '%s' in <%s> does not exist"
 #: ../lib/gis/parser.c:525
 #, fuzzy
 msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr "Usar alerta --quiet ou --verbose, não ambos. Assume --verbose."
+msgstr "Usar alerta --quiet ou --verbose, não ambos. Assume --verbose."
 #: ../lib/gis/parser.c:539
 #, fuzzy
 msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr "Usar alerta --quiet ou --verbose, não ambos. Assume --quiet."
+msgstr "Usar alerta --quiet ou --verbose, não ambos. Assume --quiet."
 #: ../lib/gis/parser.c:554
 #, fuzzy
 msgid "Use either --qq or --verbose flag, not both. Assuming --qq."
 #: ../lib/gis/parser.c:585
 #, fuzzy, c-format
 msgid "Sorry <%s> is not a valid option"
-msgstr "Desculpe <%s> não é uma opção válida\n"
+msgstr "Desculpe <%s> não é uma opção válida\n"
 #: ../lib/gis/parser.c:598
 msgid "Your installation doesn't include GUI, exiting."
@@ -2324,17 +2324,17 @@
 #: ../lib/gis/parser.c:941
 msgid "Unable to determine program name"
-msgstr "Não foi possível descobrir o nome do programa"
+msgstr "Não foi possível descobrir o nome do programa"
 #: ../lib/gis/parser.c:963 ../lib/gis/parser.c:980
 #, fuzzy, c-format
 msgid "%s: Sorry, <%c> is not a valid flag"
-msgstr "Desculpe, <%c> não é um flag válido\n"
+msgstr "Desculpe, <%c> não é um flag válido\n"
 #: ../lib/gis/parser.c:1110
 #, fuzzy, c-format
 msgid "%s: Sorry, <%s=> is ambiguous"
-msgstr "Desculpe, <%s=> é ambíguo\n"
+msgstr "Desculpe, <%s=> é ambíguo\n"
 #: ../lib/gis/parser.c:1113
 #, c-format
@@ -2349,7 +2349,7 @@
 #: ../lib/gis/parser.c:1144
 #, fuzzy, c-format
 msgid "%s: Sorry, <%s> is not a valid parameter"
-msgstr "Desculpe, <%s> não é um parâmetro válido\n"
+msgstr "Desculpe, <%s> não é um parâmetro válido\n"
 #: ../lib/gis/parser.c:1150 ../lib/gis/parser.c:1396
 #, fuzzy, c-format
@@ -2368,7 +2368,7 @@
 "\tPresented as: %s"
 msgstr ""
 "\n"
-"ERRO: sintaxe ilegal no intervalo do parâmetro <%s>\n"
+"ERRO: sintaxe ilegal no intervalo do parâmetro <%s>\n"
 #: ../lib/gis/parser.c:1233
 #, fuzzy, c-format
@@ -2377,14 +2377,14 @@
 "\tLegal range: %s"
 msgstr ""
 "\n"
-"ERRO: valor <%s> fora do intervalo do parâmetro <%s>\n"
+"ERRO: valor <%s> fora do intervalo do parâmetro <%s>\n"
 #: ../lib/gis/parser.c:1239
 #, fuzzy, c-format
 msgid "Missing value for parameter <%s>"
 msgstr ""
 "\n"
-"ERRO: Falta valor para o parâmetro <%s>\n"
+"ERRO: Falta valor para o parâmetro <%s>\n"
 #: ../lib/gis/parser.c:1245
 #, fuzzy, c-format
@@ -2393,7 +2393,7 @@
 "\tValid options: %s"
 msgstr ""
 "\n"
 #: ../lib/gis/parser.c:1418
 #, fuzzy, c-format
@@ -2402,7 +2402,7 @@
 "\t(%s)"
 msgstr ""
 "\n"
-"ERRO: Parâmetro necessário <%s> não fornecido:\n"
+"ERRO: Parâmetro necessário <%s> não fornecido:\n"
 "    (%s).\n"
 #: ../lib/gis/parser.c:1510
@@ -2412,7 +2412,7 @@
 "\tYou provided %d item(s): %s"
 msgstr ""
 "\n"
-"ERRO: A opção <%s> deve ser múltipla de %d\n"
+"ERRO: A opção <%s> deve ser múltipla de %d\n"
 #: ../lib/gis/parser.c:1584 ../lib/gis/error.c:362
 #, c-format
@@ -2427,7 +2427,7 @@
 #: ../lib/gis/parser.c:1703
 #, fuzzy, c-format
 msgid "%s= is not a separator option"
 #: ../lib/gis/parser.c:1706
 #, fuzzy, c-format
@@ -2437,22 +2437,22 @@
 #: ../lib/gis/parser.c:1768 ../lib/gis/parser.c:1785
 #, fuzzy, c-format
 msgid "%s= is not a file option"
 #: ../lib/gis/parser.c:1770
 #, fuzzy, c-format
 msgid "Opening multiple files not supported for %s="
 #: ../lib/gis/parser.c:1776
 #, fuzzy, c-format
 msgid "Unable to open %s file <%s>"
 #: ../lib/gis/parser.c:1782
 #, fuzzy, c-format
 msgid "Unable to create %s file <%s>"
 #: ../lib/gis/parser_html.c:57 ../lib/gis/parser_rest.c:60
 msgid "NAME"
@@ -2475,7 +2475,7 @@
 #: ../lib/gis/parser_html.c:167 ../lib/gis/parser_help.c:200
 #: ../lib/gis/parser_rest.c:164 ../lib/gis/parser_interface.c:329
 msgid "Allow output files to overwrite existing files"
-msgstr "Permitir que os ficheiros de saída reescrevam os ficheiros existentes"
+msgstr "Permitir que os ficheiros de saída reescrevam os ficheiros existentes"
 #: ../lib/gis/parser_html.c:171 ../lib/gis/parser_help.c:202
 #: ../lib/gis/parser_interface.c:337
@@ -2485,12 +2485,12 @@
 #: ../lib/gis/parser_html.c:174 ../lib/gis/parser_help.c:203
 #: ../lib/gis/parser_rest.c:168 ../lib/gis/parser_interface.c:344
 msgid "Verbose module output"
-msgstr "Saída do módulo verbosa"
+msgstr "Saída do módulo verbosa"
 #: ../lib/gis/parser_html.c:177 ../lib/gis/parser_help.c:204
 #: ../lib/gis/parser_rest.c:171 ../lib/gis/parser_interface.c:351
 msgid "Quiet module output"
-msgstr "Saída do módulo quiet"
+msgstr "Saída do módulo quiet"
 #: ../lib/gis/parser_html.c:180 ../lib/gis/parser_help.c:206
 msgid "Force launching GUI dialog"
@@ -2499,15 +2499,15 @@
 #: ../lib/gis/parser_html.c:189 ../lib/gis/parser_rest.c:179
 #: ../lib/init/grass.py:347
 msgid "Parameters"
-msgstr "Parâmetros"
+msgstr "Parâmetros"
 #: ../lib/gis/parser_html.c:233 ../lib/gis/parser_rest.c:223
 msgid "Options"
-msgstr "Opções"
+msgstr "Opções"
 #: ../lib/gis/parser_html.c:239 ../lib/gis/parser_rest.c:230
 msgid "Default"
-msgstr "Padrão"
+msgstr "Padrão"
 #: ../lib/gis/token.c:169
 #, fuzzy
@@ -2519,7 +2519,7 @@
 msgid "Description:"
 msgstr ""
 "\n"
-"Descrição:\n"
+"Descrição:\n"
 #: ../lib/gis/parser_help.c:89
 #, fuzzy
@@ -2539,32 +2539,32 @@
 #: ../lib/gis/parser_help.c:127
 #, fuzzy
 msgid "ERROR: Option key not defined"
-msgstr "Ignorando feição OGR sem ID"
+msgstr "Ignorando feição OGR sem ID"
 #: ../lib/gis/parser_help.c:177
 #, fuzzy
 msgid "Flags:"
-msgstr "Opções"
+msgstr "Opções"
 #: ../lib/gis/parser_help.c:205
 #, fuzzy
 msgid "Super quiet module output"
 #: ../lib/gis/parser_help.c:214
 #, fuzzy
 msgid "Parameters:"
 #: ../lib/gis/parser_help.c:237
 #, c-format
 msgid "  %*s   default: %s\n"
-msgstr "  %*s   padrão: %s\n"
+msgstr "  %*s   padrão: %s\n"
 #: ../lib/gis/parser_help.c:263
 #, c-format
 msgid "  %*s   options: "
-msgstr "  %*s   opções: "
+msgstr "  %*s   opções: "
 #: ../lib/gis/parser_dependencies.c:122
 msgid "Internal error: option or flag not found"
@@ -2573,7 +2573,7 @@
 #: ../lib/gis/parser_dependencies.c:179
 #, fuzzy, c-format
 msgid "<%s> or <%s>"
 #, fuzzy, c-format
@@ -2618,12 +2618,12 @@
 #: ../lib/gis/paths.c:201
 #, fuzzy, c-format
 msgid "Unable to open file <%s> for reading"
-msgstr "não consegui abrir %s para escrita"
+msgstr "não consegui abrir %s para escrita"
 #: ../lib/gis/paths.c:217
 #, fuzzy, c-format
 msgid "Unable to fetch security info for <%s>"
 #: ../lib/gis/cmprbzip.c:82 ../lib/gis/cmprbzip.c:142
 msgid "GRASS needs to be compiled with BZIP2 for BZIP2 compression"
@@ -2632,17 +2632,17 @@
 #: ../lib/gis/ls.c:103
 #, c-format
 msgid "Unable to open directory %s"
-msgstr "Não foi possível abrir o diretório %s"
+msgstr "Não foi possível abrir o diretório %s"
 #: ../lib/gis/make_mapset.c:66 ../lib/init/grass.py:831
 #, fuzzy, c-format, python-format
 msgid "Location <%s> doesn't exist"
 #: ../lib/gis/location.c:61
 #, fuzzy, c-format
 msgid "LOCATION <%s> not available"
-msgstr "LOCAÇÃO << %s >> indisponível"
+msgstr "LOCAÇÃO << %s >> indisponível"
 #: ../lib/gis/worker.c:84
 msgid "Task already has a worker"
@@ -2651,7 +2651,7 @@
 #: ../lib/gis/key_value3.c:33
 #, fuzzy, c-format
 msgid "Unable to open output file <%s>: %s"
 #: ../lib/gis/key_value3.c:36
 #, fuzzy, c-format
@@ -2666,12 +2666,12 @@
 #: ../lib/gis/key_value3.c:60
 #, fuzzy, c-format
 msgid "Unable to open input file <%s>: %s"
-msgstr "G_spawn: não consegui abrir o arquivo %s"
+msgstr "G_spawn: não consegui abrir o arquivo %s"
 #: ../lib/gis/key_value3.c:64
 #, fuzzy, c-format
 msgid "Error reading file <%s>: %s"
 #: ../lib/gis/key_value3.c:67
 #, fuzzy, c-format
@@ -2707,22 +2707,22 @@
 #: ../lib/gis/units.c:215
 #, fuzzy
 msgid "square meters"
 #, fuzzy
 msgid "square meter"
 #: ../lib/gis/units.c:217
 #, fuzzy
 msgid "meters"
 #, fuzzy
 msgid "meter"
 #: ../lib/gis/units.c:222
 msgid "square kilometers"
@@ -2735,7 +2735,7 @@
 #: ../lib/gis/units.c:224
 #, fuzzy
 msgid "kilometers"
 msgid "kilometer"
@@ -2792,12 +2792,12 @@
 #: ../lib/gis/units.c:259
 #, fuzzy
 msgid "square US feet"
 #, fuzzy
 msgid "square US foot"
 #: ../lib/gis/units.c:261
 msgid "US feet"
@@ -2874,27 +2874,27 @@
 #: ../lib/gis/get_ellipse.c:263 ../lib/proj/ellipse.c:243
 #, c-format
 msgid "Unable to open ellipsoid table file <%s>"
-msgstr "Não foi possível abrir o ficheiro da tabela do elipsóide <%s>"
+msgstr "Não foi possível abrir o ficheiro da tabela do elipsóide <%s>"
 #: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
 #, c-format
 msgid "Invalid a: field '%s' in file %s in <%s>"
-msgstr "Parâmetro a inválido: campo '%s' no ficheiro %s em <%s>"
+msgstr "Parâmetro a inválido: campo '%s' no ficheiro %s em <%s>"
 #: ../lib/gis/get_ellipse.c:356
 #, c-format
 msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr "Elipsóide inválido '%s' no ficheiro %s em <%s>"
+msgstr "Elipsóide inválido '%s' no ficheiro %s em <%s>"
 #: ../lib/gis/get_ellipse.c:370
 #, c-format
 msgid "Invalid es: field '%s' in file %s in <%s>"
-msgstr "Parâmetro es inválido: '%s' no ficheiro %s em <%s>"
+msgstr "Parâmetro es inválido: '%s' no ficheiro %s em <%s>"
 #: ../lib/gis/get_ellipse.c:383
 #, c-format
 msgid "No ellipsoid info given in file %s in <%s>"
-msgstr "O ficheiro %s em <%s> não tem informações sobre o elipsóide"
+msgstr "O ficheiro %s em <%s> não tem informações sobre o elipsóide"
 #: ../lib/gis/distance.c:154
 #, c-format
@@ -2903,7 +2903,7 @@
 #: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
 msgid "Unable to seek"
-msgstr "Não foi possível procurar"
+msgstr "Não foi possível procurar"
 #: ../lib/gis/seek.c:56
 msgid "Seek offset out of range"
@@ -2915,23 +2915,23 @@
 "Module built against version %s but trying to use version %s. You need to "
 "rebuild GRASS GIS or untangle multiple installations."
 msgstr ""
-"Versão incompatível da biblioteca para o módulo. Precisa de reconstruir o "
-"GRASS ou separar as instalações múltiplas."
+"Versão incompatível da biblioteca para o módulo. Precisa de reconstruir o "
+"GRASS ou separar as instalações múltiplas."
 #: ../lib/gis/gisinit.c:65
 #, c-format
 msgid "MAPSET %s - permission denied"
-msgstr "MAPSET %s - permissão negada"
+msgstr "MAPSET %s - permissão negada"
 #: ../lib/gis/gisinit.c:68
 #, c-format
 msgid "MAPSET %s not found at %s"
-msgstr "MAPSET %s não encontrado em %s"
+msgstr "MAPSET %s não encontrado em %s"
 #: ../lib/gis/gisinit.c:102
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
 msgstr ""
-"Sistema não iniciado. O programador esqueceu-se de chamar a função "
+"Sistema não iniciado. O programador esqueceu-se de chamar a função "
 "G_gisinit()."
 #: ../lib/gis/parser_wps.c:490
@@ -2941,27 +2941,27 @@
 #: ../lib/gis/legal_name.c:39
 #, fuzzy, c-format
 msgid "Illegal filename <%s>. Cannot start with '.' or be 'NULL'."
-msgstr "Nome de arquivo ilegal. não pode ser '.' ou 'NULL'\n"
+msgstr "Nome de arquivo ilegal. não pode ser '.' ou 'NULL'\n"
 #: ../lib/gis/legal_name.c:46
 #, fuzzy, c-format
 msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
-msgstr "Nome de arquivo ilegal. O caractere <%c> não é permitido.\n"
+msgstr "Nome de arquivo ilegal. O caractere <%c> não é permitido.\n"
 #: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
 #, c-format
 msgid "Output raster map name <%s> is not valid map name"
-msgstr "Nome do mapa raster de saída <%s> não é um nome de mapa válido"
+msgstr "Nome do mapa raster de saída <%s> não é um nome de mapa válido"
 #: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
 #, c-format
 msgid "Output raster map <%s> is used as input"
-msgstr "Mapa raster de saída <%s> é usado como entrada"
+msgstr "Mapa raster de saída <%s> é usado como entrada"
 #: ../lib/gis/find_file.c:114
 #, c-format
 msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
-msgstr "'%s/%s' foi encontrado em mais mapsets (encontrado também em <%s>)"
+msgstr "'%s/%s' foi encontrado em mais mapsets (encontrado também em <%s>)"
 #: ../lib/gis/find_file.c:127
 #, c-format
@@ -2971,39 +2971,39 @@
 #: ../lib/gis/debug.c:80
 #, c-format
 msgid "Cannot open debug file '%s'"
-msgstr "Não foi possível abrir ficheiro de depuração '%s'"
+msgstr "Não foi possível abrir ficheiro de depuração '%s'"
 #: ../lib/gis/error.c:361
 msgid "WARNING: "
-msgstr "ATENÇÃO: "
+msgstr "ATENÇÃO: "
 #: ../lib/gis/myname.c:46
 msgid "This location has no description."
-msgstr "Este localização não tem descrição."
+msgstr "Este localização não tem descrição."
 #: ../lib/gis/env.c:311
 msgid "GISRC - variable not set"
-msgstr "GISRC - variável não definida"
+msgstr "GISRC - variável não definida"
 #: ../lib/gis/env.c:343 ../lib/gis/env.c:369
 #, fuzzy, c-format
 msgid "Variable '%s' not set"
-msgstr "GISRC - variável não incializada"
+msgstr "GISRC - variável não incializada"
 #: ../lib/gis/list.c:83
 #, c-format
 msgid "no %s files available in current mapset\n"
-msgstr "não há ficheiros %s disponíveis no mapset ativo\n"
+msgstr "não há ficheiros %s disponíveis no mapset ativo\n"
 #: ../lib/gis/list.c:86
 #, c-format
 msgid "no %s files available in mapset <%s>\n"
-msgstr "não há ficheiros %s disponíveis no mapset <%s>\n"
+msgstr "não há ficheiros %s disponíveis no mapset <%s>\n"
 #: ../lib/gis/list.c:132
 #, c-format
 msgid "%s files available in mapset <%s>:\n"
-msgstr "ficheiros %s disponíveis no mapset <%s>:\n"
+msgstr "ficheiros %s disponíveis no mapset <%s>:\n"
 #: ../lib/gis/list.c:204
 msgid "G_list: Unknown element type"
@@ -3014,12 +3014,12 @@
 msgid "no description"
 msgstr ""
 "\n"
-"Descrição:\n"
+"Descrição:\n"
 #: ../lib/gis/adj_cellhd.c:42
 #, fuzzy, c-format
 msgid "Illegal n-s resolution value <%lf>"
-msgstr "Valor de resolução N-S ilegal"
+msgstr "Valor de resolução N-S ilegal"
 #: ../lib/gis/adj_cellhd.c:46 ../lib/gis/adj_cellhd.c:197
 msgid "Illegal row value"
@@ -3027,7 +3027,7 @@
 #: ../lib/gis/adj_cellhd.c:50 ../lib/gis/adj_cellhd.c:203
 msgid "Illegal e-w resolution value"
-msgstr "Valor de resolução E-W ilegal"
+msgstr "Valor de resolução E-W ilegal"
 #: ../lib/gis/adj_cellhd.c:54 ../lib/gis/adj_cellhd.c:209
 msgid "Illegal col value"
@@ -3079,15 +3079,15 @@
 #: ../lib/gis/adj_cellhd.c:150 ../lib/gis/adj_cellhd.c:340
 msgid "Invalid coordinates"
-msgstr "Coordenadas inválidas"
+msgstr "Coordenadas inválidas"
 #: ../lib/gis/adj_cellhd.c:191
 msgid "Illegal n-s resolution value"
 #: ../lib/gis/adj_cellhd.c:193
 msgid "Illegal n-s3 resolution value"
 #: ../lib/gis/adj_cellhd.c:199
 msgid "Illegal row3 value"
@@ -3095,7 +3095,7 @@
 #: ../lib/gis/adj_cellhd.c:205
 msgid "Illegal e-w3 resolution value"
-msgstr "Valor ilegal de resolução E-O"
+msgstr "Valor ilegal de resolução E-O"
 #: ../lib/gis/adj_cellhd.c:211
 msgid "Illegal col3 value"
@@ -3103,7 +3103,7 @@
 #: ../lib/gis/adj_cellhd.c:215
 msgid "Illegal t-b3 resolution value"
-msgstr "Valor ilegal de resolução vertical (topo-base)"
+msgstr "Valor ilegal de resolução vertical (topo-base)"
 #: ../lib/gis/adj_cellhd.c:219
 msgid "Illegal depths value"
@@ -3137,7 +3137,7 @@
 #: ../lib/gis/rd_cellhd.c:149
 #, fuzzy
 msgid "Duplicate projection field"
-msgstr "campo de projeção duplicado"
+msgstr "campo de projeção duplicado"
 #: ../lib/gis/rd_cellhd.c:159
 #, fuzzy
@@ -3152,7 +3152,7 @@
 #: ../lib/gis/rd_cellhd.c:385 ../lib/gis/rd_cellhd.c:387
 #, fuzzy, c-format
 msgid "Field <%s> missing"
-msgstr "campo de zona não encontrado"
+msgstr "campo de zona não encontrado"
 #: ../lib/gis/rd_cellhd.c:193
 #, fuzzy
@@ -3187,27 +3187,27 @@
 #: ../lib/gis/rd_cellhd.c:241
 #, fuzzy
 msgid "Duplicate e-w resolution field"
-msgstr "campo de resolução E-W duplicado"
+msgstr "campo de resolução E-W duplicado"
 #: ../lib/gis/rd_cellhd.c:251
 #, fuzzy
 msgid "Duplicate 3D e-w resolution field"
-msgstr "campo de resolução E-W 3D duplicado"
+msgstr "campo de resolução E-W 3D duplicado"
 #: ../lib/gis/rd_cellhd.c:261
 #, fuzzy
 msgid "Duplicate n-s resolution field"
-msgstr "campo de resolução N-S duplicado"
+msgstr "campo de resolução N-S duplicado"
 #: ../lib/gis/rd_cellhd.c:271
 #, fuzzy
 msgid "Duplicate 3D n-s resolution field"
-msgstr "campo de resolução N-S 3D duplicado"
+msgstr "campo de resolução N-S 3D duplicado"
 #: ../lib/gis/rd_cellhd.c:281
 #, fuzzy
 msgid "Duplicate t-b resolution field"
-msgstr "campo de resolução vertical duplicado"
+msgstr "campo de resolução vertical duplicado"
 #: ../lib/gis/rd_cellhd.c:291
 #, fuzzy
@@ -3237,7 +3237,7 @@
 #: ../lib/gis/rd_cellhd.c:341
 #, fuzzy
 msgid "Duplicate format field"
-msgstr "campo formato está duplicado"
+msgstr "campo formato está duplicado"
 #: ../lib/gis/rd_cellhd.c:349
 #, fuzzy
@@ -3246,7 +3246,7 @@
 #: ../lib/gis/proj3.c:121 ../lib/vector/Vlib/header.c:552
 msgid "Unknown projection"
-msgstr "Projeção desconhecida"
+msgstr "Projeção desconhecida"
 #: ../lib/gis/proj2.c:63
 msgid "Latitude-Longitude"
@@ -3254,71 +3254,71 @@
 #: ../lib/gis/proj2.c:65
 msgid "Other Projection"
-msgstr "Outra projeção"
+msgstr "Outra projeção"
 #: ../lib/gis/mapset.c:38
 msgid "MAPSET is not set"
-msgstr "MAPSET não foi definido"
+msgstr "MAPSET não foi definido"
 #: ../lib/gis/mapset.c:80
 #, fuzzy, c-format
 msgid "MAPSET <%s> not available"
 #: ../lib/gis/timestamp.c:292
 #, fuzzy, c-format
 msgid "Unable to create timestamp file for %s map <%s@%s>"
 #: ../lib/gis/timestamp.c:301
 #, fuzzy, c-format
 msgid "Invalid timestamp specified for %s map <%s@%s>"
-msgstr "Arquivo de data inválido para o %s mapa %s no mapset %s"
+msgstr "Arquivo de data inválido para o %s mapa %s no mapset %s"
 #: ../lib/gis/timestamp.c:331
 #, fuzzy, c-format
 msgid "Unable to open timestamp file for %s map <%s@%s>"
 #: ../lib/gis/timestamp.c:340
 #, fuzzy, c-format
 msgid "Invalid timestamp file for %s map <%s@%s>"
 #: ../lib/gis/timestamp.c:479
 #, fuzzy, c-format
 msgid "Unable to open timestamp file for vector map <%s@%s>"
 #: ../lib/gis/timestamp.c:488
 #, fuzzy, c-format
 msgid "Invalid timestamp file for vector map <%s@%s>"
 #: ../lib/gis/timestamp.c:524
 #, fuzzy, c-format
 msgid "Unable to create timestamp file for vector map <%s@%s>"
 #: ../lib/gis/timestamp.c:533
 #, fuzzy, c-format
 msgid "Invalid timestamp specified for vector map <%s@%s>"
 #: ../lib/gis/home.c:39
 #, fuzzy
 msgid "Unable to determine user's home directory"
-msgstr "não consegui encontrar o diretório do usuário"
+msgstr "não consegui encontrar o diretório do usuário"
 #: ../lib/gis/home.c:120
 #, fuzzy, c-format
 msgid "Failed to create directory [%s]"
-msgstr "Impossível mudar de diretório para %s"
+msgstr "Impossível mudar de diretório para %s"
 #: ../lib/gis/get_projinfo.c:37 ../lib/gis/get_projinfo.c:66
 #, c-format
 msgid "<%s> file not found for location <%s>"
-msgstr "Ficheiro <%s> não encontrado para localização <%s>"
+msgstr "Ficheiro <%s> não encontrado para localização <%s>"
 #: ../lib/gis/compress.c:131 ../lib/gis/compress.c:193
 #: ../lib/gis/compress.c:209
@@ -3328,7 +3328,7 @@
 #: ../lib/gis/get_window.c:118
 #, fuzzy, c-format
 msgid "Unable to open element file <%s> for <%s@%s>"
 #: ../lib/gis/get_window.c:123
 #, c-format
@@ -3338,12 +3338,12 @@
 #: ../lib/gis/mapset_msc.c:90
 #, c-format
 msgid "Unable to make mapset element %s (%s): %s"
-msgstr "Não foi possível gerar o elemento do mapset %s (%s): %s"
+msgstr "Não foi possível gerar o elemento do mapset %s (%s): %s"
 #: ../lib/gis/mapset_msc.c:94
 #, c-format
 msgid "Unable to access mapset element %s (%s): %s"
-msgstr "Não foi possível aceder ao elemento do mapset %s (%s): %s"
+msgstr "Não foi possível aceder ao elemento do mapset %s (%s): %s"
 #: ../lib/gis/parser_standard_options.c:146
 msgid "SQL select statement"
@@ -3355,7 +3355,7 @@
 #: ../lib/gis/parser_standard_options.c:155
 msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr "Cláusula WHERE do comando SQL sem palavra-chave 'where' ('onde')"
+msgstr "Cláusula WHERE do comando SQL sem palavra-chave 'where' ('onde')"
 #: ../lib/gis/parser_standard_options.c:156
 msgid "Example: income < 1000 and inhab >= 10000"
@@ -3420,12 +3420,12 @@
 #: ../lib/gis/parser_standard_options.c:267
 msgid "Name for output raster map"
-msgstr "Nome do mapa raster de saída"
+msgstr "Nome do mapa raster de saída"
 #: ../lib/gis/parser_standard_options.c:276
 #, fuzzy
 msgid "Name for output raster map(s)"
 #: ../lib/gis/parser_standard_options.c:284
 #, fuzzy
@@ -3443,22 +3443,22 @@
 #: ../lib/gis/parser_standard_options.c:309
 msgid "Name of cover raster map"
-msgstr "Nome do mapa raster de superfície"
+msgstr "Nome do mapa raster de superfície"
 #: ../lib/gis/parser_standard_options.c:317
 #, fuzzy
 msgid "Name of input elevation raster map"
-msgstr "Nome do mapa raster de elevação"
+msgstr "Nome do mapa raster de elevação"
 #: ../lib/gis/parser_standard_options.c:326
 #, fuzzy
 msgid "Name of input elevation raster map(s)"
-msgstr "Nome dos mapas raster de elevação"
+msgstr "Nome dos mapas raster de elevação"
 #: ../lib/gis/parser_standard_options.c:332
 #, fuzzy
 msgid "Sampling interpolation method"
 #: ../lib/gis/parser_standard_options.c:336
 msgid "Nearest-neighbor interpolation"
@@ -3467,12 +3467,12 @@
 #: ../lib/gis/parser_standard_options.c:337
 #, fuzzy
 msgid "Bilinear interpolation"
 #: ../lib/gis/parser_standard_options.c:338
 #, fuzzy
 msgid "Bicubic interpolation"
 #: ../lib/gis/parser_standard_options.c:347
 #, fuzzy
@@ -3482,7 +3482,7 @@
 #: ../lib/gis/parser_standard_options.c:356
 #, fuzzy
 msgid "Name for output basename raster map(s)"
 #: ../lib/gis/parser_standard_options.c:366
 #, fuzzy
@@ -3497,7 +3497,7 @@
 #: ../lib/gis/parser_standard_options.c:383
 #, fuzzy
 msgid "Name for output 3D raster map"
 #: ../lib/gis/parser_standard_options.c:391
 #, fuzzy
@@ -3512,7 +3512,7 @@
 #: ../lib/gis/parser_standard_options.c:409
 #, fuzzy
 msgid "Data type used in the output raster3d map"
-msgstr "Tipo de dados usados no arquivo de saída"
+msgstr "Tipo de dados usados no arquivo de saída"
 #: ../lib/gis/parser_standard_options.c:418
 msgid ""
@@ -3523,14 +3523,14 @@
 #: ../lib/gis/parser_standard_options.c:428
 #, fuzzy
 msgid "The compression method used in the output raster3d map"
-msgstr "Método de compressão usado no arquivo de saída"
+msgstr "Método de compressão usado no arquivo de saída"
 #: ../lib/gis/parser_standard_options.c:438
 #, fuzzy
 msgid ""
 "The dimensions of the tiles used in the output raster3d map (XxYxZ or "
 "default: 16x16x8)"
-msgstr "Dimensões dos recortes usado no mosaico de saída"
+msgstr "Dimensões dos recortes usado no mosaico de saída"
 #: ../lib/gis/parser_standard_options.c:448
 msgid "Name of input vector map"
@@ -3551,7 +3551,7 @@
 #: ../lib/gis/parser_standard_options.c:467
 msgid "Name for output vector map"
-msgstr "Nome do mapa vectorial de saída"
+msgstr "Nome do mapa vectorial de saída"
 #: ../lib/gis/parser_standard_options.c:475
 #, fuzzy
@@ -3572,7 +3572,7 @@
 #: ../lib/gis/parser_standard_options.c:510
 #, fuzzy
 msgid "Layer number or name"
-msgstr "Número da camada"
+msgstr "Número da camada"
 #: ../lib/gis/parser_standard_options.c:512
 #, fuzzy
@@ -3581,13 +3581,13 @@
 "determines which layer to use. When used with direct OGR access this is the "
 "layer name."
 msgstr ""
-"Apenas um mapa vetorial pode ser conectado a múltiplas tabelas. Este número "
+"Apenas um mapa vetorial pode ser conectado a múltiplas tabelas. Este número "
 "determina qual tabela usar."
 #: ../lib/gis/parser_standard_options.c:522
 #, fuzzy
 msgid "Layer number or name ('-1' for all layers)"
-msgstr "O campo número <%d> ou o nome <%s> já existem"
+msgstr "O campo número <%d> ou o nome <%s> já existem"
 #: ../lib/gis/parser_standard_options.c:524
 #, fuzzy
@@ -3596,7 +3596,7 @@
 "number determines which table to use. When used with direct OGR access this "
 "is the layer name."
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:533
@@ -3627,7 +3627,7 @@
 #: ../lib/gis/parser_standard_options.c:583
 msgid "Name for output file"
-msgstr "Nome do ficheiro de saída"
+msgstr "Nome do ficheiro de saída"
 #: ../lib/gis/parser_standard_options.c:592
 msgid "Field separator"
@@ -3637,8 +3637,8 @@
 #, fuzzy
 msgid "Special characters: pipe, comma, space, tab, newline"
 msgstr ""
-"Caracteres especiais: newline (nova linha), space (espaço), comma (vírgula), "
-"tab (indentação)"
+"Caracteres especiais: newline (nova linha), space (espaço), comma (vírgula), "
+"tab (indentação)"
 #: ../lib/gis/parser_standard_options.c:604
 #: ../lib/gis/parser_standard_options.c:615
@@ -3647,12 +3647,12 @@
 #: ../lib/gis/parser_standard_options.c:606
 msgid "Either a standard color name or R:G:B triplet"
-msgstr "Um nome de cor padrão ou tripla R:G:B"
+msgstr "Um nome de cor padrão ou tripla R:G:B"
 #: ../lib/gis/parser_standard_options.c:617
 #, fuzzy
 msgid "Either a standard color name, R:G:B triplet, or \"none\""
-msgstr "Cor padrão do GRASS, tripla R:G:B ou \"none\" (\"nenhum\")"
+msgstr "Cor padrão do GRASS, tripla R:G:B ou \"none\" (\"nenhum\")"
 #: ../lib/gis/parser_standard_options.c:628
 #, fuzzy
@@ -3694,7 +3694,7 @@
 #: ../lib/gis/parser_standard_options.c:690
 #, fuzzy
 msgid "Coordinates"
 #: ../lib/gis/parser_standard_options.c:699
 #, fuzzy
@@ -3718,27 +3718,27 @@
 #: ../lib/gis/parser_standard_options.c:738
 #, fuzzy
 msgid "Name of the input space time datasets"
 #: ../lib/gis/parser_standard_options.c:746
 #, fuzzy
 msgid "Name of the output space time dataset"
 #: ../lib/gis/parser_standard_options.c:754
 #, fuzzy
 msgid "Name of the input space time raster dataset"
 #: ../lib/gis/parser_standard_options.c:763
 #, fuzzy
 msgid "Name of the input space time raster datasets"
 #: ../lib/gis/parser_standard_options.c:771
 #, fuzzy
 msgid "Name of the output space time raster dataset"
 #: ../lib/gis/parser_standard_options.c:779
 #, fuzzy
@@ -3753,7 +3753,7 @@
 #: ../lib/gis/parser_standard_options.c:796
 #, fuzzy
 msgid "Name of the output space time vector dataset"
-msgstr "Nome do mapa vetor de saída"
+msgstr "Nome do mapa vetor de saída"
 #: ../lib/gis/parser_standard_options.c:804
 #, fuzzy
@@ -3768,12 +3768,12 @@
 #: ../lib/gis/parser_standard_options.c:821
 #, fuzzy
 msgid "Name of the output space time raster3d dataset"
-msgstr "Nome do mapa raster3d de saída"
+msgstr "Nome do mapa raster3d de saída"
 #: ../lib/gis/parser_standard_options.c:830
 #, fuzzy
 msgid "Type of the input space time dataset"
 #: ../lib/gis/parser_standard_options.c:838
 #, fuzzy
@@ -3788,19 +3788,19 @@
 #: ../lib/gis/parser_standard_options.c:856
 #, fuzzy
 msgid "Type of the input map"
-msgstr "Impossível fechar mapa de entrada"
+msgstr "Impossível fechar mapa de entrada"
 #: ../lib/gis/parser_standard_options.c:865
 #, fuzzy
 msgid "The temporal type of the space time dataset"
 #: ../lib/gis/parser_standard_options.c:872
 #, fuzzy
 msgid ""
 "WHERE conditions of SQL statement without 'where' keyword used in the "
 "temporal GIS framework"
-msgstr "Cláusula WHERE do comando SQL sem palavra-chave 'where'"
+msgstr "Cláusula WHERE do comando SQL sem palavra-chave 'where'"
 #: ../lib/gis/parser_standard_options.c:873
 msgid "Example: start_time > '2001-01-01 12:30:00'"
@@ -3827,7 +3827,7 @@
 #: ../lib/gis/datum.c:160
 #, c-format
 msgid "unable to open datum table file: %s"
-msgstr "não foi possível abrir o ficheiro com a tabela de datum: %s"
+msgstr "não foi possível abrir o ficheiro com a tabela de datum: %s"
 #: ../lib/gis/datum.c:182
 #, c-format
@@ -3837,7 +3837,7 @@
 #: ../lib/gis/open_misc.c:49
 #, c-format
 msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr "G__open_misc(read): o mapset <%s> não corresponde ao xmapset <%s>"
+msgstr "G__open_misc(read): o mapset <%s> não corresponde ao xmapset <%s>"
 #: ../lib/gis/open_misc.c:74
 #, c-format
@@ -3852,30 +3852,30 @@
 #: ../lib/gis/view.c:176
 #, c-format
 msgid "Unable to open %s for writing"
-msgstr "Não foi possível abrir %s para escrita"
+msgstr "Não foi possível abrir %s para escrita"
 #: ../lib/gis/view.c:262 ../lib/gis/view.c:479
 #, c-format
 msgid "Unable to open %s for reading"
-msgstr "Não foi possível abrir %s para leitura"
+msgstr "Não foi possível abrir %s para leitura"
 #: ../lib/gis/view.c:465
 #, c-format
 msgid "GRASS window when view was saved:\n"
-msgstr "Janela do GRASS quando a visão foi guardada:\n"
+msgstr "Janela do GRASS quando a visão foi guardada:\n"
 #: ../lib/gis/view.c:545
 #, c-format
 msgid " Window saved in \"%s\" is completely outside of current GRASS window."
 msgstr ""
-" Janela gravada em \"%s\" está completamente fora da janela atual do GRASS."
+" Janela gravada em \"%s\" está completamente fora da janela atual do GRASS."
 #: ../lib/gis/view.c:549
 #, c-format
 msgid ""
 " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
 msgstr ""
-" Apenas %d%% da janela salva em \"%s\" sobrepõe com a janela atual do GRASS."
+" Apenas %d%% da janela salva em \"%s\" sobrepõe com a janela atual do GRASS."
 #: ../lib/vector/neta/bridge.c:58 ../lib/vector/neta/components.c:71
 #: ../lib/vector/neta/components.c:176 ../lib/vector/neta/centrality.c:63
@@ -3896,18 +3896,18 @@
 #: ../lib/rst/interp_float/segmen2d.c:211
 #: ../lib/rst/interp_float/segmen2d.c:221
 msgid "Out of memory"
-msgstr "Sem memória"
+msgstr "Sem memória"
 #: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
 #: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
 #, c-format
 msgid "Unable to open select cursor: %s"
-msgstr "Não foi possível abrir o cursor de seleção: %s"
+msgstr "Não foi possível abrir o cursor de seleção: %s"
 #: ../lib/vector/neta/utils.c:200
 #, fuzzy, c-format
 msgid "Point %d is not connected!"
-msgstr "Matrizes não são permitidas"
+msgstr "Matrizes não são permitidas"
 #: ../lib/vector/neta/utils.c:235
 #, c-format
@@ -3918,11 +3918,11 @@
 #, fuzzy
 msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
 msgstr ""
-"os parâmetros 'where' and 'cats' foram fornecidos, cat vai ser ignorado"
+"os parâmetros 'where' and 'cats' foram fornecidos, cat vai ser ignorado"
 #: ../lib/vector/neta/utils.c:247
 msgid "Unable to load data from database"
-msgstr "Não foi possível carregar os dados da base de dados"
+msgstr "Não foi possível carregar os dados da base de dados"
 #: ../lib/vector/neta/utils.c:254
 #, fuzzy
@@ -3937,17 +3937,17 @@
 #: ../lib/vector/neta/spanningtree.c:106
 #, fuzzy
 msgid "Computing minimum spanning tree..."
-msgstr "A calcular a árvore de menores distâncias..."
+msgstr "A calcular a árvore de menores distâncias..."
 #: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
 #, c-format
 msgid "Unable to calculate centroid for area %d"
-msgstr "Não foi possível calcular centróide para a área %d"
+msgstr "Não foi possível calcular centróide para a área %d"
 #: ../lib/vector/Vlib/build_sfa.c:305
 #, fuzzy, c-format
 msgid "Feature type %d not supported"
 #: ../lib/vector/Vlib/build_sfa.c:339 ../lib/vector/Vlib/build_sfa.c:629
 #: ../lib/vector/Vlib/build_nat.c:74
@@ -3958,7 +3958,7 @@
 #: ../lib/vector/Vlib/read_pg.c:378
 #, fuzzy, c-format
 msgid "Feature %d without geometry skipped"
-msgstr "Feição %d sem geometria ignorada"
+msgstr "Feição %d sem geometria ignorada"
 #: ../lib/vector/Vlib/build_sfa.c:385 ../lib/vector/Vlib/build_sfa.c:661
 #: ../lib/vector/Vlib/build_nat.c:117
@@ -3973,21 +3973,21 @@
 #, fuzzy, c-format
 msgid "One vertex registered"
 msgid_plural "%d vertices registered"
-msgstr[0] "%d vértices registados"
-msgstr[1] "%d vértices registados"
+msgstr[0] "%d vértices registados"
+msgstr[1] "%d vértices registados"
 #: ../lib/vector/Vlib/build_sfa.c:603 ../lib/vector/Vlib/read_ogr.c:344
 #: ../lib/vector/Vlib/read_ogr.c:578
 #, c-format
 msgid "OGR feature type %d not supported"
-msgstr "elemento %d do tipo OGR não suportado"
+msgstr "elemento %d do tipo OGR não suportado"
 #: ../lib/vector/Vlib/build_sfa.c:665
 #, fuzzy, c-format
 msgid "One feature without geometry skipped"
 msgid_plural "%d features without geometry skipped"
-msgstr[0] "Feição %d sem geometria ignorada"
-msgstr[1] "Feição %d sem geometria ignorada"
+msgstr[0] "Feição %d sem geometria ignorada"
+msgstr[1] "Feição %d sem geometria ignorada"
 #: ../lib/vector/Vlib/build_sfa.c:711 ../lib/vector/Vlib/header_finfo.c:41
 #: ../lib/vector/Vlib/header_finfo.c:80 ../lib/vector/Vlib/header_finfo.c:113
@@ -4026,7 +4026,7 @@
 #: ../lib/vector/Vlib/build_sfa.c:722
 #, fuzzy, c-format
 msgid "%s: Native format unsupported"
-msgstr "Tipo da coluna não suportado"
+msgstr "Tipo da coluna não suportado"
 #: ../lib/vector/Vlib/build_sfa.c:748
 msgid "Feature index is built only for non-native formats. Nothing to dump."
@@ -4052,7 +4052,7 @@
 #: ../lib/vector/Vlib/net_analyze.c:449
 msgid "Wrong line direction in Vect_net_get_line_cost()"
-msgstr "Direção errada da linha em Vect_net_get_line_cost()"
+msgstr "Direção errada da linha em Vect_net_get_line_cost()"
 #: ../lib/vector/Vlib/overlay.c:72
 msgid "unknown operator"
@@ -4060,40 +4060,40 @@
 #: ../lib/vector/Vlib/overlay.c:124
 msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr "Sobreposição: tipo de linha/fronteira não suportado pelo operador AND"
+msgstr "Sobreposição: tipo de linha/fronteira não suportado pelo operador AND"
 #: ../lib/vector/Vlib/overlay.c:127
 msgid "Overlay: area x area types not supported by AND operator"
-msgstr "Sobreposição: tipo área x área não suportado pelo operador AND"
+msgstr "Sobreposição: tipo área x área não suportado pelo operador AND"
 #: ../lib/vector/Vlib/poly.c:268
 msgid "Unable to find point in polygon"
-msgstr "Não foi possível encontrar ponto em polígono"
+msgstr "Não foi possível encontrar ponto em polígono"
 #: ../lib/vector/Vlib/poly.c:810
 msgid "conditions failed"
-msgstr "condições falharam"
+msgstr "condições falharam"
 #: ../lib/vector/Vlib/cats.c:45
 msgid "Vect_new_cats_struct(): Out of memory"
-msgstr "Vect_new_cats_struct(): Sem memória"
+msgstr "Vect_new_cats_struct(): Sem memória"
 #: ../lib/vector/Vlib/cats.c:127
 #, c-format
 msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr "Categorias a mais (%d), não foi possível definir cat %d (camada %d)"
+msgstr "Categorias a mais (%d), não foi possível definir cat %d (camada %d)"
 #: ../lib/vector/Vlib/cats.c:419
 #, c-format
 msgid "Unable to convert category string '%s' (from '%s') to category range"
 msgstr ""
-"Não foi possível converter a categoria de texto '%s' (de '%s') para o "
+"Não foi possível converter a categoria de texto '%s' (de '%s') para o "
 "intervalo de categorias"
 #: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
 #, fuzzy
 msgid "Layer number must be > 0 for category constraints"
-msgstr "Número do campo deve ser 1 ou maior."
+msgstr "Número do campo deve ser 1 ou maior."
 #: ../lib/vector/Vlib/cats.c:585
 #, c-format
@@ -4103,19 +4103,19 @@
 #: ../lib/vector/Vlib/cats.c:593
 #, fuzzy, c-format
 msgid "Loading categories from table <%s>..."
-msgstr "Carregando mapa raster <%s> na memória"
+msgstr "Carregando mapa raster <%s> na memória"
 #: ../lib/vector/Vlib/cats.c:603 ../lib/db/dbmi_client/select.c:317
 #, c-format
 msgid "Unable select records from table <%s>"
-msgstr "Não foi possível selecionar registos da tabela <%s>"
+msgstr "Não foi possível selecionar registos da tabela <%s>"
 #: ../lib/vector/Vlib/cats.c:605
 #, fuzzy, c-format
 msgid "One category loaded"
 msgid_plural "%d categories loaded"
-msgstr[0] "sem informação sobre categoria"
-msgstr[1] "sem informação sobre categoria"
+msgstr[0] "sem informação sobre categoria"
+msgstr[1] "sem informação sobre categoria"
 #: ../lib/vector/Vlib/cats.c:627
 #, c-format
@@ -4130,98 +4130,98 @@
 #: ../lib/vector/Vlib/remove_duplicates.c:199
 #, fuzzy, c-format
 msgid "Removed duplicates: %d"
-msgstr "Número de linhas     :   %d\n"
+msgstr "Número de linhas     :   %d\n"
 #: ../lib/vector/Vlib/legal_vname.c:43
 #, c-format
 msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr "Nome ilegal para o mapa vectorial <%s>. Não pode conter '.' ou 'NULL'."
+msgstr "Nome ilegal para o mapa vectorial <%s>. Não pode conter '.' ou 'NULL'."
 #: ../lib/vector/Vlib/legal_vname.c:50
 #, c-format
 msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr "Nome ilegal de mapa vectorial <%s>. Deve começar com uma letra."
+msgstr "Nome ilegal de mapa vectorial <%s>. Deve começar com uma letra."
 #: ../lib/vector/Vlib/legal_vname.c:58
 #, c-format
 msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr "Nome ilegal de mapa vectorial <%s>. Caractere '%c' não permitido."
+msgstr "Nome ilegal de mapa vectorial <%s>. Caractere '%c' não permitido."
 #: ../lib/vector/Vlib/legal_vname.c:65
 #, c-format
 msgid ""
 "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
 msgstr ""
-"Nome ilegal de mapa vectorial <%s>. Palavra-chave SQL não pode ser usada "
+"Nome ilegal de mapa vectorial <%s>. Palavra-chave SQL não pode ser usada "
 "como nome de mapa vectorial."
 #: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
 #, fuzzy, c-format
 msgid "Output vector map name <%s> is not in the current mapset (%s)"
-msgstr "Mapa raster <%s> não está mapset atual (%s)"
+msgstr "Mapa raster <%s> não está mapset atual (%s)"
 #: ../lib/vector/Vlib/legal_vname.c:117 ../lib/vector/Vlib/legal_vname.c:121
 #, fuzzy, c-format
 msgid "Output vector map name <%s> is not SQL compliant"
-msgstr "Nome do mapa não obedece ao SQL"
+msgstr "Nome do mapa não obedece ao SQL"
 #: ../lib/vector/Vlib/legal_vname.c:159 ../lib/vector/Vlib/legal_vname.c:163
 #, c-format
 msgid "Output vector map <%s> is used as input"
-msgstr "Mapa vectorial de saída <%s> usado como entrada"
+msgstr "Mapa vectorial de saída <%s> usado como entrada"
 #: ../lib/vector/Vlib/open.c:59 ../lib/vector/Vlib/rewind.c:29
 #: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/write.c:56
 #: ../lib/vector/Vlib/write.c:62 ../lib/vector/Vlib/build.c:37
 #: ../lib/vector/Vlib/read.c:32
 msgid "Requested format is not compiled in this version"
-msgstr "O formato pedido não foi compilado nesta versão"
+msgstr "O formato pedido não foi compilado nesta versão"
 #: ../lib/vector/Vlib/open.c:138
 #, fuzzy, c-format
 msgid "Programmer requested unknown access level %d"
-msgstr "ATENÇÃO: Programador solicitou open_level desconhecido"
+msgstr "ATENÇÃO: Programador solicitou open_level desconhecido"
 #: ../lib/vector/Vlib/open.c:232
 #, fuzzy, c-format
 msgid "Vector map <%s> not found in current mapset"
 #: ../lib/vector/Vlib/open.c:252
 #, fuzzy
 msgid "Temporary vector maps can be accessed only in the current mapset"
 #: ../lib/vector/Vlib/open.c:277
 msgid ""
 "Vector map which is not in the current mapset cannot be opened for update"
 msgstr ""
-"Um mapa vectorial que não está no mapset atual não pode ser aberto para "
-"atualização"
+"Um mapa vectorial que não está no mapset atual não pode ser aberto para "
+"atualização"
 #: ../lib/vector/Vlib/open.c:311
 #, fuzzy, c-format
 msgid "Unable to read header file of vector map <%s>"
-msgstr "Impossível abrir histórico para mapa vetorial %s"
+msgstr "Impossível abrir histórico para mapa vetorial %s"
 #: ../lib/vector/Vlib/open.c:352
 #, c-format
 msgid "Unable to open topology file for vector map <%s>"
 msgstr ""
-"Não foi possível abrir o ficheiro de topologia relativo ao mapa vectorial <"
+"Não foi possível abrir o ficheiro de topologia relativo ao mapa vectorial <"
 "%s>"
 #: ../lib/vector/Vlib/open.c:367 ../lib/vector/Vlib/open.c:871
 #: ../lib/vector/Vlib/build.c:865
 #, fuzzy, c-format
 msgid "Unable to open spatial index file for vector map <%s>"
-msgstr "Impossível abrir índice de categoria para mapa vetorial <%s>"
+msgstr "Impossível abrir índice de categoria para mapa vetorial <%s>"
 #: ../lib/vector/Vlib/open.c:393 ../lib/vector/Vlib/cindex.c:539
 #, c-format
 msgid "Unable to open category index file for vector map <%s>"
 msgstr ""
-"Não foi possível abrir o ficheiro dos índices relativo ao mapa vectorial <%s>"
+"Não foi possível abrir o ficheiro dos índices relativo ao mapa vectorial <%s>"
 #: ../lib/vector/Vlib/open.c:419
 #, fuzzy, c-format
@@ -4229,7 +4229,7 @@
 "Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
 "with v.build."
 msgstr ""
-"Não foi possível abrir o mapa vectorial <%s> no nível %d. Tente reconstruir "
+"Não foi possível abrir o mapa vectorial <%s> no nível %d. Tente reconstruir "
 "a topologia do vector usando v.build."
 #: ../lib/vector/Vlib/open.c:445
@@ -4240,41 +4240,41 @@
 #: ../lib/vector/Vlib/open.c:453
 #, fuzzy, c-format
 msgid "Unable to open vector map <%s> on level %d"
 #: ../lib/vector/Vlib/open.c:507
 #, c-format
 msgid "Unable to open history file for vector map <%s>"
 msgstr ""
-"Não foi possível abrir o ficheiro do histórico relativo ao mapa vectorial <"
+"Não foi possível abrir o ficheiro do histórico relativo ao mapa vectorial <"
 "%s>"
 #: ../lib/vector/Vlib/open.c:777
 #, fuzzy, c-format
 msgid "Unable to create vector map: <%s> is not in the current mapset (%s)"
 #: ../lib/vector/Vlib/open.c:786
 #, fuzzy, c-format
 msgid "Unable to create vector map: <%s> is not SQL compliant"
 #: ../lib/vector/Vlib/open.c:813 ../lib/vector/Vlib/open.c:826
 #: ../lib/vector/Vlib/map.c:159
 #, c-format
 msgid "Unable to delete vector map <%s>"
-msgstr "Não foi possível apagar o mapa vectorial <%s>"
+msgstr "Não foi possível apagar o mapa vectorial <%s>"
 #: ../lib/vector/Vlib/open.c:821 ../lib/vector/Vlib/map.c:155
 #: ../lib/vector/Vlib/map.c:249
 #, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
-msgstr "O mapa vectorial <%s> já existe e será reescrito"
+msgstr "O mapa vectorial <%s> já existe e será reescrito"
 #: ../lib/vector/Vlib/open.c:846
 #, fuzzy, c-format
 msgid "Unable to open history file of vector map <%s>"
 #: ../lib/vector/Vlib/open.c:887
 #, c-format
@@ -4292,12 +4292,12 @@
 #: ../lib/vector/Vlib/open.c:896
 #, fuzzy
 msgid "Using native format"
 #: ../lib/vector/Vlib/open.c:985
 #, c-format
 msgid "Unable to stat file <%s>"
-msgstr "Não foi possível iniciar o ficheiro <%s>"
+msgstr "Não foi possível iniciar o ficheiro <%s>"
 #: ../lib/vector/Vlib/open.c:1049
 #, c-format
@@ -4322,7 +4322,7 @@
 #: ../lib/vector/Vlib/open.c:1317
 #, fuzzy
 msgid "Unable to open OGR file"
-msgstr "Impossível abrir arquivo %s"
+msgstr "Impossível abrir arquivo %s"
 #: ../lib/vector/Vlib/open.c:1343
 msgid "OGR output also detected, using OGR"
@@ -4332,7 +4332,7 @@
 #: ../lib/vector/Vlib/write_pg.c:612 ../lib/vector/Vlib/write_pg.c:880
 #, fuzzy
 msgid "Unable to open PG file"
 #: ../lib/vector/Vlib/read_sfa.c:50 ../lib/vector/Vlib/write_nat.c:182
 #: ../lib/vector/Vlib/write_nat.c:295 ../lib/vector/Vlib/write_nat.c:651
@@ -4343,7 +4343,7 @@
 #: ../lib/vector/Vlib/write_pg.c:396
 #, fuzzy, c-format
 msgid "Attempt to access feature with invalid id (%d)"
-msgstr "Tentativa de remover área morta"
+msgstr "Tentativa de remover área morta"
 #: ../lib/vector/Vlib/read_sfa.c:56 ../lib/vector/Vlib/write_nat.c:301
 #: ../lib/vector/Vlib/write_nat.c:657 ../lib/vector/Vlib/read_pg.c:337
@@ -4352,12 +4352,12 @@
 #: ../lib/vector/Vlib/write_pg.c:2681
 #, fuzzy, c-format
 msgid "Attempt to access dead feature %d"
 #: ../lib/vector/Vlib/read_sfa.c:90
 #, fuzzy, c-format
 msgid "Unable to construct centroid for area %d. Skipped."
-msgstr "não consegui calcular centróide para área %d"
+msgstr "não consegui calcular centróide para área %d"
 #: ../lib/vector/Vlib/read_sfa.c:95
 #, c-format
@@ -4367,7 +4367,7 @@
 #: ../lib/vector/Vlib/read_sfa.c:117 ../lib/vector/Vlib/read_pg.c:192
 #, fuzzy, c-format
 msgid "Unexpected feature type (%d) - should be (%d)"
-msgstr "Tipo(s) de feição"
+msgstr "Tipo(s) de feição"
 #: ../lib/vector/Vlib/read_sfa.c:124 ../lib/vector/Vlib/write_sfa.c:131
 #: ../lib/vector/Vlib/write_sfa.c:173 ../lib/vector/Vlib/write_sfa.c:273
@@ -4377,37 +4377,37 @@
 #: ../lib/vector/Vlib/level_two.c:23
 #, fuzzy, c-format
 msgid "Vector map <%s> is not open at topological level"
-msgstr "Vetor de entrada '%s' não encontrado"
+msgstr "Vetor de entrada '%s' não encontrado"
 #: ../lib/vector/Vlib/level_two.c:284
 #, fuzzy, c-format
 msgid "Invalid node id: %d"
 #: ../lib/vector/Vlib/level_two.c:316
 #, fuzzy, c-format
 msgid "Nodes not available for line %d"
-msgstr "No há ajuda disponível para o comando [%s]\n"
+msgstr "No há ajuda disponível para o comando [%s]\n"
 #: ../lib/vector/Vlib/level_two.c:357
 #, fuzzy, c-format
 msgid "Areas not available for line %d"
 #: ../lib/vector/Vlib/level_two.c:362
 #, fuzzy, c-format
 msgid "Line %d is not a boundary"
 #: ../lib/vector/Vlib/level_two.c:445
 #, fuzzy, c-format
 msgid "Topology info not available for feature %d"
 #: ../lib/vector/Vlib/close.c:91
 #, c-format
 msgid "Unable to create vector map <%s>"
-msgstr "Não foi possível criar o mapa vectorial <%s>"
+msgstr "Não foi possível criar o mapa vectorial <%s>"
 #: ../lib/vector/Vlib/close.c:108
 #, fuzzy
@@ -4417,12 +4417,12 @@
 #: ../lib/vector/Vlib/close.c:141
 #, fuzzy, c-format
 msgid "Unable to open %s file"
 #: ../lib/vector/Vlib/close.c:226
 #, c-format
 msgid "Unable to close vector <%s>"
-msgstr "Não foi possível fechar o vector <%s>"
+msgstr "Não foi possível fechar o vector <%s>"
 #: ../lib/vector/Vlib/close.c:257
 #, c-format
@@ -4432,37 +4432,37 @@
 #: ../lib/vector/Vlib/close.c:289
 #, fuzzy, c-format
 msgid "Link to vector map <%s> created"
 #: ../lib/vector/Vlib/map.c:139 ../lib/vector/Vlib/map.c:245
 msgid "Vector map name is not SQL compliant"
 #: ../lib/vector/Vlib/map.c:143
 #, c-format
 msgid "Unable to find vector map <%s> in <%s>"
-msgstr "Não foi possível encontrar o mapa vectorial <%s> em <%s>"
+msgstr "Não foi possível encontrar o mapa vectorial <%s> em <%s>"
 #: ../lib/vector/Vlib/map.c:179 ../lib/vector/Vlib/map.c:267
 #, c-format
 msgid "Unable to copy vector map <%s> to <%s>"
-msgstr "Não foi possível copiar o mapa vectorial <%s> para <%s>"
+msgstr "Não foi possível copiar o mapa vectorial <%s> para <%s>"
 #: ../lib/vector/Vlib/map.c:317 ../lib/vector/Vlib/close_nat.c:102
 #: ../lib/vector/Vlib/copy.c:738
 #, c-format
 msgid "Unable to copy table <%s>"
-msgstr "Não foi possível copiar a tabela <%s>"
+msgstr "Não foi possível copiar a tabela <%s>"
 #: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:462
 #, c-format
 msgid "Unable to delete table <%s>"
-msgstr "Não foi possível apagar a tabela <%s>"
+msgstr "Não foi possível apagar a tabela <%s>"
 #: ../lib/vector/Vlib/map.c:346
 #, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
-msgstr "Não foi possível criar o índice para a tabela <%s>, chave <%s>"
+msgstr "Não foi possível criar o índice para a tabela <%s>, chave <%s>"
 #: ../lib/vector/Vlib/map.c:402
 #, c-format
@@ -4472,83 +4472,83 @@
 #: ../lib/vector/Vlib/map.c:407
 #, c-format
 msgid "Invalid vector map name <%s>"
-msgstr "Nome de mapa vectorial inválido <%s>"
+msgstr "Nome de mapa vectorial inválido <%s>"
 #: ../lib/vector/Vlib/map.c:417
 #, c-format
 msgid "Unable to open header file for vector map <%s>"
 msgstr ""
-"Não foi possível abrir o ficheiro do cabeçalho para o mapa vectorial <%s>"
+"Não foi possível abrir o ficheiro do cabeçalho para o mapa vectorial <%s>"
 #: ../lib/vector/Vlib/map.c:449
 #, c-format
 msgid "Unable to find table <%s> linked to vector map <%s>"
 msgstr ""
-"Não foi possível encontrar a tabela <%s> relativa ao mapa vectorial <%s>"
+"Não foi possível encontrar a tabela <%s> relativa ao mapa vectorial <%s>"
 #: ../lib/vector/Vlib/map.c:472
 #, c-format
 msgid "Table <%s> linked to vector map <%s> does not exist"
-msgstr "A tabela <%s> relativa ao mapa vectorial <%s> não existe"
+msgstr "A tabela <%s> relativa ao mapa vectorial <%s> não existe"
 #: ../lib/vector/Vlib/map.c:485
 #, c-format
 msgid "Unable to open directory '%s'"
-msgstr "Não foi possível abrir o diretório '%s'"
+msgstr "Não foi possível abrir o diretório '%s'"
 #: ../lib/vector/Vlib/map.c:499
 #, c-format
 msgid "Unable to delete file '%s'"
-msgstr "Não foi possível apagar o ficheiro '%s'"
+msgstr "Não foi possível apagar o ficheiro '%s'"
 #: ../lib/vector/Vlib/map.c:519
 #, c-format
 msgid "Unable to rename directory '%s' to '%s'"
-msgstr "Não foi possível mudar o nome do diretório '%s' para '%s'"
+msgstr "Não foi possível mudar o nome do diretório '%s' para '%s'"
 #: ../lib/vector/Vlib/map.c:528
 #, fuzzy, c-format
 msgid "Unable to remove directory '%s': %s"
-msgstr "Não foi possível remover o diretório '%s'"
+msgstr "Não foi possível remover o diretório '%s'"
 #: ../lib/vector/Vlib/break_lines.c:563
 #, fuzzy, c-format
 msgid "Intersections: %d"
 #: ../lib/vector/Vlib/write_nat.c:398
 #, fuzzy
 msgid "Attempt to access feature with invalid id (%"
 #: ../lib/vector/Vlib/write_nat.c:404
 #, fuzzy, c-format
 msgid "Attempt to access alive feature %d"
 #: ../lib/vector/Vlib/write_nat.c:566 ../lib/vector/Vlib/write_nat.c:602
 #, c-format
 msgid "%s: Area %d does not exist"
-msgstr "%s: Área %d não existe"
+msgstr "%s: Área %d não existe"
 #: ../lib/vector/Vlib/write_nat.c:756
 #, fuzzy, c-format
 msgid "Attempt to access dead area %d"
 #: ../lib/vector/Vlib/close_pg.c:66 ../lib/vector/Vlib/read_pg.c:1405
 #, fuzzy, c-format
 msgid "Unable to close cursor %s"
-msgstr "não consegui abrir [%s]"
+msgstr "não consegui abrir [%s]"
 #: ../lib/vector/Vlib/close_pg.c:139 ../lib/vector/Vlib/close_ogr.c:104
 #, fuzzy, c-format
 msgid "Unable to save feature index file for vector map <%s>"
 #: ../lib/vector/Vlib/level.c:34
 msgid "Map structure was never initialized"
-msgstr "A estrutura do mapa não foi iniciada"
+msgstr "A estrutura do mapa não foi iniciada"
 #: ../lib/vector/Vlib/level.c:36
 msgid "Map structure has been closed"
@@ -4557,12 +4557,12 @@
 #: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
 #, fuzzy, c-format
 msgid "Unable to get feature geometry, fid %ld"
-msgstr "Impossível obter geometria do elemento, FID [%ld]"
+msgstr "Impossível obter geometria do elemento, FID [%ld]"
 #: ../lib/vector/Vlib/read_ogr.c:382 ../lib/vector/Vlib/read_pg.c:482
 #, fuzzy
 msgid "Feature without geometry. Skipped."
 #: ../lib/vector/Vlib/read_ogr.c:390
 msgid "OGR feature without ID"
@@ -4571,22 +4571,22 @@
 #: ../lib/vector/Vlib/read_ogr.c:514
 #, fuzzy, c-format
 msgid "OGR feature type '%s' not supported"
-msgstr "Feição OGR tipo %d não suportada)"
+msgstr "Feição OGR tipo %d não suportada)"
 #: ../lib/vector/Vlib/bridges.c:213
 #, fuzzy, c-format
 msgid "Removed lines: %d"
 #: ../lib/vector/Vlib/bridges.c:214
 #, fuzzy, c-format
 msgid "Removed bridges: %d"
-msgstr "Novos vértices"
+msgstr "Novos vértices"
 #: ../lib/vector/Vlib/open_nat.c:56
 #, fuzzy, c-format
 msgid "Unable to open coor file for vector map <%s>"
 #: ../lib/vector/Vlib/open_nat.c:152
 #, c-format
@@ -4604,7 +4604,7 @@
 #: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
 #: ../lib/vector/Vlib/line.c:250
 msgid "Index out of range in"
-msgstr "Índice fora dos limites em"
+msgstr "Índice fora dos limites em"
 #: ../lib/vector/Vlib/line.c:550
 msgid "Segment outside line, no segment created"
@@ -4613,7 +4613,7 @@
 #: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
 #, fuzzy, c-format
 msgid "Feature %ld without geometry skipped"
 #: ../lib/vector/Vlib/read_pg.c:365
 #, c-format
@@ -4624,7 +4624,7 @@
 #: ../lib/vector/Vlib/read_pg.c:368
 #, fuzzy, c-format
 msgid "Feature %d: unexpected type (%d) - should be %d"
 #: ../lib/vector/Vlib/read_pg.c:575
 msgid "No geometry or topo geometry column defined"
@@ -4659,7 +4659,7 @@
 #: ../lib/vector/Vlib/copy.c:100
 #, fuzzy, c-format
 msgid "Unsupported feature type %d"
 #: ../lib/vector/Vlib/read_pg.c:996 ../lib/vector/Vlib/read_pg.c:1066
 #: ../lib/vector/Vlib/read_pg.c:1137
@@ -4685,26 +4685,26 @@
 msgid ""
 "Execution failed: %s (...)\n"
 "Reason: %s"
 #: ../lib/vector/Vlib/read_pg.c:1546
 #, fuzzy, c-format
 msgid ""
 "Execution failed: %s\n"
 "Reason: %s"
 #: ../lib/vector/Vlib/read_pg.c:1675
 #, fuzzy, c-format
 msgid ""
 "Unable to read features. Reason:\n"
 "%s"
-msgstr "Não foi possível ler id do elemento %d"
+msgstr "Não foi possível ler id do elemento %d"
 #: ../lib/vector/Vlib/open_ogr.c:60
 #, fuzzy
 msgid "OGR datasource not defined"
 #: ../lib/vector/Vlib/open_ogr.c:65 ../lib/vector/Vlib/write_ogr.c:129
 msgid "OGR layer not defined"
@@ -4713,42 +4713,42 @@
 #: ../lib/vector/Vlib/open_ogr.c:77 ../lib/vector/Vlib/field.c:690
 #, c-format
 msgid "Unable to open OGR data source '%s'"
-msgstr "Não foi possível abrir a fonte de dados OGR '%s'"
+msgstr "Não foi possível abrir a fonte de dados OGR '%s'"
 #: ../lib/vector/Vlib/open_ogr.c:97
 #, fuzzy, c-format
 msgid "OGR layer <%s> not found"
 #: ../lib/vector/Vlib/open_ogr.c:145 ../lib/vector/Vlib/open_pg.c:193
 #, fuzzy, c-format
 msgid "Unable to open feature index file for vector map <%s>"
 #: ../lib/vector/Vlib/open_ogr.c:191
 #, fuzzy, c-format
 msgid "Unable to get OGR driver <%s>"
 #: ../lib/vector/Vlib/open_ogr.c:199
 #, fuzzy, c-format
 msgid "Unable to create OGR data source '%s'"
 #: ../lib/vector/Vlib/open_ogr.c:211
 #, fuzzy, c-format
 msgid "OGR layer <%s> already exists and will be overwritten"
-msgstr "O vetor '%s' já existe e será sobrescrito."
+msgstr "O vetor '%s' já existe e será sobrescrito."
 #: ../lib/vector/Vlib/open_ogr.c:215
 #, fuzzy, c-format
 msgid "Unable to delete OGR layer <%s>"
 #: ../lib/vector/Vlib/open_ogr.c:221
 #, fuzzy, c-format
 msgid "OGR layer <%s> already exists in datasource '%s'"
-msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
+msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
 #: ../lib/vector/Vlib/open_ogr.c:279
 #, c-format
@@ -4756,8 +4756,8 @@
 "Feature index format version %d.%d is not supported by this release. Try to "
 "rebuild topology or upgrade GRASS."
 msgstr ""
-"Formato versão %d do índice de elementos. %d não é suportado por esta "
-"edição. Tente reconstruir a topologia ou atualize o GRASS."
+"Formato versão %d do índice de elementos. %d não é suportado por esta "
+"edição. Tente reconstruir a topologia ou atualize o GRASS."
 #: ../lib/vector/Vlib/open_ogr.c:284
 #, c-format
@@ -4765,7 +4765,7 @@
 "Your GRASS version does not fully support feature index format %d.%d of the "
 "vector. Consider to rebuild topology or upgrade GRASS."
 msgstr ""
-"A sua versão do GRASS não suporta na totalidade o formato %d de índice de "
+"A sua versão do GRASS não suporta na totalidade o formato %d de índice de "
 "elementos.%d do vector. Considere reconstruir a topologia ou actualize o "
 "GRASS."
@@ -4782,7 +4782,7 @@
 #: ../lib/vector/Vlib/select.c:116
 #, c-format
 msgid "Unable to delete item %d from spatial index"
-msgstr "Não foi possível apagar o item %d do índice espacial"
+msgstr "Não foi possível apagar o item %d do índice espacial"
 #: ../lib/vector/Vlib/dangles.c:148
 msgid "Changed"
@@ -4799,7 +4799,7 @@
 #: ../lib/vector/Vlib/dangles.c:262
 #, fuzzy, c-format
 msgid "%s lines: %d"
 #: ../lib/vector/Vlib/dangles.c:263
 #, c-format
@@ -4813,33 +4813,33 @@
 #: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
 msgid "Mixed area and other type requested for vector array"
-msgstr "Áreas mistas e de outros tipo pedidas para o conjunto vectorial"
+msgstr "Áreas mistas e de outros tipo pedidas para o conjunto vectorial"
 #: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
 #: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
 msgid "Not enough space in vector array"
-msgstr "Sem espaço no conjunto vectorial"
+msgstr "Sem espaço no conjunto vectorial"
 #: ../lib/vector/Vlib/array.c:292
 #, c-format
 msgid "Unable to select record from table <%s> (key %s, where %s)"
 msgstr ""
-"Não foi possível selecionar o registo da tabela <%s> (chave %s, onde %s)"
+"Não foi possível selecionar o registo da tabela <%s> (chave %s, onde %s)"
 #: ../lib/vector/Vlib/header.c:86
 #, fuzzy, c-format
 msgid "Unable to create header file for vector map <%s>"
 #: ../lib/vector/Vlib/header.c:129
 #, c-format
 msgid "Unable to open header file of vector <%s>"
-msgstr "Não foi possível abrir o ficheiro do cabeçalho do vector <%s>"
+msgstr "Não foi possível abrir o ficheiro do cabeçalho do vector <%s>"
 #: ../lib/vector/Vlib/header.c:137
 #, fuzzy, c-format
 msgid "Corrupted row in head: %s"
-msgstr "Linha corrompida no cabeçalho: %s"
+msgstr "Linha corrompida no cabeçalho: %s"
 #: ../lib/vector/Vlib/header.c:175
 #, fuzzy, c-format
@@ -4849,22 +4849,22 @@
 #: ../lib/vector/Vlib/box.c:264
 #, fuzzy, c-format
 msgid "Unable to determine bbox for feature %d"
 #: ../lib/vector/Vlib/box.c:313 ../lib/vector/Vlib/box.c:359
 #, fuzzy, c-format
 msgid "Attempt to access area with invalid id (%d)"
 #: ../lib/vector/Vlib/box.c:325
 #, fuzzy, c-format
 msgid "Unable to determine bbox for area %d"
-msgstr "Impossível ler arquivo de cabeçalho"
+msgstr "Impossível ler arquivo de cabeçalho"
 #: ../lib/vector/Vlib/box.c:371
 #, fuzzy, c-format
 msgid "Unable to determine bbox for isle %d"
 #: ../lib/vector/Vlib/intersect2.c:1169 ../lib/vector/Vlib/intersect2.c:1175
 #: ../lib/vector/Vlib/intersect2.c:1177 ../lib/vector/Vlib/intersect2.c:1229
@@ -4874,7 +4874,7 @@
 #: ../lib/vector/Vlib/intersect.c:1219 ../lib/vector/Vlib/intersect.c:1228
 #: ../lib/vector/Vlib/intersect.c:1249 ../lib/vector/Vlib/intersect.c:1266
 msgid "Error while adding point to array. Out of memory"
-msgstr "Erro aquando da adição de pontos ao conjunto. Sem memória"
+msgstr "Erro aquando da adição de pontos ao conjunto. Sem memória"
 #: ../lib/vector/Vlib/clean_nodes.c:248
 #, c-format
@@ -4885,45 +4885,45 @@
 #: ../lib/vector/Vlib/write_pg.c:187 ../lib/vector/Vlib/write_pg.c:255
 #, fuzzy
 msgid "Unable to rewrite feature (incompatible feature types)"
-msgstr "não consegui escrever a linha (deslocamento negativo)"
+msgstr "não consegui escrever a linha (deslocamento negativo)"
 #: ../lib/vector/Vlib/write_ogr.c:134 ../lib/vector/Vlib/write_pg.c:326
 #, fuzzy, c-format
 msgid "Invalid offset (%ld)"
 #: ../lib/vector/Vlib/write_ogr.c:140 ../lib/vector/Vlib/write_pg.c:347
 #, fuzzy
 msgid "Unable to delete feature"
 #: ../lib/vector/Vlib/write_ogr.c:192 ../lib/vector/Vlib/ascii.c:404
 #: ../lib/vector/Vlib/write_pg.c:2902 ../lib/db/dbmi_client/db.c:41
 #: ../lib/db/dbmi_client/copy_tab.c:107 ../lib/db/dbmi_client/copy_tab.c:127
 #, c-format
 msgid "Unable to start driver <%s>"
-msgstr "Não foi possível iniciar driver <%s>"
+msgstr "Não foi possível iniciar driver <%s>"
 #: ../lib/vector/Vlib/write_ogr.c:210 ../lib/db/dbmi_client/copy_tab.c:242
 #: ../lib/db/dbmi_client/copy_tab.c:319 ../lib/db/dbmi_client/table.c:110
 #, fuzzy, c-format
 msgid "Unable to open select cursor: '%s'"
-msgstr "Não foi possível abrir o cursor de seleção: '%s'"
+msgstr "Não foi possível abrir o cursor de seleção: '%s'"
 #: ../lib/vector/Vlib/write_ogr.c:239
 #, fuzzy, c-format
 msgid "Creating field <%s> failed"
 #: ../lib/vector/Vlib/write_ogr.c:304 ../lib/vector/Vlib/write_pg.c:1104
 #, fuzzy, c-format
 msgid "Unsupported geometry type (%d)"
 #: ../lib/vector/Vlib/write_ogr.c:326
 #, fuzzy, c-format
 msgid "Unable to create OGR layer <%s> in '%s'"
 #: ../lib/vector/Vlib/write_ogr.c:338 ../lib/vector/Vlib/write_pg.c:1117
 #, c-format
@@ -4965,7 +4965,7 @@
 #: ../lib/vector/Vlib/write_ogr.c:452
 #, fuzzy, c-format
 msgid "Unsupported feature type (%d)"
 #: ../lib/vector/Vlib/write_ogr.c:471
 msgid "Boundary is not closed. Feature skipped."
@@ -4974,38 +4974,38 @@
 #: ../lib/vector/Vlib/write_ogr.c:500
 #, fuzzy
 msgid "Unable to writes feature attributes"
-msgstr "não consegui escrever os links para o banco de dados"
+msgstr "não consegui escrever os links para o banco de dados"
 #: ../lib/vector/Vlib/write_ogr.c:565
 #, fuzzy, c-format
 msgid "Feature without category of layer %d"
 #: ../lib/vector/Vlib/write_ogr.c:579 ../lib/vector/Vlib/write_pg.c:2005
 #, fuzzy, c-format
 msgid "Unable to select attributes for category %d"
 #: ../lib/vector/Vlib/write_ogr.c:585 ../lib/vector/Vlib/write_pg.c:2009
 #: ../lib/db/dbmi_client/copy_tab.c:338
 #, c-format
 msgid "Unable to fetch data from table <%s>"
-msgstr "Não foi retirar dados da tabela <%s>"
+msgstr "Não foi retirar dados da tabela <%s>"
 #: ../lib/vector/Vlib/write_ogr.c:591 ../lib/vector/Vlib/write_pg.c:2014
 #, fuzzy, c-format
 msgid "No database record for category %d, no attributes will be written"
-msgstr "Registro no banco de dados para categoria %d não encontrado"
+msgstr "Registro no banco de dados para categoria %d não encontrado"
 #: ../lib/vector/Vlib/write_ogr.c:624
 #, fuzzy, c-format
 msgid "Unable to create field <%s>"
 #: ../lib/vector/Vlib/write_ogr.c:653 ../lib/vector/Vlib/write_pg.c:2074
 #, fuzzy, c-format
 msgid "Unsupported column type %d"
 #: ../lib/vector/Vlib/break_polygons.c:102
 msgid "Break polygons: Bug in binary tree!"
@@ -5035,58 +5035,58 @@
 #: ../lib/vector/Vlib/write.c:42 ../lib/vector/Vlib/write.c:49
 #: ../lib/vector/Vlib/read.c:25
 msgid "for this format/level not supported"
-msgstr "para este formato/nível não suportado"
+msgstr "para este formato/nível não suportado"
 #: ../lib/vector/Vlib/write.c:194
 #, fuzzy, c-format
 msgid "Unable to write feature in vector map <%s>"
 #: ../lib/vector/Vlib/write.c:234
 #, fuzzy, c-format
 msgid "Unable to rewrite feature/offset %lu in vector map <%s>"
 #: ../lib/vector/Vlib/write.c:266
 #, fuzzy, c-format
 msgid "Unable to delete feature/offset %lu from vector map <%s>"
-msgstr "Não foi possível apagar o elemento %d do mapa vectorial <%s>"
+msgstr "Não foi possível apagar o elemento %d do mapa vectorial <%s>"
 #: ../lib/vector/Vlib/write.c:299
 #, fuzzy
 msgid "Unable to restore feature/offset %"
-msgstr "Não foi possível abrir o elemento %d"
+msgstr "Não foi possível abrir o elemento %d"
 #: ../lib/vector/Vlib/write.c:308
 #, fuzzy, c-format
 msgid "Vector map <%s> is not opened"
 #: ../lib/vector/Vlib/write.c:313
 #, fuzzy, c-format
 msgid "Vector map <%s> is not opened in write mode"
 #: ../lib/vector/Vlib/build.c:115
 #, fuzzy
 msgid "Area of size = 0.0 (less than 4 vertices) ignored"
-msgstr "Tamanho de área = 0.0 ignorado"
+msgstr "Tamanho de área = 0.0 ignorado"
 #: ../lib/vector/Vlib/build.c:131
 msgid "Unable to add area (map closed, topo saved)"
-msgstr "Não foi possível adicionar área (mapa fechado, topo guardada)"
+msgstr "Não foi possível adicionar área (mapa fechado, topo guardada)"
 #: ../lib/vector/Vlib/build.c:139
 msgid "Unable to add isle (map closed, topo saved)"
-msgstr "Não foi possível adicionar ilha (mapa fechado, topo guardada)"
+msgstr "Não foi possível adicionar ilha (mapa fechado, topo guardada)"
 #: ../lib/vector/Vlib/build.c:149
 msgid "Area of size = 0.0 ignored"
-msgstr "Área do tamanho = 0.0 ignorada"
+msgstr "Área do tamanho = 0.0 ignorada"
 #: ../lib/vector/Vlib/build.c:200
 msgid "Request to find area outside nonexistent isle"
-msgstr "Pedido para encontrar área fora da ilha inexistente"
+msgstr "Pedido para encontrar área fora da ilha inexistente"
 #: ../lib/vector/Vlib/build.c:351
 msgid "Larger bbox but smaller area!!!"
@@ -5099,27 +5099,27 @@
 #: ../lib/vector/Vlib/build.c:641
 #, fuzzy, c-format
 msgid "Number of lines of length zero: %d"
 #: ../lib/vector/Vlib/build.c:643
 #, fuzzy, c-format
 msgid "Number of boundaries of length zero: %d"
-msgstr "Número de fronteiras:   %d\n"
+msgstr "Número de fronteiras:   %d\n"
 #: ../lib/vector/Vlib/build.c:652
 #, fuzzy, c-format
 msgid "Number of boundary intersections: %d"
 #: ../lib/vector/Vlib/build.c:676
 #, fuzzy
 msgid "Skipping further checks because of incorrect boundaries"
-msgstr "Número de fronteiras incorretas   :   %d\n"
+msgstr "Número de fronteiras incorretas   :   %d\n"
 #: ../lib/vector/Vlib/build.c:726
 #, fuzzy, c-format
 msgid "Number of redundant holes: %d"
 #: ../lib/vector/Vlib/build.c:871
 #, c-format
@@ -5133,90 +5133,90 @@
 #: ../lib/vector/Vlib/build.c:900
 #, c-format
 msgid "Number of nodes: %d"
-msgstr "Número de nós: %d"
+msgstr "Número de nós: %d"
 #: ../lib/vector/Vlib/build.c:901
 #, c-format
 msgid "Number of primitives: %d"
-msgstr "Número de primitivos: %d"
+msgstr "Número de primitivos: %d"
 #: ../lib/vector/Vlib/build.c:902
 #, c-format
 msgid "Number of points: %d"
-msgstr "Número de pontos: %d"
+msgstr "Número de pontos: %d"
 #: ../lib/vector/Vlib/build.c:903
 #, c-format
 msgid "Number of lines: %d"
-msgstr "Número de linhas: %d"
+msgstr "Número de linhas: %d"
 #: ../lib/vector/Vlib/build.c:904
 #, c-format
 msgid "Number of boundaries: %d"
-msgstr "Número de fronteiras: %d"
+msgstr "Número de fronteiras: %d"
 #: ../lib/vector/Vlib/build.c:905
 #, c-format
 msgid "Number of centroids: %d"
-msgstr "Número de centróides: %d"
+msgstr "Número de centróides: %d"
 #: ../lib/vector/Vlib/build.c:908
 #, c-format
 msgid "Number of faces: %d"
-msgstr "Número de faces: %d"
+msgstr "Número de faces: %d"
 #: ../lib/vector/Vlib/build.c:911
 #, c-format
 msgid "Number of kernels: %d"
-msgstr "Número de núcleos: %d"
+msgstr "Número de núcleos: %d"
 #: ../lib/vector/Vlib/build.c:957
 #, c-format
 msgid "Number of areas: %d"
-msgstr "Número de áreas: %d"
+msgstr "Número de áreas: %d"
 #: ../lib/vector/Vlib/build.c:958
 #, c-format
 msgid "Number of isles: %d"
-msgstr "Número de ilhas: %d"
+msgstr "Número de ilhas: %d"
 #: ../lib/vector/Vlib/build.c:963
 #, c-format
 msgid "Number of areas without centroid: %d"
-msgstr "Número de áreas sem centróide: %d"
+msgstr "Número de áreas sem centróide: %d"
 #: ../lib/vector/Vlib/build.c:968
 #, fuzzy, c-format
 msgid "Number of centroids exceeds number of areas: %d > %d"
-msgstr "Número de centróides fora da área :   %d\n"
+msgstr "Número de centróides fora da área :   %d\n"
 #: ../lib/vector/Vlib/build.c:972
 #, c-format
 msgid "Number of incorrect boundaries: %d"
-msgstr "Número de fronteiras incorretas: %d"
+msgstr "Número de fronteiras incorretas: %d"
 #: ../lib/vector/Vlib/build.c:976
 #, c-format
 msgid "Number of centroids outside area: %d"
-msgstr "Número de centróides fora da área: %d"
+msgstr "Número de centróides fora da área: %d"
 #: ../lib/vector/Vlib/build.c:980
 #, c-format
 msgid "Number of duplicate centroids: %d"
-msgstr "Número de centróides duplicados: %d"
+msgstr "Número de centróides duplicados: %d"
 #: ../lib/vector/Vlib/build.c:984
 msgid "Number of areas: -"
-msgstr "Número de áreas: -"
+msgstr "Número de áreas: -"
 #: ../lib/vector/Vlib/build.c:985
 msgid "Number of isles: -"
-msgstr "Número de ilhas: -"
+msgstr "Número de ilhas: -"
 #: ../lib/vector/Vlib/build.c:1013
 #, fuzzy, c-format
 msgid "Unable to create topo file for vector map <%s>"
-msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
+msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
 #: ../lib/vector/Vlib/build.c:1021
 msgid "Error writing out topo file"
@@ -5227,7 +5227,7 @@
 msgid ""
 "Unable to build spatial index from topology, vector map is not opened at "
 "topology level 2"
-msgstr "não é possível apagar a linha, o mapa '%s' não está aberto no nível 2"
+msgstr "não é possível apagar a linha, o mapa '%s' não está aberto no nível 2"
 #: ../lib/vector/Vlib/build.c:1233
 #, c-format
@@ -5241,48 +5241,48 @@
 #: ../lib/vector/Vlib/build.c:1268
 #, fuzzy, c-format
 msgid "Unable to create spatial index file for vector map <%s>"
 #: ../lib/vector/Vlib/build.c:1277
 msgid "Error writing out spatial index file"
-msgstr "Erro de escrita do ficheiro de índices espaciais"
+msgstr "Erro de escrita do ficheiro de índices espaciais"
 #: ../lib/vector/Vlib/close_nat.c:74
 #, fuzzy, c-format
 msgid "Unable to create '%s': %s"
 #: ../lib/vector/Vlib/close_nat.c:81
 #, fuzzy, c-format
 msgid "Unable to copy '%s': %s"
 #: ../lib/vector/Vlib/close_nat.c:167
 #, fuzzy, c-format
 msgid "Unable to drop table <%s>"
 #: ../lib/vector/Vlib/build_nat.c:84
 msgid "Unable to read vector map"
-msgstr "Não foi possível ler o mapa vectorial"
+msgstr "Não foi possível ler o mapa vectorial"
 #: ../lib/vector/Vlib/build_nat.c:129
 msgid "Building areas..."
-msgstr "A construir áreas..."
+msgstr "A construir áreas..."
 #: ../lib/vector/Vlib/build_nat.c:153
 #, fuzzy, c-format
 msgid "One area built"
 msgid_plural "%d areas built"
-msgstr[0] "%d áreas construídas"
-msgstr[1] "%d áreas construídas"
+msgstr[0] "%d áreas construídas"
+msgstr[1] "%d áreas construídas"
 #: ../lib/vector/Vlib/build_nat.c:154
 #, fuzzy, c-format
 msgid "One isle built"
 msgid_plural "%d isles built"
-msgstr[0] "%d ilhas construídas"
-msgstr[1] "%d ilhas construídas"
+msgstr[0] "%d ilhas construídas"
+msgstr[1] "%d ilhas construídas"
 #: ../lib/vector/Vlib/build_nat.c:163
 msgid "Attaching islands..."
@@ -5290,60 +5290,60 @@
 #: ../lib/vector/Vlib/build_nat.c:180
 msgid "Attaching centroids..."
-msgstr "A anexar centróides..."
+msgstr "A anexar centróides..."
 #: ../lib/vector/Vlib/simple_features.c:225
 #, fuzzy, c-format
 msgid "Unknown Simple Features type (%d)"
-msgstr "Tipo de interpolação desconhecida"
+msgstr "Tipo de interpolação desconhecida"
 #: ../lib/vector/Vlib/simple_features.c:324 ../lib/vector/Vlib/write_pg.c:321
 #: ../lib/vector/Vlib/write_pg.c:811 ../lib/vector/Vlib/write_pg.c:1212
 #: ../lib/vector/Vlib/write_pg.c:1364
 #, fuzzy
 msgid "No connection defined"
-msgstr "Falha na conexão."
+msgstr "Falha na conexão."
 #: ../lib/vector/Vlib/simple_features.c:332
 #, fuzzy
 msgid "Unable to get number of simple features"
 #: ../lib/vector/Vlib/simple_features.c:341
 #, fuzzy, c-format
 msgid "Unable to report simple features for vector map <%s>"
 #: ../lib/vector/Vlib/read.c:93 ../lib/vector/Vlib/read.c:129
 #: ../lib/vector/Vlib/read.c:168
 #, fuzzy
 msgid "Vector map is not open for reading"
 #: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
 #, fuzzy, c-format
 msgid "Unable to read feature %d from vector map <%s>"
 #: ../lib/vector/Vlib/read.c:200
 #, fuzzy
 msgid "Line index is out of range"
-msgstr "Índice de camadas fora dos limites"
+msgstr "Índice de camadas fora dos limites"
 #: ../lib/vector/Vlib/read.c:224
 #, fuzzy
 msgid "Node index is out of range"
-msgstr "Dimensões da matriz além dos limites"
+msgstr "Dimensões da matriz além dos limites"
 #: ../lib/vector/Vlib/read.c:248
 #, fuzzy
 msgid "Area index is out of range"
 #: ../lib/vector/Vlib/read.c:272
 #, fuzzy
 msgid "Isle index is out of range"
 #: ../lib/vector/Vlib/merge_lines.c:240
 #, c-format
@@ -5358,7 +5358,7 @@
 #: ../lib/vector/Vlib/write_sfa.c:117
 #, fuzzy
 msgid "Unable to calculate centroid for area"
 #: ../lib/vector/Vlib/write_sfa.c:219
 msgid "Attempt to delete dead feature"
@@ -5376,25 +5376,25 @@
 #: ../lib/vector/Vlib/snap.c:223 ../lib/vector/Vlib/snap.c:582
 msgid "Snap vertices Pass 1: select points"
-msgstr "Passo 1 de encaixe de vértices: selecionar pontos"
+msgstr "Passo 1 de encaixe de vértices: selecionar pontos"
 #: ../lib/vector/Vlib/snap.c:271 ../lib/vector/Vlib/snap.c:636
 msgid "Snap vertices Pass 2: assign anchor vertices"
-msgstr "Passo 2 de encaixe de vértices: atribuir vértices âncora"
+msgstr "Passo 2 de encaixe de vértices: atribuir vértices âncora"
 #: ../lib/vector/Vlib/snap.c:340 ../lib/vector/Vlib/snap.c:705
 msgid "Snap vertices Pass 3: snap to assigned points"
-msgstr "Passo 3 de encaixe de vértices: snap para os pontos atributos"
+msgstr "Passo 3 de encaixe de vértices: snap para os pontos atributos"
 #: ../lib/vector/Vlib/snap.c:525 ../lib/vector/Vlib/snap.c:887
 #, c-format
 msgid "Snapped vertices: %d"
-msgstr "Vértices encaixados: %d"
+msgstr "Vértices encaixados: %d"
 #: ../lib/vector/Vlib/snap.c:526 ../lib/vector/Vlib/snap.c:888
 #, c-format
 msgid "New vertices: %d"
-msgstr "Novos vértices: %d"
+msgstr "Novos vértices: %d"
 #: ../lib/vector/Vlib/snap.c:915
 #, fuzzy
@@ -5405,24 +5405,24 @@
 #: ../lib/vector/Vlib/write_pg.c:1072
 #, fuzzy
 msgid "Connection string not defined"
 #: ../lib/vector/Vlib/open_pg.c:90 ../lib/vector/Vlib/open_pg.c:237
 #: ../lib/vector/Vlib/write_pg.c:1077 ../lib/vector/Vlib/write_pg.c:1216
 #: ../lib/vector/Vlib/write_pg.c:1368
 #, fuzzy
 msgid "PostGIS feature table not defined"
-msgstr "Ignorando feição OGR sem ID"
+msgstr "Ignorando feição OGR sem ID"
 #: ../lib/vector/Vlib/open_pg.c:109 ../lib/vector/Vlib/open_pg.c:267
 #, fuzzy
 msgid "No feature tables found in database."
 #: ../lib/vector/Vlib/open_pg.c:133
 #, fuzzy, c-format
 msgid "Feature table <%s> not found in 'geometry_columns'"
 #: ../lib/vector/Vlib/open_pg.c:181
 msgid "Topology schema not found."
@@ -5431,17 +5431,17 @@
 #: ../lib/vector/Vlib/open_pg.c:273
 #, fuzzy, c-format
 msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
 #: ../lib/vector/Vlib/open_pg.c:276
 #, fuzzy, c-format
 msgid "Unable to delete PostGIS layer <%s>"
 #: ../lib/vector/Vlib/open_pg.c:282
 #, fuzzy, c-format
 msgid "PostGIS layer <%s.%s> already exists in database '%s'"
 #: ../lib/vector/Vlib/open_pg.c:390
 #, fuzzy
@@ -5451,7 +5451,7 @@
 #: ../lib/vector/Vlib/open_pg.c:462 ../lib/vector/Vlib/open_pg.c:474
 #, fuzzy, c-format
 msgid "Execution failed: %s"
 #: ../lib/vector/Vlib/open_pg.c:476
 #, c-format
@@ -5463,12 +5463,12 @@
 msgid ""
 "Connection to PostgreSQL database failed. Try to set up username/password by "
 "db.login."
 #: ../lib/vector/Vlib/open_pg.c:566
 #, fuzzy
 msgid "Unable to get database name"
-msgstr "não é possível adicionar um link ao banco de dados."
+msgstr "não é possível adicionar um link ao banco de dados."
 #: ../lib/vector/Vlib/open_pg.c:571
 #, c-format
@@ -5478,7 +5478,7 @@
 #: ../lib/vector/Vlib/open_pg.c:580
 #, fuzzy, c-format
 msgid "PostGIS Topology extension not found in the database <%s>"
 #: ../lib/vector/Vlib/open_pg.c:667
 msgid "Empty bounding box"
@@ -5492,12 +5492,12 @@
 #: ../lib/vector/Vlib/open_pg.c:834
 #, fuzzy, c-format
 msgid "Inconsistency in topology: node %d - unexpected feature type %d"
 #: ../lib/vector/Vlib/open_pg.c:1003
 #, fuzzy, c-format
 msgid "Area %d without boundary detected"
-msgstr "Número de áreas sem centróide :   %d\n"
+msgstr "Número de áreas sem centróide :   %d\n"
 #: ../lib/vector/Vlib/open_pg.c:1061
 #, c-format
@@ -5507,14 +5507,14 @@
 #: ../lib/vector/Vlib/open_pg.c:1128
 #, fuzzy
 msgid "Unable to get map bounding box from topology"
 #: ../lib/vector/Vlib/open_pg.c:1135
 #, fuzzy, c-format
 msgid ""
 "Unable to parse map bounding box:\n"
 "%s"
 #: ../lib/vector/Vlib/open_pg.c:1159
 #, c-format
@@ -5552,28 +5552,28 @@
 #: ../lib/vector/Vlib/field.c:91
 msgid "Layer number must be 1 or greater"
-msgstr "Número da camada deve ser 1 ou maior"
+msgstr "Número da camada deve ser 1 ou maior"
 #: ../lib/vector/Vlib/field.c:96
 #, fuzzy
 msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
 msgstr ""
-"não é possível adicionar um link ao banco de dados, o mapa não está aberto "
+"não é possível adicionar um link ao banco de dados, o mapa não está aberto "
 "em modo ESCRITA."
 #: ../lib/vector/Vlib/field.c:103
 #, fuzzy
 msgid "Unable to add attribute link"
 #: ../lib/vector/Vlib/field.c:109
 #, fuzzy
 msgid "Unable to write attribute links"
 #: ../lib/vector/Vlib/field.c:154
 msgid "Unable to write database links"
-msgstr "Não é possível escrever as ligações à base de dados"
+msgstr "Não é possível escrever as ligações à base de dados"
 #: ../lib/vector/Vlib/field.c:178
 msgid "Database connection not defined. Skipping."
@@ -5588,7 +5588,7 @@
 #: ../lib/vector/Vlib/field.c:261
 #, c-format
 msgid "Layer number %d or name <%s> already exists"
-msgstr "A camada número %d ou nome <%s> já existe"
+msgstr "A camada número %d ou nome <%s> já existe"
 #: ../lib/vector/Vlib/field.c:345
 #, c-format
@@ -5597,22 +5597,22 @@
 "driver: %s\n"
 "database: %s"
 msgstr ""
-"Driver padrão / base de dados definida para:\n"
+"Driver padrão / base de dados definida para:\n"
 "driver: %s\n"
 "base de dados: %s"
 #: ../lib/vector/Vlib/field.c:352
 msgid "Default driver is not set"
-msgstr "Driver padrão não foi especificado"
+msgstr "Driver padrão não foi especificado"
 #: ../lib/vector/Vlib/field.c:355
 msgid "Default database is not set"
-msgstr "Base de dados padrão não foi especificada"
+msgstr "Base de dados padrão não foi especificada"
 #: ../lib/vector/Vlib/field.c:428
 #, c-format
 msgid "Requested dblink %d, maximum link number %d"
-msgstr "dblink %d solicitado, %d ligações no máximo"
+msgstr "dblink %d solicitado, %d ligações no máximo"
 #: ../lib/vector/Vlib/field.c:614 ../lib/vector/Vlib/field.c:622
 #, fuzzy, c-format
@@ -5622,11 +5622,11 @@
 #: ../lib/vector/Vlib/field.c:707
 #, fuzzy, c-format
 msgid "Unable to open OGR layer <%s>"
 #: ../lib/vector/Vlib/field.c:734
 msgid "Unable to open OGR DBMI driver"
-msgstr "Não foi possível abrir driver OGR DBMI"
+msgstr "Não foi possível abrir driver OGR DBMI"
 #: ../lib/vector/Vlib/field.c:773
 msgid ""
@@ -5634,7 +5634,7 @@
 "available in OGR DB table"
 msgstr ""
 "Todos os testes FID falharam. FID, 'ogc_fid', 'ogr_fid' e 'gid' "
-"indisponíveis na tabela de base de dados OGR"
+"indisponíveis na tabela de base de dados OGR"
 #: ../lib/vector/Vlib/field.c:840
 #, c-format
@@ -5654,21 +5654,21 @@
 #: ../lib/vector/Vlib/field.c:925
 #, fuzzy, c-format
 msgid "Unable to create database definition file for vector map <%s>"
 #: ../lib/vector/Vlib/field.c:1020
 msgid "Bug: attempt to update map which is not in current mapset"
-msgstr "Bug: tentativa de atualizar mapa que não está no mapset atual"
+msgstr "Bug: tentativa de atualizar mapa que não está no mapset atual"
 #: ../lib/vector/Vlib/ascii.c:84
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad type) [%s]"
-msgstr "não consegui ler arquivo de intervalo para [%s em %s]"
+msgstr "não consegui ler arquivo de intervalo para [%s em %s]"
 #: ../lib/vector/Vlib/ascii.c:123
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (unknown type) [%s]"
 #: ../lib/vector/Vlib/ascii.c:143
 msgid "End of ASCII file reached before end of coordinates"
@@ -5677,12 +5677,12 @@
 #: ../lib/vector/Vlib/ascii.c:155
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad point) [%s]"
 #: ../lib/vector/Vlib/ascii.c:160
 #, fuzzy, c-format
 msgid "Unparsable longitude value: [%s]"
-msgstr "não foi possível abrir o arquivo %s em %s"
+msgstr "não foi possível abrir o arquivo %s em %s"
 #: ../lib/vector/Vlib/ascii.c:165
 #, c-format
@@ -5696,12 +5696,12 @@
 #: ../lib/vector/Vlib/ascii.c:212
 #, fuzzy, c-format
 msgid "Error reading categories: [%s]"
 #: ../lib/vector/Vlib/ascii.c:225
 #, fuzzy
 msgid "Unable to copy points"
 #: ../lib/vector/Vlib/ascii.c:238
 #, c-format
@@ -5724,12 +5724,12 @@
 #: ../lib/db/dbmi_client/column.c:136 ../lib/python/script/db.py:45
 #, c-format, python-format
 msgid "Unable to describe table <%s>"
-msgstr "Não foi possível descrever tabela <%s>"
+msgstr "Não foi possível descrever tabela <%s>"
 #: ../lib/vector/Vlib/ascii.c:465
 #, fuzzy, c-format
 msgid "Column <%s> does not exist"
-msgstr "Coluna <%s> não é constituída por número inteiros"
+msgstr "Coluna <%s> não é constituída por número inteiros"
 #: ../lib/vector/Vlib/ascii.c:467
 msgid "Available columns:"
@@ -5742,12 +5742,12 @@
 #: ../lib/vector/Vlib/ascii.c:505
 #, fuzzy, c-format
 msgid "Unknown type of column <%s>, export cancelled"
-msgstr "não consegui ler"
+msgstr "não consegui ler"
 #: ../lib/vector/Vlib/ascii.c:539
 #, fuzzy, c-format
 msgid "Unable to select record from table <%s> (key %s, column %s)"
 #: ../lib/vector/Vlib/ascii.c:661
 #, fuzzy, c-format
@@ -5762,12 +5762,12 @@
 #: ../lib/vector/Vlib/ascii.c:718
 #, fuzzy, c-format
 msgid "Cannot select attributes for cat = %d"
-msgstr "não consegui apagar a linha"
+msgstr "não consegui apagar a linha"
 #: ../lib/vector/Vlib/ascii.c:724
 #, fuzzy
 msgid "Unable to fetch data from table"
 #: ../lib/vector/Vlib/ascii.c:756 ../lib/vector/Vlib/net_build.c:216
 #: ../lib/vector/Vlib/net_build.c:501 ../lib/vector/Vlib/net_build.c:519
@@ -5775,12 +5775,12 @@
 #: ../lib/vector/Vlib/net_build.c:981
 #, c-format
 msgid "Column <%s> not found in table <%s>"
-msgstr "A coluna <%s> não foi encontrada na tabela <%s>"
+msgstr "A coluna <%s> não foi encontrada na tabela <%s>"
 #: ../lib/vector/Vlib/ascii.c:758
 #, fuzzy, c-format
 msgid "Column <%s>: unsupported data type"
-msgstr "Impossível descrever tabela <%s>"
+msgstr "Impossível descrever tabela <%s>"
 #: ../lib/vector/Vlib/ascii.c:840
 #, fuzzy
@@ -5794,12 +5794,12 @@
 #: ../lib/vector/Vlib/ascii.c:863
 #, fuzzy, c-format
 msgid "Unable to get boundary of area id %d"
 #: ../lib/vector/Vlib/ascii.c:875
 #, fuzzy, c-format
 msgid "Unable to get boundary of isle id %d (area id %d)"
 #: ../lib/vector/Vlib/ascii.c:889
 #, c-format
@@ -5849,7 +5849,7 @@
 #: ../lib/vector/Vlib/build_pg.c:314
 #, fuzzy
 msgid "Updating edges..."
-msgstr "Ajustando custo dos nós ..."
+msgstr "Ajustando custo dos nós ..."
 #: ../lib/vector/Vlib/build_pg.c:323
 msgid "Inconsistency in topology detected. Dead line found."
@@ -5862,37 +5862,37 @@
 #: ../lib/vector/Vlib/build_pg.c:462
 #, fuzzy, c-format
 msgid "Unsupported topo geometry type %d"
 #: ../lib/vector/Vlib/build_pg.c:491
 #, fuzzy, c-format
 msgid "Unable to create <%s.%s>"
 #: ../lib/vector/Vlib/build_pg.c:642
 #, fuzzy
 msgid "Unable to write nodes, offset array mismatch"
-msgstr "Não foi possível escrever ficheiro de nós em diante"
+msgstr "Não foi possível escrever ficheiro de nós em diante"
 #: ../lib/vector/Vlib/build_pg.c:671
 #, fuzzy
 msgid "Unable to write nodes"
 #: ../lib/vector/Vlib/build_pg.c:716
 #, fuzzy, c-format
 msgid "Inconsistency in topology: number of boundaries %d (should be %d)"
 #: ../lib/vector/Vlib/build_pg.c:739
 #, fuzzy
 msgid "Unable to write lines"
 #: ../lib/vector/Vlib/build_pg.c:790
 #, fuzzy, c-format
 msgid "Topology for centroid %d not available. Area %d skipped"
 #: ../lib/vector/Vlib/build_pg.c:1000
 msgid "Create simple features topology from topogeometry data..."
@@ -5907,12 +5907,12 @@
 #: ../lib/vector/Vlib/write_pg.c:285
 #, c-format
 msgid "Unable to rewrite feature %d"
 #: ../lib/vector/Vlib/write_pg.c:452
 #, fuzzy, c-format
 msgid "Unable to delete feature (%s) %d"
 #: ../lib/vector/Vlib/write_pg.c:773
 #, fuzzy, c-format
@@ -5937,22 +5937,22 @@
 #: ../lib/vector/Vlib/write_pg.c:1129
 #, fuzzy
 msgid "Unable to create new PostGIS feature table"
 #: ../lib/vector/Vlib/write_pg.c:1143
 #, fuzzy
 msgid "Unable to create new PostGIS topology schema"
-msgstr "Impossível criar novo processo"
+msgstr "Impossível criar novo processo"
 #: ../lib/vector/Vlib/write_pg.c:1250
 #, fuzzy, c-format
 msgid "Point skipped (output feature type: %s)"
 #: ../lib/vector/Vlib/write_pg.c:1257
 #, fuzzy, c-format
 msgid "Line skipped (output feature type: %s)"
 #: ../lib/vector/Vlib/write_pg.c:1264
 #, c-format
@@ -5962,17 +5962,17 @@
 #: ../lib/vector/Vlib/write_pg.c:1272
 #, fuzzy, c-format
 msgid "Face skipped (output feature type: %s)"
 #: ../lib/vector/Vlib/write_pg.c:1358
 #, fuzzy, c-format
 msgid "Invalid feature type (%d) for nodes"
-msgstr "Impossível mudar de diretório para %s"
+msgstr "Impossível mudar de diretório para %s"
 #: ../lib/vector/Vlib/write_pg.c:1372
 #, fuzzy
 msgid "PostGIS topology schema not defined"
 #: ../lib/vector/Vlib/write_pg.c:1872
 msgid "Trying to insert 3D data into feature table which store 2D data only"
@@ -5985,7 +5985,7 @@
 #: ../lib/vector/Vlib/write_pg.c:1902
 #, fuzzy
 msgid "Unable to insert topological element into PostGIS Topology schema"
 #: ../lib/vector/Vlib/write_pg.c:2040
 #, c-format
@@ -5999,27 +5999,27 @@
 #: ../lib/vector/Vlib/write_pg.c:2173
 #, fuzzy, c-format
 msgid "Invalid feature %d (max: %d)"
 #: ../lib/vector/Vlib/write_pg.c:2187
 #, fuzzy, c-format
 msgid "Invalid feature type (%d) for node"
 #: ../lib/vector/Vlib/write_pg.c:2191
 #, fuzzy, c-format
 msgid "Invalid node %d (%d)"
 #: ../lib/vector/Vlib/write_pg.c:2269
 #, fuzzy, c-format
 msgid "Unable to determine next left/right edge for edge %d"
 #: ../lib/vector/Vlib/write_pg.c:2274
 #, fuzzy
 msgid "Unable to insert new edge. Topology not available."
-msgstr "Impossível ler topologia para ilhas"
+msgstr "Impossível ler topologia para ilhas"
 #: ../lib/vector/Vlib/write_pg.c:2373 ../lib/vector/Vlib/write_pg.c:2380
 #, fuzzy
@@ -6029,37 +6029,37 @@
 #: ../lib/vector/Vlib/write_pg.c:2579 ../lib/vector/Vlib/write_pg.c:2676
 #, fuzzy, c-format
 msgid "Attempt to access non-existing feature %d"
 #: ../lib/vector/Vlib/write_pg.c:2610
 #, fuzzy
 msgid "Unable to determine next left/right edge"
 #: ../lib/vector/Vlib/write_pg.c:2696
 #, fuzzy
 msgid "Unable to create new face"
 #: ../lib/vector/Vlib/write_pg.c:2834 ../lib/vector/Vlib/write_pg.c:2846
 #, fuzzy, c-format
 msgid "Unable to delete node %d"
 #: ../lib/vector/Vlib/copy.c:81
 #, fuzzy, c-format
 msgid "Unable to copy features. Input vector map <%s> is not open"
-msgstr "não consegui escrever a linha, o mapa não foi aberto"
+msgstr "não consegui escrever a linha, o mapa não foi aberto"
 #: ../lib/vector/Vlib/copy.c:104
 #, fuzzy, c-format
 msgid "Unable to create PostGIS layer <%s>"
 #: ../lib/vector/Vlib/copy.c:133
 #, fuzzy, c-format
 msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
 #: ../lib/vector/Vlib/copy.c:229 ../lib/vector/Vlib/copy.c:234
 #, fuzzy
@@ -6078,17 +6078,17 @@
 #: ../lib/vector/Vlib/copy.c:340
 #, fuzzy, c-format
 msgid "%d features without category or from different layer skipped"
 #: ../lib/vector/Vlib/copy.c:372
 #, fuzzy
 msgid "Exporting nodes..."
 #: ../lib/vector/Vlib/copy.c:400
 #, fuzzy, c-format
 msgid "Writing node %d failed"
 #: ../lib/vector/Vlib/copy.c:478
 #, fuzzy
@@ -6103,43 +6103,43 @@
 #: ../lib/vector/Vlib/copy.c:534 ../lib/vector/Vlib/copy.c:542
 #, fuzzy, c-format
 msgid "Writing area %d failed"
 #: ../lib/vector/Vlib/copy.c:550
 #, fuzzy, c-format
 msgid "%d areas without category or from different layer skipped"
 #: ../lib/vector/Vlib/copy.c:604
 #, fuzzy, c-format
 msgid "Unable to copy table <%s> for layer %d from <%s> to <%s>"
 #: ../lib/vector/Vlib/copy.c:723
 #, c-format
 msgid "Unable to add database link for vector map <%s>"
 msgstr ""
-"Não foi possível adicionar a ligação da base de dados relativa ao mapa "
+"Não foi possível adicionar a ligação da base de dados relativa ao mapa "
 "vectorial <%s>"
 #: ../lib/vector/Vlib/copy.c:747
 #, fuzzy, c-format
 msgid "Unable to open database <%s> with driver <%s>"
-msgstr "Não foi possível abrir a base de dados <%s> com o driver <%s>"
+msgstr "Não foi possível abrir a base de dados <%s> com o driver <%s>"
 #: ../lib/vector/Vlib/copy.c:754
 #, fuzzy
 msgid "Unable to create index"
 #: ../lib/vector/Vlib/copy.c:760
 #, fuzzy, c-format
 msgid "Unable to grant privileges on table <%s>"
-msgstr "Não foi possível criar a tabela <%s>"
+msgstr "Não foi possível criar a tabela <%s>"
 #: ../lib/vector/Vlib/graph.c:138
 msgid "Unable to add network arc"
-msgstr "Não foi possível adicionar arco à rede"
+msgstr "Não foi possível adicionar arco à rede"
 #: ../lib/vector/Vlib/build_ogr.c:71
 msgid "Empty OGR layer, nothing to build"
@@ -6153,11 +6153,11 @@
 #: ../lib/vector/Vlib/build_ogr.c:134
 #, fuzzy, c-format
 msgid "Unable to open fidx file for write <%s>"
-msgstr "Impossível abrir arquivo topo para escrita <%s>"
+msgstr "Impossível abrir arquivo topo para escrita <%s>"
 #: ../lib/vector/Vlib/geos.c:52
 msgid "vector map is not opened"
-msgstr "mapa vectorial não está aberto"
+msgstr "mapa vectorial não está aberto"
 #: ../lib/vector/Vlib/geos.c:55
 #, c-format
@@ -6165,12 +6165,12 @@
 "Vect_read_line_geos(): feature id %d is not reasonable (max features in "
 "vector map <%s>: %d)"
 msgstr ""
-"Vect_read_line_geos(): elemento id %d não é razoável (máx. de elementos no "
+"Vect_read_line_geos(): elemento id %d não é razoável (máx. de elementos no "
 "mapa vectorial <%s>: %d)"
 #: ../lib/vector/Vlib/geos.c:60
 msgid "only native format supported"
-msgstr "só suporta o formato nativo"
+msgstr "só suporta o formato nativo"
 #: ../lib/vector/Vlib/geos.c:65 ../lib/vector/Vlib/geos.c:258
 msgid "Attempt to read dead line"
@@ -6179,54 +6179,54 @@
 #: ../lib/vector/Vlib/geos.c:90
 #, c-format
 msgid "Vect_read_area_geos(): unable to read area id %d"
-msgstr "Vect_read_area_geos(): não foi possível ler a id da área %d"
+msgstr "Vect_read_area_geos(): não foi possível ler a id da área %d"
 #: ../lib/vector/Vlib/geos.c:104
 #, c-format
 msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr "Vect_read_area_geos(): não foi possível ler a id %d da isle %d"
+msgstr "Vect_read_area_geos(): não foi possível ler a id %d da isle %d"
 #: ../lib/vector/Vlib/geos.c:205
 #, c-format
 msgid "Unable to read line offset %ld"
-msgstr "Não foi possível ler o deslocamento da linha %ld"
+msgstr "Não foi possível ler o deslocamento da linha %ld"
 #: ../lib/vector/Vlib/geos.c:412
 #, c-format
 msgid "Attempt to read points of nonexistent area id %d"
-msgstr "Tentativa de ler os pontos da área inexistente com id %d"
+msgstr "Tentativa de ler os pontos da área inexistente com id %d"
 #: ../lib/vector/Vlib/geos.c:472
 #, c-format
 msgid "Unable to read feature id %d"
 #: ../lib/vector/Vlib/cindex.c:32
 msgid "Category index is not up to date"
-msgstr "A categoria índice não está actualizada"
+msgstr "A categoria índice não está actualizada"
 #: ../lib/vector/Vlib/cindex.c:38
 msgid "Layer index out of range"
 #: ../lib/vector/Vlib/cindex.c:268
 #, fuzzy
 msgid "Category index out of range"
 #: ../lib/vector/Vlib/cindex.c:488
 #, fuzzy, c-format
 msgid "Unable to create category index file for vector map <%s>"
 #: ../lib/vector/Vlib/cindex.c:497
 #, fuzzy
 msgid "Error writing out category index file"
-msgstr "Erro de escrita no arquivo de índices espaciais."
+msgstr "Erro de escrita no arquivo de índices espaciais."
 #: ../lib/vector/Vlib/remove_areas.c:107 ../lib/vector/Vlib/remove_areas.c:268
 msgid "Area is composed of dead boundary"
-msgstr "A área é constituída por uma fronteira morta"
+msgstr "A área é constituída por uma fronteira morta"
 #: ../lib/vector/Vlib/remove_areas.c:194 ../lib/vector/Vlib/remove_areas.c:602
 #, c-format
@@ -6236,12 +6236,12 @@
 #: ../lib/vector/Vlib/remove_areas.c:395
 #, fuzzy
 msgid "Could not delete line from coor"
-msgstr "não consegui reescrever a linha"
+msgstr "não consegui reescrever a linha"
 #: ../lib/vector/Vlib/remove_areas.c:458
 #, fuzzy
 msgid "dissolve_neighbour > 0, failed to build new area"
-msgstr "Impossível construir grafo da rede"
+msgstr "Impossível construir grafo da rede"
 #: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:501
 msgid "Dissolve with neighbour area: corrupt topology"
@@ -6250,12 +6250,12 @@
 #: ../lib/vector/Vlib/remove_areas.c:497
 #, fuzzy
 msgid "Failed to build new area"
 #: ../lib/vector/Vlib/remove_areas.c:544 ../lib/vector/Vlib/remove_areas.c:571
 #, fuzzy
 msgid "Failed to build new isle"
 #: ../lib/vector/Vlib/remove_areas.c:549 ../lib/vector/Vlib/remove_areas.c:576
 msgid "Dissolve with outer isle: corrupt topology"
@@ -6264,11 +6264,11 @@
 #: ../lib/vector/Vlib/remove_areas.c:581
 #, fuzzy
 msgid "Area merging failed"
 #: ../lib/vector/Vlib/intersect.c:127
 msgid "3D not supported by Vect_segment_intersection()"
-msgstr "3D não é suportado por Vect_segment_intersection()"
+msgstr "3D não é suportado por Vect_segment_intersection()"
 #: ../lib/vector/Vlib/intersect.c:313
 msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
@@ -6276,16 +6276,16 @@
 #: ../lib/vector/Vlib/intersect.c:407
 msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr "Vect_segment_intersection() ERROR (segmentos não verticais colineares)"
+msgstr "Vect_segment_intersection() ERROR (segmentos não verticais colineares)"
 #: ../lib/vector/Vlib/area.c:50
 msgid "Attempt to read points of nonexistent area"
-msgstr "Tentativa de ler os pontos da área inexistente"
+msgstr "Tentativa de ler os pontos da área inexistente"
 #: ../lib/vector/Vlib/area.c:81
 #, fuzzy
 msgid "Attempt to read points of nonexistent isle"
-msgstr "Tentativa de remover ilha de uma área morta"
+msgstr "Tentativa de remover ilha de uma área morta"
 #: ../lib/vector/Vlib/area.c:121 ../lib/vector/Vlib/area.c:153
 #: ../lib/vector/Vlib/area.c:219 ../lib/vector/Vlib/area.c:248
@@ -6301,7 +6301,7 @@
 #: ../lib/vector/Vlib/buffer2.c:361
 #, fuzzy
 msgid "Line is not looped"
-msgstr "A linha não é fechada"
+msgstr "A linha não é fechada"
 #: ../lib/vector/Vlib/buffer2.c:443
 #, c-format
@@ -6320,15 +6320,15 @@
 #: ../lib/vector/Vlib/buffer2.c:648
 msgid "side != 0 feature not implemented"
-msgstr "side != 0 elemento não implementado"
+msgstr "side != 0 elemento não implementado"
 #: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
 msgid "zero area size"
-msgstr "área de tamanho nulo"
+msgstr "área de tamanho nulo"
 #: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
 msgid "Line was not closed"
-msgstr "A linha não foi fechada"
+msgstr "A linha não foi fechada"
 #: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
 msgid "Vect_get_point_in_poly() failed"
@@ -6340,11 +6340,11 @@
 #: ../lib/vector/Vlib/net_build.c:143 ../lib/vector/Vlib/net_build.c:775
 msgid "Unable to build network graph"
-msgstr "Não foi possível construir grafo da rede"
+msgstr "Não foi possível construir grafo da rede"
 #: ../lib/vector/Vlib/net_build.c:149 ../lib/vector/Vlib/net_build.c:781
 msgid "Forward costs column not specified"
-msgstr "Coluna de custos não especificada"
+msgstr "Coluna de custos não especificada"
 #: ../lib/vector/Vlib/net_build.c:156
 #, fuzzy
@@ -6354,7 +6354,7 @@
 #: ../lib/vector/Vlib/net_build.c:172
 #, fuzzy, c-format
 msgid "Turntable column <%s> not found in table <%s>"
 #: ../lib/vector/Vlib/net_build.c:182 ../lib/vector/Vlib/net_build.c:223
 #: ../lib/vector/Vlib/net_build.c:508 ../lib/vector/Vlib/net_build.c:526
@@ -6362,23 +6362,23 @@
 #: ../lib/vector/Vlib/net_build.c:988
 #, c-format
 msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr "O tipo de dado da coluna <%s> não é suportado (deve ser numérico)"
+msgstr "O tipo de dado da coluna <%s> não é suportado (deve ser numérico)"
 #: ../lib/vector/Vlib/net_build.c:202 ../lib/vector/Vlib/net_build.c:967
 msgid "Setting node costs..."
-msgstr "A definir custo dos nós..."
+msgstr "A definir custo dos nós..."
 #: ../lib/vector/Vlib/net_build.c:277 ../lib/vector/Vlib/net_build.c:1032
 #, c-format
 msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
 msgstr ""
-"Registo da base de dados para o nó %d (cat = %d) não encontrado (custo "
+"Registo da base de dados para o nó %d (cat = %d) não encontrado (custo "
 "definido como 0)"
 #: ../lib/vector/Vlib/net_build.c:332 ../lib/vector/Vlib/net_build.c:352
 #, fuzzy
 msgid "Cannot add network arc for virtual node connection."
 #: ../lib/vector/Vlib/net_build.c:364
 #, c-format
@@ -6414,13 +6414,13 @@
 msgid ""
 "Database record for turn with cat = %d in not found. (The turn was skipped."
 msgstr ""
 "definido como 0)"
 #: ../lib/vector/Vlib/net_build.c:465
 #, fuzzy
 msgid "Cannot add network arc representing turn."
 #: ../lib/vector/Vlib/net_build.c:487 ../lib/vector/Vlib/net_build.c:788
 msgid "Arc field < 1"
@@ -6445,7 +6445,7 @@
 "(cost was set to 0)"
 msgstr ""
 "Registo da base de dados para a linha %d (cat = %d, em frente/ambas as "
-"direções) não encontrada (em frente/ambas as direções da linha ignoradas)"
+"direções) não encontrada (em frente/ambas as direções da linha ignoradas)"
 #: ../lib/vector/Vlib/net_build.c:596
 #, fuzzy, c-format
@@ -6453,8 +6453,8 @@
 "Database record for line %d (cat = %d, backword direction) not found(cost "
 "was set to 0)"
 msgstr ""
-"Registo da base de dados para a linha %d(cat = %d, direção reversa) não "
-"encontrada (direção da linha ignorada)"
+"Registo da base de dados para a linha %d(cat = %d, direção reversa) não "
+"encontrada (direção da linha ignorada)"
 #: ../lib/vector/Vlib/net_build.c:658 ../lib/vector/Vlib/net_build.c:1064
 msgid "Flattening the graph..."
@@ -6462,7 +6462,7 @@
 #: ../lib/vector/Vlib/net_build.c:667 ../lib/vector/Vlib/net_build.c:1073
 msgid "Graph was built"
-msgstr "Grafo construído"
+msgstr "Grafo construído"
 #: ../lib/vector/Vlib/net_build.c:869
 #, c-format
@@ -6471,7 +6471,7 @@
 "(forward/both direction(s) of line skipped)"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:888
 #, c-format
@@ -6479,12 +6479,12 @@
 "Database record for line %d (cat = %d, backword direction) not "
 "found(direction of line skipped)"
 msgstr ""
 #: ../lib/vector/Vlib/net_build.c:937
 msgid "Cannot add network arc"
 #: ../lib/vector/rtree/test_suite/test_main.c:61
 msgid "Unit tests for the vector rtree library"
@@ -6520,7 +6520,7 @@
 #: ../lib/vector/vedit/cats.c:63
 #, c-format
 msgid "Unable to set category %d for (feature id %d)"
-msgstr "Não foi possível definir a categoria %d para (elemento com id %d)"
+msgstr "Não foi possível definir a categoria %d para (elemento com id %d)"
 #: ../lib/vector/vedit/select.c:231
 msgid "Unknown query tool"
@@ -6529,12 +6529,12 @@
 #: ../lib/vector/vedit/delete.c:40
 #, fuzzy, c-format
 msgid "Attempt to delete dead feature (%d)"
 #: ../lib/vector/vedit/delete.c:72
 #, fuzzy, c-format
 msgid "No area found for centroid %d"
 #: ../lib/vector/vedit/delete.c:76
 #, c-format
@@ -6544,83 +6544,83 @@
 #: ../lib/vector/vedit/delete.c:105
 #, fuzzy, c-format
 msgid "Area %d without centroid"
 #: ../lib/vector/vedit/delete.c:121
 #, fuzzy, c-format
 msgid "Area %d has no boundaries"
-msgstr "Matrizes não são permitidas"
+msgstr "Matrizes não são permitidas"
 #: ../lib/vector/diglib/plus.c:222
 msgid "Unable read topology for nodes"
-msgstr "Não foi possível ler a topologia para os nós"
+msgstr "Não foi possível ler a topologia para os nós"
 #: ../lib/vector/diglib/plus.c:227
 #, c-format
 msgid "Unable to read topology for node %d"
-msgstr "Não foi possível ler topologia para o nó %d"
+msgstr "Não foi possível ler topologia para o nó %d"
 #: ../lib/vector/diglib/plus.c:232
 msgid "Unable read topology for lines"
-msgstr "Não foi possível ler a topologia para as linhas"
+msgstr "Não foi possível ler a topologia para as linhas"
 #: ../lib/vector/diglib/plus.c:237
 #, c-format
 msgid "Unable to read topology for line %d"
-msgstr "Não foi possível ler topologia para a linha %d"
+msgstr "Não foi possível ler topologia para a linha %d"
 #: ../lib/vector/diglib/plus.c:242
 msgid "Unable to read topo for areas"
-msgstr "Não foi possível ler topologia para áreas"
+msgstr "Não foi possível ler topologia para áreas"
 #: ../lib/vector/diglib/plus.c:247
 #, c-format
 msgid "Unable read topology for area %d"
-msgstr "Não foi possível ler topologia para área %d"
+msgstr "Não foi possível ler topologia para área %d"
 #: ../lib/vector/diglib/plus.c:252
 msgid "Unable to read topology for isles"
-msgstr "Não foi possível ler topologia para ilhas"
+msgstr "Não foi possível ler topologia para ilhas"
 #: ../lib/vector/diglib/plus.c:257
 #, c-format
 msgid "Unable to read topology for isle %d"
-msgstr "Não foi possível ler topologia para a ilha %d"
+msgstr "Não foi possível ler topologia para a ilha %d"
 #: ../lib/vector/diglib/plus.c:279 ../lib/vector/diglib/plus.c:305
 #, fuzzy
 msgid "Unable to write head to plus file"
-msgstr "Não foi possível escrever ficheiro de cabeçalho em diante"
+msgstr "Não foi possível escrever ficheiro de cabeçalho em diante"
 #: ../lib/vector/diglib/plus.c:284
 #, fuzzy
 msgid "Unable to write nodes to plus file"
 #: ../lib/vector/diglib/plus.c:289
 #, fuzzy
 msgid "Unable to write lines to plus file"
-msgstr "Não foi possível escrever ficheiro de linhas em diante"
+msgstr "Não foi possível escrever ficheiro de linhas em diante"
 #: ../lib/vector/diglib/plus.c:294
 #, fuzzy
 msgid "Unable to write areas to plus file"
-msgstr "Não foi possível escrever ficheiro de áreas em diante"
+msgstr "Não foi possível escrever ficheiro de áreas em diante"
 #: ../lib/vector/diglib/plus.c:299
 #, fuzzy
 msgid "Unable to write isles to plus file"
-msgstr "Não foi possível escrever ficheiro de ilhas em diante"
+msgstr "Não foi possível escrever ficheiro de ilhas em diante"
 #: ../lib/vector/diglib/port_init.c:158
 #, fuzzy, c-format
 msgid "Unable to find '%x' in %s"
-msgstr "não consegui encontrar [%s]"
+msgstr "não consegui encontrar [%s]"
 #: ../lib/vector/diglib/spindex_rw.c:98 ../lib/vector/diglib/spindex_rw.c:106
 #, fuzzy
 msgid "Topology file must be written before spatial index file"
 #: ../lib/vector/diglib/spindex_rw.c:302
 #, c-format
@@ -6663,8 +6663,8 @@
 "Old topology format version %d.%d is not supported by this release. Try to "
 "rebuild topology using v.build or v.build.all module."
 msgstr ""
 #: ../lib/vector/diglib/plus_struct.c:563 ../lib/vector/diglib/portable.c:208
 #: ../lib/vector/diglib/portable.c:241 ../lib/vector/diglib/portable.c:683
@@ -6674,26 +6674,26 @@
 #: ../lib/vector/diglib/spindex.c:450
 #, c-format
 msgid "Unable to delete node %d from spatial index"
-msgstr "Não foi possível apagar o nó %d do índice espacial"
+msgstr "Não foi possível apagar o nó %d do índice espacial"
 #: ../lib/vector/diglib/spindex.c:493
 #, c-format
 msgid "Unable to delete line %d from spatial index"
-msgstr "Não foi possível apagar a linha %d do índice espacial"
+msgstr "Não foi possível apagar a linha %d do índice espacial"
 #: ../lib/vector/diglib/spindex.c:529
 msgid "Attempt to delete sidx for dead area"
-msgstr "Tentativa de remover sidx de uma área morta"
+msgstr "Tentativa de remover sidx de uma área morta"
 #: ../lib/vector/diglib/spindex.c:546
 #, c-format
 msgid "Unable to delete area %d from spatial index"
-msgstr "Não foi possível apagar a área %d do índice espacial"
+msgstr "Não foi possível apagar a área %d do índice espacial"
 #: ../lib/vector/diglib/spindex.c:595
 #, c-format
 msgid "Unable to delete isle %d from spatial index"
-msgstr "Não foi possível apagar a ilha %d do índice espacial"
+msgstr "Não foi possível apagar a ilha %d do índice espacial"
 #: ../lib/vector/diglib/cindex_rw.c:156
 #, c-format
@@ -6705,12 +6705,12 @@
 #: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
 #, fuzzy, c-format
 msgid "Vector format not recognized: %s"
 #: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
 #, fuzzy, c-format
 msgid "Vector format '%s' not supported"
 #: ../lib/vector/diglib/frmt.c:97
 #, c-format
@@ -6719,25 +6719,25 @@
 #: ../lib/vector/diglib/file.c:159
 msgid "Writing to file loaded to memory not supported"
-msgstr "Escrita para ficheiro carregado na memória não suportada"
+msgstr "Escrita para ficheiro carregado na memória não suportada"
 #: ../lib/vector/diglib/file.c:197
 msgid "Unable to load file to memory, file not open"
-msgstr "Não foi possível carregar o ficheiro para a memória, ficheiro não abre"
+msgstr "Não foi possível carregar o ficheiro para a memória, ficheiro não abre"
 #: ../lib/vector/diglib/file.c:212
 msgid "Vector memory mode not supported, using 'AUTO'"
-msgstr "Mode de memória vectorial não suportado, a usar 'AUTO'"
+msgstr "Mode de memória vectorial não suportado, a usar 'AUTO'"
 #: ../lib/vector/diglib/plus_area.c:215 ../lib/vector/diglib/plus_area.c:711
 #, c-format
 msgid "Line %d already has area/isle %d to left"
-msgstr "A linha %d já tem área/ilha %d à esquerda"
+msgstr "A linha %d já tem área/ilha %d à esquerda"
 #: ../lib/vector/diglib/plus_area.c:225 ../lib/vector/diglib/plus_area.c:719
 #, c-format
 msgid "Line %d already has area/isle %d to right"
-msgstr "A linha %d já tem área/ilha %d à direita"
+msgstr "A linha %d já tem área/ilha %d à direita"
 #: ../lib/vector/diglib/plus_area.c:279
 msgid "Isle already registered in area"
@@ -6745,37 +6745,37 @@
 #: ../lib/vector/diglib/plus_area.c:313
 msgid "Attempt to delete isle from dead area"
 #: ../lib/vector/diglib/plus_area.c:330
 #, c-format
 msgid "Attempt to delete not registered isle %d from area %d"
-msgstr "Tentativa de remover ilha não registrada %d da área %d"
+msgstr "Tentativa de remover ilha não registrada %d da área %d"
 #: ../lib/vector/diglib/plus_area.c:369
 msgid "Attempt to delete dead area"
-msgstr "Tentativa de remover área morta"
+msgstr "Tentativa de remover área morta"
 #: ../lib/vector/diglib/plus_area.c:408
 #, c-format
 msgid "Dead centroid %d registered for area (bug in the vector library)"
 msgstr ""
-"Centróide inexistente %d registado para área (erro na biblioteca vectorial)"
+"Centróide inexistente %d registado para área (erro na biblioteca vectorial)"
 #: ../lib/vector/diglib/plus_area.c:431
 #, c-format
 msgid "Attempt to delete area %d info from dead isle %d"
-msgstr "Tentativa de remover informação da área %d da ilha morta %d"
+msgstr "Tentativa de remover informação da área %d da ilha morta %d"
 #: ../lib/vector/diglib/plus_area.c:777
 #, c-format
 msgid "Attempt to delete isle %d info from dead area %d"
-msgstr "Tentativa de remover informação da ilha %d da área morta %d"
+msgstr "Tentativa de remover informação da ilha %d da área morta %d"
 #: ../lib/vector/diglib/test.c:58
 #, fuzzy
 msgid "Unable to open test.tmp file"
-msgstr "Impossível abrir arquivo %s"
+msgstr "Impossível abrir arquivo %s"
 #: ../lib/vector/diglib/test.c:75
 #, c-format
@@ -6825,13 +6825,13 @@
 "Attempt to read line angle for the line which is not connected to the node: "
 "node %d, line %d"
 msgstr ""
-"Tentativa de ler ângulo da linha para uma linha que não está ligada ao nó: "
-"nó %d, linha %d"
+"Tentativa de ler ângulo da linha para uma linha que não está ligada ao nó: "
+"nó %d, linha %d"
 #: ../lib/cairodriver/text.c:46
 #, fuzzy, c-format
 msgid "Unable to convert from <%s> to UTF-8"
-msgstr "não foi possível abrir o mapa raster [%s em %s]"
+msgstr "não foi possível abrir o mapa raster [%s em %s]"
 #: ../lib/cairodriver/text.c:56
 msgid "Some characters could not be converted to UTF-8"
@@ -6840,37 +6840,37 @@
 #: ../lib/cairodriver/write_xid.c:14 ../lib/pngdriver/read_png.c:71
 #, fuzzy, c-format
 msgid "Unable to open output file <%s>"
 #: ../lib/cairodriver/write_xid.c:19
 #, fuzzy, c-format
 msgid "Unable to write output file <%s>"
 #: ../lib/cairodriver/read_xid.c:14
 #, fuzzy, c-format
 msgid "Unable to open input file <%s>"
-msgstr "G_spawn: não consegui abrir o arquivo %s"
+msgstr "G_spawn: não consegui abrir o arquivo %s"
 #: ../lib/cairodriver/read_xid.c:17
 #, fuzzy, c-format
 msgid "Unable to read input file <%s>"
 #: ../lib/cairodriver/read_xid.c:20
 #, fuzzy, c-format
 msgid "Unable to parse input file <%s>"
 #: ../lib/cairodriver/read_bmp.c:88 ../lib/cairodriver/read_ppm.c:28
 #, fuzzy, c-format
 msgid "Cairo: unable to open input file <%s>"
 #: ../lib/cairodriver/read_bmp.c:92 ../lib/cairodriver/read_ppm.c:32
 #, fuzzy, c-format
 msgid "Cairo: invalid input file <%s>"
-msgstr "não consegui encontrar mapa de entrada '%s'"
+msgstr "não consegui encontrar mapa de entrada '%s'"
 #: ../lib/cairodriver/read_bmp.c:96
 #, c-format
@@ -6880,17 +6880,17 @@
 #: ../lib/cairodriver/write_bmp.c:72 ../lib/cairodriver/write_ppm.c:27
 #, fuzzy, c-format
 msgid "Cairo: unable to open output file <%s>"
 #: ../lib/cairodriver/write_ppm.c:34
 #, fuzzy, c-format
 msgid "Cairo: unable to open mask file <%s>"
 #: ../lib/cairodriver/raster.c:109
 #, fuzzy
 msgid "Failed to create cairo surface"
 #: ../lib/cairodriver/read_ppm.c:38
 #, c-format
@@ -6900,12 +6900,12 @@
 #: ../lib/cairodriver/read_ppm.c:46
 #, fuzzy, c-format
 msgid "Cairo: unable to open input mask file <%s>"
 #: ../lib/cairodriver/read_ppm.c:50
 #, fuzzy, c-format
 msgid "Cairo: invalid input mask file <%s>"
 #: ../lib/cairodriver/read_ppm.c:56
 #, c-format
@@ -6916,12 +6916,12 @@
 #: ../lib/cairodriver/graph.c:67
 #, fuzzy
 msgid "Unable to open display"
 #: ../lib/cairodriver/graph.c:85
 #, fuzzy
 msgid "Unable to obtain visual"
 #: ../lib/cairodriver/graph.c:160
 #, c-format
@@ -6941,12 +6941,12 @@
 #: ../lib/cairodriver/graph.c:371
 #, fuzzy
 msgid "Unknown Cairo surface type"
 #: ../lib/cairodriver/graph.c:376
 #, fuzzy
 msgid "Failed to initialize Cairo surface"
 #: ../lib/cairodriver/draw_bitmap.c:47
 msgid "Cairo_Bitmap: Failed to create source"
@@ -6955,23 +6955,23 @@
 #: ../lib/pngdriver/write_png.c:39
 #, fuzzy
 msgid "Unable to write PNG"
 #: ../lib/pngdriver/write_png.c:71 ../lib/pngdriver/write_png.c:75
 #: ../lib/pngdriver/read_png.c:64
 #, fuzzy
 msgid "Unable to allocate PNG structure"
-msgstr "Não foi possível alocar memória"
+msgstr "Não foi possível alocar memória"
 #: ../lib/pngdriver/write_png.c:78
 #, fuzzy
 msgid "Unable to write PNG file"
 #: ../lib/pngdriver/write_png.c:82
 #, fuzzy, c-format
 msgid "Unable to open output PNG file <%s>"
 #: ../lib/pngdriver/graph_set.c:101
 #, c-format
@@ -6991,17 +6991,17 @@
 #: ../lib/pngdriver/read_png.c:42
 #, fuzzy
 msgid "Unable to read PNG"
 #: ../lib/pngdriver/read_png.c:60
 #, fuzzy
 msgid "Unable allocate PNG structure"
 #: ../lib/pngdriver/read_png.c:67
 #, fuzzy
 msgid "Unable to read PNG file"
 #: ../lib/pngdriver/read_png.c:81
 msgid "Input PNG file is not 8-bit"
@@ -7027,12 +7027,12 @@
 #: ../lib/init/grass.py:123
 #, fuzzy
 msgid "WARNING"
-msgstr "ATENÇÃO: "
+msgstr "ATENÇÃO: "
 #: ../lib/init/grass.py:188
 #, fuzzy
 msgid "Exiting..."
 #: ../lib/init/grass.py:332
 #, fuzzy
@@ -7070,7 +7070,7 @@
 #: ../lib/init/grass.py:340 ../lib/init/grass.py:342 ../lib/init/grass.py:344
 #, fuzzy
 msgid "and set as default"
-msgstr "para aceitar os valores padrão"
+msgstr "para aceitar os valores padrão"
 #: ../lib/init/grass.py:341
 msgid "use text based interface (show welcome screen)"
@@ -7101,7 +7101,7 @@
 msgid "initial GRASS Location"
 msgstr ""
 "\n"
-"projeção inválida\n"
+"projeção inválida\n"
 #: ../lib/init/grass.py:351
 msgid ""
@@ -7178,7 +7178,7 @@
 #, fuzzy, python-format
 msgid ""
 "Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
-msgstr "não consegui alocar memória\n"
+msgstr "não consegui alocar memória\n"
 #: ../lib/init/grass.py:493
 #, python-brace-format
@@ -7188,7 +7188,7 @@
 #: ../lib/init/grass.py:547
 msgid "GUI <%s> not supported in this version"
-msgstr "O formato requisitado não foi compilado nesta versão"
+msgstr "O formato requisitado não foi compilado nesta versão"
 #: ../lib/init/grass.py:704
 msgid "Searched for a web browser, but none found"
@@ -7349,7 +7349,7 @@
 #: ../lib/init/grass.py:1295
 #, fuzzy
 msgid "The SHELL variable is not set"
-msgstr "GISRC - variável não incializada"
+msgstr "GISRC - variável não incializada"
 #: ../lib/init/grass.py:1311
@@ -7373,24 +7373,24 @@
 #: ../lib/init/grass.py:1349
 msgid "Executing <%s> ..."
 #: ../lib/init/grass.py:1356
 #, fuzzy, python-brace-format
 msgid ""
 "Execution of <{cmd}> failed:\n"
 "{error}"
 #: ../lib/init/grass.py:1359
 msgid "Execution of <%s> finished."
 #: ../lib/init/grass.py:1390
 #, fuzzy
 msgid "Unable to close GUI. {}"
-msgstr "não consegui abrir [%s]"
+msgstr "não consegui abrir [%s]"
 #: ../lib/init/grass.py:1417
 #, python-format
@@ -7409,7 +7409,7 @@
 #: ../lib/init/grass.py:1443
 #, fuzzy
 msgid "Help is available with the command:"
-msgstr "No há ajuda disponível para o comando [%s]\n"
+msgstr "No há ajuda disponível para o comando [%s]\n"
 #: ../lib/init/grass.py:1444
 msgid "See the licence terms with:"
@@ -7455,7 +7455,7 @@
 #: ../lib/init/grass.py:1589
 #, fuzzy
 msgid "Cleaning up temporary files..."
-msgstr "não consegui abrir arquivo temporário"
+msgstr "não consegui abrir arquivo temporário"
 #: ../lib/init/grass.py:1609
 msgid "Please install the GRASS GIS development package"
@@ -7464,7 +7464,7 @@
 #: ../lib/init/grass.py:1641
 msgid "Parameter <%s> not supported"
-msgstr "Feição OGR tipo %d não suportada)"
+msgstr "Feição OGR tipo %d não suportada)"
 #: ../lib/init/grass.py:1785
 msgid "Flag -e requires also flag -c"
@@ -7509,7 +7509,7 @@
 #: ../lib/init/grass.py:1954
 msgid "Failed to start shell '%s'"
 #: ../lib/init/lock.c:38
 #, c-format
@@ -7523,7 +7523,7 @@
 #: ../lib/init/lock.c:60
 #, fuzzy, c-format
 msgid "Unable to write lockfile %s (%s)"
 #: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
 #: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
@@ -7531,12 +7531,12 @@
 #: ../lib/lidar/raster.c:175
 #, fuzzy, c-format
 msgid "Unable to access table <%s>"
 #: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
 #, fuzzy, c-format
 msgid "<%s> created in database."
 #: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
 #, c-format
@@ -7545,7 +7545,7 @@
 #: ../lib/gpde/n_parse_options.c:106
 msgid "The calculation time in seconds"
-msgstr "Tempo de cálculo em segundos"
+msgstr "Tempo de cálculo em segundos"
 #: ../lib/gpde/n_gwflow.c:436 ../lib/gpde/n_gwflow.c:715
 #, c-format
@@ -7560,11 +7560,11 @@
 #: ../lib/gpde/n_arrays_io.c:93
 #, c-format
 msgid "Reading raster map <%s> into memory"
-msgstr "A carregar mapa raster <%s> para a memória"
+msgstr "A carregar mapa raster <%s> para a memória"
 #: ../lib/gpde/n_arrays_io.c:183
 msgid "N_array_2d * array is empty"
-msgstr "N_array_2d * conjunto é vazio"
+msgstr "N_array_2d * conjunto é vazio"
 #: ../lib/gpde/n_arrays_io.c:202
 #, c-format
@@ -7574,7 +7574,7 @@
 #: ../lib/gpde/n_arrays_io.c:309
 #, c-format
 msgid "Read g3d map <%s> into the memory"
-msgstr "Ler mapa g3d <%s> para a memória"
+msgstr "Ler mapa g3d <%s> para a memória"
 #: ../lib/gpde/n_arrays_io.c:364 ../lib/gpde/n_arrays_io.c:464
 msgid "Error closing g3d file"
@@ -7592,7 +7592,7 @@
 #: ../lib/gpde/test/test_main.c:88
 msgid "Performs unit and integration tests for gpde library"
-msgstr "Executa teste de unidade e de integração para a biblioteca gpde"
+msgstr "Executa teste de unidade e de integração para a biblioteca gpde"
 #: ../lib/db/dbmi_driver/d_error.c:35
 #, c-format
@@ -7610,17 +7610,17 @@
 #: ../lib/db/dbmi_client/select.c:333
 msgid "Key column type is not integer"
-msgstr "A chave do tipo de coluna não é número inteiro"
+msgstr "A chave do tipo de coluna não é número inteiro"
 #: ../lib/db/dbmi_client/delete_tab.c:40 ../lib/db/dbmi_client/table.c:46
 #, c-format
 msgid "Unable open database <%s> by driver <%s>"
 #: ../lib/db/dbmi_client/delete_tab.c:53
 #, c-format
 msgid "Unable to drop table: '%s'"
-msgstr "Não foi apagar a tabela '%s'"
+msgstr "Não foi apagar a tabela '%s'"
 #: ../lib/db/dbmi_client/copy_tab.c:91
 #, c-format
@@ -7630,33 +7630,33 @@
 #: ../lib/db/dbmi_client/copy_tab.c:151
 #, c-format
 msgid "Unable to get list tables in database <%s>"
-msgstr "Não foi possível obter tabelas de lista na base de dados <%s>"
+msgstr "Não foi possível obter tabelas de lista na base de dados <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:189
 #, fuzzy, c-format
 msgid "Table <%s> already exists in database and will be overwritten"
-msgstr "O vetor '%s' já existe e será sobrescrito."
+msgstr "O vetor '%s' já existe e será sobrescrito."
 #: ../lib/db/dbmi_client/copy_tab.c:194
 #, c-format
 msgid "Table <%s> already exists in database <%s>"
-msgstr "Tabela <%s> já existe na base de dados <%s>"
+msgstr "Tabela <%s> já existe na base de dados <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:274
 #, c-format
 msgid "Column <%s> is not integer"
 #: ../lib/db/dbmi_client/copy_tab.c:291 ../lib/rst/interp_float/vinput2d.c:115
 #: ../lib/rst/interp_float/vinput2d.c:129
 #, c-format
 msgid "Column <%s> not found"
-msgstr "Coluna <%s> não encontrada"
+msgstr "Coluna <%s> não encontrada"
 #: ../lib/db/dbmi_client/copy_tab.c:294
 #, c-format
 msgid "Unable to create table <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:394
 #, c-format
@@ -7678,17 +7678,17 @@
 #: ../lib/db/dbmi_base/legal_dbname.c:38
 #, fuzzy, c-format
 msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
-msgstr "Nome de tabela de mapa <%s> ilegal. Não pode conter '.' ou 'NULL'.\n"
+msgstr "Nome de tabela de mapa <%s> ilegal. Não pode conter '.' ou 'NULL'.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:45
 #, fuzzy, c-format
 msgid "Illegal table map name <%s>. Must start with a letter."
-msgstr "Nome de tabela de mapa ilegal <%s>. Deve começar com uma letra.\n"
+msgstr "Nome de tabela de mapa ilegal <%s>. Deve começar com uma letra.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:54
 #, fuzzy, c-format
 msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr "Nome de tabela de mapa <%s> ilegal. Caractere <%c> não permitido.\n"
+msgstr "Nome de tabela de mapa <%s> ilegal. Caractere <%c> não permitido.\n"
 #: ../lib/db/dbmi_base/error.c:72
 msgid "<NULL error message>"
@@ -7701,7 +7701,7 @@
 #: ../lib/db/dbmi_base/error.c:136
 #, fuzzy
 msgid "dbmi: Out of Memory"
-msgstr "G_malloc: memória esgotada"
+msgstr "G_malloc: memória esgotada"
 #: ../lib/db/dbmi_base/error.c:149
 #, c-format
@@ -7728,7 +7728,7 @@
 #: ../lib/db/dbmi_base/test/test_main.c:83
 #, fuzzy
 msgid "Performs unit and integration tests for the dbmi base library"
-msgstr "Executar teste de unidade e de integração para a biblioteca gpde"
+msgstr "Executar teste de unidade e de integração para a biblioteca gpde"
 #: ../lib/db/dbmi_base/test/test_columns.c:37
 #, fuzzy
@@ -7799,7 +7799,7 @@
 #: ../lib/db/dbmi_base/login.c:115
 #, fuzzy, c-format
 msgid "Unable to read file '%s'"
 #: ../lib/db/dbmi_base/login.c:126
 #, fuzzy, c-format
@@ -7809,19 +7809,19 @@
 #: ../lib/db/dbmi_base/login.c:164
 #, fuzzy, c-format
 msgid "Unable to write file '%s'"
-msgstr "Não foi possível apagar o ficheiro '%s'"
+msgstr "Não foi possível apagar o ficheiro '%s'"
 #: ../lib/db/dbmi_base/login.c:229
 #, fuzzy, c-format
 msgid "DB connection <%s/%s> already exists and will be overwritten"
 #: ../lib/db/dbmi_base/login.c:232
 #, fuzzy, c-format
 msgid ""
 "DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to "
 "overwrite existing settings."
 #: ../lib/db/dbmi_base/xdrtable.c:109
 msgid "fetch: table has wrong number of columns"
@@ -7830,24 +7830,24 @@
 #: ../lib/manage/do_remove.c:42
 #, fuzzy, c-format
 msgid "Removing %s <%s>"
 #: ../lib/manage/do_remove.c:65
 #, fuzzy
 msgid "Unable to delete vector map"
 #: ../lib/manage/do_remove.c:85
 #, fuzzy, c-format
 msgid "Unable to remove %s element"
 #: ../lib/manage/do_remove.c:89 ../lib/manage/do_remove.c:109
 #: ../lib/manage/do_copy.c:61 ../lib/manage/do_rename.c:87
 #: ../lib/manage/do_rename.c:107
 #, fuzzy, c-format
 msgid "%s is missing"
-msgstr "que está faltando"
+msgstr "que está faltando"
 #: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
 #, c-format
@@ -7857,7 +7857,7 @@
 #: ../lib/manage/do_remove.c:105
 #, fuzzy, c-format
 msgid "Unable to remove %s"
 #: ../lib/manage/do_remove.c:121
 #, c-format
@@ -7867,12 +7867,12 @@
 #: ../lib/manage/do_copy.c:43
 #, fuzzy, c-format
 msgid "Copy %s <%s> to current mapset as <%s>"
-msgstr "não há arquivos <%s> disponíveis no mapset ativo\n"
+msgstr "não há arquivos <%s> disponíveis no mapset ativo\n"
 #: ../lib/manage/do_copy.c:50 ../lib/manage/do_copy.c:67
 #, fuzzy, c-format
 msgid "Unable to copy <%s> to current mapset as <%s>"
 #: ../lib/manage/do_copy.c:72
 #, c-format
@@ -7884,22 +7884,22 @@
 msgid "%s: invalid index %d"
 msgstr ""
 "\n"
-"%s é inválido. Tente novamente > "
+"%s é inválido. Tente novamente > "
 #: ../lib/manage/do_rename.c:42
 #, fuzzy, c-format
 msgid "Rename %s <%s> to <%s>"
-msgstr "Impossível abrir base de dados <%s> com driver <%s>"
+msgstr "Impossível abrir base de dados <%s> com driver <%s>"
 #: ../lib/manage/do_rename.c:62
 #, fuzzy, c-format
 msgid "Unable to rename vector map <%s> to <%s>"
 #: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
 #, fuzzy, c-format
 msgid "Unable to rename %s"
 #: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
 #, c-format
@@ -7935,7 +7935,7 @@
 #: ../lib/manage/read_list.c:73
 #, fuzzy, c-format
 msgid "Unable to open data base element list '%s'"
-msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
+msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
 #: ../lib/manage/read_list.c:134
 #, c-format
@@ -7945,12 +7945,12 @@
 #: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
 #, c-format
 msgid "[%s]: No such color"
-msgstr "[%s]: Cor não existe"
+msgstr "[%s]: Cor não existe"
 #: ../lib/display/icon.c:80
 #, fuzzy, c-format
 msgid "Unsupported icon %d"
-msgstr "Tipo(s) de feição"
+msgstr "Tipo(s) de feição"
 #: ../lib/display/r_raster.c:98
 #, c-format
@@ -7967,12 +7967,12 @@
 #: ../lib/display/r_raster.c:150
 #, fuzzy, c-format
 msgid "Unknown display driver <%s>"
 #: ../lib/display/r_raster.c:151
 #, fuzzy, c-format
 msgid "Using display driver <%s>..."
 #: ../lib/segment/open.c:53
 msgid "Segment file name is NULL"
@@ -7985,12 +7985,12 @@
 #: ../lib/segment/open.c:66
 #, fuzzy
 msgid "Unable to create segment file"
-msgstr "Impossível ler arquivo de cabeçalho"
+msgstr "Impossível ler arquivo de cabeçalho"
 #: ../lib/segment/open.c:74
 #, fuzzy
 msgid "Could not write segment file"
-msgstr "impossível escrever arquivo de quantização!"
+msgstr "impossível escrever arquivo de quantização!"
 #: ../lib/segment/open.c:78
 msgid "Illegal segment configuration parameter(s)"
@@ -7999,12 +7999,12 @@
 #: ../lib/segment/open.c:87
 #, fuzzy
 msgid "Unable to re-open segment file"
 #: ../lib/segment/open.c:94
 #, fuzzy
 msgid "Could not read segment file"
-msgstr "não consegui obter informações sobre o arquivo '%s'"
+msgstr "não consegui obter informações sobre o arquivo '%s'"
 #: ../lib/segment/format.c:143
 msgid "Segment format: file size too large"
@@ -8021,7 +8021,7 @@
 #: ../lib/temporal/lib/connect.c:110
 #, fuzzy, c-format
 msgid "Mapset <%s> does not exist."
-msgstr "Impossível abrir topologia para mapa vetorial <%s>"
+msgstr "Impossível abrir topologia para mapa vetorial <%s>"
 #: ../lib/python/gunittest/gmodules.py:103
 msgid "input='-' must be used when stdin is specified"
@@ -8058,12 +8058,12 @@
 #: ../lib/python/pygrass/raster/abstract.py:275
 msgid "Mode type: {0} not supported ('r', 'w')"
-msgstr "Tipo da coluna não suportado"
+msgstr "Tipo da coluna não suportado"
 #: ../lib/python/pygrass/raster/abstract.py:286
 msgid "Overwrite type: {0} not supported (True/False)"
 #: ../lib/python/pygrass/raster/abstract.py:299
 #: ../lib/python/pygrass/vector/abstract.py:97
@@ -8074,7 +8074,7 @@
 #: ../lib/python/pygrass/raster/category.py:69
 msgid "Raster type: {0} not supported"
 #: ../lib/python/pygrass/raster/category.py:156
 msgid "Error executing: Rast_get_ith_cat"
@@ -8097,12 +8097,12 @@
 #: ../lib/python/pygrass/raster/__init__.py:214
 msgid "Raster map <{0}> already exists and will be not overwritten"
-msgstr "O mapa vectorial <%s> já existe e será reescrito"
+msgstr "O mapa vectorial <%s> já existe e será reescrito"
 #: ../lib/python/pygrass/raster/__init__.py:218
 #, fuzzy
 msgid "Raster type not defined"
 #: ../lib/python/pygrass/raster/__init__.py:321
@@ -8112,17 +8112,17 @@
 #: ../lib/python/pygrass/raster/__init__.py:341
 msgid "Index out of range: %r."
 #: ../lib/python/pygrass/raster/__init__.py:530
 msgid "Raster map <{0}> already exists. Use overwrite."
 #: ../lib/python/pygrass/raster/__init__.py:561
 msgid "Raster map <{0}> does not exist"
 #: ../lib/python/pygrass/modules/grid/grid.py:553
 msgid "Execution of subprocesses was not successful"
@@ -8140,12 +8140,12 @@
 #: ../lib/python/pygrass/vector/__init__.py:752
 msgid "Unable to read line of feature %i"
 #: ../lib/python/pygrass/vector/__init__.py:841
 msgid "Unable to read area with id %i"
-msgstr "Não foi possível ler id do elemento %d"
+msgstr "Não foi possível ler id do elemento %d"
 #: ../lib/python/pygrass/utils.py:255
 msgid "Vector doesn't contain points"
@@ -8177,13 +8177,13 @@
 #: ../lib/python/script/array.py:356 ../lib/python/script/array.py:398
 msgid "Invalid kind <%s>"
 #: ../lib/python/script/array.py:160 ../lib/python/script/array.py:210
 #: ../lib/python/script/array.py:308 ../lib/python/script/array.py:359
 msgid "Invalid size <%d>"
 #: ../lib/python/script/array.py:197
 msgid ""
@@ -8194,12 +8194,12 @@
 #: ../lib/python/script/array.py:247 ../lib/python/script/array.py:392
 msgid "Invalid FP size <%d>"
 #: ../lib/python/script/array.py:251 ../lib/python/script/array.py:395
 msgid "Invalid integer size <%d>"
 #: ../lib/python/script/array.py:346
 msgid ""
@@ -8220,7 +8220,7 @@
 #: ../lib/python/script/task.py:191
 msgid "Flag not found: %s"
-msgstr "%s não encontrado"
+msgstr "%s não encontrado"
 #: ../lib/python/script/task.py:210
 #, python-format
@@ -8230,7 +8230,7 @@
 #: ../lib/python/script/task.py:243
 #, fuzzy
 msgid "<required>"
-msgstr "obrigatória: %s\n"
+msgstr "obrigatória: %s\n"
 #: ../lib/python/script/task.py:503 ../lib/python/script/task.py:507
 #, python-format
@@ -8251,7 +8251,7 @@
 "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
 "current mapset."
 msgstr ""
-"não consegui apagar a linha, o mapa '%s' não está aberto em modo de escrita"
+"não consegui apagar a linha, o mapa '%s' não está aberto em modo de escrita"
 #: ../lib/python/script/raster.py:113
 msgid "An error occurred while running r.mapcalc"
@@ -8309,7 +8309,7 @@
 #: ../lib/python/script/core.py:1372
 #, fuzzy
 msgid "Unable to list mapsets"
-msgstr "Impossível fechar mapa de entrada"
+msgstr "Impossível fechar mapa de entrada"
 #: ../lib/python/script/core.py:1411
 #, python-format
@@ -8319,7 +8319,7 @@
 #: ../lib/python/script/core.py:1414
 msgid "Location <%s> already exists and will be overwritten"
 #: ../lib/python/script/core.py:1538
 msgid "Debug level {}"
@@ -8332,12 +8332,12 @@
 #: ../lib/python/script/core.py:1557
 msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
-msgstr "Nome de arquivo ilegal. não pode ser '.' ou 'NULL'\n"
+msgstr "Nome de arquivo ilegal. não pode ser '.' ou 'NULL'\n"
 #: ../lib/python/script/core.py:1566
 msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
-msgstr "Nome de arquivo ilegal. O caractere <%c> não é permitido.\n"
+msgstr "Nome de arquivo ilegal. O caractere <%c> não é permitido.\n"
 #: ../lib/python/script/raster3d.py:92
 msgid "An error occurred while running r3.mapcalc"
@@ -8352,7 +8352,7 @@
 #: ../lib/python/script/db.py:163
 #, fuzzy
 msgid "Fetching data failed"
 #: ../lib/python/exceptions/__init__.py:68
 #, python-format
@@ -8387,7 +8387,7 @@
 msgid ""
 "Raster map <%(name)s> is already in temporal database, use overwrite flag to "
 "overwrite"
 #: ../lib/python/temporal/aggregation.py:143
 #, python-format
@@ -8427,37 +8427,37 @@
 #: ../lib/python/temporal/open_stds.py:66
 msgid "Space time %(sp)s dataset <%(name)s> not found"
-msgstr "Vetor de entrada '%s' não encontrado"
+msgstr "Vetor de entrada '%s' não encontrado"
 #: ../lib/python/temporal/open_stds.py:105
 #, fuzzy
 msgid "Space time datasets can only be created in the current mapset"
-msgstr "Bug: tentativa de atualizar mapa que não está no mapset atual."
+msgstr "Bug: tentativa de atualizar mapa que não está no mapset atual."
 #: ../lib/python/temporal/open_stds.py:122
 msgid ""
 "Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
 "overwrite flag."
 #: ../lib/python/temporal/open_stds.py:157
 msgid ""
 "Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
-msgstr "não consegui criar o cabeçalho para o arquivo [%s]"
+msgstr "não consegui criar o cabeçalho para o arquivo [%s]"
 #: ../lib/python/temporal/open_stds.py:165
 msgid "Creating a new space time %s dataset"
 #: ../lib/python/temporal/open_stds.py:208
 #: ../lib/python/temporal/mapcalc.py:236 ../lib/python/temporal/extract.py:130
 msgid ""
 "Map <%s> is already in temporal database, use overwrite flag to overwrite"
 #: ../lib/python/temporal/abstract_dataset.py:388
 #, python-format
@@ -8500,12 +8500,12 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:311
 msgid "Unsupported temporal unit: %s"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:361
 msgid "Created register table <%s> for space time %s  dataset <%s>"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:679
 #: ../lib/python/temporal/abstract_space_time_dataset.py:921
@@ -8520,7 +8520,7 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1488
 msgid "Unable to get map ids from register table <%s>"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1570
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1606
@@ -8557,7 +8557,7 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1944
 msgid "Delete space time %s  dataset <%s> from temporal database"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1950
 #: ../lib/python/temporal/abstract_map_dataset.py:824
@@ -8570,19 +8570,19 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1963
 msgid "Drop map register table: %s"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2018
 #, fuzzy
 msgid "Error in register table request"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2047
 msgid ""
 "Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
 "the dataset does not match the current mapset"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2056
 msgid ""
@@ -8605,18 +8605,18 @@
 msgid ""
 "Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
 "%(l)s are different"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2107
 msgid ""
 "Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2122
 msgid "Set temporal unit for space time %s dataset <%s> to %s"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2132
 #, python-format
@@ -8639,7 +8639,7 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2149
 msgid "Map <%(map)s> with layer %(l)s is already registered."
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2153
 #, python-format
@@ -8659,12 +8659,12 @@
 msgid ""
 "Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
 "%(base)s>"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2220
 msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2281
 #, python-format
@@ -8677,23 +8677,23 @@
 msgid ""
 "Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
 "%(l)s"
-msgstr "não consegui criar arquivo de data para o %s mapa %s no mapset %s"
+msgstr "não consegui criar arquivo de data para o %s mapa %s no mapset %s"
 #: ../lib/python/temporal/abstract_map_dataset.py:349
 msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
-msgstr "Arquivo de data inválido para o %s mapa %s no mapset %s"
+msgstr "Arquivo de data inválido para o %s mapa %s no mapset %s"
 #: ../lib/python/temporal/abstract_map_dataset.py:357
 msgid ""
 "End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
 #: ../lib/python/temporal/abstract_map_dataset.py:364
 msgid "End time must be of type datetime for %(type)s map <%(id)s>"
 #: ../lib/python/temporal/abstract_map_dataset.py:373
@@ -8713,12 +8713,12 @@
 msgid ""
 "Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
 "%(l)s: %(u)s"
 #: ../lib/python/temporal/abstract_map_dataset.py:459
 msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
-msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
+msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
 #: ../lib/python/temporal/abstract_map_dataset.py:468
@@ -8748,7 +8748,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:842
 msgid "Delete %s dataset <%s> from temporal database"
 #: ../lib/python/temporal/abstract_map_dataset.py:892
 #, python-format
@@ -8766,62 +8766,62 @@
 #: ../lib/python/temporal/univar_statistics.py:176
 msgid "Space time %(sp)s dataset <%(i)s> is empty"
 #: ../lib/python/temporal/univar_statistics.py:99
 msgid "Unable to get statistics for raster map <%s>"
 #: ../lib/python/temporal/univar_statistics.py:102
 msgid "Unable to get statistics for 3d raster map <%s>"
 #: ../lib/python/temporal/univar_statistics.py:166
 msgid "Space time %(sp)s dataset <%(i)s> not found"
 #: ../lib/python/temporal/univar_statistics.py:220
 msgid "Unable to get statistics for vector map <%s>"
 #: ../lib/python/temporal/stds_import.py:84
 msgid "Unable to import/link raster map <%s> from file %s."
 #: ../lib/python/temporal/stds_import.py:95
 msgid "Unable to set the color rules for raster map <%s>."
 #: ../lib/python/temporal/stds_import.py:119
 msgid "Unable to unpack raster map <%s> from file %s."
 #: ../lib/python/temporal/stds_import.py:143
 msgid "Unable to import vector map <%s> from file %s."
 #: ../lib/python/temporal/stds_import.py:167
 msgid "Unable to unpack vector map <%s> from file %s."
 #: ../lib/python/temporal/stds_import.py:207
 msgid "Space time raster dataset archive <%s> not found"
 #: ../lib/python/temporal/stds_import.py:210
 msgid "Extraction directory <%s> not found"
 #: ../lib/python/temporal/stds_import.py:216
 #, python-format
@@ -8831,17 +8831,17 @@
 #: ../lib/python/temporal/stds_import.py:223
 msgid "Unable to find init file <%s>"
 #: ../lib/python/temporal/stds_import.py:225
 msgid "Unable to find list file <%s>"
 #: ../lib/python/temporal/stds_import.py:227
 msgid "Unable to find projection file <%s>"
 #: ../lib/python/temporal/stds_import.py:229
 #, fuzzy
@@ -8866,17 +8866,17 @@
 #: ../lib/python/temporal/stds_import.py:293
 msgid "Unable to create location %(l)s. Reason: %(e)s"
 #: ../lib/python/temporal/stds_import.py:301
 msgid "Unable to switch to location %s"
-msgstr "não consegui escrever os dados históricos para [%s]"
+msgstr "não consegui escrever os dados históricos para [%s]"
 #: ../lib/python/temporal/stds_import.py:306
 msgid "Unable to create default temporal database in new location %s"
 #: ../lib/python/temporal/stds_import.py:379
 #, python-format
@@ -8894,49 +8894,49 @@
 #: ../lib/python/temporal/stds_import.py:404
 msgid "Unable to find GeoTIFF raster file <%s> in archive."
-msgstr "não foi possível encontrar o arquivo null temporário: %s"
+msgstr "não foi possível encontrar o arquivo null temporário: %s"
 #: ../lib/python/temporal/stds_import.py:410
 msgid "Unable to find AAIGrid raster file <%s> in archive."
 #: ../lib/python/temporal/stds_import.py:416
 msgid "Unable to find GML vector file <%s> in archive."
 #: ../lib/python/temporal/stds_import.py:425
 msgid "Unable to find GRASS package file <%s> in archive."
-msgstr "não consegui abrir %s para escrita"
+msgstr "não consegui abrir %s para escrita"
 #: ../lib/python/temporal/stds_import.py:428
 #, fuzzy
 msgid "Unsupported input format"
 #: ../lib/python/temporal/stds_import.py:434
 msgid ""
 "Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
 "overwrite flag."
 #: ../lib/python/temporal/stds_import.py:455
 msgid "Overwrite space time %(sp)s dataset <%(id)s> and unregister all maps."
 #: ../lib/python/temporal/stds_import.py:467
 msgid "Key word %s not found in init file."
 #: ../lib/python/temporal/stds_import.py:472
 msgid "Create space time %s dataset."
 #: ../lib/python/temporal/stds_import.py:501
 msgid "Switching to original location failed"
@@ -8955,7 +8955,7 @@
 #: ../lib/python/temporal/temporal_algebra.py:845
 #, fuzzy
 msgid "All input space time datasets must have the same temporal type."
 #: ../lib/python/temporal/temporal_algebra.py:1093
@@ -8965,7 +8965,7 @@
 #: ../lib/python/temporal/temporal_algebra.py:1148
 msgid "Space time %s dataset <%s> not found"
 #: ../lib/python/temporal/temporal_algebra.py:1176
 #: ../lib/python/temporal/temporal_algebra.py:1180
@@ -8978,7 +8978,7 @@
 #: ../lib/python/temporal/temporal_algebra.py:1200
 #, fuzzy
 msgid "Wrong type of input "
 #: ../lib/python/temporal/temporal_algebra.py:2092
 #, python-format
@@ -8997,7 +8997,7 @@
 #: ../lib/python/temporal/temporal_raster_base_algebra.py:702
 msgid "%s map <%s> not found in GRASS spatial database"
 #: ../lib/python/temporal/temporal_algebra.py:2307
 msgid ""
@@ -9020,22 +9020,22 @@
 #: ../lib/python/temporal/temporal_algebra.py:2349
 #, fuzzy
 msgid "Space time datasets to merge must have the same temporal type"
 #: ../lib/python/temporal/space_time_datasets.py:231
 msgid "Unable to read timestamp file for raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:255
 msgid "Unable to create timestamp file for raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:260
 msgid "Invalid datetime in timestamp for raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:265
 #: ../lib/python/temporal/space_time_datasets.py:609
@@ -9047,42 +9047,42 @@
 #: ../lib/python/temporal/space_time_datasets.py:623
 msgid "Unable to remove timestamp for raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:575
 msgid "Unable to read timestamp file for 3D raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:599
 msgid "Unable to create timestamp file for 3D raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:604
 msgid "Invalid datetime in timestamp for 3D raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:879
 msgid "Unable to read timestamp file for vector map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:902
 msgid "Unable to create timestamp file for vector map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:907
 msgid "Invalid datetime in timestamp for vector map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:923
 msgid "Unable to remove timestamp for vector map <%s>"
 #: ../lib/python/temporal/datetime_math.py:256
 #: ../lib/python/temporal/datetime_math.py:273
@@ -9097,33 +9097,33 @@
 #: ../lib/python/temporal/datetime_math.py:741
 #, fuzzy
 msgid "Dates Before Christ (BC) are not supported"
-msgstr "para este formato/nível não suportado"
+msgstr "para este formato/nível não suportado"
 #: ../lib/python/temporal/datetime_math.py:745
 #, fuzzy
 msgid "Time zones are not supported"
 #: ../lib/python/temporal/datetime_math.py:755
 msgid "Unable to parse time string: %s"
 #: ../lib/python/temporal/c_libraries_interface.py:597
 #: ../lib/python/temporal/c_libraries_interface.py:614
 #, fuzzy
 msgid "Unable to read range file"
 #: ../lib/python/temporal/c_libraries_interface.py:692
 msgid "Unable to load range of 3D raster map <%s>"
 #: ../lib/python/temporal/base.py:379
 msgid "Object <%s> not found in the temporal database"
 #: ../lib/python/temporal/base.py:462 ../lib/python/temporal/base.py:513
 msgid "Missing identifier"
@@ -9132,42 +9132,42 @@
 #: ../lib/python/temporal/base.py:620
 #, fuzzy
 msgid "Wrong identifier, the mapset is missing"
-msgstr "Impossível abrir índice de categoria para mapa vetorial <%s>"
+msgstr "Impossível abrir índice de categoria para mapa vetorial <%s>"
 #: ../lib/python/temporal/stds_export.py:104
 msgid "Unable to export raster map <%s>"
 #: ../lib/python/temporal/stds_export.py:115
 msgid "Unable to export color rules for raster map <%s> r.out.gdal"
 #: ../lib/python/temporal/stds_export.py:139
 msgid "Unable to export raster map <%s> with r.pack"
 #: ../lib/python/temporal/stds_export.py:167
 msgid "Unable to export vector map <%s> as GML with v.out.ogr"
 #: ../lib/python/temporal/stds_export.py:200
 msgid "Unable to export vector map <%s> with v.pack"
 #: ../lib/python/temporal/stds_export.py:226
 msgid "Unable to export raster map <%s> with r3.pack"
 #: ../lib/python/temporal/sampling.py:91 ../lib/python/temporal/sampling.py:96
 msgid "Dataset <%s> not found in temporal database"
 #: ../lib/python/temporal/mapcalc.py:105
 msgid "Starting spatio-temporal sampling..."
@@ -9191,7 +9191,7 @@
 #: ../lib/python/temporal/mapcalc.py:169
 #, fuzzy
 msgid "No maps registered in input dataset"
 #: ../lib/python/temporal/mapcalc.py:185
 msgid "Starting mapcalc computation..."
@@ -9209,7 +9209,7 @@
 #: ../lib/python/temporal/mapcalc.py:281
 #, fuzzy
 msgid "Starting map registration in temporal database..."
 #: ../lib/python/temporal/mapcalc.py:438 ../lib/python/temporal/mapcalc.py:444
 #: ../lib/python/temporal/mapcalc.py:450 ../lib/python/temporal/mapcalc.py:456
@@ -9254,7 +9254,7 @@
 msgid "Please specify %s= or %s="
 msgstr ""
 "\n"
-"Por favor especifique o nome do elipsóide\n"
+"Por favor especifique o nome do elipsóide\n"
 #: ../lib/python/temporal/register.py:108
 #, python-format
@@ -9279,21 +9279,21 @@
 #: ../lib/python/temporal/register.py:191
 msgid "Unable to update %(t)s map <%(id)s>. The map does not exist."
 #: ../lib/python/temporal/register.py:209
 msgid ""
 "Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
 "timestamp and the start time is not set."
 #: ../lib/python/temporal/register.py:215
 msgid ""
 "Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
 "start time is not set."
 #: ../lib/python/temporal/register.py:223
 #, python-format
@@ -9310,41 +9310,41 @@
 msgid ""
 "Map is already registered in temporal database. Unable to update %(t)s map <"
 "%(id)s> with layer %(l)s. Overwrite flag is not set."
 #: ../lib/python/temporal/register.py:246
 msgid ""
 "%(id)s>. Overwrite flag is not set."
 #: ../lib/python/temporal/register.py:270
 msgid ""
 "Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are "
 "different."
 #: ../lib/python/temporal/register.py:276
 msgid "Unable to update %(t)s map <%(id)s>. The temporal types are different."
 #: ../lib/python/temporal/register.py:324
 #, fuzzy
 msgid "Registering maps in the temporal database..."
 #: ../lib/python/temporal/register.py:331
 #, fuzzy
 msgid "Registering maps in the space time dataset..."
 #: ../lib/python/temporal/register.py:340
 #, fuzzy
 msgid "Updating space time dataset..."
-msgstr "Nome do mapa raster de elevação"
+msgstr "Nome do mapa raster de elevação"
 #: ../lib/python/temporal/register.py:393
 #: ../lib/python/temporal/register.py:400
@@ -9363,7 +9363,7 @@
 msgid ""
 "Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
 "%(end)s"
 #: ../lib/python/temporal/register.py:421
 #, python-format
@@ -9455,7 +9455,7 @@
 msgid ""
 "Unable to receive temporal database metadata.\n"
 "Current temporal database info:%(info)s"
 #: ../lib/python/temporal/core.py:673
@@ -9464,7 +9464,7 @@
 " %(backup)s Supported temporal API version is: %(api)i.\n"
 "Please update your GRASS GIS installation.\n"
 #: ../lib/python/temporal/core.py:681
@@ -9472,12 +9472,12 @@
 "Unsupported temporal database: version mismatch.\n"
 " %(backup)sSupported temporal database version is: %(tdb)i\n"
 #: ../lib/python/temporal/core.py:769
 msgid "Creating temporal database: %s"
-msgstr "não consegui abrir banco de dados %s"
+msgstr "não consegui abrir banco de dados %s"
 #: ../lib/python/temporal/core.py:778
 #, python-format
@@ -9490,32 +9490,32 @@
 #: ../lib/python/temporal/core.py:943
 #, fuzzy
 msgid "Unable to mogrify sql statement. "
 #: ../lib/python/temporal/core.py:965
 #, fuzzy
 msgid "Unable to check table. "
 #: ../lib/python/temporal/core.py:981
 #, fuzzy
 msgid "Unable to execute sql statement. "
-msgstr "Impossível executar o comando"
+msgstr "Impossível executar o comando"
 #: ../lib/python/temporal/core.py:991
 #, fuzzy
 msgid "Unable to fetch one. "
 #: ../lib/python/temporal/core.py:1001
 #, fuzzy
 msgid "Unable to fetch all. "
 #: ../lib/python/temporal/core.py:1018
 #, fuzzy
 msgid "Unable to execute transaction. "
 #: ../lib/python/temporal/core.py:1121
 #, python-format
@@ -9530,14 +9530,14 @@
 msgid ""
 "Unable to execute :\n"
 " %(sql)s"
 #: ../lib/python/temporal/core.py:1322
 msgid ""
 "Unable to execute transaction:\n"
 " %(sql)s"
 #: ../lib/python/temporal/temporal_vector_algebra.py:372
 #, python-format
@@ -9558,17 +9558,17 @@
 msgid ""
 "Error vector map %s exist in temporal database. Use overwrite flag.  : \n"
 "%s"
 #: ../lib/driver/parse_ftcap.c:84
 #, c-format
 msgid "%s: Unable to read font definition file; use the default"
-msgstr "%s: Não foi possível ler ficheiro de definição de fonte; use o default"
+msgstr "%s: Não foi possível ler ficheiro de definição de fonte; use o default"
 #: ../lib/driver/parse_ftcap.c:90
 #, c-format
 msgid "%s: No font definition file"
-msgstr "%s: Nenhum ficheiro de definição de fonte"
+msgstr "%s: Nenhum ficheiro de definição de fonte"
 #: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
 #, c-format
@@ -9578,11 +9578,11 @@
 #: ../lib/proj/get_proj.c:148
 #, c-format
 msgid "Invalid zone %s specified"
-msgstr "Zona inválida %s especificada"
+msgstr "Zona inválida %s especificada"
 #: ../lib/proj/get_proj.c:228
 msgid "Unable to initialise PROJ.4 with the following parameter list:"
-msgstr "Não foi possíve iniciar PROJ.4 com a seguinte lista de parâmetros:"
+msgstr "Não foi possíve iniciar PROJ.4 com a seguinte lista de parâmetros:"
 #: ../lib/proj/get_proj.c:236
 #, c-format
@@ -9591,16 +9591,16 @@
 #: ../lib/proj/get_proj.c:294
 msgid "Option input overflowed option table"
-msgstr "Inserção de opções sobrecarregou a tabela de opções"
+msgstr "Inserção de opções sobrecarregou a tabela de opções"
 #: ../lib/proj/get_proj.c:325
 #, c-format
 msgid "Unable to initialize pj cause: %s"
-msgstr "Não foi possível iniciar pj porque: %s"
+msgstr "Não foi possível iniciar pj porque: %s"
 #: ../lib/proj/get_proj.c:401
 msgid "Input Projection Parameters"
-msgstr "Parâmetros da Projeção Inicial"
+msgstr "Parâmetros da Projeção Inicial"
 #: ../lib/proj/get_proj.c:404
 msgid "Input Unit Factor"
@@ -9608,7 +9608,7 @@
 #: ../lib/proj/get_proj.c:414
 msgid "Output Projection Parameters"
-msgstr "Parâmetros da Projeção Final"
+msgstr "Parâmetros da Projeção Final"
 #: ../lib/proj/get_proj.c:417
 msgid "Output Unit Factor"
@@ -9617,54 +9617,54 @@
 #: ../lib/proj/ellipse.c:97
 #, c-format
 msgid "Invalid ellipsoid <%s> in file"
-msgstr "Elipsóide inválido <%s> no ficheiro"
+msgstr "Elipsóide inválido <%s> no ficheiro"
 #: ../lib/proj/ellipse.c:124
 msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr "Não há descritor secundário do elipsóide (rf, es ou b) no ficheiro"
+msgstr "Não há descritor secundário do elipsóide (rf, es ou b) no ficheiro"
 #: ../lib/proj/ellipse.c:128
 msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-msgstr "Descritor inválido do elipsóide (a, rf, es ou b) no ficheiro"
+msgstr "Descritor inválido do elipsóide (a, rf, es ou b) no ficheiro"
 #: ../lib/proj/ellipse.c:141
 msgid "No ellipsoid info given in file"
-msgstr "O ficheiro não tém informações sobre o elipsóide"
+msgstr "O ficheiro não tém informações sobre o elipsóide"
 #: ../lib/proj/convert.c:120
 msgid "Unable parse GRASS PROJ_INFO file"
-msgstr "Não foi possível processar o ficheiro GRASS PROJ_INFO"
+msgstr "Não foi possível processar o ficheiro GRASS PROJ_INFO"
 #: ../lib/proj/convert.c:125
 #, fuzzy
 msgid "Unable get PROJ.4-style parameter string"
-msgstr "Não foi possível obter o texto do parâmetro de estilo PROJ.4"
+msgstr "Não foi possível obter o texto do parâmetro de estilo PROJ.4"
 #: ../lib/proj/convert.c:139
 #, c-format
 msgid ""
 "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
 msgstr ""
-"OGR não consegue processar o texto do parâmetro de estilo PROJ.4: %s (O "
-"código de erro OGR foi %d)"
+"OGR não consegue processar o texto do parâmetro de estilo PROJ.4: %s (O "
+"código de erro OGR foi %d)"
 #: ../lib/proj/convert.c:152
 #, c-format
 msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
 msgstr ""
-"OGR não consegue obter o texto do parâmetro de estilo WKT (O código de erro "
+"OGR não consegue obter o texto do parâmetro de estilo WKT (O código de erro "
 "OGR foi %d)"
 #: ../lib/proj/convert.c:394
 msgid "No projection name! Projection parameters likely to be meaningless."
 msgstr ""
-"Sem nome de projeção! É provável que os parâmetros de projeção não tenham "
-"conteúdo."
+"Sem nome de projeção! É provável que os parâmetros de projeção não tenham "
+"conteúdo."
 #: ../lib/proj/convert.c:457
 #, c-format
 msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr "Datum <%s> não reconhecido pelo GRASS e nenhum parâmetro encontrado"
+msgstr "Datum <%s> não reconhecido pelo GRASS e nenhum parâmetro encontrado"
 #: ../lib/proj/convert.c:473
 #, c-format
@@ -9672,7 +9672,7 @@
 "Datum <%s> apparently recognised by GRASS but no parameters found. You may "
 "want to look into this."
 msgstr ""
-"Datum <%s> aparentemente reconhecido pelo GRASS mas nenhum parâmetro "
+"Datum <%s> aparentemente reconhecido pelo GRASS mas nenhum parâmetro "
 "encontrado. Por favor investigue isto."
 #: ../lib/proj/convert.c:477
@@ -9681,13 +9681,13 @@
 "Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
 "transform parameters unspecified."
 msgstr ""
-"Número de transformação inválido %d; intervalo de valores é 1 to %d. "
-"Parâmetros de transformação não especificados para o datum inicial."
+"Número de transformação inválido %d; intervalo de valores é 1 to %d. "
+"Parâmetros de transformação não especificados para o datum inicial."
 #: ../lib/proj/datum.c:272 ../lib/proj/datum.c:352
 #, c-format
 msgid "Unable to open datum table file <%s>"
-msgstr "Não foi possível abrir o ficheiro da tabela do datum <%s>"
+msgstr "Não foi possível abrir o ficheiro da tabela do datum <%s>"
 #: ../lib/proj/datum.c:285 ../lib/proj/datum.c:366
 #, c-format
@@ -9702,7 +9702,7 @@
 #: ../lib/rst/interp_float/output2d.c:124
 #, c-format
 msgid "First change your cols number to nsizc %d %d"
-msgstr "Altere primeiro os número das suas cols para nsizc %d %d"
+msgstr "Altere primeiro os número das suas cols para nsizc %d %d"
 #: ../lib/rst/interp_float/resout2d.c:77
 msgid "Temporarily changing the region to desired resolution..."
@@ -9729,7 +9729,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:94
 #, c-format
 msgid "Vector map <%s> is not 3D"
-msgstr "Mapa vectorial <%s> não é 3D"
+msgstr "Mapa vectorial <%s> não é 3D"
 #: ../lib/rst/interp_float/vinput2d.c:97
 msgid "Loading data from attribute table ..."
@@ -9739,7 +9739,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:131
 #, c-format
 msgid "Data type of column <%s> must be numeric"
-msgstr "O tipo de dados da coluna <%s> deve ser numérico"
+msgstr "O tipo de dados da coluna <%s> deve ser numérico"
 #: ../lib/rst/interp_float/vinput2d.c:142
 msgid "Reading features from vector map ..."
@@ -9748,7 +9748,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:174
 #, c-format
 msgid "Database record for cat %d not found"
-msgstr "Registo na base de dados para a categoria %d não encontrado"
+msgstr "Registo na base de dados para a categoria %d não encontrado"
 #: ../lib/rst/interp_float/vinput2d.c:192
 msgid "Negative value of smoothing detected: sm must be >= 0"
@@ -9756,12 +9756,12 @@
 #: ../lib/rst/interp_float/vinput2d.c:256
 msgid "Strip exists with insufficient data"
-msgstr "Há uma faixa com dados insuficientes"
+msgstr "Há uma faixa com dados insuficientes"
 #: ../lib/rst/interp_float/vinput2d.c:270
 #, c-format
 msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr "Há pontos fora da região 2D/3D especificada - %d pontos ignorados"
+msgstr "Há pontos fora da região 2D/3D especificada - %d pontos ignorados"
 #: ../lib/rst/interp_float/vinput2d.c:273
 #, c-format
@@ -9774,12 +9774,12 @@
 "%d points given for interpolation (after thinning) is less than given NPMIN="
 "%d"
 msgstr ""
-"%d pontos dados para a interpolação (após afinamento) é menor que o NPMIN=%d "
+"%d pontos dados para a interpolação (após afinamento) é menor que o NPMIN=%d "
 "definido"
 #: ../lib/rst/interp_float/vinput2d.c:282
 msgid "Zero points in the given region"
-msgstr "Zero pontos na região definida"
+msgstr "Zero pontos na região definida"
 #: ../lib/rst/interp_float/vinput2d.c:287
 #, c-format
@@ -9787,8 +9787,8 @@
 "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
 "smooth connection of segments, npmin > segmax (see manual)"
 msgstr ""
-"Parâmetros de segmentação definidos como parâmetros inválidos: npmin= %d. "
-"segmax= %d para ligação de segmentos suave, npmin > segmax (ver manual)"
+"Parâmetros de segmentação definidos como parâmetros inválidos: npmin= %d. "
+"segmax= %d para ligação de segmentos suave, npmin > segmax (ver manual)"
 #: ../lib/rst/interp_float/vinput2d.c:293
 #, c-format
@@ -9796,36 +9796,36 @@
 "There are less than %d points for interpolation. No segmentation is "
 "necessary, to run the program faster set segmax=%d (see manual)"
 msgstr ""
-"Existem menos que %d pontos para interpolação. Nenhuma segmentação é "
-"necessária, para executar o programa mais rápido use segmax=%d (ver manual)"
+"Existem menos que %d pontos para interpolação. Nenhuma segmentação é "
+"necessária, para executar o programa mais rápido use segmax=%d (ver manual)"
 #: ../lib/rst/interp_float/vinput2d.c:297
 #, c-format
 msgid "Number of points from vector map %d"
-msgstr "Número de pontos do mapa vectorial %d"
+msgstr "Número de pontos do mapa vectorial %d"
 #: ../lib/rst/interp_float/vinput2d.c:298
 #, c-format
 msgid "Number of points outside of 2D/3D region %d"
-msgstr "Número de pontos fora da região 2D/3D: %d"
+msgstr "Número de pontos fora da região 2D/3D: %d"
 #: ../lib/rst/interp_float/vinput2d.c:300
 #, c-format
 msgid "Number of points being used %d"
-msgstr "Número de pontos em uso %d"
+msgstr "Número de pontos em uso %d"
 #: ../lib/rst/interp_float/vinput2d.c:333
 msgid "Some points outside of region (ignored)"
-msgstr "Alguns pontos fora da região (ignorados)"
+msgstr "Alguns pontos fora da região (ignorados)"
 #: ../lib/rst/interp_float/vinput2d.c:339
 msgid "Unable to allocate memory"
 #: ../lib/rst/interp_float/vinput2d.c:347
 #, c-format
 msgid "Unable to insert %f,%f,%f a = %d"
-msgstr "Não foi possível inserir %f,%f,%f a = %d"
+msgstr "Não foi possível inserir %f,%f,%f a = %d"
 #: ../lib/rst/interp_float/interp2d.c:232
 #, c-format
@@ -9833,81 +9833,81 @@
 "Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell. "
 "Z-value %f, zmin %f, zmax %f."
 msgstr ""
-"Estimativa por excesso - aumento na tensão sugerida. Estimativa por excesso "
-"ocorre na célula (%d,%d). Valores Z %f, mín %f, máx %f."
+"Estimativa por excesso - aumento na tensão sugerida. Estimativa por excesso "
+"ocorre na célula (%d,%d). Valores Z %f, mín %f, máx %f."
 #: ../lib/rst/interp_float/segmen2d.c:135
 msgid ""
 "Taking too long to find points for interpolation - please change the region "
 "to area where your points are. Continuing calculations..."
 msgstr ""
-"A demorar demais para encontrar pontos para interpolação - por favor altere "
-"a região para a área onde estão os pontos. Continuando cálculos..."
+"A demorar demais para encontrar pontos para interpolação - por favor altere "
+"a região para a área onde estão os pontos. Continuando cálculos..."
 #: ../lib/rst/interp_float/write2d.c:53 ../lib/rst/interp_float/write2d.c:64
 #: ../lib/rst/interp_float/write2d.c:79 ../lib/rst/interp_float/write2d.c:88
 #: ../lib/rst/interp_float/write2d.c:96 ../lib/rst/interp_float/write2d.c:104
 #, fuzzy
 msgid "Cannot write files"
-msgstr "não consegui reescrever a linha"
+msgstr "não consegui reescrever a linha"
 #: ../lib/rst/interp_float/input2d.c:58
 #, c-format
 msgid "Mask raster map <%s> not found"
-msgstr "Máscara do mapa raster <%s> não encontrada"
+msgstr "Máscara do mapa raster <%s> não encontrada"
 #: ../lib/rst/interp_float/input2d.c:81
 msgid "Bitmap mask created"
-msgstr "Máscara bitmap criada"
+msgstr "Máscara bitmap criada"
 #, fuzzy
 #~ msgid "Unable to restore feature/offset %lu in vector map <%s>"
-#~ msgstr "Impossível mudar de diretório para %s"
+#~ msgstr "Impossível mudar de diretório para %s"
 #, fuzzy
 #~ msgid "Out of memmory"
-#~ msgstr "G_malloc: memória esgotada"
+#~ msgstr "G_malloc: memória esgotada"
 #, fuzzy
 #~ msgid ""
 #~ "Unable to check table. There is no temporal database connection defined "
 #~ "for mapset <%(mapset)s>"
-#~ msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
+#~ msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
 #, fuzzy
 #~ msgid ""
 #~ "Unable to fetch one. There is no temporal database connection defined for "
 #~ "mapset <%(mapset)s>"
-#~ msgstr "Impossível abrir histórico para mapa vetorial %s"
+#~ msgstr "Impossível abrir histórico para mapa vetorial %s"
 #, fuzzy
 #~ msgid ""
 #~ "Unable to fetch all. There is no temporal database connection defined for "
 #, fuzzy
 #~ msgid "Unable to find a temporary null file <%s>"
-#~ msgstr "não foi possível encontrar o arquivo null temporário: %s"
+#~ msgstr "não foi possível encontrar o arquivo null temporário: %s"
 #, fuzzy
 #~ msgid "Unable to open null file <%s>"
-#~ msgstr "G_spawn: não consegui abrir o arquivo %s"
+#~ msgstr "G_spawn: não consegui abrir o arquivo %s"
 #, fuzzy
 #~ msgid "ERROR: <%s> is not a valid GRASS location"
-#~ msgstr "Desculpe <%s> não é uma opção válida\n"
+#~ msgstr "Desculpe <%s> não é uma opção válida\n"
 #~ msgid "ERROR: option <%s>: <%s> exists.\n"
-#~ msgstr "ERRO: opção <%s>: <%s> já existe.\n"
+#~ msgstr "ERRO: opção <%s>: <%s> já existe.\n"
 #, fuzzy
 #~ msgid "Invalid offset (%d)"
 #, fuzzy
 #~ msgid "Unable to open file '%s'"
-#~ msgstr "Impossível abrir arquivo %s"
+#~ msgstr "Impossível abrir arquivo %s"
 #, fuzzy
 #~ msgid "Hit RETURN to continue"
@@ -9915,7 +9915,7 @@
 #, fuzzy
 #~ msgid "Vector map <%s> is not opened on topology level"
-#~ msgstr "Vetor de entrada '%s' não encontrado"
+#~ msgstr "Vetor de entrada '%s' não encontrado"
 #~ msgid "Background color"
 #~ msgstr "Cor de fundo"
@@ -9926,21 +9926,21 @@
 #, fuzzy
 #~ msgid "Mode type: {0} not supported."
-#~ msgstr "Tipo da coluna não suportado"
+#~ msgstr "Tipo da coluna não suportado"
 #, fuzzy
 #~ msgid "Invalid type {0}"
 #~ msgid "Attributes for category %d not found"
-#~ msgstr "Atributos para a categoria %d não encontrados"
+#~ msgstr "Atributos para a categoria %d não encontrados"
 #, fuzzy
 #~ msgid "Category must be integer"
-#~ msgstr "Categoria tem de ser número inteiro"
+#~ msgstr "Categoria tem de ser número inteiro"
 #~ msgid "Memory error in writing timestamp"
-#~ msgstr "Erro de memória ao escrever etiqueta de data"
+#~ msgstr "Erro de memória ao escrever etiqueta de data"
 #, fuzzy
 #~ msgid ""
@@ -9948,12 +9948,12 @@
 #~ "updated to GRASS 6 vector library)"
 #~ msgstr ""
 #~ "Nota do Dev: Bibliotecas locais adaptadas usadas para os pontos "
-#~ "vectoriais. (o módulo deverá ser atualizado para a biblioteca vectorial "
+#~ "vectoriais. (o módulo deverá ser atualizado para a biblioteca vectorial "
 #~ "GRASS 6)"
 #~ msgid "Cannot fetch row"
-#~ msgstr "Não foi possível obter linha"
+#~ msgstr "Não foi possível obter linha"
 #, fuzzy
 #~ msgid "G_oldsite_new_struct: invalid # dims or fields"
-#~ msgstr "G_oldsite_new_struct: # dims ou campos inválidos"
+#~ msgstr "G_oldsite_new_struct: # dims ou campos inválidos"
