[GRASS-SVN] r70918 - grass-addons/tools
svn_grass at osgeo.org
Sat Apr 22 06:47:15 PDT 2017
Author: neteler
Date: 2017-04-22 06:47:15 -0700 (Sat, 22 Apr 2017)
New Revision: 70918
grass-addons/tools/transifex_merge.sh
transifex_merge.sh: more explanations; update error messages
Modified: grass-addons/tools/transifex_merge.sh
--- grass-addons/tools/transifex_merge.sh 2017-04-22 13:07:52 UTC (rev 70917)
+++ grass-addons/tools/transifex_merge.sh 2017-04-22 13:47:15 UTC (rev 70918)
@@ -1,20 +1,29 @@
#!/bin/bash
+# GRASS GIS transifex support script: fetches msg from transifex
# Luca Delucchi 2017
+# based on gettext message merge procedure by Markus Neteler
-# this script has to be launched in `locale` directory.
-# the `locale` directory should contain a folder called `transifex`
-# inside the `transifex` folder you need to run the instruction documentated here
+# Required installation:
+# see
# https://grasswiki.osgeo.org/wiki/GRASS_messages_translation#Get_the_translated_po_files
+# Usage:
+# this script has to be launched in the `locale` directory.
+# upon proper installation, the `locale` directory contains a folder called `transifex`
MSGMERGE="msgmerge -N --no-wrap"
+if [ "`basename $PWD`" != "locale" ]; then
+ echo "ERROR: run $0 command in locale folder of GRASS GIS source code"
+ exit 1;
+fi
# download the translation from transifex
cd transifex
if [ $? -ne 0 ]; then
- echo "ECHO: transifex folder not found, you should run this command in locale folder"
+ echo "ERROR: transifex folder not found, for requirements see https://grasswiki.osgeo.org/wiki/GRASS_messages_translation#Get_the_translated_po_files"
exit 1;
fi
