[GRASS-SVN] r70919 - grass/trunk/locale/po
Sat Apr 22 07:06:08 PDT 2017
Author: neteler
Date: 2017-04-22 07:06:08 -0700 (Sat, 22 Apr 2017)
New Revision: 70919
   grass/trunk/locale/po/grasslibs_pt_br.po
   grass/trunk/locale/po/grasslibs_sl.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_sl.po
po files: convert to UTF-8 for transifex compatibility
Modified: grass/trunk/locale/po/grasslibs_pt_br.po
--- grass/trunk/locale/po/grasslibs_pt_br.po	2017-04-22 13:47:15 UTC (rev 70918)
+++ grass/trunk/locale/po/grasslibs_pt_br.po	2017-04-22 14:06:08 UTC (rev 70919)
@@ -1,4 +1,4 @@
-# translation of grasslibs_pt_br.po to Português Brasileiro
+# translation of grasslibs_pt_br.po to Português Brasileiro
 # translation of grasslibs_pt_br.po to Brazilian Portuguese
 # This file is distributed under the same license as the GRASS package.
 # Copyright (C) 2004 GRASS Development Team
@@ -16,7 +16,7 @@
 "Language-Team: Brazilian Portuguese <grass-translations at lists.osgeo.org>\n"
 "Language: pt_BR\n"
 "MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=ISO-8859-1\n"
+"Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "com>\n"
 "X-Generator: KBabel 1.9.1\n"
@@ -25,24 +25,24 @@
 #: ../lib/symbol/read.c:211
 #, c-format
 msgid "Cannot read symbol line coordinates: %s"
-msgstr "Não consegui ler coordenadas da linha de símbolos: %s"
+msgstr "Não consegui ler coordenadas da linha de símbolos: %s"
 #: ../lib/symbol/read.c:260
 #, c-format
 msgid ""
 "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr "Nome de símbolo incorreto: '%s' (deveria ser: grupo/"
+msgstr "Nome de símbolo incorreto: '%s' (deveria ser: grupo/"
 #: ../lib/symbol/read.c:284
 #, c-format
 msgid "Cannot find/open symbol: '%s'"
-msgstr "não consegui encontrar/abrir símbolo: '%s'"
+msgstr "não consegui encontrar/abrir símbolo: '%s'"
 #: ../lib/symbol/read.c:393 ../lib/symbol/read.c:411 ../lib/symbol/read.c:421
 #: ../lib/symbol/read.c:439
 #, c-format
 msgid "Incorrect symbol color: '%s', using default."
-msgstr "Símbolo de cor incorreto: '%s', usando padrão"
+msgstr "Símbolo de cor incorreto: '%s', usando padrão"
 #: ../lib/ogsf/gv3.c:60 ../lib/ogsf/gv3.c:333 ../lib/ogsf/gp3.c:56
 #: ../lib/ogsf/gp3.c:191 ../lib/manage/do_remove.c:57
@@ -51,7 +51,7 @@
 #: ../lib/vector/Vlib/open.c:235
 #, fuzzy, c-format
 msgid "Vector map <%s> not found"
-msgstr "Vetor de entrada '%s' não encontrado"
+msgstr "Vetor de entrada '%s' não encontrado"
 #: ../lib/ogsf/gv3.c:66 ../lib/ogsf/gv3.c:338 ../lib/ogsf/gp3.c:62
 #: ../lib/ogsf/gp3.c:196 ../lib/python/temporal/c_libraries_interface.py:747
@@ -60,7 +60,7 @@
 #: ../lib/vector/Vlib/open.c:437
 #, fuzzy, c-format, python-format
 msgid "Unable to open vector map <%s>"
-msgstr "Impossível mudar de diretório para %s"
+msgstr "Impossível mudar de diretório para %s"
 #: ../lib/ogsf/gv3.c:269
 #, c-format
@@ -70,7 +70,7 @@
 #: ../lib/ogsf/gv3.c:274
 #, fuzzy, c-format
 msgid "Vector map <%s> loaded (%d features)"
 #: ../lib/ogsf/gv3.c:344 ../lib/ogsf/gp3.c:202 ../lib/vector/Vlib/map.c:300
 #: ../lib/vector/Vlib/map.c:436 ../lib/vector/Vlib/copy.c:594
@@ -95,22 +95,22 @@
 #: ../lib/rst/interp_float/vinput2d.c:109
 #, fuzzy, c-format
 msgid "Unable to open database <%s> by driver <%s>"
-msgstr "não consegui abrir banco de dados %s"
+msgstr "não consegui abrir banco de dados %s"
 #: ../lib/ogsf/gv3.c:353
 #, fuzzy, c-format
 msgid "Loading thematic vector layer <%s>..."
-msgstr "Carregando mapa raster <%s> na memória"
+msgstr "Carregando mapa raster <%s> na memória"
 #: ../lib/ogsf/gv3.c:377 ../lib/ogsf/gp3.c:235
 #, fuzzy, c-format
 msgid "No color rule defined for category %d"
 #: ../lib/ogsf/gv3.c:392 ../lib/ogsf/gp3.c:249
 #, fuzzy, c-format
 msgid "Invalid color definition (%s)"
-msgstr "Coordenadas inválidas"
+msgstr "Coordenadas inválidas"
 #: ../lib/ogsf/gv3.c:414
 #, c-format
@@ -143,27 +143,27 @@
 #: ../lib/rst/interp_float/output2d.c:491
 #, fuzzy, c-format
 msgid "Raster map <%s> not found"
 #: ../lib/ogsf/gsd_legend.c:246
 #, fuzzy, c-format
 msgid "Unable to read color file of raster map <%s>"
-msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
+msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
 #: ../lib/ogsf/gsd_legend.c:252
 #, fuzzy, c-format
 msgid "Unable to read category file of raster map <%s>"
 #: ../lib/ogsf/gsd_legend.c:269
 #, fuzzy, c-format
 msgid "Unable to read fp range of raster map <%s>"
 #: ../lib/ogsf/gsd_legend.c:281
 #, fuzzy, c-format
 msgid "Unable to read range of raster map <%s>"
 #: ../lib/ogsf/gsd_legend.c:295
 msgid "Range request error for legend"
@@ -172,12 +172,12 @@
 #: ../lib/ogsf/gsd_legend.c:385
 #, fuzzy
 msgid "Unable to show discrete FP range (use list)"
-msgstr "não consegui escrever os links para o banco de dados"
+msgstr "não consegui escrever os links para o banco de dados"
 #: ../lib/ogsf/gsd_legend.c:501
 #, fuzzy
 msgid "Too many categories to show as discrete!"
-msgstr "Categorias de reclassificação demais para [%s em %s]"
+msgstr "Categorias de reclassificação demais para [%s em %s]"
 #: ../lib/ogsf/gsd_legend.c:503
 msgid "Try using smaller font!"
@@ -187,7 +187,7 @@
 #: ../lib/ogsf/gsd_img_tif.c:66 ../lib/ogsf/gk2.c:216
 #, fuzzy, c-format
 msgid "Unable to open file <%s> for writing"
-msgstr "não consegui abrir %s para escrita"
+msgstr "não consegui abrir %s para escrita"
 #: ../lib/ogsf/trans.c:180
 msgid "Out of matrix stack space"
@@ -223,7 +223,7 @@
 #, fuzzy, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
 msgstr ""
-"[%s] no mapset [%s] - está em uma zona diferente [%d] da região atual [%d]"
+"[%s] no mapset [%s] - está em uma zona diferente [%d] da região atual [%d]"
 #: ../lib/ogsf/gs2.c:1733 ../lib/ogsf/gs2.c:1739 ../lib/ogsf/gs2.c:1747
 #: ../lib/ogsf/gs2.c:1756 ../lib/ogsf/gs2.c:1764 ../lib/ogsf/gs2.c:1774
@@ -234,7 +234,7 @@
 #: ../lib/ogsf/gs2.c:1850
 #, fuzzy
 msgid "Loading failed"
-msgstr "Falha na conexão.\n"
+msgstr "Falha na conexão.\n"
 #: ../lib/ogsf/gs2.c:1854
 #, fuzzy
@@ -245,7 +245,7 @@
 #: ../lib/ogsf/gs3.c:454 ../lib/ogsf/gs3.c:540
 #, fuzzy, c-format
 msgid "Loading raster map <%s>..."
 #: ../lib/ogsf/gs3.c:596
 #, c-format
@@ -273,7 +273,7 @@
 #: ../lib/vector/Vlib/copy.c:245
 #, fuzzy, c-format
 msgid "Unable to read vector map <%s>"
 #: ../lib/ogsf/gp3.c:148
 #, c-format
@@ -283,12 +283,12 @@
 #: ../lib/ogsf/gp3.c:153
 #, fuzzy, c-format
 msgid "Vector map <%s> loaded (%d points)"
 #: ../lib/ogsf/gp3.c:211
 #, fuzzy, c-format
 msgid "Loading thematic points layer <%s>..."
 #: ../lib/ogsf/gp3.c:288
 #, c-format
@@ -312,14 +312,14 @@
 #: ../lib/ogsf/gvl2.c:267
 #, fuzzy, c-format
 msgid "Loading 3d raster map <%s>..."
 #: ../lib/ogsf/gvl3.c:40 ../lib/ogsf/gvl_file.c:427
 #: ../lib/manage/do_remove.c:78 ../lib/manage/do_rename.c:76
 #: ../lib/gpde/n_arrays_io.c:273
 #, fuzzy, c-format
 msgid "3D raster map <%s> not found"
 #: ../lib/ogsf/gsd_label.c:58
 msgid "Max. number of labels reached!"
@@ -328,7 +328,7 @@
 #: ../lib/ogsf/gsdrape.c:207
 #, fuzzy
 msgid "Unable to process vector map - out of memory"
 #: ../lib/ogsf/gk2.c:272 ../lib/ogsf/gk2.c:285
 msgid "Check no. of frames requested and keyframes marked"
@@ -343,19 +343,19 @@
 #: ../lib/gpde/n_arrays_io.c:281
 msgid "Unable to open 3D raster map <%s>"
 #: ../lib/ogsf/gvl_file.c:442
 #, fuzzy, c-format
 msgid "Unable to read range of 3D raster map <%s>"
 #: ../lib/ogsf/gvl_file.c:470 ../lib/raster3d/close.c:120
 #: ../lib/raster3d/close.c:130 ../lib/raster3d/close.c:159
 #: ../lib/python/temporal/c_libraries_interface.py:706
 msgid "Unable to close 3D raster map <%s>"
 #: ../lib/ogsf/gs_bm.c:124
 msgid "Bitmap mismatch"
@@ -365,22 +365,22 @@
 #: ../lib/raster3d/close.c:105 ../lib/raster3d/close.c:191
 #, fuzzy, c-format
 msgid "Unable to write header for 3D raster map <%s>"
 #: ../lib/raster3d/range.c:73
 #, fuzzy, c-format
 msgid "Unable to open range file for [%s in %s]"
 #: ../lib/raster3d/range.c:88
 #, fuzzy, c-format
 msgid "Error reading range file for [%s in %s]"
-msgstr "não consegui ler arquivo de intervalo para [%s em %s]"
+msgstr "não consegui ler arquivo de intervalo para [%s em %s]"
 #: ../lib/raster3d/range.c:150
 #, fuzzy, c-format
 msgid "Unable to open range file for <%s>"
-msgstr "Não consegui abrir histórico para o vetor %s"
+msgstr "Não consegui abrir histórico para o vetor %s"
 #: ../lib/raster3d/open.c:20
 #, fuzzy
@@ -405,7 +405,7 @@
 #: ../lib/raster3d/open.c:98
 #, fuzzy
 msgid "Rast3d_open_cell_old: can't rewind file"
-msgstr "Rast3d_openCellOld: não posso rebobinar aquivo"
+msgstr "Rast3d_openCellOld: não posso rebobinar aquivo"
 #: ../lib/raster3d/open.c:111
 #, fuzzy
@@ -415,22 +415,22 @@
 #: ../lib/raster3d/open.c:119
 #, fuzzy
 msgid "Rast3d_open_cell_old: projection does not match window projection"
-msgstr "Rast3d_openCellOld: projeção não coincide com a projeção na janela"
+msgstr "Rast3d_openCellOld: projeção não coincide com a projeção na janela"
 #: ../lib/raster3d/open.c:123
 #, fuzzy
 msgid "Rast3d_open_cell_old: zone does not match window zone"
-msgstr "Rast3d_openCellOld: zona não coincide com a zona da janela"
+msgstr "Rast3d_openCellOld: zona não coincide com a zona da janela"
 #: ../lib/raster3d/open.c:135 ../lib/raster3d/open.c:152
 #, fuzzy
 msgid "Rast3d_open_cell_old: can't read header"
-msgstr "Rast3d_openCellOld: não consigo ler cabeçalho"
+msgstr "Rast3d_openCellOld: não consigo ler cabeçalho"
 #: ../lib/raster3d/open.c:141
 #, fuzzy
 msgid "Rast3d_open_cell_old: index does not fit into long"
-msgstr "Rast3d_openCellOld: index não cabe num long"
+msgstr "Rast3d_openCellOld: index não cabe num long"
 #: ../lib/raster3d/open.c:145
 #, fuzzy
@@ -455,17 +455,17 @@
 #: ../lib/raster3d/open.c:233
 #, fuzzy, c-format
 msgid "map <%s> is not in the current mapset"
-msgstr "Bug: tentativa de atualizar mapa que não está no mapset atual."
+msgstr "Bug: tentativa de atualizar mapa que não está no mapset atual."
 #: ../lib/raster3d/open.c:243
 #, fuzzy
 msgid "Rast3d_open_cell_new: could not open file"
-msgstr "Rast3d_openCellNew: não consegui abrir arquivo"
+msgstr "Rast3d_openCellNew: não consegui abrir arquivo"
 #: ../lib/raster3d/open.c:287 ../lib/raster3d/open.c:292
 #, fuzzy
 msgid "Rast3d_open_cell_new: can't write header"
-msgstr "Rast3d_openCellNew: não consegui escrever cabeçalho"
+msgstr "Rast3d_openCellNew: não consegui escrever cabeçalho"
 #: ../lib/raster3d/open.c:314
 #, fuzzy
@@ -475,32 +475,32 @@
 #: ../lib/raster3d/close.c:47
 #, fuzzy, c-format
 msgid "Unable to write history for 3D raster map <%s>"
 #: ../lib/raster3d/close.c:62
 #, fuzzy, c-format
 msgid "Unable to move temp raster map <%s> to 3D raster map <%s>"
-msgstr "não foi possível abrir o mapa raster [%s em %s]"
+msgstr "não foi possível abrir o mapa raster [%s em %s]"
 #: ../lib/raster3d/close.c:79
 #, fuzzy
 msgid "Unable to flush all tiles"
-msgstr "não foi possível abrir o arquivo %s em %s"
+msgstr "não foi possível abrir o arquivo %s em %s"
 #: ../lib/raster3d/close.c:84
 #, fuzzy
 msgid "Unable to flush index"
-msgstr "não consegui encontrar [%s]"
+msgstr "não consegui encontrar [%s]"
 #: ../lib/raster3d/close.c:94
 #, fuzzy
 msgid "Unable to position file"
 #: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
 #, fuzzy, c-format
 msgid "Unable to create 3D raster map <%s>"
 #: ../lib/raster3d/close.c:169
 #, fuzzy
@@ -518,7 +518,7 @@
 #: ../lib/raster3d/history.c:43
 #, c-format
 msgid "can't get history information for [%s] in mapset [%s]"
-msgstr "não consegui obter dados históricos para [%s] no mapset [%s]"
+msgstr "não consegui obter dados históricos para [%s] no mapset [%s]"
 #: ../lib/raster3d/param.c:84
 msgid "Rast3d_get_standard3d_params: precision value invalid"
@@ -530,12 +530,12 @@
 #: ../lib/raster3d/param.c:129
 msgid "Window replacing the default"
-msgstr "Janela substituindo o padrão"
+msgstr "Janela substituindo o padrão"
 #: ../lib/raster3d/color.c:354
 #, fuzzy, c-format
 msgid "mapset <%s> is not the current mapset"
 #: ../lib/raster3d/maskfn.c:77
 #, c-format
@@ -550,22 +550,22 @@
 #: ../lib/imagery/iscatt_core.c:81
 #, fuzzy, c-format
 msgid "Unable to write header into category raster condition file <%s>."
 #: ../lib/imagery/iscatt_core.c:98
 #, fuzzy, c-format
 msgid "Unable to write into category raster condition file <%s>."
-msgstr "não consegui escrever os dados históricos para [%s]"
+msgstr "não consegui escrever os dados históricos para [%s]"
 #: ../lib/imagery/iscatt_core.c:255
 #, fuzzy, c-format
 msgid "Unable to open category raster condtions file <%s>."
-msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
+msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
 #: ../lib/imagery/iscatt_core.c:263
 #, fuzzy, c-format
 msgid "Unable to find patch raster <%s>."
 #: ../lib/imagery/iscatt_core.c:280
 #, c-format
@@ -580,12 +580,12 @@
 #: ../lib/imagery/iscatt_core.c:338
 #, fuzzy, c-format
 msgid "Unable to write into category raster conditions file <%s>"
 #: ../lib/imagery/iscatt_core.c:526
 #, fuzzy
 msgid "Unable to read from category raster condtition file."
 #: ../lib/imagery/iscatt_core.c:533
 msgid "Invalid size of category raster conditions file."
@@ -600,27 +600,27 @@
 #: ../lib/imagery/iscatt_core.c:745
 #, fuzzy, c-format
 msgid "Unbale to read find raster <%s>"
 #: ../lib/imagery/iscatt_core.c:755
 #, fuzzy, c-format
 msgid "Unbale to open raster <%s>"
 #: ../lib/imagery/iscatt_core.c:761
 #, fuzzy, c-format
 msgid "Raster <%s> type is not <%s>"
 #: ../lib/imagery/iscatt_core.c:775
 #, fuzzy, c-format
 msgid "Unable to read range of raster <%s>"
 #: ../lib/imagery/iscatt_core.c:803
 #, fuzzy, c-format
 msgid "Unable to open category raster condtition file <%s>"
 #: ../lib/imagery/iscatt_core.c:817
 msgid "Corrupted category raster conditions file (fseek failed)"
@@ -638,7 +638,7 @@
 #: ../lib/imagery/target.c:38
 #, fuzzy, c-format
 msgid "Unable to read target file for group [%s]"
-msgstr "não consegui criar o cabeçalho para o arquivo [%s]"
+msgstr "não consegui criar o cabeçalho para o arquivo [%s]"
 #: ../lib/imagery/georef_tps.c:219
 msgid "Calculating forward transformation coefficients"
@@ -675,17 +675,17 @@
 #: ../lib/imagery/points.c:124
 #, fuzzy, c-format
 msgid "Unable to open control point file for group [%s in %s]"
 #: ../lib/imagery/points.c:132
 #, fuzzy, c-format
 msgid "Bad format in control point file for group [%s in %s]"
 #: ../lib/imagery/points.c:159
 #, fuzzy, c-format
 msgid "Unable to create control point file for group [%s in %s]"
 #: ../lib/imagery/list_gp.c:34
 #, c-format
@@ -700,27 +700,27 @@
 #: ../lib/imagery/fopen.c:23
 #, fuzzy, c-format
 msgid "Unable to create file [%s] of group [%s in %s]"
 #: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
 #, fuzzy, c-format
 msgid "Unable to open file [%s] of group [%s in %s]"
 #: ../lib/imagery/fopen.c:49
 #, fuzzy, c-format
 msgid "Unable to find file [%s] of group [%s in %s]"
-msgstr "não consegui encontrar [%s] em [%s]"
+msgstr "não consegui encontrar [%s] em [%s]"
 #: ../lib/imagery/fopen.c:79
 #, fuzzy, c-format
 msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
 #: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
 #, fuzzy, c-format
 msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
 #: ../lib/imagery/fopen.c:116
 #, c-format
@@ -747,27 +747,27 @@
 #: ../lib/imagery/iclass_statistics.c:758
 #, fuzzy
 msgid "Band index out of range"
-msgstr "Dimensões da matriz além dos limites"
+msgstr "Dimensões da matriz além dos limites"
 #: ../lib/imagery/iclass_statistics.c:684
 #, fuzzy
 msgid "Cell category value out of range"
 #: ../lib/imagery/iclass.c:83
 #, fuzzy, c-format
 msgid "No areas in category %d"
 #: ../lib/imagery/iclass.c:127
 #, fuzzy, c-format
 msgid "Raster map <%s@%s> in subgroup <%s> does not exist"
 #: ../lib/imagery/iclass.c:131
 #, fuzzy, c-format
 msgid "Raster map <%s@%s> in group <%s> does not exist"
 #: ../lib/imagery/iclass.c:143
 #, c-format
@@ -794,17 +794,17 @@
 msgid ""
 "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
 "is not current mapset"
 #: ../lib/imagery/sigsetfile.c:57
 #, fuzzy, c-format
 msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
 #: ../lib/imagery/iclass_signatures.c:120
 #, fuzzy, c-format
 msgid "Unable to open output signature file '%s'"
 #: ../lib/psdriver/graph_set.c:199
 #, c-format
@@ -832,7 +832,7 @@
 #: ../lib/cairodriver/text.c:46
 #, fuzzy, c-format
 msgid "Unable to convert from <%s> to UTF-8"
 #: ../lib/cairodriver/text.c:56
 msgid "Some characters could not be converted to UTF-8"
@@ -841,22 +841,22 @@
 #: ../lib/cairodriver/write_ppm.c:27 ../lib/cairodriver/write_bmp.c:72
 #, fuzzy, c-format
 msgid "Cairo: unable to open output file <%s>"
 #: ../lib/cairodriver/write_ppm.c:34
 #, fuzzy, c-format
 msgid "Cairo: unable to open mask file <%s>"
-msgstr "G_spawn: não consegui abrir o arquivo %s"
+msgstr "G_spawn: não consegui abrir o arquivo %s"
 #: ../lib/cairodriver/read_ppm.c:28 ../lib/cairodriver/read_bmp.c:88
 #, fuzzy, c-format
 msgid "Cairo: unable to open input file <%s>"
 #: ../lib/cairodriver/read_ppm.c:32 ../lib/cairodriver/read_bmp.c:92
 #, fuzzy, c-format
 msgid "Cairo: invalid input file <%s>"
-msgstr "não consegui encontrar mapa de entrada '%s'"
+msgstr "não consegui encontrar mapa de entrada '%s'"
 #: ../lib/cairodriver/read_ppm.c:38
 #, c-format
@@ -866,12 +866,12 @@
 #: ../lib/cairodriver/read_ppm.c:46
 #, fuzzy, c-format
 msgid "Cairo: unable to open input mask file <%s>"
 #: ../lib/cairodriver/read_ppm.c:50
 #, fuzzy, c-format
 msgid "Cairo: invalid input mask file <%s>"
 #: ../lib/cairodriver/read_ppm.c:56
 #, c-format
@@ -882,32 +882,32 @@
 #: ../lib/cairodriver/read_xid.c:14
 #, fuzzy, c-format
 msgid "Unable to open input file <%s>"
 #: ../lib/cairodriver/read_xid.c:17
 #, fuzzy, c-format
 msgid "Unable to read input file <%s>"
 #: ../lib/cairodriver/read_xid.c:20
 #, fuzzy, c-format
 msgid "Unable to parse input file <%s>"
 #: ../lib/cairodriver/raster.c:109
 #, fuzzy
 msgid "Failed to create cairo surface"
-msgstr "Impossível criar novo processo"
+msgstr "Impossível criar novo processo"
 #: ../lib/cairodriver/write_xid.c:14 ../lib/pngdriver/read_png.c:71
 #, fuzzy, c-format
 msgid "Unable to open output file <%s>"
 #: ../lib/cairodriver/write_xid.c:19
 #, fuzzy, c-format
 msgid "Unable to write output file <%s>"
 #: ../lib/cairodriver/read_bmp.c:96
 #, c-format
@@ -917,12 +917,12 @@
 #: ../lib/cairodriver/graph.c:67
 #, fuzzy
 msgid "Unable to open display"
-msgstr "não consegui abrir [%s]"
+msgstr "não consegui abrir [%s]"
 #: ../lib/cairodriver/graph.c:85
 #, fuzzy
 msgid "Unable to obtain visual"
 #: ../lib/cairodriver/graph.c:160
 #, c-format
@@ -932,7 +932,7 @@
 #: ../lib/cairodriver/graph.c:190
 #, fuzzy, c-format
 msgid "cairo: collecting to file '%s'"
 #: ../lib/cairodriver/graph.c:192
 #, c-format
@@ -942,12 +942,12 @@
 #: ../lib/cairodriver/graph.c:371
 #, fuzzy
 msgid "Unknown Cairo surface type"
-msgstr "Tipo de interpolação desconhecida"
+msgstr "Tipo de interpolação desconhecida"
 #: ../lib/cairodriver/graph.c:376
 #, fuzzy
 msgid "Failed to initialize Cairo surface"
 #: ../lib/cairodriver/draw_bitmap.c:47
 msgid "Cairo_Bitmap: Failed to create source"
@@ -984,7 +984,7 @@
 #: ../lib/python/pygrass/raster/category.py:69
 #, fuzzy, python-brace-format
 msgid "Raster type: {0} not supported"
-msgstr "Feição OGR tipo %d não suportada)"
+msgstr "Feição OGR tipo %d não suportada)"
 #: ../lib/python/pygrass/raster/category.py:156
 msgid "Error executing: Rast_get_ith_cat"
@@ -1003,12 +1003,12 @@
 #: ../lib/python/pygrass/raster/abstract.py:275
 msgid "Mode type: {0} not supported ('r', 'w')"
 #: ../lib/python/pygrass/raster/abstract.py:286
 msgid "Overwrite type: {0} not supported (True/False)"
 #: ../lib/python/pygrass/raster/abstract.py:299
 #: ../lib/python/pygrass/vector/abstract.py:97
@@ -1023,12 +1023,12 @@
 #: ../lib/python/pygrass/raster/__init__.py:214
 msgid "Raster map <{0}> already exists and will be not overwritten"
-msgstr "O vetor '%s' já existe e será sobrescrito."
+msgstr "O vetor '%s' já existe e será sobrescrito."
 #: ../lib/python/pygrass/raster/__init__.py:218
 #, fuzzy
 msgid "Raster type not defined"
-msgstr "Ignorando feição OGR sem ID"
+msgstr "Ignorando feição OGR sem ID"
 #: ../lib/python/pygrass/raster/__init__.py:321
 #, python-brace-format
@@ -1038,17 +1038,17 @@
 #: ../lib/python/pygrass/raster/__init__.py:341
 #, fuzzy, python-format
 msgid "Index out of range: %r."
 #: ../lib/python/pygrass/raster/__init__.py:530
 msgid "Raster map <{0}> already exists. Use overwrite."
 #: ../lib/python/pygrass/raster/__init__.py:561
 msgid "Raster map <{0}> does not exist"
 #: ../lib/python/pygrass/vector/table.py:1035
 #, python-format
@@ -1062,12 +1062,12 @@
 #: ../lib/python/pygrass/vector/__init__.py:806
 msgid "Unable to read line of feature %i"
-msgstr "não consegui abrir arquivo temporário"
+msgstr "não consegui abrir arquivo temporário"
 #: ../lib/python/pygrass/vector/__init__.py:895
 msgid "Unable to read area with id %i"
 #: ../lib/python/pygrass/modules/grid/grid.py:553
 msgid "Execution of subprocesses was not successful"
@@ -1090,7 +1090,7 @@
 #: ../lib/python/temporal/temporal_algebra.py:2313
 msgid "%s map <%s> not found in GRASS spatial database"
 #: ../lib/python/temporal/datetime_math.py:256
 #: ../lib/python/temporal/datetime_math.py:273
@@ -1111,52 +1111,52 @@
 #: ../lib/python/temporal/datetime_math.py:741
 #, fuzzy
 msgid "Dates Before Christ (BC) are not supported"
-msgstr "Vect_write_line() não é suportada para este nível/formato"
+msgstr "Vect_write_line() não é suportada para este nível/formato"
 #: ../lib/python/temporal/datetime_math.py:745
 #, fuzzy
 msgid "Time zones are not supported"
 #: ../lib/python/temporal/datetime_math.py:755
 msgid "Unable to parse time string: %s"
 #: ../lib/python/temporal/stds_import.py:85
 msgid "Unable to import/link raster map <%s> from file %s."
 #: ../lib/python/temporal/stds_import.py:96
 msgid "Unable to set the color rules for raster map <%s>."
 #: ../lib/python/temporal/stds_import.py:120
 msgid "Unable to unpack raster map <%s> from file %s."
 #: ../lib/python/temporal/stds_import.py:144
 msgid "Unable to import vector map <%s> from file %s."
 #: ../lib/python/temporal/stds_import.py:168
 msgid "Unable to unpack vector map <%s> from file %s."
 #: ../lib/python/temporal/stds_import.py:207
 msgid "Space time raster dataset archive <%s> not found"
 #: ../lib/python/temporal/stds_import.py:210
 msgid "Extraction directory <%s> not found"
 #: ../lib/python/temporal/stds_import.py:216
 #, python-format
@@ -1166,17 +1166,17 @@
 #: ../lib/python/temporal/stds_import.py:223
 msgid "Unable to find init file <%s>"
 #: ../lib/python/temporal/stds_import.py:225
 msgid "Unable to find list file <%s>"
 #: ../lib/python/temporal/stds_import.py:227
 msgid "Unable to find projection file <%s>"
 #: ../lib/python/temporal/stds_import.py:229
 #, fuzzy
@@ -1201,17 +1201,17 @@
 #: ../lib/python/temporal/stds_import.py:293
 msgid "Unable to create location %(l)s. Reason: %(e)s"
 #: ../lib/python/temporal/stds_import.py:301
 msgid "Unable to switch to location %s"
 #: ../lib/python/temporal/stds_import.py:306
 msgid "Unable to create default temporal database in new location %s"
 #: ../lib/python/temporal/stds_import.py:380
 #, python-format
@@ -1229,22 +1229,22 @@
 #: ../lib/python/temporal/stds_import.py:405
 msgid "Unable to find GeoTIFF raster file <%s> in archive."
-msgstr "não foi possível encontrar o arquivo null temporário: %s"
+msgstr "não foi possível encontrar o arquivo null temporário: %s"
 #: ../lib/python/temporal/stds_import.py:411
 msgid "Unable to find AAIGrid raster file <%s> in archive."
 #: ../lib/python/temporal/stds_import.py:417
 msgid "Unable to find GML vector file <%s> in archive."
 #: ../lib/python/temporal/stds_import.py:426
 msgid "Unable to find GRASS package file <%s> in archive."
 #: ../lib/python/temporal/stds_import.py:429
 #, fuzzy
@@ -1256,22 +1256,22 @@
 msgid ""
 "Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
 "overwrite flag."
 #: ../lib/python/temporal/stds_import.py:456
 msgid "Overwrite space time %(sp)s dataset <%(id)s> and unregister all maps."
 #: ../lib/python/temporal/stds_import.py:468
 msgid "Key word %s not found in init file."
 #: ../lib/python/temporal/stds_import.py:473
 msgid "Create space time %s dataset."
 #: ../lib/python/temporal/stds_import.py:502
 msgid "Switching to original location failed"
@@ -1296,7 +1296,7 @@
 msgid ""
 "Error vector map %s exist in temporal database. Use overwrite flag.  : \n"
 "%s"
 #: ../lib/python/temporal/core.py:604
 msgid ""
@@ -1309,7 +1309,7 @@
 msgid ""
 "Unable to receive temporal database metadata.\n"
 "Current temporal database info:%(info)s"
 #: ../lib/python/temporal/core.py:672
@@ -1318,7 +1318,7 @@
 " %(backup)s Supported temporal API version is: %(api)i.\n"
 "Please update your GRASS GIS installation.\n"
 #: ../lib/python/temporal/core.py:680
@@ -1326,12 +1326,12 @@
 "Unsupported temporal database: version mismatch.\n"
 " %(backup)sSupported temporal database version is: %(tdb)i\n"
 #: ../lib/python/temporal/core.py:768
 msgid "Creating temporal database: %s"
 #: ../lib/python/temporal/core.py:777
 #, python-format
@@ -1344,32 +1344,32 @@
 #: ../lib/python/temporal/core.py:942
 #, fuzzy
 msgid "Unable to mogrify sql statement. "
 #: ../lib/python/temporal/core.py:964
 #, fuzzy
 msgid "Unable to check table. "
 #: ../lib/python/temporal/core.py:980
 #, fuzzy
 msgid "Unable to execute sql statement. "
-msgstr "Impossível executar o comando"
+msgstr "Impossível executar o comando"
 #: ../lib/python/temporal/core.py:990
 #, fuzzy
 msgid "Unable to fetch one. "
 #: ../lib/python/temporal/core.py:1000
 #, fuzzy
 msgid "Unable to fetch all. "
 #: ../lib/python/temporal/core.py:1017
 #, fuzzy
 msgid "Unable to execute transaction. "
 #: ../lib/python/temporal/core.py:1120
 #, python-format
@@ -1384,40 +1384,40 @@
 msgid ""
 "Unable to execute :\n"
 " %(sql)s"
 #: ../lib/python/temporal/core.py:1321
 msgid ""
 "Unable to execute transaction:\n"
 " %(sql)s"
 #: ../lib/python/temporal/univar_statistics.py:62
 #: ../lib/python/temporal/univar_statistics.py:178
 msgid "Space time %(sp)s dataset <%(i)s> is empty"
 #: ../lib/python/temporal/univar_statistics.py:101
 msgid "Unable to get statistics for raster map <%s>"
 #: ../lib/python/temporal/univar_statistics.py:104
 msgid "Unable to get statistics for 3d raster map <%s>"
 #: ../lib/python/temporal/univar_statistics.py:168
 msgid "Space time %(sp)s dataset <%(i)s> not found"
 #: ../lib/python/temporal/univar_statistics.py:222
 msgid "Unable to get statistics for vector map <%s>"
 #: ../lib/python/temporal/abstract_dataset.py:386
 #, python-format
@@ -1450,7 +1450,7 @@
 #: ../lib/python/temporal/temporal_algebra.py:857
 #, fuzzy
 msgid "All input space time datasets must have the same temporal type."
 #: ../lib/python/temporal/temporal_algebra.py:1105
@@ -1460,7 +1460,7 @@
 #: ../lib/python/temporal/temporal_algebra.py:1160
 msgid "Space time %s dataset <%s> not found"
 #: ../lib/python/temporal/temporal_algebra.py:1188
 #: ../lib/python/temporal/temporal_algebra.py:1192
@@ -1473,7 +1473,7 @@
 #: ../lib/python/temporal/temporal_algebra.py:1212
 #, fuzzy
 msgid "Wrong type of input "
 #: ../lib/python/temporal/temporal_algebra.py:2104
 #, python-format
@@ -1509,7 +1509,7 @@
 #: ../lib/python/temporal/temporal_algebra.py:2361
 #, fuzzy
 msgid "Space time datasets to merge must have the same temporal type"
 #: ../lib/python/temporal/register.py:82 ../lib/python/temporal/register.py:85
 #, python-format
@@ -1541,7 +1541,7 @@
 msgid "Please specify %s= or %s="
 msgstr ""
 "\n"
-"Por favor especifique o nome do elipsóide\n"
+"Por favor especifique o nome do elipsóide\n"
 #: ../lib/python/temporal/register.py:114
 #, python-format
@@ -1566,21 +1566,21 @@
 #: ../lib/python/temporal/register.py:197
 msgid "Unable to update %(t)s map <%(id)s>. The map does not exist."
 #: ../lib/python/temporal/register.py:215
 msgid ""
 "Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
 "timestamp and the start time is not set."
 #: ../lib/python/temporal/register.py:221
 msgid ""
 "Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
 "start time is not set."
 #: ../lib/python/temporal/register.py:229
 #, python-format
@@ -1597,41 +1597,41 @@
 msgid ""
 "Map is already registered in temporal database. Unable to update %(t)s map <"
 "%(id)s> with layer %(l)s. Overwrite flag is not set."
 #: ../lib/python/temporal/register.py:252
 msgid ""
 "%(id)s>. Overwrite flag is not set."
 #: ../lib/python/temporal/register.py:276
 msgid ""
 "Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are "
 "different."
 #: ../lib/python/temporal/register.py:282
 msgid "Unable to update %(t)s map <%(id)s>. The temporal types are different."
 #: ../lib/python/temporal/register.py:330
 #, fuzzy
 msgid "Registering maps in the temporal database..."
 #: ../lib/python/temporal/register.py:337
 #, fuzzy
 msgid "Registering maps in the space time dataset..."
 #: ../lib/python/temporal/register.py:346
 #, fuzzy
 msgid "Updating space time dataset..."
-msgstr "Nome do mapa raster de elevação"
+msgstr "Nome do mapa raster de elevação"
 #: ../lib/python/temporal/register.py:399
 #: ../lib/python/temporal/register.py:406
@@ -1650,23 +1650,23 @@
 msgid ""
 "Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
 "%(end)s"
 #: ../lib/python/temporal/register.py:427
 msgid "Set absolute valid time for map <%s> to %s - %s"
 #: ../lib/python/temporal/register.py:444
 msgid ""
 "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
 #: ../lib/python/temporal/register.py:449
 msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
 #: ../lib/python/temporal/mapcalc.py:109
 msgid "Starting spatio-temporal sampling..."
@@ -1690,7 +1690,7 @@
 #: ../lib/python/temporal/mapcalc.py:173
 #, fuzzy
 msgid "No maps registered in input dataset"
 #: ../lib/python/temporal/mapcalc.py:189
 msgid "Starting mapcalc computation..."
@@ -1702,7 +1702,7 @@
 msgid ""
 "Map <%s> is already in temporal database, use overwrite flag to overwrite"
 #: ../lib/python/temporal/mapcalc.py:260
 #, python-format
@@ -1716,7 +1716,7 @@
 #: ../lib/python/temporal/mapcalc.py:285
 #, fuzzy
 msgid "Starting map registration in temporal database..."
 #: ../lib/python/temporal/mapcalc.py:442 ../lib/python/temporal/mapcalc.py:448
 #: ../lib/python/temporal/mapcalc.py:454 ../lib/python/temporal/mapcalc.py:460
@@ -1748,7 +1748,7 @@
 #: ../lib/python/temporal/sampling.py:100
 msgid "Dataset <%s> not found in temporal database"
 #: ../lib/python/temporal/gui_support.py:58 ../lib/python/script/core.py:1233
 #, python-format
@@ -1792,17 +1792,17 @@
 #: ../lib/python/temporal/space_time_datasets.py:250
 msgid "Unable to read timestamp file for raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:274
 msgid "Unable to create timestamp file for raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:279
 msgid "Invalid datetime in timestamp for raster map <%s>"
-msgstr "Arquivo de data inválido para o %s mapa %s no mapset %s"
+msgstr "Arquivo de data inválido para o %s mapa %s no mapset %s"
 #: ../lib/python/temporal/space_time_datasets.py:284
 #: ../lib/python/temporal/space_time_datasets.py:632
@@ -1813,42 +1813,42 @@
 #: ../lib/python/temporal/space_time_datasets.py:646
 msgid "Unable to remove timestamp for raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:598
 msgid "Unable to read timestamp file for 3D raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:622
 msgid "Unable to create timestamp file for 3D raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:627
 msgid "Invalid datetime in timestamp for 3D raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:906
 msgid "Unable to read timestamp file for vector map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:929
 msgid "Unable to create timestamp file for vector map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:934
 msgid "Invalid datetime in timestamp for vector map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:950
 msgid "Unable to remove timestamp for vector map <%s>"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:167
 #: ../lib/python/temporal/abstract_space_time_dataset.py:301
@@ -1870,7 +1870,7 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:372
 msgid "Created register table <%s> for space time %s  dataset <%s>"
-msgstr "não consegui escrever as regras matemáticas para o mapa %s"
+msgstr "não consegui escrever as regras matemáticas para o mapa %s"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:690
 #: ../lib/python/temporal/abstract_space_time_dataset.py:932
@@ -1885,7 +1885,7 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1499
 msgid "Unable to get map ids from register table <%s>"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1609
 #, python-format
@@ -1915,7 +1915,7 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1954
 msgid "Delete space time %s  dataset <%s> from temporal database"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1960
 #: ../lib/python/temporal/abstract_map_dataset.py:841
@@ -1928,19 +1928,19 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1973
 msgid "Drop map register table: %s"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2028
 #, fuzzy
 msgid "Error in register table request"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2057
 msgid ""
 "Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
 "the dataset does not match the current mapset"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2066
 msgid ""
@@ -1963,18 +1963,18 @@
 msgid ""
 "Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
 "%(l)s are different"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2117
 msgid ""
 "Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2132
 msgid "Set temporal unit for space time %s dataset <%s> to %s"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2142
 #, python-format
@@ -1997,7 +1997,7 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2159
 msgid "Map <%(map)s> with layer %(l)s is already registered."
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2163
 #, python-format
@@ -2017,12 +2017,12 @@
 msgid ""
 "Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
 "%(base)s>"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2230
 msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2291
 #, python-format
@@ -2035,23 +2035,23 @@
 msgid ""
 "Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
 "%(l)s"
-msgstr "não consegui criar arquivo de data para o %s mapa %s no mapset %s"
+msgstr "não consegui criar arquivo de data para o %s mapa %s no mapset %s"
 #: ../lib/python/temporal/abstract_map_dataset.py:357
 msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
 #: ../lib/python/temporal/abstract_map_dataset.py:365
 msgid ""
 "End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
 #: ../lib/python/temporal/abstract_map_dataset.py:372
 msgid "End time must be of type datetime for %(type)s map <%(id)s>"
 #: ../lib/python/temporal/abstract_map_dataset.py:381
@@ -2071,12 +2071,12 @@
 msgid ""
 "Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
 "%(l)s: %(u)s"
 #: ../lib/python/temporal/abstract_map_dataset.py:467
 msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
 #: ../lib/python/temporal/abstract_map_dataset.py:476
@@ -2106,7 +2106,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:859
 msgid "Delete %s dataset <%s> from temporal database"
 #: ../lib/python/temporal/abstract_map_dataset.py:909
 #, python-format
@@ -2118,37 +2118,37 @@
 #: ../lib/python/temporal/stds_export.py:104
 msgid "Unable to export raster map <%s>"
 #: ../lib/python/temporal/stds_export.py:115
 msgid "Unable to export color rules for raster map <%s> r.out.gdal"
 #: ../lib/python/temporal/stds_export.py:139
 msgid "Unable to export raster map <%s> with r.pack"
 #: ../lib/python/temporal/stds_export.py:167
 msgid "Unable to export vector map <%s> as GML with v.out.ogr"
 #: ../lib/python/temporal/stds_export.py:200
 msgid "Unable to export vector map <%s> with v.pack"
 #: ../lib/python/temporal/stds_export.py:226
 msgid "Unable to export raster map <%s> with r3.pack"
 #: ../lib/python/temporal/base.py:380
 #, fuzzy
 msgid "Object not found in the temporal database"
 #: ../lib/python/temporal/base.py:462 ../lib/python/temporal/base.py:513
 msgid "Missing identifier"
@@ -2157,7 +2157,7 @@
 #: ../lib/python/temporal/base.py:621
 #, fuzzy
 msgid "Wrong identifier, the mapset is missing"
 #: ../lib/python/temporal/aggregation.py:127
@@ -2169,7 +2169,7 @@
 msgid ""
 "Raster map <%(name)s> is already in temporal database, use overwrite flag to "
 "overwrite"
 #: ../lib/python/temporal/aggregation.py:146
 #, python-format
@@ -2209,30 +2209,30 @@
 #: ../lib/python/temporal/open_stds.py:69
 msgid "Space time %(sp)s dataset <%(name)s> not found"
 #: ../lib/python/temporal/open_stds.py:108
 #, fuzzy
 msgid "Space time datasets can only be created in the current mapset"
 #: ../lib/python/temporal/open_stds.py:125
 msgid ""
 "Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
 "overwrite flag."
 #: ../lib/python/temporal/open_stds.py:160
 msgid ""
 "Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
 #: ../lib/python/temporal/open_stds.py:168
 msgid "Creating a new space time %s dataset"
 #: ../lib/python/temporal/extract.py:60
 msgid "You need to specify the base name of new created maps"
@@ -2262,12 +2262,12 @@
 #: ../lib/python/temporal/c_libraries_interface.py:613
 #, fuzzy
 msgid "Unable to read range file"
 #: ../lib/python/temporal/c_libraries_interface.py:691
 msgid "Unable to load range of 3D raster map <%s>"
 #: ../lib/python/script/raster3d.py:92
 #, python-format
@@ -2303,7 +2303,7 @@
 #: ../lib/python/script/core.py:1372
 #, fuzzy
 msgid "Unable to list mapsets"
 #: ../lib/python/script/core.py:1411
 #, python-format
@@ -2313,7 +2313,7 @@
 #: ../lib/python/script/core.py:1414
 msgid "Location <%s> already exists and will be overwritten"
 #: ../lib/python/script/core.py:1538
 msgid "Debug level {}"
@@ -2326,12 +2326,12 @@
 #: ../lib/python/script/core.py:1557
 msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
-msgstr "Nome de arquivo ilegal. não pode ser '.' ou 'NULL'\n"
+msgstr "Nome de arquivo ilegal. não pode ser '.' ou 'NULL'\n"
 #: ../lib/python/script/core.py:1566
 msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
-msgstr "Nome de arquivo ilegal. O caractere <%c> não é permitido.\n"
+msgstr "Nome de arquivo ilegal. O caractere <%c> não é permitido.\n"
 #: ../lib/python/script/vector.py:88
 #, python-format
@@ -2365,7 +2365,7 @@
 "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
 "current mapset."
 msgstr ""
-"não consegui apagar a linha, o mapa '%s' não está aberto em modo de escrita"
+"não consegui apagar a linha, o mapa '%s' não está aberto em modo de escrita"
 #: ../lib/python/script/raster.py:113
 #, python-format
@@ -2393,7 +2393,7 @@
 #: ../lib/vector/Vlib/write_pg.c:666 ../lib/vector/Vlib/ascii.c:428
 msgid "Unable to describe table <%s>"
 #: ../lib/python/script/db.py:153
 #, python-format
@@ -2404,20 +2404,20 @@
 #: ../lib/python/script/db.py:163
 #, fuzzy
 msgid "Fetching data failed"
 #: ../lib/python/script/array.py:157 ../lib/python/script/array.py:207
 #: ../lib/python/script/array.py:254 ../lib/python/script/array.py:305
 #: ../lib/python/script/array.py:356 ../lib/python/script/array.py:398
 msgid "Invalid kind <%s>"
 #: ../lib/python/script/array.py:160 ../lib/python/script/array.py:210
 #: ../lib/python/script/array.py:308 ../lib/python/script/array.py:359
 msgid "Invalid size <%d>"
 #: ../lib/python/script/array.py:197
 msgid ""
@@ -2428,12 +2428,12 @@
 #: ../lib/python/script/array.py:247 ../lib/python/script/array.py:392
 msgid "Invalid FP size <%d>"
 #: ../lib/python/script/array.py:251 ../lib/python/script/array.py:395
 msgid "Invalid integer size <%d>"
 #: ../lib/python/script/array.py:346
 msgid ""
@@ -2454,7 +2454,7 @@
 #: ../lib/python/script/task.py:191
 msgid "Flag not found: %s"
-msgstr "%s não encontrado"
+msgstr "%s não encontrado"
 #: ../lib/python/script/task.py:210
 #, python-format
@@ -2464,7 +2464,7 @@
 #: ../lib/python/script/task.py:243
 #, fuzzy
 msgid "<required>"
-msgstr "obrigatória: %s\n"
+msgstr "obrigatória: %s\n"
 #: ../lib/python/script/task.py:503 ../lib/python/script/task.py:507
 #, python-format
@@ -2498,7 +2498,7 @@
 "%s"
 msgstr ""
 "\n"
-"FLAG: forneça o flag seguinte?\n"
+"FLAG: forneça o flag seguinte?\n"
 #: ../lib/python/exceptions/__init__.py:75
 msgid ". See errors in the (error) output."
@@ -2577,14 +2577,14 @@
 msgid ""
 "\n"
 "++ Running blas level 3 unit tests ++"
 #: ../lib/gmath/test/test_blas3.c:44
 #, fuzzy
 msgid ""
 "\n"
 "-- blas level 3 unit tests failure --"
 #: ../lib/gmath/test/test_blas3.c:46
 msgid ""
@@ -2615,14 +2615,14 @@
 msgid ""
 "\n"
 "++ Running blas level 1 unit tests ++"
 #: ../lib/gmath/test/test_blas1.c:47
 #, fuzzy
 msgid ""
 "\n"
 "-- blas level 1 unit tests failure --"
 #: ../lib/gmath/test/test_blas1.c:49
 msgid ""
@@ -2647,14 +2647,14 @@
 msgid ""
 "\n"
 "++ Running blas level 2 unit tests ++"
 #: ../lib/gmath/test/test_blas2.c:44
 #, fuzzy
 msgid ""
 "\n"
 "-- blas level 2 unit tests failure --"
 #: ../lib/gmath/test/test_blas2.c:46
 msgid ""
@@ -2690,12 +2690,12 @@
 #: ../lib/gmath/test/test_main.c:83 ../lib/db/dbmi_base/test/test_main.c:62
 #, fuzzy
 msgid "Run all integration tests"
 #: ../lib/gmath/test/test_main.c:87 ../lib/db/dbmi_base/test/test_main.c:66
 #, fuzzy
 msgid "Run all unit and integration tests"
 #: ../lib/gmath/test/test_main.c:106
 msgid "Performs benchmarks, unit and integration tests for the gmath library"
@@ -2712,42 +2712,42 @@
 msgid ""
 "\n"
 "++ Running ccmath wrapper unit tests ++"
 #: ../lib/gmath/test/test_ccmath_wrapper.c:42
 #, fuzzy
 msgid ""
 "\n"
 "-- ccmath wrapper unit tests failure --"
 #: ../lib/gmath/test/test_ccmath_wrapper.c:44
 #, fuzzy
 msgid ""
 "\n"
 "-- ccmath wrapper unit tests finished successfully --"
 #: ../lib/gmath/test/test_matrix_conversion.c:37
 #, fuzzy
 msgid ""
 "\n"
 "++ Running matrix conversion unit tests ++"
 #: ../lib/gmath/test/test_matrix_conversion.c:42
 #, fuzzy
 msgid ""
 "\n"
 "-- Matrix conversion unit tests failure --"
 #: ../lib/gmath/test/test_matrix_conversion.c:44
 #, fuzzy
 msgid ""
 "\n"
 "-- Matrix conversion unit tests finished successfully --"
 #: ../lib/gmath/solvers_classic_iter.c:84
 #, c-format
@@ -2771,20 +2771,20 @@
 #: ../lib/gmath/la.c:61 ../lib/gmath/la.c:117
 msgid "Matrix dimensions out of range"
 #: ../lib/gmath/la.c:150
 msgid "Matrix is not initialised fully."
-msgstr "Matrix não completamente inicializada"
+msgstr "Matrix não completamente inicializada"
 #: ../lib/gmath/la.c:155
 msgid "Unable to allocate space for matrix copy"
-msgstr "Não consegui alocar espaço para cópia da matriz"
+msgstr "Não consegui alocar espaço para cópia da matriz"
 #: ../lib/gmath/la.c:220
 #, fuzzy
 msgid "Input matrix is uninitialized"
 #: ../lib/gmath/la.c:285
 msgid "First scalar multiplier must be non-zero"
@@ -2800,11 +2800,11 @@
 #: ../lib/gmath/la.c:310
 msgid "Unable to allocate space for matrix sum"
-msgstr "Não consegui alocar espaço para soma da matriz"
+msgstr "Não consegui alocar espaço para soma da matriz"
 #: ../lib/gmath/la.c:374
 msgid "Unable to allocate space for matrix product"
-msgstr "Não consegui alocar espaço para multiplicar matrizes"
+msgstr "Não consegui alocar espaço para multiplicar matrizes"
 #: ../lib/gmath/la.c:486
 msgid "Input: one or both data matrices uninitialised"
@@ -2844,7 +2844,7 @@
 #: ../lib/gmath/la.c:619
 msgid "Unable to allocate space for matrix"
-msgstr "Impossível alocar espaço para a matriz"
+msgstr "Impossível alocar espaço para a matriz"
 #: ../lib/gmath/la.c:636
 msgid "Matrix is singular"
@@ -2930,7 +2930,7 @@
 #: ../lib/gmath/la.c:1371
 #, fuzzy
 msgid "Output vector is not the same type as others"
 #: ../lib/gmath/la.c:1437
 msgid "Vector structure is not initialised"
@@ -2966,12 +2966,12 @@
 #: ../lib/lidar/raster.c:175
 #, fuzzy, c-format
 msgid "Unable to access table <%s>"
 #: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
 #, fuzzy, c-format
 msgid "<%s> created in database."
 #: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
 #, c-format
@@ -2989,17 +2989,17 @@
 #: ../lib/db/dbmi_base/legal_dbname.c:38
 #, fuzzy, c-format
 msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
-msgstr "Nome de tabela de mapa <%s> ilegal. Não pode conter '.' ou 'NULL'.\n"
+msgstr "Nome de tabela de mapa <%s> ilegal. Não pode conter '.' ou 'NULL'.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:45
 #, fuzzy, c-format
 msgid "Illegal table map name <%s>. Must start with a letter."
-msgstr "Nome de tabela de mapa Ilegal <%s>. Deve começar com uma letra.\n"
+msgstr "Nome de tabela de mapa Ilegal <%s>. Deve começar com uma letra.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:54
 #, fuzzy, c-format
 msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr "Nome de tabela de mapa <%s> ilegal. Caractere <%c> não permitido.\n"
+msgstr "Nome de tabela de mapa <%s> ilegal. Caractere <%c> não permitido.\n"
 #: ../lib/db/dbmi_base/valuefmt.c:52
 msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
@@ -3016,7 +3016,7 @@
 #: ../lib/db/dbmi_base/login.c:115
 #, fuzzy, c-format
 msgid "Unable to read file '%s'"
 #: ../lib/db/dbmi_base/login.c:126
 #, c-format
@@ -3026,66 +3026,66 @@
 #: ../lib/db/dbmi_base/login.c:164
 #, fuzzy, c-format
 msgid "Unable to write file '%s'"
 #: ../lib/db/dbmi_base/login.c:229
 #, fuzzy, c-format
 msgid "DB connection <%s/%s> already exists and will be overwritten"
 #: ../lib/db/dbmi_base/login.c:232
 #, fuzzy, c-format
 msgid ""
 "DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to "
 "overwrite existing settings."
 #: ../lib/db/dbmi_base/test/test_table.c:38
 #, fuzzy
 msgid ""
 "\n"
 "++ Running table unit tests ++"
 #: ../lib/db/dbmi_base/test/test_table.c:43
 #, fuzzy
 msgid ""
 "\n"
 "-- Table unit tests failure --"
 #: ../lib/db/dbmi_base/test/test_table.c:45
 #, fuzzy
 msgid ""
 "\n"
 "-- Table unit tests finished successfully --"
 #: ../lib/db/dbmi_base/test/test_main.c:83
 #, fuzzy
 msgid "Performs unit and integration tests for the dbmi base library"
 #: ../lib/db/dbmi_base/test/test_columns.c:37
 #, fuzzy
 msgid ""
 "\n"
 "++ Running column unit tests ++"
 #: ../lib/db/dbmi_base/test/test_columns.c:42
 #, fuzzy
 msgid ""
 "\n"
 "-- column unit tests failure --"
 #: ../lib/db/dbmi_base/test/test_columns.c:44
 #, fuzzy
 msgid ""
 "\n"
 "-- column unit tests finished successfully --"
 #: ../lib/db/dbmi_base/test/test_columns.c:57
 msgid ""
@@ -3134,18 +3134,18 @@
 #: ../lib/vector/Vlib/write_pg.c:2902 ../lib/vector/Vlib/ascii.c:404
 #, fuzzy, c-format
 msgid "Unable to start driver <%s>"
 #: ../lib/db/dbmi_client/table.c:46 ../lib/db/dbmi_client/delete_tab.c:40
 #, fuzzy, c-format
 msgid "Unable open database <%s> by driver <%s>"
 #: ../lib/db/dbmi_client/table.c:110 ../lib/db/dbmi_client/copy_tab.c:242
 #: ../lib/db/dbmi_client/copy_tab.c:319 ../lib/vector/Vlib/write_ogr.c:210
 #, fuzzy, c-format
 msgid "Unable to open select cursor: '%s'"
 #: ../lib/db/dbmi_client/copy_tab.c:91
 #, c-format
@@ -3155,49 +3155,49 @@
 #: ../lib/db/dbmi_client/copy_tab.c:151
 #, fuzzy, c-format
 msgid "Unable to get list tables in database <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:189
 #, fuzzy, c-format
 msgid "Table <%s> already exists in database and will be overwritten"
 #: ../lib/db/dbmi_client/copy_tab.c:194
 #, fuzzy, c-format
 msgid "Table <%s> already exists in database <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:274
 #, fuzzy, c-format
 msgid "Column <%s> is not integer"
-msgstr "Impossível descrever tabela <%s>"
+msgstr "Impossível descrever tabela <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:291 ../lib/rst/interp_float/vinput2d.c:115
 #: ../lib/rst/interp_float/vinput2d.c:129
 #, fuzzy, c-format
 msgid "Column <%s> not found"
 #: ../lib/db/dbmi_client/copy_tab.c:294
 #, fuzzy, c-format
 msgid "Unable to create table <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:338 ../lib/vector/Vlib/write_ogr.c:585
 #: ../lib/vector/Vlib/write_pg.c:2009
 #, fuzzy, c-format
 msgid "Unable to fetch data from table <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:394
 #, fuzzy, c-format
 msgid "Unknown column type (column <%s>)"
-msgstr "não consegui ler"
+msgstr "não consegui ler"
 #: ../lib/db/dbmi_client/delete_tab.c:53
 #, fuzzy, c-format
 msgid "Unable to drop table: '%s'"
 #: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
 #: ../lib/db/dbmi_client/select.c:288
@@ -3211,12 +3211,12 @@
 #: ../lib/db/dbmi_client/select.c:317 ../lib/vector/Vlib/cats.c:603
 #, fuzzy, c-format
 msgid "Unable select records from table <%s>"
 #: ../lib/db/dbmi_client/select.c:333
 #, fuzzy
 msgid "Key column type is not integer"
 #: ../lib/db/dbmi_driver/d_error.c:35
 #, c-format
@@ -3226,17 +3226,17 @@
 #: ../lib/nviz/lights.c:171
 #, fuzzy
 msgid "Unable to define new light"
 #: ../lib/nviz/position.c:56
 #, fuzzy
 msgid "Unable to set focus"
 #: ../lib/nviz/nviz.c:128
 #, fuzzy, c-format
 msgid "Invalid color (%s), using \"white\" as default"
 #: ../lib/nviz/render.c:106
 msgid "Bad server connection"
@@ -3245,12 +3245,12 @@
 #: ../lib/nviz/render.c:112
 #, fuzzy
 msgid "Unable to get visual info"
 #: ../lib/nviz/render.c:119
 #, fuzzy
 msgid "Unable to create rendering context"
 #: ../lib/nviz/map_obj.c:59
 msgid "Maximum surfaces loaded!"
@@ -3285,19 +3285,19 @@
 #: ../lib/manage/do_copy.c:43
 #, fuzzy, c-format
 msgid "Copy %s <%s> to current mapset as <%s>"
-msgstr "não há arquivos %s disponíveis no mapset ativo\n"
+msgstr "não há arquivos %s disponíveis no mapset ativo\n"
 #: ../lib/manage/do_copy.c:50 ../lib/manage/do_copy.c:67
 #, fuzzy, c-format
 msgid "Unable to copy <%s> to current mapset as <%s>"
 #: ../lib/manage/do_copy.c:61 ../lib/manage/do_remove.c:89
 #: ../lib/manage/do_remove.c:109 ../lib/manage/do_rename.c:87
 #: ../lib/manage/do_rename.c:107
 #, fuzzy, c-format
 msgid "%s is missing"
-msgstr "que está faltando"
+msgstr "que está faltando"
 #: ../lib/manage/do_copy.c:72
 #, c-format
@@ -3307,17 +3307,17 @@
 #: ../lib/manage/do_remove.c:42
 #, fuzzy, c-format
 msgid "Removing %s <%s>"
 #: ../lib/manage/do_remove.c:65
 #, fuzzy
 msgid "Unable to delete vector map"
 #: ../lib/manage/do_remove.c:85
 #, fuzzy, c-format
 msgid "Unable to remove %s element"
 #: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
 #, c-format
@@ -3327,7 +3327,7 @@
 #: ../lib/manage/do_remove.c:105
 #, fuzzy, c-format
 msgid "Unable to remove %s"
 #: ../lib/manage/do_remove.c:121
 #, c-format
@@ -3339,7 +3339,7 @@
 msgid "%s: invalid index %d"
 msgstr ""
 "\n"
-"%s é inválido. Tente novamente > "
+"%s é inválido. Tente novamente > "
 #: ../lib/manage/option.c:47
 #, fuzzy, c-format
@@ -3365,7 +3365,7 @@
 #: ../lib/manage/read_list.c:73
 #, fuzzy, c-format
 msgid "Unable to open data base element list '%s'"
 #: ../lib/manage/read_list.c:134
 #, c-format
@@ -3375,17 +3375,17 @@
 #: ../lib/manage/do_rename.c:42
 #, fuzzy, c-format
 msgid "Rename %s <%s> to <%s>"
 #: ../lib/manage/do_rename.c:62
 #, fuzzy, c-format
 msgid "Unable to rename vector map <%s> to <%s>"
 #: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
 #, fuzzy, c-format
 msgid "Unable to rename %s"
 #: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
 #, c-format
@@ -3405,7 +3405,7 @@
 #: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
 #, fuzzy, c-format
 msgid "Unable to create <%s> file for map <%s>"
 #: ../lib/raster/mask_info.c:43
 #, c-format
@@ -3423,37 +3423,37 @@
 #: ../lib/raster/reclass.c:168
 #, fuzzy, c-format
 msgid "Too many reclass categories for <%s@%s>"
 #: ../lib/raster/reclass.c:171
 #, fuzzy, c-format
 msgid "Illegal reclass format in header file for <%s@%s>"
 msgstr ""
-"Formato de reclassificação ilegal no cabeçalho do arquivo para [%s em %s]"
+"Formato de reclassificação ilegal no cabeçalho do arquivo para [%s em %s]"
 #: ../lib/raster/reclass.c:273
 msgid "Illegal reclass request"
-msgstr "Pedido de reclassificação ilegal"
+msgstr "Pedido de reclassificação ilegal"
 #: ../lib/raster/reclass.c:278
 msgid "Illegal reclass type"
-msgstr "Tipo de reclassificação ilegal"
+msgstr "Tipo de reclassificação ilegal"
 #: ../lib/raster/reclass.c:284
 #, fuzzy, c-format
 msgid "Unable to create header file for <%s@%s>"
 #: ../lib/raster/reclass.c:332
 #, fuzzy, c-format
 msgid "Unable to create dependency file in <%s@%s>"
-msgstr "não é possível criar arquivo de dependência [%s em %s]"
+msgstr "não é possível criar arquivo de dependência [%s em %s]"
 #: ../lib/raster/init.c:61
 #, fuzzy
 msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
 msgstr ""
-"\aERRO: Sistema não iniciado. O programador não incluiu a chamada a "
+"\aERRO: Sistema não iniciado. O programador não incluiu a chamada a "
 "G_gisinit()\n"
 #: ../lib/raster/init.c:109
@@ -3474,38 +3474,38 @@
 #: ../lib/raster/range.c:102
 #, fuzzy, c-format
 msgid "Unable to read fp range file for <%s>"
 #: ../lib/raster/range.c:169
 #, fuzzy, c-format
 msgid "Unable to read quant rules for raster map <%s>"
 #: ../lib/raster/range.c:206 ../lib/raster/range.c:226
 #, fuzzy, c-format
 msgid "Unable to read range file for <%s>"
 #: ../lib/raster/range.c:264 ../lib/raster/range.c:270
 #: ../lib/raster/range.c:300 ../lib/raster/range.c:314
 #, fuzzy, c-format
 msgid "Unable to write range file for <%s>"
 #: ../lib/raster/raster_metadata.c:109
 #, fuzzy, c-format
 msgid "Unable to read <%s> for raster map <%s@%s>"
 #: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
 #, fuzzy, c-format
 msgid "Error closing <%s> metadata file for raster map <%s@%s>"
 #: ../lib/raster/raster_metadata.c:142
 #, fuzzy, c-format
 msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
 #: ../lib/raster/put_row.c:121
 #, fuzzy, c-format
@@ -3530,7 +3530,7 @@
 #: ../lib/raster/put_row.c:462
 #, fuzzy, c-format
 msgid "Error writing data via GDAL for row %d of <%s>"
-msgstr "Erro de escrita no arquivo de índices espaciais.\n"
+msgstr "Erro de escrita no arquivo de índices espaciais.\n"
 #: ../lib/raster/put_row.c:486
 msgid "GDAL output doesn't support writing null rows separately"
@@ -3539,7 +3539,7 @@
 #: ../lib/raster/put_row.c:489
 #, fuzzy, c-format
 msgid "No null file for <%s>"
 #: ../lib/raster/put_row.c:513 ../lib/raster/put_row.c:518
 #, fuzzy, c-format
@@ -3554,12 +3554,12 @@
 #: ../lib/raster/put_row.c:680
 #, fuzzy, c-format
 msgid "put_raster_row: raster map <%s> not open for write - request ignored"
-msgstr "%s: map [%s] não está aberto para escrita - pedido ignorado"
+msgstr "%s: map [%s] não está aberto para escrita - pedido ignorado"
 #: ../lib/raster/put_row.c:687
 #, fuzzy
 msgid "put_raster_row: unopened file descriptor - request ignored"
-msgstr "%s: descritor de arquivo não foi aberto - pedido ignorado"
+msgstr "%s: descritor de arquivo não foi aberto - pedido ignorado"
 #: ../lib/raster/get_cellhd.c:66
 #, fuzzy, c-format
@@ -3567,48 +3567,48 @@
 "Unable to read header file for raster map <%s@%s>. It is a reclass of raster "
 "map <%s@%s> %s"
 msgstr ""
-"não foi possível abrir [%s] em [%s] pois este é uma reclassificação de [%s] "
-"em [%s] que não existe"
+"não foi possível abrir [%s] em [%s] pois este é uma reclassificação de [%s] "
+"em [%s] que não existe"
 #: ../lib/raster/get_cellhd.c:70
 #, fuzzy
 msgid "which is missing."
 #: ../lib/raster/get_cellhd.c:71
 #, fuzzy
 msgid "whose header file can't be opened."
-msgstr "de cujo arquivo o cabeçalho não pode ser aberto"
+msgstr "de cujo arquivo o cabeçalho não pode ser aberto"
 #: ../lib/raster/get_cellhd.c:76
 #, fuzzy, c-format
 msgid "Unable to open header file for raster map <%s@%s>"
 #: ../lib/raster/quant_io.c:43
 #, fuzzy, c-format
 msgid "Floating data range for raster map <%s> is empty"
-msgstr "O intervalo de dados float para %s@%s está vazio"
+msgstr "O intervalo de dados float para %s@%s está vazio"
 #: ../lib/raster/quant_io.c:52
 #, fuzzy, c-format
 msgid "Integer data range for raster map <%s> is empty"
-msgstr "O intervalo de dados inteiros para %s@%s está vazio"
+msgstr "O intervalo de dados inteiros para %s@%s está vazio"
 #: ../lib/raster/quant_io.c:105
 #, fuzzy, c-format
 msgid "Attempt to open quantization table for CELL raster map <%s>"
 #: ../lib/raster/quant_io.c:135
 #, fuzzy, c-format
 msgid "Quantization file for raster map <%s> is missing"
 #: ../lib/raster/quant_io.c:145
 #, fuzzy, c-format
 msgid "Quantization file for raster map <%s> is empty"
 #: ../lib/raster/alloc_cell.c:151
 #, c-format
@@ -3618,22 +3618,22 @@
 #: ../lib/raster/histogram.c:55
 #, c-format
 msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr "Está faltando o histograma para [%s em %s] (execute r.support)"
+msgstr "Está faltando o histograma para [%s em %s] (execute r.support)"
 #: ../lib/raster/histogram.c:62
 #, c-format
 msgid "Can't read histogram for [%s in %s]"
-msgstr "não consegui ler o histograma para [%s em %s]"
+msgstr "não consegui ler o histograma para [%s em %s]"
 #: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
 #, c-format
 msgid "Invalid histogram file for [%s in %s]"
-msgstr "arquivo contendo o histograma para [%s em %s] é inválido"
+msgstr "arquivo contendo o histograma para [%s em %s] é inválido"
 #: ../lib/raster/histogram.c:331
 #, fuzzy, c-format
 msgid "Unable to create histogram file for <%s>"
 #: ../lib/raster/open.c:193
 #, fuzzy, c-format
@@ -3641,13 +3641,13 @@
 "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
 "%s> which does not exist"
 msgstr ""
 #: ../lib/raster/open.c:198
 #, fuzzy, c-format
 msgid "Error reading reclass file for raster map <%s>"
 #: ../lib/raster/open.c:209
 #, fuzzy, c-format
@@ -3657,12 +3657,12 @@
 #: ../lib/raster/open.c:217
 #, fuzzy, c-format
 msgid "Raster map <%s@%s>: format field in header file invalid"
-msgstr "[%s] no mapset [%s]-o campo formato no cabeçalho do arquivo é inválido"
+msgstr "[%s] no mapset [%s]-o campo formato no cabeçalho do arquivo é inválido"
 #: ../lib/raster/open.c:236
 #, fuzzy, c-format
 msgid "Compression with %s is not supported"
 #: ../lib/raster/open.c:240
 #, fuzzy, c-format
@@ -3670,19 +3670,19 @@
 "Raster map <%s> is in different projection than current region. Found <%s>, "
 "should be <%s>."
 msgstr ""
-"[%s] no mapset [%s] - está numa projeção diferente da região atual:\n"
+"[%s] no mapset [%s] - está numa projeção diferente da região atual:\n"
 "o mapa [%s] em: <%s>, deveria ser <%s> "
 #: ../lib/raster/open.c:247
 #, fuzzy, c-format
 msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
 msgstr ""
 #: ../lib/raster/open.c:252
 #, fuzzy, c-format
 msgid "Raster map <%s>: bytes per cell (%d) too large"
-msgstr "[%s] em [%s] - bytes demais por célula (%d)"
+msgstr "[%s] em [%s] - bytes demais por célula (%d)"
 #: ../lib/raster/open.c:277
 #, c-format
@@ -3693,7 +3693,7 @@
 #: ../lib/raster/open.c:285
 #, fuzzy, c-format
 msgid "Unable to open %s file for raster map <%s@%s>"
 #: ../lib/raster/open.c:322
 #, fuzzy, c-format
@@ -3703,17 +3703,17 @@
 #: ../lib/raster/open.c:527
 #, fuzzy
 msgid "Unable to create GDAL link"
 #: ../lib/raster/open.c:599 ../lib/raster/gdal.c:476
 #, fuzzy, c-format
 msgid "Invalid map type <%d>"
 #: ../lib/raster/open.c:604 ../lib/raster/open.c:759
 #, fuzzy, c-format
 msgid "Raster map <%s> is not in the current mapset (%s)"
 #: ../lib/raster/open.c:611
 #, fuzzy, c-format
@@ -3723,12 +3723,12 @@
 #: ../lib/raster/open.c:626 ../lib/raster/open.c:706 ../lib/raster/open.c:782
 #, fuzzy, c-format
 msgid "No temp files available: %s"
-msgstr "não há arquivos %s disponíveis no mapset %s\n"
+msgstr "não há arquivos %s disponíveis no mapset %s\n"
 #: ../lib/raster/open.c:755
 #, fuzzy, c-format
 msgid "Raster map <%s> does not exist in the current mapset (%s)"
 #: ../lib/raster/open.c:821
 msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
@@ -3737,27 +3737,27 @@
 #: ../lib/raster/open.c:879
 #, fuzzy, c-format
 msgid "Raster map <%s> not found in mapset <%s>"
 #: ../lib/raster/open.c:940
 #, fuzzy, c-format
 msgid "Unable to find '%s'"
 #: ../lib/raster/open.c:951
 #, fuzzy, c-format
 msgid "Invalid type: field '%s' in file '%s'"
-msgstr "tipo inválido: campo %s no arquivo %s"
+msgstr "tipo inválido: campo %s no arquivo %s"
 #: ../lib/raster/open.c:956
 #, fuzzy, c-format
 msgid "Missing type: field in file '%s'"
 #: ../lib/raster/open.c:961
 #, fuzzy, c-format
 msgid "Raster map <%s> is not xdr: byte_order: %s"
 #: ../lib/raster/open.c:1030
 msgid ""
@@ -3772,57 +3772,57 @@
 #: ../lib/raster/quant_rw.c:88
 #, fuzzy, c-format
 msgid "Unable to read fp range for raster map <%s>"
 #: ../lib/raster/quant_rw.c:92
 #, fuzzy, c-format
 msgid "Raster map <%s> is empty"
-msgstr "O raster %s@%s está vazio"
+msgstr "O raster %s@%s está vazio"
 #: ../lib/raster/quant_rw.c:157
 #, fuzzy, c-format
 msgid "Unable to write quant rules: raster map <%s> is integer"
-msgstr "não consegui escrever regras de quantização : o mapa %s é inteiro"
+msgstr "não consegui escrever regras de quantização : o mapa %s é inteiro"
 #: ../lib/raster/quant_rw.c:166
 #, fuzzy, c-format
 msgid "Unable to write quant rules for raster map <%s>"
 #: ../lib/raster/close.c:77 ../lib/raster/close.c:110
 #, fuzzy, c-format
 msgid "Invalid descriptor: %d"
 #: ../lib/raster/close.c:391 ../lib/raster/close.c:519
 #, fuzzy, c-format
 msgid "Unable to rename null file '%s' to '%s': %s"
 #: ../lib/raster/close.c:461
 #, fuzzy, c-format
 msgid "Unable to rename cell file '%s' to '%s': %s"
 #: ../lib/raster/close.c:541
 msgid "unable to write f_format file for CELL maps"
-msgstr "impossível escrever arquivo f_format para mapas CELL"
+msgstr "impossível escrever arquivo f_format para mapas CELL"
 #: ../lib/raster/interp.c:211
 #, fuzzy, c-format
 msgid "Unknown interpolation method: %s"
 #: ../lib/raster/color_read.c:103
 #, fuzzy
 msgid "missing"
 #: ../lib/raster/color_read.c:106
 #, fuzzy
 msgid "invalid"
 msgstr ""
-"é inválido\n"
+"é inválido\n"
 "%s"
 #: ../lib/raster/color_read.c:112
@@ -3833,27 +3833,27 @@
 #: ../lib/raster/gdal.c:88
 #, fuzzy, c-format
 msgid "Unable to locate symbol <%s>"
 #: ../lib/raster/gdal.c:142
 #, fuzzy
 msgid "Unable to load GDAL library"
-msgstr "não consegui calcular centróide para área %d"
+msgstr "não consegui calcular centróide para área %d"
 #: ../lib/raster/gdal.c:372
 #, fuzzy
 msgid "Unable to open GDAL file"
 #: ../lib/raster/gdal.c:482
 #, fuzzy, c-format
 msgid "Unable to get <%s> driver"
 #: ../lib/raster/gdal.c:491
 #, fuzzy, c-format
 msgid "Unable to create <%s> dataset using <%s> driver"
 #: ../lib/raster/gdal.c:499
 #, c-format
@@ -3865,12 +3865,12 @@
 #: ../lib/raster/gdal.c:505
 #, fuzzy
 msgid "Unable to get in-memory raster driver"
-msgstr "não consegui criar novo processo"
+msgstr "não consegui criar novo processo"
 #: ../lib/raster/gdal.c:512
 #, fuzzy, c-format
 msgid "Unable to create <%s> dataset using memory driver"
 #: ../lib/raster/gdal.c:516
 #, c-format
@@ -3880,27 +3880,27 @@
 #: ../lib/raster/gdal.c:532
 #, fuzzy
 msgid "Unable to set geo transform"
 #: ../lib/raster/gdal.c:536
 #, fuzzy
 msgid "Unable to set projection"
 #: ../lib/raster/gdal.c:540
 #, fuzzy, c-format
 msgid "Unable to create cell_misc/%s/gdal file"
 #: ../lib/raster/gdal.c:556
 #, fuzzy, c-format
 msgid "Error writing cell_misc/%s/gdal file"
 #: ../lib/raster/gdal.c:604
 #, fuzzy, c-format
 msgid "Unable to create output file <%s> using driver <%s>"
 #: ../lib/raster/format.c:162
 #, c-format
@@ -3915,34 +3915,34 @@
 #: ../lib/raster/sample.c:70
 #, fuzzy
 msgid "Unknown interpolation type"
 #: ../lib/raster/sample.c:327
 msgid "\"no data\" label found; setting to zero"
-msgstr "rótulo \"no data\" encontrado; ajustando para zero"
+msgstr "rótulo \"no data\" encontrado; ajustando para zero"
 #: ../lib/raster/put_title.c:28
 #, c-format
 msgid "category information for [%s] in [%s] missing or invalid"
-msgstr "A categoria de [%s] em [%s] está faltando ou é inválida"
+msgstr "A categoria de [%s] em [%s] está faltando ou é inválida"
 #: ../lib/raster/put_title.c:37
 msgid "G_put_title - can't create a temp file"
-msgstr "G_put_title - não consegui criar um arquivo temporário"
+msgstr "G_put_title - não consegui criar um arquivo temporário"
 #: ../lib/raster/put_title.c:53
 #, c-format
 msgid "category information for [%s] in [%s] invalid"
-msgstr "a informação de categoria para [%s] em [%s] é inválida"
+msgstr "a informação de categoria para [%s] em [%s] é inválida"
 #: ../lib/raster/put_title.c:60
 msgid "G_put_title - can't reopen temp file"
-msgstr "G_put_title - não consegui reabrir o arquivo temporário"
+msgstr "G_put_title - não consegui reabrir o arquivo temporário"
 #: ../lib/raster/put_title.c:67
 #, c-format
 msgid "can't write category information for [%s] in [%s]"
-msgstr "não consegui escrever as informações de categoria para [%s] em [%s]"
+msgstr "não consegui escrever as informações de categoria para [%s] em [%s]"
 #: ../lib/raster/color_rules.c:120
 msgid "syntax error in the color rule"
@@ -3958,7 +3958,7 @@
 #: ../lib/raster/color_rules.c:132
 msgid "invalid value"
-msgstr "valor inválido"
+msgstr "valor inválido"
 #: ../lib/raster/color_rules.c:134
 msgid "unknown error"
@@ -3972,17 +3972,17 @@
 #: ../lib/raster/color_rules.c:327
 #, fuzzy, c-format
 msgid "Unable to load color rules <%s>"
-msgstr "Impossível mudar de diretório para %s"
+msgstr "Impossível mudar de diretório para %s"
 #: ../lib/raster/history.c:115 ../lib/raster/history.c:123
 #, fuzzy, c-format
 msgid "Unable to get history information for <%s@%s>"
 #: ../lib/raster/history.c:162
 #, fuzzy, c-format
 msgid "Unable to write history information for <%s>"
 #: ../lib/raster/history.c:235
 #, c-format
@@ -3997,7 +3997,7 @@
 #: ../lib/raster/cats.c:112
 #, fuzzy, c-format
 msgid "Category support for <%s@%s> invalid"
 #: ../lib/raster/cats.c:145
 #, fuzzy, c-format
@@ -4012,12 +4012,12 @@
 #: ../lib/raster/cats.c:968
 #, fuzzy, c-format
 msgid "Unable to open %s file for map <%s>"
 #: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:898
 #, fuzzy, c-format
 msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr "[%s em %s] - instrução de leitura para a linha %d está fora da região"
+msgstr "[%s em %s] - instrução de leitura para a linha %d está fora da região"
 #: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:137
 #: ../lib/raster/get_row.c:144 ../lib/raster/get_row.c:187
@@ -4034,7 +4034,7 @@
 #: ../lib/raster/get_row.c:227
 #, fuzzy, c-format
 msgid "Error reading raster data via GDAL for row %d of <%s>"
 #: ../lib/raster/get_row.c:827 ../lib/raster/get_row.c:832
 #: ../lib/raster/get_row.c:842
@@ -4082,7 +4082,7 @@
 #: ../lib/raster/auto_mask.c:69
 msgid "Unable to open automatic MASK file"
-msgstr "não é possível abrir automaticamente o arquivo MASK"
+msgstr "não é possível abrir automaticamente o arquivo MASK"
 #: ../lib/raster/set_window.c:48
 msgid "Rast_set_window() called while window split"
@@ -4094,7 +4094,7 @@
 "Rast_set_read_window(): projection/zone differs from that of currently open "
 "raster maps"
 msgstr ""
-"G_set_window(): projeção/zona difere daquela nos arquivos raster abertos"
+"G_set_window(): projeção/zona difere daquela nos arquivos raster abertos"
 #: ../lib/raster/set_window.c:158
 #, c-format
@@ -4109,12 +4109,12 @@
 #: ../lib/raster/put_cellhd.c:34
 #, fuzzy, c-format
 msgid "Unable to create header file for <%s>"
 #: ../lib/gis/lrand48.c:84
 #, fuzzy, c-format
 msgid "gettimeofday failed: %s"
-msgstr "Falha na conexão.\n"
+msgstr "Falha na conexão.\n"
 #: ../lib/gis/lrand48.c:114
 msgid "Pseudo-random number generator not seeded"
@@ -4123,52 +4123,52 @@
 #: ../lib/gis/make_mapset.c:66 ../lib/init/grass.py:841
 #, fuzzy, c-format, python-format
 msgid "Location <%s> doesn't exist"
 #: ../lib/gis/timestamp.c:292
 #, fuzzy, c-format
 msgid "Unable to create timestamp file for %s map <%s@%s>"
-msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
+msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
 #: ../lib/gis/timestamp.c:301
 #, fuzzy, c-format
 msgid "Invalid timestamp specified for %s map <%s@%s>"
 #: ../lib/gis/timestamp.c:331
 #, fuzzy, c-format
 msgid "Unable to open timestamp file for %s map <%s@%s>"
 #: ../lib/gis/timestamp.c:340
 #, fuzzy, c-format
 msgid "Invalid timestamp file for %s map <%s@%s>"
 #: ../lib/gis/timestamp.c:479
 #, fuzzy, c-format
 msgid "Unable to open timestamp file for vector map <%s@%s>"
 #: ../lib/gis/timestamp.c:488
 #, fuzzy, c-format
 msgid "Invalid timestamp file for vector map <%s@%s>"
 #: ../lib/gis/timestamp.c:524
 #, fuzzy, c-format
 msgid "Unable to create timestamp file for vector map <%s@%s>"
 #: ../lib/gis/timestamp.c:533
 #, fuzzy, c-format
 msgid "Invalid timestamp specified for vector map <%s@%s>"
 #: ../lib/gis/location.c:61
 #, fuzzy, c-format
 msgid "LOCATION <%s> not available"
-msgstr "LOCAÇÃO << %s >> indisponível"
+msgstr "LOCAÇÃO << %s >> indisponível"
 #: ../lib/gis/distance.c:154
 #, c-format
@@ -4216,17 +4216,17 @@
 msgid "Parameters"
 msgstr ""
 "\n"
-"Parâmetros:\n"
+"Parâmetros:\n"
 #: ../lib/gis/parser_rest.c:223 ../lib/gis/parser_html.c:233
 #, fuzzy
 msgid "Options"
-msgstr " opções: %s\n"
+msgstr " opções: %s\n"
 #: ../lib/gis/parser_rest.c:230 ../lib/gis/parser_html.c:239
 #, fuzzy
 msgid "Default"
-msgstr " padrão: %s\n"
+msgstr " padrão: %s\n"
 #: ../lib/gis/compress.c:131 ../lib/gis/compress.c:193
 #: ../lib/gis/compress.c:209
@@ -4243,7 +4243,7 @@
 #: ../lib/gis/proj2.c:65
 msgid "Other Projection"
-msgstr "Outra projeção"
+msgstr "Outra projeção"
 #: ../lib/gis/parser_wps.c:490
 msgid "Multiple outputs are not supported by WPS 1.0.0"
@@ -4262,26 +4262,26 @@
 #: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
 #, fuzzy
 msgid "Unable to seek"
 #: ../lib/gis/seek.c:56
 #, fuzzy
 msgid "Seek offset out of range"
 #: ../lib/gis/ls.c:103
 #, fuzzy, c-format
 msgid "Unable to open directory %s"
 #: ../lib/gis/env.c:311
 msgid "GISRC - variable not set"
-msgstr "GISRC - variável não incializada"
+msgstr "GISRC - variável não incializada"
 #: ../lib/gis/env.c:343 ../lib/gis/env.c:369
 #, fuzzy, c-format
 msgid "Variable '%s' not set"
 #: ../lib/gis/find_file.c:114
 #, c-format
@@ -4291,7 +4291,7 @@
 #: ../lib/gis/find_file.c:127
 #, fuzzy, c-format
 msgid "Using <%s@%s>"
 #: ../lib/gis/token.c:169
 msgid "parse error"
@@ -4300,34 +4300,34 @@
 #: ../lib/gis/get_ellipse.c:263 ../lib/proj/ellipse.c:243
 #, fuzzy, c-format
 msgid "Unable to open ellipsoid table file <%s>"
 #: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
 #, fuzzy, c-format
 msgid "Invalid a: field '%s' in file %s in <%s>"
-msgstr "Parâmetro 'a' inválido: campo %s no arquivo %s em %s"
+msgstr "Parâmetro 'a' inválido: campo %s no arquivo %s em %s"
 #: ../lib/gis/get_ellipse.c:356
 #, fuzzy, c-format
 msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr "elipsóide inválido %s no arquivo %s em %s"
+msgstr "elipsóide inválido %s no arquivo %s em %s"
 #: ../lib/gis/get_ellipse.c:370
 #, fuzzy, c-format
 msgid "Invalid es: field '%s' in file %s in <%s>"
-msgstr "Parâmetro 'es' inválido: campo %s no arquivo %s em %s"
+msgstr "Parâmetro 'es' inválido: campo %s no arquivo %s em %s"
 #: ../lib/gis/get_ellipse.c:383
 #, fuzzy, c-format
 msgid "No ellipsoid info given in file %s in <%s>"
-msgstr "Elipsóide não fornecido no arquivo %s em %s"
+msgstr "Elipsóide não fornecido no arquivo %s em %s"
 #: ../lib/gis/parser_help.c:84
 #, fuzzy
 msgid "Description:"
 msgstr ""
 "\n"
-"Descrição:\n"
+"Descrição:\n"
 #: ../lib/gis/parser_help.c:103
 msgid "Keywords:"
@@ -4344,7 +4344,7 @@
 #: ../lib/gis/parser_help.c:141
 #, fuzzy
 msgid "ERROR: Option key not defined"
 #: ../lib/gis/parser_help.c:191
 #, fuzzy
@@ -4366,32 +4366,32 @@
 msgid "Parameters:"
 msgstr ""
 "\n"
-"Parâmetros:\n"
+"Parâmetros:\n"
 #: ../lib/gis/parser_help.c:253
 #, c-format
 msgid "  %*s   default: %s\n"
-msgstr "  %*s   padrão: %s\n"
+msgstr "  %*s   padrão: %s\n"
 #: ../lib/gis/parser_help.c:279
 #, c-format
 msgid "  %*s   options: "
-msgstr "  %*s   opções: "
+msgstr "  %*s   opções: "
 #: ../lib/gis/list.c:83
 #, fuzzy, c-format
 msgid "no %s files available in current mapset\n"
 #: ../lib/gis/list.c:86
 #, fuzzy, c-format
 msgid "no %s files available in mapset <%s>\n"
 #: ../lib/gis/list.c:132
 #, fuzzy, c-format
 msgid "%s files available in mapset <%s>:\n"
-msgstr "%s arquivos disponíveis no mapset %s:\n"
+msgstr "%s arquivos disponíveis no mapset %s:\n"
 #: ../lib/gis/list.c:204
 #, fuzzy
@@ -4400,27 +4400,27 @@
 #: ../lib/gis/proj3.c:121 ../lib/vector/Vlib/header.c:552
 msgid "Unknown projection"
-msgstr "Projeção desconhecida"
+msgstr "Projeção desconhecida"
 #: ../lib/gis/mapset_msc.c:90
 #, fuzzy, c-format
 msgid "Unable to make mapset element %s (%s): %s"
-msgstr "não foi possível gerar o elemento  %s (%s) do mapset"
+msgstr "não foi possível gerar o elemento  %s (%s) do mapset"
 #: ../lib/gis/mapset_msc.c:94
 #, fuzzy, c-format
 msgid "Unable to access mapset element %s (%s): %s"
 #: ../lib/gis/home.c:39
 #, fuzzy
 msgid "Unable to determine user's home directory"
-msgstr "não consegui encontrar o diretório do usuário"
+msgstr "não consegui encontrar o diretório do usuário"
 #: ../lib/gis/home.c:120
 #, fuzzy, c-format
 msgid "Failed to create directory [%s]"
 #: ../lib/gis/open.c:68
 #, c-format
@@ -4430,7 +4430,7 @@
 #: ../lib/gis/open.c:89
 #, fuzzy, c-format
 msgid "G__open(read): Unable to open '%s': %s"
 #: ../lib/gis/open.c:98
 #, c-format
@@ -4440,7 +4440,7 @@
 #: ../lib/gis/open.c:122
 #, fuzzy, c-format
 msgid "G__open(write): Unable to open '%s': %s"
 #: ../lib/gis/parser_standard_options.c:147
 msgid "SQL SELECT statement"
@@ -4452,7 +4452,7 @@
 #: ../lib/gis/parser_standard_options.c:156
 msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr "Cláusula WHERE do comando SQL sem palavra-chave 'where'"
+msgstr "Cláusula WHERE do comando SQL sem palavra-chave 'where'"
 #: ../lib/gis/parser_standard_options.c:157
 msgid "Example: income < 1000 and population >= 10000"
@@ -4518,12 +4518,12 @@
 #: ../lib/gis/parser_standard_options.c:268
 msgid "Name for output raster map"
-msgstr "Nome do mapa raster de saída"
+msgstr "Nome do mapa raster de saída"
 #: ../lib/gis/parser_standard_options.c:277
 #, fuzzy
 msgid "Name for output raster map(s)"
 #: ../lib/gis/parser_standard_options.c:285
 #, fuzzy
@@ -4546,12 +4546,12 @@
 #: ../lib/gis/parser_standard_options.c:318
 #, fuzzy
 msgid "Name of input elevation raster map"
 #: ../lib/gis/parser_standard_options.c:327
 #, fuzzy
 msgid "Name of input elevation raster map(s)"
-msgstr "Nome dos mapas raster de elevação"
+msgstr "Nome dos mapas raster de elevação"
 #: ../lib/gis/parser_standard_options.c:334
 #, fuzzy
@@ -4561,7 +4561,7 @@
 #: ../lib/gis/parser_standard_options.c:335
 #, fuzzy
 msgid "Storage type for resultant raster map"
 #: ../lib/gis/parser_standard_options.c:339
 msgid "Integer"
@@ -4578,7 +4578,7 @@
 #: ../lib/gis/parser_standard_options.c:347
 #, fuzzy
 msgid "Sampling interpolation method"
 #: ../lib/gis/parser_standard_options.c:351
 msgid "Nearest-neighbor interpolation"
@@ -4587,12 +4587,12 @@
 #: ../lib/gis/parser_standard_options.c:352
 #, fuzzy
 msgid "Bilinear interpolation"
 #: ../lib/gis/parser_standard_options.c:353
 #, fuzzy
 msgid "Bicubic interpolation"
 #: ../lib/gis/parser_standard_options.c:362
 #, fuzzy
@@ -4602,7 +4602,7 @@
 #: ../lib/gis/parser_standard_options.c:371
 #, fuzzy
 msgid "Name for output basename raster map(s)"
 #: ../lib/gis/parser_standard_options.c:381
 #, fuzzy
@@ -4617,7 +4617,7 @@
 #: ../lib/gis/parser_standard_options.c:398
 #, fuzzy
 msgid "Name for output 3D raster map"
 #: ../lib/gis/parser_standard_options.c:406
 #, fuzzy
@@ -4632,7 +4632,7 @@
 #: ../lib/gis/parser_standard_options.c:424
 #, fuzzy
 msgid "Data type used in the output raster3d map"
-msgstr "Nome do mapa raster3d de saída"
+msgstr "Nome do mapa raster3d de saída"
 #: ../lib/gis/parser_standard_options.c:433
 msgid ""
@@ -4669,7 +4669,7 @@
 #: ../lib/gis/parser_standard_options.c:482
 msgid "Name for output vector map"
-msgstr "Nome do mapa vetor de saída"
+msgstr "Nome do mapa vetor de saída"
 #: ../lib/gis/parser_standard_options.c:490
 #, fuzzy
@@ -4690,7 +4690,7 @@
 #: ../lib/gis/parser_standard_options.c:525
 #, fuzzy
 msgid "Layer number or name"
-msgstr "Número da camada"
+msgstr "Número da camada"
 #: ../lib/gis/parser_standard_options.c:527
 msgid ""
@@ -4702,7 +4702,7 @@
 #: ../lib/gis/parser_standard_options.c:537
 #, fuzzy
 msgid "Layer number or name ('-1' for all layers)"
-msgstr "O campo número <%d> ou o nome <%s> já existem"
+msgstr "O campo número <%d> ou o nome <%s> já existem"
 #: ../lib/gis/parser_standard_options.c:539
 msgid ""
@@ -4741,7 +4741,7 @@
 #: ../lib/gis/parser_standard_options.c:598
 #, fuzzy
 msgid "Name for output file"
-msgstr "Nome do arquivo de saída"
+msgstr "Nome do arquivo de saída"
 #: ../lib/gis/parser_standard_options.c:607
 msgid "Field separator"
@@ -4804,7 +4804,7 @@
 #: ../lib/gis/parser_standard_options.c:705
 #, fuzzy
 msgid "Coordinates"
-msgstr "Coordenadas inválidas"
+msgstr "Coordenadas inválidas"
 #: ../lib/gis/parser_standard_options.c:714
 #, fuzzy
@@ -4818,7 +4818,7 @@
 #: ../lib/gis/parser_standard_options.c:734
 #, fuzzy
 msgid "Name of saved region"
 #: ../lib/gis/parser_standard_options.c:744
 #, fuzzy
@@ -4828,27 +4828,27 @@
 #: ../lib/gis/parser_standard_options.c:753
 #, fuzzy
 msgid "Name of the input space time datasets"
-msgstr "Bug: tentativa de atualizar mapa que não está no mapset atual."
+msgstr "Bug: tentativa de atualizar mapa que não está no mapset atual."
 #: ../lib/gis/parser_standard_options.c:761
 #, fuzzy
 msgid "Name of the output space time dataset"
 #: ../lib/gis/parser_standard_options.c:769
 #, fuzzy
 msgid "Name of the input space time raster dataset"
 #: ../lib/gis/parser_standard_options.c:778
 #, fuzzy
 msgid "Name of the input space time raster datasets"
 #: ../lib/gis/parser_standard_options.c:786
 #, fuzzy
 msgid "Name of the output space time raster dataset"
 #: ../lib/gis/parser_standard_options.c:794
 #, fuzzy
@@ -4863,7 +4863,7 @@
 #: ../lib/gis/parser_standard_options.c:811
 #, fuzzy
 msgid "Name of the output space time vector dataset"
 #: ../lib/gis/parser_standard_options.c:819
 #, fuzzy
@@ -4878,12 +4878,12 @@
 #: ../lib/gis/parser_standard_options.c:836
 #, fuzzy
 msgid "Name of the output space time raster3d dataset"
 #: ../lib/gis/parser_standard_options.c:845
 #, fuzzy
 msgid "Type of the input space time dataset"
 #: ../lib/gis/parser_standard_options.c:853
 #, fuzzy
@@ -4898,19 +4898,19 @@
 #: ../lib/gis/parser_standard_options.c:871
 #, fuzzy
 msgid "Type of the input map"
 #: ../lib/gis/parser_standard_options.c:880
 #, fuzzy
 msgid "The temporal type of the space time dataset"
-msgstr "Vetor de entrada '%s' não encontrado"
+msgstr "Vetor de entrada '%s' não encontrado"
 #: ../lib/gis/parser_standard_options.c:887
 #, fuzzy
 msgid ""
 "WHERE conditions of SQL statement without 'where' keyword used in the "
 "temporal GIS framework"
 #: ../lib/gis/parser_standard_options.c:888
 msgid "Example: start_time > '2001-01-01 12:30:00'"
@@ -4923,7 +4923,7 @@
 #: ../lib/gis/parser_standard_options.c:932
 #, fuzzy
 msgid "Do not create attribute table"
-msgstr "não consegui apagar a linha"
+msgstr "não consegui apagar a linha"
 #: ../lib/gis/parser_standard_options.c:936
 #, fuzzy
@@ -4937,7 +4937,7 @@
 #: ../lib/gis/get_window.c:118
 #, fuzzy, c-format
 msgid "Unable to open element file <%s> for <%s@%s>"
-msgstr "Não consegui abrir histórico para o vetor %s"
+msgstr "Não consegui abrir histórico para o vetor %s"
 #: ../lib/gis/get_window.c:123
 #, c-format
@@ -4947,7 +4947,7 @@
 #: ../lib/gis/debug.c:80
 #, c-format
 msgid "Cannot open debug file '%s'"
-msgstr "Não consegui abrir arquivo de depuração '%s'"
+msgstr "Não consegui abrir arquivo de depuração '%s'"
 #: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
 #, c-format
@@ -4990,28 +4990,28 @@
 msgid "square meters"
 msgstr ""
 "\n"
-"Parâmetros:\n"
+"Parâmetros:\n"
 #: ../lib/gis/units.c:215
 #, fuzzy
 msgid "square meter"
 msgstr ""
 "\n"
-"Parâmetros:\n"
+"Parâmetros:\n"
 #: ../lib/gis/units.c:217
 #, fuzzy
 msgid "meters"
 msgstr ""
 "\n"
-"Parâmetros:\n"
+"Parâmetros:\n"
 #, fuzzy
 msgid "meter"
 msgstr ""
 "\n"
-"Parâmetros:\n"
+"Parâmetros:\n"
 #: ../lib/gis/units.c:222
 msgid "square kilometers"
@@ -5026,7 +5026,7 @@
 msgid "kilometers"
 msgstr ""
 "\n"
-"Parâmetros:\n"
+"Parâmetros:\n"
 #: ../lib/gis/units.c:224
 msgid "kilometer"
@@ -5085,14 +5085,14 @@
 msgid "square US feet"
 msgstr ""
 "\n"
-"Parâmetros:\n"
+"Parâmetros:\n"
 #: ../lib/gis/units.c:259
 #, fuzzy
 msgid "square US foot"
 msgstr ""
 "\n"
-"Parâmetros:\n"
+"Parâmetros:\n"
 #: ../lib/gis/units.c:261
 msgid "US feet"
@@ -5191,7 +5191,7 @@
 #: ../lib/gis/parser.c:585
 #, fuzzy, c-format
 msgid "Sorry <%s> is not a valid option"
-msgstr "Desculpe <%s> não é uma opção válida\n"
+msgstr "Desculpe <%s> não é uma opção válida\n"
 #: ../lib/gis/parser.c:598
 msgid "Your installation doesn't include GUI, exiting."
@@ -5205,17 +5205,17 @@
 #: ../lib/gis/parser.c:941
 #, fuzzy
 msgid "Unable to determine program name"
 #: ../lib/gis/parser.c:963 ../lib/gis/parser.c:980
 #, fuzzy, c-format
 msgid "%s: Sorry, <%c> is not a valid flag"
-msgstr "Desculpe, <%c> não é um flag válido\n"
+msgstr "Desculpe, <%c> não é um flag válido\n"
 #: ../lib/gis/parser.c:1110
 #, fuzzy, c-format
 msgid "%s: Sorry, <%s=> is ambiguous"
-msgstr "Desculpe, <%s=> é ambíguo\n"
+msgstr "Desculpe, <%s=> é ambíguo\n"
 #: ../lib/gis/parser.c:1113
 #, c-format
@@ -5230,7 +5230,7 @@
 #: ../lib/gis/parser.c:1144
 #, fuzzy, c-format
 msgid "%s: Sorry, <%s> is not a valid parameter"
-msgstr "Desculpe, <%s> não é um parâmetro válido\n"
+msgstr "Desculpe, <%s> não é um parâmetro válido\n"
 #: ../lib/gis/parser.c:1150 ../lib/gis/parser.c:1396
 #, fuzzy, c-format
@@ -5249,7 +5249,7 @@
 "\tPresented as: %s"
 msgstr ""
 "\n"
-"ERRO: sintaxe ilegal no intervalo do parâmetro <%s>\n"
+"ERRO: sintaxe ilegal no intervalo do parâmetro <%s>\n"
 #: ../lib/gis/parser.c:1233
 #, fuzzy, c-format
@@ -5258,14 +5258,14 @@
 "\tLegal range: %s"
 msgstr ""
 "\n"
-"ERRO: valor <%s> fora do intervalo do parâmetro <%s>\n"
+"ERRO: valor <%s> fora do intervalo do parâmetro <%s>\n"
 #: ../lib/gis/parser.c:1239
 #, fuzzy, c-format
 msgid "Missing value for parameter <%s>"
 msgstr ""
 "\n"
-"ERRO: Falta valor para o parâmetro <%s>\n"
+"ERRO: Falta valor para o parâmetro <%s>\n"
 #: ../lib/gis/parser.c:1245
 #, fuzzy, c-format
@@ -5274,7 +5274,7 @@
 "\tValid options: %s"
 msgstr ""
 "\n"
 #: ../lib/gis/parser.c:1418
 #, fuzzy, c-format
@@ -5283,7 +5283,7 @@
 "\t(%s)"
 msgstr ""
 "\n"
-"ERRO: Parâmetro necessário <%s> não fornecido:\n"
+"ERRO: Parâmetro necessário <%s> não fornecido:\n"
 "    (%s).\n"
 #: ../lib/gis/parser.c:1510
@@ -5293,7 +5293,7 @@
 "\tYou provided %d item(s): %s"
 msgstr ""
 "\n"
-"ERRO: A opção <%s> deve ser múltipla de %d\n"
+"ERRO: A opção <%s> deve ser múltipla de %d\n"
 #: ../lib/gis/parser.c:1584 ../lib/gis/error.c:362
 #, c-format
@@ -5308,7 +5308,7 @@
 #: ../lib/gis/parser.c:1703
 #, fuzzy, c-format
 msgid "%s= is not a separator option"
 #: ../lib/gis/parser.c:1706
 #, c-format
@@ -5318,22 +5318,22 @@
 #: ../lib/gis/parser.c:1768 ../lib/gis/parser.c:1785
 #, fuzzy, c-format
 msgid "%s= is not a file option"
 #: ../lib/gis/parser.c:1770
 #, fuzzy, c-format
 msgid "Opening multiple files not supported for %s="
-msgstr "Feição OGR tipo %d não suportada)"
+msgstr "Feição OGR tipo %d não suportada)"
 #: ../lib/gis/parser.c:1776
 #, fuzzy, c-format
 msgid "Unable to open %s file <%s>"
-msgstr "não foi possível abrir o arquivo %s em %s"
+msgstr "não foi possível abrir o arquivo %s em %s"
 #: ../lib/gis/parser.c:1782
 #, fuzzy, c-format
 msgid "Unable to create %s file <%s>"
 #: ../lib/gis/worker.c:84
 msgid "Task already has a worker"
@@ -5342,7 +5342,7 @@
 #: ../lib/gis/adj_cellhd.c:42
 #, fuzzy, c-format
 msgid "Illegal n-s resolution value <%lf>"
-msgstr "Valor de resolução N-S ilegal"
+msgstr "Valor de resolução N-S ilegal"
 #: ../lib/gis/adj_cellhd.c:46 ../lib/gis/adj_cellhd.c:197
 msgid "Illegal row value"
@@ -5350,7 +5350,7 @@
 #: ../lib/gis/adj_cellhd.c:50 ../lib/gis/adj_cellhd.c:203
 msgid "Illegal e-w resolution value"
-msgstr "Valor de resolução E-W ilegal"
+msgstr "Valor de resolução E-W ilegal"
 #: ../lib/gis/adj_cellhd.c:54 ../lib/gis/adj_cellhd.c:209
 msgid "Illegal col value"
@@ -5400,15 +5400,15 @@
 #: ../lib/gis/adj_cellhd.c:150 ../lib/gis/adj_cellhd.c:340
 msgid "Invalid coordinates"
 #: ../lib/gis/adj_cellhd.c:191
 msgid "Illegal n-s resolution value"
 #: ../lib/gis/adj_cellhd.c:193
 msgid "Illegal n-s3 resolution value"
 #: ../lib/gis/adj_cellhd.c:199
 msgid "Illegal row3 value"
@@ -5416,7 +5416,7 @@
 #: ../lib/gis/adj_cellhd.c:205
 msgid "Illegal e-w3 resolution value"
-msgstr "Valor ilegal de resolução E-W"
+msgstr "Valor ilegal de resolução E-W"
 #: ../lib/gis/adj_cellhd.c:211
 msgid "Illegal col3 value"
@@ -5424,7 +5424,7 @@
 #: ../lib/gis/adj_cellhd.c:215
 msgid "Illegal t-b3 resolution value"
-msgstr "Valor ilegal de resolução vertical"
+msgstr "Valor ilegal de resolução vertical"
 #: ../lib/gis/adj_cellhd.c:219
 msgid "Illegal depths value"
@@ -5461,7 +5461,7 @@
 #: ../lib/gis/rd_cellhd.c:149
 #, fuzzy
 msgid "Duplicate projection field"
-msgstr "campo de projeção duplicado"
+msgstr "campo de projeção duplicado"
 #: ../lib/gis/rd_cellhd.c:159
 #, fuzzy
@@ -5476,7 +5476,7 @@
 #: ../lib/gis/rd_cellhd.c:385 ../lib/gis/rd_cellhd.c:387
 #, fuzzy, c-format
 msgid "Field <%s> missing"
-msgstr "campo de zona não encontrado"
+msgstr "campo de zona não encontrado"
 #: ../lib/gis/rd_cellhd.c:193
 #, fuzzy
@@ -5511,27 +5511,27 @@
 #: ../lib/gis/rd_cellhd.c:241
 #, fuzzy
 msgid "Duplicate e-w resolution field"
-msgstr "campo de resolução E-W duplicado"
+msgstr "campo de resolução E-W duplicado"
 #: ../lib/gis/rd_cellhd.c:251
 #, fuzzy
 msgid "Duplicate 3D e-w resolution field"
-msgstr "campo de resolução E-W 3D duplicado"
+msgstr "campo de resolução E-W 3D duplicado"
 #: ../lib/gis/rd_cellhd.c:261
 #, fuzzy
 msgid "Duplicate n-s resolution field"
-msgstr "campo de resolução N-S duplicado"
+msgstr "campo de resolução N-S duplicado"
 #: ../lib/gis/rd_cellhd.c:271
 #, fuzzy
 msgid "Duplicate 3D n-s resolution field"
-msgstr "campo de resolução N-S 3D duplicado"
+msgstr "campo de resolução N-S 3D duplicado"
 #: ../lib/gis/rd_cellhd.c:281
 #, fuzzy
 msgid "Duplicate t-b resolution field"
-msgstr "campo de resolução vertical duplicado"
+msgstr "campo de resolução vertical duplicado"
 #: ../lib/gis/rd_cellhd.c:291
 #, fuzzy
@@ -5561,7 +5561,7 @@
 #: ../lib/gis/rd_cellhd.c:341
 #, fuzzy
 msgid "Duplicate format field"
-msgstr "campo formato está duplicado"
+msgstr "campo formato está duplicado"
 #: ../lib/gis/rd_cellhd.c:349
 #, fuzzy
@@ -5571,7 +5571,7 @@
 #: ../lib/gis/datum.c:160
 #, c-format
 msgid "unable to open datum table file: %s"
-msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
+msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
 #: ../lib/gis/datum.c:182
 #, c-format
@@ -5590,17 +5590,17 @@
 #: ../lib/gis/mapset.c:38
 msgid "MAPSET is not set"
-msgstr "MAPSET não foi definido"
+msgstr "MAPSET não foi definido"
 #: ../lib/gis/mapset.c:80
 #, fuzzy, c-format
 msgid "MAPSET <%s> not available"
 #: ../lib/gis/mkstemp.c:132
 #, fuzzy
 msgid "Attempt to create read-only temporary file"
 #: ../lib/gis/mkstemp.c:138
 #, c-format
@@ -5610,14 +5610,14 @@
 #: ../lib/gis/get_projinfo.c:37 ../lib/gis/get_projinfo.c:66
 #, c-format
 msgid "<%s> file not found for location <%s>"
-msgstr "Arquivo <%s> não encontrado para locação <%s>"
+msgstr "Arquivo <%s> não encontrado para locação <%s>"
 #: ../lib/gis/color_rules.c:88
 #, fuzzy
 msgid "no description"
 msgstr ""
 "\n"
-"Descrição:\n"
+"Descrição:\n"
 #: ../lib/gis/spawn.c:386
 #, c-format
@@ -5627,64 +5627,64 @@
 #: ../lib/gis/spawn.c:421
 #, fuzzy, c-format
 msgid "G_spawn: unable to redirect descriptor %d"
-msgstr "G_spawn: não consegui duplicar o descritor %d para %d"
+msgstr "G_spawn: não consegui duplicar o descritor %d para %d"
 #: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
 #, c-format
 msgid "G_spawn: unable to open file %s"
-msgstr "G_spawn: não consegui abrir o arquivo %s"
+msgstr "G_spawn: não consegui abrir o arquivo %s"
 #: ../lib/gis/spawn.c:503 ../lib/gis/spawn.c:689
 msgid "Unable to execute command"
-msgstr "Impossível executar o comando"
+msgstr "Impossível executar o comando"
 #: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
 #, c-format
 msgid "G_spawn: unable to restore signal %d"
-msgstr "G_spawn: não é possível restabelecer o sinal %d"
+msgstr "G_spawn: não é possível restabelecer o sinal %d"
 #: ../lib/gis/spawn.c:567
 #, c-format
 msgid "G_spawn: unable to reset signal %d"
-msgstr "G_spawn: não é possível reiniciar o sinal %d"
+msgstr "G_spawn: não é possível reiniciar o sinal %d"
 #: ../lib/gis/spawn.c:576
 #, c-format
 msgid "G_spawn: unable to ignore signal %d"
-msgstr "G_spawn: não é possível ignorar o sinal %d"
+msgstr "G_spawn: não é possível ignorar o sinal %d"
 #: ../lib/gis/spawn.c:587
 #, c-format
 msgid "G_spawn: unable to block signal %d"
-msgstr "G_spawn: não é possível bloquear o sinal %d"
+msgstr "G_spawn: não é possível bloquear o sinal %d"
 #: ../lib/gis/spawn.c:595
 #, c-format
 msgid "G_spawn: unable to unblock signal %d"
-msgstr "G_spawn: não é possível desbloquear o sinal %d"
+msgstr "G_spawn: não é possível desbloquear o sinal %d"
 #: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
 #, c-format
 msgid "G_spawn: unable to duplicate descriptor %d to %d"
 #: ../lib/gis/spawn.c:666
 msgid "Unable to create a new process"
-msgstr "Impossível criar novo processo"
+msgstr "Impossível criar novo processo"
 #: ../lib/gis/spawn.c:681
 #, c-format
 msgid "Unable to change directory to %s"
 #: ../lib/gis/error.c:361
 msgid "WARNING: "
-msgstr "ATENÇÃO: "
+msgstr "ATENÇÃO: "
 #: ../lib/gis/key_value3.c:33
 #, fuzzy, c-format
 msgid "Unable to open output file <%s>: %s"
 #: ../lib/gis/key_value3.c:36
 #, fuzzy, c-format
@@ -5694,22 +5694,22 @@
 #: ../lib/gis/key_value3.c:39
 #, fuzzy, c-format
 msgid "Error closing output file <%s>: %s"
 #: ../lib/gis/key_value3.c:60
 #, fuzzy, c-format
 msgid "Unable to open input file <%s>: %s"
 #: ../lib/gis/key_value3.c:64
 #, fuzzy, c-format
 msgid "Error reading file <%s>: %s"
-msgstr "não consegui ler arquivo de intervalo para [%s em %s]"
+msgstr "não consegui ler arquivo de intervalo para [%s em %s]"
 #: ../lib/gis/key_value3.c:67
 #, fuzzy, c-format
 msgid "Error closing input file <%s>: %s"
-msgstr "não consegui encontrar mapa de entrada '%s'"
+msgstr "não consegui encontrar mapa de entrada '%s'"
 #: ../lib/gis/gisinit.c:53 ../lib/gis/gisinit.c:87
 #, c-format
@@ -5721,49 +5721,49 @@
 #: ../lib/gis/gisinit.c:65
 #, c-format
 msgid "MAPSET %s - permission denied"
-msgstr "MAPSET %s - permissão negada"
+msgstr "MAPSET %s - permissão negada"
 #: ../lib/gis/gisinit.c:68
 #, fuzzy, c-format
 msgid "MAPSET %s not found at %s"
-msgstr "MAPSET %s não encontrado"
+msgstr "MAPSET %s não encontrado"
 #: ../lib/gis/gisinit.c:102
 #, fuzzy
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
 msgstr ""
 "G_gisinit()\n"
 #: ../lib/gis/legal_name.c:39
 #, fuzzy, c-format
 msgid "Illegal filename <%s>. Cannot start with '.' or be 'NULL'."
 #: ../lib/gis/legal_name.c:46
 #, fuzzy, c-format
 msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
 #: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
 #, fuzzy, c-format
 msgid "Output raster map name <%s> is not valid map name"
-msgstr "Nome de arquivo de saída '%s' não é um nome de raster válido."
+msgstr "Nome de arquivo de saída '%s' não é um nome de raster válido."
 #: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
 #, fuzzy, c-format
 msgid "Output raster map <%s> is used as input"
-msgstr "Mapa de saída '%s' usado como entrada"
+msgstr "Mapa de saída '%s' usado como entrada"
 #: ../lib/gis/paths.c:201
 #, fuzzy, c-format
 msgid "Unable to open file <%s> for reading"
-msgstr "não consegui abrir %s para escrita"
+msgstr "não consegui abrir %s para escrita"
 #: ../lib/gis/paths.c:217
 #, fuzzy, c-format
 msgid "Unable to fetch security info for <%s>"
-msgstr "não consegui escrever os dados históricos para [%s]"
+msgstr "não consegui escrever os dados históricos para [%s]"
 #: ../lib/gis/parser_dependencies.c:122
 msgid "Internal error: option or flag not found"
@@ -5772,7 +5772,7 @@
 #: ../lib/gis/parser_dependencies.c:179
 #, fuzzy, c-format
 msgid "<%s> or <%s>"
-msgstr "não consegui abrir banco de dados %s"
+msgstr "não consegui abrir banco de dados %s"
 #, fuzzy, c-format
@@ -5817,29 +5817,29 @@
 #: ../lib/gis/view.c:176
 #, c-format
 msgid "Unable to open %s for writing"
 #: ../lib/gis/view.c:262 ../lib/gis/view.c:479
 #, c-format
 msgid "Unable to open %s for reading"
-msgstr "não consegui abrir %s para leitura"
+msgstr "não consegui abrir %s para leitura"
 #: ../lib/gis/view.c:465
 #, c-format
 msgid "GRASS window when view was saved:\n"
-msgstr "Janela do GRASS quando a visão foi salva:\n"
+msgstr "Janela do GRASS quando a visão foi salva:\n"
 #: ../lib/gis/view.c:545
 #, c-format
 msgid " Window saved in \"%s\" is completely outside of current GRASS window."
 msgstr ""
-" Janela gravada em \"%s\" está completamente fora da janela atual do GRASS."
+" Janela gravada em \"%s\" está completamente fora da janela atual do GRASS."
 #: ../lib/gis/view.c:549
 #, c-format
 msgid ""
 " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr "Apenas %d%% da janela salva em \"%s\" sobrepõe a janela atual do GRASS"
+msgstr "Apenas %d%% da janela salva em \"%s\" sobrepõe a janela atual do GRASS"
 #: ../lib/gpde/n_gwflow.c:436 ../lib/gpde/n_gwflow.c:715
 #, c-format
@@ -5862,7 +5862,7 @@
 #: ../lib/gpde/n_arrays_io.c:93
 #, c-format
 msgid "Reading raster map <%s> into memory"
-msgstr "Carregando mapa raster <%s> na memória"
+msgstr "Carregando mapa raster <%s> na memória"
 #: ../lib/gpde/n_arrays_io.c:183
 msgid "N_array_2d * array is empty"
@@ -5895,7 +5895,7 @@
 #: ../lib/htmldriver/graph_set.c:97
 #, fuzzy, c-format
 msgid "html: collecting to file '%s'"
-msgstr "não consegui obter informações sobre o arquivo '%s'"
+msgstr "não consegui obter informações sobre o arquivo '%s'"
 #: ../lib/htmldriver/graph_set.c:98
 #, c-format
@@ -5915,7 +5915,7 @@
 #: ../lib/temporal/lib/connect.c:110
 #, fuzzy, c-format
 msgid "Mapset <%s> does not exist."
 #: ../lib/arraystats/class.c:19
 #, fuzzy, c-format
@@ -5949,7 +5949,7 @@
 #: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
 #, c-format
 msgid "[%s]: No such color"
-msgstr "[%s]: cor não existe"
+msgstr "[%s]: cor não existe"
 #: ../lib/display/r_raster.c:98
 #, c-format
@@ -5966,12 +5966,12 @@
 #: ../lib/display/r_raster.c:150
 #, fuzzy, c-format
 msgid "Unknown display driver <%s>"
 #: ../lib/display/r_raster.c:151
 #, fuzzy, c-format
 msgid "Using display driver <%s>..."
 #: ../lib/cluster/c_exec.c:44
 #, c-format
@@ -5995,17 +5995,17 @@
 #: ../lib/init/lock.c:60
 #, fuzzy, c-format
 msgid "Unable to write lockfile %s (%s)"
 #: ../lib/init/grass.py:123
 #, fuzzy
 msgid "WARNING"
-msgstr "ATENÇÃO: "
+msgstr "ATENÇÃO: "
 #: ../lib/init/grass.py:188
 #, fuzzy
 msgid "Exiting..."
-msgstr "Anexando centróides:"
+msgstr "Anexando centróides:"
 #: ../lib/init/grass.py:332
 #, fuzzy
@@ -6043,7 +6043,7 @@
 #: ../lib/init/grass.py:340 ../lib/init/grass.py:342 ../lib/init/grass.py:344
 #, fuzzy
 msgid "and set as default"
-msgstr "para aceitar os valores padrão"
+msgstr "para aceitar os valores padrão"
 #: ../lib/init/grass.py:341
 msgid "use text based interface (show welcome screen)"
@@ -6074,7 +6074,7 @@
 msgid "initial GRASS Location"
 msgstr ""
 "\n"
-"projeção inválida\n"
+"projeção inválida\n"
 #: ../lib/init/grass.py:351
 msgid ""
@@ -6151,7 +6151,7 @@
 #, fuzzy, python-format
 msgid ""
 "Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
-msgstr "não consegui alocar memória\n"
+msgstr "não consegui alocar memória\n"
 #: ../lib/init/grass.py:493
 #, python-brace-format
@@ -6161,7 +6161,7 @@
 #: ../lib/init/grass.py:547
 msgid "GUI <%s> not supported in this version"
-msgstr "O formato requisitado não foi compilado nesta versão"
+msgstr "O formato requisitado não foi compilado nesta versão"
 #: ../lib/init/grass.py:704
 msgid "Searched for a web browser, but none found"
@@ -6332,7 +6332,7 @@
 #: ../lib/init/grass.py:1311
 #, fuzzy
 msgid "The SHELL variable is not set"
 #: ../lib/init/grass.py:1327
@@ -6356,24 +6356,24 @@
 #: ../lib/init/grass.py:1365
 msgid "Executing <%s> ..."
 #: ../lib/init/grass.py:1372
 #, fuzzy, python-brace-format
 msgid ""
 "Execution of <{cmd}> failed:\n"
 "{error}"
 #: ../lib/init/grass.py:1375
 msgid "Execution of <%s> finished."
 #: ../lib/init/grass.py:1406
 #, fuzzy
 msgid "Unable to close GUI. {}"
-msgstr "não consegui abrir [%s]"
+msgstr "não consegui abrir [%s]"
 #: ../lib/init/grass.py:1433
 #, python-format
@@ -6392,7 +6392,7 @@
 #: ../lib/init/grass.py:1459
 #, fuzzy
 msgid "Help is available with the command:"
-msgstr "No há ajuda disponível para o comando [%s]\n"
+msgstr "No há ajuda disponível para o comando [%s]\n"
 #: ../lib/init/grass.py:1460
 msgid "See the licence terms with:"
@@ -6438,7 +6438,7 @@
 #: ../lib/init/grass.py:1605
 #, fuzzy
 msgid "Cleaning up temporary files..."
-msgstr "não consegui abrir arquivo temporário"
+msgstr "não consegui abrir arquivo temporário"
 #: ../lib/init/grass.py:1625
 msgid "Please install the GRASS GIS development package"
@@ -6447,7 +6447,7 @@
 #: ../lib/init/grass.py:1657
 msgid "Parameter <%s> not supported"
 #: ../lib/init/grass.py:1801
 msgid "Flag -e requires also flag -c"
@@ -6492,7 +6492,7 @@
 #: ../lib/init/grass.py:1970
 msgid "Failed to start shell '%s'"
 #: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
 #: ../lib/vector/neta/spanningtree.c:101 ../lib/vector/neta/flow.c:66
@@ -6518,12 +6518,12 @@
 #: ../lib/vector/vedit/delete.c:40
 #, fuzzy, c-format
 msgid "Attempt to delete dead feature (%d)"
 #: ../lib/vector/vedit/delete.c:72
 #, fuzzy, c-format
 msgid "No area found for centroid %d"
-msgstr "Número de áreas sem centróide :   %d\n"
+msgstr "Número de áreas sem centróide :   %d\n"
 #: ../lib/vector/vedit/delete.c:76
 #, c-format
@@ -6533,17 +6533,17 @@
 #: ../lib/vector/vedit/delete.c:105
 #, fuzzy, c-format
 msgid "Area %d without centroid"
 #: ../lib/vector/vedit/delete.c:121
 #, fuzzy, c-format
 msgid "Area %d has no boundaries"
 #: ../lib/vector/vedit/cats.c:63
 #, fuzzy, c-format
 msgid "Unable to set category %d for (feature id %d)"
 #: ../lib/vector/vedit/select.c:231
 #, fuzzy
@@ -6559,21 +6559,21 @@
 msgid ""
 "\n"
 "++ Running basic unit tests ++"
-msgstr "Tipo de interpolação desconhecida"
+msgstr "Tipo de interpolação desconhecida"
 #: ../lib/vector/rtree/test_suite/test_basics.c:48
 #, fuzzy
 msgid ""
 "\n"
 "-- Basic rtree unit tests failure --"
 #: ../lib/vector/rtree/test_suite/test_basics.c:50
 #, fuzzy
 msgid ""
 "\n"
 "-- Basic rtree unit tests finished successfully --"
 #: ../lib/vector/neta/spanningtree.c:106
 msgid "Computing minimum spanning tree..."
@@ -6588,12 +6588,12 @@
 #: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
 #, fuzzy, c-format
 msgid "Unable to open select cursor: %s"
 #: ../lib/vector/neta/utils.c:200
 #, fuzzy, c-format
 msgid "Point %d is not connected!"
 #: ../lib/vector/neta/utils.c:235
 #, c-format
@@ -6607,7 +6607,7 @@
 #: ../lib/vector/neta/utils.c:247
 #, fuzzy
 msgid "Unable to load data from database"
-msgstr "não é possível adicionar um link ao banco de dados."
+msgstr "não é possível adicionar um link ao banco de dados."
 #: ../lib/vector/neta/utils.c:254
 #, fuzzy
@@ -6623,7 +6623,7 @@
 #: ../lib/vector/Vlib/write_sfa.c:207
 #, fuzzy, c-format
 msgid "Attempt to access feature with invalid id (%d)"
 #: ../lib/vector/Vlib/write_nat.c:301 ../lib/vector/Vlib/write_nat.c:657
 #: ../lib/vector/Vlib/read_pg.c:337 ../lib/vector/Vlib/read_sfa.c:56
@@ -6632,17 +6632,17 @@
 #: ../lib/vector/Vlib/read_nat.c:150
 #, fuzzy, c-format
 msgid "Attempt to access dead feature %d"
 #: ../lib/vector/Vlib/write_nat.c:398
 #, fuzzy
 msgid "Attempt to access feature with invalid id (%"
 #: ../lib/vector/Vlib/write_nat.c:404
 #, fuzzy, c-format
 msgid "Attempt to access alive feature %d"
 #: ../lib/vector/Vlib/write_nat.c:566 ../lib/vector/Vlib/write_nat.c:602
 #, c-format
@@ -6652,7 +6652,7 @@
 #: ../lib/vector/Vlib/write_nat.c:756
 #, fuzzy, c-format
 msgid "Attempt to access dead area %d"
 #: ../lib/vector/Vlib/write_ogr.c:69 ../lib/vector/Vlib/write_ogr.c:105
 #: ../lib/vector/Vlib/write_ogr.c:145 ../lib/vector/Vlib/field.c:675
@@ -6674,7 +6674,7 @@
 #: ../lib/vector/Vlib/write_pg.c:255 ../lib/vector/Vlib/write_sfa.c:164
 #, fuzzy
 msgid "Unable to rewrite feature (incompatible feature types)"
-msgstr "não consegui escrever a linha (deslocamento negativo)"
+msgstr "não consegui escrever a linha (deslocamento negativo)"
 #: ../lib/vector/Vlib/write_ogr.c:129 ../lib/vector/Vlib/open_ogr.c:65
 msgid "OGR layer not defined"
@@ -6683,17 +6683,17 @@
 #: ../lib/vector/Vlib/write_ogr.c:134 ../lib/vector/Vlib/write_pg.c:326
 #, fuzzy, c-format
 msgid "Invalid offset (%ld)"
 #: ../lib/vector/Vlib/write_ogr.c:140 ../lib/vector/Vlib/write_pg.c:347
 #, fuzzy
 msgid "Unable to delete feature"
 #: ../lib/vector/Vlib/write_ogr.c:239
 #, fuzzy, c-format
 msgid "Creating field <%s> failed"
 #: ../lib/vector/Vlib/write_ogr.c:304 ../lib/vector/Vlib/write_pg.c:1104
 #, c-format
@@ -6703,7 +6703,7 @@
 #: ../lib/vector/Vlib/write_ogr.c:326
 #, fuzzy, c-format
 msgid "Unable to create OGR layer <%s> in '%s'"
 #: ../lib/vector/Vlib/write_ogr.c:338 ../lib/vector/Vlib/write_pg.c:1117
 #, c-format
@@ -6754,27 +6754,27 @@
 #: ../lib/vector/Vlib/write_ogr.c:500
 #, fuzzy
 msgid "Unable to writes feature attributes"
-msgstr "não consegui escrever os links para o banco de dados"
+msgstr "não consegui escrever os links para o banco de dados"
 #: ../lib/vector/Vlib/write_ogr.c:565
 #, fuzzy, c-format
 msgid "Feature without category of layer %d"
-msgstr "Feição %d sem geometria ignorada"
+msgstr "Feição %d sem geometria ignorada"
 #: ../lib/vector/Vlib/write_ogr.c:579 ../lib/vector/Vlib/write_pg.c:2005
 #, fuzzy, c-format
 msgid "Unable to select attributes for category %d"
 #: ../lib/vector/Vlib/write_ogr.c:591 ../lib/vector/Vlib/write_pg.c:2014
 #, fuzzy, c-format
 msgid "No database record for category %d, no attributes will be written"
-msgstr "Registro no banco de dados para categoria %d não encontrado"
+msgstr "Registro no banco de dados para categoria %d não encontrado"
 #: ../lib/vector/Vlib/write_ogr.c:624
 #, fuzzy, c-format
 msgid "Unable to create field <%s>"
 #: ../lib/vector/Vlib/write_ogr.c:653 ../lib/vector/Vlib/write_pg.c:2074
 #, fuzzy, c-format
@@ -6793,12 +6793,12 @@
 #: ../lib/vector/Vlib/remove_areas.c:395
 #, fuzzy
 msgid "Could not delete line from coor"
-msgstr "não consegui reescrever a linha"
+msgstr "não consegui reescrever a linha"
 #: ../lib/vector/Vlib/remove_areas.c:458
 #, fuzzy
 msgid "dissolve_neighbour > 0, failed to build new area"
-msgstr "não consegui encontrar vetor %s"
+msgstr "não consegui encontrar vetor %s"
 #: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:501
 msgid "Dissolve with neighbour area: corrupt topology"
@@ -6807,12 +6807,12 @@
 #: ../lib/vector/Vlib/remove_areas.c:497
 #, fuzzy
 msgid "Failed to build new area"
 #: ../lib/vector/Vlib/remove_areas.c:544 ../lib/vector/Vlib/remove_areas.c:571
 #, fuzzy
 msgid "Failed to build new isle"
 #: ../lib/vector/Vlib/remove_areas.c:549 ../lib/vector/Vlib/remove_areas.c:576
 msgid "Dissolve with outer isle: corrupt topology"
@@ -6821,41 +6821,41 @@
 #: ../lib/vector/Vlib/remove_areas.c:581
 #, fuzzy
 msgid "Area merging failed"
 #: ../lib/vector/Vlib/rewind.c:29 ../lib/vector/Vlib/write.c:56
 #: ../lib/vector/Vlib/write.c:62 ../lib/vector/Vlib/open.c:59
 #: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/read.c:32
 #: ../lib/vector/Vlib/build.c:37
 msgid "Requested format is not compiled in this version"
 #: ../lib/vector/Vlib/field.c:91
 #, fuzzy
 msgid "Layer number must be 1 or greater"
-msgstr "Número do campo deve ser 1 ou maior."
+msgstr "Número do campo deve ser 1 ou maior."
 #: ../lib/vector/Vlib/field.c:96
 #, fuzzy
 msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
 msgstr ""
-"não é possível adicionar um link ao banco de dados, o mapa não está aberto "
+"não é possível adicionar um link ao banco de dados, o mapa não está aberto "
 "em modo ESCRITA."
 #: ../lib/vector/Vlib/field.c:103
 #, fuzzy
 msgid "Unable to add attribute link"
 #: ../lib/vector/Vlib/field.c:109
 #, fuzzy
 msgid "Unable to write attribute links"
 #: ../lib/vector/Vlib/field.c:154
 #, fuzzy
 msgid "Unable to write database links"
 #: ../lib/vector/Vlib/field.c:178
 msgid "Database connection not defined. Skipping."
@@ -6870,7 +6870,7 @@
 #: ../lib/vector/Vlib/field.c:261
 #, fuzzy, c-format
 msgid "Layer number %d or name <%s> already exists"
 #: ../lib/vector/Vlib/field.c:345
 #, fuzzy, c-format
@@ -6879,22 +6879,22 @@
 "driver: %s\n"
 "database: %s"
 msgstr ""
-"Driver padrão/ banco de dados ajustados para:\n"
+"Driver padrão/ banco de dados ajustados para:\n"
 "driver: dbf\n"
 "banco: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/"
 #: ../lib/vector/Vlib/field.c:352
 msgid "Default driver is not set"
-msgstr "Driver padrão não foi especificado"
+msgstr "Driver padrão não foi especificado"
 #: ../lib/vector/Vlib/field.c:355
 msgid "Default database is not set"
-msgstr "Banco de dados padrão não foi especificado"
+msgstr "Banco de dados padrão não foi especificado"
 #: ../lib/vector/Vlib/field.c:428
 #, c-format
 msgid "Requested dblink %d, maximum link number %d"
-msgstr "dblink %d solicitado, %d links no máximo"
+msgstr "dblink %d solicitado, %d links no máximo"
 #: ../lib/vector/Vlib/field.c:614 ../lib/vector/Vlib/field.c:622
 #, fuzzy, c-format
@@ -6904,17 +6904,17 @@
 #: ../lib/vector/Vlib/field.c:690 ../lib/vector/Vlib/open_ogr.c:77
 #, fuzzy, c-format
 msgid "Unable to open OGR data source '%s'"
 #: ../lib/vector/Vlib/field.c:707
 #, fuzzy, c-format
 msgid "Unable to open OGR layer <%s>"
 #: ../lib/vector/Vlib/field.c:734
 #, fuzzy
 msgid "Unable to open OGR DBMI driver"
-msgstr "não consegui abrir driver DBMI OGR"
+msgstr "não consegui abrir driver DBMI OGR"
 #: ../lib/vector/Vlib/field.c:773
 msgid ""
@@ -6940,12 +6940,12 @@
 #: ../lib/vector/Vlib/field.c:925
 #, fuzzy, c-format
 msgid "Unable to create database definition file for vector map <%s>"
 #: ../lib/vector/Vlib/field.c:1020
 #, fuzzy
 msgid "Bug: attempt to update map which is not in current mapset"
 #: ../lib/vector/Vlib/build_nat.c:74 ../lib/vector/Vlib/build_sfa.c:339
 #: ../lib/vector/Vlib/build_sfa.c:629
@@ -6956,7 +6956,7 @@
 #: ../lib/vector/Vlib/build_nat.c:84
 #, fuzzy
 msgid "Unable to read vector map"
 #: ../lib/vector/Vlib/build_nat.c:117 ../lib/vector/Vlib/build_sfa.c:385
 #: ../lib/vector/Vlib/build_sfa.c:661
@@ -7001,12 +7001,12 @@
 #: ../lib/vector/Vlib/build_nat.c:180
 #, fuzzy
 msgid "Attaching centroids..."
 #: ../lib/vector/Vlib/open_nat.c:56
 #, fuzzy, c-format
 msgid "Unable to open coor file for vector map <%s>"
 #: ../lib/vector/Vlib/open_nat.c:152
 #, c-format
@@ -7026,85 +7026,85 @@
 #: ../lib/vector/Vlib/read.c:25
 #, fuzzy
 msgid "for this format/level not supported"
-msgstr "Vect_write_line() não é suportada para este nível/formato"
+msgstr "Vect_write_line() não é suportada para este nível/formato"
 #: ../lib/vector/Vlib/write.c:194
 #, fuzzy, c-format
 msgid "Unable to write feature in vector map <%s>"
 #: ../lib/vector/Vlib/write.c:234
 #, fuzzy, c-format
 msgid "Unable to rewrite feature/offset %lu in vector map <%s>"
 #: ../lib/vector/Vlib/write.c:266
 #, fuzzy, c-format
 msgid "Unable to delete feature/offset %lu from vector map <%s>"
 #: ../lib/vector/Vlib/write.c:299
 #, fuzzy
 msgid "Unable to restore feature/offset %"
 #: ../lib/vector/Vlib/write.c:308
 #, fuzzy, c-format
 msgid "Vector map <%s> is not opened"
 #: ../lib/vector/Vlib/write.c:313
 #, fuzzy, c-format
 msgid "Vector map <%s> is not opened in write mode"
 #: ../lib/vector/Vlib/clean_nodes.c:248
 #, fuzzy, c-format
 msgid "Modifications: %d"
 #: ../lib/vector/Vlib/map.c:139 ../lib/vector/Vlib/map.c:245
 #, fuzzy
 msgid "Vector map name is not SQL compliant"
-msgstr "Nome do mapa não obedece ao SQL"
+msgstr "Nome do mapa não obedece ao SQL"
 #: ../lib/vector/Vlib/map.c:143
 #, fuzzy, c-format
 msgid "Unable to find vector map <%s> in <%s>"
-msgstr "não foi possível abrir o mapa raster [%s em %s]"
+msgstr "não foi possível abrir o mapa raster [%s em %s]"
 #: ../lib/vector/Vlib/map.c:155 ../lib/vector/Vlib/map.c:249
 #: ../lib/vector/Vlib/open.c:821
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
-msgstr "O vetor '%s' já existe e será sobrescrito."
+msgstr "O vetor '%s' já existe e será sobrescrito."
 #: ../lib/vector/Vlib/map.c:159 ../lib/vector/Vlib/open.c:813
 #: ../lib/vector/Vlib/open.c:826
 #, fuzzy, c-format
 msgid "Unable to delete vector map <%s>"
 #: ../lib/vector/Vlib/map.c:179 ../lib/vector/Vlib/map.c:267
 #, fuzzy, c-format
 msgid "Unable to copy vector map <%s> to <%s>"
 #: ../lib/vector/Vlib/map.c:317 ../lib/vector/Vlib/copy.c:738
 #: ../lib/vector/Vlib/close_nat.c:102
 #, fuzzy, c-format
 msgid "Unable to copy table <%s>"
 #: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:462
 #, fuzzy, c-format
 msgid "Unable to delete table <%s>"
 #: ../lib/vector/Vlib/map.c:346
 #, fuzzy, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
 #: ../lib/vector/Vlib/map.c:402
 #, c-format
@@ -7114,42 +7114,42 @@
 #: ../lib/vector/Vlib/map.c:407
 #, fuzzy, c-format
 msgid "Invalid vector map name <%s>"
 #: ../lib/vector/Vlib/map.c:417
 #, fuzzy, c-format
 msgid "Unable to open header file for vector map <%s>"
 #: ../lib/vector/Vlib/map.c:449
 #, fuzzy, c-format
 msgid "Unable to find table <%s> linked to vector map <%s>"
 #: ../lib/vector/Vlib/map.c:472
 #, fuzzy, c-format
 msgid "Table <%s> linked to vector map <%s> does not exist"
 #: ../lib/vector/Vlib/map.c:485
 #, fuzzy, c-format
 msgid "Unable to open directory '%s'"
 #: ../lib/vector/Vlib/map.c:499
 #, fuzzy, c-format
 msgid "Unable to delete file '%s'"
 #: ../lib/vector/Vlib/map.c:519
 #, fuzzy, c-format
 msgid "Unable to rename directory '%s' to '%s'"
 #: ../lib/vector/Vlib/map.c:528
 #, fuzzy, c-format
 msgid "Unable to remove directory '%s': %s"
 #: ../lib/vector/Vlib/read_pg.c:91 ../lib/vector/Vlib/read_pg.c:214
 #: ../lib/vector/Vlib/read_pg.c:298 ../lib/vector/Vlib/read_pg.c:416
@@ -7177,7 +7177,7 @@
 #: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
 #, fuzzy, c-format
 msgid "Feature %ld without geometry skipped"
 #: ../lib/vector/Vlib/read_pg.c:365
 #, c-format
@@ -7194,12 +7194,12 @@
 #: ../lib/vector/Vlib/build_sfa.c:364
 #, fuzzy, c-format
 msgid "Feature %d without geometry skipped"
 #: ../lib/vector/Vlib/read_pg.c:482 ../lib/vector/Vlib/read_ogr.c:382
 #, fuzzy
 msgid "Feature without geometry. Skipped."
 #: ../lib/vector/Vlib/read_pg.c:575
 msgid "No geometry or topo geometry column defined"
@@ -7258,38 +7258,38 @@
 #: ../lib/vector/Vlib/read_pg.c:1405 ../lib/vector/Vlib/close_pg.c:66
 #, fuzzy, c-format
 msgid "Unable to close cursor %s"
 #: ../lib/vector/Vlib/read_pg.c:1515
 #, fuzzy, c-format
 msgid ""
 "Execution failed: %s (...)\n"
 "Reason: %s"
 #: ../lib/vector/Vlib/read_pg.c:1546
 #, fuzzy, c-format
 msgid ""
 "Execution failed: %s\n"
 "Reason: %s"
 #: ../lib/vector/Vlib/read_pg.c:1675
 #, fuzzy, c-format
 msgid ""
 "Unable to read features. Reason:\n"
 "%s"
 #: ../lib/vector/Vlib/header.c:86
 #, fuzzy, c-format
 msgid "Unable to create header file for vector map <%s>"
 #: ../lib/vector/Vlib/header.c:129
 #, fuzzy, c-format
 msgid "Unable to open header file of vector <%s>"
 #: ../lib/vector/Vlib/header.c:137
 #, c-format
@@ -7304,7 +7304,7 @@
 #: ../lib/vector/Vlib/read_sfa.c:90
 #, fuzzy, c-format
 msgid "Unable to construct centroid for area %d. Skipped."
 #: ../lib/vector/Vlib/read_sfa.c:95
 #, c-format
@@ -7319,19 +7319,19 @@
 #: ../lib/vector/Vlib/write_pg.c:285
 #, fuzzy, c-format
 msgid "Unable to rewrite feature %d"
 #: ../lib/vector/Vlib/write_pg.c:321 ../lib/vector/Vlib/write_pg.c:811
 #: ../lib/vector/Vlib/write_pg.c:1212 ../lib/vector/Vlib/write_pg.c:1364
 #: ../lib/vector/Vlib/simple_features.c:324
 #, fuzzy
 msgid "No connection defined"
 #: ../lib/vector/Vlib/write_pg.c:452
 #, fuzzy, c-format
 msgid "Unable to delete feature (%s) %d"
 #: ../lib/vector/Vlib/write_pg.c:554 ../lib/vector/Vlib/write_pg.c:1294
 #: ../lib/vector/Vlib/write_sfa.c:349
@@ -7342,7 +7342,7 @@
 #: ../lib/vector/Vlib/open.c:1355 ../lib/vector/Vlib/build_pg.c:411
 #, fuzzy
 msgid "Unable to open PG file"
 #: ../lib/vector/Vlib/write_pg.c:773
 #, fuzzy, c-format
@@ -7368,24 +7368,24 @@
 #: ../lib/vector/Vlib/open_pg.c:232
 #, fuzzy
 msgid "Connection string not defined"
 #: ../lib/vector/Vlib/write_pg.c:1077 ../lib/vector/Vlib/write_pg.c:1216
 #: ../lib/vector/Vlib/write_pg.c:1368 ../lib/vector/Vlib/open_pg.c:90
 #: ../lib/vector/Vlib/open_pg.c:237
 #, fuzzy
 msgid "PostGIS feature table not defined"
-msgstr "Ignorando feição OGR sem ID"
+msgstr "Ignorando feição OGR sem ID"
 #: ../lib/vector/Vlib/write_pg.c:1129
 #, fuzzy
 msgid "Unable to create new PostGIS feature table"
 #: ../lib/vector/Vlib/write_pg.c:1143
 #, fuzzy
 msgid "Unable to create new PostGIS topology schema"
 #: ../lib/vector/Vlib/write_pg.c:1250
 #, fuzzy, c-format
@@ -7410,12 +7410,12 @@
 #: ../lib/vector/Vlib/write_pg.c:1358
 #, fuzzy, c-format
 msgid "Invalid feature type (%d) for nodes"
 #: ../lib/vector/Vlib/write_pg.c:1372
 #, fuzzy
 msgid "PostGIS topology schema not defined"
 #: ../lib/vector/Vlib/write_pg.c:1872
 msgid "Trying to insert 3D data into feature table which store 2D data only"
@@ -7428,7 +7428,7 @@
 #: ../lib/vector/Vlib/write_pg.c:1902
 #, fuzzy
 msgid "Unable to insert topological element into PostGIS Topology schema"
 #: ../lib/vector/Vlib/write_pg.c:2040
 #, c-format
@@ -7442,27 +7442,27 @@
 #: ../lib/vector/Vlib/write_pg.c:2173
 #, fuzzy, c-format
 msgid "Invalid feature %d (max: %d)"
 #: ../lib/vector/Vlib/write_pg.c:2187
 #, fuzzy, c-format
 msgid "Invalid feature type (%d) for node"
 #: ../lib/vector/Vlib/write_pg.c:2191
 #, fuzzy, c-format
 msgid "Invalid node %d (%d)"
 #: ../lib/vector/Vlib/write_pg.c:2269
 #, fuzzy, c-format
 msgid "Unable to determine next left/right edge for edge %d"
 #: ../lib/vector/Vlib/write_pg.c:2274
 #, fuzzy
 msgid "Unable to insert new edge. Topology not available."
 #: ../lib/vector/Vlib/write_pg.c:2373 ../lib/vector/Vlib/write_pg.c:2380
 #, fuzzy
@@ -7472,22 +7472,22 @@
 #: ../lib/vector/Vlib/write_pg.c:2579 ../lib/vector/Vlib/write_pg.c:2676
 #, fuzzy, c-format
 msgid "Attempt to access non-existing feature %d"
 #: ../lib/vector/Vlib/write_pg.c:2610
 #, fuzzy
 msgid "Unable to determine next left/right edge"
 #: ../lib/vector/Vlib/write_pg.c:2696
 #, fuzzy
 msgid "Unable to create new face"
 #: ../lib/vector/Vlib/write_pg.c:2834 ../lib/vector/Vlib/write_pg.c:2846
 #, fuzzy, c-format
 msgid "Unable to delete node %d"
 #: ../lib/vector/Vlib/dangles.c:148
 msgid "Changed"
@@ -7504,7 +7504,7 @@
 #: ../lib/vector/Vlib/dangles.c:262
 #, fuzzy, c-format
 msgid "%s lines: %d"
-msgstr "Número de linhas     :   %d\n"
+msgstr "Número de linhas     :   %d\n"
 #: ../lib/vector/Vlib/dangles.c:263
 #, c-format
@@ -7514,30 +7514,30 @@
 #: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
 #, fuzzy, c-format
 msgid "Unable to calculate centroid for area %d"
 #: ../lib/vector/Vlib/build_sfa.c:305
 #, fuzzy, c-format
 msgid "Feature type %d not supported"
 #: ../lib/vector/Vlib/build_sfa.c:603 ../lib/vector/Vlib/read_ogr.c:344
 #: ../lib/vector/Vlib/read_ogr.c:578
 #, fuzzy, c-format
 msgid "OGR feature type %d not supported"
 #: ../lib/vector/Vlib/build_sfa.c:665
 #, fuzzy, c-format
 msgid "One feature without geometry skipped"
 msgid_plural "%d features without geometry skipped"
-msgstr[0] "Feição %d sem geometria ignorada"
-msgstr[1] "Feição %d sem geometria ignorada"
+msgstr[0] "Feição %d sem geometria ignorada"
+msgstr[1] "Feição %d sem geometria ignorada"
 #: ../lib/vector/Vlib/build_sfa.c:722
 #, fuzzy, c-format
 msgid "%s: Native format unsupported"
 #: ../lib/vector/Vlib/build_sfa.c:748
 msgid "Feature index is built only for non-native formats. Nothing to dump."
@@ -7546,7 +7546,7 @@
 #: ../lib/vector/Vlib/buffer2.c:361
 #, fuzzy
 msgid "Line is not looped"
 #: ../lib/vector/Vlib/buffer2.c:443
 #, c-format
@@ -7574,7 +7574,7 @@
 #: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
 #, fuzzy
 msgid "Line was not closed"
 #: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
 msgid "Vect_get_point_in_poly() failed"
@@ -7583,42 +7583,42 @@
 #: ../lib/vector/Vlib/open_ogr.c:60
 #, fuzzy
 msgid "OGR datasource not defined"
 #: ../lib/vector/Vlib/open_ogr.c:97
 #, fuzzy, c-format
 msgid "OGR layer <%s> not found"
 #: ../lib/vector/Vlib/open_ogr.c:145 ../lib/vector/Vlib/open_pg.c:193
 #, fuzzy, c-format
 msgid "Unable to open feature index file for vector map <%s>"
 #: ../lib/vector/Vlib/open_ogr.c:191
 #, fuzzy, c-format
 msgid "Unable to get OGR driver <%s>"
 #: ../lib/vector/Vlib/open_ogr.c:199
 #, fuzzy, c-format
 msgid "Unable to create OGR data source '%s'"
 #: ../lib/vector/Vlib/open_ogr.c:211
 #, fuzzy, c-format
 msgid "OGR layer <%s> already exists and will be overwritten"
 #: ../lib/vector/Vlib/open_ogr.c:215
 #, fuzzy, c-format
 msgid "Unable to delete OGR layer <%s>"
 #: ../lib/vector/Vlib/open_ogr.c:221
 #, fuzzy, c-format
 msgid "OGR layer <%s> already exists in datasource '%s'"
 #: ../lib/vector/Vlib/open_ogr.c:279
 #, c-format
@@ -7650,7 +7650,7 @@
 #: ../lib/vector/Vlib/remove_duplicates.c:199
 #, fuzzy, c-format
 msgid "Removed duplicates: %d"
 #: ../lib/vector/Vlib/break_polygons.c:102
 msgid "Break polygons: Bug in binary tree!"
@@ -7679,7 +7679,7 @@
 #: ../lib/vector/Vlib/legal_vname.c:43
 #, fuzzy, c-format
 msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr "Nome de mapa de vetor <%s> ilegal. não pode conter '.' ou 'NULL'.\n"
+msgstr "Nome de mapa de vetor <%s> ilegal. não pode conter '.' ou 'NULL'.\n"
 #: ../lib/vector/Vlib/legal_vname.c:50
 #, fuzzy, c-format
@@ -7689,28 +7689,28 @@
 #: ../lib/vector/Vlib/legal_vname.c:58
 #, fuzzy, c-format
 msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr "Nome de mapa de vetor <%s> ilegal. Caractere <%c> não permitido.\n"
+msgstr "Nome de mapa de vetor <%s> ilegal. Caractere <%c> não permitido.\n"
 #: ../lib/vector/Vlib/legal_vname.c:65
 #, fuzzy, c-format
 msgid ""
 "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
 #: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
 #, fuzzy, c-format
 msgid "Output vector map name <%s> is not in the current mapset (%s)"
 #: ../lib/vector/Vlib/legal_vname.c:117 ../lib/vector/Vlib/legal_vname.c:121
 #, fuzzy, c-format
 msgid "Output vector map name <%s> is not SQL compliant"
 #: ../lib/vector/Vlib/legal_vname.c:159 ../lib/vector/Vlib/legal_vname.c:163
 #, fuzzy, c-format
 msgid "Output vector map <%s> is used as input"
 #: ../lib/vector/Vlib/intersect2.c:1169 ../lib/vector/Vlib/intersect2.c:1175
 #: ../lib/vector/Vlib/intersect2.c:1177 ../lib/vector/Vlib/intersect2.c:1229
@@ -7725,17 +7725,17 @@
 #: ../lib/vector/Vlib/copy.c:81
 #, fuzzy, c-format
 msgid "Unable to copy features. Input vector map <%s> is not open"
-msgstr "não consegui escrever a linha, o mapa não foi aberto"
+msgstr "não consegui escrever a linha, o mapa não foi aberto"
 #: ../lib/vector/Vlib/copy.c:104
 #, fuzzy, c-format
 msgid "Unable to create PostGIS layer <%s>"
 #: ../lib/vector/Vlib/copy.c:133
 #, fuzzy, c-format
 msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
 #: ../lib/vector/Vlib/copy.c:229 ../lib/vector/Vlib/copy.c:234
 #, fuzzy
@@ -7754,17 +7754,17 @@
 #: ../lib/vector/Vlib/copy.c:340
 #, fuzzy, c-format
 msgid "%d features without category or from different layer skipped"
 #: ../lib/vector/Vlib/copy.c:372
 #, fuzzy
 msgid "Exporting nodes..."
 #: ../lib/vector/Vlib/copy.c:400
 #, fuzzy, c-format
 msgid "Writing node %d failed"
 #: ../lib/vector/Vlib/copy.c:478
 #, fuzzy
@@ -7779,87 +7779,87 @@
 #: ../lib/vector/Vlib/copy.c:534 ../lib/vector/Vlib/copy.c:542
 #, fuzzy, c-format
 msgid "Writing area %d failed"
 #: ../lib/vector/Vlib/copy.c:550
 #, fuzzy, c-format
 msgid "%d areas without category or from different layer skipped"
 #: ../lib/vector/Vlib/copy.c:604
 #, fuzzy, c-format
 msgid "Unable to copy table <%s> for layer %d from <%s> to <%s>"
 #: ../lib/vector/Vlib/copy.c:723
 #, fuzzy, c-format
 msgid "Unable to add database link for vector map <%s>"
 #: ../lib/vector/Vlib/copy.c:747
 #, fuzzy, c-format
 msgid "Unable to open database <%s> with driver <%s>"
 #: ../lib/vector/Vlib/copy.c:754
 #, fuzzy
 msgid "Unable to create index"
 #: ../lib/vector/Vlib/copy.c:760
 #, fuzzy, c-format
 msgid "Unable to grant privileges on table <%s>"
 #: ../lib/vector/Vlib/open.c:138
 #, fuzzy, c-format
 msgid "Programmer requested unknown access level %d"
-msgstr "ATENÇÃO: Programador solicitou open_level desconhecido\n"
+msgstr "ATENÇÃO: Programador solicitou open_level desconhecido\n"
 #: ../lib/vector/Vlib/open.c:232
 #, fuzzy, c-format
 msgid "Vector map <%s> not found in current mapset"
 #: ../lib/vector/Vlib/open.c:252
 #, fuzzy
 msgid "Temporary vector maps can be accessed only in the current mapset"
 #: ../lib/vector/Vlib/open.c:277
 #, fuzzy
 msgid ""
 "Vector map which is not in the current mapset cannot be opened for update"
 msgstr ""
-"Um mapa que não está no mapset atual não pode ser aberto para atualização."
+"Um mapa que não está no mapset atual não pode ser aberto para atualização."
 #: ../lib/vector/Vlib/open.c:311
 #, fuzzy, c-format
 msgid "Unable to read header file of vector map <%s>"
 #: ../lib/vector/Vlib/open.c:352
 #, fuzzy, c-format
 msgid "Unable to open topology file for vector map <%s>"
 #: ../lib/vector/Vlib/open.c:367 ../lib/vector/Vlib/open.c:871
 #: ../lib/vector/Vlib/build.c:865
 #, fuzzy, c-format
 msgid "Unable to open spatial index file for vector map <%s>"
 #: ../lib/vector/Vlib/open.c:393 ../lib/vector/Vlib/cindex.c:539
 #, fuzzy, c-format
 msgid "Unable to open category index file for vector map <%s>"
 #: ../lib/vector/Vlib/open.c:419
 #, fuzzy, c-format
 msgid ""
 "Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
 "with v.build."
-msgstr "não consegui abrir vetor antigo %s no nível %d"
+msgstr "não consegui abrir vetor antigo %s no nível %d"
 #: ../lib/vector/Vlib/open.c:445
 #, fuzzy, c-format
@@ -7869,27 +7869,27 @@
 #: ../lib/vector/Vlib/open.c:453
 #, fuzzy, c-format
 msgid "Unable to open vector map <%s> on level %d"
 #: ../lib/vector/Vlib/open.c:507
 #, fuzzy, c-format
 msgid "Unable to open history file for vector map <%s>"
 #: ../lib/vector/Vlib/open.c:777
 #, fuzzy, c-format
 msgid "Unable to create vector map: <%s> is not in the current mapset (%s)"
 #: ../lib/vector/Vlib/open.c:786
 #, fuzzy, c-format
 msgid "Unable to create vector map: <%s> is not SQL compliant"
 #: ../lib/vector/Vlib/open.c:846
 #, fuzzy, c-format
 msgid "Unable to open history file of vector map <%s>"
 #: ../lib/vector/Vlib/open.c:887
 #, c-format
@@ -7907,12 +7907,12 @@
 #: ../lib/vector/Vlib/open.c:896
 #, fuzzy
 msgid "Using native format"
 #: ../lib/vector/Vlib/open.c:985
 #, fuzzy, c-format
 msgid "Unable to stat file <%s>"
 #: ../lib/vector/Vlib/open.c:1049
 #, c-format
@@ -7937,7 +7937,7 @@
 #: ../lib/vector/Vlib/open.c:1317
 #, fuzzy
 msgid "Unable to open OGR file"
 #: ../lib/vector/Vlib/open.c:1343
 msgid "OGR output also detected, using OGR"
@@ -7946,7 +7946,7 @@
 #: ../lib/vector/Vlib/close.c:91
 #, fuzzy, c-format
 msgid "Unable to create vector map <%s>"
 #: ../lib/vector/Vlib/close.c:108
 #, fuzzy
@@ -7956,12 +7956,12 @@
 #: ../lib/vector/Vlib/close.c:141
 #, fuzzy, c-format
 msgid "Unable to open %s file"
 #: ../lib/vector/Vlib/close.c:226
 #, fuzzy, c-format
 msgid "Unable to close vector <%s>"
 #: ../lib/vector/Vlib/close.c:257
 #, c-format
@@ -7971,7 +7971,7 @@
 #: ../lib/vector/Vlib/close.c:289
 #, fuzzy, c-format
 msgid "Link to vector map <%s> created"
 #: ../lib/vector/Vlib/cindex.c:32
 msgid "Category index is not up to date"
@@ -7980,22 +7980,22 @@
 #: ../lib/vector/Vlib/cindex.c:38
 #, fuzzy
 msgid "Layer index out of range"
-msgstr "Dimensões da matriz além dos limites"
+msgstr "Dimensões da matriz além dos limites"
 #: ../lib/vector/Vlib/cindex.c:268
 #, fuzzy
 msgid "Category index out of range"
 #: ../lib/vector/Vlib/cindex.c:488
 #, fuzzy, c-format
 msgid "Unable to create category index file for vector map <%s>"
 #: ../lib/vector/Vlib/cindex.c:497
 #, fuzzy
 msgid "Error writing out category index file"
-msgstr "Erro de escrita no arquivo de índices espaciais.\n"
+msgstr "Erro de escrita no arquivo de índices espaciais.\n"
 #: ../lib/vector/Vlib/snap.c:223 ../lib/vector/Vlib/snap.c:582
 msgid "Snap vertices Pass 1: select points"
@@ -8017,7 +8017,7 @@
 #: ../lib/vector/Vlib/snap.c:526 ../lib/vector/Vlib/snap.c:888
 #, fuzzy, c-format
 msgid "New vertices: %d"
-msgstr "Número de primitivas:   %d\n"
+msgstr "Número de primitivas:   %d\n"
 #: ../lib/vector/Vlib/snap.c:915
 #, fuzzy
@@ -8070,7 +8070,7 @@
 #: ../lib/vector/Vlib/build_pg.c:314
 #, fuzzy
 msgid "Updating edges..."
 #: ../lib/vector/Vlib/build_pg.c:323
 msgid "Inconsistency in topology detected. Dead line found."
@@ -8088,17 +8088,17 @@
 #: ../lib/vector/Vlib/build_pg.c:491
 #, fuzzy, c-format
 msgid "Unable to create <%s.%s>"
 #: ../lib/vector/Vlib/build_pg.c:642
 #, fuzzy
 msgid "Unable to write nodes, offset array mismatch"
-msgstr "impossível escrever arquivo de quantização!"
+msgstr "impossível escrever arquivo de quantização!"
 #: ../lib/vector/Vlib/build_pg.c:671
 #, fuzzy
 msgid "Unable to write nodes"
 #: ../lib/vector/Vlib/build_pg.c:716
 #, fuzzy, c-format
@@ -8108,12 +8108,12 @@
 #: ../lib/vector/Vlib/build_pg.c:739
 #, fuzzy
 msgid "Unable to write lines"
 #: ../lib/vector/Vlib/build_pg.c:790
 #, fuzzy, c-format
 msgid "Topology for centroid %d not available. Area %d skipped"
 #: ../lib/vector/Vlib/build_pg.c:1000
 msgid "Create simple features topology from topogeometry data..."
@@ -8129,37 +8129,37 @@
 #: ../lib/vector/Vlib/read.c:168
 #, fuzzy
 msgid "Vector map is not open for reading"
 #: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
 #, fuzzy, c-format
 msgid "Unable to read feature %d from vector map <%s>"
-msgstr "Impossível mudar de diretório para %s"
+msgstr "Impossível mudar de diretório para %s"
 #: ../lib/vector/Vlib/read.c:200
 #, fuzzy
 msgid "Line index is out of range"
 #: ../lib/vector/Vlib/read.c:224
 #, fuzzy
 msgid "Node index is out of range"
 #: ../lib/vector/Vlib/read.c:248
 #, fuzzy
 msgid "Area index is out of range"
 #: ../lib/vector/Vlib/read.c:272
 #, fuzzy
 msgid "Isle index is out of range"
 #: ../lib/vector/Vlib/geos.c:52
 #, fuzzy
 msgid "vector map is not opened"
 #: ../lib/vector/Vlib/geos.c:55
 #, c-format
@@ -8171,12 +8171,12 @@
 #: ../lib/vector/Vlib/geos.c:60
 #, fuzzy
 msgid "only native format supported"
 #: ../lib/vector/Vlib/geos.c:65 ../lib/vector/Vlib/geos.c:258
 #, fuzzy
 msgid "Attempt to read dead line"
 #: ../lib/vector/Vlib/geos.c:90
 #, c-format
@@ -8191,23 +8191,23 @@
 #: ../lib/vector/Vlib/geos.c:205
 #, fuzzy, c-format
 msgid "Unable to read line offset %ld"
 #: ../lib/vector/Vlib/geos.c:412
 #, fuzzy, c-format
 msgid "Attempt to read points of nonexistent area id %d"
-msgstr "não consegui calcular centróide para área %d"
+msgstr "não consegui calcular centróide para área %d"
 #: ../lib/vector/Vlib/geos.c:472
 #, fuzzy, c-format
 msgid "Unable to read feature id %d"
 #: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
 #: ../lib/vector/Vlib/line.c:250
 #, fuzzy
 msgid "Index out of range in"
 #: ../lib/vector/Vlib/line.c:550
 msgid "Segment outside line, no segment created"
@@ -8216,17 +8216,17 @@
 #: ../lib/vector/Vlib/close_nat.c:74
 #, fuzzy, c-format
 msgid "Unable to create '%s': %s"
 #: ../lib/vector/Vlib/close_nat.c:81
 #, fuzzy, c-format
 msgid "Unable to copy '%s': %s"
 #: ../lib/vector/Vlib/close_nat.c:167
 #, fuzzy, c-format
 msgid "Unable to drop table <%s>"
 #: ../lib/vector/Vlib/constraint.c:150
 msgid "Layer constraint ignored for non-native vector formats"
@@ -8235,12 +8235,12 @@
 #: ../lib/vector/Vlib/ascii.c:84
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad type) [%s]"
 #: ../lib/vector/Vlib/ascii.c:123
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (unknown type) [%s]"
 #: ../lib/vector/Vlib/ascii.c:143
 msgid "End of ASCII file reached before end of coordinates"
@@ -8249,12 +8249,12 @@
 #: ../lib/vector/Vlib/ascii.c:155
 #, fuzzy, c-format
 msgid "Error reading ASCII file: (bad point) [%s]"
 #: ../lib/vector/Vlib/ascii.c:160
 #, fuzzy, c-format
 msgid "Unparsable longitude value: [%s]"
 #: ../lib/vector/Vlib/ascii.c:165
 #, c-format
@@ -8268,12 +8268,12 @@
 #: ../lib/vector/Vlib/ascii.c:212
 #, fuzzy, c-format
 msgid "Error reading categories: [%s]"
 #: ../lib/vector/Vlib/ascii.c:225
 #, fuzzy
 msgid "Unable to copy points"
 #: ../lib/vector/Vlib/ascii.c:238
 #, c-format
@@ -8295,7 +8295,7 @@
 #: ../lib/vector/Vlib/ascii.c:465
 #, fuzzy, c-format
 msgid "Column <%s> does not exist"
-msgstr "Impossível descrever tabela <%s>"
+msgstr "Impossível descrever tabela <%s>"
 #: ../lib/vector/Vlib/ascii.c:467
 msgid "Available columns:"
@@ -8308,12 +8308,12 @@
 #: ../lib/vector/Vlib/ascii.c:505
 #, fuzzy, c-format
 msgid "Unknown type of column <%s>, export cancelled"
-msgstr "não consegui ler"
+msgstr "não consegui ler"
 #: ../lib/vector/Vlib/ascii.c:539
 #, fuzzy, c-format
 msgid "Unable to select record from table <%s> (key %s, column %s)"
-msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
+msgstr "não consegui criar o arquivo de cabeçalho para [%s em %s]"
 #: ../lib/vector/Vlib/ascii.c:661
 #, fuzzy, c-format
@@ -8328,12 +8328,12 @@
 #: ../lib/vector/Vlib/ascii.c:718
 #, fuzzy, c-format
 msgid "Cannot select attributes for cat = %d"
 #: ../lib/vector/Vlib/ascii.c:724
 #, fuzzy
 msgid "Unable to fetch data from table"
 #: ../lib/vector/Vlib/ascii.c:756 ../lib/vector/Vlib/net_build.c:216
 #: ../lib/vector/Vlib/net_build.c:501 ../lib/vector/Vlib/net_build.c:519
@@ -8341,12 +8341,12 @@
 #: ../lib/vector/Vlib/net_build.c:981
 #, fuzzy, c-format
 msgid "Column <%s> not found in table <%s>"
 #: ../lib/vector/Vlib/ascii.c:758
 #, fuzzy, c-format
 msgid "Column <%s>: unsupported data type"
 #: ../lib/vector/Vlib/ascii.c:840
 #, fuzzy
@@ -8360,12 +8360,12 @@
 #: ../lib/vector/Vlib/ascii.c:863
 #, fuzzy, c-format
 msgid "Unable to get boundary of area id %d"
 #: ../lib/vector/Vlib/ascii.c:875
 #, fuzzy, c-format
 msgid "Unable to get boundary of isle id %d (area id %d)"
 #: ../lib/vector/Vlib/ascii.c:889
 #, c-format
@@ -8391,12 +8391,12 @@
 #: ../lib/vector/Vlib/array.c:292
 #, fuzzy, c-format
 msgid "Unable to select record from table <%s> (key %s, where %s)"
 #: ../lib/vector/Vlib/close_ogr.c:104 ../lib/vector/Vlib/close_pg.c:139
 #, fuzzy, c-format
 msgid "Unable to save feature index file for vector map <%s>"
 #: ../lib/vector/Vlib/build_ogr.c:71
 msgid "Empty OGR layer, nothing to build"
@@ -8410,7 +8410,7 @@
 #: ../lib/vector/Vlib/build_ogr.c:134
 #, fuzzy, c-format
 msgid "Unable to open fidx file for write <%s>"
-msgstr "não consegui abrir arquivo topo para escrita: %s\n"
+msgstr "não consegui abrir arquivo topo para escrita: %s\n"
 #: ../lib/vector/Vlib/dgraph.c:432
 msgid ""
@@ -8435,7 +8435,7 @@
 #: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
 #, fuzzy
 msgid "Layer number must be > 0 for category constraints"
 #: ../lib/vector/Vlib/cats.c:585
 #, c-format
@@ -8445,7 +8445,7 @@
 #: ../lib/vector/Vlib/cats.c:593
 #, fuzzy, c-format
 msgid "Loading categories from table <%s>..."
 #: ../lib/vector/Vlib/cats.c:605
 #, fuzzy, c-format
@@ -8467,23 +8467,23 @@
 #: ../lib/vector/Vlib/area.c:50
 #, fuzzy
 msgid "Attempt to read points of nonexistent area"
 #: ../lib/vector/Vlib/area.c:81
 #, fuzzy
 msgid "Attempt to read points of nonexistent isle"
 #: ../lib/vector/Vlib/area.c:121 ../lib/vector/Vlib/area.c:153
 #: ../lib/vector/Vlib/area.c:219 ../lib/vector/Vlib/area.c:248
 #, fuzzy, c-format
 msgid "Attempt to read topo for dead area (%d)"
 #: ../lib/vector/Vlib/area.c:189 ../lib/vector/Vlib/area.c:275
 #, fuzzy, c-format
 msgid "Attempt to read topo for dead isle (%d)"
-msgstr "não consegui ler o histograma para [%s em %s]"
+msgstr "não consegui ler o histograma para [%s em %s]"
 #: ../lib/vector/Vlib/merge_lines.c:240
 #, c-format
@@ -8498,22 +8498,22 @@
 #: ../lib/vector/Vlib/box.c:264
 #, fuzzy, c-format
 msgid "Unable to determine bbox for feature %d"
 #: ../lib/vector/Vlib/box.c:313 ../lib/vector/Vlib/box.c:359
 #, fuzzy, c-format
 msgid "Attempt to access area with invalid id (%d)"
 #: ../lib/vector/Vlib/box.c:325
 #, fuzzy, c-format
 msgid "Unable to determine bbox for area %d"
 #: ../lib/vector/Vlib/box.c:371
 #, fuzzy, c-format
 msgid "Unable to determine bbox for isle %d"
 #: ../lib/vector/Vlib/net_build.c:101 ../lib/vector/Vlib/net_build.c:727
 #, fuzzy
@@ -8523,7 +8523,7 @@
 #: ../lib/vector/Vlib/net_build.c:143 ../lib/vector/Vlib/net_build.c:775
 #, fuzzy
 msgid "Unable to build network graph"
 #: ../lib/vector/Vlib/net_build.c:149 ../lib/vector/Vlib/net_build.c:781
 msgid "Forward costs column not specified"
@@ -8536,7 +8536,7 @@
 #: ../lib/vector/Vlib/net_build.c:172
 #, fuzzy, c-format
 msgid "Turntable column <%s> not found in table <%s>"
 #: ../lib/vector/Vlib/net_build.c:182 ../lib/vector/Vlib/net_build.c:223
 #: ../lib/vector/Vlib/net_build.c:508 ../lib/vector/Vlib/net_build.c:526
@@ -8544,7 +8544,7 @@
 #: ../lib/vector/Vlib/net_build.c:988
 #, fuzzy, c-format
 msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr "Tipo da coluna z não é suportado (deve ser inteiro ou double)"
+msgstr "Tipo da coluna z não é suportado (deve ser inteiro ou double)"
 #: ../lib/vector/Vlib/net_build.c:202 ../lib/vector/Vlib/net_build.c:967
 msgid "Setting node costs..."
@@ -8553,12 +8553,12 @@
 #: ../lib/vector/Vlib/net_build.c:277 ../lib/vector/Vlib/net_build.c:1032
 #, fuzzy, c-format
 msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
 #: ../lib/vector/Vlib/net_build.c:332 ../lib/vector/Vlib/net_build.c:352
 #, fuzzy
 msgid "Cannot add network arc for virtual node connection."
 #: ../lib/vector/Vlib/net_build.c:364
 #, c-format
@@ -8593,12 +8593,12 @@
 #, fuzzy, c-format
 msgid ""
 "Database record for turn with cat = %d in not found. (The turn was skipped."
 #: ../lib/vector/Vlib/net_build.c:465
 #, fuzzy
 msgid "Cannot add network arc representing turn."
 #: ../lib/vector/Vlib/net_build.c:487 ../lib/vector/Vlib/net_build.c:788
 msgid "Arc field < 1"
@@ -8622,14 +8622,14 @@
 msgid ""
 "Database record for line %d (cat = %d, forward/both direction(s)) not found "
 "(cost was set to 0)"
 #: ../lib/vector/Vlib/net_build.c:596
 #, fuzzy, c-format
 msgid ""
 "Database record for line %d (cat = %d, backword direction) not found(cost "
 "was set to 0)"
 #: ../lib/vector/Vlib/net_build.c:658 ../lib/vector/Vlib/net_build.c:1064
 #, fuzzy
@@ -8658,42 +8658,42 @@
 #: ../lib/vector/Vlib/net_build.c:937
 #, fuzzy
 msgid "Cannot add network arc"
 #: ../lib/vector/Vlib/simple_features.c:225
 #, fuzzy, c-format
 msgid "Unknown Simple Features type (%d)"
 #: ../lib/vector/Vlib/simple_features.c:332
 #, fuzzy
 msgid "Unable to get number of simple features"
 #: ../lib/vector/Vlib/simple_features.c:341
 #, fuzzy, c-format
 msgid "Unable to report simple features for vector map <%s>"
 #: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
 #, fuzzy, c-format
 msgid "Unable to get feature geometry, fid %ld"
 #: ../lib/vector/Vlib/read_ogr.c:390
 #, fuzzy
 msgid "OGR feature without ID"
 #: ../lib/vector/Vlib/read_ogr.c:514
 #, fuzzy, c-format
 msgid "OGR feature type '%s' not supported"
 #: ../lib/vector/Vlib/graph.c:138
 #, fuzzy
 msgid "Unable to add network arc"
 #: ../lib/vector/Vlib/graph.c:226 ../lib/vector/Vlib/net_analyze.c:198
 #, c-format
@@ -8703,32 +8703,32 @@
 #: ../lib/vector/Vlib/level_two.c:23
 #, fuzzy, c-format
 msgid "Vector map <%s> is not open at topological level"
 #: ../lib/vector/Vlib/level_two.c:284
 #, fuzzy, c-format
 msgid "Invalid node id: %d"
 #: ../lib/vector/Vlib/level_two.c:316
 #, fuzzy, c-format
 msgid "Nodes not available for line %d"
 #: ../lib/vector/Vlib/level_two.c:357
 #, fuzzy, c-format
 msgid "Areas not available for line %d"
 #: ../lib/vector/Vlib/level_two.c:362
 #, fuzzy, c-format
 msgid "Line %d is not a boundary"
 #: ../lib/vector/Vlib/level_two.c:445
 #, fuzzy, c-format
 msgid "Topology info not available for feature %d"
 #: ../lib/vector/Vlib/intersect.c:127
 msgid "3D not supported by Vect_segment_intersection()"
@@ -8745,22 +8745,22 @@
 #: ../lib/vector/Vlib/break_lines.c:563
 #, fuzzy, c-format
 msgid "Intersections: %d"
-msgstr "Outra projeção"
+msgstr "Outra projeção"
 #: ../lib/vector/Vlib/select.c:116
 #, fuzzy, c-format
 msgid "Unable to delete item %d from spatial index"
 #: ../lib/vector/Vlib/write_sfa.c:117
 #, fuzzy
 msgid "Unable to calculate centroid for area"
 #: ../lib/vector/Vlib/write_sfa.c:219
 #, fuzzy
 msgid "Attempt to delete dead feature"
 #: ../lib/vector/Vlib/write_sfa.c:311
 #, fuzzy, c-format
@@ -8770,31 +8770,31 @@
 #: ../lib/vector/Vlib/bridges.c:213
 #, fuzzy, c-format
 msgid "Removed lines: %d"
 #: ../lib/vector/Vlib/bridges.c:214
 #, fuzzy, c-format
 msgid "Removed bridges: %d"
 #: ../lib/vector/Vlib/build.c:115
 #, fuzzy
 msgid "Area of size = 0.0 (less than 4 vertices) ignored"
-msgstr "Tamanho de área = 0.0 ignorado"
+msgstr "Tamanho de área = 0.0 ignorado"
 #: ../lib/vector/Vlib/build.c:131
 #, fuzzy
 msgid "Unable to add area (map closed, topo saved)"
-msgstr "não consegui adicionar área (mapa fechado, topo salva)"
+msgstr "não consegui adicionar área (mapa fechado, topo salva)"
 #: ../lib/vector/Vlib/build.c:139
 #, fuzzy
 msgid "Unable to add isle (map closed, topo saved)"
-msgstr "não consegui adicionar ilha (mapa fechado; topo salva)"
+msgstr "não consegui adicionar ilha (mapa fechado; topo salva)"
 #: ../lib/vector/Vlib/build.c:149
 msgid "Area of size = 0.0 ignored"
 #: ../lib/vector/Vlib/build.c:200
 msgid "Request to find area outside nonexistent isle"
@@ -8811,27 +8811,27 @@
 #: ../lib/vector/Vlib/build.c:641
 #, fuzzy, c-format
 msgid "Number of lines of length zero: %d"
 #: ../lib/vector/Vlib/build.c:643
 #, fuzzy, c-format
 msgid "Number of boundaries of length zero: %d"
-msgstr "Número de fronteiras:   %d\n"
+msgstr "Número de fronteiras:   %d\n"
 #: ../lib/vector/Vlib/build.c:652
 #, fuzzy, c-format
 msgid "Number of boundary intersections: %d"
 #: ../lib/vector/Vlib/build.c:676
 #, fuzzy
 msgid "Skipping further checks because of incorrect boundaries"
-msgstr "Número de fronteiras incorretas   :   %d\n"
+msgstr "Número de fronteiras incorretas   :   %d\n"
 #: ../lib/vector/Vlib/build.c:726
 #, fuzzy, c-format
 msgid "Number of redundant holes: %d"
 #: ../lib/vector/Vlib/build.c:871
 #, fuzzy, c-format
@@ -8846,92 +8846,92 @@
 #: ../lib/vector/Vlib/build.c:900
 #, fuzzy, c-format
 msgid "Number of nodes: %d"
-msgstr "Número de nós     :   %d\n"
+msgstr "Número de nós     :   %d\n"
 #: ../lib/vector/Vlib/build.c:901
 #, fuzzy, c-format
 msgid "Number of primitives: %d"
 #: ../lib/vector/Vlib/build.c:902
 #, fuzzy, c-format
 msgid "Number of points: %d"
-msgstr "Número de pontos    :   %d\n"
+msgstr "Número de pontos    :   %d\n"
 #: ../lib/vector/Vlib/build.c:903
 #, fuzzy, c-format
 msgid "Number of lines: %d"
 #: ../lib/vector/Vlib/build.c:904
 #, fuzzy, c-format
 msgid "Number of boundaries: %d"
 #: ../lib/vector/Vlib/build.c:905
 #, fuzzy, c-format
 msgid "Number of centroids: %d"
-msgstr "Número de centróides :   %d\n"
+msgstr "Número de centróides :   %d\n"
 #: ../lib/vector/Vlib/build.c:908
 #, fuzzy, c-format
 msgid "Number of faces: %d"
-msgstr "Número de faces     :   %d\n"
+msgstr "Número de faces     :   %d\n"
 #: ../lib/vector/Vlib/build.c:911
 #, fuzzy, c-format
 msgid "Number of kernels: %d"
-msgstr "Número de núcleos   :   %d\n"
+msgstr "Número de núcleos   :   %d\n"
 #: ../lib/vector/Vlib/build.c:957
 #, fuzzy, c-format
 msgid "Number of areas: %d"
-msgstr "Número de áreas     :   %d\n"
+msgstr "Número de áreas     :   %d\n"
 #: ../lib/vector/Vlib/build.c:958
 #, fuzzy, c-format
 msgid "Number of isles: %d"
-msgstr "Número de ilhas     :   %d\n"
+msgstr "Número de ilhas     :   %d\n"
 #: ../lib/vector/Vlib/build.c:963
 #, fuzzy, c-format
 msgid "Number of areas without centroid: %d"
 #: ../lib/vector/Vlib/build.c:968
 #, fuzzy, c-format
 msgid "Number of centroids exceeds number of areas: %d > %d"
-msgstr "Número de centróides fora da área :   %d\n"
+msgstr "Número de centróides fora da área :   %d\n"
 #: ../lib/vector/Vlib/build.c:972
 #, fuzzy, c-format
 msgid "Number of incorrect boundaries: %d"
 #: ../lib/vector/Vlib/build.c:976
 #, fuzzy, c-format
 msgid "Number of centroids outside area: %d"
 #: ../lib/vector/Vlib/build.c:980
 #, fuzzy, c-format
 msgid "Number of duplicate centroids: %d"
-msgstr "Número de centróides duplicados    :   %d\n"
+msgstr "Número de centróides duplicados    :   %d\n"
 #: ../lib/vector/Vlib/build.c:984
 #, fuzzy
 msgid "Number of areas: -"
-msgstr "Número de áreas     :   -\n"
+msgstr "Número de áreas     :   -\n"
 #: ../lib/vector/Vlib/build.c:985
 #, fuzzy
 msgid "Number of isles: -"
-msgstr "Número de ilhas     :   -\n"
+msgstr "Número de ilhas     :   -\n"
 #: ../lib/vector/Vlib/build.c:1013
 #, fuzzy, c-format
 msgid "Unable to create topo file for vector map <%s>"
 #: ../lib/vector/Vlib/build.c:1021
 #, fuzzy
@@ -8943,7 +8943,7 @@
 msgid ""
 "Unable to build spatial index from topology, vector map is not opened at "
 "topology level 2"
-msgstr "não é possível apagar a linha, o mapa '%s' não está aberto no nível 2"
+msgstr "não é possível apagar a linha, o mapa '%s' não está aberto no nível 2"
 #: ../lib/vector/Vlib/build.c:1233
 #, c-format
@@ -8957,22 +8957,22 @@
 #: ../lib/vector/Vlib/build.c:1268
 #, fuzzy, c-format
 msgid "Unable to create spatial index file for vector map <%s>"
-msgstr "Não consegui abrir histórico para o vetor %s"
+msgstr "Não consegui abrir histórico para o vetor %s"
 #: ../lib/vector/Vlib/build.c:1277
 #, fuzzy
 msgid "Error writing out spatial index file"
 #: ../lib/vector/Vlib/poly.c:268
 #, fuzzy
 msgid "Unable to find point in polygon"
-msgstr "não consegui encontrar [%s] em [%s]"
+msgstr "não consegui encontrar [%s] em [%s]"
 #: ../lib/vector/Vlib/poly.c:810
 #, fuzzy
 msgid "conditions failed"
-msgstr "Falha na conexão.\n"
+msgstr "Falha na conexão.\n"
 #: ../lib/vector/Vlib/level.c:34
 msgid "Map structure was never initialized"
@@ -8985,12 +8985,12 @@
 #: ../lib/vector/Vlib/open_pg.c:109 ../lib/vector/Vlib/open_pg.c:267
 #, fuzzy
 msgid "No feature tables found in database."
 #: ../lib/vector/Vlib/open_pg.c:133
 #, fuzzy, c-format
 msgid "Feature table <%s> not found in 'geometry_columns'"
-msgstr "Vetor de entrada '%s' não encontrado"
+msgstr "Vetor de entrada '%s' não encontrado"
 #: ../lib/vector/Vlib/open_pg.c:181
 msgid "Topology schema not found."
@@ -8999,17 +8999,17 @@
 #: ../lib/vector/Vlib/open_pg.c:273
 #, fuzzy, c-format
 msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
 #: ../lib/vector/Vlib/open_pg.c:276
 #, fuzzy, c-format
 msgid "Unable to delete PostGIS layer <%s>"
 #: ../lib/vector/Vlib/open_pg.c:282
 #, fuzzy, c-format
 msgid "PostGIS layer <%s.%s> already exists in database '%s'"
 #: ../lib/vector/Vlib/open_pg.c:390
 #, fuzzy
@@ -9019,7 +9019,7 @@
 #: ../lib/vector/Vlib/open_pg.c:462 ../lib/vector/Vlib/open_pg.c:474
 #, fuzzy, c-format
 msgid "Execution failed: %s"
 #: ../lib/vector/Vlib/open_pg.c:476
 #, c-format
@@ -9031,12 +9031,12 @@
 msgid ""
 "Connection to PostgreSQL database failed. Try to set up username/password by "
 "db.login."
 #: ../lib/vector/Vlib/open_pg.c:566
 #, fuzzy
 msgid "Unable to get database name"
 #: ../lib/vector/Vlib/open_pg.c:571
 #, c-format
@@ -9046,7 +9046,7 @@
 #: ../lib/vector/Vlib/open_pg.c:580
 #, fuzzy, c-format
 msgid "PostGIS Topology extension not found in the database <%s>"
 #: ../lib/vector/Vlib/open_pg.c:667
 msgid "Empty bounding box"
@@ -9065,7 +9065,7 @@
 #: ../lib/vector/Vlib/open_pg.c:1003
 #, fuzzy, c-format
 msgid "Area %d without boundary detected"
 #: ../lib/vector/Vlib/open_pg.c:1061
 #, c-format
@@ -9075,14 +9075,14 @@
 #: ../lib/vector/Vlib/open_pg.c:1128
 #, fuzzy
 msgid "Unable to get map bounding box from topology"
 #: ../lib/vector/Vlib/open_pg.c:1135
 #, fuzzy, c-format
 msgid ""
 "Unable to parse map bounding box:\n"
 "%s"
-msgstr "não foi possível abrir o arquivo %s em %s"
+msgstr "não foi possível abrir o arquivo %s em %s"
 #: ../lib/vector/Vlib/open_pg.c:1159
 #, c-format
@@ -9133,12 +9133,12 @@
 #: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
 #, fuzzy, c-format
 msgid "Vector format not recognized: %s"
 #: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
 #, fuzzy, c-format
 msgid "Vector format '%s' not supported"
-msgstr "Feição OGR tipo %d não suportada)"
+msgstr "Feição OGR tipo %d não suportada)"
 #: ../lib/vector/diglib/frmt.c:97
 #, c-format
@@ -9153,72 +9153,72 @@
 #: ../lib/vector/diglib/plus.c:222
 #, fuzzy
 msgid "Unable read topology for nodes"
 #: ../lib/vector/diglib/plus.c:227
 #, fuzzy, c-format
 msgid "Unable to read topology for node %d"
 #: ../lib/vector/diglib/plus.c:232
 #, fuzzy
 msgid "Unable read topology for lines"
 #: ../lib/vector/diglib/plus.c:237
 #, fuzzy, c-format
 msgid "Unable to read topology for line %d"
 #: ../lib/vector/diglib/plus.c:242
 #, fuzzy
 msgid "Unable to read topo for areas"
 #: ../lib/vector/diglib/plus.c:247
 #, fuzzy, c-format
 msgid "Unable read topology for area %d"
 #: ../lib/vector/diglib/plus.c:252
 #, fuzzy
 msgid "Unable to read topology for isles"
 #: ../lib/vector/diglib/plus.c:257
 #, fuzzy, c-format
 msgid "Unable to read topology for isle %d"
 #: ../lib/vector/diglib/plus.c:279 ../lib/vector/diglib/plus.c:305
 #, fuzzy
 msgid "Unable to write head to plus file"
 #: ../lib/vector/diglib/plus.c:284
 #, fuzzy
 msgid "Unable to write nodes to plus file"
 #: ../lib/vector/diglib/plus.c:289
 #, fuzzy
 msgid "Unable to write lines to plus file"
 #: ../lib/vector/diglib/plus.c:294
 #, fuzzy
 msgid "Unable to write areas to plus file"
-msgstr "não consegui criar novo processo"
+msgstr "não consegui criar novo processo"
 #: ../lib/vector/diglib/plus.c:299
 #, fuzzy
 msgid "Unable to write isles to plus file"
 #: ../lib/vector/diglib/spindex_rw.c:98 ../lib/vector/diglib/spindex_rw.c:106
 #, fuzzy
 msgid "Topology file must be written before spatial index file"
 #: ../lib/vector/diglib/spindex_rw.c:302
 #, c-format
@@ -9283,12 +9283,12 @@
 #: ../lib/vector/diglib/plus_area.c:431
 #, fuzzy, c-format
 msgid "Attempt to delete area %d info from dead isle %d"
 #: ../lib/vector/diglib/plus_area.c:777
 #, fuzzy, c-format
 msgid "Attempt to delete isle %d info from dead area %d"
 #: ../lib/vector/diglib/plus_struct.c:523
 #, c-format
@@ -9318,7 +9318,7 @@
 #: ../lib/vector/diglib/file.c:197
 #, fuzzy
 msgid "Unable to load file to memory, file not open"
 #: ../lib/vector/diglib/file.c:212
 msgid "Vector memory mode not supported, using 'AUTO'"
@@ -9327,37 +9327,37 @@
 #: ../lib/vector/diglib/port_init.c:158
 #, fuzzy, c-format
 msgid "Unable to find '%x' in %s"
-msgstr "não consegui encontrar [%s]"
+msgstr "não consegui encontrar [%s]"
 #: ../lib/vector/diglib/spindex.c:450
 #, fuzzy, c-format
 msgid "Unable to delete node %d from spatial index"
 #: ../lib/vector/diglib/spindex.c:493
 #, fuzzy, c-format
 msgid "Unable to delete line %d from spatial index"
 #: ../lib/vector/diglib/spindex.c:529
 #, fuzzy
 msgid "Attempt to delete sidx for dead area"
 #: ../lib/vector/diglib/spindex.c:546
 #, fuzzy, c-format
 msgid "Unable to delete area %d from spatial index"
 #: ../lib/vector/diglib/spindex.c:595
 #, fuzzy, c-format
 msgid "Unable to delete isle %d from spatial index"
 #: ../lib/vector/diglib/test.c:58
 #, fuzzy
 msgid "Unable to open test.tmp file"
 #: ../lib/vector/diglib/test.c:75
 #, c-format
@@ -9419,12 +9419,12 @@
 #: ../lib/segment/open.c:66
 #, fuzzy
 msgid "Unable to create segment file"
 #: ../lib/segment/open.c:74
 #, fuzzy
 msgid "Could not write segment file"
 #: ../lib/segment/open.c:78
 msgid "Illegal segment configuration parameter(s)"
@@ -9433,12 +9433,12 @@
 #: ../lib/segment/open.c:87
 #, fuzzy
 msgid "Unable to re-open segment file"
 #: ../lib/segment/open.c:94
 #, fuzzy
 msgid "Could not read segment file"
 #: ../lib/segment/format.c:143
 msgid "Segment format: file size too large"
@@ -9498,7 +9498,7 @@
 #: ../lib/proj/ellipse.c:97
 #, fuzzy, c-format
 msgid "Invalid ellipsoid <%s> in file"
-msgstr "elipsóide inválido %s no arquivo"
+msgstr "elipsóide inválido %s no arquivo"
 #: ../lib/proj/ellipse.c:124
 msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
@@ -9507,16 +9507,16 @@
 #: ../lib/proj/ellipse.c:128
 #, fuzzy
 msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
 #: ../lib/proj/ellipse.c:141
 msgid "No ellipsoid info given in file"
-msgstr "O arquivo não contém informações sobre o elipsóide"
+msgstr "O arquivo não contém informações sobre o elipsóide"
 #: ../lib/proj/get_proj.c:148
 #, fuzzy, c-format
 msgid "Invalid zone %s specified"
 #: ../lib/proj/get_proj.c:228
 msgid "Unable to initialise PROJ.4 with the following parameter list:"
@@ -9534,7 +9534,7 @@
 #: ../lib/proj/get_proj.c:325
 #, fuzzy, c-format
 msgid "Unable to initialize pj cause: %s"
 #: ../lib/proj/get_proj.c:401
 msgid "Input Projection Parameters"
@@ -9559,7 +9559,7 @@
 #: ../lib/proj/datum.c:278 ../lib/proj/datum.c:358
 #, fuzzy, c-format
 msgid "Unable to open datum table file <%s>"
-msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
+msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
 #: ../lib/proj/datum.c:291 ../lib/proj/datum.c:372
 #, fuzzy, c-format
@@ -9591,7 +9591,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:94
 #, fuzzy, c-format
 msgid "Vector map <%s> is not 3D"
 #: ../lib/rst/interp_float/vinput2d.c:97
 msgid "Loading data from attribute table ..."
@@ -9601,17 +9601,17 @@
 #: ../lib/rst/interp_float/vinput2d.c:131
 #, fuzzy, c-format
 msgid "Data type of column <%s> must be numeric"
 #: ../lib/rst/interp_float/vinput2d.c:142
 #, fuzzy
 msgid "Reading features from vector map ..."
 #: ../lib/rst/interp_float/vinput2d.c:174
 #, c-format
 msgid "Database record for cat %d not found"
 #: ../lib/rst/interp_float/vinput2d.c:192
 msgid "Negative value of smoothing detected: sm must be >= 0"
@@ -9620,12 +9620,12 @@
 #: ../lib/rst/interp_float/vinput2d.c:256
 #, fuzzy
 msgid "Strip exists with insufficient data"
-msgstr "há uma faixa com dados insuficientes"
+msgstr "há uma faixa com dados insuficientes"
 #: ../lib/rst/interp_float/vinput2d.c:270
 #, fuzzy, c-format
 msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr "há pontos fora da região 2D/3D especificada-- ignorei %d pontos"
+msgstr "há pontos fora da região 2D/3D especificada-- ignorei %d pontos"
 #: ../lib/rst/interp_float/vinput2d.c:273
 #, fuzzy, c-format
@@ -9638,7 +9638,7 @@
 "%d points given for interpolation (after thinning) is less than given NPMIN="
 "%d"
 msgstr ""
-"%d pontos dados para a interpolação (após afinamento) é menor que o NPMIN=%d "
+"%d pontos dados para a interpolação (após afinamento) é menor que o NPMIN=%d "
 "definido."
 #: ../lib/rst/interp_float/vinput2d.c:282
@@ -9658,8 +9658,8 @@
 "There are less than %d points for interpolation. No segmentation is "
 "necessary, to run the program faster set segmax=%d (see manual)"
 msgstr ""
-"Existem menos que %d pontos para interpolação. Nenhuma segmentação é "
-"necessária. Para executar o programa mais rápido, use segmax=%d (veja o "
+"Existem menos que %d pontos para interpolação. Nenhuma segmentação é "
+"necessária. Para executar o programa mais rápido, use segmax=%d (veja o "
 "manual)"
 #: ../lib/rst/interp_float/vinput2d.c:297
@@ -9670,27 +9670,27 @@
 #: ../lib/rst/interp_float/vinput2d.c:298
 #, fuzzy, c-format
 msgid "Number of points outside of 2D/3D region %d"
 #: ../lib/rst/interp_float/vinput2d.c:300
 #, fuzzy, c-format
 msgid "Number of points being used %d"
 #: ../lib/rst/interp_float/vinput2d.c:333
 #, fuzzy
 msgid "Some points outside of region (ignored)"
-msgstr "alguns pontos fora da região -- vou ignorar..."
+msgstr "alguns pontos fora da região -- vou ignorar..."
 #: ../lib/rst/interp_float/vinput2d.c:339
 #, fuzzy
 msgid "Unable to allocate memory"
 #: ../lib/rst/interp_float/vinput2d.c:347
 #, fuzzy, c-format
 msgid "Unable to insert %f,%f,%f a = %d"
 #: ../lib/rst/interp_float/segmen2d.c:135
 #, fuzzy
@@ -9698,20 +9698,20 @@
 "Taking too long to find points for interpolation - please change the region "
 "to area where your points are. Continuing calculations..."
 msgstr ""
-"demorando demais para encontrar pontos para interpolação--favor alterar a "
-"região para a área onde estão os pontos. Continuando cálculos..."
+"demorando demais para encontrar pontos para interpolação--favor alterar a "
+"região para a área onde estão os pontos. Continuando cálculos..."
 #: ../lib/rst/interp_float/write2d.c:53 ../lib/rst/interp_float/write2d.c:64
 #: ../lib/rst/interp_float/write2d.c:79 ../lib/rst/interp_float/write2d.c:88
 #: ../lib/rst/interp_float/write2d.c:96 ../lib/rst/interp_float/write2d.c:104
 #, fuzzy
 msgid "Cannot write files"
 #: ../lib/rst/interp_float/input2d.c:58
 #, fuzzy, c-format
 msgid "Mask raster map <%s> not found"
 #: ../lib/rst/interp_float/input2d.c:81
 msgid "Bitmap mask created"
@@ -9737,23 +9737,23 @@
 #: ../lib/pngdriver/read_png.c:42
 #, fuzzy
 msgid "Unable to read PNG"
 #: ../lib/pngdriver/read_png.c:60
 #, fuzzy
 msgid "Unable allocate PNG structure"
 #: ../lib/pngdriver/read_png.c:64 ../lib/pngdriver/write_png.c:71
 #: ../lib/pngdriver/write_png.c:75
 #, fuzzy
 msgid "Unable to allocate PNG structure"
 #: ../lib/pngdriver/read_png.c:67
 #, fuzzy
 msgid "Unable to read PNG file"
 #: ../lib/pngdriver/read_png.c:81
 msgid "Input PNG file is not 8-bit"
@@ -9779,17 +9779,17 @@
 #: ../lib/pngdriver/write_png.c:39
 #, fuzzy
 msgid "Unable to write PNG"
 #: ../lib/pngdriver/write_png.c:78
 #, fuzzy
 msgid "Unable to write PNG file"
 #: ../lib/pngdriver/write_png.c:82
 #, fuzzy, c-format
 msgid "Unable to open output PNG file <%s>"
 #: ../lib/pngdriver/graph_set.c:101
 #, c-format
@@ -9807,52 +9807,52 @@
 msgstr ""
 #~ msgid "invalid color name"
-#~ msgstr "nome de cor inválido"
+#~ msgstr "nome de cor inválido"
 #, fuzzy
 #~ msgid "Unable to restore feature/offset %lu in vector map <%s>"
-#~ msgstr "Impossível mudar de diretório para %s"
+#~ msgstr "Impossível mudar de diretório para %s"
 #, fuzzy
 #~ msgid ""
 #~ "Unable to check table. There is no temporal database connection defined "
 #~ "for mapset <%(mapset)s>"
-#~ msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
+#~ msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
 #, fuzzy
 #~ msgid ""
 #~ "Unable to fetch one. There is no temporal database connection defined for "
 #~ "mapset <%(mapset)s>"
-#~ msgstr "Não consegui abrir histórico para o vetor %s"
+#~ msgstr "Não consegui abrir histórico para o vetor %s"
 #, fuzzy
 #~ msgid ""
 #~ "Unable to fetch all. There is no temporal database connection defined for "
 #, fuzzy
 #~ msgid "Unable to find a temporary null file <%s>"
-#~ msgstr "não foi possível encontrar o arquivo null temporário: %s"
+#~ msgstr "não foi possível encontrar o arquivo null temporário: %s"
 #, fuzzy
 #~ msgid "Unable to open null file <%s>"
-#~ msgstr "G_spawn: não consegui abrir o arquivo %s"
+#~ msgstr "G_spawn: não consegui abrir o arquivo %s"
 #, fuzzy
 #~ msgid "ERROR: <%s> is not a valid GRASS location"
-#~ msgstr "Desculpe <%s> não é uma opção válida\n"
+#~ msgstr "Desculpe <%s> não é uma opção válida\n"
 #~ msgid "ERROR: option <%s>: <%s> exists.\n"
-#~ msgstr "ERRO: opção <%s>:<%s> já existe.\n"
+#~ msgstr "ERRO: opção <%s>:<%s> já existe.\n"
 #, fuzzy
 #~ msgid "Invalid offset (%d)"
 #, fuzzy
 #~ msgid "Unable to open file '%s'"
-#~ msgstr "não foi possível abrir o arquivo %s em %s"
+#~ msgstr "não foi possível abrir o arquivo %s em %s"
 #, fuzzy
 #~ msgid "Hit RETURN to continue"
@@ -9860,7 +9860,7 @@
 #, fuzzy
 #~ msgid "Vector map <%s> is not opened on topology level"
-#~ msgstr "Vetor de entrada '%s' não encontrado"
+#~ msgstr "Vetor de entrada '%s' não encontrado"
 #, fuzzy
 #~ msgid "Removing empty 3D raster maps"
@@ -9868,16 +9868,16 @@
 #, fuzzy
 #~ msgid "Mode type: {0} not supported."
-#~ msgstr "Feição OGR tipo %d não suportada)"
+#~ msgstr "Feição OGR tipo %d não suportada)"
 #, fuzzy
 #~ msgid "Invalid type {0}"
 #, fuzzy
 #~ msgid "Attributes for category %d not found"
-#~ msgstr "Registro no banco de dados para categoria %d não encontrado"
+#~ msgstr "Registro no banco de dados para categoria %d não encontrado"
 #, fuzzy
 #~ msgid "Cannot fetch row"
-#~ msgstr "não consegui obter informações da camada"
+#~ msgstr "não consegui obter informações da camada"
Modified: grass/trunk/locale/po/grasslibs_sl.po
--- grass/trunk/locale/po/grasslibs_sl.po	2017-04-22 13:47:15 UTC (rev 70918)
+++ grass/trunk/locale/po/grasslibs_sl.po	2017-04-22 14:06:08 UTC (rev 70919)
@@ -1,4 +1,4 @@
-# translation of grasslibs_sl.po to Sloven¹èina
+# translation of grasslibs_sl.po to Slovenščina
 # translation of grasslibs_sl.po to slovenian
 # This file is distributed under the same license as the GRASS package.
 # Copyright (C) 2004 GRASS Development Team
@@ -11,10 +11,10 @@
 "POT-Creation-Date: 2016-11-14 14:55+0100\n"
 "PO-Revision-Date: 2005-04-26 09:38+0200\n"
 "Last-Translator: Miha Staut <mihastaut at yahoo.co.uk>\n"
-"Language-Team: Sloven¹èina <grass-translations at lists.osgeo.org>\n"
+"Language-Team: Slovenščina <grass-translations at lists.osgeo.org>\n"
 "Language: sl_SL\n"
 "MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=ISO-8859-2\n"
+"Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "X-Generator: KBabel 1.9\n"
@@ -144,12 +144,12 @@
 #: ../lib/ogsf/gsd_legend.c:246
 #, fuzzy, c-format
 msgid "Unable to read color file of raster map <%s>"
-msgstr "Nezmo¾en ustvariti datoteko z vzglavjem za [%s v %s]"
+msgstr "Nezmožen ustvariti datoteko z vzglavjem za [%s v %s]"
 #: ../lib/ogsf/gsd_legend.c:252
 #, fuzzy, c-format
 msgid "Unable to read category file of raster map <%s>"
 #: ../lib/ogsf/gsd_legend.c:269
 #, fuzzy, c-format
@@ -173,7 +173,7 @@
 #: ../lib/ogsf/gsd_legend.c:501
 #, fuzzy
 msgid "Too many categories to show as discrete!"
-msgstr "Preveè reklasifikacijskih kategorij za [%s v %s]"
+msgstr "Preveč reklasifikacijskih kategorij za [%s v %s]"
 #: ../lib/ogsf/gsd_legend.c:503
 msgid "Try using smaller font!"
@@ -183,7 +183,7 @@
 #: ../lib/ogsf/gsd_img_tif.c:66 ../lib/ogsf/gk2.c:216
 #, fuzzy, c-format
 msgid "Unable to open file <%s> for writing"
-msgstr "Nezmo¾en odpreti %s za pisanje"
+msgstr "Nezmožen odpreti %s za pisanje"
 #: ../lib/ogsf/trans.c:180
 msgid "Out of matrix stack space"
@@ -364,7 +364,7 @@
 #: ../lib/raster3d/range.c:73
 #, fuzzy, c-format
 msgid "Unable to open range file for [%s in %s]"
 #: ../lib/raster3d/range.c:88
 #, fuzzy, c-format
@@ -435,7 +435,7 @@
 #: ../lib/raster3d/open.c:233
 #, fuzzy, c-format
 msgid "map <%s> is not in the current mapset"
-msgstr "Hro¹è: poskus posodobitve sloja, ki ni v trenutnem mapset."
+msgstr "Hrošč: poskus posodobitve sloja, ki ni v trenutnem mapset."
 #: ../lib/raster3d/open.c:243
 msgid "Rast3d_open_cell_new: could not open file"
@@ -462,7 +462,7 @@
 #: ../lib/raster3d/close.c:79
 #, fuzzy
 msgid "Unable to flush all tiles"
-msgstr "Nezmo¾en odpreti datoteko %s v %s"
+msgstr "Nezmožen odpreti datoteko %s v %s"
 #: ../lib/raster3d/close.c:84
 #, fuzzy
@@ -472,7 +472,7 @@
 #: ../lib/raster3d/close.c:94
 #, fuzzy
 msgid "Unable to position file"
 #: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
 #, fuzzy, c-format
@@ -512,7 +512,7 @@
 #: ../lib/raster3d/color.c:354
 #, fuzzy, c-format
 msgid "mapset <%s> is not the current mapset"
 #: ../lib/raster3d/maskfn.c:77
 #, c-format
@@ -537,7 +537,7 @@
 #: ../lib/imagery/iscatt_core.c:255
 #, fuzzy, c-format
 msgid "Unable to open category raster condtions file <%s>."
-msgstr "Nezmo¾en odpreti datoteko s tabelo fundamentalne toèke: %s"
+msgstr "Nezmožen odpreti datoteko s tabelo fundamentalne točke: %s"
 #: ../lib/imagery/iscatt_core.c:263
 #, fuzzy, c-format
@@ -562,7 +562,7 @@
 #: ../lib/imagery/iscatt_core.c:526
 #, fuzzy
 msgid "Unable to read from category raster condtition file."
 #: ../lib/imagery/iscatt_core.c:533
 msgid "Invalid size of category raster conditions file."
@@ -582,7 +582,7 @@
 #: ../lib/imagery/iscatt_core.c:755
 #, fuzzy, c-format
 msgid "Unbale to open raster <%s>"
 #: ../lib/imagery/iscatt_core.c:761
 #, fuzzy, c-format
@@ -597,7 +597,7 @@
 #: ../lib/imagery/iscatt_core.c:803
 #, fuzzy, c-format
 msgid "Unable to open category raster condtition file <%s>"
 #: ../lib/imagery/iscatt_core.c:817
 msgid "Corrupted category raster conditions file (fseek failed)"
@@ -615,7 +615,7 @@
 #: ../lib/imagery/target.c:38
 #, fuzzy, c-format
 msgid "Unable to read target file for group [%s]"
-msgstr "Nezmo¾en ustvariti vzglavno datoteko za [%s]"
+msgstr "Nezmožen ustvariti vzglavno datoteko za [%s]"
 #: ../lib/imagery/georef_tps.c:219
 msgid "Calculating forward transformation coefficients"
@@ -652,17 +652,17 @@
 #: ../lib/imagery/points.c:124
 #, fuzzy, c-format
 msgid "Unable to open control point file for group [%s in %s]"
 #: ../lib/imagery/points.c:132
 #, fuzzy, c-format
 msgid "Bad format in control point file for group [%s in %s]"
 #: ../lib/imagery/points.c:159
 #, fuzzy, c-format
 msgid "Unable to create control point file for group [%s in %s]"
 #: ../lib/imagery/list_gp.c:34
 #, c-format
@@ -677,12 +677,12 @@
 #: ../lib/imagery/fopen.c:23
 #, fuzzy, c-format
 msgid "Unable to create file [%s] of group [%s in %s]"
 #: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
 #, fuzzy, c-format
 msgid "Unable to open file [%s] of group [%s in %s]"
 #: ../lib/imagery/fopen.c:49
 #, fuzzy, c-format
@@ -692,12 +692,12 @@
 #: ../lib/imagery/fopen.c:79
 #, fuzzy, c-format
 msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
 #: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
 #, fuzzy, c-format
 msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
 #: ../lib/imagery/fopen.c:116
 #, c-format
@@ -771,17 +771,17 @@
 msgid ""
 "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
 "is not current mapset"
 #: ../lib/imagery/sigsetfile.c:57
 #, fuzzy, c-format
 msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
 #: ../lib/imagery/iclass_signatures.c:120
 #, fuzzy, c-format
 msgid "Unable to open output signature file '%s'"
 #: ../lib/psdriver/graph_set.c:199
 #, c-format
@@ -818,7 +818,7 @@
 #: ../lib/cairodriver/write_ppm.c:27 ../lib/cairodriver/write_bmp.c:72
 #, fuzzy, c-format
 msgid "Cairo: unable to open output file <%s>"
 #: ../lib/cairodriver/write_ppm.c:34
 #, fuzzy, c-format
@@ -843,7 +843,7 @@
 #: ../lib/cairodriver/read_ppm.c:46
 #, fuzzy, c-format
 msgid "Cairo: unable to open input mask file <%s>"
 #: ../lib/cairodriver/read_ppm.c:50
 #, fuzzy, c-format
@@ -864,12 +864,12 @@
 #: ../lib/cairodriver/read_xid.c:17
 #, fuzzy, c-format
 msgid "Unable to read input file <%s>"
 #: ../lib/cairodriver/read_xid.c:20
 #, fuzzy, c-format
 msgid "Unable to parse input file <%s>"
 #: ../lib/cairodriver/raster.c:109
 #, fuzzy
@@ -879,12 +879,12 @@
 #: ../lib/cairodriver/write_xid.c:14 ../lib/pngdriver/read_png.c:71
 #, fuzzy, c-format
 msgid "Unable to open output file <%s>"
 #: ../lib/cairodriver/write_xid.c:19
 #, fuzzy, c-format
 msgid "Unable to write output file <%s>"
 #: ../lib/cairodriver/read_bmp.c:96
 #, c-format
@@ -899,7 +899,7 @@
 #: ../lib/cairodriver/graph.c:85
 #, fuzzy
 msgid "Unable to obtain visual"
 #: ../lib/cairodriver/graph.c:160
 #, c-format
@@ -924,7 +924,7 @@
 #: ../lib/cairodriver/graph.c:376
 #, fuzzy
 msgid "Failed to initialize Cairo surface"
 #: ../lib/cairodriver/draw_bitmap.c:47
 msgid "Cairo_Bitmap: Failed to create source"
@@ -975,7 +975,7 @@
 #: ../lib/python/pygrass/raster/category.py:186
 #, fuzzy
 msgid "Error executing: Rast_set_cat"
-msgstr "za obstojeèe rastrske sloje %d\n"
+msgstr "za obstoječe rastrske sloje %d\n"
 #: ../lib/python/pygrass/raster/abstract.py:275
 #, fuzzy, python-brace-format
@@ -1000,7 +1000,7 @@
 #: ../lib/python/pygrass/raster/__init__.py:214
 msgid "Raster map <{0}> already exists and will be not overwritten"
-msgstr "Vektor '%s' ¾e obstaja in bo prepisan."
+msgstr "Vektor '%s' že obstaja in bo prepisan."
 #: ../lib/python/pygrass/raster/__init__.py:218
 #, fuzzy
@@ -1020,7 +1020,7 @@
 #: ../lib/python/pygrass/raster/__init__.py:530
 msgid "Raster map <{0}> already exists. Use overwrite."
 #: ../lib/python/pygrass/raster/__init__.py:561
@@ -1044,7 +1044,7 @@
 #: ../lib/python/pygrass/vector/__init__.py:895
 #, fuzzy, python-format
 msgid "Unable to read area with id %i"
 #: ../lib/python/pygrass/modules/grid/grid.py:553
 msgid "Execution of subprocesses was not successful"
@@ -1098,7 +1098,7 @@
 #: ../lib/python/temporal/datetime_math.py:755
 msgid "Unable to parse time string: %s"
 #: ../lib/python/temporal/stds_import.py:85
@@ -1108,7 +1108,7 @@
 #: ../lib/python/temporal/stds_import.py:96
 msgid "Unable to set the color rules for raster map <%s>."
 #: ../lib/python/temporal/stds_import.py:120
@@ -1143,17 +1143,17 @@
 #: ../lib/python/temporal/stds_import.py:223
 msgid "Unable to find init file <%s>"
 #: ../lib/python/temporal/stds_import.py:225
 msgid "Unable to find list file <%s>"
 #: ../lib/python/temporal/stds_import.py:227
 msgid "Unable to find projection file <%s>"
 #: ../lib/python/temporal/stds_import.py:229
 #, fuzzy
@@ -1188,7 +1188,7 @@
 #: ../lib/python/temporal/stds_import.py:306
 msgid "Unable to create default temporal database in new location %s"
 #: ../lib/python/temporal/stds_import.py:380
 #, python-format
@@ -1206,12 +1206,12 @@
 #: ../lib/python/temporal/stds_import.py:405
 msgid "Unable to find GeoTIFF raster file <%s> in archive."
 #: ../lib/python/temporal/stds_import.py:411
 msgid "Unable to find AAIGrid raster file <%s> in archive."
 #: ../lib/python/temporal/stds_import.py:417
@@ -1221,7 +1221,7 @@
 #: ../lib/python/temporal/stds_import.py:426
 msgid "Unable to find GRASS package file <%s> in archive."
 #: ../lib/python/temporal/stds_import.py:429
 #, fuzzy
@@ -1233,17 +1233,17 @@
 msgid ""
 "Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
 "overwrite flag."
 #: ../lib/python/temporal/stds_import.py:456
 msgid "Overwrite space time %(sp)s dataset <%(id)s> and unregister all maps."
 #: ../lib/python/temporal/stds_import.py:468
 msgid "Key word %s not found in init file."
 #: ../lib/python/temporal/stds_import.py:473
@@ -1273,7 +1273,7 @@
 msgid ""
 "Error vector map %s exist in temporal database. Use overwrite flag.  : \n"
 "%s"
 #: ../lib/python/temporal/core.py:604
 msgid ""
@@ -1286,7 +1286,7 @@
 msgid ""
 "Unable to receive temporal database metadata.\n"
 "Current temporal database info:%(info)s"
 #: ../lib/python/temporal/core.py:672
@@ -1295,7 +1295,7 @@
 " %(backup)s Supported temporal API version is: %(api)i.\n"
 "Please update your GRASS GIS installation.\n"
 #: ../lib/python/temporal/core.py:680
@@ -1303,7 +1303,7 @@
 "Unsupported temporal database: version mismatch.\n"
 " %(backup)sSupported temporal database version is: %(tdb)i\n"
 #: ../lib/python/temporal/core.py:768
@@ -1326,7 +1326,7 @@
 #: ../lib/python/temporal/core.py:964
 #, fuzzy
 msgid "Unable to check table. "
 #: ../lib/python/temporal/core.py:980
 #, fuzzy
@@ -1341,7 +1341,7 @@
 #: ../lib/python/temporal/core.py:1000
 #, fuzzy
 msgid "Unable to fetch all. "
 #: ../lib/python/temporal/core.py:1017
 #, fuzzy
@@ -1379,7 +1379,7 @@
 #: ../lib/python/temporal/univar_statistics.py:101
 msgid "Unable to get statistics for raster map <%s>"
 #: ../lib/python/temporal/univar_statistics.py:104
@@ -1394,7 +1394,7 @@
 #: ../lib/python/temporal/univar_statistics.py:222
 msgid "Unable to get statistics for vector map <%s>"
 #: ../lib/python/temporal/abstract_dataset.py:386
 #, python-format
@@ -1511,14 +1511,14 @@
 msgid "Please specify %s= and %s="
 msgstr ""
 "\n"
-"Prosim doloèite fundamentalno toèko\n"
+"Prosim določite fundamentalno točko\n"
 #: ../lib/python/temporal/register.py:103
 msgid "Please specify %s= or %s="
 msgstr ""
 "\n"
-"Prosim doloèite ime elipsoida\n"
+"Prosim določite ime elipsoida\n"
 #: ../lib/python/temporal/register.py:114
 #, python-format
@@ -1574,14 +1574,14 @@
 msgid ""
 "Map is already registered in temporal database. Unable to update %(t)s map <"
 "%(id)s> with layer %(l)s. Overwrite flag is not set."
 #: ../lib/python/temporal/register.py:252
 msgid ""
 "%(id)s>. Overwrite flag is not set."
 #: ../lib/python/temporal/register.py:276
@@ -1679,7 +1679,7 @@
 msgid ""
 "Map <%s> is already in temporal database, use overwrite flag to overwrite"
 #: ../lib/python/temporal/mapcalc.py:260
 #, python-format
@@ -1769,12 +1769,12 @@
 #: ../lib/python/temporal/space_time_datasets.py:250
 msgid "Unable to read timestamp file for raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:274
 msgid "Unable to create timestamp file for raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:279
@@ -1790,17 +1790,17 @@
 #: ../lib/python/temporal/space_time_datasets.py:646
 msgid "Unable to remove timestamp for raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:598
 msgid "Unable to read timestamp file for 3D raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:622
 msgid "Unable to create timestamp file for 3D raster map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:627
@@ -1810,12 +1810,12 @@
 #: ../lib/python/temporal/space_time_datasets.py:906
 msgid "Unable to read timestamp file for vector map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:929
 msgid "Unable to create timestamp file for vector map <%s>"
 #: ../lib/python/temporal/space_time_datasets.py:934
@@ -1825,7 +1825,7 @@
 #: ../lib/python/temporal/space_time_datasets.py:950
 msgid "Unable to remove timestamp for vector map <%s>"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:167
 #: ../lib/python/temporal/abstract_space_time_dataset.py:301
@@ -1862,7 +1862,7 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1499
 msgid "Unable to get map ids from register table <%s>"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1609
 #, python-format
@@ -1905,12 +1905,12 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1973
 msgid "Drop map register table: %s"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2028
 #, fuzzy
 msgid "Error in register table request"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2057
@@ -1974,7 +1974,7 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2159
 msgid "Map <%(map)s> with layer %(l)s is already registered."
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2163
 #, python-format
@@ -1994,12 +1994,12 @@
 msgid ""
 "Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
 "%(base)s>"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2230
 msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2291
 #, python-format
@@ -2035,13 +2035,13 @@
 msgid ""
 "End time must be greater than start time for %(type)s map <%(id)s> with "
 "layer: %(l)s"
-msgstr "East mora biti veèji od West"
+msgstr "East mora biti večji od West"
 #: ../lib/python/temporal/abstract_map_dataset.py:389
 #: ../lib/python/temporal/abstract_map_dataset.py:482
 msgid "End time must be greater than start time for %(type)s map <%(id)s>"
 #: ../lib/python/temporal/abstract_map_dataset.py:460
@@ -2053,14 +2053,14 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:467
 msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
 #: ../lib/python/temporal/abstract_map_dataset.py:476
 msgid ""
 "End time must be greater than start time for %(typ)s map <%(id)s> with layer "
 "%(l)s"
 #: ../lib/python/temporal/abstract_map_dataset.py:800
 #, python-format
@@ -2100,7 +2100,7 @@
 #: ../lib/python/temporal/stds_export.py:115
 msgid "Unable to export color rules for raster map <%s> r.out.gdal"
 #: ../lib/python/temporal/stds_export.py:139
@@ -2146,7 +2146,7 @@
 msgid ""
 "Raster map <%(name)s> is already in temporal database, use overwrite flag to "
 "overwrite"
 #: ../lib/python/temporal/aggregation.py:146
 #, python-format
@@ -2191,20 +2191,20 @@
 #: ../lib/python/temporal/open_stds.py:108
 #, fuzzy
 msgid "Space time datasets can only be created in the current mapset"
 #: ../lib/python/temporal/open_stds.py:125
 msgid ""
 "Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
 "overwrite flag."
 #: ../lib/python/temporal/open_stds.py:160
 msgid ""
 "Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
 #: ../lib/python/temporal/open_stds.py:168
@@ -2290,7 +2290,7 @@
 #: ../lib/python/script/core.py:1414
 msgid "Location <%s> already exists and will be overwritten"
 #: ../lib/python/script/core.py:1538
 msgid "Debug level {}"
@@ -2341,7 +2341,7 @@
 msgid ""
 "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
 "current mapset."
-msgstr "Ne morem izbrisati linije, sloj '%s' ni odprt v zapisovalnem naèinu"
+msgstr "Ne morem izbrisati linije, sloj '%s' ni odprt v zapisovalnem načinu"
 #: ../lib/python/script/raster.py:113
 #, python-format
@@ -2369,7 +2369,7 @@
 #: ../lib/vector/Vlib/write_pg.c:666 ../lib/vector/Vlib/ascii.c:428
 #, fuzzy, c-format, python-format
 msgid "Unable to describe table <%s>"
 #: ../lib/python/script/db.py:153
 #, python-format
@@ -2380,7 +2380,7 @@
 #: ../lib/python/script/db.py:163
 #, fuzzy
 msgid "Fetching data failed"
 #: ../lib/python/script/array.py:157 ../lib/python/script/array.py:207
 #: ../lib/python/script/array.py:254 ../lib/python/script/array.py:305
@@ -2474,7 +2474,7 @@
 "%s"
 msgstr ""
 "\n"
-"IZBIRA: Doloèite naslednjo izbiro?\n"
+"IZBIRA: Določite naslednjo izbiro?\n"
 #: ../lib/python/exceptions/__init__.py:75
 msgid ". See errors in the (error) output."
@@ -2757,7 +2757,7 @@
 #: ../lib/gmath/la.c:155
 #, fuzzy
 msgid "Unable to allocate space for matrix copy"
-msgstr "Nezmo¾en dodeliti spomin\n"
+msgstr "Nezmožen dodeliti spomin\n"
 #: ../lib/gmath/la.c:220
 msgid "Input matrix is uninitialized"
@@ -2778,12 +2778,12 @@
 #: ../lib/gmath/la.c:310
 #, fuzzy
 msgid "Unable to allocate space for matrix sum"
 #: ../lib/gmath/la.c:374
 #, fuzzy
 msgid "Unable to allocate space for matrix product"
 #: ../lib/gmath/la.c:486
 msgid "Input: one or both data matrices uninitialised"
@@ -2824,7 +2824,7 @@
 #: ../lib/gmath/la.c:619
 #, fuzzy
 msgid "Unable to allocate space for matrix"
 #: ../lib/gmath/la.c:636
 msgid "Matrix is singular"
@@ -2912,7 +2912,7 @@
 #: ../lib/gmath/la.c:1371
 #, fuzzy
 msgid "Output vector is not the same type as others"
 #: ../lib/gmath/la.c:1437
 msgid "Vector structure is not initialised"
@@ -2948,12 +2948,12 @@
 #: ../lib/lidar/raster.c:175
 #, fuzzy, c-format
 msgid "Unable to access table <%s>"
 #: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
 #, fuzzy, c-format
 msgid "<%s> created in database."
-msgstr "Nezmo¾en odpreti datoteko s tabelo elipsoida: %s"
+msgstr "Nezmožen odpreti datoteko s tabelo elipsoida: %s"
 #: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
 #, c-format
@@ -2977,7 +2977,7 @@
 #: ../lib/db/dbmi_base/legal_dbname.c:45
 #, fuzzy, c-format
 msgid "Illegal table map name <%s>. Must start with a letter."
-msgstr "Neveljavno ime vektorskega sloja <%s>. Zaèeti se mora s èrko.\n"
+msgstr "Neveljavno ime vektorskega sloja <%s>. Začeti se mora s črko.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:54
 #, fuzzy, c-format
@@ -2999,7 +2999,7 @@
 #: ../lib/db/dbmi_base/login.c:115
 #, fuzzy, c-format
 msgid "Unable to read file '%s'"
 #: ../lib/db/dbmi_base/login.c:126
 #, c-format
@@ -3009,19 +3009,19 @@
 #: ../lib/db/dbmi_base/login.c:164
 #, fuzzy, c-format
 msgid "Unable to write file '%s'"
 #: ../lib/db/dbmi_base/login.c:229
 #, fuzzy, c-format
 msgid "DB connection <%s/%s> already exists and will be overwritten"
 #: ../lib/db/dbmi_base/login.c:232
 #, fuzzy, c-format
 msgid ""
 "DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to "
 "overwrite existing settings."
 #: ../lib/db/dbmi_base/test/test_table.c:38
 #, fuzzy
@@ -3118,7 +3118,7 @@
 #: ../lib/vector/Vlib/write_pg.c:2902 ../lib/vector/Vlib/ascii.c:404
 #, fuzzy, c-format
 msgid "Unable to start driver <%s>"
 #: ../lib/db/dbmi_client/table.c:46 ../lib/db/dbmi_client/delete_tab.c:40
 #, fuzzy, c-format
@@ -3139,17 +3139,17 @@
 #: ../lib/db/dbmi_client/copy_tab.c:151
 #, fuzzy, c-format
 msgid "Unable to get list tables in database <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:189
 #, fuzzy, c-format
 msgid "Table <%s> already exists in database and will be overwritten"
 #: ../lib/db/dbmi_client/copy_tab.c:194
 #, fuzzy, c-format
 msgid "Table <%s> already exists in database <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:274
 #, fuzzy, c-format
@@ -3165,13 +3165,13 @@
 #: ../lib/db/dbmi_client/copy_tab.c:294
 #, fuzzy, c-format
 msgid "Unable to create table <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:338 ../lib/vector/Vlib/write_ogr.c:585
 #: ../lib/vector/Vlib/write_pg.c:2009
 #, fuzzy, c-format
 msgid "Unable to fetch data from table <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:394
 #, c-format
@@ -3181,7 +3181,7 @@
 #: ../lib/db/dbmi_client/delete_tab.c:53
 #, fuzzy, c-format
 msgid "Unable to drop table: '%s'"
 #: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
 #: ../lib/db/dbmi_client/select.c:288
@@ -3195,7 +3195,7 @@
 #: ../lib/db/dbmi_client/select.c:317 ../lib/vector/Vlib/cats.c:603
 #, fuzzy, c-format
 msgid "Unable select records from table <%s>"
 #: ../lib/db/dbmi_client/select.c:333
 #, fuzzy
@@ -3210,7 +3210,7 @@
 #: ../lib/nviz/lights.c:171
 #, fuzzy
 msgid "Unable to define new light"
 #: ../lib/nviz/position.c:56
 #, fuzzy
@@ -3229,7 +3229,7 @@
 #: ../lib/nviz/render.c:112
 #, fuzzy
 msgid "Unable to get visual info"
 #: ../lib/nviz/render.c:119
 #, fuzzy
@@ -3260,7 +3260,7 @@
 #: ../lib/nviz/map_obj.c:152
 #, fuzzy, c-format
 msgid "Error loading 3d raster map <%s>"
 #: ../lib/nviz/map_obj.c:160
 msgid "Nviz_new_map_obj(): unsupported data type"
@@ -3349,7 +3349,7 @@
 #: ../lib/manage/read_list.c:73
 #, fuzzy, c-format
 msgid "Unable to open data base element list '%s'"
 #: ../lib/manage/read_list.c:134
 #, c-format
@@ -3407,7 +3407,7 @@
 #: ../lib/raster/reclass.c:168
 #, fuzzy, c-format
 msgid "Too many reclass categories for <%s@%s>"
 #: ../lib/raster/reclass.c:171
 #, fuzzy, c-format
@@ -3425,12 +3425,12 @@
 #: ../lib/raster/reclass.c:284
 #, fuzzy, c-format
 msgid "Unable to create header file for <%s@%s>"
 #: ../lib/raster/reclass.c:332
 #, fuzzy, c-format
 msgid "Unable to create dependency file in <%s@%s>"
-msgstr "Nezmo¾en ustvariti datoteko odvisnosti v [%s v %s]"
+msgstr "Nezmožen ustvariti datoteko odvisnosti v [%s v %s]"
 #: ../lib/raster/init.c:61
 #, fuzzy
@@ -3462,7 +3462,7 @@
 #: ../lib/raster/range.c:169
 #, fuzzy, c-format
 msgid "Unable to read quant rules for raster map <%s>"
 #: ../lib/raster/range.c:206 ../lib/raster/range.c:226
 #, fuzzy, c-format
@@ -3478,17 +3478,17 @@
 #: ../lib/raster/raster_metadata.c:109
 #, fuzzy, c-format
 msgid "Unable to read <%s> for raster map <%s@%s>"
 #: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
 #, fuzzy, c-format
 msgid "Error closing <%s> metadata file for raster map <%s@%s>"
 #: ../lib/raster/raster_metadata.c:142
 #, fuzzy, c-format
 msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
 #: ../lib/raster/put_row.c:121
 #, fuzzy, c-format
@@ -3571,7 +3571,7 @@
 #: ../lib/raster/quant_io.c:43
 #, fuzzy, c-format
 msgid "Floating data range for raster map <%s> is empty"
-msgstr "Razpon plavajoèih podatkov za %s@%s je prazen"
+msgstr "Razpon plavajočih podatkov za %s@%s je prazen"
 #: ../lib/raster/quant_io.c:52
 #, fuzzy, c-format
@@ -3601,7 +3601,7 @@
 #: ../lib/raster/histogram.c:55
 #, c-format
 msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr "Histogram za [%s v %s] manjka (po¾enite r.support) "
+msgstr "Histogram za [%s v %s] manjka (poženite r.support) "
 #: ../lib/raster/histogram.c:62
 #, c-format
@@ -3616,7 +3616,7 @@
 #: ../lib/raster/histogram.c:331
 #, fuzzy, c-format
 msgid "Unable to create histogram file for <%s>"
 #: ../lib/raster/open.c:193
 #, fuzzy, c-format
@@ -3635,7 +3635,7 @@
 #: ../lib/raster/open.c:209
 #, fuzzy, c-format
 msgid "Error reading map type for raster map <%s>"
 #: ../lib/raster/open.c:217
 #, fuzzy, c-format
@@ -3653,7 +3653,7 @@
 "Raster map <%s> is in different projection than current region. Found <%s>, "
 "should be <%s>."
 msgstr ""
-"[%s] v \"mapset\" [%s] - je v drugaèni projekciji kot trenutna regija:\n"
+"[%s] v \"mapset\" [%s] - je v drugačni projekciji kot trenutna regija:\n"
 "najden sloj [%s] v: <%s>, moral bi biti <%s> "
 #: ../lib/raster/open.c:247
@@ -3664,7 +3664,7 @@
 #: ../lib/raster/open.c:252
 #, fuzzy, c-format
 msgid "Raster map <%s>: bytes per cell (%d) too large"
-msgstr "[%s] v [%s] - bajtov na celico (%d) preveè"
+msgstr "[%s] v [%s] - bajtov na celico (%d) preveč"
 #: ../lib/raster/open.c:277
 #, c-format
@@ -3685,7 +3685,7 @@
 #: ../lib/raster/open.c:527
 #, fuzzy
 msgid "Unable to create GDAL link"
 #: ../lib/raster/open.c:599 ../lib/raster/gdal.c:476
 #, fuzzy, c-format
@@ -3695,7 +3695,7 @@
 #: ../lib/raster/open.c:604 ../lib/raster/open.c:759
 #, fuzzy, c-format
 msgid "Raster map <%s> is not in the current mapset (%s)"
 #: ../lib/raster/open.c:611
 #, fuzzy, c-format
@@ -3710,7 +3710,7 @@
 #: ../lib/raster/open.c:755
 #, fuzzy, c-format
 msgid "Raster map <%s> does not exist in the current mapset (%s)"
 #: ../lib/raster/open.c:821
 msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
@@ -3779,17 +3779,17 @@
 #: ../lib/raster/close.c:391 ../lib/raster/close.c:519
 #, fuzzy, c-format
 msgid "Unable to rename null file '%s' to '%s': %s"
 #: ../lib/raster/close.c:461
 #, fuzzy, c-format
 msgid "Unable to rename cell file '%s' to '%s': %s"
 #: ../lib/raster/close.c:541
 #, fuzzy
 msgid "unable to write f_format file for CELL maps"
 #: ../lib/raster/interp.c:211
 #, fuzzy, c-format
@@ -3816,7 +3816,7 @@
 #: ../lib/raster/gdal.c:88
 #, fuzzy, c-format
 msgid "Unable to locate symbol <%s>"
 #: ../lib/raster/gdal.c:142
 #, fuzzy
@@ -3826,7 +3826,7 @@
 #: ../lib/raster/gdal.c:372
 #, fuzzy
 msgid "Unable to open GDAL file"
 #: ../lib/raster/gdal.c:482
 #, fuzzy, c-format
@@ -3836,7 +3836,7 @@
 #: ../lib/raster/gdal.c:491
 #, fuzzy, c-format
 msgid "Unable to create <%s> dataset using <%s> driver"
 #: ../lib/raster/gdal.c:499
 #, c-format
@@ -3883,17 +3883,17 @@
 #: ../lib/raster/gdal.c:604
 #, fuzzy, c-format
 msgid "Unable to create output file <%s> using driver <%s>"
 #: ../lib/raster/format.c:162
 #, c-format
 msgid "Fail of initial read of compressed file [%s in %s]"
-msgstr "Napaka pri branju zaèetka stisnjene datoteke [%s v %s]"
+msgstr "Napaka pri branju začetka stisnjene datoteke [%s v %s]"
 #: ../lib/raster/format.c:176
 #, fuzzy, c-format
 msgid "Fail of initial read of compressed null file [%s in %s]"
 #: ../lib/raster/sample.c:70
 #, fuzzy
@@ -3907,7 +3907,7 @@
 #: ../lib/raster/put_title.c:28
 #, c-format
 msgid "category information for [%s] in [%s] missing or invalid"
-msgstr "neveljavna ali manjkajoèa informacija o kategoriji za [%s] v [%s]"
+msgstr "neveljavna ali manjkajoča informacija o kategoriji za [%s] v [%s]"
 #: ../lib/raster/put_title.c:37
 msgid "G_put_title - can't create a temp file"
@@ -3944,7 +3944,7 @@
 msgid "invalid value"
 msgstr ""
 "\n"
-"neveljavna fundamentalna toèka\n"
+"neveljavna fundamentalna točka\n"
 #: ../lib/raster/color_rules.c:134
 #, fuzzy
@@ -4060,17 +4060,17 @@
 #: ../lib/raster/null_val.c:64
 #, fuzzy
 msgid "EmbedGivenNulls: wrong data type"
-msgstr "EmbedGivenNulls: napaèen tip podatkov!"
+msgstr "EmbedGivenNulls: napačen tip podatkov!"
 #: ../lib/raster/null_val.c:114
 #, fuzzy
 msgid "Rast_set_null_value: wrong data type!"
-msgstr "G_set_null_value: napaèen tip podatkov!"
+msgstr "G_set_null_value: napačen tip podatkov!"
 #: ../lib/raster/auto_mask.c:69
 #, fuzzy
 msgid "Unable to open automatic MASK file"
-msgstr "Nezmo¾en odpreti avtomatièno datoteko MASK"
+msgstr "Nezmožen odpreti avtomatično datoteko MASK"
 #: ../lib/raster/set_window.c:48
 msgid "Rast_set_window() called while window split"
@@ -4082,7 +4082,7 @@
 "Rast_set_read_window(): projection/zone differs from that of currently open "
 "raster maps"
 msgstr ""
-"G_set_window(): projekcija/cona je razlièna od tiste, ki je doloèena za "
+"G_set_window(): projekcija/cona je različna od tiste, ki je določena za "
 "trenutno odprte rastrske sloje"
 #: ../lib/raster/set_window.c:158
@@ -4098,7 +4098,7 @@
 #: ../lib/raster/put_cellhd.c:34
 #, fuzzy, c-format
 msgid "Unable to create header file for <%s>"
 #: ../lib/gis/lrand48.c:84
 #, fuzzy, c-format
@@ -4117,12 +4117,12 @@
 #: ../lib/gis/timestamp.c:292
 #, fuzzy, c-format
 msgid "Unable to create timestamp file for %s map <%s@%s>"
 #: ../lib/gis/timestamp.c:301
 #, fuzzy, c-format
 msgid "Invalid timestamp specified for %s map <%s@%s>"
-msgstr "timestamp doloèen za %s v sloju %s v \"mapset\" %s je neveljaven "
+msgstr "timestamp določen za %s v sloju %s v \"mapset\" %s je neveljaven "
 #: ../lib/gis/timestamp.c:331
 #, fuzzy, c-format
@@ -4147,12 +4147,12 @@
 #: ../lib/gis/timestamp.c:524
 #, fuzzy, c-format
 msgid "Unable to create timestamp file for vector map <%s@%s>"
 #: ../lib/gis/timestamp.c:533
 #, fuzzy, c-format
 msgid "Invalid timestamp specified for vector map <%s@%s>"
 #: ../lib/gis/location.c:61
 #, fuzzy, c-format
@@ -4210,7 +4210,7 @@
 #: ../lib/gis/parser_rest.c:223 ../lib/gis/parser_html.c:233
 #, fuzzy
 msgid "Options"
-msgstr "mo¾nosti: %s\n"
+msgstr "možnosti: %s\n"
 #: ../lib/gis/parser_rest.c:230 ../lib/gis/parser_html.c:239
 #, fuzzy
@@ -4228,7 +4228,7 @@
 #: ../lib/gis/proj2.c:63
 msgid "Latitude-Longitude"
-msgstr "©irina-Dol¾ina"
+msgstr "Širina-Dolžina"
 #: ../lib/gis/proj2.c:65
 msgid "Other Projection"
@@ -4289,7 +4289,7 @@
 #: ../lib/gis/get_ellipse.c:263 ../lib/proj/ellipse.c:243
 #, fuzzy, c-format
 msgid "Unable to open ellipsoid table file <%s>"
 #: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
 #, fuzzy, c-format
@@ -4364,7 +4364,7 @@
 #: ../lib/gis/parser_help.c:279
 #, c-format
 msgid "  %*s   options: "
-msgstr "  %*s   mo¾nosti: "
+msgstr "  %*s   možnosti: "
 #: ../lib/gis/list.c:83
 #, fuzzy, c-format
@@ -4403,7 +4403,7 @@
 #: ../lib/gis/home.c:39
 #, fuzzy
 msgid "Unable to determine user's home directory"
-msgstr "ne morem doloèiti uporabnikovega domaèega direktorija"
+msgstr "ne morem določiti uporabnikovega domačega direktorija"
 #: ../lib/gis/home.c:120
 #, fuzzy, c-format
@@ -4442,7 +4442,7 @@
 #, fuzzy
 msgid "WHERE conditions of SQL statement without 'where' keyword"
 msgstr ""
-"WHERE pogoji SQL stavka brez kljuène besede 'where': (primer: dohodek < 1000 "
+"WHERE pogoji SQL stavka brez ključne besede 'where': (primer: dohodek < 1000 "
 "and preb >= 10000)"
 #: ../lib/gis/parser_standard_options.c:157
@@ -4692,7 +4692,7 @@
 #: ../lib/gis/parser_standard_options.c:525
 #, fuzzy
 msgid "Layer number or name"
-msgstr "©tevilka sloja"
+msgstr "Številka sloja"
 #: ../lib/gis/parser_standard_options.c:527
 msgid ""
@@ -4704,7 +4704,7 @@
 #: ../lib/gis/parser_standard_options.c:537
 #, fuzzy
 msgid "Layer number or name ('-1' for all layers)"
-msgstr "©tevilka polja <%d> ali vektor '%s' ¾e obstaja."
+msgstr "Številka polja <%d> ali vektor '%s' že obstaja."
 #: ../lib/gis/parser_standard_options.c:539
 msgid ""
@@ -4832,7 +4832,7 @@
 #: ../lib/gis/parser_standard_options.c:753
 #, fuzzy
 msgid "Name of the input space time datasets"
 #: ../lib/gis/parser_standard_options.c:761
 #, fuzzy
@@ -4887,7 +4887,7 @@
 #: ../lib/gis/parser_standard_options.c:845
 #, fuzzy
 msgid "Type of the input space time dataset"
 #: ../lib/gis/parser_standard_options.c:853
 #, fuzzy
@@ -4915,7 +4915,7 @@
 "WHERE conditions of SQL statement without 'where' keyword used in the "
 "temporal GIS framework"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:888
@@ -5197,7 +5197,7 @@
 #: ../lib/gis/parser.c:585
 #, fuzzy, c-format
 msgid "Sorry <%s> is not a valid option"
-msgstr "Oprostite <%s> ni veljavna mo¾nost\n"
+msgstr "Oprostite <%s> ni veljavna možnost\n"
 #: ../lib/gis/parser.c:598
 msgid "Your installation doesn't include GUI, exiting."
@@ -5211,7 +5211,7 @@
 #: ../lib/gis/parser.c:941
 #, fuzzy
 msgid "Unable to determine program name"
 #: ../lib/gis/parser.c:963 ../lib/gis/parser.c:980
 #, fuzzy, c-format
@@ -5271,7 +5271,7 @@
 msgid "Missing value for parameter <%s>"
 msgstr ""
 "\n"
-"Napaka: Manjkajoèa vrednost za parameter <%s>\n"
+"Napaka: Manjkajoča vrednost za parameter <%s>\n"
 #: ../lib/gis/parser.c:1245
 #, fuzzy, c-format
@@ -5299,7 +5299,7 @@
 "\tYou provided %d item(s): %s"
 msgstr ""
 "\n"
-"Napaka: mo¾nost <%s> mora biti podana v veèkratnikih %d\n"
+"Napaka: možnost <%s> mora biti podana v večkratnikih %d\n"
 #: ../lib/gis/parser.c:1584 ../lib/gis/error.c:362
 #, c-format
@@ -5314,7 +5314,7 @@
 #: ../lib/gis/parser.c:1703
 #, fuzzy, c-format
 msgid "%s= is not a separator option"
 #: ../lib/gis/parser.c:1706
 #, c-format
@@ -5324,7 +5324,7 @@
 #: ../lib/gis/parser.c:1768 ../lib/gis/parser.c:1785
 #, fuzzy, c-format
 msgid "%s= is not a file option"
 #: ../lib/gis/parser.c:1770
 #, fuzzy, c-format
@@ -5334,12 +5334,12 @@
 #: ../lib/gis/parser.c:1776
 #, fuzzy, c-format
 msgid "Unable to open %s file <%s>"
 #: ../lib/gis/parser.c:1782
 #, fuzzy, c-format
 msgid "Unable to create %s file <%s>"
 #: ../lib/gis/worker.c:84
 msgid "Task already has a worker"
@@ -5369,7 +5369,7 @@
 #: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:244
 msgid "Illegal latitude for North"
-msgstr "Neveljavna ¹irina za North"
+msgstr "Neveljavna širina za North"
 #: ../lib/gis/adj_cellhd.c:85 ../lib/gis/adj_cellhd.c:250
 #, c-format
@@ -5378,7 +5378,7 @@
 #: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:255
 msgid "Illegal latitude for South"
-msgstr "Neveljavna ¹irina za South"
+msgstr "Neveljavna širina za South"
 #: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:267
 #, c-format
@@ -5396,11 +5396,11 @@
 #: ../lib/gis/adj_cellhd.c:128 ../lib/gis/adj_cellhd.c:293
 msgid "North must be larger than South"
-msgstr "North mora biti veèji od South"
+msgstr "North mora biti večji od South"
 #: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:296
 msgid "East must be larger than West"
 #: ../lib/gis/adj_cellhd.c:150 ../lib/gis/adj_cellhd.c:340
 msgid "Invalid coordinates"
@@ -5437,7 +5437,7 @@
 #: ../lib/gis/adj_cellhd.c:299
 #, fuzzy
 msgid "Top must be larger than Bottom"
 #: ../lib/gis/myname.c:46
 msgid "This location has no description."
@@ -5541,22 +5541,22 @@
 #: ../lib/gis/rd_cellhd.c:291
 #, fuzzy
 msgid "Duplicate rows field"
-msgstr "obstajata dve polji za ¹tevilo vrstic"
+msgstr "obstajata dve polji za število vrstic"
 #: ../lib/gis/rd_cellhd.c:301
 #, fuzzy
 msgid "Duplicate 3D rows field"
-msgstr "obstajata dve polji za 3D ¹tevilo vrstic"
+msgstr "obstajata dve polji za 3D število vrstic"
 #: ../lib/gis/rd_cellhd.c:311
 #, fuzzy
 msgid "Duplicate cols field"
-msgstr "obstajata dve polji za ¹tevilo kolon"
+msgstr "obstajata dve polji za število kolon"
 #: ../lib/gis/rd_cellhd.c:321
 #, fuzzy
 msgid "Duplicate 3D cols field"
-msgstr "obstajata polji za 3D ¹tevilo kolon"
+msgstr "obstajata polji za 3D število kolon"
 #: ../lib/gis/rd_cellhd.c:331
 #, fuzzy
@@ -5576,12 +5576,12 @@
 #: ../lib/gis/datum.c:160
 #, c-format
 msgid "unable to open datum table file: %s"
 #: ../lib/gis/datum.c:182
 #, c-format
 msgid "error in datum table file, line %d"
-msgstr "napaka v datoteki s tabelo fundamentalne toèke, vrstica %d"
+msgstr "napaka v datoteki s tabelo fundamentalne točke, vrstica %d"
 #: ../lib/gis/open_misc.c:49
 #, c-format
@@ -5691,7 +5691,7 @@
 #: ../lib/gis/key_value3.c:33
 #, fuzzy, c-format
 msgid "Unable to open output file <%s>: %s"
 #: ../lib/gis/key_value3.c:36
 #, fuzzy, c-format
@@ -5701,7 +5701,7 @@
 #: ../lib/gis/key_value3.c:39
 #, fuzzy, c-format
 msgid "Error closing output file <%s>: %s"
 #: ../lib/gis/key_value3.c:60
 #, fuzzy, c-format
@@ -5766,7 +5766,7 @@
 #: ../lib/gis/paths.c:201
 #, fuzzy, c-format
 msgid "Unable to open file <%s> for reading"
 #: ../lib/gis/paths.c:217
 #, fuzzy, c-format
@@ -5825,12 +5825,12 @@
 #: ../lib/gis/view.c:176
 #, c-format
 msgid "Unable to open %s for writing"
 #: ../lib/gis/view.c:262 ../lib/gis/view.c:479
 #, c-format
 msgid "Unable to open %s for reading"
-msgstr "Nezmo¾en odpreti %s za branje"
+msgstr "Nezmožen odpreti %s za branje"
 #: ../lib/gis/view.c:465
 #, c-format
@@ -5974,12 +5974,12 @@
 #: ../lib/display/r_raster.c:150
 #, fuzzy, c-format
 msgid "Unknown display driver <%s>"
 #: ../lib/display/r_raster.c:151
 #, fuzzy, c-format
 msgid "Using display driver <%s>..."
 #: ../lib/cluster/c_exec.c:44
 #, c-format
@@ -6003,7 +6003,7 @@
 #: ../lib/init/lock.c:60
 #, fuzzy, c-format
 msgid "Unable to write lockfile %s (%s)"
 #: ../lib/init/grass.py:123
 #, fuzzy
@@ -6159,7 +6159,7 @@
 msgid ""
 "Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
 #: ../lib/init/grass.py:493
 #, python-brace-format
@@ -6275,7 +6275,7 @@
 msgid ""
 "Invalid return code from GUI startup script.\n"
 "Please advise GRASS developers of this error."
-msgstr "Prosim sporoèite razvijalcem GRASS-a o tej napaki.\n"
+msgstr "Prosim sporočite razvijalcem GRASS-a o tej napaki.\n"
 #: ../lib/init/grass.py:1051
@@ -6376,7 +6376,7 @@
 #: ../lib/init/grass.py:1375
 msgid "Execution of <%s> finished."
 #: ../lib/init/grass.py:1406
 #, fuzzy
@@ -6400,7 +6400,7 @@
 #: ../lib/init/grass.py:1459
 #, fuzzy
 msgid "Help is available with the command:"
-msgstr "Za ukaz [%s] ni na voljo pomoèi\n"
+msgstr "Za ukaz [%s] ni na voljo pomoči\n"
 #: ../lib/init/grass.py:1460
 msgid "See the licence terms with:"
@@ -6500,7 +6500,7 @@
 #: ../lib/init/grass.py:1970
 msgid "Failed to start shell '%s'"
 #: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
 #: ../lib/vector/neta/spanningtree.c:101 ../lib/vector/neta/flow.c:66
@@ -6532,7 +6532,7 @@
 #: ../lib/vector/vedit/delete.c:72
 #, fuzzy, c-format
 msgid "No area found for centroid %d"
-msgstr "©tevilo obmoèij brez centroida  :    %d\n"
+msgstr "Število območij brez centroida  :    %d\n"
 #: ../lib/vector/vedit/delete.c:76
 #, c-format
@@ -6542,7 +6542,7 @@
 #: ../lib/vector/vedit/delete.c:105
 #, fuzzy, c-format
 msgid "Area %d without centroid"
 #: ../lib/vector/vedit/delete.c:121
 #, fuzzy, c-format
@@ -6621,7 +6621,7 @@
 #: ../lib/vector/neta/utils.c:254
 #, fuzzy
 msgid "Problem loading category values"
 #: ../lib/vector/Vlib/write_nat.c:182 ../lib/vector/Vlib/write_nat.c:295
 #: ../lib/vector/Vlib/write_nat.c:651 ../lib/vector/Vlib/read_pg.c:331
@@ -6697,12 +6697,12 @@
 #: ../lib/vector/Vlib/write_ogr.c:140 ../lib/vector/Vlib/write_pg.c:347
 #, fuzzy
 msgid "Unable to delete feature"
 #: ../lib/vector/Vlib/write_ogr.c:239
 #, fuzzy, c-format
 msgid "Creating field <%s> failed"
 #: ../lib/vector/Vlib/write_ogr.c:304 ../lib/vector/Vlib/write_pg.c:1104
 #, c-format
@@ -6712,7 +6712,7 @@
 #: ../lib/vector/Vlib/write_ogr.c:326
 #, fuzzy, c-format
 msgid "Unable to create OGR layer <%s> in '%s'"
 #: ../lib/vector/Vlib/write_ogr.c:338 ../lib/vector/Vlib/write_pg.c:1117
 #, c-format
@@ -6783,7 +6783,7 @@
 #: ../lib/vector/Vlib/write_ogr.c:624
 #, fuzzy, c-format
 msgid "Unable to create field <%s>"
 #: ../lib/vector/Vlib/write_ogr.c:653 ../lib/vector/Vlib/write_pg.c:2074
 #, fuzzy, c-format
@@ -6842,14 +6842,14 @@
 #: ../lib/vector/Vlib/field.c:91
 #, fuzzy
 msgid "Layer number must be 1 or greater"
-msgstr "©tevilka polja mora biti 1 ali veè."
+msgstr "Številka polja mora biti 1 ali več."
 #: ../lib/vector/Vlib/field.c:96
 #, fuzzy
 msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
 msgstr ""
 "Ne morem dodati povezave z bazo podatkov, sloj ni odprt v ZAPISOVALNEM "
-"naèinu."
+"načinu."
 #: ../lib/vector/Vlib/field.c:103
 #, fuzzy
@@ -6879,7 +6879,7 @@
 #: ../lib/vector/Vlib/field.c:261
 #, fuzzy, c-format
 msgid "Layer number %d or name <%s> already exists"
 #: ../lib/vector/Vlib/field.c:345
 #, fuzzy, c-format
@@ -6894,7 +6894,7 @@
 #: ../lib/vector/Vlib/field.c:352
 msgid "Default driver is not set"
-msgstr "Privzeti gonilnik ni doloèen"
+msgstr "Privzeti gonilnik ni določen"
 #: ../lib/vector/Vlib/field.c:355
 msgid "Default database is not set"
@@ -6903,7 +6903,7 @@
 #: ../lib/vector/Vlib/field.c:428
 #, c-format
 msgid "Requested dblink %d, maximum link number %d"
-msgstr "Zahtevan dblink %d, najveèja vrednost ¹tevila povezave %d"
+msgstr "Zahtevan dblink %d, največja vrednost števila povezave %d"
 #: ../lib/vector/Vlib/field.c:614 ../lib/vector/Vlib/field.c:622
 #, fuzzy, c-format
@@ -6918,7 +6918,7 @@
 #: ../lib/vector/Vlib/field.c:707
 #, fuzzy, c-format
 msgid "Unable to open OGR layer <%s>"
 #: ../lib/vector/Vlib/field.c:734
 #, fuzzy
@@ -6954,7 +6954,7 @@
 #: ../lib/vector/Vlib/field.c:1020
 #, fuzzy
 msgid "Bug: attempt to update map which is not in current mapset"
 #: ../lib/vector/Vlib/build_nat.c:74 ../lib/vector/Vlib/build_sfa.c:339
 #: ../lib/vector/Vlib/build_sfa.c:629
@@ -7055,7 +7055,7 @@
 #: ../lib/vector/Vlib/write.c:299
 #, fuzzy
 msgid "Unable to restore feature/offset %"
 #: ../lib/vector/Vlib/write.c:308
 #, fuzzy, c-format
@@ -7070,7 +7070,7 @@
 #: ../lib/vector/Vlib/clean_nodes.c:248
 #, fuzzy, c-format
 msgid "Modifications: %d"
 #: ../lib/vector/Vlib/map.c:139 ../lib/vector/Vlib/map.c:245
 #, fuzzy
@@ -7086,7 +7086,7 @@
 #: ../lib/vector/Vlib/open.c:821
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 #: ../lib/vector/Vlib/map.c:159 ../lib/vector/Vlib/open.c:813
 #: ../lib/vector/Vlib/open.c:826
@@ -7103,17 +7103,17 @@
 #: ../lib/vector/Vlib/close_nat.c:102
 #, fuzzy, c-format
 msgid "Unable to copy table <%s>"
 #: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:462
 #, fuzzy, c-format
 msgid "Unable to delete table <%s>"
 #: ../lib/vector/Vlib/map.c:346
 #, fuzzy, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
 #: ../lib/vector/Vlib/map.c:402
 #, c-format
@@ -7148,7 +7148,7 @@
 #: ../lib/vector/Vlib/map.c:499
 #, fuzzy, c-format
 msgid "Unable to delete file '%s'"
 #: ../lib/vector/Vlib/map.c:519
 #, fuzzy, c-format
@@ -7186,7 +7186,7 @@
 #: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
 #, fuzzy, c-format
 msgid "Feature %ld without geometry skipped"
 #: ../lib/vector/Vlib/read_pg.c:365
 #, c-format
@@ -7203,7 +7203,7 @@
 #: ../lib/vector/Vlib/build_sfa.c:364
 #, fuzzy, c-format
 msgid "Feature %d without geometry skipped"
 #: ../lib/vector/Vlib/read_pg.c:482 ../lib/vector/Vlib/read_ogr.c:382
 msgid "Feature without geometry. Skipped."
@@ -7287,7 +7287,7 @@
 msgid ""
 "Unable to read features. Reason:\n"
 "%s"
 #: ../lib/vector/Vlib/header.c:86
 #, fuzzy, c-format
@@ -7312,7 +7312,7 @@
 #: ../lib/vector/Vlib/read_sfa.c:90
 #, fuzzy, c-format
 msgid "Unable to construct centroid for area %d. Skipped."
 #: ../lib/vector/Vlib/read_sfa.c:95
 #, c-format
@@ -7327,7 +7327,7 @@
 #: ../lib/vector/Vlib/write_pg.c:285
 #, fuzzy, c-format
 msgid "Unable to rewrite feature %d"
 #: ../lib/vector/Vlib/write_pg.c:321 ../lib/vector/Vlib/write_pg.c:811
 #: ../lib/vector/Vlib/write_pg.c:1212 ../lib/vector/Vlib/write_pg.c:1364
@@ -7339,7 +7339,7 @@
 #: ../lib/vector/Vlib/write_pg.c:452
 #, fuzzy, c-format
 msgid "Unable to delete feature (%s) %d"
 #: ../lib/vector/Vlib/write_pg.c:554 ../lib/vector/Vlib/write_pg.c:1294
 #: ../lib/vector/Vlib/write_sfa.c:349
@@ -7350,7 +7350,7 @@
 #: ../lib/vector/Vlib/open.c:1355 ../lib/vector/Vlib/build_pg.c:411
 #, fuzzy
 msgid "Unable to open PG file"
 #: ../lib/vector/Vlib/write_pg.c:773
 #, fuzzy, c-format
@@ -7388,7 +7388,7 @@
 #: ../lib/vector/Vlib/write_pg.c:1129
 #, fuzzy
 msgid "Unable to create new PostGIS feature table"
 #: ../lib/vector/Vlib/write_pg.c:1143
 #, fuzzy
@@ -7465,7 +7465,7 @@
 #: ../lib/vector/Vlib/write_pg.c:2269
 #, fuzzy, c-format
 msgid "Unable to determine next left/right edge for edge %d"
 #: ../lib/vector/Vlib/write_pg.c:2274
 #, fuzzy
@@ -7485,7 +7485,7 @@
 #: ../lib/vector/Vlib/write_pg.c:2610
 #, fuzzy
 msgid "Unable to determine next left/right edge"
 #: ../lib/vector/Vlib/write_pg.c:2696
 #, fuzzy
@@ -7512,7 +7512,7 @@
 #: ../lib/vector/Vlib/dangles.c:262
 #, fuzzy, c-format
 msgid "%s lines: %d"
-msgstr "©tevilo linij            :  %d\n"
+msgstr "Število linij            :  %d\n"
 #: ../lib/vector/Vlib/dangles.c:263
 #, c-format
@@ -7522,7 +7522,7 @@
 #: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
 #, fuzzy, c-format
 msgid "Unable to calculate centroid for area %d"
 #: ../lib/vector/Vlib/build_sfa.c:305
 #, fuzzy, c-format
@@ -7539,8 +7539,8 @@
 #, fuzzy, c-format
 msgid "One feature without geometry skipped"
 msgid_plural "%d features without geometry skipped"
-msgstr[0] "©tevilo obmoèij brez centroida  :    %d\n"
-msgstr[1] "©tevilo obmoèij brez centroida  :    %d\n"
+msgstr[0] "Število območij brez centroida  :    %d\n"
+msgstr[1] "Število območij brez centroida  :    %d\n"
 #: ../lib/vector/Vlib/build_sfa.c:722
 #, fuzzy, c-format
@@ -7605,7 +7605,7 @@
 #: ../lib/vector/Vlib/open_ogr.c:191
 #, fuzzy, c-format
 msgid "Unable to get OGR driver <%s>"
 #: ../lib/vector/Vlib/open_ogr.c:199
 #, fuzzy, c-format
@@ -7615,17 +7615,17 @@
 #: ../lib/vector/Vlib/open_ogr.c:211
 #, fuzzy, c-format
 msgid "OGR layer <%s> already exists and will be overwritten"
 #: ../lib/vector/Vlib/open_ogr.c:215
 #, fuzzy, c-format
 msgid "Unable to delete OGR layer <%s>"
 #: ../lib/vector/Vlib/open_ogr.c:221
 #, fuzzy, c-format
 msgid "OGR layer <%s> already exists in datasource '%s'"
 #: ../lib/vector/Vlib/open_ogr.c:279
 #, c-format
@@ -7657,7 +7657,7 @@
 #: ../lib/vector/Vlib/remove_duplicates.c:199
 #, fuzzy, c-format
 msgid "Removed duplicates: %d"
 #: ../lib/vector/Vlib/break_polygons.c:102
 msgid "Break polygons: Bug in binary tree!"
@@ -7692,7 +7692,7 @@
 #: ../lib/vector/Vlib/legal_vname.c:50
 #, fuzzy, c-format
 msgid "Illegal vector map name <%s>. Must start with a letter."
 #: ../lib/vector/Vlib/legal_vname.c:58
 #, fuzzy, c-format
@@ -7708,7 +7708,7 @@
 #: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
 #, fuzzy, c-format
 msgid "Output vector map name <%s> is not in the current mapset (%s)"
 #: ../lib/vector/Vlib/legal_vname.c:117 ../lib/vector/Vlib/legal_vname.c:121
 #, fuzzy, c-format
@@ -7738,7 +7738,7 @@
 #: ../lib/vector/Vlib/copy.c:104
 #, fuzzy, c-format
 msgid "Unable to create PostGIS layer <%s>"
 #: ../lib/vector/Vlib/copy.c:133
 #, fuzzy, c-format
@@ -7762,7 +7762,7 @@
 #: ../lib/vector/Vlib/copy.c:340
 #, fuzzy, c-format
 msgid "%d features without category or from different layer skipped"
 #: ../lib/vector/Vlib/copy.c:372
 #, fuzzy
@@ -7772,7 +7772,7 @@
 #: ../lib/vector/Vlib/copy.c:400
 #, fuzzy, c-format
 msgid "Writing node %d failed"
 #: ../lib/vector/Vlib/copy.c:478
 #, fuzzy
@@ -7787,7 +7787,7 @@
 #: ../lib/vector/Vlib/copy.c:534 ../lib/vector/Vlib/copy.c:542
 #, fuzzy, c-format
 msgid "Writing area %d failed"
 #: ../lib/vector/Vlib/copy.c:550
 #, c-format
@@ -7817,22 +7817,22 @@
 #: ../lib/vector/Vlib/copy.c:760
 #, fuzzy, c-format
 msgid "Unable to grant privileges on table <%s>"
 #: ../lib/vector/Vlib/open.c:138
 #, fuzzy, c-format
 msgid "Programmer requested unknown access level %d"
-msgstr "Opozorilo, Za¾elen programer: nepoznan open_level\n"
+msgstr "Opozorilo, Zaželen programer: nepoznan open_level\n"
 #: ../lib/vector/Vlib/open.c:232
 #, fuzzy, c-format
 msgid "Vector map <%s> not found in current mapset"
 #: ../lib/vector/Vlib/open.c:252
 #, fuzzy
 msgid "Temporary vector maps can be accessed only in the current mapset"
 #: ../lib/vector/Vlib/open.c:277
 #, fuzzy
@@ -7886,7 +7886,7 @@
 #: ../lib/vector/Vlib/open.c:777
 #, fuzzy, c-format
 msgid "Unable to create vector map: <%s> is not in the current mapset (%s)"
 #: ../lib/vector/Vlib/open.c:786
 #, fuzzy, c-format
@@ -7919,7 +7919,7 @@
 #: ../lib/vector/Vlib/open.c:985
 #, fuzzy, c-format
 msgid "Unable to stat file <%s>"
 #: ../lib/vector/Vlib/open.c:1049
 #, c-format
@@ -7930,7 +7930,7 @@
 #, fuzzy
 msgid "Size of 'coor' file differs from value saved in topology file"
 msgstr ""
-"Velikost datoteke 'coor' je razlièna od vrednosti shranjene v datoteki topo."
+"Velikost datoteke 'coor' je različna od vrednosti shranjene v datoteki topo."
 #: ../lib/vector/Vlib/open.c:1149 ../lib/vector/Vlib/open.c:1248
 #, fuzzy, c-format
@@ -7941,12 +7941,12 @@
 #, fuzzy
 msgid "Size of 'coor' file differs from value saved in sidx file"
 msgstr ""
 #: ../lib/vector/Vlib/open.c:1317
 #, fuzzy
 msgid "Unable to open OGR file"
 #: ../lib/vector/Vlib/open.c:1343
 msgid "OGR output also detected, using OGR"
@@ -7965,7 +7965,7 @@
 #: ../lib/vector/Vlib/close.c:141
 #, fuzzy, c-format
 msgid "Unable to open %s file"
 #: ../lib/vector/Vlib/close.c:226
 #, fuzzy, c-format
@@ -8026,7 +8026,7 @@
 #: ../lib/vector/Vlib/snap.c:526 ../lib/vector/Vlib/snap.c:888
 #, fuzzy, c-format
 msgid "New vertices: %d"
-msgstr "©tevilo primitivnih enot :  %d\n"
+msgstr "Število primitivnih enot :  %d\n"
 #: ../lib/vector/Vlib/snap.c:915
 #, fuzzy
@@ -8098,7 +8098,7 @@
 #: ../lib/vector/Vlib/build_pg.c:491
 #, fuzzy, c-format
 msgid "Unable to create <%s.%s>"
 #: ../lib/vector/Vlib/build_pg.c:642
 #, fuzzy
@@ -8123,7 +8123,7 @@
 #: ../lib/vector/Vlib/build_pg.c:790
 #, fuzzy, c-format
 msgid "Topology for centroid %d not available. Area %d skipped"
 #: ../lib/vector/Vlib/build_pg.c:1000
 msgid "Create simple features topology from topogeometry data..."
@@ -8211,7 +8211,7 @@
 #: ../lib/vector/Vlib/geos.c:472
 #, fuzzy, c-format
 msgid "Unable to read feature id %d"
 #: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
 #: ../lib/vector/Vlib/line.c:250
@@ -8226,17 +8226,17 @@
 #: ../lib/vector/Vlib/close_nat.c:74
 #, fuzzy, c-format
 msgid "Unable to create '%s': %s"
 #: ../lib/vector/Vlib/close_nat.c:81
 #, fuzzy, c-format
 msgid "Unable to copy '%s': %s"
 #: ../lib/vector/Vlib/close_nat.c:167
 #, fuzzy, c-format
 msgid "Unable to drop table <%s>"
 #: ../lib/vector/Vlib/constraint.c:150
 msgid "Layer constraint ignored for non-native vector formats"
@@ -8264,7 +8264,7 @@
 #: ../lib/vector/Vlib/ascii.c:160
 #, fuzzy, c-format
 msgid "Unparsable longitude value: [%s]"
 #: ../lib/vector/Vlib/ascii.c:165
 #, c-format
@@ -8283,7 +8283,7 @@
 #: ../lib/vector/Vlib/ascii.c:225
 #, fuzzy
 msgid "Unable to copy points"
 #: ../lib/vector/Vlib/ascii.c:238
 #, c-format
@@ -8323,7 +8323,7 @@
 #: ../lib/vector/Vlib/ascii.c:539
 #, fuzzy, c-format
 msgid "Unable to select record from table <%s> (key %s, column %s)"
 #: ../lib/vector/Vlib/ascii.c:661
 #, fuzzy, c-format
@@ -8343,7 +8343,7 @@
 #: ../lib/vector/Vlib/ascii.c:724
 #, fuzzy
 msgid "Unable to fetch data from table"
 #: ../lib/vector/Vlib/ascii.c:756 ../lib/vector/Vlib/net_build.c:216
 #: ../lib/vector/Vlib/net_build.c:501 ../lib/vector/Vlib/net_build.c:519
@@ -8401,7 +8401,7 @@
 #: ../lib/vector/Vlib/array.c:292
 #, fuzzy, c-format
 msgid "Unable to select record from table <%s> (key %s, where %s)"
 #: ../lib/vector/Vlib/close_ogr.c:104 ../lib/vector/Vlib/close_pg.c:139
 #, fuzzy, c-format
@@ -8446,7 +8446,7 @@
 #: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
 #, fuzzy
 msgid "Layer number must be > 0 for category constraints"
 #: ../lib/vector/Vlib/cats.c:585
 #, c-format
@@ -8509,7 +8509,7 @@
 #: ../lib/vector/Vlib/box.c:264
 #, fuzzy, c-format
 msgid "Unable to determine bbox for feature %d"
 #: ../lib/vector/Vlib/box.c:313 ../lib/vector/Vlib/box.c:359
 #, fuzzy, c-format
@@ -8524,7 +8524,7 @@
 #: ../lib/vector/Vlib/box.c:371
 #, fuzzy, c-format
 msgid "Unable to determine bbox for isle %d"
 #: ../lib/vector/Vlib/net_build.c:101 ../lib/vector/Vlib/net_build.c:727
 #, fuzzy
@@ -8689,7 +8689,7 @@
 #: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
 #, fuzzy, c-format
 msgid "Unable to get feature geometry, fid %ld"
 #: ../lib/vector/Vlib/read_ogr.c:390
 msgid "OGR feature without ID"
@@ -8723,7 +8723,7 @@
 #: ../lib/vector/Vlib/level_two.c:316
 #, fuzzy, c-format
 msgid "Nodes not available for line %d"
 #: ../lib/vector/Vlib/level_two.c:357
 #, fuzzy, c-format
@@ -8738,7 +8738,7 @@
 #: ../lib/vector/Vlib/level_two.c:445
 #, fuzzy, c-format
 msgid "Topology info not available for feature %d"
 #: ../lib/vector/Vlib/intersect.c:127
 msgid "3D not supported by Vect_segment_intersection()"
@@ -8760,12 +8760,12 @@
 #: ../lib/vector/Vlib/select.c:116
 #, fuzzy, c-format
 msgid "Unable to delete item %d from spatial index"
 #: ../lib/vector/Vlib/write_sfa.c:117
 #, fuzzy
 msgid "Unable to calculate centroid for area"
 #: ../lib/vector/Vlib/write_sfa.c:219
 #, fuzzy
@@ -8780,22 +8780,22 @@
 #: ../lib/vector/Vlib/bridges.c:213
 #, fuzzy, c-format
 msgid "Removed lines: %d"
 #: ../lib/vector/Vlib/bridges.c:214
 #, fuzzy, c-format
 msgid "Removed bridges: %d"
 #: ../lib/vector/Vlib/build.c:115
 #, fuzzy
 msgid "Area of size = 0.0 (less than 4 vertices) ignored"
-msgstr "Obmoèje velikosti = 0.0 ignorirano"
+msgstr "Območje velikosti = 0.0 ignorirano"
 #: ../lib/vector/Vlib/build.c:131
 #, fuzzy
 msgid "Unable to add area (map closed, topo saved)"
-msgstr "Ne morem dodati obmoèja (sloj zaprt, topo shranjen)"
+msgstr "Ne morem dodati območja (sloj zaprt, topo shranjen)"
 #: ../lib/vector/Vlib/build.c:139
 #, fuzzy
@@ -8804,7 +8804,7 @@
 #: ../lib/vector/Vlib/build.c:149
 msgid "Area of size = 0.0 ignored"
 #: ../lib/vector/Vlib/build.c:200
 msgid "Request to find area outside nonexistent isle"
@@ -8821,27 +8821,27 @@
 #: ../lib/vector/Vlib/build.c:641
 #, fuzzy, c-format
 msgid "Number of lines of length zero: %d"
 #: ../lib/vector/Vlib/build.c:643
 #, fuzzy, c-format
 msgid "Number of boundaries of length zero: %d"
-msgstr "©tevilo meja             :  %d\n"
+msgstr "Število meja             :  %d\n"
 #: ../lib/vector/Vlib/build.c:652
 #, fuzzy, c-format
 msgid "Number of boundary intersections: %d"
 #: ../lib/vector/Vlib/build.c:676
 #, fuzzy
 msgid "Skipping further checks because of incorrect boundaries"
-msgstr "©tevilo nepravilnih meja :  %d\n"
+msgstr "Število nepravilnih meja :  %d\n"
 #: ../lib/vector/Vlib/build.c:726
 #, fuzzy, c-format
 msgid "Number of redundant holes: %d"
 #: ../lib/vector/Vlib/build.c:871
 #, fuzzy, c-format
@@ -8856,92 +8856,92 @@
 #: ../lib/vector/Vlib/build.c:900
 #, fuzzy, c-format
 msgid "Number of nodes: %d"
-msgstr "©tevilo vozlov           :  %d\n"
+msgstr "Število vozlov           :  %d\n"
 #: ../lib/vector/Vlib/build.c:901
 #, fuzzy, c-format
 msgid "Number of primitives: %d"
 #: ../lib/vector/Vlib/build.c:902
 #, fuzzy, c-format
 msgid "Number of points: %d"
-msgstr "©tevilo toèk             :  %d\n"
+msgstr "Število točk             :  %d\n"
 #: ../lib/vector/Vlib/build.c:903
 #, fuzzy, c-format
 msgid "Number of lines: %d"
 #: ../lib/vector/Vlib/build.c:904
 #, fuzzy, c-format
 msgid "Number of boundaries: %d"
 #: ../lib/vector/Vlib/build.c:905
 #, fuzzy, c-format
 msgid "Number of centroids: %d"
-msgstr "©tevilo centroidov       :  %d\n"
+msgstr "Število centroidov       :  %d\n"
 #: ../lib/vector/Vlib/build.c:908
 #, fuzzy, c-format
 msgid "Number of faces: %d"
-msgstr "©tevilo povr¹in          :  %d\n"
+msgstr "Število površin          :  %d\n"
 #: ../lib/vector/Vlib/build.c:911
 #, fuzzy, c-format
 msgid "Number of kernels: %d"
-msgstr "©tevilo jeder            :  %d\n"
+msgstr "Število jeder            :  %d\n"
 #: ../lib/vector/Vlib/build.c:957
 #, fuzzy, c-format
 msgid "Number of areas: %d"
-msgstr "©tevilo obmoèij          :  %d\n"
+msgstr "Število območij          :  %d\n"
 #: ../lib/vector/Vlib/build.c:958
 #, fuzzy, c-format
 msgid "Number of isles: %d"
-msgstr "©tevilo otokov           :  %d\n"
+msgstr "Število otokov           :  %d\n"
 #: ../lib/vector/Vlib/build.c:963
 #, fuzzy, c-format
 msgid "Number of areas without centroid: %d"
 #: ../lib/vector/Vlib/build.c:968
 #, fuzzy, c-format
 msgid "Number of centroids exceeds number of areas: %d > %d"
-msgstr "©tevilo centroidov izven obmoèja:   %d\n"
+msgstr "Število centroidov izven območja:   %d\n"
 #: ../lib/vector/Vlib/build.c:972
 #, fuzzy, c-format
 msgid "Number of incorrect boundaries: %d"
 #: ../lib/vector/Vlib/build.c:976
 #, fuzzy, c-format
 msgid "Number of centroids outside area: %d"
 #: ../lib/vector/Vlib/build.c:980
 #, fuzzy, c-format
 msgid "Number of duplicate centroids: %d"
-msgstr "©tevilo dvojnih centroidov      :   %d\n"
+msgstr "Število dvojnih centroidov      :   %d\n"
 #: ../lib/vector/Vlib/build.c:984
 #, fuzzy
 msgid "Number of areas: -"
-msgstr "©tevilo obmoèij    :   -\n"
+msgstr "Število območij    :   -\n"
 #: ../lib/vector/Vlib/build.c:985
 #, fuzzy
 msgid "Number of isles: -"
-msgstr "©tevilo otokov     :   -\n"
+msgstr "Število otokov     :   -\n"
 #: ../lib/vector/Vlib/build.c:1013
 #, fuzzy, c-format
 msgid "Unable to create topo file for vector map <%s>"
 #: ../lib/vector/Vlib/build.c:1021
 #, fuzzy
@@ -8995,7 +8995,7 @@
 #: ../lib/vector/Vlib/open_pg.c:109 ../lib/vector/Vlib/open_pg.c:267
 #, fuzzy
 msgid "No feature tables found in database."
 #: ../lib/vector/Vlib/open_pg.c:133
 #, fuzzy, c-format
@@ -9009,17 +9009,17 @@
 #: ../lib/vector/Vlib/open_pg.c:273
 #, fuzzy, c-format
 msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
 #: ../lib/vector/Vlib/open_pg.c:276
 #, fuzzy, c-format
 msgid "Unable to delete PostGIS layer <%s>"
 #: ../lib/vector/Vlib/open_pg.c:282
 #, fuzzy, c-format
 msgid "PostGIS layer <%s.%s> already exists in database '%s'"
 #: ../lib/vector/Vlib/open_pg.c:390
 #, fuzzy
@@ -9075,7 +9075,7 @@
 #: ../lib/vector/Vlib/open_pg.c:1003
 #, fuzzy, c-format
 msgid "Area %d without boundary detected"
 #: ../lib/vector/Vlib/open_pg.c:1061
 #, c-format
@@ -9085,14 +9085,14 @@
 #: ../lib/vector/Vlib/open_pg.c:1128
 #, fuzzy
 msgid "Unable to get map bounding box from topology"
 #: ../lib/vector/Vlib/open_pg.c:1135
 #, fuzzy, c-format
 msgid ""
 "Unable to parse map bounding box:\n"
 "%s"
 #: ../lib/vector/Vlib/open_pg.c:1159
 #, c-format
@@ -9328,7 +9328,7 @@
 #: ../lib/vector/diglib/file.c:197
 #, fuzzy
 msgid "Unable to load file to memory, file not open"
 #: ../lib/vector/diglib/file.c:212
 msgid "Vector memory mode not supported, using 'AUTO'"
@@ -9342,12 +9342,12 @@
 #: ../lib/vector/diglib/spindex.c:450
 #, fuzzy, c-format
 msgid "Unable to delete node %d from spatial index"
 #: ../lib/vector/diglib/spindex.c:493
 #, fuzzy, c-format
 msgid "Unable to delete line %d from spatial index"
 #: ../lib/vector/diglib/spindex.c:529
 #, fuzzy
@@ -9357,17 +9357,17 @@
 #: ../lib/vector/diglib/spindex.c:546
 #, fuzzy, c-format
 msgid "Unable to delete area %d from spatial index"
 #: ../lib/vector/diglib/spindex.c:595
 #, fuzzy, c-format
 msgid "Unable to delete isle %d from spatial index"
 #: ../lib/vector/diglib/test.c:58
 #, fuzzy
 msgid "Unable to open test.tmp file"
 #: ../lib/vector/diglib/test.c:75
 #, c-format
@@ -9443,7 +9443,7 @@
 #: ../lib/segment/open.c:87
 #, fuzzy
 msgid "Unable to re-open segment file"
 #: ../lib/segment/open.c:94
 msgid "Could not read segment file"
@@ -9543,7 +9543,7 @@
 #: ../lib/proj/get_proj.c:325
 #, fuzzy, c-format
 msgid "Unable to initialize pj cause: %s"
 #: ../lib/proj/get_proj.c:401
 msgid "Input Projection Parameters"
@@ -9568,12 +9568,12 @@
 #: ../lib/proj/datum.c:278 ../lib/proj/datum.c:358
 #, fuzzy, c-format
 msgid "Unable to open datum table file <%s>"
 #: ../lib/proj/datum.c:291 ../lib/proj/datum.c:372
 #, fuzzy, c-format
 msgid "Error in datum table file <%s>, line %d"
 #: ../lib/rst/interp_float/resout2d.c:77
 msgid "Temporarily changing the region to desired resolution..."
@@ -9673,12 +9673,12 @@
 #: ../lib/rst/interp_float/vinput2d.c:298
 #, fuzzy, c-format
 msgid "Number of points outside of 2D/3D region %d"
 #: ../lib/rst/interp_float/vinput2d.c:300
 #, fuzzy, c-format
 msgid "Number of points being used %d"
 #: ../lib/rst/interp_float/vinput2d.c:333
 msgid "Some points outside of region (ignored)"
@@ -9687,12 +9687,12 @@
 #: ../lib/rst/interp_float/vinput2d.c:339
 #, fuzzy
 msgid "Unable to allocate memory"
 #: ../lib/rst/interp_float/vinput2d.c:347
 #, fuzzy, c-format
 msgid "Unable to insert %f,%f,%f a = %d"
 #: ../lib/rst/interp_float/segmen2d.c:135
 msgid ""
@@ -9741,18 +9741,18 @@
 #: ../lib/pngdriver/read_png.c:60
 #, fuzzy
 msgid "Unable allocate PNG structure"
 #: ../lib/pngdriver/read_png.c:64 ../lib/pngdriver/write_png.c:71
 #: ../lib/pngdriver/write_png.c:75
 #, fuzzy
 msgid "Unable to allocate PNG structure"
 #: ../lib/pngdriver/read_png.c:67
 #, fuzzy
 msgid "Unable to read PNG file"
 #: ../lib/pngdriver/read_png.c:81
 msgid "Input PNG file is not 8-bit"
@@ -9783,12 +9783,12 @@
 #: ../lib/pngdriver/write_png.c:78
 #, fuzzy
 msgid "Unable to write PNG file"
 #: ../lib/pngdriver/write_png.c:82
 #, fuzzy, c-format
 msgid "Unable to open output PNG file <%s>"
 #: ../lib/pngdriver/graph_set.c:101
 #, c-format
@@ -9821,7 +9821,7 @@
 #~ msgid ""
 #~ "Unable to check table. There is no temporal database connection defined "
 #~ "for mapset <%(mapset)s>"
-#~ msgstr "Nezmo¾en odpreti datoteko s tabelo fundamentalne toèke: %s"
+#~ msgstr "Nezmožen odpreti datoteko s tabelo fundamentalne točke: %s"
 #, fuzzy
 #~ msgid ""
@@ -9837,7 +9837,7 @@
 #, fuzzy
 #~ msgid "Unable to find a temporary null file <%s>"
 #, fuzzy
 #~ msgid "Unable to open null file <%s>"
@@ -9845,11 +9845,11 @@
 #, fuzzy
 #~ msgid "ERROR: <%s> is not a valid GRASS location"
-#~ msgstr "Oprostite <%s> ni veljavna mo¾nost\n"
+#~ msgstr "Oprostite <%s> ni veljavna možnost\n"
 #, fuzzy
 #~ msgid "ERROR: option <%s>: <%s> exists.\n"
-#~ msgstr "Napaka: mo¾nost <%s>: <%s> obstaja.\n"
+#~ msgstr "Napaka: možnost <%s>: <%s> obstaja.\n"
 #, fuzzy
 #~ msgid "Invalid offset (%d)"
@@ -9857,7 +9857,7 @@
 #, fuzzy
 #~ msgid "Unable to open file '%s'"
-#~ msgstr "Nezmo¾en odpreti datoteko %s v %s"
+#~ msgstr "Nezmožen odpreti datoteko %s v %s"
 #, fuzzy
 #~ msgid "Hit RETURN to continue"
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2017-04-22 13:47:15 UTC (rev 70918)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2017-04-22 14:06:08 UTC (rev 70919)
@@ -1,11 +1,11 @@
-# translation of grassmods_pt_br.po to Brasilian Português
+# translation of grassmods_pt_br.po to Brasilian Português
 # translation of grassmods_pt_br.po to Brasilian Portuguese
 # This file is distributed under the same license as the GRASS package.
 # Copyright (C) 2004-2011 GRASS Development Team
 # Paulo Eduardo Pasquini Marcondes <paulomarcondes at gmail.com>, 2005, 2006.
 # Daniel de Castro Victoria <daniel.victoria at gmail.com>, 2006.
 # Ricardo Oliveira <ricardoabeloliveira at gmail.com>, 2007.
-# Fred Maranhão <fred.maranhao at gmail.com>, 2011.
+# Fred Maranhão <fred.maranhao at gmail.com>, 2011.
 msgid ""
 msgstr ""
@@ -13,11 +13,11 @@
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2016-11-14 14:55+0100\n"
 "PO-Revision-Date: 2011-08-03 03:03-0300\n"
-"Last-Translator: Fred Ulisses Maranhão <fred.maranhao at gmail.com>\n"
+"Last-Translator: Fred Ulisses Maranhão <fred.maranhao at gmail.com>\n"
 "Language-Team: Brasilian Portuguese <grass-translations at lists.osgeo.org>\n"
 "Language: pt\n"
 "MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=ISO-8859-1\n"
+"Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "X-Generator: KBabel 1.10.2\n"
 "Plural-Forms: nplurals=2; plural=(n > 1);\n"
@@ -25,12 +25,12 @@
 #: ../raster3d/r3.out.netcdf/main.c:81
 #, fuzzy, c-format
 msgid "Unable to close 3D raster map while catching error: %s"
-msgstr "Não consegui abrir mapa raster [%s]."
+msgstr "Não consegui abrir mapa raster [%s]."
 #: ../raster3d/r3.out.netcdf/main.c:97
 #, fuzzy
 msgid "Name for netCDF output file"
-msgstr "Nome do arquivo de saída"
+msgstr "Nome do arquivo de saída"
 #: ../raster3d/r3.out.netcdf/main.c:106
 msgid "The value to be used for null values, default is the netCDF standard"
@@ -46,7 +46,7 @@
 #: ../raster/r.to.rast3elev/main.c:194
 #, fuzzy
 msgid "Use 3D raster mask (if exists) with input map"
-msgstr "Usa máscara G3D (se existir) com o mapa de entrada"
+msgstr "Usa máscara G3D (se existir) com o mapa de entrada"
 #: ../raster3d/r3.out.netcdf/main.c:586 ../raster3d/r3.timestamp/main.c:43
 #: ../raster3d/r3.out.v5d/main.c:284 ../raster3d/r3.retile/main.c:96
@@ -149,7 +149,7 @@
 #: ../vector/v.colors/main.c:319
 #, c-format
 msgid "3D raster map <%s> not found"
-msgstr "Mapa raster 3D <%s> não encontrado"
+msgstr "Mapa raster 3D <%s> não encontrado"
 #: ../raster3d/r3.out.netcdf/main.c:617 ../raster3d/r3.out.v5d/main.c:312
 #: ../raster3d/r3.retile/main.c:127 ../raster3d/r3.stats/main.c:103
@@ -167,7 +167,7 @@
 #: ../raster/r.univar/r3.univar_main.c:189
 #, fuzzy, c-format
 msgid "Unable to open 3D raster map <%s>"
-msgstr "Não consegui abrir mapa raster <%s>"
+msgstr "Não consegui abrir mapa raster <%s>"
 #: ../raster3d/r3.out.netcdf/main.c:649 ../raster3d/r3.out.v5d/main.c:55
 #: ../raster3d/r3.out.v5d/main.c:326 ../raster3d/r3.to.rast/main.c:75
@@ -178,7 +178,7 @@
 #: ../raster3d/r3.out.vtk/main.c:252 ../raster3d/r3.out.vtk/main.c:338
 #, fuzzy
 msgid "Unable to close 3D raster map"
-msgstr "Não consegui fechar arquivo de saída."
+msgstr "Não consegui fechar arquivo de saída."
 #: ../raster3d/r3.timestamp/main.c:44 ../raster3d/r3.info/main.c:76
 #: ../raster3d/r3.support/main.c:50 ../raster/r.support/main.c:55
@@ -191,13 +191,13 @@
 #: ../vector/v.timestamp/main.c:36 ../vector/v.support/main.c:40
 #, fuzzy
 msgid "metadata"
-msgstr "Inportação de vetor incompleta"
+msgstr "Inportação de vetor incompleta"
 #: ../raster3d/r3.timestamp/main.c:45 ../raster/r.timestamp/main.c:37
 #: ../vector/v.timestamp/main.c:37
 #, fuzzy
 msgid "timestamp"
-msgstr "Fonte inválida: %s"
+msgstr "Fonte inválida: %s"
 #: ../raster3d/r3.timestamp/main.c:46 ../raster/r.timestamp/main.c:38
 #: ../locale/scriptstrings/t.support_to_translate.c:4
@@ -252,7 +252,7 @@
 #: ../vector/v.timestamp/main.c:38
 #, fuzzy
 msgid "time"
 #: ../raster3d/r3.timestamp/main.c:48
 #, fuzzy
@@ -281,27 +281,27 @@
 #: ../raster3d/r3.out.v5d/main.c:77
 #, fuzzy
 msgid "Name for V5D output file"
-msgstr "Nome do arquivo v5d de saída"
+msgstr "Nome do arquivo v5d de saída"
 #: ../raster3d/r3.out.v5d/main.c:147
 #, fuzzy, c-format
 msgid "Vis5D allows %d columns, %d columns found"
-msgstr "Viz5D permite %d colunas, você tem %d colunas"
+msgstr "Viz5D permite %d colunas, você tem %d colunas"
 #: ../raster3d/r3.out.v5d/main.c:150
 #, fuzzy, c-format
 msgid "Vis5D allows %d rows, %d rows found"
-msgstr "Viz5D permite %d linhas, você tem %d linhas"
+msgstr "Viz5D permite %d linhas, você tem %d linhas"
 #: ../raster3d/r3.out.v5d/main.c:257
 #, fuzzy, c-format
 msgid "Unable to create V5D file <%s>"
-msgstr "Não consegui criar arquivo <%s>"
+msgstr "Não consegui criar arquivo <%s>"
 #: ../raster3d/r3.out.v5d/main.c:262
 #, fuzzy
 msgid "Failed writing V5D file"
-msgstr "Não consegui abrir arquivo de saída."
+msgstr "Não consegui abrir arquivo de saída."
 #: ../raster3d/r3.out.v5d/main.c:288
 #, fuzzy
@@ -310,12 +310,12 @@
 #: ../raster3d/r3.out.v5d/main.c:295
 msgid "Use map coordinates instead of xyz coordinates"
-msgstr "Usar coordenadas do mapa ao invés de xyz"
+msgstr "Usar coordenadas do mapa ao invés de xyz"
 #: ../raster3d/r3.retile/main.c:49
 #, fuzzy
 msgid "Unable to close the 3D raster map"
-msgstr "Não consegui fechar mapa raster 3d"
+msgstr "Não consegui fechar mapa raster 3d"
 #: ../raster3d/r3.retile/main.c:71
 #, fuzzy
@@ -326,7 +326,7 @@
 #: ../locale/scriptstrings/r.tileset_to_translate.c:3
 #, fuzzy
 msgid "tiling"
-msgstr "Estatísticas de transição de classe."
+msgstr "Estatísticas de transição de classe."
 #: ../raster3d/r3.retile/main.c:99
 msgid ""
@@ -374,17 +374,17 @@
 #: ../vector/v.univar/main.c:93 ../vector/v.outlier/main.c:70
 #, fuzzy
 msgid "statistics"
 #: ../raster3d/r3.stats/main.c:51
 #, fuzzy
 msgid "Generates volume statistics for 3D raster maps."
-msgstr "Gera estatísticas de volume para os mapas raster 3d."
+msgstr "Gera estatísticas de volume para os mapas raster 3d."
 #: ../raster3d/r3.stats/main.c:62
 #, fuzzy
 msgid "Number of subranges to collect stats from"
-msgstr "Número de sub-intervalos para coletar estatísticas"
+msgstr "Número de sub-intervalos para coletar estatísticas"
 #: ../raster3d/r3.stats/main.c:67
 msgid "Calculate statistics based on equal value groups"
@@ -393,7 +393,7 @@
 #: ../raster3d/r3.stats/main.c:71
 #, fuzzy
 msgid "Only print cell counts"
-msgstr "Mostra contagem de células"
+msgstr "Mostra contagem de células"
 #: ../raster3d/r3.stats/main.c:91
 msgid "The number of subranges has to be equal or greater than 1"
@@ -401,7 +401,7 @@
 #: ../raster3d/r3.stats/main.c:150
 msgid "Sort non-null values"
-msgstr "Ordenar valores não-nulo"
+msgstr "Ordenar valores não-nulo"
 #: ../raster3d/r3.to.rast/main.c:100
 #, fuzzy
@@ -415,7 +415,7 @@
 #: ../raster3d/r3.to.rast/main.c:116
 #, fuzzy
 msgid "Value to multiply the raster values with"
-msgstr "Relatório de estatísticas para mapas raster."
+msgstr "Relatório de estatísticas para mapas raster."
 #: ../raster3d/r3.to.rast/main.c:117
 msgid "Coefficient a in the equation y = ax + b"
@@ -424,7 +424,7 @@
 #: ../raster3d/r3.to.rast/main.c:123
 #, fuzzy
 msgid "Value to add to the raster values"
 #: ../raster3d/r3.to.rast/main.c:124
 msgid "Coefficient b in the equation y = ax + b"
@@ -436,8 +436,8 @@
 "Use the same resolution as the input 3D raster map for the 2D output maps, "
 "independent of the current region settings"
 msgstr ""
-"Use a mesma resolução do mapa RASTER3D de entrada para os mapas 2d de saída, "
-"independente das cofigurações da região atual"
+"Use a mesma resolução do mapa RASTER3D de entrada para os mapas 2d de saída, "
+"independente das cofigurações da região atual"
 #: ../raster3d/r3.to.rast/main.c:174
 #, fuzzy, c-format
@@ -456,7 +456,7 @@
 #: ../vector/v.to.rast3/main.c:49 ../vector/v.to.rast/main.c:45
 #, fuzzy
 msgid "conversion"
-msgstr "Erro na conversão de texto"
+msgstr "Erro na conversão de texto"
 #: ../raster3d/r3.to.rast/main.c:261 ../raster3d/r3.cross.rast/main.c:230
 #: ../visualization/ximgview/main.c:292 ../doc/raster/r.example/main.c:83
@@ -598,8 +598,8 @@
 "The 2D and 3D region settings are different. Using the 2D window settings to "
 "adjust the 2D part of the 3D region."
 msgstr ""
-"As configurações das regiões 2d e 3d são diferentes. Usando as configurações "
-"de janela 2D para ajustar a parte 2D da região 3D."
+"As configurações das regiões 2d e 3d são diferentes. Usando as configurações "
+"de janela 2D para ajustar a parte 2D da região 3D."
 #: ../raster3d/r3.to.rast/main.c:360 ../imagery/i.smap/multialloc.c:115
 #: ../db/drivers/postgres/listtab.c:92 ../db/drivers/postgres/listdb.c:88
@@ -634,7 +634,7 @@
 #: ../vector/v.vol.rst/user1.c:423 ../vector/v.net.connectivity/main.c:186
 #: ../vector/v.net.connectivity/main.c:202
 msgid "Out of memory"
-msgstr "Memória Esgotada! (Out of Memory)"
+msgstr "Memória Esgotada! (Out of Memory)"
 #: ../raster3d/r3.to.rast/main.c:362
 #, c-format
@@ -650,7 +650,7 @@
 #, fuzzy, c-format
 msgid ""
 "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
-msgstr "Nome de arquivo %d de mapa raster: %s já existe. Será sobreescrito!"
+msgstr "Nome de arquivo %d de mapa raster: %s já existe. Será sobreescrito!"
 #: ../raster3d/r3.in.bin/main.c:73
 #, fuzzy
@@ -703,7 +703,7 @@
 #: ../raster3d/r3.in.bin/main.c:256
 #, fuzzy
 msgid "Imports a binary raster file into a GRASS 3D raster map."
-msgstr "Importar um arquivo raster binário para uma camada raster do GRASS."
+msgstr "Importar um arquivo raster binário para uma camada raster do GRASS."
 #: ../raster3d/r3.in.bin/main.c:259
 #, fuzzy
@@ -713,7 +713,7 @@
 #: ../raster3d/r3.in.bin/main.c:268 ../raster3d/r3.out.bin/main.c:228
 #, fuzzy
 msgid "Number of bytes per cell in binary file"
-msgstr "Número de bytes por célula"
+msgstr "Número de bytes por célula"
 #: ../raster3d/r3.in.bin/main.c:275
 msgid "Byte order in binary file"
@@ -721,7 +721,7 @@
 #: ../raster3d/r3.in.bin/main.c:283 ../raster/r.in.bin/main.c:338
 msgid "Northern limit of geographic region (outer edge)"
-msgstr "Limite Norte da região geográfica (limite externo)"
+msgstr "Limite Norte da região geográfica (limite externo)"
 #: ../raster3d/r3.in.bin/main.c:284 ../raster3d/r3.in.bin/main.c:292
 #: ../raster3d/r3.in.bin/main.c:300 ../raster3d/r3.in.bin/main.c:308
@@ -743,38 +743,38 @@
 #: ../raster3d/r3.in.bin/main.c:291 ../raster/r.in.bin/main.c:346
 msgid "Southern limit of geographic region (outer edge)"
-msgstr "Limite Sul da região geográfica (limite externo)"
+msgstr "Limite Sul da região geográfica (limite externo)"
 #: ../raster3d/r3.in.bin/main.c:299 ../raster/r.in.bin/main.c:354
 msgid "Eastern limit of geographic region (outer edge)"
-msgstr "Limite Leste da região geográfica (limite externo)"
+msgstr "Limite Leste da região geográfica (limite externo)"
 #: ../raster3d/r3.in.bin/main.c:307 ../raster/r.in.bin/main.c:362
 msgid "Western limit of geographic region (outer edge)"
-msgstr "Limite Oeste da região geográfica (limite externo)"
+msgstr "Limite Oeste da região geográfica (limite externo)"
 #: ../raster3d/r3.in.bin/main.c:315
 #, fuzzy
 msgid "Bottom limit of geographic region (outer edge)"
 #: ../raster3d/r3.in.bin/main.c:322
 #, fuzzy
 msgid "Top limit of geographic region (outer edge)"
 #: ../raster3d/r3.in.bin/main.c:329 ../raster/r.in.bin/main.c:369
 msgid "Number of rows"
-msgstr "Número de linhas"
+msgstr "Número de linhas"
 #: ../raster3d/r3.in.bin/main.c:336 ../raster/r.in.bin/main.c:376
 msgid "Number of columns"
-msgstr "Número de colunas"
+msgstr "Número de colunas"
 #: ../raster3d/r3.in.bin/main.c:343
 #, fuzzy
 msgid "Number of depths"
 #: ../raster3d/r3.in.bin/main.c:350 ../raster/r.in.bin/main.c:383
 msgid "Set Value to NULL"
@@ -837,7 +837,7 @@
 #: ../raster3d/r3.in.bin/main.c:438 ../raster/r.in.bin/main.c:533
 #, c-format
 msgid "Unable to open <%s>"
-msgstr "Não consegui abrir <%s>"
+msgstr "Não consegui abrir <%s>"
 #: ../raster3d/r3.in.bin/main.c:446
 #, c-format
@@ -852,7 +852,7 @@
 #: ../raster3d/r3.in.v5d/main.c:201
 #, fuzzy
 msgid "Unable to open 3D raster map"
 #: ../raster3d/r3.gwflow/main.c:54
 #, fuzzy
@@ -864,7 +864,7 @@
 msgid ""
 "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
 "active, 2 - dirichlet"
-msgstr "Estados da condição de fronteira, 0-inativo, 1-ativo, 2-dirichlet"
+msgstr "Estados da condição de fronteira, 0-inativo, 1-ativo, 2-dirichlet"
 #: ../raster3d/r3.gwflow/main.c:65
 #, fuzzy
@@ -890,7 +890,7 @@
 #: ../raster3d/r3.gwflow/main.c:80
 #, fuzzy
 msgid "Input 3D raster map with sources and sinks in [m^3/s]"
-msgstr "Mapa(s) de entrada não especificado(s)."
+msgstr "Mapa(s) de entrada não especificado(s)."
 #: ../raster3d/r3.gwflow/main.c:84
 #, fuzzy
@@ -907,39 +907,39 @@
 msgid ""
 "Output 3D raster map storing the piezometric head result of the numerical "
 "calculation"
-msgstr "Título do raster de saída"
+msgstr "Título do raster de saída"
 #: ../raster3d/r3.gwflow/main.c:99
 #, fuzzy
 msgid ""
 "Output 3D raster map storing the groundwater filter velocity vector part in "
 "x direction [m/s]"
 #: ../raster3d/r3.gwflow/main.c:105
 #, fuzzy
 msgid ""
 "y direction [m/s]"
 #: ../raster3d/r3.gwflow/main.c:111
 #, fuzzy
 msgid ""
 "z direction [m/s]"
 #: ../raster3d/r3.gwflow/main.c:117
 #, fuzzy
 msgid ""
 "Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
 #: ../raster3d/r3.gwflow/main.c:127
 #, fuzzy
 msgid "Use 3D raster mask (if exists)"
 #: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
 msgid ""
@@ -979,7 +979,7 @@
 #: ../raster3d/r3.gwflow/main.c:279 ../raster/r.gwflow/main.c:546
 msgid "Unable to create and solve the linear equation system"
-msgstr "Não consegui criar e resolver o sistema de equações lineares"
+msgstr "Não consegui criar e resolver o sistema de equações lineares"
 #: ../raster3d/r3.gwflow/main.c:365 ../raster3d/r3.in.lidar/main.c:484
 #: ../raster3d/r3.in.lidar/main.c:493 ../raster3d/r3.in.lidar/main.c:501
@@ -987,7 +987,7 @@
 #: ../raster3d/r3.in.lidar/main.c:527 ../raster3d/r3.in.lidar/main.c:536
 #, fuzzy, c-format
 msgid "Unable to create 3D raster map <%s>"
-msgstr "Não consegui criar mapa raster <%s>"
+msgstr "Não consegui criar mapa raster <%s>"
 #: ../raster3d/r3.out.ascii/main.c:82
 #, fuzzy
@@ -996,15 +996,15 @@
 #: ../raster3d/r3.out.ascii/main.c:86
 msgid "Name for ASCII output file"
-msgstr "Nome do arquivo ASCII de saída"
+msgstr "Nome do arquivo ASCII de saída"
 #: ../raster3d/r3.out.ascii/main.c:95
 msgid "Number of decimal places for floats"
-msgstr "Número de casas decimais para números de ponto flutuante"
+msgstr "Número de casas decimais para números de ponto flutuante"
 #: ../raster3d/r3.out.ascii/main.c:102 ../raster/r.out.ascii/main.c:95
 msgid "Suppress printing of header information"
-msgstr "Suprimir impressão de cabeçalho"
+msgstr "Suprimir impressão de cabeçalho"
 #: ../raster3d/r3.out.ascii/main.c:114
 msgid "Print grass6 compatible format. Flags -d and -r are ignored."
@@ -1018,7 +1018,7 @@
 #: ../raster3d/r3.out.ascii/main.c:371
 #, fuzzy
 msgid "Unable to close new ASCII file"
-msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
+msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
 #: ../raster3d/r3.out.bin/main.c:113 ../raster/r.out.bin/main.c:53
 #: ../raster/r.out.bin/main.c:62 ../raster/r.out.bin/main.c:470
@@ -1030,7 +1030,7 @@
 #: ../raster3d/r3.out.bin/main.c:208
 #, fuzzy
 msgid "Exports a GRASS 3D raster map to a binary array."
-msgstr "Exporta um raster do GRASS para um arquivo binário"
+msgstr "Exporta um raster do GRASS para um arquivo binário"
 #: ../raster3d/r3.out.bin/main.c:221 ../raster/r.out.bin/main.c:304
 msgid "Value to write out for null"
@@ -1039,7 +1039,7 @@
 #: ../raster3d/r3.out.bin/main.c:235 ../raster/r.in.bin/main.c:330
 #: ../raster/r.out.bin/main.c:318
 msgid "Output byte order"
-msgstr "Ordem de bytes de saída"
+msgstr "Ordem de bytes de saída"
 #: ../raster3d/r3.out.bin/main.c:250
 #, fuzzy
@@ -1048,7 +1048,7 @@
 #: ../raster3d/r3.out.bin/main.c:256 ../raster/r.out.bin/main.c:347
 msgid "Invalid value for null (integers only)"
-msgstr "Valor inválido para null (apenas inteiros)"
+msgstr "Valor inválido para null (apenas inteiros)"
 #: ../raster3d/r3.out.bin/main.c:269
 msgid "Floating-point output requires bytes=4 or bytes=8"
@@ -1063,11 +1063,11 @@
 #: ../display/d.mon/start.c:181 ../display/d.mon/start.c:224
 #, c-format
 msgid "Unable to create file <%s>"
 #: ../raster3d/r3.out.bin/main.c:323 ../raster/r.out.bin/main.c:454
 msgid "Using the current region settings..."
-msgstr "Usando as configurações da região atual..."
+msgstr "Usando as configurações da região atual..."
 #: ../raster3d/r3.out.bin/main.c:324 ../raster/r.out.bin/main.c:455
 #, c-format
@@ -1120,32 +1120,32 @@
 #: ../locale/scriptstrings/t.info_to_translate.c:4 ../vector/v.info/main.c:40
 #, fuzzy
 msgid "extent"
-msgstr "Codificação de caractere"
+msgstr "Codificação de caractere"
 #: ../raster3d/r3.info/main.c:80
 msgid "Outputs basic information about a user-specified 3D raster map layer."
 msgstr ""
-"Imprime informações básicas sobre uma camada de mapa 3D especificada pelo "
-"usuário."
+"Imprime informações básicas sobre uma camada de mapa 3D especificada pelo "
+"usuário."
 #: ../raster3d/r3.info/main.c:86
 #, fuzzy
 msgid "Print raster3d information in shell style"
-msgstr "Mostra as estatísticas em estilo shell script"
+msgstr "Mostra as estatísticas em estilo shell script"
 #: ../raster3d/r3.info/main.c:90
 #, fuzzy
 msgid "Print range in shell style only"
 #: ../raster3d/r3.info/main.c:94 ../raster/r.info/main.c:93
 msgid "Print raster history instead of info"
-msgstr "Imprime histórico do raster ao invés de informações"
+msgstr "Imprime histórico do raster ao invés de informações"
 #: ../raster3d/r3.info/main.c:103
 #, fuzzy, c-format
 msgid "3D Raster map <%s> not found"
 #: ../raster3d/r3.info/main.c:138 ../raster3d/r3.info/main.c:145
 #: ../raster3d/r3.info/main.c:151 ../raster3d/r3.info/main.c:156
@@ -1164,24 +1164,24 @@
 #: ../raster3d/r3.info/main.c:369 ../raster3d/r3.info/main.c:382
 #: ../raster/r.info/main.c:303 ../raster/r.info/main.c:445
 msgid "Cannot allocate memory for string"
-msgstr "Não consegui alocar memória para 'string'"
+msgstr "Não consegui alocar memória para 'string'"
 #: ../raster3d/r3.info/main.c:328 ../raster3d/r3.info/main.c:448
 #: ../raster3d/r3.mkdspf/main.c:171
 #, fuzzy, c-format
 msgid "Unable to read range of 3D raster map <%s>"
-msgstr "Não consegui escrever em <%s>"
+msgstr "Não consegui escrever em <%s>"
 #: ../raster3d/r3.info/main.c:492
 msgid "Error while reading history file"
-msgstr "Erro na leitura do arquivo de histórico"
+msgstr "Erro na leitura do arquivo de histórico"
 #: ../raster3d/r3.info/main.c:499 ../raster3d/r3.null/main.c:169
 #: ../raster3d/r3.cross.rast/main.c:343
 #: ../raster3d/r3.out.vtk/errorHandling.c:65
 #, fuzzy, c-format
 msgid "Unable to close 3D raster map <%s>"
 #: ../raster3d/r3.in.ascii/main.c:86 ../raster/r.in.ascii/main.c:78
 #: ../vector/v.in.ascii/main.c:78
@@ -1199,18 +1199,18 @@
 #, fuzzy
 msgid "'-' for standard input"
 msgstr ""
-"Arquivo ASCII para converter para vetor binário, se não for dado, lê da "
-"entrada padrão"
+"Arquivo ASCII para converter para vetor binário, se não for dado, lê da "
+"entrada padrão"
 #: ../raster3d/r3.in.ascii/main.c:94
 msgid "String representing NULL value data cell (use 'none' if no such value)"
 msgstr ""
-"Texto para representar célula sem valor de dados (use 'none' se não houver)"
+"Texto para representar célula sem valor de dados (use 'none' se não houver)"
 #: ../raster3d/r3.in.ascii/main.c:130 ../raster/r.in.ascii/main.c:275
 #, fuzzy
 msgid "Unable to write to file"
-msgstr "Não consegui escrever o arquivo temporário."
+msgstr "Não consegui escrever o arquivo temporário."
 #: ../raster3d/r3.in.ascii/main.c:169 ../raster/r.resamp.rst/main.c:542
 #: ../raster/r.in.ascii/main.c:120 ../raster/r.in.ascii/main.c:150
@@ -1220,12 +1220,12 @@
 #: ../vector/v.in.ascii/main.c:273
 #, fuzzy, c-format
 msgid "Unable to open temporary file <%s>"
-msgstr "Não consegui abrir o arquivo temporário."
+msgstr "Não consegui abrir o arquivo temporário."
 #: ../raster3d/r3.in.ascii/main.c:172 ../raster/r.in.ascii/main.c:153
 #, fuzzy
 msgid "Unable to read input from stdin"
-msgstr "Não consegui ler linha %i\n"
+msgstr "Não consegui ler linha %i\n"
 #: ../raster3d/r3.in.ascii/main.c:221
 #, fuzzy, c-format
@@ -1251,33 +1251,33 @@
 msgid ""
 "Data exists in input file after fully importing expected data.  [%.4f ...]"
 msgstr ""
-"Ainda há dados no arquivo de entrada depois de uma importação completa dos "
+"Ainda há dados no arquivo de entrada depois de uma importação completa dos "
 "dados esperados.  [%.4f ...]"
 #: ../raster3d/r3.in.ascii/main.c:360
 #, fuzzy
 msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
-msgstr "Converte um arquivo raster ASCII 3D para um mapa raster 3D binário."
+msgstr "Converte um arquivo raster ASCII 3D para um mapa raster 3D binário."
 #: ../raster3d/r3.in.ascii/main.c:403
 #, fuzzy
 msgid "Unable to close ASCII file"
 #: ../raster3d/r3.support/main.c:52
 #, fuzzy
 msgid ""
 "Allows creation and/or modification of 3D raster map layer support files."
 msgstr ""
-"Permite a criação e/ou modificação dos arquivos de suporte dos mapas raster"
+"Permite a criação e/ou modificação dos arquivos de suporte dos mapas raster"
 #: ../raster3d/r3.support/main.c:62
 msgid "Text to use for map title"
-msgstr "Texto para o título do mapa"
+msgstr "Texto para o título do mapa"
 #: ../raster3d/r3.support/main.c:70 ../raster/r.support/main.c:74
 msgid "Text to append to the next line of the map's metadata file"
-msgstr "Texto para colocar na próxima linha do arquivo de metadados do mapa"
+msgstr "Texto para colocar na próxima linha do arquivo de metadados do mapa"
 #: ../raster3d/r3.support/main.c:76
 #, fuzzy
@@ -1316,7 +1316,7 @@
 #: ../raster3d/r3.support/main.c:125
 #, fuzzy
 msgid "Update range"
-msgstr "Intervalo dos dados de saída"
+msgstr "Intervalo dos dados de saída"
 #: ../raster3d/r3.support/main.c:153 ../raster/r.support/main.c:162
 #: ../raster/r.out.png/main.c:205 ../raster/r.out.pov/main.c:173
@@ -1325,7 +1325,7 @@
 #: ../general/g.cairocomp/main.c:66 ../vector/v.colors.out/main.c:103
 #, c-format
 msgid "Unable to open output file <%s>"
-msgstr "Não consegui abrir arquivo de saída <%s>"
+msgstr "Não consegui abrir arquivo de saída <%s>"
 #: ../raster3d/r3.support/main.c:167 ../raster/r.support/main.c:176
 #: ../raster/r.in.mat/main.c:125 ../raster/r.series.accumulate/main.c:221
@@ -1340,7 +1340,7 @@
 #: ../vector/v.segment/main.c:98 ../vector/v.net.path/path.c:49
 #, fuzzy, c-format
 msgid "Unable to open input file <%s>"
 #: ../raster3d/r3.support/main.c:248 ../raster/r.support/main.c:245
 #: ../raster/r.statistics/main.c:110 ../display/d.title/main.c:110
@@ -1358,13 +1358,13 @@
 msgid "Updating statistics for <%s>"
 msgstr ""
 "\n"
-" Atualizando estatísticas para [%s]"
+" Atualizando estatísticas para [%s]"
 #: ../raster3d/r3.support/check.c:36
 #, fuzzy, c-format
 msgid "Updating the number of categories for <%s>"
 msgstr ""
-"   Atualizando número de categorias de [%s]\n"
+"   Atualizando número de categorias de [%s]\n"
 "\n"
 #: ../raster3d/r3.null/main.c:55
@@ -1374,7 +1374,7 @@
 #: ../raster3d/r3.null/main.c:63 ../raster/r.null/main.c:73
 msgid "List of cell values to be set to NULL"
-msgstr "Lista de valores de célula para marcar como NULO"
+msgstr "Lista de valores de célula para marcar como NULO"
 #: ../raster3d/r3.null/main.c:70 ../raster/r.null/main.c:81
 msgid "The value to replace the null value by"
@@ -1404,7 +1404,7 @@
 #: ../raster3d/r3.null/main.c:187 ../raster/r.null/main.c:61
 #, fuzzy
 msgid "null data"
 #: ../raster3d/r3.null/main.c:190
 msgid "Explicitly create the 3D NULL-value bitmap file."
@@ -1414,12 +1414,12 @@
 #: ../raster/r.in.lidar/string_list.c:34
 #, fuzzy, c-format
 msgid "Cannot open file %s for reading"
-msgstr "Não consegui abrir o arquivo de células [%s]"
+msgstr "Não consegui abrir o arquivo de células [%s]"
 #: ../raster3d/r3.in.lidar/filters.c:27
 #, fuzzy, c-format
 msgid "Invalid range <%s> for option %s"
 #: ../raster3d/r3.in.lidar/filters.c:54 ../vector/v.in.pdal/filters.c:95
 #: ../vector/v.in.lidar/filters.c:36
@@ -1450,7 +1450,7 @@
 #: ../vector/v.neighbors/main.c:54
 #, fuzzy
 msgid "aggregation"
-msgstr "Correlação"
+msgstr "Correlação"
 #: ../raster3d/r3.in.lidar/main.c:168 ../raster/r.in.lidar/main.c:114
 #: ../raster/r.in.xyz/main.c:163
@@ -1464,7 +1464,7 @@
 msgid ""
 "Creates a 3D raster map from LAS LiDAR points using univariate statistics."
 msgstr ""
-"Cria mapas raster a partir de arquivos de dados de polígono/linha/ponto."
+"Cria mapas raster a partir de arquivos de dados de polígono/linha/ponto."
 #: ../raster3d/r3.in.lidar/main.c:174 ../raster/r.in.lidar/main.c:120
 #: ../vector/v.in.lidar/main.c:142
@@ -1537,7 +1537,7 @@
 #: ../raster3d/r3.in.lidar/main.c:181 ../raster/r.in.lidar/main.c:130
 #, fuzzy
 msgid "File containing names of LAS input files"
-msgstr "Arquivo contendo declarações SQL"
+msgstr "Arquivo contendo declarações SQL"
 #: ../raster3d/r3.in.lidar/main.c:182 ../raster/r.in.lidar/main.c:121
 #: ../raster/r.in.lidar/main.c:131 ../vector/v.in.lidar/main.c:143
@@ -1607,12 +1607,12 @@
 #: ../vector/v.out.ascii/args.c:81
 #, fuzzy
 msgid "Output"
-msgstr "Saída de mapa"
+msgstr "Saída de mapa"
 #: ../raster3d/r3.in.lidar/main.c:195
 #, fuzzy
 msgid "Sum of values of point intensities per cell"
-msgstr "Número de pontos de interpolação"
+msgstr "Número de pontos de interpolação"
 #: ../raster3d/r3.in.lidar/main.c:201
 msgid "Mean of point intensities per cell"
@@ -1621,7 +1621,7 @@
 #: ../raster3d/r3.in.lidar/main.c:209
 #, fuzzy
 msgid "3D raster map of proportional point count"
 #: ../raster3d/r3.in.lidar/main.c:211
 msgid "Point count per 3D cell divided by point count per vertical column"
@@ -1650,7 +1650,7 @@
 #: ../vector/v.in.lidar/main.c:202
 #, fuzzy
 msgid "If not specified, all points are imported"
-msgstr "valores inteiros são importados"
+msgstr "valores inteiros são importados"
 #: ../raster3d/r3.in.lidar/main.c:232 ../raster3d/r3.in.lidar/main.c:242
 #: ../raster3d/r3.in.lidar/main.c:272 ../raster3d/r3.in.lidar/main.c:288
@@ -1730,7 +1730,7 @@
 #: ../vector/v.extrude/main.c:90 ../vector/v.extrude/main.c:95
 #, fuzzy
 msgid "Selection"
-msgstr "Resolução"
+msgstr "Resolução"
 #: ../raster3d/r3.in.lidar/main.c:239 ../raster/r.in.lidar/main.c:268
 #: ../vector/v.in.lidar/main.c:211
@@ -1742,7 +1742,7 @@
 #, fuzzy
 msgid ""
 "Input is comma separated integers. If not specified, all points are imported."
 #: ../raster3d/r3.in.lidar/main.c:248
 #, fuzzy
@@ -1758,7 +1758,7 @@
 #: ../raster/r.in.lidar/main.c:200 ../raster/r.in.lidar/main.c:216
 #, fuzzy
 msgid "Transform"
 #: ../raster3d/r3.in.lidar/main.c:256
 msgid "Use base raster actual resolution instead of computational region"
@@ -1767,7 +1767,7 @@
 #: ../raster3d/r3.in.lidar/main.c:263 ../raster/r.in.lidar/main.c:199
 #, fuzzy
 msgid "Scale to apply to Z data"
 #: ../raster3d/r3.in.lidar/main.c:271 ../raster/r.in.lidar/main.c:207
 #, fuzzy
@@ -1777,7 +1777,7 @@
 #: ../raster3d/r3.in.lidar/main.c:279 ../raster/r.in.lidar/main.c:215
 #, fuzzy
 msgid "Scale to apply to intensity values"
 #: ../raster3d/r3.in.lidar/main.c:284 ../raster/r.in.lidar/main.c:335
 #: ../vector/v.in.lidar/main.c:291
@@ -1803,7 +1803,7 @@
 #: ../vector/v.external/args.c:43
 #, fuzzy
 msgid "Override projection check (use current location's projection)"
-msgstr "Sobrescrever projeção (usar projeção da locação)"
+msgstr "Sobrescrever projeção (usar projeção da locação)"
 #: ../raster3d/r3.in.lidar/main.c:295 ../raster/r.in.lidar/main.c:301
 #: ../raster/r.external/main.c:104 ../raster/r.in.gdal/main.c:180
@@ -1814,13 +1814,13 @@
 #: ../vector/v.in.lidar/main.c:321
 #, fuzzy
 msgid "Assume that the dataset has same projection as the current location"
-msgstr "Não consegui unidades de projeção da locação atual"
+msgstr "Não consegui unidades de projeção da locação atual"
 #: ../raster3d/r3.in.lidar/main.c:299 ../raster/r.in.lidar/main.c:276
 #: ../vector/v.in.lidar/main.c:276
 #, fuzzy
 msgid "Print LAS file info and exit"
-msgstr "Mostra histórico do vetor ao invés de informações"
+msgstr "Mostra histórico do vetor ao invés de informações"
 #: ../raster3d/r3.in.lidar/main.c:303 ../raster/r.in.lidar/main.c:305
 #: ../raster/r.in.xyz/main.c:327
@@ -1833,7 +1833,7 @@
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:11
 #, fuzzy
 msgid "In scan mode, print using shell script style"
 #: ../raster3d/r3.in.lidar/main.c:329
 #, c-format
@@ -1843,25 +1843,25 @@
 #: ../raster3d/r3.in.lidar/main.c:340 ../raster/r.in.lidar/main.c:367
 #, fuzzy, c-format
 msgid "File <%s> does not exist"
-msgstr "Mapa raster [%s] não encontrado"
+msgstr "Mapa raster [%s] não encontrado"
 #: ../raster3d/r3.in.lidar/main.c:374 ../raster/r.in.lidar/main.c:397
 #: ../vector/v.in.lidar/main.c:347
 #, fuzzy, c-format
 msgid "Input file <%s> does not exist"
 #: ../raster3d/r3.in.lidar/main.c:378 ../raster/r.in.lidar/main.c:401
 #: ../vector/v.in.lidar/main.c:352
 #, fuzzy, c-format
 msgid "Unable to open file <%s> as a LiDAR point cloud"
-msgstr "Não consegui abrir o arquivo de células <%s>"
+msgstr "Não consegui abrir o arquivo de células <%s>"
 #: ../raster3d/r3.in.lidar/main.c:382 ../raster/r.in.lidar/main.c:405
 #: ../vector/v.in.lidar/main.c:356
 #, fuzzy, c-format
 msgid "Unable to read LAS header of <%s>"
-msgstr "Não consegui ler intervalo fp para <%s>"
+msgstr "Não consegui ler intervalo fp para <%s>"
 #: ../raster3d/r3.in.lidar/main.c:398 ../raster/r.in.lidar/main.c:421
 msgid ""
@@ -1886,12 +1886,12 @@
 #: ../raster3d/r3.in.lidar/main.c:661
 #, fuzzy
 msgid "Computing proportional sum map..."
-msgstr "Cópia da tabela falhou"
+msgstr "Cópia da tabela falhou"
 #: ../raster3d/r3.in.lidar/main.c:666
 #, fuzzy
 msgid "Computing mean map..."
 #: ../raster3d/r3.in.lidar/main.c:671
 #, fuzzy
@@ -1901,27 +1901,27 @@
 #: ../raster3d/r3.in.lidar/main.c:707 ../vector/v.in.lidar/main.c:783
 #, fuzzy, c-format
 msgid "%lu input points were not valid and filtered out"
-msgstr "%d pontos além do limite"
+msgstr "%d pontos além do limite"
 #: ../raster3d/r3.in.lidar/main.c:710 ../vector/v.in.lidar/main.c:789
 #, fuzzy, c-format
 msgid "%lu input points were filtered out by return number"
 #: ../raster3d/r3.in.lidar/main.c:712 ../vector/v.in.lidar/main.c:791
 #, fuzzy, c-format
 msgid "%lu input points were filtered out by class number"
 #: ../raster3d/r3.in.lidar/main.c:714
 #, fuzzy, c-format
 msgid "%lu input points had intensity out of range"
 #: ../raster3d/r3.in.lidar/main.c:716 ../vector/v.in.lidar/main.c:811
 #, fuzzy, c-format
 msgid "%lu input points were not valid, use -%c flag to filter them out"
 #: ../raster3d/r3.in.lidar/projection.c:36
 #: ../raster/r.in.lidar/projection.c:34 ../raster/r.external/proj.c:42
@@ -1932,7 +1932,7 @@
 "Projection of dataset does not appear to match current location.\n"
 "\n"
 msgstr ""
-"Projeção do conjunto de dados parece não combinar com a locação atual.\n"
+"Projeção do conjunto de dados parece não combinar com a locação atual.\n"
 "\n"
 #: ../raster3d/r3.in.lidar/projection.c:42
@@ -1941,7 +1941,7 @@
 #: ../vector/v.external/proj.c:57
 #, fuzzy
 msgid "GRASS LOCATION PROJ_INFO is:\n"
-msgstr "Locação: %s\n"
+msgstr "Locação: %s\n"
 #: ../raster3d/r3.in.lidar/projection.c:51
 #: ../raster3d/r3.in.lidar/projection.c:57
@@ -1952,7 +1952,7 @@
 #: ../vector/v.in.ogr/main.c:643 ../vector/v.in.ogr/main.c:650
 #: ../vector/v.external/proj.c:67 ../vector/v.external/proj.c:74
 msgid "Import dataset PROJ_INFO is:\n"
-msgstr "PROJ_INFO do conjunto de dados importado é:\n"
+msgstr "PROJ_INFO do conjunto de dados importado é:\n"
 #: ../raster3d/r3.in.lidar/projection.c:93
 #: ../raster/r.in.lidar/projection.c:91 ../raster/r.external/proj.c:107
@@ -1975,7 +1975,7 @@
 "Consider generating a new location with 'location' parameter from input data "
 "set.\n"
 msgstr ""
-"Considere gerar uma nova locação com o parâmetro 'location' do dado de "
+"Considere gerar uma nova locação com o parâmetro 'location' do dado de "
 "entrada.\n"
 #: ../raster3d/r3.in.lidar/projection.c:115
@@ -1987,15 +1987,15 @@
 "Unable to convert input map projection information to GRASS format for "
 "checking"
 msgstr ""
-"Não consegui converter a projeção do mapa de entrada para o formato do GRASS "
-"para verificação"
+"Não consegui converter a projeção do mapa de entrada para o formato do GRASS "
+"para verificação"
 #: ../raster3d/r3.in.lidar/projection.c:130
 #: ../raster/r.in.lidar/projection.c:128 ../raster/r.external/proj.c:34
 #: ../raster/r.in.gdal/main.c:469 ../vector/v.in.lidar/projection.c:126
 #: ../vector/v.in.ogr/main.c:618
 msgid "Over-riding projection check"
-msgstr "Se sobrepondo à verificação da projeção"
+msgstr "Se sobrepondo à verificação da projeção"
 #: ../raster3d/r3.in.lidar/projection.c:141
 #: ../raster/r.in.lidar/projection.c:139 ../raster/r.external/proj.c:116
@@ -2004,13 +2004,13 @@
 #: ../vector/v.external/proj.c:122
 msgid "Projection of input dataset and current location appear to match"
 msgstr ""
-"Projeção do conjunto de dados de entrada e locação atual parecem combinar"
+"Projeção do conjunto de dados de entrada e locação atual parecem combinar"
 #: ../raster3d/r3.in.lidar/rast_segment.c:53
 #: ../raster/r.in.lidar/rast_segment.c:40
 #, fuzzy
 msgid "Cannot create temporary file with segments of a raster map"
-msgstr "Não consegui criar arquivo temporário"
+msgstr "Não consegui criar arquivo temporário"
 #: ../raster3d/r3.in.lidar/info.c:109 ../raster/r.in.lidar/info.c:108
 #: ../raster/r.in.xyz/main.c:1198
@@ -2027,7 +2027,7 @@
 #: ../raster3d/r3.mask/main.c:75
 #, fuzzy
 msgid "Unable to open 3D raster mask file"
 #: ../raster3d/r3.mask/main.c:104
 msgid "makeMask: error flushing tiles in cube"
@@ -2040,12 +2040,12 @@
 #: ../raster3d/r3.mask/main.c:117
 #, fuzzy
 msgid "Unable to close 3D raster mask file"
 #: ../raster3d/r3.mask/main.c:119
 #, fuzzy, c-format
 msgid "Unable to close raster map <%s>"
 #: ../raster3d/r3.mask/main.c:134
 #: ../locale/scriptstrings/r.mask_to_translate.c:3
@@ -2055,40 +2055,40 @@
 #: ../raster3d/r3.mask/main.c:137
 msgid "Establishes the current working 3D raster mask."
-msgstr "Estabelece a máscara raster 3D atual"
+msgstr "Estabelece a máscara raster 3D atual"
 #: ../raster3d/r3.mask/main.c:145
 #, fuzzy
 msgid "3D raster map with reference values"
-msgstr "Mapa 3dcell com valores de referência"
+msgstr "Mapa 3dcell com valores de referência"
 #: ../raster3d/r3.mask/main.c:153
 msgid "List of cell values to be masked out"
-msgstr "Lista de valores de célula para mascarar"
+msgstr "Lista de valores de célula para mascarar"
 #: ../raster3d/r3.mask/main.c:159
 #, fuzzy
 msgid "Cannot create mask file: RASTER3D_MASK already exists"
 msgstr ""
-"Não consegui criar arqivo máscara: RASTER3D_MASK já existe!\n"
-" Use 'g.remove rast3d=RASTER3D_MASK' para remover a máscara existente."
+"Não consegui criar arqivo máscara: RASTER3D_MASK já existe!\n"
+" Use 'g.remove rast3d=RASTER3D_MASK' para remover a máscara existente."
 #: ../raster3d/r3.gradient/main.c:44
 #, fuzzy
 msgid "gradient"
-msgstr "Variância"
+msgstr "Variância"
 #: ../raster3d/r3.gradient/main.c:47
 #, fuzzy
 msgid ""
 "Computes gradient of a 3D raster map and outputs gradient components as "
 "three 3D raster maps."
-msgstr "Combina camadas vermelhas, verdes e azuis numa única camada composta."
+msgstr "Combina camadas vermelhas, verdes e azuis numa única camada composta."
 #: ../raster3d/r3.gradient/main.c:56
 #, fuzzy
 msgid "Name for output 3D raster map(s)"
-msgstr "Nome do Raster de saída"
+msgstr "Nome do Raster de saída"
 #: ../raster3d/r3.gradient/main.c:63
 #, fuzzy
@@ -2098,7 +2098,7 @@
 #: ../raster3d/r3.gradient/main.c:130
 #, fuzzy
 msgid "Failed to allocate memory for blocks"
-msgstr "Não consegui alocar memória."
+msgstr "Não consegui alocar memória."
 #: ../raster3d/r3.gradient/main.c:292
 #, fuzzy
@@ -2156,7 +2156,7 @@
 "Creates a display file from an existing 3D raster map according to specified "
 "threshold levels."
 msgstr ""
-"Cria um arquivo de exibição a partir de um arquivo grid3 existente, de "
+"Cria um arquivo de exibição a partir de um arquivo grid3 existente, de "
 "acordo com os limiares especificados."
 #: ../raster3d/r3.mkdspf/main.c:91
@@ -2167,51 +2167,51 @@
 #: ../raster3d/r3.mkdspf/main.c:96
 #, fuzzy
 msgid "Name for output display file"
-msgstr "Nome do arquivo de exibição de saída"
+msgstr "Nome do arquivo de exibição de saída"
 #: ../raster3d/r3.mkdspf/main.c:103
 msgid "List of thresholds for isosurfaces"
-msgstr "Lista de limites por isosuperfícies"
+msgstr "Lista de limites por isosuperfícies"
 #: ../raster3d/r3.mkdspf/main.c:109
 msgid "Minimum isosurface level"
-msgstr "Isosuperfície mínima"
+msgstr "Isosuperfície mínima"
 #: ../raster3d/r3.mkdspf/main.c:115
 msgid "Maximum isosurface level"
-msgstr "Isosuperfície máxima"
+msgstr "Isosuperfície máxima"
 #: ../raster3d/r3.mkdspf/main.c:121
 msgid "Positive increment between isosurface levels"
-msgstr "Incremento entre isosuperfícies"
+msgstr "Incremento entre isosuperfícies"
 #: ../raster3d/r3.mkdspf/main.c:128
 msgid "Number of isosurface threshold levels"
-msgstr "Número de niveis do limite da isosuperfície"
+msgstr "Número de niveis do limite da isosuperfície"
 #: ../raster3d/r3.mkdspf/main.c:132
 msgid "Suppress progress report & min/max information"
-msgstr "Suprimir relatório de progresso e informação de máximos e mínimos"
+msgstr "Suprimir relatório de progresso e informação de máximos e mínimos"
 #: ../raster3d/r3.mkdspf/main.c:136
 #, fuzzy
 msgid "Use flat shading rather than gradient"
-msgstr "Usar sombreamento chapado ao invés de gradiente"
+msgstr "Usar sombreamento chapado ao invés de gradiente"
 #: ../raster3d/r3.mkdspf/main.c:144
 #, c-format
 msgid "Region from getWindow: %d %d %d"
-msgstr "Região de getWindow: %d %d %d"
+msgstr "Região de getWindow: %d %d %d"
 #: ../raster3d/r3.mkdspf/main.c:156
 #, c-format
 msgid "Not able to find grid3 file for [%s]"
-msgstr "Não consegui encontrar o arquivo g3d para [%s]"
+msgstr "Não consegui encontrar o arquivo g3d para [%s]"
 #: ../raster3d/r3.mkdspf/main.c:200
 #, fuzzy, c-format
 msgid "Unable to open display file <%s>"
-msgstr "Não consegui abrir o arquivo <%s>"
+msgstr "Não consegui abrir o arquivo <%s>"
 #: ../raster3d/r3.mkdspf/main.c:221
 #, c-format
@@ -2226,7 +2226,7 @@
 #: ../raster3d/r3.cross.rast/main.c:97
 #, fuzzy
 msgid "2D elevation map used to create the cross section map"
-msgstr "mapa de elevação 2D usado para criar o mapa cross section"
+msgstr "mapa de elevação 2D usado para criar o mapa cross section"
 #: ../raster3d/r3.cross.rast/main.c:104
 #, fuzzy
@@ -2246,7 +2246,7 @@
 "map"
 msgstr ""
 "Cria mapa raster 2D cross section a partir de mapas raster 3d baseados em "
-"mapas de elevação 2D"
+"mapas de elevação 2D"
 #: ../raster3d/r3.cross.rast/main.c:259
 #, fuzzy
@@ -2254,24 +2254,24 @@
 "The 2D and 3D region settings are different. Using the 3D raster map "
 "settings to adjust the 2D region."
 msgstr ""
-"As configurações de região 2d e 3d estão diferentes. Usarei as configurações "
-"g3d para ajustar a região 2d."
+"As configurações de região 2d e 3d estão diferentes. Usarei as configurações "
+"g3d para ajustar a região 2d."
 #: ../raster3d/r3.cross.rast/main.c:302
 msgid "Output map already exists. Will be overwritten!"
-msgstr "Mapa de saída já existe. Será sobreescrito!"
+msgstr "Mapa de saída já existe. Será sobreescrito!"
 #: ../raster3d/r3.cross.rast/main.c:338
 #, fuzzy
 msgid "Wrong 3D raster datatype! Cannot create raster map"
-msgstr "Tipo de dado RASTER3D errado! Não consegui criar mapa raster."
+msgstr "Tipo de dado RASTER3D errado! Não consegui criar mapa raster."
 #: ../raster3d/r3.flow/flowline.c:60 ../raster/r.contour/main.c:216
 #: ../vector/v.overlay/line_area.c:410 ../vector/v.overlay/area_area.c:345
 #: ../vector/v.to.points/write.c:52
 #, c-format
 msgid "Unable to insert new record: '%s'"
-msgstr "Não consegui inserir novo registro: '%s'"
+msgstr "Não consegui inserir novo registro: '%s'"
 #: ../raster3d/r3.flow/test_main.c:44
 msgid "unit test"
@@ -2280,7 +2280,7 @@
 #: ../raster3d/r3.flow/test_main.c:45
 #, fuzzy
 msgid "Testing flow lines."
-msgstr "Calculando médias das classes ..."
+msgstr "Calculando médias das classes ..."
 #: ../raster3d/r3.flow/main.c:46 ../ps/ps.map/catval.c:53
 #: ../ps/ps.map/catval.c:115 ../ps/ps.map/catval.c:181
@@ -2328,7 +2328,7 @@
 #: ../vector/v.vol.rst/user1.c:99 ../vector/v.vol.rst/main.c:600
 #, c-format
 msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Não conseguir abrir banco de dados <%s> com driver <%s>"
+msgstr "Não conseguir abrir banco de dados <%s> com driver <%s>"
 #: ../raster3d/r3.flow/main.c:64 ../raster/r.to.vect/main.c:229
 #: ../raster/r.volume/main.c:260 ../vector/v.lrs/v.lrs.create/main.c:338
@@ -2337,7 +2337,7 @@
 #: ../vector/v.in.ascii/main.c:413
 #, fuzzy, c-format
 msgid "Unable to create table: %s"
-msgstr "Não consegui criar arquivo [%s]"
+msgstr "Não consegui criar arquivo [%s]"
 #: ../raster3d/r3.flow/main.c:67 ../raster/r.contour/main.c:188
 #: ../vector/v.reclass/main.c:322 ../vector/v.in.lidar/attributes.c:139
@@ -2346,7 +2346,7 @@
 #: ../vector/v.in.ascii/main.c:521
 #, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
-msgstr "Não consegui criar índice para tabela <%s>, chave <%s>"
+msgstr "Não consegui criar índice para tabela <%s>, chave <%s>"
 #: ../raster3d/r3.flow/main.c:72 ../raster/r.stream.extract/close.c:196
 #: ../raster/r.to.vect/main.c:238 ../raster/r.random/random.c:257
@@ -2361,17 +2361,17 @@
 #: ../vector/v.in.ascii/main.c:421
 #, c-format
-msgstr "Não posso dar privilégios na tabela <%s>"
+msgstr "Não posso dar privilégios na tabela <%s>"
 #: ../raster3d/r3.flow/main.c:91
 #, fuzzy
 msgid "Please provide three 3D raster maps"
-msgstr "Favor fornecer três mapas RGB g3d"
+msgstr "Favor fornecer três mapas RGB g3d"
 #: ../raster3d/r3.flow/main.c:98
 #, fuzzy, c-format
 msgid "Vector seed map <%s> not found"
-msgstr "Mapa vetorial <%s> não encontrado"
+msgstr "Mapa vetorial <%s> não encontrado"
 #: ../raster3d/r3.flow/main.c:147
 msgid "init_flowaccum: error in Rast3d_put_float"
@@ -2380,7 +2380,7 @@
 #: ../raster3d/r3.flow/main.c:183
 #, fuzzy
 msgid "Computes 3D flow lines and 3D flow accumulation."
-msgstr "Calculando direções do fluxo..."
+msgstr "Calculando direções do fluxo..."
 #: ../raster3d/r3.flow/main.c:193
 msgid ""
@@ -2406,12 +2406,12 @@
 #: ../raster3d/r3.flow/main.c:217
 #, fuzzy
 msgid "Name for output flowaccumulation 3D raster"
 #: ../raster3d/r3.flow/main.c:224
 #, fuzzy
 msgid "Name for 3D raster sampled by flowlines"
-msgstr "Nome do mapa raster que conterá os resultados"
+msgstr "Nome do mapa raster que conterá os resultados"
 #: ../raster3d/r3.flow/main.c:226
 msgid ""
@@ -2434,7 +2434,7 @@
 #: ../raster3d/r3.flow/main.c:243
 #, fuzzy
 msgid "Unit of integration step"
 #: ../raster3d/r3.flow/main.c:244
 msgid "Default unit is cell"
@@ -2444,12 +2444,12 @@
 #: ../raster3d/r3.flow/main.c:262 ../raster3d/r3.flow/main.c:272
 #, fuzzy
 msgid "Integration"
-msgstr "Método de intepolação a usar"
+msgstr "Método de intepolação a usar"
 #: ../raster3d/r3.flow/main.c:252
 #, fuzzy
 msgid "Integration step in selected unit"
 #: ../raster3d/r3.flow/main.c:253
 #, fuzzy
@@ -2459,12 +2459,12 @@
 #: ../raster3d/r3.flow/main.c:261
 #, fuzzy
 msgid "Maximum number of steps"
-msgstr "Número de iterações máximas"
+msgstr "Número de iterações máximas"
 #: ../raster3d/r3.flow/main.c:269
 #, fuzzy
 msgid "Maximum error of integration"
 #: ../raster3d/r3.flow/main.c:270
 msgid "Influences step, increase maximum error to allow bigger steps"
@@ -2473,7 +2473,7 @@
 #: ../raster3d/r3.flow/main.c:280
 #, fuzzy
 msgid "Number of cells between flow lines in x, y and z direction"
-msgstr "Número de cópias"
+msgstr "Número de cópias"
 #: ../raster3d/r3.flow/main.c:289
 msgid "Compute flowlines upstream, downstream or in both direction."
@@ -2482,7 +2482,7 @@
 #: ../raster3d/r3.flow/main.c:294
 #, fuzzy
 msgid "Create and fill attribute table"
-msgstr "Não consegui descrever a tabela %s"
+msgstr "Não consegui descrever a tabela %s"
 #: ../raster3d/r3.flow/main.c:349
 msgid "Please provide 3 integer values for skip option."
@@ -2539,7 +2539,7 @@
 #: ../vector/v.net.connectivity/main.c:136
 #, fuzzy, c-format
 msgid "Unable to create vector map <%s>"
-msgstr "Não consegui criar arquivo raster [%s]."
+msgstr "Não consegui criar arquivo raster [%s]."
 #: ../raster3d/r3.flow/main.c:411 ../doc/vector/v.example/main.c:87
 #: ../raster/r.sim/simlib/observation_points.c:41 ../raster/r.what/main.c:236
@@ -2610,13 +2610,13 @@
 #: ../vector/v.net.connectivity/main.c:130
 #, fuzzy, c-format
 msgid "Unable to open vector map <%s>"
 #: ../raster3d/r3.flow/main.c:414 ../vector/v.colors/main.c:266
 #: ../vector/v.to.rast/vect2rast.c:48
 #, fuzzy, c-format
 msgid "Vector map <%s> is not 3D"
-msgstr "Mapa vetorial não é 3D"
+msgstr "Mapa vetorial não é 3D"
 #: ../raster3d/r3.flow/main.c:441
 #, fuzzy
@@ -2630,27 +2630,27 @@
 #: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:36
 msgid "Name for VTK-ASCII output file"
-msgstr "Nome do arquivo VTK-ASCII de saída"
+msgstr "Nome do arquivo VTK-ASCII de saída"
 #: ../raster3d/r3.out.vtk/parameters.c:41
 msgid "Float value to represent no data cell/points"
-msgstr "Valor flutuante para representar nenhuma célula/ponto de dados"
+msgstr "Valor flutuante para representar nenhuma célula/ponto de dados"
 #: ../raster3d/r3.out.vtk/parameters.c:47
 msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
 msgstr ""
-"Criar dados pontuais (pointdata) VTK ao invés de dados de células (celldata) "
-"VTK (dados de célula é o padrão)"
+"Criar dados pontuais (pointdata) VTK ao invés de dados de células (celldata) "
+"VTK (dados de célula é o padrão)"
 #: ../raster3d/r3.out.vtk/parameters.c:56
 #, fuzzy
 msgid "Top surface 2D raster map"
-msgstr "Mapa raster 2D de superfície de topo"
+msgstr "Mapa raster 2D de superfície de topo"
 #: ../raster3d/r3.out.vtk/parameters.c:65
 #, fuzzy
 msgid "Bottom surface 2D raster map"
-msgstr "Mapa raster 2D de superfície de fundo"
+msgstr "Mapa raster 2D de superfície de fundo"
 #: ../raster3d/r3.out.vtk/parameters.c:71
 #, fuzzy
@@ -2658,7 +2658,7 @@
 "Create 3D elevation output with a top and a bottom surface, both raster maps "
 "are required."
 msgstr ""
-"Cria saída de elevação 3d com uma superfície de topo e piso, ambos os mapas "
+"Cria saída de elevação 3d com uma superfície de topo e piso, ambos os mapas "
 "raster sendo requisitados."
 #: ../raster3d/r3.out.vtk/parameters.c:80
@@ -2666,31 +2666,31 @@
 msgid ""
 "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
 msgstr ""
-"3 mapas raster (r,g,b) 3d que serão usado para criar valores rgb "
+"3 mapas raster (r,g,b) 3d que serão usado para criar valores rgb "
 "[mapavermelho, mapaverde, mapaazul]"
 #: ../raster3d/r3.out.vtk/parameters.c:88
 #, fuzzy
 msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
 msgstr ""
-"3 mapas raster (r,g,b) que serão usado para criar valores rgb [mapavermelho, "
+"3 mapas raster (r,g,b) que serão usado para criar valores rgb [mapavermelho, "
 "mapaverde, mapaazul]"
 #: ../raster3d/r3.out.vtk/parameters.c:94 ../raster/r.out.vtk/parameters.c:85
 #: ../vector/v.out.vtk/main.c:76
 msgid "Scale factor for elevation"
-msgstr "Fator de escala para elevação"
+msgstr "Fator de escala para elevação"
 #: ../raster3d/r3.out.vtk/parameters.c:107 ../raster/r.out.vtk/parameters.c:98
 #: ../raster/r.out.ascii/main.c:79 ../display/d.rast.num/main.c:104
 #: ../vector/v.out.ascii/args.c:75 ../vector/v.out.vtk/main.c:70
 msgid "Number of significant digits (floating point only)"
-msgstr "Número de dígitos significativos (apenas ponto flutuante)"
+msgstr "Número de dígitos significativos (apenas ponto flutuante)"
 #: ../raster3d/r3.out.vtk/parameters.c:112
 #, fuzzy
 msgid "Use 3D raster mask (if exists) with input maps"
 #: ../raster3d/r3.out.vtk/parameters.c:117
 #, fuzzy
@@ -2701,7 +2701,7 @@
 #: ../raster/r.out.vtk/parameters.c:128
 #, fuzzy
 msgid "Correct the coordinates to match the VTK-OpenGL precision"
-msgstr "Corrija as coordenadas para coincidir com a precisão VTK-OpenGL"
+msgstr "Corrija as coordenadas para coincidir com a precisão VTK-OpenGL"
 #: ../raster3d/r3.out.vtk/parameters.c:129
 msgid ""
@@ -2712,37 +2712,37 @@
 #: ../raster3d/r3.out.vtk/main.c:117
 #, fuzzy
 msgid "Specify top and bottom map"
-msgstr "Você tem que especificar mapas de topo e de fundo"
+msgstr "Você tem que especificar mapas de topo e de fundo"
 #: ../raster3d/r3.out.vtk/main.c:124
 #, c-format
 msgid "Top cell map <%s> not found"
-msgstr "mapa de células de topo <%s> não encontrado"
+msgstr "mapa de células de topo <%s> não encontrado"
 #: ../raster3d/r3.out.vtk/main.c:133
 #, c-format
 msgid "Bottom cell map <%s> not found"
-msgstr "mapa de células de fundo <%s> não encontrado"
+msgstr "mapa de células de fundo <%s> não encontrado"
 #: ../raster3d/r3.out.vtk/main.c:152
 #, fuzzy, c-format
 msgid "3D raster map RGB map <%s> not found"
 #: ../raster3d/r3.out.vtk/main.c:155
 #, fuzzy
 msgid "Please provide three RGB 3D raster maps"
 #: ../raster3d/r3.out.vtk/main.c:165
 #, fuzzy, c-format
 msgid "3D vector map <%s> not found"
 #: ../raster3d/r3.out.vtk/main.c:168
 #, fuzzy
 msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
-msgstr "Favor fornecer três mapas vetoriais g3d [x,y,z]"
+msgstr "Favor fornecer três mapas vetoriais g3d [x,y,z]"
 #: ../raster3d/r3.out.vtk/main.c:175
 #, fuzzy
@@ -2750,16 +2750,16 @@
 "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
 "geometry."
 msgstr ""
-"Sem dados g3d, mapas RGB ou vetor-xyz são fornecidos! Vou escrever apenas a "
+"Sem dados g3d, mapas RGB ou vetor-xyz são fornecidos! Vou escrever apenas a "
 "geometria."
 #: ../raster3d/r3.out.vtk/main.c:209
 msgid "No RGB Data will be created."
-msgstr "Nenhum dado RGB será criado."
+msgstr "Nenhum dado RGB será criado."
 #: ../raster3d/r3.out.vtk/main.c:294
 msgid "No vector data will be created."
-msgstr "Nenhum dado vetorial será criado."
+msgstr "Nenhum dado vetorial será criado."
 #: ../raster3d/r3.out.vtk/main.c:381
 #, fuzzy
@@ -2782,7 +2782,7 @@
 #: ../raster3d/r3.out.vtk/main.c:557
 #, fuzzy
 msgid "Unable to close VTK-ASCII file"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:122
 msgid "write_vtk_points: Writing point coordinates"
@@ -2790,7 +2790,7 @@
 #: ../raster3d/r3.out.vtk/writeVTKData.c:256
 msgid "write_vtk_unstructured_grid_cells: Writing the cells"
-msgstr "write_vtk_unstructured_grid_cells: Gravando as células"
+msgstr "write_vtk_unstructured_grid_cells: Gravando as células"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:335
 #, c-format
@@ -2798,7 +2798,7 @@
 "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
 "ascii file"
 msgstr ""
-"write_vtk_data: Gravando dados de célula (celldata) %s com linhas %i colunas "
+"write_vtk_data: Gravando dados de célula (celldata) %s com linhas %i colunas "
 "%i profundidades %i para arquivo vtk-ascii"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:441
@@ -2810,13 +2810,13 @@
 #: ../raster3d/r3.out.vtk/errorHandling.c:105
 #, fuzzy
 msgid "Unable to close input raster maps"
-msgstr "Não consegui fechar mapa raster de entrada"
+msgstr "Não consegui fechar mapa raster de entrada"
 #: ../raster3d/r3.neighbors/main.c:94 ../raster/r.resamp.stats/main.c:298
 #: ../raster/r.series/main.c:104 ../raster/r.neighbors/main.c:102
 #, fuzzy, c-format
 msgid "Unknown method <%s>"
-msgstr "Métrica desconhecida: [%s]."
+msgstr "Métrica desconhecida: [%s]."
 #: ../raster3d/r3.neighbors/main.c:119 ../raster/r.series/main.c:161
 msgid "Aggregate operation"
@@ -2826,7 +2826,7 @@
 #: ../raster/r.series/main.c:168 ../raster/r.neighbors/main.c:239
 #, fuzzy
 msgid "Quantile to calculate for method=quantile"
-msgstr "Não consegui calcular área do centróide."
+msgstr "Não consegui calcular área do centróide."
 #: ../raster3d/r3.neighbors/main.c:137
 msgid ""
@@ -2846,24 +2846,24 @@
 #: ../vector/v.neighbors/main.c:51
 #, fuzzy
 msgid "algebra"
 #: ../raster3d/r3.neighbors/main.c:213 ../raster/r.neighbors/main.c:171
 #, fuzzy
 msgid "neighbor"
-msgstr "Tamanho da vizinhança"
+msgstr "Tamanho da vizinhança"
 #: ../raster3d/r3.neighbors/main.c:214 ../raster/r.neighbors/main.c:172
 #, fuzzy
 msgid "focal statistics"
 #: ../raster3d/r3.neighbors/main.c:215 ../raster/r.mfilter/main.c:59
 #: ../raster/r.resamp.filter/main.c:392 ../raster/r.neighbors/main.c:173
 #: ../vector/v.outlier/main.c:73
 #, fuzzy
 msgid "filter"
-msgstr "Tipo de feição"
+msgstr "Tipo de feição"
 #: ../raster3d/r3.neighbors/main.c:218
 #, fuzzy
@@ -2871,13 +2871,13 @@
 "Makes each voxel value a function of the values assigned to the voxels "
 "around it, and stores new voxel values in an output 3D raster map"
 msgstr ""
-"Define a categoria de cada célula como função das categorias das células "
-"vizinhas, e grava os novos valores numa camada raster de saída."
+"Define a categoria de cada célula como função das categorias das células "
+"vizinhas, e grava os novos valores numa camada raster de saída."
 #: ../raster3d/r3.neighbors/main.c:287
 #, fuzzy
 msgid "Unable to allocate buffer"
-msgstr "Não consegui alocar buffer de células."
+msgstr "Não consegui alocar buffer de células."
 #: ../imagery/i.gensigset/parse.c:13 ../imagery/i.gensig/parse.c:14
 #, fuzzy
@@ -2888,12 +2888,12 @@
 #: ../imagery/i.cluster/main.c:95
 #, fuzzy
 msgid "Name for output file containing result signatures"
-msgstr "Nome do arquivo de saída contendo a matriz de erro e capa"
+msgstr "Nome do arquivo de saída contendo a matriz de erro e capa"
 #: ../imagery/i.gensigset/parse.c:29
 #, fuzzy
 msgid "Maximum number of sub-signatures in any class"
-msgstr "Número mínimo de pixels numa classe"
+msgstr "Número mínimo de pixels numa classe"
 #: ../imagery/i.gensigset/parse.c:44 ../imagery/i.pca/main.c:139
 #: ../imagery/i.gensig/parse.c:38
@@ -2933,21 +2933,21 @@
 #: ../vector/v.colors/main.c:312 ../vector/v.vol.rst/main.c:615
 #, c-format
 msgid "Raster map <%s> not found"
-msgstr "Mapa raster <%s> não encontrado"
+msgstr "Mapa raster <%s> não encontrado"
 #: ../imagery/i.gensigset/parse.c:47 ../imagery/i.smap/parse.c:61
 #: ../imagery/i.gensig/parse.c:41 ../imagery/i.maxlik/open.c:17
 #: ../imagery/i.cluster/main.c:169
 #, fuzzy, c-format
 msgid "Group <%s> not found in current mapset"
-msgstr "mapa vetorial <%s> não encontrado no mapset atual"
+msgstr "mapa vetorial <%s> não encontrado no mapset atual"
 #: ../imagery/i.gensigset/parse.c:50 ../imagery/i.smap/parse.c:64
 #: ../imagery/i.gensig/parse.c:44 ../imagery/i.maxlik/open.c:20
 #: ../imagery/i.cluster/main.c:172
 #, fuzzy, c-format
 msgid "Subgroup <%s> in group <%s> not found"
-msgstr "subrupo <%s> não encontrado"
+msgstr "subrupo <%s> não encontrado"
 #: ../imagery/i.gensigset/parse.c:57 ../imagery/i.gensig/parse.c:50
 #: ../imagery/i.cluster/main.c:179 ../raster/r.proj/main.c:245
@@ -2960,7 +2960,7 @@
 #: ../imagery/i.gensigset/parse.c:63
 #, fuzzy, c-format
 msgid "Illegal number of sub-signatures (%s)"
-msgstr "Número inválido de passos: %s"
+msgstr "Número inválido de passos: %s"
 #: ../imagery/i.gensigset/subcluster.c:76
 #, fuzzy, c-format
@@ -2975,7 +2975,7 @@
 #: ../imagery/i.gensigset/subcluster.c:88
 #, fuzzy, c-format
 msgid "Number of subclasses set to %d"
 #: ../imagery/i.gensigset/subcluster.c:106
 #, c-format
@@ -3005,7 +3005,7 @@
 #: ../imagery/i.gensigset/write_sig.c:13 ../imagery/i.gensig/write_sig.c:15
 #, fuzzy, c-format
 msgid "Unable to create signature file <%s>"
 #: ../imagery/i.gensigset/write_sig.c:16 ../imagery/i.gensig/write_sig.c:18
 #, fuzzy
@@ -3053,13 +3053,13 @@
 #: ../raster/r.kappa/main.c:70 ../vector/v.class/main.c:46
 #, fuzzy
 msgid "classification"
-msgstr "Assinaturas para usar na classificação"
+msgstr "Assinaturas para usar na classificação"
 #: ../imagery/i.gensigset/main.c:42 ../imagery/i.smap/main.c:40
 #: ../imagery/i.gensig/main.c:41
 #, fuzzy
 msgid "supervised classification"
 #: ../imagery/i.gensigset/main.c:43 ../imagery/i.smap/main.c:42
 msgid "SMAP"
@@ -3069,33 +3069,33 @@
 #: ../imagery/i.cluster/main.c:77
 #, fuzzy
 msgid "signatures"
 #: ../imagery/i.gensigset/main.c:46
 #, fuzzy
 msgid "Generates statistics for i.smap from raster map."
-msgstr "Gera estatísticas para i.maxlik a partir de mapas raster."
+msgstr "Gera estatísticas para i.maxlik a partir de mapas raster."
 #: ../imagery/i.gensigset/main.c:56
 #, fuzzy, c-format
 msgid "Clustering class %d (%d pixels)..."
 #: ../imagery/i.gensigset/main.c:59
 #, fuzzy, c-format
 msgid "Number of subclasses is %d"
 #: ../imagery/i.gensigset/openfiles.c:18 ../imagery/i.smap/openfiles.c:18
 #: ../imagery/i.smap/read_sig.c:13 ../imagery/i.gensig/openfiles.c:19
 #, fuzzy, c-format
 msgid "Unable to read REF file for subgroup <%s> in group <%s>"
-msgstr "Não consegui ler arquivo REF para o subgrupo [%s] no grupo [%s]."
+msgstr "Não consegui ler arquivo REF para o subgrupo [%s] no grupo [%s]."
 #: ../imagery/i.gensigset/openfiles.c:22 ../imagery/i.gensig/openfiles.c:23
 #, fuzzy, c-format
 msgid "Subgroup <%s> in group <%s> contains no raster maps."
-msgstr "Subgrupo [%s] no grupo [%s] não contém arquivos."
+msgstr "Subgrupo [%s] no grupo [%s] não contém arquivos."
 #: ../imagery/i.gensigset/get_train.c:35 ../imagery/i.gensig/get_train.c:32
 #, fuzzy
@@ -3106,12 +3106,12 @@
 #, fuzzy, c-format
 msgid "Training class %d only has one cell - this class will be ignored"
 msgstr ""
-"Classe de treinamento [%d] só tem uma célula - esta classe será ignorada."
+"Classe de treinamento [%d] só tem uma célula - esta classe será ignorada."
 #: ../imagery/i.gensigset/get_train.c:63 ../imagery/i.gensig/get_train.c:60
 #, fuzzy
 msgid "Training map has no classes"
-msgstr "Mapa de treinamento não possui classes."
+msgstr "Mapa de treinamento não possui classes."
 #: ../imagery/i.gensigset/get_train.c:79 ../imagery/i.gensig/get_train.c:75
 #, fuzzy
@@ -3127,7 +3127,7 @@
 #: ../imagery/i.evapo.time/main.c:78 ../imagery/i.evapo.pm/main.c:59
 #, fuzzy
 msgid "evapotranspiration"
 #: ../imagery/i.evapo.pt/main.c:69
 msgid ""
@@ -3167,7 +3167,7 @@
 #: ../imagery/i.evapo.pt/main.c:97
 #, fuzzy
 msgid "Name of output evapotranspiration raster map [mm/d]"
-msgstr "Nome do raster de saída"
+msgstr "Nome do raster de saída"
 #: ../imagery/i.evapo.pt/main.c:102 ../imagery/i.evapo.mh/main.c:105
 msgid "Set negative ETa to zero"
@@ -3175,11 +3175,11 @@
 #: ../imagery/i.cca/transform.c:24
 msgid "Unable to allocate cell buffers."
 #: ../imagery/i.cca/transform.c:58
 msgid "Transform completed.\n"
-msgstr "Transformação completa.\n"
+msgstr "Transformação completa.\n"
 #: ../imagery/i.cca/main.c:87
 msgid "canonical components analysis"
@@ -3189,7 +3189,7 @@
 #, fuzzy
 msgid "Canonical components analysis (CCA) program for image processing."
 msgstr ""
-"Programa de Análise Canônica de Componentes (CCA) para processamento de "
+"Programa de Análise Canônica de Componentes (CCA) para processamento de "
 "imagens."
 #: ../imagery/i.cca/main.c:96
@@ -3204,7 +3204,7 @@
 #: ../imagery/i.cca/main.c:106
 msgid "Output raster map prefix name"
-msgstr "Prefixo para o nome do arquivo raster de saída"
+msgstr "Prefixo para o nome do arquivo raster de saída"
 #: ../imagery/i.cca/main.c:114
 msgid "Unknown imagery group."
@@ -3212,12 +3212,12 @@
 #: ../imagery/i.cca/main.c:117
 msgid "Unable to find subgroup reference information."
-msgstr "Não consegui encontrar informação de referência sobre o subgrupo."
+msgstr "Não consegui encontrar informação de referência sobre o subgrupo."
 #: ../imagery/i.cca/main.c:123
 #, fuzzy
 msgid "Unable to open the signature file"
-msgstr "Não consegui abrir o arquivo de assinatura."
+msgstr "Não consegui abrir o arquivo de assinatura."
 #: ../imagery/i.cca/main.c:127
 msgid "Error while reading the signatures file."
@@ -3225,13 +3225,13 @@
 #: ../imagery/i.cca/main.c:132
 msgid "Need at least two signatures in signature file."
-msgstr "Pelo menos duas assinaturas são necessárias no arquivo de assinaturas."
+msgstr "Pelo menos duas assinaturas são necessárias no arquivo de assinaturas."
 #: ../imagery/i.cca/main.c:226
 #, fuzzy, c-format
 msgid "The output cell map <%s.%d> has values outside the 0-255 range."
 msgstr ""
-"Mapa de células de saída <%s.%d> possui valores além do limite 0-255.\n"
+"Mapa de células de saída <%s.%d> possui valores além do limite 0-255.\n"
 #: ../imagery/i.evapo.mh/main.c:72
 msgid ""
@@ -3242,7 +3242,7 @@
 #: ../imagery/i.evapo.mh/main.c:78
 #, fuzzy
 msgid "Name of input diurnal net radiation raster map [W/m2/d]"
-msgstr "Nome do arquivo raster de elevação para entrada (metros)"
+msgstr "Nome do arquivo raster de elevação para entrada (metros)"
 #: ../imagery/i.evapo.mh/main.c:82
 #, fuzzy
@@ -3274,7 +3274,7 @@
 #: ../imagery/i.evapo.mh/main.c:96
 #, fuzzy
 msgid "Name of precipitation raster map [mm/month]"
 #: ../imagery/i.evapo.mh/main.c:97
 msgid "Disabled for original Hargreaves (1985)"
@@ -3283,7 +3283,7 @@
 #: ../imagery/i.evapo.mh/main.c:100
 #, fuzzy
 msgid "Name for output raster map [mm/d]"
 #: ../imagery/i.evapo.mh/main.c:109
 msgid "Use original Hargreaves (1985)"
@@ -3322,22 +3322,22 @@
 #: ../imagery/i.zc/main.c:96
 #, fuzzy
 msgid "Number of azimuth directions categorized"
 #: ../imagery/i.zc/main.c:108
 #, fuzzy
 msgid "Threshold less than or equal to zero not allowed"
-msgstr "Limite menor ou igual a zero não permitido."
+msgstr "Limite menor ou igual a zero não permitido."
 #: ../imagery/i.zc/main.c:114
 #, fuzzy
 msgid "Width less than or equal to zero not allowed"
 #: ../imagery/i.zc/main.c:118
 #, fuzzy
 msgid "Fewer than 1 orientation classes not allowed"
 #: ../imagery/i.zc/main.c:132
 #, fuzzy, c-format
@@ -3374,31 +3374,31 @@
 #: ../vector/v.proj/main.c:69
 #, fuzzy
 msgid "transformation"
 #: ../imagery/i.fft/main.c:80 ../imagery/i.ifft/main.c:79
 #, fuzzy
 msgid "Fast Fourier Transform"
-msgstr "Transformada Rápida de Fourier (FFT) para processamento de imagens."
+msgstr "Transformada Rápida de Fourier (FFT) para processamento de imagens."
 #: ../imagery/i.fft/main.c:82
 msgid "Fast Fourier Transform (FFT) for image processing."
 #: ../imagery/i.fft/main.c:90
 #, fuzzy
 msgid "Name for output real part arrays stored as raster map"
-msgstr "Saída da parte real como arquivo raster"
+msgstr "Saída da parte real como arquivo raster"
 #: ../imagery/i.fft/main.c:94
 #, fuzzy
 msgid "Name for output imaginary part arrays stored as raster map"
-msgstr "Saída da parte imaginária como arquivo raster"
+msgstr "Saída da parte imaginária como arquivo raster"
 #: ../imagery/i.fft/main.c:106
 msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
 msgstr ""
-"Máscara raster encontrada, considere excluir (veja página man). "
+"Máscara raster encontrada, considere excluir (veja página man). "
 "Continuando..."
 #: ../imagery/i.fft/main.c:129
@@ -3426,30 +3426,30 @@
 #: ../imagery/i.find/main.c:63
 #, c-format
 msgid "usage: %s location mapset element file."
-msgstr "uso: %s arquivo de elementos locação mapset."
+msgstr "uso: %s arquivo de elementos locação mapset."
 #: ../imagery/i.find/main.c:83
 #, fuzzy
 msgid "Unable to open temp file."
 #: ../imagery/i.aster.toar/main.c:98 ../imagery/i.landsat.toar/main.c:71
 #, fuzzy
 msgid "radiometric conversion"
 #: ../imagery/i.aster.toar/main.c:99 ../imagery/i.landsat.toar/main.c:72
 #: ../imagery/i.landsat.toar/main.c:578
 #, fuzzy
 msgid "radiance"
-msgstr "Variância"
+msgstr "Variância"
 #: ../imagery/i.aster.toar/main.c:100 ../imagery/i.landsat.toar/main.c:73
 #: ../imagery/i.landsat.toar/main.c:580 ../imagery/i.modis.qc/main.c:151
 #: ../imagery/i.albedo/main.c:97
 #, fuzzy
 msgid "reflectance"
-msgstr "Resolução"
+msgstr "Resolução"
 #: ../imagery/i.aster.toar/main.c:101 ../imagery/i.landsat.toar/main.c:74
 msgid "brightness temperature"
@@ -3492,7 +3492,7 @@
 #: ../imagery/i.aster.toar/main.c:126
 #, fuzzy
 msgid "Base name of the output layers (will add .x)"
 #: ../imagery/i.aster.toar/main.c:131
 msgid "Output is radiance (W/m2)"
@@ -3521,7 +3521,7 @@
 #: ../imagery/i.aster.toar/main.c:231 ../imagery/i.albedo/main.c:167
 #, fuzzy, c-format
 msgid "Too many input maps. Only %d allowed."
-msgstr "correção"
+msgstr "correção"
 #: ../imagery/i.aster.toar/main.c:246
 msgid "The input band number should be 15"
@@ -3536,19 +3536,19 @@
 #: ../imagery/i.landsat.toar/main.c:75
 #, fuzzy
 msgid "atmospheric correction"
-msgstr "Gera uma mapa de direções"
+msgstr "Gera uma mapa de direções"
 #: ../imagery/i.landsat.toar/main.c:77 ../imagery/i.albedo/main.c:99
 #: ../imagery/i.landsat.acca/main.c:109
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:4
 #, fuzzy
 msgid "Landsat"
-msgstr "Camada número"
+msgstr "Camada número"
 #: ../imagery/i.landsat.toar/main.c:82 ../imagery/i.landsat.acca/main.c:112
 #, fuzzy
 msgid "Base name of input raster bands"
 #: ../imagery/i.landsat.toar/main.c:83 ../imagery/i.landsat.acca/main.c:113
 msgid "Example: 'B.' for B.1, B.2, ..."
@@ -3557,7 +3557,7 @@
 #: ../imagery/i.landsat.toar/main.c:86
 #, fuzzy
 msgid "Prefix for output raster maps"
-msgstr "Nome do mapa raster de saída"
+msgstr "Nome do mapa raster de saída"
 #: ../imagery/i.landsat.toar/main.c:88
 msgid "Example: 'B.toar.' generates B.toar.1, B.toar.2, ..."
@@ -3624,7 +3624,7 @@
 #: ../imagery/i.landsat.toar/main.c:123 ../imagery/i.landsat.toar/main.c:124
 #, fuzzy
 msgid "Atmospheric correction method"
 #: ../imagery/i.landsat.toar/main.c:133
 msgid "Image acquisition date (yyyy-mm-dd)"
@@ -3638,7 +3638,7 @@
 #: ../imagery/i.landsat.toar/main.c:141
 #, fuzzy
 msgid "Sun elevation in degrees"
-msgstr "Ângulo de anisotropia (em graus)"
+msgstr "Ângulo de anisotropia (em graus)"
 #: ../imagery/i.landsat.toar/main.c:150
 msgid "Image creation date (yyyy-mm-dd)"
@@ -3737,12 +3737,12 @@
 #: ../imagery/i.landsat.toar/main.c:202
 #, fuzzy
 msgid "Landsat Number"
 #: ../imagery/i.landsat.toar/main.c:203
 #, fuzzy
 msgid "Creation timestamp"
 #: ../imagery/i.landsat.toar/main.c:204
 msgid "Date"
@@ -3751,7 +3751,7 @@
 #: ../imagery/i.landsat.toar/main.c:205
 #, fuzzy
 msgid "Sun Elevation"
-msgstr "Resolução"
+msgstr "Resolução"
 #: ../imagery/i.landsat.toar/main.c:206
 msgid "Sensor"
@@ -3781,7 +3781,7 @@
 #: ../imagery/i.landsat.toar/main.c:216
 #, fuzzy
 msgid "Scale factor for output"
 #: ../imagery/i.landsat.toar/main.c:222
 msgid "Output at-sensor radiance instead of reflectance for all bands"
@@ -3795,7 +3795,7 @@
 #: ../imagery/i.landsat.toar/main.c:231
 #, fuzzy
 msgid "Print output metadata info"
-msgstr "Imprime apenas informação topológica"
+msgstr "Imprime apenas informação topológica"
 #: ../imagery/i.landsat.toar/main.c:257 ../imagery/i.landsat.toar/main.c:265
 #, fuzzy, c-format
@@ -3831,25 +3831,25 @@
 #: ../raster/r.random/random.c:47 ../raster/r.mapcalc/map3.c:517
 #, c-format
 msgid "Unable to open raster map <%s>"
-msgstr "Não consegui abrir mapa raster <%s>"
+msgstr "Não consegui abrir mapa raster <%s>"
 #: ../imagery/i.landsat.toar/main.c:411 ../imagery/i.landsat.toar/main.c:560
 #, fuzzy, c-format
 msgid "Unable to read data type of raster map <%s>"
-msgstr "Não consegui ler intervalo pf do mapa raster <%s>"
+msgstr "Não consegui ler intervalo pf do mapa raster <%s>"
 #: ../imagery/i.landsat.toar/main.c:535 ../raster/r.topidx/topidx.c:41
 #: ../raster/r.flow/main.c:314
 #, fuzzy
 msgid "Calculating..."
 #: ../imagery/i.landsat.toar/main.c:549 ../raster/r.relief/main.c:194
 #: ../raster/r.in.gdal/main.c:346 ../raster/r.in.gdal/main.c:693
 #: ../vector/v.kernel/main.c:236
 #, c-format
 msgid "Raster map <%s> already exists and will be overwritten"
-msgstr "Mapa raster <%s> já existe e será sobreescrito"
+msgstr "Mapa raster <%s> já existe e será sobreescrito"
 #: ../imagery/i.landsat.toar/main.c:553
 #, fuzzy, c-format
@@ -3863,7 +3863,7 @@
 #: ../general/g.rename/main.c:85
 #, c-format
 msgid "<%s> is an illegal file name"
-msgstr "<%s> é um nome de arquivo ilegal"
+msgstr "<%s> é um nome de arquivo ilegal"
 #: ../imagery/i.landsat.toar/main.c:567
 #: ../imagery/i.landsat.acca/algorithm.c:234
@@ -3873,7 +3873,7 @@
 #: ../raster/r.mapcalc/map3.c:606
 #, c-format
 msgid "Unable to create raster map <%s>"
 #: ../imagery/i.landsat.toar/main.c:576
 #, fuzzy, c-format
@@ -3883,7 +3883,7 @@
 #, fuzzy
 msgid "temperature"
 #: ../imagery/i.landsat.toar/landsat.c:116
 msgid ""
@@ -3895,7 +3895,7 @@
 #: ../imagery/i.landsat.toar/landsat_met.c:117
 #, fuzzy, c-format
 msgid "Metadata file <%s> not found"
-msgstr "Arquivo 3dview  <%s> não encontrado"
+msgstr "Arquivo 3dview  <%s> não encontrado"
 #: ../imagery/i.rectify/rectify.c:41
 #: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:42
@@ -3907,19 +3907,19 @@
 #: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:46
 #, fuzzy, c-format
 msgid "into  <%s@%s> (location <%s>) ..."
-msgstr "Grupo [%s] destinado para locação [%s], mapset [%s]\n"
+msgstr "Grupo [%s] destinado para locação [%s], mapset [%s]\n"
 #: ../imagery/i.rectify/rectify.c:108
 #: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:126
 #, fuzzy, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
-msgstr "mapa vetorial <%s> não encontrado"
+msgstr "mapa vetorial <%s> não encontrado"
 #: ../imagery/i.rectify/rectify.c:114
 #: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:132
 #, fuzzy, c-format
 msgid "Raster map <%s@%s>: zone don't match current settings"
 #: ../imagery/i.rectify/get_wind.c:124
 #, c-format
@@ -3931,7 +3931,7 @@
 msgid "Resolution EW=%f NS=%f"
 msgstr ""
 "\n"
-"Resolução = %d; período = %d"
+"Resolução = %d; período = %d"
 #: ../imagery/i.rectify/report.c:10
 #: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:10
@@ -3975,21 +3975,21 @@
 #: ../vector/v.rectify/target.c:18
 #, fuzzy, c-format
 msgid "Target information for group <%s> missing"
-msgstr "Informação de limites para [%s] indisponível"
+msgstr "Informação de limites para [%s] indisponível"
 #: ../imagery/i.rectify/target.c:20
 #: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:19
 #: ../vector/v.rectify/target.c:29
 #, fuzzy, c-format
 msgid "Target location <%s> not found"
-msgstr "região <%s> não encontrada"
+msgstr "região <%s> não encontrada"
 #: ../imagery/i.rectify/target.c:32
 #: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:31
 #: ../raster/r.in.gdal/main.c:947 ../vector/v.rectify/target.c:40
 #, c-format
 msgid "Mapset <%s> in target location <%s> - "
-msgstr "conjunto de mapas <%s> na locação destino <%s> - "
+msgstr "conjunto de mapas <%s> na locação destino <%s> - "
 #: ../imagery/i.rectify/target.c:33
 #: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:32
@@ -4003,7 +4003,7 @@
 #: ../raster/r.proj/main.c:282 ../raster/r.in.gdal/main.c:950
 #: ../vector/v.rectify/target.c:41
 msgid "not found"
-msgstr "não encontrado"
+msgstr "não encontrado"
 #: ../imagery/i.rectify/target.c:36
 msgid "Please run i.target for group "
@@ -4012,7 +4012,7 @@
 #: ../imagery/i.rectify/cp.c:14 ../vector/v.rectify/cp.c:350
 #, fuzzy, c-format
 msgid "Control Point file for group <%s@%s> - "
-msgstr "Não consegui abrir o arquivo [%s]"
+msgstr "Não consegui abrir o arquivo [%s]"
 #: ../imagery/i.rectify/cp.c:21
 #, fuzzy, c-format
@@ -4023,25 +4023,25 @@
 #: ../vector/v.rectify/cp.c:363
 #, fuzzy
 msgid "Poorly placed control points."
-msgstr "Não pontos"
+msgstr "Não pontos"
 #: ../imagery/i.rectify/cp.c:25 ../imagery/i.rectify/cp.c:52
 #: ../vector/v.rectify/cp.c:364
 #, fuzzy
 msgid " Can not generate the transformation equation."
-msgstr "Não consegui obter informações da camada para o mapa vetorial"
+msgstr "Não consegui obter informações da camada para o mapa vetorial"
 #: ../imagery/i.rectify/cp.c:28 ../imagery/i.rectify/cp.c:55
 #: ../vector/v.rectify/cp.c:367
 #, fuzzy
 msgid "Not enough memory to solve for transformation equation"
 #: ../imagery/i.rectify/cp.c:31 ../imagery/i.rectify/cp.c:58
 #: ../vector/v.rectify/cp.c:370
 #, fuzzy
 msgid "Invalid order"
-msgstr "Coordenadas inválidas %s %s"
+msgstr "Coordenadas inválidas %s %s"
 #: ../imagery/i.rectify/cp.c:47 ../vector/v.rectify/cp.c:359
 #, fuzzy, c-format
@@ -4059,19 +4059,19 @@
 "Rectifies an image by computing a coordinate transformation for each pixel "
 "in the image based on the control points."
 msgstr ""
-"Retifica uma imagem por transformação das coordenadas de cada pixel da "
+"Retifica uma imagem por transformação das coordenadas de cada pixel da "
 "imagem a partir de pontos de controle."
 #: ../imagery/i.rectify/main.c:116
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:103
 #, fuzzy
 msgid "Output raster map(s) suffix"
-msgstr "Mapa raster de saída"
+msgstr "Mapa raster de saída"
 #: ../imagery/i.rectify/main.c:124 ../vector/v.rectify/main.c:102
 #, fuzzy
 msgid "Rectification polynomial order (1-3)"
-msgstr "Ordem do polinômio de retificação (1-3)"
+msgstr "Ordem do polinômio de retificação (1-3)"
 #: ../imagery/i.rectify/main.c:130
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:109
@@ -4082,14 +4082,14 @@
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:117
 #, fuzzy
 msgid "Amount of memory to use in MB"
-msgstr "Memória Esgotada! (Out of Memory)"
+msgstr "Memória Esgotada! (Out of Memory)"
 #: ../imagery/i.rectify/main.c:148
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:127
 #: ../raster/r.proj/main.c:182
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
 msgid "Interpolation method to use"
 #: ../imagery/i.rectify/main.c:153
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:137
@@ -4097,8 +4097,8 @@
 msgid ""
 "Use current region settings in target location (def.=calculate smallest area)"
 msgstr ""
-"Usa as definições da região atual na locação alvo (padrão: calcular a menor "
-"área)"
+"Usa as definições da região atual na locação alvo (padrão: calcular a menor "
+"área)"
 #: ../imagery/i.rectify/main.c:157
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:141
@@ -4126,7 +4126,7 @@
 #: ../imagery/i.rectify/main.c:206
 #, fuzzy, c-format
 msgid "Location: %s"
 #: ../imagery/i.rectify/main.c:207
 #, fuzzy, c-format
@@ -4136,26 +4136,26 @@
 #: ../imagery/i.rectify/main.c:208
 #, fuzzy, c-format
 msgid "Group <%s> does not exist"
 #: ../imagery/i.rectify/main.c:212
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:187
 #, fuzzy, c-format
 msgid "Group <%s> contains no raster maps; run i.group"
-msgstr "Grupo [%s] não contém arquivos"
+msgstr "Grupo [%s] não contém arquivos"
 #: ../imagery/i.rectify/main.c:287
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:281
 #, fuzzy, c-format
 msgid "Extension <%s> is illegal"
-msgstr "[%s] é um nome ilegal"
+msgstr "[%s] é um nome ilegal"
 #: ../imagery/i.rectify/main.c:290
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:284
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:293
 #, fuzzy
 msgid "The following raster map already exists in"
-msgstr "O vetor '%s' já existe."
+msgstr "O vetor '%s' já existe."
 #: ../imagery/i.rectify/main.c:291
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:285
@@ -4204,7 +4204,7 @@
 #: ../raster/r.proj/readcell.c:129 ../raster/r.stats.zonal/main.c:482
 #, fuzzy
 msgid "Unable to open temporary file"
 #: ../imagery/i.rectify/readcell.c:64
 #: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:72
@@ -4235,7 +4235,7 @@
 #: ../raster/r.his/main.c:68 ../display/d.his/main.c:64
 #, fuzzy
 msgid "color transformation"
 #: ../imagery/i.his.rgb/main.c:52
 msgid ""
@@ -4261,17 +4261,17 @@
 #: ../imagery/i.his.rgb/main.c:70
 #, fuzzy
 msgid "Name for output raster map (red)"
 #: ../imagery/i.his.rgb/main.c:74
 #, fuzzy
 msgid "Name for output raster map (green)"
 #: ../imagery/i.his.rgb/main.c:78
 #, fuzzy
 msgid "Name for output raster map (blue)"
 #: ../imagery/i.group/main.c:53 ../imagery/i.target/main.c:46
 #: ../raster/r.compress/main.c:65
@@ -4388,12 +4388,12 @@
 #: ../general/g.region/main.c:143
 #, fuzzy
 msgid "Print in shell script style"
 #: ../imagery/i.group/main.c:109
 #, fuzzy
 msgid "No input raster map(s) specified"
-msgstr "Mapa(s) de entrada não especificado(s)."
+msgstr "Mapa(s) de entrada não especificado(s)."
 #: ../imagery/i.group/main.c:117 ../imagery/i.target/main.c:80
 #, fuzzy
@@ -4403,7 +4403,7 @@
 #: ../imagery/i.group/main.c:128 ../imagery/i.group/main.c:150
 #, fuzzy
 msgid "Specified group does not exist in current mapset"
-msgstr "Grupo especificado não existe ... Saindo."
+msgstr "Grupo especificado não existe ... Saindo."
 #: ../imagery/i.group/main.c:132
 #, fuzzy, c-format
@@ -4418,17 +4418,17 @@
 #: ../imagery/i.group/main.c:158
 #, fuzzy, c-format
 msgid "Subgroup <%s> of group <%s> references the following raster maps:"
 #: ../imagery/i.group/main.c:173
 #, fuzzy, c-format
 msgid "Group <%s> references the following raster maps:"
-msgstr "Subgrupo [%s] não possui nenhum arquivo"
+msgstr "Subgrupo [%s] não possui nenhum arquivo"
 #: ../imagery/i.group/main.c:185
 #, fuzzy, c-format
 msgid "Group <%s> does not yet exist. Creating..."
-msgstr "grupo [%s] - ainda não existe. Criando ..."
+msgstr "grupo [%s] - ainda não existe. Criando ..."
 #: ../imagery/i.group/main.c:189 ../imagery/i.group/main.c:198
 #, fuzzy, c-format
@@ -4443,12 +4443,12 @@
 #: ../imagery/i.group/main.c:219
 #, fuzzy
 msgid "No input raster maps defined"
 #: ../imagery/i.group/main.c:223 ../imagery/i.group/main.c:265
 #, fuzzy, c-format
 msgid "Raster map <%s> not found. Skipped."
 #: ../imagery/i.group/main.c:228
 #, fuzzy, c-format
@@ -4473,12 +4473,12 @@
 #: ../imagery/i.group/main.c:327
 #, fuzzy, c-format
 msgid "Removing raster map <%s> from group"
 #: ../imagery/i.group/main.c:344 ../imagery/i.group/main.c:403
 #, fuzzy
 msgid "No raster map removed"
-msgstr "Arquivo raster binário a importar"
+msgstr "Arquivo raster binário a importar"
 #: ../imagery/i.group/main.c:386
 #, fuzzy, c-format
@@ -4488,12 +4488,12 @@
 #: ../imagery/i.group/main.c:422
 #, fuzzy, c-format
 msgid "Group <%s> does not contain any subgroup.\n"
 #: ../imagery/i.group/main.c:433
 #, fuzzy, c-format
 msgid "group <%s> references the following subgroups\n"
 #: ../imagery/i.biomass/main.c:51
 msgid "biomass"
@@ -4540,7 +4540,7 @@
 #: ../imagery/i.biomass/main.c:87
 #, fuzzy
 msgid "Name for output daily biomass growth raster map [kg/ha/d]"
 #: ../imagery/i.evapo.time/main.c:79
 msgid ""
@@ -4585,18 +4585,18 @@
 #: ../imagery/i.evapo.time/main.c:151
 #, fuzzy, c-format
 msgid "Too many ETa files. Only %d allowed."
-msgstr "correção"
+msgstr "correção"
 #: ../imagery/i.evapo.time/main.c:162 ../imagery/i.evapo.time/main.c:178
 #: ../imagery/i.evapo.time/main.c:200
 #, fuzzy
 msgid "The min specified input map is two"
 #: ../imagery/i.evapo.time/main.c:167
 #, fuzzy, c-format
 msgid "Too many ETa_doy files. Only %d allowed."
-msgstr "correção"
+msgstr "correção"
 #: ../imagery/i.evapo.time/main.c:183
 msgid "ETa and ETa_DOY file numbers are not equal!"
@@ -4605,12 +4605,12 @@
 #: ../imagery/i.evapo.time/main.c:189
 #, fuzzy, c-format
 msgid "Too many ETo files. Only %d allowed."
-msgstr "correção"
+msgstr "correção"
 #: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:81
 #, fuzzy
 msgid "Name of input file containing signatures"
 #: ../imagery/i.smap/parse.c:21
 msgid "Generated by i.gensigset"
@@ -4624,7 +4624,7 @@
 #: ../imagery/i.smap/parse.c:33
 #, fuzzy
 msgid "Name for output raster map holding goodness of fit (lower is better)"
-msgstr "Mapa de saída no qual os erros serão gravados"
+msgstr "Mapa de saída no qual os erros serão gravados"
 #: ../imagery/i.smap/parse.c:37
 #, fuzzy
@@ -4633,12 +4633,12 @@
 #: ../imagery/i.smap/parse.c:45
 msgid "Use maximum likelihood estimation (instead of smap)"
-msgstr "Usar estimativa por máxima verossimilhança (em vez de smap)"
+msgstr "Usar estimativa por máxima verossimilhança (em vez de smap)"
 #: ../imagery/i.smap/segment.c:67
 #, fuzzy
 msgid "Number of classes must be < 256"
-msgstr "Número de classes deve ser < 256!"
+msgstr "Número de classes deve ser < 256!"
 #: ../imagery/i.smap/segment.c:102
 #, fuzzy, c-format
@@ -4648,15 +4648,15 @@
 #: ../imagery/i.smap/main.c:41 ../imagery/i.segment/main.c:37
 #, fuzzy
 msgid "segmentation"
-msgstr "Resolução"
+msgstr "Resolução"
 #: ../imagery/i.smap/main.c:44
 msgid ""
 "Performs contextual image classification using sequential maximum a "
 "posteriori (SMAP) estimation."
 msgstr ""
-"Efetua uma classificação contextual da imagem usando estimação sequencial "
-"máxima a posteriori (SMAP)."
+"Efetua uma classificação contextual da imagem usando estimação sequencial "
+"máxima a posteriori (SMAP)."
 #: ../imagery/i.smap/write_img.c:15
 #, fuzzy
@@ -4668,45 +4668,45 @@
 #: ../raster/r.texture/h_measure.c:594 ../raster/r.walk/main.c:808
 #, fuzzy
 msgid "Unable to allocate memory"
 #: ../imagery/i.smap/interp.c:233
 #, fuzzy
 msgid "Invalid parameter values"
-msgstr "interp: valores de parâmetro inválidos."
+msgstr "interp: valores de parâmetro inválidos."
 #: ../imagery/i.smap/model.c:43
 #, fuzzy, c-format
 msgid "Nonsymetric covariance for class %d subclass %d"
 msgstr ""
 "\n"
-"Variância assimétrica para classe [%d] subclasse [%d]."
+"Variância assimétrica para classe [%d] subclasse [%d]."
 #: ../imagery/i.smap/model.c:55
 #, fuzzy, c-format
 msgid "Nonpositive eigenvalues for class %d subclass %d"
-msgstr "Eigen valores não-positivos para classe [%d] subclasse [%d]."
+msgstr "Eigen valores não-positivos para classe [%d] subclasse [%d]."
 #: ../imagery/i.smap/openfiles.c:22 ../imagery/i.smap/read_sig.c:17
 #, fuzzy, c-format
 msgid "Subgroup <%s> in group <%s> contains no raster maps"
 #: ../imagery/i.smap/read_sig.c:23 ../imagery/i.maxlik/open.c:53
 #: ../imagery/i.cluster/open_files.c:60
 #, fuzzy, c-format
 msgid "Unable to read signature file <%s>"
 #: ../imagery/i.smap/read_sig.c:27
 #, fuzzy, c-format
 msgid "Signature file <%s> is invalid"
-msgstr "Arquivo de assinatura [%s] inválido."
+msgstr "Arquivo de assinatura [%s] inválido."
 #: ../imagery/i.smap/read_sig.c:30
 #, fuzzy, c-format
 msgid "Signature file <%s> is empty"
 #: ../imagery/i.rgb.his/main.c:52
 msgid ""
@@ -4732,17 +4732,17 @@
 #: ../imagery/i.rgb.his/main.c:70
 #, fuzzy
 msgid "Name for output raster map (hue)"
 #: ../imagery/i.rgb.his/main.c:74
 #, fuzzy
 msgid "Name for output raster map (intensity)"
 #: ../imagery/i.rgb.his/main.c:78
 #, fuzzy
 msgid "Name for output raster map (saturation)"
-msgstr "Título do raster de saída"
+msgstr "Título do raster de saída"
 #: ../imagery/i.pca/main.c:74
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:8
@@ -4753,14 +4753,14 @@
 #, fuzzy
 msgid "principal components analysis"
 msgstr ""
 "imagens."
 #: ../imagery/i.pca/main.c:76
 #, fuzzy
 msgid "Principal components analysis (PCA) for image processing."
 msgstr ""
 "imagens."
 #: ../imagery/i.pca/main.c:82
@@ -4776,17 +4776,17 @@
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:8
 #, fuzzy
 msgid "Name for output basename raster map(s)"
 #: ../imagery/i.pca/main.c:87
 #, fuzzy
 msgid "A numerical suffix will be added for each component map"
-msgstr "Número de níveis a usar para componente"
+msgstr "Número de níveis a usar para componente"
 #: ../imagery/i.pca/main.c:96
 #, fuzzy
 msgid "Rescaling range for output maps"
-msgstr "Resolução do mapa de saída"
+msgstr "Resolução do mapa de saída"
 #: ../imagery/i.pca/main.c:98
 msgid "For no rescaling use 0,0"
@@ -4804,7 +4804,7 @@
 #: ../raster/r.mfilter/main.c:80 ../raster/r.mfilter/main.c:99
 #, fuzzy
 msgid "Filter"
 #: ../imagery/i.pca/main.c:113
 msgid "Normalize (center and scale) input maps"
@@ -4817,7 +4817,7 @@
 #: ../imagery/i.pca/main.c:118
 #, fuzzy
 msgid "Output will be filtered input bands"
-msgstr "Saída apenas em metros"
+msgstr "Saída apenas em metros"
 #: ../imagery/i.pca/main.c:119
 msgid "Apply inverse PCA after PCA"
@@ -4829,17 +4829,17 @@
 msgid "Group <%s> not found"
 msgstr ""
 "\n"
-"grupo <%s> não encontrado"
+"grupo <%s> não encontrado"
 #: ../imagery/i.pca/main.c:154
 #, fuzzy
 msgid "Sorry, at least 2 input bands must be provided"
-msgstr "Você precisa introduzir pelo menos quatro pontos %d."
+msgstr "Você precisa introduzir pelo menos quatro pontos %d."
 #: ../imagery/i.pca/main.c:169
 #, fuzzy, c-format
 msgid "'%s' must be positive"
 #: ../imagery/i.pca/main.c:171
 #, fuzzy, c-format
@@ -4849,7 +4849,7 @@
 #: ../imagery/i.pca/main.c:197 ../raster/r.covar/main.c:110
 #, fuzzy
 msgid "No non-null values"
-msgstr "Não"
+msgstr "Não"
 #: ../imagery/i.pca/main.c:233
 msgid "Not enough principal components left for filtering"
@@ -4864,23 +4864,23 @@
 #, fuzzy
 msgid "Scale range length should be > 0. Using default values: 0,255."
 msgstr ""
-"O intervalo da escala deve ser > 0. Utilizando os valores pré-definidos: "
+"O intervalo da escala deve ser > 0. Utilizando os valores pré-definidos: "
 "0,255"
 #: ../imagery/i.pca/main.c:343
 #, fuzzy
 msgid "Computing covariance matrix..."
-msgstr "Calculando matriz de covariância de classes..."
+msgstr "Calculando matriz de covariância de classes..."
 #: ../imagery/i.pca/main.c:456
 #, fuzzy, c-format
 msgid "Rescaling to range %d,%d..."
-msgstr "%s: Transformação da escala dos dados para o intervalo [%d,%d]:"
+msgstr "%s: Transformação da escala dos dados para o intervalo [%d,%d]:"
 #: ../imagery/i.pca/main.c:464
 #, fuzzy
 msgid "Calculating principal components..."
 #: ../imagery/i.pca/support.c:50
 msgid "Eigen values, (vectors), and [percent importance]:"
@@ -4910,7 +4910,7 @@
 #, fuzzy
 msgid "Computes evaporative fraction and root zone soil moisture."
 msgstr ""
 #: ../imagery/i.eb.evapfr/main.c:58 ../imagery/i.eb.soilheatflux/main.c:71
@@ -4935,7 +4935,7 @@
 #: ../imagery/i.eb.evapfr/main.c:71
 #, fuzzy
 msgid "Name for output evaporative fraction raster map"
 #: ../imagery/i.eb.evapfr/main.c:77
 #, fuzzy
@@ -4950,7 +4950,7 @@
 #, fuzzy
 msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
 msgstr ""
-"Transformada Inversa Rápida de Fourier (ifft) para processamento de imagens."
+"Transformada Inversa Rápida de Fourier (ifft) para processamento de imagens."
 #: ../imagery/i.ifft/main.c:86
 #, fuzzy
@@ -4960,7 +4960,7 @@
 #: ../imagery/i.ifft/main.c:90
 #, fuzzy
 msgid "Name of input raster map (image fft, imaginary part"
-msgstr "Arquivo raster de entrada (imagem FFT, parte imaginária)"
+msgstr "Arquivo raster de entrada (imagem FFT, parte imaginária)"
 #: ../imagery/i.ifft/main.c:93
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:14
@@ -4968,12 +4968,12 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:6
 #, fuzzy
 msgid "Name for output raster map"
 #: ../imagery/i.ifft/main.c:115
 #, fuzzy
 msgid "The real and imaginary original windows did not match"
-msgstr "A partes reais e imaginárias não combinam."
+msgstr "A partes reais e imaginárias não combinam."
 #: ../imagery/i.ifft/main.c:157
 #, fuzzy
@@ -4994,7 +4994,7 @@
 #: ../imagery/i.gensig/means.c:26
 #, fuzzy
 msgid "Calculating class means..."
 #: ../imagery/i.gensig/main.c:42 ../imagery/i.maxlik/main.c:63
 msgid "Maximum Likelihood Classification"
@@ -5003,31 +5003,31 @@
 #: ../imagery/i.gensig/main.c:46
 #, fuzzy
 msgid "Generates statistics for i.maxlik from raster map."
 #: ../imagery/i.gensig/covariance.c:30
 msgid "Calculating class covariance matrices..."
-msgstr "Calculando matrizes de covariância de classes..."
+msgstr "Calculando matrizes de covariância de classes..."
 #: ../imagery/i.gensig/check.c:21
 #, fuzzy, c-format
 msgid "Signature %d not invertible"
-msgstr "Assinatura [%d] não inversível."
+msgstr "Assinatura [%d] não inversível."
 #: ../imagery/i.gensig/check.c:27
 #, fuzzy, c-format
 msgid "Signature %d unable to get eigen values"
-msgstr "Assinatura [%d] não consegui obter eigen valores."
+msgstr "Assinatura [%d] não consegui obter eigen valores."
 #: ../imagery/i.gensig/check.c:33
 #, fuzzy, c-format
 msgid "Signature %d not positive definite"
-msgstr "Assinatura [%d] não é positiva definida"
+msgstr "Assinatura [%d] não é positiva definida"
 #: ../imagery/i.segment/rclist.c:17 ../raster/r.clump/rclist.c:17
 #, fuzzy
 msgid "rclist out of memory"
 #: ../imagery/i.segment/region_growing.c:93 ../imagery/i.segment/cluster.c:342
 #: ../imagery/i.segment/cluster.c:412
@@ -5038,7 +5038,7 @@
 #: ../imagery/i.segment/mean_shift.c:220
 #, fuzzy, c-format
 msgid "Processing pass %d..."
-msgstr "Processando áreas de entradaA ..."
+msgstr "Processando áreas de entradaA ..."
 #: ../imagery/i.segment/region_growing.c:529
 #, c-format
@@ -5074,7 +5074,7 @@
 #: ../imagery/i.segment/region_growing.c:983
 #, fuzzy, c-format
 msgid "Region id %d is invalid"
 #: ../imagery/i.segment/region_growing.c:987
 msgid "Region consists of only one cell, nothing to update"
@@ -5084,7 +5084,7 @@
 #: ../imagery/i.segment/region_growing.c:1485
 #, fuzzy, c-format
 msgid "Region size is larger than 2: %d"
-msgstr "O tamanho da região é menor que minreg, nada a exibir."
+msgstr "O tamanho da região é menor que minreg, nada a exibir."
 #: ../imagery/i.segment/region_growing.c:1098
 #, c-format
@@ -5094,12 +5094,12 @@
 #: ../imagery/i.segment/region_growing.c:1340
 #, fuzzy, c-format
 msgid "Candidate flag is already %s"
-msgstr "Arquivo dig_att já existe."
+msgstr "Arquivo dig_att já existe."
 #, fuzzy
 msgid "set"
-msgstr "Resolução"
+msgstr "Resolução"
 msgid "unset"
@@ -5113,24 +5113,24 @@
 #: ../imagery/i.segment/open_files.c:39
 #, fuzzy, c-format
 msgid "Group <%s> not found in the current mapset"
 #: ../imagery/i.segment/open_files.c:43
 #, fuzzy, c-format
 msgid "Group <%s> contains no raster maps"
 #: ../imagery/i.segment/open_files.c:71 ../imagery/i.segment/open_files.c:238
 #: ../imagery/i.segment/open_files.c:246
 #: ../imagery/i.segment/write_output.c:112 ../raster/r.clump/clump.c:449
 #, fuzzy, c-format
 msgid "No min/max found in raster map <%s>"
-msgstr "Coluna <%s> não encontrada"
+msgstr "Coluna <%s> não encontrada"
 #: ../imagery/i.segment/open_files.c:120
 #, fuzzy
 msgid "Insufficient number of non-NULL cells in current region"
-msgstr "Mostra a região atual"
+msgstr "Mostra a região atual"
 #: ../imagery/i.segment/open_files.c:151
 #, fuzzy
@@ -5148,7 +5148,7 @@
 #: ../imagery/i.segment/open_files.c:480
 #, fuzzy
 msgid "Unable to write to temporary file"
 #: ../imagery/i.segment/open_files.c:277
 #, c-format
@@ -5163,7 +5163,7 @@
 #: ../imagery/i.segment/open_files.c:363
 #, fuzzy, c-format
 msgid "No seeds found in '%s'!"
-msgstr "Não consegui encontrar o mapa de entrada <%s>"
+msgstr "Não consegui encontrar o mapa de entrada <%s>"
 #: ../imagery/i.segment/open_files.c:383
 msgid "Too many seeds: integer overflow"
@@ -5201,7 +5201,7 @@
 #: ../imagery/i.segment/mean_shift.c:188 ../imagery/i.segment/mean_shift.c:192
 #, fuzzy, c-format
 msgid "Estimated range bandwidth: %g"
-msgstr "Usando máxima distância entre pontos: %f"
+msgstr "Usando máxima distância entre pontos: %f"
 #: ../imagery/i.segment/mean_shift.c:208 ../imagery/i.segment/mean_shift.c:245
 #, c-format
@@ -5271,7 +5271,7 @@
 #: ../imagery/i.segment/main.c:70
 #, fuzzy, c-format
 msgid "Number of segments created: %d"
-msgstr "Número de pontos para criar"
+msgstr "Número de pontos para criar"
 #: ../imagery/i.segment/write_output.c:24
 #, fuzzy
@@ -5290,13 +5290,13 @@
 #: ../imagery/i.segment/cluster.c:66
 #, fuzzy, c-format
 msgid "%d-band clustering with threshold %g"
-msgstr "%d pontos além do limite"
+msgstr "%d pontos além do limite"
 #: ../imagery/i.segment/cluster.c:121 ../raster/r.clump/minsize.c:373
 #: ../raster/r.clump/clump.c:211 ../raster/r.clump/clump.c:475
 #, fuzzy
 msgid "Unable to open temp file"
-msgstr "Não consegui abrir arquivo de saída."
+msgstr "Não consegui abrir arquivo de saída."
 #: ../imagery/i.segment/cluster.c:135
 msgid "Assigning initial region IDs..."
@@ -5309,7 +5309,7 @@
 #: ../raster/r.clump/clump.c:660
 #, fuzzy
 msgid "Unable to write to temp file"
 #: ../imagery/i.segment/cluster.c:386 ../raster/r.clump/clump.c:51
 #: ../vector/v.cluster/main.c:404 ../vector/v.cluster/main.c:613
@@ -5329,7 +5329,7 @@
 #: ../raster/r.clump/clump.c:97 ../raster/r.clump/clump.c:149
 #, fuzzy
 msgid "Unable to read from temp file"
-msgstr "Não consegui ler arquivo de cores."
+msgstr "Não consegui ler arquivo de cores."
 #: ../imagery/i.segment/cluster.c:455
 #, fuzzy, c-format
@@ -5341,12 +5341,12 @@
 #: ../vector/v.distance/main.c:1033
 #, fuzzy
 msgid "Out of memory!"
 #: ../imagery/i.segment/watershed.c:19
 #, fuzzy
 msgid "Watershed is not yet implemented"
 #: ../imagery/i.segment/parse_args.c:30
 msgid "Suffix for output bands with modified band values"
@@ -5363,7 +5363,7 @@
 #: ../imagery/i.segment/parse_args.c:46
 #, fuzzy
 msgid "Spatial radius in number of cells"
-msgstr "Número de quadros"
+msgstr "Número de quadros"
 #: ../imagery/i.segment/parse_args.c:47
 msgid ""
@@ -5393,7 +5393,7 @@
 #: ../imagery/i.segment/parse_args.c:85
 #, fuzzy
 msgid "Minimum number of cells in a segment"
-msgstr "Número máximo de pontos num segmento"
+msgstr "Número máximo de pontos num segmento"
 #: ../imagery/i.segment/parse_args.c:87
 msgid "The final step will merge small segments with their best neighbor"
@@ -5413,7 +5413,7 @@
 #: ../imagery/i.segment/parse_args.c:126 ../imagery/i.cluster/main.c:126
 msgid "Maximum number of iterations"
 #: ../imagery/i.segment/parse_args.c:134
 #, fuzzy
@@ -5471,7 +5471,7 @@
 #: ../imagery/i.segment/parse_args.c:200
 #, fuzzy, c-format
 msgid "Option '%s' must be >= 1"
-msgstr "Locação: %s\n"
+msgstr "Locação: %s\n"
 #: ../imagery/i.segment/parse_args.c:208
 #, c-format
@@ -5486,32 +5486,32 @@
 #: ../imagery/i.segment/parse_args.c:235
 #, fuzzy
 msgid "Unable to assign segmentation method"
-msgstr "Não consegui escrever o arquivo temporário."
+msgstr "Não consegui escrever o arquivo temporário."
 #: ../imagery/i.segment/parse_args.c:245
 #, fuzzy
 msgid "Invalid similarity method"
-msgstr "Fonte inválida: %s"
+msgstr "Fonte inválida: %s"
 #: ../imagery/i.segment/parse_args.c:251
 #, fuzzy, c-format
 msgid "Option '%s' must be > 0"
 #: ../imagery/i.segment/parse_args.c:253 ../imagery/i.segment/parse_args.c:258
 #, fuzzy, c-format
 msgid "Option '%s' must be <= 1"
 #: ../imagery/i.segment/parse_args.c:256
 #, fuzzy, c-format
 msgid "Option '%s' must be >= 0"
 #: ../imagery/i.segment/parse_args.c:284
 #, fuzzy
 msgid "Seeds raster map not found"
-msgstr "%s: <%s> mapa raster não encontrado"
+msgstr "%s: <%s> mapa raster não encontrado"
 #: ../imagery/i.segment/parse_args.c:288
 #, fuzzy
@@ -5521,7 +5521,7 @@
 #: ../imagery/i.segment/parse_args.c:298
 #, fuzzy
 msgid "Segmentation constraint/boundary raster map not found"
 #: ../imagery/i.segment/parse_args.c:302
 msgid "Segmentation constraint raster map must be CELL type (integers)"
@@ -5530,7 +5530,7 @@
 #: ../imagery/i.segment/parse_args.c:321
 #, fuzzy
 msgid "Integer overflow: too many cells in current region"
 #: ../imagery/i.segment/parse_args.c:334
 msgid "Invalid output raster name for goodness of fit"
@@ -5539,27 +5539,27 @@
 #: ../imagery/i.segment/parse_args.c:341
 #, fuzzy, c-format
 msgid "Maximum number of iterations set to %d"
-msgstr "Número máximo de iterações: %d\n"
+msgstr "Número máximo de iterações: %d\n"
 #: ../imagery/i.segment/parse_args.c:351
 #, fuzzy, c-format
 msgid "Invalid number of iterations, %d will be used"
 #: ../imagery/i.segment/parse_args.c:360
 #, fuzzy
 msgid "Invalid number of MB, 300 will be used"
 #: ../imagery/i.vi/main.c:90
 #, fuzzy
 msgid "vegetation index"
-msgstr "Nome do mapa raster de elevação"
+msgstr "Nome do mapa raster de elevação"
 #: ../imagery/i.vi/main.c:91
 #, fuzzy
 msgid "biophysical parameters"
-msgstr "Parâmetro de suavização"
+msgstr "Parâmetro de suavização"
 #: ../imagery/i.vi/main.c:93
 msgid "Calculates different types of vegetation indices."
@@ -5584,37 +5584,37 @@
 #: ../imagery/i.vi/main.c:110
 #, fuzzy
 msgid "Type of vegetation index"
 #: ../imagery/i.vi/main.c:115
 #, fuzzy
 msgid "Atmospherically Resistant Vegetation Index"
 #: ../imagery/i.vi/main.c:116
 #, fuzzy
 msgid "Difference Vegetation Index"
 #: ../imagery/i.vi/main.c:117
 #, fuzzy
 msgid "Enhanced Vegetation Index"
 #: ../imagery/i.vi/main.c:118
 #, fuzzy
 msgid "Enhanced Vegetation Index 2"
 #: ../imagery/i.vi/main.c:119
 #, fuzzy
 msgid "Green Vegetation Index"
 #: ../imagery/i.vi/main.c:120
 #, fuzzy
 msgid "Green Atmospherically Resistant Vegetation Index"
 #: ../imagery/i.vi/main.c:121
 msgid "Global Environmental Monitoring Index"
@@ -5623,7 +5623,7 @@
 #: ../imagery/i.vi/main.c:122
 #, fuzzy
 msgid "Infrared Percentage Vegetation Index"
 #: ../imagery/i.vi/main.c:123
 msgid "Modified Soil Adjusted Vegetation Index"
@@ -5636,22 +5636,22 @@
 #: ../imagery/i.vi/main.c:125
 #, fuzzy
 msgid "Normalized Difference Vegetation Index"
 #: ../imagery/i.vi/main.c:126
 #, fuzzy
 msgid "Perpendicular Vegetation Index"
 #: ../imagery/i.vi/main.c:127
 #, fuzzy
 msgid "Soil Adjusted Vegetation Index"
 #: ../imagery/i.vi/main.c:128
 #, fuzzy
 msgid "Simple Ratio"
 #: ../imagery/i.vi/main.c:129
 msgid "Visible Atmospherically Resistant Index"
@@ -5660,12 +5660,12 @@
 #: ../imagery/i.vi/main.c:130
 #, fuzzy
 msgid "Weighted Difference Vegetation Index"
 #: ../imagery/i.vi/main.c:134
 #, fuzzy
 msgid "type"
 #: ../imagery/i.vi/main.c:140
 #, fuzzy
@@ -5678,7 +5678,7 @@
 #: ../vector/v.vol.rst/main.c:303
 #, fuzzy
 msgid "Optional inputs"
-msgstr "Nome ilegal do arquivo de saída"
+msgstr "Nome ilegal do arquivo de saída"
 #: ../imagery/i.vi/main.c:148
 #, fuzzy
@@ -5721,7 +5721,7 @@
 #: ../imagery/i.vi/main.c:201
 #, fuzzy
 msgid "Maximum bits for digital numbers"
-msgstr "Máximo circular mapear em"
+msgstr "Máximo circular mapear em"
 #: ../imagery/i.vi/main.c:202
 msgid ""
@@ -5732,7 +5732,7 @@
 #: ../imagery/i.vi/main.c:225
 #, fuzzy, c-format
 msgid "Calculating %s..."
 #: ../imagery/i.vi/main.c:228
 msgid "sr index requires red and nir maps"
@@ -5810,7 +5810,7 @@
 "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
 "have at least 2 raster maps."
 msgstr ""
-"Subgrupo [%s] do grupo [%s] não possui arquivos.\n"
+"Subgrupo [%s] do grupo [%s] não possui arquivos.\n"
 "O subgrupo deve ter ao menos 2 arquivos."
 #: ../imagery/i.maxlik/open.c:30
@@ -5825,12 +5825,12 @@
 #: ../imagery/i.maxlik/open.c:47
 #, fuzzy, c-format
 msgid "Unable to open signature file <%s>"
-msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
+msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
 #: ../imagery/i.maxlik/open.c:57 ../imagery/i.cluster/open_files.c:64
 #, fuzzy, c-format
 msgid "<%s> has too many signatures (limit is 255)"
-msgstr "** <%s> tem assinaturas demais (limite é 255)"
+msgstr "** <%s> tem assinaturas demais (limite é 255)"
 #: ../imagery/i.maxlik/main.c:66
 msgid "Classifies the cell spectral reflectances in imagery data."
@@ -5842,15 +5842,15 @@
 "Classification is based on the spectral signature information generated by "
 "either i.cluster, g.gui.iclass, or i.gensig."
 msgstr ""
-"Uma função que classifica as reflectâncias espectrais em imagens baseado na "
-"informação de assinatura espectral gerada por i.cluster, i.class ou i.gensig."
+"Uma função que classifica as reflectâncias espectrais em imagens baseado na "
+"informação de assinatura espectral gerada por i.cluster, i.class ou i.gensig."
 #: ../imagery/i.maxlik/main.c:82
 #, fuzzy
 msgid "Generated by either i.cluster, g.gui.iclass, or i.gensig"
 msgstr ""
 #: ../imagery/i.maxlik/main.c:92
 #, fuzzy
@@ -5860,20 +5860,20 @@
 #: ../imagery/i.maxlik/invert.c:28
 #, fuzzy, c-format
 msgid "Signature %d is not valid (ill-conditioned) - ignored"
-msgstr "assinatura %d inválida (mal-condicionada) - ignorada."
+msgstr "assinatura %d inválida (mal-condicionada) - ignorada."
 #: ../imagery/i.maxlik/invert.c:31
 #, fuzzy, c-format
 msgid "Signature %d is not valid (singular) - ignored"
-msgstr "assinatura %d inválida (singular) - ignorada."
+msgstr "assinatura %d inválida (singular) - ignorada."
 #: ../imagery/i.target/main.c:48
 msgid "Targets an imagery group to a GRASS location and mapset."
-msgstr "Aponta um grupo de imagens para uma locação e mapset do GRASS."
+msgstr "Aponta um grupo de imagens para uma locação e mapset do GRASS."
 #: ../imagery/i.target/main.c:57
 msgid "Name of imagery target location"
-msgstr "Nome de destino da locação da imagem"
+msgstr "Nome de destino da locação da imagem"
 #: ../imagery/i.target/main.c:63
 msgid "Name of target mapset"
@@ -5881,13 +5881,13 @@
 #: ../imagery/i.target/main.c:68
 msgid "Set current location and mapset as target for imagery group"
-msgstr "Definir locação e mapset atuais como destino para um grupo de imagens"
+msgstr "Definir locação e mapset atuais como destino para um grupo de imagens"
 #: ../imagery/i.target/main.c:90 ../imagery/i.target/main.c:107
 #: ../imagery/i.target/main.c:116
 #, fuzzy, c-format
 msgid "Group <%s> targeted for location [%s], mapset [%s]"
 #: ../imagery/i.target/main.c:93
 #, c-format
@@ -5901,9 +5901,9 @@
 " OR\n"
 " manually enter the variables"
 msgstr ""
-"Você deve usar a opção de mapset e locação atuais (-c)\n"
+"Você deve usar a opção de mapset e locação atuais (-c)\n"
 " OU\n"
-" digitar as variáveis manualmente"
+" digitar as variáveis manualmente"
 #: ../imagery/i.modis.qc/main.c:150
 msgid "imagery quality assessment"
@@ -5912,12 +5912,12 @@
 #: ../imagery/i.modis.qc/main.c:152
 #, fuzzy
 msgid "land surface temperature"
-msgstr "Nome da superfície aleatória a produzir"
+msgstr "Nome da superfície aleatória a produzir"
 #: ../imagery/i.modis.qc/main.c:153
 #, fuzzy
 msgid "vegetation"
-msgstr "Resolução"
+msgstr "Resolução"
 #: ../imagery/i.modis.qc/main.c:155 ../imagery/i.albedo/main.c:102
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:5
@@ -5932,12 +5932,12 @@
 #: ../imagery/i.modis.qc/main.c:162
 #, fuzzy
 msgid "Name of input surface reflectance QC layer [bit array]"
-msgstr "Nome da camada raster da superfície fractal"
+msgstr "Nome da camada raster da superfície fractal"
 #: ../imagery/i.modis.qc/main.c:167
 #, fuzzy
 msgid "Name for output QC type classification layer"
 #: ../imagery/i.modis.qc/main.c:173
 #, fuzzy
@@ -6004,7 +6004,7 @@
 #: ../imagery/i.modis.qc/main.c:273
 #, fuzzy
 msgid "mod09: Atmospheric Correction"
 #: ../imagery/i.modis.qc/main.c:274
 msgid "mod09: Cloud State"
@@ -6276,7 +6276,7 @@
 #: ../imagery/i.modis.qc/main.c:375
 #, fuzzy
 msgid "Band number out of allowed range [1-2]"
 #: ../imagery/i.modis.qc/main.c:377 ../imagery/i.modis.qc/main.c:379
 #: ../imagery/i.modis.qc/main.c:381 ../imagery/i.modis.qc/main.c:383
@@ -6284,7 +6284,7 @@
 #: ../imagery/i.modis.qc/main.c:442
 #, fuzzy
 msgid "Band number out of allowed range [1-7]"
 #: ../imagery/i.modis.qc/main.c:389
 msgid "mod09Q1 product only has 2 bands"
@@ -6319,7 +6319,7 @@
 #: ../imagery/i.evapo.pm/main.c:65
 #, fuzzy
 msgid "Name of input elevation raster map [m a.s.l.]"
 #: ../imagery/i.evapo.pm/main.c:69
 #, fuzzy
@@ -6349,12 +6349,12 @@
 #: ../imagery/i.evapo.pm/main.c:89
 #, fuzzy
 msgid "Name for output raster map [mm/h]"
-msgstr "Nome do Raster de saída"
+msgstr "Nome do Raster de saída"
 #: ../imagery/i.evapo.pm/main.c:93
 #, fuzzy
 msgid "Set negative evapotranspiration to zero"
-msgstr "Número de pontos de interpolação"
+msgstr "Número de pontos de interpolação"
 #: ../imagery/i.evapo.pm/main.c:97
 msgid "Use Night-time"
@@ -6382,7 +6382,7 @@
 #: ../imagery/i.eb.netrad/main.c:75
 #, fuzzy
 msgid "Name of surface temperature raster map [K]"
 #: ../imagery/i.eb.netrad/main.c:80 ../imagery/i.eb.soilheatflux/main.c:76
 #, fuzzy
@@ -6422,7 +6422,7 @@
 #: ../imagery/i.eb.netrad/main.c:105
 #, fuzzy
 msgid "Name of the output net radiation layer"
 #: ../imagery/i.emissivity/main.c:45
 msgid "emissivity"
@@ -6444,7 +6444,7 @@
 #: ../imagery/i.emissivity/main.c:56
 #, fuzzy
 msgid "Name of the output emissivity layer"
 #: ../imagery/i.albedo/main.c:96
 #, fuzzy
@@ -6497,7 +6497,7 @@
 #: ../imagery/i.albedo/main.c:181
 #, fuzzy
 msgid "At least two raster maps are required"
 #: ../imagery/i.landsat.acca/main.c:70
 #, c-format
@@ -6513,7 +6513,7 @@
 #: ../imagery/i.landsat.acca/main.c:107
 #, fuzzy
 msgid "cloud detection"
-msgstr "Saída de mapa"
+msgstr "Saída de mapa"
 #: ../imagery/i.landsat.acca/main.c:121
 msgid "B56composite (step 6)"
@@ -6526,13 +6526,13 @@
 #: ../imagery/i.landsat.acca/main.c:136
 #, fuzzy
 msgid "Number of classes in the cloud temperature histogram"
-msgstr "Número de vezes para repetir o filtro"
+msgstr "Número de vezes para repetir o filtro"
 #: ../imagery/i.landsat.acca/main.c:138 ../imagery/i.landsat.acca/main.c:153
 #: ../imagery/i.landsat.acca/main.c:159 ../imagery/i.landsat.acca/main.c:164
 #, fuzzy
 msgid "Cloud settings"
 #: ../imagery/i.landsat.acca/main.c:142
 msgid "Data is Landsat-5 TM"
@@ -6609,7 +6609,7 @@
 #: ../imagery/i.landsat.acca/algorithm.c:149
 #, fuzzy, c-format
 msgid "* Standard deviation: %.2lf"
-msgstr "Desvio padrão"
+msgstr "Desvio padrão"
 #: ../imagery/i.landsat.acca/algorithm.c:150
 #, c-format
@@ -6639,7 +6639,7 @@
 #: ../imagery/i.landsat.acca/algorithm.c:186
 #, fuzzy
 msgid "Maximum temperature:"
 #: ../imagery/i.landsat.acca/algorithm.c:187
 #, c-format
@@ -6662,12 +6662,12 @@
 #: ../imagery/i.landsat.acca/algorithm.c:237
 #, fuzzy
 msgid "Processing first pass..."
 #: ../imagery/i.landsat.acca/algorithm.c:391
 #, fuzzy
 msgid "Removing ambiguous pixels..."
-msgstr "Removendo centróides duplicados ..."
+msgstr "Removendo centróides duplicados ..."
 #: ../imagery/i.landsat.acca/algorithm.c:393
 #, fuzzy
@@ -6689,7 +6689,7 @@
 #: ../imagery/i.eb.eta/main.c:52
 #, fuzzy
 msgid "Name of the diurnal net radiation map [W/m2]"
 #: ../imagery/i.eb.eta/main.c:57
 #, fuzzy
@@ -6699,12 +6699,12 @@
 #: ../imagery/i.eb.eta/main.c:62
 #, fuzzy
 msgid "Name of the surface skin temperature [K]"
 #: ../imagery/i.eb.eta/main.c:67
 #, fuzzy
 msgid "Name of the output actual evapotranspiration layer [mm/d]"
 #: ../imagery/i.cluster/print5.c:15
 #, fuzzy, c-format
@@ -6719,7 +6719,7 @@
 msgid "%sinitial means for each band%s%s"
 msgstr ""
 "\n"
-"média inicial para cada banda\n"
+"média inicial para cada banda\n"
 "\n"
 #: ../imagery/i.cluster/print3.c:20
@@ -6735,17 +6735,17 @@
 #: ../imagery/i.cluster/open_files.c:29
 #, fuzzy
 msgid "No raster maps found"
 #: ../imagery/i.cluster/open_files.c:33
 #, fuzzy, c-format
 msgid "Subgroup <%s> doesn't have any raster maps"
 #: ../imagery/i.cluster/open_files.c:36
 #, fuzzy, c-format
 msgid "Subgroup <%s> only has 1 raster map"
-msgstr "Subgrupo [%s] só contém 1 arquivo"
+msgstr "Subgrupo [%s] só contém 1 arquivo"
 #: ../imagery/i.cluster/open_files.c:37
 #, fuzzy
@@ -6755,7 +6755,7 @@
 #: ../imagery/i.cluster/open_files.c:54
 #, fuzzy, c-format
 msgid "Unable to open seed signature file <%s>"
 #: ../imagery/i.cluster/checkpt.c:16
 #, fuzzy, c-format
@@ -6767,22 +6767,22 @@
 msgid "%s######## iteration %d ###########%s"
 msgstr ""
 "\n"
-"######## iteração %d ###########\n"
+"######## iteração %d ###########\n"
 #: ../imagery/i.cluster/checkpt.c:31
 #, fuzzy, c-format
 msgid "%d classes, %.2f%% points stable%s"
-msgstr "%d classes, %.2f%% pontos estáveis\n"
+msgstr "%d classes, %.2f%% pontos estáveis\n"
 #: ../imagery/i.cluster/checkpt.c:42
 #, fuzzy, c-format
 msgid "Iteration %.2d: convergence %.2f%% (%s elapsed, %s left)"
-msgstr "Iteração %d: %% Convergência: %.2f (%s decorrido, %s restante)"
+msgstr "Iteração %d: %% Convergência: %.2f (%s decorrido, %s restante)"
 #: ../imagery/i.cluster/print4.c:16
 #, fuzzy, c-format
 msgid "class centroids (sum/count=mean)%s"
-msgstr "centróide da classe (soma/contagem = média)\n"
+msgstr "centróide da classe (soma/contagem = média)\n"
 #: ../imagery/i.cluster/print4.c:18
 #, c-format
@@ -6793,18 +6793,18 @@
 #, fuzzy, c-format
 msgid "means and standard deviations for %d band%s%s%s"
 msgstr ""
-"médias e desvio-padrões para %d banda %s\n"
+"médias e desvio-padrões para %d banda %s\n"
 "\n"
 #: ../imagery/i.cluster/print1.c:14
 #, c-format
 msgid " means  "
-msgstr " média  "
+msgstr " média  "
 #: ../imagery/i.cluster/print1.c:18
 #, c-format
 msgid " stddev "
-msgstr " desvio-padrão "
+msgstr " desvio-padrão "
 #: ../imagery/i.cluster/main.c:79
 msgid ""
@@ -6818,48 +6818,48 @@
 "The resulting signature file is used as input for i.maxlik, to generate an "
 "unsupervised image classification."
 msgstr ""
-"Uma função de imagens que gera assinaturas espectrais para tipos de "
+"Uma função de imagens que gera assinaturas espectrais para tipos de "
 "cobertura do solo usando um algoritmo de agrupamento. A assinatura "
-"resultante é usada como entrada para i.maxlik, para gerar uma classificação "
-"não-supervisionada da imagem."
+"resultante é usada como entrada para i.maxlik, para gerar uma classificação "
+"não-supervisionada da imagem."
 #: ../imagery/i.cluster/main.c:102
 msgid "Initial number of classes"
-msgstr "Número inicial de classes"
+msgstr "Número inicial de classes"
 #: ../imagery/i.cluster/main.c:111
 #, fuzzy
 msgid "Name of file containing initial signatures"
-msgstr "Arquivo contendo declarações SQL"
+msgstr "Arquivo contendo declarações SQL"
 #: ../imagery/i.cluster/main.c:119
 msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
 msgstr ""
-"Intervalos de amostragem (por linhas e colunas); padrão: ~10.000 pixels"
+"Intervalos de amostragem (por linhas e colunas); padrão: ~10.000 pixels"
 #: ../imagery/i.cluster/main.c:135
 msgid "Percent convergence"
-msgstr "Convergência percentual"
+msgstr "Convergência percentual"
 #: ../imagery/i.cluster/main.c:143
 msgid "Cluster separation"
-msgstr "Separação dos agrupamentos (clusters)"
+msgstr "Separação dos agrupamentos (clusters)"
 #: ../imagery/i.cluster/main.c:151
 msgid "Minimum number of pixels in a class"
 #: ../imagery/i.cluster/main.c:158
 #, fuzzy
 msgid "Name for output file containing final report"
 #: ../imagery/i.cluster/main.c:192
 #, fuzzy, c-format
 msgid "Illegal number of initial classes (%s)"
 msgstr ""
 "\n"
-"<%s> -- número ilegal de classes iniciais"
+"<%s> -- número ilegal de classes iniciais"
 #: ../imagery/i.cluster/main.c:203
 #, fuzzy, c-format
@@ -6873,21 +6873,21 @@
 msgid "Illegal value of iterations (%s)"
 msgstr ""
 "\n"
-"<%s> -- número ilegal de iterações"
+"<%s> -- número ilegal de iterações"
 #: ../imagery/i.cluster/main.c:223
 #, fuzzy, c-format
 msgid "Illegal value of convergence (%s)"
 msgstr ""
 "\n"
-"<%s> -- valor ilegal de convergência"
+"<%s> -- valor ilegal de convergência"
 #: ../imagery/i.cluster/main.c:228
 #, fuzzy, c-format
 msgid "Illegal value of separation (%s)"
 msgstr ""
 "\n"
-"<%s> -- valor ilegal de separação"
+"<%s> -- valor ilegal de separação"
 #: ../imagery/i.cluster/main.c:233
 #, fuzzy, c-format
@@ -6897,7 +6897,7 @@
 #: ../imagery/i.cluster/main.c:242
 #, fuzzy, c-format
 msgid "Unable to create report file <%s>"
-msgstr "Não consegui criar arquivo [%s]"
+msgstr "Não consegui criar arquivo [%s]"
 #: ../imagery/i.cluster/main.c:250
 #, fuzzy, c-format
@@ -6909,7 +6909,7 @@
 #: ../imagery/i.cluster/main.c:252
 #, fuzzy, c-format
 msgid "Location: %s%s"
 #: ../imagery/i.cluster/main.c:253
 #, fuzzy, c-format
@@ -6939,7 +6939,7 @@
 #: ../imagery/i.cluster/main.c:262
 #, fuzzy, c-format
 msgid "Region%s"
-msgstr "Região\n"
+msgstr "Região\n"
 #: ../imagery/i.cluster/main.c:263
 #, fuzzy, c-format
@@ -6959,22 +6959,22 @@
 #: ../imagery/i.cluster/main.c:269
 #, fuzzy, c-format
 msgid "  Rows:  %12d  Cols: %12d  Cells: %d%s"
-msgstr "  Linhas:  %12d  Cols: %12d  Céls: %d\n"
+msgstr "  Linhas:  %12d  Cols: %12d  Céls: %d\n"
 #: ../imagery/i.cluster/main.c:271
 #, fuzzy, c-format
 msgid "Mask: %s%s"
-msgstr "Máscara: %s\n"
+msgstr "Máscara: %s\n"
 #: ../imagery/i.cluster/main.c:273
 #, fuzzy, c-format
 msgid "Cluster parameters%s"
-msgstr "Parâmetros do agrupamento\n"
+msgstr "Parâmetros do agrupamento\n"
 #: ../imagery/i.cluster/main.c:274
 #, c-format
 msgid " Number of initial classes:    %d"
-msgstr " Número de classes iniciais:    %d"
+msgstr " Número de classes iniciais:    %d"
 #: ../imagery/i.cluster/main.c:276
 #, c-format
@@ -6984,22 +6984,22 @@
 #: ../imagery/i.cluster/main.c:278
 #, fuzzy, c-format
 msgid " Minimum class size:           %d%s"
-msgstr "Tamanho mínimo de classe:       %d\n"
+msgstr "Tamanho mínimo de classe:       %d\n"
 #: ../imagery/i.cluster/main.c:279
 #, fuzzy, c-format
 msgid " Minimum class separation:     %f%s"
-msgstr "Mínima separação de classe:    %f\n"
+msgstr "Mínima separação de classe:    %f\n"
 #: ../imagery/i.cluster/main.c:280
 #, fuzzy, c-format
 msgid " Percent convergence:          %f%s"
-msgstr "Convergência porcentual:         %f\n"
+msgstr "Convergência porcentual:         %f\n"
 #: ../imagery/i.cluster/main.c:281
 #, fuzzy, c-format
 msgid " Maximum number of iterations: %d%s"
 #: ../imagery/i.cluster/main.c:283
 #, fuzzy, c-format
@@ -7015,7 +7015,7 @@
 #, fuzzy
 msgid "Out of Memory. Please run again and choose a smaller sample size."
 msgstr ""
-"Memória Esgotada. Por favor execute novamente escolhendo uma amostra menor"
+"Memória Esgotada. Por favor execute novamente escolhendo uma amostra menor"
 #: ../imagery/i.cluster/main.c:309
 #, fuzzy, c-format
@@ -7035,8 +7035,8 @@
 msgid ""
 "Not enough non-zero sample data points. Check your current region (and mask)."
 msgstr ""
-"Pontos não-nulos insuficentes na amostra. Verifique sua região atual (e "
-"máscara)"
+"Pontos não-nulos insuficentes na amostra. Verifique sua região atual (e "
+"máscara)"
 #: ../imagery/i.cluster/main.c:329
 #, fuzzy, c-format
@@ -7048,13 +7048,13 @@
 #: ../imagery/i.cluster/main.c:330
 #, fuzzy, c-format
 msgid "%d classes (convergence=%.1f%%)%s"
-msgstr "%d classes (convergência=%.1f%%)\n"
+msgstr "%d classes (convergência=%.1f%%)\n"
 #: ../imagery/i.cluster/main.c:341
 #, fuzzy, c-format
 msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
 msgstr ""
-"Não consegui escrever arquivo de assinatura <%s> para o grupo <%s>, subgrupo "
+"Não consegui escrever arquivo de assinatura <%s> para o grupo <%s>, subgrupo "
 "<%s>"
 #: ../imagery/i.cluster/main.c:346
@@ -7068,7 +7068,7 @@
 #: ../imagery/i.cluster/main.c:348
 #, fuzzy, c-format
 msgid "%s%d classes, %.2f%% points stable%s"
 #: ../imagery/i.cluster/main.c:350
 #, fuzzy, c-format
@@ -7080,14 +7080,14 @@
 #: ../imagery/i.cluster/main.c:354 ../misc/m.nviz.image/main.c:242
 #, fuzzy, c-format
 msgid "File <%s> created."
 #: ../imagery/i.cluster/print2.c:18
 #, fuzzy, c-format
 msgid "%sclass means/stddev for each band%s%s"
 msgstr ""
 "\n"
-"média da classe/desvio padrão para cada banda\n"
+"média da classe/desvio padrão para cada banda\n"
 "\n"
 #: ../imagery/i.cluster/print2.c:23
@@ -7098,17 +7098,17 @@
 #: ../imagery/i.cluster/print2.c:24
 #, c-format
 msgid "  means "
-msgstr "  média "
+msgstr "  média "
 #: ../imagery/i.cluster/print2.c:29
 #, c-format
 msgid "  stddev"
-msgstr "  desvio padrão"
+msgstr "  desvio padrão"
 #: ../imagery/i.cluster/print6.c:11
 #, c-format
 msgid "class distribution"
-msgstr "distribuição de classes"
+msgstr "distribuição de classes"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:48
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:89
@@ -7130,7 +7130,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:64
 #, fuzzy
 msgid "Name of imagery group for ortho-rectification"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
 #, fuzzy
@@ -7150,17 +7150,17 @@
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:77
 #, fuzzy
 msgid "X-coordinate standard deviation"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:82
 #, fuzzy
 msgid "Y-coordinate standard deviation"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:87
 #, fuzzy
 msgid "Z-coordinate standard deviation"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:92
 msgid "Initial Camera Omega (roll) degrees"
@@ -7177,17 +7177,17 @@
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:107
 #, fuzzy
 msgid "Omega (roll) standard deviation"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:112
 #, fuzzy
 msgid "Phi (pitch) standard deviation"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:117
 #, fuzzy
 msgid "Kappa (yaw) standard deviation"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:121
 msgid "Use initial values at run time"
@@ -7196,14 +7196,14 @@
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:125
 #, fuzzy
 msgid "Print initial values"
-msgstr "Cópia da tabela falhou"
+msgstr "Cópia da tabela falhou"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:137
 #, fuzzy, c-format
 msgid "Group [%s] not found"
 msgstr ""
 "\n"
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:150
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:154
@@ -7219,23 +7219,23 @@
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:194
 #, fuzzy, c-format
 msgid "Option '%s' is required for new exposure info"
 #: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:80
 #, fuzzy, c-format
 msgid "No elevation available at row = %d, col = %d"
-msgstr "conversão"
+msgstr "conversão"
 #: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:36
 #, fuzzy
 msgid "Calculating camera angle to local surface..."
-msgstr "Calculando médias das classes ..."
+msgstr "Calculando médias das classes ..."
 #: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:50
 #: ../imagery/i.ortho.photo/i.ortho.rectify/exec.c:43
 #, fuzzy
 msgid "Could not open elevation raster"
 #: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:66
 #, c-format
@@ -7247,17 +7247,17 @@
 msgid ""
 "Control Z Point file for group [%s] in [%s] \n"
 " \n"
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:16
 #, fuzzy
 msgid "Computing equations..."
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:22
 #, fuzzy
 msgid "Poorly placed Control Points!\n"
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:23
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:28
@@ -7265,7 +7265,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:58
 #, fuzzy
 msgid "Can not generate the transformation equation.\n"
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:24
 msgid "Run OPTION 7 of i.ortho.photo again!\n"
@@ -7274,7 +7274,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:27
 #, fuzzy
 msgid "No active Control Points!\n"
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:29
 msgid "Run OPTION 7 of i.ortho.photo!\n"
@@ -7285,12 +7285,12 @@
 msgid ""
 "Reference Point file for group [%s] in [%s] \n"
 " \n"
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:51
 #, fuzzy
 msgid "Poorly placed Reference Points!\n"
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:53
 msgid "Run OPTION 5 of i.ortho.photo again!\n"
@@ -7299,7 +7299,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:57
 #, fuzzy
 msgid "No active Reference Points!\n"
 #: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:59
 msgid "Run OPTION 5 of i.ortho.photo!\n"
@@ -7318,7 +7318,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:184
 #, fuzzy, c-format
 msgid "Could not read REF file for group <%s>"
-msgstr "Não consegui ler arquivo REF para o subgrupo [%s] no grupo [%s]."
+msgstr "Não consegui ler arquivo REF para o subgrupo [%s] no grupo [%s]."
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:241
 #, c-format
@@ -7358,12 +7358,12 @@
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:80
 #, fuzzy
 msgid "List available raster maps in target mapset and exit"
-msgstr "Lista camadas disponíveis na fonte dos dados e finaliza"
+msgstr "Lista camadas disponíveis na fonte dos dados e finaliza"
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:85
 #, fuzzy
 msgid "Print currently selected elevation map and exit"
-msgstr "Mostra a extensão da região atual"
+msgstr "Mostra a extensão da região atual"
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:108
 #, c-format
@@ -7373,7 +7373,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:114
 #, fuzzy, c-format
 msgid "Target location [%s] not found\n"
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:147
 #, c-format
@@ -7388,7 +7388,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:175
 #, fuzzy, c-format
 msgid "Mapset [%s] in target location [%s] - %s "
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:177
 #, fuzzy
@@ -7398,7 +7398,7 @@
 #, fuzzy
 msgid "not found\n"
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:59
 msgid "Select and modify the imagery group camera reference file."
@@ -7436,7 +7436,7 @@
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:129
 #, fuzzy, c-format
 msgid "Can not read camera file '%s'"
-msgstr "Não consegui abrir o arquivo de filtro '%s'"
+msgstr "Não consegui abrir o arquivo de filtro '%s'"
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:132
 #, c-format
@@ -7488,24 +7488,24 @@
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:217
 #, fuzzy, c-format
 msgid "Group [%s] in location [%s] mapset [%s] now uses camera file [%s]"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:93
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:136
 #: ../misc/m.transform/main.c:96
 #, fuzzy, c-format
 msgid "Error conducting transform (%d)"
-msgstr "Mostrar informação topológica (depuração)"
+msgstr "Mostrar informação topológica (depuração)"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:251
 #, fuzzy
 msgid "Poorly placed image to photo control points"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:253
 #, fuzzy
 msgid "Poorly placed image to target control points"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:255
 #: ../misc/m.transform/main.c:196
@@ -7516,13 +7516,13 @@
 #: ../misc/m.transform/main.c:198
 #, fuzzy
 msgid "Parameter error"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:259
 #: ../misc/m.transform/main.c:200
 #, fuzzy
 msgid "No active control points"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:348
 #: ../raster/r.in.lidar/main.c:644 ../raster/r.profile/main.c:175
@@ -7535,13 +7535,13 @@
 #: ../vector/v.net/main.c:100 ../vector/v.out.vtk/main.c:173
 #, c-format
 msgid "Unable to open file <%s>"
-msgstr "Não consegui abrir o arquivo <%s>"
+msgstr "Não consegui abrir o arquivo <%s>"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:367
 #: ../misc/m.transform/main.c:295
 #, fuzzy, c-format
 msgid "Invalid coordinates: [%s]"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:391
 msgid "GCP"
@@ -7552,7 +7552,7 @@
 #, fuzzy
 msgid "Computes a coordinate transformation based on the control points."
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:406
@@ -7600,7 +7600,7 @@
 #: ../misc/m.transform/main.c:347
 #, fuzzy
 msgid "forward error (destination)"
-msgstr "Traçar elevação"
+msgstr "Traçar elevação"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:414
 #: ../misc/m.transform/main.c:348
@@ -7610,13 +7610,13 @@
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:417
 #: ../misc/m.transform/main.c:351 ../vector/v.out.ascii/args.c:55
 msgid "Output format"
-msgstr "Formato de saída"
+msgstr "Formato de saída"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:421
 #: ../misc/m.transform/main.c:355
 #, fuzzy
 msgid "Display summary information"
-msgstr "Posição de referência"
+msgstr "Posição de referência"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:427
 #: ../misc/m.transform/main.c:360
@@ -7651,12 +7651,12 @@
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:452
 #, fuzzy, c-format
 msgid "Can not read reference points for group <%s>"
-msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
+msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:456
 #, fuzzy, c-format
 msgid "Can not read control points for group <%s>"
 #: ../imagery/i.eb.soilheatflux/main.c:51
 msgid "soil heat flux"
@@ -7669,7 +7669,7 @@
 #: ../imagery/i.eb.soilheatflux/main.c:67
 #, fuzzy
 msgid "Name of Surface temperature raster map [K]"
 #: ../imagery/i.eb.soilheatflux/main.c:83
 msgid "HAPEX-Sahel empirical correction (Roerink, 1995)"
@@ -7679,12 +7679,12 @@
 #: ../raster/r.relief/main.c:110 ../raster/r.param.scale/interface.c:56
 #, fuzzy
 msgid "terrain"
-msgstr "Método de intepolação a usar"
+msgstr "Método de intepolação a usar"
 #: ../imagery/i.topo.corr/main.c:49
 #, fuzzy
 msgid "topographic correction"
 #: ../imagery/i.topo.corr/main.c:50
 #, fuzzy
@@ -7699,7 +7699,7 @@
 #: ../imagery/i.topo.corr/main.c:62
 #, fuzzy
 msgid "Name (flag -i) or prefix for output raster maps"
 #: ../imagery/i.topo.corr/main.c:66
 #, fuzzy
@@ -7709,7 +7709,7 @@
 #: ../imagery/i.topo.corr/main.c:72
 #, fuzzy
 msgid "Solar zenith in degrees"
 #: ../imagery/i.topo.corr/main.c:78
 msgid "Solar azimuth in degrees (only if flag -i)"
@@ -7718,12 +7718,12 @@
 #: ../imagery/i.topo.corr/main.c:85
 #, fuzzy
 msgid "Topographic correction method"
 #: ../imagery/i.topo.corr/main.c:90
 #, fuzzy
 msgid "Output sun illumination terrain model"
-msgstr "Saída é o erro de interpolação"
+msgstr "Saída é o erro de interpolação"
 #: ../imagery/i.topo.corr/main.c:94
 msgid "Scale output to input and copy color rules"
@@ -7740,7 +7740,7 @@
 #: ../imagery/i.topo.corr/main.c:158 ../raster/r.resamp.interp/main.c:102
 #, fuzzy, c-format
 msgid "Invalid method: %s"
 #: ../imagery/i.topo.corr/main.c:164
 msgid "Illumination model is of CELL type"
@@ -7774,7 +7774,7 @@
 #, fuzzy
 msgid "Name of aerodynamic resistance to heat momentum raster map [s/m]"
 msgstr ""
-"Nome do mapa raster com o coeficiente de radiação do feixe de céu real [-]"
+"Nome do mapa raster com o coeficiente de radiação do feixe de céu real [-]"
 #: ../imagery/i.eb.hsebal01/main.c:131
 #, fuzzy
@@ -7812,7 +7812,7 @@
 #: ../vector/v.surf.rst/main.c:333
 #, fuzzy
 msgid "Parameters"
 #: ../imagery/i.eb.hsebal01/main.c:149
 #, fuzzy
@@ -7827,7 +7827,7 @@
 #: ../imagery/i.eb.hsebal01/main.c:163
 #, fuzzy
 msgid "Column value of the wet pixel"
-msgstr "Coluna usada para o tamanho do gráfico pizza"
+msgstr "Coluna usada para o tamanho do gráfico pizza"
 #: ../imagery/i.eb.hsebal01/main.c:170
 msgid "Row value of the dry pixel"
@@ -7836,12 +7836,12 @@
 #: ../imagery/i.eb.hsebal01/main.c:177
 #, fuzzy
 msgid "Column value of the dry pixel"
 #: ../imagery/i.eb.hsebal01/main.c:182
 #, fuzzy
 msgid "Name for output sensible heat flux raster map [W/m2]"
 #: ../imagery/i.eb.hsebal01/main.c:187
 msgid "Automatic wet/dry pixel (careful!)"
@@ -7854,7 +7854,7 @@
 #: ../imagery/i.eb.hsebal01/main.c:210
 #, fuzzy
 msgid "Automatic mode selected"
-msgstr "Nenhum dispositivo gráfico selecionado."
+msgstr "Nenhum dispositivo gráfico selecionado."
 #: ../imagery/i.eb.hsebal01/main.c:222
 msgid "Manual wet/dry pixels in image coordinates"
@@ -7877,17 +7877,17 @@
 #: ../imagery/i.eb.hsebal01/main.c:233
 #, fuzzy, c-format
 msgid "<%s> is an illegal name"
 #: ../ps/ps.map/ps_vpoints.c:71 ../ps/ps.map/ps_vareas.c:161
 #: ../ps/ps.map/ps_vlines.c:56
 #, fuzzy
 msgid "Cannot load data from table"
-msgstr "Não consegui selecionar dados da tabela"
+msgstr "Não consegui selecionar dados da tabela"
 #: ../ps/ps.map/ps_vpoints.c:87 ../ps/ps.map/do_plt.c:169
 msgid "Cannot read symbol, using default icon"
-msgstr "Não consegui ler símbolo, usando ícone padrão"
+msgstr "Não consegui ler símbolo, usando ícone padrão"
 #: ../ps/ps.map/ps_vpoints.c:160 ../ps/ps.map/ps_vpoints.c:171
 #: ../ps/ps.map/ps_vpoints.c:195 ../ps/ps.map/ps_vpoints.c:236
@@ -7900,13 +7900,13 @@
 #: ../ps/ps.map/ps_vpoints.c:177
 #, fuzzy, c-format
 msgid "Attribute is of invalid size [%.3f] for category [%d]"
-msgstr "Atributo tem tamanho inválido (%.3f) para a categoria %d."
+msgstr "Atributo tem tamanho inválido (%.3f) para a categoria %d."
 #: ../ps/ps.map/ps_vpoints.c:201 ../ps/ps.map/ps_vareas.c:108
 #: ../ps/ps.map/ps_vlines.c:125
 #, fuzzy, c-format
 msgid "Invalid RGB color definition in column <%s> for category [%d]"
-msgstr "Erro na definição de cor na coluna GRASSRGB, área %d com cat %d"
+msgstr "Erro na definição de cor na coluna GRASSRGB, área %d com cat %d"
 #: ../ps/ps.map/ps_outline.c:43
 #, fuzzy, c-format
@@ -7938,7 +7938,7 @@
 #: ../ps/ps.map/ps_outline.c:107
 #, fuzzy
 msgid "illegal outline sub-request"
-msgstr "Número ilegal de arestas"
+msgstr "Número ilegal de arestas"
 #: ../ps/ps.map/ps_vareas.c:67 ../ps/ps.map/ps_vareas.c:78
 #: ../ps/ps.map/ps_vlines.c:84
@@ -7953,7 +7953,7 @@
 #: ../ps/ps.map/ps_fclrtbl.c:51
 #, fuzzy
 msgid "Range information not available (run r.support)"
-msgstr "Informação de limites indisponível (execute r.support)."
+msgstr "Informação de limites indisponível (execute r.support)."
 #: ../ps/ps.map/ps_fclrtbl.c:64
 #, fuzzy
@@ -7962,22 +7962,22 @@
 #: ../ps/ps.map/ps_fclrtbl.c:69 ../ps/ps.map/ps_clrtbl.c:44
 msgid "Unable to read colors for colorbar"
-msgstr "Não consegui ler as cores para a escala"
+msgstr "Não consegui ler as cores para a escala"
 #: ../ps/ps.map/ps_fclrtbl.c:97 ../ps/ps.map/ps_fclrtbl.c:102
 #: ../ps/ps.map/ps_clrtbl.c:69
 msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr "Localização y da escala de cores além das margens. Ajustando."
+msgstr "Localização y da escala de cores além das margens. Ajustando."
 #: ../ps/ps.map/ps_fclrtbl.c:108 ../ps/ps.map/ps_fclrtbl.c:113
 #: ../ps/ps.map/ps_clrtbl.c:75
 msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr "Localização x da escala de cores além das margens. Ajustando."
+msgstr "Localização x da escala de cores além das margens. Ajustando."
 #: ../ps/ps.map/do_labels.c:44
 #, c-format
 msgid "Can't open label file <%s> in mapset <%s>"
-msgstr "Não consegui abrir arquivo de rótulos <%s> no mapset <%s>"
+msgstr "Não consegui abrir arquivo de rótulos <%s> no mapset <%s>"
 #: ../ps/ps.map/do_labels.c:48
 #, fuzzy, c-format
@@ -7987,7 +7987,7 @@
 #: ../ps/ps.map/do_labels.c:66
 #, c-format
 msgid "Can't open temporary label file <%s>"
-msgstr "Não consigo abrir arquivo temporário <%s>"
+msgstr "Não consigo abrir arquivo temporário <%s>"
 #: ../ps/ps.map/do_labels.c:69
 #, fuzzy
@@ -7996,17 +7996,17 @@
 #: ../ps/ps.map/do_labels.c:162
 msgid "Text labels: 'fontsize' given so ignoring 'size'"
-msgstr "Rótulos de texto: 'fontsize' definido, ignorando 'size'"
+msgstr "Rótulos de texto: 'fontsize' definido, ignorando 'size'"
 #: ../ps/ps.map/do_scalebar.c:192
 #, fuzzy
 msgid "meters"
 #: ../ps/ps.map/do_scalebar.c:194
 #, fuzzy
 msgid "kilometers"
-msgstr "Tipo de feição"
+msgstr "Tipo de feição"
 #: ../ps/ps.map/do_scalebar.c:196
 msgid "feet"
@@ -8015,7 +8015,7 @@
 #: ../ps/ps.map/do_scalebar.c:198
 #, fuzzy
 msgid "miles"
-msgstr "Mapa vetorial não é 3D"
+msgstr "Mapa vetorial não é 3D"
 #: ../ps/ps.map/do_scalebar.c:200
 msgid "nautical miles"
@@ -8024,7 +8024,7 @@
 #: ../ps/ps.map/r_plt.c:173
 #, fuzzy
 msgid "Can't open eps file"
 #: ../ps/ps.map/map_setup.c:82
 #, fuzzy, c-format
@@ -8034,7 +8034,7 @@
 #: ../ps/ps.map/do_masking.c:23
 #, fuzzy
 msgid "Can't open temporary PostScript mask file."
 #: ../ps/ps.map/do_plt.c:38
 #, fuzzy
@@ -8083,7 +8083,7 @@
 #: ../ps/ps.map/ps_clrtbl.c:39 ../display/d.histogram/main.c:174
 #, fuzzy, c-format
 msgid "Category file for <%s> not available"
-msgstr "Arquivo de categorias para [%s] não disponível"
+msgstr "Arquivo de categorias para [%s] não disponível"
 #: ../ps/ps.map/ps_clrtbl.c:54
 #, fuzzy
@@ -8092,29 +8092,29 @@
 "required for 'colortable' when using categorical legends; see the r.category "
 "help page. Colortable creation has been skipped."
 msgstr ""
-"Seu arquivo cats/ file é inválido. Um arquivo cats/  com categorias e "
-"rótulos é necessário para a escala de cores quando usar raster CELL. Nenhuma "
-"escala de cores será designada para esta saída PostScript."
+"Seu arquivo cats/ file é inválido. Um arquivo cats/  com categorias e "
+"rótulos é necessário para a escala de cores quando usar raster CELL. Nenhuma "
+"escala de cores será designada para esta saída PostScript."
 #: ../ps/ps.map/r_vlegend.c:97
 #, fuzzy
 msgid "illegal vlegend sub-request"
 #: ../ps/ps.map/r_instructions.c:62
 #, fuzzy
 msgid "Data exist after final 'end' instruction!"
-msgstr "Existem dados após a instrução 'end' final!"
+msgstr "Existem dados após a instrução 'end' final!"
 #: ../ps/ps.map/r_instructions.c:80
 #, fuzzy
 msgid "no file specified"
 #: ../ps/ps.map/r_instructions.c:84
 #, fuzzy
 msgid "unable to open"
-msgstr "Não consegui abrir <%s>"
+msgstr "Não consegui abrir <%s>"
 #: ../ps/ps.map/r_instructions.c:115
 #, fuzzy
@@ -8128,7 +8128,7 @@
 #: ../ps/ps.map/r_instructions.c:144 ../ps/ps.map/r_instructions.c:340
 #, fuzzy
 msgid "no raster map selected yet"
 #: ../ps/ps.map/r_instructions.c:160
 #, fuzzy
@@ -8138,7 +8138,7 @@
 #: ../ps/ps.map/r_instructions.c:196
 #, fuzzy
 msgid "scalebar is not appropriate for this projection"
-msgstr "Opção Geo-Grid não disponível para projeção LL"
+msgstr "Opção Geo-Grid não disponível para projeção LL"
 #: ../ps/ps.map/r_instructions.c:204
 #, fuzzy
@@ -8163,12 +8163,12 @@
 #: ../ps/ps.map/r_instructions.c:265
 #, fuzzy
 msgid "illegal line request"
 #: ../ps/ps.map/r_instructions.c:282
 #, fuzzy
 msgid "illegal rectangle request"
 #: ../ps/ps.map/r_instructions.c:293
 #, fuzzy
@@ -8178,24 +8178,24 @@
 #: ../ps/ps.map/r_instructions.c:309
 #, fuzzy
 msgid "illegal scale request"
 #: ../ps/ps.map/r_instructions.c:369
 #, fuzzy
 msgid "group not found"
 msgstr ""
 "\n"
 #: ../ps/ps.map/r_instructions.c:411
 #, fuzzy
 msgid "illegal grid spacing"
-msgstr "Não desenhar malha"
+msgstr "Não desenhar malha"
 #: ../ps/ps.map/r_instructions.c:422
 #, fuzzy
 msgid "geogrid is not available for this projection"
 #: ../ps/ps.map/r_instructions.c:432
 msgid "illegal geo-grid spacing"
@@ -8212,12 +8212,12 @@
 #: ../vector/v.vol.rst/user1.c:95
 #, fuzzy
 msgid "Unable to get layer info for vector map"
-msgstr "Não consegui obter informações de camada para o mapa vetorial"
+msgstr "Não consegui obter informações de camada para o mapa vetorial"
 #: ../ps/ps.map/catval.c:63
 #, fuzzy
 msgid "Column type not supported (must be string)"
-msgstr "Tipo da coluna não suportado (%s)"
+msgstr "Tipo da coluna não suportado (%s)"
 #: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131
 #: ../ps/ps.map/catval.c:198 ../vector/v.out.lidar/main.c:132
@@ -8228,17 +8228,17 @@
 #: ../vector/v.univar/main.c:366
 #, fuzzy
 msgid "Unable to select data from table"
 #: ../ps/ps.map/catval.c:128
 #, fuzzy
 msgid "Size column type must be numeric"
-msgstr "Nome da coluna (tipo deve ser numérico)"
+msgstr "Nome da coluna (tipo deve ser numérico)"
 #: ../ps/ps.map/catval.c:195
 #, fuzzy
 msgid "Rotation column type must be numeric"
 #: ../ps/ps.map/do_vectors.c:33
 #, fuzzy, c-format
@@ -8258,7 +8258,7 @@
 #: ../ps/ps.map/main.c:93
 #, fuzzy
 msgid "postscript"
-msgstr "Arquivo de saída PostScript"
+msgstr "Arquivo de saída PostScript"
 #: ../ps/ps.map/main.c:94
 #, fuzzy
@@ -8268,7 +8268,7 @@
 #: ../ps/ps.map/main.c:95
 #, fuzzy
 msgid "Produces hardcopy PostScript map output."
-msgstr "Utilitário para impressão de mapas em PostScript."
+msgstr "Utilitário para impressão de mapas em PostScript."
 #: ../ps/ps.map/main.c:99
 msgid "Rotate plot 90 degrees"
@@ -8283,7 +8283,7 @@
 #: ../locale/scriptstrings/r.unpack_to_translate.c:10
 #, fuzzy
 msgid "Output settings"
 #: ../ps/ps.map/main.c:105
 #, fuzzy
@@ -8296,7 +8296,7 @@
 #: ../ps/ps.map/main.c:112
 msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
-msgstr "Cria EPS (Encapsulated PostScript) ao invés de PostScript."
+msgstr "Cria EPS (Encapsulated PostScript) ao invés de PostScript."
 #: ../ps/ps.map/main.c:118
 msgid ""
@@ -8307,7 +8307,7 @@
 #: ../ps/ps.map/main.c:123
 #, fuzzy
 msgid "File containing mapping instructions"
-msgstr "Arquivo contém assinaturas resultantes"
+msgstr "Arquivo contém assinaturas resultantes"
 #: ../ps/ps.map/main.c:124
 msgid "Use '-' to enter instructions from keyboard)"
@@ -8316,16 +8316,16 @@
 #: ../ps/ps.map/main.c:127
 #, fuzzy
 msgid "Name for PostScript output file"
 #: ../ps/ps.map/main.c:133
 msgid "Number of copies to print"
-msgstr "Número de cópias"
+msgstr "Número de cópias"
 #: ../ps/ps.map/main.c:205
 #, fuzzy, c-format
 msgid "Unable to open file '%s': %s"
-msgstr "Não consegui abrir o arquivo de células [%s]"
+msgstr "Não consegui abrir o arquivo de células [%s]"
 #: ../ps/ps.map/main.c:213 ../ps/ps.map/main.c:232
 #: ../vector/v.to.db/parse.c:141 ../vector/v.to.db/parse.c:144
@@ -8334,7 +8334,7 @@
 msgid ""
 "Required parameter <%s> not set:\n"
 "\t(%s)"
-msgstr "parâmetro para"
+msgstr "parâmetro para"
 #: ../ps/ps.map/main.c:273
 #, c-format
@@ -8348,27 +8348,27 @@
 #: ../ps/ps.map/eps.c:18
 #, fuzzy, c-format
 msgid "Can't open eps file <%s>"
-msgstr "Não consegui abrir o arquivo [%s]"
+msgstr "Não consegui abrir o arquivo [%s]"
 #: ../ps/ps.map/eps.c:37
 #, fuzzy, c-format
 msgid "Bounding box in eps file <%s> was not found"
-msgstr "Arquivo 3dview  <%s> não encontrado"
+msgstr "Arquivo 3dview  <%s> não encontrado"
 #: ../ps/ps.map/makeprocs.c:29
 #, fuzzy, c-format
 msgid "Unable to open prolog <%s>"
-msgstr "não consegui abrir <%s>"
+msgstr "não consegui abrir <%s>"
 #: ../ps/ps.map/r_group.c:29
 #, fuzzy
 msgid "Can't get group information"
-msgstr "imprimir informação do atributo"
+msgstr "imprimir informação do atributo"
 #: ../ps/ps.map/ps_raster.c:42
 #, fuzzy
 msgid "Can't create temporary PostScript mask file."
 #: ../ps/ps.map/ps_raster.c:102 ../raster/r.grow.distance/main.c:276
 #: ../raster/r.series.accumulate/main.c:248
@@ -8393,7 +8393,7 @@
 #: ../ps/ps.map/r_colortable.c:106
 #, fuzzy
 msgid "illegal range request"
 #: ../ps/ps.map/r_colortable.c:122
 #, fuzzy
@@ -8412,7 +8412,7 @@
 #: ../ps/ps.map/r_colortable.c:170
 #, fuzzy
 msgid "illegal colortable sub-request"
 #: ../ps/ps.map/r_colortable.c:181
 #, fuzzy
@@ -8442,24 +8442,24 @@
 #: ../display/d.grid/plot.c:554 ../general/g.region/printwindow.c:247
 #: ../general/g.region/printwindow.c:503 ../general/g.region/printwindow.c:622
 msgid "Can't get projection key values of current location"
-msgstr "Não obtive os valores de projeção da locação atual"
+msgstr "Não obtive os valores de projeção da locação atual"
 #: ../ps/ps.map/do_geogrid.c:278 ../raster/r.sun/main.c:763
 #: ../raster/r.horizon/main.c:548 ../raster/r.latlong/main.c:114
 #: ../display/d.where/main.c:120 ../display/d.where/main.c:146
 #: ../display/d.grid/plot.c:561 ../display/d.grid/plot.c:588
 msgid "Unable to set up lat/long projection parameters"
-msgstr "Não consegui ajustar parâmetros de projeção lat/long"
+msgstr "Não consegui ajustar parâmetros de projeção lat/long"
 #: ../ps/ps.map/read_cfg.c:64
 #, fuzzy, c-format
 msgid "Paper '%s' not found, using defaults"
-msgstr "raster <%s> não encontrado"
+msgstr "raster <%s> não encontrado"
 #: ../ps/ps.map/r_header.c:77
 #, fuzzy
 msgid "illegal header sub-request"
 #: ../db/db.connect/main.c:43 ../db/db.databases/main.c:95
 #: ../db/db.copy/main.c:35 ../db/db.execute/main.c:125
@@ -8528,17 +8528,17 @@
 #: ../db/db.drivers/main.c:72
 #, fuzzy
 msgid "connection settings"
-msgstr "Por favor corrija opções."
+msgstr "Por favor corrija opções."
 #: ../db/db.connect/main.c:47
 #, fuzzy
 msgid "Prints/sets general DB connection for current mapset."
-msgstr "Mostra/seleciona conexão ao BD para o mapset atual"
+msgstr "Mostra/seleciona conexão ao BD para o mapset atual"
 #: ../db/db.connect/main.c:51 ../temporal/t.connect/main.c:42
 #, fuzzy
 msgid "Print current connection parameters and exit"
-msgstr "mostra os parâmetros de conexão atuais e finaliza"
+msgstr "mostra os parâmetros de conexão atuais e finaliza"
 #: ../db/db.connect/main.c:52
 msgid "Substitute variables in database settings"
@@ -8547,12 +8547,12 @@
 #: ../db/db.connect/main.c:57
 #, fuzzy
 msgid "Print current connection parameters using shell style and exit"
 #: ../db/db.connect/main.c:63 ../temporal/t.connect/main.c:48
 #, fuzzy
 msgid "Check connection parameters, set if uninitialized, and exit"
 #: ../db/db.connect/main.c:64 ../db/db.connect/main.c:70
 #: ../db/db.connect/main.c:75 ../db/db.connect/main.c:79
@@ -8567,7 +8567,7 @@
 #: ../db/db.connect/main.c:68 ../temporal/t.connect/main.c:53
 #, fuzzy
 msgid "Set from default settings and exit"
-msgstr "Ajustar pela região padrão"
+msgstr "Ajustar pela região padrão"
 #: ../db/db.connect/main.c:69
 #, fuzzy
@@ -8578,13 +8578,13 @@
 #, fuzzy
 msgid "Default group of database users to which select privilege is granted"
 msgstr ""
-"Grupo padrão de usuários do banco de dados que possuem privilégio de seleção "
+"Grupo padrão de usuários do banco de dados que possuem privilégio de seleção "
 "(select)"
 #: ../db/db.connect/main.c:141 ../db/db.tables/main.c:41
 #, fuzzy
 msgid "Database connection not defined. Run db.connect."
-msgstr "Conexão do mapa <%s> com banco de dados não definida no arquivo DB"
+msgstr "Conexão do mapa <%s> com banco de dados não definida no arquivo DB"
 #: ../db/db.connect/main.c:161 ../db/db.connect/main.c:188
 #: ../temporal/t.connect/main.c:133
@@ -8619,7 +8619,7 @@
 #: ../vector/v.out.vtk/writeVTK.c:644
 #, fuzzy, c-format
 msgid "Unable to start driver <%s>"
-msgstr "Não consegui iniciar o driver '%s'."
+msgstr "Não consegui iniciar o driver '%s'."
 #: ../db/db.databases/main.c:53
 msgid ""
@@ -8643,12 +8643,12 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:28
 #, fuzzy
 msgid "Connection"
-msgstr "Correlação"
+msgstr "Correlação"
 #: ../db/db.databases/main.c:87
 #, fuzzy
 msgid "Location"
 #: ../db/db.databases/main.c:88
 msgid "Path for SQLite driver, or connection string for PostgreSQL driver"
@@ -8670,7 +8670,7 @@
 #: ../db/db.copy/main.c:38
 #, fuzzy
 msgid "Copy a table."
 #: ../db/db.copy/main.c:40
 #, fuzzy
@@ -8678,8 +8678,8 @@
 "Either 'from_table' (optionally with 'where') can be used or 'select' "
 "option, but not 'from_table' and 'select' at the same time."
 msgstr ""
-"Copiar tabela. Tanto 'from_table' (opcionalmente com 'where') quanto a opção "
-"'select' podem ser usadas, mas não ao mesmo tempo."
+"Copiar tabela. Tanto 'from_table' (opcionalmente com 'where') quanto a opção "
+"'select' podem ser usadas, mas não ao mesmo tempo."
 #: ../db/db.copy/main.c:46
 msgid "Input driver name"
@@ -8691,25 +8691,25 @@
 #: ../db/db.copy/main.c:59
 msgid "Input table name (only, if 'select' is not used)"
-msgstr "Nome da tabela de entrada (apenas se select não foi usado)"
+msgstr "Nome da tabela de entrada (apenas se select não foi usado)"
 #: ../db/db.copy/main.c:65
 msgid "Output driver name"
-msgstr "Nome do driver de saída"
+msgstr "Nome do driver de saída"
 #: ../db/db.copy/main.c:71
 msgid "Output database name"
-msgstr "Nome do banco de dados de saída"
+msgstr "Nome do banco de dados de saída"
 #: ../db/db.copy/main.c:78
 msgid "Output table name"
-msgstr "Nome da tabela de saída"
+msgstr "Nome da tabela de saída"
 #: ../db/db.copy/main.c:87
 #, fuzzy
 msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
 msgstr ""
-"Comando 'select' completo (somente se 'from_table' e 'where' não forem "
+"Comando 'select' completo (somente se 'from_table' e 'where' não forem "
 "usados),\n"
 " \t\tp.ex.:SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
@@ -8719,13 +8719,13 @@
 #: ../db/db.copy/main.c:96
 msgid "Cannot combine 'from_table' and 'select' options"
-msgstr "Não é possível combinar as opções 'from_table' e 'select'"
+msgstr "Não é possível combinar as opções 'from_table' e 'select'"
 #: ../db/db.copy/main.c:100 ../db/db.select/main.c:53
 #: ../db/db.columns/main.c:44 ../db/db.describe/main.c:50
 #, fuzzy, c-format
 msgid "Table <%s> not found in database <%s> using driver <%s>"
-msgstr "Não conseguir abrir banco de dados <%s> com driver <%s>"
+msgstr "Não conseguir abrir banco de dados <%s> com driver <%s>"
 #: ../db/db.copy/main.c:122
 msgid "Either 'from_table' or 'select' option must be given."
@@ -8733,16 +8733,16 @@
 #: ../db/db.copy/main.c:125
 msgid "Cannot combine 'select' and 'where' options"
-msgstr "Não é possível combinar as opções 'select' e 'where'"
+msgstr "Não é possível combinar as opções 'select' e 'where'"
 #: ../db/db.copy/main.c:135
 msgid "Copy table failed"
 #: ../db/db.execute/main.c:57 ../db/db.select/main.c:63
 #, fuzzy, c-format
 msgid "Unable to open file <%s>: %s"
 #: ../db/db.execute/main.c:76 ../db/db.select/main.c:81
 #: ../db/db.columns/main.c:56 ../db/db.describe/main.c:61
@@ -8750,7 +8750,7 @@
 #: ../display/d.vect/opt.c:152
 #, fuzzy, c-format
 msgid "Unable to open database <%s>"
-msgstr "Não consegui abrir mapa raster [%s]."
+msgstr "Não consegui abrir mapa raster [%s]."
 #: ../db/db.execute/main.c:94 ../db/db.execute/main.c:99
 #, fuzzy, c-format
@@ -8760,7 +8760,7 @@
 #: ../db/db.execute/main.c:128
 #, fuzzy
 msgid "Executes any SQL statement."
-msgstr "Executa uma instrução SQL"
+msgstr "Executa uma instrução SQL"
 #: ../db/db.execute/main.c:129
 msgid "For SELECT statements use 'db.select'."
@@ -8778,7 +8778,7 @@
 #: ../db/db.execute/main.c:138
 #, fuzzy
 msgid "Name of file containing SQL statement(s)"
 #: ../db/db.execute/main.c:160
 msgid "Ignore SQL errors and continue"
@@ -8793,7 +8793,7 @@
 #: ../db/db.execute/main.c:167
 #, fuzzy, c-format
 msgid "You must provide <%s> or <%s> option"
 #: ../db/db.login/main.c:42
 msgid "Sets user/password for DB driver/database."
@@ -8807,7 +8807,7 @@
 #: ../db/db.login/main.c:67
 #, fuzzy
 msgid "Password"
 #: ../db/db.login/main.c:75
 #, fuzzy
@@ -8825,12 +8825,12 @@
 #: ../db/db.login/main.c:90
 #, fuzzy
 msgid "Print connection settings and exit"
 #: ../db/db.login/main.c:105
 #, fuzzy
 msgid "Unable to set user/password"
-msgstr "Impossível definir usuário/senha"
+msgstr "Impossível definir usuário/senha"
 #: ../db/db.login/main.c:109
 #, fuzzy, c-format
@@ -8854,7 +8854,7 @@
 #: ../raster/r.regression.line/main.c:77 ../vector/v.db.select/main.c:126
 #, fuzzy, c-format
 msgid "Unable to open file <%s> for writing"
-msgstr "Não consegui abrir o arquivo de células <%s>"
+msgstr "Não consegui abrir o arquivo de células <%s>"
 #: ../db/db.select/main.c:203 ../db/db.select/main.c:209
 #: ../db/db.select/main.c:213 ../db/db.select/main.c:251
@@ -8868,12 +8868,12 @@
 #: ../db/db.select/main.c:207
 #, fuzzy
 msgid "Name of file containing SQL select statement(s)"
 #: ../db/db.select/main.c:212
 #, fuzzy
 msgid "Name of table to query"
-msgstr "Camada de pesquisa. Usada pela opção 'query'."
+msgstr "Camada de pesquisa. Usada pela opção 'query'."
 #: ../db/db.select/main.c:227 ../db/db.select/main.c:233
 #: ../db/db.select/main.c:236 ../db/db.select/main.c:246
@@ -8888,7 +8888,7 @@
 #: ../db/db.select/main.c:231
 #, fuzzy
 msgid "Vertical record separator (requires -v flag)"
-msgstr "Delimitador vertical de registro na saída"
+msgstr "Delimitador vertical de registro na saída"
 #: ../db/db.select/main.c:241 ../raster/r.what/main.c:125
 #: ../raster/r.stats.quantile/main.c:553 ../raster/r.stats/main.c:119
@@ -8899,20 +8899,20 @@
 #: ../vector/v.db.select/main.c:95
 #, fuzzy
 msgid "Name for output file (if omitted or \"-\" output to stdout)"
-msgstr "Nome do mapa binário de saída (use 'out=-' para saída padrão)"
+msgstr "Nome do mapa binário de saída (use 'out=-' para saída padrão)"
 #: ../db/db.select/main.c:245 ../vector/v.db.select/main.c:105
 msgid "Do not include column names in output"
-msgstr "Não incluir nomes das colunas na saída"
+msgstr "Não incluir nomes das colunas na saída"
 #: ../db/db.select/main.c:250
 #, fuzzy
 msgid "Describe query only (don't run it)"
-msgstr "apenas descrever a pesquisa (não executar)"
+msgstr "apenas descrever a pesquisa (não executar)"
 #: ../db/db.select/main.c:255 ../vector/v.db.select/main.c:110
 msgid "Vertical output (instead of horizontal)"
-msgstr "Saída vertical (ao invés de horizontal)"
+msgstr "Saída vertical (ao invés de horizontal)"
 #: ../db/db.select/main.c:260
 msgid "Only test query, do not execute"
@@ -8921,7 +8921,7 @@
 #: ../db/db.select/main.c:268
 #, fuzzy
 msgid "Selects data from attribute table."
-msgstr "Não criar tabela de atributo."
+msgstr "Não criar tabela de atributo."
 #: ../db/db.select/main.c:269
 msgid "Performs SQL query statement(s)."
@@ -8941,7 +8941,7 @@
 #: ../vector/v.out.postgis/table.c:41 ../vector/v.out.vtk/writeVTK.c:655
 #, fuzzy, c-format
 msgid "Unable to describe table <%s>"
-msgstr "Não consegui descrever a tabela %s"
+msgstr "Não consegui descrever a tabela %s"
 #: ../db/db.columns/main.c:101
 #, fuzzy
@@ -8951,16 +8951,16 @@
 #: ../db/db.dropdb/main.c:74
 #, fuzzy
 msgid "Removes an existing database."
 #: ../db/db.drivers/main.c:39
 #, fuzzy
 msgid "Unable to read dbmscap file"
 #: ../db/db.drivers/main.c:63
 msgid "Full output"
-msgstr "Saída completa"
+msgstr "Saída completa"
 #: ../db/db.drivers/main.c:67
 #, fuzzy
@@ -8976,7 +8976,7 @@
 #, fuzzy
 msgid "Print column names only instead of full column descriptions"
 msgstr ""
-"mostra apenas os nomes das colunas ao invés das descrições completas das "
+"mostra apenas os nomes das colunas ao invés das descrições completas das "
 "colunas"
 #: ../db/db.describe/main.c:113
@@ -8997,17 +8997,17 @@
 #: ../db/drivers/dbf/db.c:94
 #, fuzzy, c-format
 msgid "Unable create DBF database: %s"
 #: ../db/drivers/dbf/db.c:102
 #, fuzzy, c-format
 msgid "Cannot open DBF database directory: %s"
 #: ../db/drivers/dbf/db.c:110
 #, fuzzy, c-format
 msgid "Unable to open DBF database: %s"
 #: ../db/drivers/dbf/column.c:49
 #, c-format
@@ -9017,22 +9017,22 @@
 #: ../db/drivers/dbf/column.c:99
 #, fuzzy, c-format
 msgid "Column '%s' does not exist"
-msgstr "Mapa raster [%s] não encontrado"
+msgstr "Mapa raster [%s] não encontrado"
 #: ../db/drivers/dbf/cursor.c:47
 #, fuzzy
 msgid "Unable to allocate new cursor"
-msgstr "Não consegui alocar memória."
+msgstr "Não consegui alocar memória."
 #: ../db/drivers/dbf/cursor.c:59
 #, fuzzy
 msgid "Unable to tokenize new cursor"
-msgstr "Não consegui abrir cursor de seleção: '%s'"
+msgstr "Não consegui abrir cursor de seleção: '%s'"
 #: ../db/drivers/dbf/dbfexe.c:72
 #, fuzzy
 msgid "SQL parser error"
 #: ../db/drivers/dbf/dbfexe.c:74
 #, fuzzy
@@ -9042,12 +9042,12 @@
 #: ../db/drivers/dbf/dbfexe.c:88
 #, fuzzy, c-format
 msgid "Table '%s' doesn't exist."
-msgstr "Ferramenta não existe"
+msgstr "Ferramenta não existe"
 #: ../db/drivers/dbf/dbfexe.c:96
 #, fuzzy
 msgid "Unable to load table head."
 #: ../db/drivers/dbf/dbfexe.c:106
 msgid "Unable to modify table, don't have write permission for DBF file."
@@ -9056,7 +9056,7 @@
 #: ../db/drivers/dbf/dbfexe.c:121 ../db/drivers/dbf/dbfexe.c:1023
 #, fuzzy, c-format
 msgid "Column '%s' not found"
 #: ../db/drivers/dbf/dbfexe.c:145
 #, fuzzy
@@ -9066,22 +9066,22 @@
 #: ../db/drivers/dbf/dbfexe.c:161
 #, fuzzy
 msgid "Unable to add column."
-msgstr "Não consegui usar a coluna '%s'"
+msgstr "Não consegui usar a coluna '%s'"
 #: ../db/drivers/dbf/dbfexe.c:183
 #, fuzzy
 msgid "Unable to delete column."
-msgstr "Não consegui executar: %s"
+msgstr "Não consegui executar: %s"
 #: ../db/drivers/dbf/dbfexe.c:191
 #, fuzzy, c-format
 msgid "Table %s already exists"
-msgstr "O vetor '%s' já existe."
+msgstr "O vetor '%s' já existe."
 #: ../db/drivers/dbf/dbfexe.c:206
 #, fuzzy
 msgid "Unable to create table."
 #: ../db/drivers/dbf/dbfexe.c:263 ../db/drivers/dbf/dbfexe.c:273
 #: ../db/drivers/dbf/dbfexe.c:303
@@ -9092,12 +9092,12 @@
 #: ../db/drivers/dbf/dbfexe.c:552
 #, fuzzy
 msgid "Cannot load table."
-msgstr "Não consegui copiar a tabela"
+msgstr "Não consegui copiar a tabela"
 #: ../db/drivers/dbf/dbfexe.c:567
 #, fuzzy
 msgid "Incompatible types in WHERE condition."
-msgstr "Tipo da coluna incompatível"
+msgstr "Tipo da coluna incompatível"
 #: ../db/drivers/dbf/dbfexe.c:572
 msgid "Result of WHERE condition is not of type BOOL."
@@ -9106,7 +9106,7 @@
 #: ../db/drivers/dbf/dbfexe.c:588
 #, fuzzy
 msgid "Error in evaluation of WHERE condition."
-msgstr "Erro no cálculo das conversões"
+msgstr "Erro no cálculo das conversões"
 #: ../db/drivers/dbf/dbfexe.c:600
 #, c-format
@@ -9120,7 +9120,7 @@
 #: ../db/drivers/dbf/dbfexe.c:633
 #, fuzzy, c-format
 msgid "Unable to find order column '%s'"
-msgstr "Não encontrei %s"
+msgstr "Não encontrei %s"
 #: ../db/drivers/dbf/dbfexe.c:778
 msgid "Division by zero"
@@ -9154,7 +9154,7 @@
 #: ../db/drivers/dbf/dbfexe.c:1098
 #, fuzzy, c-format
 msgid "Comparison '%s' between strings not allowed"
-msgstr "Este valor de passo não é permitido"
+msgstr "Este valor de passo não é permitido"
 #: ../db/drivers/dbf/dbfexe.c:1112
 msgid "Match (~) between numbers not allowed"
@@ -9163,58 +9163,58 @@
 #: ../db/drivers/dbf/execute.c:32
 #, fuzzy
 msgid "Unable to execute statement."
-msgstr "Não consegui definir tamanho"
+msgstr "Não consegui definir tamanho"
 #: ../db/drivers/dbf/table.c:117 ../db/drivers/dbf/table.c:170
 #, fuzzy
 msgid "Unable to open DBF file."
-msgstr "Não consegui criar face"
+msgstr "Não consegui criar face"
 #: ../db/drivers/dbf/table.c:312
 #, fuzzy, c-format
 msgid "Unable to move '%s' to '%s'."
 #: ../db/drivers/dbf/create_table.c:22
 #, fuzzy
 msgid "Unable to create table"
 #: ../db/drivers/dbf/select.c:44
 #, fuzzy
 msgid "Unable to open cursor."
 #: ../db/drivers/dbf/describe.c:34
 #, fuzzy, c-format
 msgid "Table '%s' doesn't exist"
 #: ../db/drivers/mysql/index.c:55 ../db/drivers/sqlite/index.c:77
 #, fuzzy
 msgid "Unable to create index:"
 #: ../db/drivers/mysql/db.c:61 ../db/drivers/postgres/db.c:71
 #: ../db/drivers/postgres/db.c:250
 #, fuzzy
 msgid "Connection failed."
 #: ../db/drivers/mysql/fetch.c:34 ../db/drivers/mysql/fetch.c:276
 #: ../db/drivers/postgres/fetch.c:33 ../db/drivers/sqlite/fetch.c:265
 #: ../db/drivers/ogr/fetch.c:55 ../db/drivers/ogr/fetch.c:188
 msgid "Cursor not found"
-msgstr "cursor não encontrado."
+msgstr "cursor não encontrado."
 #: ../db/drivers/mysql/fetch.c:52
 msgid "Cursor position is not supported by MySQL driver"
-msgstr "Posição do cursor não é suportada pelo driver MySQL"
+msgstr "Posição do cursor não é suportada pelo driver MySQL"
 #: ../db/drivers/mysql/fetch.c:191
 #, fuzzy
 msgid "Unable to scan timestamp: "
-msgstr "Não ler o carimbo de hora: "
+msgstr "Não ler o carimbo de hora: "
 #: ../db/drivers/mysql/fetch.c:200
 msgid "Unknown timestamp format: "
@@ -9223,114 +9223,114 @@
 #: ../db/drivers/mysql/fetch.c:215
 #, fuzzy
 msgid "Unable to scan date: "
 #: ../db/drivers/mysql/fetch.c:229
 #, fuzzy
 msgid "Unable to scan time: "
 #: ../db/drivers/mysql/fetch.c:245
 #, fuzzy
 msgid "Unable to scan datetime:"
-msgstr "Não consegui criar a tabela %s"
+msgstr "Não consegui criar a tabela %s"
 #: ../db/drivers/mysql/parse.c:62
 #, fuzzy
 msgid "Wrong port number in MySQL database definition: "
-msgstr "Opção desconhecida na definição do banco de dados mysql: '%s'"
+msgstr "Opção desconhecida na definição do banco de dados mysql: '%s'"
 #: ../db/drivers/mysql/parse.c:73 ../db/drivers/postgres/parse.c:60
 msgid "'user' in database definition is not supported, use db.login"
-msgstr "'user' não é suportado na definição do banco de dados, use db.login"
+msgstr "'user' não é suportado na definição do banco de dados, use db.login"
 #: ../db/drivers/mysql/parse.c:77 ../db/drivers/postgres/parse.c:64
 msgid "'password' in database definition is not supported, use db.login"
 msgstr ""
-"'password' não é suportado na definição do banco de dados, use db.login"
+"'password' não é suportado na definição do banco de dados, use db.login"
 #: ../db/drivers/mysql/parse.c:82
 #, fuzzy
 msgid "Unknown option in database definition for MySQL: "
 #: ../db/drivers/mysql/dbe.c:45
 #, fuzzy
 msgid "Unable parse MySQL embedded database name"
-msgstr "Não consegui ler o nome do banco de dados MySQL"
+msgstr "Não consegui ler o nome do banco de dados MySQL"
 #: ../db/drivers/mysql/dbe.c:61
 #, fuzzy
 msgid "Cannot initialize MySQL embedded server"
-msgstr "Não consegui iniciar o servidor MySQL"
+msgstr "Não consegui iniciar o servidor MySQL"
 #: ../db/drivers/mysql/dbe.c:80
 #, fuzzy
 msgid "Unable to connect to MySQL embedded server: "
 #: ../db/drivers/mysql/listtab.c:37
 #, fuzzy
 msgid "Unable get list of tables:"
-msgstr "Não consigo inserir na tabela: %s"
+msgstr "Não consigo inserir na tabela: %s"
 #: ../db/drivers/mysql/cursor.c:44 ../db/drivers/postgres/cursor.c:41
 #, fuzzy
 msgid "Unable allocate cursor."
 #: ../db/drivers/mysql/cursor.c:53
 #, fuzzy
 msgid "Unable to add dnew token."
-msgstr "Não consegui ler arquivo de cores."
+msgstr "Não consegui ler arquivo de cores."
 #: ../db/drivers/mysql/execute.c:41 ../db/drivers/postgres/execute.c:42
 #, fuzzy
 msgid "Unable to execute:"
 #: ../db/drivers/mysql/execute.c:62
 #, fuzzy
 msgid "Unable to start transaction:"
 #: ../db/drivers/mysql/execute.c:77
 #, fuzzy
 msgid "Unable to commit transaction:"
 #: ../db/drivers/mysql/create_table.c:108
 #: ../db/drivers/postgres/create_table.c:103
 #: ../db/drivers/sqlite/create_table.c:122
 #, fuzzy
 msgid "Unable to create table:"
 #: ../db/drivers/mysql/select.c:42
 #, fuzzy
 msgid "Unable to select data:"
 #: ../db/drivers/mysql/select.c:64 ../db/drivers/postgres/describe.c:40
 #, fuzzy
 msgid "Unable to describe table."
 #: ../db/drivers/mysql/describe.c:32 ../db/drivers/sqlite/select.c:95
 #: ../db/drivers/sqlite/describe.c:92
 #, fuzzy
 msgid "Unable to describe table:"
 #: ../db/drivers/mysql/describe.c:50 ../db/drivers/postgres/select.c:69
 #, fuzzy
 msgid "Unable to describe table"
 #: ../db/drivers/mysql/describe.c:121
 #, fuzzy, c-format
 msgid "MySQL driver: column '%s', type %d is not supported"
-msgstr "driver pg : coluna '%s', tipo %d  não é suportado"
+msgstr "driver pg : coluna '%s', tipo %d  não é suportado"
 #: ../db/drivers/mysql/describe.c:127
 #, fuzzy, c-format
@@ -9344,29 +9344,29 @@
 #: ../db/drivers/odbc/listdb.c:29
 #, fuzzy
 msgid "Unable to allocate handle."
 #: ../db/drivers/odbc/listdb.c:40 ../db/drivers/postgres/listdb.c:96
 #: ../db/drivers/sqlite/listdb.c:147
 #, fuzzy
 msgid "Unable to set handle"
 #: ../db/drivers/odbc/cursor.c:36 ../db/drivers/ogr/cursor.c:65
 #, fuzzy
 msgid "Unable to allocate cursor"
 #: ../db/drivers/odbc/cursor.c:55 ../db/drivers/postgres/cursor.c:50
 #: ../db/drivers/sqlite/cursor.c:56
 #, fuzzy
 msgid "Unable to add new token."
 #: ../db/drivers/odbc/table.c:159
 #, fuzzy, c-format
 msgid "Table %s doesn't exist"
 #: ../db/drivers/odbc/table.c:176
 #, c-format
@@ -9380,37 +9380,37 @@
 #: ../vector/v.select/copy_tabs.c:82 ../vector/v.patch/main.c:326
 #, fuzzy
 msgid "Unable to create index"
 #: ../db/drivers/postgres/db.c:99
 #, fuzzy
 msgid "Unable to set schema:"
 #: ../db/drivers/postgres/db.c:117
 #, fuzzy
 msgid "Unable to select data types"
 #: ../db/drivers/postgres/db.c:269
 #, fuzzy, c-format
 msgid "Unable to create database <%s>"
-msgstr "Não consegui abrir arquivo de saída <%s>."
+msgstr "Não consegui abrir arquivo de saída <%s>."
 #: ../db/drivers/postgres/db.c:271
 #, fuzzy, c-format
 msgid "Unable to drop database <%s>"
 #: ../db/drivers/postgres/fetch.c:129 ../db/drivers/sqlite/fetch.c:171
 #, fuzzy
 msgid "Unable to scan date:"
 #: ../db/drivers/postgres/fetch.c:147 ../db/drivers/sqlite/fetch.c:188
 #, fuzzy
 msgid "Unable to scan time:"
 #: ../db/drivers/postgres/fetch.c:166
 msgid "Unable to scan timestamp (no idea how to process time zone):"
@@ -9423,61 +9423,61 @@
 #: ../db/drivers/postgres/fetch.c:188
 #, fuzzy
 msgid "Unable to recognize boolean value"
-msgstr "Não consegui reconhecer valor booleano"
+msgstr "Não consegui reconhecer valor booleano"
 #: ../db/drivers/postgres/fetch.c:206
 #, fuzzy
 msgid "Taken not found"
-msgstr "não encontrado"
+msgstr "não encontrado"
 #: ../db/drivers/postgres/parse.c:69
 msgid "Unknown option in database definition for PostgreSQL: "
-msgstr "Opção desconhecida na definição do banco de dados PostgreSQL"
+msgstr "Opção desconhecida na definição do banco de dados PostgreSQL"
 #: ../db/drivers/postgres/listtab.c:38
 #, fuzzy
 msgid "Unable to select table names."
 #: ../db/drivers/postgres/listtab.c:65
 #, fuzzy
 msgid "Unable to select view names."
 #: ../db/drivers/postgres/listdb.c:35 ../db/drivers/sqlite/listdb.c:45
 #, fuzzy
 msgid "No path given"
-msgstr "Mapa(s) de entrada não especificado(s)."
+msgstr "Mapa(s) de entrada não especificado(s)."
 #: ../db/drivers/postgres/listdb.c:65
 #, fuzzy
 msgid "Unable to connect to Postgres:"
 #: ../db/drivers/postgres/listdb.c:76
 #, fuzzy
 msgid "Unable to select from Postgres:"
 #: ../db/drivers/postgres/priv.c:53
 #, fuzzy
 msgid "Unable grant on table:"
-msgstr "Não consegui abrir arquivo de saída."
+msgstr "Não consegui abrir arquivo de saída."
 #: ../db/drivers/postgres/execute.c:68
 #, fuzzy
 msgid "Unable to 'BEGIN' transaction"
 #: ../db/drivers/postgres/execute.c:88
 #, fuzzy
 msgid "Unable to 'COMMIT' transaction"
 #: ../db/drivers/postgres/table.c:37
 #, fuzzy
 msgid "Unable to execute():"
 #: ../db/drivers/postgres/create_table.c:90
 #, fuzzy, c-format
@@ -9487,7 +9487,7 @@
 #: ../db/drivers/postgres/create_table.c:132
 #, fuzzy
 msgid "Unable to grant select on table:"
-msgstr "Não posso dar privilégios na tabela <%s>"
+msgstr "Não posso dar privilégios na tabela <%s>"
 #: ../db/drivers/postgres/select.c:31
 msgid "Unable set DATESTYLE"
@@ -9496,12 +9496,12 @@
 #: ../db/drivers/postgres/select.c:55
 #, fuzzy
 msgid "Unable to select:"
 #: ../db/drivers/postgres/describe.c:123
 #, fuzzy, c-format
 msgid "PostgreSQL driver: column '%s', type %d is not supported"
 #: ../db/drivers/postgres/describe.c:130
 #, c-format
@@ -9518,7 +9518,7 @@
 "column '%s' : type character varying is stored as varchar(250) some data may "
 "be lost"
 msgstr ""
-"coluna '%s' : tipo character está armazenado como varchar(250) alguns dados "
+"coluna '%s' : tipo character está armazenado como varchar(250) alguns dados "
 "podem ser perdidos"
 #: ../db/drivers/postgres/describe.c:140
@@ -9527,7 +9527,7 @@
 "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
 "(true)"
 msgstr ""
-"coluna '%s' : tipo bool (booleano) está armazenado como char(1), valores 0 "
+"coluna '%s' : tipo bool (booleano) está armazenado como char(1), valores 0 "
 "(falso), 1 (verdadeiro)"
 #: ../db/drivers/sqlite/index.c:96 ../db/drivers/sqlite/execute.c:69
@@ -9539,52 +9539,52 @@
 #: ../db/drivers/sqlite/db.c:99
 #, fuzzy, c-format
 msgid "Unable to create directory '%s' for sqlite database"
 #: ../db/drivers/sqlite/db.c:107
 #, fuzzy
 msgid "Unable to open database:"
 #: ../db/drivers/sqlite/db.c:134
 #, fuzzy
 msgid "SQLite database connection is still busy"
-msgstr "Conexão com banco de dados não definida"
+msgstr "Conexão com banco de dados não definida"
 #: ../db/drivers/sqlite/db.c:155
 #, fuzzy, c-format
 msgid "Database <%s> already exists"
 #: ../db/drivers/sqlite/db.c:162
 #, fuzzy
 msgid "Unable to create database:"
 #: ../db/drivers/sqlite/db.c:186
 #, fuzzy, c-format
 msgid "Database <%s> not found"
 #: ../db/drivers/sqlite/fetch.c:72
 #, fuzzy
 msgid "Unable to fetch:"
-msgstr "Não consegui obter linha"
+msgstr "Não consegui obter linha"
 #: ../db/drivers/sqlite/fetch.c:87
 #, fuzzy
 msgid "DB_PREVIOUS is not supported"
-msgstr "Camada 0 não suportada"
+msgstr "Camada 0 não suportada"
 #: ../db/drivers/sqlite/fetch.c:93
 #, fuzzy
 msgid "DB_LAST is not supported"
 #: ../db/drivers/sqlite/fetch.c:203
 #, fuzzy
 msgid "Unable to scan timestamp:"
 #: ../db/drivers/sqlite/fetch.c:218
 msgid ""
@@ -9594,37 +9594,37 @@
 #: ../db/drivers/sqlite/fetch.c:223
 #, fuzzy
 msgid "Unable to scan interval:"
 #: ../db/drivers/sqlite/fetch.c:286
 #, fuzzy
 msgid "Unable to get number of rows:"
-msgstr "Não consegui escrever cabeçalho para [%s]."
+msgstr "Não consegui escrever cabeçalho para [%s]."
 #: ../db/drivers/sqlite/listtab.c:50 ../db/drivers/sqlite/listtab.c:66
 #, fuzzy
 msgid "Unable to list tables:"
 #: ../db/drivers/sqlite/listtab.c:78 ../db/drivers/ogr/listtab.c:49
 #, fuzzy
 msgid "Unable to db_alloc_string_array()"
 #: ../db/drivers/sqlite/listdb.c:99
 #, fuzzy, c-format
 msgid "Unable to open directory '%s'"
 #: ../db/drivers/sqlite/listdb.c:117
 #, fuzzy, c-format
 msgid "SQLite database connection '%s' is still busy"
 #: ../db/drivers/sqlite/cursor.c:47
 #, fuzzy
 msgid "Unable to allocate cursor."
 #: ../db/drivers/sqlite/main.c:47
 #, c-format
@@ -9644,12 +9644,12 @@
 #: ../db/drivers/sqlite/execute.c:111
 #, fuzzy
 msgid "'BEGIN' transaction failed:"
 #: ../db/drivers/sqlite/execute.c:139
 #, fuzzy
 msgid "'COMMIT' transaction failed:"
 #: ../db/drivers/sqlite/table.c:37
 #, fuzzy
@@ -9659,27 +9659,27 @@
 #: ../db/drivers/sqlite/describe.c:194
 #, c-format
 msgid "SQLite driver: column '%s', SQLite type %d  is not supported"
-msgstr "driver SQLite : coluna '%s', tipo SQLite %d  não é suportado"
+msgstr "driver SQLite : coluna '%s', tipo SQLite %d  não é suportado"
 #: ../db/drivers/ogr/db.c:56
 #, fuzzy
 msgid "Had to open data source read-only"
 #: ../db/drivers/ogr/db.c:60
 #, fuzzy
 msgid "Unable to open OGR data source"
 #: ../db/drivers/ogr/fetch.c:71
 #, fuzzy
 msgid "DB_PREVIOUS not supported"
 #: ../db/drivers/ogr/fetch.c:82
 #, fuzzy
 msgid "DB_LAST not supported"
 #: ../db/drivers/ogr/fetch.c:160 ../db/drivers/ogr/describe.c:200
 msgid "Unknown type"
@@ -9688,12 +9688,12 @@
 #: ../db/drivers/ogr/cursor.c:74
 #, fuzzy
 msgid "Unable to add new token"
 #: ../db/drivers/ogr/execute.c:56 ../vector/v.out.ogr/main.c:593
 #, fuzzy, c-format
 msgid "OGR layer <%s> not found"
 #: ../db/drivers/ogr/execute.c:69 ../vector/v.reclass/main.c:145
 #: ../vector/v.out.lidar/main.c:118 ../vector/v.out.lidar/main.c:155
@@ -9705,27 +9705,27 @@
 #: ../vector/v.univar/main.c:355
 #, fuzzy, c-format
 msgid "Column <%s> not found in table <%s>"
-msgstr "Coluna <%s> não encontrada"
+msgstr "Coluna <%s> não encontrada"
 #: ../db/drivers/ogr/select.c:50
 #, fuzzy
 msgid "Unable to select: \n"
 #: ../db/drivers/ogr/select.c:58 ../db/drivers/ogr/describe.c:63
 #, fuzzy
 msgid "Unable to describe table\n"
 #: ../db/drivers/ogr/describe.c:55
 #, fuzzy, c-format
 msgid "OGR layer <%s> does not exist\n"
 #: ../db/drivers/ogr/describe.c:112
 #, fuzzy, c-format
 msgid "OGR driver: column '%s', OGR type %d is not supported"
-msgstr "Driver OGR : coluna '%s', tipo OGR %d não é suportado"
+msgstr "Driver OGR : coluna '%s', tipo OGR %d não é suportado"
 #: ../db/drivers/ogr/describe.c:192
 #, c-format
@@ -9739,7 +9739,7 @@
 #: ../db/db.tables/main.c:54
 #, fuzzy, c-format
 msgid "Unable to list tables from database <%s>"
 #: ../db/db.tables/main.c:60
 #, fuzzy
@@ -9756,7 +9756,7 @@
 #: ../db/db.tables/main.c:93
 #, fuzzy
 msgid "System tables instead of user tables"
-msgstr "tabelas do sistema ao invés de tabelas do usuário"
+msgstr "tabelas do sistema ao invés de tabelas do usuário"
 #: ../db/db.tables/main.c:99
 #, fuzzy
@@ -9767,32 +9767,32 @@
 #: ../general/g.cairocomp/main.c:256
 #, fuzzy
 msgid "Unable to open display"
-msgstr "Não consegui abrir display"
+msgstr "Não consegui abrir display"
 #: ../visualization/ximgview/main.c:84
 #, fuzzy
 msgid "Unable to get window attributes"
-msgstr "Não consegui obter atributos da janela"
+msgstr "Não consegui obter atributos da janela"
 #: ../visualization/ximgview/main.c:258
 #, fuzzy
 msgid "Unable to open image file"
-msgstr "Não consegui abrir arquivo de imagem"
+msgstr "Não consegui abrir arquivo de imagem"
 #: ../visualization/ximgview/main.c:261
 #, fuzzy
 msgid "Unable to read BMP header"
-msgstr "Não consegui ler cabeçalho do arquivo BMP"
+msgstr "Não consegui ler cabeçalho do arquivo BMP"
 #: ../visualization/ximgview/main.c:264
 #, fuzzy
 msgid "Invalid BMP header"
 #: ../visualization/ximgview/main.c:270
 #, fuzzy
 msgid "Unable to map image file"
 #: ../visualization/ximgview/main.c:291
 #: ../locale/scriptstrings/d.frame_to_translate.c:3
@@ -9913,7 +9913,7 @@
 #: ../misc/m.nviz.script/main.c:74 ../misc/m.nviz.image/main.c:51
 #, fuzzy
 msgid "visualization"
-msgstr "Número de pontos de interpolação"
+msgstr "Número de pontos de interpolação"
 #: ../visualization/ximgview/main.c:295
 msgid "View BMP images from the PNG driver."
@@ -9935,11 +9935,11 @@
 #: ../visualization/ximgview/color.c:239
 msgid "Unable to get sufficient gray shades."
-msgstr "Não encontrei obter tons de cinza suficientes."
+msgstr "Não encontrei obter tons de cinza suficientes."
 #: ../visualization/ximgview/color.c:256
 msgid "Unable to get sufficient colors."
-msgstr "Não consegui obter cores suficientes."
+msgstr "Não consegui obter cores suficientes."
 #: ../visualization/ximgview/color.c:269
 msgid "Using private colormap for DirectColor visual."
@@ -9956,12 +9956,12 @@
 #: ../doc/raster/r.example/main.c:86
 #, fuzzy
 msgid "My first raster module"
-msgstr "Meu primeiro módulo raster."
+msgstr "Meu primeiro módulo raster."
 #: ../doc/vector/v.example/main.c:53
 #, fuzzy
 msgid "My first vector module"
 #: ../doc/vector/v.example/main.c:75 ../raster/r.cost/main.c:325
 #: ../raster/r.carve/main.c:158 ../raster/r.walk/main.c:410
@@ -9980,12 +9980,12 @@
 #: ../vector/v.lidar.correction/main.c:182
 #, c-format
 msgid "Vector map <%s> not found"
-msgstr "Mapa vetorial <%s> não encontrado"
+msgstr "Mapa vetorial <%s> não encontrado"
 #: ../doc/vector/v.example/main.c:81 ../vector/v.cluster/main.c:144
 #, fuzzy
 msgid "Unable to set predetermined vector open level"
-msgstr "Nome do mapa de pontos de saída"
+msgstr "Nome do mapa de pontos de saída"
 #: ../doc/vector/v.example/main.c:105 ../display/d.vect.chart/plot.c:38
 #: ../display/d.vect.thematic/plot1.c:105 ../display/d.vect/shape.c:38
@@ -10000,12 +10000,12 @@
 #: ../vector/v.extrude/main.c:224 ../vector/v.univar/main.c:229
 #, fuzzy, c-format
 msgid "Database connection not defined for layer %d"
-msgstr "Conexão com banco de dados não definida para camada <%d>"
+msgstr "Conexão com banco de dados não definida para camada <%d>"
 #: ../doc/vector/v.example/main.c:170
 #, fuzzy, c-format
 msgid "Unable to get attribute data for cat %d"
-msgstr "Não consegui selecionar atributo para cat=%d"
+msgstr "Não consegui selecionar atributo para cat=%d"
 #: ../doc/vector/v.example/main.c:179
 #, fuzzy, c-format
@@ -10015,7 +10015,7 @@
 #: ../doc/vector/v.example/main.c:212
 #, fuzzy, c-format
 msgid "Unable to copy attribute table to vector map <%s>"
 #: ../raster/r.sim/simlib/input.c:307
 #, c-format
@@ -10058,8 +10058,8 @@
 #, fuzzy, c-format
 msgid "Number of iterations \t= %d cell\n"
 msgid_plural "Number of iterations \t= %d cells\n"
-msgstr[0] "Número de pontos de interpolação"
-msgstr[1] "Número de pontos de interpolação"
+msgstr[0] "Número de pontos de interpolação"
+msgstr[1] "Número de pontos de interpolação"
 #: ../raster/r.sim/simlib/input.c:506
 #, c-format
@@ -10081,12 +10081,12 @@
 #: ../raster/r.sim/simlib/input.c:562
 #, fuzzy
 msgid "Unable to write et file"
-msgstr "Não consegui escrever o arquivo temporário."
+msgstr "Não consegui escrever o arquivo temporário."
 #: ../raster/r.sim/simlib/output.c:321 ../raster/r.sim/simlib/output.c:329
 #, fuzzy, c-format
 msgid "FP raster map <%s> not found"
-msgstr "Mapa raster 3D <%s> não encontrado"
+msgstr "Mapa raster 3D <%s> não encontrado"
 #: ../raster/r.sim/simlib/hydro.c:203
 #, c-format
@@ -10096,23 +10096,23 @@
 #: ../raster/r.sim/simlib/hydro.c:398
 #, fuzzy
 msgid "Unable to write raster maps"
-msgstr "Não consegui criar arquivo raster [%s]."
+msgstr "Não consegui criar arquivo raster [%s]."
 #: ../raster/r.sim/simlib/hydro.c:465
 #: ../raster/r.sim/r.sim.sediment/main.c:411
 #, fuzzy
 msgid "Cannot write raster maps"
-msgstr "Não consegui criar mapa raster [%s]."
+msgstr "Não consegui criar mapa raster [%s]."
 #: ../raster/r.sim/simlib/observation_points.c:64
 #, fuzzy, c-format
 msgid "Unable to read points from map %s"
-msgstr "Não consegui ler linha %i\n"
+msgstr "Não consegui ler linha %i\n"
 #: ../raster/r.sim/simlib/observation_points.c:85
 #, fuzzy, c-format
 msgid "Unable to open observation logfile %s for writing"
 #: ../raster/r.sim/r.sim.sediment/main.c:115
 #: ../raster/r.sim/r.sim.water/main.c:115 ../raster/r.usler/main.c:55
@@ -10172,7 +10172,7 @@
 #, fuzzy
 msgid "Name of detachment capacity coefficient raster map [s/m]"
 msgstr ""
 #: ../raster/r.sim/r.sim.sediment/main.c:146
 #, fuzzy
@@ -10205,18 +10205,18 @@
 #: ../raster/r.sim/r.sim.sediment/main.c:177
 #, fuzzy
 msgid "Name for output transport capacity raster map [kg/ms]"
-msgstr "Gera arquivo com a direção da encosta"
+msgstr "Gera arquivo com a direção da encosta"
 #: ../raster/r.sim/r.sim.sediment/main.c:184
 #, fuzzy
 msgid ""
 "Name for output transport limited erosion-deposition raster map [kg/m2s]"
 #: ../raster/r.sim/r.sim.sediment/main.c:191
 #, fuzzy
 msgid "Name for output sediment concentration raster map [particle/m3]"
-msgstr "Gera uma mapa de direções"
+msgstr "Gera uma mapa de direções"
 #: ../raster/r.sim/r.sim.sediment/main.c:197
 #, fuzzy
@@ -10226,7 +10226,7 @@
 #: ../raster/r.sim/r.sim.sediment/main.c:204
 #, fuzzy
 msgid "Name for output erosion-deposition raster map [kg/m2s]"
 #: ../raster/r.sim/r.sim.sediment/main.c:211
 #: ../raster/r.sim/r.sim.water/main.c:222
@@ -10244,7 +10244,7 @@
 #: ../raster/r.sim/r.sim.sediment/main.c:225
 #, fuzzy
 msgid "Number of walkers"
-msgstr "Número de quadros"
+msgstr "Número de quadros"
 #: ../raster/r.sim/r.sim.sediment/main.c:233
 #: ../raster/r.sim/r.sim.water/main.c:238
@@ -10266,7 +10266,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:304
 #, fuzzy
 msgid "Seed for random number generator"
-msgstr "Semente para geração de número aleatório"
+msgstr "Semente para geração de número aleatório"
 #: ../raster/r.sim/r.sim.sediment/main.c:270
 #: ../raster/r.sim/r.sim.water/main.c:306
@@ -10319,7 +10319,7 @@
 #: ../raster/r.sim/r.sim.sediment/main.c:395
 #, fuzzy
 msgid "You are not outputting any raster or site files"
-msgstr "Você não está gerando nenhum arquivo raster ou vetorial"
+msgstr "Você não está gerando nenhum arquivo raster ou vetorial"
 #: ../raster/r.sim/r.sim.sediment/main.c:398
 #: ../raster/r.sim/r.sim.water/main.c:507 ../vector/v.surf.rst/main.c:623
@@ -10377,7 +10377,7 @@
 #: ../raster/r.sim/r.sim.water/main.c:202
 #, fuzzy
 msgid "Name for output water discharge raster map [m3/s]"
-msgstr "Gera arquivo raster com a curvatura média"
+msgstr "Gera arquivo raster com a curvatura média"
 #: ../raster/r.sim/r.sim.water/main.c:208
 #, fuzzy
@@ -10388,7 +10388,7 @@
 #, fuzzy
 msgid "Number of walkers, default is twice the number of cells"
 msgstr ""
-"Número de arquivos de elevação não coincide com o número arquivos de cor"
+"Número de arquivos de elevação não coincide com o número arquivos de cor"
 #: ../raster/r.sim/r.sim.water/main.c:274
 msgid "Threshold water depth [m]"
@@ -10409,12 +10409,12 @@
 #: ../raster/r.sim/r.sim.water/main.c:297
 #, fuzzy
 msgid "Time-series output"
-msgstr "Sobrescrever saídas"
+msgstr "Sobrescrever saídas"
 #: ../raster/r.sim/r.sim.water/main.c:504
 #, fuzzy
 msgid "You are not outputting any raster maps"
 #: ../raster/r.buffer/parse_dist.c:54
 #, fuzzy, c-format
@@ -10441,23 +10441,23 @@
 "Creates a raster map showing buffer zones surrounding cells that contain non-"
 "NULL category values."
 msgstr ""
-"Cria uma camada raster mostrando zonas tampão ao redor das células que "
-"contém valores de categoria não-NULOS."
+"Cria uma camada raster mostrando zonas tampão ao redor das células que "
+"contém valores de categoria não-NULOS."
 #: ../raster/r.buffer/main.c:81
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:6
 msgid "Distance zone(s)"
-msgstr "Zonas de distância"
+msgstr "Zonas de distância"
 #: ../raster/r.buffer/main.c:88
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:7
 msgid "Units of distance"
-msgstr "Unidade de distância"
+msgstr "Unidade de distância"
 #: ../raster/r.buffer/main.c:94
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:5
 msgid "Ignore zero (0) data cells instead of NULL cells"
-msgstr "Ignorar células com valores zero ao invés de células NULAS"
+msgstr "Ignorar células com valores zero ao invés de células NULAS"
 #: ../raster/r.buffer/main.c:131
 msgid "Parse distances error"
@@ -10482,14 +10482,14 @@
 #: ../raster/r.support/main.c:56
 msgid "Allows creation and/or modification of raster map layer support files."
 msgstr ""
-"Permite a criação e/ou modificação dos arquivos de suporte dos mapas raster"
+"Permite a criação e/ou modificação dos arquivos de suporte dos mapas raster"
 #: ../raster/r.support/main.c:66 ../raster/r.in.bin/main.c:298
 #: ../raster/r.external/main.c:90 ../raster/r.in.poly/main.c:50
 #: ../raster/r.in.gdal/main.c:133 ../raster/r.in.ascii/main.c:92
 #: ../locale/scriptstrings/r.import_to_translate.c:24
 msgid "Title for resultant raster map"
-msgstr "Título para o mapa resultante"
+msgstr "Título para o mapa resultante"
 #: ../raster/r.support/main.c:80
 msgid "Text to use for map data units"
@@ -10502,7 +10502,7 @@
 #: ../raster/r.support/main.c:129
 #, fuzzy
 msgid "Update statistics (histogram, range)"
-msgstr "Atualizar estatísticas (histograma, intervalo) para [%s]?"
+msgstr "Atualizar estatísticas (histograma, intervalo) para [%s]?"
 #: ../raster/r.support/main.c:133
 #, fuzzy
@@ -10517,12 +10517,12 @@
 #: ../raster/r.support/main.c:147 ../raster/r.category/main.c:130
 #, c-format
 msgid "Raster map <%s> not found in current mapset"
-msgstr "mapa vetorial <%s> não encontrado no mapset atual"
+msgstr "mapa vetorial <%s> não encontrado no mapset atual"
 #: ../raster/r.support/main.c:273 ../raster/r.support/main.c:301
 #, c-format
 msgid "[%s] is a reclass of another map. Exiting."
-msgstr "[%s] é uma reclassificação de outro mapa. Saindo."
+msgstr "[%s] é uma reclassificação de outro mapa. Saindo."
 #: ../raster/r.support/main.c:285
 #, c-format
@@ -10536,7 +10536,7 @@
 #: ../raster/r.support/main.c:312
 msgid "Done."
-msgstr "Concluído."
+msgstr "Concluído."
 #: ../raster/r.support/check.c:26
 #, c-format
@@ -10545,7 +10545,7 @@
 "  Updating statistics for [%s]"
 msgstr ""
 "\n"
-" Atualizando estatísticas para [%s]"
+" Atualizando estatísticas para [%s]"
 #: ../raster/r.support/check.c:69
 #, c-format
@@ -10553,7 +10553,7 @@
 "   Updating the number of categories for [%s]\n"
 "\n"
 msgstr ""
-"   Atualizando número de categorias de [%s]\n"
+"   Atualizando número de categorias de [%s]\n"
 "\n"
 #: ../raster/r.random.cells/init.c:77
@@ -10579,7 +10579,7 @@
 #: ../vector/v.extrude/main.c:69
 #, fuzzy
 msgid "sampling"
-msgstr "Método de amostragem"
+msgstr "Método de amostragem"
 #: ../raster/r.random.cells/main.c:49 ../raster/r.random.surface/main.c:59
 #: ../raster/r.surf.random/main.c:38 ../raster/r.random/main.c:54
@@ -10587,26 +10587,26 @@
 #: ../vector/v.perturb/main.c:65 ../vector/v.random/main.c:100
 #, fuzzy
 msgid "random"
 #: ../raster/r.random.cells/main.c:50
 #, fuzzy
 msgid "autocorrelation"
 #: ../raster/r.random.cells/main.c:52
 msgid "Generates random cell values with spatial dependence."
-msgstr "Gera valores aleatórios de célula com dependência espacial."
+msgstr "Gera valores aleatórios de célula com dependência espacial."
 #: ../raster/r.random.cells/main.c:62 ../raster/r.random.surface/main.c:77
 #, fuzzy
 msgid "Maximum distance of spatial correlation (value >= 0.0)"
-msgstr "Distância máxima do ponto para a rede"
+msgstr "Distância máxima do ponto para a rede"
 #: ../raster/r.random.cells/main.c:70
 #, fuzzy
 msgid "Maximum number of cells to be created"
-msgstr "Número máximo de iterações: %d\n"
+msgstr "Número máximo de iterações: %d\n"
 #: ../raster/r.random.cells/main.c:77
 msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
@@ -10639,7 +10639,7 @@
 #: ../raster/r.what/main.c:102
 #, fuzzy
 msgid "Queries raster maps on their category values and category labels."
-msgstr "Pesquisa valores e rótulos de categoria em camadas de mapa raster."
+msgstr "Pesquisa valores e rótulos de categoria em camadas de mapa raster."
 #: ../raster/r.what/main.c:106
 msgid "Name of existing raster map(s) to query"
@@ -10671,12 +10671,12 @@
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:11
 #, fuzzy
 msgid "Output header row"
-msgstr "Mapa raster de saída"
+msgstr "Mapa raster de saída"
 #: ../raster/r.what/main.c:146
 #, fuzzy
 msgid "Show the category labels of the grid cell(s)"
-msgstr "Mostra os rótulos de categoria na célula da malha"
+msgstr "Mostra os rótulos de categoria na célula da malha"
 #: ../raster/r.what/main.c:151
 msgid "Output color values as RRR:GGG:BBB"
@@ -10684,16 +10684,16 @@
 #: ../raster/r.what/main.c:156
 msgid "Output integer category values, not cell values"
-msgstr "Gera valores inteiros de categorias, em vez de valores de célula"
+msgstr "Gera valores inteiros de categorias, em vez de valores de célula"
 #: ../raster/r.what/main.c:161
 msgid "Turn on cache reporting"
-msgstr "Habilitar relatório de cache"
+msgstr "Habilitar relatório de cache"
 #: ../raster/r.what/main.c:201
 #, fuzzy, c-format
 msgid "Can only do up to %d raster maps (%d given)"
-msgstr "Nome do arquivo RASTER3D de saída"
+msgstr "Nome do arquivo RASTER3D de saída"
 #: ../raster/r.what/main.c:217
 #, fuzzy, c-format
@@ -10703,7 +10703,7 @@
 #: ../raster/r.what/main.c:296
 #, fuzzy, c-format
 msgid "Unable to read vector map <%s>"
 #: ../raster/r.what/main.c:300
 #, c-format
@@ -10713,7 +10713,7 @@
 #: ../raster/r.what/main.c:384
 #, fuzzy, c-format
 msgid "%s %s is outside your current region"
-msgstr "Não existe mapa rasterna janela atual"
+msgstr "Não existe mapa rasterna janela atual"
 #: ../raster/r.random.surface/init.c:73
 #, c-format
@@ -10723,12 +10723,12 @@
 #: ../raster/r.random.surface/init.c:82
 #, fuzzy, c-format
 msgid "Rastar map <%s> repeated, maps must be unique"
 #: ../raster/r.random.surface/init.c:92
 #, fuzzy
 msgid "Output raster map required"
-msgstr "Título do raster de saída"
+msgstr "Título do raster de saída"
 #: ../raster/r.random.surface/init.c:108
 #, c-format
@@ -10781,16 +10781,16 @@
 #: ../vector/v.vol.rst/main.c:237
 #, fuzzy
 msgid "surface"
-msgstr "Variância da soma"
+msgstr "Variância da soma"
 #: ../raster/r.random.surface/main.c:61
 msgid "Generates random surface(s) with spatial dependence."
-msgstr "Gera superfícies aleatórias com dependência espacial."
+msgstr "Gera superfícies aleatórias com dependência espacial."
 #: ../raster/r.random.surface/main.c:68
 #, fuzzy
 msgid "Name for output raster map(s)"
-msgstr "Nome do Raster de saída"
+msgstr "Nome do Raster de saída"
 #: ../raster/r.random.surface/main.c:85
 #, fuzzy
@@ -10808,7 +10808,7 @@
 #: ../raster/r.random.surface/main.c:108
 #, fuzzy
 msgid "Maximum cell value of distribution"
-msgstr "Número de iterações máximas"
+msgstr "Número de iterações máximas"
 #: ../raster/r.random.surface/main.c:113
 msgid "Uniformly distributed cell values"
@@ -10824,16 +10824,16 @@
 msgid ""
 "Produces a raster surface map of uniform random deviates with defined range."
 msgstr ""
-"Produz uma camada de mapa raster com desvios aleatórios uniformes, cujo "
-"intervalo pode ser expresso pelo usuário."
+"Produz uma camada de mapa raster com desvios aleatórios uniformes, cujo "
+"intervalo pode ser expresso pelo usuário."
 #: ../raster/r.surf.random/main.c:46
 msgid "Minimum random value"
-msgstr "Mínimo valor aleatório"
+msgstr "Mínimo valor aleatório"
 #: ../raster/r.surf.random/main.c:52
 msgid "Maximum random value"
-msgstr "Máximo valor aleatório"
+msgstr "Máximo valor aleatório"
 #: ../raster/r.surf.random/main.c:58
 #, fuzzy
@@ -10855,12 +10855,12 @@
 #: ../raster/r.tile/main.c:55
 #, fuzzy
 msgid "Output base name"
 #: ../raster/r.tile/main.c:62
 #, fuzzy
 msgid "Width of tiles (columns)"
-msgstr "Lista de curvas de nível"
+msgstr "Lista de curvas de nível"
 #: ../raster/r.tile/main.c:69
 #, fuzzy
@@ -10870,7 +10870,7 @@
 #: ../raster/r.tile/main.c:76
 #, fuzzy
 msgid "Overlap of tiles"
 #: ../raster/r.tile/main.c:129
 #, fuzzy, c-format
@@ -10880,13 +10880,13 @@
 #: ../raster/r.tile/main.c:184
 #, fuzzy, c-format
 msgid "Unable to read cats for %s"
-msgstr "%s: não consegui criar %s"
+msgstr "%s: não consegui criar %s"
 #: ../raster/r.tile/main.c:200 ../raster/r.resamp.filter/main.c:579
 #: ../raster/r.resamp.stats/main.c:389 ../raster/r.resamp.interp/main.c:370
 #, fuzzy, c-format
 msgid "Unable to read color table for %s"
 #: ../raster/r.topidx/file_io.c:35
 #, c-format
@@ -10899,12 +10899,12 @@
 #: ../raster/r.topidx/file_io.c:42
 #, fuzzy
 msgid "Reading elevation map..."
-msgstr "Mapa de elevação"
+msgstr "Mapa de elevação"
 #: ../raster/r.topidx/file_io.c:87
 #, fuzzy
 msgid "Writing topographic index map..."
-msgstr "Mapa de índice topográfico [ln(a/tanB)]"
+msgstr "Mapa de índice topográfico [ln(a/tanB)]"
 #: ../raster/r.topidx/main.c:41
 msgid "wetness"
@@ -10916,24 +10916,24 @@
 "Creates a topographic index (wetness index) raster map from an elevation "
 "raster map."
 msgstr ""
-"Cria um índice topográfico, ln (a/tan(beta)), mapeia do mapa de elevação."
+"Cria um índice topográfico, ln (a/tan(beta)), mapeia do mapa de elevação."
 #: ../raster/r.topidx/main.c:49
 #, fuzzy
 msgid "Name for output topographic index raster map"
 #: ../raster/r.topidx/main.c:56 ../raster/r.gwflow/main.c:222
 #: ../raster/r.carve/main.c:213 ../raster/r.solute.transport/main.c:244
 #, c-format
 msgid "Lat/Long location is not supported by %s. Please reproject map first."
 msgstr ""
-"Locação Lat/Long não é suportada por %s. Favor reprojetar o mapa primeiro."
+"Locação Lat/Long não é suportada por %s. Favor reprojetar o mapa primeiro."
 #: ../raster/r.topidx/topidx.c:272
 #, fuzzy, c-format
 msgid "Number of sinks or boundaries: %d"
-msgstr "Número de pontos de entrada: %d."
+msgstr "Número de pontos de entrada: %d."
 #: ../raster/r.rescale/main.c:49 ../raster/r.rescale.eq/main.c:53
 #, fuzzy
@@ -10951,7 +10951,7 @@
 #: ../raster/r.rescale/main.c:64 ../raster/r.rescale.eq/main.c:69
 msgid "The input data range to be rescaled (default: full range of input map)"
 msgstr ""
-"Intervalo dos dados de entrada a ser reescalonados (padrão: intervalo "
+"Intervalo dos dados de entrada a ser reescalonados (padrão: intervalo "
 "completo do mapa de entrada)"
 #: ../raster/r.rescale/main.c:67 ../raster/r.rescale.eq/main.c:72
@@ -10960,11 +10960,11 @@
 #: ../raster/r.rescale/main.c:74 ../raster/r.rescale.eq/main.c:79
 msgid "The output data range"
-msgstr "Intervalo dos dados de saída"
+msgstr "Intervalo dos dados de saída"
 #: ../raster/r.rescale/main.c:81 ../raster/r.rescale.eq/main.c:86
 msgid "Title for new raster map"
-msgstr "Título para o novo mapa raster"
+msgstr "Título para o novo mapa raster"
 #: ../raster/r.rescale/main.c:110
 #, c-format
@@ -11001,13 +11001,13 @@
 #, fuzzy
 msgid "Thins non-null cells that denote linear features in a raster map layer."
 msgstr ""
-"Afina células não-zero que indicam feições lineares em uma camada de mapa "
+"Afina células não-zero que indicam feições lineares em uma camada de mapa "
 "raster."
 #: ../raster/r.thin/main.c:72
 #, fuzzy
 msgid "Maximal number of iterations"
 #: ../raster/r.thin/io.c:98
 #, fuzzy
@@ -11045,7 +11045,7 @@
 #: ../raster/r.thin/io.c:122
 #, fuzzy, c-format
 msgid "Unable to create temporary file <%s> -- errno = %d"
 #: ../raster/r.thin/io.c:131 ../raster/r.thin/io.c:138
 #: ../raster/r.thin/io.c:147 ../raster/r.resamp.rst/main.c:547
@@ -11069,7 +11069,7 @@
 #: ../raster/r.thin/thin_lines.c:67
 #, fuzzy
 msgid "Unable to find bounding box for lines"
-msgstr "Não exibir números de categorias"
+msgstr "Não exibir números de categorias"
 #: ../raster/r.thin/thin_lines.c:69
 #, c-format
@@ -11079,7 +11079,7 @@
 #: ../raster/r.thin/thin_lines.c:116
 #, fuzzy, c-format
 msgid "Pass number %d"
-msgstr "Camada número"
+msgstr "Camada número"
 #: ../raster/r.thin/thin_lines.c:167
 #, fuzzy, c-format
@@ -11124,17 +11124,17 @@
 "angle and/or irradiance raster maps. The shadowing effect of the topography "
 "is optionally incorporated."
 msgstr ""
-"Calcula mapas raster de irradiação solar direta(feixe) difusa e refletida "
-"para um dado dia, latitude, superfície e condições atmosféricas. Parâmetros "
-"solares (p.ex. alvorada, ocaso, declinação, irradiância extraterreste, "
-"comprimento do dia) são guardados num arquivo de histórico de mapa. "
-"Alternativamente, um horário local pode ser especificado para calcular "
-"ângulo de incidência solar e/ou mapas raster de irradiância. O efeito de "
-"sombreamento da topografia também pode ser opcionalmente incorporado."
+"Calcula mapas raster de irradiação solar direta(feixe) difusa e refletida "
+"para um dado dia, latitude, superfície e condições atmosféricas. Parâmetros "
+"solares (p.ex. alvorada, ocaso, declinação, irradiância extraterreste, "
+"comprimento do dia) são guardados num arquivo de histórico de mapa. "
+"Alternativamente, um horário local pode ser especificado para calcular "
+"ângulo de incidência solar e/ou mapas raster de irradiância. O efeito de "
+"sombreamento da topografia também pode ser opcionalmente incorporado."
 #: ../raster/r.sun/main.c:259
 msgid "Name of the input elevation raster map [meters]"
-msgstr "Nome do arquivo raster de elevação para entrada (metros)"
+msgstr "Nome do arquivo raster de elevação para entrada (metros)"
 #: ../raster/r.sun/main.c:268
 msgid ""
@@ -11146,29 +11146,29 @@
 #: ../raster/r.sun/main.c:277
 msgid "A single value of the orientation (aspect), 270 is south"
-msgstr "Um único valor da orientação (aspecto), 270 é sul"
+msgstr "Um único valor da orientação (aspecto), 270 é sul"
 #: ../raster/r.sun/main.c:286
 msgid ""
 "Name of the input slope raster map (terrain slope or solar panel "
 "inclination) [decimal degrees]"
 msgstr ""
-"Nome do mapa de declividade (declividade do terreno ou inclinação do painel "
+"Nome do mapa de declividade (declividade do terreno ou inclinação do painel "
 "solar) [graus decimais]"
 #: ../raster/r.sun/main.c:294
 msgid "A single value of inclination (slope)"
-msgstr "Um único valor de inclinação (declividade)"
+msgstr "Um único valor de inclinação (declividade)"
 #: ../raster/r.sun/main.c:303
 msgid ""
 "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
 msgstr ""
-"Nome do arquivo raster com o coeficiente de turbidez atmosférica de Linke [-]"
+"Nome do arquivo raster com o coeficiente de turbidez atmosférica de Linke [-]"
 #: ../raster/r.sun/main.c:312
 msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
-msgstr "Um único valor para o coeficiente de turbidez atmosférica de Linke [-]"
+msgstr "Um único valor para o coeficiente de turbidez atmosférica de Linke [-]"
 #: ../raster/r.sun/main.c:321
 msgid "Name of the ground albedo coefficient input raster map [-]"
@@ -11176,7 +11176,7 @@
 #: ../raster/r.sun/main.c:330
 msgid "A single value of the ground albedo coefficient [-]"
-msgstr "Um único valor para o albedo do solo [-]"
+msgstr "Um único valor para o albedo do solo [-]"
 #: ../raster/r.sun/main.c:339
 #, fuzzy
@@ -11194,18 +11194,18 @@
 "Name of real-sky beam radiation coefficient (thick cloud) input raster map "
 "[0-1]"
 msgstr ""
-"Nome do mapa raster com o coeficiente de radiação do feixe de céu real [-]"
+"Nome do mapa raster com o coeficiente de radiação do feixe de céu real [-]"
 #: ../raster/r.sun/main.c:366
 #, fuzzy
 msgid ""
 "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
-msgstr "Nome do mapa raster do coeficiente de radiação difusa de céu real [-]"
+msgstr "Nome do mapa raster do coeficiente de radiação difusa de céu real [-]"
 #: ../raster/r.sun/main.c:373
 #, fuzzy
 msgid "The horizon information input map basename"
-msgstr "O prefixo de mapa de entrada de informações do horizonte"
+msgstr "O prefixo de mapa de entrada de informações do horizonte"
 #: ../raster/r.sun/main.c:381 ../raster/r.horizon/main.c:211
 msgid "Angle step size for multidirectional horizon [degrees]"
@@ -11213,58 +11213,58 @@
 #: ../raster/r.sun/main.c:390
 msgid "Output incidence angle raster map (mode 1 only)"
-msgstr "Saída de mapa de ângulo de incidência (apenas modo 1)"
+msgstr "Saída de mapa de ângulo de incidência (apenas modo 1)"
 #: ../raster/r.sun/main.c:399
 msgid ""
 "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
 "day-1] (mode 2)"
 msgstr ""
-"Saída de irradiação do feixe [W.m-2] (modo 1) ou arquivo raster de "
-"irradiação [Wh.m².dia-1] (modo 2)"
+"Saída de irradiação do feixe [W.m-2] (modo 1) ou arquivo raster de "
+"irradiação [Wh.m².dia-1] (modo 2)"
 #: ../raster/r.sun/main.c:408
 msgid ""
 "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
 "day-1] (mode 2)"
 msgstr ""
-"Saída de irradiação difusa [W.m-2] (modo 1) ou arquivo raster de irradiação "
-"[Wh.m².dia-1] (modo 2)"
+"Saída de irradiação difusa [W.m-2] (modo 1) ou arquivo raster de irradiação "
+"[Wh.m².dia-1] (modo 2)"
 #: ../raster/r.sun/main.c:417
 msgid ""
 "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
 "map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
-"Saída de irradiação refletida [W.m-2] (modo 1) ou arquivo raster de "
+"Saída de irradiação refletida [W.m-2] (modo 1) ou arquivo raster de "
 #: ../raster/r.sun/main.c:426
 msgid ""
 "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
 "irradiation raster map [Wh.m-2.day-1] (mode 2)"
 msgstr ""
-"Saída de irradiação global (total) do feixe [W.m-2] (modo 1) ou arquivo "
-"raster de irradiação [Wh.m-2.dia-1] (modo 2)"
+"Saída de irradiação global (total) do feixe [W.m-2] (modo 1) ou arquivo "
+"raster de irradiação [Wh.m-2.dia-1] (modo 2)"
 #: ../raster/r.sun/main.c:435
 msgid "Output insolation time raster map [h] (mode 2 only)"
-msgstr "Saída de mapa raster de tempo de insolação [h] (apenas modo 2)"
+msgstr "Saída de mapa raster de tempo de insolação [h] (apenas modo 2)"
 #: ../raster/r.sun/main.c:442
 msgid "No. of day of the year (1-365)"
-msgstr "Número do dia do ano (1-365)"
+msgstr "Número do dia do ano (1-365)"
 #: ../raster/r.sun/main.c:452
 msgid "Time step when computing all-day radiation sums [decimal hours]"
 msgstr ""
-"Intervalo de tempo para computar soma de radiação do dia todo [horas "
+"Intervalo de tempo para computar soma de radiação do dia todo [horas "
 "decimais]"
 #: ../raster/r.sun/main.c:460
 msgid "Declination value (overriding the internally computed value) [radians]"
 msgstr ""
-"Valor de declinação (sobrepõe o valor calculado internamente) [radianos]"
+"Valor de declinação (sobrepõe o valor calculado internamente) [radianos]"
 #: ../raster/r.sun/main.c:468
 msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
@@ -11307,7 +11307,7 @@
 #: ../raster/r.sun/main.c:590
 msgid "insol_time and incidout are incompatible options"
-msgstr "insol_time e incidout são opções incompatíveis"
+msgstr "insol_time e incidout são opções incompatíveis"
 #: ../raster/r.sun/main.c:595
 msgid "Error reading time step size"
@@ -11316,7 +11316,7 @@
 #: ../raster/r.sun/main.c:597
 #, fuzzy
 msgid "Invalid time step size"
-msgstr "Fonte inválida: %s"
+msgstr "Fonte inválida: %s"
 #: ../raster/r.sun/main.c:601
 msgid "Error reading horizon step size"
@@ -11333,7 +11333,7 @@
 #: ../raster/r.sun/main.c:615
 msgid "Time and insol_time are incompatible options"
-msgstr "Tempo e insol_time são opções incompatíveis"
+msgstr "Tempo e insol_time são opções incompatíveis"
 #: ../raster/r.sun/main.c:617
 #, fuzzy
@@ -11341,16 +11341,16 @@
 "Mode 1: instantaneous solar incidence angle & irradiance using a set local "
 "time"
 msgstr ""
-"Mode 1: irradiância & ângulo de incidência solar instatâneos usando uma hora "
+"Mode 1: irradiância & ângulo de incidência solar instatâneos usando uma hora "
 "local ajustada"
 #: ../raster/r.sun/main.c:622
 msgid "incidout requires time parameter to be set"
-msgstr "incidout precisa que o parâmetro de tempo seja ajustado"
+msgstr "incidout precisa que o parâmetro de tempo seja ajustado"
 #: ../raster/r.sun/main.c:624
 msgid "Mode 2: integrated daily irradiation for a given day of the year"
-msgstr "Modo 2: irradiação diária integrada para um dado dia do ano"
+msgstr "Modo 2: irradiação diária integrada para um dado dia do ano"
 #: ../raster/r.sun/main.c:647
 #, fuzzy, c-format
@@ -11370,7 +11370,7 @@
 #: ../raster/r.sun/main.c:656
 #, fuzzy, c-format
 msgid "Using albedo map <%s>"
 #: ../raster/r.sun/main.c:661
 #, fuzzy, c-format
@@ -11406,13 +11406,13 @@
 #: ../display/d.where/main.c:107 ../general/g.region/printwindow.c:241
 #: ../general/g.region/printwindow.c:497 ../general/g.region/printwindow.c:616
 msgid "Can't get projection info of current location"
-msgstr "Não consegui informações de projeção da locação atual"
+msgstr "Não consegui informações de projeção da locação atual"
 #: ../raster/r.sun/main.c:749 ../raster/r.horizon/main.c:534
 #: ../display/d.where/main.c:110 ../general/g.region/printwindow.c:244
 #: ../general/g.region/printwindow.c:500 ../general/g.region/printwindow.c:619
 msgid "Can't get projection units of current location"
-msgstr "Não consegui unidades de projeção da locação atual"
+msgstr "Não consegui unidades de projeção da locação atual"
 #: ../raster/r.sun/main.c:767
 msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
@@ -11424,7 +11424,7 @@
 #: ../raster/r.to.rast3/main.c:59 ../raster/r.to.rast3elev/main.c:136
 msgid "Could not close the map"
-msgstr "Não consegui fechar o mapa"
+msgstr "Não consegui fechar o mapa"
 #: ../raster/r.to.rast3/main.c:79
 #, fuzzy
@@ -11438,7 +11438,7 @@
 #: ../raster/r.to.rast3/main.c:93
 #, fuzzy
 msgid "Use 3D raster mask (if exists) with output map"
-msgstr "Usa máscara G3D (se existir) com o mapa de entrada"
+msgstr "Usa máscara G3D (se existir) com o mapa de entrada"
 #: ../raster/r.to.rast3/main.c:201
 #, fuzzy
@@ -11447,7 +11447,7 @@
 #: ../raster/r.to.rast3/main.c:213
 msgid "No output map"
-msgstr "Sem mapa de saída"
+msgstr "Sem mapa de saída"
 #: ../raster/r.to.rast3/main.c:230
 #, fuzzy
@@ -11455,8 +11455,8 @@
 "The 2D and 3D region settings are different. Using the 3D region settings to "
 "adjust the 2D region."
 msgstr ""
-"As configurações de região 2d e 3d estão diferentes. Usarei as configurações "
-"g3d para ajustar a região 2d."
+"As configurações de região 2d e 3d estão diferentes. Usarei as configurações "
+"g3d para ajustar a região 2d."
 #: ../raster/r.to.rast3/main.c:262
 #, fuzzy, c-format
@@ -11484,16 +11484,16 @@
 #: ../raster/r.out.png/main.c:116
 #, fuzzy
 msgid "Export a GRASS raster map as a non-georeferenced PNG image."
-msgstr "Exporta um raster do GRASS para um arquivo binário"
+msgstr "Exporta um raster do GRASS para um arquivo binário"
 #: ../raster/r.out.png/main.c:122
 #, fuzzy
 msgid "Name for new PNG file (use '-' for stdout)"
-msgstr "Nome para novo arquivo PPM. (use out=- para saída padrão)"
+msgstr "Nome para novo arquivo PPM. (use out=- para saída padrão)"
 #: ../raster/r.out.png/main.c:130
 msgid "Compression level of PNG file"
-msgstr "Nível de Compactação do arquivo PNG"
+msgstr "Nível de Compactação do arquivo PNG"
 #: ../raster/r.out.png/main.c:131
 msgid "(0 = none, 1 = fastest, 9 = best)"
@@ -11506,7 +11506,7 @@
 #: ../raster/r.out.png/main.c:142
 #, fuzzy
 msgid "Output world file"
-msgstr "Arquivo world de saída"
+msgstr "Arquivo world de saída"
 #: ../raster/r.out.png/main.c:175 ../display/d.labels/color.c:68
 #: ../display/d.rast/display.c:27 ../display/d.graph/do_graph.c:105
@@ -11515,7 +11515,7 @@
 #: ../display/d.legend.vect/draw.c:209
 #, c-format
 msgid "[%s]: No such color"
-msgstr "[%s]: cor não existe"
+msgstr "[%s]: cor não existe"
 #: ../raster/r.out.png/main.c:257
 #, c-format
@@ -11525,7 +11525,7 @@
 #: ../raster/r.out.png/main.c:272 ../raster/r.univar/r.univar_main.c:201
 #, c-format
 msgid "Raster <%s> type mismatch"
-msgstr "tipo do raster <%s> não combina"
+msgstr "tipo do raster <%s> não combina"
 #: ../raster/r.out.png/main.c:422
 #, fuzzy
@@ -11538,20 +11538,20 @@
 #: ../raster/r.out.png/main.c:427
 msgid "Got null region struct"
-msgstr "Recebi estrutura da região nula"
+msgstr "Recebi estrutura da região nula"
 #: ../raster/r.out.png/main.c:429
 #, fuzzy
 msgid "Unable to open world file for writing"
-msgstr "Não consegui abrir o arquivo world para escrita"
+msgstr "Não consegui abrir o arquivo world para escrita"
 #: ../raster/r.region/main.c:54
 msgid "Sets the boundary definitions for a raster map."
-msgstr "Ajusta as definições de fronteira para um mapa raster"
+msgstr "Ajusta as definições de fronteira para um mapa raster"
 #: ../raster/r.region/main.c:60
 msgid "Set from current region"
-msgstr "Ajustar pela região atual"
+msgstr "Ajustar pela região atual"
 #: ../raster/r.region/main.c:61 ../raster/r.region/main.c:66
 #: ../raster/r.region/main.c:81 ../raster/r.region/main.c:88
@@ -11564,25 +11564,25 @@
 #: ../raster/r.region/main.c:65 ../general/g.region/main.c:73
 msgid "Set from default region"
 #: ../raster/r.region/main.c:71
 #, fuzzy
 msgid "Name of raster map to change"
-msgstr "Nome do mapa de orientação para exibição"
+msgstr "Nome do mapa de orientação para exibição"
 #: ../raster/r.region/main.c:79
 #, fuzzy
 msgid "Set region from named region"
-msgstr "Definir região atual pela região designada"
+msgstr "Definir região atual pela região designada"
 #: ../raster/r.region/main.c:87
 msgid "Set region to match this raster map"
-msgstr "Ajustar a região coincidente com esse mapa raster"
+msgstr "Ajustar a região coincidente com esse mapa raster"
 #: ../raster/r.region/main.c:94
 msgid "Set region to match this vector map"
-msgstr "Ajustar a região coincidente com esse mapa vetorial"
+msgstr "Ajustar a região coincidente com esse mapa vetorial"
 #: ../raster/r.region/main.c:103 ../general/g.region/main.c:199
 msgid "Value for the northern edge"
@@ -11606,11 +11606,11 @@
 #: ../raster/r.mfilter/getrow.c:23
 msgid "Error reading temporary file"
-msgstr "Erro ao ler arquivo temporário"
+msgstr "Erro ao ler arquivo temporário"
 #: ../raster/r.mfilter/perform.c:40 ../raster/r.mfilter/perform.c:51
 msgid "Unable to create temporary file"
-msgstr "Não consegui criar arquivo temporário"
+msgstr "Não consegui criar arquivo temporário"
 #: ../raster/r.mfilter/perform.c:81
 #, c-format
@@ -11629,11 +11629,11 @@
 #: ../raster/r.mfilter/main.c:79
 msgid "Number of times to repeat the filter"
-msgstr "Número de vezes para repetir o filtro"
+msgstr "Número de vezes para repetir o filtro"
 #: ../raster/r.mfilter/main.c:86
 msgid "Output raster map title"
 #: ../raster/r.mfilter/main.c:98
 msgid "Apply filter only to null data values"
@@ -11646,11 +11646,11 @@
 #: ../raster/r.mfilter/getfilt.c:27
 #, c-format
 msgid "Cannot open filter file '%s'"
-msgstr "Não consegui abrir o arquivo de filtro '%s'"
+msgstr "Não consegui abrir o arquivo de filtro '%s'"
 #: ../raster/r.mfilter/getfilt.c:47
 msgid "Illegal filter matrix size specified"
-msgstr "Tamanho especificado para a matriz de filtro é ilegal"
+msgstr "Tamanho especificado para a matriz de filtro é ilegal"
 #: ../raster/r.mfilter/getfilt.c:50
 #, fuzzy
@@ -11680,7 +11680,7 @@
 #: ../raster/r.mfilter/getfilt.c:117
 msgid "Illegal filter type specified"
-msgstr "tipo de filtro especificado é ilegal"
+msgstr "tipo de filtro especificado é ilegal"
 #: ../raster/r.mfilter/getfilt.c:127
 msgid "Duplicate filter start specified"
@@ -11698,19 +11698,19 @@
 #: ../raster/r.transect/main.c:84
 #, fuzzy, c-format
 msgid "End coordinate: %.15g, %.15g"
-msgstr "Coordenadas inválidas %s %s"
+msgstr "Coordenadas inválidas %s %s"
 #: ../raster/r.transect/main.c:104
 #, fuzzy
 msgid "transect"
-msgstr "Inportação de vetor incompleta"
+msgstr "Inportação de vetor incompleta"
 #: ../raster/r.transect/main.c:106
 msgid ""
 "Outputs raster map layer values lying along user defined transect line(s)."
 msgstr ""
 "Gera uma camada de valores de um mapa raster ao redor de linhas de perfil "
-"definidas pelo usuário."
+"definidas pelo usuário."
 #: ../raster/r.transect/main.c:110
 msgid "Raster map to be queried"
@@ -11718,12 +11718,12 @@
 #: ../raster/r.transect/main.c:116
 msgid "Transect definition"
-msgstr "Definição do perfil"
+msgstr "Definição do perfil"
 #: ../raster/r.transect/main.c:126 ../raster/r.profile/main.c:93
 msgid "Output easting and northing in first two columns of four column output"
 msgstr ""
-"Exporta leste e norte nas duas primeiras colunas da saída de quatro colunas"
+"Exporta leste e norte nas duas primeiras colunas da saída de quatro colunas"
 #: ../raster/r.slope.aspect/main.c:153
 msgid "aspect"
@@ -11736,7 +11736,7 @@
 #: ../raster/r.slope.aspect/main.c:155
 #, fuzzy
 msgid "curvature"
-msgstr "Tipo de feição"
+msgstr "Tipo de feição"
 #: ../raster/r.slope.aspect/main.c:156
 #, fuzzy
@@ -11744,19 +11744,19 @@
 "Generates raster maps of slope, aspect, curvatures and partial derivatives "
 "from an elevation raster map."
 msgstr ""
-"Gera mapas raster de declividade, direção da encosta, curvaturas e derivadas "
-"parciais a partir de um mapa raster com valores verdadeiros de elevação. "
-"Aspecto é calculado no sentido anti-horário a partir do leste."
+"Gera mapas raster de declividade, direção da encosta, curvaturas e derivadas "
+"parciais a partir de um mapa raster com valores verdadeiros de elevação. "
+"Aspecto é calculado no sentido anti-horário a partir do leste."
 #: ../raster/r.slope.aspect/main.c:158
 #, fuzzy
 msgid "Aspect is calculated counterclockwise from east."
-msgstr "Ângulo de rotação (em graus anti-horários a partir do leste)"
+msgstr "Ângulo de rotação (em graus anti-horários a partir do leste)"
 #: ../raster/r.slope.aspect/main.c:165 ../vector/v.surf.rst/main.c:195
 #, fuzzy
 msgid "Name for output slope raster map"
 #: ../raster/r.slope.aspect/main.c:166 ../raster/r.slope.aspect/main.c:172
 #: ../raster/r.slope.aspect/main.c:196 ../raster/r.slope.aspect/main.c:203
@@ -11784,12 +11784,12 @@
 #: ../vector/v.vol.rst/main.c:397 ../vector/v.vol.rst/main.c:403
 #, fuzzy
 msgid "Outputs"
-msgstr "Saída de mapa"
+msgstr "Saída de mapa"
 #: ../raster/r.slope.aspect/main.c:171 ../vector/v.surf.rst/main.c:201
 #, fuzzy
 msgid "Name for output aspect raster map"
 #: ../raster/r.slope.aspect/main.c:180
 msgid "Format for reporting the slope"
@@ -11797,7 +11797,7 @@
 #: ../raster/r.slope.aspect/main.c:187
 msgid "Type of output aspect and slope maps"
-msgstr "Tipo dos mapas de saída de direção e declividade de encosta"
+msgstr "Tipo dos mapas de saída de direção e declividade de encosta"
 #: ../raster/r.slope.aspect/main.c:195 ../vector/v.surf.rst/main.c:207
 #, fuzzy
@@ -11839,24 +11839,24 @@
 #: ../raster/r.slope.aspect/main.c:243
 #, fuzzy
 msgid "Multiplicative factor to convert elevation units to horizontal units"
-msgstr "Fator de multiplicação para converter unidades de elevação para metros"
+msgstr "Fator de multiplicação para converter unidades de elevação para metros"
 #: ../raster/r.slope.aspect/main.c:252
 #, fuzzy
 msgid "Minimum slope value (in percent) for which aspect is computed"
 msgstr ""
-"Mínimo valor da declividade (em porcentagem) para qual o aspecto será "
+"Mínimo valor da declividade (em porcentagem) para qual o aspecto será "
 "computado"
 #: ../raster/r.slope.aspect/main.c:261
 #, fuzzy
 msgid "Do not align the current region to the raster elevation map"
-msgstr "Não alinhar a região atual para a camada de elevação"
+msgstr "Não alinhar a região atual para a camada de elevação"
 #: ../raster/r.slope.aspect/main.c:315 ../raster/r.relief/main.c:220
 #, fuzzy, c-format
 msgid "%s=%s - must be a positive number"
-msgstr "Suavização deve ser um valor positivo"
+msgstr "Suavização deve ser um valor positivo"
 #: ../raster/r.slope.aspect/main.c:321 ../raster/r.relief/main.c:201
 #: ../raster/r.relief/main.c:207
@@ -11892,27 +11892,27 @@
 #: ../raster/r.slope.aspect/main.c:968
 #, fuzzy, c-format
 msgid "Elevation products for mapset <%s> in <%s>"
-msgstr "Não consegui abrir mapa raster [%s] em [%s]"
+msgstr "Não consegui abrir mapa raster [%s] em [%s]"
 #: ../raster/r.slope.aspect/main.c:987
 #, fuzzy, c-format
 msgid "Min computed aspect %.4f, max computed aspect %.4f"
-msgstr "mín. orientação calculada %.4f  máx. orientação calculada %.4f"
+msgstr "mín. orientação calculada %.4f  máx. orientação calculada %.4f"
 #: ../raster/r.slope.aspect/main.c:1051
 #, fuzzy, c-format
 msgid "Aspect raster map <%s> complete"
-msgstr "Arquivo de células [%s] não encontrado"
+msgstr "Arquivo de células [%s] não encontrado"
 #: ../raster/r.slope.aspect/main.c:1108
 #, fuzzy, c-format
 msgid "Min computed slope %.4f, max computed slope %.4f"
-msgstr "mín. declividade calculada %.4f  máx. declividade calculada %.4f"
+msgstr "mín. declividade calculada %.4f  máx. declividade calculada %.4f"
 #: ../raster/r.slope.aspect/main.c:1161
 #, fuzzy, c-format
 msgid "Slope raster map <%s> complete"
 #: ../raster/r.slope.aspect/main.c:1233
 #, fuzzy, c-format
@@ -11922,32 +11922,32 @@
 #: ../raster/r.slope.aspect/main.c:1260
 #, fuzzy, c-format
 msgid "Tangential curve raster map <%s> complete"
 #: ../raster/r.slope.aspect/main.c:1285
 #, fuzzy, c-format
 msgid "E-W slope raster map <%s> complete"
 #: ../raster/r.slope.aspect/main.c:1310
 #, fuzzy, c-format
 msgid "N-S slope raster map <%s> complete"
 #: ../raster/r.slope.aspect/main.c:1335
 #, fuzzy, c-format
 msgid "Dxx raster map <%s> complete"
 #: ../raster/r.slope.aspect/main.c:1360
 #, fuzzy, c-format
 msgid "Dyy raster map <%s> complete"
 #: ../raster/r.slope.aspect/main.c:1385
 #, fuzzy, c-format
 msgid "Dxy raster map <%s> complete"
 #: ../raster/r.timestamp/main.c:39
 #, fuzzy
@@ -11970,7 +11970,7 @@
 #: ../raster/r.timestamp/main.c:65
 #, fuzzy, c-format
 msgid "Raster map <%s> not found %s"
-msgstr "Mapa raster <%s> não encontrado"
+msgstr "Mapa raster <%s> não encontrado"
 #: ../raster/r.resamp.bspline/main.c:82 ../raster/r.resample/main.c:55
 #: ../raster/r.resamp.rst/main.c:149 ../raster/r.resamp.filter/main.c:390
@@ -11988,7 +11988,7 @@
 #: ../vector/v.surf.bspline/main.c:93 ../vector/v.vol.rst/main.c:238
 #, fuzzy
 msgid "interpolation"
-msgstr "Método de intepolação a usar"
+msgstr "Método de intepolação a usar"
 #: ../raster/r.resamp.bspline/main.c:85
 msgid ""
@@ -11999,7 +11999,7 @@
 #: ../raster/r.resamp.bspline/main.c:93
 #, fuzzy
 msgid "Name for output vector map with interpolation grid"
-msgstr "Saída é o erro de interpolação"
+msgstr "Saída é o erro de interpolação"
 #: ../raster/r.resamp.bspline/main.c:98
 #, fuzzy
@@ -12024,20 +12024,20 @@
 #: ../raster/r.resamp.bspline/main.c:119 ../vector/v.surf.bspline/main.c:163
 #, fuzzy
 msgid "Spline interpolation algorithm"
 #: ../raster/r.resamp.bspline/main.c:125 ../vector/v.surf.bspline/main.c:170
 #: ../vector/v.lidar.edgedetection/main.c:414 ../vector/v.outlier/main.c:416
 #: ../vector/v.lidar.correction/main.c:402
 #, fuzzy
 msgid "Bilinear interpolation"
 #: ../raster/r.resamp.bspline/main.c:126 ../vector/v.surf.bspline/main.c:171
 #: ../vector/v.lidar.edgedetection/main.c:431
 #, fuzzy
 msgid "Bicubic interpolation"
 #: ../raster/r.resamp.bspline/main.c:132
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:16
@@ -12048,14 +12048,14 @@
 #: ../raster/r.resamp.bspline/main.c:138
 #, fuzzy
 msgid "Only interpolate null cells in input raster map"
-msgstr "Manter valores nulos no mapa de saída"
+msgstr "Manter valores nulos no mapa de saída"
 #: ../raster/r.resamp.bspline/main.c:144 ../vector/v.surf.bspline/main.c:101
 #, fuzzy
 msgid ""
 "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
 "cross validation method"
-msgstr "Encontre melhores parâmetros utilizando o método de validação cruzada"
+msgstr "Encontre melhores parâmetros utilizando o método de validação cruzada"
 #: ../raster/r.resamp.bspline/main.c:151 ../raster/r.proj/main.c:191
 #: ../raster/r.stream.extract/main.c:141 ../raster/r.in.gdal/main.c:116
@@ -12064,7 +12064,7 @@
 #: ../vector/v.surf.bspline/main.c:194 ../vector/v.to.rast/main.c:116
 #, fuzzy
 msgid "Maximum memory to be used (in MB)"
-msgstr "Memória Esgotada! (Out of Memory)"
+msgstr "Memória Esgotada! (Out of Memory)"
 #: ../raster/r.resamp.bspline/main.c:152 ../raster/r.proj/main.c:192
 #: ../raster/r.stream.extract/main.c:142 ../raster/r.in.gdal/main.c:117
@@ -12073,17 +12073,17 @@
 #: ../vector/v.surf.bspline/main.c:195 ../vector/v.to.rast/main.c:117
 #, fuzzy
 msgid "Cache size for raster rows"
-msgstr "Relatório de estatísticas para mapas raster."
+msgstr "Relatório de estatísticas para mapas raster."
 #: ../raster/r.resamp.bspline/main.c:187
 #, fuzzy
 msgid "ew_step must be positive"
-msgstr "Tamanho da vizinhança"
+msgstr "Tamanho da vizinhança"
 #: ../raster/r.resamp.bspline/main.c:195
 #, fuzzy
 msgid "ns_step must be positive"
 #: ../raster/r.resamp.bspline/main.c:222
 #, fuzzy, c-format
@@ -12118,14 +12118,14 @@
 #: ../vector/v.surf.bspline/main.c:498
 #, fuzzy
 msgid "Can not create temporary file"
 #: ../raster/r.resamp.bspline/main.c:313 ../raster/r.resamp.bspline/main.c:399
 #: ../raster/r.resamp.bspline/main.c:470 ../vector/v.surf.bspline/main.c:475
 #: ../vector/v.surf.bspline/main.c:503
 #, fuzzy
 msgid "Can not initialize temporary file"
 #: ../raster/r.resamp.bspline/main.c:319
 #, fuzzy, c-format
@@ -12135,21 +12135,21 @@
 #: ../raster/r.resamp.bspline/main.c:339
 #, fuzzy
 msgid "Only NULL cells in input raster"
 #: ../raster/r.resamp.bspline/main.c:363 ../vector/v.surf.bspline/main.c:307
 msgid "Cross validation didn't finish correctly"
-msgstr "Validação cruzada não terminou correctamente"
+msgstr "Validação cruzada não terminou correctamente"
 #: ../raster/r.resamp.bspline/main.c:367 ../vector/v.surf.bspline/main.c:313
 #, fuzzy, c-format
 msgid "Cross validation finished for ew_step = %f and ns_step = %f"
 #: ../raster/r.resamp.bspline/main.c:387
 #, fuzzy
 msgid "Mark cells for interpolation"
 #: ../raster/r.resamp.bspline/main.c:458
 msgid "No NULL cells found in input raster."
@@ -12183,15 +12183,15 @@
 "%d are too many cells, recommended are < 100 cells. The cross validation "
 "would take too much time."
 msgstr ""
-"Correlação cruzada: %d são demasiados pontos. A validação cruzada demoraria "
+"Correlação cruzada: %d são demasiados pontos. A validação cruzada demoraria "
 "demasiado tempo"
 #: ../raster/r.resamp.bspline/crosscorr.c:169
 #, fuzzy, c-format
 msgid "%d point read in region"
 msgid_plural "%d points read in region"
-msgstr[0] "%d pontos fora da região atual."
-msgstr[1] "%d pontos fora da região atual."
+msgstr[0] "%d pontos fora da região atual."
+msgstr[1] "%d pontos fora da região atual."
 #: ../raster/r.resamp.bspline/crosscorr.c:174
 msgid "Maybe it takes too long. Consider reducing the region extents."
@@ -12221,7 +12221,7 @@
 #: ../vector/v.surf.bspline/crosscorr.c:296
 #, fuzzy, c-format
 msgid "Root Mean Square (RMS) = %.5lf"
-msgstr "Correlação cruzada: Média = %.5lf\n"
+msgstr "Correlação cruzada: Média = %.5lf\n"
 #: ../raster/r.resamp.bspline/crosscorr.c:324
 #: ../vector/v.surf.bspline/crosscorr.c:313
@@ -12236,27 +12236,27 @@
 msgid ""
 "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
 msgstr ""
-"Correlação cruzada: O valor mínimo para o teste (rms=%lf) foi obtido com:\n"
+"Correlação cruzada: O valor mínimo para o teste (rms=%lf) foi obtido com:\n"
 #: ../raster/r.resamp.bspline/crosscorr.c:334
 #: ../vector/v.surf.bspline/crosscorr.c:323
 #, fuzzy
 msgid "Table of results:"
-msgstr "Não consegui definir tamanho"
+msgstr "Não consegui definir tamanho"
 #: ../raster/r.resamp.bspline/crosscorr.c:335
 #: ../vector/v.surf.bspline/crosscorr.c:324
 #, fuzzy, c-format
 msgid "    lambda |       mean |        rms |\n"
 msgstr ""
-"                          VERIFICAÇÃO DOS ERROS NO MAPA\n"
+"                          VERIFICAÇÃO DOS ERROS NO MAPA\n"
 "\n"
 #: ../raster/r.resamp.bspline/crosscorr.c:345
 #: ../vector/v.surf.bspline/crosscorr.c:334
 #, fuzzy
 msgid "No point lies into the current region"
-msgstr "%d pontos fora da região atual."
+msgstr "%d pontos fora da região atual."
 #: ../raster/r.spread/main.c:106 ../raster/r.spreadpath/main.c:89
 #: ../raster/r.ros/main.c:213
@@ -12285,11 +12285,11 @@
 "origins. It optionally produces raster maps to contain backlink UTM "
 "coordinates for tracing spread paths. Usable for fire spread simulations."
 msgstr ""
-"Simula o espalhamento elipticamente anisotrópico numa janela gráfica e gera "
+"Simula o espalhamento elipticamente anisotrópico numa janela gráfica e gera "
 "um mapa raster do tempo cumulativo de espalhamento, sendo dados mapas "
-"contendo a razão de espalhamento (RdE), as direções de RdE e os focos "
+"contendo a razão de espalhamento (RdE), as direções de RdE e os focos "
 "originais. Opcionalmente produz mapas raster contendo as coordenadas UTM "
-"para o traçado das rotas de espalhamento."
+"para o traçado das rotas de espalhamento."
 #: ../raster/r.spread/main.c:127
 #, fuzzy
@@ -12318,7 +12318,7 @@
 #: ../raster/r.spread/main.c:153
 #, fuzzy
 msgid "Raster map containing directions of maximal ROS (degree)"
-msgstr "Nome do mapa raster contendo as direções das máximas RdE (graus)"
+msgstr "Nome do mapa raster contendo as direções das máximas RdE (graus)"
 #: ../raster/r.spread/main.c:155
 msgid ""
@@ -12343,7 +12343,7 @@
 #, fuzzy
 msgid "Raster map containing maximal spotting distance (m, required with -s)"
 msgstr ""
-"Nome do mapa raster contendo máxima distância de avistamento (m) (requer w/-"
+"Nome do mapa raster contendo máxima distância de avistamento (m) (requer w/-"
 "s)"
 #: ../raster/r.spread/main.c:181
@@ -12355,7 +12355,7 @@
 #: ../raster/r.spread/main.c:191
 #, fuzzy
 msgid "Raster map containing midflame wind speed (ft/min, required with -s)"
-msgstr "Nome do mapa raster contendo velocidade do vento das chamas (pés/min)"
+msgstr "Nome do mapa raster contendo velocidade do vento das chamas (pés/min)"
 #: ../raster/r.spread/main.c:193 ../raster/r.ros/main.c:279
 msgid ""
@@ -12370,8 +12370,8 @@
 "Raster map containing fine fuel moisture of the cell receiving a spotting "
 "firebrand (%, required with -s)"
 msgstr ""
-"Nome do mapa raster contendo a umidade do combustível fino da célula "
-"recebendo um tição incandescente (requer w/-s)"
+"Nome do mapa raster contendo a umidade do combustível fino da célula "
+"recebendo um tição incandescente (requer w/-s)"
 #: ../raster/r.spread/main.c:205 ../raster/r.ros/main.c:240
 msgid ""
@@ -12383,7 +12383,7 @@
 #: ../raster/r.spread/main.c:215
 #, fuzzy
 msgid "Basic sampling window size needed to meet certain accuracy (3)"
-msgstr "Tamanho básico da janela necessário para obter uma dada precisão (3)"
+msgstr "Tamanho básico da janela necessário para obter uma dada precisão (3)"
 #: ../raster/r.spread/main.c:217
 msgid ""
@@ -12397,7 +12397,7 @@
 #, fuzzy
 msgid "Sampling density for additional computing (range: 0.0 - 1.0 (0.5))"
 msgstr ""
-"Densidade de amostragem para computação adicional (intervalo: 0.0 - 1.0 "
+"Densidade de amostragem para computação adicional (intervalo: 0.0 - 1.0 "
 "(0.5))"
 #: ../raster/r.spread/main.c:229
@@ -12412,7 +12412,7 @@
 #: ../raster/r.spread/main.c:241
 #, fuzzy
 msgid "Initial time for current simulation (0) (min)"
-msgstr "Tempo inicial para simulação atual (0) (min)"
+msgstr "Tempo inicial para simulação atual (0) (min)"
 #: ../raster/r.spread/main.c:243
 msgid ""
@@ -12424,7 +12424,7 @@
 #: ../raster/r.spread/main.c:252
 #, fuzzy
 msgid "Simulating time duration LAG (fill the region) (min)"
-msgstr "Simulando duração do intervalo (encher a região) (min)"
+msgstr "Simulando duração do intervalo (encher a região) (min)"
 #: ../raster/r.spread/main.c:254
 msgid ""
@@ -12449,7 +12449,7 @@
 #: ../raster/r.spread/main.c:279
 #, fuzzy
 msgid "Raster map to contain output spread time (min)"
-msgstr "Nome do mapa raster de saída contendo tempo de espalhamento (min)"
+msgstr "Nome do mapa raster de saída contendo tempo de espalhamento (min)"
 #: ../raster/r.spread/main.c:281
 msgid ""
@@ -12497,7 +12497,7 @@
 #: ../raster/r.spread/main.c:324
 #, fuzzy
 msgid "Use start raster map values in output spread time raster map"
 #: ../raster/r.spread/main.c:326
 msgid ""
@@ -12540,22 +12540,22 @@
 #: ../raster/r.report/parse.c:49
 #, fuzzy
 msgid "area in square miles"
-msgstr "Mostra os totais das áreas"
+msgstr "Mostra os totais das áreas"
 #: ../raster/r.report/parse.c:50
 #, fuzzy
 msgid "area in square meters"
 #: ../raster/r.report/parse.c:51
 #, fuzzy
 msgid "area in square kilometers"
 #: ../raster/r.report/parse.c:52
 #, fuzzy
 msgid "area in acres"
-msgstr "Área\n"
+msgstr "Área\n"
 #: ../raster/r.report/parse.c:53
 msgid "area in hectares"
@@ -12564,30 +12564,30 @@
 #: ../raster/r.report/parse.c:54
 #, fuzzy
 msgid "number of cells"
 #: ../raster/r.report/parse.c:55
 #, fuzzy
 msgid "percent cover"
-msgstr "Convergência percentual"
+msgstr "Convergência percentual"
 #: ../raster/r.report/parse.c:58 ../raster/r.stats/main.c:158
 #: ../raster/r.stats/main.c:163 ../raster/r.stats/main.c:169
 #, fuzzy
 msgid "Statistics"
-msgstr "Estatísticas de transição de classe."
+msgstr "Estatísticas de transição de classe."
 #: ../raster/r.report/parse.c:63 ../raster/r.volume/main.c:104
 #, fuzzy
 msgid "Name for output file to hold the report"
-msgstr "Nome de um arquivo para gravar a saída do relatório"
+msgstr "Nome de um arquivo para gravar a saída do relatório"
 #: ../raster/r.report/parse.c:65 ../raster/r.volume/main.c:106
 #, fuzzy
 msgid "If no output file given report is printed to standard output"
 msgstr ""
-"Arquivo ASCII para converter para vetor binário, se não for dado, lê da "
-"entrada padrão"
+"Arquivo ASCII para converter para vetor binário, se não for dado, lê da "
+"entrada padrão"
 #: ../raster/r.report/parse.c:69 ../raster/r.report/parse.c:77
 #: ../raster/r.report/parse.c:85 ../raster/r.report/parse.c:109
@@ -12621,7 +12621,7 @@
 #: ../raster/r.report/parse.c:75
 #, fuzzy
 msgid "Page length"
-msgstr "Nome ilegal do arquivo de saída"
+msgstr "Nome ilegal do arquivo de saída"
 #: ../raster/r.report/parse.c:83
 #, fuzzy
@@ -12631,7 +12631,7 @@
 #: ../raster/r.report/parse.c:94 ../raster/r.stats/main.c:136
 #, fuzzy
 msgid "Number of floating-point subranges to collect stats from"
-msgstr "Número de intervalos fp para coletar estatísticas"
+msgstr "Número de intervalos fp para coletar estatísticas"
 #: ../raster/r.report/parse.c:95 ../raster/r.report/parse.c:139
 #: ../raster/r.report/parse.c:145 ../raster/r.stats/main.c:137
@@ -12648,7 +12648,7 @@
 #: ../raster/r.report/parse.c:103 ../raster/r.stats/main.c:145
 #, fuzzy
 msgid "Default: sorted by categories or intervals"
 #: ../raster/r.report/parse.c:107 ../raster/r.stats/main.c:149
 msgid "Sort by cell counts in ascending order"
@@ -12660,41 +12660,41 @@
 #: ../raster/r.report/parse.c:113
 msgid "Suppress page headers"
-msgstr "Suprimir páginas de cabeçalho"
+msgstr "Suprimir páginas de cabeçalho"
 #: ../raster/r.report/parse.c:118
 msgid "Use formfeeds between pages"
-msgstr "Usar linhas em branco entre as páginas"
+msgstr "Usar linhas em branco entre as páginas"
 #: ../raster/r.report/parse.c:123
 msgid "Scientific format"
-msgstr "Notação científica"
+msgstr "Notação científica"
 #: ../raster/r.report/parse.c:128 ../raster/r.stats/main.c:201
 #, fuzzy
 msgid "Do not report no data value"
-msgstr "Texto representando células sem valores de dados"
+msgstr "Texto representando células sem valores de dados"
 #: ../raster/r.report/parse.c:129 ../raster/r.report/parse.c:134
 #: ../raster/r.stats/main.c:202 ../raster/r.stats/main.c:207
 #, fuzzy
 msgid "No data"
 #: ../raster/r.report/parse.c:133 ../raster/r.stats/main.c:206
 #, fuzzy
 msgid "Do not report cells where all maps have no data"
-msgstr "Excluir células em que nenhum dos mapas possui dados"
+msgstr "Excluir células em que nenhum dos mapas possui dados"
 #: ../raster/r.report/parse.c:138 ../raster/r.stats/main.c:211
 #, fuzzy
 msgid "Report for cats floating-point ranges (floating-point maps only)"
-msgstr "Relatório de intervalos de categorias fp (apenas mapas fp)"
+msgstr "Relatório de intervalos de categorias fp (apenas mapas fp)"
 #: ../raster/r.report/parse.c:144 ../raster/r.stats/main.c:216
 #, fuzzy
 msgid "Read floating-point map as integer (use map's quant rules)"
-msgstr "Ler mapas fp como inteiros (usar regras de quantização do mapa)"
+msgstr "Ler mapas fp como inteiros (usar regras de quantização do mapa)"
 #: ../raster/r.report/parse.c:187
 msgid "nsteps has to be > 0; using nsteps=255"
@@ -12703,7 +12703,7 @@
 #: ../raster/r.report/parse.c:193
 #, fuzzy
 msgid "Illegal page length"
 #: ../raster/r.report/parse.c:198
 msgid "Illegal page width"
@@ -12712,33 +12712,33 @@
 #: ../raster/r.report/parse.c:253
 #, fuzzy, c-format
 msgid "Only %d unit%s allowed"
-msgstr "não"
+msgstr "não"
 #: ../raster/r.report/parse.c:286
 #, fuzzy, c-format
 msgid "Unable to read fp range for raster map <%s>"
-msgstr "Não consegui escrever em <%s>"
+msgstr "Não consegui escrever em <%s>"
 #: ../raster/r.report/parse.c:294 ../raster/r.category/main.c:148
 #: ../raster/r.category/main.c:230 ../raster/r.mapcalc/map3.c:190
 #: ../raster/r.mapcalc/map.c:233
 #, c-format
 msgid "Unable to read category file of raster map <%s@%s>"
-msgstr "Não consegui ler arquivo de categoria do mapa raster <%s@%s>"
+msgstr "Não consegui ler arquivo de categoria do mapa raster <%s@%s>"
 #: ../raster/r.report/main.c:69
 #, fuzzy
 msgid "Reports statistics for raster maps."
 #: ../raster/r.report/stats.c:93
 #, fuzzy, c-format
 msgid "Unable to open result file <%s>"
-msgstr "Não consegui abrir o arquivo de células [%s]"
+msgstr "Não consegui abrir o arquivo de células [%s]"
 #: ../raster/r.report/stats.c:128 ../raster/r.kappa/stats.c:14
 msgid "Problem reading r.stats output"
-msgstr "Problema na leitura da saída r.stats"
+msgstr "Problema na leitura da saída r.stats"
 #: ../raster/r.report/label.c:13
 msgid "Page width is too small"
@@ -12748,13 +12748,13 @@
 #, fuzzy
 msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
 msgstr ""
-"Cria mapas raster a partir de arquivos de dados de polígono/linha/ponto."
+"Cria mapas raster a partir de arquivos de dados de polígono/linha/ponto."
 #: ../raster/r.in.lidar/main.c:139 ../raster/r.in.xyz/main.c:179
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
 #, fuzzy
 msgid "Statistic to use for raster values"
 #: ../raster/r.in.lidar/main.c:143 ../raster/r.in.lidar/main.c:234
 #: ../raster/r.in.lidar/main.c:244 ../raster/r.in.xyz/main.c:183
@@ -12768,17 +12768,17 @@
 #: ../raster/r.in.lidar/main.c:158 ../raster/r.in.xyz/main.c:198
 #, fuzzy
 msgid "Number of points in cell"
-msgstr "Número de linhas"
+msgstr "Número de linhas"
 #: ../raster/r.in.lidar/main.c:159 ../raster/r.in.xyz/main.c:199
 #, fuzzy
 msgid "Minimum value of point values in cell"
-msgstr "Número mínimo de pixels numa classe"
+msgstr "Número mínimo de pixels numa classe"
 #: ../raster/r.in.lidar/main.c:160 ../raster/r.in.xyz/main.c:200
 #, fuzzy
 msgid "Maximum value of point values in cell"
-msgstr "Número máximo de pontos num segmento"
+msgstr "Número máximo de pontos num segmento"
 #: ../raster/r.in.lidar/main.c:161 ../raster/r.in.xyz/main.c:201
 #, fuzzy
@@ -12797,7 +12797,7 @@
 #: ../raster/r.in.lidar/main.c:164 ../raster/r.in.xyz/main.c:204
 #, fuzzy
 msgid "Standard deviation of point values in cell"
-msgstr "Desvio padrão da distribuição normal deve ser >= zero"
+msgstr "Desvio padrão da distribuição normal deve ser >= zero"
 #: ../raster/r.in.lidar/main.c:165 ../raster/r.in.xyz/main.c:205
 #, fuzzy
@@ -12808,12 +12808,12 @@
 #, fuzzy
 msgid "Coefficient of variance of point values in cell"
 msgstr ""
-"Calcula estatísticas univariada das células não nulas de um mapa raster."
+"Calcula estatísticas univariada das células não nulas de um mapa raster."
 #: ../raster/r.in.lidar/main.c:167 ../raster/r.in.xyz/main.c:207
 #, fuzzy
 msgid "Median value of point values in cell"
 #: ../raster/r.in.lidar/main.c:168 ../raster/r.in.xyz/main.c:208
 #, fuzzy
@@ -12848,7 +12848,7 @@
 #: ../raster/r.in.lidar/main.c:224 ../raster/r.in.xyz/main.c:304
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
 msgid "Percent of map to keep in memory"
-msgstr "Porcentagem do mapa para manter em memória"
+msgstr "Porcentagem do mapa para manter em memória"
 #: ../raster/r.in.lidar/main.c:233 ../raster/r.in.xyz/main.c:313
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
@@ -12870,7 +12870,7 @@
 #: ../raster/r.in.lidar/main.c:251
 #, fuzzy
 msgid "Output raster resolution"
 #: ../raster/r.in.lidar/main.c:281
 msgid "Use the extent of the input for the raster extent"
@@ -12883,7 +12883,7 @@
 #: ../raster/r.in.lidar/main.c:290
 #, fuzzy
 msgid "Set computation region to match the new raster map"
 #: ../raster/r.in.lidar/main.c:292
 msgid ""
@@ -12931,22 +12931,22 @@
 #: ../raster/r.in.lidar/main.c:477 ../raster/r.in.xyz/main.c:374
 #, fuzzy
 msgid "Invalid zrange"
 #: ../raster/r.in.lidar/main.c:491
 #, fuzzy, c-format
 msgid "Invalid %s"
 #: ../raster/r.in.lidar/main.c:523 ../general/g.region/main.c:798
 #, fuzzy, c-format
 msgid "Invalid input <%s=%s>"
 #: ../raster/r.in.lidar/main.c:526
 #, fuzzy, c-format
 msgid "Option '%s' must be > 0.0"
-msgstr "Locação: %s\n"
+msgstr "Locação: %s\n"
 #: ../raster/r.in.lidar/main.c:594
 #, c-format
@@ -12974,12 +12974,12 @@
 #: ../raster/r.in.lidar/main.c:791
 #, fuzzy, c-format
 msgid "%lu input points were invalid and filtered out"
-msgstr "%d pontos além do limite"
+msgstr "%d pontos além do limite"
 #: ../raster/r.in.lidar/main.c:794
 #, fuzzy, c-format
 msgid "%lu input points were invalid, use -%c flag to filter them out"
 #: ../raster/r.in.lidar/main.c:797
 #, c-format
@@ -12989,7 +12989,7 @@
 #: ../raster/r.in.lidar/main.c:802
 #, fuzzy, c-format
 msgid "Raster map <%s> created. %lu points found in region."
 #: ../raster/r.in.lidar/point_binning.c:205 ../raster/r.in.xyz/main.c:474
 msgid "Unable to calculate percentile without the pth option specified!"
@@ -13010,17 +13010,17 @@
 #: ../raster/r.usler/main.c:60
 #, fuzzy
 msgid "Name of annual precipitation raster map [mm/year]"
 #: ../raster/r.usler/main.c:63
 #, fuzzy
 msgid "Name for output USLE R raster map [MJ.mm/ha.hr.year]"
-msgstr "Nome de uma camada de saída"
+msgstr "Nome de uma camada de saída"
 #: ../raster/r.usler/main.c:70
 #, fuzzy
 msgid "Name of USLE R equation"
-msgstr "Nome do mapa raster de elevação"
+msgstr "Nome do mapa raster de elevação"
 #: ../raster/r.usler/main.c:75
 msgid "Roosle (1975)"
@@ -13045,7 +13045,7 @@
 #: ../locale/scriptstrings/r.shade_to_translate.c:3
 #, fuzzy
 msgid "elevation"
-msgstr "Resolução"
+msgstr "Resolução"
 #: ../raster/r.relief/main.c:109
 #: ../locale/scriptstrings/d.shade_to_translate.c:4
@@ -13063,12 +13063,12 @@
 #, fuzzy
 msgid "Creates shaded relief map from an elevation map (DEM)."
 msgstr ""
 #: ../raster/r.relief/main.c:117
 #, fuzzy
 msgid "Name for output shaded relief map"
 #: ../raster/r.relief/main.c:125
 #, fuzzy
@@ -13093,7 +13093,7 @@
 #: ../raster/r.relief/main.c:151
 #, fuzzy
 msgid "Scale factor for converting meters to elevation units"
 #: ../raster/r.relief/main.c:158
 #, fuzzy
@@ -13103,7 +13103,7 @@
 #: ../raster/r.relief/main.c:163
 #, fuzzy
 msgid "international feet"
 #: ../raster/r.relief/main.c:164
 msgid "survey feet"
@@ -13113,34 +13113,34 @@
 #: ../raster/r.in.gdal/main.c:696 ../vector/v.kernel/main.c:239
 #, c-format
 msgid "Raster map <%s> already exists"
-msgstr "Mapa raster <%s> já existe"
+msgstr "Mapa raster <%s> já existe"
 #: ../raster/r.relief/main.c:215
 #, fuzzy, c-format
 msgid "%s=%s - must not be zero"
 #: ../raster/r.relief/main.c:474
 #, fuzzy, c-format
 msgid "Shaded relief raster map <%s> complete"
 #: ../raster/r.support.stats/main.c:37
 #, fuzzy
 msgid "Update raster map statistics"
-msgstr "Nome do mapa raster que conterá os resultados"
+msgstr "Nome do mapa raster que conterá os resultados"
 #: ../raster/r.support.stats/main.c:49
 #, fuzzy, c-format
 msgid "Statistics for <%s> updated"
-msgstr "Arquivo de histórico para [%s] atualizado."
+msgstr "Arquivo de histórico para [%s] atualizado."
 #: ../raster/r.support.stats/check.c:43
 #, fuzzy, c-format
 msgid "Updating statistics for [%s]..."
 msgstr ""
 "\n"
 #: ../raster/r.support.stats/check.c:56
 msgid "Updating histogram range..."
@@ -13150,7 +13150,7 @@
 #, fuzzy, c-format
 msgid "Updating the number of categories for [%s]..."
 msgstr ""
 "\n"
 #: ../raster/r.grow.distance/main.c:151 ../raster/r.distance/main.c:40
@@ -13160,7 +13160,7 @@
 #: ../vector/v.distance/main.c:91
 #, fuzzy
 msgid "distance"
 #: ../raster/r.grow.distance/main.c:152
 #: ../locale/scriptstrings/r.grow_to_translate.c:4
@@ -13170,32 +13170,32 @@
 #: ../raster/r.grow.distance/main.c:154
 #, fuzzy
 msgid "Generates a raster map containing distances to nearest raster features."
-msgstr "Gera um mapa raster com áreas contíguas acrescidas de uma célula"
+msgstr "Gera um mapa raster com áreas contíguas acrescidas de uma célula"
 #: ../raster/r.grow.distance/main.c:161
 #, fuzzy
 msgid "Name for distance output raster map"
 #: ../raster/r.grow.distance/main.c:167
 #, fuzzy
 msgid "Name for value output raster map"
 #: ../raster/r.grow.distance/main.c:174
 #: ../locale/scriptstrings/r.grow_to_translate.c:7
 msgid "Metric"
-msgstr "Métrica"
+msgstr "Métrica"
 #: ../raster/r.grow.distance/main.c:180
 #, fuzzy
 msgid "Output distances in meters instead of map units"
-msgstr "Máxima distância entre pontos (em unidades do mapa)"
+msgstr "Máxima distância entre pontos (em unidades do mapa)"
 #: ../raster/r.grow.distance/main.c:184
 #, fuzzy
 msgid "Calculate distance to nearest NULL cell"
 #: ../raster/r.grow.distance/main.c:195
 msgid "Distance output is required for distance to NULL cells"
@@ -13217,17 +13217,17 @@
 #: ../raster/r.grow.distance/main.c:224
 #, fuzzy, c-format
 msgid "Unknown metric: '%s'"
-msgstr "Métrica desconhecida: [%s]."
+msgstr "Métrica desconhecida: [%s]."
 #: ../raster/r.grow.distance/main.c:229
 #, fuzzy, c-format
 msgid "Output distance in meters for lat/lon is only possible with '%s=%s'"
 #: ../raster/r.grow.distance/main.c:249
 #, fuzzy, c-format
 msgid "Unable to create temporary file <%s>"
-msgstr "Não consegui escrever o arquivo temporário."
+msgstr "Não consegui escrever o arquivo temporário."
 #: ../raster/r.grow.distance/main.c:325 ../raster/r.stream.extract/close.c:248
 #: ../raster/r.fill.dir/main.c:253
@@ -13240,7 +13240,7 @@
 #: ../vector/v.colors/main.c:315
 #, fuzzy, c-format
 msgid "Unable to read color table for raster map <%s>"
-msgstr "Não consegui criar mapa raster <%s>."
+msgstr "Não consegui criar mapa raster <%s>."
 #: ../raster/r.stats.quantile/main.c:86
 #, fuzzy
@@ -13269,12 +13269,12 @@
 #: ../raster/r.stats.quantile/main.c:315
 #, fuzzy
 msgid "Printing quantiles"
-msgstr "Cópia da tabela falhou"
+msgstr "Cópia da tabela falhou"
 #: ../raster/r.stats.quantile/main.c:360 ../raster/r.quantile/main.c:193
 #, fuzzy
 msgid "Computing quantiles"
 #: ../raster/r.stats.quantile/main.c:412
 #, fuzzy
@@ -13293,17 +13293,17 @@
 #: ../raster/r.stats.quantile/main.c:528 ../raster/r.quantile/main.c:272
 #, fuzzy
 msgid "Number of quantiles"
-msgstr "Número de quadros"
+msgstr "Número de quadros"
 #: ../raster/r.stats.quantile/main.c:534 ../raster/r.quantile/main.c:280
 #, fuzzy
 msgid "List of percentiles"
 #: ../raster/r.stats.quantile/main.c:541 ../raster/r.quantile/main.c:286
 #, fuzzy
 msgid "Number of bins to use"
-msgstr "Número de pontos para criar"
+msgstr "Número de pontos para criar"
 #: ../raster/r.stats.quantile/main.c:545
 #, fuzzy
@@ -13317,12 +13317,12 @@
 #: ../raster/r.stats.quantile/main.c:567
 #, fuzzy
 msgid "Do not create output maps; just print statistics"
-msgstr "Não consegui criar o mapa de saída"
+msgstr "Não consegui criar o mapa de saída"
 #: ../raster/r.stats.quantile/main.c:572
 #, fuzzy
 msgid "Print statistics in table format"
-msgstr "Entrada mapear é em"
+msgstr "Entrada mapear é em"
 #: ../raster/r.stats.quantile/main.c:584
 #, fuzzy, c-format
@@ -13334,13 +13334,13 @@
 #: ../raster/r.neighbors/main.c:262
 #, fuzzy, c-format
 msgid "-%c and %s= are mutually exclusive"
-msgstr "Opções -B e -C são mutuamente exclusivas. Escolha apenas uma."
+msgstr "Opções -B e -C são mutuamente exclusivas. Escolha apenas uma."
 #: ../raster/r.stats.quantile/main.c:613
 #, fuzzy, c-format
 msgid "Number of quantiles (%d) does not match number of output maps (%d)"
 msgstr ""
-"Número de colunas definidas (%d) não coincide com o número de colunas (%d) "
+"Número de colunas definidas (%d) não coincide com o número de colunas (%d) "
 "da entrada."
 #: ../raster/r.stats.quantile/main.c:622 ../raster/r.stats.zonal/main.c:181
@@ -13351,7 +13351,7 @@
 #: ../raster/r.stats.quantile/main.c:625 ../raster/r.stats.zonal/main.c:184
 #, fuzzy, c-format
 msgid "Unable to read range of base map <%s>"
 #: ../raster/r.stats.quantile/main.c:630
 #, c-format
@@ -13368,11 +13368,11 @@
 #: ../raster/r.profile/main.c:56
 msgid "Outputs the raster map layer values lying on user-defined line(s)."
 msgstr ""
-"Imprime os valores do mapa raster ao longo das linhas definidas pelo usuário."
+"Imprime os valores do mapa raster ao longo das linhas definidas pelo usuário."
 #: ../raster/r.profile/main.c:64 ../raster/r.horizon/main.c:304
 msgid "Name of file for output (use output=- for stdout)"
-msgstr "Nome do arquivo de saída (use output=- para saída padrão)"
+msgstr "Nome do arquivo de saída (use output=- para saída padrão)"
 #: ../raster/r.profile/main.c:69 ../display/d.profile/main.c:203
 #, fuzzy
@@ -13382,7 +13382,7 @@
 #: ../raster/r.profile/main.c:75
 #, fuzzy
 msgid "Name of input file containing coordinate pairs"
-msgstr "Arquivo contendo declarações SQL"
+msgstr "Arquivo contendo declarações SQL"
 #: ../raster/r.profile/main.c:77
 #, fuzzy
@@ -13391,11 +13391,11 @@
 #: ../raster/r.profile/main.c:85
 msgid "Resolution along profile (default = current region resolution)"
-msgstr "Resolução no perfil (padrão = resolução da região atual)"
+msgstr "Resolução no perfil (padrão = resolução da região atual)"
 #: ../raster/r.profile/main.c:98
 msgid "Output RRR:GGG:BBB color values for each profile point"
-msgstr "Saída de valores RRR:GGG:BBB para cada ponto do perfil"
+msgstr "Saída de valores RRR:GGG:BBB para cada ponto do perfil"
 #: ../raster/r.profile/main.c:103
 msgid ""
@@ -13410,17 +13410,17 @@
 #: ../raster/r.profile/main.c:144
 #, fuzzy, c-format
 msgid "Illegal resolution %g [%s]"
-msgstr "Resolução"
+msgstr "Resolução"
 #: ../raster/r.profile/main.c:151
 #, fuzzy, c-format
 msgid "Using resolution: %g [%s]"
-msgstr "Resolução"
+msgstr "Resolução"
 #: ../raster/r.profile/main.c:182
 #, fuzzy
 msgid "Output columns:"
 #: ../raster/r.profile/main.c:185
 #, c-format
@@ -13440,12 +13440,12 @@
 #: ../raster/r.profile/main.c:200
 #, fuzzy, c-format
 msgid "Could not open <%s>"
 #: ../raster/r.profile/main.c:207
 #, c-format
 msgid "Invalid coordinates %s %s"
 #: ../raster/r.profile/main.c:278
 #, c-format
@@ -13455,7 +13455,7 @@
 #: ../raster/r.profile/main.c:281
 #, fuzzy
 msgid "Endpoint coordinates are outside of current region settings"
 #: ../raster/r.horizon/main.c:182 ../raster/r.sunhours/main.c:75
 #: ../raster/r.sunmask/main.c:118
@@ -13536,7 +13536,7 @@
 #: ../locale/scriptstrings/r.import_to_translate.c:29
 #, fuzzy
 msgid "Optional"
 #: ../raster/r.horizon/main.c:288
 msgid "Coordinate for which you want to calculate the horizon"
@@ -13550,12 +13550,12 @@
 #: ../raster/r.horizon/main.c:310
 #, fuzzy
 msgid "Write output in degrees (default is radians)"
-msgstr "Prefixo para imagens na saída (padrão = NVIZ)"
+msgstr "Prefixo para imagens na saída (padrão = NVIZ)"
 #: ../raster/r.horizon/main.c:315
 #, fuzzy
 msgid "Write output in compass orientation (default is CCW, East=0)"
 #: ../raster/r.horizon/main.c:355
 msgid ""
@@ -13565,7 +13565,7 @@
 #: ../raster/r.horizon/main.c:368
 #, fuzzy
 msgid "Can't read the coordinates from the \"coordinate\" option."
-msgstr "Obtém coordenadas a partir da \"entrada padrão\" (stdin)"
+msgstr "Obtém coordenadas a partir da \"entrada padrão\" (stdin)"
 #: ../raster/r.horizon/main.c:395
 msgid "You didn't specify a direction value or step size. Aborting."
@@ -13586,23 +13586,23 @@
 #: ../raster/r.horizon/main.c:423
 #, fuzzy
 msgid "You specify a start grater than the end angle. Aborting."
-msgstr "Não consegui ler arquivo de limite"
+msgstr "Não consegui ler arquivo de limite"
 #: ../raster/r.horizon/main.c:431
 #, fuzzy
 msgid "You didn't specify an angle step size. Aborting."
 #: ../raster/r.horizon/main.c:442
 #, fuzzy
 msgid "Could not read bufferzone size. Aborting."
 #: ../raster/r.horizon/main.c:447 ../raster/r.horizon/main.c:453
 #: ../raster/r.horizon/main.c:460 ../raster/r.horizon/main.c:467
 #, fuzzy, c-format
 msgid "Could not read %s bufferzone size. Aborting."
 #: ../raster/r.horizon/main.c:448
 #, fuzzy
@@ -13624,7 +13624,7 @@
 #: ../raster/r.horizon/main.c:473
 #, fuzzy
 msgid "Could not read maximum distance. Aborting."
 #: ../raster/r.horizon/main.c:484
 msgid "The distance value must be 0.5-1.5. Aborting."
@@ -13643,11 +13643,11 @@
 #: ../raster/r.horizon/main.c:1174
 #, fuzzy, c-format
 msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
 #: ../raster/r.resample/main.c:57
 msgid "GRASS raster map layer data resampling capability."
-msgstr "Módulo de reamostragem de mapas raster do GRASS."
+msgstr "Módulo de reamostragem de mapas raster do GRASS."
 #: ../raster/r.resample/main.c:66
 msgid "Name of an input layer"
@@ -13655,7 +13655,7 @@
 #: ../raster/r.resample/main.c:73
 msgid "Name of an output layer"
 #: ../raster/r.resample/main.c:112 ../raster/r.resamp.rst/main.c:478
 msgid "Percent complete: "
@@ -13699,13 +13699,13 @@
 #: ../raster/r.uslek/main.c:77
 #, fuzzy
 msgid "Name for output USLE K factor raster map [t.ha.hr/ha.MJ.mm]"
 #: ../raster/r.li/r.li.padcv/padcv.c:52
 #, fuzzy
 msgid "Calculates coefficient of variation of patch area on a raster map"
 msgstr ""
 #: ../raster/r.li/r.li.padcv/padcv.c:54 ../raster/r.li/r.li.mps/mps.c:53
 #: ../raster/r.li/r.li.simpson/simpson.c:47
@@ -13721,7 +13721,7 @@
 #: ../raster/r.li/r.li.renyi/renyi.c:48
 #, fuzzy
 msgid "landscape structure analysis"
 #: ../raster/r.li/r.li.padcv/padcv.c:55 ../raster/r.li/r.li.mps/mps.c:54
 #: ../raster/r.li/r.li.padrange/padrange.c:55
@@ -13749,7 +13749,7 @@
 #: ../raster/r.li/r.li.renyi/renyi.c:57
 #, fuzzy
 msgid "Configuration file"
 #: ../raster/r.li/r.li.mps/mps.c:51
 msgid ""
@@ -13760,7 +13760,7 @@
 #: ../raster/r.li/r.li.simpson/simpson.c:45
 #, fuzzy
 msgid "Calculates Simpson's diversity index on a raster map"
-msgstr "Não consegui fechar o novo mapa g3d"
+msgstr "Não consegui fechar o novo mapa g3d"
 #: ../raster/r.li/r.li.simpson/simpson.c:48
 #: ../raster/r.li/r.li.shannon/shannon.c:48
@@ -13775,7 +13775,7 @@
 #: ../raster/r.li/r.li.shannon/shannon.c:45
 #, fuzzy
 msgid "Calculates Shannon's diversity index on a raster map"
 #: ../raster/r.li/r.li.padrange/padrange.c:52
 #, fuzzy
@@ -13785,12 +13785,12 @@
 #: ../raster/r.li/r.li.dominance/dominance.c:45
 #, fuzzy
 msgid "Calculates dominance's diversity index on a raster map"
 #: ../raster/r.li/r.li.cwed/cwed.c:53
 #, fuzzy
 msgid "Calculates contrast weighted edge density index on a raster map"
 #: ../raster/r.li/r.li.cwed/cwed.c:70
 msgid "Name of file that contains the weight to calculate the index"
@@ -13804,7 +13804,7 @@
 #: ../raster/r.li/r.li.pielou/pielou.c:45
 #, fuzzy
 msgid "Calculates Pielou's diversity index on a raster map"
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
 msgid ""
@@ -13834,30 +13834,30 @@
 #: ../raster/r.li/r.li.daemon/daemon.c:97
 #, fuzzy
 msgid "Cannot create random access file"
-msgstr "Não consegui criar a tabela %s"
+msgstr "Não consegui criar a tabela %s"
 #: ../raster/r.li/r.li.daemon/daemon.c:105
 #: ../raster/r.li/r.li.daemon/daemon.c:111
 #: ../raster/r.li/r.li.daemon/daemon.c:117
 #, fuzzy, c-format
 msgid "Cannot create %s directory"
-msgstr "Não consegui criar camada"
+msgstr "Não consegui criar camada"
 #: ../raster/r.li/r.li.daemon/daemon.c:201
 #, fuzzy, c-format
 msgid "Cannot find configuration file <%s>"
 #: ../raster/r.li/r.li.daemon/daemon.c:208
 #: ../raster/r.li/r.li.daemon/daemon.c:212
 #, fuzzy
 msgid "Cannot read setup file"
 #: ../raster/r.li/r.li.daemon/daemon.c:216
 #, fuzzy
 msgid "Unable to parse configuration file (sampling frame)"
 #: ../raster/r.li/r.li.daemon/daemon.c:475
 msgid "Irregular MASKEDOVERLAY areas definition"
@@ -13871,7 +13871,7 @@
 #: ../raster/r.li/r.li.daemon/daemon.c:485
 #, fuzzy
 msgid "Unable to parse configuration file (sample area)"
 #: ../raster/r.li/r.li.daemon/daemon.c:520
 #, fuzzy
@@ -13890,13 +13890,13 @@
 #: ../raster/r.li/r.li.daemon/daemon.c:695
 #, fuzzy
 msgid "Cannot make lseek"
-msgstr "Não consegui criar árvore"
+msgstr "Não consegui criar árvore"
 #: ../raster/r.li/r.li.patchnum/main.c:49
 #, fuzzy
 msgid ""
 "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 #: ../raster/r.li/r.li.patchdensity/main.c:50
 msgid ""
@@ -13906,28 +13906,28 @@
 #: ../raster/r.li/r.li.shape/main.c:48
 #, fuzzy
 msgid "Calculates shape index on a raster map"
 #: ../raster/r.li/r.li.padsd/padsd.c:52
 #, fuzzy
 msgid "Calculates standard deviation of patch area a raster map"
 msgstr ""
 #: ../raster/r.li/r.li.mpa/mpa.c:43
 #, fuzzy
 msgid "Calculates mean pixel attribute index on a raster map"
 #: ../raster/r.li/r.li.richness/richness.c:42
 #, fuzzy
 msgid "Calculates richness index on a raster map"
 #: ../raster/r.li/r.li.renyi/renyi.c:46
 #, fuzzy
 msgid "Calculates Renyi's diversity index on a raster map"
 #: ../raster/r.li/r.li.renyi/renyi.c:63
 msgid "Alpha value is the order of the generalized entropy"
@@ -13936,7 +13936,7 @@
 #: ../raster/r.in.mat/main.c:94
 #, fuzzy
 msgid "Imports a binary MAT-File(v4) to a GRASS raster."
-msgstr "Importar um arquivo MAT (v4) binário para um raster do GRASS"
+msgstr "Importar um arquivo MAT (v4) binário para um raster do GRASS"
 #: ../raster/r.in.mat/main.c:101
 #, fuzzy
@@ -13946,7 +13946,7 @@
 #: ../raster/r.in.mat/main.c:105
 #, fuzzy
 msgid "Name for output raster map (override)"
-msgstr "Nome do mapa raster de saída (sobrescrever)"
+msgstr "Nome do mapa raster de saída (sobrescrever)"
 #: ../raster/r.in.mat/main.c:149
 #, fuzzy
@@ -14023,7 +14023,7 @@
 #: ../raster/r.in.mat/main.c:344
 #, fuzzy, c-format
 msgid "No 'map_data' array found in <%s>"
-msgstr "Não mapear em"
+msgstr "Não mapear em"
 #: ../raster/r.in.mat/main.c:351
 #, c-format
@@ -14033,12 +14033,12 @@
 #: ../raster/r.in.mat/main.c:358
 #, fuzzy, c-format
 msgid "Setting map name to <%s>"
-msgstr "Nome ilegal do arquivo de saída: '%s'"
+msgstr "Nome ilegal do arquivo de saída: '%s'"
 #: ../raster/r.in.mat/main.c:362
 #, fuzzy
 msgid "No 'map_name' array found; using <MatFile>"
 #: ../raster/r.in.mat/main.c:373
 #, fuzzy
@@ -14048,7 +14048,7 @@
 #: ../raster/r.in.mat/main.c:377
 #, fuzzy
 msgid "Using default bounds"
-msgstr "padrão"
+msgstr "padrão"
 #: ../raster/r.in.mat/main.c:391
 #, c-format
@@ -14110,21 +14110,21 @@
 #: ../raster/r.surf.fractal/main.c:48
 msgid "Fractal dimension of surface (2 < D < 3)"
-msgstr "Dimensão fractal da superfície (2 < D < 3)"
+msgstr "Dimensão fractal da superfície (2 < D < 3)"
 #: ../raster/r.surf.fractal/main.c:55
 msgid "Number of intermediate images to produce"
-msgstr "Número de imagens intermediárias a produzir"
+msgstr "Número de imagens intermediárias a produzir"
 #: ../raster/r.surf.fractal/main.c:79
 #, fuzzy, c-format
 msgid "Fractal dimension of %.2lf must be between 2 and 3."
 #: ../raster/r.surf.fractal/process.c:54
 #, fuzzy
 msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr "Não consegui alocar memória para 'string'"
+msgstr "Não consegui alocar memória para 'string'"
 #: ../raster/r.circle/main.c:54 ../vector/v.buffer/main.c:224
 msgid "circle"
@@ -14134,8 +14134,8 @@
 #, fuzzy
 msgid "Creates a raster map containing concentric rings around a given point."
 msgstr ""
-"Nome do mapa raster contendo informação de coordenada norte do caminho "
-"retrógrado"
+"Nome do mapa raster contendo informação de coordenada norte do caminho "
+"retrógrado"
 #: ../raster/r.circle/main.c:63
 #, fuzzy
@@ -14145,12 +14145,12 @@
 #: ../raster/r.circle/main.c:69
 #, fuzzy
 msgid "Minimum radius for ring/circle map (in meters)"
-msgstr "Mínimo circular mapear em"
+msgstr "Mínimo circular mapear em"
 #: ../raster/r.circle/main.c:75
 #, fuzzy
 msgid "Maximum radius for ring/circle map (in meters)"
-msgstr "Máximo circular mapear em"
+msgstr "Máximo circular mapear em"
 #: ../raster/r.circle/main.c:81
 msgid "Data value multiplier"
@@ -14164,7 +14164,7 @@
 #: ../raster/r.circle/main.c:108
 #, fuzzy
 msgid "Please specify a radius in which min < max"
-msgstr "Especifique uma coluna z razoável."
+msgstr "Especifique uma coluna z razoável."
 #: ../raster/r.circle/main.c:116
 msgid "Please specify min and/or max radius when using the binary flag"
@@ -14177,55 +14177,55 @@
 #: ../raster/r.out.vtk/parameters.c:45
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
 msgid "Value to represent no data cell"
-msgstr "Valor para representar célula sem dados"
+msgstr "Valor para representar célula sem dados"
 #: ../raster/r.out.vtk/parameters.c:53
 #, fuzzy
 msgid "Constant elevation (if no elevation map is specified)"
-msgstr "Elevação mapear é"
+msgstr "Elevação mapear é"
 #: ../raster/r.out.vtk/parameters.c:59
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
 #, fuzzy
 msgid ""
 "Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr "Criar dados pontual VTK ao invés de dado VTK celular (padrão)"
+msgstr "Criar dados pontual VTK ao invés de dado VTK celular (padrão)"
 #: ../raster/r.out.vtk/parameters.c:69
 #, fuzzy
 msgid ""
 "Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
 msgstr ""
-"3 mapas raster (r,g,b) que serão usado para criar valores rgb [mapavermelho, "
+"3 mapas raster (r,g,b) que serão usado para criar valores rgb [mapavermelho, "
 "mapaverde, mapaazul]"
 #: ../raster/r.out.vtk/parameters.c:79
 #, fuzzy
 msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:104
 msgid "Use structured grid for elevation (not recommended)"
-msgstr "Usar malha estruturada para elevação (não recomendado)"
+msgstr "Usar malha estruturada para elevação (não recomendado)"
 #: ../raster/r.out.vtk/parameters.c:110
 #, fuzzy
 msgid "Use polydata-trianglestrips for elevation grid creation"
-msgstr "Usar polydata-trianglestrips para criação da malha de elevação"
+msgstr "Usar polydata-trianglestrips para criação da malha de elevação"
 #: ../raster/r.out.vtk/parameters.c:116
 msgid ""
 "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
 msgstr ""
-"Usar polydata-vertices para criação da malha de elevação (para usar com "
+"Usar polydata-vertices para criação da malha de elevação (para usar com "
 "vtkDelauny2D)"
 #: ../raster/r.out.vtk/parameters.c:122
 #, fuzzy
 msgid "Scale factor affects the origin (if no elevation map is given)"
-msgstr "Escala mapear é"
+msgstr "Escala mapear é"
 #: ../raster/r.out.vtk/main.c:62
 #, fuzzy
@@ -14253,7 +14253,7 @@
 #, fuzzy
 msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
 msgstr ""
-"Mapas RGB errados. Mapas devem ser do mesmo tipo! Saída RGB não adicionada!"
+"Mapas RGB errados. Mapas devem ser do mesmo tipo! Saída RGB não adicionada!"
 #: ../raster/r.out.vtk/main.c:261
 #, fuzzy
@@ -14265,7 +14265,7 @@
 msgid ""
 "Wrong vector maps. Maps should have the same type! Vector output not added!"
 msgstr ""
 #: ../raster/r.out.vtk/main.c:283
 msgid "Error closing VTK-ASCII file"
@@ -14274,17 +14274,17 @@
 #: ../raster/r.out.vtk/writeascii.c:75
 #, fuzzy
 msgid "write_vtk_normal_header: Writing VTK-Header"
-msgstr "writeVTKNormalHeader: Escrevendo cabeçalho VTK"
+msgstr "writeVTKNormalHeader: Escrevendo cabeçalho VTK"
 #: ../raster/r.out.vtk/writeascii.c:108
 #, fuzzy
 msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
-msgstr "writeVTKStructuredElevationHeader: Escrevendo cabeçalho VTK"
+msgstr "writeVTKStructuredElevationHeader: Escrevendo cabeçalho VTK"
 #: ../raster/r.out.vtk/writeascii.c:124
 #, fuzzy
 msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
-msgstr "writeVTKPolygonalElevationHeader: Escrevendo cabeçalho VTK"
+msgstr "writeVTKPolygonalElevationHeader: Escrevendo cabeçalho VTK"
 #: ../raster/r.out.vtk/writeascii.c:139
 msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
@@ -14311,7 +14311,7 @@
 #: ../raster/r.out.vtk/writeascii.c:384
 #, fuzzy
 msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
-msgstr "writeVTKRGBImageData: Escrevendo cabeçalho VTK"
+msgstr "writeVTKRGBImageData: Escrevendo cabeçalho VTK"
 #: ../raster/r.out.vtk/writeascii.c:412
 #, fuzzy
@@ -14321,7 +14321,7 @@
 #: ../raster/r.out.vtk/writeascii.c:442
 #, fuzzy
 msgid "write_vtk_vector_data: Writing VTK-vector data"
-msgstr "writeVTKData: Escrevendo cabeçalho VTK"
+msgstr "writeVTKData: Escrevendo cabeçalho VTK"
 #: ../raster/r.gwflow/main.c:57
 #, fuzzy
@@ -14333,7 +14333,7 @@
 msgid ""
 "Name of input raster map providing boundary condition status: 0-inactive, 1-"
 "active, 2-dirichlet"
-msgstr "Estados da condição de fronteira, 0-inativo, 1-ativo, 2-dirichlet"
+msgstr "Estados da condição de fronteira, 0-inativo, 1-ativo, 2-dirichlet"
 #: ../raster/r.gwflow/main.c:67
 #, fuzzy
@@ -14352,7 +14352,7 @@
 #: ../raster/r.gwflow/main.c:77
 #, fuzzy
 msgid "Name of input raster map with water sources and sinks in [m^3/s]"
-msgstr "Mapa(s) de entrada não especificado(s)."
+msgstr "Mapa(s) de entrada não especificado(s)."
 #: ../raster/r.gwflow/main.c:81
 msgid ""
@@ -14367,7 +14367,7 @@
 #: ../raster/r.gwflow/main.c:88
 #, fuzzy
 msgid "Recharge input raster map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-msgstr "Não consegui abrir arquivo de células [%s]"
+msgstr "Não consegui abrir arquivo de células [%s]"
 #: ../raster/r.gwflow/main.c:92
 #, fuzzy
@@ -14384,26 +14384,26 @@
 #: ../raster/r.gwflow/main.c:100
 #, fuzzy
 msgid "Output raster map storing the numerical result [m]"
-msgstr "Título do raster de saída"
+msgstr "Título do raster de saída"
 #: ../raster/r.gwflow/main.c:106
 #, fuzzy
 msgid ""
 "Output raster map to store the groundwater filter velocity vector part in x "
 "direction [m/s]"
 #: ../raster/r.gwflow/main.c:112
 #, fuzzy
 msgid ""
 "Output raster map to store the groundwater filter velocity vector part in y "
 "direction [m/s]"
 #: ../raster/r.gwflow/main.c:118
 #, fuzzy
 msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
 #: ../raster/r.gwflow/main.c:126
 msgid "The type of groundwater flow"
@@ -14443,7 +14443,7 @@
 #: ../raster/r.gwflow/main.c:167
 #, fuzzy
 msgid "The maximum number of iterations in the linearization approach"
-msgstr "Número de iterações máximas"
+msgstr "Número de iterações máximas"
 #: ../raster/r.gwflow/main.c:176
 msgid ""
@@ -14463,7 +14463,7 @@
 #: ../raster/r.gwflow/main.c:249
 msgid "Please provide drain_head and drain_leak maps"
-msgstr "Favor forneça os mapas drain_head e drain_leak"
+msgstr "Favor forneça os mapas drain_head e drain_leak"
 #: ../raster/r.gwflow/main.c:263
 msgid ""
@@ -14474,7 +14474,7 @@
 #: ../raster/r.gwflow/main.c:293
 #, fuzzy, c-format
 msgid "Calculation time: %g"
-msgstr "Calculando médias das classes ..."
+msgstr "Calculando médias das classes ..."
 #: ../raster/r.gwflow/main.c:380
 #, c-format
@@ -14484,12 +14484,12 @@
 #: ../raster/r.gwflow/main.c:403
 #, c-format
 msgid "Maximum difference between this and last increment: %g"
-msgstr "Máxima diferença entre este e o próximo incremento: %g"
+msgstr "Máxima diferença entre este e o próximo incremento: %g"
 #: ../raster/r.in.png/main.c:297
 #, fuzzy, c-format
 msgid "Unable to open PNG file '%s'"
 #: ../raster/r.in.png/main.c:300
 #, fuzzy
@@ -14499,28 +14499,28 @@
 #: ../raster/r.in.png/main.c:303
 #, fuzzy
 msgid "Input file not a PNG file"
-msgstr "Arquivo de entrada é portável.\n"
+msgstr "Arquivo de entrada é portável.\n"
 #: ../raster/r.in.png/main.c:307 ../raster/r.in.png/main.c:311
 #: ../general/g.ppmtopng/main.c:70 ../general/g.ppmtopng/main.c:74
 #, fuzzy
 msgid "Unable to allocate PNG structure"
 #: ../raster/r.in.png/main.c:314
 #, fuzzy
 msgid "PNG error"
-msgstr "Parâmetros do agrupamento\n"
+msgstr "Parâmetros do agrupamento\n"
 #: ../raster/r.in.png/main.c:522
 #, fuzzy
 msgid "Imports non-georeferenced PNG format image."
-msgstr "Exporta um raster do GRASS para imagem PNG não-georeferenciada"
+msgstr "Exporta um raster do GRASS para imagem PNG não-georeferenciada"
 #: ../raster/r.in.png/main.c:532
 #, fuzzy
 msgid "Title for created raster map"
-msgstr "Título para o mapa resultante"
+msgstr "Título para o mapa resultante"
 #: ../raster/r.in.png/main.c:538
 #, fuzzy
@@ -14539,7 +14539,7 @@
 #: ../raster/r.in.png/main.c:552
 #, fuzzy
 msgid "Output image file header only and exit"
-msgstr "Saída apenas em metros"
+msgstr "Saída apenas em metros"
 #: ../raster/r.rescale.eq/main.c:55
 msgid ""
@@ -14557,35 +14557,35 @@
 #: ../raster/r.stats/raw_stats.c:118
 #, fuzzy
 msgid "Invalid map type"
-msgstr "Fonte inválida: %s"
+msgstr "Fonte inválida: %s"
 #: ../raster/r.stats/main.c:109
 #, fuzzy
 msgid "Generates area statistics for raster map."
-msgstr "Gera estatísticas areais para os mapas raster."
+msgstr "Gera estatísticas areais para os mapas raster."
 #: ../raster/r.stats/main.c:157
 #, fuzzy
 msgid "Print area totals in square meters"
 #: ../raster/r.stats/main.c:162
 #, fuzzy
 msgid "Print cell counts (sortable)"
-msgstr "Mostra contagem de células"
+msgstr "Mostra contagem de células"
 #: ../raster/r.stats/main.c:168
 #, fuzzy
 msgid "Print approximate (total percent may not be 100%) percents"
-msgstr "Mostra porcentuais APROXIMADOS (porcentual total pode não ser 100%)"
+msgstr "Mostra porcentuais APROXIMADOS (porcentual total pode não ser 100%)"
 #: ../raster/r.stats/main.c:173
 msgid "Print category labels"
-msgstr "Mostra rótulos de categorias"
+msgstr "Mostra rótulos de categorias"
 #: ../raster/r.stats/main.c:177
 msgid "One cell (range) per line"
-msgstr "Uma célula (intervalo) por linha"
+msgstr "Uma célula (intervalo) por linha"
 #: ../raster/r.stats/main.c:181
 msgid "Print grid coordinates (east and north)"
@@ -14603,12 +14603,12 @@
 #: ../raster/r.stats/main.c:191
 #, fuzzy
 msgid "Print averaged values instead of intervals (floating-point maps only)"
-msgstr "Imprime valores médios ao invés de intervalos"
+msgstr "Imprime valores médios ao invés de intervalos"
 #: ../raster/r.stats/main.c:196
 #, fuzzy
 msgid "Print raw indexes of floating-point ranges (floating-point maps only)"
-msgstr "Mostrar índices brutos dos intervalos fp (apenas mapas fp)"
+msgstr "Mostrar índices brutos dos intervalos fp (apenas mapas fp)"
 #: ../raster/r.stats/main.c:233
 #, c-format
@@ -14618,7 +14618,7 @@
 #: ../raster/r.stats/main.c:285 ../raster/r.series.accumulate/main.c:265
 #: ../raster/r.series/main.c:287
 msgid "Raster map not found"
-msgstr "Mapa raster não encontrado"
+msgstr "Mapa raster não encontrado"
 #: ../raster/r.stats/main.c:303
 #, c-format
@@ -14640,18 +14640,18 @@
 "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
 "option"
 msgstr ""
-"Opção '-%c' foi dada, usando cats fp ranges do mapa raster <%s>, ignorando "
-"opção '%s'"
+"Opção '-%c' foi dada, usando cats fp ranges do mapa raster <%s>, ignorando "
+"opção '%s'"
 #: ../raster/r.stats/main.c:331 ../raster/r.contour/main.c:149
 #, c-format
 msgid "Unable to read fp range of raster map <%s>"
-msgstr "Não consegui ler intervalo pf do mapa raster <%s>"
+msgstr "Não consegui ler intervalo pf do mapa raster <%s>"
 #: ../raster/r.stats/main.c:358 ../raster/r.recode/read_rules.c:35
 #, fuzzy, c-format
 msgid "Unable to read range for map <%s>"
-msgstr "%s: não consegui criar %s"
+msgstr "%s: não consegui criar %s"
 #: ../raster/r.to.rast3elev/main.c:99
 #, fuzzy
@@ -14687,12 +14687,12 @@
 #: ../raster/r.to.rast3elev/main.c:400
 #, fuzzy
 msgid "The upper value is not valid"
-msgstr "Valor de categoria em <%s> inválido"
+msgstr "Valor de categoria em <%s> inválido"
 #: ../raster/r.to.rast3elev/main.c:410
 #, fuzzy
 msgid "The lower value is not valid"
 #: ../raster/r.to.rast3elev/main.c:427
 #, fuzzy
@@ -14700,8 +14700,8 @@
 "The 2D and 3D region settings are different. I will use the 3D region "
 "settings to adjust the 2D region."
 msgstr ""
-"As configurações de região 2d e 3d estão diferentes. Usarei as configurações "
-"g3d para ajustar a região 2d."
+"As configurações de região 2d e 3d estão diferentes. Usarei as configurações "
+"g3d para ajustar a região 2d."
 #: ../raster/r.series.accumulate/main.c:81 ../raster/r.series/main.c:139
 #: ../raster/r.series.interp/main.c:65
@@ -14723,8 +14723,8 @@
 "Makes each output cell value a accumulationfunction of the values assigned "
 "to the corresponding cells in the input raster map layers."
 msgstr ""
-"Define cada célula da saída como função dos valores designados para as "
-"células correspondentes nos mapas raster de entrada."
+"Define cada célula da saída como função dos valores designados para as "
+"células correspondentes nos mapas raster de entrada."
 #: ../raster/r.series.accumulate/main.c:90
 msgid "Existing map to be added to output"
@@ -14738,7 +14738,7 @@
 #: ../raster/r.series.accumulate/main.c:109
 #, fuzzy
 msgid "Scale factor for input"
-msgstr "Fator de escala para elevação"
+msgstr "Fator de escala para elevação"
 #: ../raster/r.series.accumulate/main.c:116
 #, fuzzy
@@ -14771,7 +14771,7 @@
 #: ../raster/r.series.accumulate/main.c:152
 #, fuzzy
 msgid "Mean: sum(input maps)/(number of input maps)"
 #: ../raster/r.series.accumulate/main.c:153
 msgid "Biologically Effective Degree Days"
@@ -14791,7 +14791,7 @@
 #: ../raster/r.series.accumulate/main.c:163 ../raster/r.series/main.c:191
 #, fuzzy
 msgid "Do not keep files open"
-msgstr "Não consegui abrir o arquivo [%s]"
+msgstr "Não consegui abrir o arquivo [%s]"
 #: ../raster/r.series.accumulate/main.c:167
 msgid "Create a FCELL map (floating point single precision) as output"
@@ -14804,7 +14804,7 @@
 #: ../raster/r.neighbors/main.c:266 ../vector/v.colors/main.c:206
 #, fuzzy, c-format
 msgid "%s= and %s= are mutually exclusive"
 #: ../raster/r.series.accumulate/main.c:210 ../raster/r.series/main.c:208
 #: ../raster/r.series.interp/main.c:126 ../raster/r.series.interp/main.c:142
@@ -14825,12 +14825,12 @@
 #: ../raster/r.proj/bordwalk.c:216
 #, fuzzy
 msgid "Input raster map is outside current region"
-msgstr "Não existe mapa rasterna janela atual"
+msgstr "Não existe mapa rasterna janela atual"
 #: ../raster/r.proj/bordwalk.c:242
 #, fuzzy
 msgid "Unable to reproject map center"
 #: ../raster/r.proj/main.c:145 ../raster/r.latlong/main.c:59
 #: ../locale/scriptstrings/v.import_to_translate.c:4
@@ -14845,12 +14845,12 @@
 #: ../raster/r.proj/main.c:149
 #, fuzzy
 msgid "Re-projects a raster map from given location to the current location."
-msgstr "Reprojeta um mapa raster de uma locação para a locação atual."
+msgstr "Reprojeta um mapa raster de uma locação para a locação atual."
 #: ../raster/r.proj/main.c:153
 #, fuzzy
 msgid "Location containing input raster map"
-msgstr "Localização do mapa de entrada"
+msgstr "Localização do mapa de entrada"
 #: ../raster/r.proj/main.c:154 ../raster/r.proj/main.c:159
 #: ../raster/r.proj/main.c:164 ../vector/v.net.flow/main.c:108
@@ -14858,7 +14858,7 @@
 #: ../vector/v.proj/main.c:83 ../vector/v.proj/main.c:89
 #, fuzzy
 msgid "Source"
-msgstr "Variância da soma"
+msgstr "Variância da soma"
 #: ../raster/r.proj/main.c:157
 #, fuzzy
@@ -14877,12 +14877,12 @@
 #: ../raster/r.proj/main.c:167 ../vector/v.proj/main.c:92
 msgid "Path to GRASS database of input location"
-msgstr "Caminho para o banco de dados GRASS da locação de entrada"
+msgstr "Caminho para o banco de dados GRASS da locação de entrada"
 #: ../raster/r.proj/main.c:171
 #, fuzzy
 msgid "Name for output raster map (default: same as 'input')"
 #: ../raster/r.proj/main.c:172 ../raster/r.proj/main.c:183
 #: ../raster/r.proj/main.c:199 ../vector/v.proj/main.c:101
@@ -14890,33 +14890,33 @@
 #: ../vector/v.proj/main.c:125
 #, fuzzy
 msgid "Target"
-msgstr "Área\n"
+msgstr "Área\n"
 #: ../raster/r.proj/main.c:198
 #, fuzzy
 msgid "Resolution of output raster map"
-msgstr "Resolução do mapa de saída"
+msgstr "Resolução do mapa de saída"
 #: ../raster/r.proj/main.c:203
 #, fuzzy
 msgid "List raster maps in input mapset and exit"
-msgstr "Mostra os arquivos raster na locação de entrada e encerra"
+msgstr "Mostra os arquivos raster na locação de entrada e encerra"
 #: ../raster/r.proj/main.c:208
 #: ../locale/scriptstrings/r.import_to_translate.c:28
 msgid "Do not perform region cropping optimization"
-msgstr "Não executar otimização do corte da regição"
+msgstr "Não executar otimização do corte da regição"
 #: ../raster/r.proj/main.c:213
 #, fuzzy
 msgid "Print input map's bounds in the current projection and exit"
 #: ../raster/r.proj/main.c:219
 #, fuzzy
 msgid ""
 "Print input map's bounds in the current projection and exit (shell style)"
-msgstr "Imprime a região atual (no estilo de script em shell)"
+msgstr "Imprime a região atual (no estilo de script em shell)"
 #: ../raster/r.proj/main.c:252 ../vector/v.proj/main.c:159
 msgid "Input and output locations can not be the same"
@@ -14925,27 +14925,27 @@
 #: ../raster/r.proj/main.c:254
 #, fuzzy
 msgid "Input and output locations are the same"
-msgstr "Mapa de Entrada: localização das depressões reais"
+msgstr "Mapa de Entrada: localização das depressões reais"
 #: ../raster/r.proj/main.c:264
 #, fuzzy
 msgid "Unable to get projection info of output raster map"
-msgstr "Não consegui informações de projeção da locação atual"
+msgstr "Não consegui informações de projeção da locação atual"
 #: ../raster/r.proj/main.c:267
 #, fuzzy
 msgid "Unable to get projection units of output raster map"
-msgstr "Não consegui unidades de projeção da locação atual"
+msgstr "Não consegui unidades de projeção da locação atual"
 #: ../raster/r.proj/main.c:270
 #, fuzzy
 msgid "Unable to get projection key values of output raster map"
-msgstr "Não obtive os valores de projeção da locação atual"
+msgstr "Não obtive os valores de projeção da locação atual"
 #: ../raster/r.proj/main.c:279
 #, fuzzy, c-format
 msgid "Mapset <%s> in input location <%s> - %s"
-msgstr "Grupo [%s] destinado para locação [%s], mapset [%s]\n"
+msgstr "Grupo [%s] destinado para locação [%s], mapset [%s]\n"
 #: ../raster/r.proj/main.c:288 ../vector/v.proj/main.c:183
 #, fuzzy, c-format
@@ -14960,27 +14960,27 @@
 #: ../vector/v.net/args.c:179 ../vector/v.proj/main.c:200
 #, c-format
 msgid "Required parameter <%s> not set"
-msgstr "parâmetro <%s> necessário não configurado"
+msgstr "parâmetro <%s> necessário não configurado"
 #: ../raster/r.proj/main.c:303
 #, fuzzy, c-format
 msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
-msgstr "Arquivo de vetores [%s] não está disponível"
+msgstr "Arquivo de vetores [%s] não está disponível"
 #: ../raster/r.proj/main.c:311
 #, fuzzy
 msgid "Unable to get projection info of input map"
 #: ../raster/r.proj/main.c:314
 #, fuzzy
 msgid "Unable to get projection units of input map"
 #: ../raster/r.proj/main.c:317
 #, fuzzy
 msgid "Unable to get projection key values of input map"
 #: ../raster/r.proj/main.c:332
 msgid "Unable to work with unprojected data (xy location)"
@@ -14989,7 +14989,7 @@
 #: ../raster/r.proj/main.c:351
 #, fuzzy, c-format
 msgid "Input map <%s@%s> in location <%s>:"
 #: ../raster/r.proj/main.c:443
 #, fuzzy
@@ -15009,7 +15009,7 @@
 #: ../raster/r.proj/main.c:446 ../raster/r.proj/main.c:457
 #, fuzzy, c-format
 msgid "North: %f (%f)"
-msgstr "Nó %d: %f %f\n"
+msgstr "Nó %d: %f %f\n"
 #: ../raster/r.proj/main.c:447 ../raster/r.proj/main.c:458
 #, c-format
@@ -15019,12 +15019,12 @@
 #: ../raster/r.proj/main.c:448 ../raster/r.proj/main.c:459
 #, fuzzy, c-format
 msgid "West: %f (%f)"
 #: ../raster/r.proj/main.c:449 ../raster/r.proj/main.c:460
 #, fuzzy, c-format
 msgid "East: %f (%f)"
 #: ../raster/r.proj/main.c:450 ../raster/r.proj/main.c:461
 #, c-format
@@ -15039,7 +15039,7 @@
 #: ../raster/r.proj/main.c:454
 #, fuzzy
 msgid "Output:"
-msgstr "Saída de mapa"
+msgstr "Saída de mapa"
 #: ../raster/r.proj/main.c:491
 #, fuzzy
@@ -15049,17 +15049,17 @@
 #: ../raster/r.proj/readcell.c:67
 #, fuzzy
 msgid "Allocating memory and reading input raster map..."
 #: ../raster/r.kappa/calc_kappa.c:32
 #, fuzzy, c-format
 msgid "Cannot open file <%s> to write kappa and relevant parameters"
-msgstr "Não consegui abrir arquivo 3dview  <%s> em <%s>"
+msgstr "Não consegui abrir arquivo 3dview  <%s> em <%s>"
 #: ../raster/r.kappa/prt_mat.c:39
 #, fuzzy, c-format
 msgid "Cannot open file <%s> to write cats and counts (error matrix)"
 #: ../raster/r.kappa/main.c:72
 #, fuzzy
@@ -15067,8 +15067,8 @@
 "Calculates error matrix and kappa parameter for accuracy assessment of "
 "classification result."
 msgstr ""
-"Calcula a matriz de erro e o parâmetro 'capa' para avaliação da acurácia do "
-"resultado da classificação."
+"Calcula a matriz de erro e o parâmetro 'capa' para avaliação da acurácia do "
+"resultado da classificação."
 #: ../raster/r.kappa/main.c:78
 #, fuzzy
@@ -15078,24 +15078,24 @@
 #: ../raster/r.kappa/main.c:83
 #, fuzzy
 msgid "Name of raster map containing reference classes"
-msgstr "Nome do mapa raster contendo MODELOS de combustível"
+msgstr "Nome do mapa raster contendo MODELOS de combustível"
 #: ../raster/r.kappa/main.c:88
 #, fuzzy
 msgid "Name for output file containing error matrix and kappa"
-msgstr "Nome do arquivo de saída contendo a matriz de erro e capa"
+msgstr "Nome do arquivo de saída contendo a matriz de erro e capa"
 #: ../raster/r.kappa/main.c:89 ../raster/r.colors.out/raster3d_main.c:57
 #: ../raster/r.colors.out/raster_main.c:56 ../vector/v.colors.out/main.c:62
 #, fuzzy
 msgid "If not given write to standard output"
 msgstr ""
-"entrada padrão"
+"entrada padrão"
 #: ../raster/r.kappa/main.c:96
 msgid "Title for error matrix and kappa"
-msgstr "Título para a matriz de erro e capa"
+msgstr "Título para a matriz de erro e capa"
 #: ../raster/r.kappa/main.c:102
 msgid "Wide report"
@@ -15104,22 +15104,22 @@
 #: ../raster/r.kappa/main.c:103
 #, fuzzy
 msgid "132 columns (default: 80)"
-msgstr "relatório largo, 132 colunas (padrão: 80)"
+msgstr "relatório largo, 132 colunas (padrão: 80)"
 #: ../raster/r.kappa/main.c:108
 #, fuzzy
 msgid "No header in the report"
-msgstr "sem cabeçalho no relatório"
+msgstr "sem cabeçalho no relatório"
 #: ../raster/r.kappa/prt_hdr.c:18
 #, fuzzy, c-format
 msgid "Cannot open file <%s> to write header"
 #: ../raster/r.kappa/prt_label.c:17
 #, fuzzy, c-format
 msgid "Can't open file <%s> to write label"
 #: ../raster/r.out.pov/main.c:124
 #, fuzzy
@@ -15129,7 +15129,7 @@
 #: ../raster/r.out.pov/main.c:131
 msgid "Name of output povray file (TGA height field file)"
-msgstr "Nome do arquivo povray de saída (arquivo de campo de altura TGA)"
+msgstr "Nome do arquivo povray de saída (arquivo de campo de altura TGA)"
 #: ../raster/r.out.pov/main.c:138
 msgid "Height-field type (0=actual heights 1=normalized)"
@@ -15137,31 +15137,31 @@
 #: ../raster/r.out.pov/main.c:144
 msgid "Elevation bias"
-msgstr "Viés (bias) de elevação"
+msgstr "Viés (bias) de elevação"
 #: ../raster/r.out.pov/main.c:150 ../raster/r.param.scale/interface.c:118
 msgid "Vertical scaling factor"
-msgstr "Fator de sobrelevação"
+msgstr "Fator de sobrelevação"
 #: ../raster/r.out.pov/main.c:170
 #, c-format
 msgid "Invalid output filename <%s>"
-msgstr "Nome do arquivo de saída <%s> inválido"
+msgstr "Nome do arquivo de saída <%s> inválido"
 #: ../raster/r.out.pov/main.c:180
 #, c-format
 msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr "Mapa raster é muito grande! Excede %d colunas ou %d linhas"
+msgstr "Mapa raster é muito grande! Excede %d colunas ou %d linhas"
 #: ../raster/r.out.pov/main.c:201
 msgid "Negative elevation values in input"
-msgstr "Valores de elevação negativos na entrada"
+msgstr "Valores de elevação negativos na entrada"
 #: ../raster/r.cost/main.c:141 ../raster/r.drain/main.c:111
 #: ../raster/r.walk/main.c:179
 #, fuzzy
 msgid "cost surface"
 #: ../raster/r.cost/main.c:142 ../raster/r.spreadpath/main.c:90
 #: ../raster/r.walk/main.c:180
@@ -15172,7 +15172,7 @@
 #: ../vector/v.net.alloc/main.c:59
 #, fuzzy
 msgid "cost allocation"
 #: ../raster/r.cost/main.c:145
 msgid ""
@@ -15181,18 +15181,18 @@
 "represent cost."
 msgstr ""
 "Gera um mapa raster mostrando o custo acumulado de movimento entre "
-"diferentes localizações em um mapa raster de entrada cujos valores de célula "
+"diferentes localizações em um mapa raster de entrada cujos valores de célula "
 "representam o custo."
 #: ../raster/r.cost/main.c:152
 #, fuzzy
 msgid "Name of input raster map containing grid cell cost information"
-msgstr "Nome do mapa raster contendo o custo de cada célula"
+msgstr "Nome do mapa raster contendo o custo de cada célula"
 #: ../raster/r.cost/main.c:160
 #, fuzzy
 msgid "Name for output raster map with nearest start point"
-msgstr "Nome do Raster de saída"
+msgstr "Nome do Raster de saída"
 #: ../raster/r.cost/main.c:161 ../raster/r.cost/main.c:168
 #: ../raster/r.walk/main.c:203
@@ -15251,12 +15251,12 @@
 #: ../raster/r.cost/main.c:209 ../raster/r.walk/main.c:244
 #, fuzzy
 msgid "Maximum cumulative cost"
-msgstr "Um custo cumulativo máximo (opcional)"
+msgstr "Um custo cumulativo máximo (opcional)"
 #: ../raster/r.cost/main.c:218 ../raster/r.walk/main.c:253
 msgid "Cost assigned to null cells. By default, null cells are excluded"
 msgstr ""
-"Custo designado para células NULL. Por padrão, células NULL são excluídas."
+"Custo designado para células NULL. Por padrão, células NULL são excluídas."
 #: ../raster/r.cost/main.c:219 ../raster/r.cost/main.c:238
 #: ../raster/r.walk/main.c:254 ../raster/r.walk/main.c:304
@@ -15266,16 +15266,16 @@
 #: ../raster/r.cost/main.c:228 ../raster/r.walk/main.c:263
 #, fuzzy
 msgid "Maximum memory to be used in MB"
-msgstr "Memória Esgotada! (Out of Memory)"
+msgstr "Memória Esgotada! (Out of Memory)"
 #: ../raster/r.cost/main.c:233 ../raster/r.walk/main.c:299
 msgid "Use the 'Knight's move'; slower, but more accurate"
-msgstr "Usar o 'movimento do Cavalo'; lento, porém mais preciso"
+msgstr "Usar o 'movimento do Cavalo'; lento, porém mais preciso"
 #: ../raster/r.cost/main.c:237 ../raster/r.walk/main.c:303
 #, fuzzy
 msgid "Keep null values in output raster map"
-msgstr "Manter valores nulos no mapa de saída"
+msgstr "Manter valores nulos no mapa de saída"
 #: ../raster/r.cost/main.c:242 ../raster/r.walk/main.c:308
 msgid "Start with values in raster map"
@@ -15284,7 +15284,7 @@
 #: ../raster/r.cost/main.c:247 ../raster/r.walk/main.c:313
 #, fuzzy
 msgid "Print info about disk space and memory requirements and exit"
-msgstr "Relata informação sobre o raster de entrada e encerra"
+msgstr "Relata informação sobre o raster de entrada e encerra"
 #: ../raster/r.cost/main.c:297 ../raster/r.walk/main.c:357
 #, fuzzy
@@ -15295,23 +15295,23 @@
 #: ../raster/r.walk/main.c:362 ../raster/r.walk/main.c:845
 #, fuzzy
 msgid "No start points"
-msgstr "Não pontos"
+msgstr "Não pontos"
 #: ../raster/r.cost/main.c:309 ../raster/r.walk/main.c:369
 #, c-format
 msgid "Inappropriate maximum cost: %d"
-msgstr "Custo máximo não apropriado: %d"
+msgstr "Custo máximo não apropriado: %d"
 #: ../raster/r.cost/main.c:312 ../raster/r.walk/main.c:372
 #, fuzzy, c-format
 msgid "Inappropriate amount of memory: %d"
 #: ../raster/r.cost/main.c:330 ../raster/r.walk/main.c:415
 #, fuzzy
 msgid "Assigning negative cost to null cell. Null cells excluded."
 msgstr ""
 #: ../raster/r.cost/main.c:412 ../raster/r.cost/main.c:424
 #: ../raster/r.walk/main.c:525 ../raster/r.walk/main.c:538
@@ -15329,11 +15329,11 @@
 #: ../raster/r.walk/main.c:529 ../raster/r.walk/main.c:540
 #, fuzzy, c-format
 msgid "%d of %d segments are kept in memory"
 #: ../raster/r.cost/main.c:431 ../raster/r.walk/main.c:545
 msgid "Creating some temporary files..."
-msgstr "Criando alguns arquivos temporários..."
+msgstr "Criando alguns arquivos temporários..."
 #: ../raster/r.cost/main.c:444
 #, fuzzy, c-format
@@ -15373,12 +15373,12 @@
 #: ../vector/v.vol.rst/user1.c:140
 #, fuzzy
 msgid "Unable to read vector map"
-msgstr "Não consegui criar arquivo raster [%s]."
+msgstr "Não consegui criar arquivo raster [%s]."
 #: ../raster/r.cost/main.c:582
 #, fuzzy, c-format
 msgid "No start points found in vector map <%s>"
-msgstr "Não consegui encontrar o mapa de entrada <%s>"
+msgstr "Não consegui encontrar o mapa de entrada <%s>"
 #: ../raster/r.cost/main.c:584
 #, fuzzy, c-format
@@ -15395,7 +15395,7 @@
 #: ../raster/r.cost/main.c:652 ../raster/r.walk/main.c:788
 #, fuzzy, c-format
 msgid "No stop points found in vector <%s>"
 #: ../raster/r.cost/main.c:675 ../raster/r.walk/main.c:810
 #, fuzzy, c-format
@@ -15404,7 +15404,7 @@
 #: ../raster/r.cost/main.c:726 ../raster/r.walk/main.c:859
 msgid "Specified starting location outside database window"
-msgstr "Locação inicial especificado fora da janela de banco de dados"
+msgstr "Locação inicial especificado fora da janela de banco de dados"
 #: ../raster/r.cost/main.c:748 ../raster/r.walk/main.c:879
 #, fuzzy
@@ -15443,7 +15443,7 @@
 #: ../raster/r.cost/main.c:1225 ../raster/r.walk/main.c:1504
 #, fuzzy, c-format
 msgid "Warning, ignoring point outside window: %g, %g"
-msgstr "Atenção, ignorando ponto fora da janela: %.4f,%.4f"
+msgstr "Atenção, ignorando ponto fora da janela: %.4f,%.4f"
 #: ../raster/r.stream.extract/do_astar.c:40
 msgid "A* Search..."
@@ -15462,7 +15462,7 @@
 #: ../raster/r.stream.extract/dseg.c:19
 #, fuzzy
 msgid "dseg_open(): unable to create segment file"
 #: ../raster/r.stream.extract/dseg.c:29 ../raster/r.stream.extract/dseg.c:79
 #: ../raster/r.stream.extract/dseg.c:88 ../raster/r.stream.extract/bseg.c:28
@@ -15472,18 +15472,18 @@
 #: ../raster/r.stream.extract/seg.c:75
 #, fuzzy
 msgid "Unable to write segment file"
 #: ../raster/r.stream.extract/dseg.c:33
 #, fuzzy
 msgid "Iillegal configuration parameter(s)"
 #: ../raster/r.stream.extract/dseg.c:40 ../raster/r.stream.extract/bseg.c:39
 #: ../raster/r.stream.extract/cseg.c:40
 #, fuzzy
 msgid "Unable to re-open segment file"
-msgstr "Não consegui abrir arquivo de saída."
+msgstr "Não consegui abrir arquivo de saída."
 #: ../raster/r.stream.extract/dseg.c:47 ../raster/r.stream.extract/dseg.c:97
 #: ../raster/r.stream.extract/bseg.c:46 ../raster/r.stream.extract/bseg.c:96
@@ -15491,12 +15491,12 @@
 #: ../raster/r.stream.extract/seg.c:93 ../raster/r.stream.extract/seg.c:102
 #, fuzzy
 msgid "Unable to read segment file"
-msgstr "Não consegui ler arquivo de cores."
+msgstr "Não consegui ler arquivo de cores."
 #: ../raster/r.stream.extract/dseg.c:120
 #, fuzzy, c-format
 msgid "Inable to segment put row %d for raster <%s>"
 #: ../raster/r.stream.extract/init_search.c:24
 #, fuzzy
@@ -15532,22 +15532,22 @@
 #: ../vector/v.to.points/main.c:182
 #, c-format
 msgid "Unable to create table: '%s'"
-msgstr "Não consegui criar tabela: '%s'"
+msgstr "Não consegui criar tabela: '%s'"
 #: ../raster/r.stream.extract/close.c:192
 #, fuzzy, c-format
 msgid "Unable to create index on table <%s>"
-msgstr "Não consegui abrir arquivo de saída <%s>."
+msgstr "Não consegui abrir arquivo de saída <%s>."
 #: ../raster/r.stream.extract/close.c:213
 #, fuzzy, c-format
 msgid "Unable to insert new row: '%s'"
-msgstr "Não consegui inserir novo registro: '%s'"
+msgstr "Não consegui inserir novo registro: '%s'"
 #: ../raster/r.stream.extract/close.c:313
 #, fuzzy, c-format
 msgid "Unable to write vector map <%s>"
 #: ../raster/r.stream.extract/main.c:78
 #, fuzzy
@@ -15557,12 +15557,12 @@
 #: ../raster/r.stream.extract/main.c:79
 #, fuzzy
 msgid "Performs stream network extraction."
-msgstr "Número de pontos de interpolação"
+msgstr "Número de pontos de interpolação"
 #: ../raster/r.stream.extract/main.c:85
 #, fuzzy
 msgid "Name of input accumulation raster map"
 #: ../raster/r.stream.extract/main.c:88
 msgid ""
@@ -15588,7 +15588,7 @@
 #: ../raster/r.stream.extract/main.c:101
 #, fuzzy
 msgid "Minimum flow accumulation for streams"
 #: ../raster/r.stream.extract/main.c:102
 #, fuzzy
@@ -15626,19 +15626,19 @@
 #: ../raster/r.stream.extract/main.c:147
 #, fuzzy
 msgid "Name for output raster map with unique stream ids"
 #: ../raster/r.stream.extract/main.c:149 ../raster/r.stream.extract/main.c:156
 #: ../raster/r.stream.extract/main.c:163 ../raster/r.flow/main.c:459
 #: ../raster/r.flow/main.c:465 ../raster/r.flow/main.c:471
 #, fuzzy
 msgid "Output maps"
 #: ../raster/r.stream.extract/main.c:154
 #, fuzzy
 msgid "Name for output vector map with unique stream ids"
-msgstr "Saída é o erro de interpolação"
+msgstr "Saída é o erro de interpolação"
 #: ../raster/r.stream.extract/main.c:161
 #, fuzzy
@@ -15653,12 +15653,12 @@
 #: ../raster/r.stream.extract/main.c:201
 #, fuzzy, c-format
 msgid "d8cut must be positive or zero but is %f"
-msgstr "Suavização deve ser um valor positivo"
+msgstr "Suavização deve ser um valor positivo"
 #: ../raster/r.stream.extract/main.c:209
 #, fuzzy, c-format
 msgid "Montgomery exponent must be positive or zero but is %f"
 #: ../raster/r.stream.extract/main.c:212
 #, c-format
@@ -15668,12 +15668,12 @@
 #: ../raster/r.stream.extract/main.c:222
 #, fuzzy, c-format
 msgid "Minimum stream length must be positive or zero but is %d"
 #: ../raster/r.stream.extract/main.c:231
 #, fuzzy, c-format
 msgid "Memory must be positive but is %d"
 #: ../raster/r.stream.extract/main.c:241
 #, fuzzy
@@ -15683,7 +15683,7 @@
 #: ../raster/r.stream.extract/main.c:315
 #, fuzzy, c-format
 msgid "%.2f%% of data are kept in memory"
 #: ../raster/r.stream.extract/main.c:319
 #: ../raster/r.watershed/seg/init_vars.c:252
@@ -15700,42 +15700,42 @@
 #: ../raster/r.stream.extract/main.c:325
 #, fuzzy
 msgid "Creating temporary files..."
 #: ../raster/r.stream.extract/main.c:345
 #, fuzzy
 msgid "Unable to load input raster map(s)"
-msgstr "Não consegui fechar mapa raster de entrada"
+msgstr "Não consegui fechar mapa raster de entrada"
 #: ../raster/r.stream.extract/main.c:347
 #, fuzzy
 msgid "No non-NULL cells in input raster map(s)"
 #: ../raster/r.stream.extract/main.c:398
 #, fuzzy
 msgid "Unable to initialize search"
-msgstr "Não consegui fechar o mapa"
+msgstr "Não consegui fechar o mapa"
 #: ../raster/r.stream.extract/main.c:402
 #, fuzzy
 msgid "Unable to sort elevation raster map values"
-msgstr "Não consegui criar mapa raster <%s>"
+msgstr "Não consegui criar mapa raster <%s>"
 #: ../raster/r.stream.extract/main.c:408
 #, fuzzy
 msgid "Unable to calculate flow accumulation"
-msgstr "Calculando direções do fluxo..."
+msgstr "Calculando direções do fluxo..."
 #: ../raster/r.stream.extract/main.c:413
 #, fuzzy
 msgid "Unable to extract streams"
 #: ../raster/r.stream.extract/main.c:420
 #, fuzzy
 msgid "Unable to thin streams"
-msgstr "Não consegui abrir mapa raster [%s]."
+msgstr "Não consegui abrir mapa raster [%s]."
 #: ../raster/r.stream.extract/main.c:425
 #, fuzzy
@@ -15745,29 +15745,29 @@
 #: ../raster/r.stream.extract/main.c:431
 #, fuzzy
 msgid "Unable to write output raster maps"
 #: ../raster/r.stream.extract/bseg.c:19 ../raster/r.stream.extract/cseg.c:19
 #: ../raster/r.stream.extract/seg.c:19
 #, fuzzy
 msgid "Unable to create segment file"
 #: ../raster/r.stream.extract/bseg.c:32 ../raster/r.stream.extract/cseg.c:33
 #: ../raster/r.stream.extract/seg.c:37
 #, fuzzy
 msgid "Illegal configuration parameter(s)"
-msgstr "Nome ilegal do arquivo de saída"
+msgstr "Nome ilegal do arquivo de saída"
 #: ../raster/r.stream.extract/cseg.c:97
 #, fuzzy
 msgid "Unabel to read segment file"
 #: ../raster/r.stream.extract/cseg.c:120
 #, fuzzy, c-format
 msgid "Unable to segment put row %d for raster map <%s>"
 #: ../raster/r.stream.extract/del_streams.c:130
 #, c-format
@@ -15807,7 +15807,7 @@
 #: ../raster/r.stream.extract/streams.c:160
 #, fuzzy
 msgid "Calculating flow accumulation..."
 #: ../raster/r.stream.extract/streams.c:336
 #: ../raster/r.watershed/seg/do_cum.c:487
@@ -15839,7 +15839,7 @@
 #: ../raster/r.stream.extract/load.c:33
 #, fuzzy
 msgid "Loading elevation raster map..."
-msgstr "Mapa de elevação"
+msgstr "Mapa de elevação"
 #: ../raster/r.stream.extract/load.c:35
 #, fuzzy
@@ -15857,7 +15857,7 @@
 #: ../raster/r.stream.extract/seg.c:44
 #, fuzzy, c-format
 msgid "Unable to re-open file '%s'"
 #: ../raster/r.stream.extract/seg.c:84
 msgid "seg_put_row(): could not write segment file"
@@ -15867,12 +15867,12 @@
 #, fuzzy
 msgid ""
 "Traces a flow through an elevation model or cost surface on a raster map."
-msgstr "Traça um fluxo através de um modelo de elevação numa camada raster."
+msgstr "Traça um fluxo através de um modelo de elevação numa camada raster."
 #: ../raster/r.drain/main.c:116
 #, fuzzy
 msgid "Name of input elevation or cost surface raster map"
 #: ../raster/r.drain/main.c:121
 msgid "Name of input movement direction map associated with the cost surface"
@@ -15881,7 +15881,7 @@
 #: ../raster/r.drain/main.c:123 ../raster/r.drain/main.c:164
 #, fuzzy
 msgid "Cost surface"
 #: ../raster/r.drain/main.c:131
 #, fuzzy
@@ -15899,7 +15899,7 @@
 #: ../raster/r.drain/main.c:148
 msgid "Copy input cell values on output"
-msgstr "Copia valores da célula de entrada"
+msgstr "Copia valores da célula de entrada"
 #: ../raster/r.drain/main.c:152
 msgid "Accumulate input values along the path"
@@ -15912,7 +15912,7 @@
 #: ../raster/r.drain/main.c:157
 msgid "Count cell numbers along the path"
-msgstr "Conta número de células ao longo do caminho"
+msgstr "Conta número de células ao longo do caminho"
 #: ../raster/r.drain/main.c:163
 msgid ""
@@ -15944,25 +15944,25 @@
 #: ../raster/r.drain/main.c:209
 msgid "Specify just one of the -c, -a and -n flags"
-msgstr "Especificar apenas um dentre as opções -c, -a e -n"
+msgstr "Especificar apenas um dentre as opções -c, -a e -n"
 #: ../raster/r.drain/main.c:240
 #, c-format
 msgid "Starting point %d is outside the current region"
-msgstr "Ponto inicial %d está fora da região atual"
+msgstr "Ponto inicial %d está fora da região atual"
 #: ../raster/r.drain/main.c:315
 #, c-format
 msgid "Starting vector map <%s> contains no points in the current region"
-msgstr "Mapa vetorial inicial <%s> não contém pontos na região atual"
+msgstr "Mapa vetorial inicial <%s> não contém pontos na região atual"
 #: ../raster/r.drain/main.c:323
 msgid "No start/stop point(s) specified"
-msgstr "Nenhum ponto de início/fim especificado"
+msgstr "Nenhum ponto de início/fim especificado"
 #: ../raster/r.drain/main.c:398
 msgid "Calculating flow directions..."
 #: ../raster/r.drain/main.c:467
 #, fuzzy
@@ -15991,7 +15991,7 @@
 #: ../vector/v.random/main.c:589 ../vector/v.vol.rst/vector.c:80
 #, c-format
 msgid "Cannot insert new row: %s"
-msgstr "Não consegui inserir nova linha: %s"
+msgstr "Não consegui inserir nova linha: %s"
 #: ../raster/r.to.vect/points.c:36
 #, fuzzy
@@ -16001,7 +16001,7 @@
 #: ../raster/r.to.vect/main.c:79
 #, fuzzy
 msgid "vectorization"
-msgstr "Traçar elevação"
+msgstr "Traçar elevação"
 #: ../raster/r.to.vect/main.c:80
 #, fuzzy
@@ -16013,13 +16013,13 @@
 #: ../vector/v.mkgrid/main.c:136
 #, fuzzy
 msgid "Output feature type"
-msgstr "Tipo de feição"
+msgstr "Tipo de feição"
 #: ../raster/r.to.vect/main.c:94
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:11
 #, fuzzy
 msgid "Name of attribute column to store value"
-msgstr "Nome da coluna de atributo para usar como rótulos"
+msgstr "Nome da coluna de atributo para usar como rótulos"
 #: ../raster/r.to.vect/main.c:95
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:19
@@ -16036,7 +16036,7 @@
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:20
 msgid "Use raster values as categories instead of unique sequence (CELL only)"
 msgstr ""
-"Usa valores do raster como categorias em vez de uma seqüência única (apenas "
+"Usa valores do raster como categorias em vez de uma seqüência única (apenas "
 "CELL)"
 #: ../raster/r.to.vect/main.c:106 ../raster/r.to.vect/main.c:113
@@ -16049,7 +16049,7 @@
 #: ../vector/v.to.rast/main.c:94 ../vector/v.to.rast/main.c:100
 #, fuzzy
 msgid "Attributes"
-msgstr "Não criar tabela de atributo."
+msgstr "Não criar tabela de atributo."
 #: ../raster/r.to.vect/main.c:110
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:16
@@ -16062,19 +16062,19 @@
 #, fuzzy
 msgid "Table is not created. Currently supported only for points."
 msgstr ""
-"Escreve valores raster como coordenada z. Não cria tabela. Atualmente só "
+"Escreve valores raster como coordenada z. Não cria tabela. Atualmente só "
 "suporta pontos."
 #: ../raster/r.to.vect/main.c:117
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:18
 #, fuzzy
 msgid "Do not build vector topology"
-msgstr "Não criar topologia (topology) no modo de pontos"
+msgstr "Não criar topologia (topology) no modo de pontos"
 #: ../raster/r.to.vect/main.c:118
 #, fuzzy
 msgid "Recommended for massive point conversion"
-msgstr "Inportação de vetor incompleta"
+msgstr "Inportação de vetor incompleta"
 #: ../raster/r.to.vect/main.c:131
 #, fuzzy
@@ -16108,7 +16108,7 @@
 #: ../raster/r.to.vect/main.c:335
 #, fuzzy, c-format
 msgid "Unable to insert into table: %s"
-msgstr "Não consigo inserir na tabela: %s"
+msgstr "Não consigo inserir na tabela: %s"
 #: ../raster/r.to.vect/areas.c:122
 #, fuzzy
@@ -16188,8 +16188,8 @@
 "layers."
 msgstr ""
 "Gera camadas de mapa raster vermelha, verde e azul combinando valores de "
-"matiz (hue), intensidade e saturação (HIS) a partir das camadas de mapas "
-"raster de entrada fornecidas pelo usuário."
+"matiz (hue), intensidade e saturação (HIS) a partir das camadas de mapas "
+"raster de entrada fornecidas pelo usuário."
 #: ../raster/r.his/main.c:82 ../display/d.his/main.c:78
 #, fuzzy
@@ -16209,34 +16209,34 @@
 #: ../raster/r.his/main.c:103
 #, fuzzy
 msgid "Name of output layer to be used for red"
-msgstr "Nome da camada de saída a usar para VERMELHO"
+msgstr "Nome da camada de saída a usar para VERMELHO"
 #: ../raster/r.his/main.c:110
 #, fuzzy
 msgid "Name of output layer to be used for green"
 #: ../raster/r.his/main.c:117
 #, fuzzy
 msgid "Name of output layer to be used for blue"
 #: ../raster/r.his/main.c:121
 #: ../locale/scriptstrings/r.shade_to_translate.c:12
 #, fuzzy
 msgid "Color to use instead of NULL values"
-msgstr "Ignorar células com valores zero ao invés de células NULAS"
+msgstr "Ignorar células com valores zero ao invés de células NULAS"
 #: ../raster/r.his/main.c:126
 #: ../locale/scriptstrings/r.shade_to_translate.c:14
 #, fuzzy
 msgid "Use colors from color tables for NULL values"
-msgstr "Usar cor do texto a partir da cor da célula"
+msgstr "Usar cor do texto a partir da cor da célula"
 #: ../raster/r.his/main.c:145
 #, fuzzy, c-format
 msgid "No such color <%s>"
-msgstr "[%s]: cor não existe"
+msgstr "[%s]: cor não existe"
 #: ../raster/r.his/main.c:167 ../raster/r.his/main.c:183
 #: ../raster/r.his/main.c:201 ../raster/r.out.ppm3/main.c:115
@@ -16247,7 +16247,7 @@
 #: ../display/d.his/main.c:156 ../display/d.his/main.c:174
 #, c-format
 msgid "Color file for <%s> not available"
-msgstr "Arquivo de cores para <%s> não disponível"
+msgstr "Arquivo de cores para <%s> não disponível"
 #: ../raster/r.out.ascii/main.c:63
 #, fuzzy
@@ -16256,19 +16256,19 @@
 #: ../raster/r.out.ascii/main.c:72
 msgid "Name for output ASCII grid map (use out=- for stdout)"
-msgstr "Nome do mapa de grid ASCII de saída (use out=- para a saída padrão)"
+msgstr "Nome do mapa de grid ASCII de saída (use out=- para a saída padrão)"
 #: ../raster/r.out.ascii/main.c:86
 msgid ""
 "Number of values printed before wrapping a line (only SURFER or MODFLOW "
 "format)"
 msgstr ""
-"Número de valores impressos antes da quebra de linha (somente formatos "
+"Número de valores impressos antes da quebra de linha (somente formatos "
 "SURFER ou MODFLOW)"
 #: ../raster/r.out.ascii/main.c:91
 msgid "String to represent null cell (GRASS grid only)"
-msgstr "Texto para representar célula nula (apenas malha GRASS)"
+msgstr "Texto para representar célula nula (apenas malha GRASS)"
 #: ../raster/r.out.ascii/main.c:99
 msgid "Write SURFER (Golden Software) ASCII grid"
@@ -16280,7 +16280,7 @@
 #: ../raster/r.out.ascii/main.c:107
 msgid "Force output of integer values"
-msgstr "Forçar saída de valores inteiros"
+msgstr "Forçar saída de valores inteiros"
 #: ../raster/r.out.ascii/main.c:114
 msgid "Failed to interpret dp as an integer"
@@ -16296,12 +16296,12 @@
 #: ../raster/r.out.ascii/main.c:131
 msgid "Use -M or -s, not both"
-msgstr "Escolha -M ou -s, não ambos"
+msgstr "Escolha -M ou -s, não ambos"
 #: ../raster/r.out.ascii/main.c:166
 #, fuzzy, c-format
 msgid "Unable to read fp range for <%s>"
-msgstr "Não consegui ler intervalo fp para <%s>"
+msgstr "Não consegui ler intervalo fp para <%s>"
 #: ../raster/r.out.ascii/main.c:182
 #, c-format
@@ -16315,7 +16315,7 @@
 #: ../raster/r.latlong/main.c:58
 #, fuzzy
 msgid "longitude"
-msgstr "Problema na leitura da saída r.stats"
+msgstr "Problema na leitura da saída r.stats"
 #: ../raster/r.latlong/main.c:60
 #, fuzzy
@@ -16325,27 +16325,27 @@
 #: ../raster/r.latlong/main.c:66
 #, fuzzy
 msgid "Name for output latitude or longitude raster map"
-msgstr "Nome de uma camada de saída"
+msgstr "Nome de uma camada de saída"
 #: ../raster/r.latlong/main.c:70
 #, fuzzy
 msgid "Longitude output"
 #: ../raster/r.latlong/main.c:101 ../raster/r.sunmask/g_solposition.c:98
 #, fuzzy
 msgid "Unable to get projection info of current location"
 #: ../raster/r.latlong/main.c:103 ../raster/r.sunmask/g_solposition.c:101
 #, fuzzy
 msgid "Unable to get projection units of current location"
 #: ../raster/r.latlong/main.c:105 ../raster/r.sunmask/g_solposition.c:104
 #, fuzzy
 msgid "Unable to get projection key values of current location"
 #: ../raster/r.colors/edit_colors.c:61
 #, fuzzy
@@ -16405,7 +16405,7 @@
 #: ../vector/v.colors/main.c:148
 #, fuzzy
 msgid "Define"
-msgstr "Concluído."
+msgstr "Concluído."
 #: ../raster/r.colors/edit_colors.c:96
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:8
@@ -16447,7 +16447,7 @@
 #: ../vector/v.colors/main.c:122
 #, fuzzy
 msgid "Remove"
-msgstr "Removendo centróides duplicados ..."
+msgstr "Removendo centróides duplicados ..."
 #: ../raster/r.colors/edit_colors.c:121
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:16
@@ -16460,7 +16460,7 @@
 #: ../vector/v.colors/main.c:131
 #, fuzzy
 msgid "List available rules then exit"
-msgstr "Lista camadas disponíveis e finaliza"
+msgstr "Lista camadas disponíveis e finaliza"
 #: ../raster/r.colors/edit_colors.c:132
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:19
@@ -16489,12 +16489,12 @@
 #: ../raster/r.colors/edit_colors.c:186 ../raster/r.series.interp/main.c:180
 #, fuzzy, c-format
 msgid "Unable to open %s file <%s>"
-msgstr "Não consegui abrir o arquivo <%s>"
+msgstr "Não consegui abrir o arquivo <%s>"
 #: ../raster/r.colors/edit_colors.c:229 ../raster/r.colors/edit_colors.c:262
 #, c-format
 msgid "%s map <%s> not found"
-msgstr "%s mapa <%s> não encontrado"
+msgstr "%s mapa <%s> não encontrado"
 #: ../raster/r.colors/edit_colors.c:235
 #, fuzzy, c-format
@@ -16504,42 +16504,42 @@
 #: ../raster/r.colors/edit_colors.c:278
 #, fuzzy, c-format
 msgid "Unable to remove color table of %s map <%s>"
 #: ../raster/r.colors/edit_colors.c:280
 #, fuzzy, c-format
 msgid "Color table of %s map <%s> not found"
-msgstr "Arquivo de células [%s] não encontrado"
+msgstr "Arquivo de células [%s] não encontrado"
 #: ../raster/r.colors/edit_colors.c:302
 #, fuzzy, c-format
 msgid "Color table exists for %s map <%s>. Exiting."
 #: ../raster/r.colors/edit_colors.c:358
 #, fuzzy, c-format
 msgid "Color table 'random' is not supported for floating point %s map"
-msgstr "argumento val é necessário para mapas de ponto flutuante!"
+msgstr "argumento val é necessário para mapas de ponto flutuante!"
 #: ../raster/r.colors/edit_colors.c:362
 #, fuzzy, c-format
 msgid "Color table 'grey.eq' is not supported for floating point %s map"
 #: ../raster/r.colors/edit_colors.c:368
 #, fuzzy, c-format
 msgid "Color table 'grey.log' is not supported for floating point %s map"
 #: ../raster/r.colors/edit_colors.c:386 ../vector/v.colors/make_colors.c:51
 #, fuzzy, c-format
 msgid "Unable to load rules file <%s>"
-msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
+msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
 #: ../raster/r.colors/edit_colors.c:403 ../vector/v.colors/main.c:322
 #, fuzzy, c-format
 msgid "Unable to read color table for 3D raster map <%s>"
-msgstr "Não consegui criar mapa raster <%s>."
+msgstr "Não consegui criar mapa raster <%s>."
 #: ../raster/r.colors/edit_colors.c:447
 #, fuzzy, c-format
@@ -16573,19 +16573,19 @@
 #: ../raster/r.colors/rules.c:49
 #, fuzzy, c-format
 msgid "fp: Data range is %s to %s\n"
-msgstr "fp: intervalo de dados é %.25f a %.25f\n"
+msgstr "fp: intervalo de dados é %.25f a %.25f\n"
 #: ../raster/r.colors/rules.c:53
 #, c-format
 msgid "Data range is %ld to %ld\n"
-msgstr "O intervalo de dados é de %ld a %ld\n"
+msgstr "O intervalo de dados é de %ld a %ld\n"
 #: ../raster/r.colors/rules.c:64
 #, fuzzy, c-format
 msgid ""
 "Your color rules do not cover the whole range of data!\n"
 " (rules %f to %f but data %f to %f)"
-msgstr "Sua regra de core não contempla o conjunto completo dos dados!"
+msgstr "Sua regra de core não contempla o conjunto completo dos dados!"
 #: ../raster/r.colors/rules.c:104 ../raster/r.reclass/parse.c:41
 #, c-format
@@ -16610,7 +16610,7 @@
 #: ../raster/r.colors/rules.c:108
 #, c-format
 msgid " default color\n"
-msgstr " cor padrão\n"
+msgstr " cor padrão\n"
 #: ../raster/r.colors/rules.c:109
 #, c-format
@@ -16625,7 +16625,7 @@
 #: ../raster/r.colors/rules.c:132
 #, fuzzy, c-format
 msgid "bad rule (%s); rule not added"
-msgstr "** a regra não foi adicionada **\n"
+msgstr "** a regra não foi adicionada **\n"
 #: ../raster/r.colors/rules.c:134
 #, c-format
@@ -16638,7 +16638,7 @@
 "Creates a raster map from an assemblage of many coordinates using univariate "
 "statistics."
 msgstr ""
-"Cria mapas raster a partir de arquivos de dados de polígono/linha/ponto."
+"Cria mapas raster a partir de arquivos de dados de polígono/linha/ponto."
 #: ../raster/r.in.xyz/main.c:171
 #, fuzzy
@@ -16650,7 +16650,7 @@
 #, fuzzy
 msgid "Column number of x coordinates in input file (first column is 1)"
 msgstr ""
-"Número da coluna usada como coordenada x (primeira coluna é 1) para o modo "
+"Número da coluna usada como coordenada x (primeira coluna é 1) para o modo "
 "de pontos"
 #: ../raster/r.in.xyz/main.c:233
@@ -16673,8 +16673,8 @@
 #, fuzzy
 msgid "Number of header lines to skip at top of input file"
 msgstr ""
-"Número de linhas do cabeçalho para pular no começo do arquivo de entrada "
-"(escritas no histórico do mapa)"
+"Número de linhas do cabeçalho para pular no começo do arquivo de entrada "
+"(escritas no histórico do mapa)"
 #: ../raster/r.in.xyz/main.c:262 ../vector/v.decimate/main.c:146
 #: ../vector/v.in.lidar/main.c:194
@@ -16696,7 +16696,7 @@
 #, fuzzy
 msgid "Alternate column number of data values in input file"
 msgstr ""
 "de pontos"
 #: ../raster/r.in.xyz/main.c:279
@@ -16720,17 +16720,17 @@
 #: ../raster/r.in.xyz/main.c:357
 #, fuzzy
 msgid "Please specify a reasonable column number."
 #: ../raster/r.in.xyz/main.c:369 ../vector/v.in.ascii/main.c:218
 #, fuzzy
 msgid "Please specify reasonable number of lines to skip"
-msgstr "Especifique um número razoável de linhas para saltar"
+msgstr "Especifique um número razoável de linhas para saltar"
 #: ../raster/r.in.xyz/main.c:388
 #, fuzzy
 msgid "Invalid vrange"
 #: ../raster/r.in.xyz/main.c:527
 #, c-format
@@ -16784,7 +16784,7 @@
 #: ../raster/r.in.xyz/main.c:773 ../raster/r.in.xyz/main.c:1284
 #, fuzzy, c-format
 msgid "Bad data value line %lu column %d. <%s>"
-msgstr "Não consegui encontrar [%s]."
+msgstr "Não consegui encontrar [%s]."
 #: ../raster/r.in.xyz/main.c:829
 #, fuzzy
@@ -16794,7 +16794,7 @@
 #: ../raster/r.in.xyz/main.c:1169
 #, fuzzy, c-format
 msgid "%lu points found in region."
-msgstr "%d pontos fora da região atual."
+msgstr "%d pontos fora da região atual."
 #: ../raster/r.random/main.c:56
 #, fuzzy
@@ -16802,7 +16802,7 @@
 "Creates a raster map layer and vector point map containing randomly located "
 "points."
 msgstr ""
-"Cria um mapa raster e um mapa vetorial de pontos contendo locais aleatórios"
+"Cria um mapa raster e um mapa vetorial de pontos contendo locais aleatórios"
 #: ../raster/r.random/main.c:65
 msgid "Name of cover raster map"
@@ -16810,16 +16810,16 @@
 #: ../raster/r.random/main.c:72
 msgid "The number of points to allocate"
-msgstr "Número de pontos a alocar"
+msgstr "Número de pontos a alocar"
 #: ../raster/r.random/main.c:84
 #, fuzzy
 msgid "Generate points also for NULL category"
-msgstr "Também gerar pontos para categoria zero"
+msgstr "Também gerar pontos para categoria zero"
 #: ../raster/r.random/main.c:89
 msgid "Report information about input raster and exit"
 #: ../raster/r.random/main.c:93
 msgid "Generate vector points as 3D points"
@@ -16827,7 +16827,7 @@
 #: ../raster/r.random/main.c:96 ../vector/v.in.ascii/main.c:193
 msgid "Do not build topology in points mode"
 #: ../raster/r.random/main.c:97 ../display/d.linegraph/main.c:330
 #: ../display/d.linegraph/main.c:339 ../display/d.linegraph/main.c:348
@@ -16851,30 +16851,30 @@
 #: ../raster/r.random/main.c:141
 #, fuzzy, c-format
 msgid "<%s=%s> invalid percentage"
-msgstr "<%s=%s> ** entrada inválida **"
+msgstr "<%s=%s> ** entrada inválida **"
 #: ../raster/r.random/main.c:148
 #, fuzzy, c-format
 msgid "<%s=%s> invalid number of points"
-msgstr "%s=%s - número de pontos de interpolação ilegal"
+msgstr "%s=%s - número de pontos de interpolação ilegal"
 #: ../raster/r.random/main.c:161
 #, fuzzy, c-format
 msgid "There aren't [%ld] cells in the current region"
-msgstr "Mostra a região atual"
+msgstr "Mostra a região atual"
 #: ../raster/r.random/main.c:164
 #, fuzzy, c-format
 msgid "There aren't [%ld] non-NULL cells in the current region"
 #: ../raster/r.random/main.c:169
 msgid "There are no valid locations in the current region"
-msgstr "Não existem locações válidas na região atual"
+msgstr "Não existem locações válidas na região atual"
 #: ../raster/r.random/count.c:68
 msgid "Collecting Stats..."
-msgstr "Coletando estatísticas..."
+msgstr "Coletando estatísticas..."
 #: ../raster/r.random/count.c:123
 msgid "Programmer error in get_stats/switch"
@@ -16882,7 +16882,7 @@
 #: ../raster/r.random/random.c:100
 msgid "Cannot create new table"
-msgstr "Não consegui criar nova tabela"
+msgstr "Não consegui criar nova tabela"
 #: ../raster/r.random/random.c:110
 #, fuzzy, c-format
@@ -16906,7 +16906,7 @@
 #: ../vector/v.net.components/main.c:39
 #, fuzzy, c-format
 msgid "Cannot insert new record: %s"
 #: ../raster/r.random/random.c:243
 #, fuzzy, c-format
@@ -16922,7 +16922,7 @@
 #, fuzzy
 msgid ""
 "Vect runs out of region and re-enters - this case is not yet implemented."
-msgstr "de é não."
+msgstr "de é não."
 #: ../raster/r.carve/main.c:76
 msgid "Generates stream channels."
@@ -16948,7 +16948,7 @@
 #: ../raster/r.carve/main.c:95
 #, fuzzy
 msgid "Name for output vector map for adjusted stream points"
-msgstr "Nome do mapa de pontos de saída"
+msgstr "Nome do mapa de pontos de saída"
 #: ../raster/r.carve/main.c:100
 #, fuzzy
@@ -16967,17 +16967,17 @@
 #: ../raster/r.carve/main.c:110
 #, fuzzy
 msgid "No flat areas allowed in flow direction"
-msgstr "Não em"
+msgstr "Não em"
 #: ../raster/r.carve/main.c:134
 #, fuzzy, c-format
 msgid "Invalid width value '%s' - using default."
-msgstr "inválido largura padrão."
+msgstr "inválido largura padrão."
 #: ../raster/r.carve/main.c:148
 #, fuzzy, c-format
 msgid "Invalid depth value '%s' - using default."
-msgstr "inválido profundidade padrão."
+msgstr "inválido profundidade padrão."
 #: ../raster/r.carve/raster.c:33 ../raster/r.in.poly/poly2rast.c:81
 #: ../vector/v.to.rast/vect2rast.c:179
@@ -16997,24 +16997,24 @@
 #: ../raster/r.in.bin/main.c:260
 #, fuzzy
 msgid "Import a binary raster file into a GRASS raster map layer."
-msgstr "Importar um arquivo raster binário para uma camada raster do GRASS."
+msgstr "Importar um arquivo raster binário para uma camada raster do GRASS."
 #: ../raster/r.in.bin/main.c:265
 msgid "Import as floating-point data (default: integer)"
-msgstr "Importar como dado decimal (padrão: inteiro)"
+msgstr "Importar como dado decimal (padrão: inteiro)"
 #: ../raster/r.in.bin/main.c:270
 msgid "Import as double-precision floating-point data (default: integer)"
-msgstr "Importar como dado decimal 'double precision' (padrão: inteiro)"
+msgstr "Importar como dado decimal 'double precision' (padrão: inteiro)"
 #: ../raster/r.in.bin/main.c:279
 #, fuzzy
 msgid "Byte swap the data during import"
-msgstr "Alternar bytes na importação (byte swap)"
+msgstr "Alternar bytes na importação (byte swap)"
 #: ../raster/r.in.bin/main.c:284
 msgid "Get region info from GMT style header"
-msgstr "Adotar região de um cabeçalho estilo GMT"
+msgstr "Adotar região de um cabeçalho estilo GMT"
 #: ../raster/r.in.bin/main.c:288
 #, fuzzy
@@ -17027,12 +17027,12 @@
 #: ../raster/r.in.bin/main.c:305 ../raster/r.out.bin/main.c:311
 msgid "Number of bytes per cell"
-msgstr "Número de bytes por célula"
+msgstr "Número de bytes por célula"
 #: ../raster/r.in.bin/main.c:313
 #, fuzzy
 msgid "Header size in bytes"
-msgstr "Arquivo de cabeçalho = %s"
+msgstr "Arquivo de cabeçalho = %s"
 #: ../raster/r.in.bin/main.c:321
 #, fuzzy
@@ -17046,7 +17046,7 @@
 #: ../raster/r.in.bin/main.c:392
 #, fuzzy
 msgid "Flip input horizontal and/or vertical"
-msgstr "Permitir apenas fluxo horizontal e vertical de água"
+msgstr "Permitir apenas fluxo horizontal e vertical de água"
 #: ../raster/r.in.bin/main.c:395
 msgid "Flip input horizontal (East - West)"
@@ -17059,23 +17059,23 @@
 #: ../raster/r.in.bin/main.c:410
 #, fuzzy, c-format
 msgid "Option %s must be > 0"
-msgstr "Locação: %s\n"
+msgstr "Locação: %s\n"
 #: ../raster/r.in.bin/main.c:413
 #, fuzzy, c-format
 msgid "Option %s must be >= 0"
 #: ../raster/r.in.bin/main.c:435 ../raster/r.in.bin/main.c:438
 #, fuzzy, c-format
 msgid "Option %s= is ignored if -%c is set"
 #: ../raster/r.in.bin/main.c:462 ../raster/r.out.bin/main.c:379
 #: ../vector/v.colors/main.c:225
 #, fuzzy, c-format
 msgid "-%c and -%c are mutually exclusive"
-msgstr "Opções -B e -C são mutuamente exclusivas. Escolha apenas uma."
+msgstr "Opções -B e -C são mutuamente exclusivas. Escolha apenas uma."
 #: ../raster/r.in.bin/main.c:467
 #, c-format
@@ -17110,7 +17110,7 @@
 #: ../raster/r.in.bin/main.c:512
 #, fuzzy, c-format
 msgid "Either all or none of %s=, %s=, %s= and %s= must be given"
-msgstr "Ou forneça north=, south=, east= e west= ou não forneça nenhuma"
+msgstr "Ou forneça north=, south=, east= e west= ou não forneça nenhuma"
 #: ../raster/r.in.bin/main.c:554
 #, c-format
@@ -17143,7 +17143,7 @@
 #: ../raster/r.external/main.c:61
 #, fuzzy
 msgid "Links GDAL supported raster data as a pseudo GRASS raster map."
-msgstr "Importar raster suportado pela GDAL para uma camada raster binária."
+msgstr "Importar raster suportado pela GDAL para uma camada raster binária."
 #: ../raster/r.external/main.c:64
 #, fuzzy
@@ -17157,7 +17157,7 @@
 #: ../raster/r.external/main.c:82
 msgid "Band to select (default is all bands)"
-msgstr "Banda selecionada (o padrão são todas as bandas)"
+msgstr "Banda selecionada (o padrão são todas as bandas)"
 #: ../raster/r.external/main.c:95 ../raster/r.external.out/main.c:271
 #: ../raster/r.in.gdal/main.c:197 ../vector/v.external/args.c:49
@@ -17169,7 +17169,7 @@
 #: ../vector/v.in.lidar/main.c:300 ../vector/v.in.ogr/main.c:303
 #, fuzzy
 msgid "Extend region extents based on new dataset"
-msgstr "Estender locação baseado no novo conjunto de dados"
+msgstr "Estender locação baseado no novo conjunto de dados"
 #: ../raster/r.external/main.c:109 ../raster/r.in.gdal/main.c:193
 #: ../vector/v.in.ogr/main.c:305
@@ -17187,7 +17187,7 @@
 #: ../raster/r.external/main.c:122
 #, fuzzy
 msgid "List available bands including band type in dataset and exit"
-msgstr "Lista camadas disponíveis na fonte dos dados e finaliza"
+msgstr "Lista camadas disponíveis na fonte dos dados e finaliza"
 #: ../raster/r.external/main.c:123
 msgid "Format: band number,type,projection check"
@@ -17201,16 +17201,16 @@
 #: ../raster/r.external/main.c:166 ../display/d.mon/start.c:86
 #, fuzzy
 msgid "Unable to get current working directory"
-msgstr "Não consegui atualizar região atual"
+msgstr "Não consegui atualizar região atual"
 #: ../raster/r.external/main.c:198
 msgid "Proceeding with import..."
-msgstr "Seguindo com a importação..."
+msgstr "Seguindo com a importação..."
 #: ../raster/r.external/main.c:202
 #, fuzzy, c-format
 msgid "Imagery group <%s> already exists and will be overwritten."
-msgstr "O vetor '%s' já existe."
+msgstr "O vetor '%s' já existe."
 #: ../raster/r.external/main.c:209
 #, fuzzy, c-format
@@ -17220,36 +17220,36 @@
 #: ../raster/r.external/main.c:214 ../raster/r.in.gdal/main.c:609
 #, c-format
 msgid "Selected band (%d) does not exist"
-msgstr "Banda selecionada (%d) não existe"
+msgstr "Banda selecionada (%d) não existe"
 #: ../raster/r.external/main.c:246
 #, fuzzy, c-format
 msgid "Imagery group <%s> created"
 #: ../raster/r.external/proj.c:18 ../raster/r.in.gdal/main.c:451
 msgid ""
 "Unable to convert input raster map projection information to GRASS format "
 "for checking"
 msgstr ""
-"Não consegui converter a projeção do mapa raster de entrada para o formato "
-"do GRASS para verificação"
+"Não consegui converter a projeção do mapa raster de entrada para o formato "
+"do GRASS para verificação"
 #: ../raster/r.external/proj.c:47 ../raster/r.in.gdal/main.c:484
 msgid "Location PROJ_INFO is:\n"
-msgstr "Locação PROJ_INFO é:\n"
+msgstr "Locação PROJ_INFO é:\n"
 #: ../raster/r.external/proj.c:58 ../raster/r.in.gdal/main.c:495
 msgid "Dataset PROJ_INFO is:\n"
-msgstr "PROJ_INFO do conjunto de dados é:\n"
+msgstr "PROJ_INFO do conjunto de dados é:\n"
 #: ../raster/r.external/proj.c:111 ../raster/r.in.gdal/main.c:553
 msgid ""
 "Consider generating a new location from the input dataset using the "
 "'location' parameter.\n"
 msgstr ""
-"Considere gerar uma nova locação a partir do conjunto de dados de entrada "
-"usando o parâmetro 'location'.\n"
+"Considere gerar uma nova locação a partir do conjunto de dados de entrada "
+"usando o parâmetro 'location'.\n"
 #: ../raster/r.external/window.c:23
 msgid ""
@@ -17269,7 +17269,7 @@
 #: ../vector/v.in.ogr/main.c:1725
 #, fuzzy
 msgid "Default region for this location updated"
-msgstr "não."
+msgstr "não."
 #: ../raster/r.external/window.c:96 ../raster/r.in.gdal/main.c:895
 #: ../vector/v.in.ogr/main.c:1728
@@ -17280,7 +17280,7 @@
 #: ../raster/r.external/link.c:48
 #, fuzzy
 msgid "Complex types not supported"
-msgstr "Tipo de coluna não suportado"
+msgstr "Tipo de coluna não suportado"
 #: ../raster/r.external/link.c:63
 #, fuzzy, c-format
@@ -17300,17 +17300,17 @@
 #: ../raster/r.external/link.c:101
 #, fuzzy, c-format
 msgid "Unable to create cell/%s file"
 #: ../raster/r.external/link.c:110
 #, fuzzy, c-format
 msgid "Unable to create fcell/%s file"
-msgstr "Não consegui criar face"
+msgstr "Não consegui criar face"
 #: ../raster/r.external/link.c:146
 #, fuzzy, c-format
 msgid "Unable to create cell_misc/%s/gdal file"
-msgstr "Não consegui escrever o arquivo temporário."
+msgstr "Não consegui escrever o arquivo temporário."
 #: ../raster/r.external/link.c:149
 #, fuzzy, c-format
@@ -17320,7 +17320,7 @@
 #: ../raster/r.external/link.c:174
 #, fuzzy, c-format
 msgid "Unable to create cell_misc/%s/f_format file"
 #: ../raster/r.external/link.c:177
 #, fuzzy, c-format
@@ -17335,14 +17335,14 @@
 #: ../raster/r.external/link.c:236
 #, fuzzy, c-format
 msgid "Link to raster map <%s> created."
 #: ../raster/r.contour/cont.c:82
 #, fuzzy, c-format
 msgid "Writing vector contour (one level)..."
 msgid_plural "Writing vector contours (total levels %d)..."
-msgstr[0] "Escrevendo contornos de vetores (%d níveis no total)..."
-msgstr[1] "Escrevendo contornos de vetores (%d níveis no total)..."
+msgstr[0] "Escrevendo contornos de vetores (%d níveis no total)..."
+msgstr[1] "Escrevendo contornos de vetores (%d níveis no total)..."
 #: ../raster/r.contour/cont.c:213
 #, fuzzy, c-format
@@ -17353,11 +17353,11 @@
 #: ../raster/r.contour/cont.c:266
 msgid "Illegal edge number"
-msgstr "Número ilegal de arestas"
+msgstr "Número ilegal de arestas"
 #: ../raster/r.contour/cont.c:374
 msgid "Edge number out of range"
-msgstr "Número de arestas fora do intervalo"
+msgstr "Número de arestas fora do intervalo"
 #: ../raster/r.contour/main.c:89
 #, fuzzy
@@ -17373,33 +17373,33 @@
 #: ../raster/r.contour/main.c:101
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:10
 msgid "Increment between contour levels"
-msgstr "Incremento entre curvas de nível"
+msgstr "Incremento entre curvas de nível"
 #: ../raster/r.contour/main.c:102 ../raster/r.contour/main.c:110
 #: ../raster/r.contour/main.c:117 ../raster/r.contour/main.c:124
 #, fuzzy
 msgid "Contour levels"
-msgstr "Lista de curvas de nível"
+msgstr "Lista de curvas de nível"
 #: ../raster/r.contour/main.c:109
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:11
 msgid "List of contour levels"
 #: ../raster/r.contour/main.c:116
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:12
 msgid "Minimum contour level"
-msgstr "Curva de nível mínima"
+msgstr "Curva de nível mínima"
 #: ../raster/r.contour/main.c:123
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:13
 msgid "Maximum contour level"
-msgstr "Curva de nível máxima"
+msgstr "Curva de nível máxima"
 #: ../raster/r.contour/main.c:132
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:14
 msgid "Minimum number of points for a contour line (0 -> no limit)"
-msgstr "Número mínimo de pontos para uma curva de nível (0 -> sem limite)"
+msgstr "Número mínimo de pontos para uma curva de nível (0 -> sem limite)"
 #: ../raster/r.contour/main.c:140
 #, fuzzy, c-format
@@ -17428,7 +17428,7 @@
 #: ../raster/r.contour/main.c:293 ../raster/r.contour/main.c:296
 msgid "This step value is not allowed"
-msgstr "Este valor de passo não é permitido"
+msgstr "Este valor de passo não é permitido"
 #: ../raster/r.contour/main.c:321
 #, c-format
@@ -17443,7 +17443,7 @@
 #: ../raster/r.out.bin/main.c:139
 #, c-format
 msgid "Header File = %s"
 #: ../raster/r.out.bin/main.c:223
 #, c-format
@@ -17452,31 +17452,31 @@
 #: ../raster/r.out.bin/main.c:281
 msgid "Exports a GRASS raster to a binary array."
-msgstr "Exporta um raster do GRASS para um arquivo binário"
+msgstr "Exporta um raster do GRASS para um arquivo binário"
 #: ../raster/r.out.bin/main.c:297
 msgid "Name for output binary map (use output=- for stdout)"
-msgstr "Nome do mapa binário de saída (use 'out=-' para saída padrão)"
+msgstr "Nome do mapa binário de saída (use 'out=-' para saída padrão)"
 #: ../raster/r.out.bin/main.c:323
 msgid "Generate integer output"
-msgstr "Gera saída inteira"
+msgstr "Gera saída inteira"
 #: ../raster/r.out.bin/main.c:327
 msgid "Generate floating-point output"
-msgstr "Gera saída de ponto flutuante"
+msgstr "Gera saída de ponto flutuante"
 #: ../raster/r.out.bin/main.c:331
 msgid "Export array with GMT compatible header"
-msgstr "Exportar array com cabeçalho compatível com GMT"
+msgstr "Exportar array com cabeçalho compatível com GMT"
 #: ../raster/r.out.bin/main.c:335
 msgid "Generate BIL world and header files"
-msgstr "Gera arquivos BIL de cabeçalho e globais"
+msgstr "Gera arquivos BIL de cabeçalho e globais"
 #: ../raster/r.out.bin/main.c:339
 msgid "Byte swap output"
-msgstr "Saída com permuta de bytes (byte swap)"
+msgstr "Saída com permuta de bytes (byte swap)"
 #: ../raster/r.out.bin/main.c:399
 #, c-format
@@ -17529,12 +17529,12 @@
 "Outputs a covariance/correlation matrix for user-specified raster map "
 "layer(s)."
 msgstr ""
-"Calcula uma matriz de covariancia/correlação para as camadas do mapa raster "
-"especificadas pelo usuário."
+"Calcula uma matriz de covariancia/correlação para as camadas do mapa raster "
+"especificadas pelo usuário."
 #: ../raster/r.covar/main.c:61
 msgid "Print correlation matrix"
-msgstr "Mostra matriz de correlação"
+msgstr "Mostra matriz de correlação"
 #: ../raster/r.covar/main.c:86
 #, fuzzy, c-format
@@ -17544,38 +17544,38 @@
 #: ../raster/r.topmodel/file_io.c:56
 #, fuzzy, c-format
 msgid "%s cannot be 0"
-msgstr "Não consegui abrir o arquivo %s"
+msgstr "Não consegui abrir o arquivo %s"
 #: ../raster/r.topmodel/file_io.c:209 ../raster/r.topmodel/topmodel.c:75
 #: ../vector/v.out.pov/main.c:104
 #, fuzzy, c-format
 msgid "Unable to create output file <%s>"
 #: ../raster/r.topmodel/main.c:55
 msgid "Simulates TOPMODEL which is a physically based hydrologic model."
-msgstr "Simula TOPMODEL, que é um modelo hidrológico fisicamente baseado."
+msgstr "Simula TOPMODEL, que é um modelo hidrológico fisicamente baseado."
 #: ../raster/r.topmodel/main.c:60
 #, fuzzy
 msgid "Name of input TOPMODEL parameters file"
-msgstr "(i)   Arquivo de parâmetros TOPMODEL"
+msgstr "(i)   Arquivo de parâmetros TOPMODEL"
 #: ../raster/r.topmodel/main.c:65
 #, fuzzy
 msgid "Name of input topographic index statistics file"
-msgstr "(o/i) Arquivo índice das estatísticas topográficas"
+msgstr "(o/i) Arquivo índice das estatísticas topográficas"
 #: ../raster/r.topmodel/main.c:69
 #, fuzzy
 msgid "Name of input rainfall and potential evapotranspiration data file"
-msgstr "(i)   Arquivo de dados de precipitação e evapotranspiração"
+msgstr "(i)   Arquivo de dados de precipitação e evapotranspiração"
 #: ../raster/r.topmodel/main.c:72
 #: ../locale/scriptstrings/d.out.file_to_translate.c:4
 #: ../general/g.list/main.c:114
 msgid "Name for output file"
-msgstr "Nome do arquivo de saída"
+msgstr "Nome do arquivo de saída"
 #: ../raster/r.topmodel/main.c:76
 msgid "Time step"
@@ -17584,22 +17584,22 @@
 #: ../raster/r.topmodel/main.c:77
 #, fuzzy
 msgid "Generate output for this time step"
-msgstr "Gera estatísticas para i.maxlik a partir de mapas raster."
+msgstr "Gera estatísticas para i.maxlik a partir de mapas raster."
 #: ../raster/r.topmodel/main.c:83
 #, fuzzy
 msgid "Topographic index class"
-msgstr "Mapa de índice topográfico [ln(a/tanB)]"
+msgstr "Mapa de índice topográfico [ln(a/tanB)]"
 #: ../raster/r.topmodel/main.c:85
 #, fuzzy
 msgid "Generate output for this topographic index class"
-msgstr "(i)   Número de classes de índice topográfico"
+msgstr "(i)   Número de classes de índice topográfico"
 #: ../raster/r.topmodel/main.c:92
 #, fuzzy
 msgid "Name of input topographic index raster map"
 #: ../raster/r.topmodel/main.c:94
 msgid ""
@@ -17615,7 +17615,7 @@
 #: ../raster/r.topmodel/main.c:100
 #, fuzzy
 msgid "Number of topographic index classes"
 #: ../raster/r.topmodel/main.c:102
 msgid "Used for generating outtopidxstats"
@@ -17624,7 +17624,7 @@
 #: ../raster/r.topmodel/main.c:111
 #, fuzzy
 msgid "Name for output topographic index statistics file"
 #: ../raster/r.topmodel/main.c:113
 msgid "Requires topidx and ntopidxclasses"
@@ -17648,22 +17648,22 @@
 #: ../raster/r.topmodel/infiltration.c:108
 #, fuzzy, c-format
 msgid "Maximum number of iterations exceeded at timestep %d"
-msgstr "Número máximo de iterações: %d\n"
+msgstr "Número máximo de iterações: %d\n"
 #: ../raster/r.topmodel/topmodel.c:30
 #, fuzzy, c-format
 msgid "Unable to run %s"
 #: ../raster/r.topmodel/topmodel.c:72
 #, fuzzy, c-format
 msgid "Invalid %s output"
-msgstr "Fonte inválida: %s"
+msgstr "Fonte inválida: %s"
 #: ../raster/r.param.scale/interface.c:55
 #, fuzzy
 msgid "geomorphology"
 #: ../raster/r.param.scale/interface.c:58
 msgid "landform"
@@ -17680,44 +17680,44 @@
 "Uses a multi-scale approach by taking fitting quadratic parameters to any "
 "size window (via least squares)."
 msgstr ""
-"Extrai parâmetros de terreno a partir de um DEM. Usa uma aproximação multi-"
-"escalar ao extrair parâmetros ajustados quadraticamente para janelas de "
-"qualquer tamanho (por mínimos quadrados)"
+"Extrai parâmetros de terreno a partir de um DEM. Usa uma aproximação multi-"
+"escalar ao extrair parâmetros ajustados quadraticamente para janelas de "
+"qualquer tamanho (por mínimos quadrados)"
 #: ../raster/r.param.scale/interface.c:78
 #, fuzzy
 msgid "Name for output raster map containing morphometric parameter"
-msgstr "Camada raster de saída contento parâmetros morfométricos"
+msgstr "Camada raster de saída contento parâmetros morfométricos"
 #: ../raster/r.param.scale/interface.c:82
 msgid "Slope tolerance that defines a 'flat' surface (degrees)"
-msgstr "Tolerância de inclinação que define uma superfície 'plana' (graus)"
+msgstr "Tolerância de inclinação que define uma superfície 'plana' (graus)"
 #: ../raster/r.param.scale/interface.c:89
 msgid "Curvature tolerance that defines 'planar' surface"
-msgstr "Tolerância de curvatura que define uma superfície 'planar'"
+msgstr "Tolerância de curvatura que define uma superfície 'planar'"
 #: ../raster/r.param.scale/interface.c:96
 #, fuzzy
 msgid "Size of processing window (odd number only)"
-msgstr "Tamanho da janela de processamento (número ímpar, máx: %i)"
+msgstr "Tamanho da janela de processamento (número ímpar, máx: %i)"
 #: ../raster/r.param.scale/interface.c:104
 msgid "Morphometric parameter in 'size' window to calculate"
-msgstr "Parâmetro morfométrico para calcular na janela de 'tamanho'"
+msgstr "Parâmetro morfométrico para calcular na janela de 'tamanho'"
 #: ../raster/r.param.scale/interface.c:112
 msgid "Exponent for distance weighting (0.0-4.0)"
-msgstr "Expoente para o peso da distância (0.0 - 0.4)"
+msgstr "Expoente para o peso da distância (0.0 - 0.4)"
 #: ../raster/r.param.scale/interface.c:124
 msgid "Constrain model through central window cell"
-msgstr "Restringir o modelo através da célula central da janela"
+msgstr "Restringir o modelo através da célula central da janela"
 #: ../raster/r.param.scale/interface.c:167
 #, fuzzy
 msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
 #: ../raster/r.param.scale/interface.c:175
 msgid "Inappropriate window size (too big or even)"
@@ -17726,7 +17726,7 @@
 #: ../raster/r.param.scale/main.c:42
 #, fuzzy
 msgid "Lat/Long locations are not supported by this module"
-msgstr "Tipo da coluna não suportado"
+msgstr "Tipo da coluna não suportado"
 #: ../raster/r.param.scale/process.c:75
 msgid "E-W and N-S grid resolutions are different. Taking average."
@@ -17739,22 +17739,22 @@
 "raster map to a new raster map (possibly with different resolution) using "
 "regularized spline with tension and smoothing."
 msgstr ""
-"Reinterpola e computa análise topográfica de um raster de entrada para um "
-"novo mapa raster (possivelmente com uma resolução diferente) usando uma "
-"spline regularizada com tensão e suavização."
+"Reinterpola e computa análise topográfica de um raster de entrada para um "
+"novo mapa raster (possivelmente com uma resolução diferente) usando uma "
+"spline regularizada com tensão e suavização."
 #: ../raster/r.resamp.rst/main.c:162
 msgid "Desired east-west resolution"
-msgstr "Resolução leste-oeste desejada"
+msgstr "Resolução leste-oeste desejada"
 #: ../raster/r.resamp.rst/main.c:168
 msgid "Desired north-south resolution"
-msgstr "Resolução norte-sul desejada"
+msgstr "Resolução norte-sul desejada"
 #: ../raster/r.resamp.rst/main.c:173
 #, fuzzy
 msgid "Name for output elevation raster map"
-msgstr "Nome do mapa raster de elevação"
+msgstr "Nome do mapa raster de elevação"
 #: ../raster/r.resamp.rst/main.c:179
 #, fuzzy
@@ -17764,7 +17764,7 @@
 #: ../raster/r.resamp.rst/main.c:185
 #, fuzzy
 msgid "Name for output aspect map (or fy)"
 #: ../raster/r.resamp.rst/main.c:191
 #, fuzzy
@@ -17779,12 +17779,12 @@
 #: ../raster/r.resamp.rst/main.c:203
 #, fuzzy
 msgid "Name for output mean curvature map (or fxy)"
-msgstr "Gera arquivo raster com a curvatura média"
+msgstr "Gera arquivo raster com a curvatura média"
 #: ../raster/r.resamp.rst/main.c:209
 #, fuzzy
 msgid "Name of input raster map containing smoothing"
-msgstr "Nome do arquivo de célula contendo a suavização"
+msgstr "Nome do arquivo de célula contendo a suavização"
 #: ../raster/r.resamp.rst/main.c:215
 #, fuzzy
@@ -17793,7 +17793,7 @@
 #: ../raster/r.resamp.rst/main.c:223
 msgid "Rows/columns overlap for segmentation"
-msgstr "Sobreposição de linhas e colunas para segmentação"
+msgstr "Sobreposição de linhas e colunas para segmentação"
 #: ../raster/r.resamp.rst/main.c:231
 #, fuzzy
@@ -17802,12 +17802,12 @@
 #: ../raster/r.resamp.rst/main.c:239
 msgid "Spline tension value"
-msgstr "Valor de tensão da spine"
+msgstr "Valor de tensão da spine"
 #: ../raster/r.resamp.rst/main.c:246 ../vector/v.surf.rst/main.c:325
 #, fuzzy
 msgid "Anisotropy angle (in degrees counterclockwise from East)"
-msgstr "Ângulo de anisotropia (em graus anti-horários a partir do leste)"
+msgstr "Ângulo de anisotropia (em graus anti-horários a partir do leste)"
 #: ../raster/r.resamp.rst/main.c:247 ../raster/r.resamp.rst/main.c:254
 #, fuzzy
@@ -17820,7 +17820,7 @@
 #: ../raster/r.resamp.rst/main.c:258
 msgid "Use dnorm independent tension"
-msgstr "Usar tensão independente de dnorm"
+msgstr "Usar tensão independente de dnorm"
 #: ../raster/r.resamp.rst/main.c:263 ../vector/v.surf.rst/main.c:165
 #, fuzzy
@@ -17830,32 +17830,32 @@
 #: ../raster/r.resamp.rst/main.c:297
 #, fuzzy
 msgid "Unable to read ew_res value"
-msgstr "Não consegui criar árvore"
+msgstr "Não consegui criar árvore"
 #: ../raster/r.resamp.rst/main.c:300
 #, fuzzy
 msgid "Unable to read ns_res value"
 #: ../raster/r.resamp.rst/main.c:303
 #, fuzzy
 msgid "Invalid value for tension"
-msgstr "Valor inválido para null (apenas inteiros)"
+msgstr "Valor inválido para null (apenas inteiros)"
 #: ../raster/r.resamp.rst/main.c:306
 #, fuzzy
 msgid "Invalid value for zmult"
 #: ../raster/r.resamp.rst/main.c:309
 #, fuzzy
 msgid "Invalid value for overlap"
 #: ../raster/r.resamp.rst/main.c:313
 #, fuzzy
 msgid "Invalid value for theta"
 #: ../raster/r.resamp.rst/main.c:317
 #, fuzzy
@@ -17870,17 +17870,17 @@
 #: ../raster/r.resamp.rst/main.c:357
 #, fuzzy, c-format
 msgid "Map <%s> is the wrong resolution"
-msgstr "Mapa é"
+msgstr "Mapa é"
 #: ../raster/r.resamp.rst/main.c:365
 #, fuzzy
 msgid "Smoothing values can not be negative or NULL"
-msgstr "não"
+msgstr "não"
 #: ../raster/r.resamp.rst/main.c:371
 #, fuzzy
 msgid "Input map resolution differs from current region resolution!"
-msgstr "Resolução no perfil (padrão = resolução da região atual)"
+msgstr "Resolução no perfil (padrão = resolução da região atual)"
 #: ../raster/r.resamp.rst/main.c:387
 msgid "Processing all selected output files will require"
@@ -17889,29 +17889,29 @@
 #: ../raster/r.resamp.rst/main.c:391
 #, fuzzy, c-format
 msgid "%.2f GB of disk space for temp files."
-msgstr "Espaço em disco insuficiente -- não posso escrever arquivos"
+msgstr "Espaço em disco insuficiente -- não posso escrever arquivos"
 #: ../raster/r.resamp.rst/main.c:394
 #, fuzzy, c-format
 msgid "%.2f MB of disk space for temp files."
 #: ../raster/r.resamp.rst/main.c:397
 #, fuzzy, c-format
 msgid "%.2f KB of disk space for temp files."
 #: ../raster/r.resamp.rst/main.c:400
 #, fuzzy, c-format
 msgid "%d byte of disk space for temp files."
 msgid_plural "%d bytes of disk space for temp files."
-msgstr[0] "Espaço em disco insuficiente -- não posso escrever arquivos"
-msgstr[1] "Espaço em disco insuficiente -- não posso escrever arquivos"
+msgstr[0] "Espaço em disco insuficiente -- não posso escrever arquivos"
+msgstr[1] "Espaço em disco insuficiente -- não posso escrever arquivos"
 #: ../raster/r.resamp.rst/main.c:436
 #, fuzzy
 msgid "Maximum value of a raster map is NULL."
-msgstr "Máximo de célula é."
+msgstr "Máximo de célula é."
 #: ../raster/r.resamp.rst/main.c:464
 #, fuzzy
@@ -17940,17 +17940,17 @@
 #: ../raster/r.resamp.rst/main.c:515
 #, fuzzy
 msgid "Unable to write raster maps -- try increasing cell size"
-msgstr "Não consegui escrever arquivo de células -- tente aumentar a resolução"
+msgstr "Não consegui escrever arquivo de células -- tente aumentar a resolução"
 #: ../raster/r.resamp.filter/main.c:142
 #, fuzzy, c-format
 msgid "Filter <%s> not found"
-msgstr "raster <%s> não encontrado"
+msgstr "raster <%s> não encontrado"
 #: ../raster/r.resamp.filter/main.c:391
 #, fuzzy
 msgid "kernel filter"
 #: ../raster/r.resamp.filter/main.c:394
 #, fuzzy
@@ -17976,7 +17976,7 @@
 #: ../raster/r.resamp.filter/main.c:438 ../vector/v.external.out/args.c:90
 #, fuzzy, c-format
 msgid "%s= and %s=/%s= are mutually exclusive"
 #: ../raster/r.resamp.filter/main.c:443
 #, fuzzy, c-format
@@ -17986,7 +17986,7 @@
 #: ../raster/r.resamp.filter/main.c:446
 #, fuzzy, c-format
 msgid "Both %s= and %s= required"
 #: ../raster/r.resamp.filter/main.c:469
 msgid "Differing number of values for filter= and [xy_]radius="
@@ -17995,7 +17995,7 @@
 #: ../raster/r.resamp.filter/main.c:472
 #, fuzzy, c-format
 msgid "Too many filters (max: %d)"
-msgstr "** <%s> tem assinaturas demais (limite é 255)"
+msgstr "** <%s> tem assinaturas demais (limite é 255)"
 #: ../raster/r.resamp.filter/main.c:490
 #, fuzzy
@@ -18029,7 +18029,7 @@
 #: ../raster/r.basins.fill/main.c:74
 msgid "Number of passes through the dataset"
-msgstr "Número de passagens no conjunto de dados"
+msgstr "Número de passagens no conjunto de dados"
 #: ../raster/r.basins.fill/main.c:122
 #, fuzzy
@@ -18049,22 +18049,22 @@
 #: ../raster/r.reclass/reclass.c:216
 #, fuzzy, c-format
 msgid "Cannot read header file of <%s@%s>"
-msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
+msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
 #: ../raster/r.reclass/reclass.c:234
 #, fuzzy, c-format
 msgid "Cannot overwrite existing raster map <%s>"
 #: ../raster/r.reclass/reclass.c:239
 #, fuzzy, c-format
 msgid "Cannot create reclass file of <%s>"
 #: ../raster/r.reclass/reclass.c:247
 #, c-format
 msgid "Cannot create raster map <%s>"
 #: ../raster/r.reclass/parse.c:42
 msgid "poor quality"
@@ -18091,12 +18091,12 @@
 #: ../vector/v.reclass/main.c:68
 #, fuzzy
 msgid "reclassification"
-msgstr "Assinaturas para usar na classificação"
+msgstr "Assinaturas para usar na classificação"
 #: ../raster/r.reclass/main.c:52
 #, fuzzy
 msgid "Reclassify raster map based on category values."
-msgstr "Pesquisa valores e rótulos de categoria em camadas de mapa raster."
+msgstr "Pesquisa valores e rótulos de categoria em camadas de mapa raster."
 #: ../raster/r.reclass/main.c:54
 #, fuzzy
@@ -18104,8 +18104,8 @@
 "Creates a new raster map whose category values are based upon a "
 "reclassification of the categories in an existing raster map."
 msgstr ""
-"Cria um novo mapa cujas categorias são baseadas na reclassificação do "
-"usuário sobre as categorias de um mapa raster existente."
+"Cria um novo mapa cujas categorias são baseadas na reclassificação do "
+"usuário sobre as categorias de um mapa raster existente."
 #: ../raster/r.reclass/main.c:59
 #, fuzzy
@@ -18115,23 +18115,23 @@
 #: ../raster/r.reclass/main.c:65
 #, fuzzy
 msgid "File containing reclass rules"
-msgstr "Arquivo contém assinaturas resultantes"
+msgstr "Arquivo contém assinaturas resultantes"
 #: ../raster/r.reclass/main.c:72 ../raster/r.clump/main.c:75
 #: ../raster/r.recode/main.c:67 ../raster/r.neighbors/main.c:221
 #, fuzzy
 msgid "Title for output raster map"
-msgstr "Título do raster de saída"
+msgstr "Título do raster de saída"
 #: ../raster/r.reclass/main.c:83
 #, fuzzy
 msgid "Input map can NOT be the same as output map"
-msgstr "Entrada célula mapear"
+msgstr "Entrada célula mapear"
 #: ../raster/r.reclass/main.c:89
 #, fuzzy, c-format
 msgid "Cannot open rules file <%s>"
-msgstr "Não consegui abrir o arquivo [%s]"
+msgstr "Não consegui abrir o arquivo [%s]"
 #: ../raster/r.reclass/main.c:103
 #, fuzzy, c-format
@@ -18142,17 +18142,17 @@
 #: ../raster/r.reclass/main.c:105
 #, fuzzy, c-format
 msgid "FCELL: Data range is %.7g to %.7g\n"
 #: ../raster/r.reclass/main.c:108
 #, fuzzy, c-format
 msgid "DCELL: Data range is %.15g to %.15g\n"
 #: ../raster/r.reclass/main.c:111
 #, fuzzy, c-format
 msgid "CELL: Data range is %ld to %ld\n"
 #: ../raster/r.reclass/main.c:119
 #, fuzzy, c-format
@@ -18171,13 +18171,13 @@
 #: ../raster/r.reclass/main.c:139
 #, fuzzy, c-format
 msgid "No rules specified. Raster map <%s> not created"
 #: ../raster/r.reclass/main.c:142 ../raster/r.recode/main.c:99
 #: ../raster/r.quant/main.c:183
 #, fuzzy
 msgid "No rules specified"
-msgstr "Mapa(s) de entrada não especificado(s)."
+msgstr "Mapa(s) de entrada não especificado(s)."
 #: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
 #, fuzzy
@@ -18187,22 +18187,22 @@
 #: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
 #, fuzzy
 msgid "Unable to open output file"
 #: ../raster/r.out.mpeg/write.c:215
 #, fuzzy
 msgid "Unable to create temporary files."
 #: ../raster/r.out.mpeg/main.c:104
 #, fuzzy
 msgid "animation"
 #: ../raster/r.out.mpeg/main.c:107
 #, fuzzy
 msgid "Converts raster map series to MPEG movie."
-msgstr "Programa para conversão de uma série de arquivos para MPEG."
+msgstr "Programa para conversão de uma série de arquivos para MPEG."
 #: ../raster/r.out.mpeg/main.c:115
 #, fuzzy, c-format
@@ -18212,25 +18212,25 @@
 #: ../raster/r.out.mpeg/main.c:117
 #, fuzzy
 msgid "Views"
-msgstr "Concluído.\n"
+msgstr "Concluído.\n"
 #: ../raster/r.out.mpeg/main.c:131
 msgid "Quality factor (1 = highest quality, lowest compression)"
-msgstr "Qualidade (1 = alta qualidade, baixa compressão)"
+msgstr "Qualidade (1 = alta qualidade, baixa compressão)"
 #: ../raster/r.out.mpeg/main.c:136
 #, fuzzy
 msgid "Convert on the fly, uses less disk space"
 msgstr ""
-"Converter diretamente, usa menos espaço em disco\n"
-"\t(requer 'r.out.ppm' com a opção 'stdout')"
+"Converter diretamente, usa menos espaço em disco\n"
+"\t(requer 'r.out.ppm' com a opção 'stdout')"
 #: ../raster/r.out.mpeg/main.c:137
 #, fuzzy
 msgid "Requires r.out.ppm with stdout option"
 msgstr ""
 #: ../raster/r.out.mpeg/main.c:160
 #, fuzzy
@@ -18240,7 +18240,7 @@
 #: ../raster/r.out.mpeg/main.c:291
 #, fuzzy, c-format
 msgid "Unable to read color table for <%s>"
 #: ../raster/r.out.mpeg/main.c:341 ../raster/r.out.mpeg/main.c:374
 #, fuzzy
@@ -18265,17 +18265,17 @@
 #: ../raster/r.fill.dir/main.c:88
 #, fuzzy
 msgid "sink"
 #: ../raster/r.fill.dir/main.c:89
 #, fuzzy
 msgid "fill sinks"
 #: ../raster/r.fill.dir/main.c:90
 #, fuzzy
 msgid "depressions"
-msgstr "Valor dos padrões de bits"
+msgstr "Valor dos padrões de bits"
 #: ../raster/r.fill.dir/main.c:92
 #, fuzzy
@@ -18283,8 +18283,8 @@
 "Filters and generates a depressionless elevation map and a flow direction "
 "map from a given elevation raster map."
 msgstr ""
-"Filtra e gera um mapa de elevação sem depressões e uma direção de fluxo a "
-"partir de um mapa de elevação fornecido"
+"Filtra e gera um mapa de elevação sem depressões e uma direção de fluxo a "
+"partir de um mapa de elevação fornecido"
 #: ../raster/r.fill.dir/main.c:99
 #, fuzzy
@@ -18295,22 +18295,22 @@
 #, fuzzy
 msgid ""
 "Name for output flow direction map for depressionless elevation raster map"
-msgstr "(o)   Mapa de direção com mapa de elevação sem depressões"
+msgstr "(o)   Mapa de direção com mapa de elevação sem depressões"
 #: ../raster/r.fill.dir/main.c:108
 #, fuzzy
 msgid "Name for output raster map of problem areas"
-msgstr "Gera um mapa das áreas problemáticas"
+msgstr "Gera um mapa das áreas problemáticas"
 #: ../raster/r.fill.dir/main.c:115
 #, fuzzy
 msgid "Aspect direction format"
-msgstr "Gera uma mapa de direções"
+msgstr "Gera uma mapa de direções"
 #: ../raster/r.fill.dir/main.c:121
 #, fuzzy
 msgid "Find unresolved areas only"
-msgstr "Encontra apenas áreas não resolvidas"
+msgstr "Encontra apenas áreas não resolvidas"
 #: ../raster/r.fill.dir/main.c:127
 #, fuzzy, c-format
@@ -18324,7 +18324,7 @@
 #: ../raster/r.fill.dir/main.c:190
 #, fuzzy
 msgid "Reading input elevation raster map..."
 #: ../raster/r.fill.dir/main.c:200
 msgid "Filling sinks..."
@@ -18347,8 +18347,8 @@
 #, fuzzy, c-format
 msgid "Found %d unresolved area"
 msgid_plural "Found %d unresolved areas"
-msgstr[0] "Encontra apenas áreas não resolvidas"
-msgstr[1] "Encontra apenas áreas não resolvidas"
+msgstr[0] "Encontra apenas áreas não resolvidas"
+msgstr[1] "Encontra apenas áreas não resolvidas"
 #: ../raster/r.resamp.stats/main.c:261
 #, fuzzy
@@ -18372,38 +18372,38 @@
 #, fuzzy
 msgid "Outputs basic information about a raster map."
 msgstr ""
-"Imprime informações básicas sobre uma camada de mapa especificada pelo "
-"usuário."
+"Imprime informações básicas sobre uma camada de mapa especificada pelo "
+"usuário."
 #: ../raster/r.info/main.c:81
 #, fuzzy
 msgid "Print raster array information in shell script style"
-msgstr "Mostra as estatísticas em estilo shell script"
+msgstr "Mostra as estatísticas em estilo shell script"
 #: ../raster/r.info/main.c:85
 #, fuzzy
 msgid "Print range in shell script style"
 #: ../raster/r.info/main.c:89
 #, fuzzy
 msgid "Print extended metadata information in shell script style"
 #: ../raster/r.info/main.c:99
 #, fuzzy, c-format
 msgid "Flags -%c and -%c/%c/%c are mutually exclusive"
 #: ../raster/r.info/main.c:127
 #, fuzzy
 msgid "Unable to read range file"
 #: ../raster/r.compress/main.c:66
 #, fuzzy
 msgid "compression"
 #: ../raster/r.compress/main.c:67
 msgid "Compresses and decompresses raster maps."
@@ -18420,30 +18420,30 @@
 #: ../raster/r.compress/main.c:78
 #, fuzzy
 msgid "Print compression information and data type of input map(s)"
 #: ../raster/r.compress/main.c:120 ../raster/r.compress/main.c:300
 #, fuzzy, c-format
 msgid "Raster map <%s> is not in the current mapset"
-msgstr "mapa vetorial <%s> não encontrado"
+msgstr "mapa vetorial <%s> não encontrado"
 #: ../raster/r.compress/main.c:126
 #, fuzzy, c-format
 msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't uncompress"
 msgstr ""
-"[%s] é uma reclassificação de [%s em %s] - não é possível editar o cabeçalho!"
+"[%s] é uma reclassificação de [%s em %s] - não é possível editar o cabeçalho!"
 #: ../raster/r.compress/main.c:128
 #, fuzzy, c-format
 msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't compress"
 msgstr ""
 #: ../raster/r.compress/main.c:133
 #, fuzzy, c-format
 msgid "<%s> is a GDAL-linked map - can't (un)compress"
 msgstr ""
 #: ../raster/r.compress/main.c:207
 msgid "DONE: uncompressed file is %lu %s (%.2f%) smaller"
@@ -18464,39 +18464,39 @@
 #: ../raster/r.compress/main.c:216
 #, fuzzy
 msgid "same size"
-msgstr "Área\n"
+msgstr "Área\n"
 #: ../raster/r.compress/main.c:232
 #, fuzzy, c-format
 msgid "<%s> already uncompressed"
-msgstr "Área já concluída."
+msgstr "Área já concluída."
 #: ../raster/r.compress/main.c:235
 #, fuzzy, c-format
 msgid "Uncompressing <%s>"
 #: ../raster/r.compress/main.c:243
 #, fuzzy, c-format
 msgid "Re-compressing <%s>"
 #: ../raster/r.compress/main.c:246
 #, fuzzy, c-format
 msgid "Compressing <%s>"
 #: ../raster/r.compress/main.c:304
 #, fuzzy, c-format
 msgid "<%s> is a GDAL-linked map"
 msgstr ""
 #: ../raster/r.compress/main.c:308
 #, fuzzy, c-format
 msgid "<%s> is a reclass file of map <%s> in mapset <%s>"
 msgstr ""
 #: ../raster/r.compress/main.c:327
 #, c-format
@@ -18571,7 +18571,7 @@
 #: ../raster/r.solute.transport/main.c:125
 msgid "Top surface of the aquifer in [m]"
-msgstr "superfície de topo do aquífero em [m]"
+msgstr "superfície de topo do aquífero em [m]"
 #: ../raster/r.solute.transport/main.c:129
 #, fuzzy
@@ -18621,7 +18621,7 @@
 #: ../raster/r.solute.transport/main.c:231
 #, fuzzy
 msgid "solute transport"
 #: ../raster/r.solute.transport/main.c:233
 msgid ""
@@ -18650,7 +18650,7 @@
 #: ../raster/r.solute.transport/main.c:380
 #, fuzzy, c-format
 msgid "Number of inner loops is %g"
 #: ../raster/r.solute.transport/main.c:381
 #, c-format
@@ -18671,12 +18671,12 @@
 #: ../raster/r.solute.transport/main.c:543
 #, fuzzy
 msgid "Could not create and solve the linear equation system"
-msgstr "Não consegui criar arquivo raster [%s]."
+msgstr "Não consegui criar arquivo raster [%s]."
 #: ../raster/r.what.color/main.c:91
 #, fuzzy
 msgid "Queries colors for a raster map layer."
-msgstr "Relatório de estatísticas para mapas raster."
+msgstr "Relatório de estatísticas para mapas raster."
 #: ../raster/r.what.color/main.c:99
 #, fuzzy
@@ -18686,12 +18686,12 @@
 #: ../raster/r.what.color/main.c:106
 #, fuzzy
 msgid "Values to query colors for"
-msgstr "Não consegui ler as cores para a escala"
+msgstr "Não consegui ler as cores para a escala"
 #: ../raster/r.what.color/main.c:113
 #, fuzzy
 msgid "Output format (printf-style)"
-msgstr "Formato de saída"
+msgstr "Formato de saída"
 #: ../raster/r.what.color/main.c:117
 #, fuzzy
@@ -18797,7 +18797,7 @@
 #, fuzzy
 msgid "Calculates solar elevation, solar azimuth, and sun hours."
 msgstr ""
-"Calcula estatísticas univariada das células não nulas de um mapa raster."
+"Calcula estatísticas univariada das células não nulas de um mapa raster."
 #: ../raster/r.sunhours/main.c:77
 msgid ""
@@ -18809,17 +18809,17 @@
 #: ../raster/r.sunhours/main.c:83
 #, fuzzy
 msgid "Output raster map with solar elevation angle"
-msgstr "Prefixo para o nome do arquivo raster de saída"
+msgstr "Prefixo para o nome do arquivo raster de saída"
 #: ../raster/r.sunhours/main.c:88
 #, fuzzy
 msgid "Output raster map with solar azimuth angle"
 #: ../raster/r.sunhours/main.c:93
 #, fuzzy
 msgid "Output raster map with sunshine hours"
 #: ../raster/r.sunhours/main.c:94
 msgid "Sunshine hours require SOLPOS use and Greenwich standard time"
@@ -18891,23 +18891,23 @@
 #: ../raster/r.sunhours/main.c:216
 #, fuzzy
 msgid "Cannot get projection info of current location"
-msgstr "Não consegui informações de projeção da locação atual"
+msgstr "Não consegui informações de projeção da locação atual"
 #: ../raster/r.sunhours/main.c:219
 #, fuzzy
 msgid "Cannot get projection units of current location"
-msgstr "Não consegui unidades de projeção da locação atual"
+msgstr "Não consegui unidades de projeção da locação atual"
 #: ../raster/r.sunhours/main.c:222
 #, fuzzy
 msgid "Cannot get projection key values of current location"
-msgstr "Não obtive os valores de projeção da locação atual"
+msgstr "Não obtive os valores de projeção da locação atual"
 #: ../raster/r.sunhours/main.c:232 ../general/g.region/printwindow.c:257
 #: ../general/g.region/printwindow.c:510 ../general/g.region/printwindow.c:641
 #, fuzzy
 msgid "Unable to update lat/long projection parameters"
-msgstr "Não consegui ajustar parâmetros de projeção lat/long"
+msgstr "Não consegui ajustar parâmetros de projeção lat/long"
 #: ../raster/r.sunhours/main.c:296 ../raster/r.sunhours/main.c:391
 #: ../raster/r.sunmask/g_solposition.c:127
@@ -18918,22 +18918,22 @@
 #: ../general/g.region/printwindow.c:670 ../general/g.region/printwindow.c:678
 #: ../general/g.region/printwindow.c:686 ../general/g.region/printwindow.c:694
 msgid "Error in pj_do_proj (projection of input coordinate pair)"
-msgstr "Erro em pj_do_proj (projeção das coordenadas de entrada)"
+msgstr "Erro em pj_do_proj (projeção das coordenadas de entrada)"
 #: ../raster/r.sunhours/main.c:356
 #, fuzzy
 msgid "Calculating solar elevation and azimuth..."
-msgstr "Calculando matrizes de covariância de classes..."
+msgstr "Calculando matrizes de covariância de classes..."
 #: ../raster/r.sunhours/main.c:359
 #, fuzzy
 msgid "Calculating solar elevation..."
-msgstr "Calculando médias das classes ..."
+msgstr "Calculando médias das classes ..."
 #: ../raster/r.sunhours/main.c:362
 #, fuzzy
 msgid "Calculating solar azimuth..."
 #: ../raster/r.in.poly/get_item.c:97
 #, c-format
@@ -18953,7 +18953,7 @@
 #: ../raster/r.in.poly/main.c:37
 msgid "Creates raster maps from ASCII polygon/line/point data files."
 msgstr ""
 #: ../raster/r.in.poly/main.c:41
 msgid "Name of input file; or \"-\" to read from stdin"
@@ -18962,20 +18962,20 @@
 #: ../raster/r.in.poly/main.c:60
 #, fuzzy
 msgid "Integer representing NULL value data cell"
-msgstr "Texto para representar célula sem valor de dados"
+msgstr "Texto para representar célula sem valor de dados"
 #: ../raster/r.in.poly/main.c:66
 msgid "Number of rows to hold in memory"
-msgstr "Número de linhas para manter na memória"
+msgstr "Número de linhas para manter na memória"
 #: ../raster/r.in.poly/main.c:74
 msgid "Minimum number of rows to hold in memory is 1"
-msgstr "Número mínimo de linhas para manter na memória é 1"
+msgstr "Número mínimo de linhas para manter na memória é 1"
 #: ../raster/r.in.poly/main.c:83
 #, fuzzy
 msgid "Type doesn't exist"
-msgstr "Ferramenta não existe"
+msgstr "Ferramenta não existe"
 #: ../raster/r.out.ppm/main.c:56
 #, fuzzy
@@ -18985,7 +18985,7 @@
 #: ../raster/r.out.ppm/main.c:64
 #, fuzzy
 msgid "Name for new PPM file (use '-' for stdout)"
-msgstr "Nome para novo arquivo PPM. (use out=- para saída padrão)"
+msgstr "Nome para novo arquivo PPM. (use out=- para saída padrão)"
 #: ../raster/r.out.ppm/main.c:68
 msgid "Output greyscale instead of color"
@@ -18994,7 +18994,7 @@
 #: ../raster/r.out.ppm/main.c:72
 #, fuzzy
 msgid "Suppress printing of PPM header"
-msgstr "Suprimir impressão de cabeçalho"
+msgstr "Suprimir impressão de cabeçalho"
 #: ../raster/r.out.ppm/main.c:101 ../raster/r.out.ppm3/main.c:95
 #, fuzzy, c-format
@@ -19014,7 +19014,7 @@
 #: ../raster/r.out.ppm/main.c:124
 #, fuzzy, c-format
 msgid "Unable to open file <%s> for write"
-msgstr "Não consegui abrir o arquivo de células [%s]"
+msgstr "Não consegui abrir o arquivo de células [%s]"
 #: ../raster/r.out.ppm/main.c:154
 #, fuzzy
@@ -19024,7 +19024,7 @@
 #: ../raster/r.out.ppm/main.c:234
 #, fuzzy, c-format
 msgid "File <%s> created"
 #: ../raster/r.resamp.interp/main.c:80
 #, fuzzy
@@ -19038,7 +19038,7 @@
 #: ../raster/r.out.vrml/put_grid.c:38
 #, fuzzy
 msgid "Writing vertices..."
-msgstr "Escrever vértices da linha."
+msgstr "Escrever vértices da linha."
 #: ../raster/r.out.vrml/put_grid.c:83
 #, fuzzy
@@ -19061,22 +19061,22 @@
 #: ../raster/r.out.vrml/main.c:65 ../misc/m.nviz.image/args.c:575
 #, fuzzy
 msgid "Vertical exaggeration"
-msgstr "Fator de sobrelevação"
+msgstr "Fator de sobrelevação"
 #: ../raster/r.out.vrml/main.c:69
 #, fuzzy
 msgid "Name for output VRML file"
 #: ../raster/r.out.vrml/main.c:88
 #, fuzzy, c-format
 msgid "Range info for [%s] not available (run r.support)"
-msgstr "Informação de limites indisponível para [%s] (execute r.support)."
+msgstr "Informação de limites indisponível para [%s] (execute r.support)."
 #: ../raster/r.out.vrml/main.c:97
 #, fuzzy, c-format
 msgid "Range info for <%s> not available (run r.support)"
 #: ../raster/r.out.vrml/main.c:129
 #, c-format
@@ -19086,13 +19086,13 @@
 #: ../raster/r.surf.area/main.c:79
 #, fuzzy
 msgid "area estimation"
 #: ../raster/r.surf.area/main.c:80
 #, fuzzy
 msgid "Prints estimation of surface area for raster map."
 msgstr ""
 #: ../raster/r.surf.area/main.c:89
 msgid "Vertical scale"
@@ -19101,22 +19101,22 @@
 #: ../raster/r.surf.area/main.c:93
 #, fuzzy
 msgid "Output units"
-msgstr "Saída de mapa"
+msgstr "Saída de mapa"
 #: ../raster/r.surf.area/main.c:94
 #, fuzzy
 msgid "Default: square map units"
-msgstr "erro de discretização em unidades de mapa"
+msgstr "erro de discretização em unidades de mapa"
 #: ../raster/r.surf.area/main.c:102
 #, fuzzy, c-format
 msgid "Output in '%s'"
 #: ../raster/r.surf.area/main.c:106
 #, fuzzy
 msgid "Output in 'square map units'"
 #: ../raster/r.surf.area/main.c:153
 #, fuzzy
@@ -19135,7 +19135,7 @@
 #: ../raster/r.surf.area/main.c:163
 #, fuzzy
 msgid "Current region plan area:"
-msgstr "Região atual não pode ser ajustada."
+msgstr "Região atual não pode ser ajustada."
 #: ../raster/r.surf.area/main.c:165
 msgid "Estimated region Surface Area:"
@@ -19161,20 +19161,20 @@
 #: ../raster/r.in.gridatb/main.c:51
 msgid "GRIDATB i/o map file"
-msgstr "entrada saída de mapa GRIDATB"
+msgstr "entrada saída de mapa GRIDATB"
 #: ../raster/r.in.gridatb/main.c:68
 #, fuzzy, c-format
 msgid "File not found: %s"
-msgstr "Arquivo de células não encontrado\n"
+msgstr "Arquivo de células não encontrado\n"
 #: ../raster/r.series/main.c:141
 msgid ""
 "Makes each output cell value a function of the values assigned to the "
 "corresponding cells in the input raster map layers."
 msgstr ""
-"Define cada célula da saída como função dos valores designados para as "
-"células correspondentes nos mapas raster de entrada."
+"Define cada célula da saída como função dos valores designados para as "
+"células correspondentes nos mapas raster de entrada."
 #: ../raster/r.series/main.c:150
 msgid ""
@@ -19190,7 +19190,7 @@
 #: ../raster/r.series/main.c:250 ../raster/r.series/main.c:312
 #, fuzzy
 msgid "Weights must be positive"
-msgstr "Tamanho da vizinhança"
+msgstr "Tamanho da vizinhança"
 #: ../raster/r.series/main.c:268 ../raster/r.series/main.c:318
 #, fuzzy, c-format
@@ -19216,18 +19216,18 @@
 #: ../vector/v.vect.stats/main.c:128
 #, fuzzy
 msgid "zonal statistics"
-msgstr "Estatísticas de transição de classe."
+msgstr "Estatísticas de transição de classe."
 #: ../raster/r.stats.zonal/main.c:105
 #, fuzzy
 msgid ""
 "Calculates category or object oriented statistics (accumulator-based "
 "statistics)."
-msgstr "Estatística orientadas a objetos ou categorias."
+msgstr "Estatística orientadas a objetos ou categorias."
 #: ../raster/r.stats.zonal/main.c:115 ../raster/r.statistics/main.c:69
 msgid "Method of object-based statistic"
-msgstr "Método para a estatística orientada a objetos"
+msgstr "Método para a estatística orientada a objetos"
 #: ../raster/r.stats.zonal/main.c:138 ../raster/r.statistics/main.c:92
 msgid "Resultant raster map"
@@ -19236,7 +19236,7 @@
 #: ../raster/r.stats.zonal/main.c:144 ../raster/r.statistics/main.c:98
 msgid "Cover values extracted from the category labels of the cover map"
 msgstr ""
-"Valores de cobertura extraídos dos rótulos de categorias no mapa de cobertura"
+"Valores de cobertura extraídos dos rótulos de categorias no mapa de cobertura"
 #: ../raster/r.stats.zonal/main.c:178
 #, fuzzy, c-format
@@ -19297,8 +19297,8 @@
 "Recategorizes data in a raster map by grouping cells that form physically "
 "discrete areas into unique categories."
 msgstr ""
-"Agrupa células que formam áreas fisicamente discretas num raster, em "
-"categorias únicas."
+"Agrupa células que formam áreas fisicamente discretas num raster, em "
+"categorias únicas."
 #: ../raster/r.clump/main.c:82
 msgid "Threshold to identify similar cells"
@@ -19311,7 +19311,7 @@
 #: ../raster/r.clump/main.c:90
 #, fuzzy
 msgid "Minimum clump size in cells"
-msgstr "Isosuperfície mínima"
+msgstr "Isosuperfície mínima"
 #: ../raster/r.clump/main.c:91
 msgid "Clumps smaller than minsize will be merged to form larger clumps"
@@ -19320,7 +19320,7 @@
 #: ../raster/r.clump/main.c:95
 #, fuzzy
 msgid "Clump also diagonal cells"
-msgstr "Excluir as células sem valores numéricos"
+msgstr "Excluir as células sem valores numéricos"
 #: ../raster/r.clump/main.c:96
 msgid "Clumps are also traced along diagonal neighboring cells"
@@ -19329,7 +19329,7 @@
 #: ../raster/r.clump/main.c:100
 #, fuzzy
 msgid "Print only the number of clumps in shell script style"
 #: ../raster/r.clump/main.c:122
 #, c-format
@@ -19346,22 +19346,22 @@
 #: ../raster/r.clump/clump.c:81
 #, fuzzy
 msgid "Pass 2 of 2..."
-msgstr "Máscara: %s\n"
+msgstr "Máscara: %s\n"
 #: ../raster/r.clump/clump.c:122
 #, fuzzy, c-format
 msgid "%d initial clumps"
-msgstr "Cópia da tabela falhou"
+msgstr "Cópia da tabela falhou"
 #: ../raster/r.clump/clump.c:233 ../raster/r.clump/clump.c:490
 #, fuzzy
 msgid "Pass 1 of 2..."
 #: ../raster/r.clump/clump.c:425
 #, fuzzy, c-format
 msgid "%d-band clumping with threshold %g"
-msgstr "%d pontos além do limite"
+msgstr "%d pontos além do limite"
 #: ../raster/r.composite/main.c:73
 #: ../locale/scriptstrings/r.blend_to_translate.c:3
@@ -19373,7 +19373,7 @@
 #, fuzzy
 msgid ""
 "Combines red, green and blue raster maps into a single composite raster map."
-msgstr "Combina camadas vermelhas, verdes e azuis numa única camada composta."
+msgstr "Combina camadas vermelhas, verdes e azuis numa única camada composta."
 #: ../raster/r.composite/main.c:90 ../raster/r.out.ppm3/main.c:64
 #: ../display/d.rgb/main.c:69
@@ -19383,7 +19383,7 @@
 #: ../raster/r.composite/main.c:102
 msgid "Number of levels to be used for each component"
-msgstr "Número de níveis a usar para componente"
+msgstr "Número de níveis a usar para componente"
 #: ../raster/r.composite/main.c:103 ../raster/r.composite/main.c:121
 msgid "Levels"
@@ -19392,7 +19392,7 @@
 #: ../raster/r.composite/main.c:118
 #, c-format
 msgid "Number of levels to be used for <%s>"
-msgstr "Número de níveis a usar para <%s>"
+msgstr "Número de níveis a usar para <%s>"
 #: ../raster/r.composite/main.c:128
 msgid "Dither"
@@ -19400,12 +19400,12 @@
 #: ../raster/r.composite/main.c:132
 msgid "Use closest color"
-msgstr "Usar a cor mais próxima"
+msgstr "Usar a cor mais próxima"
 #: ../raster/r.composite/main.c:164
 #, c-format
 msgid "Unable to read color file of raster map <%s>"
-msgstr "Não consegui ler arquivo de cores do mapa raster <%s>."
+msgstr "Não consegui ler arquivo de cores do mapa raster <%s>."
 #: ../raster/r.composite/main.c:286
 #, fuzzy
@@ -19433,7 +19433,7 @@
 #: ../raster/r.univar/r3.univar_main.c:59 ../vector/v.what/main.c:98
 #: ../vector/v.univar/main.c:126
 msgid "Print the stats in shell script style"
 #: ../raster/r.univar/r.univar_main.c:66
 #: ../raster/r.univar/r3.univar_main.c:63
@@ -19443,7 +19443,7 @@
 #: ../vector/v.univar/main.c:130
 #, fuzzy
 msgid "Calculate extended statistics"
 #: ../raster/r.univar/r.univar_main.c:71
 #: ../raster/r.univar/r3.univar_main.c:67
@@ -19456,8 +19456,8 @@
 "Use the native resolution and extent of the raster map, instead of the "
 "current region"
 msgstr ""
-"Use a mesma resolução do mapa RASTER3D de entrada para os mapas 2d de saída, "
-"independente das cofigurações da região atual"
+"Use a mesma resolução do mapa RASTER3D de entrada para os mapas 2d de saída, "
+"independente das cofigurações da região atual"
 #: ../raster/r.univar/r.univar_main.c:106
 #: ../raster/r.univar/r3.univar_main.c:100
@@ -19465,13 +19465,13 @@
 #: ../vector/v.vect.stats/main.c:127 ../vector/v.univar/main.c:94
 #, fuzzy
 msgid "univariate statistics"
-msgstr "Nome do mapa raster que conterá os resultados"
+msgstr "Nome do mapa raster que conterá os resultados"
 #: ../raster/r.univar/r.univar_main.c:110
 msgid ""
 "Calculates univariate statistics from the non-null cells of a raster map."
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:112
 #: ../raster/r.univar/r3.univar_main.c:105
@@ -19484,7 +19484,7 @@
 #: ../raster/r.univar/r.univar_main.c:123
 #, fuzzy
 msgid "zones option and region flag -r are mutually exclusive"
 #: ../raster/r.univar/r3.univar_main.c:37
 msgid "3D Raster map used for zoning, must be of type CELL"
@@ -19495,7 +19495,7 @@
 msgid ""
 "Calculates univariate statistics from the non-null cells of a 3D raster map."
 msgstr ""
 #: ../raster/r.cross/renumber.c:33
 #, c-format
@@ -19507,7 +19507,7 @@
 "Creates a cross product of the category values from multiple raster map "
 "layers."
 msgstr ""
-"Cria um produto cruzado dos valores de categorias a partir de múltiplas "
+"Cria um produto cruzado dos valores de categorias a partir de múltiplas "
 "camadas raster"
 #: ../raster/r.cross/main.c:81
@@ -19517,12 +19517,12 @@
 #: ../raster/r.cross/main.c:90
 msgid "Non-zero data only"
-msgstr "Apenas valores não nulos"
+msgstr "Apenas valores não nulos"
 #: ../raster/r.cross/main.c:103
 #, fuzzy, c-format
 msgid "More than %d files not allowed"
-msgstr "não"
+msgstr "não"
 #: ../raster/r.cross/main.c:119
 msgid "Must specify 2 or more input maps"
@@ -19568,7 +19568,7 @@
 #: ../raster/r.coin/main.c:84
 #, fuzzy
 msgid "Unit of measure"
-msgstr "Unidade de distância"
+msgstr "Unidade de distância"
 #: ../raster/r.coin/main.c:86
 msgid ""
@@ -19579,7 +19579,7 @@
 #: ../raster/r.coin/main.c:93
 #, fuzzy
 msgid "Wide report, 132 columns (default: 80)"
-msgstr "relatório largo, 132 colunas (padrão: 80)"
+msgstr "relatório largo, 132 colunas (padrão: 80)"
 #: ../raster/r.coin/make_coin.c:48
 #, c-format
@@ -19589,12 +19589,12 @@
 #: ../raster/r.coin/make_coin.c:61
 #, fuzzy
 msgid "Unable to create any tempfiles"
 #: ../raster/r.coin/make_coin.c:65
 #, fuzzy
 msgid "Unable to run r.stats"
-msgstr "Não consegui abrir mapa raster [%s]."
+msgstr "Não consegui abrir mapa raster [%s]."
 #: ../raster/r.coin/make_coin.c:72
 #, fuzzy
@@ -19604,7 +19604,7 @@
 #: ../raster/r.coin/make_coin.c:84
 #, fuzzy
 msgid "Unable to open tempfile"
-msgstr "Não consegui abrir arquivo de saída."
+msgstr "Não consegui abrir arquivo de saída."
 #: ../raster/r.statistics/o_var.c:95 ../raster/r.statistics/o_sdev.c:94
 msgid "o_var: No data in array"
@@ -19617,7 +19617,7 @@
 #: ../raster/r.statistics/main.c:59
 #, fuzzy
 msgid "Calculates category or object oriented statistics."
 #: ../raster/r.statistics/main.c:104 ../raster/r.statistics/main.c:107
 #: ../raster/r.surf.idw/main.c:164
@@ -19634,7 +19634,7 @@
 #: ../raster/r.statistics/read_stats.c:20
 msgid "Reading r.stats output"
-msgstr "Lendo a saída do r.stats"
+msgstr "Lendo a saída do r.stats"
 #: ../raster/r.series.interp/main.c:69
 msgid ""
@@ -19645,7 +19645,7 @@
 #: ../raster/r.series.interp/main.c:79
 #, fuzzy
 msgid "Data point position for each input map"
 #: ../raster/r.series.interp/main.c:84
 msgid ""
@@ -19656,7 +19656,7 @@
 #: ../raster/r.series.interp/main.c:97
 #, fuzzy
 msgid "Sampling point position for each output map"
 #: ../raster/r.series.interp/main.c:101
 msgid ""
@@ -19691,7 +19691,7 @@
 #: ../raster/r.series.interp/main.c:243
 #, fuzzy, c-format
 msgid "No %s raster map not found"
-msgstr "%s: <%s> mapa raster não encontrado"
+msgstr "%s: <%s> mapa raster não encontrado"
 #: ../raster/r.series.interp/main.c:250
 #, fuzzy, c-format
@@ -19713,7 +19713,7 @@
 #: ../raster/r.series.interp/main.c:319
 #, fuzzy
 msgid "At least 2 input maps are required for linear interpolation"
-msgstr "Alocação de memória para interpolação bilinear"
+msgstr "Alocação de memória para interpolação bilinear"
 #: ../raster/r.series.interp/main.c:337
 #, c-format
@@ -19723,31 +19723,31 @@
 #: ../raster/r.texture/main.c:67
 #, fuzzy, c-format
 msgid "Unknown measure <%s>"
-msgstr "Métrica desconhecida: [%s]."
+msgstr "Métrica desconhecida: [%s]."
 #: ../raster/r.texture/main.c:104
 #, fuzzy
 msgid "texture"
-msgstr "Tipo de feição"
+msgstr "Tipo de feição"
 #: ../raster/r.texture/main.c:106
 #, fuzzy
 msgid "Generate images with textural features from a raster map."
-msgstr "Gera imagens com feições texturais de um mapa raster"
+msgstr "Gera imagens com feições texturais de um mapa raster"
 #: ../raster/r.texture/main.c:120
 #, fuzzy
 msgid "The size of moving window (odd and >= 3)"
-msgstr "Tamanho da janela deslizante (ímpar e >= 3)"
+msgstr "Tamanho da janela deslizante (ímpar e >= 3)"
 #: ../raster/r.texture/main.c:130
 msgid "The distance between two samples (>= 1)"
-msgstr "Distância entre duas amostras (>= 1)"
+msgstr "Distância entre duas amostras (>= 1)"
 #: ../raster/r.texture/main.c:146
 #, fuzzy
 msgid "Textural measurement method"
 #: ../raster/r.texture/main.c:150
 msgid "Separate output for each angle (0, 45, 90, 135)"
@@ -19756,7 +19756,7 @@
 #: ../raster/r.texture/main.c:154
 #, fuzzy
 msgid "Calculate all textural measurements"
 #: ../raster/r.texture/main.c:163
 msgid "Size of the moving window must be > 0"
@@ -19769,24 +19769,24 @@
 #: ../raster/r.texture/main.c:168
 #, fuzzy
 msgid "The distance between two samples must be > 0"
 #: ../raster/r.texture/main.c:189
 #, fuzzy
 msgid "Nothing to compute. Use at least one textural measure."
-msgstr "Nada a calcular. Verifique as opções."
+msgstr "Nada a calcular. Verifique as opções."
 #: ../raster/r.texture/main.c:327
 #, fuzzy, c-format
 msgid "Calculating %d texture measure"
 msgid_plural "Calculating %d texture measures"
-msgstr[0] "Calculando médias das classes ..."
-msgstr[1] "Calculando médias das classes ..."
+msgstr[0] "Calculando médias das classes ..."
+msgstr[1] "Calculando médias das classes ..."
 #: ../raster/r.texture/main.c:330
 #, fuzzy, c-format
 msgid "Calculating %s"
 #: ../raster/r.texture/h_measure.c:123
 #, c-format
@@ -19794,7 +19794,7 @@
 "Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
 "map"
 msgstr ""
-"Categorias demais (encontrei: %i, máx: %i). Tente rescalonar ou "
+"Categorias demais (encontrei: %i, máx: %i). Tente rescalonar ou "
 "reclassificar o mapa."
 #: ../raster/r.colors.out/raster3d_main.c:50
@@ -19812,12 +19812,12 @@
 #: ../raster/r.colors.out/raster_main.c:61 ../vector/v.colors.out/main.c:72
 #, fuzzy
 msgid "Output values as percentages"
-msgstr "Nome do arquivo de saída de direção da encosta"
+msgstr "Nome do arquivo de saída de direção da encosta"
 #: ../raster/r.colors.out/raster3d_main.c:70
 #, fuzzy, c-format
 msgid "Unable to read color table for raster3d map <%s>"
-msgstr "Não consegui criar mapa raster <%s>."
+msgstr "Não consegui criar mapa raster <%s>."
 #: ../raster/r.colors.out/raster_main.c:49
 #, fuzzy
@@ -19830,11 +19830,11 @@
 #: ../raster/r.lake/main.c:154
 msgid "Fills lake at given point to given level."
-msgstr "Preenche lago a partir da origem num dado nível."
+msgstr "Preenche lago a partir da origem num dado nível."
 #: ../raster/r.lake/main.c:160
 msgid "Water level"
-msgstr "Nível da água"
+msgstr "Nível da água"
 #: ../raster/r.lake/main.c:170
 #, fuzzy
@@ -19844,7 +19844,7 @@
 #: ../raster/r.lake/main.c:171
 #, fuzzy
 msgid "Either this coordinates pair or a seed map have to be specified"
-msgstr "Um dos parâmetros [%s] ou [%s] deve ser especificado"
+msgstr "Um dos parâmetros [%s] ou [%s] deve ser especificado"
 #: ../raster/r.lake/main.c:175 ../raster/r.lake/main.c:184
 msgid "Seed"
@@ -19853,13 +19853,13 @@
 #: ../raster/r.lake/main.c:180
 #, fuzzy
 msgid "Input raster map with given starting point(s) (at least 1 cell > 0)"
-msgstr "Nome do mapa raster com origem (pelo menos uma célula > 0)"
+msgstr "Nome do mapa raster com origem (pelo menos uma célula > 0)"
 #: ../raster/r.lake/main.c:182
 #, fuzzy
 msgid "Either this parameter or a coordinates pair have to be specified"
 msgstr ""
-"Tanto o mapa de origem quanto as coordenadas não puderam ser especificadas!"
+"Tanto o mapa de origem quanto as coordenadas não puderam ser especificadas!"
 #: ../raster/r.lake/main.c:189
 msgid "Use negative depth values for lake raster map"
@@ -19872,7 +19872,7 @@
 #: ../raster/r.lake/main.c:201
 msgid "Both seed map and coordinates cannot be specified"
 msgstr ""
 #: ../raster/r.lake/main.c:204
 msgid "Seed map or seed coordinates must be set!"
@@ -19880,25 +19880,25 @@
 #: ../raster/r.lake/main.c:207
 msgid "Seed coordinates and output map lake= must be set!"
-msgstr "Coordenadas da origem e mapa de saída lake= devem ser configurados!"
+msgstr "Coordenadas da origem e mapa de saída lake= devem ser configurados!"
 #: ../raster/r.lake/main.c:210
 #, fuzzy
 msgid "Both lake and overwrite cannot be specified"
-msgstr "lake e overwrite não podem ser especificados simultaneamente"
+msgstr "lake e overwrite não podem ser especificados simultaneamente"
 #: ../raster/r.lake/main.c:213
 msgid "Output lake map or overwrite flag must be set!"
 msgstr ""
-"Ou mapa do lago de saída ou a opção sobreescrever devem ser configuradas!"
+"Ou mapa do lago de saída ou a opção sobreescrever devem ser configuradas!"
 #: ../raster/r.lake/main.c:240
 msgid "Seed point outside the current region"
-msgstr "ponto de origem fora da região atual"
+msgstr "ponto de origem fora da região atual"
 #: ../raster/r.lake/main.c:254
 msgid "G_malloc: out of memory"
-msgstr "G_malloc: Memória Esgotada"
+msgstr "G_malloc: Memória Esgotada"
 #: ../raster/r.lake/main.c:276
 msgid ""
@@ -19938,13 +19938,13 @@
 "Manages category values and labels associated with user-specified raster map "
 "layers."
 msgstr ""
-"Mostra valores de categoria e rótulos associados com camadas raster "
+"Mostra valores de categoria e rótulos associados com camadas raster "
 #: ../raster/r.category/main.c:69
 #, fuzzy
 msgid "Comma separated value list"
-msgstr "Lista separada por vírgulas, p.ex.: 1.4,3.8,13"
+msgstr "Lista separada por vírgulas, p.ex.: 1.4,3.8,13"
 #: ../raster/r.category/main.c:70
 msgid "Example: 1.4,3.8,13"
@@ -19992,11 +19992,11 @@
 #, fuzzy
 msgid "The map is floating point! Ignoring cats list, using vals list"
 msgstr ""
-"O mapa é ponto flutuante! Ignorando lista de cats, usando lista de vals"
+"O mapa é ponto flutuante! Ignorando lista de cats, usando lista de vals"
 #: ../raster/r.category/main.c:300
 msgid "vals argument is required for floating point map!"
-msgstr "argumento val é necessário para mapas de ponto flutuante!"
+msgstr "argumento val é necessário para mapas de ponto flutuante!"
 #: ../raster/r.category/cats.c:47
 #, fuzzy, c-format
@@ -20007,7 +20007,7 @@
 #, fuzzy
 msgid "Generates surface raster map from rasterized contours."
 msgstr ""
-"Programa para geração de superfícies a partir de isolinhas rasterizadas."
+"Programa para geração de superfícies a partir de isolinhas rasterizadas."
 #: ../raster/r.surf.contour/main.c:67
 #, fuzzy
@@ -20022,11 +20022,11 @@
 #: ../raster/r.describe/main.c:71
 msgid "Number of quantization steps"
-msgstr "Número de níveis de quantização"
+msgstr "Número de níveis de quantização"
 #: ../raster/r.describe/main.c:77
 msgid "Print the output one value per line"
-msgstr "Exibe um valor da saída por linha"
+msgstr "Exibe um valor da saída por linha"
 #: ../raster/r.describe/main.c:81
 msgid "Only print the range of the data"
@@ -20038,7 +20038,7 @@
 #: ../raster/r.describe/main.c:89
 msgid "Use the current region"
-msgstr "Usa a região atual"
+msgstr "Usa a região atual"
 #: ../raster/r.describe/main.c:93
 #, fuzzy
@@ -20068,7 +20068,7 @@
 #: ../raster/r.regression.multi/main.c:132
 #, fuzzy
 msgid "Calculates multiple linear regression from raster maps."
-msgstr "Não consegui fechar o novo mapa g3d"
+msgstr "Não consegui fechar o novo mapa g3d"
 #: ../raster/r.regression.multi/main.c:137
 #: ../raster/r.regression.line/main.c:55
@@ -20096,12 +20096,12 @@
 msgid ""
 "ASCII file for storing regression coefficients (output to screen if file not "
 "specified)."
-msgstr "ASCII para não."
+msgstr "ASCII para não."
 #: ../raster/r.regression.multi/main.c:249
 #, fuzzy
 msgid "First pass..."
-msgstr "Processando áreas de entradaA ..."
+msgstr "Processando áreas de entradaA ..."
 #: ../raster/r.regression.multi/main.c:322
 #, fuzzy
@@ -20119,12 +20119,12 @@
 #: ../raster/r.mapcalc/map3.c:181 ../raster/r.mapcalc/map.c:224
 #, fuzzy, c-format
 msgid "Unable to read color file for raster map <%s@%s>"
 #: ../raster/r.mapcalc/map3.c:194 ../raster/r.mapcalc/map.c:237
 #, fuzzy, c-format
 msgid "Unable to create btree for raster map <%s@%s>"
 #: ../raster/r.mapcalc/map3.c:239 ../raster/r.mapcalc/map3.c:423
 #: ../raster/r.mapcalc/map3.c:468 ../raster/r.mapcalc/map3.c:565
@@ -20133,7 +20133,7 @@
 #: ../raster/r.mapcalc/expression.c:357
 #, fuzzy, c-format
 msgid "Invalid map modifier: '%c'"
-msgstr "Número inválido de passos: %s"
+msgstr "Número inválido de passos: %s"
 #: ../raster/r.mapcalc/map3.c:353 ../raster/r.mapcalc/map.c:424
 #: ../raster/r.mapcalc/evaluate.c:94 ../raster/r.mapcalc/evaluate.c:234
@@ -20144,12 +20144,12 @@
 #: ../raster/r.mapcalc/map3.c:372
 #, fuzzy, c-format
 msgid "Unable to close raster map <%s@%s>"
 #: ../raster/r.mapcalc/map3.c:631
 #, fuzzy
 msgid "Unable to close output raster map"
-msgstr "Não consegui fechar mapa de entrada"
+msgstr "Não consegui fechar mapa de entrada"
 #: ../raster/r.mapcalc/expression.c:206
 #, c-format
@@ -20159,7 +20159,7 @@
 #: ../raster/r.mapcalc/expression.c:221
 #, fuzzy, c-format
 msgid "Invalid map <%s>"
 #: ../raster/r.mapcalc/expression.c:262
 #, fuzzy, c-format
@@ -20179,7 +20179,7 @@
 #: ../raster/r.mapcalc/expression.c:275
 #, fuzzy, c-format
 msgid "Incorrect argument types to function %s()"
-msgstr "Não consegui criar a tabela %s"
+msgstr "Não consegui criar a tabela %s"
 #: ../raster/r.mapcalc/expression.c:278
 #, c-format
@@ -20204,22 +20204,22 @@
 #: ../raster/r.mapcalc/main.c:78
 #, fuzzy
 msgid "Expression to evaluate"
 #: ../raster/r.mapcalc/main.c:79 ../raster/r.mapcalc/main.c:85
 #, fuzzy
 msgid "Expression"
 #: ../raster/r.mapcalc/main.c:84
 #, fuzzy
 msgid "File containing expression(s) to evaluate"
 #: ../raster/r.mapcalc/main.c:91
 #, fuzzy
 msgid "Seed for rand() function"
-msgstr "Semente para geração de número aleatório"
+msgstr "Semente para geração de número aleatório"
 #: ../raster/r.mapcalc/main.c:95
 msgid "Generate random seed (result is non-deterministic)"
@@ -20233,12 +20233,12 @@
 #: ../raster/r.mapcalc/main.c:121
 #, fuzzy, c-format
 msgid "%s= and -%c are mutually exclusive"
-msgstr "Opções -B e -C são mutuamente exclusivas. Escolha apenas uma."
+msgstr "Opções -B e -C são mutuamente exclusivas. Escolha apenas uma."
 #: ../raster/r.mapcalc/main.c:132
 #, fuzzy
 msgid "parse error"
-msgstr "Parâmetros do agrupamento\n"
+msgstr "Parâmetros do agrupamento\n"
 #: ../raster/r.mapcalc/main.c:159
 msgid "Floating point error(s) occurred in the calculation"
@@ -20252,7 +20252,7 @@
 #: ../raster/r.mapcalc/evaluate.c:140
 #, fuzzy, c-format
 msgid "Invalid type: %d"
 #: ../raster/r.mapcalc/evaluate.c:179
 #, c-format
@@ -20262,17 +20262,17 @@
 #: ../raster/r.mapcalc/evaluate.c:183
 #, fuzzy, c-format
 msgid "Too many arguments for function '%s'"
-msgstr "Parâmetros demais para <reference>"
+msgstr "Parâmetros demais para <reference>"
 #: ../raster/r.mapcalc/evaluate.c:187
 #, fuzzy, c-format
 msgid "Invalid argument type for function '%s'"
 #: ../raster/r.mapcalc/evaluate.c:191
 #, fuzzy, c-format
 msgid "Invalid return type for function '%s'"
 #: ../raster/r.mapcalc/evaluate.c:195
 #, fuzzy, c-format
@@ -20282,7 +20282,7 @@
 #: ../raster/r.mapcalc/evaluate.c:198
 #, fuzzy, c-format
 msgid "Number of arguments for function '%s'"
-msgstr "Número de linhas"
+msgstr "Número de linhas"
 #: ../raster/r.mapcalc/evaluate.c:202
 #, fuzzy, c-format
@@ -20343,7 +20343,7 @@
 msgid "SECTION %d: Watershed determination."
 msgstr ""
 "\n"
-"SEÇÃO %d: Determinação de divisores."
+"SEÇÃO %d: Determinação de divisores."
 #: ../raster/r.watershed/seg/close_maps.c:20
 #, fuzzy
@@ -20436,10 +20436,10 @@
 msgid_plural "SECTION 1 beginning: Initiating Variables. %d sections total."
 msgstr[0] ""
 "\n"
-"SEÇÃO 1 iniciando: Inicializando variáveis. %d seções no total."
+"SEÇÃO 1 iniciando: Inicializando variáveis. %d seções no total."
 msgstr[1] ""
 "\n"
 #: ../raster/r.watershed/seg/init_vars.c:175
 msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
@@ -20475,7 +20475,7 @@
 #: ../raster/r.watershed/front/main.c:90
 #, fuzzy
 msgid "Name of input raster representing amount of overland flow per cell"
-msgstr "Mapa de Entrada: quantidade de fluxo superficial por célula"
+msgstr "Mapa de Entrada: quantidade de fluxo superficial por célula"
 #: ../raster/r.watershed/front/main.c:96
 #, fuzzy
@@ -20500,83 +20500,83 @@
 #: ../raster/r.watershed/front/main.c:113
 #, fuzzy
 msgid "Minimum size of exterior watershed basin"
-msgstr "Mapa de entrada: tamanho mínimo de bacias de drenagem exteriores"
+msgstr "Mapa de entrada: tamanho mínimo de bacias de drenagem exteriores"
 #: ../raster/r.watershed/front/main.c:121
 #, fuzzy
 msgid "Maximum length of surface flow in map units"
-msgstr "Valor de entrada: comprimento máximo para fluxo superficial, para USLE"
+msgstr "Valor de entrada: comprimento máximo para fluxo superficial, para USLE"
 #: ../raster/r.watershed/front/main.c:130
 #, fuzzy
 msgid "Name for output accumulation raster map"
-msgstr "Nome do Raster de saída"
+msgstr "Nome do Raster de saída"
 #: ../raster/r.watershed/front/main.c:132
 #, fuzzy
 msgid "Number of cells that drain through each cell"
-msgstr "Mapa de saída: número de células que drenam através de cada célula"
+msgstr "Mapa de saída: número de células que drenam através de cada célula"
 #: ../raster/r.watershed/front/main.c:139
 #, fuzzy
 msgid "Name for output topographic index ln(a / tan(b)) map"
 #: ../raster/r.watershed/front/main.c:146
 #, fuzzy
 msgid "Stream power index a * tan(b)"
 #: ../raster/r.watershed/front/main.c:152
 #, fuzzy
 msgid "Name for output drainage direction raster map"
 #: ../raster/r.watershed/front/main.c:158
 #, fuzzy
 msgid "Name for output basins raster map"
 #: ../raster/r.watershed/front/main.c:164
 #, fuzzy
 msgid "Name for output stream segments raster map"
 #: ../raster/r.watershed/front/main.c:170
 #, fuzzy
 msgid "Name for output half basins raster map"
 #: ../raster/r.watershed/front/main.c:172
 #, fuzzy
 msgid "Each half-basin is given a unique value"
-msgstr "Mapa de saída: um valor único é dado para cada meia-bacia"
+msgstr "Mapa de saída: um valor único é dado para cada meia-bacia"
 #: ../raster/r.watershed/front/main.c:178
 #, fuzzy
 msgid "Name for output slope length raster map"
 #: ../raster/r.watershed/front/main.c:180
 #, fuzzy
 msgid "Slope length and steepness (LS) factor for USLE"
 msgstr ""
-"Saída de mapa: fator de comprimento do declive e declividade (LS) para USLE"
+"Saída de mapa: fator de comprimento do declive e declividade (LS) para USLE"
 #: ../raster/r.watershed/front/main.c:186
 #, fuzzy
 msgid "Name for output slope steepness raster map"
 #: ../raster/r.watershed/front/main.c:187
 #, fuzzy
 msgid "Slope steepness (S) factor for USLE"
-msgstr "Saída de mapa: fator de comprimento de declividade (S) para USLE"
+msgstr "Saída de mapa: fator de comprimento de declividade (S) para USLE"
 #: ../raster/r.watershed/front/main.c:196
 #, fuzzy
 msgid "Convergence factor for MFD (1-10)"
-msgstr "Fator de conversão para os valores de z"
+msgstr "Fator de conversão para os valores de z"
 #: ../raster/r.watershed/front/main.c:198
 msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
@@ -20596,11 +20596,11 @@
 #: ../raster/r.watershed/front/main.c:216
 msgid "Allow only horizontal and vertical flow of water"
-msgstr "Permitir apenas fluxo horizontal e vertical de água"
+msgstr "Permitir apenas fluxo horizontal e vertical de água"
 #: ../raster/r.watershed/front/main.c:221
 msgid "Enable disk swap memory option: Operation is slow"
-msgstr "Habilita opção de swap em disco: Operação é lenta"
+msgstr "Habilita opção de swap em disco: Operação é lenta"
 #: ../raster/r.watershed/front/main.c:223
 msgid ""
@@ -20632,7 +20632,7 @@
 #: ../raster/r.watershed/front/main.c:259
 #, fuzzy
 msgid "The basin threshold must be a positive number."
-msgstr "Suavização deve ser um valor positivo"
+msgstr "Suavização deve ser um valor positivo"
 #: ../raster/r.watershed/front/main.c:275
 #, fuzzy
@@ -20648,7 +20648,7 @@
 #: ../raster/r.watershed/front/main.c:302
 #, fuzzy
 msgid "Beautify flat areas is not yet supported for disk swap mode"
 #: ../raster/r.watershed/front/main.c:332
 #, c-format
@@ -20671,7 +20671,7 @@
 #: ../raster/r.watershed/shed/basin_maps.c:13
 #, fuzzy
 msgid "parameter hydrologic/soil erosion model.  Continue inputing cell map"
-msgstr "parâmetro Continuar célula mapear"
+msgstr "parâmetro Continuar célula mapear"
 #: ../raster/r.watershed/shed/basin_maps.c:14
 #, fuzzy
@@ -20697,7 +20697,7 @@
 "The output from %s will be divided into watershed"
 msgstr ""
 "\n"
-"A saída de %s será dividida em divisores"
+"A saída de %s será dividida em divisores"
 #: ../raster/r.watershed/shed/basin_maps.c:38
 #, fuzzy
@@ -20748,7 +20748,7 @@
 "%s"
 msgstr ""
 "\n"
-"OK, %s deve começar a executar agora usando a seguinte forma:\n"
+"OK, %s deve começar a executar agora usando a seguinte forma:\n"
 "%s"
 #: ../raster/r.watershed/shed/main.c:41
@@ -20764,12 +20764,12 @@
 #: ../raster/r.watershed/shed/main.c:72
 #, fuzzy
 msgid "unable to open output file"
 #: ../raster/r.watershed/shed/read.c:23
 #, fuzzy
 msgid "unable to open basin/half basin map"
 #: ../raster/r.watershed/shed/com_line.c:23
 #, fuzzy
@@ -20781,12 +20781,12 @@
 #: ../raster/r.watershed/shed/com_line.c:24
 #, fuzzy, c-format
 msgid "%s program to run properly for your application."
-msgstr "para aplicação."
+msgstr "para aplicação."
 #: ../raster/r.watershed/shed/com_line.c:26
 #, fuzzy, c-format
 msgid "The first question is whether you want %s to run"
-msgstr "é para"
+msgstr "é para"
 #: ../raster/r.watershed/shed/com_line.c:28
 #, fuzzy, c-format
@@ -20801,7 +20801,7 @@
 #: ../raster/r.watershed/shed/com_line.c:31
 #, fuzzy
 msgid "than in the slow mode, but will not allow other programs to run"
-msgstr "em não para"
+msgstr "em não para"
 #: ../raster/r.watershed/shed/com_line.c:32
 #, fuzzy
@@ -20816,17 +20816,17 @@
 #: ../raster/r.watershed/shed/com_line.c:34
 #, fuzzy
 msgid "mode uses disk space in the same hard disk partition as where GRASS is"
-msgstr "em partição é"
+msgstr "em partição é"
 #: ../raster/r.watershed/shed/com_line.c:35
 #, fuzzy
 msgid "stored.  Thus, if the program does not work in the slow mode, you will"
-msgstr "não em"
+msgstr "não em"
 #: ../raster/r.watershed/shed/com_line.c:36
 #, fuzzy
 msgid "need to remove unnecessary files from that partition.  The slow mode"
-msgstr "para remover partição"
+msgstr "para remover partição"
 #: ../raster/r.watershed/shed/com_line.c:37
 #, fuzzy, c-format
@@ -20839,19 +20839,19 @@
 msgid ""
 "\n"
 "If you hit <return> by itself for the next question, this"
-msgstr "coincidência<return> seguinte"
+msgstr "coincidência<return> seguinte"
 #: ../raster/r.watershed/shed/com_line.c:70
 #: ../raster/r.watershed/shed/com_line.c:183
 msgid "program will terminate."
-msgstr "programa será encerrado."
+msgstr "programa será encerrado."
 #: ../raster/r.watershed/shed/com_line.c:81
 #, fuzzy, c-format
 msgid ""
 "\n"
 "One of the options for %s is a `depression map'.  A"
-msgstr "de é mapear"
+msgstr "de é mapear"
 #: ../raster/r.watershed/shed/com_line.c:83
 #, fuzzy
@@ -20863,7 +20863,7 @@
 #, fuzzy
 msgid ""
 "water accumulates and does not leave by the edge of the map. Lakes without"
-msgstr "não de mapear"
+msgstr "não de mapear"
 #: ../raster/r.watershed/shed/com_line.c:85
 #, fuzzy
@@ -20879,13 +20879,13 @@
 #: ../raster/r.watershed/shed/com_line.c:87
 #, fuzzy
 msgid "locations where depressions occur.\n"
-msgstr "Mapa de Entrada: localização das depressões reais"
+msgstr "Mapa de Entrada: localização das depressões reais"
 #: ../raster/r.watershed/shed/com_line.c:88
 #, fuzzy
 msgid ""
 "Hit <return> by itself for the next question if there is no depression map."
-msgstr "<return> seguinte é mapear."
+msgstr "<return> seguinte é mapear."
 #: ../raster/r.watershed/shed/com_line.c:99
 #, fuzzy, c-format
@@ -20898,31 +20898,31 @@
 #, fuzzy
 msgid ""
 "watershed basins.  The number of watershed basins is indirectly determined"
-msgstr "de é"
+msgstr "de é"
 #: ../raster/r.watershed/shed/com_line.c:102
 #, fuzzy
 msgid ""
 "by the `basin threshold' value.  The basin threshold is the area necessary "
 "for"
-msgstr "limiar limiar é área"
+msgstr "limiar limiar é área"
 #: ../raster/r.watershed/shed/com_line.c:103
 #, fuzzy, c-format
 msgid "%s to define a unique watershed basin.  This area only applies to"
-msgstr "para área para"
+msgstr "para área para"
 #: ../raster/r.watershed/shed/com_line.c:105
 #, fuzzy
 msgid ""
 "`exterior drainage basins'.  An exterior drainage basin does not have any"
-msgstr "não"
+msgstr "não"
 #: ../raster/r.watershed/shed/com_line.c:106
 #, fuzzy
 msgid ""
 "drainage basins flowing into it.  Interior drainage basin size is determined"
-msgstr "é"
+msgstr "é"
 #: ../raster/r.watershed/shed/com_line.c:107
 #, fuzzy
@@ -20961,7 +20961,7 @@
 #: ../raster/r.watershed/shed/com_line.c:114
 #, fuzzy, c-format
 msgid "%s will accumulate those values instead of area.\n"
-msgstr "de área"
+msgstr "de área"
 #: ../raster/r.watershed/shed/com_line.c:116
 #, fuzzy
@@ -20988,7 +20988,7 @@
 msgid ""
 "\n"
 "How large an area (or how many overland flow units) must a drainage basin"
-msgstr "área"
+msgstr "área"
 #: ../raster/r.watershed/shed/com_line.c:132
 #, fuzzy, c-format
@@ -21054,12 +21054,12 @@
 msgid ""
 "\n"
 "%s can produce several maps not necessary for"
-msgstr "não"
+msgstr "não"
 #: ../raster/r.watershed/shed/com_line.c:292
 #, fuzzy, c-format
 msgid "%s to function (stream channels, overland flow aspect, and"
-msgstr "para função fluxo aspecto"
+msgstr "para função fluxo aspecto"
 #: ../raster/r.watershed/shed/com_line.c:294
 #, fuzzy, c-format
@@ -21075,7 +21075,7 @@
 #: ../raster/r.watershed/shed/com_line.c:297
 #, fuzzy
 msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
-msgstr "Equação LS"
+msgstr "Equação LS"
 #: ../raster/r.watershed/shed/com_line.c:348
 #, fuzzy
@@ -21094,12 +21094,12 @@
 msgid ""
 "where the value indicates the percent of disturbed (barren) land in that "
 "cell."
-msgstr "de em célula."
+msgstr "de em célula."
 #: ../raster/r.watershed/shed/com_line.c:352
 #, fuzzy
 msgid "Type <return> if you do not have a disturbed land map layer."
-msgstr "Tipo<return> não mapear."
+msgstr "Tipo<return> não mapear."
 #: ../raster/r.watershed/shed/com_line.c:364
 #, fuzzy
@@ -21111,7 +21111,7 @@
 #: ../raster/r.watershed/shed/com_line.c:365
 #, fuzzy
 msgid "be used for every cell in the current region."
-msgstr "Mostra a região atual"
+msgstr "Mostra a região atual"
 #: ../raster/r.watershed/shed/com_line.c:368
 #, c-format
@@ -21142,13 +21142,13 @@
 msgid ""
 "that prevents the surface flow distance from getting too long.  Normally,"
 msgstr ""
-"isso previne que a distância de fluxo superficial fique muito grande.  "
+"isso previne que a distância de fluxo superficial fique muito grande.  "
 "Normalmente,"
 #: ../raster/r.watershed/shed/com_line.c:385
 #, fuzzy
 msgid "maximum slope length is around 600 feet (about 183 meters)."
-msgstr "comprimento é."
+msgstr "comprimento é."
 #: ../raster/r.watershed/shed/com_line.c:400
 #, fuzzy
@@ -21172,7 +21172,7 @@
 #, fuzzy
 msgid ""
 "Hit <return> by itself for the next question if there is no blocking map."
-msgstr "<return> seguinte é Bloqueio mapear."
+msgstr "<return> seguinte é Bloqueio mapear."
 #: ../raster/r.watershed/shed/intro.c:8
 #, fuzzy, c-format
@@ -21182,12 +21182,12 @@
 #: ../raster/r.watershed/shed/intro.c:10
 #, fuzzy, c-format
 msgid "%s also allows the user to prepare a report of map layers for each"
-msgstr "para relatório de mapear"
+msgstr "para relatório de mapear"
 #: ../raster/r.watershed/shed/intro.c:12
 #, fuzzy, c-format
 msgid "watershed basin determined in %s.\n"
-msgstr "Programa de criação de bacias de drenagem"
+msgstr "Programa de criação de bacias de drenagem"
 #: ../raster/r.watershed/shed/intro.c:14
 #, fuzzy, c-format
@@ -21202,12 +21202,12 @@
 #: ../raster/r.watershed/shed/intro.c:18
 #, fuzzy, c-format
 msgid "divided by basin. %s will then run %s and create the report."
-msgstr "relatório."
+msgstr "relatório."
 #: ../raster/r.watershed/shed/file_in.c:15
 #, fuzzy
 msgid "unable to open ARMSED file"
-msgstr "Não consegui abrir os arquivos das bandas."
+msgstr "Não consegui abrir os arquivos das bandas."
 #: ../raster/r.watershed/ram/do_astar.c:256
 msgid "heapsize too large"
@@ -21254,7 +21254,7 @@
 #: ../raster/r.watershed/ram/do_flatarea.c:344
 #, fuzzy
 msgid "flat cell escaped in downhill correction"
-msgstr "Não em"
+msgstr "Não em"
 #: ../raster/r.watershed/ram/do_flatarea.c:382
 msgid "flat cell escaped for adjustment"
@@ -21288,7 +21288,7 @@
 #: ../raster/r.watershed/ram/init_vars.c:121
 #, fuzzy, c-format
 msgid "SECTION 1a (of %1d): Initiating Memory."
-msgstr "de Memória."
+msgstr "de Memória."
 #: ../raster/r.watershed/ram/init_vars.c:311
 #, fuzzy, c-format
@@ -21301,22 +21301,22 @@
 "Recursively traces the least cost path backwards to cells from which the "
 "cumulative cost was determined."
 msgstr ""
-"Traça recursivamente o caminho de menor custo retrocedendo para as células "
+"Traça recursivamente o caminho de menor custo retrocedendo para as células "
 "das quais o custo cumulativo foi calculado."
 #: ../raster/r.spreadpath/main.c:98
 #, fuzzy
 msgid "Name of raster map containing back-path easting information"
 msgstr ""
-"Nome do mapa raster contendo informação de coordenada leste do caminho "
-"retrógrado"
+"Nome do mapa raster contendo informação de coordenada leste do caminho "
+"retrógrado"
 #: ../raster/r.spreadpath/main.c:103
 #, fuzzy
 msgid "Name of raster map containing back-path northing information"
 msgstr ""
-"Nome do mapa raster contendo informação de coordenada norte do caminho "
-"retrógrado"
+"Nome do mapa raster contendo informação de coordenada norte do caminho "
+"retrógrado"
 #: ../raster/r.spreadpath/main.c:108
 msgid "The map E and N grid coordinates of starting points"
@@ -21326,7 +21326,7 @@
 #, fuzzy, c-format
 msgid ""
 "\\eading the input map -%s- and -%s- and creating some temporary files..."
-msgstr "Criando alguns arquivos temporários..."
+msgstr "Criando alguns arquivos temporários..."
 #: ../raster/r.spreadpath/main.c:281
 #, fuzzy
@@ -21359,7 +21359,7 @@
 "(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
 msgstr ""
 "Cria um mapa raster composto, usando valores conhecidos de categorias de uma "
-"(ou mais) camada(s) para preencher áreas de \"no data\" em outra camada."
+"(ou mais) camada(s) para preencher áreas de \"no data\" em outra camada."
 #: ../raster/r.patch/main.c:71
 msgid "Name of raster maps to be patched together"
@@ -21371,17 +21371,17 @@
 #: ../raster/r.patch/main.c:81
 msgid "Use zero (0) for transparency instead of NULL"
-msgstr "Usar zero (0) para transparência ao invés de NULL"
+msgstr "Usar zero (0) para transparência ao invés de NULL"
 #: ../raster/r.patch/main.c:86
 #, fuzzy
 msgid "Do not create color and category files"
 #: ../raster/r.patch/main.c:101
 #, fuzzy
 msgid "The minimum number of input raster maps is two"
-msgstr "Número mínimo de pixels numa classe"
+msgstr "Número mínimo de pixels numa classe"
 #: ../raster/r.patch/main.c:178
 #, fuzzy, c-format
@@ -21396,7 +21396,7 @@
 #: ../raster/r.out.gdal/main.c:135
 #, fuzzy
 msgid "Exports GRASS raster maps into GDAL supported formats."
-msgstr "Exporta um raster do GRASS para um arquivo binário"
+msgstr "Exporta um raster do GRASS para um arquivo binário"
 #: ../raster/r.out.gdal/main.c:141
 #, fuzzy
@@ -21411,7 +21411,7 @@
 #: ../raster/r.out.gdal/main.c:148
 #, fuzzy
 msgid "Only applicable to Byte or UInt16 data types"
-msgstr "Não consegui selecionar dados da tabela"
+msgstr "Não consegui selecionar dados da tabela"
 #: ../raster/r.out.gdal/main.c:149 ../raster/r.out.gdal/main.c:155
 #: ../raster/r.out.gdal/main.c:202 ../raster/r.out.gdal/main.c:213
@@ -21426,7 +21426,7 @@
 #: ../vector/v.out.postgis/args.c:79
 #, fuzzy
 msgid "Creation"
-msgstr "Correlação"
+msgstr "Correlação"
 #: ../raster/r.out.gdal/main.c:153
 #, fuzzy
@@ -21440,12 +21440,12 @@
 #: ../raster/r.out.gdal/main.c:159
 #, fuzzy
 msgid "Write raster attribute table"
-msgstr "Não criar tabela de atributo."
+msgstr "Não criar tabela de atributo."
 #: ../raster/r.out.gdal/main.c:160
 #, fuzzy
 msgid "Some export formats may not be supported"
-msgstr "Tipo de coluna não suportado"
+msgstr "Tipo de coluna não suportado"
 #: ../raster/r.out.gdal/main.c:164
 msgid "Force raster export despite any warnings of data loss"
@@ -21458,12 +21458,12 @@
 #: ../raster/r.out.gdal/main.c:168
 #, fuzzy
 msgid "Name of raster map (or group) to export"
 #: ../raster/r.out.gdal/main.c:171
 #, fuzzy
 msgid "Name for output raster file"
 #: ../raster/r.out.gdal/main.c:177
 #, fuzzy
@@ -21474,12 +21474,12 @@
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:11
 #, fuzzy
 msgid "Data type"
 #: ../raster/r.out.gdal/main.c:208
 #, fuzzy
 msgid "Creation option(s) to pass to the output format driver"
-msgstr "para Múltipla"
+msgstr "para Múltipla"
 #: ../raster/r.out.gdal/main.c:210
 msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma"
@@ -21508,7 +21508,7 @@
 #: ../raster/r.out.gdal/main.c:264
 #, fuzzy, c-format
 msgid "Raster map or group <%s> not found"
-msgstr "Mapa raster [%s] não encontrado"
+msgstr "Mapa raster [%s] não encontrado"
 #: ../raster/r.out.gdal/main.c:268
 #, fuzzy, c-format
@@ -21518,7 +21518,7 @@
 #: ../raster/r.out.gdal/main.c:282
 #, fuzzy, c-format
 msgid "Unable to get <%s> driver"
-msgstr "Não consegui definir tamanho"
+msgstr "Não consegui definir tamanho"
 #: ../raster/r.out.gdal/main.c:288
 #, c-format
@@ -21530,7 +21530,7 @@
 #: ../raster/r.out.gdal/main.c:293
 #, fuzzy
 msgid "Unable to get in-memory raster driver"
-msgstr "Não consegui alocar memória para 'string'"
+msgstr "Não consegui alocar memória para 'string'"
 #: ../raster/r.out.gdal/main.c:297
 #, c-format
@@ -21540,7 +21540,7 @@
 #: ../raster/r.out.gdal/main.c:372
 #, fuzzy, c-format
 msgid "Could not read data range of raster <%s>"
-msgstr "Não consegui escrever em <%s>"
+msgstr "Não consegui escrever em <%s>"
 #: ../raster/r.out.gdal/main.c:429
 #, c-format
@@ -21605,22 +21605,22 @@
 #: ../raster/r.out.gdal/main.c:558
 #, fuzzy
 msgid "Unable to create dataset using memory raster driver"
-msgstr "Não conseguir abrir banco de dados %s com driver %s"
+msgstr "Não conseguir abrir banco de dados %s com driver %s"
 #: ../raster/r.out.gdal/main.c:567
 #, fuzzy, c-format
 msgid "Unable to create <%s> dataset using <%s> driver"
 #: ../raster/r.out.gdal/main.c:582
 #, fuzzy
 msgid "Unable to set geo transform"
-msgstr "Impossível definir usuário/senha"
+msgstr "Impossível definir usuário/senha"
 #: ../raster/r.out.gdal/main.c:590
 #, fuzzy
 msgid "Unable to set projection"
 #: ../raster/r.out.gdal/main.c:618
 #, fuzzy, c-format
@@ -21635,12 +21635,12 @@
 #: ../raster/r.out.gdal/main.c:634
 #, fuzzy, c-format
 msgid "Unable to export raster map <%s>"
 #: ../raster/r.out.gdal/main.c:650
 #, fuzzy, c-format
 msgid "Unable to create raster map <%s> using driver <%s>"
-msgstr "Não consegui abrir mapa raster [%s] em [%s]"
+msgstr "Não consegui abrir mapa raster [%s] em [%s]"
 #: ../raster/r.out.gdal/main.c:673 ../raster/r.out.gdal/main.c:685
 #: ../raster/r.out.gdal/main.c:698 ../raster/r.out.gdal/main.c:711
@@ -21721,7 +21721,7 @@
 #: ../raster/r.out.gdal/export_band.c:344
 #, fuzzy
 msgid "Unable to allocate buffer for reading raster map"
 #: ../raster/r.out.gdal/export_band.c:156
 #, fuzzy, c-format
@@ -21761,14 +21761,14 @@
 #: ../raster/r.out.gdal/export_band.c:228
 #, fuzzy
 msgid "Unable to get raster band"
 #: ../raster/r.out.gdal/export_band.c:381
 #: ../raster/r.out.gdal/export_band.c:410
 #: ../raster/r.out.gdal/export_band.c:439
 #, fuzzy
 msgid "Unable to write GDAL raster file"
-msgstr "Não consegui escrever o arquivo temporário."
+msgstr "Não consegui escrever o arquivo temporário."
 #: ../raster/r.out.gdal/export_band.c:466
 #: ../raster/r.out.gdal/export_band.c:478
@@ -21784,16 +21784,16 @@
 #: ../raster/r.out.gdal/attr.c:140 ../raster/r.out.gdal/attr.c:178
 #, fuzzy
 msgid "Failed to set raster attribute table"
 #: ../raster/r.out.mat/main.c:64
 msgid "Exports a GRASS raster to a binary MAT-File."
-msgstr "Exporta um raster do GRASS para um arquivo MAT binário"
+msgstr "Exporta um raster do GRASS para um arquivo MAT binário"
 #: ../raster/r.out.mat/main.c:73
 #, fuzzy
 msgid "Name for output binary MAT file"
-msgstr "Nome do arquivo MAT de saída"
+msgstr "Nome do arquivo MAT de saída"
 #: ../raster/r.out.mat/main.c:113
 #, c-format
@@ -21802,7 +21802,7 @@
 #: ../raster/r.out.mat/main.c:173
 msgid "Using the Current Region settings:"
-msgstr "Usando as configurações da Região atual:"
+msgstr "Usando as configurações da Região atual:"
 #: ../raster/r.out.mat/main.c:248
 msgid "Exporting raster as integer values"
@@ -21837,27 +21837,27 @@
 #: ../raster/r.external.out/main.c:132
 #, fuzzy
 msgid "Unable to open GDAL file"
-msgstr "Não consegui criar face"
+msgstr "Não consegui criar face"
 #: ../raster/r.external.out/main.c:156 ../vector/v.external.out/format.c:49
 #, fuzzy, c-format
 msgid "Format <%s> not supported"
-msgstr "Tipo da coluna não suportado"
+msgstr "Tipo da coluna não suportado"
 #: ../raster/r.external.out/main.c:162
 #, fuzzy, c-format
 msgid "Format <%s> does not support direct write"
-msgstr "formato 'point' não é suportado para versão antiga"
+msgstr "formato 'point' não é suportado para versão antiga"
 #: ../raster/r.external.out/main.c:166 ../vector/v.external.out/format.c:52
 #, fuzzy, c-format
 msgid "Format <%s> does not support writing"
 #: ../raster/r.external.out/main.c:214
 #, fuzzy
 msgid "Unable to create GDAL file"
 #: ../raster/r.external.out/main.c:217
 #, fuzzy
@@ -21867,7 +21867,7 @@
 #: ../raster/r.external.out/main.c:237 ../vector/v.external.out/main.c:45
 #, fuzzy
 msgid "output"
 #: ../raster/r.external.out/main.c:240
 msgid "Defines raster output format utilizing GDAL library."
@@ -21876,23 +21876,23 @@
 #: ../raster/r.external.out/main.c:244
 #, fuzzy
 msgid "Name of output directory"
-msgstr "Nome do arquivo de saída"
+msgstr "Nome do arquivo de saída"
 #: ../raster/r.external.out/main.c:251
 #, fuzzy
 msgid "Extension for output files"
 #: ../raster/r.external.out/main.c:257
 #, fuzzy
 msgid "Format of output files"
 #: ../raster/r.external.out/main.c:264 ../vector/v.external.out/args.c:39
 #: ../vector/v.out.postgis/args.c:52
 #, fuzzy
 msgid "Creation options"
 #: ../raster/r.external.out/main.c:277
 msgid "Cease using GDAL and revert to native output"
@@ -21901,7 +21901,7 @@
 #: ../raster/r.external.out/main.c:282 ../vector/v.external.out/args.c:74
 #, fuzzy
 msgid "Print current status"
-msgstr "para padrão atual Pesquisa"
+msgstr "para padrão atual Pesquisa"
 #: ../raster/r.volume/main.c:77
 #, fuzzy
@@ -21943,7 +21943,7 @@
 #: ../raster/r.volume/main.c:110
 #, fuzzy
 msgid "Generate unformatted report (items separated by colon)"
-msgstr "sem cabeçalho no relatório"
+msgstr "sem cabeçalho no relatório"
 #: ../raster/r.volume/main.c:143
 msgid ""
@@ -21968,7 +21968,7 @@
 #: ../raster/r.volume/main.c:233
 #, fuzzy, c-format
 msgid "From '%s' on raster map <%s> using clumps from <%s>"
 #: ../raster/r.volume/main.c:266
 #, c-format
@@ -22002,16 +22002,16 @@
 "Provides surface interpolation from raster point data by Inverse Distance "
 "Squared Weighting."
 msgstr ""
-"Interpolação de superfícies a partir de dados pontuais pelo Inverso do "
-"Quadrado da Distância"
+"Interpolação de superfícies a partir de dados pontuais pelo Inverso do "
+"Quadrado da Distância"
 #: ../raster/r.surf.idw/main.c:119 ../vector/v.surf.idw/main.c:113
 msgid "Number of interpolation points"
-msgstr "Número de pontos de interpolação"
+msgstr "Número de pontos de interpolação"
 #: ../raster/r.surf.idw/main.c:124
 msgid "Output is the interpolation error"
-msgstr "Saída é o erro de interpolação"
+msgstr "Saída é o erro de interpolação"
 #: ../raster/r.surf.idw/main.c:130
 #, c-format
@@ -22033,7 +22033,7 @@
 #: ../raster/r.ros/main.c:218
 #, fuzzy
 msgid "Generates rate of spread raster maps."
-msgstr "Gera estatísticas areais para os mapas raster."
+msgstr "Gera estatísticas areais para os mapas raster."
 #: ../raster/r.ros/main.c:220
 #, fuzzy
@@ -22043,14 +22043,14 @@
 "maximum ROS, and optionally the maximum potential spotting distance for fire "
 "spread simulation."
 msgstr ""
-"Gera três ou quatro camadas de mapa raster exibindo 1) razão de espalhamento "
-"(RdE) base (perpendicular), 2) máxima RdE (avanço), 3) direção da máxima RdE "
-"e opcionalmente 4) a máxima distância potencial de avistamento"
+"Gera três ou quatro camadas de mapa raster exibindo 1) razão de espalhamento "
+"(RdE) base (perpendicular), 2) máxima RdE (avanço), 3) direção da máxima RdE "
+"e opcionalmente 4) a máxima distância potencial de avistamento"
 #: ../raster/r.ros/main.c:227
 #, fuzzy
 msgid "Raster map containing fuel models"
-msgstr "Nome do mapa raster contendo MODELOS de combustível"
+msgstr "Nome do mapa raster contendo MODELOS de combustível"
 #: ../raster/r.ros/main.c:229
 msgid ""
@@ -22062,12 +22062,12 @@
 #: ../raster/r.ros/main.c:238
 #, fuzzy
 msgid "Raster map containing the 1-hour fuel moisture (%)"
-msgstr "Nome do mapa raster contendo umidade (%) do combustível em 1 hora"
+msgstr "Nome do mapa raster contendo umidade (%) do combustível em 1 hora"
 #: ../raster/r.ros/main.c:248
 #, fuzzy
 msgid "Raster map containing the 10-hour fuel moisture (%)"
-msgstr "Nome do mapa raster contendo umidade (%) do combustível em 10 horas"
+msgstr "Nome do mapa raster contendo umidade (%) do combustível em 10 horas"
 #: ../raster/r.ros/main.c:250
 msgid ""
@@ -22079,7 +22079,7 @@
 #: ../raster/r.ros/main.c:258
 #, fuzzy
 msgid "Raster map containing the 100-hour fuel moisture (%)"
-msgstr "Nome do mapa raster contendo umidade (%) do combustível em 100 horas"
+msgstr "Nome do mapa raster contendo umidade (%) do combustível em 100 horas"
 #: ../raster/r.ros/main.c:260
 msgid ""
@@ -22103,12 +22103,12 @@
 #: ../raster/r.ros/main.c:277
 #, fuzzy
 msgid "Raster map containing midflame wind velocities (ft/min)"
-msgstr "Nome do mapa raster contendo velocidade do vento das chamas (pés/min)"
+msgstr "Nome do mapa raster contendo velocidade do vento das chamas (pés/min)"
 #: ../raster/r.ros/main.c:287
 #, fuzzy
 msgid "Name of raster map containing wind directions (degree)"
-msgstr "Nome do mapa raster contendo direção do vento (graus)"
+msgstr "Nome do mapa raster contendo direção do vento (graus)"
 #: ../raster/r.ros/main.c:289
 msgid ""
@@ -22131,7 +22131,7 @@
 #, fuzzy
 msgid "Raster map containing aspect (degree, CCW from E)"
 msgstr ""
-"Nome do mapa raster contendo a direção das encostas (graus, anti-horário a "
+"Nome do mapa raster contendo a direção das encostas (graus, anti-horário a "
 "partir do Leste)"
 #: ../raster/r.ros/main.c:309
@@ -22144,7 +22144,7 @@
 #: ../raster/r.ros/main.c:317
 #, fuzzy
 msgid "Raster map containing elevation (m, required for spotting)"
-msgstr "Nome do mapa raster contendo elevação (m) (requer w/-s)"
+msgstr "Nome do mapa raster contendo elevação (m) (requer w/-s)"
 #: ../raster/r.ros/main.c:319
 msgid ""
@@ -22174,7 +22174,7 @@
 #: ../raster/r.ros/main.c:344
 #, fuzzy
 msgid "Output raster map containing directions of maximal ROS (degree)"
-msgstr "Nome do mapa raster contendo as direções das máximas RdE (graus)"
+msgstr "Nome do mapa raster contendo as direções das máximas RdE (graus)"
 #: ../raster/r.ros/main.c:346
 msgid "The direction of the maximal (forward) rate of spread (ROS)"
@@ -22184,7 +22184,7 @@
 #, fuzzy
 msgid "Output raster map containing maximal spotting distance (m)"
 msgstr ""
-"Nome do mapa raster contendo máxima distância de avistamento (m) (requer w/-"
+"Nome do mapa raster contendo máxima distância de avistamento (m) (requer w/-"
 "s)"
 #: ../raster/r.ros/main.c:354
@@ -22230,7 +22230,7 @@
 #: ../raster/r.ros/main.c:873
 #, fuzzy, c-format
 msgid "Raster maps <%s>, <%s> and <%s> created."
-msgstr "O vetor '%s' já existe."
+msgstr "O vetor '%s' já existe."
 #: ../raster/r.flow/main.c:423
 msgid "Constructs flowlines."
@@ -22257,12 +22257,12 @@
 #: ../raster/r.flow/main.c:447
 #, fuzzy
 msgid "Number of cells between flowlines"
-msgstr "Número de cópias"
+msgstr "Número de cópias"
 #: ../raster/r.flow/main.c:453
 #, fuzzy
 msgid "Maximum number of segments per flowline"
-msgstr "Número de iterações máximas"
+msgstr "Número de iterações máximas"
 #: ../raster/r.flow/main.c:458
 #, fuzzy
@@ -22277,12 +22277,12 @@
 #: ../raster/r.flow/main.c:470
 #, fuzzy
 msgid "Name for output flow accumulation raster map"
 #: ../raster/r.flow/main.c:476
 #, fuzzy
 msgid "Compute upslope flowlines instead of default downhill flowlines"
-msgstr "Computar de padrão"
+msgstr "Computar de padrão"
 #: ../raster/r.flow/main.c:480
 #, fuzzy
@@ -22304,18 +22304,18 @@
 "lat/long projection not supported by r.flow. Please use 'r.watershed' for "
 "calculating flow accumulation."
 msgstr ""
-"Bancos de dados lat/long não são suportados por r.flow. Use 'r.watershed' "
+"Bancos de dados lat/long não são suportados por r.flow. Use 'r.watershed' "
 "para calcular fluxo."
 #: ../raster/r.flow/io.c:87
 #, fuzzy
 msgid "Elevation raster map resolution differs from current region resolution"
-msgstr "Elevação atual"
+msgstr "Elevação atual"
 #: ../raster/r.flow/io.c:104
 #, fuzzy
 msgid "Resolution of aspect file differs from current region resolution"
-msgstr "Resolução no perfil (padrão = resolução da região atual)"
+msgstr "Resolução no perfil (padrão = resolução da região atual)"
 #: ../raster/r.flow/io.c:121
 #, fuzzy
@@ -22325,32 +22325,32 @@
 #: ../raster/r.flow/io.c:149
 #, fuzzy, c-format
 msgid "Cannot create segment file %s"
 #: ../raster/r.flow/io.c:154
 #, fuzzy, c-format
 msgid "Cannot format segment file %s"
-msgstr "Não consegui abrir o arquivo %s"
+msgstr "Não consegui abrir o arquivo %s"
 #: ../raster/r.flow/io.c:160
 #, fuzzy, c-format
 msgid "Cannot open segment file %s"
-msgstr "Não consegui abrir arquivo temp %s"
+msgstr "Não consegui abrir arquivo temp %s"
 #: ../raster/r.flow/mem.c:40
 #, fuzzy, c-format
 msgid "Unable to write segment file for %s"
 #: ../raster/r.flow/precomp.c:48
 #, fuzzy
 msgid "Precomputing e/w distances..."
-msgstr "Mapas para computar distâncias entre classes"
+msgstr "Mapas para computar distâncias entre classes"
 #: ../raster/r.flow/precomp.c:50
 #, fuzzy
 msgid "Precomputing quantization tolerances..."
 #: ../raster/r.flow/precomp.c:53
 msgid "Precomputing inverted elevations..."
@@ -22363,12 +22363,12 @@
 #: ../raster/r.flow/precomp.c:63
 #, fuzzy
 msgid "Precomputing re-oriented aspects..."
 #: ../raster/r.flow/precomp.c:67
 #, fuzzy
 msgid "Precomputing aspects..."
 #: ../raster/r.flow/precomp.c:111
 #, c-format
@@ -22399,7 +22399,7 @@
 #: ../raster/r.null/main.c:86
 msgid "Only do the work if the map is floating-point"
-msgstr "Fazer o serviço apenas se o mapa for decimal"
+msgstr "Fazer o serviço apenas se o mapa for decimal"
 #: ../raster/r.null/main.c:87 ../raster/r.null/main.c:92
 #: ../raster/r.null/main.c:98
@@ -22408,13 +22408,13 @@
 #: ../raster/r.null/main.c:91
 msgid "Only do the work if the map is integer"
-msgstr "Fazer o serviço apenas se o mapa for inteiro"
+msgstr "Fazer o serviço apenas se o mapa for inteiro"
 #: ../raster/r.null/main.c:97
 #, fuzzy
 msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
 msgstr ""
-"Fazer o serviço apenas se o mapa não tiver um arquivo bitmap de valores nulos"
+"Fazer o serviço apenas se o mapa não tiver um arquivo bitmap de valores nulos"
 #: ../raster/r.null/main.c:103
 msgid "Create NULL-value bitmap file validating all data cells"
@@ -22439,7 +22439,7 @@
 #: ../raster/r.null/main.c:138
 #, fuzzy, c-format
 msgid "Raster map <%s> is not in your mapset <%s>"
-msgstr "mapa vetorial <%s> não encontrado"
+msgstr "mapa vetorial <%s> não encontrado"
 #: ../raster/r.null/main.c:145
 #, fuzzy, c-format
@@ -22449,17 +22449,17 @@
 #: ../raster/r.null/main.c:152
 #, fuzzy, c-format
 msgid "Raster map <%s> already has a null bitmap file"
 #: ../raster/r.null/main.c:156
 #, fuzzy, c-format
 msgid "<%s> is integer raster map (CELL)"
-msgstr "%s: ERRO não consegui abrir tempfile"
+msgstr "%s: ERRO não consegui abrir tempfile"
 #: ../raster/r.null/main.c:160
 #, fuzzy, c-format
 msgid "<%s> is integer raster map (CELL). Using null=%d."
 #: ../raster/r.null/main.c:166
 #, fuzzy, c-format
@@ -22475,7 +22475,7 @@
 #: ../raster/r.null/main.c:234
 #, fuzzy, c-format
 msgid "Raster map <%s> modified."
-msgstr "mapa raster <%s> não encontrado"
+msgstr "mapa raster <%s> não encontrado"
 #: ../raster/r.null/main.c:227
 #, fuzzy, c-format
@@ -22500,7 +22500,7 @@
 #: ../raster/r.in.gdal/main.c:93
 #, fuzzy
 msgid "Imports raster data into a GRASS raster map using GDAL library."
-msgstr "Importar um arquivo raster binário para uma camada raster do GRASS."
+msgstr "Importar um arquivo raster binário para uma camada raster do GRASS."
 #: ../raster/r.in.gdal/main.c:99
 #, fuzzy
@@ -22510,23 +22510,23 @@
 #: ../raster/r.in.gdal/main.c:108
 #, fuzzy
 msgid "Band(s) to select (default is all bands)"
-msgstr "Banda selecionada (o padrão são todas as bandas)"
+msgstr "Banda selecionada (o padrão são todas as bandas)"
 #: ../raster/r.in.gdal/main.c:123
 #, fuzzy
 msgid "Name of GCPs target location"
-msgstr "Nome de destino da locação da imagem"
+msgstr "Nome de destino da locação da imagem"
 #: ../raster/r.in.gdal/main.c:125
 #, fuzzy
 msgid ""
 "Name of location to create or to read projection from for GCPs transformation"
-msgstr "Nome da locação de onde ler a projeção para transformação dos GCPs"
+msgstr "Nome da locação de onde ler a projeção para transformação dos GCPs"
 #: ../raster/r.in.gdal/main.c:141
 #, fuzzy
 msgid "Offset to be added to band numbers"
-msgstr "Não consegui criar arquivo raster [%s]."
+msgstr "Não consegui criar arquivo raster [%s]."
 #: ../raster/r.in.gdal/main.c:142
 msgid "If 0, no offset is added and the first band is 1"
@@ -22544,17 +22544,17 @@
 #: ../raster/r.in.gdal/main.c:157
 #, fuzzy
 msgid "Name of the output file that contains the imported map names"
-msgstr "Nome do arquivo raster de elevação para entrada (metros)"
+msgstr "Nome do arquivo raster de elevação para entrada (metros)"
 #: ../raster/r.in.gdal/main.c:164 ../vector/v.in.lidar/main.c:270
 #: ../vector/v.in.ogr/main.c:218
 msgid "Name for new location to create"
-msgstr "Nome da nova locação a criar"
+msgstr "Nome da nova locação a criar"
 #: ../raster/r.in.gdal/main.c:171
 #, fuzzy
 msgid "File prefix for raster attribute tables"
 #: ../raster/r.in.gdal/main.c:172
 msgid "The band number and \".csv\" will be appended to the file prefix"
@@ -22563,17 +22563,17 @@
 #: ../raster/r.in.gdal/main.c:185 ../vector/v.in.ogr/main.c:291
 #, fuzzy
 msgid "Perform projection check only and exit"
-msgstr "mostra os parâmetros de conexão atuais e finaliza"
+msgstr "mostra os parâmetros de conexão atuais e finaliza"
 #: ../raster/r.in.gdal/main.c:204
 #: ../locale/scriptstrings/r.import_to_translate.c:30
 msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
 msgstr ""
-"Força mapas Lat/Lon a se ajustarem em coordenadas geográficas (90N,S; 180E,W)"
+"Força mapas Lat/Lon a se ajustarem em coordenadas geográficas (90N,S; 180E,W)"
 #: ../raster/r.in.gdal/main.c:209
 msgid "Keep band numbers instead of using band color names"
-msgstr "Manter os números das bandas em vez de usar os nomes das cores"
+msgstr "Manter os números das bandas em vez de usar os nomes das cores"
 #: ../raster/r.in.gdal/main.c:214
 msgid ""
@@ -22588,7 +22588,7 @@
 #: ../raster/r.in.gdal/main.c:247
 msgid "You have to specify a target location different from output location"
-msgstr "Você tem que especificar uma locação alvo diferente da locação saída"
+msgstr "Você tem que especificar uma locação alvo diferente da locação saída"
 #: ../raster/r.in.gdal/main.c:251
 #, fuzzy
@@ -22597,7 +22597,7 @@
 #: ../raster/r.in.gdal/main.c:255
 msgid "The '-l' flag only works in Lat/Lon locations"
-msgstr "A opção '-l' funciona apenas em locações Lat/Lon"
+msgstr "A opção '-l' funciona apenas em locações Lat/Lon"
 #: ../raster/r.in.gdal/main.c:258
 msgid "The number of digits for band numbering must be equal or greater than 0"
@@ -22611,7 +22611,7 @@
 #: ../raster/r.in.gdal/main.c:319
 #, fuzzy, c-format
 msgid "Unable to open datasource <%s>"
 #: ../raster/r.in.gdal/main.c:330
 #, c-format
@@ -22639,36 +22639,36 @@
 "Unable to convert input map projection to GRASS format; cannot create new "
 "location."
 msgstr ""
-"Não consegui converter a projeção do mapa de entrada para o formato do "
-"GRASS, não posso criar nova locação."
+"Não consegui converter a projeção do mapa de entrada para o formato do "
+"GRASS, não posso criar nova locação."
 #: ../raster/r.in.gdal/main.c:436 ../raster/r.in.gdal/main.c:843
 #: ../vector/v.in.lidar/main.c:511 ../vector/v.in.ogr/main.c:581
 #, fuzzy, c-format
 msgid "Unable to create new location <%s>"
 #: ../raster/r.in.gdal/main.c:439 ../raster/r.in.gdal/main.c:849
 #: ../general/g.proj/create.c:15 ../vector/v.in.lidar/main.c:514
 #: ../vector/v.in.ogr/main.c:584
 #, c-format
 msgid "Location <%s> created"
-msgstr "Locação <%s> criada"
+msgstr "Locação <%s> criada"
 #: ../raster/r.in.gdal/main.c:577
 #, fuzzy, c-format
 msgid "Proceeding with import of %d raster bands..."
-msgstr "Seguindo com a importação..."
+msgstr "Seguindo com a importação..."
 #: ../raster/r.in.gdal/main.c:634
 #, fuzzy
 msgid "Unable to open the map names output text file"
-msgstr "Não consegui abrir o arquivo de assinatura."
+msgstr "Não consegui abrir o arquivo de assinatura."
 #: ../raster/r.in.gdal/main.c:665
 #, fuzzy, c-format
 msgid "Unable to get raster band number %d"
 #: ../raster/r.in.gdal/main.c:742
 #, c-format
@@ -22686,17 +22686,17 @@
 #: ../raster/r.in.gdal/main.c:774
 #, c-format
 msgid "* Input projection for GCP table: %s"
-msgstr "* Projeção de entrada para a tabela GCP: %s"
+msgstr "* Projeção de entrada para a tabela GCP: %s"
 #: ../raster/r.in.gdal/main.c:776
 #, c-format
 msgid "* Output projection for GCP table: %s"
-msgstr "* Projeção de saída para a tabela GCP: %s"
+msgstr "* Projeção de saída para a tabela GCP: %s"
 #: ../raster/r.in.gdal/main.c:797
 #, c-format
 msgid "Error in pj_do_proj (can't re-projection GCP %i)"
-msgstr "Erro em pj_do_proj (Não posso re-projetar GCP %i)"
+msgstr "Erro em pj_do_proj (Não posso re-projetar GCP %i)"
 #: ../raster/r.in.gdal/main.c:852
 #, c-format
@@ -22707,19 +22707,19 @@
 #: ../raster/r.in.gdal/main.c:923
 msgid "Unable to translate projection key values of input GCPs"
-msgstr "Não consegui traduzir valores chave de projeção das entradas GCPs"
+msgstr "Não consegui traduzir valores chave de projeção das entradas GCPs"
 #: ../raster/r.in.gdal/main.c:939
 msgid "Unable to get projection info of target location"
-msgstr "Não consegui informações de projeção da locação destino"
+msgstr "Não consegui informações de projeção da locação destino"
 #: ../raster/r.in.gdal/main.c:941
 msgid "Unable to get projection units of target location"
-msgstr "Não consegui unidades de projeção da locação alvo"
+msgstr "Não consegui unidades de projeção da locação alvo"
 #: ../raster/r.in.gdal/main.c:943
 msgid "Unable to get projection key values of target location"
-msgstr "Não obtive os valores chave de projeção da locação alvo"
+msgstr "Não obtive os valores chave de projeção da locação alvo"
 #: ../raster/r.in.gdal/main.c:982
 #, fuzzy, c-format
@@ -22745,7 +22745,7 @@
 #: ../raster/r.in.gdal/main.c:1607
 #, fuzzy, c-format
 msgid "Unable to open file <%s>: %s."
-msgstr "Não consegui abrir o arquivo de células [%s]"
+msgstr "Não consegui abrir o arquivo de células [%s]"
 #: ../raster/r.distance/distance.c:102
 #, c-format
@@ -22755,17 +22755,17 @@
 #: ../raster/r.distance/parse.c:35
 #, fuzzy
 msgid "Name of two input raster maps for computing inter-class distances"
 #: ../raster/r.distance/parse.c:45
 #, fuzzy
 msgid "Sort output by distance"
 #: ../raster/r.distance/parse.c:46
 #, fuzzy
 msgid "Default: sorted by categories"
-msgstr "Título do raster de saída"
+msgstr "Título do raster de saída"
 #: ../raster/r.distance/parse.c:50
 msgid "Sort by distance in ascending order"
@@ -22790,7 +22790,7 @@
 #: ../raster/r.distance/parse.c:74 ../raster/r.distance/parse.c:83
 #, fuzzy, c-format
 msgid "Raster map <%s> is not CELL"
-msgstr "Mapa raster <%s> não encontrado"
+msgstr "Mapa raster <%s> não encontrado"
 #: ../raster/r.distance/report.c:61
 #, fuzzy
@@ -22799,7 +22799,7 @@
 #: ../raster/r.distance/main.c:42
 msgid "Locates the closest points between objects in two raster maps."
-msgstr "Localiza os pontos mais próximos entre objetos de dois mapas raster."
+msgstr "Localiza os pontos mais próximos entre objetos de dois mapas raster."
 #: ../raster/r.distance/edges.c:47
 #, fuzzy, c-format
@@ -22814,12 +22814,12 @@
 #: ../raster/r.water.outlet/main.c:62
 #, fuzzy
 msgid "Name of input drainage direction map"
 #: ../raster/r.water.outlet/main.c:65
 #, fuzzy
 msgid "Name for output watershed basin map"
 #: ../raster/r.water.outlet/main.c:68
 #, fuzzy
@@ -22839,12 +22839,12 @@
 #: ../raster/r.water.outlet/main.c:88
 #, fuzzy, c-format
 msgid "Ignoring point outside computation region: %.4f,%.4f"
-msgstr "Atenção, ignorando ponto fora da janela: %.4f,%.4f"
+msgstr "Atenção, ignorando ponto fora da janela: %.4f,%.4f"
 #: ../raster/r.surf.gauss/main.c:42
 #, fuzzy
 msgid "Generates a raster map using gaussian random number generator."
-msgstr "Gera um mapa raster com áreas contíguas acrescidas de uma célula"
+msgstr "Gera um mapa raster com áreas contíguas acrescidas de uma célula"
 #: ../raster/r.surf.gauss/main.c:44
 #, fuzzy
@@ -22852,32 +22852,32 @@
 "Mean and standard deviation of gaussian deviates can be expressed by the "
 "user."
 msgstr ""
-"Produz uma camada de mapa raster com desvios aleatórios uniformes, cujo "
-"intervalo pode ser expresso pelo usuário."
+"Produz uma camada de mapa raster com desvios aleatórios uniformes, cujo "
+"intervalo pode ser expresso pelo usuário."
 #: ../raster/r.surf.gauss/main.c:51
 msgid "Distribution mean"
-msgstr "Média da distribuição"
+msgstr "Média da distribuição"
 #: ../raster/r.surf.gauss/main.c:57
 msgid "Standard deviation"
-msgstr "Desvio padrão"
+msgstr "Desvio padrão"
 #: ../raster/r.out.ppm3/main.c:59
 #, fuzzy
 msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
 msgstr ""
-"Converte 3 camadas raster do GRASS (R,G,B) em uma imagem PPM na resolução da "
-"região atualmente definida."
+"Converte 3 camadas raster do GRASS (R,G,B) em uma imagem PPM na resolução da "
+"região atualmente definida."
 #: ../raster/r.out.ppm3/main.c:84
 #, fuzzy
 msgid "Name for new PPM file. (use '-' for stdout)"
-msgstr "Nome para novo arquivo PPM. (use out=- para saída padrão)"
+msgstr "Nome para novo arquivo PPM. (use out=- para saída padrão)"
 #: ../raster/r.out.ppm3/main.c:88
 msgid "Add comments to describe the region"
-msgstr "Adicionar comentário para descrever a região"
+msgstr "Adicionar comentário para descrever a região"
 #: ../raster/r.out.ppm3/main.c:160
 #, fuzzy
@@ -22887,7 +22887,7 @@
 #: ../raster/r.in.ascii/main.c:74
 #, fuzzy
 msgid "Converts a GRASS ASCII raster file to binary raster map."
-msgstr "Converte um arquivo raster ASCII para um mapa raster binário."
+msgstr "Converte um arquivo raster ASCII para um mapa raster binário."
 #: ../raster/r.in.ascii/main.c:85
 #, fuzzy
@@ -22897,7 +22897,7 @@
 #: ../raster/r.in.ascii/main.c:97 ../raster/r.in.ascii/main.c:102
 #, fuzzy
 msgid "Default: read from header"
-msgstr "Não consegui ler cabeçalho do arquivo BMP"
+msgstr "Não consegui ler cabeçalho do arquivo BMP"
 #: ../raster/r.in.ascii/main.c:99
 #, fuzzy
@@ -22906,7 +22906,7 @@
 #: ../raster/r.in.ascii/main.c:103
 msgid "String representing NULL value data cell"
-msgstr "Texto para representar célula sem valor de dados"
+msgstr "Texto para representar célula sem valor de dados"
 #: ../raster/r.in.ascii/main.c:104
 msgid "NULL data"
@@ -22915,7 +22915,7 @@
 #: ../raster/r.in.ascii/main.c:109
 #, fuzzy
 msgid "SURFER (Golden Software) ASCII file will be imported"
-msgstr "Grid ASCII do SURFER (Golden Software) será importado"
+msgstr "Grid ASCII do SURFER (Golden Software) será importado"
 #: ../raster/r.in.ascii/main.c:128
 #, c-format
@@ -22925,17 +22925,17 @@
 #: ../raster/r.in.ascii/main.c:160
 #, fuzzy, c-format
 msgid "Unable to read input from <%s>"
-msgstr "Não consegui ler linha %i\n"
+msgstr "Não consegui ler linha %i\n"
 #: ../raster/r.in.ascii/main.c:180
 #, fuzzy
 msgid "Can't get cell header"
-msgstr "Não consegui criar camada"
+msgstr "Não consegui criar camada"
 #: ../raster/r.in.ascii/main.c:202
 #, fuzzy, c-format
 msgid "Data conversion failed at row %d, col %d"
-msgstr "conversão"
+msgstr "conversão"
 #: ../raster/r.in.ascii/gethead.c:35
 msgid "input file is not a Surfer ascii grid file"
@@ -22960,7 +22960,7 @@
 #: ../raster/r.in.ascii/gethead.c:105
 #, fuzzy
 msgid "error getting file position"
-msgstr "Posição de referência"
+msgstr "Posição de referência"
 #: ../raster/r.in.ascii/gethead.c:164
 msgid "illegal type field: using type int"
@@ -22985,7 +22985,7 @@
 #: ../raster/r.in.ascii/gethead.c:218
 #, fuzzy
 msgid "error in ascii data format"
-msgstr "%d erros na opção cat"
+msgstr "%d erros na opção cat"
 #: ../raster/r.in.ascii/gethead.c:248
 #, c-format
@@ -23019,52 +23019,52 @@
 #: ../raster/r.recode/main.c:54
 #, fuzzy
 msgid "Name of raster map to be recoded"
-msgstr "Nome do mapa de orientação para exibição"
+msgstr "Nome do mapa de orientação para exibição"
 #: ../raster/r.recode/main.c:60
 #, fuzzy
 msgid "File containing recode rules"
-msgstr "Arquivo contendo declarações SQL"
+msgstr "Arquivo contendo declarações SQL"
 #: ../raster/r.recode/main.c:71
 #, fuzzy
 msgid "Align the current region to the input raster map"
-msgstr "Alinhar a região atual pelo mapa de entrada"
+msgstr "Alinhar a região atual pelo mapa de entrada"
 #: ../raster/r.recode/main.c:75
 #, fuzzy
 msgid "Force output to 'double' raster map type (DCELL)"
-msgstr "Forçar saída para mapa tipo 'double' (DCELL)"
+msgstr "Forçar saída para mapa tipo 'double' (DCELL)"
 #: ../raster/r.recode/main.c:96
 #, fuzzy, c-format
 msgid "No rules specified. Raster map <%s> not created."
-msgstr "Arquivo de células [%s] não encontrado"
+msgstr "Arquivo de células [%s] não encontrado"
 #: ../raster/r.recode/read_rules.c:20
 #, fuzzy, c-format
 msgid "Unable to read f_range for map %s"
-msgstr "%s: não consegui criar %s"
+msgstr "%s: não consegui criar %s"
 #: ../raster/r.recode/read_rules.c:24 ../display/d.colortable/main.c:146
 #, fuzzy
 msgid "Data range is empty"
-msgstr "O intervalo de dados é de %ld a %ld\n"
+msgstr "O intervalo de dados é de %ld a %ld\n"
 #: ../raster/r.recode/read_rules.c:30
 #, fuzzy, c-format
 msgid "Data range of %s is %s to %s (entire map)"
-msgstr "fp: intervalo de dados é %.25f a %.25f\n"
+msgstr "fp: intervalo de dados é %.25f a %.25f\n"
 #: ../raster/r.recode/read_rules.c:39
 #, fuzzy, c-format
 msgid "Integer data range of %s is empty"
 #: ../raster/r.recode/read_rules.c:41
 #, fuzzy, c-format
 msgid "Integer data range of %s is %d to %d"
 #: ../raster/r.recode/read_rules.c:61
 #, fuzzy
@@ -23099,13 +23099,13 @@
 #: ../raster/r.recode/read_rules.c:126 ../raster/r.quant/read_rules.c:158
 #, fuzzy, c-format
 msgid "%s is not a valid rule"
-msgstr "é não mapear"
+msgstr "é não mapear"
 #: ../raster/r.sunmask/main.c:120
 #, fuzzy
 msgid ""
 "Calculates cast shadow areas from sun position and elevation raster map."
 #: ../raster/r.sunmask/main.c:121
 #, fuzzy
@@ -23113,9 +23113,9 @@
 "Either exact sun position (A) is specified, or date/time to calculate the "
 "sun position (B) by r.sunmask itself."
 msgstr ""
-"Calcula áreas de sombra a partir da posição do sol e de um modelo de "
-"elevação digital. Deve ser especificada A: posição exata do sol ou B: data e "
-"hora para cálculo da posição por r.sunmask."
+"Calcula áreas de sombra a partir da posição do sol e de um modelo de "
+"elevação digital. Deve ser especificada A: posição exata do sol ou B: data e "
+"hora para cálculo da posição por r.sunmask."
 #: ../raster/r.sunmask/main.c:135
 #, fuzzy
@@ -23170,8 +23170,8 @@
 #, fuzzy
 msgid "East positive, offset from GMT, also use to adjust daylight savings"
 msgstr ""
-"B: fuso horário (leste positivo, diferença de GMT, também usar para "
-"compensar horário de verão)"
+"B: fuso horário (leste positivo, diferença de GMT, também usar para "
+"compensar horário de verão)"
 #: ../raster/r.sunmask/main.c:211
 #, fuzzy
@@ -23190,16 +23190,16 @@
 #: ../raster/r.sunmask/main.c:227
 #, fuzzy
 msgid "Do not ignore zero elevation"
-msgstr "Nome do mapa raster de elevação"
+msgstr "Nome do mapa raster de elevação"
 #: ../raster/r.sunmask/main.c:231
 #, fuzzy
 msgid "Calculate sun position only and exit"
-msgstr "apenas calcula a posição do Sol e encerra"
+msgstr "apenas calcula a posição do Sol e encerra"
 #: ../raster/r.sunmask/main.c:237
 msgid "Print the sun position output in shell script style"
-msgstr "Imprime a posição do sol no estilo shell script"
+msgstr "Imprime a posição do sol no estilo shell script"
 #: ../raster/r.sunmask/main.c:251
 #, fuzzy, c-format
@@ -23219,7 +23219,7 @@
 #: ../raster/r.sunmask/main.c:279
 #, fuzzy
 msgid "Either define sun position or location/date/time parameters"
-msgstr "Defina a posição do sol ou parâmetros de local/data/hora."
+msgstr "Defina a posição do sol ou parâmetros de local/data/hora."
 #: ../raster/r.sunmask/main.c:282
 #, fuzzy
@@ -23227,13 +23227,13 @@
 "Neither sun position nor east/north, date/time/timezone definition are "
 "complete"
 msgstr ""
-"Nem a posição do sol nem as definições de norte/leste data/hora/fuso horário "
-"estão completas."
+"Nem a posição do sol nem as definições de norte/leste data/hora/fuso horário "
+"estão completas."
 #: ../raster/r.sunmask/main.c:286
 #, fuzzy, c-format
 msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
-msgstr "Calculando a posição do sol... (usando solpos (V.%s) de NREL)\n"
+msgstr "Calculando a posição do sol... (usando solpos (V.%s) de NREL)\n"
 #: ../raster/r.sunmask/main.c:291
 #, fuzzy
@@ -23241,32 +23241,32 @@
 "Using user defined sun azimuth, altitude settings (ignoring eventual other "
 "values)"
 msgstr ""
-"Usando ajustes de altitude e azimute do sol definidos pelo usuário "
+"Usando ajustes de altitude e azimute do sol definidos pelo usuário "
 "(ignorando eventuais outros valores)\n"
 #: ../raster/r.sunmask/main.c:399
 #, fuzzy
 msgid "Please correct settings"
-msgstr "Por favor corrija opções."
+msgstr "Por favor corrija opções."
 #: ../raster/r.sunmask/main.c:413
 #, fuzzy, c-format
 msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
-msgstr "Hora (%02i:%02i:%02i) é antes do nascente (%02d:%02d:%02d)!\n"
+msgstr "Hora (%02i:%02i:%02i) é antes do nascente (%02d:%02d:%02d)!\n"
 #: ../raster/r.sunmask/main.c:417
 #, fuzzy, c-format
 msgid "Time (%02i:%02i:%02i) is before sunrise"
-msgstr "Hora (%02i:%02i:%02i) é antes do nascente!\n"
+msgstr "Hora (%02i:%02i:%02i) é antes do nascente!\n"
 #: ../raster/r.sunmask/main.c:420 ../raster/r.sunmask/main.c:430
 msgid "Nothing to calculate. Please verify settings."
-msgstr "Nada a calcular. Verifique as opções."
+msgstr "Nada a calcular. Verifique as opções."
 #: ../raster/r.sunmask/main.c:424
 #, fuzzy, c-format
 msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
-msgstr "Hora (%02i:%02i:%02i) é depois do poente (%02d:%02d:%02d)!\n"
+msgstr "Hora (%02i:%02i:%02i) é depois do poente (%02d:%02d:%02d)!\n"
 #: ../raster/r.sunmask/main.c:428
 #, fuzzy, c-format
@@ -23276,17 +23276,17 @@
 #: ../raster/r.sunmask/main.c:439
 #, fuzzy
 msgid "You already know the sun position"
-msgstr "Você já sabe a posição do sol.\n"
+msgstr "Você já sabe a posição do sol.\n"
 #: ../raster/r.sunmask/main.c:444 ../vector/v.colors/main.c:199
 #, fuzzy, c-format
 msgid "Option <%s> required"
-msgstr "Locação: %s\n"
+msgstr "Locação: %s\n"
 #: ../raster/r.sunmask/main.c:456
 #, fuzzy, c-format
 msgid "Unable to open range file for raster map <%s>"
 #: ../raster/r.sunmask/main.c:472
 msgid "Calculating shadows from DEM..."
@@ -23308,13 +23308,13 @@
 #: ../raster/r.quant/main.c:49
 #, fuzzy
 msgid "quantization"
-msgstr "Assinaturas para usar na classificação"
+msgstr "Assinaturas para usar na classificação"
 #: ../raster/r.quant/main.c:51
 #, fuzzy
 msgid "Produces the quantization file for a floating-point map."
 msgstr ""
-"Esta rotina produz um arquivo de quantização para um mapa floating point."
+"Esta rotina produz um arquivo de quantização para um mapa floating point."
 #: ../raster/r.quant/main.c:59
 msgid "Raster map(s) to be quantized"
@@ -23327,7 +23327,7 @@
 #: ../raster/r.quant/main.c:70
 msgid "Base map to take quant rules from"
-msgstr "Mapa base do qual tirar as regras de quantização"
+msgstr "Mapa base do qual tirar as regras de quantização"
 #: ../raster/r.quant/main.c:75
 msgid "Floating point range: dmin,dmax"
@@ -23348,7 +23348,7 @@
 #: ../raster/r.quant/main.c:111
 #, fuzzy, c-format
 msgid "-%c, -%c, %s=, %s= and %s= are mutually exclusive"
 #: ../raster/r.quant/main.c:120
 #, fuzzy, c-format
@@ -23377,7 +23377,7 @@
 #: ../raster/r.quant/main.c:156
 #, fuzzy, c-format
 msgid "unable to read quant rules for basemap <%s>"
 #: ../raster/r.quant/main.c:163 ../raster/r.quant/main.c:166
 #, fuzzy, c-format
@@ -23392,12 +23392,12 @@
 #: ../raster/r.quant/main.c:181
 #, fuzzy
 msgid "No rules specified. Quant table(s) not changed."
 #: ../raster/r.quant/main.c:189
 #, fuzzy, c-format
 msgid "New quant table created for %s"
-msgstr "não consegui criar %s"
+msgstr "não consegui criar %s"
 #: ../raster/r.quant/read_rules.c:50
 msgid "Old data range is empty"
@@ -23406,7 +23406,7 @@
 #: ../raster/r.quant/read_rules.c:56
 #, fuzzy, c-format
 msgid "Old data range is %s to %s"
 #: ../raster/r.quant/read_rules.c:59
 msgid "Old integer data range is empty"
@@ -23415,12 +23415,12 @@
 #: ../raster/r.quant/read_rules.c:61
 #, fuzzy, c-format
 msgid "Old integer data range is %d to %d"
 #: ../raster/r.quant/read_rules.c:83
 #, fuzzy, c-format
 msgid "unable to open input file <%s>"
-msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
+msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
 #: ../raster/r.quant/read_rules.c:89
 #, fuzzy, c-format
@@ -23432,12 +23432,12 @@
 #: ../raster/r.quant/read_rules.c:112
 #, fuzzy
 msgid "quant rules do not cover the whole range map"
 #: ../raster/r.neighbors/readweights.c:18
 #, fuzzy, c-format
 msgid "Unable to open weights file %s"
 #: ../raster/r.neighbors/readweights.c:23
 #, fuzzy, c-format
@@ -23447,7 +23447,7 @@
 #: ../raster/r.neighbors/main.c:121
 #, fuzzy, c-format
 msgid "Invalid out_type enumeration: %d"
-msgstr "Fonte inválida: %s"
+msgstr "Fonte inválida: %s"
 #: ../raster/r.neighbors/main.c:175
 msgid ""
@@ -23455,8 +23455,8 @@
 "the cells around it, and stores new cell values in an output raster map "
 "layer."
 msgstr ""
-"Define a categoria de cada célula como função das categorias das células "
-"vizinhas, e grava os novos valores numa camada raster de saída."
+"Define a categoria de cada célula como função das categorias das células "
+"vizinhas, e grava os novos valores numa camada raster de saída."
 #: ../raster/r.neighbors/main.c:185
 #, fuzzy
@@ -23466,23 +23466,23 @@
 #: ../raster/r.neighbors/main.c:204 ../vector/v.neighbors/main.c:72
 msgid "Neighborhood operation"
-msgstr "Operação de vizinhança"
+msgstr "Operação de vizinhança"
 #: ../raster/r.neighbors/main.c:206 ../raster/r.neighbors/main.c:214
 #: ../raster/r.neighbors/main.c:249
 #, fuzzy
 msgid "Neighborhood"
-msgstr "Tamanho da vizinhança"
+msgstr "Tamanho da vizinhança"
 #: ../raster/r.neighbors/main.c:212
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
 msgid "Neighborhood size"
 #: ../raster/r.neighbors/main.c:226
 #, fuzzy
 msgid "Text file containing weights"
 #: ../raster/r.neighbors/main.c:232
 msgid "Sigma (in cells) for Gaussian filter"
@@ -23490,7 +23490,7 @@
 #: ../raster/r.neighbors/main.c:244
 msgid "Do not align output with the input"
-msgstr "Não alinhar saída com a entrada"
+msgstr "Não alinhar saída com a entrada"
 #: ../raster/r.neighbors/main.c:248
 msgid "Use circular neighborhood"
@@ -23499,12 +23499,12 @@
 #: ../raster/r.neighbors/main.c:256
 #, fuzzy
 msgid "Neighborhood size must be positive"
 #: ../raster/r.neighbors/main.c:258
 #, fuzzy
 msgid "Neighborhood size must be odd"
 #: ../raster/r.neighbors/main.c:293
 #, c-format
@@ -23534,8 +23534,8 @@
 "Finds the mode of values in a cover map within areas assigned the same "
 "category value in a user-specified base map."
 msgstr ""
-"Encontra a moda dos valores de um mapa de cobertura dentro de áreas com o "
-"mesmo valor de categoria em um mapa base especificado pelo usuário"
+"Encontra a moda dos valores de um mapa de cobertura dentro de áreas com o "
+"mesmo valor de categoria em um mapa base especificado pelo usuário"
 #: ../raster/r.mode/main.c:64
 msgid "Base map to be reclassified"
@@ -23547,17 +23547,17 @@
 #: ../raster/r.mode/main.c:78
 msgid "Output map"
-msgstr "Saída de mapa"
+msgstr "Saída de mapa"
 #: ../raster/r.mode/main.c:91
 #, fuzzy, c-format
 msgid "%s: Unable to read category labels"
-msgstr "%s: %s em %s - não consegui ler arquivo de categoria"
+msgstr "%s: %s em %s - não consegui ler arquivo de categoria"
 #: ../raster/r.mode/read_stats.c:14
 #, fuzzy
 msgid "reading r.stats output"
-msgstr "Problema na leitura da saída r.stats"
+msgstr "Problema na leitura da saída r.stats"
 #: ../raster/r.walk/main.c:183
 #, fuzzy
@@ -23567,7 +23567,7 @@
 "category values represent cost."
 msgstr ""
 "Gera um mapa raster mostrando o custo acumulado de movimento entre "
-"diferentes localizações em um mapa raster de entrada cujos valores de célula "
+"diferentes localizações em um mapa raster de entrada cujos valores de célula "
 "representam o custo."
 #: ../raster/r.walk/main.c:193
@@ -23595,7 +23595,7 @@
 #: ../raster/r.walk/main.c:377
 #, c-format
 msgid "Missing required value: got %d instead of 4"
-msgstr "Faltando valor necessário: obtive %d ao invés de 4"
+msgstr "Faltando valor necessário: obtive %d ao invés de 4"
 #: ../raster/r.walk/main.c:380
 #, c-format
@@ -23610,12 +23610,12 @@
 #: ../raster/r.walk/main.c:388
 #, fuzzy, c-format
 msgid "Lambda is %g"
-msgstr "Lambda é %lf"
+msgstr "Lambda é %lf"
 #: ../raster/r.walk/main.c:396
 #, fuzzy, c-format
 msgid "Slope_factor is %g"
-msgstr "Slope_factor (fator de declividade) é %lf"
+msgstr "Slope_factor (fator de declividade) é %lf"
 #: ../raster/r.walk/main.c:558
 #, fuzzy, c-format
@@ -23625,7 +23625,7 @@
 #: ../raster/r.walk/main.c:722
 #, fuzzy, c-format
 msgid "No start points found in vector <%s>"
-msgstr "Não consegui encontrar o mapa de entrada <%s>"
+msgstr "Não consegui encontrar o mapa de entrada <%s>"
 #: ../raster/r.walk/main.c:1368
 #, fuzzy, c-format
@@ -23671,7 +23671,7 @@
 #: ../locale/scriptstrings/r.mask_to_translate.c:11
 #, fuzzy
 msgid "Layer number or name (vector)"
-msgstr "Camada número"
+msgstr "Camada número"
 #: ../locale/scriptstrings/r.mask_to_translate.c:13
 #, fuzzy
@@ -23681,7 +23681,7 @@
 #: ../locale/scriptstrings/r.mask_to_translate.c:15
 #, fuzzy
 msgid "WHERE conditions of SQL statement without 'where' keyword (vector)"
-msgstr "de SQL instrução palavra-chave"
+msgstr "de SQL instrução palavra-chave"
 #: ../locale/scriptstrings/r.mask_to_translate.c:17
 #, fuzzy
@@ -23692,7 +23692,7 @@
 #: ../general/g.mapset/main.c:70 ../general/g.proj/main.c:201
 #, fuzzy
 msgid "Create"
 #: ../locale/scriptstrings/r.mask_to_translate.c:19
 msgid "Remove existing mask (overrides other options)"
@@ -23755,7 +23755,7 @@
 #: ../temporal/t.connect/main.c:34
 #, fuzzy
 msgid "temporal"
-msgstr "Tipo de feição"
+msgstr "Tipo de feição"
 #: ../locale/scriptstrings/t.support_to_translate.c:5
 #: ../locale/scriptstrings/t.create_to_translate.c:7
@@ -23872,7 +23872,7 @@
 #: ../locale/scriptstrings/g.manual_to_translate.c:8
 #, fuzzy
 msgid "Display online manuals instead of locally installed"
-msgstr "Desenha uma linha ao invés de escala gráfica"
+msgstr "Desenha uma linha ao invés de escala gráfica"
 #: ../locale/scriptstrings/g.manual_to_translate.c:9
 msgid ""
@@ -23883,7 +23883,7 @@
 #: ../locale/scriptstrings/g.manual_to_translate.c:10
 #, fuzzy
 msgid "Manual entry to be displayed"
-msgstr "Digite o nome da coluna para exibição"
+msgstr "Digite o nome da coluna para exibição"
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:1
 msgid ""
@@ -23894,12 +23894,12 @@
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:6
 #, fuzzy
 msgid "Comma separated list of coordinates"
-msgstr "Lista separada por vírgulas, p.ex.: 1.4,3.8,13"
+msgstr "Lista separada por vírgulas, p.ex.: 1.4,3.8,13"
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:7
 #, fuzzy
 msgid "Name for the output file or \"-\" in case stdout should be used"
-msgstr "Nome de um arquivo para gravar a saída do relatório"
+msgstr "Nome de um arquivo para gravar a saída do relatório"
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:8
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:8
@@ -23916,7 +23916,7 @@
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:10
 #, fuzzy
 msgid "Number of r.what processes to run in parallel"
 #: ../locale/scriptstrings/t.rast.what_to_translate.c:12
 msgid "Use stdin as input and ignore coordinates and point option"
@@ -23925,7 +23925,7 @@
 #: ../locale/scriptstrings/v.build.all_to_translate.c:1
 #, fuzzy
 msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr "Não consegui encontrar o arquivo vetorial %s"
+msgstr "Não consegui encontrar o arquivo vetorial %s"
 #: ../locale/scriptstrings/v.build.all_to_translate.c:3
 #: ../locale/scriptstrings/t.topology_to_translate.c:3
@@ -23954,7 +23954,7 @@
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
 #, fuzzy
 msgid "Name for output table"
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:9
 #, fuzzy
@@ -23984,12 +23984,12 @@
 #: ../vector/v.outlier/main.c:71
 #, fuzzy
 msgid "extract"
-msgstr "Inportação de vetor incompleta"
+msgstr "Inportação de vetor incompleta"
 #: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:7
 #, fuzzy
 msgid "The r3.mapcalc expression assigned to all extracted 3D raster maps"
-msgstr "Mostra os arquivos raster na locação de entrada e encerra"
+msgstr "Mostra os arquivos raster na locação de entrada e encerra"
 #: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:8
 #, fuzzy
@@ -24017,7 +24017,7 @@
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:10
 #, fuzzy
 msgid "Number of r3.mapcalc processes to run in parallel"
 #: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:11
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:10
@@ -24040,7 +24040,7 @@
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:6
 #, fuzzy
 msgid "Tasseled Cap transformation"
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:7
 msgid ""
@@ -24063,7 +24063,7 @@
 #: ../locale/scriptstrings/d.frame_to_translate.c:1
 #, fuzzy
 msgid "Manages display frames on the user's graphics monitor."
-msgstr "Exibe escala gráfica no monitor do GRASS"
+msgstr "Exibe escala gráfica no monitor do GRASS"
 #: ../locale/scriptstrings/d.frame_to_translate.c:4
 #: ../locale/scriptstrings/d.redraw_to_translate.c:4
@@ -24080,7 +24080,7 @@
 #: ../locale/scriptstrings/d.frame_to_translate.c:6
 #, fuzzy
 msgid "Create a new frame if doesn't exist and select"
-msgstr "Criar novo arquivo caso este não exista."
+msgstr "Criar novo arquivo caso este não exista."
 #: ../locale/scriptstrings/d.frame_to_translate.c:7
 #, fuzzy
@@ -24090,12 +24090,12 @@
 #: ../locale/scriptstrings/d.frame_to_translate.c:8
 #, fuzzy
 msgid "Print name of current frame and exit"
 #: ../locale/scriptstrings/d.frame_to_translate.c:9
 #, fuzzy
 msgid "Print names of all frames including 'at' position and exit"
-msgstr "Mostra a extensão da região atual"
+msgstr "Mostra a extensão da região atual"
 #: ../locale/scriptstrings/d.frame_to_translate.c:10
 msgid "Frame to be selected or created (if -c flag is given)"
@@ -24106,8 +24106,8 @@
 msgid ""
 "Screen coordinates in percent where to place the frame (0,0 is lower-left)"
 msgstr ""
-"Posição da tela a partir da qual o texto será desenhado (porcentagem, [0,0] "
-"é o canto inferior direito)"
+"Posição da tela a partir da qual o texto será desenhado (porcentagem, [0,0] "
+"é o canto inferior direito)"
 #: ../locale/scriptstrings/d.frame_to_translate.c:12
 msgid "Implies only when -c or --overwrite flag is given"
@@ -24267,7 +24267,7 @@
 #, fuzzy
 msgid ""
 "Base name for output raster map (band number will be appended to base name)"
 #: ../locale/scriptstrings/db.test_to_translate.c:1
 #, fuzzy
@@ -24284,7 +24284,7 @@
 msgid ""
 "Imports vector data into a GRASS vector map using OGR library and reprojects "
 "on the fly."
-msgstr "Converte vetores OGR para GRASS. Drivers disponíveis:\n"
+msgstr "Converte vetores OGR para GRASS. Drivers disponíveis:\n"
 #: ../locale/scriptstrings/v.import_to_translate.c:5
 #: ../vector/v.in.ogr/main.c:144
@@ -24297,24 +24297,24 @@
 #, fuzzy
 msgid "OGR layer name. If not given, all available layers are imported"
 msgstr ""
-"Vetor de saída, se não for fornecido, camadas disponíveis serão apenas "
+"Vetor de saída, se não for fornecido, camadas disponíveis serão apenas "
 "mostradas"
 #: ../locale/scriptstrings/v.import_to_translate.c:9
 #: ../vector/v.proj/main.c:105
 #, fuzzy
 msgid "Name for output vector map (default: input)"
 #: ../locale/scriptstrings/v.import_to_translate.c:11
 #, fuzzy
 msgid "Output vector map extent"
-msgstr "Gera um mapa das áreas problemáticas"
+msgstr "Gera um mapa das áreas problemáticas"
 #: ../locale/scriptstrings/v.import_to_translate.c:12
 #, fuzzy
 msgid "input;extent of input map;region;extent of current region"
 #: ../locale/scriptstrings/v.import_to_translate.c:15
 #: ../vector/v.in.ogr/main.c:235
@@ -24330,7 +24330,7 @@
 #: ../locale/scriptstrings/v.import_to_translate.c:18
 #: ../vector/v.in.ogr/main.c:212
 msgid "'-1' for no snap"
-msgstr "-1 para não haver snap"
+msgstr "-1 para não haver snap"
 #: ../locale/scriptstrings/v.import_to_translate.c:20
 #: ../locale/scriptstrings/v.import_to_translate.c:22
@@ -24342,7 +24342,7 @@
 #: ../general/g.proj/main.c:159
 #, fuzzy
 msgid "EPSG projection code"
-msgstr "Método de intepolação a usar"
+msgstr "Método de intepolação a usar"
 #: ../locale/scriptstrings/v.import_to_translate.c:23
 #: ../general/g.proj/main.c:181
@@ -24365,14 +24365,14 @@
 #: ../vector/v.in.ogr/main.c:262
 #, fuzzy
 msgid "List available OGR layers in data source and exit"
-msgstr "Lista camadas disponíveis na fonte dos dados e finaliza"
+msgstr "Lista camadas disponíveis na fonte dos dados e finaliza"
 #: ../locale/scriptstrings/v.import_to_translate.c:28
 #: ../locale/scriptstrings/r.import_to_translate.c:32
 #: ../vector/v.in.ogr/main.c:286 ../vector/v.external/args.c:45
 #, fuzzy
 msgid "Assume that the dataset has the same projection as the current location"
-msgstr "Não consegui unidades de projeção da locação atual"
+msgstr "Não consegui unidades de projeção da locação atual"
 #: ../locale/scriptstrings/r.pack_to_translate.c:1
 #, fuzzy
@@ -24389,13 +24389,13 @@
 #: ../locale/scriptstrings/r.pack_to_translate.c:5
 #, fuzzy
 msgid "Name of raster map to pack up"
 #: ../locale/scriptstrings/r.pack_to_translate.c:6
 #: ../locale/scriptstrings/v.pack_to_translate.c:6
 #, fuzzy
 msgid "Name for output file (default is <input>.pack)"
 #: ../locale/scriptstrings/r.pack_to_translate.c:7
 #: ../locale/scriptstrings/v.pack_to_translate.c:7
@@ -24430,14 +24430,14 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:5
 #, fuzzy
 msgid "extensions"
-msgstr "Codificação de caractere"
+msgstr "Codificação de caractere"
 #: ../locale/scriptstrings/g.extension.all_to_translate.c:6
 #: ../locale/scriptstrings/g.extension_to_translate.c:10
 #: ../general/g.mapsets/main.c:81 ../vector/v.net/args.c:36
 #, fuzzy
 msgid "Operation to be performed"
-msgstr "região <%s> não encontrada"
+msgstr "região <%s> não encontrada"
 #: ../locale/scriptstrings/g.extension.all_to_translate.c:7
 msgid "Force operation (required for removal)"
@@ -24451,7 +24451,7 @@
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
 #, fuzzy
 msgid "Input map is in Matlab format"
-msgstr "Entrada mapear é em"
+msgstr "Entrada mapear é em"
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
 #, fuzzy
@@ -24463,12 +24463,12 @@
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
 #, fuzzy
 msgid "Name of input file in Mapgen/Matlab format"
-msgstr "Nome de arquivo de saída para conter relatório"
+msgstr "Nome de arquivo de saída para conter relatório"
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
 #, fuzzy
 msgid "Name for output vector map (omit for display to stdout)"
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
 msgid ""
@@ -24481,19 +24481,19 @@
 msgid ""
 "Name of the new created vector map that stores the sampled values in "
 "different layers"
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:7
 #, fuzzy
 msgid ""
 "Names of the vector columns to be created and to store sampled raster "
 "values, one name for each STRDS"
-msgstr "Nome da coluna de atributo para usar como rótulos"
+msgstr "Nome da coluna de atributo para usar como rótulos"
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:1
 #, fuzzy
 msgid "Imports space time raster dataset."
-msgstr "Nome do mapa raster que conterá os resultados"
+msgstr "Nome do mapa raster que conterá os resultados"
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:8
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:8
@@ -24522,17 +24522,17 @@
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:14
 #, fuzzy
 msgid "Set the current region from the last map that was imported"
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:15
 #, fuzzy
 msgid "Link the raster files using r.external"
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:16
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:12
 msgid "Extend location extents based on new dataset"
-msgstr "Estender locação baseado no novo conjunto de dados"
+msgstr "Estender locação baseado no novo conjunto de dados"
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:19
 msgid ""
@@ -24545,7 +24545,7 @@
 msgid ""
 "Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
 "space time raster datasets."
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:6
@@ -24555,7 +24555,7 @@
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:7
 #, fuzzy
 msgid "Basename for output raster maps"
-msgstr "Nome do Raster de saída"
+msgstr "Nome do Raster de saída"
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:9
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:9
@@ -24563,7 +24563,7 @@
 #: ../locale/scriptstrings/t.rast.extract_to_translate.c:10
 #, fuzzy
 msgid "Number of r.mapcalc processes to run in parallel"
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:11
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:10
@@ -24605,12 +24605,12 @@
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
 #, fuzzy
 msgid "Scale factor for input space time raster dataset"
-msgstr "Nome do raster de saída"
+msgstr "Nome do raster de saída"
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:18
 #, fuzzy
 msgid "Shift factor for input space time raster dataset"
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:19
 msgid ""
@@ -24638,17 +24638,17 @@
 #: ../locale/scriptstrings/i.spectral_to_translate.c:9
 #, fuzzy
 msgid "Name for output image (or text file for -t)"
 #: ../locale/scriptstrings/i.spectral_to_translate.c:11
 #, fuzzy
 msgid "Graphics format for output file"
 #: ../locale/scriptstrings/i.spectral_to_translate.c:13
 #, fuzzy
 msgid "Show sampling coordinates instead of numbering in the legend"
-msgstr "Usar coordenadas do mapa ao invés de xyz"
+msgstr "Usar coordenadas do mapa ao invés de xyz"
 #: ../locale/scriptstrings/i.spectral_to_translate.c:14
 #, fuzzy
@@ -24658,7 +24658,7 @@
 #: ../locale/scriptstrings/i.spectral_to_translate.c:15
 #, fuzzy
 msgid "output to text file"
-msgstr "Arquivo world de saída"
+msgstr "Arquivo world de saída"
 #: ../locale/scriptstrings/v.in.lines_to_translate.c:1
 msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
@@ -24715,7 +24715,7 @@
 #: ../locale/scriptstrings/v.unpack_to_translate.c:7
 #, fuzzy
 msgid "Default: taken from input file internals"
 #: ../locale/scriptstrings/m.proj_to_translate.c:1
 #, fuzzy
@@ -24739,7 +24739,7 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:13
 #, fuzzy
 msgid "Input coordinates"
-msgstr "Coordenadas inválidas %s %s"
+msgstr "Coordenadas inválidas %s %s"
 #: ../locale/scriptstrings/m.proj_to_translate.c:7
 #, fuzzy
@@ -24772,17 +24772,17 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:16
 #, fuzzy
 msgid "Output projection parameters (PROJ.4 style)"
-msgstr "Gera uma mapa de direções"
+msgstr "Gera uma mapa de direções"
 #: ../locale/scriptstrings/m.proj_to_translate.c:18
 #, fuzzy
 msgid "Use LL WGS84 as input and current location as output projection"
-msgstr "Uso atual localização"
+msgstr "Uso atual localização"
 #: ../locale/scriptstrings/m.proj_to_translate.c:20
 #, fuzzy
 msgid "Use current location as input and LL WGS84 as output projection"
 #: ../locale/scriptstrings/m.proj_to_translate.c:22
 #, fuzzy
@@ -24794,12 +24794,12 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:24
 #, fuzzy
 msgid "Include input coordinates in output file"
-msgstr "Coordenadas de entrada não foram informadas"
+msgstr "Coordenadas de entrada não foram informadas"
 #: ../locale/scriptstrings/m.proj_to_translate.c:26
 #, fuzzy
 msgid "Include column names in output file"
-msgstr "Não incluir nomes das colunas na saída"
+msgstr "Não incluir nomes das colunas na saída"
 #, fuzzy
@@ -24813,7 +24813,7 @@
 msgid ""
 "r.mapcalc expression for temporal and spatial analysis of space time raster "
 "datasets"
 #: ../locale/scriptstrings/t.rast.algebra_to_translate.c:12
 #: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:13
@@ -24830,7 +24830,7 @@
 #: ../locale/scriptstrings/t.info_to_translate.c:1
 #, fuzzy
 msgid "Lists information about space time datasets and maps."
-msgstr "Relata informação sobre o raster de entrada e encerra"
+msgstr "Relata informação sobre o raster de entrada e encerra"
 #: ../locale/scriptstrings/t.info_to_translate.c:6
 #, fuzzy
@@ -24842,12 +24842,12 @@
 msgid ""
 "Print history information in human readable shell style for space time "
 "datasets"
-msgstr "Suprimir impressão de cabeçalho"
+msgstr "Suprimir impressão de cabeçalho"
 #: ../locale/scriptstrings/t.info_to_translate.c:11
 #, fuzzy
 msgid "Print information about the temporal DBMI interface and exit"
 #: ../locale/scriptstrings/t.vect.export_to_translate.c:1
 #, fuzzy
@@ -24868,12 +24868,12 @@
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:8
 #, fuzzy
 msgid "Compression method of the tar archive"
-msgstr "Nível de Compactação do arquivo PNG"
+msgstr "Nível de Compactação do arquivo PNG"
 #: ../locale/scriptstrings/t.vect.export_to_translate.c:9
 #, fuzzy
 msgid "The export format of a single vector map"
 #: ../locale/scriptstrings/t.vect.export_to_translate.c:10
 msgid "Supported are GML via v.out.ogr and the GRASS package format of v.pack"
@@ -24887,7 +24887,7 @@
 #, fuzzy
 msgid "Color using standard deviation bands"
 msgstr ""
-"médias e desvio-padrões para %d banda %s\n"
+"médias e desvio-padrões para %d banda %s\n"
 "\n"
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
@@ -24897,12 +24897,12 @@
 #: ../locale/scriptstrings/d.to.rast_to_translate.c:1
 #, fuzzy
 msgid "Saves the contents of the active display monitor to a raster map."
-msgstr "Substitui o conteúdo do quadro ativo com a cor definida pelo usuário"
+msgstr "Substitui o conteúdo do quadro ativo com a cor definida pelo usuário"
 #: ../locale/scriptstrings/d.redraw_to_translate.c:1
 #, fuzzy
 msgid "Redraws the content of currently selected monitor."
 #, fuzzy
@@ -24916,19 +24916,19 @@
 msgid ""
 "Algebraic expression for temporal and spatial analysis of space time 3D "
 "raster datasets"
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
 #, fuzzy
 msgid ""
 "Reclasses a raster map greater or less than user specified area size (in "
 "hectares)."
-msgstr "mapear menos área em"
+msgstr "mapear menos área em"
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
 #, fuzzy
 msgid "Value option that sets the area size limit (in hectares)"
-msgstr "área"
+msgstr "área"
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
@@ -24936,7 +24936,7 @@
 #: ../locale/scriptstrings/v.to.lines_to_translate.c:8
 #, fuzzy
 msgid "Area"
-msgstr "Área\n"
+msgstr "Área\n"
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
 msgid "Lesser or greater than specified value"
@@ -24945,7 +24945,7 @@
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:9
 #, fuzzy
 msgid "Method used for reclassification"
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:11
 #, fuzzy
@@ -24955,7 +24955,7 @@
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:12
 #, fuzzy
 msgid "Clumps including diagonal neighbors"
-msgstr "Excluir as células sem valores numéricos"
+msgstr "Excluir as células sem valores numéricos"
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
 msgid ""
@@ -24976,7 +24976,7 @@
 #, fuzzy
 msgid "Column number of z coordinates in input file"
 msgstr ""
-"Número da coluna usada como coordenada x (primeira coluna é 1) para o modo "
+"Número da coluna usada como coordenada x (primeira coluna é 1) para o modo "
 "de pontos"
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:26
@@ -24997,7 +24997,7 @@
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:35
 #, fuzzy
 msgid "Number of parallel processes to launch"
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
 #, fuzzy
@@ -25009,7 +25009,7 @@
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
 #, fuzzy
 msgid "Name of new attribute table (default: vector map name)"
-msgstr "Nome de atributo padrão mapear"
+msgstr "Nome de atributo padrão mapear"
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
@@ -25017,12 +25017,12 @@
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:12
 #, fuzzy
 msgid "Definition"
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
 #, fuzzy
 msgid "Layer number where to add new attribute table"
-msgstr "Não criar tabela de atributo."
+msgstr "Não criar tabela de atributo."
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:10
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
@@ -25035,7 +25035,7 @@
 msgid ""
 "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
 "PRECISION and DATE. Example: 'label varchar(250), value integer'"
-msgstr "de tipos ativo banco de dados todos Suporte NÚM.INT"
+msgstr "de tipos ativo banco de dados todos Suporte NÚM.INT"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:1
 #, fuzzy
@@ -25045,7 +25045,7 @@
 #: ../locale/scriptstrings/v.db.update_to_translate.c:5
 #, fuzzy
 msgid "Name of attribute column to update"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:6
 msgid "Literal value to update the column with"
@@ -25083,7 +25083,7 @@
 msgid ""
 "Imports raster data into a GRASS raster map using GDAL library and "
 "reprojects on the fly."
 #: ../locale/scriptstrings/r.import_to_translate.c:5
 #, fuzzy
@@ -25093,12 +25093,12 @@
 #: ../locale/scriptstrings/r.import_to_translate.c:7
 #, fuzzy
 msgid "Input band(s) to select (default is all bands)"
 #: ../locale/scriptstrings/r.import_to_translate.c:13
 #, fuzzy
 msgid "Resampling method to use for reprojection"
 #: ../locale/scriptstrings/r.import_to_translate.c:14
 msgid ""
@@ -25111,34 +25111,34 @@
 #: ../locale/scriptstrings/r.import_to_translate.c:16
 #, fuzzy
 msgid "Output raster map extent"
 #: ../locale/scriptstrings/r.import_to_translate.c:17
 #, fuzzy
 msgid "region;extent of current region;input;extent of input map"
 #: ../locale/scriptstrings/r.import_to_translate.c:19
 #, fuzzy
 msgid "Resolution of output raster map (default: estimated)"
-msgstr "Resolução do mapa de saída"
+msgstr "Resolução do mapa de saída"
 #: ../locale/scriptstrings/r.import_to_translate.c:20
 #, fuzzy
 msgid ""
 "estimated;estimated resolution;value;user-specified resolution;region;"
 "current region resolution"
 #: ../locale/scriptstrings/r.import_to_translate.c:22
 #, fuzzy
 msgid "Resolution of output raster map (use with option resolution=value)"
 #: ../locale/scriptstrings/r.import_to_translate.c:26
 #, fuzzy
 msgid "Estimate resolution only"
-msgstr "Resolução"
+msgstr "Resolução"
 #: ../locale/scriptstrings/t.shift_to_translate.c:1
 #, fuzzy
@@ -25218,25 +25218,25 @@
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:17
 #, fuzzy
 msgid "Shell script format"
-msgstr "Mostra as estatísticas em estilo shell script"
+msgstr "Mostra as estatísticas em estilo shell script"
 #: ../locale/scriptstrings/g.search.modules_to_translate.c:19
 #, fuzzy
 msgid "JSON format"
-msgstr "Formato de saída"
+msgstr "Formato de saída"
 #: ../locale/scriptstrings/db.univar_to_translate.c:1
 #, fuzzy
 msgid "Calculates univariate statistics on selected table column."
 msgstr ""
-"Calcula estatísticas univariada das células não nulas de um mapa raster."
+"Calcula estatísticas univariada das células não nulas de um mapa raster."
 #: ../locale/scriptstrings/db.univar_to_translate.c:5
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
 #, fuzzy
 msgid ""
 "Name of attribute column on which to calculate statistics (must be numeric)"
-msgstr "ativo para calcular numérico"
+msgstr "ativo para calcular numérico"
 #: ../locale/scriptstrings/db.univar_to_translate.c:7
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:7
@@ -25247,12 +25247,12 @@
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:8
 #, fuzzy
 msgid "Print stats in shell script style"
 #: ../locale/scriptstrings/r.grow_to_translate.c:1
 #, fuzzy
 msgid "Generates a raster map layer with contiguous areas grown by one cell."
 #: ../locale/scriptstrings/r.grow_to_translate.c:5
 #, fuzzy
@@ -25266,11 +25266,11 @@
 #: ../locale/scriptstrings/r.grow_to_translate.c:8
 msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
-msgstr "Valor para escrever para as células não-nulas (-1 => NULL)"
+msgstr "Valor para escrever para as células não-nulas (-1 => NULL)"
 #: ../locale/scriptstrings/r.grow_to_translate.c:9
 msgid "Value to write for \"grown\" cells"
-msgstr "Valor para escrever para as células crescidas"
+msgstr "Valor para escrever para as células crescidas"
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
 #, fuzzy
@@ -25278,7 +25278,7 @@
 "Calculates univariate statistics from a raster map based on a vector map and "
 "uploads statistics to new attribute columns."
 msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
 #, fuzzy
@@ -25288,17 +25288,17 @@
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
 #, fuzzy
 msgid "Name of input raster map to calculate statistics from"
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
 #, fuzzy
 msgid "Column prefix for new attribute columns"
-msgstr "Coluna de atributo numérico"
+msgstr "Coluna de atributo numérico"
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:10
 #, fuzzy
 msgid "The methods to use"
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:11
 #, fuzzy
@@ -25310,7 +25310,7 @@
 msgid ""
 "Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
 "datasets."
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
 msgid "r3.mapcalc expression applied to each time step of the sampled data"
@@ -25328,7 +25328,7 @@
 #: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
 #, fuzzy
 msgid "Name of uncompressed geonames file (with .txt extension)"
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:1
 #, fuzzy
@@ -25336,18 +25336,18 @@
 "Calculates univariate statistics on selected table column for a GRASS vector "
 "map."
 msgstr ""
 #: ../locale/scriptstrings/v.centroids_to_translate.c:1
 #, fuzzy
 msgid "Adds missing centroids to closed boundaries."
-msgstr "não consegui atualizar limites"
+msgstr "não consegui atualizar limites"
 #: ../locale/scriptstrings/v.centroids_to_translate.c:3
 #: ../vector/v.category/main.c:691
 #, fuzzy
 msgid "centroid"
-msgstr "%-5d centróides lidos\n"
+msgstr "%-5d centróides lidos\n"
 #: ../locale/scriptstrings/v.centroids_to_translate.c:4
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:4
@@ -25356,12 +25356,12 @@
 #: ../vector/v.category/main.c:695 ../vector/v.buffer/main.c:223
 #, fuzzy
 msgid "area"
-msgstr "Área\n"
+msgstr "Área\n"
 #: ../locale/scriptstrings/v.centroids_to_translate.c:5
 #, fuzzy
 msgid "Action to be taken"
-msgstr "ícone para remover"
+msgstr "ícone para remover"
 #: ../locale/scriptstrings/v.centroids_to_translate.c:6
 #, fuzzy
@@ -25385,7 +25385,7 @@
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
 #, fuzzy
 msgid "Table name (default: vector map name)"
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
 #, fuzzy
@@ -25393,13 +25393,13 @@
 "Stores raster map values at spatial and temporal positions of vector points "
 "as vector attributes."
 msgstr ""
-"Atualizar na tabela os valores do raster nas posições dos pontos vetoriais"
+"Atualizar na tabela os valores do raster nas posições dos pontos vetoriais"
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
 #, fuzzy
 msgid ""
 "Name of the vector column to be created and to store sampled raster values"
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:7
 msgid ""
@@ -25508,7 +25508,7 @@
 #: ../locale/scriptstrings/r.shade_to_translate.c:11
 #, fuzzy
 msgid "Percent to brighten"
-msgstr "Convergência percentual"
+msgstr "Convergência percentual"
 #: ../locale/scriptstrings/t.rast.contour_to_translate.c:1
 #, fuzzy
@@ -25540,7 +25540,7 @@
 #: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:14
 #, fuzzy
 msgid "Do not create attribute tables"
 #: ../locale/scriptstrings/t.vect.algebra_to_translate.c:1
 #, fuzzy
@@ -25552,7 +25552,7 @@
 #: ../locale/scriptstrings/d.correlate_to_translate.c:1
 #, fuzzy
 msgid "Prints a graph of the correlation between raster maps (in pairs)."
-msgstr "gráfico de entre em"
+msgstr "gráfico de entre em"
 #: ../locale/scriptstrings/d.correlate_to_translate.c:5
 #: ../locale/scriptstrings/d.polar_to_translate.c:3
@@ -25563,18 +25563,18 @@
 #: ../locale/scriptstrings/d.correlate_to_translate.c:6
 #, fuzzy
 msgid "correlation"
-msgstr "Correlação"
+msgstr "Correlação"
 #: ../locale/scriptstrings/d.out.file_to_translate.c:1
 #, fuzzy
 msgid "Saves the contents of the active display monitor to a graphics file."
 #: ../locale/scriptstrings/d.out.file_to_translate.c:5
 #: ../misc/m.nviz.image/args.c:105
 #, fuzzy
 msgid "Graphics file format"
-msgstr "Gráficos"
+msgstr "Gráficos"
 #: ../locale/scriptstrings/d.out.file_to_translate.c:6
 #, fuzzy
@@ -25645,7 +25645,7 @@
 #: ../locale/scriptstrings/t.register_to_translate.c:1
 #, fuzzy
 msgid "Registers raster, vector and raster3d maps in a space time datasets."
 #: ../locale/scriptstrings/t.register_to_translate.c:4
 #, fuzzy
@@ -25694,7 +25694,7 @@
 #: ../locale/scriptstrings/t.register_to_translate.c:19
 #, fuzzy
 msgid "Time stamp unit"
 #: ../locale/scriptstrings/t.register_to_translate.c:20
 msgid "Unit must be set in case of relative time stamps"
@@ -25725,7 +25725,7 @@
 #: ../locale/scriptstrings/v.report_to_translate.c:1
 #, fuzzy
 msgid "Reports geometry statistics for vector maps."
-msgstr "Relatório de estatísticas para mapas raster."
+msgstr "Relatório de estatísticas para mapas raster."
 #: ../locale/scriptstrings/v.report_to_translate.c:6
 #, fuzzy
@@ -25773,7 +25773,7 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:8
 #, fuzzy
 msgid "Name of extension to install or remove"
 #: ../locale/scriptstrings/g.extension_to_translate.c:9
 msgid "Name of toolbox (set of extensions) when -t flag is given"
@@ -25802,21 +25802,21 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:15
 #, fuzzy
 msgid "List available extensions in the official GRASS GIS Addons repository"
-msgstr "Lista camadas disponíveis e finaliza"
+msgstr "Lista camadas disponíveis e finaliza"
 #: ../locale/scriptstrings/g.extension_to_translate.c:17
 #, fuzzy
 msgid ""
 "List available extensions in the official GRASS GIS Addons repository "
 "including module description"
 #: ../locale/scriptstrings/g.extension_to_translate.c:19
 #, fuzzy
 msgid ""
 "List available extensions in the official GRASS GIS Addons repository (shell "
 "script style)"
 #: ../locale/scriptstrings/g.extension_to_translate.c:21
 msgid "List locally installed extensions"
@@ -25848,7 +25848,7 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:31
 #, fuzzy
 msgid "Operate on toolboxes instead of single modules (experimental)"
-msgstr "tabelas do sistema ao invés de tabelas do usuário"
+msgstr "tabelas do sistema ao invés de tabelas do usuário"
 #: ../locale/scriptstrings/t.snap_to_translate.c:1
 #, fuzzy
@@ -25862,7 +25862,7 @@
 #: ../locale/scriptstrings/r.blend_to_translate.c:1
 #, fuzzy
 msgid "Blends color components of two raster maps by a given ratio."
-msgstr "de relação"
+msgstr "de relação"
 #: ../locale/scriptstrings/r.blend_to_translate.c:4
 #, fuzzy
@@ -25877,7 +25877,7 @@
 #: ../locale/scriptstrings/r.blend_to_translate.c:6
 #, fuzzy
 msgid "Basename for red, green and blue output raster maps"
-msgstr "Nome do mapa raster de saída"
+msgstr "Nome do mapa raster de saída"
 #: ../locale/scriptstrings/r.blend_to_translate.c:7
 #, fuzzy
@@ -25925,7 +25925,7 @@
 #: ../locale/scriptstrings/db.droptable_to_translate.c:1
 #, fuzzy
 msgid "Drops an attribute table."
 #: ../locale/scriptstrings/db.droptable_to_translate.c:4
 #: ../locale/scriptstrings/db.dropcolumn_to_translate.c:4
@@ -25936,7 +25936,7 @@
 #: ../locale/scriptstrings/db.droptable_to_translate.c:5
 #, fuzzy
 msgid "Name of database driver"
-msgstr "Nome do arquivo de rótulos"
+msgstr "Nome do arquivo de rótulos"
 #: ../locale/scriptstrings/db.droptable_to_translate.c:6
 #, fuzzy
@@ -25956,7 +25956,7 @@
 #: ../locale/scriptstrings/db.droptable_to_translate.c:11
 #, fuzzy
 msgid "Name of table to drop"
-msgstr "Camada de pesquisa. Usada pela opção 'query'."
+msgstr "Camada de pesquisa. Usada pela opção 'query'."
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
 #, fuzzy
@@ -25971,7 +25971,7 @@
 #: ../locale/scriptstrings/d.polar_to_translate.c:1
 #, fuzzy
 msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr "de ângulo mapear aspecto"
+msgstr "de ângulo mapear aspecto"
 #: ../locale/scriptstrings/d.polar_to_translate.c:4
 #, fuzzy
@@ -25986,7 +25986,7 @@
 #: ../locale/scriptstrings/d.polar_to_translate.c:6
 #, fuzzy
 msgid "Name for optional EPS output file"
-msgstr "Nome do arquivo vetor de saída"
+msgstr "Nome do arquivo vetor de saída"
 #: ../locale/scriptstrings/d.polar_to_translate.c:7
 msgid "Plot using Xgraph"
@@ -25998,7 +25998,7 @@
 "Calculates univariate statistics from the non-null cells for each registered "
 "raster map of a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:10
 msgid ""
@@ -26014,7 +26014,7 @@
 #: ../locale/scriptstrings/t.vect.univar_to_translate.c:11
 #, fuzzy
 msgid "Suppress printing of column names"
 #: ../locale/scriptstrings/t.unregister_to_translate.c:1
 msgid ""
@@ -26034,7 +26034,7 @@
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:1
 #, fuzzy
 msgid "Exports space time raster dataset."
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:6
 #, fuzzy
@@ -26044,7 +26044,7 @@
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:9
 #, fuzzy
 msgid "The export format of a single raster map"
-msgstr "Gera estatísticas areais para os mapas raster."
+msgstr "Gera estatísticas areais para os mapas raster."
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:10
 msgid ""
@@ -26063,7 +26063,7 @@
 "Dissolves boundaries between adjacent areas sharing a common category number "
 "or attribute."
 msgstr ""
-"Nenhuma tabela de atributos encontrada -> usando apenas números de "
+"Nenhuma tabela de atributos encontrada -> usando apenas números de "
 "categorias como atributos"
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:3
@@ -26074,12 +26074,12 @@
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:6
 #, fuzzy
 msgid "Layer number or name."
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:7
 #, fuzzy
 msgid "Name of attribute column used to dissolve common boundaries"
 #: ../locale/scriptstrings/r.plane_to_translate.c:1
 #, fuzzy
@@ -26091,7 +26091,7 @@
 #: ../locale/scriptstrings/r.plane_to_translate.c:4
 #, fuzzy
 msgid "Dip of plane in degrees"
-msgstr "Ângulo de anisotropia (em graus)"
+msgstr "Ângulo de anisotropia (em graus)"
 #: ../locale/scriptstrings/r.plane_to_translate.c:5
 #, fuzzy
@@ -26133,7 +26133,7 @@
 #: ../general/g.remove/main.c:71
 #, fuzzy
 msgid "remove"
-msgstr "Removendo centróides duplicados ..."
+msgstr "Removendo centróides duplicados ..."
 #: ../locale/scriptstrings/t.remove_to_translate.c:7
 msgid "Type of the space time dataset, default is strds"
@@ -26164,17 +26164,17 @@
 #: ../locale/scriptstrings/t.topology_to_translate.c:1
 #, fuzzy
 msgid "Lists temporal topology of a space time dataset."
-msgstr "Mostra matriz de correlação"
+msgstr "Mostra matriz de correlação"
 #: ../locale/scriptstrings/t.topology_to_translate.c:7
 #, fuzzy
 msgid "Print temporal topological relationships and exit"
 #: ../locale/scriptstrings/t.topology_to_translate.c:8
 #, fuzzy
 msgid "Print spatio-temporal topological relationships and exit"
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
 msgid "This is the low-memory alternative to the classic r.buffer module."
@@ -26204,17 +26204,17 @@
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
 #, fuzzy
 msgid "Minimum size of each cell"
-msgstr "Isosuperfície mínima"
+msgstr "Isosuperfície mínima"
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
 #, fuzzy
 msgid "Maximum number of rows to load"
-msgstr "Número máximo de iterações: %d\n"
+msgstr "Número máximo de iterações: %d\n"
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
 #, fuzzy
 msgid "Maximum number of columns to load"
 #: ../locale/scriptstrings/d.what.vect_to_translate.c:1
 #, fuzzy
@@ -26226,7 +26226,7 @@
 #: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
 #, fuzzy
 msgid "Drops a column from selected attribute table."
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
 #, fuzzy
@@ -26236,7 +26236,7 @@
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
 #, fuzzy
 msgid "Spline tension parameter"
-msgstr "Parâmetros de tensão"
+msgstr "Parâmetros de tensão"
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:9
@@ -26245,12 +26245,12 @@
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:15
 #, fuzzy
 msgid "RST options"
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:8
 #, fuzzy
 msgid "Spline smoothing parameter"
-msgstr "Parâmetro de suavização"
+msgstr "Parâmetro de suavização"
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:10
 msgid "Width of hole edge used for interpolation (in cells)"
@@ -26260,13 +26260,13 @@
 #: ../vector/v.surf.rst/main.c:292 ../vector/v.vol.rst/main.c:319
 #, fuzzy
 msgid "Minimum number of points for approximation in a segment (>segmax)"
-msgstr "Número mínimo de pontos para interpolação (> segmax)"
+msgstr "Número mínimo de pontos para interpolação (> segmax)"
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:14
 #: ../vector/v.surf.rst/main.c:283 ../vector/v.vol.rst/main.c:310
 #, fuzzy
 msgid "Maximum number of points in a segment"
-msgstr "Número máximo de pontos num segmento"
+msgstr "Número máximo de pontos num segmento"
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:17
 #, fuzzy
@@ -26276,7 +26276,7 @@
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:18
 #, fuzzy
 msgid "Spline options"
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
 #, fuzzy
@@ -26286,7 +26286,7 @@
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
 #, fuzzy
 msgid "GRASS table name"
-msgstr "Nome da tabela de saída"
+msgstr "Nome da tabela de saída"
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
 #, fuzzy
@@ -26301,7 +26301,7 @@
 #: ../locale/scriptstrings/db.out.ogr_to_translate.c:8
 #, fuzzy
 msgid "Name for output table (default: input name)"
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
 #, fuzzy
@@ -26325,12 +26325,12 @@
 #: ../locale/scriptstrings/r.tileset_to_translate.c:4
 #, fuzzy
 msgid "Produces shell script output"
-msgstr "Arquivo de saída PostScript"
+msgstr "Arquivo de saída PostScript"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:5
 #, fuzzy
 msgid "Produces web map server query string output"
-msgstr "mapear servidor seqüência"
+msgstr "mapear servidor seqüência"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:6
 #, fuzzy
@@ -26352,22 +26352,22 @@
 #: ../locale/scriptstrings/r.tileset_to_translate.c:9
 #, fuzzy
 msgid "Destination projection, defaults to this location's projection"
-msgstr "Sobrescrever projeção (usar projeção da locação)"
+msgstr "Sobrescrever projeção (usar projeção da locação)"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:11
 #, fuzzy
 msgid "Maximum number of columns for a tile in the source projection"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:12
 #, fuzzy
 msgid "Maximum number of rows for a tile in the source projection"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:13
 #, fuzzy
 msgid "Number of cells tiles should overlap in each direction"
-msgstr "Número de níveis a usar para componente"
+msgstr "Número de níveis a usar para componente"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:14
 msgid "Output field separator"
@@ -26399,7 +26399,7 @@
 #: ../vector/v.what.rast3/main.c:87 ../vector/v.what.rast/main.c:98
 #, fuzzy
 msgid "Name of attribute column to be updated with the query result"
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:12
 #, fuzzy
@@ -26418,19 +26418,19 @@
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:15
 #, fuzzy
 msgid "Name of attribute column to be queried"
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:16
 #, fuzzy
 msgid "Maximum query distance in map units"
-msgstr "Distância do buffer (em unidades do mapa)"
+msgstr "Distância do buffer (em unidades do mapa)"
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
 #, fuzzy
 msgid ""
 "Reconnects attribute tables for all vector maps from the current mapset to a "
 "new database."
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
 msgid "Copy attribute tables to the target database if not exist"
@@ -26501,12 +26501,12 @@
 "Uploads space time raster dataset values at positions of vector points to "
 "the table."
 msgstr ""
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:9
 #, fuzzy
 msgid "Update attribute table of input vector map"
-msgstr "Não consegui abrir mapa raster [%s]."
+msgstr "Não consegui abrir mapa raster [%s]."
 #: ../locale/scriptstrings/v.what.strds_to_translate.c:10
 msgid ""
@@ -26517,7 +26517,7 @@
 #, fuzzy
 msgid "Displays a raster map and its legend on a graphics window"
 msgstr ""
-"Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
+"Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
 #: ../display/d.title/main.c:50 ../display/d.vect.chart/main.c:64
@@ -26544,12 +26544,12 @@
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
 #, fuzzy
 msgid "Omit entries with missing label"
-msgstr "Pula categorias sem rótulos"
+msgstr "Pula categorias sem rótulos"
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
 #, fuzzy
 msgid "Name of raster map to display"
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:8
 #: ../display/d.legend/main.c:272
@@ -26559,7 +26559,7 @@
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:9
 #, fuzzy
 msgid "Number of lines to appear in the legend"
-msgstr "Número de vezes para repetir o filtro"
+msgstr "Número de vezes para repetir o filtro"
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:10
 #, fuzzy
@@ -26582,26 +26582,26 @@
 #, fuzzy
 msgid "Either a standard color name, R:G:B triplet, or \"none\""
 msgstr ""
-"Cor do fundo, tanto uma cor padrão do GRASS como uma triplete R:G:B, ou "
+"Cor do fundo, tanto uma cor padrão do GRASS como uma triplete R:G:B, ou "
 "\"none\""
 #: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
 #, fuzzy
 msgid ""
 "Prints attributes of vector maps registered in a space time vector dataset."
 #: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
 #: ../vector/v.extract/main.c:79 ../vector/v.decimate/main.c:128
 #: ../vector/v.outlier/main.c:72
 #, fuzzy
 msgid "select"
-msgstr "Resolução"
+msgstr "Resolução"
 #: ../locale/scriptstrings/t.rast3d.list_to_translate.c:1
 #, fuzzy
 msgid "Lists registered maps of a space time raster3d dataset."
 #: ../locale/scriptstrings/t.rast3d.list_to_translate.c:8
 #, fuzzy
@@ -26624,12 +26624,12 @@
 #: ../locale/scriptstrings/r.unpack_to_translate.c:6
 #, fuzzy
 msgid "Name for output raster map (default: taken from input file internals)"
-msgstr "Título do raster de saída"
+msgstr "Título do raster de saída"
 #: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
 #, fuzzy
 msgid "Imports SPOT VGT NDVI data into a raster map."
-msgstr "Importar um arquivo raster binário para uma camada raster do GRASS."
+msgstr "Importar um arquivo raster binário para uma camada raster do GRASS."
 #: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
 #, fuzzy
@@ -26644,7 +26644,7 @@
 #: ../locale/scriptstrings/t.vect.list_to_translate.c:1
 #, fuzzy
 msgid "Lists registered maps of a space time vector dataset."
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:1
 #, fuzzy
@@ -26675,7 +26675,7 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:40
 #, fuzzy
 msgid "Map style"
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:10
 #, fuzzy
@@ -26713,17 +26713,17 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:17
 #, fuzzy
 msgid "WMS standard version"
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:19
 #, fuzzy
 msgid "Maximum columns to request at a time"
-msgstr "Máximo para"
+msgstr "Máximo para"
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:21
 #, fuzzy
 msgid "Maximum rows to request at a time"
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:23
 #, fuzzy
@@ -26733,7 +26733,7 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:25
 #, fuzzy
 msgid "Username for server connection"
-msgstr "Não consegui criar a tabela %s"
+msgstr "Não consegui criar a tabela %s"
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:27
 msgid "Password for server connection"
@@ -26742,7 +26742,7 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:29
 #, fuzzy
 msgid "Interpolation method to use in reprojection"
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:30
 msgid "Request data for this named region instead of the current region bounds"
@@ -26823,7 +26823,7 @@
 #: ../locale/scriptstrings/i.colors.enhance_to_translate.c:9
 #, fuzzy
 msgid "Cropping intensity (upper brightness level)"
-msgstr "superior nível"
+msgstr "superior nível"
 #: ../locale/scriptstrings/i.colors.enhance_to_translate.c:10
 #, fuzzy
@@ -26868,22 +26868,22 @@
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
 #, fuzzy
 msgid "Imports SRTM HGT files into raster map."
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
 #, fuzzy
 msgid "Name of SRTM input tile (file without .hgt.zip extension)"
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
 #, fuzzy
 msgid "Name for output raster map (default: input tile)"
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
 #, fuzzy
 msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
-msgstr "Entrada é padrão"
+msgstr "Entrada é padrão"
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
 #, fuzzy
@@ -26910,7 +26910,7 @@
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
 #, fuzzy
 msgid "Maximum number of features to download"
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:10
 msgid "(default: unlimited)"
@@ -26945,7 +26945,7 @@
 "Performs different aggregation algorithms from r.series on all or a subset "
 "of raster maps in a space time raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:9
 #, fuzzy
@@ -26957,12 +26957,12 @@
 #: ../locale/scriptstrings/i.oif_to_translate.c:1
 #, fuzzy
 msgid "Calculates Optimum-Index-Factor table for spectral bands"
-msgstr "Sumário Fator"
+msgstr "Sumário Fator"
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:1
 #, fuzzy
 msgid "Exports space time raster dataset as VTK time series."
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:5
 msgid "VTK"
@@ -26971,12 +26971,12 @@
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:7
 #, fuzzy
 msgid "Path to the export directory"
-msgstr "Nome do arquivo de saída"
+msgstr "Nome do arquivo de saída"
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
 #: ../vector/v.out.vtk/main.c:84
 msgid "Correct the coordinates to fit the VTK-OpenGL precision"
-msgstr "Corrija as coordenadas para coincidir com a precisão VTK-OpenGL"
+msgstr "Corrija as coordenadas para coincidir com a precisão VTK-OpenGL"
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:11
 msgid ""
@@ -27031,7 +27031,7 @@
 #: ../locale/scriptstrings/t.create_to_translate.c:4
 #, fuzzy
 msgid "create"
 #: ../locale/scriptstrings/t.create_to_translate.c:6
 #, fuzzy
@@ -27041,7 +27041,7 @@
 #: ../locale/scriptstrings/t.rast.list_to_translate.c:1
 #, fuzzy
 msgid "Lists registered maps of a space time raster dataset."
 #: ../locale/scriptstrings/t.rast.list_to_translate.c:13
 msgid ""
@@ -27059,12 +27059,12 @@
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
 #, fuzzy
 msgid "Name of color table (see r.color help)"
-msgstr "Erro na definição de cor na coluna GRASSRGB, área %d com cat %d"
+msgstr "Erro na definição de cor na coluna GRASSRGB, área %d com cat %d"
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:1
 #, fuzzy
 msgid "Imports E00 file into a vector map."
-msgstr "Não consegui obter informações de camada para o mapa vetorial"
+msgstr "Não consegui obter informações de camada para o mapa vetorial"
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:4
 msgid "E00"
@@ -27083,7 +27083,7 @@
 #: ../locale/scriptstrings/v.pack_to_translate.c:5
 #, fuzzy
 msgid "Name of vector map to pack up"
-msgstr "Nome do mapa de orientação para exibição"
+msgstr "Nome do mapa de orientação para exibição"
 #: ../locale/scriptstrings/v.db.join_to_translate.c:1
 #, fuzzy
@@ -27093,7 +27093,7 @@
 #: ../locale/scriptstrings/v.db.join_to_translate.c:5
 #, fuzzy
 msgid "Vector map to which to join other table"
 #: ../locale/scriptstrings/v.db.join_to_translate.c:7
 #, fuzzy
@@ -27107,7 +27107,7 @@
 #: ../locale/scriptstrings/v.db.join_to_translate.c:10
 #, fuzzy
 msgid "Other table name"
 #: ../locale/scriptstrings/v.db.join_to_translate.c:11
 #, fuzzy
@@ -27121,14 +27121,14 @@
 #: ../locale/scriptstrings/v.db.join_to_translate.c:13
 #, fuzzy
 msgid "Subset of columns from the other table"
 #: ../locale/scriptstrings/t.sample_to_translate.c:1
 #, fuzzy
 msgid ""
 "Samples the input space time dataset(s) with a sample space time dataset and "
 "print the result to stdout."
 #: ../locale/scriptstrings/t.sample_to_translate.c:5
 #, fuzzy
@@ -27164,7 +27164,7 @@
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
 #, fuzzy
 msgid "Name of attribute column(s) to drop"
-msgstr "Número de colunas"
+msgstr "Número de colunas"
 #: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:1
 #, fuzzy
@@ -27172,20 +27172,20 @@
 "3D raster map of a space time 3D raster dataset."
 msgstr ""
 #: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
 #, fuzzy
 msgid "Removes a vector feature from a vector map through attribute selection."
 msgstr ""
-"Mostra/seleciona conexão no BD entre um mapa vetorial e tabela de atributos"
+"Mostra/seleciona conexão no BD entre um mapa vetorial e tabela de atributos"
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:1
 #, fuzzy
 msgid ""
 "Aggregates temporally the maps of a space time raster dataset by a user "
 "defined granularity."
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:7
 msgid ""
@@ -27202,7 +27202,7 @@
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:12
 #, fuzzy
 msgid "Number of r.series processes to run in parallel"
-msgstr "Número de pontos de interpolação"
+msgstr "Número de pontos de interpolação"
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:13
 msgid "The maximum number of open files allowed for each r.series process"
@@ -27217,7 +27217,7 @@
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:9
 #, fuzzy
 msgid "Number of interpolation processes to run in parallel"
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:10
 msgid ""
@@ -27228,7 +27228,7 @@
 #, fuzzy
 msgid "Converts vector polygons or points to lines."
 msgstr ""
-"Converte um mapa vetorial binário do GRASS (apenas pontos) numa camada "
+"Converte um mapa vetorial binário do GRASS (apenas pontos) numa camada "
 "raster 3D do GRASS."
 #: ../locale/scriptstrings/v.to.lines_to_translate.c:7
@@ -27240,17 +27240,17 @@
 #, fuzzy
 msgid ""
 "Performs a neighborhood analysis for each map in a space time raster dataset."
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:11
 #, fuzzy
 msgid "Number of r.neighbor processes to run in parallel"
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:13
 #, fuzzy
 msgid "Ignore the current region settings and use the raster map regions"
-msgstr "Alinhar a região atual pelo mapa de entrada"
+msgstr "Alinhar a região atual pelo mapa de entrada"
 #, fuzzy
@@ -27258,7 +27258,7 @@
 "Calculates univariate statistics of attributes for each registered vector "
 "map of a space time vector dataset"
 msgstr ""
 #: ../temporal/t.connect/main.c:35 ../display/d.fontlist/main.c:46
 #: ../display/d.colorlist/main.c:36 ../display/d.font/main.c:46
@@ -27272,7 +27272,7 @@
 #, fuzzy
 msgid ""
 "Prints/sets general temporal GIS database connection for current mapset."
-msgstr "Mostra/seleciona conexão ao BD para o mapset atual"
+msgstr "Mostra/seleciona conexão ao BD para o mapset atual"
 #: ../temporal/t.connect/main.c:54
 #, fuzzy
@@ -27282,12 +27282,12 @@
 #: ../temporal/t.connect/main.c:59
 #, fuzzy
 msgid "Print current connection parameter in shell style and exit"
-msgstr "mostra os parâmetros de conexão atuais e finaliza"
+msgstr "mostra os parâmetros de conexão atuais e finaliza"
 #: ../temporal/t.connect/main.c:83 ../temporal/t.connect/main.c:95
 #, fuzzy
 msgid "Temporal GIS database connection not defined. Run t.connect."
-msgstr "Conexão do mapa <%s> com banco de dados não definida no arquivo DB"
+msgstr "Conexão do mapa <%s> com banco de dados não definida no arquivo DB"
 #: ../temporal/t.connect/main.c:111
 #, c-format
@@ -27312,7 +27312,7 @@
 msgid ""
 "Erases the contents of the active graphics display frame with user defined "
 "color."
 #: ../display/d.erase/main.c:42
 msgid "Remove all frames and erase the screen"
@@ -27331,12 +27331,12 @@
 #: ../display/d.title/main.c:71
 #, fuzzy
 msgid "Sets the text size as percentage of the frame's height"
-msgstr "Altura das letras em porcentagem da altura disponível do quadro"
+msgstr "Altura das letras em porcentagem da altura disponível do quadro"
 #: ../display/d.title/main.c:75
 #, fuzzy
 msgid "Draw title on current display"
-msgstr "Não consegui abrir display"
+msgstr "Não consegui abrir display"
 #: ../display/d.title/main.c:79
 msgid "Do a fancier title"
@@ -27353,12 +27353,12 @@
 #: ../display/d.title/main.c:105
 #, fuzzy
 msgid "No map name given"
-msgstr "Mapa(s) de entrada não especificado(s)."
+msgstr "Mapa(s) de entrada não especificado(s)."
 #: ../display/d.rast.num/main.c:78 ../display/d.rast.arrow/main.c:98
 #, fuzzy
 msgid "map annotations"
-msgstr "Mostrar informação topológica (depuração)"
+msgstr "Mostrar informação topológica (depuração)"
 #: ../display/d.rast.num/main.c:81
 #, fuzzy
@@ -27366,8 +27366,8 @@
 "Overlays cell category values on a raster map displayed in the active "
 "graphics frame."
 msgstr ""
-"Sobrepõe valores de categorias em um mapa raster no quadro ativo do monitor "
-"gráfico."
+"Sobrepõe valores de categorias em um mapa raster no quadro ativo do monitor "
+"gráfico."
 #: ../display/d.rast.num/main.c:88 ../display/d.rhumbline/main.c:62
 #: ../display/d.northarrow/main.c:113 ../display/d.geodesic/main.c:66
@@ -27389,7 +27389,7 @@
 #: ../display/d.rast.num/main.c:112
 msgid "Get text color from cell color value"
-msgstr "Usar cor do texto a partir da cor da célula"
+msgstr "Usar cor do texto a partir da cor da célula"
 #: ../display/d.rast.num/main.c:119 ../display/d.text/main.c:222
 #: ../display/d.vect/main.c:265 ../display/d.legend.vect/main.c:115
@@ -27436,7 +27436,7 @@
 "Current region size: %s X %s\n"
 "Your current region setting may be too large. Cells displayed on your "
 "graphics window may be too small for cell category number to be visible."
-msgstr "atual definição Células ativo célula para."
+msgstr "atual definição Células ativo célula para."
 #: ../display/d.rast.num/main.c:212
 msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
@@ -27445,7 +27445,7 @@
 #: ../display/d.info/main.c:38
 #, fuzzy
 msgid "Displays information about the active display monitor."
-msgstr "Mostra informações sobre o monitor gráfico atual"
+msgstr "Mostra informações sobre o monitor gráfico atual"
 #: ../display/d.info/main.c:40
 msgid "Display monitors are maintained by d.mon."
@@ -27454,7 +27454,7 @@
 #: ../display/d.info/main.c:45
 #, fuzzy
 msgid "Display screen rectangle (left, right, top, bottom)"
-msgstr "Mostra retângulo na tela"
+msgstr "Mostra retângulo na tela"
 #: ../display/d.info/main.c:49
 #, fuzzy
@@ -27464,7 +27464,7 @@
 #: ../display/d.info/main.c:53
 #, fuzzy
 msgid "Display active frame rectangle"
 #: ../display/d.info/main.c:57
 #, fuzzy
@@ -27474,7 +27474,7 @@
 #: ../display/d.info/main.c:61
 #, fuzzy
 msgid "Display screen rectangle of current region"
 #: ../display/d.info/main.c:66
 msgid "Display geographic coordinates and resolution of entire frame"
@@ -27484,7 +27484,7 @@
 #: ../vector/v.in.db/main.c:225
 #, fuzzy, c-format
 msgid "Unable to open select cursor: '%s'"
-msgstr "Não consegui abrir cursor de seleção: '%s'"
+msgstr "Não consegui abrir cursor de seleção: '%s'"
 #: ../display/d.vect.chart/main.c:65
 #, fuzzy
@@ -27495,12 +27495,12 @@
 #, fuzzy
 msgid ""
 "Displays charts of vector data in the active frame on the graphics monitor."
-msgstr "Exibir dados vetoriais do GRASS no quadro ativo do monitor gráfico"
+msgstr "Exibir dados vetoriais do GRASS no quadro ativo do monitor gráfico"
 #: ../display/d.vect.chart/main.c:86
 #, fuzzy
 msgid "Chart type"
 #: ../display/d.vect.chart/main.c:87 ../display/d.vect.chart/main.c:97
 #: ../display/d.vect.chart/main.c:105 ../display/d.vect.chart/main.c:112
@@ -27508,7 +27508,7 @@
 #: ../display/d.vect.chart/main.c:129 ../display/d.vect.chart/main.c:148
 #, fuzzy
 msgid "Chart properties"
 #: ../display/d.vect.chart/main.c:91
 #, fuzzy
@@ -27518,11 +27518,11 @@
 #: ../display/d.vect.chart/main.c:96
 #, fuzzy
 msgid "Column used for pie chart size"
-msgstr "Coluna usada para o tamanho do gráfico pizza"
+msgstr "Coluna usada para o tamanho do gráfico pizza"
 #: ../display/d.vect.chart/main.c:104
 msgid "Size of chart (diameter for pie, total width for bar)"
-msgstr "Tamanho do gráfivo (diâmetro da pizza, largura total para barras)"
+msgstr "Tamanho do gráfivo (diâmetro da pizza, largura total para barras)"
 #: ../display/d.vect.chart/main.c:111
 #, fuzzy
@@ -27536,17 +27536,17 @@
 #: ../display/d.vect.chart/main.c:122
 msgid "Colors used to fill charts"
-msgstr "Cores usadas para preencher os gráficos"
+msgstr "Cores usadas para preencher os gráficos"
 #: ../display/d.vect.chart/main.c:128
 #, fuzzy
 msgid "Center the bar chart around a data point"
-msgstr "Centralizar o gráfico sobre o ponto de dados"
+msgstr "Centralizar o gráfico sobre o ponto de dados"
 #: ../display/d.vect.chart/main.c:137
 #, fuzzy
 msgid "Maximum value used for bar plot reference"
-msgstr "Maior valor usado como referência do gráfico de barras"
+msgstr "Maior valor usado como referência do gráfico de barras"
 #: ../display/d.vect.chart/main.c:142 ../display/d.vect.thematic/main.c:223
 msgid "Create legend information and send to stdout"
@@ -27555,7 +27555,7 @@
 #: ../display/d.vect.chart/main.c:147
 #, fuzzy
 msgid "Create 3D charts"
-msgstr "Criar saída 3D"
+msgstr "Criar saída 3D"
 #: ../display/d.vect.thematic/main.c:87
 #, fuzzy
@@ -27566,17 +27566,17 @@
 #, fuzzy
 msgid "Displays a thematic vector map in the active graphics frame."
 msgstr ""
-"Exibe três mapas raster selecionados pelo usuário como bandas vermelha, "
-"verde e azul no quadro gráfico atual"
+"Exibe três mapas raster selecionados pelo usuário como bandas vermelha, "
+"verde e azul no quadro gráfico atual"
 #: ../display/d.vect.thematic/main.c:97
 msgid "Layer number. If -1, all layers are displayed."
-msgstr "Número da camada. Se -1, todas as camadas serão exibidas"
+msgstr "Número da camada. Se -1, todas as camadas serão exibidas"
 #: ../display/d.vect.thematic/main.c:103
 #, fuzzy
 msgid "Name of attribute column to be classified"
 #: ../display/d.vect.thematic/main.c:110
 msgid "Class breaks, without minimum and maximum"
@@ -27586,27 +27586,27 @@
 #: ../display/d.vect.thematic/main.c:137
 #, fuzzy
 msgid "Classes"
 #: ../display/d.vect.thematic/main.c:119 ../vector/v.class/main.c:68
 #, fuzzy
 msgid "Algorithm to use for classification"
-msgstr "Assinaturas para usar na classificação"
+msgstr "Assinaturas para usar na classificação"
 #: ../display/d.vect.thematic/main.c:123 ../vector/v.class/main.c:76
 #, fuzzy
 msgid "simple intervals"
 #: ../display/d.vect.thematic/main.c:124 ../vector/v.class/main.c:77
 #, fuzzy
 msgid "standard deviations"
-msgstr "Desvio padrão"
+msgstr "Desvio padrão"
 #: ../display/d.vect.thematic/main.c:125 ../vector/v.class/main.c:78
 #, fuzzy
 msgid "quantiles"
-msgstr "Cópia da tabela falhou"
+msgstr "Cópia da tabela falhou"
 #: ../display/d.vect.thematic/main.c:126 ../vector/v.class/main.c:79
 msgid "equiprobable (normal distribution)"
@@ -27615,7 +27615,7 @@
 #: ../display/d.vect.thematic/main.c:136 ../vector/v.class/main.c:88
 #, fuzzy
 msgid "Number of classes to define"
-msgstr "Número de cópias"
+msgstr "Número de cópias"
 #: ../disp
