installing problem on SUN-sparc2
Darrell McCauley mccauley at ecn.purdue.edu
Thu Oct 8 22:13:20 EDT 1992
[replies directed to grassp-list]
> % man dlsym
> DLOPEN(3X)       MISCELLANEOUS LIBRARY FUNCTIONS       DLOPEN(3X)
> NAME
>      dlopen, dlsym, dlerror, dlclose - simple programmatic inter-
*>      face to the dynamic linker             (problemmattic?)
>      These functions are obtained by specifying -ldl as an option
>      to ld(1).
Peter,
I've noticed this with compilation of other software and have never seen
this problem before Sun OS 4.1.1, but the work around is to edit the
Gmakefile in the directory where it bombed and add the -ldl in the
appropriate spot.  If you find this problem with other directories,
then you may want to edit src/CMD/head/*
Can someone check the bug list for Sun OS 4.1.1 and see if this is
on there?
--Darrell
> Hello
> excuse me with bothering with this problem - maybe it can be a simple
> one.
> I am trying to instal GRASs on SUN sparc2 with mono monitor.
> I did :    1. setup program
>            2. edited the list of config.
>            3. started the GISGEN - after aprx . 50 min it came
>               with a problem  - I try to retype it
>               (my Sun is not in network yet )
>          it was : at
>          make -f OBJ/make.rules
>          cc -s OBJ/splitfont.c  OBJ/fontmap.o -o splitfont
>          ld: Undefined symbols
>              _dlopen
>              _dlclose
>              _dlsym
>           Error code 2
> error at target splitfont
>          failure at STEP: fonts/for_grass
>       Any kind of help would be nice - I admit I am begginer at
> Sun and Unix. Thank you very much in advance
> please mail directly to KUKO at CSPUNI12.bitnet
> Peter Sincak
