installing problem on SUN-sparc2
Joachim Wiesel
wiesel at ipf.bau-verm.uni-karlsruhe.de
Fri Oct 9 10:51:31 EDT 1992
According to Darrell McCauley:
> [replies directed to grassp-list]
> > % man dlsym
> > DLOPEN(3X) MISCELLANEOUS LIBRARY FUNCTIONS DLOPEN(3X)
> > NAME
> > dlopen, dlsym, dlerror, dlclose - simple programmatic inter-
> *> face to the dynamic linker (problemmattic?)
> > These functions are obtained by specifying -ldl as an option
> > to ld(1).
> Peter,
> I've noticed this with compilation of other software and have never seen
> this problem before Sun OS 4.1.1, but the work around is to edit the
> Gmakefile in the directory where it bombed and add the -ldl in the
> appropriate spot. If you find this problem with other directories,
> then you may want to edit src/CMD/head/*
> Can someone check the bug list for Sun OS 4.1.1 and see if this is
> on there?
...stuff deleted ...
As far as I can tell you ... this is a 'ld' bug introduced at Sunos 4.1.2.
There should be a bug fix for that from SUN (or use the 4.1.1 ld ...).
Joachim
Joachim Wiesel, Institut fuer Photogrammetrie und Fernerkundung,
Universitaet Karlsruhe, Englerstr. 7, D-7500 Karlsruhe, Germany
Phone: +49 721 608 2316 Fax: +49 721 694 568
Internet: wiesel at ipf.bau-verm.uni-karlsruhe.de
