xgrass, multiple users
    Simon Cox
    simon at artemis.earth.monash.edu.au
    Sun Dec 19 10:42:05 EST 1993
1.  My my - I didn't realise that there were so many frustrated
potential xgrass users out there!  Here are extracts from my
installation notes dealing with xgrass.  This is almost certainly
not comprehensive, but I hope that it assists folk:
SJDC  30/6/93
xgrass installation
Can't use gmake scripts because we do not have Motif locally
Use the binaries distributed from CERL
Grabbed binaries, and unpacked.
Moved xgrass4.1 (script) and xgdatabases (script) to $UNIX_BIN
Renamed $UNIX_BIN/xgrass4.1 to xgrass
Moved bin/x* to $GISBASE/bin
Moved etc/xg*.exe to $GISBASE/etc
Moved etc/xgrass-menu to $GISBASE/etc
Moved etc/XGIS.sh to $GISBASE/etc
Moved etc/xclip/* to $GISBASE/etc/xclip
Moved etc/xhelp/* to $GISBASE/etc/xhelp
Moved etc/app-defaults/* to $GISBASE/etc/app-defaults
NB there is a disfunctional version of xgrass-menu
in etc/xclip which should be AVOIDED
Users may want to
copy etc/xgrass-menu to .xgrass-menu in home directory
set environment variables $GIS $GISBASE $GISDBASE
run "xgdatabases" to set up database lists
add a couple of lines to the .Xdefaults file
	Mwm*keyboardFocusPolicy:pointer
	Mwm*interactivePlacement:False
SJDC  30/6/93
SJDC  14/8/93
Another item found in the installation manual:
appended $GIS/src/xgrass/XKeysymDB to /usr/openwin/lib/XKeysymDB
SJDC  14/8/93
2.  Multiple users:  > From grass-lists-owner at max.cecer.army.mil Sat Dec 18
10:41:38 1993
> Return-Path: <grass-lists-owner at max.cecer.army.mil>
> From: "Mark P. Line" <markline at henson.cc.wwu.edu>
> Subject: Re: xgrass, multiple users and photos
> Sender: grass-lists-owner at max.cecer.army.mil
> Reply-To: grassp-list at max.cecer.army.mil
> In-Reply-To: <9312170641.AA11450 at artemis.earth.monash.edu.au>
> Mime-Version: 1.0
> Content-Type> : > TEXT/PLAIN> ; > charset=US-ASCII>
> X-Lines: 41
> Mark Line writes
> On Fri, 17 Dec 1993, Simon Cox wrote:
> > Chris Skelly wrote:
