> > (btw, does anyone else think that "g.manual" a little long for a > > command name? :-) > It would really be great if the horrible > ``option=name1,name2'' command line arguments would replaced for > unix syntax. > It is UNIX syntax. Unfortunately the syntax it follows is the dd command. :-)
