Concurrent d.rast
Conn Copas
cvc at itd.dsto.gov.au
Tue Jul 5 21:27:27 EDT 1994
Martin writes about my problems with running several 'd.rast' commands
concurrently:
1) Is there any reason why you shouldn't use one monitor with multiple
> frames?
Yes, by writing to frames I will lose basic window manager facilities such as
being able to reposition individual monitors. However, I must confess that I
don't understand why this should make a difference to my problem. Surely,
concurrent 'd.rast' processes will still be involved?
> 2) If your <map1> and <map2> are in different regions, that might cause
> trouble...
All maps are in the same region. I guess my main questions are whether I have
struck some limitation with GRASS, whether the problem is due to the use of
an outdated X driver, or whether our installation process is the culprit. Any
clues?
Conn V Copas
Information Technology Division
Defence Science and Technology Organisation
PO Box 1500
Salisbury tel: +61 (0)8 25 95349
SA 5108 fax: +61 (0)8 25 96781
Australia e-mail: cvc at itd.dsto.gov.au
