Limits of GRASS
charnotw charnotw at helios.aston.ac.uk
Mon Jun 27 10:12:22 EDT 1994
> From grass-lists-owner at max.cecer.army.mil Fri Jun 24 18:15 BST 1994
Steve Culshaw writes:
> GRASS's r.in.ascii reports an error 'Error: Data conversion failed at row
> 5562, col 253'
I usually get this error when the input ascii file has been cut off for some reason,  usually I've run out of file space when ftp'ing new data onto the system.   I don't think it is a GRASS size limit as I regular use rasters larger than this.
cheers   Tom   :-)
Tom Charnock                       O--O
Dept Civil Engineering            (~~~~)
Aston University                 (  __  )
Birmingham B4 7ET UK             /|\  /|\
charnotw at sun.aston.ac.uk
