[GRASS5] Re: [GRASSLIST:1299] Re: Grass 5b10 make clean
Eric G . Miller egm2 at jps.net
Thu Dec 21 04:14:25 EST 2000
On Thu, Dec 21, 2000 at 03:51:08PM +0700, Justin Hickey wrote:
> The problem is not that the clean directories touch the installed files.
> The problem is that the installation directories and the build
> directories are under the *same physical directory*. I am now in the
That's your choice.  I have grass sources under /usr/local/src/grass,
but the binaries are in /usr/local/grass5.  So they are not in the same
directory tree (well, /usr/local ;).
> testing phase of the proposal I made earlier for a new Makefile that
> will separate the build and installation directories. Now that the
> directories are separate, the clean targets do not touch the
> installation directory and there is an uninstall target to remove the
> installation files. Hopefully I'll be able to check in the new system
> tomorrow for people to test.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
