[GRASS5] Makefiles, autoconf, etc.
Eric Mitchell
emitchell at altaira.com
Fri Jul 28 21:57:46 EDT 2000
Ok, I've tried to summarize my thoughts on the current makefile
setup, where it should head, and how to get there below.
I'll take a look at the new beta8 code to see how hard this
will be to implement and report back next week.
Please comment in gory detail.
Whereas:
1) "make" should build targets. "make install" should copy
them to their destinations. This is how the majority of
projects out there operate. The current build setup uses
a collection of scripts to build grass using Gmakefiles.
Properly constructed Makefiles are sufficient to build grass
and all of its support libraries.
2) The standard usage of autoconf/automake takes forever to
configure with many automake constructed makefiles. Running
sed with several dozen substitutions, on several dozen
template files takes forever. It would be better to restrict
the substitutions to a handful of files, and include the
platform specific files from each Makefile.
3) Any build solution for a module product must allow easy
use by external module developers. A template Makefile
structure should be provided that can be customized for use
by extensions.
4) Libraries should be built as shared libs when possible.
This results in greater filesystem cache hits, as each
executable program hits the same chunk of disk space. This
in turn results in improved program performance. This also
results in less disk usage for the installed program.
I propose the following solution:
[background: we use the following layout to build The Product
(tm) at work. It's a satellite control automation tool. (I
just play with grass in my all too rare spare time) It runs
on HP-UX, IRIX, Linux, WinNT, and Solaris. It integrates
three major external toolkits (visualization, corba, scripting)
from three different vendors. This make strategy works well,
provided a couple MAKE variables are set properly.
Separate platform independent makefile components from the
standard set of make rules, and common make variable
definitions. Basically, you divide standard make stuff into
"Grass.make" (defines standard make variables like target
directory, etc.), "Platform.make" (encapsulates platform
specific stuff), and "Rules.make" (define standard make rules).
In addition, common target makefiles (e.g. "Lib.make",
"Shlib.make", "Progs.make") can be included for convenient
creation of common target types.
# sample makefile
include $(GRASS_SRC)/include/Make/Grass.make
include $(GRASS_SRC)/include/Make/Platform.make
include $(GRASS_SRC)/include/Make/Rules.make
LIBNAME = sdts
include $(GRASS_SRC)/include/Make/Shlib.make
# end of sample
This is all that's required to build a shared library,
provided that Platform.make is configured properly.
By careful selection of default, but overridable rules
and parameters, it's easy to extend this to programs,
and static libs.
Thoughts? Comments? Flames?
-- ebm
| Eric B. Mitchell mailto:emitchell at altaira.com |
| tel: (301) 809 - 3534 Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122 Bowie, MD 20716 |
,___
/"\ / o=\ /"""---===/
/ \_/ \__/ ---===/
| //\ || /""TT""/ //\ || ||""\
| // \ || || // \ || ||__/
| //--==\ |L--/ || //--==\ || || "=,
\____---===/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
