[GRASS5] GRASS 5 beta 8 to be published this week
Andreas Lange
Andreas.Lange at Rhein-Main.de
Tue Jul 25 06:14:34 EDT 2000
Hi developers, Hi Markus,
is the problem with the void pointer arithmetics in segment lib (file
get_row.c) solved?
What about compiling on IRIX? Has someone succeeded in compiling beta8
from CVS on IRIX? I had no luck and got no response until now.
Sorry, i am busy with other projects right now so that i am not able to
verify my changes for datum support. Everything is ready for release,
but i couldn't run a test with known data/verify against another
implementation.
I would propose to wait some more days so that we can incorporate some
more fixes in beta8.
Another observation: The d.mon -L bug only occurs on Linux, on IRIX
everything is ok. I read the code and experimented with it, but i
couldn't find the problem. This is something for the signal
specialists/system programmers from BSD and SYSV.
cu,
Andreas
Markus Neteler wrote:
> Dear developers,
> if you agree, we should publish GRASS 5 beta8 by
> Wednesday this week.
> Is this o.k. with you?
> I will prepare the Linux binaries and build them on Wednesday
> morning. But we need volunteers for
> - SGI
> - Solaris
> - DEC/Alpha64
> If possible, please build the binaries from CVS on Wednesday to
> store them on the GRASS web site. You can anonymous ftp to
> ftp 130.75.72.14 (that's the WWW here)
> cd incoming
> Note: This directory is *write* only.
> Thanks!
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
