[GRASS5] grass names changing
John Huddleston jhuddleston at itc.nrcs.usda.gov
Tue May 30 12:27:59 EDT 2000
FYI,
Markus and I are in the process of changing files names
that are the same for upper/lower case.   This is because
windows cannot distinguish between the two.   You will
notice some messages from the cvs command about files
being updated and others being removed because of this.
A 'cvs update -A' brings out the most recent and removes
older ones.  Markus has changed the Gmakefiles to reflect
these changes.
John Huddleston, P.E.
Computer Engineer
USDA - NRCS
John.Huddleston at usda.gov
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
