[GRASS5] configure doesn't find MATHLIB
Markus Neteler
neteler at geog.uni-hannover.de
Thu Nov 30 07:37:06 EST 2000
On Thu, Nov 30, 2000 at 12:53:17PM +0100, mlennert at club.worldonline.be wrote:
> Hello,
> Trying to compile the latest CVS tree, configure doesn't seem to be able to
> find the mathlib (I get @MATHLIB@). And it doesn't seem to be the only library
> not found. libm.a is in /usr/lib, so it should be found. Where does configure
> check for the libs ?
Moritz,
the configure is just updated. Please
cvs update configure.in
Then run
autoconf
configure
and it should be o.k. (check in src/CMD/head/head)
If not, please report again.
Thanks
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
