[GRASS5] Re; [GRASS] Re: [GRASSLIST:1116] compiling postgres modules (fwd)
John Huddleston jhudd at lamar.colostate.edu
Tue Nov 28 10:05:02 EST 2000
Moritz and Justin, (Grass list)
Yes, there is a very quick way to see if you have a TAG'd version
checked out.  Look into the CVS subdirectory and the Entries file.
After the very last forward slash, there will be no value if it is the
current or HEAD value.  If it is checked out with a TAG or release
number (which is the same thing as a tag) then you will see /T...
where ... is the tag name.
For instance, for a 'thatfile' which has more than one revision, do the following:
grep thatfile CVS/Entries
cvs update -r1.1 thatfile
cvs update -A thatfile
You will be able to see the difference.   The jCVS and the WinCVS
show the TAG in the window if it exists.   Hope that helps.
Regarding the message, cannot open CVS/Entres, you may have
checked out grass using the full command:
cvs -d :ext:user at intevation.de:/grassrepository co grass
In which case, no top level file would have been created.  In this
case change in the grass directory and do the update
cd grass
cvs update -PdA  .
John Huddleston
----- Original Message -----
To: <grass5 at geog.uni-hannover.de>
Sent: Tuesday, November 14, 2000 3:27 AM
Subject: Re: [GRASS5] Re: [GRASSLIST:1116] compiling postgres modules (fwd)
> I'm forwarding this message to the list since there are a few open questions.
> I've actually followed Justin's advice and am reinstalling the entire cvs tree
> on my machine, but for the future it would be nice to know what is wrong...
> Moritz
> ------- Forwarded Message
> Hi Moritz
> mlennert at club.worldonline.be wrote:
> > I'll try that. Is there any way of finding out if  I checked out a
> > tagged tree? I don't think so, but wouldn't swear on it.
> I'm not sure either, but you can ask Bernhard Reiter or John Huddleston.
> Bernhard is the CVS administrator and John seems to be our CVS expert.
> > Justin when I type 'cvs update -PdA grass I get:
> > cvs update: cannot open CVS/Entries for reading: No such file or
> > directory
> > cvs [update aborted]: no repository
> > I don't get this message when I leave out 'grass'. Is this a problem ?
> It always worked for me, so I'm not sure. If you have the time, you
> might consider deleteing your grass tree and checking out the entire
> source again (if you haven't made a lot of changes). I had to do it a
> couple of times myself. I don't know for sure, it's getting out of my
> league now. Perhaps Bernhard and John have better answers for you.
> Sorry.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
