[GRASS5] ps.map grid label fail to appear
Mike Thomas mthomas at gil.com.au
Tue Nov 28 07:13:23 EST 2000
Hi all.
Despite the pessimism  I managed to build Grass under Win 98 today.
First port of call was ps.map, as there is no graphical output under
Windows.
The following ps.map script doesn't produce the results I expected ie there
were no numbers on the grid lines and no copper values next to the sample
points, just small rectangles:
sites copper
  color red
  size 0.100000
  desc y
  end
scale 1:3000
grid 10
 numbers 1
 end
end
The red markers came out OK though.
I can send the ps file and the zipped location if you like.
Cheers
Mike Thomas.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
