[GRASS5] New initialization code
Justin Hickey jhickey at hpcc.nectec.or.th
Tue Nov 28 06:40:11 EST 2000
Hi Andreas
Andreas Lange wrote:
> This will IMHO render the cygwin "port" almost useless, as there is no
> tcltkgrass until now. There is a wish (could not test this right now),
> but it does not work with the tcltkgrass code. I tried to start
> tcltkgrass within the cygwin grass shell, but i got only an error
> window from wish stating that something is wrong. I remember that all
> x11-specific calls will not work with the windows wish, as the
> geometry things are implemented differently.
I assume that the behaviour is the same as before if you use "grass5
-text"? If not, then could you please indicate what the new behaviour
is? I didn't change how tcltkgrass works from the command line so it
should be the same if you start with the old text interface.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
