[GRASS5] configure.in Wants testers...
Justin Hickey
jhickey at hpcc.nectec.or.th
Tue Nov 28 05:33:33 EST 2000
Hi Eric
"Eric G . Miller" wrote:
> Well, the problem really seems to be with the way configure handles
> $bindir. It is always set to something (at least here). Also, my
> autoconf choked on the AC_BINDIR_DEFAULT() macro (claiming no such
> thing exists). $bindir is always apparently set to
> ${exec_prefix}/bin, and ${exec_prefix} is always set to ${prefix}
> (these are defaults). So I can't figure out how to have the --bindir
> command work, but use the /usr/local/bin as a default. Piece of cake
> if I ignore --bindir and go back to using --with-bindir (as it was
> set-up before).
Good news!!! I found the error with the BINDIR stuff in configure.in.
The problem was that the test for $exec_prefix was testing if the
variable existed. Apparently autoconf defines it as NONE. So the test
needs to compare with NONE. I changed the line from:
if test -z "${exec_prefix}"; then
to the following:
if test "${exec_prefix}" = "NONE"; then
And now the following appears in my Makefile after running configure
prefix= /usr/local/grass5
exec_prefix= /usr/local
BINDIR= ${exec_prefix}/bin
I didn't test anything else though (--bindir or --with-bindir)
> As far as the headers and libraries, does it work with the
> --with-tcltk-includes=[DIRs] --with-tcltk-libs=[DIRS] ?
It almost works. I get the following using those two options:
checking for /usr/include/tk.h... no
checking for /usr/include/tcl.h... no
checking TK include dirs... -I/usr/local/include
checking TCL include dirs... -I/usr/local/include
checking additional TCL and TK library dirs... -L/usr/local/lib
checking for Tk_MainWindow in -ltk$(grep #define TCL_VERSION
/usr/local/include/tcl.h | sed -e s/^\(.*\)\"\(.*\)\"$/\2/)...
./configure[3482]: no space
I don't know what is happening here but before it printed the error, it
paused for a while if that means anything.
> Sorry I'm not better at this configure stuff. I'm a lousy shell
> programmer to begin with ;)
No need to apologize. We all are learning things. I'm just happy you had
the guts to tackle this beast in the first place :)
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
