[GRASS5] configure.in Wants testers...
Bernhard Reiter bernhard at intevation.de
Tue Nov 28 05:28:34 EST 2000
On Tue, Nov 28, 2000 at 01:08:00AM -0800, Eric G . Miller wrote:
> On Tue, Nov 28, 2000 at 03:34:39PM +0700, Justin Hickey wrote:
> What I gleaned from the AutoConf docs I have, is that $top_srcdir should
> be used to reference the TOP src directory.  Apparently it's not being
> expanded, so I'll look into a way to make it be forcably expanded.
As I am just happen to fill a bug report for autconf, you might be
interested to read it, though it might not be directly related to your
problem.
It is bug #160  and you can get to the bug database from
	http://sources.redhat.com/autoconf/
The mailinglists there might be another good point for specific autoconf
questions.
Here is the text:
       	There are two kind of preset output variables for Makefiles
        in autoconf. The first kind delivers(@prefix@)
        and the second kind only works if you are actually
        using it in a makefile and have certain other
        variables already defined.
        MY_PATH=@exec_prefix@
        just alone will not work in a Makefile.in, because it
        might get replaced with ${prefix}, so you need at least
        prefix=@prefix@
        this is confusing and inconsistant. I would expect these
        predefined variables for paths just to give me the path
        having done all relevant substitutions already. This way I
        can also use them in other file not just real Makefiles.
        If you think this is the correct behavious it still is a
        documentation bug. There should be a warning that you need to
        have certain variables ready for shell substituion
        if you want to use @exec_prefix@ or @libdir at .
Bernhard
Professional Service around Free Software                (intevation.net)
The FreeGIS Project				            (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
FSF Europe					      (www.fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20001128/a1493fb0/attachment.bin
