[GRASS5] configure.in Wants testers...
Eric G . Miller
egm2 at jps.net
Fri Nov 24 15:15:11 EST 2000
On Fri, Nov 24, 2000 at 06:05:25PM +0000, Markus Neteler wrote:
> Also, note that there doesn't seem to be a good way
> > to have the --bindir default to /usr/local/bin. The macro
> > AC_DEFAULT_BINDIR() was not recognized by my autoconf and the variable
> > $bindir is always set to something (defaulting to ${exec_prefix}/bin,
> > where $exec_prefix defaults to ${prefix} which is set to
> > /usr/local/grass5 by default. Confused?). So, if you want
> > /usr/local/bin for $bindir, you need to specify it. Also, see
> > ./configure --help for some of the options (they need testing too).
> Mhhh, here we have the problem that the start script is neither
> put into /usr/local/bin nor /usr/bin.
> I think we should decide to write it to /usr/bin on default.
> Means: The UNIX_BIN would have to be set differently than prefix.
Well, then we're back to using --with-bindir. Under that, it is
possible to know if the user specified something different than the
defaults set by configure.
> not yet o.k.:
> ODBCINC not yet (not yet implemented, I think)
Ahh, yes, missed that. Not sure what I need to look for.
> TCLINCDIR =
> -> found from configure, but here it's empty (it's in /usr/include)
> TKINCDIR =
> TCLTKLIBS =
/usr/include is in the default search path, so nothing extra should need
to be specified, correct???
> -> *not* found from configure (in /usr/lib)
I'm still struggling with why this works on my system and fails on yours
when the libraries are in the exact same location (and even the version
is the same).
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
