[GRASS5] configure.in Wants testers...
Markus Neteler
neteler at geog.uni-hannover.de
Fri Nov 24 13:05:25 EST 2000
Hi Eric,
thank for your ongoing improvement of configure.in!
Here my report (just updated)
On Thu, Nov 23, 2000 at 09:32:28PM -0800, Eric G . Miller wrote:
> Okay,
> I think I've implemented all of the checks in the hacked configure
> script in configure.in. So, now I need others to test it and give me
> problem reports. I haven't added anything, like searching for libjpeg,
> yet. I want to get the input script at least to where the hacked
> configure script is before I start adding things. Probably there will
> be search paths for things that I didn't think of. Anyway, make a
> backup of the configure script and delete your config.cache before
> running autoconf.
o.k.
Also, note that there doesn't seem to be a good way
> to have the --bindir default to /usr/local/bin. The macro
> AC_DEFAULT_BINDIR() was not recognized by my autoconf and the variable
> $bindir is always set to something (defaulting to ${exec_prefix}/bin,
> where $exec_prefix defaults to ${prefix} which is set to
> /usr/local/grass5 by default. Confused?). So, if you want
> /usr/local/bin for $bindir, you need to specify it. Also, see
> ./configure --help for some of the options (they need testing too).
Mhhh, here we have the problem that the start script is neither
put into /usr/local/bin nor /usr/bin.
I think we should decide to write it to /usr/bin on default.
Means: The UNIX_BIN would have to be set differently than prefix.
DLLIB is o.k.
ZLIB as well,
XDRLIB, too
PostgreSQL, o.k.
openGL o.k.
not yet o.k.:
ODBCINC not yet (not yet implemented, I think)
TCLINCDIR =
-> found from configure, but here it's empty (it's in /usr/include)
TKINCDIR =
TCLTKLIBS =
-> *not* found from configure (in /usr/lib)
Now I will compile...
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
