[GRASS5] Re: bug in configure routine
Justin Hickey
jhickey at hpcc.nectec.or.th
Fri Nov 24 01:46:27 EST 2000
Hi Eric
"Eric G . Miller" wrote:
> On Thu, Nov 23, 2000 at 01:55:54PM +0700, Justin Hickey wrote:
> > Yeah it's strange. On SGI, the XDRLIB is usually -lsun, however, I
> > noticed that a lot of modules were indicating that -lsun wasn't
> > being used when I was compiling. So to determine which modules were
> > dependent
> Does the -lsun "not used" or whatever break the compile or is it just
> an informative message? I'm not sure, but I'd think most modules
> don't need it, but libgis.a does. If libgis.a already has the XDRLIB
> compiled in statically, then maybe the linker just refuses to include
> it twice (good!). But where it is not built into libgis.a, not having
> the flag will cause libgis.a to fail. If it doesn't break the
> compile, I'd rather leave it in for now. Seems at least libgis.a
> would need it, even if the modules don't??? Maybe the functions or
> XDRLIB are built into SGI's C library? I could put in a check before
> the checks for XDRLIB if that is the case. Then I'd feel comfortable
> allowing XDRLIB to be empty.
The libgis.a library compiles and links without error. I checked out the
current CVS, ran configure, and then deleted the -lsun option for XDRLIB
from the head file. Then I ran make install and src/libes/gis did not
report any errors. I don't know why it didn't fail. Perhaps you are
right about the necessary functions being in SGI's standard C library.
Do you know what functions those are?
Here are the modules that caused errors
Module source code not installed: html (ignored)
Module source code not installed: src/general/g.version (ignored)
Module source code not installed: src/raster/r.in.gdal (ignored)
Module source code not installed: src/raster/r.in.png (ignored)
Module source code not installed: src/raster/r.out.png (ignored)
Module source code not installed: src/raster/r.tiff (ignored)
Module source code not installed: src/sites/s.qcount (ignored)
Module source code not installed: src.contrib/UCB/gdbase (ignored)
None of the errors in these modules seem to be caused by the missing
XDRLIB option. Let me know if you want me to try for a clean compile.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
