[GRASS5] Re: bug in configure routine
Bernhard Reiter bernhard at intevation.de
Tue Nov 21 12:39:12 EST 2000
On Wed, Nov 22, 2000 at 01:37:01AM +0900, GRASS wrote:
> From: Jan-Oliver Wagner <jan at intevation.de>
> Subject: Re: [GRASS5] Re: bug in configure routine
> > > Hmm, yes you're right. You can use --with-bindir instead of --bindir.
> > Yes, I have done that to compile GRASS :-)
> > > $bindir, created by --bindir, is not used though defined.
> > > $BINDIR, created by --with-bindir, is used instead.
> > > So i suggest to remove --bindir and other unused options of configure.
> > > Any objection?
> > The configure environment should just behave in a general way
> > (as it is widely used) and be consistent.
> > Jan
> OK, however, those options do not work right now.
> If we want to be consistent, those options should be fixed to work correctly.
> In this case, what should be used if --bindir and --with-bindir both given?
Remove --with-bindir
and make --bindir work.
If I understood everything... :)
	Bernhard
Professional Service around Free Software                (intevation.net)
The FreeGIS Project				            (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20001121/eee91aab/attachment.bin
