[GRASS5] Win32 compile with cygnus
James Cameron
quozl at us.netrek.org
Sun Nov 19 19:36:36 EST 2000
On Sun, Nov 19, 2000 at 08:18:21PM +0100, Andreas Lange wrote:
> depend on the netpbm library. This is always installed on Linux and most
> other Unix.
Not so. On many Linux distributions it is not installed unless some
other product depends on it. It is fairly small (528Kb Intel bin) and
so placing a dependency on it does not seem to me to be a worry.
> I personally think that we shouldn't waste time on re-writing
> r.in.png/r.out.png to remove the dependency on this library, but look
> for a more generic solution for the import of non-georeferenced images.
> I'll check in some thoughts of mine in the next days. I think we should
> look for a general library that handles the usual image formats (png,
> jpeg, etc.).
Last I checked, netpbm is the best for this sort of stuff. Rather than
write a converter from any image format to any other, netpbm solves the
issue by adopting a common intermediate format, and supplying converters
to and from that format.
James Cameron mailto:quozl at us.netrek.org http://quozl.netrek.org/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
