[GRASS5] Jan's copyright notice ++
Markus Neteler neteler at geog.uni-hannover.de
Thu Nov 2 12:59:41 EST 2000
On Thu, Nov 02, 2000 at 11:32:02AM -0500, Frank Warmerdam wrote:
> Andreas Lange wrote:
> > the file header is as such a nice idea. But wouldn't it be possible to
> > get one step further and introduce something that can be processed
> > automated (with some documentation system or something homegrown)?
> > I feel it is a waste of time to re-write the headers (which are from
> > on-liners to several pages of prose) while we have not decided how the
> > future development strategy will be.
> > If we agree that we want the modules have internal information about
> > authors, version, purpose, function, title etc. this should be done in
> > one place/with one system.
> Andreas,
> I think that there is a big difference in effort between settling on a new
> style of header, and applying it to code as touched vs. implementing
> auto-extractable function descriptions which would have to be applied to
> all interesting functions to be of much use.
> > Another question: What should be done with the old comment headers? I am
> > clueless if they must be preserved for license reasons or if the info
> > should be included into the new headers and then discarded.
> I presume we should try to retain information in the PURPOSE field, and
> if the copyright isn't GPL, then retain the copyright information in the
> COPYRIGHT field.
> On the suggested format, I have a few questions.
> * <Id flag - see STYLE_PROGRAMMING for proper syntax>
> * 	               -- GRASS Development Team --
> * MODULE: 	GRASS gis library
> What does MODULE mean?  Is this effectively the directory the files is in?
> Would it be "raster" for src/raster/r.in.gdal?   Please explain more fully.
For the next major release we want to get GRASS modularized. A package
"GRASS-core", "GRASS-hydrology" or something like that.
The idea of "MODULE" (I guess) might be to describe where is file is
located. On the other hand it might be redundant.
> * FILENAME:	env.c
> I hate including filenames in standard headers.  It will be included in the
> $Id$ after exapansion anyways, and filenames in the header that need to be
> hand maintained are often not done properly, and just left with the value
> copied from somewhere else.  I propose this be dropped.
I agree.
> * AUTHOR(S):	Original author unknown - probably CERL
> *  	    	Justin Hickey - Bangkok Thailand - jhickey at hpcc.nectec.or.th
> *   	    	Roger Bivand - rsb at reclus.nhh.no
> * PURPOSE: 	To provide functionality for GRASS programs to set and get
> *  	    	environment variables. The set environment functions can set
> *  	    	variables for the duration of the program, or variables can be
> *  	    	set permanently by adding them to the GISRC file. The get
> *  	    	environment functions simply get the given variable from the
> *  	    	environment regardless of whether it is permanent or not.
> *  	    	Functions are also provided to read and write the GISRC file.
> *  	    	This file has been rewritten by Justin Hickey.
> * DATE CREATED: Jul 14 2000
> What is the purpose of DATE CREATED?   Perhaps it should be dropped.
Might be dropped as $Id$ is already there.
> * COPYRIGHT:  	(C) 2000 by the GRASS Development Team
> *   	    	This program is free software under the GPL (>=v2)
> *   	    	Read the file COPYING that comes with GRASS for details.
> Beyond the above I would like to see capture of log messages automatically.
> I find it enormously useful to be able to scan back through log messages (the
> same messages entered on a CVS commit) when looking at source file.
The problem might be that the files get longer and longer. Is there an
option to restrict the lines (aka versions) to be shown?
> The following is an example of the header style I normally use.  I think the
> most sigificant difference compared to the proposed style is the inclusion of
> the $Log$ section to auto-generate checkin logs.  Could we consider dropping
> DATE CREATED and FILENAME from the existing style, and adding a $Log$ section?
>  * $Id: make_loc.c,v 1.1 2000/10/31 04:39:43 frankw Exp $
>  * Project:  libgrass
>  * Purpose:  Function to create a new location automatically given a
>  *           "Cell_head", PROJ_INFO and PROJ_UNITS information.
>  * Author:   Frank Warmerdam, warmerda at home.com
>  * Copyright (c) 2000, Frank Warmerdam
>  * This library is free software; you can redistribute it and/or
>  * modify it under the terms of the GNU Library General Public
>  * License as published by the Free Software Foundation; either
>  * version 2 of the License, or (at your option) any later version.
>  * This library is distributed in the hope that it will be useful,
>  * but WITHOUT ANY WARRANTY; without even the implied warranty of
>  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
>  * Library General Public License for more details.
>  * You should have received a copy of the GNU Library General Public
>  * License along with this library; if not, write to the
>  * Free Software Foundation, Inc., 59 Temple Place - Suite 330,
>  * Boston, MA 02111-1307, USA.
.. this part is quite long and already put in grass/COPYING.
I would prefer the short version as above for the GPL stuff.
>  * $Log: make_loc.c,v $
>  * Revision 1.1  2000/10/31 04:39:43  frankw
>  * New
Generally it's nice to have the Log here (as being helpful). Only
it's length is a question as we deal with > 18000 files
(see http://www.codecatalog.com/statsProjectFiles.html)
Regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
