[GRASS5] Re: [GRASSLIST:1775] r.in.bin
Bob Covill
bcovill at tekmap.ns.ca
Fri Apr 27 11:19:12 EDT 2001
Jan-Oliver Wagner wrote:
> On Fri, Apr 27, 2001 at 09:30:19AM -0300, Bob Covill wrote:
> > I am not sure I know what the bug is that is being described above. It
> > sounds like there might be a problem with how the signed integers are
> > converted. This was a routine that I took from the original r.in.bin and
> > never really tested too much.
> > However, if it works with one projection and not another (XY & Lat Lon),
> > then there is probably something else wrong.
> > Have you applied your fix to the CVS yet Glynn? If not you could email
> > it to me and I will take a look to see if something jogs my memory.
> I have also a problem with r.in.bin and urgently need your bug fix
> (or I need to fix it on my own).
> $r.in.bin -s input=/opt/geo-data/globe/l10g output=globe bytes=2 north=0 south=-50 east=180 west=90 r=6000 c=10800
> Illegal row value
> This error is relatively new. It was not there a while ago.
> Jan
> Jan-Oliver Wagner http://intevation.de/~jan/
> Intevation GmbH http://intevation.de/
> FreeGIS http://freegis.org/
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Jan,
I have just been duplicating the error you mention above. The problem
seems to be in the auto calculation of rows cols etc.
For a test leave the rows and cols off of the command line, and see if
your data is imported. The program will report the calculated rows and
columns which will hopefully be the same as above.
Let me know if this works, which should help track down the problem.
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
