[GRASS5] Volunteer wanted for CELL driver color problem
Bob Covill
bcovill at tekmap.ns.ca
Wed Apr 18 19:32:52 EDT 2001
Bob Covill wrote:
> Malcolm Blue wrote:
> > Bob,
> > It sounds like your CELL driver is the FIFO version, while d.mon is is the
> > sockets version.
> > Did you compile this yourself? If so check the source code for SWITCHER.c in
> > display/devices/lib vs display/devices/lib/sockets.new and
> > display/devices/lib/fifo.orig (could also check ipc.new). You could also check
> > in XDRIVER/XDRIVER24. I just checked the file sizes to verify that socket.new is
> > different size from fifo.orig version. If your monitor works, and the monitor is
> > using the socket version - which seems likely since that's what d.mon is using,
> > then you should recompile the devices/lib directory and the CELL driver (at
> > least). libes/raster/io.c may be worth checking as well.
> > Depending on what is out of sync you may need to recompile other routines as
> > well.
> > HTH,
> > Malcolm
Malcolm,
Success.
I have tracked down the missing files and built a working version of the
CELL driver. The culprit was the SWITCHER.c in the devices/lib direcory.
I found the correct sockets version and successfully built a working
version of the CELL driver.
Thanks for the help in pointing me in the right direction.
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
