[GRASS5] v.in.arc: import files
Rich Shepard
rshepard at appl-ecosys.com
Tue Apr 17 14:57:54 EDT 2001
On Tue, 17 Apr 2001, David D Gray wrote:
> Some changes to v.in.mif now mean it should open a file given any valid
> unix path name.
> ie. Supply for input a full path, relative path or just a file name of
> *.mif, *.mid or just the base name *.
> Default output is the base name of the file, if `output' is supplied it
> over-rides this. So output would always be an optional parameter.
> Can I suggest this as appropriate default behaviour for any external
> file import?
Works for me.
My comments were prompted by my efforts to run the import modules using
only the source file name. I kept getting a "file not found" error unless I
specified the absolute path name. Shrug. Perhaps it's the drought out here.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
