[GRASS5] Re: Current GDAL problem
Markus Neteler neteler at geog.uni-hannover.de
Tue Apr 17 11:17:07 EDT 2001
On Tue, Apr 17, 2001 at 10:11:40AM -0400, mberglund wrote:
> NVIZ still fails with:
> The papers are available at
> http://www2.gis.uiuc.edu:2280/modviz/
> Unable to load map
> Unable to load map
> Loading Data
> child killed: segmentation violation
>     while executing
> "exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
> /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script elevation=4117ne1.1
> -name NVIZ >&@stdout"
>     ("eval" body line 1)
>     invoked from within
> "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $CMD -name NVIZ >&@stdout
>     (file "/usr/local/grass5/bin/nviz2.2" line 92)
> Finished
> But it should be noted that there is no elevation data for 4117ne1.1, so
> why is it looking for some?
Mhhh, this is also surprising. How did you start nviz?
Perhaps try:
nviz2.2 el=yourelmap
           ^^^^^^^^^ use some correct raster map name
does this work?
Regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
