[GRASS5] error on make r3.showdspf
Panoot Suwanwiwattana
panoot at engineer.com
Sat Apr 7 04:22:03 EDT 2001
Thank you, Clements.
I just delete /GL header file in /usr/X11R6/GL and recompile again. but it
has another error on "../r3.showdspf.opengl/new_init_graphic.c:569:undefined
reference to 'GLwCreateMDrawingArea' "
Is the IIRC problem? and How to install IIRC? I am linux beginner and i know
a little bit about linux.
sincerely yours,
------Original Message------
From: Glynn Clements <glynn.clements at virgin.net>
To: grass5 at geog.uni-hannover.de
Sent: April 7, 2001 7:28:27 AM GMT
Subject: Re: [GRASS5] error on make r3.showdspf
Panoot Suwanwiwattana wrote:
> I try to compile grass5.b12 on my redhat 6.2. I had already installed Mesa
> 3.4.1, LessTif 0.92.26 ,zlib, jpeg-6b and tif 3.5.6.
> After i configure grass, it show me almost 'yes' but
> GLwCreateMDrawingArea in -IGLwM .. no
Do you have this library? IIRC, Mesa doesn't build it by default; you
have to build it separately.
Also, whilst recent versions of XFree86 provide the correct
functionality, the Motif versions are included in libGLw, rather than
being in a separate library. Furthermore, the "configure" test won't
find the necessary function (GLwCreateMDrawingArea) because it is a
macro.
> and sql.h .. no
Do you have UnixODBC installed? iODBC won't work.
> And then i compiled grass, there is no error message now, but when i
compile
> G3d by using gmake5 /src.contrib/GMSL/g3d, it has error on
> r3.showdspf.opengl (detail on attached file)
You have two conflicting sets of OpenGL headers installed, in
/usr/local/include/GL and /usr/X11R6/include/GL.
This is coupled with a bug in r3.showdspf.openGL, in that it includes
OpenGL headers without using the "GL/" prefix, and a complementary bug
in the build process, which is using /usr/local/include/GL as the
include path.
> So how can i solve it?
Either temporarily remove one of the sets of OpenGL headers, or don't
try to build GMSL.
> and if sql.h is not exits, do i have problem with postgresql?
No; PostgreSQL doesn't provide an sql.h file.
Mr.Panoot Suwanwiwattana
Research Assistance
Geotechnical Engineering R&D Center.
Kasetsart University, Thailand.
______________________________________________
FREE Personalized Email at Mail.com
Sign up at http://www.mail.com/?sr=signup
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
