[GRASS5] Re: [winGRASS] libG11 update
Glynn Clements
glynn.clements at virgin.net
Wed Dec 12 09:52:51 EST 2001
Mike Thomas wrote:
> I notice that the resize crashing mentioned in an earlier message seems only
> to occur when I have sites displayed on the monitor. Raster and vector
> combinations eg Speargrass geology with streams and roads do not crash after
> many resizes whereas adding the bugsites to the display will cause a crash
> quickly.
Crashes the monitor?
That seems odd; all the monitor does is to fork() a subprocess which
calls system() for each command which was registered with
D_add_to_list(). It shouldn't make any difference if the commands are
d.vect or d.sites. Does the output of d.save contain anything unusual?
Glynn Clements <glynn.clements at virgin.net>
